10-Tools
HomeSupportConfigure & DeployConfiguration ExamplesH3C Access Controllers Web-Based Configuration Examples-6W10010-Tools
01-Ping Configuration Example
01-Ping Configuration Example 175.39 KB
Comware 7 Ping Configuration Example
Overview
The following information provides an example for using the ping utility to determine if an address is reachable.
The following information applies to Comware 7-based access controllers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the H3C access controllers.
The following information is provided based on the assumption that you have basic knowledge of ping.
Example: Using the ping utility
As shown in Figure 1, use the ping utility to determine if AC1 can reach AC2.
Figure 1 Network diagram
You can ping AC2 from AC1 by AC2's IPv4 address, IPv6 address, or hostname. To ping AC2 by its hostname, make sure the DNS feature is configured to resolve AC2's domain name into the correct IP address.
Procedures
Pinging AC2 by its IPv4 address or hostname
1.     Click the System View tab at the bottom of the page.
2.     From the navigation pane, select Tools > Ping.
3.     Click the IPv4 Ping tab.
4.     In the Destination IP address or hostname field, enter the IPv4 address or hostname of AC2.
5.     Click Start.
Figure 2 Pinging AC2 by its IPv4 address or hostname
Pinging AC2 by its IPv6 address or hostname
3.     Click the IPv6 Ping tab.
4.     In the Destination IP address or hostname field, enter the IPv6 address or hostname of AC2.
5.     Click Start.
Figure 3 Pinging AC2 by its IPv6 address or hostname
Viewing the IPv4 ping result
The IPv4 ping result will be displayed in the Result field at the bottom of the IPv4 Ping page, as shown in Figure 4.
Figure 4 Viewing the IPv4 ping result
Viewing the IPv6 ping result
The IPv6 ping result will be displayed in the Result field at the bottom of the IPv6 Ping page, as shown in Figure 5.
Figure 5 Viewing the IPv6 ping result
Related documentation
H3C Access Controllers Web-Based Configuration Guide
