03-Interface
HomeSupportReference GuidesMIB CompanionH3C S6826 & S9826 MIB Companion-Release 6715-6W10003-Interface
01-HH3C-IF-EXT-MIB
01-HH3C-IF-EXT-MIB 1.14 MB
HH3C-IF-EXT-MIB· 1
About this MIB· 1
MIB file name· 1
Root object 1
Scalar objects· 1
hh3cIfStatGlobalFlowInterval 1
hh3cIfShutDownInterval 1
hh3cIfChassisIndex· 1
hh3cIfSlotIndex· 2
hh3cIfSubSlotIndex· 2
hh3cIfErrDownDesc· 2
hh3cIfCpuId· 2
hh3cIfOldComboType· 3
hh3cIfNewComboType· 3
hh3cIfDropRateThreshold· 3
hh3cIfCurrentDropRate· 3
hh3cIfDropRateInterval 4
hh3cIfMessageProtocol 4
hh3cIfCurrentFlowThreshold· 12
hh3cIfCurrentFlowValue· 12
hh3cIfCurrentUsedRatio· 13
hh3cIfUsedRatioThreshold· 13
hh3cIfDiscardType· 13
hh3cIfDiscardThreshold· 13
Tabular objects· 14
hh3cIfFlowStatTable· 14
hh3cIfSpeedStatTable· 15
hh3cIfHCFlowStatTable· 17
hh3cRTParentIfTable· 18
hh3cRTSubIfTable· 19
hh3cIfLinkModeTable· 20
hh3cIfPortTypeTable· 21
hh3cIfTable· 21
hh3cIfUsingTable· 23
hh3cIfQueBufferTable· 24
hh3cIfHCSpeedStatTable· 27
hh3cIfExtTrapCfgTable· 28
hh3cIfPfcDot1pTable· 29
Notifications· 30
hh3cIfPortUp· 30
hh3cIfPortDown· 31
hh3cIfMonInputUsageRising· 33
hh3cIfMonInputUsageResume· 34
hh3cIfMonOutputUsageRising· 35
hh3cIfMonOutputUsageResume· 37
hh3cIfMonInputErrorAlarmRising· 38
hh3cIfMonInputErrorAlarmResume· 40
hh3cIfMonOutputErrorAlarmRising· 41
hh3cIfMonOutputErrorAlarmResume· 43
hh3cIfMonSdhErrorRising· 44
hh3cIfMonSdhErrorResume· 46
hh3cIfMonSdhB1ErrorRising· 47
hh3cIfMonSdhB1ErrorResume· 49
hh3cIfMonSdhB2ErrorRising· 50
hh3cIfMonSdhB2ErrorResume· 52
hh3cIfMonCRCErrorRising· 53
hh3cIfMonCRCErrorResume· 55
hh3cIfMonRxPauseFrameRising· 56
hh3cIfMonRxPauseFrameResume· 58
hh3cIfMonTxPauseFrameRising· 60
hh3cIfMonTxPauseFrameResume· 61
hh3cIfMonGiantRising· 63
hh3cIfMonGiantResume· 64
hh3cIfMonRuntRising· 66
hh3cIfMonRuntResume· 67
hh3cIfPfcOutRising· 68
hh3cIfInPfcRising· 70
hh3cIfBufferInDiscardAlarm·· 71
hh3cIfBufferInDiscardResume· 72
hh3cIfHalfDuplexRising· 73
hh3cIfChangeMultiChassis· 74
hh3cIfChangeMultiChassisResume· 75
hh3cIfCfgRecoverOverSlot 76
hh3cIfCfgRecoverOverSubSlot 77
hh3cIfInterfaceDelete· 78
hh3cIfErrordown· 78
hh3cIfErrordownRecovery· 82
hh3cIfHalfDuplexClear 83
hh3cIfEgressDropAlarm·· 84
hh3cIfEgressDropRecover 85
hh3cIfBoardEgressDropAlarm·· 86
hh3cIfBoardEgressDropRecover 87
hh3cIfComboTypeChange· 88
hh3cIfIngressAgingDropAlarm·· 89
hh3cIfIngressAgingDropResume· 90
hh3cIfMonInputJamDiscardAlarm·· 91
hh3cIfMonInputJamDiscardResume· 93
hh3cIfMonOutputJamDiscardAlarm·· 94
hh3cIfMonOutputJamDiscardResume· 96
hh3cIfMonPktDropRateRising· 97
hh3cIfMonPktDropRateRecover 99
hh3cIfMonBadBytesErrorRising· 101
hh3cIfMonBadBytesErrorResume· 102
hh3cIfMonPortCrcRateExceed· 103
hh3cIfMonPortErrorRateExceed· 105
hh3cIfMonInBCRapidChange· 106
hh3cIfMonInBCRapidRecover 108
hh3cIfMonPortCrcRateExceedResume· 109
hh3cIfFlowControlDLAlarm·· 110
hh3cIfFlowControlDLAlarmResume· 111
hh3cIfOutputErrorAlarm·· 112
hh3cIfOutputErrorAlarmResume· 113
hh3cIfCableSnrAbnormal 114
hh3cIfCableSnrNormal 115
hh3cIfCableSnrDetectNotSupport 116
hh3cIfSfpNotSupportSingleFiber 117
hh3cIfLRMStateAbnormal 118
hh3cIfSfpWorkOnlyNonNego· 119
hh3cIfPfcDeadLockAlarm·· 120
hh3cIfPfcDeadLockResume· 122
hh3cIfPfcTurnOffAlarm·· 123
hh3cIfPfcTurnOffResume· 124
hh3cIfQueueAlarm·· 126
hh3cIfQueueResume· 127
hh3cIfQueueStatDiscardAlarm·· 129
hh3cIfQueueStatDiscardResume· 130
hh3cIfQueueEgressCongestionAlarm·· 132
hh3cIfQueueEgressCongestionClear 133
hh3cIfAggPortBwChange· 134
hh3cIfRateOfTrafficRising· 135
HH3C-IF-EXT-MIB
About this MIB
Use this MIB to manage and describe interfaces.
MIB file name
hh3c-if-ext.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cIfExt(40)
Scalar objects
Object (OID)
Access
Value range
Implementation
hh3cIfStatGlobalFlowInterval (1.3.6.1.4.1.25506.2.40.1.1)
read-write
Integer32
Integer32(0..2147483647)
Global statistics polling interval. 0 indicates the traffic statistics collection feature is disabled.
Not supported
Object (OID)
Access
Value range
Implementation
hh3cIfShutDownInterval (1.3.6.1.4.1.25506.2.40.1.2)
read-write
Integer32
Integer32(1..2147483647)
Port status detection timer.
0..300
hh3cIfChassisIndex
Object (OID)
Access
Value range
Implementation
hh3cIfChassisIndex (1.3.6.1.4.1.25506.2.40.1.6)
accessible-for-notify
Integer32
0-65535
Actual interface bandwidth.
As per the MIB.
hh3cIfSlotIndex
Object (OID)
Access
Value range
Implementation
hh3cIfSlotIndex (1.3.6.1.4.1.25506.2.40.1.7)
Integer32
0-65535
As per the MIB.
hh3cIfSubSlotIndex
Object (OID)
Access
Value range
Implementation
hh3cIfSubSlotIndex (1.3.6.1.4.1.25506.2.40.1.8)
Integer32
0-65535
As per the MIB.
hh3cIfErrDownDesc
Object (OID)
Access
Value range
Implementation
hh3cIfErrDownDesc (1.3.6.1.4.1.25506.2.40.1.9)
DisplayString
OCTET STRING(0..255)
Error-down description.
As per the MIB.
hh3cIfCpuId
Object (OID)
Access
Value range
Implementation
hh3cIfCpuId (1.3.6.1.4.1.25506.2.40.1.21)
Unsigned32
0-65535
CPU ID of a card.
As per the MIB.
hh3cIfOldComboType
Object (OID)
Access
Value range
Implementation
hh3cIfOldComboType (1.3.6.1.4.1.25506.2.40.1.22)
INTEGER
fiber(1),
copper(2)
Combo interface type before change
As per the MIB.
