19-EVPN Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C S6800 & S6860 Switch Series Configuration Guides-Release 6715-6W10019-EVPN Configuration Guide
04-MVXLAN configuration
04-MVXLAN configuration 2.37 MB
MVXLAN overview·· 1
Restrictions: Hardware compatibility with MVXLAN· 1
Restrictions and guidelines: MVXLAN configuration· 1
MVXLAN modes· 1
Ingress replication MVXLAN· 2
Network model 2
Working mechanism·· 2
MDT MVXLAN· 3
Benefits· 3
Network model 3
Basic concepts· 4
MP-BGP extension for MVXLAN· 4
Automatic MVXLAN tunnel establishment and assignment 5
Default MDT establishment 5
Default MDT-based transmission· 6
MDT switchover 6
Layer 3 multicast in DCI scenarios· 9
Layer 3 multicast in DCI multihoming scenarios· 12
Configuring ingress replication MVXLAN·· 14
Restrictions and guidelines: Multicast source location· 14
Ingress replication MVXLAN tasks at a glance· 14
Enabling IP multicast routing for a VPN instance· 15
Creating an MVXLAN· 15
Configuring a VSI interface as a distributed designated router interface· 16
Ingress replication MVXLAN configuration examples· 16
Example: Configuring an ingress replication MVXLAN· 16
Configuring MDT-based MVXLAN·· 22
MDT-based MVXLAN tasks at a glance· 22
Restrictions: IGMP proxying configuration· 22
Enabling IP multicast routing for a VPN instance· 23
Creating an MVXLAN· 23
Configuring a default group· 24
Specifying the MVXLAN source interface· 24
Configuring MDT switchover parameters· 25
Configuring a VSI interface as a distributed designated router interface· 26
Configuring an MVXLAN extranet RPF selection policy· 26
Configuring M-LAG in MVXLAN· 28
Configuring DCI Layer 3 multicast 30
About this task· 30
Restrictions and guidelines· 30
Configuring an ED·· 31
Configuring a VTEP· 31
Configuring an ED group for DCI Layer 3 multicast 32
Display and maintenance commands for MDT-based MVXLAN· 33
MDT-based MVXLAN configuration examples· 34
Example: Configuring intra-VPN MVXLAN Layer 3 multicast forwarding (IPv4 site network) 34
Example: Configuring intra-VPN MVXLAN Layer 3 multicast forwarding (IPv6 site network) 46
Example: Configuring MVXLAN extranet on the receiver VPN instance for symmetrically configured extranet 58
Example: Configuring MVXLAN extranet on the receiver VPN instance for asymmetrically configured extranet 72
Example: Configuring MVXLAN extranet with receivers on both VPNs and the public network· 85
Example: Configuring M-LAG in MVXLAN with an Ethernet aggregate link as the peer link· 98
Example: Configuring DCI Layer 3 multicast without L3 VXLAN ID mapping· 125
Example: Configuring DCI Layer 3 multicast in a source-ED directly connected scenario (without L3 VXLAN ID mapping) 140
Example: Configuring DCI Layer 3 multicast with multiple L3 VXLAN IDs mapped to the same intermediate L3 VXLAN ID·· 173
Example: Configuring DCI Layer 3 multicast with multiple L3 VXLAN IDs mapped to different intermediate L3 VXLAN IDs· 196
Example: Configuring Layer 3 multicast without L3 VXLAN ID mapping in a DCI multihoming scenario  221
Example: Configuring Layer 3 multicast with the same L3 VXLAN ID mapping in a DCI multihoming scenario  259
Example: Configuring ED M-LAG without L3 VXLAN ID mapping in a DCI multihoming scenario· 303
MVXLAN overview
Multicast VXLAN (MVXLAN) transmits multicast traffic from a multicast source to multicast receivers in a VXLAN or EVPN VXLAN network.
MVXLAN is not supported by S6800 switches labeled with the following product codes:
·     LS-6800-2C.
·     LS-6800-32Q.
·     LS-6800-4C.
In an MVXLAN network, the VXLAN hardware resource mode of the multicast receiver-side VTEP must be set to border. As a best practice, also set the VXLAN hardware resource mode of the multicast source-side VTEP to border.
The packet match rules of an Ethernet service instance cannot be configured as encapsulation s-vid vlan-id-list or encapsulation s-vid vlan-id-list c-vid vlan-id-list.
If multiple output interfaces exist for a multicast VXLAN tunnel, the interface type must be the same. The output interfaces can be VLAN interfaces, Layer 3 Ethernet interfaces, and Layer 3 Ethernet subinterfaces.
If the multicast source and receivers in the same multicast group are connected to a VTEP through the same AC, multicast packets will be forwarded out of their input interface. To resolve this issue:
·     If the MAC-based Layer 2 multicast forwarding mode is used, assign the input interface to an isolation group by using the port-isolate enable command.
·     If the IP-based Layer 2 multicast forwarding mode is used, assign the input interface to an isolation group by using the port-isolate enable command and enable split horizon forwarding by using the forwarding split-horizon command.
MVXLAN supports only IPv4 underlay networks in the current software version.
A unicast tunnel cannot act as the output interface for two VSI interfaces in the same multicast group.
MVXLAN modes
MVXLAN supports the following traffic transmission modes:
·     Ingress replication—Used for forwarding multicast traffic of multiple VPN instances in a VXLAN network.
·     Multicast distribution tree (MDT)—Used for forwarding multicast traffic in an EVPN VXLAN network.
MVXLAN supports both IPv4 and IPv6 site networks. This document uses the IPv4 site network as an example to describe the operating mechanism of MVXLAN. The operating mechanism of MVXLAN in an IPv6 site network is similar.
Network model
Figure 1 shows a typical MVXLAN network that uses ingress replication. In the network, the border device is attached to multiple sources, and the VTEPs are attached to multicast receivers. VXLAN tunnels are manually established between the border device and the VTEPs and assigned to VXLANs. When receiving multicast packets, the border device identifies the VPN instance to which the packets belong and forwards them to the VTEPs configured with the VPN instance. Then, the VTEPs forward the multicast packets to the attached multicast receivers in the VPN instance.
Figure 1 Ingress replication MVXLAN network model
Working mechanism
Ingress replication MVXLAN requires the following configuration on the border device and VTEPs:
·     On the border device, create VSI interfaces, associate them with VPN instances, and enable IGMP on the VSI interfaces.
·     On the border device, associate the multicast source-facing interfaces with VPN instances.
·     On the border device and VTEPs, enable IGMP snooping on VSIs.
The border device and VTEPs learn multicast forwarding entries as follows:
1.     On the border device, VSI interfaces broadcast IGMP queries in their respective VXLANs after they are enabled with IGMP.
2.     The VTEPs mark the VXLAN tunnel interfaces where the IGMP queries are received as IGMP snooping router ports, remove VXLAN encapsulation from the IGMP queries, and forward them to local hosts.
3.     Multicast receivers reply with IGMP membership reports.
4.     The VTEPs mark the ACs where the IGMP membership reports are received as IGMP snooping member ports and forward the reports to the border device through VXLAN tunnels.
5.     The border device receives the IGMP membership reports on a VXLAN tunnel interface and marks the VXLAN tunnel interface as an IGMP snooping member port.
Having learned multicast forwarding entries, the border device and VTEPs forward multicast traffic as follows:
1.     When receiving multicast packets, the border device identifies their VPN instance by the incoming interface and forwards them based on the multicast forwarding table of the VPN instance.
2.     If the traffic outgoing interface is a VSI interface, the border device forwards the multicast packets through the IGMP snooping member ports in the VXLAN associated with the VSI interface. The IGMP snooping member ports are VXLAN tunnel interfaces.
3.     The VTEPs decapsulate the multicast packets and forward them out of member ports to multicast receivers.
MDT MVXLAN
On the public network, MVXLAN multicast traffic is forwarded along an MDT rooted at the multicast source-side VTEP to leaf receiver-side VTEPs through unidirectional MVXLAN tunnels. MDT-based transmission ensures that multicast traffic is forwarded along optimal paths.
Benefits
MDT MVXLAN provides the following benefits:
·     On-demand multicast forwarding—Creates multicast distribution trees and manages multicast group members by using BGP EVPN routes and PIM.
·     Inter-VXLAN multicast forwarding—Uses distributed EVPN gateways to forward Layer 3 multicast traffic between VXLANs.
Network model
As shown in Figure 2, distributed EVPN gateways are collocated with the VTEPs, and MVXLANs are created on the VTEPs to direct multicast traffic forwarding. When receiving multicast packets, a VTEP forwards them through ACs and MVXLAN tunnels to multicast receivers.
For more information about VTEPs, VSIs, and VXLANs, see VXLAN Configuration Guide. For more information about EVPN configuration, see "Configuring EVPN."
Figure 2 MDT MVXLAN network model
Basic concepts
The following are the basic concepts in MVXLAN:
·     MDT—An MDT is a multicast distribution tree constructed by all VTEPs in the same MVXLAN. MDTs include the default MDT and the data MDT.
·     Default group—A default group is a unique multicast address assigned to each MVXLAN on the public network. It is the unique identifier of an MVXLAN on the public network and helps build the default MDT for an MVXLAN on the public network. Packets of the private multicast groups in an MVXLAN are encapsulated into packets of the default group before they are transmitted on the public network.
·     Default MDT—A default MDT uses a default group address as its group address. The default MDT of an MVXLAN is uniquely identified by the default group and transmits all private multicast packets of the MVXLAN. A default MDT is automatically created after the default group is specified and will always exist on the public network, regardless of whether multicast services exist on the public network or MVXLAN.
·     Data group—An MVXLAN is assigned a unique data group for MDT switchover. If you use an ACL to match the multicast traffic of an MVXLAN, the ingress VTEP selects a least used address from the data group range to encapsulate the matching multicast packets of the MVXLAN. Other VTEPs are notified to use the address to forward the matching traffic of the MVXLAN. This initiates the switchover to the data MDT.
·     Data MDT—A data MDT is an MDT that uses a data group as it group address. At MDT switchover, VTEPs with downstream receivers join a data group to build a data MDT. The ingress VTEP forwards the encapsulated MVXLAN multicast traffic along the data MDT over the public network.
To support MVXLAN, MP-BGP introduces the following routes for creating MDTs under the EVPN address family:
·     Supplementary broadcast domain selective multicast Ethernet tag (SBD-SMET) route—Contains private multicast source address and private multicast group address information. A receiver-side VTEP uses the SBD-SMET route to advertise its interest in a specific (*, G) or (S, G). An SBD-SMET route carries the RD configured in VPN instance view and export targets configured in VPN instance IPv4 or IPv6 address family view.
·     Selective provider multicast service interface route—Also known as S-PMSI A-D route. An S-PMSI A-D route contains the private multicast source address, private multicast group address, default or data group address, and MVXLAN source interface address. S-PMSI A-D routes are used by the multicast source-side VTEP and its BGP peers to establish the default MDT and switch traffic from the default MDT to a data MDT. An S-PMSI A-D route carries the RD configured in VPN instance view and export targets configured in VPN instance IPv4 or IPv6 address family view.
In an MVXLAN network, VTEPs automatically establish MVXLAN tunnels and assign them to MVXLANs to forward Layer 3 multicast traffic. The tunnel source is the MVXLAN source interface address, and the tunnel destination is the default or data group address. An MVXLAN tunnel is a unidirectional tunnel from the multicast source-side VTEP to a multicast receiver-side VTEP.
The multicast routing protocol running on the public network can be PIM-SM or PIM-SSM. The process of creating a default MDT is the same in these PIM modes. All VTEPs in an MVXLAN join the default MDT of the MVXLAN. The private multicast packets of the MVXLAN are forwarded along the default MDT to the VTEPs, no matter whether the site attached to a VTEP contains receivers.
Figure 3 Default MDT establishment in a PIM-SM network
As shown in Figure 3, PIM-SM runs on the public network, and MVXLAN is configured on all VTEPs. The process for establishing a default MDT is as follows:
1.     VTEP 1 sends an S-PMSI A-D route that contains (*, *) to VTEP 2 and VTEP 3.
2.     VTEP 2 and VTEP 3 receive the route and join a multicast group according to the PMSI tunnel attribute of the route. The PMSI tunnel attribute contains the following information:
¡     The multicast source is the IP address of the MVXLAN source interface on VTEP 1.
¡     The multicast group is the default group configured on VTEP 1.
3.     Multicast forwarding entries are created on each device along the paths on the public network, and a shortest path tree (SPT) with VTEP 1 as the root and VTEP 2 and VTEP 3 as leaves is created. The SPT is the default MDT.
After the default MDT is established, the multicast source sends the private multicast traffic to the receivers in each site along the default MDT. The private multicast packets are encapsulated into public multicast packets on the local VTEP and transmitted along the default MDT. Then, they are decapsulated on the remote VTEPs and transmitted in remote VXLAN sites.
Figure 4 Multicast data packet transmission
As shown in Figure 4, PIM-SM runs on the public network, the multicast source is attached to VTEP 1, and the multicast receiver is attached to VTEP 2. The multicast forwarding process is as follows:
1.     The multicast source sends private multicast packets (192.1.1.1, 225.1.1.1) to VTEP 1.
2.     VTEP 1 creates a multicast forwarding entry for (192.1.1.1, 225.1.1.1).
3.     VTEP 1 processes the packets based on whether the receiver has joined the private multicast group:
¡     If the receiver has sent an IGMP join message to VTEP 2, VTEP 1 has an SBD-SMET route sent by VTEP 1 that contains (*, G). VTEP 1 adds VXLAN encapsulation to the packets according to the route and forwards them to VTEP 2 and VTEP 3 along the default MDT. In the outer IP header of the VXLAN packets, the source IP address is the IP address of the MVXLAN source interface, and the destination IP address is the default group address.
¡     If no receiver exists, VTEP 1 drops the packets.
4.     VTEP 2 decapsulates the VXLAN packets and forwards the private multicast packets to the receiver.
5.     VTEP 3 decapsulates the VXLAN packets and drops the private multicast packets because no local receiver exists.
MDT switchover
An MVXLAN can use the default MDT or a data MDT for multicast traffic forwarding. The default MDT is uniquely identified by the default group, and a data MDT is uniquely identified by a data group. Each default group is associated with a data group range.
Switching from the default MDT to a data MDT
When a multicast packet of an MVXLAN is transmitted through the default MDT on the public network, the packet is forwarded to all VTEPs configured with the VPN instance of the MVXLAN. This occurs whether or not any active receivers exist in the sites attached to the VTEPs. When the rate of the multicast traffic of that MVXLAN is high, multicast traffic might be flooded on the public network. This increases the bandwidth use and brings extra burden on the VTEPs.
To optimize multicast transmission, the MDT-based MVXLAN solution introduces a dedicated data MDT. The data MDT is built between the VTEPs that are attached to MVXLAN multicast receivers and multicast sources. When specific network criteria are met, multicast traffic is switched from the default MDT to the data MDT.
A switchover from the default MDT to the data MDT is initiated as follows:
1.     Private multicast traffic passes the ACL rule filtering for default MDT to data MDT switchover.
2.     The source-side VTEP selects a least-used address from the data group range and sends an S-PMSI A-D route to all the other VTEPs down the default MDT. This route contains the private multicast source address, private multicast group address, IP address of the MVXLAN source interface, and data group address.
3.     Each VTEP that receives the route examines whether it has receivers of that private multicast stream.
If so, it joins the data MDT rooted at the source-side VTEP. Otherwise, it caches the route and will join the data MDT when it has attached receivers.
4.     After sending the S-PMSI A-D route, the source-side VTEP starts the data-delay timer. When the timer expires, the source-side VTEP uses the data group address to encapsulate the private multicast traffic. The multicast traffic is then forwarded down the data MDT.
5.     After the multicast traffic is switched from the default MDT to the data MDT, a downstream VTEP can leave the data MDT by sending a PIM prune message if it no longer has active receivers attached to it.
Switching from the data MDT to the default MDT
After the MXVLAN multicast traffic is switched to the data MDT, the multicast traffic conditions might change and no longer meet the switchover criterion. In this case, the source-side VTEP initiates a backward MDT switchover process when any of the following criteria are met:
·     The associated data group range is changed, and the data group address for encapsulating the MVXLAN multicast traffic is not in the new address range.
·     The ACL rule for controlling the switchover from the default MDT to the data MDT has changed, and the MVXLAN multicast traffic fails to pass the new ACL rule.
Layer 3 multicast data failover through the peer link
As shown in Figure 5, in the M-LAG in MVXLAN scenario, multicast traffic on VTEP 2 cannot be synchronized to VTEP 1 over the peer link when the uplink of VTEP 1 fails. As defined by the odd/even traffic forwarding rules, VTEP 2 can forward only multicast data destined for odd or even multicast group addresses to the receiver. This practice can cause forwarding exceptions of multicast data destined for even or odd multicast group addresses.
Figure 5 Forwarding failures of some multicast traffic when the uplink fails
To address the previously-mentioned issue, you can specify a reserved VLAN for the peer link on VTEP 1 and VTEP 2 to add the peer-link interfaces to the reserved VLAN. With a reserved VLAN configured, the peer link can be used as the failover link for multicast data. As shown in Figure 6, if the outgoing interface corresponding to the (S, G) entry on VTEP 2 is the reserved VLAN interface, the peer-link interfaces will be added to the outgoing interface list of the (S, G) entry. Multicast data on VTEP 2 will be forwarded to VTEP 1 over the peer link. For more information about reserved VLAN configuration for the peer link, see M-LAG configuration in Layer 2—LAN Switching Configuration Guide.
Figure 6 Peer link used as the failover link for Layer 3 multicast data
This feature is supported only in an IPv4 site network.
Features
DCI Layer 3 multicast in an MDT-based MVXLAN network has the following features:
·     On-demand multicast forwarding—An ED forwards multicast traffic over VXLAN-DCI tunnels only when it detects multicast receivers in remote data centers through BGP EVPN routes.
·     Inter-L3 VXLAN ID multicast forwarding—You can configure L3 VXLAN ID mappings on EDs to enable inter-data center multicast for a VPN instance that use different L3 VXLAN IDs at multiple data centers.
Working mechanism
As shown in Figure 7, inter-data center Layer 3 multicast traffic is forwarded through the VXLAN-DCI tunnels set up among EDs.
An ED operates as follows after receiving SBD-SMET and S-PMSI A-D routes from a remote ED:
·     For an SBD-SMET route, the ED finds a VXLAN-DCI tunnel interface based on the nexthop for the route and uses the interface as the outgoing interface for multicast traffic.
·     For an S-PMSI A-D route, the ED replaces the multicast source address in the PMSI tunnel attribute of the route with the address of the local MVXLAN source interface. Then, a default-MDT or data-MDT with the ED as the multicast source is set up in the local data center.
Within a data center, EDs and VTEPs advertise BGP EVPN routes and set up MVXLAN tunnels in the same way they do in a non-DCI environment.
As shown in Figure 7, after BGP EVPN route advertisement and tunnel setup are finished, VTEPs and EDs forward traffic as follows:
1.     When VTEP 1 receives multicast traffic in a VPN, it forwards the traffic over MVXLAN tunnels to local VTEPs and ED in the VPN.
2.     VTEP 2 forwards the multicast traffic to the attached receivers, and ED 1 forwards the multicast traffic over the VXLAN-DCI tunnel to DC 2.
3.     ED 3 forwards the multicast traffic to VTEP 3, and VTEP 3 forwards the multicast traffic to the attached receiver.
Figure 7 Network model for DCI Layer 3 multicast in an MDT-based MVXLAN network
L3 VXLAN ID mapping
If a VPN instance uses different L3 VXLAN IDs at two data centers, perform the following tasks for multicast traffic of the VPN instance to be transmitted between the data centers:
1.     Create an intermediate VPN instance on both EDs.
2.     Configure L3 VXLAN ID mappings on the EDs and associate the non-local L3 VXLAN ID in the mapping with the intermediate VPN instance. You can map L3 VXLAN IDs by using one of the following methods
¡     On each ED, map the local L3 VXLAN ID to an intermediate L3 VXLAN ID. The following is an example of intermediate L3 VXLAN ID mapping:
Data center
ED
Local L3 VXLAN ID
Mapped L3 VXLAN ID
DC 1
ED 1
1
12
DC 2
ED 2
2
12
¡     On each ED, map the local L3 VXLAN ID to the remote L3 VXLAN ID. The following is an example of non-intermediate L3 VXLAN ID mapping:
Data center
ED
Local L3 VXLAN ID
Mapped L3 VXLAN ID
DC 1
ED 1
10
20
DC 2
ED 2
20
10
3.     Configure VTEPs and EDs to reoriginate S-PMSI and SMET routes and modify the RDs, route targets, and L3 VXLAN ID in the routes.
As shown in Figure 8, DC 1 uses L3 VXLAN ID 1, and DC 2 uses L3 VXLAN ID 2. Both L3 VXLAN IDs are mapped to L3 VXLAN ID 12 on the EDs. The multicast forwarding entry learning and multicast forwarding processes are as follows:
1.     After the default group is configured on VTEP 3, VTEP 3 advertises an S-PMSI route that carries the (*, *) entry and L3 VXLAN ID 2.
2.     ED 2 receives the S-PMSI route and imports it to the local VPN instance and intermediate VPN instance. ED 2 then reoriginates an S-PMSI route with the intermediate L3 VXLAN ID included for the intermediate VPN instance and advertises it to ED 1.
3.     ED 1 receives the S-PMSI route and imports it to the local VPN instance and intermediate VPN instance. ED 1 then reoriginates an S-PMSI route for the local VPN instance and advertises it to VTEP 1 and VTEP 2.
4.     Receiver 3 sends an IGMP membership report to join the multicast group.
5.     VTEP 3 creates a (*, G) entry and advertises an SMET route for the multicast group.
6.     ED 2 performs the following actions after receiving the SMET route:
a.     Imports it to the local VPN instance and intermediate VPN instance.
b.     Reoriginates an SMET route for the intermediate VPN instance and advertises it to ED 1.
c.     Creates a (*, G) entry for the local VPN instance.
7.     ED 1 performs the following actions after receiving the SMET route:
b.     Reoriginates an SMET route for the local VPN instance and advertises it to VTEP 1 and VTEP 2.
c.     Creates a (*, G) entry with a VSI interface as the outgoing interface for the intermediate VPN instance.
8.     VTEP 1 and VTEP 2 receive the SMET route, import it to the local VPN instance, and create a (*, G) entry.
9.     When VTEP 1 receives multicast traffic, it advertises an S-PMSI route that carries default group information and (S, G) multicast source information.
10.     ED 1 receives the S-PMSI route, reoriginates an S-PMSI route, and creates the following entries:
¡     A (S, G) entry for the local VPN instance, in which the intermediate VPN instance is the outgoing interface.
¡     A (S, G) entry for the intermediate VPN instance, in which the local VPN instance is the incoming interface and a VSI interface is the outgoing interface. The traffic sent out of the VSI interface is forwarded through a VXLAN-DCI tunnel interface.
11.     ED 2 receives the S-PMSI route, reoriginates an S-PMSI route, and creates the following entries:
¡     A (S, G) entry for the intermediate VPN instance, in which a VSI interface is the incoming interface and the local VPN instance is the outgoing interface.
¡     A (S, G) entry for the local VPN instance, in which the intermediate VPN instance is the incoming interface and an MTunnel interface is the outgoing interface.
12.     After the multicast source sends multicast traffic, the VTEPs and EDs forward the traffic based on the learned multicast forwarding entries.
Figure 8 L3 VXLAN ID mapping
As shown in Figure 9, to avoid single point of failure for Layer 3 multicast in DCI scenarios, you can deploy multiple EDs at the edge of a data center. The EDs use the same virtual ED address to form an ED group. The ED group uses the virtual ED address to establish VXLAN tunnels with VTEPs and VXLAN-DCI tunnels with remote EDs for ED redundancy and load balancing.
Figure 9 Layer 3 multicast in DCI multihoming scenarios
As shown in Figure 10, Layer 3 multicast in DCI multihoming scenarios uses the same BGP EVPN route advertisement and VXLAN/MVXLAN tunnel establishment processes as Layer 3 multicast in DCI scenarios except for the following items:
·     Multiple EDs (ED 1 and ED 2 in this example) use the virtual IP address of the ED group to establish VXLAN-DCI tunnels with remote EDs (ED 3 in this example).
·     When ED 3 receives SMET or S-PMSI A-D routes from DC 1, it replaces the next hop of the routes with the virtual IP address of the ED group.
·     An ED in the ED group does not join the MVXLAN tunnels of other EDs in the same ED group.
After BGP EVPN route advertisement and VXLAN/MVXLAN tunnel establishment, DCI Layer 3 multicast traffic is forwarded as follows:
1.     When VTEP 1 receives multicast traffic from a multicast source, it identifies the VPN instance of the traffic. Then, VTEP 1 forwards the multicast traffic to ED 1, ED 2, and the other VTEPs in the local data center through multicast tunnels in the VPN instance.
2.     The other VTEPs in the local data center forwards the multicast traffic to the multicast receiver attached to the VTEPs. ED 1 and ED 2 performs forwarder election and the ED that wins the election forwards the multicast traffic to ED 3 in DC 2 over a VXLAN-DCI tunnel.
3.     ED 3 forwards the multicast traffic to VTEP 2 through a multicast tunnel.
4.     VTEP 2 forwards the multicast traffic to multicast receivers.
You can attach a multicast source only to a border device in an ingress replication MVXLAN network.
Before you configure multicast features on a VSI interface, assign a primary IP address to the VSI interface.
To configure ingress replication MVXLAN, perform the following tasks:
1.     Configuring VXLAN
a.     Configuring a VXLAN on a VSI
b.     Configuring a VXLAN tunnel
c.     Manually assigning VXLAN tunnels to a VXLAN
d.     Assigning customer frames to a VSI
For more information about VXLAN configuration, see VXLAN Configuration Guide.
2.     (IPv4 site network.) Configuring IGMP and IGMP snooping
a.     Enabling IGMP on a VSI interface on a border device
b.     Enabling IGMP snooping on a VSI on a border device or VTEP
For more information about IGMP and IGMP snooping configuration, see IP Multicast Configuration Guide.
3.     (IPv6 site network.) Configuring MLD and MLD snooping
a.     Enabling MLD on a VSI interface on a border device
b.     Enabling MLD snooping on a VSI on a border device or VTEP
For more information about MLD and MLD snooping configuration, see IP Multicast Configuration Guide.
4.     Configuring a VPN instance
a.     Creating a VPN instance
b.     Associating a VSI interface with a multicast source-facing interface on a border device
For more information about VPN instance configuration, see MPLS L3VPN configuration in MPLS Configuration Guide.
5.     Configuring MVXLAN
a.     Enabling IP multicast routing for a VPN instance
b.     Creating an MVXLAN
c.     Configuring a VSI interface as a distributed designated router interface
You must perform this task on a VTEP if the VTEP acts as a distributed VXLAN IP gateway.
Procedure (IPv4)
2.     Enable IP multicast routing for a VPN instance and enter MRIB view.
multicast routing vpn-instance instance-name
By default, IP multicast routing is disabled for VPN instances.
For more information about this command, see multicast routing and forwarding commands in IP Multicast Command Reference.
Procedure (IPv6)
2.     Enable IPv6 multicast routing for a VPN instance and enter IPv6 MRIB view.
ipv6 multicast routing vpn-instance instance-name
By default, IPv6 multicast routing is disabled for VPN instances.
For more information about this command, see IPv6 multicast routing and forwarding commands in IP Multicast Command Reference.
Creating an MVXLAN
You can create one or multiple ingress replication MVXLANs on a VTEP to provide services for different VPN instances and the public instance.
Creating an MVXLAN for a VPN instance
2.     Create an ingress replication MVXLAN and enter MVXLAN view.
multicast-vpn vxlan vpn-instance instance-name mode ingress-replication
3.     Create an MVXLAN address family and enter its view.
IPv4:
address-family ipv4
IPv6:
address-family ipv6
Creating an MVXLAN for the public instance
multicast-vpn vxlan public-instance mode ingress-replication
IPv4:
address-family ipv4
IPv6:
address-family ipv6
On the VTEPs configured with MVXLAN, you must specify the VSI interfaces that act as distributed EVPN gateways as distributed designated router interfaces. This operation ensures that a distributed EVPN gateway can forward multicast traffic to the local site.
Procedure (IPv4)
2.     Enter VSI interface view.
interface vsi-interface interface-number
3.     Configure the VSI interface as a distributed designated router interface.
pim distributed-dr
By default, a VSI interface is not a distributed designated router interface.
For more information about this command, see PIM commands in IP Multicast Command Reference.
Procedure (IPv6)
ipv6 pim distributed-dr
For more information about this command, see IPv6 PIM commands in IP Multicast Command Reference.
As shown in Figure 10, the border device is attached to a multicast source in VPN A. Configure an ingress replication MVXLAN to forward the multicast traffic from the source to the receivers, and configure VTEP 1 as a centralized VXLAN IP gateway.
Figure 10 Network diagram
1.     Set the VXLAN hardware resource mode:
# Set the VXLAN hardware resource mode on VTEP 1 and reboot it.
[VTEP1] hardware-resource vxlan l3gw16k
Do you want to change the specified hardware resource working mode? [Y/N]:y
The hardware resource working mode is changed, please save the configuration and
 reboot the system to make it effective.
[VTEP1] quit
<SwitchA> reboot
Start to check configuration with next startup configuration file, please wait..
.......DONE!
Current configuration may be lost after the reboot, save current configuration?
[Y/N]:y
# Set the VXLAN hardware resource mode on the border device and reboot it.
[Border] hardware-resource vxlan border24k
[Border] quit
<SwitchC> reboot
.......DONE!
[Y/N]:y
2.     Configure IP addresses and unicast routing settings:
# Assign IP addresses to interfaces, as shown in Figure 10. (Details not shown.)
# Configure OSPF on the border device and VTEPs for them to reach one another. (Details not shown.)
3.     Configure the border device:
# Enable L2VPN and IGMP snooping.
<Border> system-view
[Border] l2vpn enable
[Border] igmp-snooping
[Border-igmp-snooping] quit
# Set up VXLAN tunnels to the VTEPs.
[Border] interface tunnel 1 mode vxlan
[Border-Tunnel1] source 2.2.2.2
[Border-Tunnel1] destination 1.1.1.1
[Border-Tunnel1] quit
[Border] interface tunnel 2 mode vxlan
[Border-Tunnel2] source 2.2.2.2
[Border-Tunnel2] destination 3.3.3.3
[Border-Tunnel2] quit
# Create VSI vpna and VXLAN 10, and enable IGMP snooping on VSI vpna.
[Border] vsi vpna
[Border-vsi-vpna] igmp-snooping enable
[Border-vsi-vpna] vxlan 10
# Assign Tunnel 1 and Tunnel 2 to VXLAN 10.
[Border-vsi-vpna-vxlan-10] tunnel 1
[Border-vsi-vpna-vxlan-10] tunnel 2
[Border-vsi-vpna-vxlan-10] quit
[Border-vsi-vpna] quit
# Create VPN instance vpna.
[Border] ip vpn-instance vpna
[Border-vpn-instance-vpna] quit
# Enable IP multicast routing.
[Border] multicast routing vpn-instance vpna
[Border-mrib] quit
# Configure VSI-interface 1, associate it with VPN instance vpna, and enable IGMP on it.
[Border] interface vsi-interface 1
[Border-Vsi-interface] ip binding vpn-instance vpna
[Border-Vsi-interface] ip address 100.1.1.2 255.255.255.0
[Border-Vsi-interface] igmp enable
[Border-Vsi-interface] quit
# Specify VSI-interface 1 as the gateway interface for VSI vpna.
[Border] vsi vpna
[Border-vsi-vpna] gateway vsi-interface 1
# Associate multicast source-facing interface VLAN-interface 30 with VPN instance vpna, and enable PIM SM on VLAN-interface 30.
[Border] interface vlan-interface 30
[Border-Vlan-interface30] ip binding vpn-instance vpna
[Border-Vlan-interface30] ip address 100.2.2.2 255.255.255.0
[Border-Vlan-interface30] pim sm
[Border-Vlan-interface30] quit
# Create an ingress replication MVXLAN, and create the MVXLAN IPv4 address family and enter its view.
[Border] multicast-vpn vxlan vpn-instance vpna mode ingress-replication
[Border-mvxlan-vpna] address-family ipv4
[Border-mvxlan-vpna] quit
4.     Configure VTEP 1:
<VTEP1> system-view
[VTEP1] l2vpn enable
[VTEP1] igmp-snooping
[VTEP1-igmp-snooping] quit
# Set up a VXLAN tunnel to the border device.
[VTEP1] interface tunnel 2 mode vxlan
[VTEP1-Tunnel2] source 1.1.1.1
[VTEP1-Tunnel2] destination 2.2.2.2
[VTEP1-Tunnel2] quit
[VTEP1] vsi vpna
[VTEP1-vsi-vpna] igmp-snooping enable
[VTEP1-vsi-vpna] vxlan 10
# Assign Tunnel 2 to VXLAN 10.
[VTEP1-vsi-vpna-vxlan-10] tunnel 2
[VTEP1-vsi-vpna-vxlan-10] quit
[VTEP1-vsi-vpna] quit
# On Ten-GigabitEthernet 1/0/1 and Ten-GigabitEthernet 1/0/2, create Ethernet service instance 1000 to match VLAN 2 and map Ethernet service instance 1000 to VSI vpna.
[VTEP1] interface ten-gigabitethernet 1/0/1
[VTEP1-Ten-GigabitEthernet1/0/1] service-instance 1000
[VTEP1-Ten-GigabitEthernet1/0/1-srv1000] encapsulation s-vid 2
[VTEP1-Ten-GigabitEthernet1/0/1-srv1000] xconnect vsi vpna
[VTEP1-Ten-GigabitEthernet1/0/1-srv1000] quit
[VTEP1-Ten-GigabitEthernet1/0/1] quit
[VTEP1] interface ten-gigabitethernet 1/0/2
[VTEP1-Ten-GigabitEthernet1/0/2] service-instance 1000
[VTEP1-Ten-GigabitEthernet1/0/2-srv1000] encapsulation s-vid 2
[VTEP1-Ten-GigabitEthernet1/0/2-srv1000] xconnect vsi vpna
[VTEP1-Ten-GigabitEthernet1/0/2-srv1000] quit
[VTEP1-Ten-GigabitEthernet1/0/2] quit
5.     Configure VTEP 2:
<VTEP2> system-view
[VTEP2] l2vpn enable
[VTEP2] igmp-snooping
[VTEP2-igmp-snooping] quit
[VTEP2] interface tunnel 2 mode vxlan
[VTEP2-Tunnel2] source 3.3.3.3
[VTEP2-Tunnel2] destination 2.2.2.2
[VTEP2-Tunnel2] quit
[VTEP2] vsi vpna
[VTEP2-vsi-vpna] igmp-snooping enable
[VTEP2-vsi-vpna] vxlan 10
[VTEP2-vsi-vpna-vxlan-10] tunnel 2
[VTEP2-vsi-vpna-vxlan-10] quit
[VTEP2-vsi-vpna] quit
[VTEP2] interface ten-gigabitethernet 1/0/1
[VTEP2-Ten-GigabitEthernet1/0/1] service-instance 1000
[VTEP2-Ten-GigabitEthernet1/0/1-srv1000] encapsulation s-vid 2
[VTEP2-Ten-GigabitEthernet1/0/1-srv1000] xconnect vsi vpna
[VTEP2-Ten-GigabitEthernet1/0/1-srv1000] quit
[VTEP2-Ten-GigabitEthernet1/0/1] quit
[VTEP2] interface ten-gigabitethernet 1/0/2
[VTEP2-Ten-GigabitEthernet1/0/2] service-instance 1000
[VTEP2-Ten-GigabitEthernet1/0/2-srv1000] encapsulation s-vid 2
[VTEP2-Ten-GigabitEthernet1/0/2-srv1000] xconnect vsi vpna
[VTEP2-Ten-GigabitEthernet1/0/2-srv1000] quit
[VTEP2-Ten-GigabitEthernet1/0/2] quit
1.     Verify the MVXLAN settings on the border device:
# Verify that the VXLAN tunnel interfaces are up on the border device.
[Border] display interface tunnel 1
Tunnel1
Current state: UP
Line protocol state: UP
Description: Tunnel2 Interface
Bandwidth: 64 kbps
Tunnel source 2.2.2.2, destination 1.1.1.1
# Verify that VSI-interface 1 is up.
[Border] display interface vsi-interface brief
Protocol: (s) - spoofing
Interface            Link Protocol Primary IP        Description
Vsi1                  UP    UP        10.1.1.1
# Verify that the border device has multicast routing entries.
[Border] display pim vpn-instance vpna routing-table
Total 17 (*, G) entries; 18 (S, G) entries
(10.1.2.99, 225.0.1.1)
     RP: 10.1.2.88 (local)
     Protocol: pim-sm, Flag: SPT 2MSDP LOC ACT 2MVPN
     UpTime: 21:24:27
     Upstream interface: Vlan-interface30
         Upstream neighbor: NULL
         RPF prime neighbor: NULL
     Downstream interface information:
         1: Vsi-interface1
             Protocol: pim-sm, UpTime: 07:08:26, Expires: -
2.     Verify the MVXLAN settings on VTEP 1:
# Verify that the interfaces that host ACs are member ports.
[VTEP1] display igmp-snooping group
Total 1 entries.
VSI vpna: Total 1 entries.
  (0.0.0.0, 225.0.1.1)
    Host ports (1 in total):
      XGE1/0/1 (Link ID 0)                        (00:04:20)
      XGE1/0/2 (Link ID 1)                        (00:04:20)
# Verify that Tunnel 2 is a router port.
[VTEP1] display igmp-snooping router-port
VSI vpna:
  Router ports (1 in total):
    Tun2 (VXLAN ID 10)                            (00:03:23)
3.     Verify that the multicast receivers can receive the multicast traffic sent by the multicast source. (Details not shown.)
To configure MDT-based MVXLAN, perform the following tasks:
1.     Configuring EVPN
b.     Mapping ACs to a VSI
c.     Configuring an EVPN instance
d.     Configuring BGP to advertise BGP EVPN routes
e.     Configuring a distributed EVPN gateway
2.     Configuring IGMP and IGMP snooping
b.     Enabling IGMP proxying on a VSI interface
c.     Enabling IGMP snooping
d.     Configuring IGMP snooping proxying
3.     Configuring PIM on the transport-facing interfaces of VTEPs
¡     Configuring PIM-SM
¡     Configuring PIM-SSM
For more information about PIM configuration, see IP Multicast Configuration Guide.
4.     Configuring MVXLAN
c.     Configuring a default group
d.     Specifying the MVXLAN source interface
e.     Configuring MDT switchover parameters
f.     Configuring a VSI interface as a distributed designated router interface
g.     (Optional.) Configuring an MVXLAN extranet RPF selection policy
h.     (Optional.) Configuring DCI Layer 3 multicast
i.     (Optional.) Configuring an ED group for DCI Layer 3 multicast
When you configure IGMP proxying for an MDT-based MVXLAN, follow these restrictions and guidelines:
·     You must enable IGMP proxying on all VTEPs and EDs. Do not enable IGMP proxying on only some of the VTEPs or EDs in the MVXLAN.
·     IGMPv1 is not supported.
·     If multicast receivers send IGMP membership reports that carry (*, G) information, make sure all multicast sources that send traffic to the related multicast group are attached to the same VTEP. This restriction frequents frequent changes of outgoing interfaces in multicast forwarding entries from affecting traffic forwarding.
Procedure (IPv4)
2.     Enable IPv4 multicast routing for a VPN instance and enter MRIB view.
By default, IPv4 multicast routing is disabled for VPN instances.
For more information about the commands, see multicast routing and forwarding commands in IP Multicast Command Reference.
Procedure (IPv6)
2.     Enable IPv6 multicast routing for a VPN instance and enter MRIB view.
For more information about the commands, see IPv6 multicast routing and forwarding commands in IP Multicast Command Reference.
Creating an MVXLAN
You can create one or multiple MDT-based MVXLANs on a VTEP to provide services for different VPN instances and the public instance.
If a multicast source is attached to one VTEP or border device and the multicast receivers are attached to another VTEP or border device, MVXLAN cannot forward multicast traffic in the public instance.
2.     Create an MDT-based MVXLAN and enter MVXLAN view.
multicast-vpn vxlan vpn-instance instance-name mode mdt
multicast-vpn vxlan public-instance mode mdt
When adding VXLAN encapsulation to private multicast packets, the VTEP uses the default group as the destination IP address in the outer IP header.
The default group address of an MVXLAN must be unique among MVXLANs, and it cannot be the same as a data group address of any MVXLAN.
For an MVXLAN that transmits both IPv4 and IPv6 multicast packets, you must specify the same default group in MVXLAN IPv4 address family view and IPv6 address family view, and the data group ranges in the two views cannot overlap.
2.     Enter MVXLAN view.
3.     Create the MVXLAN IPv4 or IPv6 address family and enter its view.
IPv4:
address-family ipv4
IPv6:
address-family ipv6
4.     Configure the default group.
default-group group-address
By default, no default group exists.
When adding VXLAN encapsulation to private multicast packets, the VTEP uses the IP address of the MVXLAN source interface as the source IP address in the outer IP header.
You must configure the same MVXLAN source interface for all MVXLAN instances on the device.
For the VTEP to obtain correct routing information, you must specify the interface used for establishing BGP peer relationships as the MVXLAN source interface.
3.     Enter MVXLAN IPv4 or IPv6 address family view.
IPv4:
address-family ipv4
IPv6:
address-family ipv6
4.     Specify the MVXLAN source interface.
source interface-type interface-number
By default, no MVXLAN source interface is specified.
To avoid frequent switching of multicast traffic between the default MDT and a data MDT, set the data-delay period. The data-delay period enables the device to perform MDT switchover after a delay.
On a VTEP, the data group range of an MVXLAN cannot include the default group or data groups of any other MVXLAN.
All VPN instances share the data group resources. As a best practice to avoid data group resource exhaustion, specify a reasonable data group range for a VPN instance.
IPv4:
address-family ipv4
IPv6:
address-family ipv6
4.     Configure the data group range and the switchover criteria.
data-group group-address { mask-length | mask } [ acl acl-number | name acl-name ]
By default, no data group range exists, and the default MDT to data MDT switchover never occurs.
5.     Set the data-delay period.
data-delay delay
By default, the data-delay period is 3 seconds.
pim distributed-dr
A VSI instance is not a distributed designated router interface.
MVXLAN extranet RPF routing policies are used for multicast transmission when multicast sources and receivers are located in different VPNs.
MVXLAN extranet RPF selection policies identify the multicast traffic to forward between VPN instances based on the L3 VXLAN ID or VPN instance of traffic.
·     L3 VXLAN ID-based RPF selection policy—A policy of this kind specifies the L3 VXLAN ID of the VPN instance where a multicast source resides, a multicast source address, and a multicast group address.
A multicast source-side VTEP matches the L3 VXLAN ID, multicast source address, and multicast group address in multicast packets with RPF selection policies. If a match is found, the VTEP forwards the packets to the receiver VPN instance.
With RPF selection policies configured, a multicast receiver-side VTEP forwards multicast traffic as follows:
a.     Removes the VXLAN header added by the multicast source-side VTEP from received multicast packets. The VXLAN header includes the L3 VXLAN ID of the source VPN instance.
b.     Matches the L3 VXLAN ID, multicast source address, and multicast group address of the packets with RPF selection policies.
c.     Forwards the packets in the receiver VPN instance if a match is found.
·     VPN instance-based RPF selection policy—A policy of this kind specifies the VPN instance where a multicast source resides, a multicast source address, and a multicast group address.
A multicast source-side VTEP matches the VPN instance, multicast source address, and multicast group address in multicast packets with RPF selection policies. If a match is found, the VTEP forwards the packets to the receiver VPN instance.
d.     Removes the VXLAN header added by the multicast source-side VTEP from received multicast packets. The VXLAN header includes the L3 VXLAN ID of the source VPN instance.
e.     Matches the VPN instance, multicast source address, and multicast group address of the packets with RPF selection policies.
f.     Forwards the packets in the receiver VPN instance if a match is found.
You can use RPF selection policies on the following networks:
·     Asymmetrically configured extranet—The source VPN instance is not configured on the multicast receiver-side VTEP.
¡     On the multicast source-side VTEP, you can configure either L3 VXLAN ID-based or VPN instance-based RPF selection policies.
¡     On the multicast receiver-side VTEP, you can configure only L3 VXLAN ID-based RPF selection policies.
·     Symmetrically configured extranet—The source VPN instance is configured on the multicast receiver-side VTEP. You can configure either L3 VXLAN ID-based or VPN instance-based RPF selection policies on the multicast source-side and receiver-side VTEPs.
If some of the multicast receivers reside on the public network, specify only the multicast source address and multicast group address in the related RPF selection policies. On the multicast receiver-side VTEP, perform the following tasks for the VTEP to forward multicast traffic in both the receiver VPN instance and the public network:
2.     Assign an L3 VXLAN ID to the public instance.
3.     Configure an RPF selection policy that does not include an L3 VXLAN ID or VPN instance for the receiver VPN instance.
MVXLAN does not support redirecting the public multicast traffic received by a VSI interface to receiver VPNs based on an L3 VXLAN ID-based RPF selection policy.
The PIM mode in the source VPN instance and the receiver VPN instance must be the same. Only PIM-SM and PIM-SSM are supported.
When you use PIM-SM, use one of the following schemes as a best practice:
·     Specifying only the multicast source address—Configure two RPF selection policies as follows:
¡     In one policy, configure the multicast source address as the RP address of the multicast group that requires inter-VPN transmission.
¡     In the other policy, specify the multicast source address of the source VPN instance.
If multiple multicast groups require inter-VPN transmission, configure a dedicated RP for the multicast groups and specify the multicast source address as the RP address in RPF selection policies.
·     Specifying only the multicast group address—Configure one RPF selection policy that specifies the multicast group address of the source VPN instance.
When you use PIM-SSM, configure one RPF selection policy that contains both the multicast source address and multicast group address as a best practice.
Multicast packets can only be forwarded between two VPNs. The receiver VPN instance cannot also be the source VPN instance.
You cannot specify both an L3 VXLAN ID and an MPLS L3VPN instance for a multicast source address and multicast group address pair.
·     In PIM-SM mode, you can configure one RPF selection policy that specifies an L3 VXLAN ID or VPN instance for a multicast group address.
·     In PIM-SSM mode, you can configure one RPF selection policy that specifies an L3 VXLAN ID or VPN instance for a multicast source address and multicast group address pair.
For a receiver VPN instance, you must configure the same types of RPF selection policies for all multicast traffic from the same source VPN instance.
If an IPv4 or IPv6 MVPN extranet RPF selection policy with only the multicast group address specified is configured in the receiver VPN instance, the multicast traffic for the intra-VPN transmission will be interrupted.
Multicast source addresses in different MVXLAN extranet RPF routing policies cannot be the same, but they can overlap. The same restriction applies to the multicast group addresses in different MVXLAN extranet RPF routing policies. If multiple routing policies exist for an (S, G) entry, the device selects the policy in which the multicast group address has the longest mask. If multiple policies have the same mask length, the device selects the policy in which the multicast source address has the longest mask.
Configuring an IPv4 MVXLAN extranet RPF selection policy
2.     Enter MRIB view.
3.     Configure an IPv4 MVXLAN extranet RPF selection policy.
multicast extranet select-rpf [ l3-vni vxlan-id | vpn-instance vpn-instance-name ] { source source-address { mask | mask-length } | group group-address { mask | mask-length } } *
Configuring an IPv6 MVXLAN extranet RPF selection policy
2.     Enter IPv6 MRIB view.
ipv6 multicast routing [ vpn-instance vpn-instance-name ]
3.     Configure an IPv6 MVXLAN extranet RPF selection policy.
ipv6 multicast extranet select-rpf [ l3-vni vxlan-id | vpn-instance vpn-instance-name ] { group group-address prefix-length | source source-address prefix-length } *
For two VTEPs or border devices to be identified as one device, you must assign the same IP address to the MVXLAN source interfaces on them and specify that IP address as the virtual VTEP address. The devices use the virtual VTEP address as the multicast source address to set up MVXLAN tunnels with other devices.
To use M-LAG in MVXLAN, follow these restrictions:
·     All ACs must be dualhomed to the M-LAG member devices. Singlehomed ACs are not supported.
·     The peer link can only be an Ethernet aggregate link.
·     You cannot use M-LAG to aggregate the links between two VTEPs or between a VTEP and a border device.
Multicast traffic load sharing
You can use only PIM SM on an M-LAG system. The M-LAG member devices load share multicast traffic based on the multicast destination address. They do not support load sharing based on the multicast source address.
If the peer link fails, each M-LAG member device sets its MVXLAN tunnel source address to the local M-LAG member device address and forwards multicast traffic only through the default group. Instead of load sharing multicast traffic, each M-LAG member device forwards all received multicast traffic. When the peer link recovers, the M-LAG member devices set the MVXLAN tunnel source addresses to the virtual VTEP address. They are able to perform switchover to data groups and load share multicast traffic.
Underlay network traffic
As a best practice to prevent receivers from receiving two copies of multicast traffic when the underlay network traffic enters the VTEP or border device through a VLAN interface, configure the peer link to deny the VLAN of the underlay network traffic.
Relationship with M-LAG in EVPN
If you configure both M-LAG in MVXLAN and M-LAG in EVPN or EVPN-DCI, follow these restrictions and guidelines:
·     In addition to M-LAG in MVXLAN configuration, you must also execute the evpn m-lag group command to specify the MVXLAN source interface address as the virtual VTEP address.
·     For an MVXLAN, the following settings are in descending order of priority:
¡     The m-lag local setting in MVXLAN address family view. This setting takes effect on a per-MVXLAN basis.
¡     The multicast-vpn vxlan m-lag local setting in system view. This setting takes effect on all MVXLANs.
¡     The evpn m-lag local setting in system view. This setting takes effect on all MVXLANs.
Preprequisites
For M-LAG in MVXLAN to take effect, you must enable both Layer 2 and Layer 3 multicast.
To advertise multiple routes with the same prefix to a peer or peer group, configure the BGP Additional Paths feature on the devices connected to the M-LAG system.
2.     Globally specify the IP addresses of the member devices in an M-LAG system.
multicast-vpn vxlan m-lag local local-ipv4-address remote remote-ipv4-address
By default, the IP addresses of the member devices in an M-LAG system are not specified globally.
3.     Enter MVXLAN view.
4.     Enter MVXLAN IPv4 or IPv6 address family view.
IPv4:
address-family ipv4
IPv6:
address-family ipv6
5.     Specify the IP addresses of the member devices in the M-LAG system.
By default, the IP addresses of the member devices in an M-LAG system are not specified.
6.     Specify an MVXLAN source interface to provide the virtual VTEP address.
source interface-type interface-number evpn-m-lag-group
7.     (Optional.) Specify a reserved VLAN for the peer link in an M-LAG system.
a.     Enter the following commands in sequence to enter VLAN view:
vlan vlan-id
b.     Specify the VLAN as the reserved VLAN for the peer link.
m-lag peer-link reserved
By default, no reserved VLAN is specified for the peer link in an M-LAG system.
For more information about this command, see Layer 2—LAN Switching Command Reference.
When the multicast source and multicast receivers reside in different data centers, configure both MDT-based MVXLAN and DCI Layer 3 multicast for multicast traffic to be transmitted between the data centers.
Multicast source migration is not supported in the same data center or across data centers.
