- 07-MPLS Command Reference
- 01-Basic MPLS commands
- 02-Static LSP commands
- 03-LDP commands
- 04-MPLS TE commands
- 05-Static CRLSP commands
- 06-RSVP commands
- 07-Tunnel policy commands
- 08-MPLS L3VPN commands
- 09-IPv6 MPLS L3VPN commands
- 10-MPLS OAM commands
- 11-MCE commands
- 12-VPLS commands
- 13-MPLS L2VPN commands
01-Basic MPLS commands | 255.44 KB |
Basic MPLS commands
display mpls forwarding ilm
Use display mpls forwarding ilm to display Incoming Label Map (ILM) entries.
display mpls forwarding ilm [ label ] [ slot slot-number ]
label: Displays the ILM entry with the specified incoming label. The value range for this argument is 16 to 250000. If you do not specify an incoming label, this command displays ILM entry information for all incoming labels.
slot slot-number: Specifies the slot number of the device, which is fixed at 1.
An ILM entry records the label operation type, outgoing label, and other forwarding information.
After an LSR receives a labeled packet, it performs the following operations:
1. Identifies the ILM entry that matches the top label of the packet.
2. Performs the specified label operation.
3. Forwards the packet.
# Display all ILM entries.
<Sysname> display mpls forwarding ilm
Total ILM entries: 3
Flags: T - Forwarded through a tunnel
N - Forwarded through the outgoing interface to the nexthop IP address
B - Backup forwarding information
A - Active forwarding information
M – P2MP forwarding information
InLabel Oper VRF Flag SwapLabel Forwarding Info
30 SWAP 0 T 1000 1024
1279 POP 0 - - -
1407 SWAP 0 NA 1271 HGE1/0/3 50.2.0.2
NB 1270 Tun0 0.0.0.0
Total ILM entries |
Total number of ILM entries. |
InLabel |
Incoming label. |
Oper |
Operation type: · POP—Pops the label. · POPGO—Pops the label and forwards the packet to another tunnel. · SWAP—Swaps the label. |
VRF |
Index of a VPN instance. |
Flag |
Forwarding flag: · T—Forwarded through a tunnel. · N—Forwarded through the outgoing interface to the next hop IP address. · B—Backup forwarding information. · A—Active forwarding information. · M—P2MP forwarding information. This flag is not supported in the current software version. |
SwapLabel |
Outgoing label value. |
Forwarding Info |
Forwarding information: · When the forwarding flag is N, the forwarding information records the outgoing interface and the next hop. · When the forwarding flag is T, the forwarding information records the NID. |
display mpls forwarding nhlfe
Use display mpls forwarding nhlfe to display Next Hop Label Forwarding Entry (NHLFE) entries.
display mpls forwarding nhlfe [ nid ] [ slot slot-number ]
nid: Displays the NHLFE entry with the specified NID. The NID value range is 0 to 4294967294. If you do not specify an NID, this command displays NHLFE entry information for all NIDs
An NHLFE entry records label forwarding information, such as the outgoing label and outgoing interface. NHLFE entries are mainly used to add multiple labels to packets.
To add multiple labels to a packet, an LSR performs the following operations:
1. Obtains the bottom label and NID in the matching FIB or ILM entry.
2. Obtains the outer label in the NHLFE entry identified by the NID.
# Display the NHLFE entry with NID 2048.
<Sysname> display mpls forwarding nhlfe 2048
S – Secondary backup path
NID Tnl-Type Flag OutLabel Forwarding Info
2048 LSP NA 2025 HGE1/0/2 10.11.112.26
# Display all NHLFE entries.
Total NHLFE entries: 5
10 - TA - 2049
20 - TA - 2050
2049 LSP NA 3024 HGE1/0/2 10.11.112.26
TB 3026 20
2050 LSP NA 3025 HGE1/0/1 10.11.113.26
Total NHLFE entries |
Total number of NHLFE entries. |
NID |
NHLFE entry index. |
Tnl-Type |
Tunnel type: · LOCAL—Direct LSP tunnel. · LSP—Static LSP tunnel, or LSP tunnel signaled using LDP or BGP. · TE—TE tunnel. · CRLSP—Static CRLSP tunnel or CRLSP tunnel signaled using RSVP. · SRLSP—Static SRLSP tunnel or SRLSP tunnel signaled using IS-IS or OSPF. · SRPolicy—SR-MPLS TE policy tunnel. · SRPSIDs—Tunnel corresponding to SR-MPLS TE policy SIDs. · SRPGroup—Tunnel corresponding to SR-MPLS TE policy group. This field displays a hyphen (-) if the tunnel type is invalid. |
Flag |
Forwarding flag: · T—Forwarded through a tunnel. · N—Forwarded through the outgoing interface to the next hop IP address. · B—Backup forwarding information. · A—Active forwarding information. · M—P2MP forwarding information. This flag is not supported in the current software version. · S—The second backup tunnel. |
OutLabel |
Outgoing label. |
Forwarding Info |
display mpls interface
Use display mpls interface to display MPLS interface information, including the interface name, interface status, and interface MPLS MTU.
display mpls interface [ interface-type interface-number ]
interface-type interface-number: Specifies an interface by the interface type and number. If you do not specify an interface, this command displays MPLS information for all MPLS-enabled interfaces.
