05-Virtual Technologies
HomeSupportReference GuidesMIB CompanionH3C MSR Router Series MIB Reference-R6749-6W10005-Virtual Technologies
Table of Contents
Related Documents
01-HH3C-STACK-MIB
01-HH3C-STACK-MIB 131.17 KB
HH3C-STACK-MIB
About this MIB
Use this MIB to obtain IRF information and manage IRF fabrics.
MIB file name
hh3c-stack.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cStack(91)
Scalar objects
hh3cStackMaxMember (1.3.6.1.4.1.25506.2.91.1.1)
Object (OID)
Access
Value range
Implementation
read-only
Integer32
Standard MIB values.
Maximum number of member devices that an IRF fabric can contain.
As per the MIB.
hh3cStackMemberNum (1.3.6.1.4.1.25506.2.91.1.2)
Object (OID)
Access
Value range
Implementation
read-only
Integer32
Number of member devices that an IRF fabric contains.
As per the MIB.
hh3cStackMaxConfigPriority (1.3.6.1.4.1.25506.2.91.1.3)
Object (OID)
Access
Value range
Implementation
read-only
Integer32
The maximum priority value that can be assigned to a member device in an IRF fabric.
The member priority can affect master election.
As per the MIB.
hh3cStackAutoUpdate (1.3.6.1.4.1.25506.2.91.1.4)
Object (OID)
Access
Value range
Implementation
read-write
IINTEGER
IINTEGER{
disabled(1),
enabled(2)
Whether an IRF fabric supports software auto-update.
When you add a device to the IRF fabric, software auto-update compares the startup software images of the device with the current software images of the IRF master. If the two sets of images are different, the device automatically performs the following operations:
1.     Downloads the current software images of the master.
2.     Sets the downloaded images as its main startup software images.
3.     Reboots with the new software images to rejoin the IRF fabric.
You must manually update the new device with the software images running on the IRF fabric for the device to join the IRF fabric if software auto-update is disabled.
As per the MIB.
hh3cStackMacPersistence (1.3.6.1.4.1.25506.2.91.1.5)
Object (OID)
Access
Value range
Implementation
read-write
INTEGER
INTEGER            {
notPersist(1),
persistForSixMin(2),
persistForever(3)
Status of the IRF bridge MAC persistence feature.
As per the MIB.
hh3cStackLinkDelayInterval (1.3.6.1.4.1.25506.2.91.1.6)
Object (OID)
Access
Value range
Implementation
read-write
Integer32
SIZE((0.. 10000))
IRF link status change report delay, in the range of 1 to 10000 milliseconds.
If the value is set to 0, link status change events of IRF ports are reported without any delay.
As per the MIB.
hh3cStackTopology (1.3.6.1.4.1.25506.2.91.1.7)
Object (OID)
Access
Value range
Implementation
read-only
INTEGER
INTEGER            {
chainConn(1),
ringConn(2)
Topology type of an IRF fabric.
As per the MIB.
hh3cStackDomainId (1.3.6.1.4.1.25506.2.91.1.8)
Object (OID)
Access
Value range
Implementation
read-write
Unsigned32
SIZE((0..4294967295))
Domain ID of an IRF fabric.
As per the MIB.
Tabular objects
hh3cStackDeviceConfigTable
About this table
This table contains parameters about each IRF member device in an IRF fabric.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Not supported
Columns
The table index is entPhysicalIndex.
Object (OID)
Access
Value range
Implementation
hh3cStackMemberID (1.3.6.1.4.1.25506.2.91.2.1.1)
read-only
Integer32
IRF member ID of a member device.
The member ID must be unique in the IRF fabric.
As per the MIB.
hh3cStackConfigMemberID (1.3.6.1.4.1.25506.2.91.2.1.2)
read-write
Integer32
IRF member ID that will take effect at the next startup.
As per the MIB.
hh3cStackPriority (1.3.6.1.4.1.25506.2.91.2.1.3)
read-write
Integer32
IRF priority of the member device.
The priority can affect master election.
As per the MIB.
hh3cStackPortNum (1.3.6.1.4.1.25506.2.91.2.1.4)
read-only
Integer32
Number of IRF ports enabled on the member device.
As per the MIB.
hh3cStackPortMaxNum (1.3.6.1.4.1.25506.2.91.2.1.5)
read-only
Integer32
Maximum number of IRF ports supported by the member device.
As per the MIB.
hh3cStackBoardConfigTable
About this table
This table contains role information about each board in an IRF fabric. For modular devices, a board refers to an MPU. For fix-port devices or expandable fixed-port devices, a board refers to an IRF member device.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Not supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cStackBoardRole (1.3.6.1.4.1.25506.2.91.3.1.1)
read-only
INTEGER
INTEGER
slave(1),
master(2),
loading(3),
other(4)
IRF role of a board.
As per the MIB.
hh3cStackBoardBelongtoMember (1.3.6.1.4.1.25506.2.91.3.1.2)
read-only
Integer32
IRF member ID of the member device where the board resides.
As per the MIB.
hh3cStackPortInfoTable
About this table
This table contains IRF port information about each member device in an IRF fabric.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Not supported
Columns
The table indexes are hh3cStackMemberID and hh3cStackPortIndex.
Object (OID)
Access
Value range
Implementation
hh3cStackPortIndex (1.3.6.1.4.1.25506.2.91.4.1.1)
not-accessible
Integer32
Logical index of an IRF port on a member device.
As per the MIB.
hh3cStackPortEnable (1.3.6.1.4.1.25506.2.91.4.1.2)
read-only
INTEGER
INTEGER
disabled(1),
enabled(2)
Whether the IRF port has been enabled.
If IRF physical interfaces have been bound to the IRF port, the IRF port is enabled.
If no IRF physical interface has been bound to the IRF port, the IRF port is disabled.
As per the MIB.
hh3cStackPortStatus (1.3.6.1.4.1.25506.2.91.4.1.3)
read-only
INTEGER
INTEGER            {
up(1),
down(2),
silent(3),
disabled(4)
Link status of the IRF port.
As per the MIB.
hh3cStackNeighbor (1.3.6.1.4.1.25506.2.91.4.1.4)
read-only
Integer32
IRF member ID of the member device connected to the IRF port.
As per the MIB.
hh3cStackPortForwardingPath(1.3.6.1.4.1.25506.2.91.4.1.5)
read-only
OCTET STRING
Forwarding path information for traffic from the IRF port to other member devices in the IRF fabric.
The return value is a string of comma-separated IRF member IDs and the string ends with \0.
As per the MIB.
hh3cStackPhyPortInfoTable
About this table
This table contains information about IRF physical interfaces.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Not supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cStackBelongtoPort (1.3.6.1.4.1.25506.2.91.5.1.1)
read-write
Integer32
Logical index of an IRF port to which an IRF physical interface is bound.
As per the MIB.
