H3C SR8800-F Routers Maintenance Guides-R838x-6W101
HomeSupportRoutersH3C SR8800-F Router SeriesDiagnose & MaintainMaintenance GuidesH3C SR8800-F Routers Maintenance Guides-R838x-6W101
03-FAQ
03-FAQ 390.85 KB
FAQ
Copyright © 2015-2019 New H3C Technologies Co., Ltd. All rights reserved.
Hardware· 1
Q.     What models does the H3C SR8800-F router series include?· 1
Q.     Can I install MPUs of different models on the same router?· 1
Q.     Does the router support DC power supplies?· 1
Q.     Can the power supplies be hot swapped?· 1
Q.     Can power supplies of different models be installed on the same router?· 1
Q.     Can the cards/subcards be hot swapped?· 1
Q.     How are the interfaces numbered on the router?· 1
Q.     Does the router support active/standby MPU switchover?· 1
Q.     Can the fan speed automatically adjusted to adapt to the cooling requirements?· 2
Q.     Are the fan trays and power supplies hot swappable?· 2
Q.     What is the operating temperature and upper and lower temperature thresholds of the router?· 2
Q.     How do I identify the card serial number or manufacture information?· 2
Q.     Which cards does the router use for data forwarding?· 2
Q.     Does the router support CF cards?· 2
Q.     What protective measures do the power supplies use?· 2
Q.     What subcards are available for the SPEX/CSPEX cards?· 3
Q.     Does the router provide crossbar module redundancy?· 3
Q.     Do the service modules support interface type switching between POS and GE?· 3
Q.     Do the service modules support interface type switching between GE and XGE?· 3
Software· 3
Q.     Does the BootWare support forward compatibility?· 3
Q.     How do I view the system version information and operation time information?· 3
Q.     Can I delete the Comware system software image file after the upgrade is completed?· 3
Q.     Can I view deleted files?· 3
Q.     How can I empty the recycle bin?· 4
Q.     Is software hotfix supported?· 4
Q.     What is the name of the default configuration file?· 4
Q.     What should I do before installing patches?· 4
Q.     Why doesn't the router display the current startup configuration file?· 4
Q.     System management and maintenance· 4
Q.     Information displayed on the console terminal is incorrect sometimes. Why?· 4
Q.     Data loss occurred after I logged in to the router through the console port. What should I do?· 5
Q.     How can I clear a Telnet connection?· 5
Q.     Can a Telnet user's username contain the at sign (@)?· 5
Q.     I cleared the packet statistics on an interface by using the reset counters interface command. Why does the MIB browser show that the error packet count is still the same?· 5
Q.     How do I format the CF card or flash memory from the BootWare?· 5
Q.     How do I examine the memory of the router before the router starts up?· 7
Q.     Does the router relearn MAC address, ARP, and route entries after an active/standby switchover?· 7
Q.     Why should I wait for all LPUs to operate correctly before I save the running configuration?· 8
Q.     Can the management Ethernet interface come up without an IP address?· 8
Q.     I was using TFTP to transfer data from the router. Why did the transfer fail when the amount of transferred data reached about 32 MB?· 8
Q.     How are packets arriving at the standby MPU's management Ethernet interface handled?· 8
IRF· 8
Q.     How many chassis can an IRF fabric have?· 8
Q.     Can I use the MCC 10-GE ports on MPUs in standalone mode?· 8
Q.     Can all types of service modules support IRF?· 8
Q.     Are there any special requirements for connecting IRF member chassis?· 8
Q.     Why can't I bind a physical interface to or remove it from an IRF port in IRF mode?· 9
Q.     Can I connect IRF physical interfaces over a relay device?· 9
Q.     Does an IRF fabric support multichassis Ethernet link aggregation?· 9
Q.     Can I set up an IRF connection that has multiple links?· 9
Q.     Can IRF member chassis use duplicate member IDs?· 9
Q.     Can I add an MPU to an IRF fabric if it runs a different software version than the global active MPU?  9
Q.     Can I remove both the MPUs in a subordinate chassis?· 9
Q.     Can I run LACP MAD on any Ethernet link aggregations?· 9
Q.     Can I use an IRF fabric as the intermediate device to detect multi-active collisions for another IRF fabric?  10
Q.     Why are network interfaces that were shut down by MAD still down after an IRF merge?· 10
Q.     Why doesn't the running configuration on a reunified IRF fabric include the configuration that I made on one chassis after an IRF split?· 10
Q.     Will the active IRF fabric retain configuration for chassis in the recovery IRF fabric after an IRF split?  10
Q.     Why can't data traffic be forwarded at the wire speed across chassis in an IRF fabric?· 10
Network security and attack prevention· 10
Q.     What attack prevention features does the router support?· 11
Q.     What roles can the router play when using different SSH versions?· 13
Q.     Why cannot a user log in to an ACS authentication server through a console port when the router uses RADIUS authentication?· 13
Q.     Why can the level for the RADIUS server (the router) only be 1 when it connects to an ACS server?· 13
Q.     Does the router support local authentication when HWTACACS authentication fails?· 13
Q.     Can the router be connected to a TACACS server that runs third-party TACACS server software?· 14
Q.     Does the reply from a RADIUS server include the Login-Service option after the authentication succeeds?  14
Q.     How do I set the user role?· 14
Q.     How are the levels of HWTACACS and Cisco's ACS matched?· 14
Q.     Which one of the user role configured in VTY user interface and the user role configured on a RADIUS server or a HWTACACS server is assigned to a Telnet user?· 14
Q.     How do I prevent gateway spoofing when the router acts as a gateway?· 15
Network access· 15
Q.     What is the maximum number of bits of a port count?· 15
Q.     What are the definitions of the error packet fields for input and output packets in the output from the display interface command?· 15
Q.     Does the router support jumbo frames?· 16
Q.     How do different services handle packets larger than MTU?· 16
Q.     Does the MTU configuration affect only the fragmentation of packets sent to the CPU?· 17
Q.     Are the MAC address entries the same across the interface cards on the router?· 17
Q.     How long is the aging timer for dynamic MAC address entries? How are the dynamic MAC address entries aged?  17
Q.     Can frames be correctly forwarded when the MAC address learning limit is set to 0?· 17
Q.     Why does a port still have MAC address entries after the mac-address max-mac-count 0 command is configured on the port?  17
Q.     Why is a MAC address learned into multiple VLANs?· 17
Q.     Does the router support multicard link aggregation?· 17
Q.     How is traffic load shared for link aggregation on the router?· 17
Q.     Does the router support configuring static MAC address entries on an aggregate interface?· 18
Q.     Does DLDP take effect when one fiber is connected in case that two fibers of a link are both disconnected?  18
Q.     What fields are displayed in the output transceiver module optical power information?· 18
Q.     How is the port rate percentage calculated?· 18
Q.     Why is the peer port down and the local port not down when the port of the router is connected to the port of another device?· 19
Q.     What are the restrictions and guidelines for configuring the duplex modes and rates for subcard interfaces?  19
Q.     What types of subinterfaces on the router support VLAN termination?· 20
Q.     What is the difference between regular termination and user VLAN termination? What are the usage scenarios?  21
Q.     Does the router support Layer 3 subinterface statistics collection?· 21
IP forwarding services· 21
Q.     Does the router support configuring a secondary IP address for a Layer 3 Ethernet interface?· 21
Q.     Is the secondary IP address still valid when the primary IP address is removed from a Layer 3 Ethernet interface?  22
Q.     What is the MAC address of a VLAN interface used for?· 22
Q.     Does the router support the super VLAN configuration?· 22
Q.     Which route in the FIB table has higher priority for packet forwarding when a route obtained from the routing table conflicts with a host route obtained from the ARP table?· 22
Q.     How does the router handle an ICMP ping packet whose size exceeds 1500 bytes?· 22
Q.     Is the sending interval of ICMP ping packets configurable on the router?· 22
Q.     Does the router support cross-card port mirroring?· 23
Q.     Does the router support remote port mirroring?· 23
Q.     What tunneling technologies does the router support?· 23
Q.     What protocols and features does BFD support on the router?· 23
Q.     Which load sharing modes are supported by the router?· 24
IP routing· 24