# Display all MPLS interfaces.
<Sysname> display mpls interface
Interface Status MPLS MTU
HGE1/0/1 Up 1500
HGE1/0/2 Up 1500
Interface name. |
Status |
Interface state. |
MPLS MTU |
MPLS MTU (in bytes) of the interface. This field displays a hyphen (-) if the interface is not configured with an MPLS MTU. |
mpls enable
mpls mtu
display mpls label
Use display mpls label to display MPLS label usage information.
display mpls label { label-value1 [ to label-value2 ] | all }
label-value1: Specifies a label value. The value range for this argument is 16 to 250000. If used with the label-value2 argument, the label-value1 argument represents the start label of a label range.
to label-value2: Specifies the end label of the label range. The value range for the end label is 16 to 250000. If you specify a label range by using the label-value1 argument and the to label-value2 option, this command displays usage information for the specified range of labels.
all: Specifies all labels.
# Display usage information for labels 1025 through 1027.
<Sysname> display mpls label 1025 to 1027
Label Owner State
1025 LDP Alloc
1026 LDP Alloc
1027 LDP Inuse
Label |
Label value. |
Owner |
Protocol that is using the label: · Static—Static LSP. · LDP. · BGP. · StaticCR—Static CRLSP or static SRLSP. · RSVP. · ISIS. · OSPF. This field displays a hyphen (-) when the label state is Idle. |
State |
Usage state of the label: · Idle—The label is idle. · Alloc—The label has been allocated. · Pending—The label has been released but is still used by an LSP entry. · Inuse—The label has been allocated and used by an LSP entry. |
display mpls lsp
Use display mpls lsp to display LSP information.
display mpls lsp [ egress | in-label label-value | ingress | outgoing-interface interface-type interface-number | protocol { bgp | isis | ldp | local | ospf | rsvp-te [ p2mp ] | sr-policy | sr-te | static | static-cr } | transit ] [ vpn-instance vpn-instance-name ] [ ipv4-address mask-length | ipv6 [ ipv6-address prefix-length ] ] [ verbose ]
egress: Displays the LSPs taking the current LSR as egress.
in-label label-value: Displays the LSPs using the specified label as the incoming label. The value range for the label-value argument is 0 to 250000.
ingress: Displays the LSPs taking the current LSR as ingress.
outgoing-interface interface-type interface-number: Displays the LSPs using the specified interface as the outgoing interface. The interface-type interface-number argument specifies an interface by its type and number.
protocol: Displays the LSPs established by a protocol.
bgp: Displays BGP LSPs.
isis: Displays IS-IS SRLSPs.
ldp: Displays LDP LSPs.
local: Displays LSPs destined for the direct next hops, or displays LSPs that use the local MPLS TE tunnel interfaces or tunnel bundle interfaces as the LSP heads.
ospf: Displays OSPF SRLSPs.
rsvp-te: Displays CRLSPs established by RSVP-TE.
p2mp: Displays P2MP CRLSPs established by RSVP-TE. If you do not specify this keyword, the command displays information about P2P CRLSPs and P2MP CRLSPs established by RSVP-TE.
sr-policy: Displays SRLSPs established by SR-MPLS TE policies.
sr-te: Displays SRLSPs established by SR-TE.
static: Displays static LSPs.
static-cr: Displays static CRLSPs and static SRLSPs.
transit: Displays the LSPs taking the current LSR as a transit LSR.
vpn-instance vpn-instance-name: Displays LSPs for the specified MPLS L3VPN instance. The vpn-instance-name is a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays LSPs for the public network.
ipv4-address mask-length: Displays the IPv4 LSP for an FEC specified by an IPv4 address and a mask length. The value range for the mask length is 0 to 32.
ipv6: Displays IPv6 LSP information. If you do not specify this keyword, the command displays IPv4 LSP information.
ipv6-address prefix-length: Displays the IPv6 LSP for an FEC specified by an IPv6 address and a prefix length. The value range for the prefix length is 0 to 128.
verbose: Displays detailed LSP information. If you do not specify this keyword, the command displays brief LSP information.
If you do not specify any parameters, this command displays brief information about all LSPs. If you specify only the verbose keyword, this command displays detailed information about all LSPs.
# Display brief information about all IPv4 LSPs.
<Sysname> display mpls lsp
FEC Proto In/Out Label Out Inter/NHLFE/LSINDEX
100.100.100.100/24 LDP -/1049 HGE1/0/1
Backup -/1050 HGE1/0/2
100.100.100.10/24 LDP -/1051 HGE1/0/3
100.100.100.10/24 LDP -/1049 HGE1/0/4
101.100.100.10/24 LDP 1026/1049 HGE1/0/1
102.100.100.10/24 LDP 1027/- -
103.100.100.10/24 LDP 1028/1049 Tunnel10
110.100.100.20/24 BGP -/1049 HGE1/0/1
111.100.100.10/24 BGP 2028/1049 HGE1/0/1
112.100.100.10/24 BGP 2029/- HGE1/0/1
113.100.100.10/24 BGP 2030/1049 NHLFE1500
114.100.100.10/24 BGP 2031/1050 Tunnel100
100.100.100.100 Local -/- HGE1/0/1
101.101.101.101/32 Static -/100 HGE1/0/1
- Static 100/200 HGE1/0/1
- Static 101/- HGE1/0/1
200.200.200.200/64000/64000 RSVP -/1030 HGE1/0/5
201.200.200.200/64000/64000 RSVP 1024/1031 HGE1/0/5
202.200.200.200/64000/64000 RSVP 1025/- -
150.140.150.100/64001/0 StaticCR -/1000 HGE1/0/5
- StaticCR 50/1001 HGE1/0/5
