05-Layer 3—IP Routing Configuration Guide
HomeSupportSwitchesS5560X-EI SeriesConfigure & DeployConfiguration GuidesH3C S5560X-EI & S5500V2-EI & MS4520V2 Switch Series Configuration Guides-R65xx-6W10405-Layer 3—IP Routing Configuration Guide
11-IPv6 policy-based routing configuration
11-IPv6 policy-based routing configuration 193.79 KB
Configuring IPv6 PBR
About IPv6 PBR
IPv6 policy-based routing (PBR) uses user-defined policies to route IPv6 packets. A policy can specify parameters for packets that match specific criteria such as ACLs. The parameters include the next hop.
IPv6 packet forwarding process
A device forwards received IPv6 packets using the following process:
1.     The device uses PBR to forward matching packets.
2.     If one of the following events occurs, the device searches for a route (except the default route) in the routing table to forward packets:
¡     The packets do not match the PBR policy.
¡     The PBR-based forwarding fails.
3.     If the forwarding fails, the device uses the default route to forward packets.
IPv6 PBR types
IPv6 PBR includes the following types:
·     Local PBR—Guides the forwarding of locally generated packets, such as the ICMP packets generated by using the ping command.
·     Interface PBR—Guides the forwarding of packets received on an interface only.
Policy
An IPv6 policy includes match criteria and actions to be taken on the matching packets. A policy can have one or multiple nodes as follows:
·     Each node is identified by a node number. A smaller node number has a higher priority.
·     A node contains if-match and apply clauses. An if-match clause specifies a match criterion, and an apply clause specifies an action.
·     A node has a match mode of permit or deny.
An IPv6 policy compares packets with nodes in priority order. If a packet matches the criteria on a node, it is processed by the action on the node. If the packet does not match any criteria on the node, it goes to the next node for a match. If the packet does not match the criteria on any node, the device performs a routing table lookup for the packet.
Relationship between if-match clauses
On a node, you can specify multiple types of if-match clauses, but only one if-match clause for each type. For a specific type of if-match clause, the most recent configuration overwrites the previous one. A packet that matches all the if-match clauses of a node matches the node.
Relationship between apply clauses
You can specify multiple apply clauses for a node, but some of them might not be executed. For more information about relationship between apply clauses, see "Configuring actions for a node."
Relationship between the match mode and clauses on the node
Does a packet match all the if-match clauses on the node?
Match mode
In permit mode
In deny mode
Yes
·     If the node contains apply clauses, IPv6 PBR executes the apply clauses on the node.
¡     If IPv6 PBR-based forwarding succeeds, IPv6 PBR does not compare the packet with the next node.
¡     If IPv6 PBR-based forwarding fails, IPv6 PBR compares the packet with the next node.
·     If the node does not contain apply clauses, the device performs a routing table lookup for the packet.
The device performs a routing table lookup for the packet.
No
A node that has no if-match clauses matches any packet.
IPv6 PBR and Track
IPv6 PBR can work with the Track feature to dynamically adapt the availability status of an apply clause to the link status of a tracked object. The tracked object can be a next hop.
·     When the track entry associated with an object changes to Negative, the apply clause is invalid.
·     When the track entry changes to Positive or NotReady, the apply clause is valid.
For more information about Track and IPv6 PBR collaboration, see High Availability Configuration Guide.
Restrictions and guidelines: IPv6 PBR configuration
If a packet destined for the local device matches an IPv6 PBR policy, IPv6 PBR will execute the apply clauses in the policy, including the clause for forwarding. When you configure an IPv6 PBR policy, be careful to avoid this situation.
The S5500V2-E switch series does not support the VXLAN and EVPN features. For more information about EVPN, see EVPN Configuration Guide. For more information about VXLAN, see VXLAN Configuration Guide.
IPv6 PBR tasks at a glance
To configure IPv6 PBR, perform the following tasks:
1.     Configuring an IPv6 policy
a.     Creating an IPv6 node
b.     Setting match criteria for an IPv6 node
c.     Configuring actions for an IPv6 node
2.     Specifying a policy for IPv6 PBR
¡     Specifying an IPv6 policy for IPv6 local PBR
¡     Specifying an IPv6 policy for IPv6 interface PBR
¡     Specifying an IPv6 policy for IPv6 global PBR
3.     (Optional.) Disabling IPv6 PBR from processing packets destined for the local interface
2.     Create an IPv6 policy or policy node and enter its view.
3.     (Optional.) Configure a description for the IPv6 policy node.