Q.     Does the router support configuring blackhole routes?· 24
Q.     Is the OSPF cost of a Layer 3 Ethernet interface on the router relevant to the interface rate?· 24
Q.     What are the preferences of different routing protocols?· 25
Q.     What are the possible reasons for the OSPF CONFIG ERROR trap?· 25
Q.     Does the router discard the matching packets when the PBR-based forwarding fails?· 25
MPLS·· 25
Q.     How do I filter LSPs triggered by routes with non-32-bit masks?· 25
Q.     How do I view the tracert path correctly after enabling TTL propagation for the router?· 26
IP multicast 26
Q.     Which IGMP versions are supported by the router?· 26
Q.     Are static RPs supported by the router?· 26
Q.     Are static multicast routes supported by the router?· 26
Q.     How do I deny multicast packets from an illegal multicast source?· 26
Q.     Are multicast group policies supported by the router?· 26
Q.     The RPF check fails after the MSDP peer switchover in inter-domain multicast routing. What are the possible reasons?  27
Q.     Is inter-AS MD VPN supported by the router?· 27
Q.     Is IP multicast unavailable if I configure both of VPLS and IP multicast on the same interface of the router?  27
QACL· 27
Q.     Are QoS policy, port mirroring, and flow mirroring are supported on logical interfaces?· 27
Q.     What if both redirection and traffic policing are associated with one class in a QoS policy?· 28
Q.     What are the traffic priorities for CBQ?· 28
Q.     What can I configure to limit the traffic rate on an interface if I have configured a queue scheduling profile or CBQ on the interface?· 29
Q.     What is the default action in a QoS traffic behavior?· 29
Q.     How can I view the rate limit values for protocol packets to the control plane?· 29
Q.     What happens if I configure traffic policing for a user profile by using both the MQC and non-MQC approaches?  29
ATM·· 29
Q.     What are the restrictions and guidelines for configuring the interval argument for the oam loopback command?  29
Q.     What are the restrictions and guidelines for configuring an ATM P2P/P2MP subinterface?· 30
Q.     Can OAM continuity check be enabled on only one end of the network?· 30
Q.     What are the restrictions and guidelines for configuring an ATM network involving multicast or broadcast traffic?  31
Q.     Must the network types of the OSPF interfaces on both ends of an ATM network be the same?· 31
Q.     What are the restrictions and guidelines for configuring the schedule value for a WFQ queue on an ATM interface?  31
Q.     When configuring the ATM cell transmission rate for the local PVC, should I take the peak rate of the remote PVC into consideration?· 31
NAT· 32
Q.     How does the router perform NAT?· 32
Q.     Why routing protocols are not recommended to be configured on the interface with Easy IP configured?  32
Q.     Do I need to configure a QoS policy to redirect packets to be NATed to a NAT service card?· 32
Hardware
This section contains the most frequently asked questions about the router hardware.
A.     See Appendix A in the installation guide for the router series.
A.     No. The active and standby MPUs on a router must be the same model. If they are not the same model, the standby MPU will fail to start up.
A.     Yes. The router supports AC and DC power supplies.
A.     Yes.
A.     No.
A.     In IRF mode, the interfaces on the router are numbered in the interface-type A/B/C/D format. In standalone mode, the interfaces on the router are numbered in the interface-type B/C/D format.
·     A—IRF member ID of the chassis.
·     B—Slot number of the card.
·     C—Subslot number. If the card does not have a subslot, the subslot number is 0.
·     DInterface number.
A.     Yes. The standby MPU automatically takes over when the active MPU fails or is manually rebooted, to ensure service continuity.
For a successful active/standby switchover, make sure the active and standby MPUs run the same software version.
A.     Yes.
A.     Yes. As a best practice, hot-swapping a component when there is a minimum influence on the service and finish the hot-swapping as quickly as possible.
To avoid card damage and power-off protection of the router, finish hot-swapping a fan tray within 2 minutes.
A.     The operating temperature of the router is in the range of 0°C (32°F) to 45°C (113°F).
You can use the display environment command to display the router temperature statistics, including the current temperature and temperature thresholds.
·     When the temperature drops below the lower threshold or reaches the warning threshold, the router displays a log message and a trap.
·     When the temperature reaches the alarm threshold, the router repeatedly displays log and trap messages. It also alerts the user to the high-temperature condition through LEDs on the panel.
·     When the temperature reaches the shutdown threshold, the router generates a log message and a trap, and the cards automatically power off.
A.     Use the display device manuinfo command on the router.
[Sysname]display device manuinfo
A.     The router uses MPUs for data forwarding.
A.     All the MPUs except the CSR07SRPUA1 support CF cards.
A.     The power supplies adopt the following protective measures:
·     Input protection—Input over-voltage protection, input under-voltage protection, and input over-current protection.
·     Output protectionOutput over-voltage protection, output over-current protection, output short-circuit protection, and output over-temperature protection.
A.     See Appendix B in the installation guide for the router.
A.     Yes. Crossbar modules are built in MPUs, and crossbar module redundancy is implemented through MPU redundancy.
A.     Only the MIC-TCP8L and PIC-TCP8L subcards support interface type switching between POS and GE.
Only the following subcards support switching the interface type between GE and XGE:
·     All interfaces on the MIC-XP2L, MIC-XP2L-LAN, MIC-XP4L1, and MIC-XP20L subcards.
·     The last four interfaces on a MIC-XP5L, MIC-XP5L1, or MIC-XP5L2 subcard.
Software
This section contains the most frequently asked questions about the router software.
A.     Yes. After a software upgrade, you can roll back the Comware system software without rolling back the BootWare.
A.     Use the display version command. This command displays information about the current BootWare version, Comware system software version, and system operation time.
A.     No. The file contains the software images for MPUs and the software images for LPUs. MPUs and LPUs read these images during startup.
A.     Yes if the files were deleted by a delete command without the /unreserved option. A delete command with the /unreserved option permanently deletes files. A delete command without the /unreserved option moves commands to the recycle bin.
To view the commands in the recycle bin, use the dir /all command. The name of a file in the recycle bin is placed in brackets ([ ]).
You can use the undelete command to restore commands from the recycle bin.
A.     Use the reset recycle-bin command. If a file in the recycle bin is corrupt, use the reset recycle-bin command with the /force option to delete the file.
A.     Yes.
A.     The name of the default configuration file is flash:/startup.cfg.
A.     Before installing patches, perform the following tasks:
·     Save the patch image file in the same directory on the same type of storage medium (CF card or flash memory) on the MPUs.
·     Specify the path of the patch image file for the patch file location argument.
A.     The router does not display the current startup configuration file at the first startup:
<Sysname>display startup
MainBoard:
   Current saved-configuration file:          NULL
Next main startup saved-configuration file: flash:/startup.cfg
   Next backup startup saved-configuration file: NULL
SlaveBoard:
This section contains the most frequently asked questions about system management and maintenance.
A.     If nothing is displayed on the console terminal, examine the following:
·     Whether the power system is operating correctly.
·     Whether the MPUs are operating correctly.
·     Whether the console cable is connected to the console port correctly.
If no problem is found, the reason might be one of the following:
·     The access port specified for the terminal is different from the port to which the console cable is connected.
·     Settings on the configuration terminal are incorrect.
·     The cable has a problem.
If garbled characters are displayed on the terminal, settings on the configuration terminal might be incorrect.
The correct terminal settings are as follows:
·     Bits per second9600 bps
·     Flow controlNone
·     ParityNone
·     Stop bits—1
·     Data bits—8
·     Terminal display type—VT100
If you are running the terminal software SecureCRT, you must deselect the DTR/DSR option and RTS/CTS option for flow control. By default, the RTS/CTS option is selected for flow control.