- StaticCR 51/- -
Table 5 Command output
FEC |
Forwarding equivalence class: · IP address/mask—Classifies FECs by destination address. · IP address/mask/LSINDEX—Classifies FECs by label stack index. · IP address—Classifies FECs by next hop. · IP address/Out Label—Classifies FECs by next hop and outgoing label. · IP address/Color—Classifies FECs by destination address and color attribute. · NID—Classifies FECs by NID. · GroupID—Classifies FECs by SR-MPLS TE policy group ID. · Ingress LSR ID/Tunnel ID/LSP ID—RSVP TE FEC or static SRLSP FEC. · IP address/mask (Flex-Algo ID)—Classifies FECs by destination address and flexible algorithm ID. · IP address/private data/VPN instance index—Classifies FECs by IP address, private data, and VPN instance index. This field displays a hyphen (-) if the LSP is a static transit LSP, static egress LSP, static transit CRLSP, static egress CRLSP, or an adjacency path for static SRLSPs. This field displays Backup if the LSP is a backup LSP of the primary LSP. This field displays SecondBackup if the LSP is the second backup LSP of the primary LSP. |
Proto |
Label distribution protocol: · LDP. · BGP. · IS-IS. · RSVP. · Static. · StaticCR—Static CRLSP or static SRLSP. · Local—LSP to a direct next hop, or LSP that uses a local MPLS TE tunnel interface or tunnel bundle interface as the LSP head. · OSPF. · RSVP-P2MP—P2MP CRLSP established by RSVP-TE. · SR-TE—SRLSP established by SR-TE. · SRPolicy—SRLSP established by SR-MPLS TE policies. |
In/Out Label |
Incoming label/outgoing label. |
Out Inter/NHLFE/LSINDEX |
Outgoing interface name, NHLFE entry index, or label stack index of the LSP. NHLFEnumber specifies the ingress LSP selected for the current LSP after route recursion. The ingress LSP is the one that matches the NHLFE entry with an NID of number. LSINDEXnumber specifies the ingress LSP selected for the current LSP after route recursion. The ingress LSP is the one that matches the LSINDEX entry with a label stack index of number. |
# Display IPv6 LSP information.
<Sysname> display mpls lsp ipv6
FEC : 100:100:100:100:100:100:100:100/128
Protocol : BGP In-Label : 1200
Out-Label: 1300 Out-Interface: HGE1/0/1
BkLabel : 1400 BkInterface : HGE1/0/2
Table 6 Command output
FEC |
Forwarding equivalence class: · IP address/mask—Classifies FECs by destination address. · IP address—Classifies FECs by next hop. · IP address/Out Label—Classifies FECs by next hop and outgoing label. · IP address/Color—Classifies FECs by destination address and color attribute. · NID—Classifies FECs by NID. · GroupID—Classifies FECs by SR-MPLS TE policy group ID. · Ingress LSR ID/Tunnel ID/LSP ID—RSVP TE FEC or static SRLSP FEC. · IP address/mask (Flex-Algo ID)—Classifies FECs by destination address and flexible algorithm ID. · IP address/private data/VPN instance index—Classifies FECs by IP address, private data, and VPN instance index. This field displays a hyphen (-) if the LSP is a static transit LSP, static egress LSP, static transit CRLSP, or static egress CRLSP. |
Protocol |
Label distribution protocol: · LDP. · BGP. · RSVP. · Static. · StaticCR—Static CRLSP or static SRLSP. · Local—LSP to a direct next hop, or LSP that uses a local MPLS TE tunnel interface or tunnel bundle interface as the LSP head. · RSVP-P2MP—P2MP CRLSP established by RSVP-TE. · SR-TE—SRLSP established by SR-TE. |
BkLabel |
Outgoing label of the backup LSP. |
BkInterface |
Outgoing interface of the backup LSP. |
# Display detailed information about all LSPs.
<Sysname> display mpls lsp verbose
Destination : 56.10.10.2
FEC : 56.10.10.2/32
Protocol : LDP
LSR Type : Egress
Service : Statistics
Create Time : 2021-07-05 11:44:06
Last Chg Time: 2021-07-05 11:44:06
In-Label : 1024
State : Active
Inbound Statistics:
Octets : 13000
Packets : 100
Errors : 0
Discards : 0
Destination : 56.10.10.4
FEC : 56.10.10.2/32
Protocol : LDP
LSR Type : Transit
In-Label : 1026
Inbound Statistics:
Octets : 10600
Packets : 100
Errors : 0
Discards : 0
Path ID : 0x40000000.1
State : Active
Out-Label : 1800
Nexthop : 10.1.1.2
BkLabel : 1900
BkNexthop : 20.1.1.2
Outbound Statistics:
Octets : 12600
Packets : 100
Errors : 0
Discards : 0
FEC : 56.10.10.2/32
Protocol : LDP
LSR Type : Ingress
Service : -
NHLFE ID : 2000
State : Active
Out-Label : 1800
Nexthop : 10.1.1.2
Table 7 Command output
Destination |
LSP destination address. |
FEC |
Forwarding equivalence class: · IP address/mask—Classifies FECs by destination address. · IP address—Classifies FECs by next hop. · IP address/Out Label—Classifies FECs by next hop and outgoing label. · IP address/Color—Classifies FECs by destination address and color attribute. · NID—Classifies FECs by NID. · GroupID—Classifies FECs by SR-MPLS TE policy group ID. · Ingress LSR ID/Tunnel ID/LSP ID—RSVP TE FEC. · IP address/mask (Flex-Algo ID)—Classifies FECs by destination address and flexible algorithm ID. This field displays a hyphen (-) if the LSP is a static transit LSP, static egress LSP, static transit CRLSP, static egress CRLSP, or adjacency path for static SRLSPs. |
Protocol |