If you use dynamic VXLAN-DCI tunnels, execute the dci enable command on the Layer 3 interfaces that interconnect the EDs. This restriction does not apply to static VXLAN-DCI tunnels.
If you use intermediate L3 VXLAN ID mapping, make sure the route targets of different intermediate VPN instances do not overlap. For example, the export route targets of one intermediate VPN instance cannot overlap with the import route targets of another intermediate VPN instance.
To use DCI Layer 3 multicast, you must configure routing policies on each ED to disable it from sending any EDs the S-PMSI A-D and SMET routes received from other local or remote EDs.
If you directly attach a multicast source or multicast receiver to EDs, follow these restrictions:
·     The multicast source and receiver must be dualhomed to the M-LAG member devices if the EDs form an M-LAG system. Singlehomed sources and receivers are not supported.
·     Devices in the same DC must use the same L3VNI.
·     An ED group is not supported.
·     If the dci enable or evpn m-lag local command configuration change causes data encapsulation changes, use the reset multicast vpn-instance vpn-instance-name forwarding-table all command to clear all multicast forwarding entries for the specified VPN instance.
If you set the L3 VXLAN ID to be greater than 16000000 by using the l3-vni command, inter-data center traffic will fail to be forwarded over VXLAN-DCI tunnels.
Configuring an ED
3.     Enter MVXLAN IPv4 address family view.
address-family ipv4
4.     Enable DCI multicast.
dci enable
By default, DCI multicast is disabled.
5.     (Optional.) Configure the device to modify the information in received BGP EVPN routes.
a.     Execute the following commands in sequence to return to system view.
b.     Enter BGP instance view.
c.     Enter BGP EVPN address family view.
address-family l2vpn evpn
d.     Configure the device to modify the information in received BGP EVPN routes.
peer { group-name | ipv4-address [ mask-length ] } re-originated [ smet | s-pmsi ] [ replace-rt ]
By default, the device does not modify the BGP EVPN routes that are received from peers or peer groups.
Execute this command if a VPN instance uses different L3 VXLAN IDs at two data centers.
For more information about this command, see EVPN Command Reference.
Configuring a VTEP
If you execute both the s-pmsi advertise source-active and data-group commands, set the data-delay period to be longer than the frequency of sending the same route update to a peer or peer group. If you fail to do so, BGP might suppress advertisement of the S-PMSI routes for the data group, and traffic will be interrupted during the switchover from the default MDT to the data MDT. To set the data-delay period, use the data-delay command. To set the frequency of sending the same route update to a peer or peer group, use the peer route-update-interval command.
address-family ipv4
4.     Enable the device to advertise active multicast sources through S-PMSI routes.
By default, the device does not advertise active multicast sources through S-PMSI routes.
This command enables the VTEP to advertise an S-PMSI route for a (S, G) entry after it receives multicast traffic for the entry. The S-PMSI routes carry information about active multicast sources and allow other VTEPs and EDs in the MVXLAN network to be aware of multicast source location changes.
Perform this task to deploy an ED group that contains multiple EDs in a data center to avoid single-point of failure for DCI Layer 3 multicast.
If one of the redundant EDs fails at a multihomed site with DCI Layer 3 multicast configured, traffic of the failed ED is distributed to the other EDs for forwarding. After the failed ED recovers, it will advertise BGP EVPN routes to create multicast forwarding entries. If traffic is switched back before the recovered ED creates multicast forwarding entries, traffic forwarding is interrupted. To avoid traffic interruption, set the traffic switchback delay on all the redundant EDs.
To avoid multicast traffic forwarding failures, each VTEP must establish VXLAN tunnels to the real IP addresses of all EDs in the same data center. You must manually establish these tunnels or use the vxlan default-decapsulation command to enable default IPv4 VXLAN decapsulation on the VTEPs.
Make sure all EDs in the same data center have BGP routes to reach each other. In addition, do not configure BGP route reorigination on the EDs.
To enable the device to advertise multiple routes with the same prefix to a peer or peer group, configure the BGP Additional Paths feature on all EDs connected to the same DC.
Make sure that the EDs at the same data center do not send S-PMSI A-D or SMET routes to one another. If the EDs might send BGP routes, configure routing policies on each ED to disable it from sending other local EDs the S-PMSI A-D and SMET routes received from BGP peers.
You can set the traffic switchback delay in system view and MVXLAN address family view. The global traffic switchback delay takes effect on all MVXLANs, and the traffic switchback delay set in MVXLAN address family view takes effect on a per-MVXLAN basis. For an MVXLAN, the MVXLAN-specific traffic switchback delay takes precedence over the global one.
Complete DCI Layer 3 multicast settings. For more information, see "Configuring DCI Layer 3 multicast."
2.     Specify a virtual ED address.
evpn edge group group-ipv4
By default, no virtual ED address is configured.
3.     Specify a peer ED for ED redundancy in the same data center for Layer 3 multicast in DCI multihoming scenarios.
multicast-vpn vxlan edge remote remote-ipv4-address
By default, no peer ED is specified for ED redundancy in the same data center for Layer 3 multicast in DCI multihoming scenarios.
4.     Set the global traffic switchback delay.
multicast-vpn vxlan dci switch-delay delay-time
By default, the global traffic switchback delay is 10 seconds.
5.     Enter MVXLAN view.
6.     Enter MVXLAN IPv4 address family view.
address-family ipv4
7.     Set the MVXLAN-specific traffic switchback delay.
By default, the global traffic switchback delay set by using the multicast-vpn vxlan dci switch-delay command takes effect.
Display received IPv4 data group information in an MVXLAN.
display multicast-vpn vxlan { vpn-instance instance-name | public-instance } data-group receive [ brief | [ active | group group-address | sender source-address | vpn-source-address [ mask { mask-length | mask } ] | vpn-group-address [ mask { mask-length | mask } ] ] * ]
Display sent IPv4 data group information in an MVXLAN.
display multicast-vpn vxlan { vpn-instance instance-name | public-instance } data-group send [ group group-address | vpn-source-address [ mask { mask-length | mask } ] | vpn-group-address [ mask { mask-length | mask } ] ] *
Display information about IPv4 default groups.
display multicast-vpn vxlan [ vpn-instance instance-name | public-instance ] default-group { local | remote }
Display received IPv6 data group information in an MVXLAN.
display multicast-vpn vxlan vpn-instance instance-name ipv6 data-group receive [ brief | [ active | group group-address | sender source-address | vpn-source-address [ prefix-length ] | vpn-group-address [ prefix-length ] ] * ]
Display sent IPv6 data group information in an MVXLAN.
display multicast-vpn vxlan vpn-instance instance-name ipv6 data-group send [ group group-address | vpn-source-address [ prefix-length ] | vpn-group-address [ prefix-length ] ] *
Display information about IPv6 default groups.
display multicast-vpn vxlan [ vpn-instance instance-name ] ipv6 default-group { local | remote }
As shown in Figure 11, VM 1 is the multicast source of multicast group 225.0.0.0, and the other VMs are multicast receivers. Configure MVXLAN to forward the multicast traffic from the source to the receivers.
·     Configure VXLAN 10 and VXLAN 20 on Switch A and Switch B to extend VLAN 2 and VLAN 3 across the sites.
·     Configure Switch A and Switch B as distributed EVPN gateways to provide gateway services. Configure Switch C as a border gateway to provide access to the connected Layer 3 network.
·     Configure Switch D as an RR to reflect BGP EVPN routes between Switch A, Switch B, and Switch C.
·     Configure PIM-SM on the transport-facing interfaces of Switches A through D. Configure IGMP snooping on Switches A through C for multicast forwarding entry creation.
Figure 11 Network diagram
1.     On VM 1 and VM 3, specify 10.1.1.1 as the gateway address. On VM 2 and VM 4, specify 10.1.2.1 as the gateway address. (Details not shown.)
# Assign IP addresses to interfaces, as shown in Figure 11. (Details not shown.)
# Configure OSPF on all transport network switches (Switches A through D) for them to reach one another. (Details not shown.)
3.     Configure Switch A:
# Enable L2VPN and IP multicast routing.
[SwitchA] l2vpn enable
[SwitchA] multicast routing
[SwitchA-mrib] quit
# Enable the IGMP snooping feature.
[SwitchA] igmp-snooping
[SwitchA-igmp-snooping] quit
# Disable remote MAC address learning and remote ARP learning.
[SwitchA] vxlan tunnel mac-learning disable
[SwitchA] vxlan tunnel arp-learning disable
# Create VLAN-interface 11 and enter its view.
[SwitchA] vlan 11
[SwitchA-vlan11] quit
# Enable PIM-SM on VLAN-interface 11.
[SwitchA-Vlan-interface11] pim sm
# Create an EVPN instance on VSI vpna.
[SwitchA] vsi vpna
[SwitchA-vsi-vpna] evpn encapsulation vxlan
[SwitchA-vsi-vpna-evpn-vxlan] route-distinguisher auto
[SwitchA-vsi-vpna-evpn-vxlan] vpn-target auto
[SwitchA-vsi-vpna-evpn-vxlan] quit
# Enable IGMP snooping and IGMP snooping proxying on VSI vpna.
[SwitchA-vsi-vpna] igmp-snooping enable
[SwitchA-vsi-vpna] igmp-snooping proxy enable
# Create VXLAN 10.
[SwitchA-vsi-vpna] vxlan 10
[SwitchA-vsi-vpna] quit
# Create an EVPN instance on VSI vpnb.
[SwitchA] vsi vpnb
[SwitchA-vsi-vpnb] evpn encapsulation vxlan
[SwitchA-vsi-vpnb-evpn-vxlan] route-distinguisher auto
[SwitchA-vsi-vpnb-evpn-vxlan] vpn-target auto
[SwitchA-vsi-vpnb-evpn-vxlan] quit
# Enable IGMP snooping and IGMP snooping proxying on VSI vpnb.
[SwitchA-vsi-vpnb] igmp-snooping enable
[SwitchA-vsi-vpnb] igmp-snooping proxy enable
# Create VXLAN 20.
[SwitchA-vsi-vpnb] vxlan 20
[SwitchA-vsi-vpnb-vxlan-20] quit
[SwitchA-vsi-vpnb] quit
# Configure BGP to advertise BGP EVPN routes.
[SwitchA] bgp 200
[SwitchA-bgp-default] peer 4.4.4.4 as-number 200
[SwitchA-bgp-default] peer 4.4.4.4 connect-interface loopback 0
[SwitchA-bgp-default] address-family l2vpn evpn
[SwitchA-bgp-default-evpn] peer 4.4.4.4 enable
[SwitchA-bgp-default-evpn] quit
[SwitchA-bgp-default] quit
# Create VLAN 2.
[SwitchA] vlan 2
[SwitchA-vlan2] quit
# Create VLAN 3.
[SwitchA] vlan 3
[SwitchA-vlan3] quit
# Configure Ten-GigabitEthernet 1/0/1 as a trunk port and assign it to VLAN 2 and VLAN 3.
[SwitchA] interface ten-gigabitethernet 1/0/1
[SwitchA-Ten-GigabitEthernet1/0/1] port link-type trunk
[SwitchA-Ten-GigabitEthernet1/0/1] port trunk permit vlan 2 3
# On Ten-GigabitEthernet 1/0/1, create Ethernet service instance 1000 to match VLAN 2.
[SwitchA-Ten-GigabitEthernet1/0/1] service-instance 1000
[SwitchA-Ten-GigabitEthernet1/0/1-srv1000] encapsulation s-vid 2
# Map Ethernet service instance 1000 to VSI vpna.
[SwitchA-Ten-GigabitEthernet1/0/1-srv1000] xconnect vsi vpna
[SwitchA-Ten-GigabitEthernet1/0/1-srv1000] quit
# On Ten-GigabitEthernet 1/0/1, create Ethernet service instance 2000 to match VLAN 3.
[SwitchA-Ten-GigabitEthernet1/0/1] service-instance 2000
[SwitchA-Ten-GigabitEthernet1/0/1-srv2000] encapsulation s-vid 3
# Map Ethernet service instance 2000 to VSI vpnb.
[SwitchA-Ten-GigabitEthernet1/0/1-srv2000] xconnect vsi vpnb
[SwitchA-Ten-GigabitEthernet1/0/1-srv2000] quit
[SwitchA-Ten-GigabitEthernet1/0/1] quit
# Configure RD and route target settings for VPN instance vpna.
[SwitchA] ip vpn-instance vpna
[SwitchA-vpn-instance-vpna] route-distinguisher 1:1
[SwitchA-vpn-instance-vpna] address-family ipv4
[SwitchA-vpn-ipv4-vpna] vpn-target 1:1
[SwitchA-vpn-ipv4-vpna] quit
[SwitchA-vpn-instance-vpna] address-family evpn
[SwitchA-vpn-evpn-vpna] vpn-target 1:1
[SwitchA-vpn-evpn-vpna] quit
[SwitchA-vpn-instance-vpna] quit
# Configure VSI-interface 1.
[SwitchA] interface vsi-interface 1
[SwitchA-Vsi-interface1] ip binding vpn-instance vpna
[SwitchA-Vsi-interface1] ip address 10.1.1.1 255.255.255.0
[SwitchA-Vsi-interface1] pim sm
[SwitchA-Vsi-interface1] pim distributed-dr
[SwitchA-Vsi-interface1] mac-address 1-1-1
[SwitchA-Vsi-interface1] distributed-gateway local
[SwitchA-Vsi-interface1] local-proxy-arp enable
[SwitchA-Vsi-interface1] quit
# Configure VSI-interface 2.
[SwitchA] interface vsi-interface 2
[SwitchA-Vsi-interface2] ip binding vpn-instance vpna
[SwitchA-Vsi-interface2] ip address 10.1.2.1 255.255.255.0
[SwitchA-Vsi-interface2] igmp enable
[SwitchA-Vsi-interface2] mac-address 2-2-2
[SwitchA-Vsi-interface2] distributed-gateway local
[SwitchA-Vsi-interface2] local-proxy-arp enable
[SwitchA-Vsi-interface2] quit
# Associate VSI-interface 3 with VPN instance vpna, and configure the L3 VXLAN ID as 1000 for the VPN instance.
[SwitchA] interface vsi-interface 3
[SwitchA-Vsi-interface3] ip binding vpn-instance vpna
[SwitchA-Vsi-interface3] l3-vni 1000
[SwitchA-Vsi-interface3] pim sm
[SwitchA-Vsi-interface3] quit
# Enable IP multicast routing for VPN instance vpna.
[SwitchA] multicast routing vpn-instance vpna
[SwitchA-mrib-vpna] quit
# Create an MDT-based MVXLAN for VPN instance vpna and enter MVXLAN IPv4 address family view. Configure the default group, MVXLAN source interface, and data group range settings.
[SwitchA] multicast-vpn vxlan vpn-instance vpna mode mdt
[SwitchA-mvxlan-vpna] address-family ipv4
[SwitchA-mvxlan-vpna-ipv4] default-group 236.0.0.1
[SwitchA-mvxlan-vpna-ipv4] source loopback 0
[SwitchA-mvxlan-vpna-ipv4] data-group 239.0.1.0 30
[SwitchA-mvxlan-vpna-ipv4] quit
[SwitchA-mvxlan-vpna] quit
# Configure Loopback 1.
[SwitchA] interface loopback 1
[SwitchA-LoopBack1] ip binding vpn-instance vpna
[SwitchA-LoopBack1] ip address 12.12.12.12 32
[SwitchA-LoopBack1] pim sm
[SwitchA-LoopBack1] quit
# Enter VPN instance PIM view, and configure Loopback 1 as a candidate-BSR and candidate-RP in VPN instance vpna.
[SwitchA] pim vpn-instance vpna
[SwitchA-pim-vpna] c-bsr 12.12.12.12
[SwitchA-pim-vpna] c-rp 12.12.12.12
[SwitchA-pim-vpna] quit
[SwitchA] vsi vpna
[SwitchA-vsi-vpna] gateway vsi-interface 1
# Specify VSI-interface 2 as the gateway interface for VSI vpnb.
[SwitchA] vsi vpnb
[SwitchA-vsi-vpnb] gateway vsi-interface 2
4.     Configure Switch B:
[SwitchB] l2vpn enable
[SwitchB] multicast routing
[SwitchB-mrib] quit
[SwitchB] igmp-snooping
[SwitchB-igmp-snooping] quit
[SwitchB] vxlan tunnel mac-learning disable
[SwitchB] vxlan tunnel arp-learning disable
# Create VLAN-interface 12 and enter its view.
[SwitchB] vlan 12
[SwitchB-vlan12] quit
[SwitchB] interface vlan-interface 12
# Enable PIM-SM on VLAN-interface 12.
[SwitchB-Vlan-interface12] pim sm
[SwitchB-Vlan-interface12] quit
[SwitchB] vsi vpna
[SwitchB-vsi-vpna] evpn encapsulation vxlan
[SwitchB-vsi-vpna-evpn-vxlan] route-distinguisher auto
[SwitchB-vsi-vpna-evpn-vxlan] vpn-target auto
[SwitchB-vsi-vpna-evpn-vxlan] quit
[SwitchB-vsi-vpna] igmp-snooping enable
[SwitchB-vsi-vpna] igmp-snooping proxy enable
# Create VXLAN 10.
[SwitchB-vsi-vpna] vxlan 10
[SwitchB-vsi-vpna] quit
[SwitchB] vsi vpnb
[SwitchB-vsi-vpnb] evpn encapsulation vxlan
[SwitchB-vsi-vpnb-evpn-vxlan] route-distinguisher auto
[SwitchB-vsi-vpnb-evpn-vxlan] vpn-target auto
[SwitchB-vsi-vpnb-evpn-vxlan] quit
[SwitchB-vsi-vpnb] igmp-snooping enable
[SwitchB-vsi-vpnb] igmp-snooping proxy enable
# Create VXLAN 20.
[SwitchB-vsi-vpnb] vxlan 20
[SwitchB-vsi-vpnb-vxlan-20] quit
[SwitchB-vsi-vpnb] quit
[SwitchB] bgp 200
[SwitchB-bgp-default] peer 4.4.4.4 as-number 200
[SwitchB-bgp-default] peer 4.4.4.4 connect-interface loopback 0
[SwitchB-bgp-default] address-family l2vpn evpn
[SwitchB-bgp-default-evpn] peer 4.4.4.4 enable
[SwitchB-bgp-default-evpn] quit
[SwitchB-bgp-default] quit
# Create VLAN 2.
[SwitchB] vlan 2
[SwitchB-vlan2] quit
# Create VLAN 3.
[SwitchB] vlan 3
[SwitchB-vlan3] quit
# Configure Ten-GigabitEthernet 1/0/1 as a trunk port and assign it to VLAN 2.
[SwitchB] interface ten-gigabitethernet 1/0/1
[SwitchB-Ten-GigabitEthernet1/0/1] port link-type trunk
[SwitchB-Ten-GigabitEthernet1/0/1] port trunk permit vlan 2
[SwitchB-Ten-GigabitEthernet1/0/1] service-instance 1000
[SwitchB-Ten-GigabitEthernet1/0/1-srv1000] encapsulation s-vid 2
[SwitchB-Ten-GigabitEthernet1/0/1-srv1000] xconnect vsi vpna
[SwitchB-Ten-GigabitEthernet1/0/1-srv1000] quit
# Configure Ten-GigabitEthernet 1/0/1 as a trunk port and assign it to VLAN 3.
[SwitchB-Ten-GigabitEthernet1/0/1] port trunk permit vlan 3
[SwitchB-Ten-GigabitEthernet1/0/1] service-instance 2000
[SwitchB-Ten-GigabitEthernet1/0/1-srv2000] encapsulation s-vid 3
[SwitchB-Ten-GigabitEthernet1/0/1-srv2000] xconnect vsi vpnb
[SwitchB-Ten-GigabitEthernet1/0/1-srv2000] quit
[SwitchB-Ten-GigabitEthernet1/0/1] quit
[SwitchB] ip vpn-instance vpna
[SwitchB-vpn-instance-vpna] route-distinguisher 1:1
[SwitchB-vpn-instance-vpna] address-family ipv4
[SwitchB-vpn-ipv4-vpna] vpn-target 1:1
[SwitchB-vpn-ipv4-vpna] quit
[SwitchB-vpn-instance-vpna] address-family evpn
[SwitchB-vpn-evpn-vpna] vpn-target 1:1
[SwitchB-vpn-evpn-vpna] quit
[SwitchB-vpn-instance-vpna] quit
[SwitchB] interface vsi-interface 1
[SwitchB-Vsi-interface1] ip binding vpn-instance vpna
[SwitchB-Vsi-interface1] ip address 10.1.1.1 255.255.255.0
[SwitchB-Vsi-interface1] igmp enable
[SwitchB-Vsi-interface1] mac-address 1-1-1
[SwitchB-Vsi-interface1] distributed-gateway local
[SwitchB-Vsi-interface1] local-proxy-arp enable
[SwitchB-Vsi-interface1] quit
[SwitchB] interface vsi-interface 2
[SwitchB-Vsi-interface2] ip binding vpn-instance vpna
[SwitchB-Vsi-interface2] ip address 10.1.2.1 255.255.255.0
[SwitchB-Vsi-interface2] igmp enable
[SwitchB-Vsi-interface2] mac-address 2-2-2
[SwitchB-Vsi-interface2] distributed-gateway local
[SwitchB-Vsi-interface2] local-proxy-arp enable
[SwitchB-Vsi-interface2] quit
[SwitchB] interface vsi-interface 3
[SwitchB-Vsi-interface3] ip binding vpn-instance vpna
[SwitchB-Vsi-interface3] l3-vni 1000
[SwitchB-Vsi-interface3] pim sm
[SwitchB-Vsi-interface3] quit
[SwitchB] multicast routing vpn-instance vpna
[SwitchB-mrib-vpna] quit
# Create an MDT-based MVXLAN for VPN instance vpna and enter MVXLAN IPv4 address family view. Configure the MVXLAN source interface.
[SwitchB] multicast-vpn vxlan vpn-instance vpna mode mdt
[SwitchB-mvxlan-vpna] address-family ipv4
[SwitchB-mvxlan-vpna-ipv4] source loopback 0
[SwitchB-mvxlan-vpna-ipv4] quit
[SwitchB-mvxlan-vpna] quit
[SwitchB] interface loopback 1
[SwitchB-LoopBack1] ip binding vpn-instance vpna
[SwitchB-LoopBack1] ip address 12.12.12.12 32
[SwitchB-LoopBack1] pim sm
[SwitchB-LoopBack1] quit
[SwitchB] pim vpn-instance vpna
[SwitchB-pim-vpna] c-bsr 12.12.12.12
[SwitchB-pim-vpna] c-rp 12.12.12.12
[SwitchB-pim-vpna] quit
[SwitchB] vsi vpna
[SwitchB-vsi-vpna] gateway vsi-interface 1
[SwitchB] vsi vpnb
[SwitchB-vsi-vpnb] gateway vsi-interface 2
5.     Configure Switch C:
[SwitchC] l2vpn enable
[SwitchC] multicast routing
[SwitchC-mrib] quit
[SwitchC] vxlan tunnel mac-learning disable
[SwitchC] vxlan tunnel arp-learning disable
# Create VLAN-interface 13 and enter its view.
[SwitchC] vlan 13
[SwitchC-vlan13] quit
[SwitchC] interface vlan-interface 13
# Enable PIM-SM on VLAN-interface 13.
[SwitchC-Vlan-interface13] pim sm
[SwitchC-Vlan-interface13] quit
[SwitchC] bgp 200
[SwitchC-bgp-default] peer 4.4.4.4 as-number 200
[SwitchC-bgp-default] peer 4.4.4.4 connect-interface loopback 0
[SwitchC-bgp-default] address-family l2vpn evpn
[SwitchC-bgp-default-evpn] peer 4.4.4.4 enable
[SwitchC-bgp-default-evpn] quit
[SwitchC-bgp-default] quit
[SwitchC] ip vpn-instance vpna
[SwitchC-vpn-instance-vpna] route-distinguisher 1:1
[SwitchC-vpn-instance-vpna] address-family ipv4
[SwitchC-vpn-ipv4-vpna] vpn-target 1:1
[SwitchC-vpn-ipv4-vpna] quit
[SwitchC-vpn-instance-vpna] address-family evpn
[SwitchC-vpn-evpn-vpna] vpn-target 1:1
[SwitchC-vpn-evpn-vpna] quit
[SwitchC-vpn-instance-vpna] quit
[SwitchC] interface vsi-interface 3
[SwitchC-Vsi-interface3] ip binding vpn-instance vpna
[SwitchC-Vsi-interface3] l3-vni 1000
[SwitchC-Vsi-interface3] pim sm
[SwitchC-Vsi-interface3] quit
# Enable IP multicast routing on VPN instance vpna.
[SwitchC] multicast routing vpn-instance vpna
[SwitchC-mrib-vpna] quit
[SwitchC] multicast-vpn vxlan vpn-instance vpna mode mdt
[SwitchC-mvxlan-vpna] address-family ipv4
[SwitchC-mvxlan-vpna-ipv4] source loopback 0
[SwitchC-mvxlan-vpna-ipv4] quit
[SwitchC-mvxlan-vpna] quit
[SwitchC] interface loopback 1
[SwitchC-LoopBack1] ip binding vpn-instance vpna
[SwitchC-LoopBack1] ip address 12.12.12.12 32
[SwitchC-LoopBack1] pim sm
[SwitchC-LoopBack1] quit
[SwitchC] pim vpn-instance vpna
[SwitchC-pim-vpna] c-bsr 12.12.12.12
[SwitchC-pim-vpna] c-rp 12.12.12.12
[SwitchC-pim-vpna] quit
# Configure a default route. Specify the next hop as 20.1.1.100, the IP address of a device in the Layer 3 network.
[SwitchC] ip route-static vpn-instance vpna 0.0.0.0 0 20.1.1.100
# Import the default route to the BGP IPv4 unicast routing table of VPN instance vpna.
[SwitchC] bgp 200
[SwitchC-bgp-default] ip vpn-instance vpna
[SwitchC-bgp-default-vpna] address-family ipv4 unicast
[SwitchC-bgp-default-ipv4-vpna] default-route imported
[SwitchC-bgp-default-ipv4-vpna] import-route static
[SwitchC-bgp-default-ipv4-vpna] quit
[SwitchC-bgp-default-vpna] quit
# Create VLAN 20 and enter its view.
[SwitchC] vlan 20
[SwitchC-vlan20] quit
# Associate WAN-facing interface VLAN-interface 20 with VPN instance vpna.
[SwitchC] interface vlan-interface 20
[SwitchC-Vlan-interface20] ip binding vpn-instance vpna
[SwitchC-Vlan-interface20] ip address 20.1.1.3 24
[SwitchC-Vlan-interface20] pim sm
[SwitchC-Vlan-interface20] quit
6.     Configure Switch D:
<SwitchD> system-view
[SwitchD] multicast routing
[SwitchD-mrib] quit
# Enter PIM view, and configure Loopback 0 as a candidate-BSR and candidate-RP in the public network.
[SwitchD] pim
[SwitchD-pim] c-bsr 4.4.4.4
[SwitchD-pim] c-rp 4.4.4.4
[SwitchD-pim] quit
[SwitchD] interface vlan-interface11
[SwitchD-Vlan-interface11] pim sm
[SwitchD-Vlan-interface11] quit
[SwitchD] interface vlan-interface12
[SwitchD-Vlan-interface12] pim sm
[SwitchD-Vlan-interface12] quit
[SwitchD] interface vlan-interface13
[SwitchD-Vlan-interface13] pim sm
[SwitchD-Vlan-interface13] quit
# Establish BGP connections with other transport network switches.
[SwitchD] bgp 200
[SwitchD-bgp-default] group evpn
[SwitchD-bgp-default] peer 1.1.1.1 group evpn
[SwitchD-bgp-default] peer 2.2.2.2 group evpn
[SwitchD-bgp-default] peer 3.3.3.3 group evpn
[SwitchD-bgp-default] peer evpn as-number 200
[SwitchD-bgp-default] peer evpn connect-interface loopback 0
# Configure BGP to advertise BGP EVPN routes, and disable route target filtering of received BGP EVPN routes.
[SwitchD-bgp-default] address-family l2vpn evpn
[SwitchD-bgp-default-evpn] peer evpn enable
[SwitchD-bgp-default-evpn] undo policy vpn-target
# Configure Switch D as an RR.
[SwitchD-bgp-default-evpn] peer evpn reflect-client
[SwitchD-bgp-default-evpn] quit
[SwitchD-bgp-default] quit
1.     Verify the multicast routing information on Switch A:
# Verify that Switch A has multicast routing entries for VPN instance vpna.
<SwitchA> display pim vpn-instance vpna routing-table
 Total 1 (*, G) entries; 1 (S, G) entries
 (*, 225.0.0.0)
     RP: 12.12.12.12 (local)
     Protocol: pim-sm, Flag: WC RC
     UpTime: 02:57:31
     Upstream interface: Register-Tunnel0
         1: MTunnel0
             Protocol: MD, UpTime: 02:57:31, Expires: -
(10.1.1.10, 225.0.0.0)
     Protocol: pim-sm, Flag: SPT 2MSDP LOC ACT SQ RC 2MVPN
     UpTime: 04:44:08
     Upstream interface: Vsi-interface1
         1: MTunnel1
             Protocol: MD, UpTime: 02:00:27, Expires: -
# Verify that Switch A has multicast routing entries for the public network.
<SwitchA> display pim routing-table
 Total 0 (*, G) entries; 2 (S, G) entries
(1.1.1.1, 236.0.0.1)
     RP: 4.4.4.4
     Protocol: pim-sm, Flag: SPT LOC VXLAN_L3
     UpTime: 02:09:52
     Upstream interface: MTunnel0 (VPN: vpna)
         1: Vlan-interface11
             Protocol: pim-sm, UpTime: 01:16:34, Expires: 00:03:10
(1.1.1.1, 239.0.1.0)
     RP: 4.4.4.4
     UpTime: 02:08:52
     Upstream interface: MTunnel1 (VPN: vpna)
         1: Vlan-interface11
             Protocol: pim-sm, UpTime: 01:15:34, Expires: 00:03:11
2.     Verify the multicast routing information on Switch B:
# Verify that Switch B has multicast routing entries for VPN instance vpna.
<SwitchB> display pim vpn-instance vpna routing-table
(*, 225.0.0.0)
     UpTime: 05:04:06
         1: Vsi-interface1
             Protocol: igmp, UpTime: 05:04:06, Expires: -
     Protocol: pim-sm, Flag: SPT ACT RQ FROMVXLAN
     UpTime: 01:57:12
     Upstream interface: MVXLAN-UPE0 (0.0.0.0)
         1: Vsi-interface1
             Protocol: pim-sm, UpTime: 01:57:12, Expires: -
# Verify that Switch B has multicast routing entries for the public network.
<SwitchB> display pim routing-table
     RP: 4.4.4.4
     UpTime: 01:59:46
     Upstream interface: Vlan-interface12
         Upstream neighbor: 12.1.1.4
         RPF prime neighbor: 12.1.1.4
         1: MVXLAN-UPE0
             Protocol: MD, UpTime: 01:59:46, Expires: -
     RP: 4.4.4.4
     UpTime: 01:58:46
         1: MVXLAN-UPE0
             Protocol: MD, UpTime: 01:58:46, Expires: -
Example: Configuring intra-VPN MVXLAN Layer 3 multicast forwarding (IPv6 site network)
As shown in Figure 11, VM 1 is the multicast source of multicast group FF1E::, and the other VMs are multicast receivers. Configure MVXLAN to forward the multicast traffic from the source to the receivers.
·     Configure PIM-SM on the transport-facing interfaces of Switches A through D. Configure MLD snooping on Switches A through C for multicast forwarding entry creation.
Figure 12 Network diagram
1.     On VM 1 and VM 3, specify 10:1::1:1 as the gateway address. On VM 2 and VM 4, specify 10:1::2:1 as the gateway address. (Details not shown.)
[SwitchA-mrib] quit
# Enable the MLD snooping feature.
[SwitchA] mld-snooping
[SwitchA-mld-snooping] quit
# Disable remote MAC address learning and remote ND learning.
[SwitchA] vxlan tunnel nd-learning disable
[SwitchA] vlan 11
[SwitchA] vsi vpna
# Enable MLD snooping and MLD snooping proxying on VSI vpna.
[SwitchA-vsi-vpna] mld-snooping enable
[SwitchA-vsi-vpna] mld-snooping proxy enable
# Create VXLAN 10.
[SwitchA] vsi vpnb
# Enable MLD snooping and MLD snooping proxying on VSI vpnb.
[SwitchA-vsi-vpnb] mld-snooping enable
[SwitchA-vsi-vpnb] mld-snooping proxy enable
# Create VXLAN 20.
[SwitchA] bgp 200
# Create VLAN 2.
[SwitchA] vlan 2
# Create VLAN 3.
[SwitchA] vlan 3
[SwitchA-vpn-instance-vpna] address-family ipv6
[SwitchA-vpn-ipv6-vpna] vpn-target 1:1
[SwitchA-vpn-ipv6-vpna] quit
[SwitchA-Vsi-interface1] ipv6 address 10:1::1:1 96
[SwitchA-Vsi-interface1] ipv6 pim sm
[SwitchA-Vsi-interface1] ipv6 pim distributed-dr
[SwitchA-Vsi-interface2] ipv6 address 10:1::2:1 96
[SwitchA-Vsi-interface2] mld enable
[SwitchA-Vsi-interface3] ipv6 pim sm
[SwitchA] ipv6 multicast routing vpn-instance vpna
[SwitchA-mrib6-vpna] quit
# Create an MDT-based MVXLAN for VPN instance vpna and enter MVXLAN IPv6 address family view. Configure the default group, MVXLAN source interface, and data group range settings.
[SwitchA-mvxlan-vpna] address-family ipv6
[SwitchA-mvxlan-vpna-ipv6] default-group 236.0.0.1
[SwitchA-mvxlan-vpna-ipv6] source loopback 0
[SwitchA-mvxlan-vpna-ipv6] data-group 239.0.1.0 30
[SwitchA-mvxlan-vpna-ipv6] quit
[SwitchA-LoopBack1] ipv6 address 12:12::12:12 128
[SwitchA-LoopBack1] ipv6 pim sm
# Enter VPN instance IPv6 PIM view, and configure Loopback 1 as a candidate-BSR and candidate-RP in VPN instance vpna.
[SwitchA] ipv6 pim vpn-instance vpna
[SwitchA-pim6-vpna] c-bsr 12:12::12:12
[SwitchA-pim6-vpna] c-rp 12:12::12:12
[SwitchA-pim6-vpna] quit
[SwitchA] vsi vpna
[SwitchA] vsi vpnb
[SwitchB-mrib] quit
[SwitchB] mld-snooping
[SwitchB-mld-snooping] quit
[SwitchB] vxlan tunnel nd-learning disable
[SwitchB] vlan 12
[SwitchB] vsi vpna
[SwitchB-vsi-vpna] mld-snooping enable
[SwitchB-vsi-vpna] mld-snooping proxy enable
# Create VXLAN 10.
[SwitchB] vsi vpnb
[SwitchB-vsi-vpnb] mld-snooping enable
[SwitchB-vsi-vpnb] mld-snooping proxy enable
# Create VXLAN 20.
[SwitchB] bgp 200
# Create VLAN 2.
[SwitchB] vlan 2
# Create VLAN 3.
[SwitchB] vlan 3
[SwitchB-vpn-instance-vpna] address-family ipv6
[SwitchB-vpn-ipv6-vpna] vpn-target 1:1
[SwitchB-vpn-ipv6-vpna] quit
[SwitchB-Vsi-interface1] ipv6 address 10:1::1:1 96
[SwitchB-Vsi-interface1] mld enable
[SwitchB-Vsi-interface2] ipv6 address 10:1::2:1 96
[SwitchB-Vsi-interface2] mld enable
[SwitchB-Vsi-interface3] ipv6 pim sm
[SwitchB] ipv6 multicast routing vpn-instance vpna
[SwitchB-mrib6-vpna] quit
# Create an MDT-based MVXLAN for VPN instance vpna and enter MVXLAN IPv6 address family view. Configure the MVXLAN source interface.
[SwitchB-mvxlan-vpna] address-family ipv6
[SwitchB-mvxlan-vpna-ipv6] source loopback 0
[SwitchB-mvxlan-vpna-ipv6] quit
[SwitchB-LoopBack1] ipv6 address 12:12::12:12 128
[SwitchB-LoopBack1] ipv6 pim sm
[SwitchB] ipv6 pim vpn-instance vpna
[SwitchB-pim6-vpna] c-bsr 12:12::12:12
[SwitchB-pim6-vpna] c-rp 12:12::12:12
[SwitchB-pim6-vpna] quit
[SwitchB] vsi vpna
[SwitchB] vsi vpnb
[SwitchC-mrib] quit
[SwitchC] vxlan tunnel nd-learning disable
[SwitchC] vlan 13
[SwitchC] bgp 200
[SwitchC-vpn-instance-vpna] address-family ipv6
[SwitchC-vpn-ipv6-vpna] vpn-target 1:1
[SwitchC-vpn-ipv6-vpna] quit
[SwitchC-Vsi-interface3] ipv6 pim sm
[SwitchC] ipv6 multicast routing vpn-instance vpna
[SwitchC-mrib6-vpna] quit
[SwitchC-mvxlan-vpna] address-family ipv6
[SwitchC-mvxlan-vpna-ipv6] source loopback 0
[SwitchC-mvxlan-vpna-ipv6] quit
[SwitchC-LoopBack1] ipv6 address 12:12::12:12 128
[SwitchC-LoopBack1] ipv6 pim sm
[SwitchC] ipv6 pim vpn-instance vpna
[SwitchC-pim6-vpna] c-bsr 12:12::12:12
[SwitchC-pim6-vpna] c-rp 12:12::12:12
[SwitchC-pim6-vpna] quit
# Configure a default route. Specify the next hop as 20:1::1:100, the IP address of a device in the Layer 3 network.
[SwitchC] ipv6 route-static vpn-instance vpna 0::0 20:1::1:100
# Import the default route to the BGP IPv6 unicast routing table of VPN instance vpna.
[SwitchC] bgp 200
[SwitchC-bgp-default-vpna] address-family ipv6 unicast
[SwitchC-bgp-default-ipv6-vpna] default-route imported
[SwitchC-bgp-default-ipv6-vpna] import-route static
[SwitchC-bgp-default-ipv6-vpna] quit
[SwitchC] vlan 20
[SwitchC-Vlan-interface20] ipv6 address 20:1::1:3 96
[SwitchC-Vlan-interface20] ipv6 pim sm
[SwitchD-mrib] quit
[SwitchD] pim
[SwitchD-pim] quit
[SwitchD] bgp 200
<SwitchA> display ipv6 pim vpn-instance vpna routing-table
 (*, FF1E::1)
     RP: 12:12::12:12 (local)
     UpTime: 02:57:31
         1: MTunnel0
(10:1::1:10, FF1E::1)
     Protocol: pim-sm, Flag: SPT LOC ACT SQ RC SRC-ACT 2MVPN
     UpTime: 04:44:08
         1: MTunnel1
     RP: 4.4.4.4
     UpTime: 02:09:52
         1: Vlan-interface11
     RP: 4.4.4.4
     UpTime: 02:08:52
         1: Vlan-interface11
<SwitchB> display ipv6 pim vpn-instance vpna routing-table
(*, FF1E::1)
     UpTime: 05:04:06
         1: Vsi-interface1
             Protocol: mld, UpTime: 05:04:06, Expires: -
     RP: 12:12::12::12 (local)
     UpTime: 01:57:12
     Upstream interface: MVXLAN-UPE0 (::)
         1: Vsi-interface1
     RP: 4.4.4.4
     UpTime: 01:59:46
         1: MVXLAN-UPE0
     RP: 4.4.4.4
     UpTime: 01:58:46
         1: MVXLAN-UPE0
Example: Configuring MVXLAN extranet on the receiver VPN instance for symmetrically configured extranet
As shown in Figure 13, VM 1 is the multicast source of multicast group 225.0.0.0, and the other VMs are multicast receivers. VM 1, VM 2, and VM 3 belong to VPN instance vpna, and VM 4 belongs to VPN instance vpnb. VM 1 and VM 3 are in VXLAN 10, and VM 2 and VM 4 are in VXLAN 20. Configure MVXLAN to forward the multicast traffic from the source to the receivers.
·     Configure MVXLAN extranet to import the traffic of VPN instance vpna to VPN instance vpnb based on the L3 VXLAN ID on Switch B.
Figure 13 Network diagram
# Assign IP addresses to interfaces, as shown in Figure 13. (Details not shown.)
[SwitchA-mrib] quit
[SwitchA] vlan 11
[SwitchA] vsi vpna
[SwitchA-vsi-vpna-evpn-vxlan] vpn-target auto export-extcommunity
[SwitchA-vsi-vpna-evpn-vxlan] vpn-target auto import-extcommunity
# Create VXLAN 10.
[SwitchA] vsi vpnb
[SwitchA-vsi-vpnb-evpn-vxlan] vpn-target auto export-extcommunity
[SwitchA-vsi-vpnb-evpn-vxlan] vpn-target auto import-extcommunity
# Create VXLAN 20.
[SwitchA] bgp 200
# Create VLAN 2.
[SwitchA] vlan 2
# Create VLAN 3.
[SwitchA] vlan 3
[SwitchA] vsi vpna
[SwitchA] vsi vpnb
[SwitchB-mrib] quit
[SwitchB] vlan 12
[SwitchB] vsi vpna
[SwitchB-vsi-vpna-evpn-vxlan] vpn-target auto export-extcommunity
[SwitchB-vsi-vpna-evpn-vxlan] vpn-target auto import-extcommunity
# Create VXLAN 10.
[SwitchB] vsi vpnb
[SwitchB-vsi-vpnb-evpn-vxlan] vpn-target auto export-extcommunity
[SwitchB-vsi-vpnb-evpn-vxlan] vpn-target auto import-extcommunity
# Create VXLAN 20.
[SwitchB] bgp 200
# Create VLAN 2.
[SwitchB] vlan 2
# Create VLAN 3.
[SwitchB] vlan 3
[SwitchB-Ten-GigabitEthernet1/0/1-srv1000]encapsulation s-vid 2
# Configure Ten-GigabitEthernet 1/0/2 as a trunk port and assign it to VLAN 3.
[SwitchB] interface ten-gigabitethernet 1/0/2
[SwitchB-Ten-GigabitEthernet1/0/2] port link-type trunk
[SwitchB-Ten-GigabitEthernet1/0/2] port trunk permit vlan 3
# On Ten-GigabitEthernet 1/0/2, create Ethernet service instance 2000 to match VLAN 3.
[SwitchB-Ten-GigabitEthernet1/0/2] service-instance 2000
[SwitchB-Ten-GigabitEthernet1/0/2-srv2000] encapsulation s-vid 3
[SwitchB-Ten-GigabitEthernet1/0/2-srv2000] xconnect vsi vpnb
[SwitchB-Ten-GigabitEthernet1/0/2-srv2000] quit
[SwitchB-Ten-GigabitEthernet1/0/2] quit
# Configure RD and route target settings for VPN instance vpnb.
[SwitchB] ip vpn-instance vpnb
[SwitchB-vpn-instance-vpnb] route-distinguisher 2:2
[SwitchB-vpn-instance-vpnb] address-family ipv4
[SwitchB-vpn-ipv4-vpnb] vpn-target 1:1
[SwitchB-vpn-ipv4-vpnb] quit
[SwitchB-vpn-instance-vpnb] address-family evpn
[SwitchB-vpn-evpn-vpnb] vpn-target 1:1
[SwitchB-vpn-evpn-vpnb] quit
[SwitchB-vpn-instance-vpnb] quit
[SwitchB-Vsi-interface2] ip binding vpn-instance vpnb
# Enable IP multicast routing for VPN instance vpnb.
[SwitchB] multicast routing vpn-instance vpnb
[SwitchB-mrib-vpnb] quit
# Create an MDT-based MVXLAN for VPN instance vpna, enter MVXLAN IPv4 address family view, and configure the MVXLAN source interface.
# Configure Loopback 2.
[SwitchB] interface loopback 2
[SwitchB-LoopBack2] ip binding vpn-instance vpnb
[SwitchB-LoopBack2] ip address 13.13.13.13 32
[SwitchB-LoopBack2] pim sm
[SwitchB-LoopBack2] quit
# Enter VPN instance PIM view, and configure Loopback 2 as a candidate-BSR and candidate-RP in VPN instance vpnb.
[SwitchB] pim vpn-instance vpnb
[SwitchB-pim-vpnb] c-bsr 13.13.13.13
[SwitchB-pim-vpnb] c-rp 13.13.13.13
[SwitchB-pim-vpnb] quit
[SwitchB] vsi vpna
[SwitchB] vsi vpnb
# Enable IP multicast routing for VPN instance vpnb, and import the traffic of VPN instance vpna to VPN instance vpnb.
[SwitchB-mrib-vpnb] multicast extranet select-rpf l3-vni 1000 group 225.0.0.0 16
[SwitchC-mrib] quit
[SwitchC] vlan 13
[SwitchC] bgp 200
[SwitchC] ip vpn-instance vpnb
[SwitchC-vpn-instance-vpna] route-distinguisher 2:2
[SwitchC] multicast routing vpn-instance vpnb
[SwitchC-mrib-vpnb] quit
[SwitchC] interface loopback 2
[SwitchC-LoopBack2] ip binding vpn-instance vpnb
[SwitchC-LoopBack2] ip address 13.13.13.13 32
[SwitchC-LoopBack2] pim sm
[SwitchC-LoopBack2] quit
[SwitchC] pim vpn-instance vpnb
[SwitchC-pim-vpnb] c-bsr 13.13.13.13
[SwitchC-pim-vpnb] c-rp 13.13.13.13
[SwitchC-pim-vpnb] quit
[SwitchC] ip route-static vpn-instance vpnb 0.0.0.0 0 20.1.1.100
# Import the default route to the BGP IPv4 unicast routing table of VPN instance vpnb.
[SwitchC] bgp 200
[SwitchC-bgp-default] ip vpn-instance vpnb
[SwitchC-bgp-default-vpnb] address-family ipv4 unicast
[SwitchC-bgp-default-ipv4-vpnb] default-route imported
[SwitchC-bgp-default-ipv4-vpnb] import-route static
[SwitchC-bgp-default-ipv4-vpnb] quit
[SwitchC-bgp-default-vpnb] quit
# Create VLAN 20.
[SwitchC] vlan 20
# Configure VLAN-interface 20 that connects to the Layer 3 network and associate the interface with VPN instance vpnb.
[SwitchC-Vlan-interface20] ip binding vpn-instance vpnb
[SwitchC-mrib-vpnb] multicast extranet select-rpf l3-vni 1000 group 225.0.0.0 16
[SwitchD-mrib] quit
[SwitchD] pim
[SwitchD-pim] quit
[SwitchD] bgp 200
 (*, 225.0.0.0)
     UpTime: 03:01:20
         1: MTunnel0
         2: Vsi-interface2
             Protocol: igmp, UpTime: 03:01:22, Expires: -
     UpTime: 03:01:20
         1: MTunnel1
             Protocol: MD, UpTime: 02:56:31, Expires: -
         2: Vsi-interface2
     RP: 4.4.4.4
     UpTime: 04:09:52
         1: Vlan-interface11
             Protocol: pim-sm, UpTime: 04:09:40, Expires: 00:03:10
     RP: 4.4.4.4
     UpTime: 03:00:20
         1: Vlan-interface11
             Protocol: pim-sm, UpTime: 03:00:20, Expires: 00:03:11
(*, 225.0.0.0)
     UpTime: 03:01:20
     Total number of downstream interfaces: 2
         1: Extranet (VPN: vpnb)
             Protocol: MD, UpTime: 03:01:20, Expires: -
         2: Vsi-interface1
             Protocol: igmp, UpTime: 03:01:20, Expires: -
     Protocol: pim-sm, Flag: SPT ACT FROMVXLAN
     UpTime: 03:00:20
             Protocol: MD, UpTime: 03:00:20, Expires: -
         2: Vsi-interface1
             Protocol: pim-sm, UpTime: 03:00:20, Expires: -
# Verify that Switch B has multicast routing entries for VPN instance vpnb.
<SwitchB> display pim vpn-instance vpnb routing-table
(*, 225.0.0.0)
     RP: 13.13.13.13 (local)
     UpTime: 03:01:20
     Upstream interface: Extranet (VPN: vpna, l3-vni: 1000)
         Upstream neighbor: 127.0.0.1
         RPF prime neighbor: 127.0.0.1
         1: Vsi-interface2
             Protocol: igmp, UpTime: 05:04:11, Expires: -
     Protocol: pim-sm, Flag: SPT ACT RQ 2MVPN
     UpTime: 03:00:20
         1: Vsi-interface2
     RP: 4.4.4.4
     UpTime: 04:09:00
         1: MVXLAN-UPE0
             Protocol: MD, UpTime: 04:09:40, Expires: -
     RP: 4.4.4.4
     Protocol: pim-sm, Flag: SPT ACT 2MVPN
     UpTime: 03:00:20
         1: MVXLAN-UPE0
Example: Configuring MVXLAN extranet on the receiver VPN instance for asymmetrically configured extranet
As shown in Figure 14, VM 1 is the multicast source of multicast group 225.0.0.0, and the other VMs are multicast receivers. VM 1 and VM 2 belong to VPN instance vpna, VM 3 belongs to VPN instance vpnb, and VM 4 belongs to vpnc. VM 1 and VM 3 are in VXLAN 10, and VM 2 and VM 4 are in VXLAN 20. Configure MVXLAN to forward the multicast traffic from the source to the receivers.
·     Configure MVXLAN extranet to import the traffic of VPN instance vpna to VPN instance vpnb and VPN instance vpnc based on the L3 VXLAN ID on Switch B.
Figure 14 Network diagram
2.     Configure IP addresses and unicast routing settings:
# Assign IP addresses to interfaces, as shown in Figure 14. (Details not shown.)
[SwitchA-mrib] quit
[SwitchA] vlan 11
[SwitchA] vsi vpna
# Create VXLAN 10.
[SwitchA] vsi vpnb
# Create VXLAN 20.
[SwitchA] bgp 200
# Create VLAN 2.
[SwitchA] vlan 2
# Create VLAN 3.
[SwitchA] vlan 3
[SwitchA] vsi vpna
[SwitchA] vsi vpnb
[SwitchB-mrib] quit
[SwitchB] vlan 12
[SwitchB] vsi vpna
# Create VXLAN 10.
[SwitchB] vsi vpnb
# Create VXLAN 20.
[SwitchB] bgp 200
# Create VLAN 2.
[SwitchB] vlan 2
# Create VLAN 3.
[SwitchB] vlan 3
# Configure RD and route target settings for VPN instance vpnc.
[SwitchB] ip vpn-instance vpnc
[SwitchB-vpn-instance-vpnc] route-distinguisher 3:3
[SwitchB-vpn-instance-vpnc] address-family ipv4
[SwitchB-vpn-ipv4-vpnc] vpn-target 1:1
[SwitchB-vpn-ipv4-vpnc] quit
[SwitchB-vpn-instance-vpnc] address-family evpn
[SwitchB-vpn-evpn-vpnc] vpn-target 1:1
[SwitchB-vpn-evpn-vpnc] quit
[SwitchB-vpn-instance-vpnc] quit
[SwitchB-Vsi-interface1] ip binding vpn-instance vpnb
[SwitchB-Vsi-interface2] ip binding vpn-instance vpnc
# Configure the L3 VXLAN ID as 1000 for VSI-interface 3.
# Enable IP multicast routing for VPN instance vpnc.
[SwitchB] multicast routing vpn-instance vpnc
[SwitchB-mrib-vpnc] quit
# Create an MDT-based MVXLAN for VPN instance vpnb, enter MVXLAN IPv4 address family view, and configure the MVXLAN source interface.
