| 03-HH3C-STACK-MIB | 366.88 KB |
hh3cStackLocalPhysicalIntfName
hh3cStackPhysicalIntfRxTimeout
hh3cStackMemberPortLoopAlarmRecover
hh3cStackLogicStackPortLinkErr
hh3cStackLogicStackPortLinkErrRecover
HH3C-STACK-MIB
About this MIB
Use this MIB to obtain IRF information and manage IRF fabrics.
MIB file name
hh3c-stack.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cStack(91)
Scalar objects
hh3cStackMaxMember
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cStackMaxMember (1.3.6.1.4.1.25506.2.91.1.1) |
read-only |
Integer32 |
Standard MIB values. |
Maximum number of member devices that an IRF fabric can contain. |
As per the MIB. |
hh3cStackMemberNum
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cStackMemberNum (1.3.6.1.4.1.25506.2.91.1.2) |
read-only |
Integer32 |
Number of member devices that an IRF fabric contains. |
As per the MIB. |
hh3cStackMaxConfigPriority
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cStackMaxConfigPriority (1.3.6.1.4.1.25506.2.91.1.3) |
read-only |
Integer32 |
The maximum priority value that can be assigned to a member device in an IRF fabric. The member priority can affect master election. |
As per the MIB. |
hh3cStackAutoUpdate
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cStackAutoUpdate (1.3.6.1.4.1.25506.2.91.1.4) |
read-write |
IINTEGER |
IINTEGER{ disabled(1), enabled(2) } |
Whether an IRF fabric supports software auto-update. When you add a device to the IRF fabric, software auto-update compares the startup software images of the device with the current software images of the IRF master. If the two sets of images are different, the device automatically performs the following operations: 1. Downloads the current software images of the master. 2. Sets the downloaded images as its main startup software images. 3. Reboots with the new software images to rejoin the IRF fabric. You must manually update the new device with the software images running on the IRF fabric for the device to join the IRF fabric if software auto-update is disabled. |
As per the MIB. |
hh3cStackMacPersistence
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cStackMacPersistence (1.3.6.1.4.1.25506.2.91.1.5) |
read-write |
INTEGER |
INTEGER { notPersist(1), persistForSixMin(2), persistForever(3) } |
Status of the IRF bridge MAC persistence feature. |
As per the MIB. |
hh3cStackLinkDelayInterval
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cStackLinkDelayInterval (1.3.6.1.4.1.25506.2.91.1.6) |
read-write |
Integer32 |
SIZE((0.. 2147483647)) |
IRF link status change report delay, in the range of 1 to 10000 milliseconds. If the value is set to 0, link status change events of IRF ports are reported without any delay. |
As per the MIB. |
hh3cStackTopology
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cStackTopology (1.3.6.1.4.1.25506.2.91.1.7) |
read-only |
INTEGER |
INTEGER { chainConn(1), ringConn(2) } |
Topology type of an IRF fabric. |
As per the MIB. |
hh3cStackDomainId
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cStackDomainId (1.3.6.1.4.1.25506.2.91.1.8) |
read-write |
Unsigned32 |
Domain ID of an IRF fabric. |
As per the MIB. |
hh3cStackPortConfigActivate
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cStackPortConfigActivate (1.3.6.1.4.1.25506.2.91.1.9) |
read-write |
INTEGER |
INTEGER { none(1), set(2) } |
Whether to activate IRF port configuration. |
As per the MIB. |
hh3cStackPhysicalIntfName
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cStackPhysicalIntfName (1.3.6.1.4.1.25506.2.91.6.1.1) |
accessible-for-notify |
OCTET STRING |
OCTET STRING (1..255) |
IRF physical interface name. |
As per the MIB. |
hh3cStackMacAddress
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cStackMacAddress (1.3.6.1.4.1.25506.2.91.6.1.2) |
OCTET STRING |
OCTET STRING (6) |
MAC address of the IRF member device. |
As per the MIB. |
hh3cStackMemberThreshold