Label distribution protocol: · LDP. · BGP (instance-name)—The instance-name specifies a BGP instance name. The value of default represents the default BGP instance. · IS-IS. · RSVP. · Static. · StaticCR—Static CRLSP or static SRLSP. · Local—LSP to a direct next hop, or LSP that uses a local MPLS TE tunnel interface or tunnel bundle interface as the LSP head. · OSPF. · RSVP-P2MP—P2MP CRLSP established by RSVP-TE. · SR-TE. · SRPolicy—SRLSP established by SR-MPLS TE policies. |
LSR Type |
LSR type: · Ingress—The current LSR is the ingress node of the LSP. · Transit—The current LSR is a transit node of the LSP. · Egress—The current LSR is the egress node of the LSP. |
Service |
Service deployed on the LSP. The service can only be Statistics, which indicates the MPLS forwarding statistics feature. |
Create Time |
Time when the LSP generated. |
Last Chg Time |
Time when the LSP changed most recently. |
Path ID |
Forwarding path. The value is in the format of 0xnn.m. The nn represents the NHLFE group ID of the outer LSPs that carry the current LSP, and m represents the sequence number of the equivalence path. |
NHLFE ID |
State |
LSP state: · Active—The LSP is in use. · Inactive—The LSP is idle. |
Inbound Statistics |
MPLS forwarding statistics in inbound direction: · Octets—Number of received octets. · Packets—Number of received packets. · Errors—Number of received error packets. · Discards—Number of discarded packets. |
BkLabel |
BkNexthop |
Next hop address of the backup LSP. |
BkInterface |
SBKOut interface |
Outgoing interface of the second backup LSP. |
BkLsIndex |
Label stack index of the backup LSP. |
Outbound Statistics |
MPLS forwarding statistics in outbound direction: · Octets—Number of sent octets. · Packets—Number of sent packets. · Errors—Number of error packets. · Discards—Number of discarded packets. |
display mpls lsp statistics
Use display mpls lsp statistics to display LSP statistics.
display mpls lsp statistics [ ipv6 ] [ vpn-instance vpn-instance-name ]
ipv6: Displays IPv6 LSP statistics. If you do not specify this keyword, the command displays IPv4 LSP statistics.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays LSP statistics for the public network and all VPN instances.
# Display IPv4 LSP statistics.
<Sysname> display mpls lsp statistics
LSP Type Ingress/Transit/Egress Active
Static LSP 0/0/0 0/0/0
Static CRLSP 0/0/0 0/0/0
LDP LSP 2/2/1 2/2/1
RSVP CRLSP 0/0/0 0/0/0
BGP LSP 0/0/0 0/0/0
Local LSP 2/0/0 2/0/0
ISIS LSP 0/0/0 0/0/0
OSPF LSP 0/0/0 0/0/0
SR LSP 0/0/0 0/0/0
SR Policy LSP 0/0/0 0/0/0
Total 4/2/1 4/2/1
# Display IPv6 LSP statistics.
<Sysname> display mpls lsp statistics ipv6
LDP LSP 6/6/2 6/6/2
BGP LSP 0/0/0 0/0/0
SR LSP 0/0/0 0/0/0
Total 8/6/2 8/6/2
Table 8 Command output
LSP Type |
LSP types: · Static LSP. · Static CRLSP—Static CRLSP or static SRLSP. · LDP LSP. · Local LSP—LSP to a direct next hop, or LSP that uses a local MPLS TE tunnel interface or tunnel bundle interface as the LSP head. · RSVP CRLSP. · BGP LSP. · IS-IS. · OSPF. · SR LSP—Dynamic SRLSPs established by SR and stateful PCE. · SR Policy LSP—SRLSP established by SR-MPLS TE policies. |
Total |
Total number of LSPs. |
Ingress |
Number of LSPs that take the local device as the ingress node. |
Transit |
Number of LSPs that take the local device as a transit node. |
Egress |
Number of LSPs that take the local device as the egress node. |
Active |
Number of active LSPs of a type. |
display mpls nib
Use display mpls nib to display MPLS Nexthop Information Base (NIB) information.
display mpls nib [ nib-id ]
nib-id: Specifies a next hop ID in the range of 1 to FFFFFFFFFFFFFFFE. If you do not specify a next hop, this command displays information about all MPLS next hops.
# Display information about all MPLS next hops.
<Sysname> display mpls nib
NIB ID: 0x40000000
Users: 1
Status: Active
ECMP number: 1
Outgoing NHLFE ID: 1024
Backup outgoing NHLFE ID: 1027
Table 9 Command output
NIB ID |
ID of the next hop. |
Users |
Number of ILM entries that use this next hop. |
Status |
Next hop status: · Active—The next hop is active. · Dummy—The next hop is inactive. |
ECMP number |
Number of equal-cost NHLFE entries. |
Outgoing NHLFE ID |
ID of the NHLFE entry to which the next hop corresponds. |
Backup outgoing NHLFE ID |
ID of the backup NHLFE entry. |
display mpls nid
Use display mpls nid to display usage information for NIDs.
display mpls nid [ nid-value1 [ to nid-value2 ] ]
nid-value1: Specifies an NID in the range of 0 to 65535. If used with the nid-value2 argument, the nid-value1 argument represents the start NID of an NID range.
to nid-value2: Specifies the end NID of the NID range. The value range for the end NID is 0 to 65535. If you specify an NID range by using the nid-value1 argument and the to nid-value2 option, this command displays usage information for the specified range of NIDs.
NIDs are 32-bit binary numbers. They include fixed NIDs and dynamic NIDs.
· Fixed NIDs—Generated for tunnel interfaces or tunnel bundle interfaces. The highest four bits are a value other than 0000.
· Dynamic NIDs—NIDs except fixed NIDs. The highest four bits are 0s.
This command displays usage information only for dynamic NIDs.
If you do not specify any parameters, this command displays usage information for all dynamic NIDs.