[SwitchB] multicast-vpn vxlan vpn-instance vpnb mode mdt
[SwitchB-mvxlan-vpnb] address-family ipv4
[SwitchB-mvxlan-vpnb-ipv4] source loopback 0
[SwitchB-mvxlan-vpnb-ipv4] quit
[SwitchB-mvxlan-vpnb] quit
# Create an MDT-based MVXLAN for VPN instance vpnc, enter MVXLAN IPv4 address family view, and configure the MVXLAN source interface.
[SwitchB] multicast-vpn vxlan vpn-instance vpnc mode mdt
[SwitchB-mvxlan-vpnc] address-family ipv4
[SwitchB-mvxlan-vpnc-ipv4] source loopback 0
[SwitchB-mvxlan-vpnc-ipv4] quit
[SwitchB-mvxlan-vpnc] quit
[SwitchB-LoopBack1] ip binding vpn-instance vpnb
# Enter VPN instance PIM view, and configure Loopback 1 as a candidate-BSR and candidate-RP in VPN instance vpnb.
[SwitchB-pim-vpnb] c-bsr 12.12.12.12
[SwitchB-pim-vpnb] c-rp 12.12.12.12
[SwitchB-LoopBack2] ip binding vpn-instance vpnc
# Enter VPN instance PIM view, and configure Loopback 2 as a candidate-BSR and candidate-RP in VPN instance vpnc.
[SwitchB] pim vpn-instance vpnc
[SwitchB-pim-vpnc] c-bsr 13.13.13.13
[SwitchB-pim-vpnc] c-rp 13.13.13.13
[SwitchB-pim-vpnc] quit
# Specify VSI-interface 1 as the gateway interface for VSI vpna.
[SwitchB] vsi vpna
[SwitchB] vsi vpnb
# Enable IP multicast routing for VPN instance vpnb and VPN instance vpnc, and import the traffic of VPN instance vpna to VPN instance vpnb and VPN instance vpnc.
[SwitchB-mrib-vpnc] multicast extranet select-rpf l3-vni 1000 group 225.0.0.0 16
[SwitchC-mrib] quit
[SwitchC] vlan 13
[SwitchC] bgp 200
[SwitchC-vpn-instance-vpnb] route-distinguisher 1:1
[SwitchC-vpn-instance-vpnb] address-family ipv4
[SwitchC-vpn-ipv4-vpnb] vpn-target 1:1
[SwitchC-vpn-ipv4-vpnb] quit
[SwitchC-vpn-instance-vpnb] address-family evpn
[SwitchC-vpn-evpn-vpnb] vpn-target 1:1
[SwitchC-vpn-evpn-vpnb] quit
[SwitchC-vpn-instance-vpnb] quit
[SwitchC] multicast-vpn vxlan vpn-instance vpnb mode mdt
[SwitchC-mvxlan-vpnb] address-family ipv4
[SwitchC-mvxlan-vpnb-ipv4] source loopback 0
[SwitchC-mvxlan-vpnb-ipv4] quit
[SwitchC-mvxlan-vpnb] quit
[SwitchC-LoopBack1] ip binding vpn-instance vpnb
[SwitchC-pim-vpnb] c-bsr 12.12.12.12
[SwitchC-pim-vpnb] c-rp 12.12.12.12
[SwitchC] bgp 200
# Create VLAN 20.
[SwitchC] vlan 20
# Enable IP multicast routing.
[SwitchD-mrib] quit
[SwitchD] pim
[SwitchD-pim] quit
[SwitchD] bgp 200
 (*, 225.0.0.0)
     UpTime: 02:57:31
         1: MTunnel0
         2: Vsi-interface2
             Protocol: igmp, UpTime: 02:57:31, Expires: -
     UpTime: 02:56:31
         1: MTunnel1
             Protocol: MD, UpTime: 02:56:21, Expires: -
         2: Vsi-interface2
             Protocol: igmp, UpTime: 02:56:31, Expires: -
     RP: 4.4.4.4
     UpTime: 03:09:52
         1: Vlan-interface11
             Protocol: pim-sm, UpTime: 03:08:52, Expires: 00:03:10
     RP: 4.4.4.4
     UpTime: 02:55:31
         1: Vlan-interface11
             Protocol: pim-sm, UpTime: 02:55:20, Expires: 00:03:11
(*, 225.0.0.0)
     UpTime: 02:56:32
     Upstream interface: Extranet (public instance, l3-vni: 1000)
         1: Vsi-interface1
             Protocol: igmp, UpTime: 02:56:32, Expires: -
     UpTime: 02:55:20
         1: Vsi-interface1
             Protocol: pim-sm, UpTime: 02:55:20, Expires: -
# Verify that Switch B has multicast routing entries for VPN instance vpnc.
<SwitchB> display pim vpn-instance vpnc routing-table
(*, 225.0.0.0)
     UpTime: 02:56:32
         1: Vsi-interface2
     UpTime: 02:55:20
         1: Vsi-interface2
     RP: 4.4.4.4
     UpTime: 03:08:52
         1: MVXLAN-UPE0
             Protocol: MD, UpTime: 03:08:52, Expires: -
     RP: 4.4.4.4
     UpTime: 02:55:31
         1: MVXLAN-UPE0
             Protocol: MD, UpTime: 02:55:31, Expires: -
Example: Configuring MVXLAN extranet with receivers on both VPNs and the public network
As shown in Figure 15, VM 1 is the multicast source of multicast group 225.0.0.0, and the other VMs are multicast receivers. VM 1 and VM 2 belong to VPN instance vpna, VM 3 belongs to the public instance, and VM 4 belongs to VPN instance vpnb. VM 1 and VM 3 are in VXLAN 10, and VM 2 and VM 4 are in VXLAN 20. Configure MVXLAN to forward the multicast traffic from the source to the receivers.
·     Configure MVXLAN extranet to import the traffic of VPN instance vpna to VPN instance vpnb and the public instance.
Figure 15 Network diagram
1.     On VM 1 and VM 2, specify 10.1.1.1 as the gateway address. On VM 3 and VM 4, specify 10.1.2.1 as the gateway address. (Details not shown.)
# Assign IP addresses to interfaces, as shown in Figure 15. (Details not shown.)
[SwitchA-mrib] quit
[SwitchA] vlan 11
[SwitchA] vsi vpna
# Create VXLAN 10.
[SwitchA] vsi vpnb
# Create VXLAN 20.
[SwitchA] bgp 200
# Create VLAN 2.
[SwitchA] vlan 2
# Create VLAN 3.
[SwitchA] vlan 3
[SwitchA] vsi vpna
[SwitchA] vsi vpnb
[SwitchB-mrib] quit
[SwitchB] vlan 12
[SwitchB] vsi vpna
# Create VXLAN 10.
[SwitchB] vsi vpnb
# Create VXLAN 20.
[SwitchB] bgp 200
# Create VLAN 2.
[SwitchB] vlan 2
# Create VLAN 3.
[SwitchB] vlan 3
[SwitchB-vpn-instance-vpnb] route-distinguisher 1:1
# Configure RD and route target settings for the public instance.
[SwitchB] ip public-instance
[SwitchB-public-instance] route-distinguisher 2:2
[SwitchB-public-instance] address-family ipv4
[SwitchB-public-instance-ipv4] vpn-target 1:1
[SwitchB-public-instance-ipv4] quit
[SwitchB-public-instance] address-family evpn
[SwitchB-public-instance-evpn] vpn-target 1:1
[SwitchB-public-instance-evpn] quit
[SwitchB-public-instance] quit
# Create VSI-interface 4 and configure its L3 VXLAN ID as 1000.
[SwitchB] interface vsi-interface 4
[SwitchB-Vsi-interface4] l3-vni 1000
[SwitchB-Vsi-interface4] pim sm
[SwitchB-Vsi-interface4] quit
# Create IPv4 basic ACL 2000 and enter its view. Create a rule in the ACL to permit only packets from 225.0.0.0/8.
[SwitchB-acl-ipv4-basic-2000] acl basic 2000
[SwitchB-acl-ipv4-basic-2000] rule permit source 225.0.0.0 0.255.255.255
[SwitchB-acl-ipv4-basic-2000] quit
# Enter public instance PIM view, configure Loopback 2 as a candidate-BSR and candidate-RP in the public instance, and specify a candidate-RP policy.
[SwitchB] pim
[SwitchB-pim] c-bsr 13.13.13.13
[SwitchB-pim] c-rp 13.13.13.13 group-policy 2000
[SwitchB-pim] quit
[SwitchB] vsi vpna
[SwitchB] vsi vpnb
[SwitchB-mrib-vpnb] multicast extranet select-rpf group 225.0.0.0 16
[SwitchC-mrib] quit
[SwitchC] vlan 13
[SwitchC] bgp 200
[SwitchC] ip public-instance
[SwitchC-public-instance] route-distinguisher 1:1
[SwitchC-public-instance] address-family ipv4
[SwitchC-public-instance] vpn-target 1:1
[SwitchC-public-instance] quit
[SwitchC-public-instance] address-family evpn
# Create an MDT-based MVXLAN for the public instance, enter MVXLAN IPv4 address family view, and configure the MVXLAN source interface.
[SwitchC] multicast-vpn vxlan public-instance mode mdt
[SwitchC-mvxlan-public-instance] address-family ipv4
[SwitchC-mvxlan-public-instance-ipv4] source loopback 0
[SwitchC-mvxlan-public-instance-ipv4] quit
[SwitchC-mvxlan-public-instance] quit
[SwitchC-acl-ipv4-basic-2000] acl basic 2000
[SwitchC-acl-ipv4-basic-2000] rule permit source 225.0.0.0 0.255.255.255
[SwitchC-acl-ipv4-basic-2000] qui
# Enter PIM view, and configure Loopback 1 as a candidate-BSR and candidate-RP in the public network.
[SwitchC] pim
[SwitchC-pim] c-bsr 12.12.12.12
[SwitchC-pim] c-rp 12.12.12.12 group-policy 2000
[SwitchC-pim] quit
[SwitchC] ip route-static 0.0.0.0 0 20.1.1.100
# Import the default route to the BGP IPv4 unicast routing table of the public instance.
[SwitchC] bgp 200
[SwitchC-bgp-default-ipv4] default-route imported
[SwitchC-bgp-default-ipv4] import-route static
# Create VLAN 20.
[SwitchC] vlan 20
# Configure VLAN-interface 20 that connects to the Layer 3 network and associate the interface with the public instance.
[SwitchD-mrib] quit
[SwitchD] pim
[SwitchD-pim] quit
[SwitchD] bgp 200
 (*, 225.0.0.0)
     UpTime: 02:57:31
         Upstream neighbor: NULL
         RPF prime neighbor: NULL
     Downstream interface information:
         1: MTunnel0
     UpTime: 02:56:31
         1: MTunnel1
     RP: 4.4.4.4
     UpTime: 03:09:52
         1: Vlan-interface11
             Protocol: pim-sm, UpTime: 03:09:50, Expires: 00:03:10
     RP: 4.4.4.4
     UpTime: 02:55:31
         1: Vlan-interface11
             Protocol: pim-sm, UpTime: 02:55:28, Expires: 00:03:11
(*, 225.0.0.0)
     UpTime: 02:56:35
     Upstream interface: Extranet (public instance)
     Total number of downstream interfaces: 11: Vsi-interface2
             Protocol: igmp, UpTime: 02:56:35, Expires: -
     UpTime: 02:56:31
     Total number of downstream interfaces: 1  1: Vsi-interface2
Total 1 (*, G) entries; 3 (S, G) entries
(*, 225.0.0.0)
     UpTime: 02:56:31
       1: Vsi-interface 1
         2: Extranet (VPN: vpnb)
     UpTime: 02:56:30
         1: Vsi-interface 1
     RP: 4.4.4.4
     UpTime: 03:00:46
         1: MVXLAN-UPE0
             Protocol: MD, UpTime: 03:00:46, Expires: -
     RP: 4.4.4.4
     UpTime: 02:56:31
         1: MVXLAN-UPE0
Example: Configuring M-LAG in MVXLAN with an Ethernet aggregate link as the peer link
As shown in Figure 16, set up M-LAG systems as follows:
·     Set up an M-LAG system with distributed EVPN gateways Switch A and Switch B. The devices are attached to multicast source 1.
·     Set up an M-LAG system with distributed EVPN gateways Switch C and Switch D. The devices are attached to multicast receiver 1.
·     Set up an M-LAG system with border devices Switch E and Switch F. The devices are attached to multicast receiver 2. Configure the devices as RRs to reflect BGP EVPN routes.
·     Configure an Ethernet aggregate link as the peer link for each M-LAG system.
·     On each switch, configure VLAN 100 as the reserved VLAN for the peer link and add the peer-link interface to VLAN 100. The peer link can be used as the failover link for Layer multicast traffic when the uplink fails.
·     Configure IGMP snooping on Switches A through F for multicast forwarding entry creation.
·     Configure PIM-SM on the transport-facing interfaces of Switches A through F.
·     Configure VXLAN 10 on the M-LAG systems for the multicast receivers to receive multicast traffic from multicast source 1.
Figure 16 Network diagram
Device
IP address
Device
IP address
Switch A
Loop0
1.1.1.1/32
Switch B
Loop0
2.2.2.2/32
Loop1
1.2.3.4/32
Loop1
1.2.3.4/32
Loop2
1.2.3.4/32
Loop2
1.2.3.4/32
Vlan-int2
192.168.1.1/24
Vlan-int2
192.168.1.2/24
Vlan-int3
30.1.1.1/24
Vlan-int5
50.1.1.2/24
Vlan-int4
40.1.1.1/24
Vlan-int6
60.1.1.2/24
Vlan-int100
100.1.1.1/24
Vlan-int100
100.1.1.2/24
Switch C
Loop0
3.3.3.3/32
Switch D
Loop0
4.4.4.4/32
Loop1
1.2.3.6/32
Loop1
1.2.3.6/32
Loop2
1.2.3.6/32
Loop2
1.2.3.6/32
Vlan-int7
70.1.1.3/24
Vlan-int9
90.1.1.4/24
Vlan-int8
80.1.1.3/24
Vlan-int10
100.1.1.4/24
Vlan-int12
192.168.3.1/24
Vlan-int12
192.168.3.2/24
Vlan-int100
100.1.1.3/24
Vlan-int100
100.1.1.4/24
Switch E
Loop0
5.5.5.5/32
Switch F
Loop0
6.6.6.6/32
Loop1
1.2.3.5/32
Loop1
1.2.3.5/32
Loop2
1.2.3.5/32
Loop2
1.2.3.5/32
Vlan-int3
30.1.1.5/24
Vlan-int4
40.1.1.6/24
Vlan-int5
50.1.1.5/24
Vlan-int6
60.1.1.6/24
Vlan-int7
70.1.1.5/24
Vlan-int8
80.1.1.6/24
Vlan-int9
90.1.1.5/24
Vlan-int10
100.1.1.6/24
Vlan-int11
192.168.4.1/24
Vlan-int11
192.168.4.2/24
Vlan-int100
100.1.1.5/24
Vlan-int100
100.1.1.6/24
1.     Configure IP addresses and unicast routing settings:
# Assign IP addresses to interfaces, as shown in Figure 16. (Details not shown.)
# Configure OSPF on all transport network switches (Switches A through F) for them to reach one another. (Details not shown.)
2.     Configure Switch A:
# Enable L2VPN.
# Specify the virtual VTEP address as 1.2.3.4.
[SwitchA] evpn m-lag group 1.2.3.4
# Specify the IP addresses of the member devices in the M-LAG system.
[SwitchA] evpn m-lag local 1.1.1.1 remote 2.2.2.2
[SwitchA-mrib] quit
[SwitchA] vsi vpna
# Create VXLAN 10.
[SwitchA] bgp 200
[SwitchA-bgp-default] peer 5.5.5.5 as-number 200
[SwitchA-bgp-default] peer 5.5.5.5 connect-interface loopback 0
[SwitchA-bgp-default] peer 6.6.6.6 as-number 200
[SwitchA-bgp-default] peer 6.6.6.6 connect-interface loopback 0
[SwitchA-bgp-default-evpn] peer 5.5.5.5 enable
[SwitchA-bgp-default-evpn] peer 6.6.6.6 enable
[SwitchA-vpn-ipv4-vpna] vpn-target 2:2
[SwitchA-Vsi-interface1] igmp enable
# Configure Loopback 0.
[SwitchA-LoopBack0] ip address 1.1.1.1 32
[SwitchA-LoopBack0] pim sm
[SwitchA-LoopBack0] ospf 1 area 0
[SwitchA-LoopBack0] quit
[SwitchA-LoopBack1] ip address 1.2.3.4 32
[SwitchA-LoopBack1] ospf 1 area 0
[SwitchA] interface loopback 2
[SwitchA-LoopBack2] ip binding vpn-instance vpna
[SwitchA-LoopBack2] ip address 1.2.3.4 32
[SwitchA-LoopBack2] pim sm
[SwitchA-LoopBack2] quit
[SwitchA-mvxlan-vpna-ipv4] source loopback 1 evpn-mlag-group
[SwitchA-mvxlan-vpna-ipv4] data-group 239.0.0.1 30
# Enter VPN instance PIM view, and configure Loopback 2 as a candidate-BSR and candidate-RP in VPN instance vpna.
[SwitchA-pim-vpna] c-bsr 1.2.3.4
[SwitchA-pim-vpna] c-rp 1.2.3.4
[SwitchA] vsi vpna
# Configure VLAN 100 as the reserved VLAN for the peer link.
[SwitchA] vlan 100
[SwitchA–vlan100] m-lag peer-link reserved
[SwitchA–vlan100] quit
# Configure an M-LAG interface.
[SwitchA] interface bridge-aggregation 21
[SwitchA-Bridge-Aggregation21] port link-type trunk
[SwitchA-Bridge-Aggregation21] port trunk permit vlan 1 20 to 29
[SwitchA-Bridge-Aggregation21] link-aggregation mode dynamic
[SwitchA-Bridge-Aggregation21] port m-lag group 1
# Map Ethernet service instance 100 to VSI vpna.
[SwitchA-Bridge-Aggregation21] service-instance 100
[SwitchA-Bridge-Aggregation21-srv100] encapsulation s-vid 21
[SwitchA-Bridge-Aggregation21-srv100] xconnect vsi vpna
[SwitchA-Bridge-Aggregation21-srv100] quit
# Assign a Layer 2 Ethernet interface to the aggregation group of the M-LAG interface.
[SwitchA-Ten-GigabitEthernet1/0/1] port link-aggregation group 21
# Configure an aggregate interface as the peer-link interface.
[SwitchA] interface bridge-aggregation 9
[SwitchA-Bridge-Aggregation9] port link-type trunk
[SwitchA-Bridge-Aggregation9] port trunk permit vlan all
[SwitchA-Bridge-Aggregation9] link-aggregation mode dynamic
[SwitchA-Bridge-Aggregation9] port m-lag peer-link 1
[SwitchA-Bridge-Aggregation9] quit
# Assign a Layer 2 Ethernet interface to the aggregation group of the peer-link interface.
[SwitchA] interface ten-gigabitethernet 1/0/2
[SwitchA-Ten-GigabitEthernet1/0/2] port link-aggregation group 9
[SwitchA-Ten-GigabitEthernet1/0/2] quit
# Exclude the interface used for setting up the keepalive link from the shutdown action by M-LAG MAD.
[SwitchA] m-lag mad exclude interface ten-gigabitethernet 1/0/3
# Configure M-LAG system parameters.
[SwitchA] m-lag restore-delay 180
[SwitchA] m-lag system-mac 1-1-1
[SwitchA] m-lag system-number 1
[SwitchA] m-lag system-priority 10
[SwitchA] m-lag keepalive ip destination 192.168.1.2 source 192.168.1.1
3.     Configure Switch B:
# Enable L2VPN.
[SwitchB] evpn m-lag group 1.2.3.4
[SwitchB] evpn m-lag local 2.2.2.2 remote 1.1.1.1
[SwitchB-mrib] quit
[SwitchB] vsi vpna
# Create VXLAN 10.
[SwitchB] bgp 200
[SwitchB-bgp-default] peer 5.5.5.5 as-number 200
[SwitchB-bgp-default] peer 5.5.5.5 connect-interface loopback 0
[SwitchB-bgp-default] peer 6.6.6.6 as-number 200
[SwitchB-bgp-default] peer 6.6.6.6 connect-interface loopback 0
[SwitchB-bgp-default-evpn] peer 5.5.5.5 enable
[SwitchB-bgp-default-evpn] peer 6.6.6.6 enable
[SwitchB-vpn-ipv4-vpna] vpn-target 2:2
[SwitchB-Vsi-interface1] pim sm
[SwitchB-Vsi-interface1] pim distributed-dr
[SwitchB-LoopBack0] ip address 2.2.2.2 32
[SwitchB-LoopBack0] pim sm
[SwitchB-LoopBack0] ospf 1 area 0
[SwitchB-LoopBack0] quit
[SwitchB-LoopBack1] ip address 1.2.3.4 32
[SwitchB-LoopBack1] ospf 1 area 0
[SwitchB-LoopBack2] ip binding vpn-instance vpna
[SwitchB-LoopBack2] ip address 1.2.3.4 32
[SwitchB-mvxlan-vpna-ipv4] default-group 236.0.0.1
[SwitchB-mvxlan-vpna-ipv4] source loopback 1 evpn-mlag-group
[SwitchB-mvxlan-vpna-ipv4] data-group 239.0.0.1 30
[SwitchB-pim-vpna] c-bsr 1.2.3.4
[SwitchB-pim-vpna] c-rp 1.2.3.4
[SwitchB] vsi vpna
[SwitchB] vlan 100
[SwitchB–vlan100] m-lag peer-link reserved
[SwitchB–vlan100] quit
[SwitchB] interface bridge-aggregation 21
[SwitchB-Bridge-Aggregation21] port link-type trunk
[SwitchB-Bridge-Aggregation21] port trunk permit vlan 1 20 to 29
[SwitchB-Bridge-Aggregation21] link-aggregation mode dynamic
[SwitchB-Bridge-Aggregation21] port m-lag group 1
[SwitchB-Bridge-Aggregation21] service-instance 100
[SwitchB-Bridge-Aggregation21-srv100] encapsulation s-vid 21
[SwitchB-Bridge-Aggregation21-srv100] xconnect vsi vpna
[SwitchB-Bridge-Aggregation21-srv100] quit
[SwitchB-Ten-GigabitEthernet1/0/1] port link-aggregation group 21
[SwitchB] interface bridge-aggregation 9
[SwitchB-Bridge-Aggregation9] port link-type trunk
[SwitchB-Bridge-Aggregation9] port trunk permit vlan all
[SwitchB-Bridge-Aggregation9] link-aggregation mode dynamic
[SwitchB-Bridge-Aggregation9] port m-lag peer-link 1
[SwitchB-Bridge-Aggregation9] quit
[SwitchB-Ten-GigabitEthernet1/0/2] port link-aggregation group 9
[SwitchB] m-lag mad exclude interface ten-gigabitethernet 1/0/3
[SwitchB] m-lag restore-delay 180
[SwitchB] m-lag system-mac 1-1-1
[SwitchB] m-lag system-number 2
[SwitchB] m-lag system-priority 10
[SwitchB] m-lag keepalive ip destination 192.168.1.1 source 192.168.1.2
4.     Configure Switch C:
# Enable L2VPN.
# Specify the virtual VTEP address as 1.2.3.6.
[SwitchC] evpn m-lag group 1.2.3.6
[SwitchC] evpn m-lag local 3.3.3.3 remote 4.4.4.4
[SwitchC-mrib] quit
[SwitchC] igmp-snooping
[SwitchC-igmp-snooping] quit
[SwitchC] vsi vpna
[SwitchC-vsi-vpna] evpn encapsulation vxlan
[SwitchC-vsi-vpna-evpn-vxlan] route-distinguisher auto
[SwitchC-vsi-vpna-evpn-vxlan] vpn-target auto
[SwitchC-vsi-vpna-evpn-vxlan] quit
[SwitchC-vsi-vpna] igmp-snooping enable
[SwitchC-vsi-vpna] igmp-snooping proxy enable
# Create VXLAN 10.
[SwitchC-vsi-vpna] vxlan 10
[SwitchC-vsi-vpna] quit
[SwitchC] bgp 200
[SwitchC-bgp-default] peer 6.6.6.6 as-number 200
[SwitchC-bgp-default] peer 6.6.6.6 connect-interface loopback 0
[SwitchC-bgp-default] peer 5.5.5.5 as-number 200
[SwitchC-bgp-default] peer 5.5.5.5 connect-interface loopback 0
[SwitchC-bgp-default-evpn] peer 6.6.6.6 enable
[SwitchC-bgp-default-evpn] peer 5.5.5.5 enable
[SwitchC-vpn-ipv4-vpna] vpn-target 2:2
[SwitchC] interface vsi-interface 1
[SwitchC-Vsi-interface1] ip binding vpn-instance vpna
[SwitchC-Vsi-interface1] ip address 10.1.1.1 255.255.255.0
[SwitchC-Vsi-interface1] pim sm
[SwitchC-Vsi-interface1] igmp enable
[SwitchC-Vsi-interface1] pim distributed-dr
[SwitchC-Vsi-interface1] mac-address 1-1-1
[SwitchC-Vsi-interface1] distributed-gateway local
[SwitchC-Vsi-interface1] local-proxy-arp enable
[SwitchC-Vsi-interface1] quit
[SwitchC-LoopBack0] ip address 3.3.3.3 32
[SwitchC-LoopBack0] pim sm
[SwitchC-LoopBack0] ospf 1 area 0
[SwitchC-LoopBack1] ip address 1.2.3.6 32
[SwitchC-LoopBack1] ospf 1 area 0
[SwitchC-LoopBack2] ip binding vpn-instance vpna
[SwitchC-LoopBack2] ip address 1.2.3.6 255.255.255.255
[SwitchC-mvxlan-vpna-ipv4] default-group 236.0.0.1
[SwitchC-mvxlan-vpna-ipv4] source loopback 1 evpn-mlag-group
[SwitchC-mvxlan-vpna-ipv4] data-group 239.0.1.0 30
[SwitchC-mvxlan-vpna-ipv4] m-lag local 3.3.3.3 remote 4.4.4.4
[SwitchC-pim-vpna] c-bsr 1.2.3.6
[SwitchC-pim-vpna] c-rp 1.2.3.6
[SwitchC] vsi vpna
[SwitchC-vsi-vpna] gateway vsi-interface 1
[SwitchC] vlan 100
[SwitchC–vlan100] m-lag peer-link reserved
[SwitchC–vlan100] quit
[SwitchC] interface bridge-aggregation 17
[SwitchC-Bridge-Aggregation17] link-aggregation mode dynamic
[SwitchC-Bridge-Aggregation17] port m-lag group 17
# Map Ethernet service instance 20 to VSI vpna.
[SwitchC-Bridge-Aggregation17] service-instance 20
[SwitchC-Bridge-Aggregation17-srv20] encapsulation s-vid 2
[SwitchC-Bridge-Aggregation17-srv20] xconnect vsi vpna
[SwitchC-Bridge-Aggregation17-srv20] quit
[SwitchC]interface ten-gigabitethernet 1/0/1
[SwitchC-Ten-GigabitEthernet1/0/1] port link-aggregation group 17
[SwitchC-Ten-GigabitEthernet1/0/1] quit
[SwitchC] interface bridge-aggregation 9
[SwitchC-Bridge-Aggregation9] link-aggregation mode dynamic
[SwitchC-Bridge-Aggregation9] port m-lag peer-link 1
[SwitchC-Bridge-Aggregation9] quit
[SwitchC] interface ten-gigabitethernet 1/0/2
[SwitchC-Ten-GigabitEthernet1/0/2] port link-aggregation group 9
[SwitchC] m-lag mad exclude interface ten-gigabitethernet 1/0/3
[SwitchC] m-lag restore-delay 180
[SwitchC] m-lag system-mac 2-2-2
[SwitchC] m-lag system-number 1
[SwitchC] m-lag system-priority 10
[SwitchC] m-lag keepalive ip destination 192.168.3.2 source 192.168.3.1
# Configure Bridge-Aggregation 17 as a trunk port and configure it to permit VLANs 20 through 29.
[SwitchC-Bridge-Aggregation17] port link-type trunk
[SwitchC-Bridge-Aggregation17] undo port trunk permit vlan 1
[SwitchC-Bridge-Aggregation17] port trunk permit vlan 20 to 29
[SwitchC-Bridge-Aggregation17] quit
# Configure the peer-link interface as a trunk port and configure it to permit all VLANs.
[SwitchC-Bridge-Aggregation9] port link-type trunk
[SwitchC-Bridge-Aggregation9] undo port trunk permit vlan 1
[SwitchC-Bridge-Aggregation9] port trunk permit vlan all
5.     Configure Switch D:
# Enable L2VPN.
[SwitchD] l2vpn enable
[SwitchD] evpn m-lag group 1.2.3.6
[SwitchD] evpn m-lag local 4.4.4.4 remote 3.3.3.3
[SwitchD-mrib] quit
[SwitchD] igmp-snooping
[SwitchD-igmp-snooping] quit
[SwitchD] vxlan tunnel mac-learning disable
[SwitchD] vxlan tunnel arp-learning disable
[SwitchD] vsi vpna
[SwitchD-vsi-vpna] evpn encapsulation vxlan
[SwitchD-vsi-vpna-evpn-vxlan] route-distinguisher auto
[SwitchD-vsi-vpna-evpn-vxlan] vpn-target auto
[SwitchD-vsi-vpna-evpn-vxlan] quit
[SwitchD-vsi-vpna] igmp-snooping enable
[SwitchD-vsi-vpna] igmp-snooping proxy enable
# Create VXLAN 10.
[SwitchD-vsi-vpna] vxlan 10
[SwitchD-vsi-vpna-vxlan-10] quit
[SwitchD-vsi-vpna] quit
[SwitchD] bgp 200
[SwitchD-bgp-default] peer 6.6.6.6 as-number 200
[SwitchD-bgp-default] peer 6.6.6.6 connect-interface loopback 0
[SwitchD-bgp-default] peer 5.5.5.5 as-number 200
[SwitchD-bgp-default] peer 5.5.5.5 connect-interface loopback 0
[SwitchD-bgp-default-evpn] peer 6.6.6.6 enable
[SwitchD-bgp-default-evpn] peer 5.5.5.5 enable
[SwitchD] ip vpn-instance vpna
[SwitchD-vpn-instance-vpna] route-distinguisher 1:1
[SwitchD-vpn-instance-vpna] address-family ipv4
[SwitchD-vpn-ipv4-vpna] vpn-target 2:2
[SwitchD-vpn-ipv4-vpna] quit
[SwitchD-vpn-instance-vpna] address-family evpn
[SwitchD-vpn-evpn-vpna] vpn-target 1:1
[SwitchD-vpn-evpn-vpna] quit
[SwitchD-vpn-instance-vpna] quit
[SwitchD] interface vsi-interface 1
[SwitchD-Vsi-interface1] ip binding vpn-instance vpna
[SwitchD-Vsi-interface1] ip address 10.1.1.1 255.255.255.0
[SwitchD-Vsi-interface1] pim sm
[SwitchD-Vsi-interface1] igmp enable
[SwitchD-Vsi-interface1] pim distributed-dr
[SwitchD-Vsi-interface1] mac-address 1-1-1
[SwitchD-Vsi-interface1] distributed-gateway local
[SwitchD-Vsi-interface1] local-proxy-arp enable
[SwitchD-Vsi-interface1] quit
[SwitchD] interface vsi-interface 3
[SwitchD-Vsi-interface3] ip binding vpn-instance vpna
[SwitchD-Vsi-interface3] l3-vni 1000
[SwitchD-Vsi-interface3] pim sm
[SwitchD-Vsi-interface3] quit
[SwitchD] multicast routing vpn-instance vpna
[SwitchD-mrib-vpna] quit
[SwitchD] interface loopback 0
[SwitchD-LoopBack0] ip address 4.4.4.4 32
[SwitchD-LoopBack0] pim sm
[SwitchD-LoopBack0] ospf 1 area 0
[SwitchD-LoopBack1] quit
[SwitchD] interface loopback 1
[SwitchD-LoopBack1] ip address 1.2.3.6 32
[SwitchD-LoopBack1] pim sm
[SwitchD-LoopBack1] ospf 1 area 0
[SwitchD] interface loopback 2
[SwitchD-LoopBack2] ip binding vpn-instance vpna
[SwitchD-LoopBack2] ip address 1.2.3.6 255.255.255.255
[SwitchD-LoopBack2] pim sm
[SwitchD-LoopBack2] quit
[SwitchD] multicast-vpn vxlan vpn-instance vpna mode mdt
[SwitchD-mvxlan-vpna] address-family ipv4
[SwitchD-mvxlan-vpna-ipv4] default-group 236.0.0.1
[SwitchD-mvxlan-vpna-ipv4] source loopback 1 evpn-mlag-group
[SwitchD-mvxlan-vpna-ipv4] data-group 239.0.1.0 30
[SwitchD-mvxlan-vpna-ipv4] m-lag local 4.4.4.4 remote 3.3.3.3
[SwitchD-mvxlan-vpna-ipv4] quit
[SwitchD-mvxlan-vpna] quit
[SwitchD] pim vpn-instance vpna
[SwitchD-pim-vpna] c-bsr 1.2.3.6
[SwitchD-pim-vpna] c-rp 1.2.3.6
[SwitchD-pim-vpna] quit
[SwitchD] vsi vpna
[SwitchD-vsi-vpna] gateway vsi-interface 1
[SwitchD] vlan 100
[SwitchD–vlan100] m-lag peer-link reserved
[SwitchD–vlan100] quit
[SwitchD] interface bridge-aggregation 17
[SwitchD-Bridge-Aggregation17] link-aggregation mode dynamic
[SwitchD-Bridge-Aggregation17] port m-lag group 17
[SwitchD-Bridge-Aggregation17] service-instance 20
[SwitchD-Bridge-Aggregation17-srv20] encapsulation s-vid 2
[SwitchD-Bridge-Aggregation17-srv20] xconnect vsi vpna
[SwitchD-Bridge-Aggregation17-srv20] quit
[SwitchD] interface ten-gigabitethernet 1/0/1
[SwitchD-Ten-GigabitEthernet1/0/1] port link-aggregation group 17
[SwitchD-Ten-GigabitEthernet1/0/1] quit
[SwitchD] interface bridge-aggregation 9
[SwitchD-Bridge-Aggregation9] link-aggregation mode dynamic
[SwitchD-Bridge-Aggregation9] port m-lag peer-link 1
[SwitchD-Bridge-Aggregation9] quit
[SwitchD] interface ten-gigabitethernet 1/0/2
[SwitchD-Ten-GigabitEthernet1/0/2] port link-aggregation group 9
[SwitchD] m-lag mad exclude interface ten-gigabitethernet 1/0/3
[SwitchD] m-lag restore-delay 180
[SwitchD] m-lag system-mac 2-2-2
[SwitchD] m-lag system-number 2
[SwitchD] m-lag system-priority 10
[SwitchD] m-lag keepalive ip destination 192.168.3.1 source 192.168.3.2
[SwitchD-Bridge-Aggregation17] port link-type trunk
[SwitchD-Bridge-Aggregation17] undo port trunk permit vlan 1
[SwitchD-Bridge-Aggregation17] port trunk permit vlan 20 to 29
[SwitchD-Bridge-Aggregation17] quit
[SwitchD-Bridge-Aggregation9] port link-type trunk
[SwitchD-Bridge-Aggregation9] undo port trunk permit vlan 1
[SwitchD-Bridge-Aggregation9] port trunk permit vlan all
6.     Configure Switch E:
# Enable L2VPN.
<SwitchE> system-view
[SwitchE] l2vpn enable
# Specify the virtual VTEP address as 1.2.3.5.
[SwitchE] evpn m-lag group 1.2.3.5
[SwitchE] evpn m-lag local 5.5.5.5 remote 6.6.6.6
[SwitchE] multicast routing
[SwitchE-mrib] quit
[SwitchE] igmp-snooping
[SwitchE-igmp-snooping] quit
[SwitchE] vxlan tunnel mac-learning disable
[SwitchE] vxlan tunnel arp-learning disable
[SwitchE] vsi vpna
[SwitchE-vsi-vpna] evpn encapsulation vxlan
[SwitchE-vsi-vpna-evpn-vxlan] route-distinguisher auto
[SwitchE-vsi-vpna-evpn-vxlan] vpn-target auto
[SwitchE-vsi-vpna-evpn-vxlan] quit
[SwitchE-vsi-vpna] igmp-snooping enable
[SwitchE-vsi-vpna] igmp-snooping proxy enable
# Create VXLAN 10.
[SwitchE-vsi-vpna] vxlan 10
[SwitchE-vsi-vpna-vxlan-10] quit
[SwitchE-vsi-vpna] quit
[SwitchE] bgp 200
[SwitchE-bgp-default] non-stop-routing
[SwitchE-bgp-default] group evpn internal
[SwitchE-bgp-default] peer evpn connect-interface loopback 0
[SwitchE-bgp-default] peer 1.1.1.1 group evpn
[SwitchE-bgp-default] peer 2.2.2.2 group evpn
[SwitchE-bgp-default] peer 3.3.3.3 group evpn
[SwitchE-bgp-default] peer 4.4.4.4 group evpn
[SwitchE-bgp-default] peer 6.6.6.6 group evpn
[SwitchE-bgp-default] address-family l2vpn evpn
[SwitchE-bgp-default-evpn] undo policy vpn-target
[SwitchE-bgp-default-evpn] peer evpn enable
[SwitchE-bgp-default-evpn] peer evpn next-hop-local
[SwitchE-bgp-default-evpn] peer evpn reflect-client
[SwitchE-bgp-default-evpn] quit
[SwitchE-bgp-default] quit
[SwitchE] ip vpn-instance vpna
[SwitchE-vpn-instance-vpna] route-distinguisher 1:1
[SwitchE-vpn-instance-vpna] address-family ipv4
[SwitchE-vpn-ipv4-vpna] vpn-target 2:2
[SwitchE-vpn-ipv4-vpna] quit
[SwitchE-vpn-instance-vpna] address-family evpn
[SwitchE-vpn-evpn-vpna] vpn-target 1:1
[SwitchE-vpn-evpn-vpna] quit
[SwitchE-vpn-instance-vpna] quit
[SwitchE] interface vsi-interface 1
[SwitchE-Vsi-interface1] ip binding vpn-instance vpna
[SwitchE-Vsi-interface1] ip address 10.1.1.1 255.255.255.0
[SwitchE-Vsi-interface1] pim sm
[SwitchE-Vsi-interface1] igmp enable
[SwitchE-Vsi-interface1] pim distributed-dr
[SwitchE-Vsi-interface1] mac-address 1-1-1
[SwitchE-Vsi-interface1] distributed-gateway local
[SwitchE-Vsi-interface1] local-proxy-arp enable
[SwitchE-Vsi-interface1] quit
[SwitchE] interface vsi-interface 3
[SwitchE-Vsi-interface3] ip binding vpn-instance vpna
[SwitchE-Vsi-interface3] l3-vni 1000
[SwitchE-Vsi-interface3] pim sm
[SwitchE-Vsi-interface3] quit
[SwitchE] multicast routing vpn-instance vpna
[SwitchE-mrib-vpna] quit
[SwitchE] interface loopback 0
[SwitchE-LoopBack0] ip address 5.5.5.5 32
[SwitchE-LoopBack0] ospf 1 area 0
[SwitchE-LoopBack0] quit
[SwitchE] interface loopback 1
[SwitchE-LoopBack1] ip address 1.2.3.5 32
[SwitchE-LoopBack1] ospf 1 area 0
[SwitchE-LoopBack1] quit
[SwitchE] interface loopback 2
[SwitchE-LoopBack2] ip binding vpn-instance vpna
[SwitchE-LoopBack2] ip address 1.2.3.5 255.255.255.255
[SwitchE-LoopBack2] pim sm
[SwitchE-LoopBack2] quit
[SwitchE] multicast-vpn vxlan vpn-instance vpna mode mdt
[SwitchE-mvxlan-vpna] address-family ipv4
[SwitchE-mvxlan-vpna-ipv4] default-group 236.0.0.1
[SwitchE-mvxlan-vpna-ipv4] source loopback 1 evpn-mlag-group
[SwitchE-mvxlan-vpna-ipv4] data-group 239.0.0.1 30
[SwitchE-mvxlan-vpna-ipv4] quit
[SwitchE-mvxlan-vpna] quit
[SwitchE] pim vpn-instance vpna
[SwitchE-pim-vpna] c-bsr 1.2.3.5
[SwitchE-pim-vpna] c-rp 1.2.3.5
[SwitchE-pim-vpna] quit
[SwitchE] vsi vpna
[SwitchE-vsi-vpna] gateway vsi-interface 1
[SwitchE] vlan 100
[SwitchE–vlan100] m-lag peer-link reserved
[SwitchE–vlan100] quit
[SwitchE] interface bridge-aggregation 17
[SwitchE-Bridge-Aggregation17] link-aggregation mode dynamic
[SwitchE-Bridge-Aggregation17] port m-lag group 17
[SwitchE-Bridge-Aggregation17] service-instance 20
[SwitchE-Bridge-Aggregation17-srv20] encapsulation s-vid 2
[SwitchE-Bridge-Aggregation17-srv20] xconnect vsi vpna
[SwitchE-Bridge-Aggregation17-srv20] quit
[SwitchE]interface ten-gigabitethernet 1/0/1
[SwitchE-Ten-GigabitEthernet1/0/1] port link-aggregation group 17
[SwitchE-Ten-GigabitEthernet1/0/1] quit
[SwitchE] interface bridge-aggregation 9
[SwitchE-Bridge-Aggregation9] port link-type trunk
[SwitchE-Bridge-Aggregation9] port trunk permit vlan all
[SwitchE-Bridge-Aggregation9] link-aggregation mode dynamic
[SwitchE-Bridge-Aggregation9] port m-lag peer-link 1
[SwitchE-Bridge-Aggregation9] quit
[SwitchE] interface ten-gigabitethernet 1/0/2
[SwitchE-Ten-GigabitEthernet1/0/2] port link-aggregation group 9
[SwitchE-Ten-GigabitEthernet1/0/2] quit
[SwitchE] m-lag mad exclude interface ten-gigabitethernet 1/0/3
[SwitchE] m-lag restore-delay 180
[SwitchE] m-lag system-mac 3-3-3
[SwitchE] m-lag system-number 1
[SwitchE] m-lag system-priority 10
[SwitchE] m-lag keepalive ip destination 192.168.4.2 source 192.168.4.1
[SwitchE-Bridge-Aggregation17] port link-type trunk
[SwitchE-Bridge-Aggregation17] undo port trunk permit vlan 1
[SwitchE-Bridge-Aggregation17] port trunk permit vlan 20 to 29
[SwitchE-Bridge-Aggregation17] quit
[SwitchE-Bridge-Aggregation9] undo port trunk permit vlan 1
7.     Configure Switch F:
# Enable L2VPN.
<SwitchF> system-view
[SwitchF] l2vpn enable
[SwitchF] evpn m-lag group 1.2.3.5
[SwitchF] evpn m-lag local 6.6.6.6 remote 5.5.5.5
[SwitchF] multicast routing
[SwitchF-mrib] quit
# Enable the IGMP snooping feature.
[SwitchF] igmp-snooping
[SwitchF-igmp-snooping] quit
# Disable remote MAC address learning and remote ARP learning.
[SwitchF] vxlan tunnel mac-learning disable
[SwitchF] vxlan tunnel arp-learning disable
# Create an EVPN instance on VSI vpna.
[SwitchF] vsi vpna
[SwitchF-vsi-vpna] evpn encapsulation vxlan
[SwitchF-vsi-vpna-evpn-vxlan] route-distinguisher auto
[SwitchF-vsi-vpna-evpn-vxlan] vpn-target auto
[SwitchF-vsi-vpna-evpn-vxlan] quit
# Enable IGMP snooping and IGMP snooping proxying on VSI vpna.
[SwitchF-vsi-vpna] igmp-snooping enable
[SwitchF-vsi-vpna] igmp-snooping proxy enable
# Create VXLAN 10.
[SwitchF-vsi-vpna] vxlan 10
[SwitchF-vsi-vpna-vxlan-10] quit
[SwitchF-vsi-vpna] quit
# Configure BGP to advertise BGP EVPN routes.
[SwitchF] bgp 200
[SwitchF-bgp-default] non-stop-routing
[SwitchF-bgp-default] group evpn internal
[SwitchF-bgp-default] peer evpn connect-interface loopback 0
[SwitchF-bgp-default] peer 1.1.1.1 group evpn
[SwitchF-bgp-default] peer 2.2.2.2 group evpn
[SwitchF-bgp-default] peer 3.3.3.3 group evpn
[SwitchF-bgp-default] peer 4.4.4.4 group evpn
[SwitchF-bgp-default] peer 5.5.5.5 group evpn
[SwitchF-bgp-default] address-family l2vpn evpn
[SwitchF-bgp-default-evpn] undo policy vpn-target
[SwitchF-bgp-default-evpn] peer evpn enable
[SwitchF-bgp-default-evpn] peer evpn next-hop-local
[SwitchF-bgp-default-evpn] peer evpn reflect-client
[SwitchF-bgp-default-evpn] quit
[SwitchF-bgp-default] quit
# Configure RD and route target settings for VPN instance vpna.
[SwitchF] ip vpn-instance vpna
[SwitchF-vpn-instance-vpna] route-distinguisher 1:1
[SwitchF-vpn-instance-vpna] address-family ipv4
[SwitchF-vpn-ipv4-vpna] vpn-target 2:2
[SwitchF-vpn-ipv4-vpna] quit
[SwitchF-vpn-instance-vpna] address-family evpn
[SwitchF-vpn-evpn-vpna] vpn-target 1:1
[SwitchF-vpn-evpn-vpna] quit
[SwitchF-vpn-instance-vpna] quit
# Configure VSI-interface 1.
[SwitchF] interface vsi-interface 1
[SwitchF-Vsi-interface1] ip binding vpn-instance vpna
[SwitchF-Vsi-interface1] ip address 10.1.1.1 255.255.255.0
[SwitchF-Vsi-interface1] pim sm
[SwitchF-Vsi-interface1] igmp enable
[SwitchF-Vsi-interface1] pim distributed-dr
[SwitchF-Vsi-interface1] mac-address 1-1-1
[SwitchF-Vsi-interface1] distributed-gateway local
[SwitchF-Vsi-interface1] local-proxy-arp enable
[SwitchF-Vsi-interface1] quit
[SwitchF] interface vsi-interface 3
[SwitchF-Vsi-interface3] ip binding vpn-instance vpna
[SwitchF-Vsi-interface3] l3-vni 1000
[SwitchF-Vsi-interface3] pim sm
[SwitchF-Vsi-interface3] quit
[SwitchF] multicast routing vpn-instance vpna
[SwitchF-mrib-vpna] quit
[SwitchF] interface loopback 0
[SwitchF-LoopBack0] ip address 6.6.6.6 32
[SwitchF-LoopBack0] ospf 1 area 0
[SwitchF-LoopBack0] quit
[SwitchF] interface loopback 1
[SwitchF-LoopBack1] ip address 1.2.3.5 32
[SwitchF-LoopBack1] ospf 1 area 0
[SwitchF-LoopBack1] quit
[SwitchF] interface loopback 2
[SwitchF-LoopBack2] ip binding vpn-instance vpna
[SwitchF-LoopBack2] ip address 1.2.3.5 255.255.255.255
[SwitchF-LoopBack2] pim sm
[SwitchF-LoopBack2] quit
# Create an MDT-based MVXLAN for VPN instance vpna and enter MVXLAN IPv4 address family view. Configure the default group, MVXLAN source interface, and data group range settings.
[SwitchF] multicast-vpn vxlan vpn-instance vpna mode mdt
[SwitchF-mvxlan-vpna] address-family ipv4
[SwitchF-mvxlan-vpna-ipv4] default-group 236.0.0.1
[SwitchF-mvxlan-vpna-ipv4] source loopback 1 evpn-mlag-group
[SwitchF-mvxlan-vpna-ipv4] data-group 239.0.0.1 30
[SwitchF-mvxlan-vpna-ipv4] quit
[SwitchF-mvxlan-vpna] quit
[SwitchF] pim vpn-instance vpna
[SwitchF-pim-vpna] c-bsr 1.2.3.5
[SwitchF-pim-vpna] c-rp 1.2.3.5
[SwitchF-pim-vpna] quit
[SwitchF] vsi vpna
[SwitchF-vsi-vpna] gateway vsi-interface 1
[SwitchF] vlan 100
[SwitchF–vlan100] m-lag peer-link reserved
[SwitchF–vlan100] quit
[SwitchF] interface bridge-aggregation 17
[SwitchF-Bridge-Aggregation17] link-aggregation mode dynamic
[SwitchF-Bridge-Aggregation17] port m-lag group 17
[SwitchF-Bridge-Aggregation17] service-instance 20
[SwitchF-Bridge-Aggregation17-srv20] encapsulation s-vid 2
[SwitchF-Bridge-Aggregation17-srv20] xconnect vsi vpna
[SwitchF-Bridge-Aggregation17-srv20] quit
[SwitchF] interface ten-gigabitethernet 1/0/1
[SwitchF-Ten-GigabitEthernet1/0/1] port link-aggregation group 17
[SwitchF-Ten-GigabitEthernet1/0/1] quit
[SwitchF] interface bridge-aggregation 9
[SwitchF-Bridge-Aggregation9] port link-type trunk
[SwitchF-Bridge-Aggregation9] port trunk permit vlan all
[SwitchF-Bridge-Aggregation9] link-aggregation mode dynamic
[SwitchF-Bridge-Aggregation9] port m-lag peer-link 1
[SwitchF-Bridge-Aggregation9] quit
[SwitchF] interface ten-gigabitethernet 1/0/2
[SwitchF-Ten-GigabitEthernet1/0/2] port link-aggregation group 9
[SwitchF-Ten-GigabitEthernet1/0/2] quit
[SwitchF] m-lag mad exclude interface ten-gigabitethernet 1/0/3
[SwitchF] m-lag restore-delay 180
[SwitchF] m-lag system-mac 3-3-3
[SwitchF] m-lag system-number 2
[SwitchF] m-lag system-priority 10
[SwitchF] m-lag keepalive ip destination 192.168.4.1 source 192.168.4.2
[SwitchF-Bridge-Aggregation17] port link-type trunk
[SwitchF-Bridge-Aggregation17] undo port trunk permit vlan 1
[SwitchF-Bridge-Aggregation17] port trunk permit vlan 20 to 29
[SwitchF-Bridge-Aggregation17] quit
[SwitchF-Bridge-Aggregation9] undo port trunk permit vlan 1
1.     Verify the VXLAN tunnel and VSI configuration on Switch A:
# Verify that the VXLAN tunnels are up, and the virtual VTEP address is used as the source address of some VXLAN tunnels.
