H3C WA6620X Access Point Installation Guide-6W102
HomeSupportWirelessWA6620X Access PointInstall & UpgradeInstallation GuidesH3C WA6620X Access Point Installation Guide-6W102
01-Text
01-Text 2.71 MB
1 Preparing for installation· 1-1
Examining the installation site· 1-1
Installation site selection· 1-1
Temperature and humidity requirements· 1-1
Power supply· 1-1
Grounding and lightning protection· 1-2
Installation accessories· 1-3
Installation tools· 1-3
2 Installing the AP·· 2-1
Pre-installation tasks· 2-1
Installation flowchart 2-2
Connecting the grounding cable· 2-2
Connecting cables· 2-3
Connecting an Ethernet cable· 2-4
Connecting an optical fiber 2-5
Connecting an RF cable or external omnidirectional antenna· 2-7
Installing the AP· 2-9
Attaching the AP bracket to the AP· 2-9
Mounting the AP on a pole· 2-11
Mounting the AP on a wall 2-13
Adjusting the AP angle· 2-15
Powering the AP· 2-16
Powering the AP by using a PoE device· 2-16
Powering the AP by using a power injector 2-17
Labeling cables· 2-18
Verifying the installation· 2-19
Powering on the AP· 2-19
Connecting the AP to the network· 2-19
Verifying network connectivity when the AP operates in fit mode· 2-19
Verifying network connectivity when the AP operates in cloud mode· 2-20
3 Accessing the AP·· 2-1
Logging in to the AP from the console port 2-1
Connecting the AP to a configuration terminal from the console port 2-1
Setting parameters for the configuration terminal 2-1
Procedure· 2-1
Logging in to the AP through Telnet 2-2
Cloud mode· 2-2
Anchor ACmode· 2-2
Logging in from the Web interface· 2-2
Cloud mode· 2-3
Anchor ACmode· 2-3
4 Configuring the AP from the Cloudnet platform·· 2-4
Downloading and installing Cloudnet App Int 2-4
Logging in to the Cloudnet platform·· 2-4
5 Appendix A Technical specifications· 5-5
6 Appendix B LEDs and Ports· 6-1
LEDs· 6-1
Ports· 6-2
7 Appendix C Transceiver modules· 7-1
Views· 7-1
Specifications· 7-1
WARNING
WARNING!
Install the AP under the guidance of technical engineers and read this chapter carefully before installation.
Examine the installation site before installation to ensure that the AP will work in a good environment.
The installation site must be selected according to the network planning and technical requirements of telecommunications equipment, with factors such as climate, hydrology, geology, earthquake, electric power, and transportation taken into consideration.
Determine the installation location by observing the following principles:
·     Install the AP away from large-scale metal coverings such as metal ceilings and walls (including the casing). If you fail to do so, the overall signal-to-noise ratio of the AP will be affected, causing AP signal and throughput attenuation.
·     The AP will not be exposed to moisture, high temperature, dust, harmful gases, electromagnetic interference sources (high power radars, radio stations, or electrical substations), unstable voltage, heavy vibration, and loud noise.
·     The location is not water seeping, water soaking, and condensing.
·     The location is away from inflammable and explosive substances.
Table1-1 Temperature and humidity requirements
Item
Specification
Operating temperature
–40°C to +65°C (–40°F to +149°F)
Storage temperature
–40°C to +85°C (–40°F to +185°F)
Operating humidity
0% RH to 100% RH, noncondensing
Storage humidity
Protection class
IP68
Power supply
Power the AP by using a power injector. No power injector is provided with the AP. You can purchase an H3C power injector for the AP. See "Powering the AP by using a power injector" for the connection method.
The AP must be reliably grounded. Make sure the grounding points of the grounding conductor of the AP, lightning arresters, PE wire of the power cord, and antenna support are separate from each other, make good contact, and are securely connected and treated with corrosion protection.
Ground resistance
The ground resistance is typically required to be less than 5 ohms, and less than 10 ohms in an area with less than 20 thunderstorm days a year. For a piece of angle steel buried in the earth as a grounding conductor, the ground resistance is required to be less than 10 ohms. In an area with a higher ground resistance, reduce the ground resistance by using brine or resistance reducing agent around the grounding conductor.