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cStackMemberThreshold (1.3.6.1.4.1.25506.2.91.6.1.3) |
OCTET STRING |
Maximum number of IRF member devices. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cStackLocalPhysicalIntfName (1.3.6.1.4.1.25506.2.91.6.1.4) |
OCTET STRING |
Name of the local IRF physical interface. |
As per the MIB. |
hh3cStackPeerPhysicalIntfName
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cStackPeerPhysicalIntfName (1.3.6.1.4.1.25506.2.91.6.1.5) |
OCTET STRING |
Name of the peer IRF physical interface. |
As per the MIB. |
hh3cStackLinkErrReason
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cStackLinkErrReason (1.3.6.1.4.1.25506.2.91.6.1.6) |
OCTET STRING |
DisplayString (1..512) |
Connection failure cause. |
As per the MIB. |
hh3cStackLocalSlotID
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cStackLocalSlotID (1.3.6.1.4.1.25506.2.91.6.1.7) |
Integer32 |
Slot number of the IRF member. |
As per the MIB. |
hh3cStackPeerSlotID
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cStackPeerSlotID (1.3.6.1.4.1.25506.2.91.6.1.8) |
Integer32 |
Slot number of the peer IRF member. |
As per the MIB. |
hh3cStackSetUpFailureReason
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cStackSetUpFailureReason (1.3.6.1.4.1.25506.2.91.6.1.9) |
OCTET STRING |
Stacking failure cause. |
As per the MIB. |
Tabular objects
hh3cStackDeviceConfigTable
About this table
This table contains parameters about each IRF member device in an IRF fabric.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Not supported |
Columns
The table index is entPhysicalIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cStackMemberID (1.3.6.1.4.1.25506.2.91.2.1.1) |
read-only |
Integer32 |
IRF member ID of a member device. The member ID must be unique in the IRF fabric. |
As per the MIB. |
hh3cStackConfigMemberID (1.3.6.1.4.1.25506.2.91.2.1.2) |
read-write |
Integer32 |
IRF member ID that will take effect at the next startup. |
As per the MIB. |
hh3cStackPriority (1.3.6.1.4.1.25506.2.91.2.1.3) |
read-write |
Integer32 |
IRF priority of the member device. The priority can affect master election. |
As per the MIB. |
hh3cStackPortNum (1.3.6.1.4.1.25506.2.91.2.1.4) |
read-only |
Integer32 |
Number of IRF ports enabled on the member device. |
As per the MIB. |
hh3cStackPortMaxNum (1.3.6.1.4.1.25506.2.91.2.1.5) |
read-only |
Integer32 |
Maximum number of IRF ports supported by the member device. |
As per the MIB. |
hh3cStackBoardConfigTable
About this table
This table contains role information about each board in an IRF fabric. For modular devices, a board refers to an MPU. For fix-port devices or expandable fixed-port devices, a board refers to an IRF member device.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Not supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cStackBoardRole (1.3.6.1.4.1.25506.2.91.3.1.1) |
read-only |
INTEGER |
INTEGER { slave(1), master(2), loading(3), other(4) } |
IRF role of a board. |
As per the MIB. |
hh3cStackBoardBelongtoMember (1.3.6.1.4.1.25506.2.91.3.1.2) |
read-only |
Integer32 |
IRF member ID of the member device where the board resides. |
As per the MIB. |
hh3cStackPortInfoTable
About this table
This table contains IRF port information about each member device in an IRF fabric.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Not supported |
Columns
The table indexes are hh3cStackMemberID and hh3cStackPortIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cStackPortIndex (1.3.6.1.4.1.25506.2.91.4.1.1) |
Integer32 |
Logical index of an IRF port on a member device. |
As per the MIB. |
hh3cStackPortEnable (1.3.6.1.4.1.25506.2.91.4.1.2) |
read-only |
INTEGER |
INTEGER { disabled(1), enabled(2) } |
Whether the IRF port has been enabled. If IRF physical interfaces have been bound to the IRF port, the IRF port is enabled. If no IRF physical interface has been bound to the IRF port, the IRF port is disabled. |
As per the MIB. |