[SwitchA] display interface tunnel
Tunnel0
Current state: UP
Line protocol state: UP
Bandwidth: 64 kbps
Tunnel source 1.2.3.4, destination 6.6.6.6
Tunnel1
Current state: UP
Bandwidth: 64 kbps
Input: 1159 packets, 176556 bytes, 0 drops
Output: 1176 packets, 178121 bytes, 0 drops
Tunnel2
Current state: UP
Description: Tunnel2 Interface
Bandwidth: 64 kbps
Tunnel source 1.2.3.4, destination 3.3.3.3
Tunnel3
Current state: UP
Description: Tunnel3 Interface
Bandwidth: 64 kbps
Tunnel source 1.2.3.4, destination 1.2.3.6
Input: 8 packets, 480 bytes, 0 drops
# Verify that the VXLAN tunnels have been assigned to the VXLANs, and that the VSI interfaces are the gateway interfaces of their respective VXLANs.
[SwitchA] display l2vpn vsi verbose
VSI Name: vpna
  VSI Index                  : 0
  VSI State                  : Up
  MTU                         : 1500
  Bandwidth                  : -
  Broadcast Restrain       : -
  Multicast Restrain       : -
  Unknown Unicast Restrain: -
  MAC Learning              : Enabled
  MAC Table Limit          : -
  MAC Learning rate        : -
  Drop Unknown              : -
  Flooding                   : Enabled
  Statistics                    : Disabled
  Gateway Interface        : VSI-interface 1
  VXLAN ID                  : 10
  Tunnels:
    Tunnel Name          Link ID    State    Type        Flood proxy
    Tunnel0               0x5000000  UP       Auto        Disabled
    Tunnel1               0x5000001  UP       Auto        Disabled
    Tunnel2               0x5000002  UP       Auto        Disabled
    Tunnel3               0x5000003  UP       Auto        Disabled
  ACs:
    AC                                 Link ID    State       Type
    BAGG17 srv20                     0           Up           Manual
2.     Verify the multicast routing information on Switch A:
# Display the multicast routing entries when the peer links of the M-LAG systems are up.
 (1.2.3.4, 236.0.0.1)
     RP: 5.5.5.5
     UpTime: 03:59:50
         1: Register-Tunnel0
             Protocol: pim-sm, UpTime: 03:38:17, Expires: -
 (1.2.3.6, 236.0.0.1)
     RP: 5.5.5.5
     UpTime: 01:18:49
     Upstream interface: Vlan-interface11
         Upstream neighbor: 11.1.1.11
         RPF prime neighbor: 11.1.1.11
         1: MVXLAN-UPE1
             Protocol: MD, UpTime: 01:18:49, Expires: -
# Display the multicast routing entries when the peer links of the M-LAG systems are down.
Total 0 (*, G) entries; 4 (S, G) entries
     RP: 5.5.5.5
     UpTime: 00:02:12
         1: Vlan-interface11
             Protocol: pim-sm, UpTime: 00:02:11, Expires: 00:03:19
 (2.2.2.2, 236.0.0.1)
     RP: 5.5.5.5
     UpTime: 00:01:04
         1: MVXLAN-UPE0
             Protocol: MD, UpTime: 00:01:04, Expires: -
 (3.3.3.3, 236.0.0.1)
     RP: 5.5.5.5
     UpTime: 00:01:36
         1: MVXLAN-UPE0
             Protocol: MD, UpTime: 00:01:36, Expires: -
 (6.6.6.6, 236.0.0.1)
     RP: 5.5.5.5
     UpTime: 00:00:32
         1: MVXLAN-UPE0
             Protocol: MD, UpTime: 00:00:32, Expires: -
3.     Verify the multicast routing information on Switch E:
# Display the public multicast routing entries when the peer links of the M-LAG systems are up.
<SwitchE> display pim routing-table
     RP: 5.5.5.5 (local)
     Protocol: pim-sm, Flag: SPT 2MSDP ACT 2MVPN
     UpTime: 04:11:32
         Upstream neighbor: 12.1.1.2
         RPF prime neighbor: 12.1.1.2
         1: Vlan-interface13
             Protocol: pim-sm, UpTime: 01:33:53, Expires: 00:02:40
         2: Vlan-interface14
             Protocol: pim-sm, UpTime: 01:31:35, Expires: 00:02:40
     RP: 5.5.5.5 (local)
     UpTime: 01:34:02
     Upstream interface: Vlan-interface14
         Upstream neighbor: 14.1.1.4
         RPF prime neighbor: 14.1.1.4
         1: Vlan-interface11
             Protocol: pim-sm, UpTime: 01:30:50, Expires: 00:02:40
         2: Vlan-interface12
             Protocol: pim-sm, UpTime: 01:30:50, Expires: 00:02:41-
     RP: 5.5.5.5 (local)
     UpTime: 00:04:00
     Total number of downstream interfaces: 3
         1: Vlan-interface12
             Protocol: pim-sm, UpTime: 00:02:51, Expires: 00:02:39
         2: Vlan-interface13
             Protocol: pim-sm, UpTime: 00:03:59, Expires: 00:03:06
         3: Vlan-interface14
             Protocol: pim-sm, UpTime: 00:03:59, Expires: 00:03:10
     RP: 5.5.5.5 (local)
     UpTime: 00:02:52
         1: Vlan-interface11
             Protocol: pim-sm, UpTime: 00:02:52, Expires: 00:02:38
         2: Vlan-interface13
             Protocol: pim-sm, UpTime: 00:02:52, Expires: 00:02:39
         3: Vlan-interface14
             Protocol: pim-sm, UpTime: 00:02:52, Expires: 00:03:10
     RP: 5.5.5.5 (local)
     UpTime: 00:03:25
     Upstream interface: Vlan-interface13
         Upstream neighbor: 13.1.1.3
         RPF prime neighbor: 13.1.1.3
         1: Vlan-interface11
             Protocol: pim-sm, UpTime: 00:03:24, Expires: 00:03:06
         2: Vlan-interface12
             Protocol: pim-sm, UpTime: 00:03:24, Expires: 00:02:38
         3: Vlan-interface14
             Protocol: pim-sm, UpTime: 00:02:20, Expires: 00:03:10
     RP: 5.5.5.5 (local)
     UpTime: 00:02:20
         1: Vlan-interface11
         2: Vlan-interface12
         3: Vlan-interface13
             Protocol: pim-sm, UpTime: 00:02:20, Expires: 00:03:11
Example: Configuring DCI Layer 3 multicast without L3 VXLAN ID mapping
As shown in Figure 17, the multicast source of multicast group 225.0.0.1 is attached to Switch A, and the receivers of the multicast group are attached to Switch B and Switch E. Configure DCI Layer 3 multicast as follows:
·     For DC 1, configure Switch A and Switch B as VTEPs, and configure Switch C as an ED.
·     For DC 2, configure Switch E as a VTEP, and configure Switch D as an ED.
·     Assign L3 VXLAN ID to DC 1 and DC 2.
·     On Switch A through Switch E, configure PIM SM on the public-network interfaces used for intra-data center connection. Enable IGMP snooping on Switch E.
Figure 17 Network diagram
1.     On the multicast source, specify 192.168.10.1 as the gateway address. On Receiver 1, specify 192.168.20.1 as the gateway address. On Receiver 2, specify 192.168.40.1 as the gateway address. (Details not shown.)
2.     Configure IP addresses, PIM SM, and unicast routing settings:
# Assign IP addresses to interfaces, as shown in Figure 17. (Details not shown.)
# Configure OSPF in each data center for the switches in a data center to reach one another. (Details not shown.)
# Enable PIM SM on the VLAN interfaces that interconnect the devices in a data center. (Details not shown.)
# Verify that PIM SM is disabled on the VLAN interfaces that interconnect the EDs. (Details not shown.)
3.     Configure Switch A:
# Enable L2VPN and IP multicast routing, and create VLAN 11.
[SwitchA] l2vpn enable
[SwitchA] multicast routing
[SwitchA-mrib] quit
[SwitchA] vlan 11
[SwitchA-vlan11] quit
[SwitchA] igmp-snooping
[SwitchA-igmp-snooping] quit
[SwitchA] vxlan tunnel mac-learning disable
[SwitchA] vxlan tunnel arp-learning disable
[SwitchA-LoopBack0] ospf 1 area 0.0.0.0
[SwitchA] vsi vpna
[SwitchA-vsi-vpna] evpn encapsulation vxlan
[SwitchA-vsi-vpna-evpn-vxlan] route-distinguisher auto
[SwitchA-vsi-vpna-evpn-vxlan] quit
[SwitchA-vsi-vpna] igmp-snooping enable
[SwitchA-vsi-vpna] igmp-snooping proxy enable
# Create VXLAN 11.
[SwitchA-vsi-vpna] vxlan 11
[SwitchA-vsi-vpna-vxlan-11] quit
[SwitchA-vsi-vpna] quit
[SwitchA] bgp 100
[SwitchA-bgp-default] peer 77.77.77.77 as-number 100
[SwitchA-bgp-default] peer 77.77.77.77 connect-interface loopback 0
[SwitchA-bgp-default] address-family l2vpn evpn
[SwitchA-bgp-default-evpn] peer 77.77.77.77 enable
[SwitchA-bgp-default-evpn] peer 77.77.77.77 next-hop-local
[SwitchA-bgp-default-evpn] quit
[SwitchA-bgp-default] quit
# On Ten-GigabitEthernet 1/0/1, create Ethernet service instance 100 to match VLAN 11.
[SwitchA] interface ten-gigabitethernet 1/0/1
[SwitchA-Ten-GigabitEthernet1/0/1] port link-type trunk
[SwitchA-Ten-GigabitEthernet1/0/1] port trunk permit vlan 1 11
[SwitchA-Ten-GigabitEthernet1/0/1] service-instance 100
[SwitchA-Ten-GigabitEthernet1/0/1-srv100] encapsulation s-vid 11
[SwitchA-Ten-GigabitEthernet1/0/1-srv100] xconnect vsi vpna
[SwitchA-Ten-GigabitEthernet1/0/1-srv100] quit
# Configure RD and route target settings for VPN instance vpn1.
[SwitchA] ip vpn-instance vpn1
[SwitchA-vpn-instance-vpn1] route-distinguisher 1:1
[SwitchA-vpn-instance-vpn1] vpn-target 10:10 20:20 30:30 import-extcommunity
[SwitchA-vpn-instance-vpn1] vpn-target 10:10 export-extcommunity
[SwitchA-vpn-instance-vpn1] quit
[SwitchA] interface vsi-interface 1
[SwitchA-Vsi-interface1] ip binding vpn-instance vpn1
[SwitchA-Vsi-interface1] ip address 192.168.10.1 255.255.255.0
[SwitchA-Vsi-interface1] pim sm
[SwitchA-Vsi-interface1] distributed-gateway local
[SwitchA-Vsi-interface1] quit
# Associate VSI-interface 2 with VPN instance vpn1, and configure the L3 VXLAN ID as 1000 for the VPN instance.
[SwitchA] interface vsi-interface 2
[SwitchA-Vsi-interface2] ip binding vpn-instance vpn1
[SwitchA-Vsi-interface2] l3-vni 1000
[SwitchA-Vsi-interface2] pim sm
[SwitchA-Vsi-interface2] quit
# Enable IP multicast routing for VPN instance vpn1.
[SwitchA] multicast routing vpn-instance vpn1
[SwitchA-mrib-vpn1] quit
# Create an MDT-based MVXLAN for VPN instance vpn1 and enter MVXLAN IPv4 address family view. Configure the default group, MVXLAN source interface, and data group range settings. Enable advertising active multicast sources through S-PMSI routes. Set the data-delay period to 20 seconds, which is longer than the default frequency of sending the same route update to a peer or peer group.
[SwitchA] multicast-vpn vxlan vpn-instance vpn1 mode mdt
[SwitchA-mvxlan-vpn1] address-family ipv4
[SwitchA-mvxlan-vpn1-ipv4] default-group 239.0.0.1
[SwitchA-mvxlan-vpn1-ipv4] source loopback 0
[SwitchA-mvxlan-vpn1-ipv4] data-group 239.1.1.0 30
[SwitchA-mvxlan-vpn1-ipv4] s-pmsi advertise source-active
[SwitchA-mvxlan-vpn1-ipv4] data-delay 20
[SwitchA-mvxlan-vpn1-ipv4] quit
[SwitchA-mvxlan-vpn1] quit
# Configure Loopback 1.
[SwitchA] interface loopback 1
[SwitchA-LoopBack1] ip binding vpn-instance vpn1
[SwitchA-LoopBack1] ip address 1.1.1.1 32
[SwitchA-LoopBack1] pim sm
[SwitchA-LoopBack1] quit
# Enter VPN instance PIM view, and configure Loopback 1 as a candidate-BSR and candidate-RP in VPN instance vpn1.
[SwitchA] pim vpn-instance vpn1
[SwitchA-pim-vpn1] c-bsr 1.1.1.1
[SwitchA-pim-vpn1] c-rp 1.1.1.1
[SwitchA-pim-vpn1] quit
[SwitchA] vsi vpna
[SwitchA-vsi-vpna] gateway vsi-interface 1
4.     Configure Switch B:
# Enable L2VPN and IP multicast routing, and create VLAN 12.
[SwitchB] l2vpn enable
[SwitchB-mrib] quit
[SwitchB] vlan 12
[SwitchB-vlan12] quit
[SwitchB] igmp-snooping
[SwitchB-igmp-snooping] quit
[SwitchB] vxlan tunnel mac-learning disable
[SwitchB] vxlan tunnel arp-learning disable
[SwitchB-LoopBack0] ospf 1 area 0.0.0.0
[SwitchB] vsi vpna
[SwitchB-vsi-vpna] evpn encapsulation vxlan
[SwitchB-vsi-vpna-evpn-vxlan] route-distinguisher auto
[SwitchB-vsi-vpna-evpn-vxlan] quit
[SwitchB-vsi-vpna] igmp-snooping enable
[SwitchB-vsi-vpna] igmp-snooping proxy enable
# Create VXLAN 12.
[SwitchB-vsi-vpna] vxlan 12
[SwitchB-vsi-vpna-vxlan-12] quit
[SwitchB-vsi-vpna] quit
[SwitchB] bgp 100
[SwitchB-bgp-default] peer 77.77.77.77 as-number 100
[SwitchB-bgp-default] peer 77.77.77.77 connect-interface loopback 0
[SwitchB-bgp-default] address-family l2vpn evpn
[SwitchB-bgp-default-evpn] peer 77.77.77.77 enable
[SwitchB-bgp-default-evpn] peer 77.77.77.77 next-hop-local
[SwitchB-bgp-default-evpn] quit
[SwitchB-bgp-default] quit
# On Ten-GigabitEthernet 1/0/1, create Ethernet service instance 100 to match VLAN 12.
[SwitchB] interface ten-gigabitethernet 1/0/1
[SwitchB-Ten-GigabitEthernet1/0/1] port link-type trunk
[SwitchB-Ten-GigabitEthernet1/0/1] port trunk permit vlan 1 12
[SwitchB-Ten-GigabitEthernet1/0/1] service-instance 100
[SwitchB-Ten-GigabitEthernet1/0/1-srv100] encapsulation s-vid 12
[SwitchB-Ten-GigabitEthernet1/0/1-srv100] xconnect vsi vpna
[SwitchB-Ten-GigabitEthernet1/0/1-srv100] quit
[SwitchB] ip vpn-instance vpn1
[SwitchB-vpn-instance-vpn1] route-distinguisher 1:2
[SwitchB-vpn-instance-vpn1] vpn-target 10:10 20:20 30:30 import-extcommunity
[SwitchB-vpn-instance-vpn1] vpn-target 10:10 export-extcommunity
[SwitchB-vpn-instance-vpn1] quit
[SwitchB] interface vsi-interface 1
[SwitchB-Vsi-interface1] ip binding vpn-instance vpn1
[SwitchB-Vsi-interface1] ip address 192.168.20.1 255.255.255.0
[SwitchB-Vsi-interface1] igmp enable
[SwitchB-Vsi-interface1] distributed-gateway local
[SwitchB-Vsi-interface1] quit
[SwitchB] interface vsi-interface 2
[SwitchB-Vsi-interface2] ip binding vpn-instance vpn1
[SwitchB-Vsi-interface2] l3-vni 1000
[SwitchB-Vsi-interface2] pim sm
[SwitchB-Vsi-interface2] quit
[SwitchB] multicast routing vpn-instance vpn1
[SwitchB-mrib-vpn1] quit
# Create an MDT-based MVXLAN for VPN instance vpn1 and enter MVXLAN IPv4 address family view. Configure the MVXLAN source interface.
[SwitchB] multicast-vpn vxlan vpn-instance vpn1 mode mdt
[SwitchB-mvxlan-vpn1] address-family ipv4
[SwitchB-mvxlan-vpn1-ipv4] source loopback 0
[SwitchB-mvxlan-vpn1-ipv4] quit
[SwitchB-mvxlan-vpn1] quit
[SwitchB] interface loopback 1
[SwitchB-LoopBack1] ip binding vpn-instance vpn1
[SwitchB-LoopBack1] ip address 2.2.2.2 32
[SwitchB-LoopBack1] pim sm
[SwitchB-LoopBack1] quit
[SwitchB] pim vpn-instance vpn1
[SwitchB-pim-vpn1] c-bsr 2.2.2.2
[SwitchB-pim-vpn1] c-rp 2.2.2.2
[SwitchB-pim-vpn1] quit
[SwitchB] vsi vpna
[SwitchB-vsi-vpna] gateway vsi-interface 1
5.     Configure Switch C:
# Enable L2VPN, IP multicast routing, and RIP process 1.
[SwitchC] l2vpn enable
[SwitchC-mrib] quit
[SwitchC] rip 1
[SwitchC-rip-1] quit
[SwitchC]vxlan tunnel mac-learning disable
[SwitchC]vxlan tunnel arp-learning disable
[SwitchC-LoopBack0] ip address 77.77.77.77 32
[SwitchC-LoopBack0] rip 1 enable
[SwitchC-LoopBack0] ospf 1 area 0.0.0.0
[SwitchC-LoopBack0] quit
# Configure RIP and enable DCI on the interface connected to a remote ED.
[SwitchC] interface vlan-interface 70
[SwitchC-Vlan-interface70] ip address 78.1.1.1 255.255.255.0
[SwitchC-Vlan-interface70] rip 1 enable
[SwitchC-Vlan-interface70] dci enable
# Configure BGP to advertise BGP EVPN routes, and configure Switch C as an RR.
[SwitchC] bgp 100
[SwitchC-bgp-default] group group1 internal
[SwitchC-bgp-default] peer group1 connect-interface loopback 0
[SwitchC-bgp-default] peer 1.1.1.1 group group1
[SwitchC-bgp-default] peer 2.2.2.2 group group1
[SwitchC-bgp-default] peer 88.88.88.88 as-number 200
[SwitchC-bgp-default] peer 88.88.88.88 connect-interface loopback 0
[SwitchC-bgp-default] peer 88.88.88.88 ebgp-max-hop 64
[SwitchC-bgp-default] address-family l2vpn evpn
[SwitchC-bgp-default-evpn] peer group1 enable
[SwitchC-bgp-default-evpn] peer group1 next-hop-local
[SwitchC-bgp-default-evpn] peer group1 reflect-client
[SwitchC-bgp-default-evpn] peer 88.88.88.88 enable
[SwitchC-bgp-default-evpn] peer 88.88.88.88 router-mac-local
[SwitchC-bgp-default-evpn] quit
[SwitchC-bgp-default] quit
[SwitchC] ip vpn-instance vpn1
[SwitchC-vpn-instance-vpn1] route-distinguisher 1:3
[SwitchC-vpn-instance-vpn1] vpn-target 10:10 20:20 30:30 import-extcommunity
[SwitchC-vpn-instance-vpn1] vpn-target 10:10 export-extcommunity
[SwitchC-vpn-instance-vpn1] quit
[SwitchC] interface vsi-interface 2
[SwitchC-Vsi-interface2] ip binding vpn-instance vpn1
[SwitchC-Vsi-interface2] l3-vni 1000
[SwitchC-Vsi-interface2] pim sm
[SwitchC-Vsi-interface2] quit
[SwitchC] multicast routing vpn-instance vpn1
[SwitchC-mrib-vpn1] quit
# Create an MDT-based MVXLAN for VPN instance vpn1 and enter MVXLAN IPv4 address family view. Configure the MVXLAN source interface and enable DCI multicast.
[SwitchC] multicast-vpn vxlan vpn-instance vpn1 mode mdt
[SwitchC-mvxlan-vpn1] address-family ipv4
[SwitchC-mvxlan-vpn1-ipv4] source loopback 0
[SwitchC-mvxlan-vpn1-ipv4] dci enable
[SwitchC-mvxlan-vpn1-ipv4] quit
[SwitchC-mvxlan-vpn1] quit
[SwitchC] interface loopback 1
[SwitchC-LoopBack1] ip binding vpn-instance vpn1
[SwitchC-LoopBack1] ip address 77.77.77.77 32
[SwitchC-LoopBack1] pim sm
[SwitchC-LoopBack1] quit
[SwitchC] pim vpn-instance vpn1
[SwitchC-pim-vpn1] c-bsr 77.77.77.77
[SwitchC-pim-vpn1] c-rp 77.77.77.77
[SwitchC-pim-vpn1] quit
6.     Configure Switch D:
<SwitchD> system-view
[SwitchD-mrib] quit
[SwitchD] rip 1
[SwitchD-rip-1] quit
[SwitchD]vxlan tunnel mac-learning disable
[SwitchD]vxlan tunnel arp-learning disable
[SwitchD-LoopBack0] ip address 88.88.88.88 32
[SwitchD-LoopBack0] rip 1 enable
[SwitchD-LoopBack0] ospf 1 area 0.0.0.0
[SwitchD-LoopBack0] quit
[SwitchD] interface vlan-interface 70
[SwitchD-Vlan-interface70] ip address 78.1.1.2 255.255.255.0
[SwitchD-Vlan-interface70] rip 1 enable
[SwitchD-Vlan-interface70] dci enable
[SwitchD] bgp 200
[SwitchD-bgp-default] peer 4.4.4.4 as-number 200
[SwitchD-bgp-default] peer 4.4.4.4 connect-interface loopback 0
[SwitchD-bgp-default] peer 77.77.77.77 as-number 100
[SwitchD-bgp-default] peer 77.77.77.77 connect-interface loopback 0
[SwitchD-bgp-default] peer 77.77.77.77 ebgp-max-hop 64
[SwitchD-bgp-default] address-family l2vpn evpn
[SwitchD-bgp-default-evpn] peer 4.4.4.4 enable
[SwitchD-bgp-default-evpn] peer 4.4.4.4 next-hop-local
[SwitchD-bgp-default-evpn] peer 77.77.77.77 enable
[SwitchD-bgp-default-evpn] peer 77.77.77.77 router-mac-local
[SwitchD-bgp-default-evpn] quit
[SwitchD-bgp-default] quit
[SwitchD] ip vpn-instance vpn1
[SwitchD-vpn-instance-vpn1] route-distinguisher 2:1
[SwitchD-vpn-instance-vpn1] vpn-target 10:10 20:20 30:30 import-extcommunity
[SwitchD-vpn-instance-vpn1] vpn-target 20:20 export-extcommunity
[SwitchD-vpn-instance-vpn1] quit
[SwitchD] interface vsi-interface 2
[SwitchD-Vsi-interface2] ip binding vpn-instance vpn1
[SwitchD-Vsi-interface2] l3-vni 1000
[SwitchD-Vsi-interface2] pim sm
[SwitchD-Vsi-interface2] quit
[SwitchD] multicast routing vpn-instance vpn1
[SwitchD-mrib-vpn1] quit
# Create an MDT-based MVXLAN for VPN instance vpn1 and enter MVXLAN IPv4 address family view. Configure the default group, MVXLAN source interface, and data group range settings, and enable DCI multicast. Configure the data group range to be the same as that on Switch A to ensure correct forwarding.
[SwitchD] multicast-vpn vxlan vpn-instance vpn1 mode mdt
[SwitchD-mvxlan-vpn1] address-family ipv4
[SwitchD-mvxlan-vpn1-ipv4] default-group 239.0.0.1
[SwitchD-mvxlan-vpn1-ipv4] source loopback 0
[SwitchD-mvxlan-vpn1-ipv4] data-group 239.1.1.0 30
[SwitchD-mvxlan-vpn1-ipv4] dci enable
[SwitchD-mvxlan-vpn1-ipv4] quit
[SwitchD-mvxlan-vpn1] quit
[SwitchD-LoopBack1] ip binding vpn-instance vpn1
[SwitchD-LoopBack1] ip address 88.88.88.88 32
[SwitchD] pim vpn-instance vpn1
[SwitchD-pim-vpn1] c-bsr 88.88.88.88
[SwitchD-pim-vpn1] c-rp 88.88.88.88
[SwitchD-pim-vpn1] quit
7.     Configure Switch E:
# Enable L2VPN and IP multicast routing, and create VLAN 21.
[SwitchE-mrib] quit
[SwitchE] vlan 21
[SwitchE-vlan21] quit
[SwitchE-LoopBack0] ip address 4.4.4.4 32
[SwitchE-LoopBack0] pim sm
[SwitchE-LoopBack0] ospf 1 area 0.0.0.0
[SwitchE] vsi vpna
# Create VXLAN 21.
[SwitchE-vsi-vpna] vxlan 21
[SwitchE-vsi-vpna-vxlan-21] quit
[SwitchE] bgp 200
[SwitchE-bgp-default] peer 88.88.88.88 as-number 200
[SwitchE-bgp-default] peer 88.88.88.88 connect-interface loopback 0
[SwitchE-bgp-default-evpn] peer 88.88.88.88 enable
[SwitchE-bgp-default-evpn] peer 88.88.88.88 next-hop-local
# On Ten-GigabitEthernet 1/0/1, create Ethernet service instance 100 to match VLAN 21.
[SwitchE] interface ten-gigabitethernet 1/0/1
[SwitchE-Ten-GigabitEthernet1/0/1] port link-type trunk
[SwitchE-Ten-GigabitEthernet1/0/1] port trunk permit vlan 1 21
[SwitchE-Ten-GigabitEthernet1/0/1] service-instance 100
[SwitchE-Ten-GigabitEthernet1/0/1-srv100] encapsulation s-vid 21
[SwitchE-Ten-GigabitEthernet1/0/1-srv100] xconnect vsi vpna
[SwitchE-Ten-GigabitEthernet1/0/1-srv100] quit
[SwitchE] ip vpn-instance vpn1
[SwitchE-vpn-instance-vpn1] route-distinguisher 2:3
[SwitchE-vpn-instance-vpn1] vpn-target 10:10 20:20 30:30 import-extcommunity
[SwitchE-vpn-instance-vpn1] vpn-target 20:20 export-extcommunity
[SwitchE-vpn-instance-vpn1] quit
[SwitchE-Vsi-interface1] ip binding vpn-instance vpn1
[SwitchE-Vsi-interface1] ip address 192.168.40.1 255.255.255.0
[SwitchE] interface vsi-interface 2
[SwitchE-Vsi-interface2] ip binding vpn-instance vpn1
[SwitchE-Vsi-interface2] l3-vni 1000
[SwitchE-Vsi-interface2] pim sm
[SwitchE-Vsi-interface2] quit
[SwitchE] multicast routing vpn-instance vpn1
[SwitchE-mrib-vpn1] quit
[SwitchE] multicast-vpn vxlan vpn-instance vpn1 mode mdt
[SwitchE-mvxlan-vpn1] address-family ipv4
[SwitchE-mvxlan-vpn1-ipv4] source loopback 0
[SwitchE-mvxlan-vpn1-ipv4] quit
[SwitchE-mvxlan-vpn1] quit
[SwitchE-LoopBack1] ip binding vpn-instance vpn1
[SwitchE-LoopBack1] ip address 4.4.4.4 32
[SwitchE-LoopBack1] pim sm
[SwitchE] pim vpn-instance vpn1
[SwitchE-pim-vpn1] c-bsr 4.4.4.4
[SwitchE-pim-vpn1] c-rp 4.4.4.4
[SwitchE-pim-vpn1] quit
[SwitchE] vsi vpna
1.     Verify the multicast routing information on Switch A, Switch B, and Switch E. This step uses Switch A as an example.
# Verify that Switch A has multicast routing entries for VPN instance vpn1.
<SwitchA> display pim vpn-instance vpn1 routing-table
 Total 1 (*, G) entries; 1 (S, G) entries
 (*, 225.0.0.1)
     RP: 1.1.1.1 (local)
     Protocol: pim-sm, Flag: WC RC
     UpTime: 01:19:10
     Upstream interface: Register-Tunnel0
         1: MTunnel0
             Protocol: MD, UpTime: 01:19:10, Expires: -
 (192.168.10.2, 225.0.0.1)
     RP: 1.1.1.1 (local)
     Protocol: pim-sm, Flag: SPT 2MSDP LOC ACT SQ RC 2MVPN
     UpTime: 03:27:40
     Upstream interface: Vsi-interface1
         1: MTunnel1
             Protocol: MD, UpTime: 01:19:06, Expires: -
# Verify that Switch A has multicast routing entries for the public network.
<SwitchA> display pim routing-table
 (1.1.1.1, 239.0.0.1)
     RP: NULL
     Protocol: pim-sm, Flag: SPT LOC VXLAN_L3
     UpTime: 03:43:30
     Upstream interface: MTunnel0 (VPN: vpn1)
         1: Vlan-interface10
             Protocol: pim-sm, UpTime: 01:19:18, Expires: 00:03:15
 (2.2.2.2, 239.0.0.1)
     RP: NULL
     UpTime: 01:18:42
     Upstream interface: Vlan-interface10
         Upstream neighbor: 11.1.1.2
         RPF prime neighbor: 11.1.1.2
         1: MVXLAN-UPE0
             Protocol: MD, UpTime: 01:18:42, Expires: -
 (77.77.77.77, 239.0.0.1)
     RP: NULL
     UpTime: 01:19:16
         1: MVXLAN-UPE0
             Protocol: MD, UpTime: 01:19:16, Expires: -
 (1.1.1.1, 239.1.1.0)
     RP: NULL
     UpTime: 01:19:16
     Upstream interface: MTunnel1 (VPN: vpn1)
         1: Vlan-interface10
             Protocol: pim-sm, UpTime: 01:19:01, Expires: 00:02:30
2.     Verify the multicast routing information on the EDs. This step uses Switch C as an example.
# Verify that Switch C has multicast routing entries for VPN instance vpn1.
<SwitchC> display pim vpn-instance vpn1 routing-table
 (*, 225.0.0.1)
     RP: 77.77.77.77 (local)
     UpTime: 01:18:39
     Total number of downstream interfaces: 2
         1: Vsi-interface2
             Protocol: MD, UpTime: 01:18:39, Expires: -
         2: MTunnel0
             Protocol: MD, UpTime: 01:18:05, Expires: -
     Protocol: pim-sm, Flag: SPT ACT RQ SRC-ACT 2MVPN FROMVXLAN
     UpTime: 01:18:39
     Upstream interface: MVXLAN-UPE0 (0.0.0.0)
         1: Vsi-interface2
# Verify that Switch C has multicast routing entries for the public network.
<SwitchC> display pim routing-table
     RP: NULL
     UpTime: 01:18:46
         1: Vlan-interface20
             Protocol: pim-sm, UpTime: 01:18:11, Expires: 00:03:17
         2: MVXLAN-UPE0
             Protocol: MD, UpTime: 01:18:44, Expires: -
     RP: NULL
     UpTime: 01:18:11
     Upstream interface: Vlan-interface20
         Upstream neighbor: 12.1.1.1
         RPF prime neighbor: 12.1.1.1
         1: Vlan-interface10
             Protocol: pim-sm, UpTime: 01:18:11, Expires: 00:03:15
         2: MVXLAN-UPE0
             Protocol: MD, UpTime: 01:18:11, Expires: -
     RP: NULL
     UpTime: 01:19:30
         1: Vlan-interface10
             Protocol: pim-sm, UpTime: 01:18:44, Expires: 00:02:42
         2: Vlan-interface20
     RP: NULL
     Protocol: pim-sm, Flag: SPT ACT 2MVPN
     UpTime: 01:18:46
         1: Vlan-interface20
         2: MVXLAN-UPE0
             Protocol: MD, UpTime: 01:18:30, Expires: -
# Verify that IGMP snooping has learned multicast group entries through EVPN on Switch C.
<SwitchC> display igmp-snooping evpn-group
Total 2 entries.
VSI Auto_L3VNI1000_2: Total 2 entries.
  (0.0.0.0, 225.0.0.1)
    Host ports (1 in total):
      Tun0 (VXLAN ID 1000)
Example: Configuring DCI Layer 3 multicast in a source-ED directly connected scenario (without L3 VXLAN ID mapping)
As shown in Figure 18, the multicast source is attached to Switch C and Switch D, and the receivers are attached to Switch A, Switch E, Switch F, and Switch G.
·     Switch B is a common Layer 2 switch for forwarding multicast traffic at Layer 2.
·     Switch A is a VTEP in DC 1.
·     Switch C and Switch D are EDs in DC 1 and form an M-LAG system.
·     Switch E and Switch F are EDs in DC 2 and form an M-LAG system.
·     Switch G is a VTEP in DC 2.
·     Both DC 1 and DC 2 use L3VNI 1000.
On Switch A through Switch G, configure PIM SM on the public-network interfaces used for intra-data center connection. Enable IGMP snooping on Switch C through Switch F.
Figure 18 Network diagram
Table 1 Interfaces and IP address assignment
Device
IP address
Device
IP address
Switch A
Loop0
1.1.1.1/32
Switch G
Loop0
6.6.6.6/32
Loop1
1.1.1.1/32
Loop1
6.6.6.6/32
Vlan-int12
12.1.1.1/24
Vlan-int13
13.1.1.6/24
VSI-int1
192.168.59.2/24
VSI-int1
192.168.60.2/24
Switch C
Loop0
2.2.2.2/32
Switch D
Loop0
3.3.3.3/32
Loop1
2.2.2.2/32
Loop1
3.3.3.3/32
Loop2
1.2.3.4/32
Loop2
1.2.3.4/32
Vlan-int12
12.1.1.2/24
Vlan-int12
12.1.1.3/24
Vlan-int24
24.1.1.2/24
Vlan-int34
34.1.1.3/24
Vlan-int25
25.1.1.2/24
Vlan-int35
35.1.1.3/24
VSI-int1
192.168.57.2/24
VSI-int1
192.168.57.3/24
Switch E
Loop0
4.4.4.4/32
Switch F
Loop0
5.5.5.5/32
Loop1
4.4.4.4/32
Loop1
5.5.5.5/32
Loop2
5.6.7.8/32
Loop2
5.6.7.8/32
Vlan-int13
13.1.1.4/24
Vlan-int13
12.1.1.5/24
Vlan-int24
24.1.1.4/24
Vlan-int25
25.1.1.5/24
Vlan-int34
34.1.1.4/24
Vlan-int35
35.1.1.5/24
VSI-int1
192.168.58.2/24
VSI-int1
192.168.58.3/24
1.     On the multicast source, specify 192.168.57.1 as the gateway address. On Receiver 1, Receiver 2, and Receiver 3, specify 192.168.58.1, 192.168.59.1, and 192.168.60.1 as the gateway addresses, respectively. (Details not shown.)
# Assign IP addresses to interfaces, as shown in Figure 18. (Details not shown.)
[SwitchA-mrib] quit
[SwitchA] vlan 11
[SwitchA] vsi vpna
[SwitchA-vsi-vpna-evpn-vxlan] vpn-target auto
# Create VXLAN 11.
[SwitchA] bgp 100
[SwitchA-bgp-default] group evpn internal
[SwitchA-bgp-default] peer evpn connect-interface loopback 0
[SwitchA-bgp-default] peer 2.2.2.2 group evpn
[SwitchA-bgp-default] peer 3.3.3.3 group evpn
[SwitchA-bgp-default-evpn] peer evpn enable
[SwitchA-bgp-default-evpn] peer evpn next-hop-local
[SwitchA-vpn-instance-vpn1] address-family ipv4
[SwitchA-vpn-ipv4-vpn1] vpn-target 2:2
[SwitchA-vpn-ipv4-vpn1] quit
[SwitchA-vpn-instance-vpn1] address-family evpn
[SwitchA-vpn-evpn-vpn1] vpn-target 1:1
[SwitchA-vpn-evpn-vpn1] quit
[SwitchA-Vsi-interface1] ip address 192.168.59.2 255.255.255.0
[SwitchA-mvxlan-vpn1-ipv4] default-group 236.0.0.0
[SwitchA-mvxlan-vpn1-ipv4] data-group 239.0.0.0 24
# Specify VSI-interface 1 as the gateway interface for VSI vpna.
[SwitchA] vsi vpna
# Create Layer 2 aggregate interface Bridge-Aggregation 1, and set the link aggregation mode to dynamic.
[SwitchB] interface bridge-aggregation 1
[SwitchB-Bridge-Aggregation1] link-aggregation mode dynamic
[SwitchB-Bridge-Aggregation1] quit
# Assign ports Ten-GigabitEthernet 1/0/2 and Ten-GigabitEthernet 1/0/3 to link aggregation group 1.
[SwitchB] interface range ten-gigabitethernet 1/0/2 to ten-gigabitethernet 1/0/3
[SwitchB-if-range] port link-aggregation group 1
[SwitchB-if-range] quit
# Create VLAN 11.
[SwitchB] vlan 11
[SwitchB-vlan11] quit
# Configure Layer 2 aggregate interface Bridge-Aggregation 1 as a trunk port and assign it to VLAN 11.
[SwitchB] interface Bridge-Aggregation 1
[SwitchB-Bridge-Aggregation1] port link-type trunk
[SwitchB-Bridge-Aggregation1] port trunk permit vlan 11
# Configure Ten-GigabitEthernet 1/0/1 as a trunk port and assign it to VLAN 11.
[SwitchB-Ten-GigabitEthernet1/0/1] port trunk permit vlan 11
[SwitchB-Ten-GigabitEthernet1/0/1] quit
# Enable L2VPN, IP multicast routing, OSPF process 1, and RIP process 1.
[SwitchC-mrib] quit
[SwitchC] pim
[SwitchC-pim] quit
[SwitchC] ospf 1
[SwitchC-ospf-1] area 0.0.0.0
[SwitchC-ospf-1] quit
[SwitchC] rip 1
[SwitchC] vsi vpna
# Create VXLAN 11.
[SwitchC-vsi-vpna] vxlan 11
[SwitchC-vsi-vpna-vxlan-11] quit
# On VLAN interface 24, enable RIP and DCI multicast.
[SwitchC] interface vlan-interface 24
[SwitchC-Vlan-interface24] rip 1 enable
[SwitchC-Vlan-interface24] dci enable
[SwitchC-Vlan-interface24] quit
# On VLAN interface 25, enable RIP and DCI multicast.
[SwitchC] interface vlan-interface 25
[SwitchC-Vlan-interface25] rip 1 enable
[SwitchC-Vlan-interface25] dci enable
[SwitchC-Vlan-interface25] quit
# Specify the virtual ED address as 1.2.3.4.
[SwitchC] evpn m-lag group 1.2.3.4
[SwitchC] evpn m-lag local 2.2.2.2 remote 3.3.3.3
[SwitchC-vpn-instance-vpn1] route-distinguisher 1:2
[SwitchC-vpn-instance-vpn1] address-family ipv4
[SwitchC-vpn-ipv4-vpn1] vpn-target 2:2
[SwitchC-vpn-ipv4-vpn1] quit
[SwitchC-vpn-instance-vpn1] address-family evpn
[SwitchC-vpn-evpn-vpn1] vpn-target 1:1
[SwitchC-vpn-evpn-vpn1] quit
[SwitchC-LoopBack0] ip address 2.2.2.2 32
[SwitchC-LoopBack1] ip address 2.2.2.2 32
# Configure Loopback 2.
[SwitchC] interface loopback 2
[SwitchC-LoopBack2] ip address 1.2.3.4 32
[SwitchC-LoopBack2] ospf 1 area 0.0.0.0
[SwitchC-LoopBack2] rip 1 enable
[SwitchC-LoopBack2] quit
[SwitchC-Vsi-interface1] ip binding vpn-instance vpn1
[SwitchC-Vsi-interface1] ip address 192.168.57.2 255.255.255.0
[SwitchC-Bridge-Aggregation1] link-aggregation mode dynamic
[SwitchC-Bridge-Aggregation1] quit
# Assign Ten-GigabitEthernet 1/0/1 to link aggregation group 1.
[SwitchC] interface ten-gigabitethernet 1/0/1
# Assign the Layer 2 aggregate interface to M-LAG group 1, create Ethernet service instance 100, and configure the Ethernet service instance to match frames that have an outer 802.1Q VLAN ID of 11.
[SwitchC-Bridge-Aggregation1] port link-type trunk
[SwitchC-Bridge-Aggregation1] port trunk permit vlan 1 11
[SwitchC-Bridge-Aggregation1] port m-lag group 1
[SwitchC-Bridge-Aggregation1] service-instance 100
[SwitchC-Bridge-Aggregation1-srv100] encapsulation s-vid 11
[SwitchC-Bridge-Aggregation1-srv100] xconnect vsi vpna
[SwitchC-Bridge-Aggregation1-srv100] quit
# Enable IP multicast routing in VPN instance vpn1.
[SwitchC-pim-vpn1] c-bsr 2.2.2.2
[SwitchC-pim-vpn1] c-rp 2.2.2.2
# Create an MDT-based MVXLAN for VPN instance vpn1 and enter MVXLAN IPv4 address family view. Configure the default group, MVXLAN source interface, and data group range settings. Enable advertising active multicast sources through S-PMSI routes, and enable DCI multicast.
[SwitchC-mvxlan-vpn1-ipv4] default-group 236.0.0.0
[SwitchC-mvxlan-vpn1-ipv4] source loopback 2 evpn-mlag-group
[SwitchC-mvxlan-vpn1-ipv4] data-group 239.0.0.0 24
[SwitchC-mvxlan-vpn1-ipv4] s-pmsi advertise source-active
# Configure a routing policy to meet the following requirements:
¡     Switch C does not forward SMET and S-PMSI routes from Switch D to Switch E or Switch F.
¡     Switch C modifies the next hop as 2.2.2.2 when receiving a SMET or S-PMSI route from a device other than Switch D.
[SwitchC] ip prefix-list 1 index 10 permit 0.0.0.0 0 less-equal 32
[SwitchC] ip prefix-list 2 index 10 permit 3.3.3.3 32
[SwitchC] route-policy 2 deny node 0
[SwitchC-route-policy-2-0] if-match ip route-source prefix-list 2
[SwitchC-route-policy-2-0] if-match route-type bgp-evpn-mac-ip bgp-evpn-imet bgp-evpn-ip-prefix
[SwitchC-route-policy-2-0] quit
[SwitchC] route-policy 2 deny node 1
[SwitchC-route-policy-2-1] if-match ip route-source prefix-list 2
[SwitchC-route-policy-2-1] if-match route-type bgp-evpn-smet bgp-evpn-s-pmsi
[SwitchC-route-policy-2-1] quit
[SwitchC] route-policy 2 permit node 2
[SwitchC-route-policy-2-2] if-match ip route-source prefix-list 1
[SwitchC-route-policy-2-2] if-match route-type bgp-evpn-smet bgp-evpn-s-pmsi
[SwitchC-route-policy-2-2] apply ip-address next-hop 2.2.2.2
[SwitchC-route-policy-2-2] quit
[SwitchC] route-policy 2 permit node 3
[SwitchC-route-policy-2-3] if-match ip route-source prefix-list 1
[SwitchC-route-policy-2-3] quit
# Configure another routing policy, so Switch C sends SMET and S-PMSI routes to only Switch D.
[SwitchC] route-policy 10 permit node 1
[SwitchC-route-policy-10-1] if-match ip route-source prefix-list 1
[SwitchC-route-policy-10-1] if-match route-type bgp-evpn-smet bgp-evpn-s-pmsi
[SwitchC-route-policy-10-1] quit
# Configure BGP to advertise EVPN routes, and set the virtual ED address as the next hop for the advertised routes.
[SwitchC] bgp 100
[SwitchC-bgp-default] peer 1.1.1.1 as-number 100
[SwitchC-bgp-default] peer 1.1.1.1 connect-interface loopback 0
[SwitchC-bgp-default] peer 3.3.3.3 as-number 100
[SwitchC-bgp-default] peer 3.3.3.3 connect-interface loopback 0
[SwitchC-bgp-default] peer 4.4.4.4 as-number 200
[SwitchC-bgp-default] peer 4.4.4.4 connect-interface loopback 0
[SwitchC-bgp-default] peer 4.4.4.4 ebgp-max-hop 64
[SwitchC-bgp-default] peer 5.5.5.5 ebgp-max-hop 64
[SwitchC-bgp-default-evpn] nexthop evpn-m-lag group-address
[SwitchC-bgp-default-evpn] peer 1.1.1.1 enable
[SwitchC-bgp-default-evpn] peer 1.1.1.1 next-hop-local
[SwitchC-bgp-default-evpn] peer 3.3.3.3 enable
[SwitchC-bgp-default-evpn] peer 3.3.3.3 next-hop-local
[SwitchC-bgp-default-evpn] peer 3.3.3.3 route-policy 10 export
[SwitchC-bgp-default-evpn] peer 4.4.4.4 enable
[SwitchC-bgp-default-evpn] peer 4.4.4.4 router-mac-local
[SwitchC-bgp-default-evpn] peer 4.4.4.4 route-policy 2 export
[SwitchC-bgp-default-evpn] peer 5.5.5.5 router-mac-local
[SwitchC-bgp-default-evpn] peer 5.5.5.5 route-policy 2 export
# Configure Layer 2 dynamic aggregate interface Bridge-Aggregation 9, and specify it as the peer-link interface.
# Assign Ten-GigabitEthernet 1/0/2 to link aggregation group 9.
[SwitchC-Ten-GigabitEthernet1/0/2] quit
# Configure M-LAG system settings.
[SwitchC] m-lag system-mac 0001-0001-0001
[SwitchC] vsi vpna
[SwitchD-mrib] quit
[SwitchD] pim
[SwitchD-pim] quit
[SwitchD] ospf 1
[SwitchD-ospf-1] area 0.0.0.0
[SwitchD-ospf-1] quit
[SwitchD] rip 1
[SwitchD] vsi vpna
# Create VXLAN 11.
[SwitchD-vsi-vpna] vxlan 11
[SwitchD-vsi-vpna-vxlan-11] quit
# On VLAN interface 34, enable RIP and DCI multicast.
[SwitchD] interface vlan-interface 34
[SwitchD-Vlan-interface34] rip 1 enable
[SwitchD-Vlan-interface34] dci enable
[SwitchD-Vlan-interface34] quit
# On VLAN interface 35, enable RIP and DCI multicast.
[SwitchD] interface vlan-interface 35
[SwitchD-Vlan-interface35] rip 1 enable
[SwitchD-Vlan-interface35] dci enable
[SwitchD-Vlan-interface35] quit
[SwitchD] evpn m-lag group 1.2.3.4
[SwitchD] evpn m-lag local 3.3.3.3 remote 2.2.2.2
[SwitchD-vpn-instance-vpn1] route-distinguisher 1:3
[SwitchD-vpn-instance-vpn1] address-family ipv4
[SwitchD-vpn-ipv4-vpn1] vpn-target 2:2
[SwitchD-vpn-ipv4-vpn1] quit
[SwitchD-vpn-instance-vpn1] address-family evpn
[SwitchD-vpn-evpn-vpn1] vpn-target 1:1
[SwitchD-vpn-evpn-vpn1] quit
[SwitchD-LoopBack0] ip address 3.3.3.3 32
[SwitchD-LoopBack1] ip address 3.3.3.3 32
[SwitchD-LoopBack2] ip address 1.2.3.4 32
[SwitchD-LoopBack2] ospf 1 area 0.0.0.0
[SwitchD-LoopBack2] rip 1 enable
[SwitchD-Vsi-interface1] ip binding vpn-instance vpn1
[SwitchD-Vsi-interface1] ip address 192.168.57.3 255.255.255.0
[SwitchD-Bridge-Aggregation1] link-aggregation mode dynamic
[SwitchD-Bridge-Aggregation1] quit
[SwitchD-Bridge-Aggregation1] port link-type trunk
[SwitchD-Bridge-Aggregation1] port trunk permit vlan 1 11
[SwitchD-Bridge-Aggregation1] port m-lag group 1
[SwitchD-Bridge-Aggregation1] service-instance 100
[SwitchD-Bridge-Aggregation1-srv100] encapsulation s-vid 11
[SwitchD-Bridge-Aggregation1-srv100] xconnect vsi vpna
[SwitchD-Bridge-Aggregation1-srv100] quit
[SwitchD-pim-vpn1] c-bsr 3.3.3.3
[SwitchD-pim-vpn1] c-rp 3.3.3.3
[SwitchD-mvxlan-vpn1-ipv4] default-group 236.0.0.0
[SwitchD-mvxlan-vpn1-ipv4] source loopback 2 evpn-mlag-group
[SwitchD-mvxlan-vpn1-ipv4] data-group 239.0.0.0 24
[SwitchD-mvxlan-vpn1-ipv4] s-pmsi advertise source-active
# Specify the IP addresses of the member devices in the M-LAG system.
¡     Switch D does not forward SMET and S-PMSI routes from Switch C to Switch E or Switch F.
¡     Switch D modifies the next hop as 3.3.3.3 when receiving a SMET or S-PMSI route from a device other than Switch C.
