- 10-Segment Routing Configuration Guide
- 01-SR-MPLS configuration
- 02-SR-MPLS TE policy configuration
- 03-SRv6 configuration
- 04-SRv6 TE policy configuration
- 05-SRv6 VPN overview
- 06-IP L3VPN over SRv6 configuration
- 07-EVPN L3VPN over SRv6 configuration
- 08-Public network IP over SRv6 configuration
- 09-SRv6 OAM configuration
- 10-EVPN VPLS over SRv6 configuration
- 11-EVPN VPWS over SRv6 configuration
| 00-Preface | 110.49 KB |
Preface
This configuration guide describes the fundamentals and configuration procedures for Segment Routing features, including SR-MPLS, SR-MPLS TE policy,SRv6,SRv6 TE, SRv6 VPN, IP L3VPN over SRv6, EVPN L3VPN over SRv6, Public network IP over SRv6, SRv6 OAM, EVPN VPLS over SRv6, and EVPN VPWS over SRv6.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
