- 04-Layer 2—LAN Switching Command Reference
- 01-MAC address table commands
- 02-Ethernet link aggregation commands
- 03-Port isolation commands
- 04-VLAN commands
- 05-QinQ commands
- 06-VLAN mapping commands
- 07-VLAN termination commands
- 08-Loop detection commands
- 09-Spanning tree commands
- 10-LLDP commands
- 11-Layer 2 forwarding commands
05-QinQ commands | 68.96 KB |
QinQ commands
This document uses the following terms:
· CVLAN—Customer network VLANs, also called inner VLANs, refer to VLANs that a customer uses on the private network.
· SVLAN—Service provider network VLANs, also called outer VLANs, refer to VLANs that a service provider uses to transmit VLAN tagged traffic for customers.
display qinq
Use display qinq to display QinQ-enabled interfaces.
display qinq [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays all QinQ-enabled interfaces.
If QinQ is not enabled on any interfaces, this command does not provide any output.
# Enable QinQ on GigabitEthernet 1/0/1. Then, verify that QinQ is enabled on the interface.
[Sysname-GigabitEthernet1/0/1] qinq enable
[Sysname-GigabitEthernet1/0/1] display qinq interface gigabitethernet 1/0/1
# Enable QinQ on GigabitEthernet 1/0/1 and GigabitEthernet 1/0/3. Then, verify that QinQ is enabled on the interfaces.
[Sysname] interface gigabitethernet 1/0/3
[Sysname-GigabitEthernet1/0/3] qinq enable
[Sysname-GigabitEthernet1/0/3] display qinq
qinq enable
qinq enable
Use qinq enable to enable QinQ on an interface.
Use undo qinq enable to disable QinQ on an interface.
qinq enable
undo qinq enable
QinQ is disabled on interfaces.
VEB interface view
display qinq
qinq ethernet-type (interface view)
Use qinq ethernet-type to set the TPID value in SVLAN tags on an interface.
Use undo qinq ethernet-type to restore the default TPID value in SVLAN tags on an interface.
qinq ethernet-type service-tag { hex-value | dot1ad | dot1q }
undo qinq ethernet-type service-tag
If the device supports global TPID configuration, the interface-level TPID value in SVLAN tags equals the global TPID value.
If the device does not support global TPID configuration, the TPID value in SVLAN tags is 8100 in hexadecimal notation.
VEB interface view
service-tag: Sets the TPID value in the SVLAN tag.
hex-value: Sets a hexadecimal TPID value in the range of 600 to ffff, excluding the reserved EtherType values listed in Table 1.
Table 1 Reserved EtherType values
Protocol type |
Value |
ARP |
0x0806 |
PUP |
0x0200 |
RARP |
0x8035 |
IP |
0x0800 |
IPv6 |
0x86dd |
PPPoE |
0x8863/0x8864 |
MPLS |
0x8847/0x8848 |
IPX/SPX |
0x8137 |
IS-IS |
0x8000 |
LACP |
0x8809 |
LLDP |
0x88cc |
802.1X |
0x888e |
802.1ag |
0x8902 |
Cluster |
0x88a7 |
Reserved |
0xfffd/0xfffe/0xffff |
dot1ad: Sets the hexadecimal TPID value to 88a8.
dot1q: Sets the hexadecimal TPID value to 8100.
For a port, the TPID value set in interface view applies preferentially over the TPID value set in system view.
# Set the TPID value in SVLAN tags to 9100 (hexadecimal) on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] qinq ethernet-type service-tag 9100
qinq ethernet-type (system view)
Use qinq ethernet-type to set the TPID value in CVLAN tags globally.
Use undo qinq ethernet-type to restore the default TPID value in CVLAN tags globally.
qinq ethernet-type customer-tag { hex-value | dot1ad | dot1q }
undo qinq ethernet-type customer-tag
The global TPID value in CVLAN tags is 8100 in hexadecimal notation.
customer-tag: Sets the TPID value in the CVLAN tag.
hex-value: Sets a hexadecimal TPID value in the range of 600 to ffff, excluding the reserved EtherType values listed in Table 2.
Table 2 Reserved EtherType values
Protocol type |
Value |
ARP |
0x0806 |
PUP |
0x0200 |
RARP |
0x8035 |
IP |
0x0800 |
IPv6 |
0x86dd |
PPPoE |
0x8863/0x8864 |
MPLS |
0x8847/0x8848 |
IPX/SPX |
0x8137 |
IS-IS |
0x8000 |
LACP |
0x8809 |
LLDP |
0x88cc |
802.1X |
0x888e |
802.1ag |
0x8902 |
Cluster |
0x88a7 |
Reserved |
# Set the global TPID value in CVLAN tags to 88a8 (hexadecimal).
[Sysname] qinq ethernet-type customer-tag dot1ad