[SwitchD] ip prefix-list 1 index 10 permit 0.0.0.0 0 less-equal 32
[SwitchD] ip prefix-list 2 index 10 permit 2.2.2.2 32
[SwitchD] route-policy 3 deny node 0
[SwitchD-route-policy-3-0] if-match ip route-source prefix-list 2
[SwitchD-route-policy-3-0] if-match route-type bgp-evpn-mac-ip bgp-evpn-imet bgp-evpn-ip-prefix
[SwitchD-route-policy-3-0] quit
[SwitchD] route-policy 3 deny node 1
[SwitchD-route-policy-3-1] if-match ip route-source prefix-list 2
[SwitchD-route-policy-3-1] if-match route-type bgp-evpn-smet bgp-evpn-s-pmsi
[SwitchD-route-policy-3-1] quit
[SwitchD] route-policy 3 permit node 2
[SwitchD-route-policy-3-2] if-match ip route-source prefix-list 1
[SwitchD-route-policy-3-2] if-match route-type bgp-evpn-smet bgp-evpn-s-pmsi
[SwitchD-route-policy-3-2] apply ip-address next-hop 3.3.3.3
[SwitchD-route-policy-3-2] quit
[SwitchD] route-policy 3 permit node 3
[SwitchD-route-policy-3-3] if-match ip route-source prefix-list 1
[SwitchD-route-policy-3-3] quit
# Configure another routing policy, so Switch D send SMET and S-PMSI routes to only Switch C.
[SwitchD] route-policy 10 permit node 1
[SwitchD-route-policy-10-1] if-match ip route-source prefix-list 1
[SwitchD-route-policy-10-1] if-match route-type bgp-evpn-smet bgp-evpn-s-pmsi
[SwitchD-route-policy-10-1] quit
[SwitchD] bgp 100
[SwitchD-bgp-default] peer 1.1.1.1 as-number 100
[SwitchD-bgp-default] peer 1.1.1.1 connect-interface loopback 0
[SwitchD-bgp-default] peer 2.2.2.2 as-number 100
[SwitchD-bgp-default] peer 2.2.2.2 connect-interface loopback 0
[SwitchD-bgp-default] peer 4.4.4.4 ebgp-max-hop 64
[SwitchD-bgp-default] peer 5.5.5.5 ebgp-max-hop 64
[SwitchD-bgp-default-evpn] nexthop evpn-m-lag group-address
[SwitchD-bgp-default-evpn] peer 1.1.1.1 enable
[SwitchD-bgp-default-evpn] peer 1.1.1.1 next-hop-local
[SwitchD-bgp-default-evpn] peer 2.2.2.2 enable
[SwitchD-bgp-default-evpn] peer 2.2.2.2 next-hop-local
[SwitchD-bgp-default-evpn] peer 2.2.2.2 route-policy 10 export
[SwitchD-bgp-default-evpn] peer 4.4.4.4 router-mac-local
[SwitchD-bgp-default-evpn] peer 4.4.4.4 route-policy 3 export
[SwitchD-bgp-default-evpn] peer 5.5.5.5 router-mac-local
[SwitchD-bgp-default-evpn] peer 5.5.5.5 route-policy 3 export
[SwitchD-Ten-GigabitEthernet1/0/2] quit
[SwitchD] m-lag system-mac 0001-0001-0001
[SwitchD] vsi vpna
[SwitchE-mrib] quit
[SwitchE] pim
[SwitchE-pim] quit
[SwitchE] ospf 1
[SwitchE-ospf-1] area 0.0.0.0
[SwitchE-ospf-1-area-0.0.0.0] quit
[SwitchE-ospf-1] quit
[SwitchE] rip 1
[SwitchE-rip-1] quit
[SwitchE] vsi vpna
# Create VXLAN 11.
[SwitchE-vsi-vpna] vxlan 11
[SwitchE-vsi-vpna-vxlan-11] quit
[SwitchE] interface vlan-interface 24
[SwitchE-Vlan-interface24] rip 1 enable
[SwitchE-Vlan-interface24] dci enable
[SwitchE-Vlan-interface24] quit
[SwitchE] interface vlan-interface 34
[SwitchE-Vlan-interface34] rip 1 enable
[SwitchE-Vlan-interface34] dci enable
[SwitchE-Vlan-interface34] quit
# Specify the virtual ED address as 5.6.7.8.
[SwitchE] evpn m-lag group 5.6.7.8
[SwitchE] evpn m-lag local 4.4.4.4 remote 5.5.5.5
[SwitchE-vpn-instance-vpn1] route-distinguisher 1:4
[SwitchE-vpn-instance-vpn1] address-family ipv4
[SwitchE-vpn-ipv4-vpn1] vpn-target 2:2
[SwitchE-vpn-ipv4-vpn1] quit
[SwitchE-vpn-instance-vpn1] address-family evpn
[SwitchE-vpn-evpn-vpn1] vpn-target 1:1
[SwitchE-vpn-evpn-vpn1] quit
# Configure Loopback 0.
[SwitchE-LoopBack0] rip 1 enable
[SwitchE-LoopBack2] ip address 5.6.7.8 32
[SwitchE-LoopBack2] ospf 1 area 0.0.0.0
[SwitchE-LoopBack2] rip 1 enable
[SwitchE-Vsi-interface1] ip address 192.168.58.2 255.255.255.0
# Create Ethernet service instance 100 on Ten-GigabitEthernet 1/0/1, and configure the Ethernet service instance to match frames that have an outer 802.1Q VLAN ID of 11.
[SwitchE-Ten-GigabitEthernet1/0/1] port trunk permit vlan 1 11
[SwitchE-Ten-GigabitEthernet1/0/1-srv100] encapsulation s-vid 11
# Map Ethernet service instance 100 to VSI vpna.
[SwitchE-mvxlan-vpn1-ipv4] default-group 236.0.0.0
[SwitchE-mvxlan-vpn1-ipv4] source loopback 2 evpn-mlag-group
[SwitchE-mvxlan-vpn1-ipv4] data-group 239.0.0.0 24
[SwitchE-mvxlan-vpn1-ipv4] s-pmsi advertise source-active
[SwitchE-mvxlan-vpn1-ipv4] dci enable
¡     Switch E does not forward SMET and S-PMSI routes from Switch F to Switch C or Switch D.
¡     Switch E modifies the next hop as 4.4.4.4 when receiving a SMET or S-PMSI route from a device other than Switch F.
[SwitchE] ip prefix-list 1 index 10 permit 0.0.0.0 0 less-equal 32
[SwitchE] ip prefix-list 2 index 10 permit 5.5.5.5 32
[SwitchE] route-policy 4 deny node 0
[SwitchE-route-policy-4-0] if-match ip route-source prefix-list 2
[SwitchE-route-policy-4-0] if-match route-type bgp-evpn-mac-ip bgp-evpn-imet bgp-evpn-ip-prefix
[SwitchE-route-policy-4-0] quit
[SwitchE] route-policy 4 deny node 1
[SwitchE-route-policy-4-1] if-match ip route-source prefix-list 2
[SwitchE-route-policy-4-1] if-match route-type bgp-evpn-smet bgp-evpn-s-pmsi
[SwitchE-route-policy-4-1] quit
[SwitchE] route-policy 4 permit node 2
[SwitchE-route-policy-4-2] if-match ip route-source prefix-list 1
[SwitchE-route-policy-4-2] if-match route-type bgp-evpn-smet bgp-evpn-s-pmsi
[SwitchE-route-policy-4-2] apply ip-address next-hop 4.4.4.4
[SwitchE-route-policy-4-2] quit
[SwitchE] route-policy 4 permit node 3
[SwitchE-route-policy-4-3] if-match ip route-source prefix-list 1
[SwitchE-route-policy-4-3] quit
# Configure another routing policy, so Switch E sends SMET and S-PMSI routes to only Switch F.
[SwitchE] route-policy 10 permit node 1
[SwitchE-route-policy-10-1] if-match ip route-source prefix-list 1
[SwitchE-route-policy-10-1] if-match route-type bgp-evpn-smet bgp-evpn-s-pmsi
[SwitchE-route-policy-10-1] quit
[SwitchE] bgp 200
[SwitchE-bgp-default] peer 5.5.5.5 as-number 200
[SwitchE-bgp-default] peer 5.5.5.5 connect-interface loopback 0
[SwitchE-bgp-default] peer 6.6.6.6 as-number 200
[SwitchE-bgp-default] peer 6.6.6.6 connect-interface loopback 0
[SwitchE-bgp-default] peer 2.2.2.2 as-number 100
[SwitchE-bgp-default] peer 2.2.2.2 connect-interface loopback 0
[SwitchE-bgp-default] peer 2.2.2.2 ebgp-max-hop 64
[SwitchE-bgp-default] peer 3.3.3.3 as-number 100
[SwitchE-bgp-default] peer 3.3.3.3 connect-interface loopback 0
[SwitchE-bgp-default] peer 3.3.3.3 ebgp-max-hop 64
[SwitchE-bgp-default-evpn] nexthop evpn-m-lag group-address
[SwitchE-bgp-default-evpn] peer 5.5.5.5 enable
[SwitchE-bgp-default-evpn] peer 5.5.5.5 next-hop-local
[SwitchE-bgp-default-evpn] peer 5.5.5.5 route-policy 10 export
[SwitchE-bgp-default-evpn] peer 6.6.6.6 enable
[SwitchE-bgp-default-evpn] peer 6.6.6.6 next-hop-local
[SwitchE-bgp-default-evpn] peer 2.2.2.2 enable
[SwitchE-bgp-default-evpn] peer 2.2.2.2 router-mac-local
[SwitchE-bgp-default-evpn] peer 2.2.2.2 route-policy 4 export
[SwitchE-bgp-default-evpn] peer 3.3.3.3 enable
[SwitchE-bgp-default-evpn] peer 3.3.3.3 router-mac-local
[SwitchE-bgp-default-evpn] peer 3.3.3.3 route-policy 4 export
[SwitchE] m-lag system-mac 0002-0002-0002
[SwitchE] vsi vpna
8.     Configure Switch F:
[SwitchF-mrib] quit
[SwitchF] pim
[SwitchF-pim] quit
[SwitchF] ospf 1
[SwitchF-ospf-1] area 0.0.0.0
[SwitchF-ospf-1-area-0.0.0.0] quit
[SwitchF-ospf-1] quit
[SwitchF] rip 1
[SwitchF-rip-1] quit
[SwitchF] vsi vpna
# Create VXLAN 11.
[SwitchF-vsi-vpna] vxlan 11
[SwitchF-vsi-vpna-vxlan-11] quit
[SwitchF] interface vlan-interface 25
[SwitchF-Vlan-interface25] rip 1 enable
[SwitchF-Vlan-interface25] dci enable
[SwitchF-Vlan-interface25] quit
[SwitchF] interface vlan-interface 35
[SwitchF-Vlan-interface35] rip 1 enable
[SwitchF-Vlan-interface35] dci enable
[SwitchF-Vlan-interface35] quit
[SwitchF] evpn m-lag group 5.6.7.8
[SwitchF] evpn m-lag local 5.5.5.5 remote 4.4.4.4
[SwitchF] ip vpn-instance vpn1
[SwitchF-vpn-instance-vpn1] route-distinguisher 1:5
[SwitchF-vpn-instance-vpn1] address-family ipv4
[SwitchF-vpn-ipv4-vpn1] vpn-target 2:2
[SwitchF-vpn-ipv4-vpn1] quit
[SwitchF-vpn-instance-vpn1] address-family evpn
[SwitchF-vpn-evpn-vpn1] vpn-target 1:1
[SwitchF-vpn-evpn-vpn1] quit
[SwitchF-vpn-instance-vpn1] quit
[SwitchF-LoopBack0] ip address 5.5.5.5 32
[SwitchF-LoopBack0] ospf 1 area 0.0.0.0
[SwitchF-LoopBack0] rip 1 enable
[SwitchF-LoopBack0] pim sm
[SwitchF-LoopBack1] ip binding vpn-instance vpn1
[SwitchF-LoopBack1] ip address 5.5.5.5 32
[SwitchF-LoopBack1] pim sm
[SwitchF-LoopBack2] ip address 5.6.7.8 32
[SwitchF-LoopBack2] ospf 1 area 0.0.0.0
[SwitchF-LoopBack2] rip 1 enable
[SwitchF-Vsi-interface1] ip binding vpn-instance vpn1
[SwitchF-Vsi-interface1] ip address 192.168.58.3 255.255.255.0
[SwitchF] interface vsi-interface 2
[SwitchF-Vsi-interface2] ip binding vpn-instance vpn1
[SwitchF-Vsi-interface2] l3-vni 1000
[SwitchF-Vsi-interface2] pim sm
[SwitchF-Vsi-interface2] quit
[SwitchF-Ten-GigabitEthernet1/0/1] port link-type trunk
[SwitchF-Ten-GigabitEthernet1/0/1] port trunk permit vlan 1 11
[SwitchF-Ten-GigabitEthernet1/0/1] service-instance 100
[SwitchF-Ten-GigabitEthernet1/0/1-srv100] encapsulation s-vid 11
[SwitchF-Ten-GigabitEthernet1/0/1-srv100] xconnect vsi vpna
[SwitchF-Ten-GigabitEthernet1/0/1-srv100] quit
[SwitchF] multicast routing vpn-instance vpn1
[SwitchF-mrib-vpn1] quit
[SwitchF] pim vpn-instance vpn1
[SwitchF-pim-vpn1] c-bsr 5.5.5.5
[SwitchF-pim-vpn1] c-rp 5.5.5.5
[SwitchF-pim-vpn1] quit
[SwitchF] multicast-vpn vxlan vpn-instance vpn1 mode mdt
[SwitchF-mvxlan-vpn1] address-family ipv4
[SwitchF-mvxlan-vpn1-ipv4] default-group 236.0.0.0
[SwitchF-mvxlan-vpn1-ipv4] source loopback 2 evpn-mlag-group
[SwitchF-mvxlan-vpn1-ipv4] data-group 239.0.0.0 24
[SwitchF-mvxlan-vpn1-ipv4] s-pmsi advertise source-active
[SwitchF-mvxlan-vpn1-ipv4] dci enable
[SwitchF-mvxlan-vpn1-ipv4] quit
[SwitchF-mvxlan-vpn1] quit
¡     Switch F does not forward SMET and S-PMSI routes from Switch E to Switch C or Switch D.
¡     Switch F modifies the next hop as 5.5.5.5 when receiving a SMET or S-PMSI route from a device other than Switch E.
[SwitchF] ip prefix-list 1 index 10 permit 0.0.0.0 0 less-equal 32
[SwitchF] ip prefix-list 2 index 10 permit 5.5.5.5 32
[SwitchF] route-policy 5 deny node 0
[SwitchF-route-policy-5-0] if-match ip route-source prefix-list 2
[SwitchF-route-policy-5-0] if-match route-type bgp-evpn-mac-ip bgp-evpn-imet bgp-evpn-ip-prefix
[SwitchF-route-policy-5-0] quit
[SwitchF] route-policy 5 deny node 1
[SwitchF-route-policy-5-1] if-match ip route-source prefix-list 2
[SwitchF-route-policy-5-1] if-match route-type bgp-evpn-smet bgp-evpn-s-pmsi
[SwitchF-route-policy-5-1] quit
[SwitchF] route-policy 5 permit node 2
[SwitchF-route-policy-5-2] if-match ip route-source prefix-list 1
[SwitchF-route-policy-5-2] if-match route-type bgp-evpn-smet bgp-evpn-s-pmsi
[SwitchF-route-policy-5-2] apply ip-address next-hop 5.5.5.5
[SwitchF-route-policy-5-2] quit
[SwitchF] route-policy 5 permit node 3
[SwitchF-route-policy-5-3] if-match ip route-source prefix-list 1
[SwitchF-route-policy-5-3] quit
# Configure another routing policy, so Switch F send SMET and S-PMSI routes to only Switch E.
[SwitchF] route-policy 10 permit node 1
[SwitchF-route-policy-10-1] if-match ip route-source prefix-list 1
[SwitchF-route-policy-10-1] if-match route-type bgp-evpn-smet bgp-evpn-s-pmsi
[SwitchF-route-policy-10-1] quit
[SwitchF] bgp 200
[SwitchF-bgp-default] peer 4.4.4.4 as-number 200
[SwitchF-bgp-default] peer 4.4.4.4 connect-interface loopback 0
[SwitchF-bgp-default] peer 6.6.6.6 as-number 200
[SwitchF-bgp-default] peer 6.6.6.6 connect-interface loopback 0
[SwitchF-bgp-default] peer 2.2.2.2 as-number 100
[SwitchF-bgp-default] peer 2.2.2.2 connect-interface loopback 0
[SwitchF-bgp-default] peer 2.2.2.2 ebgp-max-hop 64
[SwitchF-bgp-default] peer 3.3.3.3 as-number 100
[SwitchF-bgp-default] peer 3.3.3.3 connect-interface loopback 0
[SwitchF-bgp-default] peer 3.3.3.3 ebgp-max-hop 64
[SwitchF-bgp-default-evpn] nexthop evpn-m-lag group-address
[SwitchF-bgp-default-evpn] peer 4.4.4.4 enable
[SwitchF-bgp-default-evpn] peer 4.4.4.4 next-hop-local
[SwitchF-bgp-default-evpn] peer 4.4.4.4 route-policy 10 export
[SwitchF-bgp-default-evpn] peer 6.6.6.6 enable
[SwitchF-bgp-default-evpn] peer 6.6.6.6 next-hop-local
[SwitchF-bgp-default-evpn] peer 2.2.2.2 enable
[SwitchF-bgp-default-evpn] peer 2.2.2.2 router-mac-local
[SwitchF-bgp-default-evpn] peer 2.2.2.2 route-policy 5 export
[SwitchF-bgp-default-evpn] peer 3.3.3.3 enable
[SwitchF-bgp-default-evpn] peer 3.3.3.3 router-mac-local
[SwitchF-bgp-default-evpn] peer 3.3.3.3 route-policy 5 export
[SwitchF] m-lag system-mac 0002-0002-0002
[SwitchF] vsi vpna
9.     Configure Switch G:
<SwitchG> system-view
[SwitchG] l2vpn enable
[SwitchG] multicast routing
[SwitchG-mrib] quit
[SwitchG] vlan 11
[SwitchG-vlan11] quit
[SwitchG] igmp-snooping
[SwitchG-igmp-snooping] quit
[SwitchG] vxlan tunnel mac-learning disable
[SwitchG] vxlan tunnel arp-learning disable
[SwitchG] interface loopback 0
[SwitchG-LoopBack0] ip address 6.6.6.6 32
[SwitchG-LoopBack0] pim sm
[SwitchG-LoopBack0] ospf 1 area 0.0.0.0
[SwitchG-LoopBack0] quit
[SwitchG] vsi vpna
[SwitchG-vsi-vpna] evpn encapsulation vxlan
[SwitchG-vsi-vpna-evpn-vxlan] route-distinguisher auto
[SwitchG-vsi-vpna-evpn-vxlan] vpn-target auto
[SwitchG-vsi-vpna-evpn-vxlan] quit
[SwitchG-vsi-vpna] igmp-snooping enable
[SwitchG-vsi-vpna] igmp-snooping proxy enable
# Create VXLAN 11.
[SwitchG-vsi-vpna] vxlan 11
[SwitchG-vsi-vpna-vxlan-11] quit
[SwitchG-vsi-vpna] quit
[SwitchG] bgp 200
[SwitchG-bgp-default] group evpn internal
[SwitchG-bgp-default] peer evpn connect-interface loopback 0
[SwitchG-bgp-default] peer 4.4.4.4 group evpn
[SwitchG-bgp-default] peer 5.5.5.5 group evpn
[SwitchG-bgp-default] address-family l2vpn evpn
[SwitchG-bgp-default-evpn] peer evpn enable
[SwitchG-bgp-default-evpn] peer evpn next-hop-local
[SwitchG-bgp-default-evpn] quit
[SwitchG-bgp-default] quit
[SwitchG] interface ten-gigabitethernet 1/0/1
[SwitchG-Ten-GigabitEthernet1/0/1] port link-type trunk
[SwitchG-Ten-GigabitEthernet1/0/1] port trunk permit vlan 1 11
[SwitchG-Ten-GigabitEthernet1/0/1] service-instance 100
[SwitchG-Ten-GigabitEthernet1/0/1-srv100] encapsulation s-vid 11
[SwitchG-Ten-GigabitEthernet1/0/1-srv100] xconnect vsi vpna
[SwitchG-Ten-GigabitEthernet1/0/1-srv100] quit
[SwitchG] ip vpn-instance vpn1
[SwitchG-vpn-instance-vpn1] route-distinguisher 1:6
[SwitchG-vpn-instance-vpn1] address-family ipv4
[SwitchG-vpn-ipv4-vpn1] vpn-target 2:2
[SwitchG-vpn-ipv4-vpn1] quit
[SwitchG-vpn-instance-vpn1] address-family evpn
[SwitchG-vpn-evpn-vpn1] vpn-target 1:1
[SwitchG-vpn-evpn-vpn1] quit
[SwitchG-vpn-instance-vpn1] quit
[SwitchG] interface vsi-interface 1
[SwitchG-Vsi-interface1] ip binding vpn-instance vpn1
[SwitchG-Vsi-interface1] ip address 192.168.60.2 255.255.255.0
[SwitchG-Vsi-interface1] pim sm
[SwitchG-Vsi-interface1] igmp enable
[SwitchG-Vsi-interface1] distributed-gateway local
[SwitchG-Vsi-interface1] quit
[SwitchG] interface vsi-interface 2
[SwitchG-Vsi-interface2] ip binding vpn-instance vpn1
[SwitchG-Vsi-interface2] l3-vni 1000
[SwitchG-Vsi-interface2] pim sm
[SwitchG-Vsi-interface2] quit
[SwitchG] multicast routing vpn-instance vpn1
[SwitchG-mrib-vpn1] quit
[SwitchG] multicast-vpn vxlan vpn-instance vpn1 mode mdt
[SwitchG-mvxlan-vpn1] address-family ipv4
[SwitchG-mvxlan-vpn1-ipv4] default-group 236.0.0.0
[SwitchG-mvxlan-vpn1-ipv4] source loopback 0
[SwitchG-mvxlan-vpn1-ipv4] data-group 239.0.0.0 24
[SwitchG-mvxlan-vpn1-ipv4] quit
[SwitchG-mvxlan-vpn1] quit
[SwitchG] interface loopback 1
[SwitchG-LoopBack1] ip binding vpn-instance vpn1
[SwitchG-LoopBack1] ip address 6.6.6.6 32
[SwitchG-LoopBack1] pim sm
[SwitchG-LoopBack1] quit
[SwitchG] pim vpn-instance vpn1
[SwitchG-pim-vpn1] c-bsr 6.6.6.6
[SwitchG-pim-vpn1] c-rp 6.6.6.6
[SwitchG-pim-vpn1] quit
[SwitchG] vsi vpna
[SwitchG-vsi-vpna] gateway vsi-interface 1
1.     Verify the multicast routing information on the VTEPs.
# Verify that Switch A has multicast routing entries for VPN instance vpn1 and the public network.
 (*, 225.0.0.1)
     RP: NULL
     Protocol: pim-sm, Flag: WC NIIF RC
     UpTime: 00:00:55
     Upstream interface: NULL
         Upstream neighbor: NULL
         RPF prime neighbor: NULL
     Downstream interface information:
         1: Vsi-interface1
             Protocol: igmp, UpTime: 00:00:04, Expires: -
         2: MTunnel0
             Protocol: MD, UpTime: 00:00:55, Expires: -
 (192.168.57.1, 225.0.0.1)
     RP: NULL
     Protocol: pim-sm, Flag: SPT ACT RQ SRC-ACT FROMVXLAN
     UpTime: 00:01:06
         1: Vsi-interface1
             Protocol: pim-sm, UpTime: 00:00:04, Expires: -
Total 0 (*, G) entries; 5 (S, G) entries
 (1.1.1.1, 236.0.0.0)
     RP: NULL
     UpTime: 04:53:19
         1: Ten-GigabitEthernet1/0/2
             Protocol: pim-sm, UpTime: 04:50:57, Expires: 00:03:30
         2: Ten-GigabitEthernet1/0/3
             Protocol: pim-sm, UpTime: 04:51:43, Expires: 00:02:35
 (2.2.2.2, 236.0.0.0)
     RP: NULL
     UpTime: 04:50:57
     Upstream interface: Ten-GigabitEthernet1/0/2
         1: MVXLAN-UPE0
             Protocol: MD, UpTime: 04:50:57, Expires: -
 (3.3.3.3, 236.0.0.0)
     RP: NULL
     UpTime: 04:51:43
     Upstream interface: Ten-GigabitEthernet1/0/3
         Upstream neighbor: 13.1.1.2
         RPF prime neighbor: 13.1.1.2
         1: MVXLAN-UPE0
             Protocol: MD, UpTime: 04:51:43, Expires: -
 (2.2.2.2, 239.0.0.0)
     RP: NULL
     UpTime: 00:00:54
         1: MVXLAN-UPE0
             Protocol: MD, UpTime: 00:00:54, Expires: -
 (3.3.3.3, 239.0.0.0)
     RP: NULL
     UpTime: 00:00:54
         1: MVXLAN-UPE0
# Verify that Switch G has multicast routing entries for VPN instance vpn1 and the public network.
<SwitchG> display pim vpn-instance vpn1 routing-table
 (*, 225.0.0.1)
     RP: NULL
     UpTime: 00:03:29
         1: Vsi-interface1
             Protocol: igmp, UpTime: 00:03:29, Expires: -
         2: MTunnel0
             Protocol: MD, UpTime: 00:02:38, Expires: -
     RP: NULL
     UpTime: 00:03:40
         1: Vsi-interface1
             Protocol: pim-sm, UpTime: 00:03:29, Expires: -
<SwitchG> display pim routing-table
 (4.4.4.4, 236.0.0.0)
     RP: NULL
     UpTime: 04:53:14
         Upstream neighbor: 46.1.1.1
         RPF prime neighbor: 46.1.1.1
         1: MVXLAN-UPE0
             Protocol: MD, UpTime: 04:53:14, Expires: -
 (5.5.5.5, 236.0.0.0)
     RP: NULL
     UpTime: 04:52:09
         Upstream neighbor: 56.1.1.1
         RPF prime neighbor: 56.1.1.1
         1: MVXLAN-UPE0
             Protocol: MD, UpTime: 04:52:09, Expires: -
 (6.6.6.6, 236.0.0.0)
     RP: NULL
     UpTime: 04:55:14
             Protocol: pim-sm, UpTime: 04:53:14, Expires: 00:02:47
             Protocol: pim-sm, UpTime: 04:52:03, Expires: 00:02:46
 (4.4.4.4, 239.0.0.0)
     RP: NULL
     UpTime: 00:03:35
         1: MVXLAN-UPE0
             Protocol: MD, UpTime: 00:03:35, Expires: -
 (5.5.5.5, 239.0.0.0)
     RP: NULL
     UpTime: 00:03:35
         1: MVXLAN-UPE0
# Verify that Switch C has multicast routing entries for VPN instance vpn1 and the public network.
 (*, 225.0.0.1)
     RP: NULL
     UpTime: 00:04:47
         1: MTunnel0
             Protocol: MD, UpTime: 00:03:55, Expires: -
         2: Vsi-interface2
             Protocol: MD, UpTime: 00:04:47, Expires: -
     RP: NULL
     Protocol: pim-sm, Flag: SPT LOC ACT SQ SRC-ACT FROMMLAG
     UpTime: 00:04:58
         1: Vsi-interface2
Total 0 (*, G) entries; 3 (S, G) entries
     RP: NULL
     UpTime: 04:54:47
         1: MVXLAN-UPE0
             Protocol: MD, UpTime: 04:54:47, Expires: -
     RP: NULL
     UpTime: 04:56:53
             Protocol: pim-sm, UpTime: 04:54:47, Expires: 00:02:48
     RP: NULL
     UpTime: 00:05:34
             Protocol: pim-sm, UpTime: 00:04:42, Expires: 00:02:51
# Verify that Switch D has multicast routing entries for VPN instance vpn1 and the public network.
<SwitchD> display pim vpn-instance vpn1 routing-table
 (*, 225.0.0.1)
     RP: NULL
     UpTime: 00:06:17
         1: Vsi-interface2
             Protocol: MD, UpTime: 00:06:17, Expires: -
         2: MTunnel0
             Protocol: MD, UpTime: 00:05:25, Expires: -
     RP: NULL
     Protocol: pim-sm, Flag: SPT LOC ACT SQ SRC-ACT 2MVPN FROMMLAG
     UpTime: 00:06:29
         1: MTunnel1
         2: Vsi-interface2
<SwitchD> display pim routing-table
     RP: NULL
     UpTime: 04:56:42
         Upstream neighbor: 13.1.1.1
         RPF prime neighbor: 13.1.1.1
         1: MVXLAN-UPE0
             Protocol: MD, UpTime: 04:56:42, Expires: -
     RP: NULL
     UpTime: 04:57:45
         1: Ten-GigabitEthernet1/0/3
             Protocol: pim-sm, UpTime: 04:56:42, Expires: 00:03:02
     RP: NULL
     UpTime: 00:06:33
             Protocol: pim-sm, UpTime: 00:05:42, Expires: 00:02:51
# Verify that Switch E has multicast routing entries for VPN instance vpn1 and the public network.
<SwitchE> display pim vpn-instance vpn1 routing-table
 (*, 225.0.0.1)
     RP: NULL
     UpTime: 00:07:09
         1: Vsi-interface2
             Protocol: MD, UpTime: 00:06:18, Expires: -
         2: MTunnel0
             Protocol: MD, UpTime: 00:07:09, Expires: -
     RP: NULL
     Protocol: pim-sm, Flag: SPT ACT SQ SRC-ACT FROMACTDCI
     UpTime: 00:07:21
     Upstream interface: Vsi-interface2
     Downstream interface information: None
<SwitchE>display pim routing-table
     RP: NULL
     UpTime: 05:00:50
             Protocol: pim-sm, UpTime: 04:59:00, Expires: 00:02:52
     RP: NULL
     UpTime: 04:59:00
         Upstream neighbor: 46.1.1.2
         RPF prime neighbor: 46.1.1.2
         1: MVXLAN-UPE0
             Protocol: MD, UpTime: 04:59:00, Expires: -
     RP: NULL
     UpTime: 00:08:49
             Protocol: pim-sm, UpTime: 00:08:49, Expires: 00:03:30
# Verify that Switch F has multicast routing entries for VPN instance vpn1 and the public network.
<SwitchF> display pim vpn-instance vpn1 routing-table
 (*, 225.0.0.1)
     RP: NULL
     UpTime: 00:10:25
         1: MTunnel0
             Protocol: MD, UpTime: 00:10:25, Expires: -
         2: Vsi-interface2
             Protocol: MD, UpTime: 00:09:34, Expires: -
         3: Vsi-interface1
             Protocol: igmp, UpTime: 00:09:35, Expires: -
     RP: NULL
     UpTime: 00:10:37
         1: Vsi-interface1
             Protocol: pim-sm, UpTime: 00:09:35, Expires: -
         2: MTunnel1
             Protocol: MD, UpTime: 00:10:05, Expires: -
<SwitchF> display pim routing-table
     RP: NULL
     UpTime: 05:02:07
             Protocol: pim-sm, UpTime: 04:58:49, Expires: 00:03:21
     RP: NULL
     UpTime: 04:58:49
         Upstream neighbor: 56.1.1.2
         RPF prime neighbor: 56.1.1.2
         1: MVXLAN-UPE0
             Protocol: MD, UpTime: 04:58:49, Expires: -
     RP: NULL
     UpTime: 00:10:34
             Protocol: pim-sm, UpTime: 00:10:34, Expires: 00:02:55
Example: Configuring DCI Layer 3 multicast with multiple L3 VXLAN IDs mapped to the same intermediate L3 VXLAN ID
As shown in Figure 19, the multicast source of multicast group 225.0.0.1 is attached to Switch A, and the receivers of the multicast group are attached to Switch B, Switch E, and Switch G. Configure DCI Layer 3 multicast as follows:
·     For DC 3, configure Switch G as a VTEP, and configure Switch F as an ED.
·     On Switch A, Switch B, Switch E, and Switch G, configure PIM SM on the public-network interfaces. Enable IGMP snooping on Switch B, Switch E, and Switch G.
·     For DC 1, assign L3 VXLAN ID 1001 to VPN instance vpn1. For DC 2, assign L3 VXLAN ID 1002 to VPN instance vpn1. For DC 3, assign L3 VXLAN ID 1003 to VPN instance vpn1.
·     On Switch C, Switch D, and Switch F, create intermediate VPN instance vpn2 and assign L3 VXLAN ID 1000 to it.
Figure 19 Network diagram
1.     On the multicast source, specify 192.168.10.1 as the gateway address. On Receiver 1, specify 192.168.20.1 as the gateway address. On Receiver 2, specify 192.168.40.1 as the gateway address. On Receiver 3, specify 192.168.60.1 as the gateway address. (Details not shown.)
# Assign IP addresses to interfaces, as shown in Figure 19. (Details not shown.)
As a best practice, do not enable PIM SM on the VLAN interfaces that interconnect the EDs.
# Enable L2VPN and IP multicast routing.
[SwitchA-mrib] quit
# Enable the IGMP snooping feature.
# Disable remote MAC address learning and remote ARP learning.
# Create VLAN 11 and enter its view.
[SwitchA] vlan 11
# Create an EVPN instance on VSI vpna.
[SwitchA] vsi vpna
# Enable IGMP snooping and IGMP snooping proxying on VSI vpna.
# Create VXLAN 11.
# Configure BGP to advertise BGP EVPN routes.
[SwitchA] bgp 100
[SwitchA-vpn-instance-vpn1] vpn-target 10:10 import-extcommunity
# Configure VSI-interface 1.
[SwitchA-Vsi-interface1] igmp enable
# Associate VSI-interface 2 with VPN instance vpn1, and configure the L3 VXLAN ID as 1001 for the VPN instance.
[SwitchA-Vsi-interface3] ip binding vpn-instance vpn1
[SwitchA-Vsi-interface3] l3-vni 1001
[SwitchA-Vsi-interface3] pim sm
[SwitchA-Vsi-interface3] quit
[SwitchA-LoopBack0] ip address 1.1.1.1 32
[SwitchA-LoopBack0] pim sm
[SwitchA-LoopBack0] quit
[SwitchA] vsi vpna
[SwitchB-mrib] quit
# Create VLAN 12 and enter its view.
[SwitchB] vlan 12
[SwitchB] vsi vpna
[SwitchB-vsi-vpna-evpn-vxlan] vpn-target auto
# Create VXLAN 12.
[SwitchB] bgp 100
[SwitchB-vpn-instance-vpn1] vpn-target 10:10 import-extcommunity
[SwitchB-Vsi-interface1] pim sm
[SwitchB-Vsi-interface2] l3-vni 1001
[SwitchB-LoopBack0] ip address 2.2.2.2 32
[SwitchB-LoopBack0] pim sm
[SwitchB-LoopBack0] quit
[SwitchB] vsi vpna
[SwitchC-mrib] quit
[SwitchC] igmp-snooping
[SwitchC-igmp-snooping] quit
[SwitchC] vxlan tunnel mac-learning disable
[SwitchC] vxlan tunnel arp-learning disable
# Configure a route policy to disable Switch C from forwarding the SMET and S-PMSI routes received from Switch D to Switch F and from forwarding the SMET and S-PMSI routes received from Switch F to Switch D.
[SwitchC] ip prefix-list 8 index 10 permit 99.99.99.99 32
[SwitchC] ip prefix-list 9 index 10 permit 88.88.88.88 32
[SwitchC] route-policy 8 deny node 0
[SwitchC-route-policy-8-0] if-match ip route-source prefix-list 8
[SwitchC-route-policy-8-0] if-match route-type bgp-evpn-smet bgp-evpn-s-pmsi
[SwitchC-route-policy-8-0] quit
[SwitchC] route-policy 8 permit node 1
[SwitchC-route-policy-8-1] if-match ip route-source prefix-list 1
[SwitchC-route-policy-8-1] quit
[SwitchC] route-policy 9 deny node 0
[SwitchC-route-policy-9-0] if-match ip route-source prefix-list 9
[SwitchC-route-policy-9-0] if-match route-type bgp-evpn-smet bgp-evpn-s-pmsi
[SwitchC-route-policy-9-0] quit
[SwitchC] route-policy 9 permit node 1
[SwitchC-route-policy-9-1] if-match ip route-source prefix-list 1
[SwitchC-route-policy-9-1] quit
[SwitchC] bgp 100
[SwitchC-bgp-default] peer 99.99.99.99 as-number 300
[SwitchC-bgp-default] peer 99.99.99.99 connect-interface loopback 0
[SwitchC-bgp-default] peer 99.99.99.99 ebgp-max-hop 64
[SwitchC-bgp-default-evpn] peer group1 re-originated replace-rt
[SwitchC-bgp-default-evpn] peer group1 re-originated mac-ip replace-rt
[SwitchC-bgp-default-evpn] peer group1 re-originated imet replace-rt
[SwitchC-bgp-default-evpn] peer group1 advertise original-route
[SwitchC-bgp-default-evpn] peer group1 re-originated smet replace-rt
[SwitchC-bgp-default-evpn] peer group1 re-originated s-pmsi replace-rt
[SwitchC-bgp-default-evpn] peer 88.88.88.88 route-policy 8 export
[SwitchC-bgp-default-evpn] peer 88.88.88.88 re-originated replace-rt
[SwitchC-bgp-default-evpn] peer 88.88.88.88 re-originated mac-ip replace-rt
[SwitchC-bgp-default-evpn] peer 88.88.88.88 re-originated imet replace-rt
[SwitchC-bgp-default-evpn] peer 88.88.88.88 re-originated smet replace-rt
[SwitchC-bgp-default-evpn] peer 88.88.88.88 re-originated s-pmsi replace-rt
[SwitchC-bgp-default-evpn] peer 99.99.99.99 enable
[SwitchC-bgp-default-evpn] peer 99.99.99.99 route-policy 9 export
[SwitchC-bgp-default-evpn] peer 99.99.99.99 router-mac-local
[SwitchC-bgp-default-evpn] peer 99.99.99.99 re-originated replace-rt
[SwitchC-bgp-default-evpn] peer 99.99.99.99 re-originated mac-ip replace-rt
[SwitchC-bgp-default-evpn] peer 99.99.99.99 re-originated imet replace-rt
[SwitchC-bgp-default-evpn] peer 99.99.99.99 re-originated smet replace-rt
[SwitchC-bgp-default-evpn] peer 99.99.99.99 re-originated s-pmsi replace-rt
[SwitchC-vpn-instance-vpn1] vpn-target 10:10 200:200 300:300 import-extcommunity
[SwitchC-vpn-instance-vpn1] vpn-target 10:10 export-extcommunity [SwitchC-vpn-instance-vpn1] quit
# Configure RD and route target settings for VPN instance vpn2.
[SwitchC] ip vpn-instance vpn2
[SwitchC-vpn-instance-vpn2] route-distinguisher 1:13
[SwitchC-vpn-instance-vpn2] vpn-target 10:10 200:200 300:300 import-extcommunity
[SwitchC-vpn-instance-vpn2] vpn-target 100:100 export-extcommunity [SwitchC-vpn-instance-vpn2] quit
# Associate VSI-interface 1 with VPN instance vpn1, and configure the L3 VXLAN ID as 1001 for the VPN instance.
[SwitchC] interface vsi-interface 1
[SwitchC-Vsi-interface1] l3-vni 1001
[SwitchC-Vsi-interface1] pim sm
[SwitchC-Vsi-interface1] quit
# Associate VSI-interface 2 with VPN instance vpn2, and configure the L3 VXLAN ID as 1000 for the VPN instance.
[SwitchC-Vsi-interface2] ip binding vpn-instance vpn2
# Enable IP multicast routing for VPN instance vpn2.
[SwitchC] multicast routing vpn-instance vpn2
[SwitchC-mrib-vpn2] quit
# Create an MDT-based MVXLAN for VPN instance vpn1 and enter MVXLAN IPv4 address family view. Configure the default group and MVXLAN source interface, and enable DCI multicast.
[SwitchC-mvxlan-vpn1-ipv4] default-group 239.0.0.1
# Configure VLAN-interface 70 that is connected to remote EDs.
[SwitchC-Vlan-interface70] ospf 1 area 0.0.0.0
[SwitchC-Vlan-interface70] quit
# Configure VLAN-interface 90 that is connected to remote EDs.
[SwitchC] interface vlan-interface 90
[SwitchC-Vlan-interface90] ip address 79.1.1.1 255.255.255.0
[SwitchC-Vlan-interface90] ospf 1 area 0.0.0.0
[SwitchC-Vlan-interface90] dci enable
[SwitchC-Vlan-interface90] quit
[SwitchC-LoopBack0] pim sm
[SwitchC-LoopBack2] ip binding vpn-instance vpn2
[SwitchC-LoopBack2] ip address 77.77.77.77 32
[SwitchC-LoopBack2] pim sm
# Enter VPN instance PIM view, and configure Loopback 2 as a candidate-BSR and candidate-RP in VPN instance vpn2.
[SwitchC] pim vpn-instance vpn2
[SwitchC-pim-vpn2] c-bsr 77.77.77.77
[SwitchC-pim-vpn2] c-rp 77.77.77.77
[SwitchC-pim-vpn2] quit
[SwitchD] l2vpn enable
[SwitchD-mrib] quit
[SwitchD] igmp-snooping
[SwitchD-igmp-snooping] quit
[SwitchD] vxlan tunnel mac-learning disable
[SwitchD] vxlan tunnel arp-learning disable
# Configure a route policy to disable Switch D from forwarding the SMET and S-PMSI routes received from Switch C to Switch F and from forwarding the SMET and S-PMSI routes received from Switch F to Switch C.
[SwitchD] ip prefix-list 7 index 10 permit 99.99.99.99 32
[SwitchD] ip prefix-list 9 index 10 permit 77.77.77.77 32
[SwitchD] route-policy 7 deny node 0
[SwitchD-route-policy-7-0] if-match ip route-source prefix-list 7
[SwitchD-route-policy-7-0] if-match route-type bgp-evpn-smet bgp-evpn-s-pmsi
[SwitchD-route-policy-7-0] quit
[SwitchD] route-policy 7 permit node 1
[SwitchD-route-policy-7-1] if-match ip route-source prefix-list 1
[SwitchD-route-policy-7-1] quit
[SwitchD] route-policy 9 deny node 0
[SwitchD-route-policy-9-0] if-match ip route-source prefix-list 9
[SwitchD-route-policy-9-0] if-match route-type bgp-evpn-smet bgp-evpn-s-pmsi
[SwitchD-route-policy-9-0] quit
[SwitchD] route-policy 9 permit node 1
[SwitchD-route-policy-9-1] if-match ip route-source prefix-list 1
[SwitchD-route-policy-9-1] quit
[SwitchD] bgp 200
[SwitchD-bgp-default] peer 99.99.99.99 as-number 300
[SwitchD-bgp-default] peer 99.99.99.99 connect-interface loopback 0
[SwitchD-bgp-default] peer 99.99.99.99 ebgp-max-hop 64
[SwitchD-bgp-default-evpn] peer 4.4.4.4 re-originated replace-rt
[SwitchD-bgp-default-evpn] peer 4.4.4.4 re-originated mac-ip replace-rt
[SwitchD-bgp-default-evpn] peer 4.4.4.4 re-originated imet replace-rt
[SwitchD-bgp-default-evpn] peer 4.4.4.4 re-originated smet replace-rt
[SwitchD-bgp-default-evpn] peer 4.4.4.4 re-originated s-pmsi replace-rt
[SwitchD-bgp-default-evpn] peer 77.77.77.77 route-policy 7 export
[SwitchD-bgp-default-evpn] peer 77.77.77.77 re-originated replace-rt
[SwitchD-bgp-default-evpn] peer 77.77.77.77 re-originated mac-ip replace-rt
[SwitchD-bgp-default-evpn] peer 77.77.77.77 re-originated imet replace-rt
[SwitchD-bgp-default-evpn] peer 77.77.77.77 re-originated smet replace-rt
[SwitchD-bgp-default-evpn] peer 77.77.77.77 re-originated s-pmsi replace-rt
[SwitchD-bgp-default-evpn] peer 99.99.99.99 enable
[SwitchD-bgp-default-evpn] peer 99.99.99.99 route-policy 9 export
[SwitchD-bgp-default-evpn] peer 99.99.99.99 router-mac-local
[SwitchD-bgp-default-evpn] peer 99.99.99.99 re-originated replace-rt
[SwitchD-bgp-default-evpn] peer 99.99.99.99 re-originated mac-ip replace-rt
[SwitchD-bgp-default-evpn] peer 99.99.99.99 re-originated imet replace-rt
[SwitchD-bgp-default-evpn] peer 99.99.99.99 re-originated smet replace-rt
[SwitchD-bgp-default-evpn] peer 99.99.99.99 re-originated s-pmsi replace-rt
[SwitchD-vpn-instance-vpn1] vpn-target 20:20 100:100 300:300 import-extcommunity
[SwitchD-vpn-instance-vpn1] vpn-target 20:20 export-extcommunity [SwitchD-vpn-instance-vpn1] quit
[SwitchD] ip vpn-instance vpn2
[SwitchD-vpn-instance-vpn2] route-distinguisher 2:11
[SwitchD-vpn-instance-vpn2] vpn-target 20:20 100:100 300:300 import-extcommunity
[SwitchD-vpn-instance-vpn2] vpn-target 200:200 export-extcommunity [SwitchD-vpn-instance-vpn2] quit
# Associate VSI-interface 1 with VPN instance vpn1, and configure the L3 VXLAN ID as 1002 for the VPN instance.
[SwitchD] interface vsi-interface 1
[SwitchD-Vsi-interface1] l3-vni 1002
[SwitchD-Vsi-interface1] pim sm
[SwitchD-Vsi-interface1] quit
[SwitchD-Vsi-interface2] ip binding vpn-instance vpn2
[SwitchD] multicast routing vpn-instance vpn2
[SwitchD-mrib-vpn2] quit
[SwitchD-Vlan-interface70] ospf 1 area 0.0.0.0
[SwitchD-Vlan-interface70] quit
# Configure VLAN-interface 80 that is connected to remote EDs.
[SwitchD] interface vlan-interface 80
[SwitchD-Vlan-interface80] ip address 89.1.1.1 255.255.255.0
[SwitchD-Vlan-interface80] ospf 1 area 0.0.0.0
[SwitchD-Vlan-interface80] dci enable
[SwitchD-Vlan-interface80] quit
[SwitchD] interface loopback 0
[SwitchD-LoopBack0] pim sm
[SwitchD] interface loopback 1
[SwitchD-LoopBack1] pim sm
[SwitchD-LoopBack1] quit
[SwitchD] interface loopback 2
[SwitchD-LoopBack2] ip binding vpn-instance vpn2
[SwitchD-LoopBack2] ip address 88.88.88.88 32
[SwitchD-LoopBack2] pim sm
[SwitchD-LoopBack2] quit
[SwitchD] pim vpn-instance vpn2
[SwitchD-pim-vpn2] c-bsr 88.88.88.88
[SwitchD-pim-vpn2] c-rp 88.88.88.88
[SwitchD-pim-vpn2] quit
<SwitchE> system-view
[SwitchE] l2vpn enable
[SwitchE-mrib] quit
[SwitchE] igmp-snooping
[SwitchE-igmp-snooping] quit
[SwitchE] vxlan tunnel mac-learning disable
[SwitchE] vxlan tunnel arp-learning disable
# Create VLAN 21 and enter its view.
[SwitchE] vlan 21
[SwitchE-vlan12] quit
[SwitchE] vsi vpna
[SwitchE-vsi-vpna] evpn encapsulation vxlan
[SwitchE-vsi-vpna-evpn-vxlan] route-distinguisher auto
[SwitchE-vsi-vpna-evpn-vxlan] vpn-target auto
[SwitchE-vsi-vpna-evpn-vxlan] quit
[SwitchE-vsi-vpna] igmp-snooping enable
[SwitchE-vsi-vpna] igmp-snooping proxy enable
# Create VXLAN 21.
[SwitchE-vsi-vpna] quit
[SwitchE] bgp 200
[SwitchE-bgp-default] address-family l2vpn evpn
[SwitchE-bgp-default-evpn] quit
[SwitchE-bgp-default] quit
# Configure RD and route target settings for VPN instance vpn1.
[SwitchE-vpn-instance-vpn1] vpn-target 20:20 import-extcommunity
[SwitchE] interface vsi-interface 1
[SwitchE-Vsi-interface1] igmp enable
[SwitchE-Vsi-interface1] pim sm
[SwitchE-Vsi-interface1] distributed-gateway local
[SwitchE-Vsi-interface1] quit
# Associate VSI-interface 2 with VPN instance vpn1, and configure the L3 VXLAN ID as 1002 for the VPN instance.
[SwitchE-Vsi-interface2] l3-vni 1002
# Enable IP multicast routing for VPN instance vpn1.
[SwitchE] interface loopback 0
[SwitchE-LoopBack0] quit
# Configure Loopback 1.
[SwitchE] interface loopback 1
[SwitchE-LoopBack1] quit
# Enter VPN instance PIM view, and configure Loopback 1 as a candidate-BSR and candidate-RP in VPN instance vpn1.
[SwitchE] vsi vpna
[SwitchE-vsi-vpna] gateway vsi-interface 1
<SwitchF> system-view
[SwitchF] l2vpn enable
[SwitchF-mrib] quit
[SwitchF] igmp-snooping
[SwitchF-igmp-snooping] quit
[SwitchF] vxlan tunnel mac-learning disable
[SwitchF] vxlan tunnel arp-learning disable
# Configure a route policy to disable Switch F from forwarding the SMET and S-PMSI routes received from Switch C to Switch D and from forwarding the SMET and S-PMSI routes received from Switch D to Switch C.
