GB0-601-MOCK
    04-06-2024
1. Which of the following features is not supported on the HBA card of the H3C server?
A. JBOD
B. HBA
C. RAID
D. simply volumes
2. When a server is installed with a RedHat Linux OS and needs to load an array card driver, which of the following methods is correct?
A. Enter "linux dd" at the end of the lunuxefi line, and press F10 or Ctrl + X to start the installation.
B. Input linux diag at the end of the lunuxefi line, and press F10 or Ctrl+X to start the installation.
C. Input linux single at the end of the lunuxefi line, and press F10 or Ctrl+X to start the installation.
D. Input linux driver at the end of the lunuxefi line, and press F10 or Ctrl+X to start the installation.
3. During the upgrade of the HDM, if configuration overridden is selected, after the update, which of the following will occur?
A. All configurations of the HDM will be overridden.
B. All configurations of the BIOS will be overridden.
C. All configurations of the storage card will be overridden.
D. All users in the OS will be overridden.
4. How many hard disks do we have to access at most to the H3C R4300 G3 server?
A. 24
B. 36
C. 48
D. 52
5. For the H3C rack-mounted server R4900G3, when the Windows 2012R2 Datacenter system is installed, the hard disk is not recognized during the installation. Which of the statements below is wrong?
A. The R4900G3 server does not support Windows 2012R2 Datacenter system.
B. The array card driver may be loaded.
C. The array card may be replaced.
D. The hard disk may be replaced.
6. What are the startup modes of the server BIOS?
A. UEFI
B. legacy
C. PXE
D. DHCP
7. What statements below about the RedHat Linux OS are correct?
A. Use the rpm -ivh drivername.rpm command to install the driver.
B. Use the modinfo drivername command to view the current driver in use of the system.
C. Use the apt-get install drivername command to install the driver.
D. Use the rpm -e drivename.rpm command to install the driver.
8. What are the alarm levels in the SDS log?
A. information
B. warning
C. critical
D. caution
9. What features can the array card battery support?
A. Pre-read
B. Pre-write
C. Write-back
10. Which of the following are the common request actions of Redfish?
A. GET
B. POST
C. DELETE
D. PATCH