hh3cIfNewComboType
Object (OID)
Access
Value range
Implementation
hh3cIfNewComboType (1.3.6.1.4.1.25506.2.40.1.23)
INTEGER
fiber(1),
copper(2)
Combo interface type after change
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cIfDropRateThreshold (1.3.6.1.4.1.25506.2.40.1.24)
Integer32
Integer32(0..1000)
Threshold for the packet loss rate
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cIfCurrentDropRate (1.3.6.1.4.1.25506.2.40.1.25)
Integer32
Current packet loss rate
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cIfDropRateInterval (1.3.6.1.4.1.25506.2.40.1.26)
Integer32
Packet loss rate period
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cIfMessageProtocol (1.3.6.1.4.1.25506.2.40.1.27)
Integer32
1:ISIS
2:ESIS
3:CLNP
4:VRRP
5:UNKNOWN_IPV4MC
6:UNKNOWN_IPV6MC
7:IPV4_MCAST_RIP
8:IPV4_BCAST_RIP
9:MCAST_NTP
10:BCAST_NTP
11:IPV4_MCAST_OSPF_5
12:IPV4_MCAST_OSPF_6
13:IPV4_UCAST_OSPF
14:IPV4_MCAST_PIM
15:IPV4_UCAST_PIM
16:IPV4_IGMP
17:UCAST_LDP
18:IPV6_MCAST_PIM
19:IPV6_UCAST_PIM
20:IPV6_MLD
21:IPV6_RIPNG
22:IPV6_UCAST_OSPFV3
23:IPV6_MCAST_OSPFV3_5
24:IPV6_MCAST_OSPFV3_6
25:IPV6_LDP
26:IPV6_VRRP
27:IPV6_VRRP_DHCPV6
28:RRPP
29:IPV4_AUTORP
30:ARP
31:ARP_REPLY
32:DHCP_CLIENT
33:DHCP_SERVER
34:DHCP_RELAY_CLIENT
35:DHCP_RELAY_SERVER
36:DOT1X
37:STP
38:LACP
39:GVRP
40:HGMP
41:UCAST_BGP
42:UCAST_ICMP
43:UCAST_TTL
44:UCAST_IPOPTION
45:IPV6_BGP
46:IPV6_ND_PASS
47:IPV6_ND_DEST
48:IPV6_PING
49:IPV6_TTL
50:IPV6_IPOPTION
51:IPV6_DHCP
52:LOOPBACKDETECTION
53:LOOP_TEST
54:LLDP
55:DLDP
56:LSP_PING
57:BPDU_TUNNEL_DEF
58:BPDU_TUNNEL_MAC0
59:BPDU_TUNNEL_MAC1
60:BPDU_TUNNEL_MAC2
61:MSDP
62:TELNET_SSH
63:HTTP_HTTPS
64:SNMP
65:SMLK
66:DOT1AG
67:CDP
68:ARP_DAI
69:ARP_DAI_VLAN
70:ACSEI
71:UCAST_NTP
72:MD
73:IPV4_UC_DHCP
74:IPV4_UC_OSPF_TTL
75:IPV4_UC_PIM_TTL
76:IPV4_UC_BGP_TTL
77:UKNOWN_SMAC
78:IPV6_ICMP
79:IPV6_TELNET_SSH
80:MPLS_RSVP
81:HGMP_BC
82:GMRP
83:PVST
84:SNAP_CIS
85:OAM
86:EAPOL_BRIDGEMAC
87:WPI_BRIDGEMAC
88:CFD_BRIDGEMAC
89:HGMP_BRIDGEMAC
90:ACSEI_BRIDGEMAC
91:IPV6_DHCPUC_CLIENT
92:IPV6_DHCPUC_RELAY
93:IPV6_DHCP_RELAY_SERVER
94:RRPP_FD
95:BFD_ARPREPLY
96:MAC_BASEVLAN
97:TUNNEL
98:BFD_ECHO
99:BFD_CTRL
100:BFD_DEFAULTMADBFD
101:BFD_MULTIHOP
102:L2_STATIONMOVE
103:IPV6_ND_DAI
104:IPV6_ND_RA
105:IPV6_ND_DAI_VLAN
106:IPV6_ND_RA_VLAN
107:IPV6_DHCP_CLIENT
108:IPV6_DHCP_SERVER
109:ICMP_RDM
110:IPV6_CPUDST_CAR
111:PTP
112:FCOE_FIP_UC
113:FCOE_TO_CPU
114:IPV6_UCAST_RTRENUM
115:IPV6_MCAST_RTRENUM
116:IPV6_UCAST_NTP
117:IPV6_MCAST_NTP
118:TRILL_ALLISIS
119:TRILL_STP
120:VDP
121:IPV4_MCAST_CBT
122:FCOE_ROUTE
123:ISSU_RELAY
124:PTP_UDP
125:VXLAN_UDP
126:CAPWAP
127:OFP_MISS
128:OFP_MATCH
129:OFP_DEVCONF_TTL
130:OFP_MACIP_MISS
131:SPBM
132:FTP_CTRL
133:BFD_INTF_CTRL
134:ROUTE_TO_CPU_MASK
135:VSRP_CONTROL
136:IPV6_VSRP_CONTROL
137:IPSEC_ESP_AH_OSPFV3
138:IPSEC_ESP_AH_OSPFV3_UC
139:IPSEC_ESP_AH_RIPNG
140:SMARTMC_UC
141:SMARTMC_BC
142:IPV6_ND_NA_OVERLAY
143:IPV6_ND_NS_OVERLAY
144:IPV6_ND_RA_OVERLAY
145:IPV6_ND_RS_OVERLAY
146:IPV6_ND_RR_OVERLAY
147:MDNS
148: DRV_RXTX_PPPOE
149:VSRP_DHCP4
150:DRCP
151:RLINK_NORMAL
152:RLINK_MIDDLE
153:RLINK_HIGH
154:RLINKEXT_NORMAL
155:RLINKEXT_MIDDLE
156:RLINKEXT_HIGH
157:LOOPBACKDETECTION_DRNI
158:SADP_HIK_PRIVATE
159:LOOPBACKDETECTION_VSI
160:IPV4_SIP
161:IPV4_EMDI
162:IPV6_ND_DAI_PORT
163:IPV6_ND_RA_MLAG
164:TWAMP
165:IPV6_IPSG
166:ARP_DAI_PORT
167:L2PT_PASS
168:IPV4_SIPH225
169:IPV4_SIPH245
170:TYPE_ERPS
171:ONVIFv4
172:ONVIFv6
173:DOT11CAPWAP
174:ESMC
175:ARP_DETECTION
176:ND_DETECTION
177:MDNS_GATE_WAY
Packet protocol
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cIfCurrentFlowThreshold (1.3.6.1.4.1.25506.2.40.1.28)
Counter64
Counter64
(0..18446744073709551615)
Current traffic threshold
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cIfCurrentFlowValue (1.3.6.1.4.1.25506.2.40.1.29)
Counter64
Counter64
Current traffic value
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cIfCurrentUsedRatio (1.3.6.1.4.1.25506.2.40.1.30)
Unsigned32
Unsigned32 (0..4294967295)
Current queue usage
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cIfUsedRatioThershold (1.3.6.1.4.1.25506.2.40.1.31)
Unsigned32
Queue usage threshold
As per the MIB.
hh3cIfDiscardType
Object (OID)
Access
Value range
Implementation
hh3cIfDiscardType (1.3.6.1.4.1.25506.2.40.1.32)
INTEGER
discardstat(1)
discardByte(2)
discardrate(3)
Packet loss type
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cIfDiscardThreshold (1.3.6.1.4.1.25506.2.40.1.33)
Counter64
Counter64
Packet loss threshold
As per the MIB.
Tabular objects
hh3cIfFlowStatTable
About this table
Use this table to obtain the interface traffic information.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is ifIndex.
Object (OID)
Access
Value range
Implementation
hh3cIfStatFlowInterval (1.3.6.1.4.1.25506.2.40.2.1.2.1.1.1)
read-write
Integer32
Integer32(1..300)
Traffic statistics polling interval.
Implementation varies by product.
hh3cIfStatFlowInBits (1.3.6.1.4.1.25506.2.40.2.1.2.1.1.2)
read-only
Unsigned32
Incoming traffic in bits.
As per the MIB.
hh3cIfStatFlowOutBits (1.3.6.1.4.1.25506.2.40.2.1.2.1.1.3)
read-only
Unsigned32
Outgoing traffic in bits.
As per the MIB.
hh3cIfStatFlowInPkts (1.3.6.1.4.1.25506.2.40.2.1.2.1.1.4)
read-only
Unsigned32
Incoming traffic in packets.
As per the MIB.
hh3cIfStatFlowOutPkts (1.3.6.1.4.1.25506.2.40.2.1.2.1.1.5)
read-only
Unsigned32
Outgoing traffic in packets.
As per the MIB.
hh3cIfStatFlowInBytes (1.3.6.1.4.1.25506.2.40.2.1.2.1.1.6)
read-only
Unsigned32
Incoming traffic in bytes.
As per the MIB.
hh3cIfStatFlowOutBytes (1.3.6.1.4.1.25506.2.40.2.1.2.1.1.7)
read-only
Unsigned32
Outgoing traffic in bytes.
As per the MIB.
About this table
Use this table to obtain the interface traffic speed statistics.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cIfSpeedStatInterval (1.3.6.1.4.1.25506.2.40.2.1.2.2.1.1)
read-write
Integer32
Integer32(1..300)
Interface traffic speed statistics polling interval. 0 indicates the interface traffic speed statistics collection feature is disabled.
hh3cIfSpeedStatInPkts (1.3.6.1.4.1.25506.2.40.2.1.2.2.1.2)
read-only
Unsigned32
Average incoming traffic speed (in pps) of the interface within the specified interval before the latest sampling point. The interval is specified by h3cIfSpeedStatInterval.
As per the MIB.
hh3cIfSpeedStatOutPkts (1.3.6.1.4.1.25506.2.40.2.1.2.2.1.3)
read-only
Unsigned32
Average outgoing traffic speed (in pps) of the interface within the specified interval before the latest sampling point. The interval is specified by h3cIfSpeedStatInterval.
As per the MIB.
hh3cIfSpeedStatInBytes (1.3.6.1.4.1.25506.2.40.2.1.2.2.1.4)
read-only
Unsigned32
Average incoming traffic speed (in Bps) of the interface within the specified interval before the latest sampling point. The interval is specified by h3cIfSpeedStatInterval.
As per the MIB.
hh3cIfSpeedStatOutBytes (1.3.6.1.4.1.25506.2.40.2.1.2.2.1.5)
read-only
Unsigned32
Average outgoing traffic speed (in Bps) of the interface within the specified interval before the latest sampling point. The interval is specified by h3cIfSpeedStatInterval.
As per the MIB.
About this table
Use this table to obtain the 64-bit traffic information of interfaces.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cIfStatFlowHCInBits (1.3.6.1.4.1.25506.2.40.2.1.2.3.1.1)
read-only
CounterBasedGauge64
Counter64 (0..18446744073709551615)
Incoming traffic in bits (64-bit version).
As per the MIB.
hh3cIfStatFlowHCOutBits (1.3.6.1.4.1.25506.2.40.2.1.2.3.1.2)
read-only
CounterBasedGauge64
Outgoing traffic in bits (64-bit version).
As per the MIB.
hh3cIfStatFlowHCInPkts (1.3.6.1.4.1.25506.2.40.2.1.2.3.1.3)
read-only
CounterBasedGauge64
Incoming traffic in packets (64-bit version).
As per the MIB.
hh3cIfStatFlowHCOutPkts (1.3.6.1.4.1.25506.2.40.2.1.2.3.1.4)
read-only
CounterBasedGauge64
Outgoing traffic in packets (64-bit version).
As per the MIB.
hh3cIfStatFlowHCInBytes (1.3.6.1.4.1.25506.2.40.2.1.2.3.1.5)
read-only
CounterBasedGauge64
Incoming traffic in bytes (64-bit version).
As per the MIB.
hh3cIfStatFlowHCOutBytes (1.3.6.1.4.1.25506.2.40.2.1.2.3.1.6)
read-only
CounterBasedGauge64
Outgoing traffic in bytes (64-bit version).
As per the MIB.
hh3cRTParentIfTable
About this table
Use this table to obtain main interface information of subinterfaces.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cRTParentIfIndex (1.3.6.1.4.1.25506.2.40.2.2.1.1.1)
not-accessible
Integer32
Main interface index. Index of the interface for which you can create subinterfaces.
As per the MIB.
hh3cRTMinSubIfOrdinal (1.3.6.1.4.1.25506.2.40.2.2.1.1.2)
read-only
Integer32
Minimum number of the subinterface that can be created.
As per the MIB.
hh3cRTMaxSubIfOrdinal (1.3.6.1.4.1.25506.2.40.2.2.1.1.3)
read-only
Integer32
Maximum number of the subinterface that can be created.
As per the MIB.
hh3cRTSubIfTable
About this table
Use this table to obtain information about subinterface information of main interfaces.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cRTSubIfParentIfIndex.
Object (OID)
Access
Value range
Implementation
hh3cRTSubIfParentIfIndex (1.3.6.1.4.1.25506.2.40.2.2.2.1.1)
not-accessible
Integer32
As per the MIB.
hh3cRTSubIfOrdinal (1.3.6.1.4.1.25506.2.40.2.2.2.1.2)
not-accessible
Integer32
Subinterface number.
As per the MIB.
hh3cRTSubIfSubIfIndex (1.3.6.1.4.1.25506.2.40.2.2.2.1.3)
read-only
Integer32
Subinterface index.
As per the MIB.
hh3cRTSubIfSubIfDesc (1.3.6.1.4.1.25506.2.40.2.2.2.1.4)
read-only
DisplayString
Subinterface description.
As per the MIB.
hh3cRTSubIfRowStatus (1.3.6.1.4.1.25506.2.40.2.2.2.1.5)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Subinterface state.
Available values are active(1), createAndGo(4), and destroy(6).
hh3cIfLinkModeTable
About this table
Use this table to obtain the interface link mode.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cIfLinkModeIndex.
Object (OID)
Access
Value range
Implementation
hh3cIfLinkModeIndex (1.3.6.1.4.1.25506.2.40.2.2.3.1.1)
not-accessible
Integer32
1..2147483647
Link mode index.
As per the MIB.
hh3cIfLinkMode (1.3.6.1.4.1.25506.2.40.2.2.3.1.2)
read-write
INTEGER
bridgeMode(1),
routeMode(2)
Current link mode of the interface.