hh3cStackPortStatus (1.3.6.1.4.1.25506.2.91.4.1.3) |
read-only |
INTEGER |
INTEGER { up(1), down(2), silent(3), disabled(4) } |
Link status of the IRF port. |
As per the MIB. |
hh3cStackNeighbor (1.3.6.1.4.1.25506.2.91.4.1.4) |
read-only |
Integer32 |
IRF member ID of the member device connected to the IRF port. |
As per the MIB. |
hh3cStackPortForwardingPath(1.3.6.1.4.1.25506.2.91.4.1.5) |
read-only |
OCTET STRING |
Forwarding path information for traffic from the IRF port to other member devices in the IRF fabric. The return value is a string of comma-separated IRF member IDs and the string ends with \0. |
As per the MIB. |
hh3cStackPhyPortInfoTable
About this table
This table contains information about IRF physical interfaces.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Not supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cStackBelongtoPort (1.3.6.1.4.1.25506.2.91.5.1.1) |
read-write |
Integer32 |
Logical index of an IRF port to which an IRF physical interface is bound. |
As per the MIB. |
Notifications
hh3cStackPortLinkStatusChange
Basic information
OID |
event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.91.6.0.1 |
The link status of an IRF port changed. |
Informational |
Warning |
N/A |
ON |
Notification triggers
This notification is generated when the link status of an IRF port changes.
System impact
The system impact differs depending on the link state change.
Link state change |
Impact |
up |
A minimum of one member link of the IRF port comes up. IRF merge might occur if the IRF fabric has split because the IRF port went down. |
down |
All member links of the IRF port go down. IRF split might occur. |
silent |
The member device will be isolated. |
disabled |
Status control
This notification cannot be disabled.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.91.2.1.1 (hh3cStackMemberID) |
IRF member ID. |
entPhysicalIndex |
Integer32 |
1.3.6.1.4.1.25506.2.91.4.1.1 (hh3cStackPortIndex) |
IRF port index. |
hh3cStackMemberID hh3cStackPortIndex |
Integer32 |
1.3.6.1.4.1.25506.2.91.4.1.3 (hh3cStackPortStatus) |
INTEGER |
up(1) down(2) silent(3) disabled(4) |
Recommended action
If the IRF port is up, no action is required.
If the IRF port is down, perform the following tasks to resolve the issue:
1. Check the operating status of the IRF fabric.
¡ If the IRF fabric is being established, verify that the IRF port is up after the IRF fabric is established.
¡ If the IRF fabric has been established, execute the display irf link command to check the link for connectivity issues and resolve the issues.
2. If the issue persists, contact H3C Support.
If the IRF port is silent, perform the following tasks to resolve the issue:
2. If the IRF fabric is not established, check the member links of the IRF port for connectivity issues and make sure the two ends of the IRF links are compatible in configuration and other aspects as required.
3. If the issue persists, contact H3C Support for help.
If the IRF port is disabled, perform the following tasks to resolve the issue:
1. Bind physical interfaces to the IRF port to establish IRF links.
2. Verify that the IRF port comes up.
3. If the issue persists, contact H3C Support.
hh3cStackTopologyChange
Basic information
OID |
event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.91.6.0.2 |
The topology type of an IRF fabric changed. |
Informational |
Major |
N/A |
ON |
This notification is generated when the topology type of an IRF fabric changes.
System impact
Robustness of the IRF fabric might increase or decrease.
System impact
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.91.1.7 (hh3cStackTopology) |
N/A |
INTEGER |
chainConn(1) ringConn(2) |
Recommended action
No action is required in the following situations:
· The topology is administratively changed.
· The topology changes when the IRF fabric is being established.
· The topology changes from a daisy chain topology to a ring topology.
