04-Layer 2—LAN Switching Command Reference
HomeSupportSwitchesS12500R SeriesReference GuidesCommand ReferencesH3C S12500R-48Y8C&S12500R-48C6D Switch Router Command References(R52xx)-6W10204-Layer 2—LAN Switching Command Reference
07-VLAN termination commands
07-VLAN termination commands 93.73 KB
second-dot1q
Use second-dot1q to enable QinQ termination on an interface, and specify the Layer 2 VLAN IDs of the VLAN-tagged packets that can be terminated by the interface.
Use undo second-dot1q to disable QinQ termination on an interface.
second-dot1q { vlan-id-list | any } [ loose ]
undo second-dot1q { vlan-id-list | any } [ loose ]
QinQ termination is disabled on an interface.
VLAN interface view
vlan-id-list: Specifies a space-separated list of up to 10 Layer 2 VLAN ID items. Each item specifies a Layer 2 VLAN ID or a range of Layer 2 VLAN IDs in the form of vlan-id1 to vlan-id2. The value range for VLAN IDs is 1 to 4094. The value for the vlan-id2 argument must be equal to or greater than the value for the vlan-id1 argument.
any: Specifies all values between 1 and 4094.
loose: Configures the interface to receive and terminate packets that include two or more layers of VLAN tags.
When you execute this command, the Layer 1 VLAN ID of VLAN-tagged packets that can be terminated by the interface is the interface number. This Layer 1 VLAN ID is not configurable.
# Configure VLAN-interface 10 to terminate VLAN-tagged packets with Layer 2 VLAN IDs in the range of 10 to 20. Configure VLAN-interface 12 to terminate VLAN-tagged packets with Layer 2 VLAN ID 100. Configure VLAN-interface 100 to terminate VLAN-tagged packets with any Layer 2 VLAN IDs.
[Sysname-Vlan-interface10] second-dot1q 10 to 20
[Sysname-Vlan-interface10] quit
[Sysname] interface vlan-interface 12
[Sysname-Vlan-interface12] second-dot1q 100
[Sysname-Vlan-interface12] quit
[Sysname-Vlan-interface100] second-dot1q any
The following table describes the configuration results:
VLAN interface
Layer 1 VLAN ID of VLAN-tagged packets that the VLAN interface can terminate
Layer 2 VLAN IDs of VLAN-tagged packets that the VLAN interface can terminate
VLAN-interface 10
10
10–20
VLAN-interface 12
12
100
VLAN-interface 100
100
1–4094
vlan-termination broadcast enable
Use vlan-termination broadcast enable to enable an interface to transmit broadcasts and multicasts.
Use undo vlan-termination broadcast enable to disable an interface from transmitting broadcasts and multicasts.
Broadcast and multicast packets are dropped on an interface configured with Dot1q/QinQ termination to terminate packets of multiple VLANs.
VLAN interface view
IMPORTANT
IMPORTANT:
This command affects system performance. If system performance is seriously affected by this command, execute the undo form of this command to remove the command configuration.
To transmit a broadcast or multicast packet, the interface starts a traversal over all the VLAN IDs specified for Dot1q/QinQ termination. It copies the packet and tags each copy with VLAN IDs, until all combinations of VLAN IDs are traversed.
·     Configure HundredGigE 1/0/1.10 to tag a multicast or broadcast packet with each VLAN tag in the range of 10 to 20.
# Enable Dot1q termination on HundredGigE 1/0/1.10 to terminate VLAN-tagged packets with outermost VLAN IDs in the range of 10 to 20.
[Sysname] interface hundredgige 1/0/1.10
[Sysname-HundredGigE1/0/1.10] vlan-type dot1q vid 10 to 20
# Enable HundredGigE 1/0/1.10 to transmit broadcast and multicast packets.
[Sysname-HundredGigE1/0/1.10] vlan-termination broadcast enable
·     Configure HundredGigE 1/0/1.10 to tag a multicast or broadcast packet with each Layer 1 VLAN ID and each Layer 2 VLAN ID. The Layer 1 and Layer 2 VLAN IDs are in the range of 300 to 400 and 500 to 600, respectively.
