06-IP Multicast Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S6520X-EI[HI][SI] & S6520-SI & S5560X-HI Switch Series Command References-R65xx-6W10406-IP Multicast Command Reference
01-IGMP snooping commands
01-IGMP snooping commands 457.49 KB
IGMP snooping commands· 1
display igmp-snooping· 1
display igmp-snooping group· 4
display igmp-snooping evpn-group· 7
display igmp-snooping host-tracking· 8
display igmp-snooping router-port 9
display igmp-snooping static-group· 11
display igmp-snooping static-router-port 12
display igmp-snooping statistics· 13
display l2-multicast fast-forwarding cache· 14
display l2-multicast ip· 16
display l2-multicast ip forwarding· 18
display l2-multicast mac· 19
display l2-multicast mac forwarding· 20
display mac-address [ multicast ] 21
dot1p-priority (IGMP-snooping view) 22
dscp· 23
enable (IGMP-snooping view) 23
entry-limit (IGMP-snooping view) 24
fast-leave (IGMP-snooping view) 25
global-enable (IGMP-snooping view) 26
group-policy (IGMP-snooping view) 26
host-aging-time (IGMP-snooping view) 27
host-tracking (IGMP-snooping view) 28
igmp-snooping· 29
igmp-snooping dot1p-priority· 30
igmp-snooping drop-unknown· 30
igmp-snooping { disable | enable } 31
igmp-snooping fast-leave· 32
igmp-snooping forwarding-mode· 33
igmp-snooping general-query source-ip· 34
igmp-snooping group-limit 35
igmp-snooping group-policy· 36
igmp-snooping host-aging-time· 37
igmp-snooping host-join· 38
igmp-snooping host-tracking· 39
igmp-snooping last-member-query-interval 40
igmp-snooping leave source-ip· 41
igmp-snooping max-response-time· 42
igmp-snooping overflow-replace· 43
igmp-snooping proxy enable· 44
igmp-snooping querier 45
igmp-snooping querier-election· 46
igmp-snooping query-interval 47
igmp-snooping report source-ip· 48
igmp-snooping router-aging-time· 49
igmp-snooping router-port-deny· 50
igmp-snooping source-deny· 50
igmp-snooping special-query source-ip· 51
igmp-snooping static-group· 52
igmp-snooping static-router-port 53
igmp-snooping version· 54
last-member-query-interval (IGMP-snooping view) 55
mac-address multicast 55
mac-address multicast vsi 56
max-response-time (IGMP-snooping view) 58
overflow-replace (IGMP-snooping view) 59
report-aggregation (IGMP-snooping view) 60
reset igmp-snooping group· 60
reset igmp-snooping router-port 61
reset igmp-snooping statistics· 61
reset l2-multicast fast-forwarding cache· 62
router-aging-time (IGMP-snooping view) 62
send-query enable· 63
source-deny (IGMP-snooping view) 64
version (IGMP-snooping view) 64
Use display igmp-snooping to display IGMP snooping status.
display igmp-snooping [ global | vlan vlan-id | vsi vsi-name ]
global: Displays the global IGMP snooping status.
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094.
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters.
If you do not specify any parameters, this command displays the global IGMP snooping status and the IGMP snooping status in all VLANs and VSIs.
# Display the global IGMP snooping status and the IGMP snooping status for all VLANs and VSIs.
<Sysname> display igmp-snooping
IGMP snooping information: Global
 Global-enable: Enabled
 Host-aging-time: 260s
 Router-aging-time: 260s
 Max-response-time: 10s
 Last-member-query-interval: 1s
 Report-aggregation: Enabled
 Host-tracking: Disabled
 Dot1p-priority: --
 DRNI: Enabled (IPP: Bridge-Aggregation 1)
IGMP snooping information: VLAN 1
 IGMP snooping: Enabled
 Drop-unknown: Disabled
 Version: 2
 Querier: Enabled (IP: 1.1.1.1, Expires: 00:02:05)
 Querier-election: Enabled
 Query-interval: 125s
 General-query source IP: 1.1.1.1
 Special-query source IP: 2.2.2.2
 Report source IP: 3.0.0.3
 Leave source IP: 1.0.0.1
 Dot1p-priority: 2
 Proxy: Disabled
IGMP snooping information: VLAN 10
 Drop-unknown: Enabled
 Version: 3
 Dot1p-priority: --
 Proxy: Disabled
IGMP snooping information: VSI aaa
 Version: 2
 Querier: Disabled
 Querier-election: Disabled
 Proxy: Disabled
 IPP: Bridge-Aggregation 1 (Link ID: 0x1001)
Global-enable
Global IGMP snooping status:
·     Enabled.
·     Disabled.
IGMP snooping
IGMP snooping status in a VLAN or VSI:
·     Enabled.
·     Disabled.
·     Globally enabled.
·     Inactive—IGMP snooping configuration does not take effect.
Drop-unknown
Status of dropping unknown multicast data:
·     Enabled.
·     Disabled.
Version
IGMP snooping version.
Host-aging-time
Aging timer for the dynamic member port.
Router-aging-time
Aging timer for the dynamic router port.
Max-response-time
Maximum response time for IGMP general queries.
Interval for sending IGMP group-specific queries.
Report-aggregation
Status of IGMP report suppression:
·     Enabled.
·     Disabled.
Dot1p-priority
802.1p priority for IGMP messages. If the priority is not configured, this field displays two hyphens (--).
Querier
Status of IGMP snooping querier:
·     Enabled.
·     Disabled.
IGMP snooping querier information:
·     IP—IP address of the IGMP snooping querier.
·     Expire—Remaining aging time for the IGMP snooping querier.
This field is not displayed if IGMP snooping querier election is disabled.
Querier-election
Status of IGMP snooping querier election:
·     Enabled.
·     Disabled.
Query-interval
Interval for sending IGMP general queries.
Source IP address of IGMP general queries.
Source IP address of IGMP group-specific queries.
Report source IP
Source IP address of IGMP reports.
Leave source IP
Source IP address of IGMP leave messages.
Host-tracking
Status of host tracking:
·     Enabled
·     Disabled.
·     Globally enabled.
Proxy
Status of IGMP snooping proxying:
·     Enabled.
·     Disabled.
DRNI
Status of DRNI:
·     Enabled.
·     Disabled
IPP
DRNI IPP interface.
Link ID
Link ID for the DRNI IPP interface in the VSI.
Use display igmp-snooping group to display information about dynamic IGMP snooping group entries.
display igmp-snooping group [ group-address | source-address ] * [ vlan vlan-id | vsi vsi-name ] [ interface interface-type interface-number | [ verbose ] [ slot slot-number  ] ]
group-address: Specifies a multicast group by its IP address in the range of 224.0.1.0 to 239.255.255.255. If you do not specify a multicast group, this command displays information about dynamic IGMP snooping group entries for all multicast groups.
source-address: Specifies a multicast source by its IP address. If you do not specify a multicast source, this command displays information about dynamic IGMP snooping group entries for all multicast sources.
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, this command displays information about dynamic IGMP snooping group entries for all VLANs.
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays information about dynamic IGMP snooping group entries for all VSIs.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays brief information about dynamic IGMP snooping group entries for all interfaces.
verbose: Displays detailed information about dynamic IGMP snooping group entries. If you do not specify this keyword, the command displays brief information about dynamic IGMP snooping group entries.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays information about dynamic IGMP snooping group entries for the master device.
# Display brief information about dynamic IGMP snooping group entries for Ten-GigabitEthernet 1/0/1.
<Sysname> display igmp-snooping group interface ten-gigabitethernet 1/0/1
Total 1 entries.
XGE1/0/1:
  VLAN 2: Total 1 entries.
   (0.0.0.0, 224.1.1.1)                    (00:03:23)
# Display detailed information about dynamic IGMP snooping group entries for VLAN 2.
<Sysname> display igmp-snooping group vlan 2 verbose
Total 2 entries.
VLAN 2: Total 2 entries.
    Attribute: local port
    FSM information: dummy
    Host slots (0 in total):
    Host ports (1 in total):
      XGE1/0/2                             (00:03:23)
  (1.1.1.1, 224.1.1.1)
      XGE1/0/2                             (00:04:04)
# Display brief information about dynamic IGMP snooping group entries for VSI aaa.
<Sysname> display igmp-snooping group vsi aaa
Total 2 entries.
VSI aaa: Total 2 entries.
    Host ports (3 in total):
      XGE1/0/3 (Link ID 0)                (00:03:35)
      NPW (Link ID 8)                    (00:02:35)
      UPW (Link ID 9)                    (00:01:35)
# Display detailed information about dynamic IGMP snooping group entries for VSI bbb.
<Sysname> display igmp-snooping group vsi bbb verbose
Total 2 entries.
VSI bbb: Total 2 entries.
    Attribute: global port
    Host ports (2 in total):
        VLAN pairs (1 in total):
          Outer VLAN 5     Inner VLAN 2           (00:03:35)
      Tun1 (VXLAN ID 0)                           (00:03:35)
Total 1 entries
Total number of dynamic IGMP snooping group entries.