If the topology changes from ring to daisy chain in other situations, take the following actions to resolve the issue:
1. Execute the display irf and display irf link commands to check for faulty links.
2. If the topology change results from a link failure, recover the failed link.
3. If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
hh3cStackMadBfdChangeNormal
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.91.6.0.3 |
The state of BFD MAD changed to normal. |
Recovery |
Warning |
N/A |
ON |
This notification is generated when the state of BFD MAD changes to normal.
System impact
No negative impact on the system.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.2.1.2.2.1.1 (ifIndex) |
Index of the BFD MAD-enabled interface. |
ifIndex |
InterfaceIndex |
Integer32 (1..2147483647) |
1.3.6.1.2.1.2.2.1.2 ( ifDescr) |
BFD MAD interface name. |
ifIndex |
OCTET STRING |
OCTET STRING (0..255) |
Recommended action
No action is required.
hh3cStackMadBfdChangeFailure
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.91.6.0.4 |
The state of BFD MAD changed to faulty. |
Error |
Warning |
ON |
This notification is generated when the state of BFD MAD changes to faulty.
System impact
BFD MAD cannot operate to detect IRF split.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
ifIndex |
InterfaceIndex |
1.3.6.1.2.1.2.2.1.2 (ifDescr) |
ifIndex |
OCTET STRING |
Recommended action
To resolve this issue:
1. Verify that the configuration is correct.
2. Execute the display mad verbose command to verify that the MAD status is Normal.
3. If the MAD status is not Normal, execute the display interface interface-name brief command to verify that the interfaces used for BFD MAD are operating correctly.
4. If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
hh3cStackMadLacpChangeNormal
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.91.6.0.5 |
The state of LACP MAD changed to normal. |
Recovery |
Warning |
N/A |
ON |
This notification is generated when the state of LACP MAD changes to normal.
System impact
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Index of the LACP MAD-enabled interface. |
ifIndex |
InterfaceIndex |
LACP MAD interface name. |
ifIndex |
OCTET STRING |
Recommended action
hh3cStackMadLacpChangeFailure
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.91.6.0.6 |
The state of LACP MAD changed to faulty. |
Error |
Warning |
1.3.6.1.4.1.25506.2.91.6.0.5 (hh3cStackMadLacpChangeNormal) |
ON |
This notification is generated when the state of LACP MAD changes to faulty.
System impact
LACP MAD cannot operate to detect IRF split.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
ifIndex |
InterfaceIndex |
ifIndex |
OCTET STRING |
Recommended action
3. If the MAD status is not Normal, execute the display interface interface-name brief command to verify that the interfaces used for MAD are operating correctly.
hh3cStackPhysicalIntfLinkUp
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.91.6.0.7 |
An IRF physical interface came up. |
Recovery |
Warning |
N/A |
ON |
This notification is generated when an IRF physical interface comes up.
System impact
The number of IRF links in up state increases. IRF merge might occur if the IRF fabric has split because all links in the IRF port were down.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
IRF member ID. |
entPhysicalIndex |
Integer32 |
IRF port index. |
Integer32 |
1.3.6.1.4.1.25506.2.91.6.1.1 (hh3cStackPhysicalIntfName) |
N/A |
OCTET STRING |
Recommended action
hh3cStackPhysicalIntfLinkDown
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.91.6.0.8 |
An IRF physical interface went down. |
Error |
Warning |
1.3.6.1.4.1.25506.2.91.6.0.7 (hh3cStackPhysicalIntfLinkUp) |
ON |
This notification is generated when an IRF physical interface goes down.
System impact
The number of IRF links in up state decreases. If all IRF links of an IRF port go down, IRF fabric might split.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
IRF member ID. |
entPhysicalIndex |
Integer32 |
IRF port index. |
Integer32 |
N/A |
OCTET STRING |
Recommended action
1. Execute the display interface command to identify the state of the IRF physical interface and its failure cause.
2. Resolve the interface issue as instructed.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.91.6.0.9 |
An IRF physical interface cannot receive IRF protocol packets. |
Informational |
Warning |
N/A |
ON |
This notification is generated when an IRF physical interface cannot receive IRF protocol packets.