# Configure HundredGigE 1/0/1.10 to terminate VLAN-tagged packets whose Layer 1 and Layer 2 VLAN IDs are in the range of 300 to 400 and 500 to 600, respectively.
[Sysname-HundredGigE1/0/1.10] vlan-type dot1q vid 300 to 400 second-dot1q 500 to 600
vlan-termination broadcast ra
Use vlan-termination broadcast ra to enable an interface to transmit router advertisement (RA) multicast packets.
Use undo vlan-termination broadcast ra to disable an interface from transmitting RA multicast packets.
VLAN interface view
To transmit an RA multicast packet, the interface starts a traversal over all the VLAN IDs specified for Dot1q/QinQ termination. It copies the packet and tags each copy with VLAN IDs, until all combinations of VLAN IDs are traversed.
On an IPv6 network, you must use this command to enable an ambiguous Dot1q or QinQ termination-enabled interface to transmit RA multicast packets. This command prohibits transmission of broadcast packets and other types of multicast packets, and consumes less CPU resources than the vlan-termination broadcast enable command.
·     Configure HundredGigE 1/0/1.10 to tag RA multicast packets with each VLAN tag in the range of 10 to 20.
# Enable HundredGigE 1/0/1.10 to transmit RA multicast packets.
[Sysname-HundredGigE1/0/1.10] vlan-termination broadcast ra
·     Configure HundredGigE 1/0/1.10 to tag RA multicast packets with each Layer 1 VLAN ID and each Layer 2 VLAN ID. The Layer 1 and Layer 2 VLAN IDs are in the range of 300 to 400 and 500 to 600, respectively.
vlan-termination mode
Use vlan-termination mode to configure the VLAN termination mode for subinterfaces.
Use undo vlan-termination mode to restore the default.
vlan-termination mode { auto | custom }
By default, the VLAN termination mode for subinterfaces is automatic.
auto: Specifies automatic termination mode. In this mode, a newly created subinterface automatically terminates the packets whose outermost VLAN ID is the same as the subinterface number. In addition, you cannot configure VLAN termination on subinterfaces.
custom: Specifies customized termination mode. In this mode, you must configure VLAN termination on a newly created subinterface for it to terminate VLAN-tagged packets.
Delete all existing subinterfaces before you switch the VLAN termination mode for subinterfaces.
# Set the VLAN termination mode for subinterfaces to customized.
[Sysname] vlan-termination mode custom
vlan-type dot1q default
vlan-type dot1q untagged
vlan-type dot1q vid
vlan-type dot1q vid second-dot1q
Use vlan-type dot1q untagged to enable untagged termination on a subinterface.
Use undo vlan-type dot1q untagged to disable untagged termination on a subinterface.
Untagged termination is disabled on a subinterface.
This command enables the subinterface to process untagged packets.
On a main interface, you can execute this command only on one subinterface.
# Enable untagged termination on HundredGigE 1/0/1.1.
[Sysname-HundredGigE1/0/1.1] vlan-type dot1q untagged
[Sysname-HundredGigE1/0/1.1] quit
vlan-type dot1q vid
Use vlan-type dot1q vid to enable Dot1q termination on a subinterface, and specify the outermost VLAN IDs in the VLAN-tagged packets that can be terminated by the subinterface.
Use undo vlan-type dot1q vid to disable Dot1q termination on a subinterface.
vlan-type dot1q vid vlan-id-list
undo vlan-type dot1q vid vlan-id-list
Dot1q termination is disabled on a subinterface.
vlan-id-list: Specifies a space-separated list of up to 10 outermost VLAN ID items. Each item specifies an outermost VLAN ID or a range of outermost VLAN IDs in the form of vlan-id1 to vlan-id2. The value range for VLAN IDs is 1 to 4094. The value for the vlan-id2 argument must be equal to or greater than the value for the vlan-id1 argument.
The outermost VLAN ID ranges specified by the vlan-id-list argument for different subinterfaces of a main interface cannot overlap.