# Display usage information for dynamic NIDs 1028 through 1500.
<Sysname> display mpls nid 1028 to 1500
NID alloc state: '.' means not used, '$' means used
1028 :...$.... ........ ........ ........ ........ ........ ........ ........
1092 :........ ........ ........ ........ ........ ........ ........ ........
1156 :........ ........ ........ ........ ........ ........ ........ ........
1220 :........ ........ ........ ........ ........ ........ ........ ........
1284 :........ ........ ........ ........ ........ ........ ........ ........
1348 :........ ........ ........ ........ ........ ........ ........ ........
1412 :........ ........ ........ ........ ........ ........ ........ ........
1476 :........ ........ ........ .
display mpls summary
Use display mpls summary to display MPLS summary information.
# Display MPLS summary information.
<Sysname> display mpls summary
MPLS LSR ID : 1.1.1.1
Egress Label Type: Implicit-null
Labels:
Range Idle Owner
16-14999 14984 Static
StaticCR
StaticPW
Static SR Adj
BGP 6PE
15000-15999(default SRLB) 1000 Default SR Adj
Static
StaticCR
Static SR Adj
BSID
16000-55999(default SRGB, reusable) 40000 Default SR Prefix
Static
StaticCR
Static SR Adj
BSID
56000-250000 194001 LDP
RSVP
BGP
BGP 6PE
BGP SR EPE
OSPF SR Adj
ISIS SR Adj
mLDP
VSRP
VPWS
VPLS
Protocols:
Type State
CCC Normal
TE Normal
OSPF Normal
Table 10 Command output
Egress Label Type |
Label type that the egress node assigns to the penultimate hop: · Implicit-null. · Explicit-null. · Non-null. |
Labels |
Label information. |
Range |
Label range. · If labels within the label range can be reused, this field displays (reusable) behind the label range. · If the default label range is used, this field displays (default) behind the label range. · If the configured global label range is used, this field displays (global) behind the label range. · If the label range is the SRGB range, this field displays (SRGB) behind the label range. · If the label range is the SRLB range, this field displays (SRLB) behind the label range. |
Idle |
Number of idle labels in the label range. |
Owner |
Label range owner. · LDP. · BGP. · RSVP. · Static—Static LSP. · StaticCR—Static CRLSP. · StaticPW—Static PW. This option is not supported in the current software version. · Static SR Adj—Static SR adjacency SID. · Default SR Adj—Default SR adjacency SID. · SR Adj—Configured global SR adjacency SID. · Default SR Prefix—Default SR prefix SID. · SR Prefix—Configured global SR prefix SID. · OSPF SR Adj—SR adjacency SID automatically allocated to OSPF. · ISIS SR Adj—SR adjacency SID automatically allocated to IS-IS. · ISIS-1 SR Prefix—SR prefix SID of IS-IS process 1. · OSPF-1 SR Prefix—SR prefix SID of OSPF process 1. · VPWS. · VPLS—This option is not supported in the current software version. · BGP SR EPE—BGP PeerNode SID, PeerAdj SID, or PeerSet SID. · VRF—Label range specified for all VPN instances. |
Protocols |
Label distribution protocols that generated LSPs and their running states. |
Type |
Protocol type: · LDP. · BGP (instance-name). The instance-name specifies a BGP instance name. The value of default represents the default BGP instance. · RSVP. · Static—Static LSP. · StaticCR—Static CRLSP. · TE. · CCC. · ISIS. · OSPF. · SRPolicy. |
State |
Label distribution protocol running state: · Normal—The protocol is in normal state. · Recover—The protocol is in the GR process. |
mpls bandwidth-based-sharing
Use mpls bandwidth-based-sharing to enable bandwidth-based load sharing on an MPLS transit node.
Use undo mpls bandwidth-based-sharing to disable bandwidth-based load sharing on an MPLS transit node.
Bandwidth-based load sharing is disabled on an MPLS transit node.
If equal-cost LDP LSPs exist on a transit node, the node evenly transmits MPLS packets through the LSPs. After you enable this feature, MPLS packets are transmitted through the LSPs in the proportion calculated based on the bandwidth of the egress interfaces.
# Enable bandwidth-based load sharing on an MPLS transit node.
[Sysname] mpls bandwidth-based-sharing
mpls enable
Use mpls enable to enable MPLS on an interface.
Use undo mpls enable to disable MPLS on an interface.
mpls enable
undo mpls enable
MPLS is disabled on an interface.
Interface view
# Enable MPLS on HundredGigE 1/0/1.
<Sysname> System-view
[Sysname-HundredGigE1/0/1] mpls enable
mpls forwarding split-horizon
Use mpls forwarding split-horizon to enable split horizon for MPLS forwarding.
Use undo mpls forwarding split-horizon to disable split horizon for MPLS forwarding.
Split horizon is disabled for MPLS forwarding.
# Enable split horizon for MPLS forwarding.
[Sysname] mpls forwarding split-horizon
mpls label advertise
Use mpls label advertise to specify the type of label the egress node will advertise to the penultimate hop.
Use undo mpls label advertise to restore the default.
mpls label advertise { explicit-null | implicit-null | non-null }
As egress, the device advertises an implicit null label to the penultimate hop.
explicit-null: Specifies the egress node to advertise an explicit null label of 0 or 2 to the penultimate hop. The explicit null label value is 0 in IPv4 networks and 2 in IPv6 networks.
implicit-null: Specifies the egress node to advertise an implicit null label of 3 to the penultimate hop.
non-null: Specifies the egress node to advertise a non-null label to the penultimate hop.
As a best practice, configure the egress node to advertise an implicit null label to the penultimate hop if the penultimate hop supports PHP.
