- 01-Fundamentals Command Reference
- 01-CLI commands
- 02-RBAC commands
- 03-Login management commands
- 04-License management commands
- 05-Device management commands
- 06-FTP and TFTP commands
- 07-File system management commands
- 08-Configuration file management commands
- 09-Software upgrade commands
- 10-ISSU commands
- 11-Automatic configuration commands
- 12-Tcl commands
- 13-Python commands
- 14-RAID management commands (security devices)
| 11-Automatic configuration commands | 36.90 KB |
autodeploy udisk enable
Use autodeploy udisk enable to enable USB-based automatic configuration.
Use undo autodeploy udisk enable to disable USB-based automatic configuration.
USB-based automatic configuration is enabled.
context-admin
# Disable USB-based automatic configuration.
[Sysname] undo autodeploy udisk enable
autodeploy url enable
Use autodeploy url enable to enable URL-based automatic configuration.
Use undo autodeploy url enable to disable URL-based automatic configuration.
URL-based automatic configuration is enabled.
context-admin
# Disable URL-based automatic configuration.
[Sysname] autodeploy url enable