The top of the grounding conductor must be a minimum of 0.7 m (2.30 ft) away from the ground surface. In cold areas, the grounding conductor must be buried below the frozen soil layer.
Grounding conductor
If a grounding strip is available, connect the yellow and green grounding cable to the grounding strip. To make a grounding cable, make sure the cable has a cross-section area of a minimum of 6 mm2 (0.01 in2) and a length of no longer than 3 m (9.84 ft).
If no grounding strip is available, bury a piece of angle steel/steel tube a minimum of 0.5 m (1.64 ft) long in the earth to act as the grounding conductor. It must be zinc-plated. In the case of a piece of angle steel, the size must be a minimum of 50 × 50 × 5 mm (1.97 × 1.97 × 0.20 in). In the case of a piece of steel tube, it must have a wall thickness of a minimum of 3.5 mm (0.14 in). Weld the grounding cable of the AP onto the grounding conductor and use anti-erosion treatment on the welding joint. With a cross-section area of a minimum of 6 mm2 (0.01 in2), the grounding cable must be as short as possible and must not be coiled.
Make sure the grounding terminals of all the lightning arresters of the AP and the peer devices of the AP are reliably grounded.
Ground lead
A ground lead is a metal conductor connecting a grounding net and a grounding strip. The grounding cable of the AP must be connected to the grounding strip. The ground lead must be 30 m (98.43 ft) or shorter. A piece of zinc-coated flat steel with a cross-section area of 40 × 4 mm (1.57 × 0.16 in) or 50 × 5 mm (1.97 × 0.20 in) is recommended. Connect the grounding strip and the ground lead of the AP through the yellow and green grounding cable with an area of 35 mm2 (0.05 in2), or weld them directly. Use anti-erosion treatment on the welding joint.
Power grounding (AC)
Use a power cord with a protective earth (PE). Do not use a power cord with only an L line and an N line.
The neutral line of the power cord must not be connected with the PGND of other communications equipment. The L and N lines cannot be connected.
Lightning rod
The lightning protection grounding (for example, the grounding of the lightning rod) must be connected to the grounding conductor of the equipment room.
The lightning rod must be installed high enough to protect the AP and its antennas.
In plain areas, the shielding angle of the lightning rod must be less than 45 degrees. In mountainous areas or lightning areas, the shielding angle must be less than 30 degrees.
Ethernet cable
Use a shielded twisted pair cable for outdoor installation. Make sure the devices at the two ends of the cable are reliably grounded.
If a metal tube is used, make sure the Ethernet cable is reliably grounded at both ends of the tube.
Figure1-1 Installation accessories
Installation tools
When installing the AP, you might need the following tools. Prepare the installation tools yourself as required.
Figure1-2 Installation tools
2 Installing the AP
IMPORTANT
IMPORTANT:
For optimal radio coverage, use professional technical engineers to install the AP as a best practice.
Before installing an AP, perform the following tasks:
·     Connect the AP to a power source and the network. Examine the LEDs to verify that the AP can operate correctly. For more information about the AP LEDs, see "Appendix B LEDs and Ports."
·     Verify that cabling at the installation site has been completed.
·     Record the MAC address and serial number marked on the rear of the AP for future use.
Before installing the AP, read the following restrictions and guidelines carefully:
·     The AP is large and heavy. Avoid bodily injury and device damage during the installation.
·     If you install the AP on a pole, make sure the pole is vertical to the ground and iron components have been treated with corrosion protection. Make sure the installation height and location of the AP meet the requirements.
·     If you pole-mount the AP on the top of a building, make sure the AP does not project beyond the sides of the building.
·     To avoid high temperature caused by exposure to the sun, install the AP in a place without or with less direct sunlight and take protection measures if necessary.
Before connecting cables to the AP, read the following guidelines carefully:
·     Route cables according to the cabling design.
·     Arrange cables firmly and neatly without crossing, twisting, or cracking them.
·     Do not route cables together with high-voltage electric power pipelines, fire-fighting pipes, or lightning protection cables to avoid electromagnetic interference.