Total number of dynamic IGMP snooping group entries in VLAN 2.
VSI aaa: Total 1 entries
Total number of dynamic IGMP snooping group entries in VSI aaa.
(S, G) entry, where 0.0.0.0 in the S position means all multicast sources.
Attribute
Entry attribute:
·     global port—The entry has a global port.
·     local port—The entry has a port that resides on the member device for which the information is displayed.
·     slot—The entry has ports that reside on other member devices except the member device for which the information is displayed.
FSM information
Finite state machine information of the entry:
·     delete—The entry attributes have been deleted.
·     dummy—The entry is a new temporary entry.
·     no info—No entry exists.
·     normal—The entry is a correct entry.
Member IDs and total number of the member devices that have member ports, except for the specified member device or the master device when no member device is specified.
Member ports, and the total number of member ports.
(00:03:23)
Remaining aging time for the dynamic member port.
Global ports include Layer 2 aggregate interfaces, ACs, N-PWs, and U-PWs.
For a global port, this field is displayed when no member device is specified or the master device is specified.
For a non-global port, this field is displayed when one of the following conditions exists:
·     The port is on the specified member device.
·     The port is on the master device and no member device is specified.
AC and its link ID.
NPW (Link ID 8)
N-PW and its link ID.
Tun1 (VXLAN ID 0)
VXLAN tunnel and its VXLAN ID.
VLAN pairs and total number of the VLAN pairs.
Outer VLAN ID and inner VLAN ID.
Use display igmp-snooping evpn-group to display multicast group information that IGMP snooping learns from EVPN.
display igmp-snooping evpn-group [ group-address | source-address ] * [ vsi vsi-name ] [ slot slot-number  ]
group-address: Specifies a multicast group by its IP address in the range of 224.0.1.0 to 239.255.255.255. If you do not specify a multicast group, this command displays information that IGMP snooping learns from EVPN for all multicast groups.
source-address: Specifies a multicast source by its IP address. If you do not specify a multicast source, this command displays multicast group information that IGMP snooping learns from EVPN for all multicast sources.
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays multicast group information that IGMP snooping learns from EVPN for all VSIs.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a card, this command displays multicast group information that IGMP snooping learns from EVPN on the master device.
# Display multicast group information that IGMP snooping learns from EVPN in VSI aaa.
<Sysname> display igmp-snooping evpn-group vsi aaa
Total 2 entries.
      Tun1 (VXLAN ID 1)
      Tun2 (VXLAN ID 1)
       Tun2 (VXLAN ID 1)
Total 1 entries
Total number of entries.
Total entries in VSI aaa.
Member port and the link ID.
Use display igmp-snooping host-tracking to display host tracking information.
display igmp-snooping host-tracking vlan vlan-id group group-address [ source source-address ] [ slot slot-number ]
group group-address: Specifies a multicast group by its IP address in the range of 224.0.1.0 to 239.255.255.255.
source source-address: Specifies a multicast source by its IP address. If you do not specify a multicast source, this command displays host tracking information for all multicast sources.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays host tracking information for the master device.
# Display tracking information for hosts that have joined multicast group 224.1.1.1 in VLAN 2.
<Sysname> display igmp-snooping host-tracking vlan 2 group 224.1.1.1
VLAN 2
    Port: XGE1/0/1
      Host                                    Uptime          Expires
      1.1.1.1                                 00:02:20        00:00:40
      2.2.2.2                                 00:02:21        00:00:39
VLAN
VLAN ID.
(S, G) entry, where 0.0.0.0 in the S position means any multicast sources.
Port
Member port.
Host
IP address of the host.
Uptime
Length of time elapsed since the host joined the multicast group.
Expires
Remaining timeout time for the host. The host timeout time is the same as the aging timer for the port. The timer is reset when the port receives an IGMP report from the host.
This field displays timeout if the host times out.
igmp-snooping enable
Use display igmp-snooping router-port to display dynamic router port information.
display igmp-snooping router-port [ vlan vlan-id | vsi vsi-name ] [ verbose ] [ slot slot-number ]
verbose: Displays detailed information. If you do not specify the keyword, this command displays brief information.
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, this command displays dynamic router port information for all VLANs.
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays dynamic router port information for all VSIs.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays dynamic router port information for the master device.
# Display brief information about dynamic router ports for VLAN 2.
<Sysname> display igmp-snooping router-port vlan 2
VLAN 2:
  Router ports (2 in total):
    XGE1/0/1                              (00:01:30)
    XGE1/0/2                              (00:00:23)
# Display detailed information about dynamic router ports for VLAN 2.
<Sysname> display igmp-snooping router-port vlan 2 verbose
VLAN 2:
  Router slots (0 in total):
    XGE1/0/1                             (00:01:30)
    XGE1/0/2                             (00:00:23)
# Display brief information about dynamic router ports for VSI aaa.
<Sysname> display igmp-snooping router-port vsi aaa
VSI aaa:
  Router ports (3 in total):
    XGE1/0/3 (Link ID 1)                           (00:03:35)
    NPW (Link ID 8)                               (00:03:35)
    UPW (Link ID 9)                               (00:03:35)
# Display detailed information about dynamic router ports for VSI bbb.
<Sysname> display igmp-snooping router-port vsi bbb verbose
VSI bbb:
Table 5 Command output
VLAN 2
VLAN ID.
VSI aaa
VSI name.
Member IDs and total number of the member devices that have dynamic router ports, except for the specified member device or the master device when no member device is specified.
Dynamic router ports and total number of dynamic router ports.
(00:01:30)
Remaining aging time for the dynamic router port.
For a global port, this field is always displayed.
AC and its link ID.
NPW (Link ID 8)
UPW (Link ID 9)
U-PW and its link ID.
Tun1 (VXLAN ID 0)
VLAN pairs and total number of VLAN pairs.
Use display igmp-snooping static-group to display information about static IGMP snooping group entries.
display igmp-snooping static-group [ group-address | source-address ] * [ vlan vlan-id ] [ verbose ] [ slot slot-number ]
group-address: Specifies a multicast group by its IP address in the range of 224.0.1.0 to 239.255.255.255. If you do not specify a multicast group, this command displays information about static IGMP snooping group entries for all multicast groups.
source-address: Specifies a multicast source by its IP address. If you do not specify a multicast source, this command displays information about static IGMP snooping group entries for all multicast sources.
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, this command displays information about static IGMP snooping group entries for all VLANs.
verbose: Displays detailed information about static IGMP snooping group entries. If you do not specify the keyword, this command displays brief information about static IGMP snooping group entries.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays information about static IGMP snooping group entries for the master device.
# Display detailed information about static IGMP snooping group entries for VLAN 2.
<Sysname> display igmp-snooping static-group vlan 2 verbose
Total 1 entries.
      XGE1/0/2
Table 6 Command output
Total 1 entries
Total number of static IGMP snooping group entries.
Total number of static IGMP snooping group entries in VLAN 2.
Attribute
Entry attribute:
FSM information
Member ports and total number of member ports.
Use display igmp-snooping static-router-port to display static router port information.
display igmp-snooping static-router-port [ vlan vlan-id ] [ verbose ] [ slot slot-number ]
verbose: Displays detailed information about static router ports. If you do not specify this keyword, the command displays brief information about static router ports.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays static router port information for the master device.
# Display brief information about static router ports for VLAN 2.
<Sysname> display igmp-snooping static-router-port vlan 2
VLAN 2:
    XGE1/0/1
    XGE1/0/2
# Display detailed information about static router ports for VLAN 2.
<Sysname> display igmp-snooping static-router-port vlan 2 verbose
VLAN 2:
    XGE1/0/1
    XGE1/0/2
Table 7 Command output
VLAN 2
VLAN ID.
Member IDs and total number of the member devices that have static router ports, except for the specified member device or the master device when no member device is specified.
Static router ports and total number of static router ports.
Use display igmp-snooping statistics to display statistics for the IGMP messages and PIMv2 hello messages learned through IGMP snooping.
# Display statistics for the IGMP messages and PIMv2 hello messages learned through IGMP snooping.
<Sysname> display igmp-snooping statistics
Received IGMP messages:
  IGMP general queries: 19
    DRNI: 19
  IGMPv2 specific queries: 10
    DRNI: 0
  IGMPv3 specific queries: 0
    DRNI: 0
  IGMPv3 specific sg queries: 0
    DRNI: 0
  IGMPv1 reports: 0
    DRNI: 0
  IGMPv2 reports: 19
    DRNI: 19
  IGMPv3 reports: 0
    DRNI: 0
  IGMPv3 reports with right and wrong records: 0
    DRNI: 0
  IGMP leaves: 5
    DRNI: 5
  Error IGMP messages: 1
    DRNI: 1
Sent IGMP messages:
  IGMPv2 specific queries: 0
Received PIMv2 hello : 0
Table 8 Command output
general queries
Number of IGMP general queries.
specific queries
Number of IGMP group-specific queries.
reports
Number of IGMP reports.
leaves
Number of IGMP leave messages.