A.     Perform the following tasks:
1.     Enter console user interface view.
2.     Use the speed command to change the data rate to 115200 bps.
3.     Close the connection.
4.     Initiate a new console connection.
A.     Use the free user-interface vty number command in user view.
A.     The username of a Telnet user that is configured on the router cannot contain the at sign (@).
A.     The MIB browser shows the values of the hardware counters. The reset counters interface command does not reset the hardware counters. This command clears only the statistics calculated by software.
A.     To format the CF card or flash memory:
1.     Access the extended BootWare menu.
2.     Access the storage media management menu and select the storage medium to be formatted.
3.     Format the storage medium.
Procedure:
For example, to format the flash memory:
1.     Power on or reboot the router.
The startup information appears. (Details not shown.)
2.     Press Ctrl + B within three seconds after the "Press Ctrl+B to access EXTENDED-BOOTWARE MENU..." prompt message appears.
The extended BootWare menu appears.
==========================<EXTENDED-BOOTWARE MENU>==========================
|<1> Boot System        |
|<2> Enter Serial SubMenu                                                            |
|<3> Enter Ethernet SubMenu                                                          |
|<4> File Control        |
|<5> Restore to Factory Default Configuration                                    |
|<6> Skip Current System Configuration                                             |
|<7> BootWare Operation Menu                                                         |
|<8> Skip Authentication for Console Login                                        |
|<9> Storage Device Operation                                                        |
|<0> Reboot        |
Ctrl+Z: Access EXTEND-ASSISTANT MENU
Ctrl+F: Format File System
Enter your choice(0-9): 9
3.     Enter 9 to access the storage media management menu.
==============================<DEVICE CONTROL>==============================
|<1> Display All Available Nonvolatile Storage Device(s)                        |
|<2> Set The Operating Device                                                         |
|<3> Set The Default Boot Device                                                     |
|<0> Exit To Main Menu        |
Enter your choice(0-3): 2
4.     Enter 2 to specify the operating storage medium.
Please set the operating device:
|Note:the operating device is flash                                                  |
|NO.  Device Name  File System  Total Size  Available Space                      |
|1    flash        JFFS2        503808KB    9604KB                                    |
|2    cfa0         FAT          4088468KB   3685136KB                                 |
|0    Exit        |
Enter your choice(0-2):1
Set the operation device successful!
5.     Enter 1 to use the flash memory as the operating storage medium.
Enter your choice(0-3): 0
6.     Enter 0 to return to the extended BootWare menu.
|<1> Boot System        |
|<4> File Control        |
|<0> Reboot        |
Ctrl+Z: Access EXTENDED ASSISTANT MENU
Warning:All files on flash will be lost! Are you sure to format? [Y/N] Y
7.     Press Ctrl+F to format the flash memory.
A.     Power on the router and press Ctrl+T or Ctrl+Y as prompted.
Press Ctrl+T to start the 5-step memory test procedure:
DDR2 SDRAM test successful.
System is starting...
Press Ctrl+D to access BASIC-BOOTWARE MENU...
Press Ctrl+T to start memory test
Running five-step RAM test...
This operation may take several minutes. Please wait...
DDR2 SDRAM dataline testing...                    [ PASS ]
DDR2 SDRAM addressline testing...                 [ PASS ]
Five-step RAM test succeeded.
Press Ctrl+Y to start the 9-step memory test procedure:
Press Ctrl+T to start five-step full RAM test...
Press Ctrl+Y to start nine-step full RAM test...
Running Nine-Step RAM test…
DDR2 SDRAM unit testing...                        [ PASS ]
Nine-Step ram test successful.
Booting Normal Extend BootWare
The Extend BootWare is self-decompressing.....................Done!
A.     The router relearns route entries, but it does not relearn MAC address entries and ARP entries.
The switchover does not interrupt MAC-based forwarding or ARP services because the MAC address table and the ARP table are backed up on the standby MPU. The impact on routing-based forwarding services depends on the configuration of GR or NSR:
·     If GR or NSR is configured, the switchover will not interrupt forwarding services.
·     If GR or NSR is not configured, the switchover will interrupt forwarding services.
A.     The configuration is saved on the flash memory or CF card. During startup, the router configures LPUs by loading the configuration to memory. If you execute the save command before the process is completed, the incomplete configuration in memory will be saved to the flash memory to replace the complete configuration, resulting in configuration loss.
A.     Yes. The interface can come up as long as the Layer 2 link is up. In addition, flow control is performed on the interface by software, and excessive packets arriving at the interface cannot affect system operation.
A.     This problem is caused by the TFTP server. Some TFTP servers have a limit of 32 MB on a transferred data block. When the amount of transferred data for the block reaches approximately 32 MB, the TFTP server stops requesting data transfer. If you experience this problem, please change the TFTP server software.
A.     Packets are discarded on the standby MPU's management Ethernet interface. To access the device over Ethernet, use the management Ethernet interface on the active MPU or an Ethernet port on the interface card.
IRF
This section contains the most frequently asked questions about IRF.
A.     An IRF fabric can have a maximum of two member chassis. You must connect them in a daisy-chain topology. Ring topology is not supported.
A.     No. The ports can be used only as IRF physical interfaces.
A.     Yes. You can use all types of service modules in IRF mode.
A.     Yes. When you connect two neighboring IRF members, you must connect the physical interfaces of IRF-port 1 on one member to the physical interfaces of IRF-port 2 on the other. The IRF fabric cannot be established if physical connections are incorrect.
When you bind physical interfaces to IRF ports, you must ensure that the bindings are consistent with the physical connections.
A.     In IRF mode, you must shut down a physical interface before you bind it to or remove it from an IRF port. You cannot shut down the interface if one of the following conditions exists:
·     The interface is the only member interface of a subordinate chassis in an IRF port binding.
·     Among all interfaces of a subordinate chassis in an IRF port binding, only the interface is in up state.
A.     No. No relay device is allowed between the member chassis.
A.     Yes.
A.     Yes, you can bind multiple physical links into one IRF connection. These links aggregate automatically. You do not need to create a link aggregation group as you do for creating an Ethernet link aggregation.
A.     No. You must assign a unique IRF member ID to each member chassis before setting up an IRF fabric. If a chassis has different member IDs on its active MPU and the standby MPU, the standby MPU will reboot automatically with the member ID on the active MPU.
A.     No. All MPUs in the IRF fabric must run the same version of software.
A.     No. Each subordinate chassis must have an MPU to communicate with the global active MPU and manage forwarding on the local chassis. If you remove both the MPUs on a subordinate chassis, its interface modules cannot communicate with each other to forward cross-card traffic correctly. If IRF physical interfaces are located on MPUs, removing both the MPUs on a subordinate chassis will cause IRF split.
A.     No. To run LACP MAD, make sure the aggregation meets following requirements:
·     The remote device is an IRF-capable device that can process the LACPDUs that convey the ActiveID field for MAD.
·     The aggregation mode is dynamic.
·     The aggregation includes a minimum of one link from each member chassis.
A.     Yes. You must assign the two IRF fabrics different domain IDs for correct split detection.
A.     If you reboot the active fabric instead of the recovery IRF fabric to complete an IRF merge, the network interfaces that were shut down by MAD cannot be restored automatically. You must use the mad restore command to restore their original physical state.
To avoid this issue, reboot the recovery IRF fabric instead of the active IRF fabric to complete an IRF merge.
A.     When an IRF fabric merges, the chassis in the Recovery-state IRF fabric reboots with the running configuration on the active IRF fabric. The configuration you made on the recovery IRF fabric will not take effect.
A.     Yes. In the running configuration, the active IRF fabric will retain the settings for the chassis in the recovery IRF fabric. You do not need to reconfigure these settings after the recovery IRF fabric rejoins the active IRF fabric. However, the display current-configuration command does not display these settings on the active IRF fabric before a merge. You cannot save the settings to the configuration file on the active IRF fabric. The settings will be lost if the active IRF fabric reboots before an IRF merge occurs.