·     Use PVC pipes, iron pipes, Plica tube, or cable troughs for cable routing. Route cable pipes and troughs neatly against the wall and connect them through hoses or pipe joints at the bend. Secure cable pipes and troughs by using cable ties or angle steels at the spacing of 1 m (3.28 ft) to 1.5 m (4.92 ft) and ground the two ends in the case of metal tubes.
·     When you route PVC pipes outdoors in a horizontal way, cut an opening at the bottom of the PVC pipes every 6 m (19.69 ft) to avoid water accumulation.
·     When routing cables outdoors without using cable casings, create drip loops on the cables to prevent the rainwater from flowing into the Ethernet ports of the device along the cables.
·     Seal the holes for routing cables in the wall with waterproof and flame retardant material.
Figure2-1 Installation flowchart
CAUTION
CAUTION:
·     Correctly connecting the grounding cable is crucial to lightning protection and EMI protection.
·     Before connecting the AP to the power source, make sure the grounding cable is correctly connected.
No grounding cable is provided with the AP. Prepare one yourself.
To connect the grounding cable to the AP:
1.     Attach a ring terminal to the grounding cable.
Figure2-2 Attaching a ring terminal to the grounding cable
2.     Use the grounding screw to attach the ring terminal to the grounding point on the AP.
Figure2-3 Connecting the grounding cable to the AP
Connecting cables
CAUTION
CAUTION:
To avoid device damage, install weatherproof caps securely for unused ports.
IMPORTANT
IMPORTANT:
When you apply weatherproof tape to a cable connection, follow these restrictions and guidelines:
·     Make sure you attach the adhesive side of the tape to the cable connector.
·     Pull the tape as needed for overlap.
·     Start wrapping at the top of the connector, and overlap the tape to half-width. Avoid creases or wrinkles and press the tape against the connection so that there are no gaps. Smooth each wrapped layer with your hands to ensure full adhesion.
Use Category-5e or above Ethernet cables only. As a best practice, use shielded twisted pair (STP) cables.
To connect an Ethernet cable:
1.     Disassemble the liquid-tight adapter and put the rubber seal aside, and then feed the cable through the adapter.
2.     Attach the rubber seal to the cable, connect the Ethernet cable to the target port on the AP, and insert the rubber seal into the liquid-tight adapter.
3.     Use a wrench or wear nonslip gloves to fasten the sealing nut and the liquid-tight adapter.
Figure2-4 Connecting an Ethernet cable
4.     Start wrapping at the top of the connector. Smooth the tape edges to ensure full adhesion.
Figure2-5 Wrapping the connector
5.     Route the cable outdoors.
¡     If you route the cable outdoors by using PVC pipes, cut an opening at the bottom of the PVC pipes every 6 m (19.69 ft) to avoid water accumulation.
¡     If you route the cable outdoors without using cable casings, create drip loops on the cable to prevent rainwater from flowing into the Ethernet port of the device along the cable.
Figure2-6 Creating a drip loop
When you connect an optical fiber, follow these restrictions and guidelines:
·     Before connecting an optical fiber, remove the dust caps from the fiber connectors and keep the caps secure.
·     To avoid optical fiber damage, do not pull the optical fiber with excessive force.
·     To avoid affecting fiber performance, make sure the optical fiber is not bended or folded when fastening the sealing nut.
·     To use a fiber pigtail that does not have any protective sleeve, first use weatherproof tape to wrap the fiber pigtail before you connect the fiber pigtail.
1.     Use weatherproof tape to wrap the fiber connectors around the rubber boots, build up the optical fiber diameter near the opening in the split sealing washer. Smooth the tape edges to ensure full adhesion.
Figure2-7 Wrapping the rubber boots of the fiber connectors
2.     Disassemble the liquid tight adapter (assembled by a weatherproof connector, a sealing nut, and a rubber seal) and detach the rubber seal, feed the optical fiber through the connector, and then attach the rubber seal to the cable.