[SwitchF] ip prefix-list 7 index 10 permit 88.88.88.88 32
[SwitchF] ip prefix-list 8 index 10 permit 77.77.77.77 32
[SwitchF] route-policy 7 deny node 0
[SwitchF-route-policy-7-0] if-match ip route-source prefix-list 7
[SwitchF-route-policy-7-0] if-match route-type bgp-evpn-smet bgp-evpn-s-pmsi
[SwitchF-route-policy-7-0] quit
[SwitchF] route-policy 7 permit node 1
[SwitchF-route-policy-7-1] if-match ip route-source prefix-list 1
[SwitchF-route-policy-7-1] quit
[SwitchF] route-policy 8 deny node 0
[SwitchF-route-policy-8-0] if-match ip route-source prefix-list 8
[SwitchF-route-policy-8-0] if-match route-type bgp-evpn-smet bgp-evpn-s-pmsi
[SwitchF-route-policy-8-0] quit
[SwitchF] route-policy 8 permit node 1
[SwitchF-route-policy-8-1] if-match ip route-source prefix-list 1
[SwitchF-route-policy-8-1] quit
[SwitchF] bgp 300
[SwitchF-bgp-default] peer 6.6.6.6 as-number 300
[SwitchF-bgp-default] peer 77.77.77.77 as-number 100
[SwitchF-bgp-default] peer 77.77.77.77 connect-interface loopback 0
[SwitchF-bgp-default] peer 77.77.77.77 ebgp-max-hop 64
[SwitchF-bgp-default] peer 88.88.88.88 as-number 200
[SwitchF-bgp-default] peer 88.88.88.88 connect-interface loopback 0
[SwitchF-bgp-default] peer 88.88.88.88 ebgp-max-hop 64
[SwitchF-bgp-default] address-family l2vpn evpn
[SwitchF-bgp-default-evpn] peer 6.6.6.6 re-originated replace-rt
[SwitchF-bgp-default-evpn] peer 6.6.6.6 re-originated mac-ip replace-rt
[SwitchF-bgp-default-evpn] peer 6.6.6.6 re-originated imet replace-rt
[SwitchF-bgp-default-evpn] peer 6.6.6.6 re-originated smet replace-rt
[SwitchF-bgp-default-evpn] peer 6.6.6.6 re-originated s-pmsi replace-rt
[SwitchF-bgp-default-evpn] peer 77.77.77.77 enable
[SwitchF-bgp-default-evpn] peer 77.77.77.77 route-policy 7 export
[SwitchF-bgp-default-evpn] peer 77.77.77.77 router-mac-local
[SwitchF-bgp-default-evpn] peer 77.77.77.77 re-originated replace-rt
[SwitchF-bgp-default-evpn] peer 77.77.77.77 re-originated mac-ip replace-rt
[SwitchF-bgp-default-evpn] peer 77.77.77.77 re-originated imet replace-rt
[SwitchF-bgp-default-evpn] peer 77.77.77.77 re-originated smet replace-rt
[SwitchF-bgp-default-evpn] peer 77.77.77.77 re-originated s-pmsi replace-rt
[SwitchF-bgp-default-evpn] peer 88.88.88.88 enable
[SwitchF-bgp-default-evpn] peer 88.88.88.88 route-policy 8 export
[SwitchF-bgp-default-evpn] peer 88.88.88.88 router-mac-local
[SwitchF-bgp-default-evpn] peer 88.88.88.88 re-originated replace-rt
[SwitchF-bgp-default-evpn] peer 88.88.88.88 re-originated mac-ip replace-rt
[SwitchF-bgp-default-evpn] peer 88.88.88.88 re-originated imet replace-rt
[SwitchF-bgp-default-evpn] peer 88.88.88.88 re-originated smet replace-rt
[SwitchF-bgp-default-evpn] peer 88.88.88.88 re-originated s-pmsi replace-rt
[SwitchF-bgp-default-evpn] quit
[SwitchF-bgp-default] quit
[SwitchF-vpn-instance-vpn1] route-distinguisher 3:1
[SwitchF-vpn-instance-vpn1] vpn-target 30:30 100:100 200:200 import-extcommunity
[SwitchF-vpn-instance-vpn1] vpn-target 30:30 export-extcommunity [SwitchF-vpn-instance-vpn1] quit
[SwitchF] ip vpn-instance vpn2
[SwitchF-vpn-instance-vpn2] route-distinguisher 3:11
[SwitchF-vpn-instance-vpn2] vpn-target 30:30 100:100 200:200 import-extcommunity
[SwitchF-vpn-instance-vpn2] vpn-target 300:300 export-extcommunity [SwitchF-vpn-instance-vpn2] quit
# Associate VSI-interface 1 with VPN instance vpn1, and configure the L3 VXLAN ID as 1003 for the VPN instance.
[SwitchF] interface vsi-interface 1
[SwitchF-Vsi-interface1] l3-vni 1003
[SwitchF-Vsi-interface1] pim sm
[SwitchF-Vsi-interface1] quit
[SwitchF-Vsi-interface2] ip binding vpn-instance vpn2
[SwitchF] multicast routing vpn-instance vpn2
[SwitchF-mrib-vpn2] quit
[SwitchF-mvxlan-vpn1-ipv4] source loopback 0
[SwitchF-mvxlan-vpn1-ipv4] default-group 239.0.0.1
[SwitchF-mvxlan-vpn1-ipv4] data-group 239.1.1.0 30
[SwitchF] interface vlan-interface 80
[SwitchF-Vlan-interface80] ip address 89.1.1.2 255.255.255.0
[SwitchF-Vlan-interface80] ospf 1 area 0.0.0.0
[SwitchF-Vlan-interface80] dci enable
[SwitchF-Vlan-interface80] quit
[SwitchF] interface vlan-interface 90
[SwitchF-Vlan-interface90] ip address 79.1.1.2 255.255.255.0
[SwitchF-Vlan-interface90] ospf 1 area 0.0.0.0
[SwitchF-Vlan-interface90] dci enable
[SwitchF-Vlan-interface90] quit
[SwitchF] interface loopback 0
[SwitchF-LoopBack0] ip address 99.99.99.99 32
[SwitchF-LoopBack0] quit
[SwitchF] interface loopback 1
[SwitchF-LoopBack1] ip address 99.99.99.99 32
[SwitchF-LoopBack1] quit
[SwitchF] interface loopback 2
[SwitchF-LoopBack2] ip binding vpn-instance vpn2
[SwitchF-LoopBack2] ip address 99.99.99.99 32
[SwitchF-LoopBack2] pim sm
[SwitchF-LoopBack2] quit
[SwitchF-pim-vpn1] c-bsr 99.99.99.99
[SwitchF-pim-vpn1] c-rp 99.99.99.99
[SwitchF] pim vpn-instance vpn2
[SwitchF-pim-vpn2] c-bsr 99.99.99.99
[SwitchF-pim-vpn2] c-rp 99.99.99.99
[SwitchF-pim-vpn2] quit
[SwitchG-mrib] quit
# Create VLAN 31 and enter its view.
[SwitchG] vlan 31
[SwitchG-vlan31] quit
[SwitchG] vsi vpna
# Create VXLAN 31.
[SwitchG-vsi-vpna] vxlan 31
[SwitchG-vsi-vpna-vxlan-31] quit
[SwitchG] bgp 300
[SwitchG-bgp-default] peer 99.99.99.99 as-number 300
[SwitchG-bgp-default] peer 99.99.99.99 connect-interface loopback 0
[SwitchG-bgp-default-evpn] peer 99.99.99.99 enable
[SwitchG-bgp-default-evpn] peer 99.99.99.99 next-hop-local
# On Ten-GigabitEthernet 1/0/1, create Ethernet service instance 100 to match VLAN 31.
[SwitchG-Ten-GigabitEthernet1/0/1] port trunk permit vlan 1 31
[SwitchG-Ten-GigabitEthernet1/0/1-srv100] encapsulation s-vid 31
[SwitchG-vpn-instance-vpn1] route-distinguisher 3:2
[SwitchG-vpn-instance-vpn1] vpn-target 30:30 import-extcommunity
[SwitchG-vpn-instance-vpn1] vpn-target 30:30 export-extcommunity
[SwitchG-Vsi-interface1] ip address 192.168.60.1 255.255.255.0
[SwitchG-Vsi-interface2] l3-vni 1003
# Create an MDT-based MVXLAN for VPN instance vpn1 and enter MVXLAN IPv4 address family view. Configure the MVXLAN source interface.
[SwitchG] vsi vpna
1.     Verify the multicast routing information on Switch A, Switch B, Switch E, and Switch G. This step uses Switch A as an example.
<SwitchA> display pim vpn-instance vpn routing-table
 (*, 225.0.1.1)
     RP: 1.1.1.1 (local)
     UpTime: 02:57:31
         1: MTunnel0
             Protocol: MD, UpTime: 02:57:31, Expires: -
(192.168.10.10, 225.0.1.1)
     RP: 1.1.1.1 (local)
     UpTime: 04:44:08
         1: MTunnel1
             Protocol: MD, UpTime: 02:00:27, Expires: -
 Total 0 (*, G) entries; 4 (S, G) entries
     RP: NULL
     UpTime: 01:08:58
         1: Vlan-interface10
             Protocol: pim-sm, UpTime: 01:08:06, Expires: 00:03:26
     RP: NULL
     UpTime: 01:07:53
         1: MVXLAN-UPE0
             Protocol: MD, UpTime: 01:07:53, Expires: -
     RP: NULL
     UpTime: 01:08:06
         1: MVXLAN-UPE0
             Protocol: MD, UpTime: 01:08:06, Expires: -
     RP: NULL
     UpTime: 01:07:53
         1: Vlan-interface10
             Protocol: pim-sm, UpTime: 01:07:53, Expires: 00:02:39
 (*, 225.0.1.1)
     UpTime: 01:29:29
         1: MTunnel0
             Protocol: MD, UpTime: 01:29:29, Expires: -
     UpTime: 01:29:42
         1: Extranet (VPN: vpn2)
             Protocol: MD, UpTime: 01:29:37, Expires: -
# Verify that Switch C has multicast routing entries for VPN instance vpn2.
<SwitchC> display  pim vpn-instance vpn2 routing-table
 (*, 225.0.1.1)
     UpTime: 01:39:28
         1: Vsi-interface3
             Protocol: MD, UpTime: 01:39:28, Expires: -
     UpTime: 01:39:24
     Upstream interface: Extranet (VPN: vpn1)
         Upstream neighbor: 127.0.0.1
         RPF prime neighbor: 127.0.0.1
         1: Vsi-interface3
             Protocol: MD, UpTime: 01:39:24, Expires: -
     RP: NULL
     UpTime: 01:29:21
         Upstream neighbor: 11.1.1.1
         RPF prime neighbor: 11.1.1.1
         1: Vlan-interface20
             Protocol: pim-sm, UpTime: 01:29:07, Expires: 00:03:25
         2: MVXLAN-UPE0
             Protocol: MD, UpTime: 01:29:21, Expires: -
     RP: NULL
     UpTime: 01:29:08
         1: Vlan-interface10
             Protocol: pim-sm, UpTime: 01:29:07, Expires: 00:03:20
         2: MVXLAN-UPE0
             Protocol: MD, UpTime: 01:29:08, Expires: -
     RP: NULL
     UpTime: 01:30:55
         1: Vlan-interface10
             Protocol: pim-sm, UpTime: 01:29:21, Expires: 00:03:07
         2: Vlan-interface20
     RP: NULL
     UpTime: 01:29:08
         1: Vlan-interface20
         2: MVXLAN-UPE0
Example: Configuring DCI Layer 3 multicast with multiple L3 VXLAN IDs mapped to different intermediate L3 VXLAN IDs
As shown in Figure 20, the multicast source of multicast group 225.0.1.1 is attached to Switch A, and the receivers of the multicast group are attached to Switch B, Switch E, and Switch G. All receivers reside in VPN instance vpn1. Configure DCI Layer 3 multicast as follows:
·     For DC 1, configure Switch A and Switch B as VTEPs, and configure Switch C as an ED.
·     For DC 2, configure Switch E as a VTEP, and configure Switch D as an ED.
·     On Switch C and Switch D, create intermediate VPN instance vpn2 and assign L3 VXLAN ID 1122 to it.
·     On Switch C and Switch F, create intermediate VPN instance vpn4 and assign L3 VXLAN ID 1133 to it.
Figure 20 Network diagram
2.     Configure IP addresses, PIM SM, and unicast routing settings:
# Assign IP addresses to interfaces, as shown in Figure 20. (Details not shown.)
# Configure OSPF in each data center for the switches in a data center to reach one another. (Details not shown.)
# Enable PIM SM on the VLAN interfaces that interconnect the devices in a data center. (Details not shown.)
3.     Configure Switch A:
[SwitchA] l2vpn enable
[SwitchA] multicast routing
[SwitchA-mrib] quit
[SwitchA] multicast routing vpn-instance vpn1
[SwitchA-mrib-vpn1] quit
[SwitchA] igmp-snooping
[SwitchA-igmp-snooping] quit
[SwitchA] vxlan tunnel mac-learning disable
[SwitchA] vxlan tunnel arp-learning disable
[SwitchA] vlan 11
[SwitchA-vlan11] quit
[SwitchA] vsi vpna
[SwitchA-vsi-vpna] evpn encapsulation vxlan
[SwitchA-vsi-vpna-evpn-vxlan] route-distinguisher auto
[SwitchA-vsi-vpna-evpn-vxlan] quit
[SwitchA-vsi-vpna] igmp-snooping enable
[SwitchA-vsi-vpna] igmp-snooping proxy enable
# Create VXLAN 11.
[SwitchA-vsi-vpna] vxlan 11
[SwitchA-vsi-vpna-vxlan-11] quit
[SwitchA-vsi-vpna] quit
[SwitchA] bgp 100
[SwitchA-bgp-default] peer 77.77.77.77 as-number 100
[SwitchA-bgp-default] peer 77.77.77.77 connect-interface loopback 0
[SwitchA-bgp-default] address-family l2vpn evpn
[SwitchA-bgp-default-evpn] peer 77.77.77.77 enable
[SwitchA-bgp-default-evpn] peer 77.77.77.77 next-hop-local
[SwitchA-bgp-default-evpn] quit
[SwitchA-bgp-default] quit
# On Ten-GigabitEthernet 1/0/1, create Ethernet service instance 100 to match VLAN 11.
[SwitchA] interface ten-gigabitethernet 1/0/1
[SwitchA-Ten-GigabitEthernet1/0/1] port link-type trunk
[SwitchA-Ten-GigabitEthernet1/0/1] port trunk permit vlan 1 11
[SwitchA-Ten-GigabitEthernet1/0/1] service-instance 100
[SwitchA-Ten-GigabitEthernet1/0/1-srv100] encapsulation s-vid 11
[SwitchA-Ten-GigabitEthernet1/0/1-srv100] xconnect vsi vpna
[SwitchA-Ten-GigabitEthernet1/0/1-srv100] quit
[SwitchA] ip vpn-instance vpn1
[SwitchA-vpn-instance-vpn1] route-distinguisher 1:1
[SwitchA-vpn-instance-vpn1] vpn-target 10:10 export-extcommunity
[SwitchA-vpn-instance-vpn1] quit
[SwitchA] interface vsi-interface 1
[SwitchA-Vsi-interface1] ip binding vpn-instance vpn1
[SwitchA-Vsi-interface1] ip address 192.168.10.1 255.255.255.0
[SwitchA-Vsi-interface1] pim sm
[SwitchA-Vsi-interface1] distributed-gateway local
[SwitchA-Vsi-interface1] quit
[SwitchA] interface vsi-interface 2
# Create an MDT-based MVXLAN for VPN instance vpn1 and enter MVXLAN IPv4 address family view. Configure the default group, MVXLAN source interface, and data group range settings. Enable advertising active multicast sources through S-PMSI routes. Set the data-delay period to 20 seconds, which is longer than the default frequency of sending the same route update to a peer or peer group.
[SwitchA] multicast-vpn vxlan vpn-instance vpn1 mode mdt
[SwitchA-mvxlan-vpn1] address-family ipv4
[SwitchA-mvxlan-vpn1-ipv4] default-group 239.0.0.1
[SwitchA-mvxlan-vpn1-ipv4] source loopback 0
[SwitchA-mvxlan-vpn1-ipv4] data-group 239.1.1.0 30
[SwitchA-mvxlan-vpn1-ipv4] s-pmsi advertise source-active
[SwitchA-mvxlan-vpn1-ipv4] data-delay 20
[SwitchA-mvxlan-vpn1-ipv4] quit
[SwitchA-mvxlan-vpn1] quit
[SwitchA-LoopBack0] ospf 1 area 0.0.0.0
[SwitchA] interface loopback 1
[SwitchA-LoopBack1] ip binding vpn-instance vpn1
[SwitchA-LoopBack1] ip address 1.1.1.1 32
[SwitchA-LoopBack1] pim sm
[SwitchA-LoopBack1] quit
[SwitchA] pim vpn-instance vpn1
[SwitchA-pim-vpn1] c-bsr 1.1.1.1
[SwitchA-pim-vpn1] c-rp 1.1.1.1
[SwitchA-pim-vpn1] quit
[SwitchA] vsi vpna
[SwitchA-vsi-vpna] gateway vsi-interface 1
4.     Configure Switch B:
[SwitchB] l2vpn enable
[SwitchB] multicast routing
[SwitchB-mrib] quit
[SwitchB] igmp-snooping
[SwitchB-igmp-snooping] quit
[SwitchB] vxlan tunnel mac-learning disable
[SwitchB] vxlan tunnel arp-learning disable
[SwitchB] vlan 12
[SwitchB-vlan12] quit
[SwitchB] vsi vpna
[SwitchB-vsi-vpna] evpn encapsulation vxlan
[SwitchB-vsi-vpna-evpn-vxlan] route-distinguisher auto
[SwitchB-vsi-vpna-evpn-vxlan] quit
[SwitchB-vsi-vpna] igmp-snooping enable
[SwitchB-vsi-vpna] igmp-snooping proxy enable
# Create VXLAN 12.
[SwitchB-vsi-vpna] vxlan 12
[SwitchB-vsi-vpna-vxlan-12] quit
[SwitchB-vsi-vpna] quit
[SwitchB] bgp 100
[SwitchB-bgp-default] peer 77.77.77.77 as-number 100
[SwitchB-bgp-default] peer 77.77.77.77 connect-interface loopback 0
[SwitchB-bgp-default] address-family l2vpn evpn
[SwitchB-bgp-default-evpn] peer 77.77.77.77 enable
[SwitchB-bgp-default-evpn] peer 77.77.77.77 next-hop-local
[SwitchB-bgp-default-evpn] quit
[SwitchB-bgp-default] quit
# On Ten-GigabitEthernet 1/0/1, create Ethernet service instance 100 to match VLAN 12.
[SwitchB] interface ten-gigabitethernet 1/0/1
[SwitchB-Ten-GigabitEthernet1/0/1] port link-type trunk
[SwitchB-Ten-GigabitEthernet1/0/1] port trunk permit vlan 1 12
[SwitchB-Ten-GigabitEthernet1/0/1] service-instance 100
[SwitchB-Ten-GigabitEthernet1/0/1-srv100] encapsulation s-vid 12
[SwitchB-Ten-GigabitEthernet1/0/1-srv100] xconnect vsi vpna
[SwitchB-Ten-GigabitEthernet1/0/1-srv100] quit
[SwitchB] ip vpn-instance vpn1
[SwitchB-vpn-instance-vpn1] route-distinguisher 1:2
[SwitchB-vpn-instance-vpn1] vpn-target 10:10 export-extcommunity
[SwitchB-vpn-instance-vpn1] quit
[SwitchB] interface vsi-interface 1
[SwitchB-Vsi-interface1] ip binding vpn-instance vpn1
[SwitchB-Vsi-interface1] ip address 192.168.20.1 255.255.255.0
[SwitchB-Vsi-interface1] igmp enable
[SwitchB-Vsi-interface1] distributed-gateway local
[SwitchB-Vsi-interface1] quit
[SwitchB] interface vsi-interface 2
[SwitchB-Vsi-interface2] ip binding vpn-instance vpn1
[SwitchB-Vsi-interface2] pim sm
[SwitchB-Vsi-interface2] quit
[SwitchB] multicast routing vpn-instance vpn1
[SwitchB-mrib-vpn1] quit
[SwitchB] multicast-vpn vxlan vpn-instance vpn1 mode mdt
[SwitchB-mvxlan-vpn1] address-family ipv4
[SwitchB-mvxlan-vpn1-ipv4] source loopback 0
[SwitchB-mvxlan-vpn1-ipv4] quit
[SwitchB-mvxlan-vpn1] quit
[SwitchB-LoopBack0] ospf 1 area 0.0.0.0
[SwitchB] interface loopback 1
[SwitchB-LoopBack1] ip binding vpn-instance vpn1
[SwitchB-LoopBack1] ip address 2.2.2.2 32
[SwitchB-LoopBack1] pim sm
[SwitchB-LoopBack1] quit
[SwitchB] pim vpn-instance vpn1
[SwitchB-pim-vpn1] c-bsr 2.2.2.2
[SwitchB-pim-vpn1] c-rp 2.2.2.2
[SwitchB-pim-vpn1] quit
[SwitchB] vsi vpna
[SwitchB-vsi-vpna] gateway vsi-interface 1
5.     Configure Switch C:
[SwitchC] l2vpn enable
[SwitchC-mrib] quit
# Configure BGP to advertise BGP EVPN routes, and configure Switch C as an RR.
[SwitchC] bgp 100
[SwitchC-bgp-default] group group1 internal
[SwitchC-bgp-default] peer group1 connect-interface loopback 0
[SwitchC-bgp-default] peer 1.1.1.1 group group1
[SwitchC-bgp-default] peer 2.2.2.2 group group1
[SwitchC-bgp-default] peer 88.88.88.88 as-number 200
[SwitchC-bgp-default] peer 88.88.88.88 connect-interface loopback 0
[SwitchC-bgp-default] peer 88.88.88.88 ebgp-max-hop 64
[SwitchC-bgp-default] address-family l2vpn evpn
[SwitchC-bgp-default-evpn] peer group1 enable
[SwitchC-bgp-default-evpn] peer group1 next-hop-local
[SwitchC-bgp-default-evpn] peer group1 reflect-client
[SwitchC-bgp-default-evpn] peer 88.88.88.88 enable
[SwitchC-bgp-default-evpn] peer 88.88.88.88 router-mac-local
[SwitchC-bgp-default-evpn] quit
[SwitchC-bgp-default] quit
[SwitchC] ip vpn-instance vpn1
[SwitchC-vpn-instance-vpn1] route-distinguisher 1:1
[SwitchC-vpn-instance-vpn1] vpn-target 10:10 200:200 3000:3000 import-extcommunity
[SwitchC-vpn-instance-vpn2] route-distinguisher 1:11
[SwitchC-vpn-instance-vpn2] vpn-target 10:10 200:200 import-extcommunity
# Configure RD and route target settings for VPN instance vpn4.
[SwitchC] ip vpn-instance vpn4
[SwitchC-vpn-instance-vpn4] route-distinguisher 1:111
[SwitchC-vpn-instance-vpn4] vpn-target 10:10 3000:3000 import-extcommunity
[SwitchC-vpn-instance-vpn4] vpn-target 1000:1000 export-extcommunity [SwitchC-vpn-instance-vpn4] quit
# Associate VSI-interface 2 with VPN instance vpn2, and configure the L3 VXLAN ID as 1122 for the VPN instance.
[SwitchC] interface vsi-interface 2
[SwitchC-Vsi-interface2] l3-vni 1122
[SwitchC-Vsi-interface2] pim sm
[SwitchC-Vsi-interface2] quit
# Associate VSI-interface 4 with VPN instance vpn4, and configure the L3 VXLAN ID as 1133 for the VPN instance.
[SwitchC] interface vsi-interface 4
[SwitchC-Vsi-interface4] ip binding vpn-instance vpn4
[SwitchC-Vsi-interface4] l3-vni 1133
[SwitchC-Vsi-interface4] pim sm
[SwitchC-Vsi-interface4] quit
[SwitchC] multicast routing vpn-instance vpn1
[SwitchC-mrib-vpn1] quit
# Enable IP multicast routing for VPN instance vpn4.
[SwitchC] multicast routing vpn-instance vpn4
[SwitchC-mrib-vpn4] quit
[SwitchC] multicast-vpn vxlan vpn-instance vpn1 mode mdt
[SwitchC-mvxlan-vpn1] address-family ipv4
[SwitchC-mvxlan-vpn1-ipv4] source loopback 0
[SwitchC-mvxlan-vpn1-ipv4] dci enable
[SwitchC-mvxlan-vpn1-ipv4] quit
[SwitchC-mvxlan-vpn1] quit
[SwitchC] interface loopback 1
[SwitchC-LoopBack0] ip address 77.77.77.77 32
[SwitchC-LoopBack0] ospf 1 area 0.0.0.0
[SwitchC-LoopBack0] quit
[SwitchC-LoopBack1] ip binding vpn-instance vpn1
[SwitchC-LoopBack1] ip address 77.77.77.77 32
[SwitchC-LoopBack1] pim sm
[SwitchC-LoopBack1] quit
# Configure Loopback 2.
[SwitchC] interface loopback 2
[SwitchC-LoopBack2] quit
# Configure Loopback 4.
[SwitchC] interface loopback 4
[SwitchC-LoopBack4] ip binding vpn-instance vpn4
[SwitchC-LoopBack4] ip address 77.77.77.77 32
[SwitchC-LoopBack4] pim sm
[SwitchC-LoopBack4] quit
[SwitchC] interface vlan-interface 70
[SwitchC-Vlan-interface70] ip address 78.1.1.1 255.255.255.0
[SwitchC-Vlan-interface70] dci enable
[SwitchC] pim vpn-instance vpn1
[SwitchC-pim-vpn1] c-bsr 77.77.77.77
[SwitchC-pim-vpn1] c-rp 77.77.77.77
[SwitchC-pim-vpn1] quit
# Enter VPN instance PIM view, and configure Loopback 4 as a candidate-BSR and candidate-RP in VPN instance vpn4.
[SwitchC] pim vpn-instance vpn4
[SwitchC-pim-vpn4] c-bsr 77.77.77.77
[SwitchC-pim-vpn4] c-rp 77.77.77.77
[SwitchC-pim-vpn4] quit
6.     Configure Switch D:
<SwitchD> system-view
[SwitchD-mrib] quit
[SwitchD] bgp 200
[SwitchD-bgp-default] peer 4.4.4.4 as-number 200
[SwitchD-bgp-default] peer 4.4.4.4 connect-interface loopback 0
[SwitchD-bgp-default] peer 77.77.77.77 as-number 100
[SwitchD-bgp-default] peer 77.77.77.77 connect-interface loopback 0
[SwitchD-bgp-default] peer 77.77.77.77 ebgp-max-hop 64
[SwitchD-bgp-default] address-family l2vpn evpn
[SwitchD-bgp-default-evpn] peer 4.4.4.4 enable
[SwitchD-bgp-default-evpn] peer 4.4.4.4 next-hop-local
[SwitchD-bgp-default-evpn] peer 77.77.77.77 enable
[SwitchD-bgp-default-evpn] peer 77.77.77.77 router-mac-local
[SwitchD-bgp-default-evpn] quit
[SwitchD-bgp-default] quit
[SwitchD] ip vpn-instance vpn1
[SwitchD-vpn-instance-vpn1] route-distinguisher 2:1
[SwitchD-vpn-instance-vpn2] vpn-target 20:20 100:100 import-extcommunity
# Configure RD and route target settings for VPN instance vpn3.
[SwitchD] ip vpn-instance vpn3
[SwitchD-vpn-instance-vpn3] route-distinguisher 2:111
[SwitchD-vpn-instance-vpn3] vpn-target 20:20 300:300 import-extcommunity
[SwitchD-vpn-instance-vpn3] vpn-target 2000:2000 export-extcommunity [SwitchD-vpn-instance-vpn3] quit
[SwitchD] interface vsi-interface 2
[SwitchD-Vsi-interface2] l3-vni 1122
[SwitchD-Vsi-interface2] pim sm
[SwitchD-Vsi-interface2] quit
# Associate VSI-interface 3 with VPN instance vpn3, and configure the L3 VXLAN ID as 2233 for the VPN instance.
[SwitchD] interface vsi-interface 3
[SwitchD-Vsi-interface3] ip binding vpn-instance vpn3
[SwitchD-Vsi-interface3] l3-vni 2233
[SwitchD-Vsi-interface3] pim sm
[SwitchD-Vsi-interface3] quit
[SwitchD] multicast routing vpn-instance vpn1
[SwitchD-mrib-vpn1] quit
# Enable IP multicast routing for VPN instance vpn3.
[SwitchD] multicast routing vpn-instance vpn3
[SwitchD-mrib-vpn3] quit
# Create an MDT-based MVXLAN for VPN instance vpn1 and enter MVXLAN IPv4 address family view. Configure the default group, MVXLAN source interface, and data group range settings, and enable DCI multicast. Configure the data group range to be the same as that on Switch A to ensure correct forwarding.
[SwitchD] multicast-vpn vxlan vpn-instance vpn1 mode mdt
[SwitchD-mvxlan-vpn1] address-family ipv4
[SwitchD-mvxlan-vpn1-ipv4] source loopback 0
[SwitchD-mvxlan-vpn1-ipv4] default-group 239.0.0.1
[SwitchD-mvxlan-vpn1-ipv4] data-group 239.1.1.0 30
[SwitchD-mvxlan-vpn1-ipv4] dci enable
[SwitchD-mvxlan-vpn1-ipv4] quit
[SwitchD-mvxlan-vpn1] quit
[SwitchD] interface vlan-interface 70
[SwitchD-Vlan-interface70] ip address 78.1.1.2 255.255.255.0
[SwitchD-Vlan-interface70] dci enable
[SwitchD-LoopBack0] ip address 88.88.88.88 32
[SwitchD-LoopBack0] ospf 1 area 0.0.0.0
[SwitchD-LoopBack0] quit
[SwitchD-LoopBack1] ip binding vpn-instance vpn1
[SwitchD-LoopBack1] ip address 88.88.88.88 32
# Configure Loopback 3.
[SwitchD] interface loopback 3
[SwitchD-LoopBack3] ip binding vpn-instance vpn3
[SwitchD-LoopBack3] ip address 88.88.88.88 32
[SwitchD-LoopBack3] pim sm
[SwitchD-LoopBack3] quit
[SwitchD] pim vpn-instance vpn1
[SwitchD-pim-vpn1] c-bsr 88.88.88.88
[SwitchD-pim-vpn1] c-rp 88.88.88.88
[SwitchD-pim-vpn1] quit
# Enter VPN instance PIM view, and configure Loopback 3 as a candidate-BSR and candidate-RP in VPN instance vpn3.
[SwitchD] pim vpn-instance vpn3
[SwitchD-pim-vpn3] c-bsr 88.88.88.88
[SwitchD-pim-vpn3] c-rp 88.88.88.88
[SwitchD-pim-vpn3] quit
7.     Configure Switch E:
[SwitchE] multicast routing
[SwitchE-mrib] quit
[SwitchE] vlan 21
[SwitchE] vsi vpna
# Create VXLAN 21.
[SwitchE-vsi-vpna] vxlan 21
[SwitchE-vsi-vpna-vxlan-21] quit
[SwitchE] bgp 200
[SwitchE-bgp-default] peer 88.88.88.88 as-number 200
[SwitchE-bgp-default] peer 88.88.88.88 connect-interface loopback 0
[SwitchE-bgp-default-evpn] peer 88.88.88.88 enable
[SwitchE-bgp-default-evpn] peer 88.88.88.88 next-hop-local
# On Ten-GigabitEthernet 1/0/1, create Ethernet service instance 100 to match VLAN 21.
[SwitchE] interface ten-gigabitethernet 1/0/1
[SwitchE-Ten-GigabitEthernet1/0/1] port link-type trunk
[SwitchE-Ten-GigabitEthernet1/0/1] port trunk permit vlan 1 21
[SwitchE-Ten-GigabitEthernet1/0/1] service-instance 100
[SwitchE-Ten-GigabitEthernet1/0/1-srv100] encapsulation s-vid 21
[SwitchE-Ten-GigabitEthernet1/0/1-srv100] xconnect vsi vpna
[SwitchE-Ten-GigabitEthernet1/0/1-srv100] quit
[SwitchE] ip vpn-instance vpn1
[SwitchE-vpn-instance-vpn1] route-distinguisher 2:3
[SwitchE-vpn-instance-vpn1] vpn-target 20:20 export-extcommunity
[SwitchE-vpn-instance-vpn1] quit
[SwitchE-Vsi-interface1] ip binding vpn-instance vpn1
[SwitchE-Vsi-interface1] ip address 192.168.40.1 255.255.255.0
[SwitchE] interface vsi-interface 2
[SwitchE-Vsi-interface2] ip binding vpn-instance vpn1
[SwitchE-Vsi-interface2] pim sm
[SwitchE-Vsi-interface2] quit
[SwitchE] multicast routing vpn-instance vpn1
[SwitchE-mrib-vpn1] quit
[SwitchE] multicast-vpn vxlan vpn-instance vpn1 mode mdt
[SwitchE-mvxlan-vpn1] address-family ipv4
[SwitchE-mvxlan-vpn1-ipv4] source loopback 0
[SwitchE-mvxlan-vpn1-ipv4] quit
[SwitchE-mvxlan-vpn1] quit
[SwitchE-LoopBack0] ip address 4.4.4.4 32
[SwitchE-LoopBack0] ospf 1 area 0.0.0.0
[SwitchE-LoopBack0] pim sm
[SwitchE-LoopBack1] ip binding vpn-instance vpn1
[SwitchE-LoopBack1] ip address 4.4.4.4 32
[SwitchE-LoopBack1] pim sm
[SwitchE] pim vpn-instance vpn1
[SwitchE-pim-vpn1] c-bsr 4.4.4.4
[SwitchE-pim-vpn1] c-rp 4.4.4.4
[SwitchE-pim-vpn1] quit
# Specify VSI-interface 1 as the gateway interface for VSI vpna.
[SwitchE] vsi vpna
[SwitchF-mrib] quit
[SwitchF] bgp 300
[SwitchF-vpn-instance-vpn1] vpn-target 30:30 1000:1000 2000:2000 import-extcommunity
[SwitchF] ip vpn-instance vpn3
[SwitchF-vpn-instance-vpn3] route-distinguisher 3:11
[SwitchF-vpn-instance-vpn3] vpn-target 30:30 2000:2000 import-extcommunity
[SwitchF-vpn-instance-vpn3] vpn-target 300:300 export-extcommunity [SwitchF-vpn-instance-vpn3] quit
[SwitchF] ip vpn-instance vpn4
[SwitchF-vpn-instance-vpn4] route-distinguisher 3:111
[SwitchF-vpn-instance-vpn4] vpn-target 30:30 1000:1000 import-extcommunity
[SwitchF-vpn-instance-vpn4] vpn-target 3000:3000 export-extcommunity [SwitchF-vpn-instance-vpn4] quit
[SwitchF] interface vsi-interface 3
[SwitchF-Vsi-interface3] ip binding vpn-instance vpn3
[SwitchF-Vsi-interface3] l3-vni 2233
[SwitchF-Vsi-interface3] pim sm
[SwitchF-Vsi-interface3] quit
[SwitchF] interface vsi-interface 4
[SwitchF-Vsi-interface4] ip binding vpn-instance vpn4
[SwitchF-Vsi-interface4] l3-vni 1133
[SwitchF-Vsi-interface4] pim sm
[SwitchF-Vsi-interface4] quit
[SwitchF] multicast routing vpn-instance vpn3
[SwitchF-mrib-vpn3] quit
[SwitchF] multicast routing vpn-instance vpn4
[SwitchF-mrib-vpn4] quit
[SwitchF] interface loopback 3
[SwitchF-LoopBack3] ip binding vpn-instance vpn3
[SwitchF-LoopBack3] ip address 99.99.99.99 32
[SwitchF-LoopBack3] pim sm
[SwitchF-LoopBack3] quit
[SwitchF] interface loopback 4
[SwitchF-LoopBack4] ip binding vpn-instance vpn4
[SwitchF-LoopBack4] ip address 99.99.99.99 32
[SwitchF-LoopBack4] pim sm
[SwitchF-LoopBack4] quit
[SwitchF] pim vpn-instance vpn3
[SwitchF-pim-vpn3] c-bsr 99.99.99.99
[SwitchF-pim-vpn3] c-rp 99.99.99.99
[SwitchF-pim-vpn3] quit
[SwitchF] pim vpn-instance vpn4
[SwitchF-pim-vpn4] c-bsr 99.99.99.99
[SwitchF-pim-vpn4] c-rp 99.99.99.99
[SwitchF-pim-vpn4] quit
[SwitchG-mrib] quit
[SwitchG] vlan 31
[SwitchG] vsi vpna
# Create VXLAN 31.
[SwitchG] bgp 300
[SwitchG] vsi vpna
# Verify that Switch A has multicast routing entries for VPN instance vpn1.
 Total 1 (*, G) entries; 1 (S, G) entries
 (*, 225.0.1.1)
     RP: 1.1.1.1 (local)
     Protocol: pim-sm, Flag: WC RC
     UpTime: 02:57:31
     Upstream interface: Register-Tunnel0
         1: MTunnel0
     RP: 1.1.1.1 (local)
     Protocol: pim-sm, Flag: SPT 2MSDP LOC ACT SQ RC 2MVPN
     UpTime: 04:44:08
     Upstream interface: Vsi-interface1
         1: MTunnel1
# Verify that Switch A has multicast routing entries for the public network.
<SwitchA> display pim routing-table
(1.1.1.1, 239.0.0.1)
     RP: NULL
     Protocol: pim-sm, Flag: SPT LOC VXLAN_L3
     UpTime: 01:08:58
     Upstream interface: MTunnel0 (VPN: vpn1)
         1: Vlan-interface10
(2.2.2.2, 239.0.0.1)
     RP: NULL
     UpTime: 01:07:53
     Upstream interface: Vlan-interface10
         Upstream neighbor: 11.1.1.2
         RPF prime neighbor: 11.1.1.2
         1: MVXLAN-UPE0
(77.77.77.77, 239.0.0.1)
     RP: NULL
     UpTime: 01:08:06
         1: MVXLAN-UPE0
(1.1.1.1, 239.1.1.0)
     RP: NULL
     UpTime: 01:07:53
     Upstream interface: MTunnel1 (VPN: vpn1)
         1: Vlan-interface10
2.     Verify the multicast routing information on the EDs. This step uses Switch C as an example.
# Verify that Switch C has multicast routing entries for VPN instance vpn1.
<SwitchC> display pim vpn-instance vpn1 routing-table
 (*, 225.0.1.1)
     RP: 77.77.77.77 (local)
     UpTime: 01:09:14
         1: MTunnel0
             Protocol: MD, UpTime: 01:09:14, Expires: -
     Protocol: pim-sm, Flag: SPT ACT RQ SRC-ACT 2MVPN FROMVXLAN
     UpTime: 00:58:36
     Upstream interface: MVXLAN-UPE0 (0.0.0.0)
     Total number of downstream interfaces: 2
             Protocol: MD, UpTime: 00:58:36, Expires: -
         2: Extranet (VPN: vpn4)
 (*, 225.0.1.1)
     UpTime: 01:39:28
         1: Vsi-interface3
     UpTime: 01:39:24
         1: Vsi-interface3
# Verify that Switch C has multicast routing entries for VPN instance vpn4.
<SwitchC> display pim vpn-instance vpn4 routing-table
 (*, 225.0.1.1)
     UpTime: 01:04:54
         1: Vsi-interface4
             Protocol: MD, UpTime: 01:04:54, Expires: -
     UpTime: 01:00:09
         1: Vsi-interface4
             Protocol: MD, UpTime: 01:00:09, Expires: -
# Verify that Switch C has multicast routing entries for the public network.
<SwitchC> display pim routing-table
     RP: NULL
     UpTime: 01:29:21
         1: Vlan-interface20
         2: MVXLAN-UPE0
     RP: NULL
     UpTime: 01:29:08
     Upstream interface: Vlan-interface20
         Upstream neighbor: 12.1.1.1
         RPF prime neighbor: 12.1.1.1
         1: Vlan-interface10
         2: MVXLAN-UPE0
     RP: NULL
     UpTime: 01:30:55
         1: Vlan-interface10
         2: Vlan-interface20
     RP: NULL
     Protocol: pim-sm, Flag: SPT ACT 2MVPN
     UpTime: 01:29:08
         1: Vlan-interface20
         2: MVXLAN-UPE0
Example: Configuring Layer 3 multicast without L3 VXLAN ID mapping in a DCI multihoming scenario
As shown in Figure 21, the multicast source of multicast group 225.0.0.1 is attached to Switch A, and the receivers of the multicast group are attached to Switch B, Switch J, and Switch L. Configure Layer 3 multicast in a DCI multihoming scenario as follows:
·     For DC 1, configure Switch A and Switch B as VTEPs, configure Switch C as an RR, and configure Switch D, Switch E, and Switch F as EDs.
·     For DC 2, configure Switch J as a VTEP, and configure Switch H and Switch I as EDs.
·     For DC 3, configure Switch L as a VTEP, and configure Switch K as an ED.
·     Assign L3 VXLAN ID 1000 to DC 1, DC 2, and DC 3.
·     Configure Switch G to connect all the EDs.
·     On Switch A through Switch L, configure PIM SM on the public-network interfaces used for intra-data center connection. On Switch A, Switch B, Switch J, and Switch L, enable IGMP snooping for multicat entry creation.
Figure 21 Network diagram
Device
IP address
Device
IP address
Switch A
Loop0
1.1.1.1/32
Switch B
Loop0
2.2.2.2/32
Loop1
1.1.1.1/32
Loop1
2.2.2.2/32
Vlan-int10
121.121.121.1/24
XGE1/0/1
XGE1/0/2
Vlan-int20
122.122.122.2/24
VSI-int1
10.0.0.1/24
VSI-int1
10.0.0.1/24
VSI-int2
VSI-int2
Switch C
Loop0
12.12.12.12/32
Switch D
Loop0
3.3.3.3/32
Vlan-int10
121.121.121.12/24
Loop1
3.3.3.3/32
Vlan-int20
122.122.122.12/24
Loop2
3.4.5.0/32
Vlan-int30
123.123.123.12/24
Vlan-int3
113.113.113.3/24
Vlan-int40
124.124.124.12/24
Vlan-int30
123.123.123.3/24
Vlan-int50
125.125.125.12/24
VSI-int2
Switch E
Loop0
4.4.4.4/32
Switch F
Loop0
5.5.5.5/32
Loop1
4.4.4.4/32
Loop1
5.5.5.5/32
Loop2
3.4.5.0/32
Loop2
3.4.5.0/32
Vlan-int4
114.114.114.4/24
Vlan-int50
125.125.125.5/24
Vlan-int40
124.124.124.4/24
Vlan-int5
115.115.115.5/24
VSI-int2
VSI-int2
Switch G
Loop0
11.11.11.11/32
Switch J
Loop0
8.8.8.8/32
Vlan-int3
113.113.113.11/24
Loop1
8.8.8.8/32
Vlan-int4
114.114.114.11/24
XGE1/0/1
Vlan-int5
115.115.115.11/24
Vlan-int200
78.78.78.87/24
Vlan-int9
119.119.119.11/24
Vlan-int300
68.68.68.86/24
Vlan-int7
117.117.117.11/24
VSI-int1
10.0.0.1/24
Vlan-int6
116.116.116.11/24
VSI-int2
Switch H
Loop0
6.6.6.6/32
Switch I
Loop0
7.7.7.7/32
Loop1
6.6.6.6/32
Loop1
7.7.7.7/32
Loop2
2.2.1.1/32
Loop2
2.2.1.1/32
Vlan-int300
68.68.68.68/24
Vlan-int7
117.117.117.7/24
Vlan-int6
116.116.116.6/24
Vlan-int200
78.78.78.78/24
VSI-int2
VSI-int2
Switch K
Loop0
9.9.9.9/32
Switch L
Loop0
10.10.10.10/32
Loop1
9.9.9.9/32
Loop1
10.10.10.10/32
Vlan-int100
109.109.109.9/24
Vlan-int100
109.109.109.10/24
Vlan-int9
119.119.119.9/24
XGE1/0/2
VSI-int2
VSI-int1
10.0.0.1/24
VSI-int2
1.     Configure IP addresses, PIM SM, and unicast routing settings:
# On the multicast source and receivers, specify 10.0.0.1 as the gateway address. (Details not shown.)
# Assign IP addresses to interfaces, as shown in Figure 21. (Details not shown.)
# Verify that PIM SM is disabled on the VLAN interfaces that interconnect the EDs. (Details not shown.)
2.     Configure Switch A:
# Enable L2VPN and IP multicast routing, start an OSPF process, and create VLAN 11.
[SwitchA-mrib] quit
[SwitchA] pim
[SwitchA-pim] quit
[SwitchA] ospf 1
[SwitchA-ospf-1] area 0.0.0.0
[SwitchA] vlan 11
# Configure Loopback 0.
# Enable default IPv4 VXLAN decapsulation.
[SwitchA] vxlan default-decapsulation source interface loopback 0
# Create an EVPN instance on VSI 1.
[SwitchA] vsi 1
[SwitchA-vsi-1] evpn encapsulation vxlan
[SwitchA-vsi-1-evpn-vxlan] route-distinguisher auto
[SwitchA-vsi-1-evpn-vxlan] vpn-target auto export-extcommunity
[SwitchA-vsi-1-evpn-vxlan] vpn-target auto import-extcommunity [SwitchA-vsi-1-evpn-vxlan] quit
# Enable IGMP snooping on VSI 1.
[SwitchA-vsi-1] igmp-snooping enable
# Create VXLAN 10.
[SwitchA-vsi-1] vxlan 10
[SwitchA-vsi-1-vxlan-10] quit
# Configure BGP to advertise BGP EVPN routes and enable the BGP additional path receiving capability.
[SwitchA] bgp 100
[SwitchA-bgp-default] peer 12.12.12.12 as-number 100
[SwitchA-bgp-default] peer 12.12.12.12 connect-interface loopback 0
[SwitchA-bgp-default-evpn] peer 12.12.12.12 enable
[SwitchA-bgp-default-evpn] peer 12.12.12.12 additional-paths receive
# On server-facing interface Ten-GigabitEthernet 1/0/2, create Ethernet service instance 11 to match VLAN 11.
[SwitchA] interface ten-gigabitethernet 1/0/2
[SwitchA-Ten-GigabitEthernet1/0/2] port link-mode bridge
[SwitchA-Ten-GigabitEthernet1/0/2] port link-type trunk
[SwitchA-Ten-GigabitEthernet1/0/2] port trunk permit vlan 1 11
[SwitchA-Ten-GigabitEthernet1/0/2] service-instance 11
[SwitchA-Ten-GigabitEthernet1/0/2-srv11] encapsulation s-vid 11
# Map Ethernet service instance 11 to VSI 1.
[SwitchA-Ten-GigabitEthernet1/0/2-srv11] xconnect vsi 1
[SwitchA-Ten-GigabitEthernet1/0/2-srv11] quit
[SwitchA-Ten-GigabitEthernet1/0/2] quit
# Configure RD and route target settings for VPN instance a.
[SwitchA] ip vpn-instance a
[SwitchA-vpn-instance-a] route-distinguisher 1:1
[SwitchA-vpn-instance-a] vpn-target 1:1 import-extcommunity
[SwitchA-vpn-instance-a] vpn-target 1:1 export-extcommunity
[SwitchA-vpn-instance-a] quit
[SwitchA-Vsi-interface1] ip binding vpn-instance a
[SwitchA-Vsi-interface1] ip address 10.0.0.1 255.255.255.0
[SwitchA-Vsi-interface1] mac-address 0001-0001-0001
# Create VSI-interface 2, associate the VSI interface with VPN instance a, and configure the L3 VXLAN ID as 1000 for the VPN instance.
[SwitchA-Vsi-interface2] ip binding vpn-instance a
[SwitchA-Vsi-interface2] l3-vni 1000
[SwitchA-Vsi-interface2] pim sm
[SwitchA-Vsi-interface2] quit
# Enable IP multicast routing for the public network.
[SwitchA-mrib] quit
[SwitchA] pim
[SwitchA-pim] quit
# Enable IP multicast routing for VPN instance a.
[SwitchA] multicast routing vpn-instance a
[SwitchA-mrib-a] quit
# Enter VPN instance PIM view, and configure Loopback 1 as a candidate-BSR and candidate-RP in VPN instance a.
[SwitchA] pim vpn-instance a
[SwitchA-pim-a] c-bsr 1.1.1.1
[SwitchA-pim-a] c-rp 1.1.1.1
[SwitchA-pim-a] quit
# Create an MDT-based MVXLAN for VPN instance a and enter MVXLAN IPv4 address family view. Configure the default group, MVXLAN source interface, and data group range settings. Enable advertising active multicast sources through S-PMSI routes. Set the data-delay period to 20 seconds, which is longer than the default frequency of sending the same route update to a peer or peer group.
[SwitchA] multicast-vpn vxlan vpn-instance a mode mdt
[SwitchA-mvxlan-a] address-family ipv4
[SwitchA-mvxlan-a-ipv4] default-group 236.0.0.0
[SwitchA-mvxlan-a-ipv4] source loopback 0
[SwitchA-mvxlan-a-ipv4] data-group 239.0.0.0 30
[SwitchA-mvxlan-a-ipv4] s-pmsi advertise source-active
[SwitchA-mvxlan-a-ipv4] data-delay 20
[SwitchA-mvxlan-a-ipv4] quit
[SwitchA-mvxlan-a] quit
[SwitchA-LoopBack1] ip binding vpn-instance a
# Specify VSI-interface 1 as the gateway interface for VSI 1.
[SwitchA] vsi 1
[SwitchA-vsi-1] gateway vsi-interface 1
[SwitchA-vsi-1] quit
3.     Configure Switch B:
# Enable L2VPN and IP multicast routing, start an OSPF process, and create VLAN 22.
[SwitchB-mrib] quit
[SwitchB] pim
[SwitchB-pim] quit
[SwitchB] ospf 1
[SwitchB-ospf-1] area 0.0.0.0
[SwitchB] vlan 22
[SwitchB-vlan22] quit
[SwitchB] vxlan default-decapsulation source interface loopback 0
[SwitchB] vsi 1
[SwitchB-vsi-1] evpn encapsulation vxlan
[SwitchB-vsi-1-evpn-vxlan] route-distinguisher auto
[SwitchB-vsi-1-evpn-vxlan] vpn-target auto export-extcommunity
[SwitchB-vsi-1-evpn-vxlan] vpn-target auto import-extcommunity [SwitchB-vsi-1-evpn-vxlan] quit
[SwitchB-vsi-1] igmp-snooping enable
# Create VXLAN 10.
[SwitchB-vsi-1] vxlan 10
[SwitchB-vsi-1-vxlan-10] quit
[SwitchB] bgp 100
[SwitchB-bgp-default] peer 12.12.12.12 as-number 100
[SwitchB-bgp-default] peer 12.12.12.12 connect-interface loopback 0
[SwitchB-bgp-default-evpn] peer 12.12.12.12 enable
[SwitchB-bgp-default-evpn] peer 12.12.12.12 additional-paths receive
# On server-facing interface Ten-GigabitEthernet 1/0/1, create Ethernet service instance 22 to match VLAN 22.
[SwitchB-Ten-GigabitEthernet1/0/1] port link-mode bridge
[SwitchB-Ten-GigabitEthernet1/0/1] port trunk permit vlan 1 22
[SwitchB-Ten-GigabitEthernet1/0/1] service-instance 22
[SwitchB-Ten-GigabitEthernet1/0/1-srv22] encapsulation s-vid 22
# Map Ethernet service instance 22 to VSI 1.
[SwitchB-Ten-GigabitEthernet1/0/1-srv22] xconnect vsi 1
[SwitchB-Ten-GigabitEthernet1/0/1-srv22] quit
[SwitchB-Ten-GigabitEthernet1/0/1] quit
[SwitchB] ip vpn-instance a
[SwitchB-vpn-instance-a] route-distinguisher 2:2
[SwitchB-vpn-instance-a] vpn-target 1:1 import-extcommunity
[SwitchB-vpn-instance-a] vpn-target 1:1 export-extcommunity
[SwitchB-vpn-instance-a] quit
[SwitchB-Vsi-interface1] ip binding vpn-instance a
[SwitchB-Vsi-interface1] ip address 10.0.0.1 255.255.255.0
[SwitchB-Vsi-interface1] mac-address 0001-0001-0001
[SwitchB-Vsi-interface2] ip binding vpn-instance a
[SwitchB-Vsi-interface2] l3-vni 1000
[SwitchB-mrib] quit
[SwitchB] pim
[SwitchB-pim] quit
[SwitchB] multicast routing vpn-instance a
[SwitchB-mrib-a] quit
[SwitchB] pim vpn-instance a
[SwitchB-pim-a] c-bsr 2.2.2.2
[SwitchB-pim-a] c-rp 2.2.2.2
[SwitchB-pim-a] quit
# Create an MDT-based MVXLAN for VPN instance a and enter MVXLAN IPv4 address family view. Configure the MVXLAN source interface.
[SwitchB] multicast-vpn vxlan vpn-instance a mode mdt
[SwitchB-mvxlan-a] address-family ipv4
[SwitchB-mvxlan-a-ipv4] source loopback 0
[SwitchB-mvxlan-a-ipv4] quit
[SwitchB-mvxlan-a] quit
[SwitchB-LoopBack1] ip binding vpn-instance a
[SwitchB] vsi 1
[SwitchB-vsi-1] gateway vsi-interface 1
[SwitchB-vsi-1] quit
4.     Configure Switch C:
# Enable IP multicast routing and start an OSPF process.
[SwitchC-mrib] quit
[SwitchC] pim
[SwitchC-pim] quit
[SwitchC] ospf 1
[SwitchC-ospf-1] area 0.0.0.0
[SwitchC-ospf-1] quit
[SwitchC-LoopBack0] ip address 12.12.12.12 32
# Configure Switch C as an RR to reflect BGP EVPN routes between switches. Enable the BGP additional path sending capability to Switch A and Switch B, and set the maximum number of Add-Path optimal routes that can be advertised. The maximum number of Add-Path optimal routes cannot be smaller than the number of peer EDs.