A.     The following events can cause data traffic to not be forwarded at the wire speed across chassis in an IRF fabric:
·     Tag removal on outgoing ports—Frames sent on IRF links always have a 4-byte VLAN tag. If the VLAN tag is removed on the outgoing port, the traffic rate will not reach the wire speed.
·     Unbalanced traffic distribution—IRF distributes traffic across member chassis on a flow-by-flow basis. All traffic of a flow will be forwarded on the same IRF link. As a result, some IRF links might have heavy traffic while others have light traffic.
·     Control traffic—Part of bandwidth is used for configuration synchronization and IRF protocol traffic (for example, IRF hello packets) between member chassis.
This section contains the most frequently asked questions about network security and attack prevention.
A.     The router supports protection against link layer, ARP, network layer, and transport layer attacks, as shown in Table 1.
Table 1 Attack prevention types
Link layer
MAC address attack prevention
Prevents the attack of packets with different source MAC addresses or VLANs by limiting the maximum number of MAC addresses that an interface can learn.
STP packet attack protection
Provides protection measures such as BPDU guard, root guard, loop guard, port role restriction, TC-BPDU transmission restriction, and TC-BPDU guard.
ARP attack
ARP source suppression
Prevents IP attack packets from fixed sources.
ARP black hole routing
Prevents IP attack packets from sources that are not fixed.
ARP active acknowledgement
Prevents user spoofing.
ARP safe-guard
Prevents traffic-intensive ARP packet attacks.
Source MAC-based ARP attack detection
Prevents ARP packet attacks from the same source MAC.
ARP packet source MAC consistency check
Prevents attacks from ARP packets whose source MAC address in the Ethernet header is different from the sender MAC address in the message body.
ARP packet rate limiting
Prevents ARP packet attacks on a per-interface basis by limiting the rate of ARP packets delivered to the CPU when the number of incoming ARP packets exceeds the maximum ARP packet rate.
ND attack
Source MAC-based ND attack detection
Prevents ND packet attacks from the same source MAC.
ND packet rate limiting
Prevents ND packet attacks on a per-interface basis by limiting the rate of ND packets delivered to the CPU when the number of incoming ND packets exceeds the maximum ND packet rate.
Network layer
uRPF check
Protects a network against source spoofing attacks.
TTL attack prevention
Prevents an attack by disabling sending ICMP time exceeded messages.
ICMP attack prevention
Prevents the attack of excessive ICMP requests by enabling the hardware to reply to the requests.
IGMP suppression
Prevents IGMP packet attacks by limiting the IGMP packet rate on a per-MAC basis or by limiting the rate of IGMP packets delivered to the CPU on a per-interface basis.
·     Source-MAC-based IGMP suppression—When the number of IGMP packets from a MAC address exceeds the threshold within the check interval, the device drops IGMP packets from the MAC address.
·     Interface-based IGMP suppression—When the number of IGMP packets on an interface exceeds the threshold within the check interval, the device limits the rate for sending IGMP packets to the CPU.
MLD suppression
Prevents MLD packet attacks by limiting the MLD packet rate on a per-MAC basis or by limiting the rate of MLD packets delivered to the CPU on a per-interface basis.
·     Source-MAC-based MLD suppression—When the number of MLD packets from a MAC address exceeds the threshold within the check interval, the device drops MLD packets from the MAC address.
·     Interface-based MLD suppression—When the number of MLD packets on an interface exceeds the threshold within the check interval, the device limits the rate for sending MLD packets to the CPU.
Malformed packet attack prevention
Prevents malformed packet attacks by dropping the following received packets:
·     Land packets in which the source and destination IP addresses are the same and the source and destination ports are the same.
·     ICMP echo requests in which the destination IP address is a broadcast address.
·     Empty IP, TCP, or UDP packets that only have the header and do not have high-layer data.
Source route option packet attack prevention
Disables the device from processing packets that contain the source route option to prevent a forged source route option from affecting network failure troubleshooting and specific service transmission.
Transport layer
TCP SYN flood attack prevention
An attacker sends a large number of SYN packets to a server. This causes the server to open a large number of half-open connections and respond to the requests. However, the server will never receive the expected ACK packets. Because all of its resources are bound to half-open connections, the server is unable to accept new incoming connection requests.
After you enable TCP SYN flood attack prevention, the device enters attack detection state. When the number of received SYN packets reaches or exceeds the threshold within a check interval, the device changes to prevention state and rate limits (on a per-interface basis) or drops subsequent SYN packets (on a per-flow basis).
UDP flood attack prevention
A UDP flood attacker sends a large number of UDP packets to a target system within a short period of time. Busy processing these packets, the target system cannot respond to normal services.
After you enable UDP flood attack prevention, the device enters attack detection state. When the number of received UDP packets reaches or exceeds the threshold during a check interval, the device changes to prevention state and rate limits (on a per-interface basis) or drops subsequent UDP packets (on a per-flow basis).
Application layer
Interface-based DHCP attack suppression
Enables the device to drop DHCP packets that exceed the specified DHCP packet rate threshold.
DHCP flood attack prevention
Prevents DHCP flood attacks by limiting the DHCP packet rate on a per-MAC basis or by limiting the rate of DHCP packets delivered to the CPU on a per-interface basis.
·     MAC-based DHCP flood attack prevention—If the number of DHCP packets from the same MAC address reaches the upper limit in the detection duration, the server determines that the client is launching a DHCP flood attack and drops the DHCP packets from that client.
·     Interface-based DHCP flood attack prevention—If the number of DHCP packets received on an interface reaches the upper limit in the detection duration, the server determines that a DHCP flood attack occurs on the interface and limits the rate of DHCP packets that the interface delivers to the CPU.
Application layer
PPPoE PADI attack prevention
Disables the server from replying to requests sent from a PPPoE user within a time period if the user performs the following operations:
·     Send excessive PADI packets to the server.
·     Come online or go offline frequently.
A.     Table 2 describes roles that the router supports when it uses different SSH versions.
Table 2 Router roles and SSH versions
Version
SSH1
SSH2
SR8800-X
Acts as the server.
Acts as the server and the client.
A.     The user can log in to an ACS server through a console port only when you deselect the Login-Service option for the ACS server configuration.
A.     The symptom might occur when one of the following conditions takes place:
·     The 2011/002 private attributes for the ACS server are not complete.
·     The Login-Service attribute for the ACS server is not configured.
A.     The router supports local authentication when a HWTACACS authentication fails because the server is not reachable.
The router does not support local authentication when a HWTACACS authentication fails because of an incorrect username or password.
To perform local authentication when the HWTACACS server is not reachable, specify a HWTACACS scheme, and then the local keyword when you configure the authentication method. For example, configure the default authentication method for the ISP domain abc as follows:
[Sysname] domain abc
[Sysname-isp-abc] authentication default hwtacacs-scheme hwtacacs1 local
A.     As long as the TACACS server is configured with the standard RADIUS protocol, the router can be connected to the server. The servers include ACS servers from Cisco and TACACS servers open to public (for example, free TACACS servers).
A.     It depends on whether a service type is specified on the server. If a service type is specified on the server, the reply includes the Login-Service option. If no service type is specified on the server, the reply does not include the Login-Service option.
A.     You can set the user role in one of the following ways:
·     Execute the user-role command in user line view or user line class view to assign a user role to a user line. Users who log in through the user line will get the user role.
·     Execute the authorization-attribute user-role command in local user view to specify a user role for the local user account.
·     If AAA remote authentication is used, set the user role on the remote server.
A.     The 0 to 16 levels of HWTACACS and ACS are matched level by level.
A.     The user role configured on a RADIUS server or a HWTACACS server is assigned. Both the default user roles are network-operator.