Figure2-8 Feeding the optical fiber through the connector
3.     Insert the rubber seal into the weatherproof connector.
Figure2-9 Inserting the rubber seal into the weatherproof connector
4.     Adjust the weatherproof connector to ensure that the rubber boots of optical fiber reaches out of the weatherproof connector. Attach a transceiver module to the SFP port of the AP, and then connect the optical fiber to the transceiver module.
Figure2-10 Connecting the optical fiber to the transceiver module
5.     Adjust the weatherproof connector to ensure that the optical fiber between the liquid-tight adapter and the optical fiber connector is not bended or folded, and then fasten the weatherproof connector.
Figure2-11 Fastening the weatherproof connector
6.     Fasten the sealing nut.
Figure2-12 Fastening the sealing nut
7.     Start wrapping at the top of the weatherproof connector until the entire connector is wrapped. Smooth the tape edges to ensure full adhesion.
Figure2-13 Wrapping the connection
CAUTION
CAUTION:
To avoid device damage or bodily injury caused by excessive radiation exposure, make sure the antennas and RF cables comply with local regulations. As a best practice, purchase H3C recommended antennas and RF cables. To ensure correct operation of the AP, make sure the antennas and RF cables meet the following basic requirements:
·     The VSWR for RF cables is less than or equal to 1.4.
·     The VSWR for antennas is less than or equal to 1.8.
·     The maximum gain can make sure the AP's EIRP complies with local regulations.
IMPORTANT
IMPORTANT:
·     As a best practice, purchase and install lightning arresters for antenna ports in the areas where thunderstorms frequently occur.
·     The primary antenna chain for radio 1 corresponds to the 2.4G-1 antenna port. When you install antennas for radio 1, the 2.4G-1 antenna port takes precedence. The primary antenna chain for radio 2 corresponds to the 5G-1 antenna port. To install antennas for radio 2, the 5G-1 antenna port takes precedence.
·     Connect a 50-ohm RF load to any empty antenna port.
An RF cable connects an outdoor antenna to an antenna connector on the AP.
To connect an RF cable:
1.     Remove the weatherproof cap from the antenna connector on the AP.
2.     Connect a lightning arrester to the antenna connector.
3.     Connect the RF cable to the lightning arrester.
4.     Wrap each connection with weatherproof tape until the entire connection is wrapped. Smooth the tape edges to ensure full adhesion.
5.     Ground the lighting arrester.
Figure2-14 Connecting an RF cable
6.     Attach loads to unused antenna connectors to avoid radio interference.
Figure2-15 Attaching loads to unused antenna connectors
Connecting an external omnidirectional antenna
3.     Connect the antenna to the lightning arrester.
6.     Attach loads to unused antenna connectors to avoid radio interference. For the figure of attaching loads to unused antenna connectors, see Figure2-15.
Figure2-16 Connecting an external omnidirectional antenna
Installing the AP
1.     Orient the AP bracket correctly.
¡     To mount the AP on a horizontal pole, orient the AP bracket with the horizontal pole mounting arrow on it pointing up. To mount the AP on a vertical pole, orient the AP bracket with the vertical pole mounting arrow on it pointing up.
¡     To mount the AP on a wall, you can orient the AP bracket horizontally or vertically as required.
2.     Align the AP bracket with the screw holes on the rear of the AP, and then use M5 × 12 screws to attach the AP bracket to the AP.
Figure2-17 Installing the AP bracket with the horizontal pole mounting arrow on it pointing up
Figure2-18 Installing the AP bracket with the vertical pole mounting arrow on it pointing up
Mounting the AP on a vertical pole
You can use band clamps and a wall/pole bracket to mount the AP on a pole. The provided band clamps support poles with a diameter of 60 to 80 mm (2.36 to 3.15 in). If the diameter of the pole is not in the range, prepare band clamps yourself.
To mount the AP on a vertical pole:
1.     Slide the two band clamps through the mounting slots on the wall/pole bracket. Then use the band clamps to attach the wall/pole bracket to the vertical pole.
Figure2-19 Securing the wall/pole bracket to the vertical pole
2.     Orient the AP with the vertical pole mounting arrow on the AP bracket pointing up. Use M5 × 20 screws to secure the AP bracket attached to the AP to the wall/pole bracket.