If you want to simplify packet forwarding on egress but keep labels to determine QoS policies, configure the egress node to advertise an explicit null label to the penultimate hop.
Use non-null labels only in particular scenarios. For example, when OAM is configured on the egress node, the egress node can get the OAM function entity status only through non-null labels.
As a penultimate hop, the device accepts the implicit null label, explicit null label, or non-null label advertised by the egress node.
For LDP LSPs, the mpls label advertise command triggers LDP to delete the LSPs established before the command is executed and re-establishes new LSPs.
For BGP LSPs, the mpls label advertise command takes effect only on the BGP LSPs established after the command is executed. To apply the new setting to BGP LSPs established before the command is executed, delete the routes corresponding to the BGP LSPs, and then redistribute the routes.
# Configure the egress node to advertise an implicit null label to the penultimate hop.
[Sysname] mpls label advertise implicit-null
reset mpls ldp
mpls label range
Use mpls label range to set the value range for dynamic labels that the device can allocate.
Use undo mpls label range to restore the default.
mpls label range minimum maximum
The value range for dynamic labels that the device can allocate is not configured.
minimum: Specifies the minimum label value that the device can allocate. The value range for this argument is 15000 to 249999.
maximum: Specifies the maximum label value that the device can allocate. The value range for this argument is 15001 to 250000.
This command sets the value range in which label distribution protocols can dynamically allocate labels.
This command does not take effect on static LSP labels, static CRLSP labels, static SRLSP labels, or SRGBs. For more information about static LSP labels, see "Configuring a static LSP." For more information about static CRLSP labels, see "Configuring a static CRLSP." For more information about static SRLSPs and SRGBs, see MPLS SR configuration in Segment Routing Configuration Guide.
If you configure this command multiple times, the most recent configuration takes effect.
# Set the value range to 15000 to 25000 for dynamic labels that the device can allocate.
[Sysname] mpls label range 15000 25000
mpls label-block
Use mpls label-block to configure an MPLS label block.
Use undo mpls label-block to delete an MPLS label block.
mpls label-block name name range minimum-label maximum-label
undo mpls label-block name name
No MPLS label block is configured.
name name: Specifies a name for the MPLS label block, a case-sensitive string of 1 to 127 characters.
range: Specifies the range of labels of the MPLS label block.
minimum-label: Minimum label value of the MPLS label block. The value range for this argument depends on the device model.
maximum-label: Maximum label value of the MPLS label block. The value range for this argument depends on the device model.
An MPLS label block configured by using this command can be used by the SRLB and SRGBs, so IGP and BGP use the labels within the MPLS label block.
If you configure MPLS label blocks with the same name multiple times, the most recent configuration takes effect.
MPLS label blocks with different names cannot contain overlapping label values.
If an MPLS label block has been used, you cannot delete the MPLS label block.
# Configure an MPLS label block named srgb, and specify its label range as 10000 to 15000.
[Sysname] mpls label-block name srgb range 10000 15000
mpls load-sharing mode
Use mpls load-sharing mode to configure an MPLS load sharing mode.
Use undo mpls load-sharing mode to restore the default.
mpls load-sharing mode { per-flow { flow-label | label | ip } | per-packet }
The device performs per-flow load sharing based on IP addresses.
per-flow: Enables per-flow load sharing.
flow-label: Enables per-flow load sharing based on flow labels.
label: Enables per-flow load sharing based on labels.
ip: Enables per-flow load sharing based on IP information.
per-packet: Enables per-packet load sharing.
The device supports the following MPLS load sharing modes:
· Per-flow load sharing based on flow labels—In MPLS L2VPN or VPLS networks, the P device uses the L2VPN flow label feature to implement load sharing for different data flows on the same PW.
To enable MPLS per-flow load sharing based on flow labels:
¡ Configure the flow-label command on the PE to enable the PE to add different flow labels for packets of different traffic types.
The PE device adds a flow label behind the private label in a data packet.
¡ Configure the mpls load-sharing mode per-flow flow-label command on the P device to enable per-flow load sharing based on flow labels.
· Per-flow load sharing based on labels
¡ If the label stack contains five or less MPLS labels:
- For MPLS packets carrying IP packets, the device performs load sharing based on the destination IP, source IP, destination port, source port, protocol number, and the ToS field in the IP packets.
- For MPLS packets carrying TCP and UDP packets, the device performs load sharing based on the destination IP, source IP, protocol number, and the ToS field in the IP packets.
- For MPLS packets carrying non-IP packets, the device performs load sharing based on all MPLS labels in the packets.
¡ If the label stack contains more than five MPLS labels, the device performs load sharing based on the outmost five MPLS labels.
· Per-flow load sharing based on IP information
¡ If the label stack contains five or less MPLS labels, the device performs load sharing based on the five tuples of packets.
· Per-packet load sharing—Sends packets to outgoing interfaces in turn, one packet to one interface at a time, according to the packet reception order.
# Enable per-flow load sharing based on flow labels.
[Sysname] mpls load-sharing mode per-flow label flow-label
flow-label (MPLS L2VPN)
flow-label (VPLS)
mpls lsr-id
Use mpls lsr-id to configure an LSR ID for the local LSR.
Use undo mpls lsr-id to restore the default.
mpls lsr-id lsr-id
undo mpls lsr-id
An LSR has no LSR ID.
lsr-id: Specifies an ID for identifying the LSR, in dotted decimal notation.
As a best practice, use the address of a loopback interface on the LSR as the LSR ID.