As per the MIB.
hh3cIfLinkModeSwitchSupport (1.3.6.1.4.1.25506.2.40.2.2.3.1.3)
read-only
TruthValue
true(1),
false(2)
Whether the link mode of the interface can be switched.
As per the MIB.
hh3cIfPortTypeTable
About this table
Use this table to obtain the port type of an interface.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cIfPortTypeIndex.
Object (OID)
Access
Value range
Implementation
hh3cIfPortTypeIndex (1.3.6.1.4.1.25506.2.40.2.2.4.1.1)
not-accessible
Integer32
Interface index, which is the same as ifIndex in ifTable.
As per the MIB.
hh3cIfPortType (1.3.6.1.4.1.25506.2.40.2.2.4.1.2)
read-write
INTEGER
other(1),ethernet(2),fc(3)
Ethernet/ FC mode of an interface.
As per the MIB.
hh3cIfTable
About this table
Use this table to obtain interface-related information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cIfUpDownTimes.
Object (OID)
Access
Value range
Implementation
hh3cIfUpDownTimes (1.3.6.1.4.1.25506.2.40.2.3.2.1.1)
read-only
Integer32
Number of interface up/down events.
As per the MIB.
hh3cIfMtu (1.3.6.1.4.1.25506.2.40.2.3.2.1.2)
read-write
Integer32
Interface MTU.
As per the MIB.
hh3cIfBandwidthRate (1.3.6.1.4.1.25506.2.40.2.3.2.1.3)
read-only
Integer32
Integer32(0..100)
Interface bandwidth.
Not supported
hh3cIfDiscardPktRate (1.3.6.1.4.1.25506.2.40.2.3.2.1.4)
read-only
Integer32
Integer32(0..100)
Packet loss rate of an interface.
Not supported
hh3cIfStatusKeepTime (1.3.6.1.4.1.25506.2.40.2.3.2.1.5)
read-only
TimeTicks
TimeTicks (0..4294967295)
Duration of the current interface state.
As per the MIB.
hh3cIfInNUcastPkts (1.3.6.1.4.1.25506.2.40.2.3.2.1.6)
read-only
Counter64
Number of incoming non-unicast packets.
Not supported
hh3cIfOutNUcastPkts (1.3.6.1.4.1.25506.2.40.2.3.2.1.7)
read-only
Counter64
Number of outgoing non-unicast packets.
Not supported
hh3cIfIsPoe (1.3.6.1.4.1.25506.2.40.2.3.2.1.8)
read-only
TruthValue
true(1),
false(2)
Support for PoE on an interface.
Not supported
hh3cIfOperStatus (1.3.6.1.4.1.25506.2.40.2.3.2.1.9)
read-only
INTEGER
up(1),
down(2),
testing(3),
admindown(4)
Operational state of an interface.
Not supported
hh3cIfDownTimes (1.3.6.1.4.1.25506.2.40.2.3.2.1.10)
read-only
Integer32
Number of link-down events.
Not supported
hh3cIfPfcStatus (1.3.6.1.4.1.25506.2.40.2.3.2.1.11)
read-write
INTEGER
enable(1),
disable(2),
auto(3)
PFC mode of an interface.
hh3cIfPfcDot1pNoDrop (1.3.6.1.4.1.25506.2.40.2.3.2.1.12)
read-write
BITS
pri0(0), pri1(1), pri2(2), pri3(3), pri4(4), pri5(5), pri6(6), pri7(7)
802.1p priority list for PFC on an interface.
hh3cIfDescription (1.3.6.1.4.1.25506.2.40.2.3.2.1.13)
read-write
DisplayString
Description of an interface.
As per the MIB.
hh3cIfFwdErrDiscards
(1.3.6.1.4.1.25506.2.40.2.3.2.1.14)
read-only
Unsigned32
Number of packets dropped because of forwarding entry errors on an interface.
As per the MIB.
hh3cIfUsingTable
About this table
Use this table to obtain information about breakout interfaces.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cIfUsingIndex.
Object (OID)
Access
Value range
Implementation
hh3cIfUsingIndex (1.3.6.1.4.1.25506.2.40.2.3.3.1.1)
not-accessible
Integer32
Index of an interface that can be split or combined.
As per the MIB.
hh3cIfUsingSupportType (1.3.6.1.4.1.25506.2.40.2.3.3.1.2)
read-only
Integer32
Interface type that an interface can be split or combined into.
As per the MIB.
hh3cIfUsingType (1.3.6.1.4.1.25506.2.40.2.3.3.1.3)
read-write
INTEGER
noUsing(0),
using10GE(1),
using20GE(2),
using40GE(3),
using100GE(4),
using25GE(5),
using50GE(6)
using200GE(7)
using400GE(8)
Interface type that an interface will be split or combined into.
As per the MIB.
hh3cIfUsingStatus (1.3.6.1.4.1.25506.2.40.2.3.3.1.4)
read-only
INTEGER
noUsing(0),
needReboot(1)
State of the splitting or combining operation.
As per the MIB.
About this table
Use this table to obtain the interface buffer information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cIfQueId.
Object (OID)
Access
Value range
Implementation
hh3cIfQueId
(1.3.6.1.4.1.25506.2.40.2.2.6.1.1)
read-only
INTEGER
que0(1),
que1(2),
que2(3),
que3(4),
que4(5),
que5(6),
que6(7),
que7(8)
ID of an interface buffer queue.
As per the MIB.
hh3cIfQueOutUcastTotal
(1.3.6.1.4.1.25506.2.40.2.2.6.1.2)
read-only
Unsigned32
Total buffer of an outbound unicast queue.
As per the MIB.
hh3cIfQueOutUcastFree
(1.3.6.1.4.1.25506.2.40.2.2.6.1.3)
read-only
Unsigned32
Available buffer of an outbound unicast queue.
As per the MIB.
hh3cIfQueOutUcastUsedRatio
(1.3.6.1.4.1.25506.2.40.2.2.6.1.4)
read-only
Unsigned32
Buffer usage of an outbound unicast queue.
As per the MIB.
hh3cIfQueOutUcastUsedPeak
(1.3.6.1.4.1.25506.2.40.2.2.6.1.5)
read-only
Unsigned32
Peak buffer usage of an outbound unicast queue.
As per the MIB.
hh3cIfQueOutUcastThreshold
(1.3.6.1.4.1.25506.2.40.2.2.6.1.6)
read-write
Unsigned32
Buffer alarm threshold of an outbound unicast queue.
As per the MIB.
hh3cIfQueOutUcastOverThres
(1.3.6.1.4.1.25506.2.40.2.2.6.1.7)
read-only
Unsigned32
Number of buffer usage alarms of an outbound unicast queue.
As per the MIB.
hh3cIfQueInTotal
(1.3.6.1.4.1.25506.2.40.2.2.6.1.8)
read-only
Unsigned32
Total buffer of an inbound unicast queue.
As per the MIB.
hh3cIfQueInFree
(1.3.6.1.4.1.25506.2.40.2.2.6.1.9)
read-only
Unsigned32
Available buffer of an inbound unicast queue.
As per the MIB.
hh3cIfQueInUsedRatio
(1.3.6.1.4.1.25506.2.40.2.2.6.1.10)
read-only
Unsigned32
Buffer usage of an inbound unicast queue.
As per the MIB.
hh3cIfQueInUsedPeak
(1.3.6.1.4.1.25506.2.40.2.2.6.1.11)
read-only
Unsigned32
Peak buffer usage of an inbound unicast queue.
As per the MIB.
hh3cIfQueInThreshold
(1.3.6.1.4.1.25506.2.40.2.2.6.1.12)
read-write
Unsigned32
Buffer alarm threshold of an inbound unicast queue.
As per the MIB.
hh3cIfQueInOverThres
(1.3.6.1.4.1.25506.2.40.2.2.6.1.13)
read-only
Unsigned32
Number of buffer usage alarms of an inbound unicast queue.
As per the MIB.
hh3cIfQueInHeadRoomTotal
(1.3.6.1.4.1.25506.2.40.2.2.6.1.14)
read-only
Unsigned32
Total headroom of an inbound queue.
As per the MIB.
hh3cIfQueInHeadRoomFree
(1.3.6.1.4.1.25506.2.40.2.2.6.1.15)
read-only
Unsigned32
Available headroom of an inbound queue.
As per the MIB.
hh3cIfQueInHeadRoomUsedRatio
(1.3.6.1.4.1.25506.2.40.2.2.6.1.16)
read-only
Unsigned32
Headroom usage of an inbound queue.
As per the MIB.
hh3cIfQueInHeadRoomUsedPeak
(1.3.6.1.4.1.25506.2.40.2.2.6.1.17)
read-only
Unsigned32
Peak headroom usage of an inbound unicast queue.
As per the MIB.
About this table
Use this table to obtain the 64-bit packet statistics of an interface.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cIfSpeedStatHCInPkts.
Object (OID)
Access
Value range
Implementation
hh3cIfSpeedStatHCInPkts (1.3.6.1.4.1.25506.2.40.2.1.2.4.1.1)
read-only
CounterBasedGauge64
Average incoming traffic speed (in packets) of the interface within the specified interval before the latest sampling point.
As per the MIB.
hh3cIfSpeedStatHCOutPkts (1.3.6.1.4.1.25506.2.40.2.1.2.4.1.2)
read-only
CounterBasedGauge64
Average outgoing traffic speed (in packets) of the interface within the specified interval before the latest sampling point.
As per the MIB.
hh3cIfSpeedStatHCInBytes (1.3.6.1.4.1.25506.2.40.2.1.2.4.1.3)
read-only
CounterBasedGauge64
Average incoming traffic speed (in bytes) of the interface within the specified interval before the latest sampling point.
As per the MIB.
hh3cIfSpeedStatHCOutBytes (1.3.6.1.4.1.25506.2.40.2.1.2.4.1.4)
read-only
CounterBasedGauge64
Average outgoing traffic speed (in bytes) of the interface within the specified interval before the latest sampling point.
As per the MIB.
About this table
Use this table to obtain information about the interface bandwidth and packet loss rate.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cIfBandwidthUpperLimit.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.40.3.1.1.1.1)
read-write
Integer32
Integer32(1..100)
Upper limit of the interface bandwidth.
Not supported
hh3cIfDiscardPktRateUpperLimit
(1.3.6.1.4.1.25506.2.40.3.1.1.1.2)
read-write
Integer32
Integer32(1..100)
Upper limit of the interface packet loss rate.
Not supported
hh3cIfPfcDot1pTable
About this table
Use this table to set the inbound and outbound rate thresholds for an 802.1p priority.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cIfPfcDot1pValue (1.3.6.1.4.1.25506.2.40.2.2.5.1.1)
read-only
INTEGER
0-7
Interface queue priority.
As per the MIB.
hh3cIfPfcDot1pInPps (1.3.6.1.4.1.25506.2.40.2.2.5.1.2)
read-only
Unsigned32
1-4294967295
Inbound rate for a priority.
As per the MIB.
hh3cIfPfcDot1pOutPps (1.3.6.1.4.1.25506.2.40.2.2.5.1.3)
read-only
Unsigned32
1-4294967295
Outbound rate for a priority.
As per the MIB.
hh3cIfPfcDot1pInPpsThreshold (1.3.6.1.4.1.25506.2.40.2.2.5.1.4)
read-write
Unsigned32
1-4294967295
Inbound rate threshold for a priority.