System impact
The IRF fabric might malfunction.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
IRF member ID. |
entPhysicalIndex |
Integer32 |
IRF port index. |
Integer32 |
OCTET STRING |
Recommended action
1. Execute the display irf topology command to identify the link state of the IRF port.
2. If the link state is TIMEOUT, check for the heartbeat timeout error message, which indicates that the link of the IRF port is disconnected.
For example, if the link state of IRF port 2 is TIMEOUT, you might have received the IRF port 2 is down because heartbeat timed out. IRF port 2 is down message.
3. To restore link connectivity, make sure a minimum of one fabric module is present and is operating correctly.
hh3cStackMemberAdd
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.91.6.0.10 |
A new IRF member device was added to an IRF fabric. |
Informational |
Warning |
N/A |
ON |
This notification is generated when a new IRF member device is added to an IRF fabric.
System impact
A new member device is added to the IRF fabric.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Member ID of an IRF member device. |
entPhysicalIndex |
Integer32 |
1.3.6.1.4.1.25506.2.91.6.1.2 (hh3cStackMacAddress) |
N/A |
OCTET STRING |
Recommended action
hh3cStackMemberLeave
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.91.6.0.11 |
An IRF member device left an IRF fabric. |
Informational |
Warning |
N/A |
ON |
This notification is generated when an IRF member device leaves an IRF fabric.
System impact
An IRF member device is removed from the IRF fabric. IRF split might occur.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
entPhysicalIndex |
Integer32 |
N/A |
OCTET STRING |
Recommended action
If the member device is administratively removed from the IRF fabric, no action is required.
If the removal of the IRF member device is unexpected, take the following actions:
1. Execute the display irf link command to identify the link state of each physical interface bound to the IRF ports. If a physical interface is down, verify that its cable is securely connected.
2. If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
hh3cStackLinkUp
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.91.6.0.12 |
An IRF port on an IRF member device came up. |
Informational |
Warning |
N/A |
ON |
This notification is generated when an IRF port on an IRF member device comes up.
System impact
The IRF fabric can be established.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
IRF port index. |
Integer32 |
Recommended action
hh3cStackLinkDown
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.91.6.0.13 |
An IRF port on an IRF member device went down. |
Error |
Warning |
1.3.6.1.4.1.25506.2.91.6.0.12 (hh3cStackLinkUp) |
ON |
This notification is generated when an IRF port on an IRF member device goes down.
System impact
Attempt to establish an IRF fabric might fail or IRF split might occur.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
IRF port index |
Integer32 |
Recommended action
2. If a physical interface is down, verify that its cable is securely connected.
hh3cStackLinkMemberLimit
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.91.6.0.14 |
Failed to add a new IRF member device to an IRF fabric after the number of IRF member devices in that IRF fabric has reached the upper limit. |
Informational |
Warning |
N/A |
ON |
This notification is generated when the system fails to add a new IRF member device to an IRF fabric after the number of IRF member devices in that IRF fabric has reached the upper limit.
System impact
No additional devices can be added to the IRF fabric.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.91.6.1.3 (hh3cStackMemberThreshold) |
Maximum number of IRF member devices allowed in an IRF fabric. |
N/A |
OCTET STRING |
Recommended action
To resolve this issue, take either of the following actions:
· If this notification is triggered by an undesirable IRF fabric expansion or merge, check for miscabling and reconnect the device.
· If you must add the device to the IRF fabric, first remove an existing member device from the IRF fabric.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.91.6.0.15 |
Error packets were forwarded on an IRF port in loops. |
Error |
Warning |
1.3.6.1.4.1.25506.2.91.6.0.16 (hh3cStackMemberPortLoopAlarmRecover) |
ON |
This notification is generated when error packets are forwarded on an IRF port in loops.