If no LDP LSR ID is configured for the public network or a VPN instance, LDP uses the MPLS LSR ID configured by the mpls lsr-id command. If you modify the MPLS LSR ID, the LDP sessions in the public network or VPN instance will be re-established. To configure an LDP LSR ID for the public network or a VPN instance, use the lsr-id command in LDP view or LDP-VPN instance view.
# Configure the LSR ID as 3.3.3.3 for the local node.
[Sysname] mpls lsr-id 3.3.3.3
# Change the LSR ID to 4.4.4.4.
[Sysname] mpls lsr-id 4.4.4.4
All LDP sessions using the MPLS LSR ID will be reset. Continue? [Y/N]:Y
lsr-id
mpls mtu
Use mpls mtu to set the MPLS MTU for an interface.
Use undo mpls mtu to restore the default.
mpls mtu size
undo mpls mtu
The MPLS MTU of an interface is not configured. Fragmentation for MPLS packets is based on the MTU set on the interface by the ip mtu command. If no MTU is set by the ip mtu command, the fragmentation is based on the MTU of the interface. The length of a fragment does not include that of the MPLS label. Thus, after an MPLS label is added into a fragment, the length of the MPLS fragment might exceed the interface MTU.
If the peer interface has low performance and cannot receive packets larger than the IP MTU, set the MPLS MTU to a value smaller than the IP MTU as a best practice to ensure correct packet forwarding.
Interface view
size: Specifies the MPLS MTU of the interface, in the range of 46 to 65535 bytes.
This command is effective only when MPLS is enabled on the interface.
If the MPLS MTU is larger than the interface MTU, data forwarding might fail.
MPLS TE tunnel interfaces do not support this command.
# Set the MPLS MTU of HundredGigE 1/0/1 to 1000 bytes.
[Sysname-HundredGigE1/0/1] mpls mtu 1000
mpls php-with-outrif
Use mpls php-with-outrif to configure the local node to add outgoing VLAN tags for packets when performing PHP forwarding, in order to facilitate internal processing.
Use undo mpls php-with-outrif to restore the default.
The local node does not add outgoing VLAN tags for packets when performing PHP forwarding.
Application scenarios
NetStream cannot sample and count the traffic forwarded by Penultimate Hop Popping (PHP) in the following situation: The operation type in the ILM entry is SWAP and the outermost label carried in a packet is a public network label. The device performs PHP forwarding to pop the label stack as instructed by the implicit null label. To enable NetStream for the traffic forwarded by implicit null PHP, you can configure the device to add VLAN tags to the traffic.
Operating mechanism
After this command is executed, the device adds VLAN tags to packets after performing PHP forwarding for the packets. NetStream then can sample and collect statistics on the traffic based on the VLAN tag information.
The VLAN tag information added by this command is only used for packet processing within the device. Whether to carry VLAN tags when forwarding packets out of the outgoing interfaces is determined by the VLAN and VLAN termination settings on the device.
# Configure the local node to add outgoing VLAN tags after performing PHP forwarding for packets to facilitate internal processing.
[Sysname] mpls php-with-outrif
mpls statistics
Use mpls statistics to enable MPLS label forwarding statistics for LSPs.
Use undo mpls statistics to disable MPLS label forwarding statistics for LSPs.
mpls statistics { all | [ vpn-instance vpn-instance-name ] { ipv4 ipv4-address mask-length | ipv6 ipv6-address prefix-length } | static | te ingress-lsr-id tunnel-id }
undo mpls statistics { all | [ vpn-instance vpn-instance-name ] { ipv4 ipv4-address mask-length | ipv6 ipv6-address prefix-length } | static | te ingress-lsr-id tunnel-id }
MPLS label forwarding statistics are disabled for all LSPs.
all: Specifies all LSPs.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command enables MPLS forwarding statistics for public LSPs.
ipv4 ipv4-address mask-length: Specifies the IPv4 LSP for an FEC specified by an IPv4 address and a mask length. The mask length is in the range of 0 to 32.
ipv6 ipv6-address prefix-length: Specifies the BGP-IPv6 LSP for an FEC specified by an IPv6 address and a prefix length. The prefix length is in the range of 0 to 128.
static: Specifies static LSPs and static CRLSPs.
te ingress-lsr-id tunnel-id: Specifies an RSVP-TE tunnel. The ingress-lsr-id represents the LSR ID of the ingress node of the tunnel. The tunnel-id argument represents the ID of the tunnel. The value range for the tunnel-id argument is 0 to 65534. If you specify this option, the device automatically sets the MPLS label forwarding statistics collection interval to 30 seconds.
MPLS label forwarding forwards a labeled packet based on its incoming label. MPLS label forwarding statistics is enabled by this command.
To display MPLS label forwarding statistics for the specified LSPs by using the display mpls lsp verbose command, you must perform the following tasks:
· Use the mpls statistics command to enable the MPLS label forwarding statistics feature for the LSPs.
· Use the mpls statistics interval command to set the MPLS label forwarding statistics collection interval.
If you specify the te ingress-lsr-id tunnel-id option in the mpls statistics command, the MPLS label forwarding statistics collection interval is automatically set to 30 seconds. If you also execute the mpls statistics interval command, the interval set by the mpls statistics interval command takes effect.
The execution of the mpls statistics enable command on a PE enables MPLS label forwarding statistics for a VPN instance and for all LSPs in the VPN instance. For more information about enabling MPLS label forwarding statistics for a VPN instance, see the MPLS L3VPN configuration in MPLS Configuration Guide.
The undo mpls statistics all command cannot disable MPLS label forwarding statistics for a VPN instance or a protocol after the mpls statistics command is executed with the vpn-instance, ipv4, ipv6, static, or te keyword specified. To disable MPLS label forwarding statistics for the VPN instance or protocol, execute the undo mpls statistics command with the vpn-instance, ipv4, ipv6, static, or te keyword specified.