For example, if the user role network-admin or level 15 is configured in VTY user interface, and no user role is configured on the server, the user role network-operator is assigned to the Telnet user.
If no user role is configured in VTY user interface, and the user role level 15 is configured on the server, the user role level 15 is assigned to the Telnet user.
The user role configured in VTY user interface is assigned only after the authentication-mode none command or the password command is executed.
A.     When receiving an ARP packet from a device that acts as a gateway, the router (the gateway) sends a gratuitous ARP packet to modify the spoofed ARP entries. If a large number of attack packets exist, the router detects the incoming interface of the attack packets, captures the packets to obtain packet information, and applies an ACL to filter the attack packets.
Network access
This section contains the most frequently asked questions about network access.
A.     On the router, the port count can be up to 64 bits, and the port count will be reset after it exceeds 64 bits.
A.     Table 3 and Table 4 describe the error packet fields in the output from the display interface command.
Table 3 Error packet fields for input packets
input errors
Statistics of error packets received by the port.
runts
Number of inbound runt frames shorter than 64 bytes, in correct format, and containing valid CRCs.
giants
Number of inbound giant frames larger than the maximum frame length supported on the interface and containing valid CRCs.
throttles
Number of inbound frames shorter than 64 bytes and containing CRC errors.
CRC
Total number of inbound frames that had a normal length, but contained CRC errors.
frame
Total number of inbound frames that contained unknown errors.
overruns
Number of packets dropped because the input rate of the port exceeded the queuing capability. This problem occurs when the network is congested.
aborts
Number of inbound frames with input description errors.
ignored
Number of inbound frames dropped because the receiving buffer of the incoming interface ran low.
parity errors
Number of inbound frames with parity errors.
Table 4 Error packet fields for output packets
output errors
Total number of packets with various sending errors.
giants
Number of outbound giant frames larger than the maximum frame length supported on the interface and containing valid CRCs.
Underruns
Number of packets dropped because the output rate of the interface exceeded the output queuing capability.
buffer failures
Number of packets dropped because the transmit buffer of the interface ran low.
aborts
Packets that failed to be forwarded at the MAC layer due to network congestion.
deferred
Number of frames that the interface operating in half duplex mode deferred to transmit because of detected collisions.
collisions
Number of frames that the interface stopped transmitting because Ethernet collisions were detected during transmission.
late collisions
Number of frames that the interface deferred to transmit and were buffered at the MAC layer.
lost carrier
Number of carrier losses during transmission.
no carrier
Number of times that the port failed to detect the carrier when attempting to send frames.
The output packet errors seldom occur. Most packets errors are input packet errors.
·     If error frames of the runts, giants, throttles, CRC, or frame type are received, you must identify whether the peer device or the link has failed.
·     If overruns error frames are received, you must verify whether the link bandwidth of the local end is sufficient.
A.     The router supports configuring an Ethernet interface to permit jumbo frames and setting the maximum jumbo frame size. If an incoming frame is longer than the maximum jumbo frame size, the router drops the frame. The maximum jumbo frame size varies by card. For more information, see the command references for the router.
A.     MPLS forwarding does not fragment oversized packets by default. If you execute the mpls mtu command on the MPLS public interface, L3VPN forwarded packets can be fragmented. If packets are forwarded on a P node, you must use the mpls l3vpn fragment enable command to enable fragmentation.
For regular Layer 3 forwarding, IPv4 protocol will fragment packets larger than the MTU by default. IPv6 protocol specifies no fragmentation and the packets will be sent directly to the CPU for processing.
In tunnel forwarding, IPv4 protocol will fragment packets larger than the MTU by default. IPv6 protocol does not fragment packets.
The tunnel packet fragmentation method is as follows:
·     The inner layer packet is fragmented, and the fragmented packets are separately added with a tunnel header.
·     Fragmentation of the encapsulated packet after adding the tunnel header.
The fragmentation of the inner layer packet and the fragmentation of the packet after adding the tunnel header will not occur at the same time.
A.     Yes.
A.     Yes. When MAC address entries change on a card, the MAC address entries are automatically synchronized to all cards.
A.     By default, the aging time for dynamic MAC address entries is 5 minutes. To modify the aging time, use the mac-address timer aging command.
When a data flow enters a port, the MAC address of the data flow is dynamically learned. When the data flow continues to send traffic, the aging time of the MAC address entry continues to be refreshed, and the MAC address entry will not be aged. When the data flow stops sending traffic, the MAC address entry is aged after the aging time expires.
A.     When the MAC address learning limit is set to 0 on a port, the port does not learn source MAC addresses. Destination unknown frames are broadcast in VLANs by default. To prevent the router from forwarding source-unknown frames after the MAC learning limit is reached, use the undo mac-address max-mac-count enable-forwarding command.
A.     These MAC address entries are learned before the mac-address max-mac-count 0 command is configured to disable MAC address learning. When MAC address learning is disabled, the software waits for these MAC address entries to age out, or the MAC address entries can be deleted by using the undo mac-address command.
A.     The router learns MAC address entries in the MAC+VLAN method. When multiple VLANs receive packets with the same MAC address, all these VLANs will learn the MAC address.
A.     Yes.
Rate-based load sharing is supported only when 1-GE and 10-GE interfaces or 10-GE and 100-GE interfaces are aggregated to form a single Ethernet link aggregation group.
A.     By default, traffic is load-shared among member ports based on their rates.
The load sharing mode varies by card model. You can use the link-aggregation global load-sharing mode command to configure the global load sharing mode.
In a link aggregation group, traffic can be load shared across the Selected ports based on any of the following modes:
·     Per-flow load sharing—Load shares traffic on a per-flow basis. The load sharing mode classifies packets into flows and forwards packets of the same flow on the same link. This mode can be one or any combination of the following traffic classification criteria:
¡     Source or destination MAC address.
¡     Source or destination port number.
¡     Ingress port.
¡     Source or destination IP address.
¡     Protocol number.
¡     MPLS label.
·     Per-packet load sharing—Load shares traffic on a per-packet basis.
A.     Yes.
A.     No. When both ends of a link are down, DLDP neighborship cannot be established. As a result, DLDP does not take effect.
A.     The router supports diagnosing transceiver modules. A port might come down if the Rx or Tx optical power of its transceiver module is out of the range. Verify that the transceiver modules are the same type at the two ends and the link is operating correctly if any of the following error messages is displayed:
·     RX power is high!
·     RX power is low!
·     TX power is high!
·     TX power is low!
A.     The port rate percentage is the ratio of the actual traffic to the total port bandwidth and describes the actual port bandwidth usage. When you calculate the port rate percentage, the inter-frame gap and the preamble must be added as follows:
(ulActualSpeed + 20 (preamble + inter-frame gap) * ulPktSpeed) * 8/ulRatedSpeed
·     ulActualSpeed—Rate in kbps (the field in red) in the output.
·     ulPktSpeed—Rate in pps (the field in blue) in the output.
·     ulRatedSpeed—Port rate. For example, the port rate of a 10-GE port is 10000000000 bps.
[Sysname-Ten-GigabitEthernet3/1/2]display interface te-gigabitEthernet 3/1/2
 Ten-GigabitEthernet3/1/2 current state: DOWN
 IP Packet Frame Type: PKTFMT_ETHNT_2, Hardware Address: 00e0-fc00-0000
 Description: Ten-GigabitEthernet3/1/2 Interface
 Loopback is not set
 Peak value of input: 0 bytes/sec, at 2000-04-26 12:00:32
 Peak value of output: 0 bytes/sec, at 2000-04-26 12:00:32
 Last 300 seconds input:  0 packets/sec 0 bytes/sec      0%
 Last 300 seconds output:  0 packets/sec 0 bytes/sec     0%
 Input (total):  0 packets, 0 bytes
          - unicasts, - broadcasts, - multicasts
 Input (normal):  0 packets, 0 bytes
          0 unicasts, 0 broadcasts, 0 multicasts
          - ignored, - parity errors
          - unicasts, - broadcasts, - multicasts, - pauses
 Output (normal): 0 packets, 0 bytes
          - lost carrier, - no carrier
A.     When fiber GE ports are connected and the local port is manually configured with a speed and duplex mode, the local port can go up only if the port can receive fiber signals. When the speed and duplex mode of the local port are autonegotiated, the local port goes down when the peer port goes down.