Number of IGMP reports with correct and incorrect records.
specific sg queries
Number of IGMP group-and-source-specific queries.
error IGMP messages
Number of IGMP messages with errors.
DRNI
IGMP messages received on the DRNI IPP.
Use display l2-multicast fast-forwarding cache to display Layer 2 multicast fast forwarding entries.
display l2-multicast fast-forwarding cache [ vlan vlan-id ] [ source-address | group-address ] * [ slot slot-number ]
source-address: Specifies a multicast source address. If you do not specify a multicast source, this command displays Layer 2 multicast fast forwarding entries for all multicast sources.
group-address: Specifies a multicast group address in the range of 224.0.1.0 to 239.255.255.255. If you do not specify a multicast group, this command displays Layer 2 multicast fast forwarding entries for all multicast groups.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays Layer 2 multicast fast forwarding entries for the master device.
# Display Layer 2 multicast fast forwarding entries.
<Sysname> display l2-multicast fast-forwarding cache
Total 1 entries, 1 matched
(10.1.1.2,225.1.1.1)
     Status      : Enable                VLAN            : 1
     Source port : 9876                  Destination port: 5432
     Protocol    : 17                    Flag            : 0x2
     Ingress port: Ten-GigabitEthernet1/0/2
     List of 1 egress ports:
         Ten-GigabitEthernet1/0/3
         Status: Enable                Flag: 0x10
Table 9 Command output
Total number of (S, G) entries in the Layer 2 multicast fast forwarding table, and the total number of matching entries.
(10.1.1.2, 225.1.1.1)
(S, G) entry in the Layer 2 multicast fast forwarding table.
Protocol
Protocol number.
VLAN
VLAN ID.
Flag
Flag for the (S, G) entry or the outgoing port.
This field displays one flag or the sum of multiple flags. In this example, the value 0x2 means that the entry has only one flag 0x2.
The following flags are available for an entry:
·     0x1—The entry is created because of packets passed through between cards.
·     0x2—The entry is added by multicast forwarding.
The following flags are available for an outgoing interface:
·     0x1—The port is added to the entry because of packets passed through between cards.
·     0x2—The port is added to an existing entry.
·     0x10—The port is associated with the entry.
·     0x20—The port is to be deleted.
Status
Status of the (S, G) entry or the outgoing port:
·     Enabled—Available.
·     Disabled—Unavailable.
Ingress port
Incoming port of the (S, G) entry.
Outgoing port list of the (S, G) entry.
reset l2-multicast fast-forwarding cache all
Use display l2-multicast ip to display information about Layer 2 IP multicast groups.
display l2-multicast ip [ group group-address | source source-address ] * [ vlan vlan-id | vsi vsi-name ] [ slot slot-number ]
group group-address: Specifies a multicast group by its IP address. If you do not specify a multicast group, this command displays information about all Layer 2 IP multicast groups.
source source-address: Specifies a multicast source by its IP address. If you do not specify a multicast source, this command displays information about Layer 2 IP multicast groups for all multicast sources.
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, this command displays information about Layer 2 IP multicast groups for all VLANs.
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays information about Layer 2 IP multicast groups for all VSIs.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays information about Layer 2 IP multicast groups for the master device.
# Display information about Layer 2 IP multicast groups for VLAN 2.
<Sysname> display l2-multicast ip vlan 2
Total 1 entries.
    Attribute: static, success
      XGE1/0/1                              (S, SUC)
# Display information about Layer 2 IP multicast groups for VSI aaa.
<Sysname> display l2-multicast ip vsi aaa
Total 1 entries.
VSI aaa: Total 1 entries.
    Attribute: dynamic, success
      XGE1/0/1 (Link ID 1)                 (D, SUC)
      NPW (Link ID 8)                     (D, SUC)
      UPW (Link ID 9)                     (D, SUC)
Table 10 Command output
Total 1 entries
Total number of Layer 2 IP multicast groups.
Total number of Layer 2 IP multicast groups in VLAN 2.
Total number of Layer 2 IP multicast groups in VSI aaa.
Attribute
Entry attribute:
·     dynamic—The entry is created by a dynamic protocol.
·     static—The entry is created by a static protocol.
·     pim—The entry is created by PIM.
·     kernel—The entry is obtained from the kernel.
·     success—Processing has succeeded.
·     fail—Processing has failed.
(S, SUC)
Port attribute:
·     D—Dynamic port.
·     S—Static port.
·     P—PIM port.
·     K—Port obtained from the kernel.
·     R—Port learned from (*, *) entries.
·     W—Port learned from (*, G) entries.
·     SUC—Processing has succeeded.
·     F—Processing has failed.
AC and its link ID.
NPW (Link ID 8)
UPW (Link ID 9)
Tun1 (VXLAN ID 0)
Use display l2-multicast ip forwarding to display Layer 2 multicast IP forwarding entries.
display l2-multicast ip forwarding [ group group-address | source source-address ] * [ vlan vlan-id ] [ slot slot-number ]
group group-address: Specifies a multicast group by its IP address. If you do not specify a multicast group, this command displays Layer 2 multicast IP forwarding entries for all multicast groups.
source source-address: Specifies a multicast source by its IP address. If you do not specify a multicast source, this command displays Layer 2 multicast IP forwarding entries for all multicast sources.
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, this command displays Layer 2 multicast IP forwarding entries for all VLANs.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays Layer 2 multicast IP forwarding entries for the master device.
# Display Layer 2 multicast IP forwarding entries for VLAN 2.
<Sysname> display l2-multicast ip forwarding vlan 2
Total 1 entries.
      GigabitEthernet1/0/1
Table 11 Command output
Total 1 entries
Total number of Layer 2 multicast IP forwarding entries.
Total number of Layer 2 multicast IP forwarding entries in VLAN 2.
NPW (Link ID 8)
UPW (Link ID 9)
Use display l2-multicast mac to display information about Layer 2 MAC multicast groups.
display l2-multicast mac [ mac-address ] [ vlan vlan-id | vsi vsi-name ] [ slot slot-number ]
mac-address: Specifies a MAC multicast group by its multicast MAC address. If you do not specify a MAC multicast group, this command displays information about all Layer 2 MAC multicast groups.
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, this command displays information about Layer 2 MAC multicast groups for all VLANs.
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays information about Layer 2 MAC multicast groups for all VSIs.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays information about Layer 2 MAC multicast groups for the master device.
# Display information about Layer 2 MAC multicast groups for VLAN 2.
<Sysname> display l2-multicast mac vlan 2
Total 1 entries.
  MAC group address: 0100-5e01-0101
    Attribute: success
      XGE1/0/1
# Display information about Layer 2 MAC multicast groups for VSI aaa.
<Sysname> display l2-multicast mac vsi aaa
Total 1 entries.
    Attribute: success
      NPW (Link ID 8)
      UPW (Link ID 9)
# Display information about Layer 2 MAC multicast groups for VSI bbb.
<Sysname> display l2-multicast mac vsi bbb
Total 1 entries.
VSI bbb: Total 1 entries.
    Attribute: success
      Tun1 (VXLAN ID 0)
Table 12 Command output
Total 1 entries
Total number of Layer 2 MAC multicast groups.
Total number of Layer 2 MAC multicast groups in VLAN 2.
Total number of Layer 2 MAC multicast groups in VSI aaa.
MAC group address
Address of the MAC multicast group.
Attribute
Entry attribute:
AC and its link ID.
NPW (Link ID 8)
UPW (Link ID 9)
Tun1 (VXLAN ID 0)
Use display l2-multicast mac forwarding to display Layer 2 multicast MAC forwarding entries.
display l2-multicast mac forwarding [ mac-address ] [ vlan vlan-id ] [ slot slot-number ]
mac-address: Specifies a MAC multicast group by its MAC address. If you do not specify a MAC multicast group, this command displays Layer 2 multicast MAC forwarding entries for all MAC multicast groups.
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, this command displays Layer 2 multicast MAC forwarding entries for all VLANs.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays Layer 2 multicast MAC group entries for the master device.
# Display Layer 2 multicast MAC forwarding entries for VLAN 2.
<Sysname> display l2-multicast mac forwarding vlan 2
Total 1 entries.
      Ten-GigabitEthernet1/0/1
Table 13 Command output
Total 1 entries
Total number of Layer 2 multicast MAC forwarding entries.
Total number of Layer 2 multicast MAC forwarding entries in VLAN 2.
Total number of Layer 2 multicast MAC multicast group entries in VSI aaa.
MAC group address
NPW (Link ID 8)
UPW (Link ID 9)
Use display mac-address [ multicast ] to display static multicast MAC address entries.
mac-address: Specifies a multicast MAC address. The MAC address can be any legal multicast MAC address except 0100-5Exx-xxxx and 3333-xxxx-xxxx, where "x" represents a hexadecimal number in the range of 0 to F.
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, this command displays MAC address entries for all VLANs.
multicast: Specifies static multicast MAC address entries.
count: Specifies the number of MAC address entries. If you specify this keyword, the command displays the number of matching MAC address entries. If you do not specify this keyword, the command displays the contents of the matching entries rather than the entry count.
