12-ACL Configuration
HomeSupportConfigure & DeployConfiguration ExamplesH3C Routers Easy and Effortless Routing Feature Configuration Examples-6W10112-ACL Configuration
01-Denying Access to a Specific Subnet by Using Packet Filtering
Introduction
The following information provides examples for denying access to a specific subnet by using packet filtering.
This document is not restricted to specific software or hardware versions. Procedures and information in the examples might be slightly different depending on the software or hardware version of the device.
The following information is provided based on the assumption that you have basic knowledge of ACL.
Configuration example
As shown in Figure 1, the device acts as the gateway for the 192.168.10.0/24, 192.168.20.0/24, and 192.168.20.0/24 subnets. Configure ACLs to meet the following requirements:
·     Prevent hosts on the 192.168.10.0/24 subnet from accessing servers on the 192.168.20.0/24 subnet, and allow hosts on the 192.168.20.0/24 subnet to access servers on the 192.168.30.0/24 subnet.
·     Prevent hosts on any other subnet to access servers on the 192.168.20.0/24 and 192.168.30.0/24 subnets.
Figure 1 Network diagram
Analysis
To prevent hosts on a subnet from accessing hosts on another subnet, configure an ACL on GigabitEthernet 1/0/1 to deny the incoming packets with a destination IP address on the destination subnet.
# Assign IP addresses to interfaces.
[Device-GigabitEthernet1/0/1] ip address 192.168.10.1 24
[Device-GigabitEthernet1/0/2] ip address 192.168.20.1 24
[Device] interface gigabitethernet 1/0/3
[Device-GigabitEthernet1/0/3] ip address 192.168.30.1 24
[Device-GigabitEthernet1/0/3] quit
# Create IPv4 advanced ACL 3000, configure a rule to deny the the packets with a destination IP address on the 192.168.20.0/24 network, and configure another rule to permit all other packets.
[Device] acl advanced 3000
[Device-acl-ipv4-adv-3000] rule deny ip destination 192.168.20.0 0.0.0.255
[Device-acl-ipv4-adv-3000] rule permit ip
# Apply ACL 3000 to filter the incoming packets on GigabitEthernet 1/0/ 1.
[Device-GigabitEthernet1/0/1] packet-filter 3000 inbound
# Use the display packet-filter command to display ACL application information for packet filtering.
[Device] display packet-filter interface inbound
 In-bound policy:
  ACL 3000
The output shows that GigabitEthernet 1/0/1 has been successfully applied with an ACL for packet filtering. Ping a server on the 192.168.20.0/24 subnet from a host on the 192.168.10.0/24 subnet. The ping fails. Ping a server on any other subnet from a host on the 192.168.10.0/24 subnet. The ping succeeds.
Configuration files
 port link-mode route
 combo enable copper
 ip address 192.168.10.1 255.255.255.0
 combo enable copper
 ip address 192.168.20.1 255.255.255.0
 combo enable copper
 ip address 192.168.30.1 255.255.255.0
acl advanced 3000
 rule permit ip
Related documentation
·     ACL and QoS Configuration Guide in H3C MSR Router Series Comware 7 Configuration Guides
·     ACL and QoS Command Reference in H3C MSR Router Series Comware 7 Command References