By default, no description is configured for an IPv6 policy node.
2.     Enter IPv6 policy node view.
3.     Set match criteria.
¡     Set an ACL match criterion.
By default, no ACL match criterion is set.
The ACL match criterion cannot match Layer 2 information.
When using the ACL to match packets, IPv6 PBR ignores the action (permit or deny) and time range settings in the ACL.
The apply clauses allow you to specify actions to take on matching packets on a node.
The following apply clauses determine the packet forwarding paths in a descending order:
·     apply next-hop
·     apply output-interface
IPv6 PBR supports the apply clauses in Table 1.
Table 1 Apply clauses supported in IPv6 PBR
Clause
Meaning
Remarks
apply loadshare next-hop
Enables load sharing among multiple next hops.
Multiple next hop options operate in either primary/backup or load sharing mode.
·     Primary/backup mode—One option is selected from all options in configuration order for packet forwarding, with all remaining options as backups. When the selected option fails, the next available option takes over.
·     Load sharing mode—Matching traffic is distributed across the available options, as follows:
¡     Multiple next hops—Load share traffic in proportion to their weight. By default, all next hops have the same weight and traffic is evenly distributed among them.
By default, the primary/backup mode applies.
For the load sharing mode to take effect, make sure multiple next hops are set in the policy.
apply next-hop and apply output-interface
Sets next hops and sets output interfaces.
If both clauses are configured, only the apply next-hop clause is executed.
apply service-chain
Sets service chain information.
For this clause to take effect, you must also use the apply next-hop clause to specify a reachable next hop.
Restrictions and guidelines for action configuration
If you specify a next hop, IPv6 PBR periodically performs a lookup in the FIB table to determine its availability. Temporary service interruption might occur if IPv6 PBR does not update the route immediately after its availability status changes.
3.     Configure actions for a node.
¡     Set next hops for permitted IPv6 packets.
apply next-hop [ vpn-instance vpn-instance-name ] { ipv6-address [ direct ] [ track track-entry-number ] [ service-chain path-id service-path-id [ path-index service-path-index ] ] } &<1-6>
By default, no next hops are specified.
You can specify multiple next hops for backup in one command line or by executing this command multiple times. You can specify a maximum of six next hops for a node.
If multiple next hops on the same subnet are specified for backup, the device first uses the subnet route for the next hops to forward packets when the primary next hop fails. If the subnet route is not available, the device selects a backup next hop.
¡     Enable load sharing among multiple next hops.
By default, the next hops operate in primary/backup mode.
¡     Set output interfaces.
apply output-interface null 0 [ track track-entry-number ]
By default, no output interfaces are specified.
¡     Set service chain information.
apply service-chain path-id service-path-id [ path-index service-path-index ]
By default, no service chain information is set.
This clause does not apply to software forwarded packets.
Perform this task to specify an IPv6 policy for IPv6 local PBR to guide the forwarding of locally generated packets.
You can specify only one policy for IPv6 local PBR and must make sure the specified policy already exists. Before you apply a new policy, you must first remove the current policy.
IPv6 local PBR might affect local services, such as ping and Telnet. When you use IPv6 local PBR, make sure you fully understand its impact on local services of the device.
2.     Specify an IPv6 policy for IPv6 local PBR.
By default, IPv6 local PBR is not enabled.
Perform this task to apply an IPv6 policy to an interface to guide the forwarding of packets received on the interface only.
You can apply only one policy to an interface and must make sure the specified policy already exists. Before you apply a new policy, you must first remove the current policy from the interface.
You can apply a policy to multiple interfaces.
2.     Enter interface view.
3.     Specify an IPv6 policy for IPv6 interface PBR.
By default, no IPv6 policy is applied to the interface.
Perform this task to apply an IPv6 policy to all interfaces on the device to guide the forwarding of packets received on the interfaces.
You can apply only one IPv6 policy for IPv6 global PBR and the specified IPv6 policy must already exist. Before you can apply a new IPv6 policy, you must first remove the current IPv6 policy.