On an MPLS L2VPN network, when you configure the VLAN IDs that can be terminated by an AC interface, you can specify up to 1024 VLAN ranges (vlan-id-list arguments), with each VLAN range containing up to 32 VLANs. On an SRv6 L2VPN network, when you configure the VLAN IDs that can be terminated by an AC interface, the number of VLAN ranges (vlan-id-list arguments) is not limited, with each VLAN range containing up to 32 VLANs.
# Configure HundredGigE 1/0/1.1 to terminate VLAN-tagged packets with outermost VLAN IDs in the range of 2 to 100.
[Sysname-HundredGigE1/0/1.1] vlan-type dot1q vid 2 to 100
# Configure HundredGigE 1/0/1.2 to terminate VLAN-tagged packets whose outermost VLAN ID is 3.
[Sysname] interface hundredgige 1/0/1.2
[Sysname-HundredGigE1/0/1.2] vlan-type dot1q vid 3
Subinterface
Outermost VLAN ID of packets that can be terminated
Whether packets to be terminated include more than one layer of VLAN tags
HundredGigE 1/0/1.2
3
No
Use vlan-type dot1q vid second-dot1q to enable QinQ termination on a subinterface, and specify the Layer 1 VLAN ID and Layer 2 VLAN ID range of VLAN-tagged packets that can be terminated by the subinterface.
Use undo vlan-type dot1q vid second-dot1q to disable QinQ termination on a subinterface.
vlan-type dot1q vid vlan-id second-dot1q { vlan-id-list | any }
undo vlan-type dot1q vid vlan-id second-dot1q { vlan-id-list | any }
QinQ termination is disabled on a subinterface.
vlan-id-list: Specifies a space-separated list of up to 10 VLAN ID items. Each item specifies a VLAN ID or a range of VLAN IDs in the form of vlan-id1 to vlan-id2. The value range for VLAN IDs is 1 to 4094. The value for the vlan-id2 argument must be equal to or greater than the value for the vlan-id1 argument.
When you enable QinQ termination on multiple subinterfaces of the same main interface, specify different Layer 2 VLAN IDs for the subinterfaces.
To modify the QinQ termination settings on a subinterface, perform the following tasks:
1.     Execute the undo vlan-type dot1q vid second-dot1q command to delete the existing QinQ termination settings.
2.     Configure QinQ termination again.
# Enable QinQ termination on the Layer 3 Ethernet subinterfaces, and configure each subinterface to terminate VLAN-tagged packets with the specified Layer 1 and Layer 2 VLAN IDs.
·     Configure HundredGigE 1/0/1.1 to terminate VLAN-tagged packets whose Layer 1 and Layer 2 VLAN IDs are both 100.
[Sysname-HundredGigE1/0/1.1] vlan-type dot1q vid 100 second-dot1q 100
·     Configure HundredGigE 1/0/1.2 to terminate VLAN-tagged packets with Layer 1 VLAN ID 100 and Layer 2 VLAN IDs in the range of 200 to 300.
[Sysname-HundredGigE1/0/1.2] vlan-type dot1q vid 100 second-dot1q 200 to 300
[Sysname-HundredGigE1/0/1.2] quit
·     Configure HundredGigE 1/0/1.3 to terminate VLAN-tagged packets whose Layer 1 VLAN ID is 200 and Layer 2 VLAN ID is in the range of 500 to 600.
[Sysname] interface hundredgige 1/0/1.3
[Sysname-HundredGigE1/0/1.3] vlan-type dot1q vid 200 second-dot1q 500 to 600
[Sysname-HundredGigE1/0/1.3] quit
Layer 1 VLAN IDs of VLAN-tagged packets that the subinterface can terminate
Layer 2 VLAN IDs of VLAN-tagged packets that the subinterface can terminate
HundredGigE 1/0/1.1
100
100
HundredGigE 1/0/1.2
100
200–300
HundredGigE 1/0/1.3
200
500–600
# Configure HundredGigE 1/0/1.2 to terminate VLAN-tagged packets whose Layer 1 and Layer 2 VLAN IDs are both 20.
[Sysname-HundredGigE1/0/1.2] vlan-type dot1q vid 20 second-dot1q 20
Subinterface
Whether the packets to be terminated include two or more layers of VLAN tags
HundredGigE 1/0/1.2
20
20
No
