HomeSupportConfigure & DeployConfiguration GuidesH3C S6520X & S6520-SI & S5560X-HI & S5000-EI & MS4600 Configuration Guides-R6652Pxx-6W10009-Security Configuration Guide
16-Object group configuration
16-Object group configuration 53.62 KB
Configuring object groups
About object groups
An object group is a group of objects that can be used by an ACL, object policy, or object group to identify packets. Object groups are divided into the following types:
·     IPv4 address object group—A group of IPv4 address objects used to match the IPv4 address in a packet or match the user from whom a packet comes.
·     IPv6 address object group—A group of IPv6 address objects used to match the IPv6 address in a packet or match the user from whom a packet comes.
Configuring an IPv4 address object group
2.     Configure an IPv4 address object group and enter its view.
object-group ip address object-group-name
The system has one default IPv4 address object group named any.
3.     (Optional.) Configure a description for the IPv4 address object group.
By default, an object group does not have a description.
4.     Configure an IPv4 address object.
[ object-id ] network { host { address ip-address | name host-name } | subnet ip-address { mask-length | mask } }
Configuring an IPv6 address object group
2.     Configure an IPv6 address object group and enter its view.
object-group ipv6 address object-group-name
The system has one default IPv6 address object group named any.
3.     (Optional.) Configure a description for the IPv6 address object group.
4.     Configure an IPv6 address object.
[ object-id ] network { host { address ipv6-address | name host-name } | subnet ipv6-address prefix-length }
Display and maintenance commands for object groups
Display information about object groups.
display object-group [ { { ip | ipv6 } address } [ default ] [ name object-group-name ] | name object-group-name ]
