00-Preface
Preface
H3C CPE5100P 5G Wireless Data Terminal Installation Guide describes the installation workflow, pre-installation preparation, device installation,cable connection, post-installation check, initial login to the local network management web, and device maintenance for the CPE5100P.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents a mobile communication endpoint. |
Represents a mobile communication base station, such as an eNodeB. |
Represents a BBU. |
Represents an RRU. |
Represents an FSW. |
Represents a pRRU. |
Documentation feedback
We appreciate your comments.
