20-Internet Access Behavior Management Command Reference
HomeSupportReference GuidesCommand ReferencesH3C SR6600[SR6600-X] Routers Command Reference(V7)-R8149-6W10020-Internet Access Behavior Management Command Reference
02-NetShare control commands
02-NetShare control commands 126.64 KB
action
Use action to specify the NetShare control action to take when the number of terminals sharing an IP address exceeds the limit.
Use undo action to restore the default.
action { freeze freeze-time | permit } [ logging ]
undo action
A NetShare control policy uses the permit action.
NetShare control policy view
freeze: Freezes the shared IP address so all packets sourced from the IP address will be dropped.
freeze-time: Specifies the time period that an IP address will be frozen, in minutes. The value range for this argument is 2 to 720.
permit: Permits the packets sourced from the IP address to pass through.
logging: Logs the NetShare control event.
A NetShare control policy analyzes packets to track the number of terminals sharing the same source IP address. If the number of terminals sharing an IP address exceeds the limit set by using the per-ip-shared max-terminals command, the device will take the NetShare control action in the policy.
# Specify the freeze action and set the freezing time to 10 minutes in NetShare control policy abc.
[Sysname] netshare-control
[Sysname-netshare-control] policy name abc
[Sysname-netshare-control-policy-abc] action freeze 10
application-inspect enable
Use application-inspect enable to enable APR-based detection.
Use undo application-inspect enable to disable APR-based detection.
APR-based detection is enabled.
APR-based NetShare detection uses the APR signature library to inspect only specific applications, such as QQ and WeChat. If an application is encrypted, APR-based NetShare detection cannot inspect it. As a best practice, enable APR-based detection only when explicitly required, because the detection might degrade the device performance.
You can enable both APR-based detection and IPID trail tracking to detect NetShare behaviors.
# Enable APR-based detection in NetShare control policy share.
[Sysname-netshare-control] policy name share
[Sysname-netshare-control-policy-share] application-inspect enable
ipid-trail enable
description
Use description to configure a description for a NetShare control policy.
No description is configured for a NetShare control policy.
text: Configures a description, a case-sensitive string of 1 to 127 characters.
# Configure a description for NetShare control policy abc.
[Sysname-netshare-control-policy-abc] description The Netshare Management
destination-address
Use destination-address to set a destination address filtering criterion in a NetShare control policy.
Use undo destination-address to remove a destination address filtering criterion from a NetShare control policy.
destination-address { ipv4 | ipv6 } object-group-name
undo destination-address { ipv4 | ipv6 } object-group-name
A NetShare control policy does not contain any destination address filtering criterion.
ipv4: Specifies an IPv4 address object group.
ipv6: Specifies an IPv6 address object group.
object-group-name: Specifies an address object group by its name, a case-insensitive string of 1 to 63 characters.
You can execute this command multiple times in a NetShare control policy to set multiple destination address filtering criteria. A packet passes the destination address filtering if it matches any of the configured destination address filtering criteria.
# Set IPv4 address object group obgroup2 as a destination address filtering criterion in NetShare control policy abc.
[Sysname-netshare-control-policy-abc] destination-address ipv4 obgroup2
object-group (Security Command Reference)
destination-zone
Use destination-zone to set a destination security zone filtering criterion in a NetShare control policy.
Use undo destination-zone to remove a destination security zone filtering criterion from a NetShare control policy.
destination-zone destination-zone-name
undo destination-zone destination-zone-name
A NetShare control policy does not contain any destination security zone filtering criterion.
destination-zone-name: Specifies a destination security zone by its name, a case-insensitive string of 1 to 31 characters.
You can execute this command multiple times in a NetShare control policy to set multiple destination security zone filtering criteria. A packet passes the destination security zone filtering if it matches any of the configured destination security zone filtering criteria.
# Set security zone zone2 as a destination security zone filtering criterion in NetShare control policy abc.
[sysname-netshare-control] policy name abc
[sysname-netshare-control-policy-abc] destination-zone zone2
security-zone name (Security Command Reference)
disable
Use disable to disable a NetShare control policy.
Use undo disable to enable a NetShare control policy.
disable
undo disable
A NetShare control policy is enabled.
The device supports only one NetShare control policy.
After you disable the NetShare control policy, the NetShare control feature becomes invalid.
# Disable NetShare control policy abc.
[Sysname-netshare-control-policy-abc] disable
display netshare-control
Use display netshare-control to display NetShare control information about shared IP addresses.