[SwitchC] bgp 100
[SwitchC-bgp-default] group ED internal
[SwitchC-bgp-default] peer ED connect-interface loopback 0
[SwitchC-bgp-default] group VTEP internal
[SwitchC-bgp-default] peer VTEP connect-interface loopback 0
[SwitchC-bgp-default] peer 1.1.1.1 group VTEP
[SwitchC-bgp-default] peer 2.2.2.2 group VTEP
[SwitchC-bgp-default] peer 3.3.3.3 group ED
[SwitchC-bgp-default] peer 4.4.4.4 group ED
[SwitchC-bgp-default] peer 5.5.5.5 group ED
[SwitchC-bgp-default-evpn] undo policy vpn-target
[SwitchC-bgp-default-evpn] additional-paths select-best 3
[SwitchC-bgp-default-evpn] peer ED enable
[SwitchC-bgp-default-evpn] peer ED reflect-client
[SwitchC-bgp-default-evpn] peer VTEP enable
[SwitchC-bgp-default-evpn] peer VTEP reflect-client
[SwitchC-bgp-default-evpn] peer VTEP additional-paths send
[SwitchC-bgp-default-evpn] peer VTEP advertise additional-paths best 3
5.     Configure Switch D:
# Enable L2VPN and IP multicast routing, and start an OSPF process and a RIP process.
[SwitchD-mrib] quit
[SwitchD] pim
[SwitchD-pim] quit
[SwitchD] ospf 1
[SwitchD-ospf-1] area 0.0.0.0
[SwitchD-ospf-1] quit
[SwitchD] rip 1
[SwitchD-rip-1] network 3.0.0.0
[SwitchD-rip-1] network 113.0.0.0
[SwitchD-rip-1] quit
# Configure RIP and enable DCI on the interface connected to a remote ED.
[SwitchD] interface vlan-interface 3
[SwitchD-Vlan-interface3] rip 1 enable
[SwitchD-Vlan-interface3] dci enable
[SwitchD-Vlan-interface3] quit
# Specify virtual ED address 3.4.5.0.
[SwitchD] evpn edge group 3.4.5.0
[SwitchD] ip vpn-instance a
[SwitchD-vpn-instance-a] route-distinguisher 3:3
[SwitchD-vpn-instance-a] vpn-target 1:1 import-extcommunity
[SwitchD-vpn-instance-a] vpn-target 1:1 export-extcommunity
[SwitchD-vpn-instance-a] quit
[SwitchD-LoopBack0] ip address 3.3.3.3 32
[SwitchD-LoopBack0] rip 1 enable
[SwitchD-LoopBack1] ip binding vpn-instance a
[SwitchD-LoopBack1] ip address 3.3.3.3 32
[SwitchD-LoopBack2] ip address 3.4.5.0 32
[SwitchD-LoopBack2] rip 1 enable
[SwitchD-LoopBack2] ospf 1 area 0.0.0.0
[SwitchD-Vsi-interface2] ip binding vpn-instance a
[SwitchD-Vsi-interface2] l3-vni 1000
[SwitchD] multicast routing vpn-instance a
[SwitchD-mrib-a] quit
[SwitchD] pim vpn-instance a
[SwitchD-pim-a] c-bsr 3.3.3.3
[SwitchD-pim-a] c-rp 3.3.3.3
[SwitchD-pim-a] quit
# Specify peer EDs for the local ED.
[SwitchD] multicast-vpn vxlan edge remote 4.4.4.4
[SwitchD] multicast-vpn vxlan edge remote 5.5.5.5
# Create an MDT-based MVXLAN for VPN instance a and enter MVXLAN IPv4 address family view. Configure the default group and MVXLAN source interface, and enable DCI multicast.
[SwitchD] multicast-vpn vxlan vpn-instance a mode mdt
[SwitchD-mvxlan-a] address-family ipv4
[SwitchD-mvxlan-a-ipv4] default-group 236.0.0.0
[SwitchD-mvxlan-a-ipv4] source loopback 0
[SwitchD-mvxlan-a-ipv4] dci enable
[SwitchD-mvxlan-a-ipv4] quit
[SwitchD-mvxlan-a] quit
# Configure a routing policy. Configure Switch D to not forward the SMET and S-PMSI routes received from Switch H and Switch I to Switch K. Configure Switch D to not forward the SMET and S-PMSI routes received from Switch K to Switch H and Switch I.
[SwitchD] ip prefix-list 1 index 10 permit 0.0.0.0 0 less-equal 32
[SwitchD] ip prefix-list 2 index 10 permit 6.6.6.6 32
[SwitchD] ip prefix-list 2 index 20 permit 7.7.7.7 32
[SwitchD] ip prefix-list 3 index 10 permit 9.9.9.9 32
[SwitchD] route-policy dc2 deny node 0
[SwitchD-route-policy-dc2-0] if-match ip route-source prefix-list 3
[SwitchD-route-policy-dc2-0] if-match route-type bgp-evpn-smet bgp-evpn-s-pmsi
[SwitchD-route-policy-dc2-0] route-policy dc2 permit node 1
[SwitchD-route-policy-dc2-1] if-match ip route-source prefix-list 1
[SwitchD-route-policy-dc2-1] route-policy dc3 deny node 0
[SwitchD-route-policy-dc3-0] if-match ip route-source prefix-list 2
[SwitchD-route-policy-dc3-0] if-match route-type bgp-evpn-smet bgp-evpn-s-pmsi
[SwitchD-route-policy-dc3-0] route-policy dc3 permit node 1
[SwitchD-route-policy-dc3-1] if-match ip route-source prefix-list 1
[SwitchD-route-policy-dc3-1] quit
# Configure a routing policy to change the next hop of the S-PMSI routes sent from Switch D to Switch C to 3.3.3.3.
[SwitchD] route-policy rt_spmsi permit node 0
[SwitchD-route-policy-rt_spmsi-0] if-match route-type bgp-evpn-s-pmsi
[SwitchD-route-policy-rt_spmsi-0] apply ip-address next-hop 3.3.3.3
[SwitchD-route-policy-rt_spmsi-0] quit
[SwitchD] route-policy rt_spmsi permit node 1
[SwitchD-route-policy-rt_spmsi-1] quit
# Enable BGP to advertise BGP EVPN routes and configure Switch C as an RR.
[SwitchD] bgp 100
[SwitchD-bgp-default] group ED2 external
[SwitchD-bgp-default] peer ED2 as-number 200
[SwitchD-bgp-default] peer ED2 connect-interface loopback 0
[SwitchD-bgp-default] peer ED2 ebgp-max-hop 64
[SwitchD-bgp-default] peer 6.6.6.6 group ED2
[SwitchD-bgp-default] peer 7.7.7.7 group ED2
[SwitchD-bgp-default] peer 9.9.9.9 as-number 300
[SwitchD-bgp-default] peer 9.9.9.9 connect-interface loopback 0
[SwitchD-bgp-default] peer 9.9.9.9 ebgp-max-hop 64
[SwitchD-bgp-default] peer 12.12.12.12 as-number 100
[SwitchD-bgp-default] peer 12.12.12.12 connect-interface loopback 0
[SwitchD-bgp-default-evpn] undo policy vpn-target
[SwitchD-bgp-default-evpn] peer ED2 enable
[SwitchD-bgp-default-evpn] peer ED2 route-policy dc2 export
[SwitchD-bgp-default-evpn] peer ED2 router-mac-local
[SwitchD-bgp-default-evpn] peer 9.9.9.9 enable
[SwitchD-bgp-default-evpn] peer 9.9.9.9 route-policy dc3 export
[SwitchD-bgp-default-evpn] peer 9.9.9.9 router-mac-local
[SwitchD-bgp-default-evpn] peer 12.12.12.12 enable
[SwitchD-bgp-default-evpn] peer 12.12.12.12 route-policy rt_spmsi export
6.     Configure Switch E:
[SwitchE-mrib] quit
[SwitchE] pim
[SwitchE-pim] quit
[SwitchE] ospf 1
[SwitchE-ospf-1] area 0.0.0.0
[SwitchE-ospf-1-area-0.0.0.0] quit
[SwitchE] rip 1
[SwitchE-rip-1] network 4.0.0.0
[SwitchE-rip-1] network 114.0.0.0
[SwitchE-rip-1] quit
[SwitchE] interface  vlan-interface 4
[SwitchE-Vlan-interface4] rip 1 enable
[SwitchE-Vlan-interface4] dci enable
[SwitchE-LoopBack0] rip 1 enable
[SwitchE] ip vpn-instance a
[SwitchE-vpn-instance-a] route-distinguisher 4:4
[SwitchE-vpn-instance-a] vpn-target 1:1 import-extcommunity
[SwitchE-vpn-instance-a] vpn-target 1:1 export-extcommunity
[SwitchE-vpn-instance-a] quit
[SwitchE-LoopBack1] ip binding vpn-instance a
[SwitchE] interface loopback 2
[SwitchE-LoopBack2] ip address 3.4.5.0 32
[SwitchE-LoopBack2] rip 1 enable
[SwitchE-LoopBack2] ospf 1 area 0.0.0.0
[SwitchE-LoopBack2] quit
[SwitchE-Vsi-interface2] ip binding vpn-instance a
[SwitchE-Vsi-interface2] l3-vni 1000
[SwitchE] evpn edge group 3.4.5.0
[SwitchE] multicast routing vpn-instance a
[SwitchE-mrib-a] quit
[SwitchE] pim vpn-instance a
[SwitchE-pim-a] c-bsr 4.4.4.4
[SwitchE-pim-a] c-rp 4.4.4.4
[SwitchE-pim-a] quit
[SwitchE] multicast-vpn vxlan edge remote 3.3.3.3
[SwitchE] multicast-vpn vxlan edge remote 5.5.5.5
[SwitchE] multicast-vpn vxlan vpn-instance a mode mdt
[SwitchE-mvxlan-a] address-family ipv4
[SwitchE-mvxlan-a-ipv4] default-group 236.0.0.0
[SwitchE-mvxlan-a-ipv4] source loopback 0
[SwitchE-mvxlan-a-ipv4] dci enable
[SwitchE-mvxlan-a-ipv4] quit
[SwitchE-mvxlan-a] quit
# Configure a routing policy. Configure Switch E to not forward the SMET and S-PMSI routes received from Switch H and Switch I to Switch K. Configure Switch E to not forward the SMET and S-PMSI routes received from Switch K to Switch H and Switch I.
[SwitchE] ip prefix-list 1 index 10 permit 0.0.0.0 0 less-equal 32
[SwitchE] ip prefix-list 2 index 10 permit 6.6.6.6 32
[SwitchE] ip prefix-list 2 index 20 permit 7.7.7.7 32
[SwitchE] ip prefix-list 3 index 10 permit 9.9.9.9 32
[SwitchE] route-policy dc2 deny node 0
[SwitchE-route-policy-dc2-0] if-match ip route-source prefix-list 3
[SwitchE-route-policy-dc2-0] if-match route-type bgp-evpn-smet bgp-evpn-s-pmsi
[SwitchE-route-policy-dc2-0] route-policy dc2 permit node 1
[SwitchE-route-policy-dc2-1] if-match ip route-source prefix-list 1
[SwitchE-route-policy-dc2-1] route-policy dc3 deny node 0
[SwitchE-route-policy-dc3-0] if-match ip route-source prefix-list 2
[SwitchE-route-policy-dc3-0] if-match route-type bgp-evpn-smet bgp-evpn-s-pmsi
[SwitchE-route-policy-dc3-0] route-policy dc3 permit node 1
[SwitchE-route-policy-dc3-1] if-match ip route-source prefix-list 1
[SwitchE-route-policy-dc3-1] quit
# Configure a routing policy to change the next hop of the S-PMSI routes sent from Switch E to Switch C to 4.4.4.4.
[SwitchE] route-policy rt_spmsi permit node 0
[SwitchE-route-policy-rt_spmsi-0] if-match route-type bgp-evpn-s-pmsi
[SwitchE-route-policy-rt_spmsi-0] apply ip-address next-hop 4.4.4.4
[SwitchE-route-policy-rt_spmsi-0] quit
[SwitchE] route-policy rt_spmsi permit node 1
[SwitchE-route-policy-rt_spmsi-1] quit
[SwitchE] bgp 100
[SwitchE-bgp-default] group ED2 external
[SwitchE-bgp-default] peer ED2 as-number 200
[SwitchE-bgp-default] peer ED2 connect-interface loopback 0
[SwitchE-bgp-default] peer ED2 ebgp-max-hop 64
[SwitchE-bgp-default] peer 6.6.6.6 group ED2
[SwitchE-bgp-default] peer 7.7.7.7 group ED2
[SwitchE-bgp-default] peer 9.9.9.9 as-number 300
[SwitchE-bgp-default] peer 9.9.9.9 connect-interface loopback 0
[SwitchE-bgp-default] peer 9.9.9.9 ebgp-max-hop 64
[SwitchE-bgp-default] peer 12.12.12.12 as-number 100
[SwitchE-bgp-default] peer 12.12.12.12 connect-interface loopback 0
[SwitchE-bgp-default-evpn] undo policy vpn-target
[SwitchE-bgp-default-evpn] peer ED2 enable
[SwitchE-bgp-default-evpn] peer ED2 route-policy dc2 export
[SwitchE-bgp-default-evpn] peer ED2 router-mac-local
[SwitchE-bgp-default-evpn] peer 9.9.9.9 enable
[SwitchE-bgp-default-evpn] peer 9.9.9.9 route-policy dc3 export
[SwitchE-bgp-default-evpn] peer 9.9.9.9 router-mac-local
[SwitchE-bgp-default-evpn] peer 12.12.12.12 enable
[SwitchE-bgp-default-evpn] peer 12.12.12.12 route-policy rt_spmsi export
7.     Configure Switch F:
[SwitchF-mrib] quit
[SwitchF] pim
[SwitchF-pim] quit
[SwitchF] ospf 1
[SwitchF-ospf-1] area 0.0.0.0
[SwitchF-ospf-1-area-0.0.0.0] quit
[SwitchF] rip 1
[SwitchF-rip-1] network 5.0.0.0
[SwitchF-rip-1] network 115.0.0.0
[SwitchF-rip-1] quit
# Enable the IGMP snooping feature.
[SwitchF-LoopBack0] ip address 5.5.5.5 32
[SwitchF-LoopBack0] rip 1 enable
[SwitchF-LoopBack0] ospf 1 area 0.0.0.0
[SwitchF] interface vlan-interface 5
[SwitchF-Vlan-interface5] rip 1 enable
[SwitchF-Vlan-interface5] dci enable
[SwitchF] ip vpn-instance a
[SwitchF-vpn-instance-a] route-distinguisher 5:5
[SwitchF-vpn-instance-a] vpn-target 1:1 import-extcommunity
[SwitchF-vpn-instance-a] vpn-target 1:1 export-extcommunity
[SwitchF-vpn-instance-a] quit
[SwitchF] interface vsi-interface 2
[SwitchF-Vsi-interface2] ip binding vpn-instance a
[SwitchF-Vsi-interface2] l3-vni 1000
[SwitchF-Vsi-interface2] pim sm
[SwitchF-Vsi-interface2] quit
[SwitchF] evpn edge group 3.4.5.0
[SwitchF] multicast-vpn vxlan edge remote 3.3.3.3
[SwitchF] multicast-vpn vxlan edge remote 4.4.4.4
[SwitchF-LoopBack1] ip binding vpn-instance a
[SwitchF-LoopBack1] ip address 5.5.5.5 32
[SwitchF-LoopBack1] pim sm
[SwitchF-LoopBack2] ip address 3.4.5.0 32
[SwitchF-LoopBack2] rip 1 enable
[SwitchF-LoopBack2] ospf 1 area 0.0.0.0
[SwitchF] pim vpn-instance a
[SwitchF-pim-a] c-bsr 5.5.5.5
[SwitchF-pim-a] c-rp 5.5.5.5
[SwitchF-pim-a] quit
[SwitchF] multicast routing vpn-instance a
[SwitchF-mrib-a] quit
[SwitchF] multicast-vpn vxlan vpn-instance a mode mdt
[SwitchF-mvxlan-a] address-family ipv4
[SwitchF-mvxlan-a-ipv4] default-group 236.0.0.0
[SwitchF-mvxlan-a-ipv4] source loopback 0
[SwitchF-mvxlan-a-ipv4] dci enable
[SwitchF-mvxlan-a-ipv4] quit
[SwitchF-mvxlan-a] quit
# Configure a routing policy. Configure Switch F to not forward the SMET and S-PMSI routes received from Switch H and Switch I to Switch K. Configure Switch F to not forward the SMET and S-PMSI routes received from Switch K to Switch H and Switch I.
[SwitchF] ip prefix-list 1 index 10 permit 0.0.0.0 0 less-equal 32
[SwitchF] ip prefix-list 2 index 10 permit 6.6.6.6 32
[SwitchF] ip prefix-list 2 index 20 permit 7.7.7.7 32
[SwitchF] ip prefix-list 3 index 10 permit 9.9.9.9 32
[SwitchF] route-policy dc2 deny node 0
[SwitchF-route-policy-dc2-0] if-match ip route-source prefix-list 3
[SwitchF-route-policy-dc2-0] if-match route-type bgp-evpn-smet bgp-evpn-s-pmsi
[SwitchF-route-policy-dc2-0] route-policy dc2 permit node 1
[SwitchF-route-policy-dc2-1] if-match ip route-source prefix-list 1
[SwitchF-route-policy-dc2-1] route-policy dc3 deny node 0
[SwitchF-route-policy-dc3-0] if-match ip route-source prefix-list 2
[SwitchF-route-policy-dc3-0] if-match route-type bgp-evpn-smet bgp-evpn-s-pmsi
[SwitchF-route-policy-dc3-0] route-policy dc3 permit node 1
[SwitchF-route-policy-dc3-1] if-match ip route-source prefix-list 1
[SwitchF-route-policy-dc3-1] quit
# Configure a routing policy to change the next hop of the S-PMSI routes sent from Switch F to Switch C to 5.5.5.5.
[SwitchF] route-policy rt_spmsi permit node 0
[SwitchF-route-policy-rt_spmsi-0] if-match route-type bgp-evpn-s-pmsi
[SwitchF-route-policy-rt_spmsi-0] apply ip-address next-hop 5.5.5.5
[SwitchF] quit
[SwitchF-route-policy-rt_spmsi-0] route-policy rt_spmsi permit node 1
[SwitchF-route-policy-rt_spmsi-1] quit
[SwitchF] bgp 100
[SwitchF-bgp-default] group ED2 external
[SwitchF-bgp-default] peer ED2 as-number 200
[SwitchF-bgp-default] peer ED2 connect-interface loopback 0
[SwitchF-bgp-default] peer ED2 ebgp-max-hop 64
[SwitchF-bgp-default] peer 6.6.6.6 group ED2
[SwitchF-bgp-default] peer 7.7.7.7 group ED2
[SwitchF-bgp-default] peer 9.9.9.9 as-number 300
[SwitchF-bgp-default] peer 9.9.9.9 connect-interface loopback 0
[SwitchF-bgp-default] peer 9.9.9.9 ebgp-max-hop 64
[SwitchF-bgp-default] peer 12.12.12.12 as-number 100
[SwitchF-bgp-default] peer 12.12.12.12 connect-interface loopback 0
[SwitchF-bgp-default-evpn] undo policy vpn-target
[SwitchF-bgp-default-evpn] peer ED2 enable
[SwitchF-bgp-default-evpn] peer ED2 route-policy dc2 export
[SwitchF-bgp-default-evpn] peer ED2 router-mac-local
[SwitchF-bgp-default-evpn] peer 9.9.9.9 enable
[SwitchF-bgp-default-evpn] peer 9.9.9.9 route-policy dc3 export
[SwitchF-bgp-default-evpn] peer 9.9.9.9 router-mac-local
[SwitchF-bgp-default-evpn] peer 12.12.12.12 enable
[SwitchF-bgp-default-evpn] peer 12.12.12.12 route-policy rt_spmsi export
8.     Configure Switch G:
# Start a RIP process.
<SwitchG> system-view
[SwitchG] rip 1
[SwitchG-rip-1] network 113.0.0.0
[SwitchG-rip-1] network 114.0.0.0
[SwitchG-rip-1] network 115.0.0.0
[SwitchG-rip-1] network 116.0.0.0
[SwitchG-rip-1] network 117.0.0.0
[SwitchG-rip-1] network 119.0.0.0
[SwitchG-rip-1] quit
# Configure RIP on the interfaces connected to EDs.
[SwitchG] interface vlan-interface 3
[SwitchG-Vlan-interface3] rip 1 enable
[SwitchG-Vlan-interface3] quit
[SwitchG] interface vlan-interface 4
[SwitchG-Vlan-interface4] rip 1 enable
[SwitchG-Vlan-interface4] quit
[SwitchG] interface vlan-interface 5
[SwitchG-Vlan-interface5] rip 1 enable
[SwitchG-Vlan-interface5] quit
[SwitchG] interface vlan-interface 6
[SwitchG-Vlan-interface6] rip 1 enable
[SwitchG-Vlan-interface6] quit
[SwitchG] interface vlan-interface 7
[SwitchG-Vlan-interface7] rip 1 enable
[SwitchG-Vlan-interface7] quit
[SwitchG] interface vlan-interface 9
[SwitchG-Vlan-interface9] rip 1 enable
[SwitchG-Vlan-interface9] quit
9.     Configure Switch H:
<SwitchH> system-view
[SwitchH] l2vpn enable
[SwitchH] multicast routing
[SwitchH-mrib] quit
[SwitchH] pim
[SwitchH-pim] quit
[SwitchH] ospf 1
[SwitchH-ospf-1] area 0.0.0.0
[SwitchH-ospf-1-area-0.0.0.0] quit
[SwitchH] rip 1
[SwitchH-rip-1] network 2.0.0.0
[SwitchH-rip-1] network 6.0.0.0
[SwitchH-rip-1] network 116.0.0.0
[SwitchH-rip-1] quit
[SwitchH] igmp-snooping
[SwitchH-igmp-snooping] quit
[SwitchH] interface loopback 0
[SwitchH-LoopBack0] ip address 6.6.6.6 32
[SwitchH-LoopBack0] rip 1 enable
[SwitchH-LoopBack0] ospf 1 area 0.0.0.0
[SwitchH-LoopBack0] quit
[SwitchH] interface vlan-interface 6
[SwitchH-Vlan-interface6] rip 1 enable
[SwitchH-Vlan-interface6] dci enable
[SwitchH-Vlan-interface6] quit
[SwitchH] ip vpn-instance a
[SwitchH-vpn-instance-a] route-distinguisher 6:6
[SwitchH-vpn-instance-a] vpn-target 1:1 import-extcommunity
[SwitchH-vpn-instance-a] vpn-target 1:1 export-extcommunity
[SwitchH-vpn-instance-a] quit
[SwitchH] interface vsi-interface 2
[SwitchH-Vsi-interface2] ip binding vpn-instance a
[SwitchH-Vsi-interface2] l3-vni 1000
[SwitchH-Vsi-interface2] pim sm
[SwitchH-Vsi-interface2] quit
[SwitchH] interface loopback 1
[SwitchH-LoopBack1] ip binding vpn-instance a
[SwitchH-LoopBack1] ip address 6.6.6.6 32
[SwitchH-LoopBack1] pim sm
[SwitchH-LoopBack1] quit
[SwitchH] interface loopback 2
[SwitchH-LoopBack2] ip address 2.2.1.1 32
[SwitchH-LoopBack2] rip 1 enable
[SwitchH-LoopBack2] ospf 1 area 0.0.0.0
[SwitchH-LoopBack2] quit
[SwitchH] pim vpn-instance a
[SwitchH-pim-a] c-bsr 6.6.6.6
[SwitchH-pim-a] c-rp 6.6.6.6
[SwitchH-pim-a] quit
[SwitchH] multicast routing vpn-instance a
[SwitchH-mrib-a] quit
# Specify virtual ED address 2.2.1.1.
[SwitchH] evpn edge group 2.2.1.1
[SwitchH] multicast-vpn vxlan edge remote 7.7.7.7
# Create an MDT-based MVXLAN for VPN instance a and enter MVXLAN IPv4 address family view. Configure the default group, MVXLAN source interface, and data group range settings, and enable DCI multicast. Configure the data group range to be the same as that on Switch A to ensure correct forwarding.
[SwitchH] multicast-vpn vxlan vpn-instance a mode mdt
[SwitchH-mvxlan-a] address-family ipv4
[SwitchH-mvxlan-a-ipv4] default-group 236.0.0.0
[SwitchH-mvxlan-a-ipv4] source loopback 0
[SwitchH-mvxlan-a-ipv4] data-group 239.0.0.0 30
[SwitchH-mvxlan-a-ipv4] dci enable
[SwitchH-mvxlan-a-ipv4] quit
[SwitchH-mvxlan-a] quit
# Configure a routing policy. Configure Switch H to not forward the SMET and S-PMSI routes received from Switch D, Switch E, and Switch F to Switch K. Configure Switch H to not forward the SMET and S-PMSI routes received from Switch K to Switch D, Switch E, and Switch F.
[SwitchH] ip prefix-list 0 index 10 permit 0.0.0.0 0 less-equal 32
[SwitchH] ip prefix-list 1 index 10 permit 3.3.3.3 32
[SwitchH] ip prefix-list 1 index 20 permit 4.4.4.4 32
[SwitchH] ip prefix-list 1 index 30 permit 5.5.5.5 32
[SwitchH] ip prefix-list 3 index 10 permit 9.9.9.9 32
[SwitchH] route-policy dc1 deny node 0
[SwitchH-route-policy-dc1-0] if-match ip route-source prefix-list 3
[SwitchH-route-policy-dc1-0] if-match route-type bgp-evpn-smet bgp-evpn-s-pmsi
[SwitchH-route-policy-dc1-0] route-policy dc1 permit node 1
[SwitchH-route-policy-dc1-1] if-match ip route-source prefix-list 0
[SwitchH-route-policy-dc1-1] route-policy dc3 deny node 0
[SwitchH-route-policy-dc3-0] if-match ip route-source prefix-list 1
[SwitchH-route-policy-dc3-0] if-match route-type bgp-evpn-smet bgp-evpn-s-pmsi
[SwitchH-route-policy-dc3-0] route-policy dc3 permit node 1
[SwitchH-route-policy-dc3-1] if-match ip route-source prefix-list 0
[SwitchH-route-policy-dc3-1] quit
# Configure a routing policy to change the next hop of the S-PMSI routes sent from Switch H to Switch J to 6.6.6.6.
[SwitchH] route-policy rt_spmsi permit node 0
[SwitchH-route-policy-rt_spmsi-0] if-match route-type bgp-evpn-s-pmsi
[SwitchH-route-policy-rt_spmsi-0] apply ip-address next-hop 6.6.6.6
[SwitchH-route-policy-rt_spmsi-0] quit
[SwitchH] route-policy rt_spmsi permit node 1
[SwitchH-route-policy-rt_spmsi-1] quit
# Enable BGP to advertise BGP EVPN routes.
[SwitchH] bgp 200
[SwitchH-bgp-default] group ED1 external
[SwitchH-bgp-default] peer ED1 as-number 100
[SwitchH-bgp-default] peer ED1 connect-interface loopback 0
[SwitchH-bgp-default] peer ED1 ebgp-max-hop 64
[SwitchH-bgp-default] peer 3.3.3.3 group ED1
[SwitchH-bgp-default] peer 4.4.4.4 group ED1
[SwitchH-bgp-default] peer 5.5.5.5 group ED1
[SwitchH-bgp-default] peer 7.7.7.7 as-number 200
[SwitchH-bgp-default] peer 7.7.7.7 connect-interface loopback 0
[SwitchH-bgp-default] peer 8.8.8.8 as-number 200
[SwitchH-bgp-default] peer 8.8.8.8 connect-interface loopback 0
[SwitchH-bgp-default] peer 9.9.9.9 as-number 300
[SwitchH-bgp-default] peer 9.9.9.9 connect-interface loopback 0
[SwitchH-bgp-default] peer 9.9.9.9 ebgp-max-hop 64
[SwitchH-bgp-default] address-family l2vpn evpn
[SwitchH-bgp-default-evpn] peer ED1 enable
[SwitchH-bgp-default-evpn] peer ED1 route-policy dc1 export
[SwitchH-bgp-default-evpn] peer ED1 router-mac-local
[SwitchH-bgp-default-evpn] peer 7.7.7.7 enable
[SwitchH-bgp-default-evpn] peer 7.7.7.7 next-hop-local
[SwitchH-bgp-default-evpn] peer 8.8.8.8 enable
[SwitchH-bgp-default-evpn] peer 8.8.8.8 route-policy rt_spmsi export
[SwitchH-bgp-default-evpn] peer 8.8.8.8 next-hop-local
[SwitchH-bgp-default-evpn] peer 9.9.9.9 enable
[SwitchH-bgp-default-evpn] peer 9.9.9.9 route-policy dc3 export
[SwitchH-bgp-default-evpn] peer 9.9.9.9 router-mac-local
[SwitchH-bgp-default-evpn] quit
[SwitchH-bgp-default] quit
10.     Configure Switch I:
<SwitchI> system-view
[SwitchI] l2vpn enable
[SwitchI] multicast routing
[SwitchI-mrib] quit
[SwitchI] pim
[SwitchI-pim] quit
[SwitchI] ospf 1
[SwitchI-ospf-1] area 0.0.0.0
[SwitchI-ospf-1-area-0.0.0.0] quit
[SwitchI] rip 1
[SwitchI-rip-1] network 2.0.0.0
[SwitchI-rip-1] network 7.0.0.0
[SwitchI-rip-1] network 117.0.0.0
[SwitchI-rip-1] quit
[SwitchI] igmp-snooping
[SwitchI-igmp-snooping] quit
[SwitchI] interface loopback 0
[SwitchI-LoopBack0] ip address 7.7.7.7 32
[SwitchI-LoopBack0] rip 1 enable
[SwitchI-LoopBack0] ospf 1 area 0.0.0.0
[SwitchI-LoopBack0] quit
[SwitchI] interface vlan-interface 7
[SwitchI-Vlan-interface7] rip 1 enable
[SwitchI-Vlan-interface7] dci enable
[SwitchI] ip vpn-instance a
[SwitchI-vpn-instance-a] route-distinguisher 7:7
[SwitchI-vpn-instance-a] vpn-target 1:1 import-extcommunity
[SwitchI-vpn-instance-a] vpn-target 1:1 export-extcommunity
[SwitchI-vpn-instance-a] quit
[SwitchI] interface vsi-interface 2
[SwitchI-Vsi-interface2] ip binding vpn-instance a
[SwitchI-Vsi-interface2] l3-vni 1000
[SwitchI-Vsi-interface2] pim sm
[SwitchI-Vsi-interface2] quit
# Configure Loopback 1.
[SwitchI] interface loopback 1
[SwitchI-LoopBack1] ip binding vpn-instance a
[SwitchI-LoopBack1] ip address 7.7.7.7 32
[SwitchI-LoopBack1] pim sm
[SwitchI-LoopBack1] quit
[SwitchI] interface loopback 2
[SwitchI-LoopBack2] ip address 2.2.1.1 32
[SwitchI-LoopBack2] rip 1 enable
[SwitchI-LoopBack2] ospf 1 area 0.0.0.0
[SwitchI-LoopBack2] quit
[SwitchI] pim vpn-instance a
[SwitchI-pim-a] c-bsr 7.7.7.7
[SwitchI-pim-a] c-rp 7.7.7.7
[SwitchI-pim-a] quit
[SwitchI] multicast routing vpn-instance a
[SwitchI-mrib-a] quit
[SwitchI] evpn edge group 2.2.1.1
[SwitchI] multicast-vpn vxlan edge remote 6.6.6.6
[SwitchI] multicast-vpn vxlan vpn-instance a mode mdt
[SwitchI-mvxlan-a] address-family ipv4
[SwitchI-mvxlan-a-ipv4] default-group 236.0.0.0
[SwitchI-mvxlan-a-ipv4] source loopback 0
[SwitchI-mvxlan-a-ipv4] data-group 239.0.0.0 30
[SwitchI-mvxlan-a-ipv4] dci enable
[SwitchI-mvxlan-a-ipv4] quit
[SwitchI-mvxlan-a] quit
# Configure a routing policy. Configure Switch I to not forward the SMET and S-PMSI routes received from Switch D, Switch E, and Switch F to Switch K. Configure Switch I to not forward the SMET and S-PMSI routes received from Switch K to Switch D, Switch E, and Switch F.
[SwitchI] ip prefix-list 0 index 10 permit 0.0.0.0 0 less-equal 32
[SwitchI] ip prefix-list 1 index 10 permit 3.3.3.3 32
[SwitchI] ip prefix-list 1 index 20 permit 4.4.4.4 32
[SwitchI] ip prefix-list 1 index 30 permit 5.5.5.5 32
[SwitchI] ip prefix-list 3 index 10 permit 9.9.9.9 32
[SwitchI] route-policy dc1 deny node 0
[SwitchI-route-policy-dc1-0] if-match ip route-source prefix-list 3
[SwitchI-route-policy-dc1-0] if-match route-type bgp-evpn-smet bgp-evpn-s-pmsi
[SwitchI-route-policy-dc1-0] route-policy dc1 permit node 1
[SwitchI-route-policy-dc1-1] if-match ip route-source prefix-list 0
[SwitchI-route-policy-dc1-1] route-policy dc3 deny node 0
[SwitchI-route-policy-dc3-0] if-match ip route-source prefix-list 1
[SwitchI-route-policy-dc3-0] if-match route-type bgp-evpn-smet bgp-evpn-s-pmsi
[SwitchI-route-policy-dc3-0] route-policy dc3 permit node 1
[SwitchI-route-policy-dc3-1] if-match ip route-source prefix-list 0
[SwitchI-route-policy-dc3-1] quit
# Configure a routing policy to change the next hop of the S-PMSI routes sent from Switch I to Switch J to 7.7.7.7.
[SwitchI] route-policy rt_spmsi permit node 0
[SwitchI-route-policy-rt_spmsi-0] if-match route-type bgp-evpn-s-pmsi
[SwitchI-route-policy-rt_spmsi-0] apply ip-address next-hop 7.7.7.7
[SwitchI-route-policy-rt_spmsi-0] route-policy rt_spmsi permit node 1
[SwitchI-route-policy-rt_spmsi-1] quit
[SwitchI] bgp 200
[SwitchI-bgp-default] group ED1 external
[SwitchI-bgp-default] peer ED1 as-number 100
[SwitchI-bgp-default] peer ED1 connect-interface loopback 0
[SwitchI-bgp-default] peer ED1 ebgp-max-hop 64
[SwitchI-bgp-default] peer 3.3.3.3 group ED1
[SwitchI-bgp-default] peer 4.4.4.4 group ED1
[SwitchI-bgp-default] peer 5.5.5.5 group ED1
[SwitchI-bgp-default] peer 6.6.6.6 as-number 200
[SwitchI-bgp-default] peer 6.6.6.6 connect-interface loopback 0
[SwitchI-bgp-default] peer 8.8.8.8 as-number 200
[SwitchI-bgp-default] peer 8.8.8.8 connect-interface loopback 0
[SwitchI-bgp-default] peer 9.9.9.9 as-number 300
[SwitchI-bgp-default] peer 9.9.9.9 connect-interface loopback 0
[SwitchI-bgp-default] peer 9.9.9.9 ebgp-max-hop 64
[SwitchI-bgp-default] address-family l2vpn evpn
[SwitchI-bgp-default-evpn] peer ED1 enable
[SwitchI-bgp-default-evpn] peer ED1 route-policy dc1 export
[SwitchI-bgp-default-evpn] peer ED1 router-mac-local
[SwitchI-bgp-default-evpn] peer 6.6.6.6 enable
[SwitchI-bgp-default-evpn] peer 6.6.6.6 next-hop-local
[SwitchI-bgp-default-evpn] peer 8.8.8.8 enable
[SwitchI-bgp-default-evpn] peer 8.8.8.8 route-policy rt_spmsi export
[SwitchI-bgp-default-evpn] peer 8.8.8.8 next-hop-local
[SwitchI-bgp-default-evpn] peer 9.9.9.9 enable
[SwitchI-bgp-default-evpn] peer 9.9.9.9 route-policy dc3 export
[SwitchI-bgp-default-evpn] peer 9.9.9.9 router-mac-local
[SwitchI-bgp-default-evpn] quit
[SwitchI-bgp-default] quit
11.     Configure Switch J:
# Enable L2VPN and IP multicast routing, start an OSPF process, and create VLAN 33.
<SwitchJ> system-view
[SwitchJ] l2vpn enable
[SwitchJ] multicast routing
[SwitchJ-mrib] quit
[SwitchJ] pim
[SwitchJ-pim] quit
[SwitchJ] ospf 1
[SwitchJ-ospf-1] area 0.0.0.0
[SwitchJ-ospf-1- area-0.0.0.0] quit
[SwitchJ] vlan 33
[SwitchJ-vlan33] quit
[SwitchJ] igmp-snooping
[SwitchJ-igmp-snooping] quit
[SwitchJ] interface loopback 0
[SwitchJ-LoopBack0] ip address 8.8.8.8 32
[SwitchJ-LoopBack0] pim sm
[SwitchJ-LoopBack0] ospf 1 area 0.0.0.0
[SwitchJ-LoopBack0] quit
[SwitchJ] vxlan default-decapsulation source interface loopback 0
[SwitchJ] vsi 1
[SwitchJ-vsi-1] evpn encapsulation vxlan
[SwitchJ-vsi-1-evpn-vxlan] route-distinguisher auto
[SwitchJ-vsi-1-evpn-vxlan] vpn-target auto export-extcommunity
[SwitchJ-vsi-1-evpn-vxlan] vpn-target auto import-extcommunity [SwitchJ-vsi-1-evpn-vxlan] quit
[SwitchJ-vsi-1] igmp-snooping enable
# Create VXLAN 10.
[SwitchJ-vsi-1] vxlan 10
[SwitchJ-vsi-1-vxlan-10] quit
# Configure BGP to advertise BGP EVPN routes.
[SwitchJ] bgp 200
[SwitchJ-bgp-default] group ed internal
[SwitchJ-bgp-default] peer ed connect-interface loopback 0
[SwitchJ-bgp-default] peer 6.6.6.6 group ed
[SwitchJ-bgp-default] peer 7.7.7.7 group ed
[SwitchJ-bgp-default] address-family l2vpn evpn
[SwitchJ-bgp-default-evpn] peer ed enable
[SwitchJ-bgp-default-evpn] peer ed next-hop-local
[SwitchJ-bgp-default-evpn] peer ed additional-paths receive
[SwitchJ-bgp-default-evpn] quit
[SwitchJ-bgp-default] quit
# On server-facing interface Ten-GigabitEthernet 1/0/1, create Ethernet service instance 33 to match VLAN 33.
[SwitchJ] interface ten-gigabitethernet 1/0/1
[SwitchJ-Ten-GigabitEthernet1/0/1] port link-mode bridge
[SwitchJ-Ten-GigabitEthernet1/0/1] port link-type trunk
[SwitchJ-Ten-GigabitEthernet1/0/1] port trunk permit vlan 1 33
[SwitchJ-Ten-GigabitEthernet1/0/1] service-instance 33
[SwitchJ-Ten-GigabitEthernet1/0/1-srv33] encapsulation s-vid 33
# Map Ethernet service instance 33 to VSI 1.
[SwitchJ-Ten-GigabitEthernet1/0/1-srv33] xconnect vsi 1
[SwitchJ-Ten-GigabitEthernet1/0/1-srv33] quit
[SwitchJ-Ten-GigabitEthernet1/0/1] quit
[SwitchJ] ip vpn-instance a
[SwitchJ-vpn-instance-a] route-distinguisher 8:8
[SwitchJ-vpn-instance-a] vpn-target 1:1 import-extcommunity
[SwitchJ-vpn-instance-a] vpn-target 1:1 export-extcommunity
[SwitchJ-vpn-instance-a] quit
# Configure VSI-interface 1.
[SwitchJ] interface vsi-interface 1
[SwitchJ-Vsi-interface1] ip binding vpn-instance a
[SwitchJ-Vsi-interface1] ip address 10.0.0.1 255.255.255.0
[SwitchJ-Vsi-interface1] pim sm
[SwitchJ-Vsi-interface1] igmp enable
[SwitchJ-Vsi-interface1] mac-address 0001-0001-0001
[SwitchJ-Vsi-interface1] distributed-gateway local
[SwitchJ-Vsi-interface1] quit
[SwitchJ] interface vsi-interface 2
[SwitchJ-Vsi-interface2] ip binding vpn-instance a
[SwitchJ-Vsi-interface2] l3-vni 1000
[SwitchJ-Vsi-interface2] pim sm
[SwitchJ-Vsi-interface2] quit
[SwitchJ] multicast routing vpn-instance a
[SwitchJ-mrib-a] quit
[SwitchJ] multicast-vpn vxlan vpn-instance a mode mdt
[SwitchJ-mvxlan-a] address-family ipv4
[SwitchJ-mvxlan-a-ipv4] source loopback 0
[SwitchJ-mvxlan-a-ipv4] quit
[SwitchJ-mvxlan-a] quit
[SwitchJ] interface loopback 1
[SwitchJ-LoopBack1] ip binding vpn-instance a
[SwitchJ-LoopBack1] ip address 8.8.8.8 32
[SwitchJ-LoopBack1] pim sm
[SwitchJ-LoopBack1] quit
[SwitchJ] pim vpn-instance a
[SwitchJ-pim-a] c-bsr 8.8.8.8
[SwitchJ-pim-a] c-rp 8.8.8.8
[SwitchJ-pim-a] quit
[SwitchJ] vsi 1
[SwitchJ-vsi-1] gateway vsi-interface 1
[SwitchJ-vsi-1] quit
12.     Configure Switch K:
<SwitchK> system-view
[SwitchK] l2vpn enable
[SwitchK] multicast routing
[SwitchK-mrib] quit
[SwitchK] pim
[SwitchK-pim] quit
[SwitchK] ospf 1
[SwitchK-ospf-1] area 0.0.0.0
[SwitchK-ospf-1-area-0.0.0.0] quit
[SwitchK] rip 1
[SwitchK-rip-1] network 9.0.0.0
[SwitchK-rip-1] network 119.0.0.0
[SwitchK-rip-1] quit
[SwitchK] igmp-snooping
[SwitchK-igmp-snooping] quit
[SwitchK] interface loopback 0
[SwitchK-LoopBack0] ip address 9.9.9.9 32
[SwitchK-LoopBack0] rip 1 enable
[SwitchK-LoopBack0] ospf 1 area 0.0.0.0
[SwitchK-LoopBack0] quit
[SwitchK] interface vlan-interface 9
[SwitchK-Vlan-interface9] rip 1 enable
[SwitchK-Vlan-interface9] dci enable
[SwitchK-Vlan-interface9] quit
[SwitchK] ip vpn-instance a
[SwitchK-vpn-instance-a] route-distinguisher 9:9
[SwitchK-vpn-instance-a] vpn-target 1:1 import-extcommunity
[SwitchK-vpn-instance-a] vpn-target 1:1 export-extcommunity
[SwitchK-vpn-instance-a] quit
[SwitchK] interface vsi-interface 2
[SwitchK-Vsi-interface2] ip binding vpn-instance a
[SwitchK-Vsi-interface2] l3-vni 1000
[SwitchK-Vsi-interface2] pim sm
[SwitchK-Vsi-interface2] quit
[SwitchK] interface loopback 1
[SwitchK-LoopBack1] ip binding vpn-instance a
[SwitchK-LoopBack1] ip address 9.9.9.9 32
[SwitchK-LoopBack1] pim sm
[SwitchK-LoopBack1] quit
[SwitchK] pim vpn-instance a
[SwitchK-pim-a] c-bsr 9.9.9.9
[SwitchK-pim-a] c-rp 9.9.9.9
[SwitchK-pim-a] quit
[SwitchK] multicast routing vpn-instance a
[SwitchK-mrib-a] quit
[SwitchK] multicast-vpn vxlan vpn-instance a mode mdt
[SwitchK-mvxlan-a] address-family ipv4
[SwitchK-mvxlan-a-ipv4] default-group 236.0.0.0
[SwitchK-mvxlan-a-ipv4] source loopback 0
[SwitchK-mvxlan-a-ipv4] data-group 239.0.0.0 30
[SwitchK-mvxlan-a-ipv4] dci enable
[SwitchK-mvxlan-a-ipv4] quit
[SwitchK-mvxlan-a] quit
# Configure a routing policy. Configure Switch K to not forward the SMET and S-PMSI routes received from Switch H and Switch I to Switch D, Switch E, and Switch F. Configure Switch K to not forward the SMET and S-PMSI routes received from Switch D, Switch E, and Switch F to Switch H and Switch I.
[SwitchK] ip prefix-list 0 index 10 permit 0.0.0.0 0 less-equal 32
[SwitchK] ip prefix-list 1 index 10 permit 3.3.3.3 32
[SwitchK] ip prefix-list 1 index 20 permit 4.4.4.4 32
[SwitchK] ip prefix-list 1 index 30 permit 5.5.5.5 32
[SwitchK] ip prefix-list 2 index 10 permit 6.6.6.6 32
[SwitchK] ip prefix-list 2 index 10 permit 7.7.7.7 32
[SwitchK] route-policy dc1 deny node 0
[SwitchK-route-policy-dc1-0] if-match ip route-source prefix-list 2
[SwitchK-route-policy-dc1-0] if-match route-type bgp-evpn-smet bgp-evpn-s-pmsi
[SwitchK-route-policy-dc1-0] route-policy dc1 permit node 1
[SwitchK-route-policy-dc1-1] if-match ip route-source prefix-list 0
[SwitchK-route-policy-dc1-1] route-policy dc2 deny node 0
[SwitchK-route-policy-dc2-0] if-match ip route-source prefix-list 1
[SwitchK-route-policy-dc2-0] if-match route-type bgp-evpn-smet bgp-evpn-s-pmsi
[SwitchK-route-policy-dc2-0] route-policy dc2 permit node 1
[SwitchK-route-policy-dc2-1] if-match ip route-source prefix-list 0
[SwitchK-route-policy-dc2-1] quit
[SwitchK] bgp 300
[SwitchK-bgp-default] group ED1 external
[SwitchK-bgp-default] peer ED1 as-number 100
[SwitchK-bgp-default] peer ED1 connect-interface loopback 0
[SwitchK-bgp-default] peer ED1 ebgp-max-hop 64
[SwitchK-bgp-default] group ED2 external
[SwitchK-bgp-default] peer ED2 as-number 100
[SwitchK-bgp-default] peer ED2 connect-interface loopback 0
[SwitchK-bgp-default] peer ED2 ebgp-max-hop 64
[SwitchK-bgp-default] peer 3.3.3.3 group ED1
[SwitchK-bgp-default] peer 4.4.4.4 group ED1
[SwitchK-bgp-default] peer 5.5.5.5 group ED1
[SwitchK-bgp-default] peer 6.6.6.6 group ED2
[SwitchK-bgp-default] peer 7.7.7.7 group ED2
[SwitchK-bgp-default] peer 10.10.10.10 as-number 300
[SwitchK-bgp-default] peer 10.10.10.10 connect-interface loopback 0
[SwitchK-bgp-default] address-family l2vpn evpn
[SwitchK-bgp-default-evpn] peer ED1 enable
[SwitchK-bgp-default-evpn] peer ED1 route-policy dc1 export
[SwitchK-bgp-default-evpn] peer ED1 router-mac-local
[SwitchK-bgp-default-evpn] peer ED2 enable
[SwitchK-bgp-default-evpn] peer ED2 route-policy dc2 export
[SwitchK-bgp-default-evpn] peer ED2 router-mac-local
[SwitchK-bgp-default-evpn] peer 10.10.10.10 enable
[SwitchK-bgp-default-evpn] peer 10.10.10.10 next-hop-local
[SwitchK-bgp-default-evpn] quit
[SwitchK-bgp-default] quit
13.     Configure Switch L:
# Enable L2VPN and IP multicast routing, start an OSPF process, and create VLAN 44.
<SwitchL> system-view
[SwitchL] l2vpn enable
[SwitchL] multicast routing
[SwitchL-mrib] quit
[SwitchL] pim
[SwitchL-pim] quit
[SwitchL] ospf 1
[SwitchL-ospf-1] area 0.0.0.0
[SwitchL-ospf-1-area-0.0.0.0] quit
[SwitchL] vlan 44
[SwitchL-vlan44] quit
[SwitchL] igmp-snooping
[SwitchL-igmp-snooping] quit
[SwitchL] interface loopback 0
[SwitchL-LoopBack0] ip address 10.10.10.10 32
[SwitchL-LoopBack0] pim sm
[SwitchL-LoopBack0] ospf 1 area 0.0.0.0
[SwitchL-LoopBack0] quit
[SwitchL] vsi 1
[SwitchL-vsi-1] evpn encapsulation vxlan
[SwitchL-vsi-1-evpn-vxlan] route-distinguisher auto
[SwitchL-vsi-1-evpn-vxlan] vpn-target auto export-extcommunity
[SwitchL-vsi-1-evpn-vxlan] vpn-target auto import-extcommunity [SwitchL-vsi-1-evpn-vxlan] quit
[SwitchL-vsi-1] igmp-snooping enable
# Create VXLAN 10.
[SwitchL-vsi-1] vxlan 10
[SwitchL-vsi-1-vxlan-10] quit
[SwitchL] bgp 300
[SwitchL-bgp-default] peer 9.9.9.9 as-number 300
[SwitchL-bgp-default] peer 9.9.9.9 connect-interface loopback 0
[SwitchL-bgp-default] address-family l2vpn evpn
[SwitchL-bgp-default-evpn] peer 9.9.9.9 enable
[SwitchL-bgp-default-evpn] peer 9.9.9.9 next-hop-local
[SwitchL-bgp-default-evpn] quit
[SwitchL-bgp-default] quit
# On server-facing interface Ten-GigabitEthernet 1/0/2, create Ethernet service instance 44 to match VLAN 44.
[SwitchL] interface ten-gigabitethernet 1/0/2
[SwitchL-Ten-GigabitEthernet1/0/2] port link-mode bridge
[SwitchL-Ten-GigabitEthernet1/0/2] port link-type trunk
[SwitchL-Ten-GigabitEthernet1/0/2] port trunk permit vlan 1 44
[SwitchL-Ten-GigabitEthernet1/0/2] service-instance 44
[SwitchL-Ten-GigabitEthernet1/0/2-srv44] encapsulation s-vid 44
# Map Ethernet service instance 44 to VSI 1.
[SwitchL-Ten-GigabitEthernet1/0/2-srv44] xconnect vsi 1
[SwitchL-Ten-GigabitEthernet1/0/2-srv44] quit
[SwitchL-Ten-GigabitEthernet1/0/2] quit
[SwitchL] ip vpn-instance a
[SwitchL-vpn-instance-a] route-distinguisher 10:10
[SwitchL-vpn-instance-a] vpn-target 1:1 import-extcommunity
[SwitchL-vpn-instance-a] vpn-target 1:1 export-extcommunity
[SwitchL-vpn-instance-a] quit
[SwitchL] interface vsi-interface 1
[SwitchL-Vsi-interface1] ip binding vpn-instance a
[SwitchL-Vsi-interface1] ip address 10.0.0.1 255.255.255.0
[SwitchL-Vsi-interface1] pim sm
[SwitchL-Vsi-interface1] igmp enable
[SwitchL-Vsi-interface1] mac-address 0001-0001-0001
[SwitchL-Vsi-interface1] distributed-gateway local
[SwitchL-Vsi-interface1] quit
[SwitchL] interface vsi-interface 2
[SwitchL-Vsi-interface2] ip binding vpn-instance a
[SwitchL-Vsi-interface2] l3-vni 1000
[SwitchL-Vsi-interface2] pim sm
[SwitchL-Vsi-interface2] quit
[SwitchL] multicast routing vpn-instance a
[SwitchL-mrib-vpn1] quit
[SwitchL] multicast-vpn vxlan vpn-instance a mode mdt
[SwitchL-mvxlan-a] address-family ipv4
[SwitchL-mvxlan-a-ipv4] source loopback 0
[SwitchL-mvxlan-a-ipv4] quit
[SwitchL-mvxlan-a] quit
[SwitchL] interface loopback 1
[SwitchL-LoopBack1] ip binding vpn-instance a
[SwitchL-LoopBack1] ip address 10.10.10.10 32
[SwitchL-LoopBack1] pim sm
[SwitchL-LoopBack1] quit
[SwitchL] pim vpn-instance a
[SwitchL-pim-a] c-bsr 10.10.10.10
[SwitchL-pim-a] c-rp 10.10.10.10
[SwitchL-pim-a] quit
[SwitchL] vsi 1
[SwitchL-vsi-1] gateway vsi-interface 1
[SwitchL-vsi-1] quit
1.     Verify the multicast routing information on the VTEPs:
# Verify that Switch A has multicast routing entries for VPN instance a and the public network.
<SwitchA> display pim vpn-instance a routing-table
 (*, 225.0.0.1)
     RP: 1.1.1.1 (local)
     UpTime: 00:00:31
         Upstream neighbor: NULL
         RPF prime neighbor: NULL
     Downstream interface information:
         1: MTunnel0
             Protocol: MD, UpTime: 00:00:31, Expires: -
 (10.0.0.2, 225.0.0.1)
     RP: 1.1.1.1 (local)
     UpTime: 00:00:32
         1: MTunnel1
             Protocol: MD, UpTime: 00:00:26, Expires: -
 Total 0 (*, G) entries; 6 (S, G) entries
 (1.1.1.1, 236.0.0.0)
     RP: NULL
     UpTime: 00:03:31
     Upstream interface: MTunnel0 (VPN: a)
         1: Vlan-interface10
             Protocol: pim-sm, UpTime: 00:01:53, Expires: 00:02:38
 (2.2.2.2, 236.0.0.0)
     RP: NULL
     UpTime: 00:01:47
         Upstream neighbor: 121.121.121.12
         RPF prime neighbor: 121.121.121.12
         1: MVXLAN-UPE0
             Protocol: MD, UpTime: 00:01:47, Expires: -
 (3.3.3.3, 236.0.0.0)
     RP: NULL
     UpTime: 00:01:53
         1: MVXLAN-UPE0
             Protocol: MD, UpTime: 00:01:53, Expires: -
 (4.4.4.4, 236.0.0.0)
     RP: NULL
     UpTime: 00:01:47
         1: MVXLAN-UPE0
 (5.5.5.5, 236.0.0.0)
     RP: NULL
     UpTime: 00:01:47
         1: MVXLAN-UPE0
 (1.1.1.1, 239.0.0.0)
     RP: NULL
     UpTime: 00:00:51
     Upstream interface: MTunnel1 (VPN: a)
         1: Vlan-interface10
             Protocol: pim-sm, UpTime: 00:00:51, Expires: 00:02:40
# Verify that Switch J has multicast routing entries for VPN instance a and the public network. Use the same method to display multicast routing entries on Switch B and Switch L.