As per the MIB.
hh3cIfPfcDot1pOutPpsThreshold (1.3.6.1.4.1.25506.2.40.2.2.5.1.5)
read-write
Unsigned32
1-4294967295
Outbound rate threshold for a priority.
As per the MIB.
Notifications
The following information describes the notifications included in the HH3C-IF-EXT-MIB module.
hh3cIfPortUp
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.40.3.0.5
Link-up alarm
Recovery
Major
ON
Notification triggers
The notification is generated when physical state of the interface changes to up.
Possible reasons are:
·     The undo shutdown command is executed on the interface.
·     The interface or link failure is resolved.
·     The physical state of the interface comes up.
System impact
The interface can normally forward packets.
Status control
ON
CLI: snmp-agent trap enable standard linkup
OFF
CLI: undo snmp-agent trap enable standard linkup
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.2.1.2.2.1.1 (ifIndex)
Interface index.
ifIndex
Integer32
Standard MIB values.
1.3.6.1.2.1.2.2.1.2 (ifDescr)
Interface description.
ifIndex
OCTET STRING
Recommended action
No action is required.
hh3cIfPortDown
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.3.0.6
Link-down alarm.
Error
Major
1.3.6.1.4.1.25506.2.40.3.0.5 (hh3cIfPortUp)
ON
The notification is generated when physical state of the interface changes to down.
·     The physical link of the interface is down, and the link is disconnected.
·     The interface is shut down.
System impact
The interface cannot normally forward packets.
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
Recommended action
To resolve this issue:
1.     Execute the display this command in interface view to identify whether the interfaces on both end are shut down. If the interfaces are shut down, execute the undo shutdown command in interface view to bring them up.
2.     Identify whether the physical connection is normal (for example, whether the network cables or transceiver modules are firmly connected). If the physical connection is abnormal, correctly connect the interfaces.
3.     If the issue persists, contact H3C Support.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.6.0.1
Inbound bandwidth usage rising alarm.
Error
Warning
1.3.6.1.4.1.25506.2.40.6.0.2 (hh3cIfMonInputUsageResume)
ON
The notification is generated when the inbound bandwidth usage exceeds the upper threshold.
System impact
When the inbound bandwidth usage reaches about 100%, the service traffic might be delayed or dropped.
Status control
ON
CLI: snmp-agent trap enable ifmonitor input-usage
OFF
CLI: undo snmp-agent trap enable ifmonitor input-usage
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
1.3.6.1.4.1.25506.2.40.5.2.1.1.1(hh3cIfMonInputUsageLowThres)
Lower threshold for the inbound bandwidth usage.
Unsigned32
0-100
1.3.6.1.4.1.25506.2.40.5.2.1.1.2(hh3cIfMonInputUsageHighThres)
Upper threshold for the inbound bandwidth usage.
Unsigned32
0-100
1.3.6.1.4.1.25506.2.40.5.1.1.1.1(hh3cIfMonInputUsageStatistics)
Inbound bandwidth usage statistics.
hh3cIfMonInputRateStatistics
Counter64
Recommended action
1.     Identify whether the upper threshold set on the interface is too low.
¡     If the threshold is too low, execute the port ifmonitor input-usage command to modify the threshold.
¡     If the threshold is set reasonably, collect alarm information and configuration data, and then contact H3C Support.
Basic information
OID
Event
Severity
Default status
Inbound bandwidth usage recovery alarm
Recovery
Warning
ON
The notification is generated when the inbound bandwidth usage drops from above the upper threshold to below the lower threshold.
System impact
The service restores.
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
Unsigned32
0-100
Unsigned32
0-100
Counter64
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.6.0.3
Outbound bandwidth usage rising alarm
Error
Warning
1.3.6.1.4.1.25506.2.40.6.0.4 (hh3cIfMonOutputUsageResume)
ON
The notification is generated when the outbound bandwidth usage exceeds the upper threshold.
System impact
When the outbound bandwidth usage reaches about 100%, the service traffic might be delayed or dropped.
Status control
ON
CLI: snmp-agent trap enable ifmonitor output-usage
OFF
CLI: undo snmp-agent trap enable ifmonitor output-usage
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
1.3.6.1.4.1.25506.2.40.5.2.1.1.3(hh3cIfMonOutputUsageLowThres)
Lower threshold for the outbound bandwidth usage.
Unsigned32
0-100
1.3.6.1.4.1.25506.2.40.5.2.1.1.4(hh3cIfMonOutputUsageHighThres)
Upper threshold for the outbound bandwidth usage.
Unsigned32
0-100
1.3.6.1.4.1.25506.2.40.5.1.1.1.2(hh3cIfMonOutputUsageStatistics)
Outbound bandwidth usage statistics.
Counter64
Recommended action
¡     If the threshold is too low, execute the port ifmonitor output-usage command to modify the threshold.
Basic information
OID
Event
Severity
Default status
Outbound bandwidth usage recovery alarm
Recovery
Warning
ON
The notification is generated when the outbound bandwidth usage drops from above the upper threshold to below the lower threshold.
System impact
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
Unsigned32
1-4294967295
Unsigned32
1-4294967295
Counter64
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.6.0.5
Inbound error packet rising alarm
Error
Warning
1.3.6.1.4.1.25506.2.40.6.0.6 (hh3cIfMonInputErrorAlarmResume)
ON
The notification is generated when the number of inbound error packets exceeds the upper threshold within the specified interval.
·     The optical transceiver module fails.
·     The optical fiber or link fails.
System impact
Service traffic might be dropped.
Status control
ON
CLI: snmp-agent trap enable ifmonitor input-error
OFF
CLI: undo snmp-agent trap enable ifmonitor input-error
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
1.3.6.1.4.1.25506.2.40.5.2.1.1.6(hh3cIfMonInputErrorAlarmHighThres)
Upper threshold for the number of inbound error packets.
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.5(hh3cIfMonInputErrorAlarmLowThres)
Lower threshold for the number of inbound error packets.
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.1.1.1.3(hh3cIfMonInputErrorAlarmStatistics)
Inbound error alarm statistics.
Counter64
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.7(hh3cIfMonInputErrorAlarmInterval)
Inbound error alarm statistics collection interval.
Unsigned32
0-65535
Recommended action
1.     Replace the transceiver module. Identify whether the alarm is cleared.
2.     Replace the optical fiber or link. Identify whether the alarm is cleared.
3.     Identify whether the upper threshold set on the interface is too low.
¡     If the threshold is too low, execute the port ifmonitor input-error command to modify the threshold.
Basic information
OID
Event
Severity
Default status
Inbound error packet recovery alarm
Recovery
Warning
ON
The notification is generated when the number of inbound error packets drops from above the upper threshold to below the lower threshold within the specified interval.
System impact
Status control
ON
OFF
CLI: undo snmp-agent trap enable ifmonitor input -error
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
Unsigned32
1-4294967295
Unsigned32
1-4294967295
Counter64
1-4294967295
Unsigned32
0-65535
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.6.0.7
Outbound error packet rising alarm
Error
Warning
1.3.6.1.4.1.25506.2.40.6.0.8 (hh3cIfMonOutputErrorAlarmResume)
ON
The notification is generated when the number of outbound error packets exceeds the upper threshold within the specified interval.
System impact
Status control
ON
CLI: snmp-agent trap enable ifmonitor output-error
OFF
CLI: undo snmp-agent trap enable ifmonitor output-error
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
1.3.6.1.4.1.25506.2.40.5.2.1.1.9(hh3cIfMonOutputErrorAlarmHighThres)
Upper threshold for the number of outbound error packets.
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.8(hh3cIfMonOutputErrorAlarmLowThres)
Lower threshold for the number of outbound error packets.
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.1.1.1.4(hh3cIfMonOutputErrorAlarmStatistics)
Outbound error alarm statistics.
Counter64
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.10(hh3cIfMonOutputErrorAlarmInterval)
Outbound error alarm statistics collection interval.
Unsigned32
0-65535
Recommended action
1.     Verify that the optical fiber is firmly installed. Identify whether the alarm is cleared.
2.     Verify that the physical link is normal.
3.     Execute the display interface command to identify whether the Tx power of the transceiver module of the interface that fails is within the normal range. Identify whether the negotiation mode, clock mode, and scrambling mode (link protocol, clock, and scramble) are the same on both ends. If they are different, modify the negotiation mode configuration on both ends to make them consistent. Identify whether the alarm is cleared.
4.     Identify whether the upper threshold set on the interface is too low. If the threshold is too low, execute the port ifmonitor output-error command to modify the threshold.
5.     If the threshold is set reasonably, collect alarm information and configuration data, and then contact H3C Support.
Basic information
OID
Event
Severity
Default status
Outbound error packet recovery alarm
Recovery
Warning
ON
The notification is generated when the number of outbound error packets drops from above the upper threshold to below the lower threshold within the specified interval.
System impact
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
Unsigned32
1-4294967295
Unsigned32
1-4294967295
Counter64
1-4294967295
Unsigned32
0-65535
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.6.0.9
SDH error packet rising alarm
Error
Warning
1.3.6.1.4.1.25506.2.40.6.0.10 (hh3cIfMonSdhErrorResume)
ON
The notification is generated when the number of SDH error packets exceeds the upper threshold within the specified interval.
·     The optical fiber fails.
System impact
Status control
ON
Syntax: snmp-agent trap enable ifmonitor sdh-error
OFF
CLI: undo snmp-agent trap enable ifmonitor sdh-error
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
1.3.6.1.4.1.25506.2.40.5.2.1.1.11(hh3cIfMonSdhErrorLowThres)
Lower threshold for the number of SDH error packets.
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.12(hh3cIfMonSdhErrorHighThres)
Upper threshold for the number of SDH error packets.
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.1.1.1.5(hh3cIfMonSdhErrorStatistics)
SDH error statistics.
Counter64
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.13(hh3cIfMonSdhErrorInterval)
SDH error statistics collection interval.
Unsigned32
0-65535
Recommended action
2.     Replace the optical fiber. Identify whether the alarm is cleared.
3.     Identify whether the upper threshold set on the interface is too low. If the threshold is too low, execute the port ifmonitor sdh-error command to modify the threshold.
4.     Collect alarm information and configuration data, and then contact H3C Support.
Basic information
OID
Event
Severity
Default status
SDH error packet recovery alarm
Recovery
Warning
ON
The notification is generated when the number of SDH error packets drops from above the upper threshold to below the lower threshold within the specified interval.
System impact
Status control
ON
CLI: snmp-agent trap enable ifmonitor sdh-error
OFF
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
Unsigned32
1-4294967295
Unsigned32
1-4294967295
Counter64
1-4294967295
Unsigned32
0-65535
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.6.0.11
SDH B1 error packet rising alarm
Error
Warning
1.3.6.1.4.1.25506.2.40.6.0.12 (hh3cIfMonSdhB1ErrorResume)
ON
The notification is generated when the number of SDH B1 error packets exceeds the upper threshold within the specified interval.
System impact
Status control
ON
CLI: snmp-agent trap enable ifmonitor sdh-b1-error
OFF
CLI: undo snmp-agent trap enable ifmonitor sdh-b1-error
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
1.3.6.1.4.1.25506.2.40.5.2.1.1.14(hh3cIfMonSdhB1ErrorLowThres)
Lower threshold for the number of SDH B1 error packets.
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.15(hh3cIfMonSdhB1ErrorHighThres)
Upper threshold for the number of SDH B1 error packets.