In standalone mode:
display netshare-control [ { ipv4 | ipv6 } ip-address | status { frozen | unfrozen } ] [ slot slot-number ]
In IRF mode:
display netshare-control [ { ipv4 | ipv6 } ip-address | status { frozen | unfrozen } ] [ chassis chassis-number slot slot-number ]
Any
ipv4: Specifies the IPv4 address type.
ipv6: Specifies the IPv6 address type.
ip-address: Displays NetShare control information about the specified IP address.
status: Specifies the status of the IP addresses to be displayed.
frozen: Displays NetShare control information about frozen IP addresses.
unfrozen: Displays NetShare control information about unfrozen IP addresses.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays information for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays information for all cards. (In IRF mode.)
This command displays information about detected IP addresses that are shared by multiple terminals.
# (In standalone mode.) Displays all shared IP addresses in frozen state.
<Sysname> display netshare-control status frozen
Slot 1:
  Total frozen shared IP addresses: 2
  IP address     VPN instance  Policy   Terminals   Status    Remaining time  User
  192.168.1.18   vpn1           P1        3            Frozen     20 min           abc
  12.12.12.1     -               P1        4            Frozen     10 min           kwq123
Total number of shared IP address in frozen state.
IP address
Shared IP address.
VPN instance
VPN instance to which the IP address belongs.
This field displays a hyphen (-) if the IP address is on the public network.
Policy
Name of the NetShare control policy.
Terminals
Number of terminals sharing the IP address.
Status
Status of the shared IP address: frozen or unfrozen.
Remaining time
Remaining time before the IP address will be released from the frozen IP address list.
User
User name.
freeze
Use freeze to manually freeze an IP address.
freeze { ipv4 | ipv6 } ip-address [ vpn-instance vpn-instance-name ] time freeze-time
NetShare control configuration view
ip-address: Specifies the IP address to freeze.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If the IP address is on the public network, do not specify this option.
freeze-time: Specifies the time period that the IP address will be frozen, in minutes. The value range is 5 to 720.
Use this command to manually freeze an IP address that is shared by terminals. This command is not available for IP addresses that are already on frozen IP address list.
To view the shared IP addresses that can be manually frozen, use the display netshare-control command.
# Manually freeze IP address 12.12.12.1 for 15 minutes.
[Sysname-netshare-control] freeze ipv4 12.12.12.1 time 15
unfreeze
ipid-trail enable
Use ipid-trail enable to enable IPID trail tracking.
Use undo ipid-trail enable to disable IPID trail tracking.
ipid-trail enable
IPID trail tracking is disabled.
By default, the device uses the Application Recognition (APR) feature to detect NetShare behaviors. APR-based detection applies only to a limited set of applications in the APR signature library. You can enable IPID trail tracking to meet the NetShare control requirements of various application scenarios.
IPID trail tracking tracks the values of the IPID fields in packets to detect NetShare behaviors. Packets sent by the same host contain incremented IPID values of a unique sequential pattern that starts at a random number. NetShare control tracks the IPID values of packets sourced from the same IP address. In a time period, if the IPID values in the packets belong to the same unique sequential pattern, only one terminal is using the IP address. If the IPID values belong to different sequential patterns, the source IP address is shared by multiple terminals.
IPID trail tracking might degrade the device performance. Enable it only when explicitly required.
IPID trail tracking supports detecting the terminals that are running the Windows system, and detecting packets in which values of the IPID fields change regularly. Mobile terminals are not supported.
IPID trail tracking supports detecting IPv4 packets.
# Enable IPID trail tracking in NetShare control policy abc.
[Sysname-netshare-control-policy-abc] ipid-trail enable
netshare-control
Use netshare-control to enter NetShare control configuration view.
netshare-control
# Enter NetShare control configuration view.
Use per-ip-shared max-terminals to set the maximum number of terminals that can share an IP address.
Use undo per-ip-shared max-terminals to restore the default.
per-ip-shared max-terminals number
The number of terminals that can share an IP address is not limited.
number: Sets the maximum number of terminals that can share an IP address. The value range is 1 to 15. If you set the value to 1, one IP address can be used by only one terminal.
If the number of terminals sharing an IP address exceeds the limit, the device will take the NetShare control action set by using the action command in the NetShare control policy.
# Set the maximum number of terminals that can share an IP address to 3 in NetShare control policy abc.
<sysname> system-view
[sysname] netshare-control
[sysname-netshare-control-policy-abc] per-ip-shared max-terminals 3
action
policy name
Use policy name to create a NetShare control policy and enter its view, or enter the view of an existing NetShare control policy.
