| 03-Data buffer commands | 73.86 KB |
Inappropriate data buffer changes can cause system problems. Before manually changing data buffer settings, make sure you understand its impact on your device. As a best practice, use the burst-mode enable command if the system requires large buffer spaces. The burst-mode enable command and the buffer apply command are mutually exclusive. If you have configured the data buffer by using one command, you must execute the undo form of the command before using the other command.
buffer apply
Use buffer apply to apply manually configured data buffer settings.
Use undo buffer apply to restore the default.
buffer apply
undo buffer apply
For data buffer settings to take effect, you must execute this command after configuring data buffer settings.
After applying manually configured data buffer settings, you cannot directly modify the applied settings. To modify them, you must cancel the application, reconfigure data buffer settings, and reapply the new settings.
# Apply manually configured data buffer settings.
[Sysname] buffer apply
buffer total-shared
Use buffer total-shared to set the total shared-area ratio.
Use undo buffer total-shared to delete the total shared-area ratio setting.
buffer egress slot slot-number { cell | packet } total-shared ratio ratio
undo buffer egress slot slot-number { cell | packet } total-shared
If this command is not configured, you can display the default value by using the display buffer command.
egress: Specifies the egress buffer.
slot slot-number: Specifies an IRF member device by its member ID (slot number). If you do not specify an IRF member device, this command applies to all IRF member devices.
cell: Specifies cell resources.
packet: Specifies packet resources.
ratio ratio: Specifies the ratio of the shared area, in percentage. The value range for ratio is 0 to 100.
After you set the shared-area ratio, the remaining buffer space is automatically assigned to the fixed area.
# Configure the shared area to use 50% space of cell resources in the egress buffer.
[Sysname] buffer egress slot 1 cell total-shared ratio 50
burst-mode enable
Use burst-mode enable to enable the Burst feature.
Use undo burst-mode enable to disable the Burst feature.
burst-mode enable
The Burst feature is disabled.
The Burst feature is especially useful for reducing packet losses under the following circumstances:
· Broadcast or multicast traffic is intensive, resulting in bursts of traffic.
· Traffic enters a device from a high-speed interface and goes out of a low-speed interface.
· Traffic enters a device from multiple same-rate interfaces and goes out of an interface with the same rate.
# Enable the Burst feature.
[Sysname] burst-mode enable
display buffer
Use display buffer to display buffer size settings.
display buffer [ slot slot-number ] [ queue [ queue-id ] ]
slot slot-number: Specifies an IRF member device by its member ID (slot number). If you do not specify an IRF member device, this command displays buffer size settings for all IRF member devices.
queue queue-id: Specifies a queue by its number in the range of 0 to 7. If you specify a queue, this command displays the fixed-area ratio and shared-area ratio for the specified queue. If you specify the queue keyword without the queue-id argument, this command displays the fixed-area ratio and shared-area ratio for each queue. If you do not specify the queue keyword, this command displays the total shared-area ratio.
# Display buffer size settings.
<Sysname> display buffer
Slot Type Eg(Total-shared , Shared)
1 packet 50% , 10%
1 cell 52% , 10%
Eg: Size of the sending buffer
Total-shared: Size of the shared buffer for all ports
Shared: Size of the maximum shared buffer per port
Unit: Ratio
# Display the fixed-area ratio and shared-area ratio for the queues.
<Sysname> display buffer queue
Slot Queue Type Eg(Guaranteed , Shared)
1 0-7 packet 12% , --
1 0-7 cell 12% , --
Guaranteed: Size of the minimum guaranteed buffer per queue
Shared: Size of the maximum shared buffer per queue
Type |
Resource type: packet or cell. |
Queue |
Queue ID in the range of 0 to 7. |
Eg |
Egress buffer. |
(Total-shared , Shared) |
Total-shared indicates the total shared-area ratio. If the device does not support a resource type, this field displays two hyphens (--). Shared indicates the shared-area ratio of a port. If the device does not support a resource type, this field displays two hyphens (--). |
(Guaranteed , Shared) |
· Guaranteed indicates the fixed-area ratio of a queue. · Shared indicates the shared-area ratio of a queue. |
display buffer usage
Use display buffer usage to display buffer usage.
display buffer usage [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID (slot number). If you do not specify an IRF member device, this command displays buffer usage for all IRF member devices.
