11-Network Management and Monitoring Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S6520X & S6520-SI & S5560X-HI & S5000-EI & MS4600 Command References-R6652Pxx-6W10011-Network Management and Monitoring Command Reference
23-EPS agent commands
23-EPS agent commands 57.22 KB
EPS agent commands
display eps agent
Use display eps agent to display EPS scanner information.
display eps agent
Example
# Display EPS scanner information.
<Sysname> display eps agent
EPS agent information:
  Slot       Port number
  1          12000
EPS server information:
  IP address        : 1.1.1.1
  Port number       : 6060
  Cipher key        : $c$3$rGn++lJ/vHnkk1oQDAKX9NLIz+4vXONZXCRTpQ==
  Log level         : 5
  Use server setting: Yes
Port number
Port number that the EPS scanner listens on.
IP address
IP address of the EPS server.
Port number
Port number of the EPS server.
Cipher key
Key used for communications between the EPS scanner and the EPS server.
Log level
Highest numeric level of logs that the EPS scanner can generate, in the range of 0 to 5. A higher value represents more detailed log information. For example, if the log level is set to 5, the EPS scanner can generate logs of levels from 0 to 5.
Use server setting
Whether the EPS scanner uses the parameter settings deployed by the EPS server. If this field displays No, the EPS scanner uses the default settings of the EPS agent.
display eps agent discovery
Use display eps agent discovery to display scanned endpoint information.
display eps agent discovery [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays the scanned endpoint information for the master device.
# Display scanned endpoint information on slot 1.
<Sysname> display eps agent discovery slot 1
IP-Address       MAC-Address        OS-Type  OS-ver   Vendor    Product
100.100.100.100  cc:ef:48:9b:5f:c1  IOS      12.X     Cisco     C3560E
IP-Address
Endpoint IP address.
MAC-Address
Endpoint MAC address.
OS-Type
Endpoint operating system type.
OS-ver
Endpoint operating system version.
Vendor
Endpoint vendor.
Product
Endpoint model.
eps agent enable
Use eps agent enable to enable EPS agent.
Use undo eps agent enable to disable EPS agent.
eps agent enable [ slot slot-number ]
undo eps agent enable [ slot slot-number ]
EPS agent is disabled.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command enables EPS agent for the master device.
After you enable EPS agent for the scanner on a slot, the scanner scans and manages connected, reachable endpoints in its ARP table by following the instruction of the EPS server.
# Enable EPS agent on slot 1.
[Sysname] eps agent enable slot 1
eps server
Use eps server to configure EPS server parameters.
Use undo eps server to restore the default.
eps server ip-address port port-number [ key { cipher | simple } key-value ] [ log-level level-value ] [ use-server-setting ]
undo eps server
EPS server parameters are not configured.
ip-address: Specifies the IP address of the EPS server.
port port-number: Specifies the port number of the EPS server, in the range of 1 to 65535.
key: Sets the key for communication between the scanner and the EPS server.
simple: Specifies a key in plaintext form. For security purposes, the key specified in plaintext form will be stored in encrypted form.
key-value: Specifies the key string. Its plaintext form is a case-sensitive string of 1 to 24 characters. Its encrypted form is a case-sensitive string of 1 to 65 characters.
log-level level-value: Specifies the highest numeric level of logs that the EPS scanner can generate, in the range of 0 to 5. A higher value represents more detailed log information. For example, if the log level is set to 5, the EPS scanner can generate logs of levels from 0 to 5.
use-server-setting: Specifies that the EPS scanner uses the parameter settings deployed by the EPS server. If you do not specify this keyword, the EPS scanner uses the default settings of the EPS agent.
A scanner enabled with EPS agent automatically generates EPS logs to record the running conditions of the EPS agent. EPS logs are saved to a local storage device instead of being sent to the information center. You can use the log-level level-value option to set the detail level of logs that the EPS scanner can generate. A higher value represents more detailed log information. The EPS scanner will generate logs at the specified level and all lower levels.
# Specify 192.168.7.27 as the IP address of the EPS server, and 4500 as the port number of the EPS server.
[Sysname] eps server 192.168.7.27 port 4500