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.1.1.1.6(hh3cIfMonSdhB1ErrorStatistics)
SDH B1 error packet statistics.
Counter64
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.16(hh3cIfMonSdhB1ErrorInterval)
SDH B1 error statistics collection interval.
Unsigned32
0-65535
Recommended action
1.     Identify whether the link (including optical fiber, transceiver module, transmission device, jumper, and so on) fails. Replace the faulty components (if any), and verify that the link is connected correctly. Identify whether the alarm is cleared.
2.     Identify whether the upper threshold set on the interface is too low. If the threshold is too low, execute the port ifmonitor sdh-b1-error command to modify the threshold.
3.     Collect alarm information and configuration data, and then contact H3C Support.
Basic information
OID
Event
Severity
Default status
SDH B1 error packet recovery alarm
Recovery
Warning
ON
The notification is generated when the number of SDH B1 error packets drops from above the upper threshold to below the lower threshold within the specified interval.
System impact
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
Unsigned32
1-4294967295
Unsigned32
1-4294967295
Counter64
1-4294967295
Unsigned32
0-65535
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.6.0.13
SDH B2 error packet rising alarm
Error
Warning
1.3.6.1.4.1.25506.2.40.6.0.14 (hh3cIfMonSdhB2ErrorResume)
ON
The notification is generated when the number of SDH B2 error packets exceeds the upper threshold within the specified interval.
System impact
Status control
ON
CLI: snmp-agent trap enable ifmonitor sdh-b2-error
OFF
CLI: undo snmp-agent trap enable ifmonitor sdh-b2-error
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
1.3.6.1.4.1.25506.2.40.5.2.1.1.17(hh3cIfMonSdhB2ErrorLowThres)
Lower threshold for the number of SDH B2 error packets.
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.18(hh3cIfMonSdhB2ErrorHighThres)
Upper threshold for the number of SDH B2 error packets.
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.1.1.1.7(hh3cIfMonSdhB2ErrorStatistics)
SDH B2 error packet statistics.
Counter64
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.19(hh3cIfMonSdhB2ErrorInterval)
SDH B2 error statistics collection interval.
Unsigned32
0-65535
Recommended action
2.     Replace the faulty components (if any), and verify that the link is connected correctly. Identify whether the alarm is cleared.
3.     Identify whether the upper threshold set on the interface is too low. If the threshold is too low, execute the port ifmonitor sdh-b2-error command to modify the threshold. If the threshold is set reasonably, collect alarm information and configuration data, and then contact H3C Support.
Basic information
OID
Event
Severity
Default status
Recovery
Warning
ON
The notification is generated when the number of SDH B2 error packets drops from above the upper threshold to below the lower threshold within the specified interval.
System impact
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
Unsigned32
1-4294967295
Unsigned32
1-4294967295
SDH B2 error statistics.
Counter64
1-4294967295
Unsigned32
0-65535
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.6.0.15
CRC error packet rising alarm
Error
Warning
1.3.6.1.4.1.25506.2.40.6.0.16 (hh3cIfMonCRCErrorResume)
ON
The notification is generated when the number of CRC error packets exceeds the upper threshold within the specified interval.
System impact
Status control
ON
CLI: snmp-agent trap enable ifmonitor crc-error
OFF
CLI: undo snmp-agent trap enable ifmonitor crc-error
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
1.3.6.1.4.1.25506.2.40.5.2.1.1.21(hh3cIfMonCRCErrorHighThres)
Upper threshold for the number of CRC error packets.
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.20(hh3cIfMonCRCErrorLowThres)
Lower threshold for the number of CRC error packets.
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.1.1.1.8(hh3cIfMonCRCErrorStatistics)
CRC error statistics.
Counter64
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.22(hh3cIfMonCRCErrorInterval)
CRC error statistics collection interval.
Unsigned32
0-65535
1.3.6.1.4.1.25506.2.40.5.2.1.1.23(hh3cIfMonCRCErrType)
INTEGER
1-2
Recommended action
3.     Identify whether the upper threshold set on the interface is too low. If the threshold is too low, execute the port ifmonitor crc-error command to modify the threshold. If the threshold is set reasonably, collect alarm information and configuration data, and then contact H3C Support.
Basic information
OID
Event
Severity
Default status
CRC error packet recovery alarm
Recovery
Warning
ON
The notification is generated when the number of CRC error packets drops from above the upper threshold to below the lower threshold within the specified interval.
System impact
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
Unsigned32
1-4294967295
Unsigned32
1-4294967295
Counter64
1-4294967295
Unsigned32
0-65535
INTEGER
1-2
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.6.0.17
Received pause frame rising alarm
Error
Warning
1.3.6.1.4.1.25506.2.40.6.0.18 (hh3cIfMonRxPauseFrameResume)
ON
The notification is generated when the number of received pause frames exceeds the upper threshold within the specified interval.
·     The rate of received pause frames exceeds the threshold.
·     Pause frames are received continuously for a long period of time.
System impact
Status control
ON
CLI: snmp-agent trap enable ifmonitor rx-pause
OFF
CLI: undo snmp-agent trap enable ifmonitor rx-pause
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
1.3.6.1.4.1.25506.2.40.5.2.1.1.25(hh3cIfMonRxPauseFrameHighThres)
Upper threshold for received pause frames.
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.24(hh3cIfMonRxPauseFrameLowThres)
Lower threshold for received pause frames.
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.1.1.1.9(hh3cIfMonRxPauseFrameStatistics)
Received pause frame statistics.
Counter64
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.26(hh3cIfMonRxPauseFrameInterval)
Received pause frame statistics collection interval.
Unsigned32
0-65535
Recommended action
1.     Decrease the service traffic received on the peer interface. Identify whether the alarm is cleared.
2.     Identify whether the upper threshold set on the interface is too low. If the threshold is too low, execute the port ifmonitor rx-pause command to modify the threshold. If the threshold is set reasonably, collect alarm information and configuration data, and then contact H3C Support.
Basic information
OID
Event
Severity
Default status
Received pause frame recovery alarm
Recovery
Warning
ON
The notification is generated when the number of received pause frames drops from above the upper threshold to below the lower-threshold within the specified interval.
System impact
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
Unsigned32
1-4294967295
Unsigned32
1-4294967295
Counter64
1-4294967295
Unsigned32
0-65535
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.6.0.19
Transmitted pause frame rising alarm
Error
Warning
1.3.6.1.4.1.25506.2.40.6.0.20 (hh3cIfMonTxPauseFrameResume)
ON
The notification is generated when the number of transmitted pause frames exceeds the upper threshold within the specified interval.
·     The rate of sent pause frames exceeds the threshold.
·     Pause frames are sent continuously for a long period of time.
System impact
Status control
ON
CLI: snmp-agent trap enable ifmonitor tx-pause
OFF
CLI: undo snmp-agent trap enable ifmonitor tx-pause
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
1.3.6.1.4.1.25506.2.40.5.2.1.1.28(hh3cIfMonTxPauseFrameHighThres)
Upper threshold for transmitted pause frames.
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.27(hh3cIfMonTxPauseFrameLowThres)
Lower threshold for transmitted pause frames.
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.1.1.1.10(hh3cIfMonTxPauseFrameStatistics)
Transmitted pause frame statistics.
Counter64
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.29(hh3cIfMonTxPauseFrameInterval)
Transmitted pause frame statistics collection interval.
Unsigned32
0-65535
Recommended action
1.     Decrease the service traffic sent on the peer interface. Identify whether the alarm is cleared.
2.     Identify whether the upper threshold set on the interface is too low. If the threshold is too low, execute the port ifmonitor tx-pause command to modify the threshold. If the threshold is set reasonably, collect alarm information and configuration data, and then contact H3C Support.
Basic information
OID
Event
Severity
Default status
Transmitted pause frame recovery alarm
Recovery
Warning
ON
The notification is generated when the number of transmitted pause frames drops from above the upper threshold to below the lower threshold within the specified interval.
System impact
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
Unsigned32
1-4294967295
Unsigned32
1-4294967295
Counter64
1-4294967295
Unsigned32
0-65535
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.6.0.21
Giant packet rising alarm
Error
Warning
1.3.6.1.4.1.25506.2.40.6.0.22 (hh3cIfMonGiantResume)
ON
The notification is generated when the number of giant packets exceeds the upper threshold within the specified interval.
System impact
Status control
ON
CLI: snmp-agent trap enable ifmonitor giant
OFF
CLI: undo snmp-agent trap enable ifmonitor giant
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
1.3.6.1.4.1.25506.2.40.5.2.1.1.30(hh3cIfMonGiantLowThres)
Lower threshold for giant packets.
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.31(hh3cIfMonGiantHighThres)
Upper threshold for giant packets.
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.1.1.1.11(hh3cIfMonGiantStatistics)
Giant packet statistics.
Counter64
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.32(hh3cIfMonGiantInterval)
Giant packet statistics collection interval.
Unsigned32
0-65535
Recommended action
1.     Verify that the source traffic is normal.
2.     Execute the jumboframe enable command to adjust the maximum size of a packet that can be transmitted on the interface.
Basic information
OID
Event
Severity
Default status
Giant packet recovery alarm
Recovery
Warning
ON
The notification is generated when the number of giant packets drops from above the upper threshold to below the lower threshold within the specified interval.
System impact
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
Unsigned32
1-4294967295
Unsigned32
1-4294967295
Counter64
1-4294967295
Unsigned32
0-65535
Recommended action
hh3cIfMonRuntRising
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.6.0.23
Runt packet rising alarm
Error
Warning
1.3.6.1.4.1.25506.2.40.6.0.24 (hh3cIfMonRuntResume)
ON
The notification is generated when the number of runt packets exceeds the upper threshold within the specified interval.
System impact
Status control
ON
CLI: snmp-agent trap enable ifmonitor runt
OFF
CLI: undo snmp-agent trap enable ifmonitor runt
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
1.3.6.1.4.1.25506.2.40.5.2.1.1.33(hh3cIfMonRuntLowThres)
Lower threshold for runt packets.
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.34(hh3cIfMonRuntHighThres)
Upper threshold for runt packets.
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.1.1.1.12(hh3cIfMonRuntStatistics)
Runt packet statistics.
Counter64
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.35(hh3cIfMonRuntInterval)
Runt packet statistics collection interval.
Unsigned32
0-65535
Recommended action
hh3cIfMonRuntResume
Basic information
OID
Event
Severity
Default status
Runt packet recovery alarm
Recovery
Warning
ON
The notification is generated when the number of runt packets drops from above the upper threshold to below the lower threshold within the specified interval.
System impact
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
Unsigned32
1-4294967295
Unsigned32
1-4294967295
Counter64
1-4294967295
Unsigned32
0-65535
Recommended action
hh3cIfPfcOutRising
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.3.0.7
Outbound PFC frame rate rising alarm
Informational
Warning
ON
This notification is generated when the outbound PFC frame rate exceeds the early warning threshold.
System impact
Outbound PFC frames might be lost.
Status control
This notification cannot be turned off.
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
1.3.6.1.4.1.25506.2.40.2.2.5.1.1(hh3cIfPfcDot1pValue)
INTEGER
0-7
1.3.6.1.4.1.25506.2.40.2.2.5.1.3(hh3cIfPfcDot1pOutPps)
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.2.2.5.1.5(hh3cIfPfcDot1pOutPpsThreshold)
Unsigned32
1-4294967295
Recommended action
1.     Identify whether the upper threshold set on the interface is too low. If the threshold is set reasonably, identify whether the interface fails.