If you do not specify any parameters, this command displays all MAC address table entries, including unicast MAC address entries and static multicast MAC address entries.
# Display static multicast MAC address entries for VLAN 2.
<Sysname> display mac-address multicast vlan 2
MAC Address      VLAN ID    State            Port/NickName            Aging
0100-0001-0001   2          Multicast        XGE1/0/1                 N
# Display the number of static multicast MAC address entries.
<Sysname> display mac-address multicast count
1 mac address(es) found.
Table 14 Command output
MAC address
MAC address of a multicast group.
VLAN ID
ID of the VLAN to which the network device identified by the MAC address belongs.
Status of the MAC address. If the multicast MAC address entry is static, this field displays Multicast.
Port/NickName
Outgoing ports or nickname of the Egress RB in a TRILL network for the packet that is sent to the MAC address in this MAC address entry. TRILL is not supported in the current software version.
Aging
Aging timer state. If this entry never expires, this field displays N.
One static multicast MAC address entry is found.
Use dot1p-priority to set the 802.1p priority for IGMP messages globally.
Use undo dot1p-priority to restore the default.
dot1p-priority priority
undo dot1p-priority
The global 802.1p priority is 6 for IGMP messages.
IGMP-snooping view
priority: Specifies an 802.1p priority for IGMP messages, in the range of 0 to 7. The greater the value, the higher the priority.
You can set the 802.1p priority globally for all VLANs and VSIs in IGMP-snooping view or for a VLAN in VLAN view. For a VLAN, the VLAN-specific configuration takes priority over the global configuration.
# Set the 802.1p priority for IGMP messages to 3 globally.
[Sysname] igmp-snooping
[Sysname-igmp-snooping] dot1p-priority 3
dscp
Use dscp to set the DSCP value for outgoing IGMP protocol packets.
Use undo dscp to restore the default.
dscp dscp-value
undo dscp
The DSCP value is 48 for outgoing IGMP protocol packets.
IGMP-snooping view
dscp-value: Specifies a DSCP value in the range of 0 to 63.
The DSCP value is carried in the ToS field of an IP packet to determine the transmission priority of the packet. A greater DSCP value represents a higher priority.
# Set the DSCP value to 63 for outgoing IGMP protocol packets.
[Sysname-igmp-snooping] dscp 63
Use enable to enable IGMP snooping for VLANs.
Use undo enable to disable IGMP snooping for VLANs.
enable vlan vlan-list
undo enable vlan vlan-list
IGMP snooping status in a VLAN is consistent with the global IGMP snooping status.
IGMP-snooping view
vlan vlan-list: Specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN by its ID or a range of VLANs in the form of start-vlan-id to end-vlan-id. The VLAN ID is in the range of 1 to 4094.
You must enable the IGMP snooping feature by using the igmp-snooping command before you enable IGMP snooping for VLANs.
You can enable IGMP snooping for multiple VLANs by using this command in IGMP-snooping view or for a VLAN by using the igmp-snooping enable command in VLAN view. The configuration in IGMP-snooping view has the same priority as the configuration in VLAN view, and the most recent configuration takes effect.
# Enable the IGMP snooping feature, and then enable IGMP snooping for VLAN 2 through VLAN 10.
[Sysname-igmp-snooping] enable vlan 2 to 10
igmp-snooping
Use entry-limit to globally set the maximum number of IGMP snooping forwarding entries, including dynamic entries and static entries.
Use undo entry-limit to restore the default.
entry-limit limit
undo entry-limit
The maximum number of IGMP snooping forwarding entries is 4294967295.
IGMP-snooping view
limit: Specifies the maximum number of IGMP snooping forwarding entries, in the range of 0 to 4294967295.
# Set the global maximum number of IGMP snooping forwarding entries to 512.
[Sysname-igmp-snooping] entry-limit 512
Use fast-leave to enable fast-leave processing globally.
Use undo fast-leave to disable fast-leave processing globally.
fast-leave [ vlan vlan-list ]
undo fast-leave [ vlan vlan-list ]
Fast-leave processing is disabled.
IGMP-snooping view
vlan vlan-list: Specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN by its ID or a range of VLANs in the form of start-vlan-id to end-vlan-id. The VLAN ID is in the range of 1 to 4094. If you do not specify a VLAN, this command takes effect on all VLANs and VSIs.
The fast-leave processing feature enables the device to immediately remove a port from the forwarding entry for a multicast group when the port receives a leave message.
You can enable fast-leave processing globally for all ports in IGMP-snooping view or for a port in interface view. For a port, the port-specific configuration takes priority over the global configuration.
# Globally enable fast-leave processing for VLAN 2.
[Sysname-igmp-snooping] fast-leave vlan 2
Use global-enable to enable IGMP snooping globally.
Use undo global-enable to disable IGMP snooping globally.
global-enable
undo global-enable
IGMP snooping is disabled globally.
IGMP-snooping view
To configure other IGMP snooping features for VLANs or VSIs, you must enable IGMP snooping for the specific VLANs or VSIs even though IGMP snooping is enabled globally.
# Enable IGMP snooping globally.
[Sysname-igmp-snooping] global-enable
igmp-snooping
igmp-snooping disable
Use group-policy to globally configure a multicast group policy to control the multicast groups that hosts can join.
Use undo group-policy to globally delete multicast group policies.
group-policy ipv4-acl-number [ vlan vlan-list ]
undo group-policy [ vlan vlan-list ]
No multicast group policies exist. Hosts can join any multicast groups.
IGMP-snooping view
ipv4-acl-number: Specifies an IPv4 basic or advanced ACL by its number in the range of 2000 to 3999. Hosts can join only the multicast groups that the ACL permits. If the ACL does not exist or does not have valid rules, hosts cannot join multicast groups.
A multicast group policy filters IGMP reports to control the multicast groups that hosts can join.
This command does not take effect on static member ports, because static member ports do not send IGMP reports.
You can configure a multicast group policy globally for all ports in IGMP-snooping view or for a port in interface view. For a port, the port-specific configuration takes priority over the global configuration.
When you configure a rule in the IPv4 ACL, follow these restrictions and guidelines:
·     In a basic ACL, the source source-address source-wildcard option specifies a multicast group address.
·     In an advanced ACL, the source source-address source-wildcard option specifies a multicast source address. The destination dest-address dest-wildcard option specifies a multicast group address.
To match the following IGMP reports, set the source source-address source-wildcard option to 0.0.0.0:
¡     IGMPv1 and IGMPv2 reports.
¡     IGMPv3 IS_EX and IGMPv3 TO_EX reports that do not carry multicast source addresses.
·     Among the other optional parameters, only the fragment keyword and the time-range time-range-name option take effect.
You can configure different ACLs for all ports in different VLANs. If you configure multiple ACLs for all ports in the same VLAN, the most recent configuration takes effect.
# Configure a multicast group policy for VLAN 2 so that hosts in VLAN 2 can join only multicast group 225.1.1.1.
[Sysname] acl basic 2000
[Sysname-acl-ipv4-basic-2000] rule permit source 225.1.1.1 0
[Sysname-igmp-snooping] group-policy 2000 vlan 2
Use host-aging-time to set the aging timer for dynamic member ports globally.
Use undo host-aging-time to restore the default.
host-aging-time seconds
The aging timer for dynamic member ports is 260 seconds.
IGMP-snooping view
seconds: Specifies an aging timer for dynamic member ports, in the range of 1 to 8097894 seconds.
You can set the timer globally for all VLANs and VSIs in IGMP-snooping view, for a VSI in VSI view, or for a VLAN in VLAN view. For a VSI, the VSI-specific configuration takes priority over the global configuration. For a VLAN, the VLAN-specific configuration takes priority over the global configuration.
To avoid mistakenly deleting multicast group members, set the aging timer for dynamic member ports to be greater than the value calculated by using the following formula:
[ IGMP general query interval ] + [ maximum response time for IGMP general queries ]
As a best practice, set the aging timer of dynamic member ports to the value calculated by using the following formula:
[ IGMP general query interval ] × 2 + [ maximum response time for IGMP general queries ]
# Set the global aging timer for dynamic member ports to 300 seconds.
[Sysname-igmp-snooping] host-aging-time 300
Use host-tracking to enable host tracking globally.
Use undo host-tracking to disable host tracking globally.
host-tracking
undo host-tracking
Host tracking is disabled.
IGMP-snooping view
You can enable host tracking globally for all VLANs in IGMP-snooping view or for a VLAN in VLAN view. For a VLAN, the global configuration has the same priority as the VLAN-specific configuration.
# Enable host tracking globally.
[Sysname-igmp-snooping] host-tracking
igmp-snooping
Use igmp-snooping to enable the IGMP snooping feature and enter IGMP-snooping view.
Use undo igmp-snooping to disable the IGMP snooping feature.
igmp-snooping
undo igmp-snooping
The IGMP snooping feature is disabled.
If you disable the IGMP snooping feature, IGMP snooping is disabled in all VLANs and VSIs.