Figure2-20 Attaching the AP to the wall/pole bracket
Mounting the AP on a horizontal pole
1.     Slide the two band clamps through the mounting slots on the wall/pole bracket. Then use the band clamps to attach the wall/pole bracket to the horizontal pole.
Figure2-21 Securing the wall/pole bracket to the horizontal pole
2.     Orient the AP with the horizontal pole mounting arrow on the AP bracket pointing up. Use M5 × 20 screws to secure the AP bracket attached to the AP to the wall/pole bracket.
Figure2-22 Attaching the AP to the wall/pole bracket
The following procedure mounts the AP on a wall with the vertical pole mounting arrow on the AP bracket pointing up. To mount the AP on a wall with the horizontal pole mounting arrow on the AP bracket pointing up, adjust the installation direction of the wall/pole bracket accordingly.
No expansion bolts are provided with the AP. Prepare them yourself.
To mount the AP on a wall:
1.     Use the wall/pole bracket to mark four installation holes on the wall.
Figure2-23 Marking the installation holes
2.     Drill four holes with a diameter of 8 mm (0.32 in) at the marked locations. Tap an expansion bolt with a rubber hammer into each hole and then remove the nut and washers, as shown in Figure2-24.
¡     Keep the drill bit perpendicular to the wall and hold the drill handle tightly with both hands when drilling holes.
¡     In a sturdy and smooth wall, use a punch to create a hole to help locate the drill bit.
¡     The depths of four holes must be the same.
¡     Do not tap the expansion bolts all the way in, leaving a certain space for hanging the AP.
Figure2-24 Installing an expansion bolt into the wall
3.     Align the installation holes on the wall/pole bracket with the bolts on the wall, and then fasten the nuts and washers on the expansion bolts to secure the wall/pole bracket to the wall.
Figure2-25 Attaching the wall/pole bracket to the wall
4.     Orient the AP with the vertical pole mounting arrow on the AP bracket pointing up. Use M5 × 20 screws to secure the AP bracket attached to the AP to the wall/pole bracket.
Figure2-26 Attaching the AP to the wall/pole bracket
After the AP is installed, you can adjust the AP angle by loosening the four screws that secure the AP bracket and wall/pole bracket.
·     If the AP is installed with the vertical pole mounting arrow on the AP bracket pointing up, you can adjust the AP to the desired elevation angle (the adjustment angle must not exceed 60 degrees).
·     If the AP is installed with the horizontal pole mounting arrow on the AP bracket pointing up, you can adjust the AP to the desired azimuth angle (the adjustment angle must not exceed 60 degrees).
Figure2-27 Adjusting the AP angle on a vertical pole
Powering the AP
CAUTION
CAUTION:
·     Only the GE1 port of the AP supports IEEE 802.3at PoE input.
·     To avoid damage, do not connect a cable carrying power to the PoE_OUT port.
To power the AP through PoE, use an Ethernet cable to connect an Ethernet port on a PoE switch to the GE1 port on the AP.
Figure2-28 Powering the AP through PoE
CAUTION
CAUTION:
Follow these restrictions and guidelines for powering the AP by using a power injector:
·     Make sure the AP is installed correctly before powering on the AP.
·     Place the power injector stable in a well-ventilated location near the switch or access controller. Do not suspend the power injector in the air or place it on another device.
·     If multiple power injectors are installed in one equipment room or low voltage room, use one power strip for all these injectors and lead in the power strip from the spare air switch of the AC power distribution box.
You can supply power to the AP by using a dual-port power injector. Use a power injector that meets the requirements listed in Table2-1.
Table2-1 Power injector specifications
Item
Specification
Model
ADP060-55V-PoE-GL
Input
100 V to 240 V @ 1.5 A
Output
55 V @ 1100 mA
The power injector connection is different depending on whether a copper cable or optical fiber is used to connect the AP to the uplink network.
Using a copper cable for uplink network connection
To use a power injector to power the AP, the switch or AC to which the power injector connects does not need to be PoE-capable.
The PoE1 port on the PoE injector is connected to the uplink network through the LAN1 port, and PoE2 through LAN2.