¡     If the inbound PFC frame rate exceeds the threshold, identify whether the peer device fails.
¡     If the outbound PFC frame rate exceeds the threshold, identify whether the local device fails.
¡     If both the inbound PFC frame rate and outbound PFC frame rate exceed the thresholds, identify whether the local device and peer device fail.
2.     Identify whether the upper threshold set on the interface is too low. If the threshold is too low, execute the priority-flow-control early-warning dot1p dot1p-list outpps pps-value command to modify the threshold. If the threshold is set reasonably, collect alarm information and configuration data, and then contact H3C Support.
hh3cIfInPfcRising
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.3.0.8
Inbound PFC frame rate rising alarm
Informational
Warning
ON
This notification is generated when the inbound PFC frame rate exceeds the early warning threshold.
System impact
Incoming PFC frames might be lost.
Status control
Objects
OID (object name)
Index nodes
Value range
Interface index.
Integer32
OCTET STRING
INTEGER
0-7
1.3.6.1.4.1.25506.2.40.2.2.5.1.2(hh3cIfPfcDot1pInPps)
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.2.2.5.1.4(hh3cIfPfcDot1pInPpsThreshold)
Unsigned32
1-4294967295
Recommended action
1.     Identify whether the upper threshold set on the interface is too low. If the threshold is set reasonably, identify whether the device fails.
2.     Identify whether the upper threshold set on the interface is too low. If the threshold is too low, execute the priority-flow-control early-warning dot1p dot1p-list inpps pps-value command to modify the threshold. If the threshold is set reasonably, collect alarm information and configuration data, and then contact H3C Support.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.3.0.14
Traffic in the ingress buffer of a card is dropped
Error
Warning
1.3.6.1.4.1.25506.2.40.3.0.15 (hh3cIfBufferInDiscardResume)
ON
This notification is generated when the traffic in the ingress buffer of a card is dropped.
System impact
Traffic in the ingress buffer of a card is dropped. The inbound traffic of the card exceeds the link bandwidth of the switching fabric module.
Status control
This notification cannot be disabled.
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.4.1.25506.2.40.1.6 (hh3cIfChassisIndex)
Chassis index.
N/A
Integer32
0-65535
1.3.6.1.4.1.25506.2.40.1.7 (hh3cIfSlotIndex)
Card index.
N/A
Integer32
0-65535
Recommended action
Optimize the network, and adjust the traffic forwarding solution.
Basic information
OID
Event
Severity
Default status
The uplink traffic of a card recovers from the drop state.
Recovery
Warning
ON
This notification is generated when network congestion is relieved within the specified time.
System impact
The system is not impacted.
Status control
Objects
OID (object name)
Index nodes
Value range
Chassis index.
N/A
Integer32
0-65535
Card index.
N/A
Integer32
0-65535
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.3.0.16
An interface operates in half duplex mode
Error
Warning
1.3.6.1.4.1.25506.2.40.3.0.52 (hh3cIfHalfDuplexClear)
ON
This notification is generated when an interface operates in half duplex mode.
System impact
Packets might be lost when an interface operates in half duplex mode.
Status control
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
0-65535
ifIndex
OCTET STRING
Recommended action
Configure the interface to operate in full duplex mode. Related command: duplex full.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.3.0.17
Interface information changes when a single-chassis device is expanded to a multi-chassis device
Informational
Informational
1.3.6.1.4.1.25506.2.40.3.0.18 (hh3cIfChangeMultiChassisResume)
ON
This notification is generated if interface information changes when a single-chassis device is expanded to a multi-chassis device.
System impact
An interface name changes from a three-tier name to a four-tier name.
Status control
Objects
None.
Recommended action
Basic information
OID
Event
Severity
Default status
Interface information changes when a multi-chassis device is rolled back to a single-chassis device
Informational
Informational
ON
This notification is generated if interface information changes when a multi-chassis device is rolled back to a single-chassis device.
System impact
An interface name changes from a four-tier name to a three-tier name.
Status control
Objects
None.
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.3.0.19
The interface card configuration recovers
Informational
Informational
ON
This notification is generated if the interface card configuration recovers.
System impact
The interface card configuration has recovered, and the interface card becomes available.
Status control
Objects
OID (object name)
Index nodes
Value range
Chassis index.
N/A
Integer32
0-65535
Card index.
N/A
Integer32
0-65535
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.3.0.20
The interface subcard configuration recovers
Informational
Informational
ON
System impact
The interface subcard configuration has recovered, and the interface subcard becomes available.
Status control
Objects
OID (object name)
Index nodes
Value range
Chassis index.
N/A
Integer32
0-65535
Slot index.
N/A
Integer32
0-65535
1.3.6.1.4.1.25506.2.40.1.8 (hh3cIfSubSlotIndex)
Subcard index.
N/A
Integer32
0-65535
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.3.0.21
An interface is deleted
Informational
Informational
ON
This notification is generated if an interface is deleted.
System impact
Services that depend on the interface might be impacted.
Status control
Objects
OID (object name)
Index nodes
Value range
ifIndex
OCTET STRING
Recommended action
hh3cIfErrordown
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.3.0.22
An interface enters the error-down state
Error
Warning
1.3.6.1.4.1.25506.2.40.3.0.23 (hh3cIfErrordownRecovery)
ON
An error-down event occurs when an interface is set to the ERROR DOWN state after the device detects failure. In this case, the interface cannot receive or send packets and the LED for the interface is solid off.
·     Too many CRC error packets are generated on the interface.
·     The interface flaps frequently and is unstable.
System impact
Interface traffic cannot be forwarded, and the services are interrupted.
Status control
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
0-65535
ifIndex
OCTET STRING
1.3.6.1.4.1.25506.2.40.1.9 (hh3cIfErrDownDesc)
Error-down reason description.
N/A
OCTET STRING
1: CRC error packets actively report physical down events.
2: All serdes between interface cards and switching fabric modules fail.
3: IRF fabric configuration conflicts cause the IRF port to go down.
4: The optical powers of transceiver modules are low.
5: IRF physical interfaces receive a large number of protocol packets or IRF fabric error packets within a short period of time.
 6: STP Down
7: The interface is shut down on the data link layer because the MACsec module has not successfully negotiated the communication encryption parameters for the interface.
8: The interface is shut down because the unknown unicast, multicast, or broadcast traffic on the interface exceeds the corresponding upper threshold.
9: Standby bit
10: Loop detection
11: Link-Aggregation interface down
12: Monitor-Link uplink down
13: IRF-link-down
14: MAD Down
15: Used by FC aggregation
16: Tunnel-Bundle administratively down
17: FC port security
18: Used by the NPV feature of an FC interface
19: Used by M-LAG MAD
20: Used by MAC flapping
21: ETH-rddc Down
22: Used by CFD collaboration
23: Used by LLDP
24: OFP DOWN
25: The interface is shut down on the data link layer because DLDP has detected unidirectional links on the interface
26: Used by POSA
27: Used by collaboration group
28: DRNI MAD Down
29: Link-Flap DOWN
Recommended action
1.     Troubleshoot the link failures.
2.     Collect alarm information and configuration data, and then contact H3C Support.
Basic information
OID
Event
Severity
Default status
An interface recovers from the error-down state
Recovery
Warning
ON
This notification is generated when an IRF physical interface recovers from the error-down state.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
0-65535
ifIndex
OCTET STRING
N/A
OCTET STRING
Same as that of the hh3cIfErrordown node
Recommended action
Basic information
OID
Event
Severity
Default status
Autonegotiated full duplex mode for an interface
Recovery
Warning
ON
This notification is generated when the autonegotiated duplex mode changes from half duplex to full duplex for an interface.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
Recommended action
hh3cIfEgressDropAlarm
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.3.0.53
Packet drop on a port
Error
Warning
1.3.6.1.4.1.25506.2.40.3.0.54 (hh3cIfEgressDropRecover)
ON
This notification is generated when packets are dropped within the specified time.
System impact
Outgoing traffic of a port is dropped.
Status control
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
1.3.6.1.4.1.25506.2.40.2.2.6.1.1 (hh3cIfQueId)
ID of an interface's buffer queue.
hh3cIfQueId
INTEGER
que0(1),
que1(2),
que2(3),
que3(4),
que4(5),
que5(6),
que6(7),
que7(8)
Recommended action
Basic information
OID
Event
Severity
Default status
Packet drop on a port recovers
Recovery
Warning
ON
This notification is generated when packet drop recovers on a port within the specified time.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
hh3cIfQueId
INTEGER
que0(1),
que1(2),
que2(3),
que3(4),
que4(5),
que5(6),
que6(7),
que7(8)
Recommended action
hh3cIfBoardEgressDropAlarm
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.3.0.55
Outgoing unicast traffic of a card is dropped
Error
Warning
1.3.6.1.4.1.25506.2.40.3.0.56 (hh3cIfBoardEgressDropRecover)
ON
This notification is generated if outgoing unicast traffic of a card is dropped within the specified time.
System impact
The outgoing unicast traffic of a card is dropped.
Status control
Objects
OID (object name)
Index nodes
Value range
Chassis index.
N/A
Integer32
0-65535
Card index.
N/A
Integer32
0-65535
1.3.6.1.4.1.25506.2.40.1.21 (hh3cIfCpuId)
CPU ID of a card.
N/A
Unsigned32
Recommended action
Basic information
OID
Event
Severity
Default status
Outgoing unicast traffic drop of a card recovers.
Recovery
Warning
ON
This notification is generated if outgoing unicast traffic drop of a card recovers within the specified time.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
Chassis index.
N/A
Integer32
0-65535
Card index.
N/A
Integer32
0-65535
CPU ID of a card.
N/A
Unsigned32
Recommended action
hh3cIfComboTypeChange
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.3.0.57
The combo type is changed by the CLI
Informational
Informational
ON
This notification is generated if the combo enable { copper | fiber } command configuration changes.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
OCTET STRING(0..255)
1.3.6.1.4.1.25506.2.40.1.22 (hh3cIfOldComboType)
Combo interface type before change.
N/A
INTEGER
fiber(1),
copper(2)
1.3.6.1.4.1.25506.2.40.1.23 (hh3cIfNewComboType)
Combo interface type after change.
N/A
INTEGER
fiber(1),
copper(2)
Recommended action
hh3cIfIngressAgingDropAlarm
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.3.0.58
The traffic in the ingress buffer of a slot is dropped because of no schedule.
Error
Warning
1.3.6.1.4.1.25506.2.40.3.0.59 (hh3cIfIngressAgingDropResume)
ON
This notification is generated if the traffic of high-priority queues exceeds the port bandwidth and thus the packets in low-priority queues cannot be scheduled.
System impact
The service traffic of a card is lost.
Status control
Objects
OID (object name)
Index nodes
Value range
Chassis index.
N/A
Integer32
0-65535
Card index.
N/A
Integer32
0-65535
CPU ID of a card.
N/A
Unsigned32
Recommended action
Basic information
OID
Event
Severity
Default status
Traffic drop in the ingress buffer of a slot recovers
Recovery
Warning
ON
This notification is generated if traffic drop in the ingress buffer of a slot recovers within the specified time.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
Chassis index.
N/A
Integer32
0-65535
Card index.
N/A
Integer32
0-65535
CPU ID of a card.