# Enable MPLS label forwarding statistics for the LSP destined for 2.2.2.2/32.
[Sysname] mpls statistics ipv4 2.2.2.2 32
reset mpls statistics
Use mpls statistics interval to set the MPLS label forwarding statistics collection interval.
Use undo mpls statistics interval to delete the MPLS label forwarding statistics collection interval.
mpls statistics interval interval
The MPLS forwarding statistics collection interval is not set.
interval: Specifies the MPLS label forwarding statistics collection interval, in the range of 30 to 65535 seconds.
# Set the MPLS label forwarding statistics collection interval to 30 seconds.
[Sysname] mpls statistics interval 30
display ip vpn-instance mpls statistics
mpls statistics
reset ip vpn-instance mpls statistics
mpls ttl expiration enable
Use mpls ttl expiration enable to enable sending MPLS TTL-expired messages.
Use undo mpls ttl expiration enable to disable sending MPLS TTL-expired messages.
The MPLS TTL-expired messages sending feature is enabled.
This command enables an LSR to generate an ICMP TTL-expired message upon receiving an MPLS packet with TTL being 1.
· If the MPLS packet has only one label, the LSR sends the ICMP TTL-expired message back to the source through IP routing.
· If the MPLS packet has multiple labels, the LSR forwards the ICMP TTL-expired message along the LSP of the MPLS packet to the egress node. Then, the egress node sends the message back to the source.
# Disable sending MPLS TTL-expired messages.
[Sysname] undo mpls ttl expiration enable
mpls ttl propagate
Use mpls ttl propagate to enable TTL propagation.
Use undo mpls ttl propagate to disable TTL propagation.
mpls ttl propagate { public | vpn }
undo mpls ttl propagate { public | vpn }
TTL propagation is enabled for public network packets and is disabled for VPN packets.
public: Specifies public network packets.
vpn: Specifies VPN packets.
NOTE: The ttl-mode command has higher priority than this command. For more information about the ttl-mode command, see MPLS L3VPN configuration in MPLS Configuration Guide. |
TTL propagation does not take effect on existing LSPs. For existing LSPs, perform the following tasks after you enable TTL propagation:
· Reconfigure static LSPs.
· Execute the reset mpls ldp command to restart LDP sessions for dynamic LSPs.
When TTL propagation is enabled, MPLS performs the following operations:
· Copies the IP TTL to the label TTL for packets entering the MPLS network.
· Copies the label TTL to the IP TTL for packets leaving the MPLS network.
If you enable TTL propagation on both ingress and egress, the IP tracert facility can show the real path in the MPLS network.
When TTL propagation is disabled, MPLS performs the following operations:
· Sets the label TTL to 255 for packets entering the MPLS network.
· Pops the label for packets leaving the MPLS network, without copying the label TTL value to the IP TTL.
The IP tracert facility cannot show the real path in the MPLS network.
Within an MPLS network, TTL is always copied between the labels of an MPLS packet. The mpls ttl propagate command affects only the propagation between IP TTL and label TTL.
As a best practice, set the same TTL processing mode on all LSRs of an LSP.
To enable TTL propagation for a VPN, you must enable it on all PE devices in the VPN. This allows you to obtain the same traceroute result (hop count) from those PEs.
# Enable TTL propagation for VPN packets.
[Sysname] mpls ttl propagate vpn
mpls-in-udp
Use mpls-in-udp to enable MPLS in UDP and enter MPLS-in-UDP view.
Use undo mpls-in-udp to disable MPLS in UDP.
mpls-in-udp
undo mpls-in-udp
MPLS in UDP is disabled.
With this feature enabled, the device encapsulates MPLS packets in UDP packets (UDP destination port number is 6635) and the UDP packets are transmitted through MPLS/SR-MPLS-incapable devices. Tunnels used to transmit MPLS packets packaged in UDP packets are called MPLS in UDP tunnels.
In the current software version, the device supports acting only as the tail node of a MPLS in UDP tunnel. With this feature enabled, the device can decode UDP packets encapsulated with MPLS packets (UDP packets using destination port 6653), remove the UDP headers, and then forward MPLS packets based on MPLS labels.
# Enable MPLS in UDP and enter MPLS-in-UDP view.
[Sysname] mpls-in-udp
[Sysname-mpls-in-udp]
Use reset mpls statistics to clear MPLS forwarding statistics for the specified LSPs.
reset mpls statistics { all | [ vpn-instance vpn-instance-name ] { ipv4 ipv4-address mask-length | ipv6 ipv6-address prefix-length } | static | te ingress-lsr-id tunnel-id }
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command clears MPLS forwarding statistics for public LSPs.
te ingress-lsr-id tunnel-id: Specifies an RSVP-TE tunnel. The ingress-lsr-id argument represents the LSR ID of the ingress node of the tunnel. The tunnel-id argument represents the ID of the tunnel. The value range for the tunnel-id argument is 0 to 65534.
# Clear MPLS forwarding statistics for the LSP destined for 2.2.2.2/32.
<Sysname> reset mpls statistics ipv4 2.2.2.2 32
mpls statistics
snmp-agent trap enable mpls
Use snmp-agent trap enable mpls to enable SNMP notifications for MPLS.
Use undo snmp-agent trap enable mpls to disable SNMP notifications for MPLS.
SNMP notifications for MPLS are disabled.
To report critical MPLS events to an NMS, enable SNMP notifications for MPLS. For MPLS event notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see the network management and monitoring configuration guide for the device.
# Enable SNMP notifications for MPLS.
[Sysname] snmp-agent trap enable mpls