To power the AP by using a power injector:
1.     Connect the PoE1 port on the injector to the GE1 port of the AP.
2.     Connect the LAN1 port on the injector to a switch or access controller.
3.     Connect the power injector and the Ethernet switch or AC to AC power sources.
Figure2-29 Powering the AP by using a power injector (1)
Using an optical fiber for uplink network connection
1.     Use an optical fiber to connect the SFP port on the AP to an Ethernet switch or access controller.
2.     Connect the power input end of the power injector to an AC power source.
3.     Connect the PoE1 port on the injector to the GE1 port of the AP.
Figure2-30 Powering the AP by using a power injector (2)
Labeling cables
After cable connection, attach labels to each cable as a best practice for future maintenance.
·     Attach a label to both ends of a cable and every certain distance.
·     Use cable flags or cable sleeves to label antenna and Ethernet cables. Use cable flags to label optical fibers.
·     Use waterproof labels with clear content. Attach labels to proper places where they can be seen directly.
·     When routing the cables outdoors, use weatherproof tape to seal the labels to prevent them from falling off.
After the installation is complete, check the following items before powering on the AP:
·     The power source meets the power specification of the AP.
·     The AP is reliably grounded.
·     The Ethernet cables are correctly connected.
·     The cables are correctly labeled.
·     Weatherproof caps are installed securely for unused ports on the AP.
Powering on the AP
IMPORTANT
IMPORTANT:
Make sure all cables are correctly connected and the AP is connected to the power source correctly before powering on the AP.
Switch on the external power source and verify that the AP is operating correctly by examining the LEDs on the AP. For more information about the LEDs, see "Appendix B LEDs and Ports."
All AP settings are configured on the AC. To verify network connectivity of the AP, execute the display wlan ap all command on the AC. If the AP status is R/M, the AP has been connected to the network.
<AC> display wlan ap all
Total number of APs: 1
Total number of connected APs: 1
Total number of connected manual APs: 1
Total number of connected auto APs: 0
Total number of connected common APs: 1
Total number of connected WTUs: 0
Total number of inside APs: 0
Maximum supported APs: 3072
Remaining APs: 3071
Total AP licenses: 128
Remaining AP licenses: 127
                                 AP information
 State : I = Idle,       J  = Join,       JA = JoinAck,    IL = ImageLoad
         C = Config,     DC = DataCheck,  R  = Run   M = Master,  B = Backup
AP name                        APID  State Model           Serial ID
ap1                             1      R/M   WA6620X         219801A1CS8206E00001
When the AP operates in cloud mode, use a wireless terminal to search for and access the wireless service provided by the AP. If you can access external networks, the AP has been connected to the network.
3 Accessing the AP
When the AP operates in cloud or anchor AC mode, you can access and configure the AP from the console port, Web interface, or through Telnet. Accessing the AP from the Web interface or through Telnet requires the IP address of the AP.
Prepare the following items for accessing the device from the console port:
·     An 8-core console cable, with a crimped RJ-45 connector at one end, and a DB-9 connector at the other end.
·     A configuration terminal. It can be a standard character terminal with an RS-232 port, or a PC.
CAUTION
CAUTION:
·     To connect a PC to the AP, first connect the PC end. To disconnect a PC from the AP, first disconnect the AP end.
·     If the PC does not have an RS-232 port but a USB port, use a USB-to-RS-232 converter to connect the USB port to the console cable and install the driver on the PC.
To connect the AP to a configuration terminal from the console port:
1.     Connect the DB-9 connector of the console cable to the serial port on the configuration terminal, for example, a PC.
2.     Connect the RJ-45 connector of the console cable to the console port on the AP.
To configure and manage the AP from the console port, you must run a terminal emulator program, such as HyperTerminal or PuTTY, on your configuration terminal. You can use the emulator program to connect a network device, a Telnet site, or an SSH site. For more information about the terminal emulator programs, see the user guides for these programs.
Configure the terminal parameters as follows:
·     Bits per second—9,600.
·     Data bits—8.
·     Stop bits—1.
·     Parity—None.
·     Flow control—None.
