- 04-Layer 2—LAN Switching Configuration Guide
- 01-MAC address table configuration
- 02-Ethernet link aggregation configuration
- 03-Port isolation configuration
- 04-VLAN configuration
- 05-QinQ configuration
- 06-VLAN mapping configuration
- 07-VLAN termination configuration
- 08-Loop detection configuration
- 09-Spanning tree configuration
- 10-LLDP configuration
- 11-Layer 2 forwarding configuration
08-Loop detection configuration | 146.73 KB |
Restrictions: Hardware compatibility with loop detection
Loop detection tasks at a glance
Restrictions and guidelines for loop detection configuration
Enabling loop detection globally
Enabling loop detection on a port
Setting the loop protection action
Restrictions and guidelines for loop protection action configuration
Setting the global loop protection action
Setting the loop protection action on an interface
Setting the loop detection interval
Display and maintenance commands for loop detection
Loop detection configuration examples
Example: Configuring basic loop detection functions
Configuring loop detection
About loop detection
The loop detection mechanism performs periodic checking for Layer 2 loops. The mechanism immediately generates a log message when a loop occurs so that you are promptly notified to adjust network connections and configurations. You can configure loop detection to shut down the looped port. Logs are maintained in the information center. For more information, see Network Management and Monitoring Configuration Guide.
Loop detection mechanism
The device detects loops by sending detection frames and then checking whether these frames return to any port on the device. If they do, the device considers that the port is on a looped link.
Loop detection usually works within a VLAN. If a detection frame is returned with a different VLAN tag than it was sent out with, an inter-VLAN loop has occurred. To remove the loop, examine the QinQ or VLAN mapping configuration for incorrect settings. For more information about QinQ and VLAN mapping, see "Configuring QinQ" and "Configuring VLAN mapping."
Figure 1 Ethernet frame header for loop detection
The Ethernet frame header of a loop detection packet contains the following fields:
· DMAC—Destination MAC address of the frame, which is the multicast MAC address 010f-e200-0007. When a loop detection-enabled device receives a frame with this destination MAC address, it performs the following operations:
¡ Sends the frame to the CPU.
¡ Floods the frame in the VLAN from which the frame was originally received.
· SMAC—Source MAC address of the frame, which is the bridge MAC address of the sending device.
· TPID—Type of the VLAN tag, with the value of 0x8100.
· TCI—Information of the VLAN tag, including the priority and VLAN ID.
· Type—Protocol type, with the value of 0x8918.
Figure 2 Inner frame header for loop detection
The inner frame header of a loop detection packet contains the following fields:
· Code—Protocol sub-type, which is 0x0001, indicating the loop detection protocol.
· Version—Protocol version, which is always 0x0000.
· Length—Length of the frame. The value includes the inner header, but excludes the Ethernet header.
· Reserved—This field is reserved.
Frames for loop detection are encapsulated as TLV triplets.
Table 1 TLVs supported by loop detection
TLV |
Remarks |
End of PDU |
End of a PDU. |
Optional. |
Device ID |
Bridge MAC address of the sending device. |
Required. |
Port ID |
ID of the PDU sending port. |
Optional. |
Port Name |
Name of the PDU sending port. |
Optional. |
System Name |
Device name. |
Optional. |
Chassis ID |
Chassis ID of the sending port. |
Optional. |
Slot ID |
Slot ID of the sending port. |
Optional. |
Sub Slot ID |
Sub-slot ID of the sending port. |
Optional. |
Loop detection interval
Loop protection actions
When detecting a loop on a port, the device by default logs the loop event without taking any action on the port. You can configure the device to take one of the following actions:
· Block—Disables the port from learning MAC addresses and blocks the port.
· No-learning—Disables the port from learning MAC addresses.
· Shutdown—Shuts down the port to disable it from receiving and sending any frames.
Port status auto recovery
When the device configured with the block or no-learning loop action detects a loop on a port, it performs the action and waits three loop detection intervals. If the device does not receive a loop detection frame within three loop detection intervals, it performs the following operations:
· Automatically sets the port to the forwarding state.
· Notifies the user of the event.
When the device configured with the shutdown action detects a loop on a port, the following events occur:
1. The device automatically shuts down the port.
2. The device automatically sets the port to the forwarding state after the detection timer set by using the shutdown-interval command expires. For more information about the shutdown-interval command, see Fundamentals Command Reference.
3. The device shuts down the port again if a loop is still detected on the port when the detection timer expires.
This process is repeated until the loop is removed.
NOTE: Incorrect recovery can occur when loop detection frames are discarded to reduce the load. To avoid this, use the shutdown action, or manually remove the loop. |
This feature is supported only on the Layer 2 Ethernet ports on Ethernet switching modules.
To configure loop detection, perform the following tasks:
¡ Enabling loop detection globally
¡ Enabling loop detection on a port
2. (Optional) Setting the loop protection action
¡ Setting the global loop protection action
¡ Setting the loop protection action on an interface
3. (Optional) Setting the loop detection interval
When you enable loop detection, follow these restrictions and guidelines:
· You can enable loop detection globally or on a per-port basis. When a port receives a detection frame in any VLAN, the loop protection action is triggered on that port, regardless of whether loop detection is enabled on it.