IPv6 interface PBR takes precedence over IPv6 global PBR on an interface. When they are both configured and packets fail to match the IPv6 interface PBR policy, IPv6 global PBR applies.
2.     Specify an IPv6 policy for IPv6 global PBR.
ipv6 global policy-based-route policy-name
By default, no IPv6 policy is specified for IPv6 global PBR.
When an interface receives a packet destined for an IPv6 address of itself, the interface matches the packet against the IPv6 PBR policies. If the packet matches a node in a policy, IPv6 PBR will execute the action specified by the node on the packet before sending the packet to the CPU. To enable the interface to directly send the packet to the CPU without executing the PBR action, configure this feature on the interface. This feature prevents IPv6 PBR from sending packets destined for the local device to other devices by mistake.
This feature is supported in Release 6530P01 and later.
3.     Disable IPv6 PBR from processing packets destined for an IPv6 address of the interface.
ipv6 ignore policy-based-route dest-local enable
By default, IPv6 PBR processes packets destined for an IPv6 address of the interface.
Display and maintenance commands for IPv6 PBR
Display IPv6 PBR policy information.
Display IPv6 global PBR configuration and statistics.
display ipv6 policy-based-route global [ slot slot-number ]
Display IPv6 interface PBR configuration and statistics.
display ipv6 policy-based-route interface interface-type interface-number [ slot slot-number ]
Display IPv6 local PBR configuration and statistics.
display ipv6 policy-based-route local [ slot slot-number ]
Display IPv6 PBR configuration.
display ipv6 policy-based-route setup
Clear IPv6 PBR statistics.
IPv6 PBR configuration examples
Example: Configuring packet type-based IPv6 local PBR
As shown in Figure 1, Switch B and Switch C are connected through Switch A. Switch B and Switch C do not have a route to reach each other.
Configure IPv6 PBR on Switch A to forward all TCP packets to the next hop 1::2 (Switch B).
Figure 1 Network diagram
1.     Configure Switch A:
# Create VLAN 10 and VLAN 20.
[SwitchA] vlan 10
[SwitchA-vlan10] quit
[SwitchA] vlan 20
[SwitchA-vlan20] quit
# Configure the IPv6 addresses of VLAN-interface 10 and VLAN-interface 20.
[SwitchA-Vlan-interface10] ipv6 address 1::1 64
[SwitchA-Vlan-interface20] ipv6 address 2::1 64
# Configure ACL 3001 to match TCP packets.
[SwitchA] acl ipv6 advanced 3001
[SwitchA-acl-ipv6-adv-3001] rule permit tcp
[SwitchA-acl-ipv6-adv-3001] quit
# Configure Node 5 for policy aaa to forward TCP packets to next hop 1::2.
[SwitchA] ipv6 policy-based-route aaa permit node 5
[SwitchA-pbr6-aaa-5] if-match acl 3001
[SwitchA-pbr6-aaa-5] apply next-hop 1::2
[SwitchA-pbr6-aaa-5] quit
# Configure IPv6 local PBR by applying policy aaa to Switch A.
[SwitchA] ipv6 local policy-based-route aaa
2.     Configure Switch B:
# Create VLAN 10.
[SwitchB] vlan 10
[SwitchB-vlan10] quit
# Configure the IPv6 address of VLAN-interface 10.
[SwitchB-Vlan-interface10] ipv6 address 1::2 64
3.     Configure Switch C:
# Create VLAN 20.
[SwitchC] vlan 20
[SwitchC-vlan20] quit
# Configure the IPv6 address of VLAN-interface 20.
[SwitchC] interface vlan-interface 20
[SwitchC-Vlan-interface20] ipv6 address 2::2 64
1.     Perform telnet operations to verify that IPv6 local PBR on Switch A operates as configured to forward the matching TCP packets to the next hop 1::2 (Switch B), as follows:
# Verify that you can telnet to Switch B from Switch A successfully. (Details not shown.)
# Verify that you cannot telnet to Switch C from Switch A. (Details not shown.)
2.     Verify that Switch A forwards packets other than TCP packets through VLAN-interface 20. For example, verify that you can ping Switch C from Switch A. (Details not shown.)
