H3C UniServer B16000 Blade Server Chassis User Guide-6W101
HomeSupportServersBlade ServerH3C UniServer B16000Blade Server ChassisConfigure & DeployConfiguration ExamplesH3C UniServer B16000 Blade Server Chassis User Guide-6W101
02-Appendix
02-Appendix 91.66 KB
Appendix A  Modules in the chassis
Blade server
Model
Maximum Number
H3C UniServer B5700 G6
16
Half-width full-height blade servers with two processors
H3C UniServer B5700 G5
16
H3C UniServer B5700 G3
16
H3C UniServer B5800 G3
8
Full-width full-height blade servers with two processors
H3C UniServer B7800 G3
8
Full-width full-height blade servers with four processors
AE module
Model
Maximum Number
H3C Unisever AE100
2
APP engine module
H3C Unisever AE101
2
APP engine module
LCD module
Model
Maximum Number
SID-LCD-B
1
LCD display
Management module
Model
Maximum Number
H3C Unisever OM100
2
OM module
ICM module
Model
Maximum Number
H3C UniServer BX720E
6
16*10GE+4*40GE Ethernet switching modules (16*10GB fiber ports+4*40GE fiber ports)
H3C UniServer BX720EF
6
16*10GE+4*40GE converged switching modules (8*FC ports+8*10GE fiber ports+4*40GE fiber ports)
H3C UniServer BX608FE
6
8*16G FC switching modules (8*16G FC ports)
H3C UniServer BT616E
6
16*10GE Ethernet Direct Connect Module (16*10GB fiber ports)
H3C UniServer BT716F
6
16*16G FC switching modules (16*16G FC ports)
H3C UniServer BX1010E
6
8*25GE+2*100GE Ethernet switching modules (8*10GB fiber ports+2*100GE fiber ports)
H3C UniServer BT1004E
6
4*(4*25G) Interconnect Module
H3C UniServer BX1020B
6
36*EDR Unmanaged IB Switch Module(16*Downlink Ports+20*Uplink Ports)
H3C UniServer BX1020EF
6
8*FC+8*25GE+4*100GE Converged Network Switch Module
Power supply
Item
Model
PSR3000-12A
CRPS3200T
3000 W power supply
3200 W power supply
Range of rated input voltage @ Corresponding output power
·     90–180 V AC, 50 Hz/60 Hz @ 1200 W
·     180–220 V AC, 50 Hz/60 Hz @ 2500 W
·     220–264 V AC, 50 Hz/60 Hz @ 3000 W
·     180–220 V DC @ 2500 W
·     220–320 V DC @ 3000 W
·     100–127 V AC, 50 Hz/60 Hz @ 1200 W
·     200–210 V AC, 50 Hz/60 Hz @ 2800 W
·     210–220 V AC, 50 Hz/60 Hz @ 3000 W
·     220–240 V AC, 50 Hz/60 Hz @ 3200 W
·     240 V DC @ 3200 W
Rated input voltage
16.0A Max
16.0A Max
Maximum rated output power
·     3000 W @ 220–264 V AC
·     3000 W @ 220–320 V DC
·     3200 W @ 220–240 V AC
·     3200 W @ 240 V DC
Efficiency @ 50% load
94%, 80 Plus Platinum level
96%, 80 Plus Titanium level
Redundancy
No redundancy, N+1 redundancy, and N+N redundancy
Cold backup
Yes
No
Fan module
Model
Maximum Number
FAN-L-B
12
Fan module
Slide rails/cable management bracket
Model
RAIL-12U
12U standard slide rails
CMA-12U
12U cable management bracket
Appendix B  Technical support
If you encounter any complicated problems during daily maintenance or troubleshooting, contact H3C Support.
Collecting server information
Before contacting H3C Support, collect the following server information to facilitate troubleshooting:
·     Log and sensor information of modules in the chassis.
·     Product serial number.
·     Product model and name.
·     Snapshots of error messages and descriptions.
·     Hardware change history of the chassis and modules in the chassis, including installation, replacement, insertion, and removal of hardware.
·     Third-party software installed on modules in the chassis.
·     Operating system type and version of modules in the chassis.
Preparing tools
To facilitate troubleshooting, prepare the following tools as needed:
·     Phillips screwdriver.
·     Cage nut insertion/extraction tool.
·     Diagonal pliers.
·     Multimeter.
·     Interface cable (such as network cable).
·     Access terminal (such as a PC).
·     ESD wrist strap, antistatic gloves, and antistatic clothing.
For more information about these tools, see "Installation tools."
Appendix C  Product recycling
New H3C Technologies Co., Ltd. provides product recycling services for its customers to ensure that hardware at the end of its life is recycled. Vendors with product recycling qualification are contracted to New H3C to process the recycled hardware in an environmentally responsible way.
For product recycling services, contact New H3C at
·     Tel: 400-810-0504
·     Email address: [email protected]
·     Website: http://www.h3c.com
Appendix D  Glossary
Item
B
BIOS
Basic input/output system is non-volatile firmware pre-installed in a ROM chip on a server's management module. The BIOS stores basic input/output, power-on self-test, and auto startup programs to provide the most basic hardware initialization, setup and control functionality.
F
FIST
Fast Intelligent Scalable Toolkit provided by H3C for easy and extensible server management. It can guide users to configure a server quickly with ease and provide an API interface to allow users to develop their own management tools.
H
HDM
Hardware Device Management is the server management control unit with which administrators can configure server settings, view component information, monitor server health status, and remotely manage the server.
K
KVM
KVM is a management method that allows remote users to use their local video display, keyboard, and mouse to monitor and control the server.
R
RAID
Redundant array of independent disks (RAID) is a data storage virtualization technology that combines multiple physical hard drives into a single logical unit to improve storage and security performance.
U
U
Unit of measurement for the height of racks and blade server chassis in the IEC 60297-1 standard. 1 U = 44.45 mm.
Others
Hot swapping
A module that supports hot swapping (a hot-swappable module) can be installed or removed while the server is running without affecting the system operation.
Redundancy
A mechanism that ensures high availability and business continuity by providing backup modules. In redundancy mode, a backup or standby module takes over when the primary module fails.
Appendix E  Acronyms
Acronym
Full name
A
AE
App Engine
AMC
Auxiliary Management Controller
B
BIOS
Basic Input Output System
BMC
Baseboard Management Controller
F
FC
Fiber Channel
FIST
H
HDM
H3C Device Management
I
ICM
Interconnect module
K
KVM
Keyboard, Video, and Mouse
L
LCD
Liquid Crystal Display
LDAP
Lightweight Directory Access Protocol
LOM
LAN on Motherboard
M
Mezz
Mezzanine
N
NTP
Network Time Protocol
O
OM
Onboard Management
P
PDU
Power Distribution Unit
PSU
Power Supply Units
R
RAID
Redundant Arrays of Independent Disks
S
SMTP
Simple Mail Transfer Protocol
SOL
Serial Over Lan
SSH
Secure Shell
SSL
Secure Sockets Layer
SUV
Serial, USB, and VGA
U
UID
Unit Identification
UIS
Unified Infrastructure System
UPS
Uninterruptible Power Supply