# Enable the IGMP snooping feature and enter IGMP-snooping view.
Use igmp-snooping dot1p-priority to set the 802.1p priority for IGMP messages in a VLAN.
Use undo igmp-snooping dot1p-priority to restore the default.
igmp-snooping dot1p-priority priority
The 802.1p priority is 6 for IGMP messages in a VLAN.
VLAN view
You must enable IGMP snooping for a VLAN before you execute this command.
You can set the 802.1p priority for a VLAN in VLAN view or globally for all VLANs in IGMP-snooping view. The VLAN-specific configuration takes priority over the global configuration.
# In VLAN 2, enable IGMP snooping, and set the 802.1p priority for IGMP messages to 3.
[Sysname-igmp-snooping] quit
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping enable
[Sysname-vlan2] igmp-snooping dot1p-priority 3
Use igmp-snooping drop-unknown to enable dropping unknown multicast data packets for a VLAN or VSI.
Use undo igmp-snooping drop-unknown to disable dropping unknown multicast data packets for a VLAN or VSI.
Dropping unknown multicast data packets is disabled. Unknown multicast data packets are flooded.
VLAN view
VSI view
You must enable IGMP snooping for a VLAN or VSI before you execute this command.
# In VLAN 2, enable IGMP snooping, and enable dropping unknown multicast data packets.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping drop-unknown
# In VSI aaa, enable IGMP snooping, and enable dropping unknown multicast data packets.
[Sysname] vsi aaa
[Sysname-vsi-aaa] igmp-snooping enable
[Sysname-vsi-aaa] igmp-snooping drop-unknown
Use igmp-snooping enable to enable IGMP snooping for a VLAN or VSI.
Use igmp-snooping disable to disable IGMP snooping for a VLAN or VSI.
Use undo igmp-snooping to restore the IGMP snooping status in a VLAN or VSI to the global IGMP snooping status.
undo igmp-snooping
The IGMP snooping status in a VLAN or VSI is consistent with the global IGMP snooping status.
VLAN view
VSI view
You must enable the IGMP snooping feature by using the igmp-snooping command before you enable IGMP snooping for a VLAN or VSI.
You can enable IGMP snooping for a VLAN by using this command in VLAN view or for multiple VLANs by using the enable command in IGMP-snooping view. The configuration in VLAN view has the same priority as the configuration in IGMP-snooping view, and the most recent configuration takes effect.
# Enable the IGMP snooping feature, and then enable IGMP snooping for VLAN 2.
[Sysname] vlan 2
# Disable IGMP snooping for VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping disable
# Enable the IGMP snooping feature, and then enable IGMP snooping for VSI aaa.
[Sysname] vsi aaa
# Disable IGMP snooping for VSI aaa.
[Sysname] vsi aaa
[Sysname-vsi-aaa] igmp-snooping disable
igmp-snooping
Use igmp-snooping fast-leave to enable fast-leave processing on a port.
Use undo igmp-snooping fast-leave to disable fast-leave processing on a port.
igmp-snooping fast-leave [ vlan vlan-list ]
undo igmp-snooping fast-leave [ vlan vlan-list ]
Fast-leave processing is disabled on a port.
vlan vlan-list: Specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN by its ID or a range of VLANs in the form of start-vlan-id to end-vlan-id. The VLAN ID is in the range of 1 to 4094. If you do not specify a VLAN, this command takes effect on all VLANs.
You can enable fast-leave processing for a port in interface view or globally for all ports in IGMP-snooping view. For a port, the port-specific configuration takes priority over the global configuration.
# Enable fast-leave processing for VLAN 2 on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] igmp-snooping fast-leave vlan 2
Use igmp-snooping forwarding-mode to specify the Layer 2 multicast forwarding mode.
Use undo igmp-snooping forwarding-mode to restore the default.
igmp-snooping forwarding-mode { ip | mac }
The device forwards Layer 2 multicast packets based on the multicast MAC addresses in the packets.
VLAN view
ip: Specifies IP-based forwarding mode. The device forwards Layer 2 multicast packets based on the IP addresses (multicast source addresses and multicast group addresses) in the packets.
mac: Specifies MAC-based forwarding mode. The device forwards Layer 2 multicast packets based on the multicast MAC addresses in the packets.
Before you execute this command for a VLAN, you must enable IGMP snooping in it.
Multiple multicast IP addresses might be mapped to the same multicast MAC address. This causes that non-members of a multicast group receive the multicast data of this group if the device uses the MAC-based forwarding mode. As a best practice, specify the IP-based Layer 2 multicast forwarding mode on Layer 3 multicast devices.
# In VLAN 2, enable IGMP snooping, and then specify the MAC-based Layer 2 multicast forwarding mode.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping forwarding-mode mac
# In VSI aaa, enable IGMP snooping, and then specify the MAC-based Layer 2 multicast forwarding mode.
[Sysname] vsi aaa
[Sysname-vsi-aaa] igmp-snooping forwarding-mode mac
Use igmp-snooping general-query source-ip to configure the source IP address for IGMP general queries.
Use undo igmp-snooping general-query source-ip to restore the default.
igmp-snooping general-query source-ip ip-address
In a VLAN, the source IP address of IGMP general queries is the IP address of the current VLAN interface. If the current VLAN interface does not have an IP address, the source IP address is 0.0.0.0.
In a VSI, the source IP address of IGMP general queries is the IP address of the gateway interface for the VSI. If the gateway interface does not have an interface, the source IP address is 0.0.0.0.
VLAN view
VSI view
ip-address: Specifies the source IP address for IGMP general queries.
# In VLAN 2, enable IGMP snooping, and specify 10.1.1.1 as the source IP address of IGMP general queries.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping general-query source-ip 10.1.1.1
# In VSI aaa, enable IGMP snooping, and specify 10.1.1.1 as the source IP address of IGMP general queries.
[Sysname] vsi aaa
[Sysname-vsi-aaa] igmp-snooping general-query source-ip 10.1.1.1
Use igmp-snooping group-limit to set the maximum number of multicast groups that a port can join.
Use undo igmp-snooping group-limit to remove the limit on the maximum number of multicast groups that a port can join.
igmp-snooping group-limit limit [ vlan vlan-list ]
undo igmp-snooping group-limit [ vlan vlan-list ]
No limit is placed on the maximum number of multicast groups that a port can join.
limit: Specifies the maximum number of multicast groups that a port can join, in the range of 0 to 4294967295.
This command takes effect only on the multicast groups that a port joins dynamically.
# On Ten-GigabitEthernet 1/0/1, set the maximum number of multicast groups the port can join in VLAN 2 to 10.
[Sysname-Ten-GigabitEthernet1/0/1] igmp-snooping group-limit 10 vlan 2
Use igmp-snooping group-policy to configure a multicast group policy on a port to control the multicast groups that hosts attached to the port can join.
Use undo igmp-snooping group-policy to delete multicast group policies on a port.
igmp-snooping group-policy ipv4-acl-number [ vlan vlan-list ]
undo igmp-snooping group-policy [ vlan vlan-list ]
No multicast group polices exist on a port. Hosts attached to the port can join any multicast groups.
You can configure a multicast group policy for a port in interface view or globally for all ports in IGMP-snooping view. For a port, the port-specific configuration takes priority over the global configuration.
You can configure different ACLs on a port for different VLANs. If you configure multiple ACLs on a port for the same VLAN, the most recent configuration takes effect.
# On Ten-GigabitEthernet 1/0/1, configure a multicast group policy for VLAN 2 so that hosts in VLAN 2 can join only multicast group 225.1.1.1.
[Sysname-Ten-GigabitEthernet1/0/1] igmp-snooping group-policy 2000 vlan 2
Use igmp-snooping host-aging-time to set the aging timer for dynamic member ports in a VLAN or VSI.
Use undo igmp-snooping host-aging-time to restore the default.
igmp-snooping host-aging-time seconds
VLAN view
VSI view
You can set the timer for a VLAN in VLAN view, for a VSI in VSI view, or globally for all VLANs and VSIs in IGMP-snooping view. For a VLAN, the VLAN-specific configuration takes priority over the global configuration. For a VSI, the VSI-specific configuration takes priority over the global configuration.
# In VLAN 2, enable IGMP snooping, and set the aging timer for dynamic member ports to 300 seconds.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping host-aging-time 300
# In VSI aaa, enable IGMP snooping, and set the aging timer for dynamic member ports to 300 seconds.
[Sysname] vsi aaa
[Sysname-vsi-aaa] igmp-snooping host-aging-time 300
Use igmp-snooping host-join to configure a port as a simulated member host for a multicast group.
Use undo igmp-snooping host-join to remove the configuration of a simulated member host for a multicast group.
igmp-snooping host-join group-address [ source-ip source-address ] vlan vlan-id
undo igmp-snooping host-join { group-address [ source-ip source-address ] vlan vlan-id | all }
A port is not configured as a simulated member host for multicast groups.
group-address: Specifies a multicast group in the range of 224.0.1.0 to 239.255.255.255.
source-ip source-address: Specifies a multicast source by its IP address. If you specify a multicast source, this command configures the port as a simulated member host for a multicast source and group. If you do not specify a multicast source, this command configures the port as a simulated member host for a multicast group. This option takes effect on IGMPv3 snooping devices.
all: Specifies all multicast groups.