Example: Configuring packet type-based IPv6 interface PBR
As shown in Figure 2, Switch B and Switch C do not have a route to reach each other.
Configure IPv6 PBR on Switch A to forward all TCP packets received on VLAN-interface 11 to the next hop 1::2 (Switch B).
Figure 2 Network diagram
[SwitchA] vlan 10
[SwitchA] vlan 20
# Configure RIPng.
[SwitchA] ripng 1
[SwitchA-ripng-1] quit
[SwitchA-Vlan-interface10] ripng 1 enable
[SwitchA-Vlan-interface20] ripng 1 enable
# Configure IPv6 interface PBR by applying policy aaa to VLAN-interface 11.
[SwitchA-Vlan-interface11] ipv6 address 10::2 64
[SwitchA-Vlan-interface11] undo ipv6 nd ra halt
[SwitchA-Vlan-interface11] ripng 1 enable
[SwitchA-Vlan-interface11] ipv6 policy-based-route aaa
# Create VLAN 10.
[SwitchB] vlan 10
# Configure RIPng.
[SwitchB] ripng 1
[SwitchB-ripng-1] quit
[SwitchB-Vlan-interface10] ripng 1 enable
# Create VLAN 20.
[SwitchC] vlan 20
# Configure RIPng.
[SwitchC] ripng 1
[SwitchC-ripng-1] quit
[SwitchC-Vlan-interface20] ripng 1 enable
[SwitchC-Vlan-interface20] quit
1.     Enable IPv6 and configure the IPv6 address 10::3 for Host A.
C:\>ipv6 install
Installing...
Succeeded.
C:\>ipv6 adu 4/10::3
2.     Perform telnet operations to verify that IPv6 interface PBR on Switch A operates as configured to forward the matching TCP packets to the next hop 1::2 (Switch B), as follows:
# Verify that you can telnet to Switch B from Host A successfully. (Details not shown.)
# Verify that you cannot telnet to Switch C from Host A. (Details not shown.)
3.     Verify that Switch A forwards packets other than TCP packets through VLAN-interface 20. For example, verify that you can ping Switch C from Host A. (Details not shown.)
Example: Configuring packet type-based IPv6 global PBR
As shown in Figure 3, Switch E and Switch F do not have a route to reach each other.
Configure IPv6 global PBR on Switch D to forward TCP packets to the next hop 4::2 (Switch E).
Figure 3 Network diagram
1.     Configure IPv6 addresses for the interfaces. Make sure Switch A, B and C can communicate with Switch E and Switch F, respectively. (Details not shown.)
2.     Configure Switch D:
# Configure IPv6 ACL 3101 to match TCP packets sourced from networks 1::0/64, 2::0/64, and 3::0/64.
<SwitchD> system-view
[SwitchD] acl ipv6 advanced 3101
[SwitchD-acl-ipv6-adv-3101] rule permit tcp source 1::0 64
[SwitchD-acl-ipv4-adv-3101] rule permit tcp source 2::0 64
[SwitchD-acl-ipv4-adv-3101] rule permit tcp source 3::0 64
[SwitchD-acl-ipv4-adv-3101] quit
# Configure node 5 in IPv6 PBR policy aaa to forward TCP packets that match ACL 3101 to next hop 4::2.
[SwitchD] ipv6 policy-based-route aaa permit node 5
[SwitchD-pbr6-aaa-5] if-match acl 3101
[SwitchD-pbr6-aaa-5] apply next-hop 4::2
[SwitchD-pbr6-aaa-5] quit
# Specify IPv6 PBR policy aaa as the IPv6 global PBR policy.
[SwitchD] ipv6 global policy-based-route aaa
1.     Perform telnet operations to verify that IPv6 global PBR on Switch D operates as configured to forward the matching TCP packets to the next hop 4::2 (Switch E), as follows:
# Verify that you can telnet to Switch E from Switch A, Switch B, and Switch C successfully. (Details not shown.)
# Verify that you cannot telnet to Switch F from Switch A, Switch B, or Switch C. (Details not shown.)
2.     Verify that Switch D forwards packets other than TCP packets as long as a route is available. For example, verify that you can ping Switch F from Switch A, Switch B, and Switch C. (Details not shown.)