N/A
Unsigned32
Recommended action
hh3cIfMonInputJamDiscardAlarm
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.6.0.35
The number of incoming packets dropped due to congestion exceeds the threshold
Error
Warning
1.3.6.1.4.1.25506.2.40.6.0.36 (hh3cIfMonInputJamDiscardResume)
ON
This notification is generated if the number of incoming packets dropped due to congestion exceeds the threshold.
System impact
If this alarm appears, serious congestion has occurred in the network. If you do not resolve this issue timely, network congestion will cause more packets to be dropped. As a result, services will be impacted.
Status control
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
1.3.6.1.4.1.25506.2.40.5.1.1.1.15 (hh3cIfMonJamDiscardStatistics)
Number of packets dropped due to congestion.
Counter64
Counter64
1.3.6.1.4.1.25506.2.40.5.2.1.1.42 (hh3cIfMonJamDiscardThres)
Threshold for the number of packets dropped due to congestion.
Unsigned32
1.3.6.1.4.1.25506.2.40.5.2.1.1.43 (hh3cIfMonJamDiscardInterval)
Statistics interval for the number of packets dropped due to congestion.
Unsigned32
Unsigned32 (0..65535)
Recommended action
1.     Execute the display this command to identify whether rate limiting is configured in the inbound direction of the interface.
2.     Execute the qos lr inbound cir cir-value [ cbs cbs-value ] command in interface view to modify the rate limit values or execute the undo qos lr inbound command to delete rate limit configuration. Identify whether the alarm is cleared.
3.     According to the service conditions, execute the port ifmonitor input-usage high-threshold high-value command in interface view to modify the alarm threshold for the number of packets lost due to congestion on the interface.
Basic information
OID
Event
Severity
Default status
The number of incoming packets dropped due to congestion is restored to the normal state
Recovery
Warning
ON
This notification is generated if the number of incoming packets dropped due to congestion drops below the threshold.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
Counter64
Counter64
Unsigned32
Unsigned32
Recommended action
hh3cIfMonOutputJamDiscardAlarm
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.6.0.37
The number of outgoing packets dropped due to congestion exceeds the threshold
Error
Warning
1.3.6.1.4.1.25506.2.40.6.0.38 (hh3cIfMonOutputJamDiscardResume)
ON
This notification is generated if the number of outgoing packets dropped due to congestion exceeds the threshold.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
Counter64
Counter64
Unsigned32
Unsigned32 (0..4294967295)
Unsigned32
Recommended action
1.     Execute the display this command to identify whether rate limiting is configured in the outbound direction of the interface.
2.     Execute the qos lr outbound cir cir-value [ cbs cbs-value ] command in interface view to modify the rate limit values or execute the undo qos lr outbound command to delete rate limit configuration. Identify whether the alarm is cleared.
3.     According to the service conditions, execute the port ifmonitor output-usage high-threshold high-value command in interface view to modify the alarm threshold for the number of packets lost due to congestion on the interface.
Basic information
OID
Event
Severity
Default status
The number of outgoing packets dropped due to congestion is restored to the normal state
Recovery
Warning
ON
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
Counter64
Counter64
Unsigned32
Unsigned32
Recommended action
hh3cIfMonPktDropRateRising
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.6.0.39
The number of packets dropped on an interface card exceeds the configured alarm threshold
Error
Warning
1.3.6.1.4.1.25506.2.40.6.0.40 (hh3cIfMonPktDropRateRecover)
ON
This notification is generated when the number of packets dropped on an interface card exceeds the configured alarm threshold.
System impact
The sending bandwidth of normal protocol packets is preempted. As a result, the protocols are interrupted, and data is lost.
Status control
Objects
OID (object name)
Index nodes
Value range
Chassis index.
N/A
Integer32
0-65535
Card index.
N/A
Integer32
0-65535
CPU ID of a card.
N/A
Unsigned32
1.3.6.1.4.1.25506.2.40.1.24 (hh3cIfDropRateThreshold)
Threshold for the packet loss rate.
N/A
Integer32
Integer32(1..2147483647)
1.3.6.1.4.1.25506.2.40.1.25 (hh3cIfCurrentDropRate)
Current packet loss rate.
N/A
Integer32
1.3.6.1.4.1.25506.2.40.1.26 (hh3cIfDropRateInterval)
Packet loss rate detection interval.
N/A
Integer32
1.3.6.1.4.1.25506.2.40.1.27 (hh3cIfMessageProtocol)
Packet protocol.
N/A
Integer32
Recommended action
1.     If the shutdown keyword is specified when you configure the alarm for the number of packets lost on a card, the system shuts down all interfaces on the card when the number of lost packets on the card exceeds the upper threshold. Then, the card stops forwarding all packets. To recover the interfaces on the card, execute the undo shutdown command on the interfaces.
2.     If the reboot keyword is specified when you configure the alarm for the number of packets lost on a card, the system reboots the interface card when the number of lost packets on the card exceeds the upper threshold.
Basic information
OID
Event
Severity
Default status
The number of packets dropped on an interface card is restored to the normal state
Recovery
Warning
ON
This notification is generated when the number of packets dropped on an interface card drops below the threshold within the specified time.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
Chassis index.
N/A
Integer32
0-65535
Card index.
N/A
Integer32
0-65535
CPU ID of a card.
N/A
Unsigned32
N/A
Integer32
N/A
Integer32
N/A
Integer32
Packet protocol.
N/A
Integer32
Recommended action
hh3cIfMonBadBytesErrorRising
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.6.0.41
The number of bytes in bad packets exceeds the set alarm threshold
Error
Warning
1.3.6.1.4.1.25506.2.40.6.0.42 (hh3cIfMonBadBytesErrorResume)
ON
This notification is generated when the number of bytes in bad packets exceeds the set alarm threshold within the specified time.
System impact
Service switchover or interruption might occur.
Status control
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
1.3.6.1.4.1.25506.2.40.5.1.1.1.16 (hh3cIfMonBadBytesStatistics)
Number of bytes in bad packets.
Counter64
Counter64 (0..18446744073709551615)
1.3.6.1.4.1.25506.2.40.5.2.1.1.44 (hh3cIfMonBadBytesThreshold)
Threshold for the number of bytes in bad packets.
Unsigned32
1.3.6.1.4.1.25506.2.40.5.2.1.1.45 (hh3cIfMonBadBytesDiscardInterval)
Statistics interval for the number of bytes in bad packets.
Unsigned32
Recommended action
1.     When the attenuation of the line is too great, replace the optical fiber. Identify whether the alarm is cleared.
2.     View the Tx optical power of the remote end on NMS. If the Tx optical power is abnormal, replace the corresponding line card of the remote end. Identify whether the recovery notification is generated.
3.     Replace the line card of the local end that reports the alarm. Identify whether the recovery notification is generated.
Basic information
OID
Event
Severity
Default status
The number of bytes in bad packets is restored to the normal state
Recovery
Warning
ON
This notification is generated when the number of bytes in bad packets drops below the set alarm threshold within the specified time.
System impact
The services recover.
Status control
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
Counter64
Unsigned32
Unsigned32
Recommended action
hh3cIfMonPortCrcRateExceed
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.6.0.43
The CRC packet error rate is equal to or greater than 1000 pps
Informational
Warning
ON
This notification is generated when the CRC packet error rate is equal to or greater than 1000 pps within the specified time.
System impact
Some service data on the interface is dropped.
Status control
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
1.3.6.1.4.1.25506.2.40.5.1.1.1.17 (hh3cIfMonErrorRateStatistics)
Packet error rate statistics.
Counter64
Counter64
1.3.6.1.4.1.25506.2.40.5.2.1.1.46 (hh3cIfMonErrorRateThres)
Threshold for the packet error rate.
Unsigned32
1.3.6.1.4.1.25506.2.40.5.2.1.1.47 (hh3cIfMonErrorRateDiscardInterval)
Statistics interval for the packet error rate.
Unsigned32
Recommended action
1.     Replace the transceiver module, and then execute the display interface command to identify whether the number of CRC error packets keeps increasing on the interface.
2.     Replace the fiber, and then execute the display interface command to identify whether the number of CRC error packets keeps increasing on the interface.
hh3cIfMonPortErrorRateExceed
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.6.0.44
The average packet error rate of CRC error packets, giants, and runts exceeds 1000 pps.
Informational
Warning
ON
This notification is generated when the average packet error rate of CRC error packets, giants, and runts exceeds 1000 pps within the specified time.
System impact
Some service data on the interface might be dropped.
Status control
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
Counter64
Counter64
Unsigned32
Unsigned32
Recommended action
1.     Replace the transceiver module, and then execute the display interface command to identify whether the number of error packets keeps increasing on the interface.
2.     Replace the fiber, and then execute the display interface command to identify whether the number of error packets keeps increasing on the interface.
3.     Execute the jumboframe enable command to modify the jumbo frame length limit or change the packet length. Then, execute the display interface command to identify whether the number of error packets keeps increasing.
hh3cIfMonInBCRapidChange
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.6.0.45
The inbound broadcast traffic of an interface rapidly changes to exceed the threshold
Error
Warning
1.3.6.1.4.1.25506.2.40.6.0.46 (hh3cIfMonInBCRapidRecover)
ON
This notification is generated if the inbound broadcast traffic of an interface rapidly changes to exceed the threshold (CurrentInputBroadcastRate ≥BaseInputBroadcastRate+InputBroadcastChangeThreshold) within the specified time.
System impact
Packet loss might occur.
Status control
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
1.3.6.1.4.1.25506.2.40.1.28 (hh3cIfCurrentFlowThreshold)
Current traffic threshold.
N/A
Counter64
Counter64
1.3.6.1.4.1.25506.2.40.1.29 (hh3cIfCurrentFlowValue)
N/A
Counter64
Counter64
Recommended action
1.     When CurrentInputBroadcastRate ≥BaseInputBroadcastRate+InputBroadcastChangeThreshold, identify whether the broadcast traffic increases normally. If not, identify whether loops exist in the link.
Basic information
OID
Event
Severity
Default status
The rapid change of inbound broadcast traffic on an interface restores
Recovery
Warning
ON
This notification is generated if the inbound broadcast traffic of an interface rapidly changes to drop below the threshold (CurrentInputBroadcastRate≤BaseInputBroadcastRate- InputBroadcastChangeThresholdd) within the specified time.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
N/A
Counter64
Counter64
N/A
Counter64
Counter64
Recommended action
hh3cIfMonPortCrcRateExceedResume
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.6.0.47
The CRC packet error rate is less than or equal to 1000 pps.
Informational
Warning
N/A
ON
This recovery notification is generated when the CRC packet error rate is less than or equal to 1000 pps within the specified time.
System impact
No negative impact on the system.
Status control
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
Counter64
Counter64
Unsigned32
Unsigned32
Recommended action
hh3cIfFlowControlDLAlarm
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.3.0.63
The port does not forward packets but receives pause frames, or the port sends pause frames but does not receive packets
Error
Warning
1.3.6.1.4.1.25506.2.40.3.0.64 (hh3cIfFlowControlDLAlarmResume)
ON
This notification is generated in either of the following conditions:
·     The port does not forward packets, but receives a large number of pause frames.
·     The port continuously sends a large number of pause frames, but does not receive packets.
System impact
An interface cannot forward packets.
Status control
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
Recommended action
To resolve this issue, collect alarm information and configuration data, and then contact H3C Support.