1. Enter system view.
2. Globally enable loop detection.
loopback-detection global enable vlan { vlan-id--list | all }
By default, loop detection is globally disabled.
2. Enter Layer 2 Ethernet interface view or Layer 2 aggregate interface view.
3. Enable loop detection on the port.
loopback-detection enable vlan { vlan-id-list | all }
By default, loop detection is disabled on ports.
You can set the loop protection action globally or on a per-port basis. The global action applies to all ports. The per-port action applies to the individual ports. The per-port action takes precedence over the global action.
2. Set the global loop protection action.
loopback-detection global action shutdown
By default, the device logs the event without taking any action on the port on which a loop is detected.
2. Enter interface view.
3. Set the loop protection action on the interface.
loopback-detection action { block | no-learning | shutdown }
By default, the device logs the event without taking action on the port on which a loop is detected.
Support for the keywords of this command varies by interface type. For more information, see Layer 2—LAN Switching Command Reference.
With loop detection enabled, the device sends loop detection frames at the loopback detection interval. A shorter interval offers more sensitive detection but consumes more resources. Consider the system performance and loop detection speed when you set the loop detection interval.
2. Set the loop detection interval.
loopback-detection interval-time interval
The default setting is 30 seconds.
Task |
Command |
Display the loop detection configuration and status. |
display loopback-detection |
As shown in Figure 3, configure Device A to shut down a looped port in addition to logging loop events.
1. Configure Device A:
# Create VLAN 100 and globally enable loop detection for the VLAN.
[DeviceA] vlan 100
[DeviceA-vlan100] quit
[DeviceA] loopback-detection global enable vlan 100
# Configure GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 as trunk ports, and assign them to VLAN 100.
[DeviceA] interface GigabitEthernet 1/0/1
[DeviceA-GigabitEthernet1/0/1] port trunk permit vlan 100
[DeviceA-GigabitEthernet1/0/2] port trunk permit vlan 100
# Set the global loop protection action to shutdown.
[DeviceA] loopback-detection global action shutdown
# Set the loop detection interval to 35 seconds.
[DeviceA] loopback-detection interval-time 35
2. Configure Device B:
# Create VLAN 100.
[DeviceB] vlan 100
[DeviceB–vlan100] quit
[DeviceB-GigabitEthernet1/0/1] port trunk permit vlan 100
[DeviceB-GigabitEthernet1/0/2] port trunk permit vlan 100
3. Configure Device C:
# Create VLAN 100.
<DeviceC> system-view
[DeviceC] vlan 100
[DeviceC–vlan100] quit
[DeviceC-GigabitEthernet1/0/1] port trunk permit vlan 100
[DeviceC-GigabitEthernet1/0/2] port link-type trunk
[DeviceC-GigabitEthernet1/0/2] port trunk permit vlan 100
# View the system logs on devices, for example, Device A.
[DeviceA]
%Feb 24 15:04:29:663 2013 DeviceA LPDT/4/LPDT LOOPED: Loopback exists on GigabitEthernet1/0/1.
%Feb 24 15:04:29:665 2013 DeviceA LPDT/4/LPDT_VLAN_LOOPED: Loopback exists on GigabitEthernet1/0/1 in VLAN 100.
%Feb 24 15:04:29:667 2013 DeviceA LPDT/4/LPDT LOOPED: Loopback exists on GigabitEthernet1/0/2.
%Feb 24 15:04:29:669 2013 DeviceA LPDT/4/LPDT_VLAN_LOOPED: Loopback exists on GigabitEthernet1/0/2 in VLAN 100.
%Feb 24 15:04:44:240 2013 DeviceA LPDT/5/LPDT_RECOVERED: Loopback on GigabitEthernet1/0/1 in VLAN 100 recovered.
%Feb 24 15:04:44:243 2013 DeviceA LPDT/5/LPDT RECOVERED: Loopback on GigabitEthernet1/0/1 recovered.
%Feb 24 15:04:44:245 2013 DeviceA LPDT/5/LPDT_RECOVERED: Loopback on GigabitEthernet1/0/2 in VLAN 100 recovered.
%Feb 24 15:04:44:248 2013 DeviceA LPDT/5/LPDT RECOVERED: Loopback on GigabitEthernet1/0/2 recovered.
· Device A detected loops on GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 within a loop detection interval.
· Loops on GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 were removed.
# Use the display loopback-detection command to display the loop detection configuration and status on devices, for example, Device A.
[DeviceA] display loopback-detection
Loop detection is enabled.
Loop detection interval is 35 second(s).
No loopback is detected.
The output shows that the device has removed the loops from GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2.
# Display the status of GigabitEthernet 1/0/1 on devices, for example, Device A.
[DeviceA] display interface gigabitethernet 1/0/1
GigabitEthernet1/0/1 current state: DOWN (Loop detection down)
The output shows that GigabitEthernet 1/0/1 has been shut down by the loop detection module.
# Display the status of GigabitEthernet 1/0/2 on devices, for example, Device A.
[DeviceA] display interface gigabitethernet 1/0/2
GigabitEthernet1/0/2 current state: DOWN (Loop detection down)
The output shows that GigabitEthernet 1/0/2 has been shut down by the loop detection module.