When fiber 10-GE ports of two routers of this router series are connected, the MAC layer will negotiate the port status. If one end detects local faults, the port will go down and send remote faults to notify the remote end. When the remote end detects remote faults, the remote port will go down.
When the port of the router connects to the port of a device not of this router series, the local port does not go down if both of the following conditions exist:
·     The remote port is down but sends out fiber signals correctly.
·     The remote port does not send remote faults.
For a 10-GE interface installed with GE transceiver module on an MIC-XP4L1, MIC-XP2L, and MIC-XP2L-LAN interface subcard of a CSPEX-1104-E card, you can set the duplex mode of the local and peer end to full and set the interface speed to 1000 Mbps. When configuring the duplex mode, follow these restrictions and guidelines:
·     Fiber ports do not support the half keyword.
·     For an interface subcard on a CSPEX-1104-E or CSPEX-1204 card, copper ports do not support the half duplex mode. For an interface subcard on other CSPEX cards, only the fiber ports on a MIC-GP4L interface subcard support the half duplex mode.
·     For a GE interface on a MIC interface subcard of a CSPEX-1204 card, the full and half duplex modes at 10 or 100 Mbps is not supported.
When you configure the speed for a 10-GE interface subcard on a CSPEX-1304S, CSPEX-1404S, CSPEX-1504S card, follow these restrictions and guidelines:
·     Only the MIC-XP2L, MIC-XP2L-LAN, MIC-XP4L1, MIC-XP5L, and MIC-XP5L1 interface subcards support switching the speed between 1000 Mbps and 10000 Mbps.
·     After you execute the speed auto command on a MIC-XP2L, MIC-XP2L-LAN, MIC-XP4L1, MIC-XP5L, and MIC-XP5L1 interface subcard, the interface can negotiate a speed with its peer and operate at 10, 100, or 1000 Mbps.
·     Interfaces 1 and 2 on the MIC-XP2L or MIC-XP2L-LAN interface subcards form an interface group. When you switch the speed of this interface group, all interfaces under the interface group will switch speed simultaneously.
·     On a MIC-XP4L1 interface subcard, interfaces 1 and 3 form an interface group, and interfaces 2 and 4 form an interface group. When you switch the speed of these interface group, all interfaces under the interface group will switch speed simultaneously.
·     On a MIC-XP5L or MIC-XP5L1 interface subcard, interfaces 2 and 4 form an interface group, and interfaces 3 and 5 form an interface group. When you switch the speed of these interface group, all interfaces under the interface group will switch speed simultaneously. Interface 1 on the MIC-XP5L or MIC-XP5L1 interface subcards do not support switching speed.
The speed of a GE interface on a PIC-TCP8L interface subcard supports only autonegotiation, and can only be negotiated to 1000 Mbps.
When you configure the interface speed, follow these restrictions and guidelines:
·     40-GE and 100-GE interfaces can only operate at the maximum speed.
·     Interfaces on the MIC interface subcard of a CSPEX-1104-E and CSPEX-1204 card support the 1000 and auto keywords.
·     When you configure the speed for a 10-GE interface subcard on a CSPEX-1304S, CSPEX-1404S, and CSPEX-1504S cards to auto, 10-GE transceiver modules are not supported.
When you configure the duplex mode, fiber ports do not support the half keyword.
When you configure the interface speed, 100-GE interfaces can only work at the maximum speed.
After you execute the speed 1000 and speed auto command on an interface of a RX-NIC-XP5L, RX-NIC-XP10L, and RX-NIC-XP20L interface subcard:
·     The system will deliver the configuration with two ports as a group. The specific port number is subject to the actual prompt information of the device. When the interface group includes member interfaces of an aggregation group, the configuration is not supported.
·     After configure the speed auto command, the interface can negotiate a speed with its peer and operate at 10, 100, or 1000 Mbps.
Layer 3 Ethernet subinterface, Layer 3 aggregate subinterface, L2VE subinterface, and L3VE subinterface support the following types of VLAN termination:
·     Ambiguous Dot1q termination.
·     Unambiguous Dot1q termination.
·     Ambiguous QinQ termination.
·     Unambiguous QinQ termination.
·     Untagged termination.
·     Default termination.
A.     According to the creation method of VLAN termination related entries, VLAN termination on sub-interfaces include regular termination and user VLAN termination.
·     Regular terminationIncludes regular Dot1q termination (vlan-type dot1q vid) and regular QinQ termination (vlan-type dot1q vid second-dot1q). After configuration, the device will immediately create entries to record the configured VLAN termination information.
·     User VLAN terminationIncludes user VLAN Dot1q termination (user-vlan dot1q vid), user VLAN QinQ termination (user-vlan dot1q vid second-dot1q), and user VLAN Default termination (user-vlan dot1q default). After configuration, the device will only dynamically create entries for online users in the specified VLAN to save system resources.
User VLAN termination is suitable for BRAS user access scenarios, such as IPoE or PPPoE networking.
A.     Yes. Use the traffic-statistic enable command to enable Ethernet interface statistics collection.
This section contains the most frequently asked questions about IP forwarding services.
A.     Yes. You can configure a secondary IP address for a Layer 3 Ethernet interface of the router. The secondary IP address has similar functions to the primary IP address. The secondary IP address cannot be used for multicast. The users on the network segment to which the secondary IP address belongs cannot receive any multicast packets or establish OSPF neighbor relationship.
In addition, you can configure secondary IP addresses for any Layer 3 interfaces, including Layer 3 Ethernet interfaces (subinterfaces), Layer 3 aggregate interfaces (subinterfaces), and VLAN interfaces.
A.     Yes. The primary and secondary IP addresses are independent on a Layer 3 Ethernet interface. The secondary IP address on a Layer 3 Ethernet interface is still valid after you remove the primary IP address from that interface.
A.     When an Ethernet interface operates in bridge mode (configured with the port link-mode bridge command), the router examines the MAC address of a packet received on the interface. If the MAC address of the packet matches the MAC address of the VLAN interface, the router forwards the packet at Layer 3 or sends the packet through MPLS network. If not, the router forwards the packet at Layer 2.
A.     Yes.
A.     The route with a 32-bit mask obtained from the routing table has a higher priority.
A.     When sending an ICMP echo request whose size (including the IP header) exceeds 1500 bytes (the default MTU value), the router fragments the packet. If the Don't fragment flag is set, the packet fails to be sent out.
When receiving an ICMP echo request that exceeds 1500 bytes, the router can process the request and respond with an ICMP echo reply if configured with jumbo frame support. The router fragments the reply if its size exceeds 1500 bytes.
A.     Upon receiving an ICMP echo request, the CPU of the router responds with an ICMP echo reply.
Upon receiving an ICMP echo reply, the router sends the next request by default. If no reply is received, the router sends the next request when the aging timer expires. By default, the aging timer is 2 seconds.
If you specify the -m interval option in the ping command, the router sends the next ICMP echo request at the specified interval after receiving an ICMP echo reply.
A.     The local mirroring group supports cross-card port mirroring. The mirroring source and destination can reside on different cards of a router.
A.     Yes. The router supports remote port mirroring.
A.     The router supports the following tunneling technologies:
·     GRE tunneling. For more information, see GRE configuration in Layer 3—IP Services Configuration Guide.
·     IPv6 over IPv4 tunneling—Enables IPv6 packets to traverse IPv4 networks and enables isolated IPv6 networks to communicate.
·     IPv4 over IPv4 tunneling/GRE tunneling—Creates VPN to ensure communication security.