Basic information
OID
Event
Severity
Default status
The port does not forward packets or receive pause frames, or the port sends pause frames and receives packets
Recovery
Warning
N/A
ON
This notification is generated when the port sends pause frames and receives packets or the port does not forward packets or receive pause frames.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
Recommended action
hh3cIfOutputErrorAlarm
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.3.0.65
Some service data on the port is dropped
Error
Warning
1.3.6.1.4.1.25506.2.40.3.0.66 (hh3cIfOutputErrorAlarmResume)
ON
This notification is generated if the optical transceiver module or optical fiber fails.
System impact
Some service data on the port is dropped.
Status control
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
Card index.
N/A
Integer32
0-65535
Subcard index.
N/A
Integer32
0-65535
Recommended action
Basic information
OID
Event
Severity
Default status
No service data is dropped on the port.
Recovery
Warning
N/A
ON
This notification is generated when the optical transceiver module or optical fiber recovers and the service data on the port restores.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
Card index.
N/A
Integer32
0-65535
Subcard index.
N/A
Integer32
0-65535
Recommended action
hh3cIfCableSnrAbnormal
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.3.0.67
The network cable quality is poor or signal interference occurs
Error
Warning
1.3.6.1.4.1.25506.2.40.3.0.68 (hh3cIfCableSnrNormal)
ON
This notification is generated when a multiGE copper port operates at 2.5 Gbps or higher and the network cable quality is poor or signal interference occurs.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
Recommended action
1.     Replace the current cable with a higher-quality cable, for example, category 6A cable or shielded cable.
2.     Execute the speed { 100 | 1000 } or auto speed { 100 | 1000 } command to set a lower speed for the multiGE interface.
Basic information
OID
Event
Severity
Default status
The network cable quality is good and no signal interference occurs
Recovery
Warning
N/A
ON
This notification is generated when a multiGE copper port operates at 2.5 Gbps or higher, the network cable quality is good, and no signal interference occurs.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
Recommended action
hh3cIfCableSnrDetectNotSupport
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.3.0.69
A multiGE interface in up state goes down
Informational
Warning
N/A
ON
This notification is generated when the network cable quality cannot be detected and a multiGE interface in up state goes down.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
Recommended action
1.     The network cable quality cannot be detected. Replace the network cable.
hh3cIfSfpNotSupportSingleFiber
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.3.0.70
A transceiver module inserted into an interface does not support single fiber communication
Informational
Warning
N/A
ON
This notification is generated when a transceiver module inserted into an interface does not support single fiber communication.
System impact
The single fiber communication function cannot be used on the interface because of the transceiver module inserted into the interface.
Status control
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
Recommended action
To resolve this issue, replace the transceiver module with a transceiver module that supports single fiber communication.
hh3cIfLRMStateAbnormal
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.3.0.71
The interface does not support LRM transceiver modules
Informational
Warning
N/A
ON
This notification is generated when the transceiver module inserted into an interface does not support LRM transceiver modules.
System impact
The transceiver module is not available, and the service of the interface is interrupted.
Status control
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
Recommended action
1.     Execute the display transceiver command to view the type of the transceiver module installed in the interface.
2.     Replace the transceiver module with a non-LRM transceiver module.
hh3cIfSfpWorkOnlyNonNego
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.3.0.72
A GE transceiver module installed in an XGE interface can operate only at non-autonegotiated 1000 Mbps
Informational
Warning
N/A
ON
This notification is generated when a GE transceiver module installed in an XGE interface can operate only at non-autonegotiated 1000 Mbps and the interconnect interface is manually configured to operate at 1000 Mbps.
System impact
After an XGE interface has a GE transceiver module installed, the autonegotiation function of the interface is unavailable.
Status control
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
Recommended action
To resolve this issue, manually configure the interconnect interface to operate at 1000 Mbps.
hh3cIfPfcDeadLockAlarm
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.40.3.0.73
PFC deadlock might cause traffic interruption on the network
Error
Warning
1.3.6.1.4.1.25506.2.40.3.0.74 (hh3cIfPfcDeadLockResume)
ON
Notification triggers
This notification is generated when PFC deadlock occurs.
System impact
Traffic interruption might occur on the network.
Status control
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.2.1.2.2.1.1 (ifIndex)
Interface index.
ifIndex
Integer32
Standard MIB values.
1.3.6.1.2.1.2.2.1.2 (ifDescr)
Interface description.
ifIndex
OCTET STRING
hh3cIfQueId
INTEGER
que0(1),
que1(2),
que2(3),
que3(4),
que4(5),
que5(6),
que6(7),
que7(8)
Recommended action
1.     Execute the display priority-flow-control command to identify the PFC deadlock reasons on the network and optimize the network. If this issue persists on the network, proceed with step 2.
2.     Execute the priority-flow-control deadlock cos cos-value interval interval command to adjust the PFC deadlock detection interval to meet the actual network requirements.
Basic information
OID
Event
Severity
Default status
PFC deadlock recovers, and traffic is forwarded
Recovery
Warning
N/A
ON
This notification is generated when PFC deadlock recovers and traffic can be normally forwarded.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
hh3cIfQueId
INTEGER
que0(1),
que1(2),
que2(3),
que3(4),
que4(5),
que5(6),
que6(7),
que7(8)
Recommended action
No action is required.
hh3cIfPfcTurnOffAlarm
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.3.0.75
The number of PFC deadlock times exceeds the threshold for automatically disabling PFC
Error
Warning
1.3.6.1.4.1.25506.2.40.3.0.76 (hh3cIfPfcTurnOffResume)
ON
This notification is generated when the number of PFC deadlock times within a detection period exceeds the threshold for automatically disabling PFC.
System impact
PFC is automatically disabled.
Status control
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
hh3cIfQueId
INTEGER
que0(1),
que1(2),
que2(3),
que3(4),
que4(5),
que5(6),
que6(7),
que7(8)
Recommended action
To resolve this issue:
2.     Execute the priority-flow-control deadlock cos cos-value interval interval command to adjust the PFC deadlock detection interval and execute the priority-flow-control deadlock threshold cos cos-value period period count count command to adjust the number of PFC deadlock times for automatically disabling PFC to meet the actual network requirements.
3.     If the PFC deadlock has been removed from the network, first execute the undo priority-flow-control enable command to disable PFC and then execute the priority-flow-control enable command to enable PFC on the interface, so that PFC is applied again.
Basic information
OID
Event
Severity
Default status
The number of PFC deadlock times is lower than the threshold for automatically disabling PFC
Recovery
Warning
N/A
ON
This notification is generated when the number of PFC deadlock times within a detection period is lower than the threshold for automatically disabling PFC.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
hh3cIfQueId
INTEGER
que0(1),
que1(2),
que2(3),
que3(4),
que4(5),
que5(6),
que6(7),
que7(8)
Recommended action
hh3cIfQueueAlarm
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.3.0.77
The usage of a queue on an interface exceeds the threshold configured on the interface
Error
Warning
1.3.6.1.4.1.25506.2.40.3.0.78 (hh3cIfQueueResume)
ON
This notification is generated when the usage of a queue on an interface exceeds the threshold configured on the interface.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
hh3cIfQueId
INTEGER
que0(1),
que1(2),
que2(3),
que3(4),
que4(5),
que5(6),
que6(7),
que7(8)
1.3.6.1.4.1.25506.2.40.1.30 (hh3cIfCurrentUsedRatio)
Current queue usage
N/A
Unsigned32
1.3.6.1.4.1.25506.2.40.31.0 (hh3cIfUsedRatioThershold)
Queue usage threshold
N/A
Unsigned32
Recommended action
hh3cIfQueueResume
Basic information
OID
Event
Severity
Default status
The usage of a queue on an interface drops below the threshold configured on the interface
Recovery
Warning
N/A
ON
This notification is generated when the usage of a queue on an interface drops below the threshold configured on the interface.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
hh3cIfQueId
INTEGER
que0(1),
que1(2),
que2(3),
que3(4),
que4(5),
que5(6),
que6(7),
que7(8)
Current queue usage
N/A
Unsigned32
N/A
Unsigned32
Recommended action
hh3cIfQueueStatDiscardAlarm
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.3.0.79
The number of dropped packets, the number of dropped bytes, or the packet loss ratio of a port queue exceeds the alarm threshold
Error
Warning
1.3.6.1.4.1.25506.2.40.3.0.80 (hh3cIfQueueStatDiscardResume)
ON
This notification is generated when the number of dropped packets, the number of dropped bytes, or the packet loss ratio of a port queue exceeds the alarm threshold.
System impact
Packet loss occurs, and services on the interface might be impacted.
Status control
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
hh3cIfQueId
INTEGER
que0(1),
que1(2),
que2(3),
que3(4),
que4(5),
que5(6),
que6(7),
que7(8)
1.3.6.1.4.1.25506.2.40.1.32 (hh3cIfDiscardType)
Packet loss type
N/A
INTEGER
discardstat(1)
discardByte(2)
discardrate(3)
1.3.6.1.4.1.25506.2.40.1.33 (hh3cIfDiscardThreshold)
Packet loss threshold
N/A
Counter64
Counter64
Recommended action
Basic information
OID
Event
Severity
Default status
The number of dropped packets, the number of dropped bytes, or the packet loss ratio of a port queue drops below the alarm threshold
Recovery
Warning
N/A
ON
This notification is generated when the number of dropped packets, the number of dropped bytes, or the packet loss ratio of a port queue drops below the alarm threshold.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
hh3cIfQueId
INTEGER
que0(1),
que1(2),
que2(3),
que3(4),
que4(5),
que5(6),
que6(7),
que7(8)
Packet loss type
N/A
INTEGER
discardstat(1)
discardByte(2)
discardrate(3)
N/A
Counter64
Counter64
Recommended action
hh3cIfQueueEgressCongestionAlarm
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.3.0.81
Congestion occurs in the outbound direction of an interface queue
Error
Warning
1.3.6.1.4.1.25506.2.40.3.0.82(hh3cIfQueueEgressCongestionClear)
ON
This notification is generated when congestion occurs in the outbound direction of an interface queue.
System impact
Outgoing traffic of an interface might be lost.
Status control
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
hh3cIfQueId
INTEGER
que0(1),
que1(2),
que2(3),
que3(4),
que4(5),
que5(6),
que6(7),
que7(8)
Recommended action
Adjust the network to relieve the network congestion.
Basic information
OID
Event
Severity
Default status
Congestion in the outbound direction of an interface queue is removed
Recovery
Warning
ON
This recovery notification is generated when congestion in the outbound direction of an interface queue is removed.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
hh3cIfQueId
INTEGER
que0(1),
que1(2),
que2(3),
que3(4),
que4(5),
que5(6),
que6(7),
que7(8)
Recommended action
hh3cIfAggPortBwChange
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.3.0.83
The bandwidth of the Trunk interface changes
Informational
Informational
ON
This notification is generated when the bandwidth of the aggregate interface changes.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
Recommended action
hh3cIfRateOfTrafficRising
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.3.0.84
The traffic on the interface modules exceeds the threshold
Informational
Warning
ON
This notification is generated when the traffic on the interface modules exceeds the threshold, and the downlink bandwidth of the NP data channel exceeds 80 percent.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
Chassis index.
N/A
Integer32
0-65535
Card index.
N/A
Integer32
0-65535
Recommended action
1.     Adjust the network topology and identify whether the alarm is cleared.
2.     If the issue persists, collect alarm information, log messages, and configuration data, and then contact Technical Support for help.
