04-DPI Configuration Guide
HomeSupportSecurityH3C SecPath F100-C-A FirewallConfigure & DeployConfiguration GuidesH3C SecPath F100[F1000] Firewalls Series Configuration Guides(V7)-6W90004-DPI Configuration Guide
16-Intelligent service platform configuration
16-Intelligent service platform configuration 98.37 KB
Configuring the intelligent service platform
About the intelligent service platform
The intelligent service platform is a comprehensive service deployment platform designed for security applications. You can deploy the SecCenter Security Management Platform (SMP), the enhanced anti-virus inspection function, and the DGA detection function as needed on the intelligent service platform.
·     For more information about SMP, see H3C SecCenter SMP Installation Guide and H3C SecCenter SMP Web Configuration Guides.
·     For more information about the enhanced anti-virus inspection function, see "Configuring anti-virus."
·     For more information about the DGA detection function, see "Configuring DGA detection."
Intelligent service platform module
The intelligent service platform is installed on the device as a module and is connected to the device through an internal Ethernet interface. Figure 1 shows the network diagram of the intelligent service platform module.
Figure 1 Intelligent service platform module
After the intelligent service platform module is installed on the device, the internal Ethernet interface (Port4 in the figure) is presented as another Ethernet interface (Port1 in the figure). Port1 connects to Port4 logically. The device communicates with Port4 of the intelligent service platform module through Port1.
Restrictions: Hardware compatibility with intelligent service platform
F1000 series
Models
Intelligent service platform compatibility
F1000-X-G5 series
F1000-A-G5, F1000-C-G5, F1000-C-G5-LI, F1000-E-G5, F1000-H-G5, F1000-S-G5
Yes
F100 series
Models
F100-X-G5 series
F100-E-G5
Yes
F100-A-G5, F100-C-G5, F100-M-G5, F100-S-G5
No
F100-C-A series
F100-C-A2, F100-C-A1
No
Configuring an IP address for the intelligent service platform
The IP address of the Ethernet interface on the device corresponding to the internal Ethernet interface must be in the same network segment as the IP address of the intelligent service platform.
Only IPv4 addresses can be configured for the intelligent service platform.
Install the intelligent service platform on the device, and complete initial settings. For more information about installation and configuration, see Intelligent Service Platform Deployment Guide.
2.     Assign an IP address to the intelligent service platform.
intelligent-inspect ip ip-address
By default, the intelligent service platform does not have an IP address.
The specified address acts as the IP address of the internal Ethernet interface.
Configuring SMP
See H3C SecCenter SMP Deployment Guide.
Configuring enhanced anti-virus inspection
See "Configuring anti-virus."
See "Configuring DGA detection."
Display and maintenance commands for the intelligent service platform
Execute the display commands in any view.
Display the connection status of the intelligent service platform.
display intelligent-inspect status
