- 05-Layer 2—LAN Switching Configuration Guide
- 01-MAC address table configuration
- 02-Ethernet link aggregation configuration
- 03-M-LAG configuration
- 04-VLAN configuration
- 05-MVRP configuration
- 06-VLAN mapping configuration
- 07-VLAN termination configuration
- 08-Loop detection configuration
- 09-Spanning tree configuration
- 10-LLDP configuration
- 11-PFC configuration
- 12-Service loopback group configuration
- 13-Cut-Through Layer 2 forwarding configuration
| 00-Preface | 110.78 KB |
Preface
This configuration guide describes the LAN switching fundamentals and configuration procedures. It describes how to configure a Layer 2 network in the following aspects:
· Layer 2 traffic control and load sharing.
· Eliminating Layer 2 loops.
· Isolating users within a VLAN and dividing VLANs.
· Modifying VLAN tags of packets.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