# Display buffer usage.
<Sysname> display buffer usage
Egress total-shared cell buffer usage on slot 1 :
Total: 2964 KB
Used: 0 KB
Free: 2964 KB
5sec 1min 5min
Block 1 0% 0% 0%
GigabitEthernet1/0/1 0% 0% 0%
GigabitEthernet1/0/2 0% 0% 0%
GigabitEthernet1/0/3 0% 0% 0%
GigabitEthernet1/0/4 0% 0% 0%
GigabitEthernet1/0/5 0% 0% 0%
GigabitEthernet1/0/6 0% 0% 0%
GigabitEthernet1/0/7 0% 0% 0%
GigabitEthernet1/0/8 0% 0% 0%
GigabitEthernet1/0/9 0% 0% 0%
GigabitEthernet1/0/10 0% 0% 0%
GigabitEthernet1/0/11 0% 0% 0%
GigabitEthernet1/0/12 0% 0% 0%
GigabitEthernet1/0/13 0% 0% 0%
GigabitEthernet1/0/14 0% 0% 0%
GigabitEthernet1/0/15 0% 0% 0%
GigabitEthernet1/0/16 0% 0% 0%
GigabitEthernet1/0/17 0% 0% 0%
GigabitEthernet1/0/18 0% 0% 0%
GigabitEthernet1/0/19 0% 0% 0%
GigabitEthernet1/0/20 0% 0% 0%
GigabitEthernet1/0/21 0% 0% 0%
GigabitEthernet1/0/22 0% 0% 0%
GigabitEthernet1/0/23 0% 0% 0%
GigabitEthernet1/0/24 0% 0% 0%
GigabitEthernet1/0/25 0% 0% 0%
GigabitEthernet1/0/26 0% 0% 0%
GigabitEthernet1/0/27 0% 0% 0%
GigabitEthernet1/0/28 0% 0% 0%
GigabitEthernet1/0/29 0% 0% 0%
GigabitEthernet1/0/30 0% 0% 0%
GigabitEthernet1/0/31 0% 0% 0%
GigabitEthernet1/0/32 0% 0% 0%
GigabitEthernet1/0/33 0% 0% 0%
GigabitEthernet1/0/34 0% 0% 0%
GigabitEthernet1/0/35 0% 0% 0%
GigabitEthernet1/0/36 0% 0% 0%
GigabitEthernet1/0/37 0% 0% 0%
GigabitEthernet1/0/38 0% 0% 0%
GigabitEthernet1/0/39 0% 0% 0%
GigabitEthernet1/0/40 0% 0% 0%
GigabitEthernet1/0/41 0% 0% 0%
GigabitEthernet1/0/42 0% 0% 0%
GigabitEthernet1/0/43 0% 0% 0%
GigabitEthernet1/0/44 0% 0% 0%
GigabitEthernet1/0/45 0% 0% 0%
GigabitEthernet1/0/46 0% 0% 0%
GigabitEthernet1/0/47 0% 0% 0%
GigabitEthernet1/0/48 0% 0% 0%
Ten-GigabitEthernet1/0/49 0% 0% 0%
Ten-GigabitEthernet1/0/50 0% 0% 0%
Ten-GigabitEthernet1/0/51 0% 0% 0%
Ten-GigabitEthernet1/0/52 0% 0% 0%
Egress total-shared cell buffer usage on slot |
Usage of cell resources in the shared area on an IRF member device. |
XPE |
Type of the data buffer. |
Block |
Block where the port resides. The block where the ports on the front panel of the device reside is fixed to Block 1. |
Total |
Total size of the data buffer. |
Used |
Size of used data buffer. |
Free |
Size of free data buffer. |
5sec |
Percentage of the buffer that the port uses for the last 5 seconds. |
1min |
Percentage of the buffer that the port uses for the last 1 minute. |
5min |
Percentage of the buffer that the port uses for the last 5 minutes. |