Verify that the AP is connected correctly to the configuration terminal and the configuration terminal parameters are configured correctly. Then, power on the AP. You can see the following information on the configuration terminal:
System is starting...
Booting Normal Extend BootWare.
System application is starting...
Startup configuration file does not exist.
User interface con0 is available.
Press ENTER to get started.
By default, Telnet is enabled and the following login information is defined for your login:
·     Username—admin.
·     Password—h3capadmin.
Cloud mode
Make sure the PC obtains an IP address dynamically.
When the AP operates in cloud mode, it obtains the IP address of VLAN 1 dynamically by default.
Some Intel wireless adapters do not support 802.11ax. For clients to detect Wi-Fi 6 networks, upgrade the driver for the wireless adapter to the most recent version. For more information, see the official statement of Intel.
To log in to the AP through a wireless connection:
1.     Enable WLAN on the configuration terminal and access WLAN H3C_xxxxxx, where xxxxxx is the last six bits of the AP's MAC address.
2.     Enter telnet wlan.h3c.com from the CLI of the terminal.
3.     Enter the default username and password and change the default password as prompted.
Anchor ACmode
Make sure the PC and AP are on the same network.
To log in to the AP through a wired connection:
1.     Enter the default IP address for accessing the device through Telnet: 192.168.0.50. If the default IP address has been changed, contact the administrator to get the new IP address.
2.     Enter the default username and password and change the default password as prompted.
By default, HTTP and HTTPS are enabled and the following login information is defined for your login:
·     Username—admin.
Cloud mode
2.     Visit http://wlan.h3c.com from a browser, and then press Enter.
Visit http://myap.h3c.com from a browser for a configuration terminal in a version earlier than 2448P10.
3.     Enter the default username and password. For security purposes, change the password as prompted after you access the Web interface, and then click OK.
Anchor ACmode
To log in to the AP from the Web interface:
1.     Enter the default IP address for accessing the device from the Web interface: 192.168.0.50. If the default IP address has been changed, contact the administrator to get the new IP address.
2.     Enter the default username and password, and then click Log In. Change the default password as prompted, and then click OK.
You can manage the AP remotely from the Cloudnet platform (Web interface or app) only when the AP operates in cloud mode.
Make sure the smartphone uses Android 4.0, iOS7.0, or a higher-version operating system.
Download and install Cloudnet App Int from Google Play Store.
To manage the AP from the Cloudnet platform, make sure the AP uses an IP address that can reach the external network.
To log in to the Cloudnet platform:
1.     Open Cloudnet App Int or visit https://oasiscloudnet.h3c.com from a browser.
2.     Enter the username and password.
After login, you can add the AP to the platform and manage the AP. For more information about platform login and device management, see H3C Cloudnet Deployment Guide.
Table5-1 Technical specifications
Item
Specification
Dimensions (H × W × D)
79.5 × 250 × 250 mm (3.13 × 9.84 × 9.84 in)
Weight
1.8 kg (3.97 lb)
System power consumption
31 W
Antennas
·     External antenna
·     Built-in directional antenna:
¡     2.4 G: 11 dBi gain
¡     5 G: 11 dBi gain
IEEE standards
IEEE802.11a/b/g/n/ac/ax
LEDs
Table6-1 LED descriptions (fit mode)
LED status
Off
No power is present.
Yellow
Flashing (twice per second)
The Ethernet interfaces are down and no mesh links are established.
Steady on
The AP is initializing.
Green
Flashing (once per two seconds)
The AP is starting up.
Flashing (once per second)
Only the 2.4G radio has associated clients.
The AP is upgrading the image.
Steady on
The AP has registered with an AC, but does not have any associated clients.
Blue
Only the 5G radio has associated clients.
Alternating between green and blue at 1 Hz
Both the 2.4G and 5G radios have associated clients.
Table6-2 LED descriptions (cloud mode)
LED status
Off
No power is present or the LED has been turned off from the CLI.
Yellow
Steady on
The AP is initializing, or an initialization exception has occurred.
Green
Steady on
The AP is in standby state, has connected to Cloudnet, but does not have any associated clients.
The AP has connected to Cloudnet, and the radios have associated clients.
