16-Network Management and Monitoring
HomeSupportDiagnose & MaintainAlarms ReferencesH3C MSR Router Series Alarm Reference-R6749-6W10016-Network Management and Monitoring
02-DISMAN-PING-MIB
02-DISMAN-PING-MIB 107.38 KB
DISMAN-PING-MIB
About this MIB
Use this MIB to implement the ping utility defined by RFC 2925. Ping operations are performed by NQA ICMP echo probes.
To implement DISMAN PING, the devices must support this MIB. This MIB cannot be used together with CLI.
MIB file name
rfc2925-disman-ping.mib
Notifications
pingProbeFailed
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.2.1.80.0.1
A ping operation failure was detected.
Informational
Warning
N/A
OFF
Notification triggers
This notification is generated when the number of consecutive probe failures in a ping operation reaches the specified value. The following might be the ping failure reasons:
·     The destination address does not exist.
·     The destination address exists but is unreachable.
·     The network latency is large and the round-trip time of packets is larger than the specified timeout time.
System impact
The device cannot communicate with the ping destination.
Status control
ON
CLI: Use the reaction trap probe-failure command.
OFF
CLI: Use the undo reaction trap probe-failure command.
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.2.1.80.1.2.1.3 (pingCtlTargetAddressType)
Destination address type.
pingCtlOwnerIndex
pingCtlTestName
InetAddressType
Standard MIB values.
1.3.6.1.2.1.80.1.2.1.4 (pingCtlTargetAddress)
Destination address.
pingCtlOwnerIndex
pingCtlTestName
InetAddress
1.3.6.1.2.1.80.1.3.1.1 (pingResultsOperStatus)
Operation status.
pingCtlOwnerIndex
pingCtlTestName
INTEGER
enabled(1),
disabled(2)
1.3.6.1.2.1.80.1.3.1.2 (pingResultsIpTargetAddressType)
Destination address type in the probe result.
pingCtlOwnerIndex
pingCtlTestName
InetAddressType
1.3.6.1.2.1.80.1.3.1.3 (pingResultsIpTargetAddress)
Destination address in the probe result.
pingCtlOwnerIndex
pingCtlTestName
InetAddress
1.3.6.1.2.1.80.1.3.1.4 (pingResultsMinRtt)
Minimum round-trip time in the probe result.
pingCtlOwnerIndex
pingCtlTestName
Unsigned32
1.3.6.1.2.1.80.1.3.1.5 (pingResultsMaxRtt)
Maximum round-trip time in the probe result.
pingCtlOwnerIndex
pingCtlTestName
Unsigned32
1.3.6.1.2.1.80.1.3.1.6 (pingResultsAverageRtt)
Average round-trip time in the probe result.
pingCtlOwnerIndex
pingCtlTestName
Unsigned32
1.3.6.1.2.1.80.1.3.1.7 (pingResultsProbeResponses)
Number of received echo replies in the probe result.
pingCtlOwnerIndex
pingCtlTestName
Unsigned32
1.3.6.1.2.1.80.1.3.1.8 (pingResultsSentProbes)
Number of sent echo requests in the probe result.
pingCtlOwnerIndex
pingCtlTestName
Unsigned32
1.3.6.1.2.1.80.1.3.1.9 (pingResultsRttSumOfSquares)
Sum of squares for the round-trip time in the probe result.
pingCtlOwnerIndex
pingCtlTestName
Unsigned32
1.3.6.1.2.1.80.1.3.1.10 (pingResultsLastGoodProbe)
Date and time when the last echo reply was received in the probe result.
pingCtlOwnerIndex
pingCtlTestName
DateAndTime
Recommended action
1.     In NQA operation view, execute the display this command to identify whether the destination address is configured correctly.
¡     If the destination address is correct, go to step 2.
¡     If the destination address is incorrect, execute the destination ip command to change the destination address, and then perform the ping operation again.
-     If no notification is generated, the issue is cleared.
-     If the notification is generated, go to step 2.
2.     In NQA operation view, execute the ping command to identify whether the destination address is reachable.
¡     If the destination address is reachable, go to step 3.
¡     If the destination address is unreachable, locate routing issues. For example, execute the display ip routing-table command to verify routing table information.
3.     In NQA operation view, execute the probe timeout command to set the probe timeout time, and then perform the ping operation again.
4.     If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
pingTestFailed
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.80.0.2
A ping operation failed.
Informational
Warning
N/A
OFF
System impact
Status control
ON
CLI: Use the reaction trap test-failure [ accumulate-probe-failures ] command.
OFF
CLI: Use the undo reaction trap test-failure [ accumulate-probe-failures ] command.
Objects
OID (object name)
Index nodes
Value range
pingCtlOwnerIndex
pingCtlTestName
InetAddressType
pingCtlOwnerIndex
pingCtlTestName
InetAddress
Operation status.
pingCtlOwnerIndex
pingCtlTestName
INTEGER
enabled(1),
disabled(2)
pingCtlOwnerIndex
pingCtlTestName
InetAddressType
pingCtlOwnerIndex
pingCtlTestName
InetAddress
pingCtlOwnerIndex
pingCtlTestName
Unsigned32
pingCtlOwnerIndex
pingCtlTestName
Unsigned32
pingCtlOwnerIndex
pingCtlTestName
Unsigned32
pingCtlOwnerIndex
pingCtlTestName
Unsigned32
pingCtlOwnerIndex
pingCtlTestName
Unsigned32
pingCtlOwnerIndex
pingCtlTestName
Unsigned32
pingCtlOwnerIndex
pingCtlTestName
DateAndTime
Recommended action
pingTestCompleted
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.80.0.3
A ping operation completed.
Informational
Warning
N/A
OFF
This notification is generated when a ping operation completes.
System impact
No impact on the system.
Status control
ON
CLI: Use the reaction trap test-complete command.
OFF
CLI: Use the undo reaction trap test-complete command.
Objects
OID (object name)
Index nodes
Value range
pingCtlOwnerIndex
pingCtlTestName
InetAddressType
pingCtlOwnerIndex
pingCtlTestName
InetAddress
Operation status.
pingCtlOwnerIndex
pingCtlTestName
INTEGER
enabled(1),
disabled(2)
pingCtlOwnerIndex
pingCtlTestName
InetAddressType
pingCtlOwnerIndex
pingCtlTestName
InetAddress
pingCtlOwnerIndex
pingCtlTestName
Unsigned32
pingCtlOwnerIndex
pingCtlTestName
Unsigned32
pingCtlOwnerIndex
pingCtlTestName
Unsigned32
pingCtlOwnerIndex
pingCtlTestName
Unsigned32
pingCtlOwnerIndex
pingCtlTestName
Unsigned32
pingCtlOwnerIndex
pingCtlTestName
Unsigned32
pingCtlOwnerIndex
pingCtlTestName
DateAndTime
Recommended action
No action is required.