The version of IGMP running on a simulated member host is the same as the version of IGMP snooping running on the port. The port ages out in the same way as a dynamic member port.
# Configure Ten-GigabitEthernet 1/0/1 as a simulated member host of the multicast source and group (1.1.1.1, 232.1.1.1) in VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping version 3
[Sysname-vlan2] quit
[Sysname-Ten-GigabitEthernet1/0/1] igmp-snooping host-join 232.1.1.1 source-ip 1.1.1.1 vlan 2
Use igmp-snooping host-tracking to enable host tracking for a VLAN.
Use undo igmp-snooping host-tracking to disable host tracking for a VLAN.
VLAN view
You must enable IGMP snooping for a VLAN before you execute this command for the VLAN.
You can enable host tracking for a VLAN in VLAN view or globally for all VLANs in IGMP-snooping view. For a VLAN, the VLAN-specific configuration has the same priority as the global configuration.
# In VLAN 2, enable IGMP snooping, and then enable host tracking.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping host-tracking
Use igmp-snooping last-member-query-interval to set the IGMP last member query interval for a VLAN or VSI.
Use undo igmp-snooping last-member-query-interval to restore the default.
igmp-snooping last-member-query-interval interval
The IGMP last member query interval is 1 second.
VLAN view
VSI view
interval: Specifies an IGMP last member query interval in the range of 1 to 25 seconds.
You can set the interval for a VLAN in VLAN view, for a VSI in VSI view, or globally for all VLANs and VSIs in IGMP-snooping view. For a VLAN, the VLAN-specific configuration takes priority over the global configuration. For a VSI, the VSI-specific configuration takes priority over the global configuration.
# In VLAN 2, enable IGMP snooping, and set the IGMP last member query interval to 3 seconds.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping last-member-query-interval 3
# In VSI aaa, enable IGMP snooping, and set the IGMP last member query interval to 3 seconds.
[Sysname] vsi aaa
[Sysname-vsi-aaa] igmp-snooping last-member-query-interval 3
Use igmp-snooping leave source-ip to configure the source IP address for IGMP leave messages.
Use undo igmp-snooping leave source-ip to restore the default.
igmp-snooping leave source-ip ip-address
In a VLAN, the source IP address of IGMP leave messages is the IP address of the current VLAN interface. If the current VLAN interface does not have an IP address, the source IP address is 0.0.0.0.
In a VSI, the source IP address of IGMP leave messages is the IP address of the gateway interface for the VSI. If the gateway interface does not have an IP address, the source IP address is 0.0.0.0.
VLAN view
VSI view
ip-address: Specifies the source IP address for IGMP leave messages.
# In VLAN 2, enable IGMP snooping, and specify 10.1.1.1 as the source IP address of IGMP leave messages.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping leave source-ip 10.1.1.1
# In VSI aaa, enable IGMP snooping, and specify 10.1.1.1 as the source IP address of IGMP leave messages.
[Sysname] vsi aaa
[Sysname-vsi-aaa] igmp-snooping leave source-ip 10.1.1.1
Use igmp-snooping max-response-time to set the maximum response time for IGMP general queries in a VLAN or VSI.
Use undo igmp-snooping max-response-time to restore the default.
igmp-snooping max-response-time seconds
The maximum response time for IGMP general queries is 10 seconds.
VLAN view
VSI view
seconds: Specifies the maximum response time for IGMP general queries, in the range of 1 to 3174 seconds.
You can set the time for a VLAN in VLAN view, for a VSI in VSI view, or globally for all VLANs and VSIs in IGMP-snooping view. For a VLAN, the VLAN-specific configuration takes priority over the global configuration. For a VSI, the VSI-specific configuration takes priority over the global configuration.
To avoid mistakenly deleting multicast group members, set the maximum response time for IGMP general queries to be less than the IGMP general query interval.
# In VLAN 2, enable IGMP snooping, and set the maximum response time for IGMP general queries to 5 seconds.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping max-response-time 5
# In VSI aaa, enable IGMP snooping, and set the maximum response time for IGMP general queries to 5 seconds.
[Sysname] vsi aaa
[Sysname-vsi-aaa] igmp-snooping max-response-time 5
Use igmp-snooping overflow-replace to enable multicast group replacement on a port.
Use undo igmp-snooping overflow-replace to disable multicast group replacement on a port.
igmp-snooping overflow-replace [ vlan vlan-list ]
undo igmp-snooping overflow-replace [ vlan vlan-list ]
Multicast group replacement is disabled.
You can enable multicast group replacement for a port in interface view or globally for all ports in IGMP-snooping view. For a port, the port-specific configuration takes priority over the global configuration.
# On Ten-GigabitEthernet 1/0/1, enable multicast group replacement for VLAN 2.
[Sysname-Ten-GigabitEthernet1/0/1] igmp-snooping overflow-replace vlan 2
Use igmp-snooping proxy enable to enable IGMP snooping proxying for a VLAN or VSI.
Use undo igmp-snooping proxy enable to disable IGMP snooping proxying for a VLAN or VSI.
IGMP snooping proxying is disabled.
VLAN view
VSI view
This command does not take effect on a VLAN that is a sub-VLAN of a multicast VLAN.
# In VLAN 2, enable IGMP snooping, and enable IGMP snooping proxying.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping proxy enable
# In VSI aaa, enable IGMP snooping, and enable IGMP snooping proxying.
[Sysname] vsi aaa
[Sysname-vsi-aaa] igmp-snooping proxy enable
subvlan (multicast-VLAN view)
Use igmp-snooping querier to enable the IGMP snooping querier.
Use undo igmp-snooping querier to disable the IGMP snooping querier.
The IGMP snooping querier is disabled.
VLAN view
VSI view
For a sub-VLAN of a multicast VLAN, this command takes effect only after you remove the sub-VLAN from the multicast VLAN.
# In VLAN 2, enable IGMP snooping, and enable the IGMP snooping querier.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping querier
# In VSI aaa, enable IGMP snooping, and enable the IGMP snooping querier.
[Sysname] vsi aaa
[Sysname-vsi-aaa] igmp-snooping querier
subvlan (multicast VLAN view)
Use igmp-snooping querier-election to enable IGMP snooping querier election for a VLAN or VSI.
Use undo igmp-snooping querier-election to disable IGMP snooping querier election for a VLAN or VSI.
IGMP snooping querier election is disabled for a VLAN or VSI.
VLAN view
VSI view
For IGMP snooping querier election to take effect, you must enable the IGMP snooping querier.
# In VLAN 2, enable IGMP snooping, and enable IGMP snooping querier election.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping querier-election
# In VSI aaa, enable IGMP snooping, and enable IGMP snooping querier election.
[Sysname] vsi aaa
[Sysname-vsi-aaa] igmp-snooping querier-election
Use igmp-snooping query-interval to set the IGMP general query interval for a VLAN or VSI.
Use undo igmp-snooping query-interval to restore the default.
igmp-snooping query-interval interval
The IGMP general query interval is 125 seconds.
VLAN view
VSI view
interval: Specifies an IGMP general query interval in the range of 2 to 31744 seconds.
To avoid mistakenly deleting multicast group members, set the IGMP general query interval to be greater than the maximum response time for IGMP general queries.
# In VLAN 2, enable IGMP snooping, and set the IGMP general query interval to 20 seconds.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping query-interval 20
# In VSI aaa, enable IGMP snooping, and set the IGMP general query interval to 20 seconds.
[Sysname] vsi aaa
[Sysname-vsi-aaa] igmp-snooping query-interval 20
max-response-time
Use igmp-snooping report source-ip to configure the source IP address for IGMP reports.
Use undo igmp-snooping report source-ip to restore the default.
igmp-snooping report source-ip ip-address
In a VLAN, the source IP address of IGMP reports is the IP address of the current VLAN interface. If the current VLAN interface does not have an IP address, the source IP address is 0.0.0.0.
In a VSI, the source IP address of IGMP reports is the IP address of the gateway interface for the VSI. If the gateway interface does not have an IP address, the source IP address is 0.0.0.0.
VLAN view
VSI view
ip-address: Specifies the source IP address for IGMP reports.
# In VLAN 2, enable IGMP snooping, and specify 10.1.1.1 as the source IP address of IGMP reports.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping report source-ip 10.1.1.1
# In VSI aaa, enable IGMP snooping, and specify 10.1.1.1 as the source IP address of IGMP reports.
[Sysname] vsi aaa
[Sysname-vsi-aaa] igmp-snooping report source-ip 10.1.1.1
enable (IGMP-snooping view)
Use igmp-snooping router-aging-time to set the aging timer for dynamic router ports in a VLAN or VSI.
Use undo igmp-snooping router-aging-time to restore the default.
igmp-snooping router-aging-time seconds
The aging timer for dynamic router ports is 260 seconds.