System impact
A high percentage of bandwidth is consumed by looped error packets.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
IRF port index. |
Integer32 |
Recommended action
Collect alarm information, log messages, and configuration data, and then contact H3C Support for help.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.91.6.0.16 |
The conditions that error packets were forwarded on an IRF port in loops were cleared. |
Recovery |
Warning |
N/A |
ON |
This notification is generated when the conditions that error packets are forwarded on an IRF port in loops are cleared.
System impact
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
IRF port index. |
Integer32 |
Recommended action
hh3cStackBrigdgeMacChange
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.91.6.0.17 |
The bridge MAC address of an IRF fabric changed. |
Informational |
Warning |
N/A |
ON |
This notification is generated when the bridge MAC address of an IRF fabric changes to the MAC address of the new mater device.
System impact
Traffic might be interrupted.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
entPhysicalIndex |
Integer32 |
Recommended action
1. Execute the display irf command to identify the bridge MAC address of the IRF fabric.
2. If two IRF fabrics on the network use the same bridge MAC address, execute the irf mac-address mac-address command to reassign a bridge MAC address to either of the IRF fabrics.
3. If the issue persists, collect alarm information, log messages, and configuration data, and then contact H3C Support for help.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.91.6.0.18 |
IRF port connection error. |
Error |
Warning |
1.3.6.1.4.1.25506.2.91.6.0.19 (hh3cStackLogicStackPortLinkErrRecover) |
ON |
This notification is generated when an IRF port connection error is detected.
System impact
IRF fabric cannot be established.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.91.6.1.4 (hh3cStackLocalPhysicalIntfName) |
N/A |
OCTET STRING |
1.3.6.1.4.1.25506.2.91.6.1.5 (hh3cStackPeerPhysicalIntfName) |
N/A |
OCTET STRING |
1.3.6.1.4.1.25506.2.91.6.1.6 (hh3cStackLinkErrReason) |
Connection error reason. |
N/A |
OCTET STRING |
DisplayString (1..512)) |
Recommended action
1. Execute the display irf link command to identify the member physical interfaces of the local and peer IRF ports.
2. Verify that the physical interfaces of IRF-port 1 on one member are connected to the physical interfaces of IRF-port 2 on the other.
Basic information
OID |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.91.6.0.19 |
An IRF port connection error was removed. |
Recovery |
Warning |
N/A |
ON |
This notification is generated when an IRF port connection error is removed.
System impact
The IRF fabric can be established or restored.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
N/A |
OCTET STRING |
N/A |
OCTET STRING |
N/A |
OCTET STRING |
Recommended action
hh3cStackPortConfigureFailure
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.91.6.0.20 |
IRF port configuration failed. |
Informational |
Warning |
N/A |
ON |
This notification is generated when IRF port configuration fails.
System impact
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
IRF member ID. |
entPhysicalIndex |
Integer32 |
Recommended action
1. Verify that the physical interfaces assigned to the IRF port can be used for IRF setup and do not exceed the maximum number of physical interfaces for an IRF port.
2. Take action depending on the cause of the issue:
¡ Change the physical interfaces if they cannot be used for IRF setup because of their interface type or any other restrictions.
¡ Reduce the number of physical interfaces assigned to the IRF port if the limit is exceeded.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.91.6.0.21 |
IRF fabric setup failed. |
Informational |
Warning |
N/A |
ON |
This notification is generated when IRF fabric setup fails.
System impact
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.91.6.1.7 (hh3cStackLocalSlotID) |
N/A |
Integer32 |
1.3.6.1.4.1.25506.2.91.6.1.8 (hh3cStackPeerSlotID) |
N/A |
Integer32 |
1.3.6.1.4.1.25506.2.91.6.1.9 (hh3cStackSetUpFailureReason) |
N/A |
OCTET STRING |
Recommended action
1. Verify that the candidate member devices meet the hardware, software, and configuration requirements for IRF setup. To identify the device models and other hardware information, execute the display version command.
2. Verify that the candidate member devices have the same settings for features that require consistency, including settings for the display system-working-mode and display max-ecmp-num commands.