·     IPv4 over IPv6 tunneling—Adds an IPv6 header to IPv4 packets so that the IPv4 packets can pass an IPv6 network through a tunnel to realize interworking between isolated IPv4 networks.
·     MPLS TE tunneling—Implements traffic engineering to prevent network congestion.
·     VXLAN tunneling—Uses a MAC-in-UDP technology to provide Layer 2 connectivity between distant network sites across an IP network. VXLAN is typically used in data centers for multitenant services.
·     SR-MPLS tunneling—Supports segment routing based on existing MPLS framework. After an SR-MPLS tunnel is established, you need to steer service packets to the tunnel. The service packets that can be steered to and forwarded by the SR-MPLS tunnel include public network, L3VPN, VPLS, and EVPN service packets.
·     SRv6 tunneling—Supports segment routing based on IPv6 framework. The tunnel ingress node encapsulates data packets with an IPv6 basic header and an SRH. The transit nodes use the SIDs in the SRH to replace the destination IPv6 address of the packets and forward the packets. The egress node executes the functions corresponding to the last SID.
A.     BFD supports the following protocols and features:
·     BFD for IPv4 routing protocols, including IPv4 static routing, RIP, OSPF, IS-IS, BGP, and PIM.
·     BFD for IPv6 routing protocols, including IPv6 static routing, OSPFv3, IPv6 IS-IS, IPv6 BGP, and IPv6 PIM.
·     BFD for MPLS features, including LSP, MPLS TE, and PW.
·     BFD for policy-based routing and Track.
·     BFD for IP FRR and MPLS TE FRR.
·     BFD for Ethernet link aggregation.
·     BFD for interface.
·     BFD for MAD.
·     BFD for SRv6 PW.
·     SBFD/BFD echo for SRv6 TE policy.
To meet the requirements for high-performance and large-scale service rapid detection, you can use hardware BFD. In hardware BFD, the CPU completes session parameter negotiation on the control plane and the hardware completes high-speed detection on packet transmission and reception. This feature requires the support of special network chips. For more information, see BFD configuration in High Availability Configuration Guide.
A.     The router supports the following load sharing modes:
·     Per-flow load sharing based on destination IP address of packets.
·     Per-flow load sharing based on destination MAC address of packets.
·     Per-flow load sharing based on destination port of packets.
·     Per-flow load sharing based on source IP address of packets.
·     Per-flow load sharing based on source MAC address of packets.
·     Per-flow load sharing based on source port of packets.
·     Per-flow load sharing based on IP protocol number of packets.
·     Packet-based per-flow load sharing.
·     Packet-based per-packet load sharing.
The default algorithm for packet-based per-flow load sharing is XOR16. Other algorithms include CRC16, CRC16XOR1, CRC16XOR2, CRC16XOR4, CRC16XOR8, and CRC16CCITT.
IP routing
This section contains the most frequently asked questions about IP routing.
A.     Yes. A blackhole route is a static route whose output interface is Null 0. The router discards the matching packets without sending ICMP messages to notify the source host. To prevent IP attacks, you can configure blackhole routes to discard packets destined for specific destinations. The following example shows how to configure a blackhole route:
[Sysname] ip route-static 1.1.1.1 32 null 0 preference 1
A.     Yes. By default, a Layer 3 Ethernet interface automatically computes its OSPF cost according to the interface rate with the following formula: Interface OSPF cost = Bandwidth reference value (100 Mbps) / Interface rate (Mbps).
If the calculated cost is greater than 65535, the value of 65535 is used. If the calculated cost is smaller than 1, the value of 1 is used.
A.     Routing protocols, including static routing, each have a preference by default. If they find multiple routes to the same destination, the router selects the route with the highest preference as the optimal route. The preference of a direct route is always 0 and cannot be changed. You can configure a preference for each static route and each dynamic routing protocol. Table 5 lists the route types and default preferences. The smaller the value, the higher the preference.
Table 5 Route types and default route preferences
Route type
Preference
Direct route
0
OSPF
10
IS-IS
15
Static route
60
RIP
100
OSPF ASE
150
OSPF NSSA
150
IBGP
255
EBGP
255
Unknown (route from an untrusted source)
256
A.     The following configuration errors cause the router to output the OSPF CONFIG ERROR trap:
·     The local interface and its directly connected interface are on the same network segment but in different areas.
·     The virtual link configuration is performed on the peer device but not on the router. When the router receives packets sent from the peer device through the virtual link, the router outputs the OSPF CONFIG ERROR trap.
A.     No. If the PBR-based forwarding fails because of nonexistent next hop, the router forwards the matching packets based on the IP routing table.
MPLS
This section contains the most frequently asked questions about MPLS.
A.     You can configure label acceptance policies on the router to achieve the purpose. A label acceptance policy uses an IP prefix list to control the label mappings received from a peer. This example uses LDP peer 1.1.1.9:
[Sysname]ip prefix-list host index 10 permit 0.0.0.0 0 greater-equal 32 less-equal 32
[Sysname]mpls ldp
[Sysname-mpls-ldp]accept-label peer 1.1.1.9 prefix-list host
After the configuration, the router accepts only the FEC-label mappings containing 32-bit prefixes from LDP peer 1.1.1.9.
To remove the label acceptance policy and accept non-32-bit prefixes from the LDP peer, execute the reset mpls ldp peer command. More LSPs will be created as a result, using up the LSP resources on the router.
A.     To display the real path by using the tracert facility after TTL propagation is enabled, you must refresh the route entries.
IP multicast
This section contains the most frequently asked questions about IP multicast.
A.     The router supports IGMPv1, IGMPv2, and IGMPv3. By default, the router runs IGMPv2.
A.     Yes. You can use the static-rp rp-address [ acl-number | bidir | preferred ] *command to configure a static RP. You can also use this command to define the multicast group range to which the static RP is designated and to give priority to the static RP.
When you configure a static RP, follow these restrictions and guidelines:
·     If you specify the preferred keyword, the static RP takes priority. The dynamic RP takes effect only if the static RP fails. If you do not specify the preferred keyword, the dynamic RP takes priority.
·     You must configure the same static RP for all routers in the PIM domain.
A.     Yes. You can configure static multicast routes to create or change RPF routes.
A.     You can configure an ACL to permit multicast packets only from legal sources. For example, to permit only packets from the source 99.100.100.4 to the group 225.1.1.1, follow these steps:
1.     Configure an ACL.
[Sysname] acl advanced 3000
[Sysname-acl-ipv4-adv-3000] rule 0 permit ip source 99.100.100.4 0 destination 225.1.1.1 0
[Sysname-acl-ipv4-adv-3000] rule 1 deny ip
2.     Use the source-policy command in PIM view to reference the configured ACL.
[Sysname-pim] source-policy 3000
A.     Yes. You can configure a multicast group policy by using the igmp-snooping group-policy acl-number [ vlan vlan-list ] command in Layer 2 Ethernet interface view or Layer 2 aggregation interface view.
When you configure a multicast group policy, follow these restrictions and guidelines:
·     Receiver hosts can join only the multicast groups that the specified ACL permits. If the specified ACL does not exist or the ACL does not have any valid rules, receiver hosts cannot join any multicast groups.
·     The multicast group policy takes effect on all ports in the specified VLANs.
·     The multicast group policy does not take effect on static member ports.
·     When you execute this command in Layer 2 Ethernet interface view or Layer 2 aggregate interface view, one of the following occurs:
¡     If you do not specify a VLAN, this command takes effect on all VLANs to which the interface belongs.
¡     If you specify a VLAN, this command takes effect only when the interface belongs to the specified VLAN.
A.     The RPF check fails due to either of the following reasons:
·     The configuration for the static RPF peer is not correct. For example, the filtering policy for the static RPF peer is incorrect.
·     Loops exist between MSDP peers, causing packets to arrive at non-RPF interfaces.
A.     Yes.
A.     Yes. Do not configure both of VPLS and IP multicast on the same interface of the router.
QACL
This section contains the most frequently asked questions about QACL.