VLAN view
VSI view
seconds: Specifies an aging timer for dynamic router ports, in the range of 1 to 8097894 seconds.
# In VLAN 2, enable IGMP snooping, and set the aging timer for dynamic router ports to 100 seconds.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping router-aging-time 100
# In VSI aaa, enable IGMP snooping, and set the aging timer for dynamic router ports to 100 seconds.
[Sysname] vsi aaa
[Sysname-vsi-aaa] igmp-snooping router-aging-time 100
igmp-snooping router-port-deny
Use igmp-snooping router-port-deny to disable a port from becoming a dynamic router port.
Use undo igmp-snooping router-port-deny to allow a port to become a dynamic router port.
igmp-snooping router-port-deny [ vlan vlan-list ]
undo igmp-snooping router-port-deny [ vlan vlan-list ]
A port is allowed to become a dynamic router port.
vlan vlan-list: Specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN by its ID or a range of VLANs in the form of start-vlan-id to end-vlan-id. The VLAN ID is in the range of 1 to 4094. If you specify VLANs, this command takes effect only when the port belongs to the specified VLANs. If you do not specify a VLAN, this command takes effect on all VLANs to which the port belongs.
# Disable Ten-GigabitEthernet 1/0/1 from becoming a dynamic router port in VLAN 2.
[Sysname-Ten-GigabitEthernet1/0/1] igmp-snooping router-port-deny vlan 2
igmp-snooping source-deny
Use igmp-snooping source-deny to enable multicast source port filtering on a port to discard all multicast data packets.
Use undo igmp-snooping source-deny to disable multicast source port filtering on a port.
Multicast source port filtering is disabled.
You can enable this feature for a port in interface view or for the specified ports in IGMP-snooping view. For a port, the configuration in interface view has the same priority as the configuration in IGMP-snooping view, and the most recent configuration takes effect.
# Enable source port filtering for multicast data on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] igmp-snooping source-deny
source-deny (IGMP-snooping view)
igmp-snooping special-query source-ip
Use igmp-snooping special-query source-ip to configure the source IP address for IGMP group-specific queries.
Use undo igmp-snooping special-query source-ip to restore the default.
igmp-snooping special-query source-ip ip-address
In a VLAN, the source IP address of IGMP group-specific queries is one of the following:
·     The source address of IGMP group-specific queries if the IGMP snooping querier of the VLAN has received IGMP general queries.
·     The IP address of the current VLAN interface if the IGMP snooping querier does not receive an IGMP general query.
·     0.0.0.0 if the IGMP snooping querier does not receive an IGMP general query and the current VLAN interface does not have an IP address.
In a VSI, the source IP address of IGMP group-specific queries is one of the following:
·     The source IP address of IGMP general queries if the IGMP snooping querier of the VSI has received IGMP general queries.
·     The IP address of the gateway interface for the VSI if the IGMP snooping querier does not receive an IGMP general query.
·     0.0.0.0 if the gateway interface for the VSI does not have an IP address.
VLAN view
VSI view
ip-address: Specifies the source IP address for IGMP group-specific queries.
# In VLAN 2, enable IGMP snooping, and specify 10.1.1.1 as the source IP address of IGMP group-specific queries.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping special-query source-ip 10.1.1.1
# In VSI aaa, enable IGMP snooping, and specify 10.1.1.1 as the source IP address of IGMP group-specific queries.
[Sysname] vsi aaa
[Sysname-vsi-aaa] igmp-snooping special-query source-ip 10.1.1.1
Use igmp-snooping static-group to configure a port as a static member port of a multicast group.
Use undo igmp-snooping static-group to remove the configuration of static member ports.
igmp-snooping static-group group-address [ source-ip source-address ] vlan vlan-id
undo igmp-snooping static-group { group-address [ source-ip source-address ] vlan vlan-id | all }
A port is not a static member port of a multicast group.
source-ip source-address: Specifies a multicast source by its IP address. If you specify a multicast source, this command configures the port as a static member port for a multicast source and group. If you do not specify a multicast source, this command configures the port as a static member port for a multicast group. This option takes effect on IGMPv3 snooping devices.
# Configure Ten-GigabitEthernet 1/0/1 as a static member port of the multicast source and group (1.1.1.1, 225.0.0.1) in VLAN 2.
[Sysname] vlan 2
[Sysname] interface Ten-GigabitEthernet 1/0/1
[Sysname-Ten-GigabitEthernet1/0/1] igmp-snooping static-group 225.0.0.1 source-ip 1.1.1.1 vlan 2
Use igmp-snooping static-router-port to configure a port as a static router port.
Use undo igmp-snooping static-router-port to remove the configuration of static router ports.
igmp-snooping static-router-port vlan vlan-id
undo igmp-snooping static-router-port { all | vlan vlan-id }
A port is not a static router port.
all: Specifies all VLANs.
# Configure Ten-GigabitEthernet 1/0/1 as a static router port in VLAN 2.
[Sysname-Ten-GigabitEthernet1/0/1] igmp-snooping static-router-port vlan 2
Use igmp-snooping version to specify an IGMP snooping version for a VLAN or VSI.
Use undo igmp-snooping version to restore the default.
igmp-snooping version version-number
The IGMP snooping version in a VLAN or VSI is 2.
VLAN view
VSI view
version-number: Specifies an IGMP snooping version, 2 or 3.
You can specify the version for a VLAN in VLAN view or for the specified VLANs in IGMP-snooping view. The VLAN-specific configuration has the same priority as the configuration in IGMP-snooping view, and the most recent configuration takes effect.
# In VLAN 2, enable IGMP snooping, and specify IGMP snooping version 3.
[Sysname] vlan 2
# In VSI aaa, enable IGMP snooping, and specify IGMP snooping version 3.
[Sysname] vsi aaa
[Sysname-vsi-aaa] igmp-snooping version 3
version (IGMP-snooping view)
last-member-query-interval (IGMP-snooping view)
Use last-member-query-interval to set the IGMP last member query interval globally.
Use undo last-member-query-interval to restore the default.
IGMP-snooping view
# Set the global IGMP last member query interval to 3 seconds.
[Sysname-igmp-snooping] last-member-query-interval 3
Use mac-address multicast to configure a static multicast MAC address entry.
Use undo mac-address multicast to delete a static multicast MAC address entry.
In system view:
undo mac-address [ multicast ] [ [ mac-address [ interface interface-list ] ] vlan vlan-id ]
In Layer 2 aggregate interface view or Layer 2 Ethernet interface view:
undo mac-address [ multicast ] mac-address vlan vlan-id
No static multicast MAC address entries exist.
mac-address: Specifies a static multicast MAC address, in the format of H-H-H. You must specify an unused multicast MAC address. A multicast MAC address is a MAC address in which the least significant bit of the most significant octet is 1.
interface interface-list: Specifies a space-separated list of up to four interface items. Each item specifies an interface or an interface list in the format of start-interface-type interface-number to end-interface-type interface-number. The interface-type interface-number argument specifies an interface by its type and number. The available interface types include Layer 2 Ethernet interfaces and Layer 2 aggregate interfaces.
vlan vlan-id: Specifies an existing VLAN by its VLAN ID in the range of 1 to 4094. The system gives a prompt if the specified interface does not belong to the VLAN.
You do not need to enable IP multicast routing before you execute this command.
You can configure static multicast MAC address entries for the specified interfaces in system view or for the current interface in interface view.
If you do not specify the multicast keyword in the undo mac-address command, all static unicast MAC address entries and static multicast MAC entries are deleted.
# Configure a static multicast MAC address entry. In the entry, the multicast MAC address is 0100-5E00-0003 and the outgoing ports are Ten-GigabitEthernet 1/0/1 through Ten-GigabitEthernet 1/0/5 in VLAN 2.
[Sysname] mac-address multicast 0100-5e00-0003 interface ten-gigabitethernet 1/0/1 to ten-gigabitethernet 1/0/5 vlan 2
# Configure a static multicast MAC address entry on Ten-GigabitEthernet 1/0/1. In the entry, the multicast MAC address is 0100-5E00-0003 and the outgoing port is Ten-GigabitEthernet 1/0/1, which belongs to VLAN 2.
[Sysname-Ten-GigabitEthernet1/0/1] mac-address multicast 0100-5e00-0003 vlan 2
mac-address multicast vsi
Use mac-address multicast vsi to configure a static multicast MAC address entry for VXLAN.
Use undo mac-address multicast vsi to delete a static multicast MAC address entry for VXLAN or delete outgoing interfaces for such an entry.
