13-Layer 3—IP Services Configuration Guide
HomeSupportSecurityH3C SecPath F100-C-A FirewallConfigure & DeployConfiguration GuidesH3C SecPath F100[F1000] Firewalls Series Configuration Guides(V7)-6W90013-Layer 3—IP Services Configuration Guide
11-Multi-CPU packet distribution configuration
11-Multi-CPU packet distribution configuration 51.72 KB
Configuring multi-CPU packet distribution
About multi-CPU packet distribution
On a multi-CPU device, packets can be distributed among CPUs based on one of the following policies:
·     Flow-based policy—Forwards packets of a flow to one CPU or multiple CPUs. The CPU processes flow packets by following the first-in first-out rule. The device supports using the source IP address, destination IP address, source port number, destination port number, and protocol number to identify a flow.
·     Packet-based policy—Forwards packets in sequence to different CPUs, even though they are the same flow. This policy does not ensure packet order.
Restrictions: Hardware compatibility with multi-CPU packet distribution
F1000 series
Models
Multi-CPU packet distribution compatibility
F1000-X-G5 series
F1000-A-G5, F1000-S-G5
Yes
F1000-C-G5, F1000-C-G5-LI
No
F1000-E-G5, F1000-H-G5
Yes
F1000-X-XI series
F1000-E-X
No
F100 series
Models
F100-X-G5 series
F100-A-G5
Yes
F100-E-G5
No
F100-C-G5, F100-M-G5, F100-S-G5
Yes
F100-C-A series
F100-C-A2, F100-C-A1
No
F100-X-XI series
F100-A-XI
No
F100-C-XI, F100-S-XI
Yes
Restrictions and guidelines: Multi-CPU packet distribution configuration
If a service requires packets of a flow to be received by the same CPU, you must use the flow-based policy.
Specifying a packet distribution policy
2.     Specify a packet distribution policy.
forwarding policy { per-flow [ three-tuple | mode { source-ip | destination-ip | source-port | destination-port } ] | per-packet }
By default, the device uses the flow-based policy that identifies a flow by source IP address, destination IP address, source port number, destination port number, and protocol number.