Blue
Steady on
The AP is in standby state, has not connected to Cloudnet, and does not have any associated clients.
The AP has not connected to Cloudnet, but the radios have associated clients.
Table6-3 LED descriptions (anchor AC mode)
LED status
Off
Yellow
Steady on
Green
Steady on
The AP has started up and is in standby state, but does not have any associated clients.
Blue
Ports
The AP has the following ports:
·     One GE1/PoE+ port.
·     One GE2/PoE_OUT port.
·     One GE3/SFP port.
·     One console port.
·     Two 2.4G antenna ports.
·     Two 5G antenna ports.
Figure6-1 Front view
(1) and (2) 10/100/1000M Ethernet ports
(3) 1000BASE-X SFP port
(4) Console port
Figure6-2 Rear view
(1) 2.4G antenna ports (2.4G-1/2)
(2) 5G antenna ports (5G-1/2)
Table6-4 Port descriptions
Port
Standards and protocols
GE1/PoE+
·     IEEE802.3
·     IEEE802.3u
·     IEEE802.3at
·     IEEE802.3af
Connects the AP to an uplink device for Internet or MAN access. It can also receive PoE power from the uplink device.
It is represented by interface GE1/0/1 in the MAP file and Gigabitethernet 1 for configuration on the AC.
GE2/PoE_OUT
·     IEEE802.3
·     IEEE802.3u
Connects the AP to a downlink device. It can also supplies power to a standard PD.
It is represented by interface GE1/0/2 in the MAP file and Gigabitethernet 2 for configuration on the AC.
GE3/SFP
·     IEEE802.3
·     SFP MSA
·     SFF-8427
It is represented by interface GE1/0/3 in the MAP file and Gigabitethernet 3 for configuration on the AC.
CONSOLE
RS/EIA-232
For device configuration and management by the maintenance engineers.
2.4G-1/2 and 5G-1/2
·     IEEE802.11a
·     IEEE802.11b
·     IEEE802.11g
·     IEEE802.11n
·     IEEE802.11ac
·     IEEE802.11ax
Connect RF cables.
An SFP transceiver module is required if you are to use the SFP fiber port. The AP supports only fibers with LC connectors.
Figure7-1 SFP transceiver module
Figure7-2 Optical fibers with LC connectors
(1) LC connector
(2) Optical fiber
Specifications
A transceiver module that has "MM" in its name supports multi-mode optical fibers. A transceiver module that has "SM" in its name supports single-mode optical fibers.
Table7-1 SFP-GE-SX-MM850-A transceiver module specifications
Item
SFP-GE-SX-MM850-A
Central wavelength
850 nm
Max transmission distance
550 m (1804.46 ft)
Data rate
1250 Mbps
Connector type
Duplex LC
Fiber mode
MMF
Fiber diameter
50 μm
Output optical power
–9.5 to 0 dBm
Receiver sensitivity
–17 dBm
Light saturation
–3 dBm
Table7-2 SFP-GE-LX-SM1310-A transceiver module specifications
Item
SFP-GE-LX-SM1310-A
Central wavelength
1310 nm
10 km (6.21 miles)
Data rate
1250 Mbps
Connector type
Duplex LC
Fiber mode
SMF
Fiber diameter
9 μm
–9.5 to –3 dBm
–20 dBm
Light saturation
–3 dBm
Table7-3 SFP-GE-LH40-SM1310 transceiver module specifications
Item
SFP-GE-LH40-SM1310
Central wavelength
1310 nm
40 km (24.86 miles)
Data rate
1250 Mbps
Connector type
Duplex LC
Fiber mode
SMF
Fiber diameter
9 μm
–2 to +5 dBm
–22 dBm
Light saturation
–3 dBm
Table7-4 SFP-GE-LH40-SM1550 transceiver module specifications
Item
SFP-GE-LH40-SM1550
Central wavelength
1550 nm
40 km (24.86 miles)
Data rate
1250 Mbps
Connector type
Duplex LC
Fiber mode
SMF
Fiber diameter
9 μm
–4 to +1 dBm
–21 dBm
Light saturation
–3 dBm