For local static multicast MAC address entries:
mac-address multicast mac-address { interface { interface-type interface-number service-instance instance-id }&<1-4> } vsi vsi-name
undo mac-address multicast [ mac-address [ interface { interface-type interface-number service-instance instance-id }&<1-4> ] ] vsi vsi-name
For remote static multicast MAC address entries:
mac-address multicast mac-address { interface { tunnel tunnel-number1 [ to tunnel tunnel-number2 ] }&<1-4> } vsi vsi-name
undo mac-address multicast [ mac-address [ interface { tunnel tunnel-number1 [ to tunnel tunnel-number2 ] }&<1-4> ] ] vsi vsi-name
mac-address: Specifies a multicast MAC address in the format of H-H-H, excluding the all-zero MAC address. When entering a MAC address, you can omit the leading zeros in each H section. For example, enter 100-5e00-3 for 0100-5e00-0003.
interface { interface-type interface-number service-instance instance-id }&<1-4>: Specifies a space-separated list of up to four Ethernet service instances. The interface-type interface-number argument specifies the interface that hosts an Ethernet service instance by its type and number. The instance-id argument specifies the Ethernet service instance by its ID in the range of 1 to 4096.
interface { tunnel tunnel-number1 [ to tunnel tunnel-number2 ] }&<1-4>: Specifies a space-separated list of up to four VXLAN tunnel interface items. Each item specifies a VXLAN tunnel interface number or a range of VXLAN tunnel interface numbers in the format of tunnel tunnel-number1 to tunnel tunnel-number2. On the S6520X-H and S5560X-HI switch series, the value range for tunnel interface numbers is 0 to 4095. On the S6520X-EI switch series switch series, the value range is 0 to 2047. On the S6520X-SI, S6520-SI, S5000-EI, and MS4600 switch series, the value range for tunnel interface numbers is 0 to 1023. The number of tunnel interfaces that can be created is restricted by the total number of interfaces and the memory. The value of tunnel tunnel-number2 must be equal to or larger than the value of tunnel tunnel-number1. The specified VXLAN tunnel interfaces must exist.
vsi vsi-name: Specifies a VSI name, a case-sensitive string of 1 to 31 characters.
To send packets with a specific destination MAC address out of multiple ports, use this command to configure a static multicast MAC address entry. You can repeat this command to add outgoing interfaces for an existing entry.
For successful configuration, follow these restrictions when you configure static multicast MAC address entries:
·     For a local static multicast MAC address entry, make sure the specified Ethernet service instances have been mapped to the specified VSI.
·     For a remote static multicast MAC address entry, make sure the specified VXLAN tunnel interfaces have been associated with the specified VSI.
Follow these guidelines when you use the undo mac-address multicast vsi command:
·     To delete all static multicast MAC address for a VSI, do not specify any optional parameters.
·     To remove outgoing interfaces from a static multicast MAC address entry, specify the MAC address and the interfaces.
Do not specify the tunnel interfaces automatically created by using ENDP or EVPN as outgoing interfaces for a remote static multicast MAC address entry. If you do so, the numbers of these tunnel interfaces might change during tunnel re-establishment, and the related entries cannot be restored as a result.
In an EVPN network, you cannot configure the same multicast MAC address entry on multiple leaf nodes or VTEPs. When configured with EVPN multihoming, a VTEP does not support synchronization of multicast MAC address entries.
For more information about VXLAN, see VXLAN Configuration Guide. For more information about EVPN, see EVPN Configuration Guide.
# Configure a local static multicast MAC address entry for VSI vsi1.
[Sysname] mac-address multicast 0100-5e00-0003 interface ten-gigabitethernet 1/0/1 service-instance 1 ten-gigabitethernet 1/0/2 service-instance 1 vsi vsi1
# Configure a remote static multicast MAC address entry for VSI vsi1.
[Sysname] mac-address multicast 0100-5e00-0003 interface tunnel 1 to tunnel 3 vsi vsi1
display l2vpn mac-address (VXLAN Command Reference)
max-response-time (IGMP-snooping view)
Use max-response-time to set the maximum response time for IGMP general queries globally.
Use undo max-response-time to restore the default.
IGMP-snooping view
# Set the global maximum response time for IGMP general queries to 5 seconds.
[Sysname-igmp-snooping] max-response-time 5
overflow-replace (IGMP-snooping view)
Use overflow-replace to enable the multicast group replacement feature globally.
Use undo overflow-replace to disable the multicast group replacement feature globally.
undo overflow-replace [ vlan vlan-list ]
The multicast group replacement feature is disabled.
IGMP-snooping view
You can enable the multicast group replacement feature globally for all ports in IGMP-snooping view or for a port in interface view. For a port, the port-specific configuration takes priority over the global configuration.
# Globally enable the multicast group replacement feature for VLAN 2.
[Sysname-igmp-snooping] overflow-replace vlan 2
report-aggregation (IGMP-snooping view)
Use report-aggregation to enable IGMP report suppression.
Use undo report-aggregation to disable IGMP report suppression.
report-aggregation
IGMP report suppression is enabled.
IGMP-snooping view
# Disable IGMP report suppression.
[Sysname-igmp-snooping] undo report-aggregation
reset igmp-snooping group
Use reset igmp-snooping group to clear information about dynamic IGMP snooping group entries.
reset igmp-snooping group { group-address [ source-address ] | all } [ vlan vlan-id | vsi vsi-name ]
source-address: Specifies a multicast source address. If you do not specify a multicast source, this command clears information about dynamic IGMP snooping group entries for all multicast sources.
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, this command clears information about dynamic IGMP snooping group entries for all VLANs.
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command clears information about dynamic IGMP snooping group entries for all VSIs.
# Clear information about all dynamic IGMP snooping group entries.
<Sysname> reset igmp-snooping group all
display igmp-snooping group
reset igmp-snooping router-port
Use reset igmp-snooping router-port to clear dynamic router port information.
reset igmp-snooping router-port { all | vlan vlan-id | vsi vsi-name }
all: Specifies all dynamic router ports.
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, this command clears dynamic router port information for all VLANs.
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command clears dynamic router port information for all VSIs.
# Clear dynamic router port information.
<Sysname> reset igmp-snooping router-port all
display igmp-snooping router-port
reset igmp-snooping statistics
Use reset igmp-snooping statistics to clear statistics for IGMP messages and PIMv2 hello messages learned through IGMP snooping.
# Clear the statistics for all IGMP messages and PIMv2 hello messages learned through IGMP snooping.
<Sysname> reset igmp-snooping statistics
display igmp-snooping statistics
Use reset l2-multicast fast-forwarding cache to clear Layer 2 multicast fast forwarding entries.
reset l2-multicast fast-forwarding cache [ vlan vlan-id ] { { source-address | group-address } * | all } [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command clears Layer 2 multicast fast forwarding entries for the master device.
all: Specifies all Layer 2 multicast fast forwarding entries.
# Clear all Layer 2 multicast fast forwarding entries.
<Sysname> reset l2-multicast fast-forwarding cache all
# Clear the Layer 2 multicast fast forwarding entry for the multicast source and group (20.0.0.2, 225.0.0.2).
<Sysname> reset l2-multicast fast-forwarding cache 20.0.0.2 225.0.0.2
router-aging-time (IGMP-snooping view)
Use router-aging-time to set the aging timer for dynamic router ports globally.
Use undo router-aging-time to restore the default.
IGMP-snooping view
# Set the global aging timer for dynamic router ports to 100 seconds.
[Sysname-igmp-snooping] router-aging-time 100
send-query enable
Use send-query enable to enable the device to send IGMP general queries upon a path change.
Use undo send-query enable to restore the default.
send-query enable
The device does not send IGMP general queries upon a path change.
IGMP-snooping view
Use this command to enable the device to immediately send an IGMP general query to all ports in the affected VLAN or VSI when the path changes. This feature ensures that the device can update the member port information in multicast forwarding entries and switch multicast traffic to the new path promptly.
# Enable the device to send IGMP general queries upon a path change.
[Sysname-igmp-snooping] send-query enable
igmp-snooping
Use source-deny to enable multicast source port filtering on ports to discard all multicast data packets.
Use undo source-deny to disable multicast source port filtering on ports.
undo source-deny port interface-list
IGMP-snooping view
port interface-list: Specifies a space-separated list of port items. Each item specifies a port by its port type and number or a range of ports in the form of start-interface-type interface-number to end-interface-type interface-number.
You can enable this feature for the specified ports in IGMP-snooping view or for a port in interface view. For a port, the configuration in IGMP-snooping view has the same priority as the configuration in interface view, and the most recent configuration takes effect.
# Enable multicast source port filtering on ports Ten-GigabitEthernet 1/0/1 through Ten-GigabitEthernet 1/0/4.
[Sysname-igmp-snooping] source-deny port ten-gigabitethernet 1/0/1 to ten-gigabitethernet 1/0/4
Use version to specify an IGMP snooping version for VLANs.
Use undo version to restore the default.
undo version vlan vlan-list
The IGMP snooping version in a VLAN is 2.
IGMP-snooping view
You must enable IGMP snooping for the specified VLANs before you execute this command.
You can specify the version for the specified VLANs in IGMP-snooping view or for a VLAN in VLAN view. The configuration in IGMP-snooping view has the same priority as the VLAN-specific configuration, and the most recent configuration takes effect.
# Enable IGMP snooping for VLAN 2 through VLAN 10, and specify IGMP snooping version 3 for these VLANs.
[Sysname-igmp-snooping] version 3 vlan 2 to 10