A.     Table 6 shows the support of different logical interfaces for QoS policy, port mirroring, and flow mirroring.
Table 6 Support of different logical interfaces for QoS policy, port mirroring, and flow mirroring
Interface type
QoS policy
Port mirroring
Flow mirroring
Remarks
Yes. Applied to the aggregate interface.
The source port must be assigned to the aggregate interface as a member port.
N/A
Yes. Applied to the aggregate subinterface.
The source port must be assigned to the aggregate subinterface as a member port.
N/A
Supported on only on member ports.
N/A
VLAN interface
A QoS policy cannot be applied in VLAN interface view, but can be applied in system view. A QoS policy applied in system view takes effect on both the Layer 2 traffic the entire VLAN and the Layer 3 traffic of the VLAN interface.
The source port must be assigned to the VLAN.
A QoS policy containing flow mirroring configuration cannot be applied in VLAN interface view, but can be applied in system view. A QoS policy applied in system view takes effect on both the Layer 2 traffic the entire VLAN and the Layer 3 traffic of the VLAN interface.
N/A
A.     The system first performs traffic policing to discard excess packets and then redirects conforming packets, regardless of the configuration order of the two actions.
Note that packets can be redirected only to internal ports of OAP cards.
A.     The matching traffic is enqueued according to the following rules:
·     LLQ (EF)—When congestion does not occur, the excess traffic can be forwarded. When congestion occurs, the excess traffic is dropped preferentially.
·     BQ (AF)The excess traffic and traffic in BE queues (including the default BE queue) are scheduled by using WFQ.
·     Default BE queue—Traffic does not match any criteria in CBQ is assigned to this queue.
On CSPEX-1204 cards, two CBQ modes are available: standard CBQ and advanced CBQ.
·     Standard CBQ—The following types of traffic are in descending order of priority:
¡     Traffic within the minimum guaranteed bandwidth for EF.
¡     Traffic within the minimum guaranteed bandwidth for AF.
¡     Traffic beyond the minimum guaranteed bandwidth for AF and BE traffic.
¡     Traffic beyond the minimum guaranteed bandwidth for EF.
·     Advanced CBQ—The following types of traffic are in descending order of priority:
¡     Traffic within the minimum guaranteed bandwidth for EF and traffic within the minimum guaranteed bandwidth for AF.
¡     Traffic beyond the minimum guaranteed bandwidth for EF, traffic beyond the minimum guaranteed bandwidth for AF, and traffic in BE queues configured with WFQ weights.
¡     Traffic in BE queues not configured with WFQ weights.
On CSPC-GE16XP4L-E, CSPC-GE24L-E, CSPC-GP24GE8XP2L-E, and CSPEX(except CSPEX-1204) cards, the following types of traffic are in descending order of priority:
·     Traffic within the minimum guaranteed bandwidth for EF.
·     Traffic within the minimum guaranteed bandwidth for AF.
·     Traffic beyond the minimum guaranteed bandwidth for EF, traffic beyond the minimum guaranteed bandwidth for AF, and traffic in BE queues configured with WFQ weights.
·     Traffic in BE queues not configured with WFQ weights.
A.     As a best practice, configure a rate limit by using the qos lr command. Do not configure traffic policing (qos car) or traffic shaping (qos gts).
A.     By default, no action exists in a QoS traffic behavior.
Use the display hardware internal rxtx proto-limit-speed command in probe view on the following cards:
Use the display hardware internal rxtx tm command in probe view on the following cards:
CSPEX-1104-E, CSPEX-1204, CSPC-GE16XP4L-E, CSPC-GE24L-E, CSPC-GP24GE8XP2L-E
A.     The union of the configurations takes effect. The CIR, CBS, EBS, and PIR values that take effect are the smaller ones if they are configured in both approaches.
ATM
This section contains the most frequently asked questions about ATM.
A.     H3C recommends that you configure the value of the interval argument as 10.
With OAM F5 Loopback cell transmission and retransmission detection enabled, the local end checks the PVC state of the remote end by sending OAM F5 loopback cells. If the local end receives a response from the remote end within the time specified by the interval argument, the remote PVC is up. Otherwise, the remote PVC is down. When detecting that the remote PVC is down, the local end changes its own PVC to down state.
If you configure the interval argument as 1, the PVC down event is detected in 5 to 6 seconds. When the link is unstable, to prevent frequent changes between up and down events, configure the interval argument as 10. The PVC down event can then be detected in 15 to 25 seconds.
A.     Configure the map ip default command on a P2P subinterface.
Configure the map ip { ip-address | inarp [ minutes ] } command on a P2MP subinterface.
If you configure the map ip default command on a P2MP interface, the routes cannot be switched immediately when OAM detects that the PVC is down.
The following examples show how to configure P2P and P2MP subinterfaces.
·     Configure map ip default command on the P2P subinterface ATM 2/1/1.1:
interface Atm2/1/1.1 p2p
pvc 5/81
  oam loopback 10 up 3 down 3 retry 1
  broadcast
  map ip default
 ip address 1.1.1.1 255.255.255.252
·     Configure the map ip { ip-address | inarp [ minutes ] } command on the P2MP subinterface ATM 2/1/1.1:
interface Atm2/1/1.1 p2mp
 description TeleCom ATM To ShangHai
 pvc 5/81
 broadcast
 map ip 1.1.1.2
A.     No. OAM continuity check must be enabled on both ends of the network. Otherwise, link flapping might occur.
H3C recommends that you configure the oam cc command on both ends. If the PVC on one end is down, the other end can detect the down event in 3 seconds and change its own PVC to down state.
A.     When multicast or broadcast traffic is involved in the ATM network, configure the broadcast command for the PVC. Otherwise, the broadcast and multicast packets cannot be forwarded.
A.     Yes. Use the ospf network-type { broadcast | nbma | p2mp [ unicast ] | p2p [ peer-address-check ] } command to configure the same network type for the OSPF interfaces on both ends of an ATM network. By default, the network type of an OSPF interface operating in an ATM network is NBMA.
A.     H3C recommends that you configure a schedule value larger than 10 for the WFQ queue on an ATM interface. By default, the schedule value for the WFQ queue is 1. The following is a sample configuration.
interface Atm13/1/2.31
 mtu 1280
 pvc sg1_a_to_sh_a 31/100
  service cbr 2000
  oam loopback 1 up 1 down 1 retry 1
  broadcast
  map ip inarp 15
 ip binding vpn-instance sg1_a
 ip address 21.1.1.2 255.255.255.0
 ospf network-type p2p
 qos wfq 1 weight 10
qos wfq 2 weight 20
qos wfq 3 weight 30
 qos trust auto
A.     Yes. When you configure the ATM cell transmission rate for the local PVC by using the service ubr output-pcr command, the rate must be equal to or smaller than the peak rate of the remote PVC. The following is a sample configuration.
interface Atm2/1/1
 pvc 10/40
  service ubr 2000
  broadcast
  map ip default
 ip address 1.0.0.1 255.255.255.0
NAT
This section contains the most frequently asked questions about NAT.
A.     The router can perform traditional NAT and twice NAT:
·     Traditional NAT applies to the interface that connects the public network. It translates the source IP addresses of outgoing packets and destination IP addresses of incoming packets.
·     Twice NAT translates the destination IP address on the receiving interface and the source IP address on the sending interface. The receiving and sending interfaces are both NAT interfaces. Twice NAT allows VPNs with overlapping addresses to access each other.
A.     With Easy IP configured, the interface puts all packets into one software queue to the CPU. If routing protocols are configured on the interface, a large number of protocol packets will be generated. Queue congestion might occur and some packets will be dropped, affecting the correct function of the device. If Easy IP is not configured, the interface puts packets of different protocols into different queues.
A.     For outbound NAT, you must configure a QoS policy. The QoS policy redirects packets to be NATed to the NAT service card bound to the NAT interface.