Use undo policy name to delete a NetShare control policy.
policy name policy-name
undo policy name policy-name
No NetShare control policy exists.
policy-name: Specify a name for the NetShare control policy, a case-insensitive string of 1 to 63 characters.
In the NetShare control policy, you can configure the following items:
·     The following types of criteria to filter the packets to be analyzed by the NetShare control policy:
¡     Source IP address.
¡     Destination IP address.
¡     Source security zone.
¡     Destination security zone.
¡     User.
¡     User group.
·     Maximum number of terminals that can share an IP address.
·     Action to take when the number of terminals sharing an IP address exceeds the limit.
# Create NetShare control policy abc and enter its view.
source-address
Use source-address to set a source address filtering criterion in a NetShare control policy.
Use undo source-address to remove a source address filtering criterion from a NetShare control policy.
source-address { ipv4 | ipv6 } object-group-name
undo source-address { ipv4 | ipv6 } object-group-name
A NetShare control policy does not contain any source address filtering criterion.
You can execute this command multiple times in a NetShare control policy to set multiple source address filtering criteria. A packet passes the source address filtering if it matches any of the configured source address filtering criteria.
# Set IPv4 address object group obgroup1 as a source address filtering criterion in NetShare control policy abc.
[Sysname-netshare-control-policy-abc] source-address ipv4 obgroup1
source-zone
Use source zone to set a source security zone filtering criterion in a NetShare control policy.
Use undo source zone to remove a source security zone filtering criterion from a NetShare control policy.
source-zone source-zone-name
undo source-zone source-zone-name
A NetShare control policy does not contain any source security zone filtering criterion.
source-zone-name: Specifies a source security zone by its name, a case-insensitive string of 1 to 31 characters.
You can execute this command multiple times in a NetShare control policy to set multiple source security zone filtering criteria. A packet passes the source security zone filtering if it matches any of the configured source security zone filtering criteria.
# Set security zone zone1 as a source security zone filtering criterion in NetShare control policy abc.
[Sysname-netshare-control-policy-abc] source-zone zone1
unfreeze
Use freeze to manually unfreeze an IP address.
unfreeze { ipv4 | ipv6 } ip-address [ vpn-instance vpn-instance-name ]
ip-address: Specifies the IP address to unfreeze.
Use this command to manually unfreeze a frozen IP address.
To view the available frozen IP addresses, use the display netshare-control command.
# Manually unfreeze IP address 12.12.12.1.
[Sysname-netshare-control] unfreeze ipv4 12.12.12.1
user
Use user to set a user filtering criterion in a NetShare control policy.
Use undo user to remove a user filtering criterion from a NetShare control policy.
user username [ domain domain-name ]
undo user username [ domain domain-name ]
A NetShare control policy does not contain any user filtering criteria.
username: Specify a username, a case-sensitive string of 1 to 55 characters. The username cannot contain the following characters: \|/:*?<>@, and cannot be a, al, or all.
domain domain-name: Specifies the name of the identity domain to which the user belongs. The identity domain name is a case-insensitive string of 1 to 255 characters which cannot contain question marks (?). If the user name does not belong to any identity domains, do not specify this option. For more information about identity domains, see user identification configuration in Security Configuration Guide.
You can execute this command multiple times in a NetShare control policy to set multiple user filtering criteria. A packet passes the user filtering if it matches any of the configured user filtering criteria.
# Set user managers as a user filtering criterion in NetShare control policy abc.
[sysname-netshare-control-policy-abc] user managers
user-identity enable (Security Command Reference)
user-group
Use user-group to set a user group filtering criterion in a NetShare control policy.
Use undo user-group to remove a user group filtering criterion from a NetShare control policy.
user-group user-group-name [ domain domain-name ]
undo user-group user-group-name [ domain domain-name ]
A NetShare control policy does not contain any user group filtering criteria.
user-group-name: Specify a user group by its name, a case-sensitive string of 1 to 32 characters.
domain domain-name: Specifies the name of the identity domain to which the user group belongs. The identity domain name is a case-insensitive string of 1 to 255 characters which cannot contain question marks (?). If the user group does not belong to any identity domains, do not specify this option. For more information about identity domains, see user identification configuration in Security Configuration Guide.
You can execute this command multiple times in a NetShare control policy to set multiple user group filtering criteria. A packet passes the user group filtering if it matches any of the configured user group filtering criteria.
# Set user group group1 as a user group filtering criterion in NetShare control policy abc.
[sysname-netshare-control-policy-abc] user-group group1
identity-group (Security Command Reference)