<SwitchJ> display pim vpn-instance a routing-table
 (*, 225.0.0.1)
     RP: 8.8.8.8 (local)
     UpTime: 00:12:32
         1: Vsi-interface1
             Protocol: igmp, UpTime: 00:12:32, Expires: -
         2: MTunnel0
             Protocol: MD, UpTime: 00:12:31, Expires: -
     RP: 8.8.8.8 (local)
     Protocol: pim-sm, Flag: SPT 2MSDP ACT RQ SRC-ACT 2MVPN FROMVXLAN
     UpTime: 00:12:30
         1: Vsi-interface1
             Protocol: pim-sm, UpTime: 00:12:21, Expires: -
<SwitchJ> display pim routing-table
 Total 0 (*, G) entries; 5 (S, G) entries
 (6.6.6.6, 236.0.0.0)
     RP: NULL
     UpTime: 00:19:27
     Upstream interface: Vlan-interface300
         Upstream neighbor: 68.68.68.68
         RPF prime neighbor: 68.68.68.68
         1: MVXLAN-UPE0
             Protocol: MD, UpTime: 00:19:27, Expires: -
 (7.7.7.7, 236.0.0.0)
     RP: NULL
     UpTime: 00:19:29
     Upstream interface: Vlan-interface200
         Upstream neighbor: 78.78.78.78
         RPF prime neighbor: 78.78.78.78
         1: MVXLAN-UPE0
             Protocol: MD, UpTime: 00:19:29, Expires: -
 (8.8.8.8, 236.0.0.0)
     RP: NULL
     UpTime: 00:20:26
         1: Vlan-interface200
             Protocol: pim-sm, UpTime: 00:19:29, Expires: 00:02:31
         2: Vlan-interface300
             Protocol: pim-sm, UpTime: 00:19:27, Expires: 00:02:56
 (6.6.6.6, 239.0.0.0)
     RP: NULL
     UpTime: 00:18:04
         1: MVXLAN-UPE0
             Protocol: MD, UpTime: 00:18:04, Expires: -
 (7.7.7.7, 239.0.0.0)
     RP: NULL
     UpTime: 00:18:04
         1: MVXLAN-UPE0
2.     Verify the multicast routing information on the EDs:
# Verify that Switch D has multicast routing entries for VPN instance a and the public network. Use the same method to display multicast routing entries on Switch E and Switch F.
<SwitchD> display pim vpn-instance a routing-table
 (*, 225.0.0.1)
     RP: 3.3.3.3 (local)
     UpTime: 00:20:48
         1: Vsi-interface2
             Protocol: MD, UpTime: 00:20:48, Expires: -
         2: MTunnel0
     RP: 3.3.3.3 (local)
     UpTime: 00:20:47
         1: Vsi-interface2
             Protocol: MD, UpTime: 00:20:47, Expires: -
<SwitchD> display pim routing-table
 Total 0 (*, G) entries; 4 (S, G) entries
     RP: NULL
     UpTime: 00:23:32
         Upstream neighbor: 123.123.123.12
         RPF prime neighbor: 123.123.123.12
         1: MVXLAN-UPE0
             Protocol: MD, UpTime: 00:23:32, Expires: -
     RP: NULL
     UpTime: 00:23:27
         1: MVXLAN-UPE0
             Protocol: MD, UpTime: 00:23:27, Expires: -
     RP: NULL
     UpTime: 00:25:33
         1: Vlan-interface30
             Protocol: pim-sm, UpTime: 00:23:32, Expires: 00:02:58
     RP: NULL
     UpTime: 00:22:31
         1: MVXLAN-UPE0
             Protocol: MD, UpTime: 00:22:31, Expires: -
# Verify the Layer 2 multicast routing entries on Switch D. Use the same method to display Layer 2 multicast routing entries on Switch F.
<SwitchD> display igmp-snooping evpn-group
Total 0 entries.
# Verify that Switch E has forwarded multicast traffic and generated Layer 2 multicast routing entries.
<SwitchE> display igmp-snooping evpn-group
Total 2 entries.
VSI Auto_L3VNI1000_2: Total 2 entries.
  (0.0.0.0, 225.0.0.1)
    Host ports (2 in total):
      Tun0 (VXLAN ID 1000)
      Tun1 (VXLAN ID 1000)
# Verify that Switch H has multicast routing entries for VPN instance a and the public network. The output shows that multicast traffic is forwarded from Switch H to DC 2.
<SwitchH> display pim routing-table
 Total 0 (*, G) entries; 3 (S, G) entries
     RP: NULL
     UpTime: 00:35:01
         1: Vlan-interface300
             Protocol: pim-sm, UpTime: 00:33:54, Expires: 00:02:52
     RP: NULL
     UpTime: 00:33:54
         Upstream neighbor: 68.68.68.86
         RPF prime neighbor: 68.68.68.86
         1: MVXLAN-UPE0
             Protocol: MD, UpTime: 00:33:54, Expires: -
     RP: NULL
     UpTime: 00:32:39
             Protocol: pim-sm, UpTime: 00:32:39, Expires: 00:03:13
<SwitchH> display pim vpn-instance a routing-table
 (*, 225.0.0.1)
     RP: 6.6.6.6 (local)
     UpTime: 00:32:44
         1: Vsi-interface2
             Protocol: MD, UpTime: 00:32:44, Expires: -
         2: MTunnel0
             Protocol: MD, UpTime: 00:32:43, Expires: -
     RP: 6.6.6.6 (local)
     Protocol: pim-sm, Flag: SPT 2MSDP ACT SQ RC SRC-ACT 2MVPN FROMDCI
     UpTime: 00:32:44
     Upstream interface: Vsi-interface2
         1: MTunnel1
             Protocol: MD, UpTime: 00:32:35, Expires: -
# Verify that Switch I has multicast routing entries for VPN instance a and the public network.
<SwitchI> display pim routing-table
     RP: NULL
     UpTime: 00:35:43
             Protocol: pim-sm, UpTime: 00:34:09, Expires: 00:03:21
     RP: NULL
     UpTime: 00:34:09
         Upstream neighbor: 78.78.78.87
         RPF prime neighbor: 78.78.78.87
         1: MVXLAN-UPE0
             Protocol: MD, UpTime: 00:34:09, Expires: -
     RP: NULL
     UpTime: 00:32:51
             Protocol: pim-sm, UpTime: 00:32:51, Expires: 00:02:48
<SwitchI> display pim vpn-instance a routing-table
 (*, 225.0.0.1)
     RP: 7.7.7.7 (local)
     UpTime: 00:32:57
         1: Vsi-interface2
             Protocol: MD, UpTime: 00:32:57, Expires: -
         2: MTunnel0
             Protocol: MD, UpTime: 00:32:56, Expires: -
     RP: 7.7.7.7 (local)
     Protocol: pim-sm, Flag: SPT 2MSDP NIIF SQ RC SRC-ACT
     UpTime: 00:32:57
     Upstream interface: NULL
         1: Vsi-interface2
         2: MTunnel1
             Protocol: MD, UpTime: 00:32:48, Expires: -
Example: Configuring Layer 3 multicast with the same L3 VXLAN ID mapping in a DCI multihoming scenario
As shown in Figure 22, the multicast source of multicast group 225.0.0.1 is attached to Switch A, and the receivers of the multicast group are attached to Switch B, Switch J, and Switch L. Configure Layer 3 multicast in a DCI multihoming scenario as follows:
·     Assign L3 VXLAN IDs 1000, 2000, and 3000 to DC 1, DC 2, and DC 3, respectively, and map all of them to L3 VXLAN ID 4000.
·     On Switch A through Switch L, configure PIM SM on the public-network interfaces used for intra-data center connection. On Switch A, Switch B, Switch J, and Switch L, enable IGMP snooping for multicast entry creation.
Figure 22 Network diagram
Device
IP address
Device
IP address
Switch A
Loop0
1.1.1.1/32
Switch B
Loop0
2.2.2.2/32
Loop1
1.1.1.1/32
Loop1
2.2.2.2/32
Vlan-int10
121.121.121.1/24
XGE1/0/1
XGE1/0/2
Vlan-int20
122.122.122.2/24
VSI-int1
10.0.0.1/24
VSI-int1
10.0.0.1/24
VSI-int2
VSI-int2
Switch C
Loop0
12.12.12.12/32
Switch D
Loop0
3.3.3.3/32
Vlan-int10
121.121.121.12/24
Loop1
3.3.3.3/32
Vlan-int20
122.122.122.12/24
Loop2
3.4.5.0/32
Vlan-int30
123.123.123.12/24
Vlan-int3
113.113.113.3/24
Vlan-int40
124.124.124.12/24
Vlan-int30
123.123.123.3/24
Vlan-int50
125.125.125.12/24
VSI-int2
Switch E
Loop0
4.4.4.4/32
Switch F
Loop0
5.5.5.5/32
Loop1
4.4.4.4/32
Loop1
5.5.5.5/32
Loop2
3.4.5.0/32
Loop2
3.4.5.0/32
Vlan-int4
114.114.114.4/24
Vlan-int50
125.125.125.5/24
Vlan-int40
124.124.124.4/24
Vlan-int5
115.115.115.5/24
VSI-int2
VSI-int2
Switch G
Loop0
11.11.11.11/32
Switch J
Loop0
8.8.8.8/32
Vlan-int3
113.113.113.11/24
Loop1
8.8.8.8/32
Vlan-int4
114.114.114.11/24
XGE1/0/1
Vlan-int5
115.115.115.11/24
Vlan-int200
78.78.78.87/24
Vlan-int9
119.119.119.11/24
Vlan-int300
68.68.68.86/24
Vlan-int7
117.117.117.11/24
VSI-int1
10.0.0.1/24
Vlan-int6
116.116.116.11/24
VSI-int2
Switch H
Loop0
6.6.6.6/32
Switch I
Loop0
7.7.7.7/32
Loop1
6.6.6.6/32
Loop1
7.7.7.7/32
Loop2
2.2.1.1/32
Loop2
2.2.1.1/32
Vlan-int300
68.68.68.68/24
Vlan-int7
117.117.117.7/24
Vlan-int6
116.116.116.6/24
Vlan-int200
78.78.78.78/24
VSI-int2
VSI-int2
Switch K
Loop0
9.9.9.9/32
Switch L
Loop0
10.10.10.10/32
Loop1
9.9.9.9/32
Loop1
10.10.10.10/32
Vlan-int100
109.109.109.9/24
Vlan-int100
109.109.109.10/24
Vlan-int9
119.119.119.9/24
XGE1/0/2
VSI-int2
VSI-int1
10.0.0.1/24
VSI-int2
# Assign IP addresses to interfaces, as shown in Figure 22. (Details not shown.)
# Configure OSPF in each data center for the switches in a data center to reach one another. (Details not shown.)
# Enable PIM SM on the VLAN interfaces that interconnect the devices in a data center. (Details not shown.)
# If you enable PIM SM on interfaces connecting EDs, you must use the pim bsr-boundary command configure each ED as a PIM-SM domain border. (Details not shown.)
# Enable L2VPN, IP multicast routing, and OSPF process 1, and create VLAN 11.
[SwitchA] l2vpn enable
[SwitchA-mrib] quit
[SwitchA] pim
[SwitchA-pim] quit
[SwitchA] ospf 1
[SwitchA] vlan 11
[SwitchA-vlan11] quit
[SwitchA] igmp-snooping
[SwitchA-igmp-snooping] quit
[SwitchA-LoopBack0] ip address 1.1.1.1 32
[SwitchA-LoopBack0] ospf 1 area 0.0.0.0
[SwitchA-LoopBack0] quit
[SwitchA] vsi 1
# Create VXLAN 10.
# Configure BGP to advertise BGP EVPN routes, and enable the BGP additional path receiving capability.
[SwitchA] bgp 100
[SwitchA-bgp-default] address-family l2vpn evpn
[SwitchA-bgp-default-evpn] quit
[SwitchA-bgp-default] quit
[SwitchA-vpn-instance-a] vpn-target 10:10 import-extcommunity
[SwitchA-vpn-instance-a] vpn-target 10:10 export-extcommunity
[SwitchA] interface vsi-interface 1
[SwitchA-Vsi-interface1] pim sm
[SwitchA-Vsi-interface1] igmp enable
[SwitchA-Vsi-interface1] distributed-gateway local
[SwitchA-Vsi-interface1] quit
[SwitchA] interface vsi-interface 2
[SwitchA-mvxlan-a-ipv4] data-group 239.0.0.0 24
[SwitchA] interface loopback 1
[SwitchA-LoopBack1] ip address 1.1.1.1 32
[SwitchA-LoopBack1] pim sm
[SwitchA-LoopBack1] quit
[SwitchA] vsi 1
# Enable L2VPN, IP multicast routing, and OSPF process 1, and create VLAN 22.
[SwitchB] l2vpn enable
[SwitchB-mrib] quit
[SwitchB] pim
[SwitchB-pim] quit
[SwitchB] ospf 1
[SwitchB-ospf-1] quit
[SwitchB] vlan 22
[SwitchB] igmp-snooping
[SwitchB-igmp-snooping] quit
[SwitchB-LoopBack0] ip address 2.2.2.2 32
[SwitchB-LoopBack0] ospf 1 area 0.0.0.0
[SwitchB-LoopBack0] quit
[SwitchB] vsi 1
# Create VXLAN 10.
[SwitchB] bgp 100
[SwitchB-bgp-default] address-family l2vpn evpn
[SwitchB-bgp-default-evpn] quit
[SwitchB-bgp-default] quit
[SwitchB] interface ten-gigabitethernet 1/0/1
[SwitchB-Ten-GigabitEthernet1/0/1] port link-type trunk
[SwitchB-vpn-instance-a] vpn-target 10:10 import-extcommunity
[SwitchB-vpn-instance-a] vpn-target 10:10 export-extcommunity
[SwitchB] interface vsi-interface 1
[SwitchB-Vsi-interface1] pim sm
[SwitchB-Vsi-interface1] igmp enable
[SwitchB-Vsi-interface1] distributed-gateway local
[SwitchB-Vsi-interface1] quit
[SwitchB] interface vsi-interface 2
[SwitchB-Vsi-interface2] pim sm
[SwitchB-Vsi-interface2] quit
[SwitchB-mvxlan-a-ipv4] default-group 236.0.0.0
[SwitchB-mvxlan-a-ipv4] data-group 239.0.0.0 24
[SwitchB-mvxlan-a-ipv4] s-pmsi advertise source-active
[SwitchB] interface loopback 1
[SwitchB-LoopBack1] ip address 2.2.2.2 32
[SwitchB-LoopBack1] pim sm
[SwitchB-LoopBack1] quit
[SwitchB] vsi 1
# Enable IP multicast routing and OSPF process 1.
[SwitchC] multicast routing
[SwitchC-mrib] quit
[SwitchC] pim
[SwitchC-pim] quit
[SwitchC] ospf 1
[SwitchC-LoopBack0] ospf 1 area 0.0.0.0
[SwitchC-LoopBack0] quit
[SwitchC] bgp 100
[SwitchC-bgp-default] address-family l2vpn evpn
[SwitchC-bgp-default-evpn] quit
[SwitchC-bgp-default] quit
# Enable L2VPN, IP multicast routing, OSPF process 1, and RIP process 1.
<SwitchD> system-view
[SwitchD] l2vpn enable
[SwitchD-mrib] quit
[SwitchD] pim
[SwitchD-pim] quit
[SwitchD] ospf 1
[SwitchD] rip 1
[SwitchD] igmp-snooping
[SwitchD-igmp-snooping] quit
[SwitchD] interface loopback 0
[SwitchD-LoopBack0] ospf 1 area 0.0.0.0
[SwitchD-LoopBack0] quit
# Configure RIP and enable DCI multicast on the interface connected to a peer ED.
[SwitchD-vpn-instance-a] vpn-target 10:10 200:200 300:300 import-extcommunity
[SwitchD-vpn-instance-a] vpn-target 10:10 export-extcommunity
# Configure RD and route target settings for VPN instance b.
[SwitchD] ip vpn-instance b
[SwitchD-vpn-instance-b] route-distinguisher 3:33
[SwitchD-vpn-instance-b] vpn-target 10:10 200:200 300:300 import-extcommunity
[SwitchD-vpn-instance-b] vpn-target 10:10 export-extcommunity
[SwitchD-vpn-instance-b] quit
[SwitchD] interface loopback 1
[SwitchD-LoopBack1] pim sm
[SwitchD-LoopBack1] quit
# Configure Loopback 2.
[SwitchD] interface loopback 2
[SwitchD-LoopBack2] quit
[SwitchD] interface vsi-interface 2
[SwitchD-Vsi-interface2] pim sm
[SwitchD-Vsi-interface2] quit
# Create VSI-interface 3, associate the VSI interface with VPN instance b, and configure the L3 VXLAN ID as 4000 for the VPN instance.
[SwitchD] interface vsi-interface 3
[SwitchD-Vsi-interface3] ip binding vpn-instance b
[SwitchD-Vsi-interface3] l3-vni 4000
[SwitchD-Vsi-interface3] pim sm
[SwitchD-Vsi-interface3] quit
# Enable IP multicast routing for VPN instance b.
[SwitchD] multicast routing vpn-instance b
[SwitchD-mrib-b] quit
[SwitchD] pim vpn-instance b
[SwitchD-pim-b] quit
# Create an MDT-based MVXLAN for VPN instance a and enter MVXLAN IPv4 address family view. Configure the default group, MVXLAN source interface, and data group range settings. Enable DCI multicast.
[SwitchD-mvxlan-a-ipv4] data-group 239.0.0.0 24
[SwitchD-route-policy-rt_spmsi-0] route-policy rt_spmsi permit node 1
# Enable BGP to advertise BGP EVPN routes, and configure the device to modify the information in received BGP EVPN routes.
[SwitchD] bgp 100
[SwitchD-bgp-default] address-family l2vpn evpn
[SwitchD-bgp-default-evpn] peer ED2 re-originated replace-rt
[SwitchD-bgp-default-evpn] peer ED2 imet replace-rt
[SwitchD-bgp-default-evpn] peer ED2 mac-ip replace-rt
[SwitchD-bgp-default-evpn] peer ED2 smet replace-rt
[SwitchD-bgp-default-evpn] peer ED2 s-pmsi replace-rt
[SwitchD-bgp-default-evpn] peer 9.9.9.9 re-originated replace-rt
[SwitchD-bgp-default-evpn] peer 9.9.9.9 re-originated mac-ip replace-rt
[SwitchD-bgp-default-evpn] peer 9.9.9.9 re-originated imet replace-rt
[SwitchD-bgp-default-evpn] peer 9.9.9.9 re-originated smet replace-rt
[SwitchD-bgp-default-evpn] peer 9.9.9.9 re-originated s-pmsi replace-rt
[SwitchD-bgp-default-evpn] peer 12.12.12.12 re-originated replace-rt
[SwitchD-bgp-default-evpn] peer 12.12.12.12 re-originated mac-ip replace-rt
[SwitchD-bgp-default-evpn] peer 12.12.12.12 re-originated imet replace-rt
[SwitchD-bgp-default-evpn] peer 12.12.12.12 re-originated smet replace-rt
[SwitchD-bgp-default-evpn] peer 12.12.12.12 re-originated s-pmsi replace-rt
[SwitchD-bgp-default-evpn] quit
[SwitchD-bgp-default] quit
<SwitchE> system-view
[SwitchE] l2vpn enable
[SwitchE-mrib] quit
[SwitchE] pim
[SwitchE-pim] quit
[SwitchE] ospf 1
[SwitchE] rip 1
[SwitchE] igmp-snooping
[SwitchE-igmp-snooping] quit
[SwitchE] interface loopback 0
[SwitchE-LoopBack0] ip address 4.4.4.4 32
[SwitchE-LoopBack0] ospf 1 area 0.0.0.0
[SwitchE-LoopBack0] quit
[SwitchE-Vlan-interface4] quit
[SwitchE-vpn-instance-a] vpn-target 10:10 200:200 300:300 import-extcommunity
[SwitchE-vpn-instance-a] vpn-target 10:10 export-extcommunity
[SwitchE] ip vpn-instance b
[SwitchE-vpn-instance-b] route-distinguisher 4:44
[SwitchE-vpn-instance-b] vpn-target 10:10 200:200 300:300 import-extcommunity
[SwitchE-vpn-instance-b] vpn-target 100:100 export-extcommunity
[SwitchE-vpn-instance-b] quit
[SwitchE] interface loopback 1
[SwitchE-LoopBack1] ip address 4.4.4.4 32
[SwitchE-LoopBack1] pim sm
[SwitchE-LoopBack1] quit
[SwitchE] interface vsi-interface 2
[SwitchE-Vsi-interface2] pim sm
[SwitchE-Vsi-interface2] quit
[SwitchE] interface vsi-interface 3
[SwitchE-Vsi-interface3] ip binding vpn-instance b
[SwitchE-Vsi-interface3] l3-vni 4000
[SwitchE-Vsi-interface3] pim sm
[SwitchE-Vsi-interface3] quit
[SwitchE] multicast routing vpn-instance b
[SwitchE-mrib-b] quit
[SwitchE] pim vpn-instance b
[SwitchE-pim-b] quit
[SwitchE-mvxlan-a-ipv4] data-group 239.0.0.0 24
[SwitchE-route-policy-rt_spmsi-0] route-policy rt_spmsi permit node 1
[SwitchE] bgp 100
[SwitchE-bgp-default] address-family l2vpn evpn
[SwitchE-bgp-default-evpn] peer ED2 re-originated replace-rt
[SwitchE-bgp-default-evpn] peer ED2 imet replace-rt
[SwitchE-bgp-default-evpn] peer ED2 mac-ip replace-rt
[SwitchE-bgp-default-evpn] peer ED2 smet replace-rt
[SwitchE-bgp-default-evpn] peer ED2 s-pmsi replace-rt
[SwitchE-bgp-default-evpn] peer 9.9.9.9 re-originated replace-rt
[SwitchE-bgp-default-evpn] peer 9.9.9.9 re-originated mac-ip replace-rt
[SwitchE-bgp-default-evpn] peer 9.9.9.9 re-originated imet replace-rt
[SwitchE-bgp-default-evpn] peer 9.9.9.9 re-originated smet replace-rt
[SwitchE-bgp-default-evpn] peer 9.9.9.9 re-originated s-pmsi replace-rt
[SwitchE-bgp-default-evpn] peer 12.12.12.12 re-originated replace-rt
[SwitchE-bgp-default-evpn] peer 12.12.12.12 re-originated mac-ip replace-rt
[SwitchE-bgp-default-evpn] peer 12.12.12.12 re-originated imet replace-rt
[SwitchE-bgp-default-evpn] peer 12.12.12.12 re-originated smet replace-rt
[SwitchE-bgp-default-evpn] peer 12.12.12.12 re-originated s-pmsi replace-rt
[SwitchE-bgp-default-evpn] quit
[SwitchE-bgp-default] quit
<SwitchF> system-view
[SwitchF] l2vpn enable
[SwitchF-mrib] quit
[SwitchF] pim
[SwitchF-pim] quit
[SwitchF] ospf 1
[SwitchF] rip 1
[SwitchF] igmp-snooping
[SwitchF-igmp-snooping] quit
# Configure Loopback 0.
[SwitchF] interface loopback 0
[SwitchF-LoopBack0] quit
[SwitchF-Vlan-interface5] quit
# Configure RD and route target settings for VPN instance a.
[SwitchF-vpn-instance-a] vpn-target 10:10 200:200 300:300 import-extcommunity
[SwitchF-vpn-instance-a] vpn-target 10:10 export-extcommunity
[SwitchF] ip vpn-instance b
[SwitchF-vpn-instance-b] route-distinguisher 5:55
[SwitchF-vpn-instance-b] vpn-target 10:10 200:200 300:300 import-extcommunity
[SwitchF-vpn-instance-b] vpn-target 100:100 export-extcommunity
[SwitchF-vpn-instance-b] quit
[SwitchF] interface loopback 1
[SwitchF-LoopBack1] quit
[SwitchF] interface loopback 2
[SwitchF-LoopBack2] quit
# Create VSI-interface 2, associate the VSI interface with VPN instance a, and configure the L3 VXLAN ID as 1000 for the VPN instance.
[SwitchF] interface vsi-interface 3
[SwitchF-Vsi-interface2] ip binding vpn-instance b
[SwitchF-Vsi-interface2] l3-vni 4000
# Enable IP multicast routing for VPN instance a.
# Enter VPN instance PIM view, and configure Loopback 1 as a candidate-BSR and candidate-RP in VPN instance a.
[SwitchF] multicast routing vpn-instance b
[SwitchF-mrib-b] quit
[SwitchF] pim vpn-instance b
[SwitchF-pim-b] quit
[SwitchF-mvxlan-a-ipv4] data-group 239.0.0.0 24
[SwitchF-route-policy-rt_spmsi-0] quit
[SwitchF] bgp 100
[SwitchF-bgp-default] address-family l2vpn evpn
[SwitchF-bgp-default-evpn] peer ED2 re-originated replace-rt
[SwitchF-bgp-default-evpn] peer ED2 imet replace-rt
[SwitchF-bgp-default-evpn] peer ED2 mac-ip replace-rt
[SwitchF-bgp-default-evpn] peer ED2 smet replace-rt
[SwitchF-bgp-default-evpn] peer ED2 s-pmsi replace-rt
[SwitchF-bgp-default-evpn] peer 9.9.9.9 re-originated replace-rt
[SwitchF-bgp-default-evpn] peer 9.9.9.9 re-originated mac-ip replace-rt
[SwitchF-bgp-default-evpn] peer 9.9.9.9 re-originated imet replace-rt
[SwitchF-bgp-default-evpn] peer 9.9.9.9 re-originated smet replace-rt
[SwitchF-bgp-default-evpn] peer 9.9.9.9 re-originated s-pmsi replace-rt
[SwitchF-bgp-default-evpn] peer 12.12.12.12 re-originated replace-rt
[SwitchF-bgp-default-evpn] peer 12.12.12.12 re-originated mac-ip replace-rt
[SwitchF-bgp-default-evpn] peer 12.12.12.12 re-originated imet replace-rt
[SwitchF-bgp-default-evpn] peer 12.12.12.12 re-originated smet replace-rt
[SwitchF-bgp-default-evpn] peer 12.12.12.12 re-originated s-pmsi replace-rt
[SwitchF-bgp-default-evpn] quit
[SwitchF-bgp-default] quit
# Configure RIP process 1.
[SwitchG] rip 1
# Enable RIP on the interfaces connected to EDs.
[SwitchH-mrib] quit
[SwitchH] pim
[SwitchH-pim] quit
[SwitchH] ospf 1
[SwitchH] rip 1
[SwitchH-vpn-instance-a] vpn-target 20:20 100:100 300:300 import-extcommunity
[SwitchH-vpn-instance-a] vpn-target 200:200 export-extcommunity
[SwitchH] ip vpn-instance b
[SwitchH-vpn-instance-b] route-distinguisher 6:66
[SwitchH-vpn-instance-b] vpn-target 20:20 100:100 300:300 import-extcommunity
[SwitchH-vpn-instance-b] vpn-target 200:200 export-extcommunity
[SwitchH-vpn-instance-b] quit
# Create VSI-interface 2, associate the VSI interface with VPN instance a, and configure the L3 VXLAN ID as 2000 for the VPN instance.
[SwitchH-Vsi-interface2] l3-vni 2000
# Create VSI-interface 3, associate the VSI interface with VPN instance b and configure the L3 VXLAN ID as 4000 for the VPN instance.
[SwitchH] interface vsi-interface 3
[SwitchH-Vsi-interface2] ip binding vpn-instance b
[SwitchH-Vsi-interface2] l3-vni 4000
[SwitchH] multicast routing vpn-instance b
[SwitchH-mrib-b] quit
[SwitchH] pim vpn-instance b
[SwitchH-pim-b] quit
[SwitchH-mvxlan-a-ipv4] data-group 239.0.0.0 24
[SwitchH] bgp 200
[SwitchH-bgp-default-evpn] peer ED1 re-originated mac-ip replace-rt
[SwitchH-bgp-default-evpn] peer ED1 re-originated imet replace-rt
[SwitchH-bgp-default-evpn] peer ED1 re-originated smet replace-rt
[SwitchH-bgp-default-evpn] peer ED1 re-originated s-pmsi replace-rt
[SwitchH-bgp-default-evpn] peer ED1 re-originated replace-rt
[SwitchH-bgp-default-evpn] peer 8.8.8.8 re-originated mac-ip replace-rt
[SwitchH-bgp-default-evpn] peer 8.8.8.8 re-originated imet replace-rt
[SwitchH-bgp-default-evpn] peer 8.8.8.8 re-originated smet replace-rt
[SwitchH-bgp-default-evpn] peer 8.8.8.8 re-originated s-pmsi replace-rt
[SwitchH-bgp-default-evpn] peer 8.8.8.8 re-originated replace-rt
[SwitchH-bgp-default-evpn] peer 9.9.9.9 re-originated mac-ip replace-rt
[SwitchH-bgp-default-evpn] peer 9.9.9.9 re-originated imet replace-rt
[SwitchH-bgp-default-evpn] peer 9.9.9.9 re-originated smet replace-rt
[SwitchH-bgp-default-evpn] peer 9.9.9.9 re-originated s-pmsi replace-rt
[SwitchH-bgp-default-evpn] peer 9.9.9.9 re-originated replace-rt
[SwitchI-mrib] quit
[SwitchI] pim
[SwitchI-pim] quit
[SwitchI] ospf 1
[SwitchI] rip 1
[SwitchI-Vlan-interface7] quit
[SwitchI-vpn-instance-a] vpn-target 20:20 100:100 300:300 import-extcommunity
[SwitchI-vpn-instance-a] vpn-target 20:20 export-extcommunity
[SwitchI] ip vpn-instance b
[SwitchI-vpn-instance-b] route-distinguisher 7:77
[SwitchI-vpn-instance-b] vpn-target 100:100 300:300 20:20 import-extcommunity
[SwitchI-vpn-instance-b] vpn-target 20:20 export-extcommunity
[SwitchI-vpn-instance-b] quit
[SwitchI-Vsi-interface2] l3-vni 2000
[SwitchI] interface vsi-interface 3
[SwitchI-Vsi-interface3] ip binding vpn-instance b
[SwitchI-Vsi-interface3] l3-vni 4000
[SwitchI-Vsi-interface3] pim sm
[SwitchI-Vsi-interface3] quit
[SwitchI] multicast routing vpn-instance b
[SwitchI-mrib-b] quit
[SwitchI] pim vpn-instance b
[SwitchI-pim-b] quit
[SwitchI-mvxlan-a-ipv4] data-group 239.0.0.0 24
[SwitchI-route-policy-rt_spmsi-0] quit
[SwitchI] bgp 200
[SwitchI-bgp-default-evpn] peer ED1 re-originated mac-ip replace-rt
[SwitchI-bgp-default-evpn] peer ED1 re-originated imet replace-rt
[SwitchI-bgp-default-evpn] peer ED1 re-originated smet replace-rt
[SwitchI-bgp-default-evpn] peer ED1 re-originated s-pmsi replace-rt
[SwitchI-bgp-default-evpn] peer ED1 re-originated replace-rt
[SwitchI-bgp-default-evpn] peer 8.8.8.8 re-originated mac-ip replace-rt
[SwitchI-bgp-default-evpn] peer 8.8.8.8 re-originated imet replace-rt
[SwitchI-bgp-default-evpn] peer 8.8.8.8 re-originated smet replace-rt
[SwitchI-bgp-default-evpn] peer 8.8.8.8 re-originated s-pmsi replace-rt
[SwitchI-bgp-default-evpn] peer 8.8.8.8 re-originated replace-rt
[SwitchI-bgp-default-evpn] peer 9.9.9.9 re-originated mac-ip replace-rt
[SwitchI-bgp-default-evpn] peer 9.9.9.9 re-originated imet replace-rt
[SwitchI-bgp-default-evpn] peer 9.9.9.9 re-originated smet replace-rt
[SwitchI-bgp-default-evpn] peer 9.9.9.9 re-originated s-pmsi replace-rt
[SwitchI-bgp-default-evpn] peer 9.9.9.9 re-originated replace-rt
# Enable L2VPN, IP multicast routing, and OSPF process 1, and create VLAN 33.
[SwitchJ-mrib] quit
[SwitchJ] pim
[SwitchJ-pim] quit
[SwitchJ] ospf 1
[SwitchJ-ospf-1-area-0.0.0.0] quit
[SwitchJ] vlan 33
[SwitchJ-vpn-instance-a] vpn-target 20:20 import-extcommunity
[SwitchJ-vpn-instance-a] vpn-target 20:20 export-extcommunity
[SwitchJ-Vsi-interface2] l3-vni 2000
# Create an EVPN instance on VSI 1.
[SwitchJ] vsi 1
# Enable IGMP snooping on VSI 1.
# Create VXLAN 10.
[SwitchJ] bgp 200
[SwitchJ-mvxlan-a-ipv4] default-group 236.0.0.0
[SwitchJ-mvxlan-a-ipv4] data-group 239.0.0.0 24
[SwitchJ-mvxlan-a-ipv4] s-pmsi advertise source-active
# Specify VSI-interface 1 as the gateway interface for VSI 1.
[SwitchJ] vsi 1
[SwitchK-mrib] quit
[SwitchK] pim
[SwitchK-pim] quit
[SwitchK] ospf 1
[SwitchK] rip 1
[SwitchK-vpn-instance-a] vpn-target 30:30 100:100 200:200 import-extcommunity
[SwitchK-vpn-instance-a] vpn-target 30:30 export-extcommunity
[SwitchK] ip vpn-instance b
[SwitchK-vpn-instance-b] route-distinguisher 9:99
[SwitchK-vpn-instance-b] vpn-target 30:30 100:100 200:200 import-extcommunity
[SwitchK-vpn-instance-b] vpn-target 300:300 export-extcommunity
[SwitchK-vpn-instance-b] quit
# Create VSI-interface 2, associate the VSI interface with VPN instance a, and configure the L3 VXLAN ID as 3000 for the VPN instance.
[SwitchK-Vsi-interface2] l3-vni 3000
[SwitchK] multicast routing vpn-instance b
[SwitchK-mrib-b] quit
[SwitchK] pim vpn-instance b
[SwitchK-pim-b] quit
[SwitchK-mvxlan-a-ipv4] data-group 239.0.0.0 24
[SwitchK] bgp 300
[SwitchK-bgp-default] peer ED2 as-number 200
[SwitchK-bgp-default-evpn] peer ED1 re-originated replace-rt
[SwitchK-bgp-default-evpn] peer ED1 re-originated mac-ip replace-rt
[SwitchK-bgp-default-evpn] peer ED1 re-originated imet replace-rt
[SwitchK-bgp-default-evpn] peer ED1 re-originated smet replace-rt
[SwitchK-bgp-default-evpn] peer ED1 re-originated s-pmsi replace-rt
[SwitchK-bgp-default-evpn] peer ED2 re-originated replace-rt
[SwitchK-bgp-default-evpn] peer ED2 re-originated mac-ip replace-rt
[SwitchK-bgp-default-evpn] peer ED2 re-originated imet replace-rt
[SwitchK-bgp-default-evpn] peer ED2 re-originated smet replace-rt
[SwitchK-bgp-default-evpn] peer ED2 re-originated s-pmsi replace-rt
[SwitchK-bgp-default-evpn] peer 10.10.10.10 re-originated replace-rt
[SwitchK-bgp-default-evpn] peer 10.10.10.10 re-originated mac-ip replace-rt
[SwitchK-bgp-default-evpn] peer 10.10.10.10 re-originated imet replace-rt
[SwitchK-bgp-default-evpn] peer 10.10.10.10 re-originated smet replace-rt
[SwitchK-bgp-default-evpn] peer 10.10.10.10 re-originated s-pmsi replace-rt
# Enable L2VPN, IP multicast routing, and OSPF process 1, and create VLAN 44.
[SwitchL-mrib] quit
[SwitchL] pim
[SwitchL-pim] quit
[SwitchL] ospf 1
[SwitchL] vlan 44
[SwitchL-vpn-instance-a] vpn-target 30:30 import-extcommunity
[SwitchL-vpn-instance-a] vpn-target 30:30 export-extcommunity
[SwitchL-Vsi-interface2] l3-vni 3000
[SwitchL] vsi 1
[SwitchL] vsi 1
# Create VXLAN 10.
[SwitchL-mrib-a] quit
# Create an MDT-based MVXLAN for VPN instance a and enter MVXLAN IPv4 address family view. Configure the default group, MVXLAN source interface, and data group range settings, and enable advertising active multicast sources through S-PMSI routes.
[SwitchL-mvxlan-a-ipv4] default-group 236.0.0.0
[SwitchL-mvxlan-a-ipv4] data-group 239.0.0.0 24
[SwitchL-mvxlan-a-ipv4] s-pmsi advertise source-active
[SwitchL] bgp 300
 Total 1 (*, G) entries; 1 (S, G) entries
 (*, 225.0.0.1)
     RP: 1.1.1.1 (local)
     Protocol: pim-sm, Flag: WC RC
     UpTime: 00:00:31
     Upstream interface: Register-Tunnel0
         1: MTunnel0
     RP: 1.1.1.1 (local)
     Protocol: pim-sm, Flag: SPT 2MSDP LOC ACT SQ RC 2MVPN
     UpTime: 00:00:32
     Upstream interface: Vsi-interface1
         1: MTunnel1
<SwitchA> display pim routing-table
     RP: NULL
     Protocol: pim-sm, Flag: SPT LOC VXLAN_L3
     UpTime: 00:03:31
         1: Vlan-interface10
     RP: NULL
     UpTime: 00:01:47
     Upstream interface: Vlan-interface10
         1: MVXLAN-UPE0
     RP: NULL
     UpTime: 00:01:53
         1: MVXLAN-UPE0
     RP: NULL
     UpTime: 00:01:47
         1: MVXLAN-UPE0
     RP: NULL
     UpTime: 00:01:47
         1: MVXLAN-UPE0
     RP: NULL
     UpTime: 00:00:51
         1: Vlan-interface10
 (*, 225.0.0.1)
     RP: 8.8.8.8 (local)
     UpTime: 00:12:32
     Total number of downstream interfaces: 2
         1: Vsi-interface1
         2: MTunnel0
     RP: 8.8.8.8 (local)
     UpTime: 00:12:30
     Upstream interface: MVXLAN-UPE0 (0.0.0.0)
         1: Vsi-interface1
     RP: NULL
     UpTime: 00:19:27
         1: MVXLAN-UPE0
     RP: NULL
     UpTime: 00:19:29
         1: MVXLAN-UPE0
     RP: NULL
     UpTime: 00:20:26
     RP: NULL
     Protocol: pim-sm, Flag: SPT ACT 2MVPN
     UpTime: 00:18:04
         1: MVXLAN-UPE0
     RP: NULL
     UpTime: 00:18:04
         1: MVXLAN-UPE0
# Verify that Switch D has multicast routing entries for VPN instance a, VPN instance b, and the public network. Use the same method to display multicast routing entries on Switch E and Switch F.
 (*, 225.0.0.1)
     RP: 3.3.3.3 (local)
     UpTime: 00:20:48
         1: Vsi-interface2
         2: MTunnel0
     RP: 3.3.3.3 (local)
     UpTime: 00:00:18
         1: Extranet (VPN: b)
             Protocol: MD, UpTime: 00:00:18, Expires: -
[SwitchD]display pim vpn-instance b routing-table
 (*, 225.0.0.1)
     RP: NULL
     Protocol: pim-sm, Flag: WC NIIF
     UpTime: 00:00:12
         1: Vsi-interface3
             Protocol: MD, UpTime: 00:00:12, Expires: -
     RP: NULL
     Protocol: pim-sm, Flag: SPT ACT RQ SRC-ACT 2MVPN
     UpTime: 00:00:12
     Upstream interface: Extranet (VPN: a)
         Upstream neighbor: 127.0.0.1
         RPF prime neighbor: 127.0.0.1
         1: Vsi-interface3
     RP: NULL
     UpTime: 00:23:32
         1: MVXLAN-UPE0
     RP: NULL
     UpTime: 00:23:27
         1: MVXLAN-UPE0
     RP: NULL
     UpTime: 00:25:33
         1: Vlan-interface30
     RP: NULL
     UpTime: 00:22:31
         1: MVXLAN-UPE0
Total 0 entries.
Total 2 entries.
VSI Auto_L3VNI4000_3: Total 2 entries.
      Tun0 (VXLAN ID 4000)
      Tun1 (VXLAN ID 4000)
     RP: NULL
     UpTime: 00:35:01
     RP: NULL
     UpTime: 00:33:54
         1: MVXLAN-UPE0
     RP: NULL
     UpTime: 00:32:39
 (*, 225.0.0.1)
     RP: 6.6.6.6 (local)
     UpTime: 00:05:35
         1: MTunnel0
             Protocol: MD, UpTime: 00:05:35, Expires: -
     RP: 6.6.6.6 (local)
     UpTime: 00:05:35
     Upstream interface: Extranet (VPN: b)
         1: MTunnel1
             Protocol: MD, UpTime: 00:05:33, Expires: -
<SwitchH> display pim vpn-instance b routing-table
 (*, 225.0.0.1)
     RP: NULL
     UpTime: 00:05:40
         1: Vsi-interface3
             Protocol: MD, UpTime: 00:05:40, Expires: -
     RP: NULL
     Protocol: pim-sm, Flag: SPT ACT SRC-ACT FROMDCI
     UpTime: 00:05:40
     Upstream interface: Vsi-interface3
         1: Extranet (VPN: a)
# Verify that Switch I has multicast routing entries for VPN instance a, VPN instance b, and the public network.
     RP: NULL
     UpTime: 00:35:43
     RP: NULL
     UpTime: 00:34:09
         1: MVXLAN-UPE0
     RP: NULL
     UpTime: 00:32:51
 (*, 225.0.0.1)
     RP: 7.7.7.7 (local)
     UpTime: 00:08:06
         1: MTunnel0
             Protocol: MD, UpTime: 00:08:06, Expires: -
     RP: 7.7.7.7 (local)
     Protocol: pim-sm, Flag: SPT 2MSDP SQ RC SRC-ACT
     UpTime: 00:08:06
         1: MTunnel1
             Protocol: MD, UpTime: 00:07:57, Expires: -
<SwitchI> display pim vpn-instance b routing-table
 (*, 225.0.0.1)
     RP: NULL
     UpTime: 00:08:10
         1: Vsi-interface3
             Protocol: MD, UpTime: 00:08:10, Expires: -
     RP: NULL
     Protocol: pim-sm, Flag: SPT NIIF SRC-ACT
     UpTime: 00:08:10
         1: Vsi-interface3
         2: Extranet (VPN: a)
Example: Configuring ED M-LAG without L3 VXLAN ID mapping in a DCI multihoming scenario
As shown in Figure 23, the multicast source is attached to Switch A, and the receiver is attached to Switch G.
·     Switch A is a VTEP in DC 1.
·     Switch B is an RR in DC 1.
·     Switch C and Switch D are EDs in DC 1 and form an M-LAG system.
·     Switch F is an ED in DC 2.
·     Switch E is a common Layer 3 switch for connecting the EDs.
·     Switch G is a VTEP in DC 2.
·     Both DC 1 and DC 2 use L3VNI 1000.
On Switch A through Switch G, configure PIM SM on the public-network interfaces used for intra-data center connection. Enable IGMP snooping on Switch A and Switch C.
Figure 23 Network diagram
Table 2 Interfaces and IP address assignment
Device
IP address
Device
IP address
Switch A
Loop0
1.1.1.1/32
Switch B
Loop0
2.2.2.2/32
Loop1
1.1.1.1/32
Vlan-int10
121.121.121.12/24
Vlan-int10
121.121.121.1/24
Vlan-int30
123.123.123.12/24
VSI-int1
100.1.1.1/24
Vlan-int50
124.124.124.12/24
Switch C
Loop0
3.3.3.3/32
Switch D
Loop0
4.4.4.4/32
Loop1
3.3.3.3/32
Loop1
4.4.4.4/32
Loop2
1.2.3.4/32
Loop2
1.2.3.4/32
Vlan-int3
23.23.23.3/24
Vlan-int5
24.24.24.4/24
Vlan-int30
123.123.123.3/24
Vlan-int50
124.124.124.4/24
Switch E
Loop0
5.5.5.5/32
Switch F
Loop0
6.6.6.6/32
Vlan-int3
23.23.23.5/24
Loop1
6.6.6.6/32
Vlan-int5
24.24.24.5/24
Vlan-int6
26.26.26.6/24
Vlan-int6
26.26.26.5/24
Vlan-int20
68.68.68.68/24
Switch G
Loop0
7.7.7.7/32
Loop1
7.7.7.7/32
Vlan-int20
68.68.68.7/24
VSI-int1
100.1.2.1/24
1.     On the multicast source, specify 100.1.1.1 as the gateway address. On the receiver , specify 100.1.2.1 as the gateway address. (Details not shown.)
2.     Configure IP addresses, PIM SM, and unicast routing settings:
# Assign IP addresses to interfaces, as shown in Figure 23. (Details not shown.)
# Verify that PIM SM is disabled on the VLAN interfaces that interconnect the EDs. (Details not shown.)
3.     Configure Switch A:
# Enable L2VPN, IP multicast routing, and OSPF process 1.
[SwitchA] multicast routing
[SwitchA-mrib] quit
[SwitchA] pim
[SwitchA-pim] quit
[SwitchA] ospf 1
[SwitchA-ospf-1] area 0.0.0.0
# Enable the IGMP snooping feature.
[SwitchA-LoopBack0] pim sm
# Create an EVPN instance on VSI vsi1.
[SwitchA] vsi vsi1
[SwitchA-vsi-vsi1] evpn encapsulation vxlan
[SwitchA-vsi-vsi1-evpn-vxlan] route-distinguisher auto
[SwitchA-vsi-vsi1-evpn-vxlan] vpn-target auto export-extcommunity
[SwitchA-vsi-vsi1-evpn-vxlan] vpn-target auto import-extcommunity [SwitchA-vsi-vsi1-evpn-vxlan] quit
# Enable IGMP snooping on VSI vsi1.
[SwitchA-vsi-vsi1] igmp-snooping enable
# Create VXLAN 10.
[SwitchA-vsi-vsi1] vxlan 10
[SwitchA-vsi-vsi1-vxlan-10] quit
[SwitchA-vsi-vsi1] quit
[SwitchA] bgp 100
[SwitchA-bgp-default] peer 2.2.2.2 as-number 100
[SwitchA-bgp-default] peer 2.2.2.2 connect-interface loopback 0
[SwitchA-bgp-default-evpn] peer 2.2.2.2 enable
[SwitchA-bgp-default-evpn] peer 2.2.2.2 additional-paths receive
# On Ten-GigabitEthernet 1/0/1, create Ethernet service instance 11 to match VLAN 11.
[SwitchA] interface ten-gigabitethernet 1/0/1
[SwitchA-Ten-GigabitEthernet1/0/1] port link-mode bridge
[SwitchA-Ten-GigabitEthernet1/0/1] port link-type trunk
[SwitchA-Ten-GigabitEthernet1/0/1] port trunk permit vlan 1 11
[SwitchA-Ten-GigabitEthernet1/0/1] service-instance 11
[SwitchA-Ten-GigabitEthernet1/0/1-srv11] encapsulation s-vid 11
# Map Ethernet service instance 11 to VSI vsi1.
[SwitchA-Ten-GigabitEthernet1/0/1-srv11] xconnect vsi vsi1
[SwitchA-Ten-GigabitEthernet1/0/1-srv11] quit
# Configure RD and route target settings for VPN instance vpna.
[SwitchA] ip vpn-instance vpna
[SwitchA-vpn-instance-vpna] route-distinguisher 1:1
[SwitchA-vpn-instance-vpna] vpn-target 1:1 import-extcommunity
[SwitchA-vpn-instance-vpna] vpn-target 1:1 export-extcommunity
[SwitchA-vpn-instance-vpna] quit
[SwitchA-Vsi-interface1] ip binding vpn-instance vpna
[SwitchA-Vsi-interface1] ip address 100.1.1.1 255.255.255.0
[SwitchA-Vsi-interface1] mac-address 0001-0001-0001
# Associate VSI-interface 2 with VPN instance vpna, and configure the L3 VXLAN ID as 1000 for the VPN instance.
[SwitchA-Vsi-interface2] ip binding vpn-instance vpna
[SwitchA-Vsi-interface2] l3-vni 1000
[SwitchA-Vsi-interface2] pim sm
[SwitchA-Vsi-interface2] quit
# Enable IP multicast routing for VPN instance vpna.
[SwitchA] multicast routing vpn-instance vpna
[SwitchA-mrib-vpna] quit
# Enter VPN instance PIM view, and configure Loopback 1 as a candidate-BSR and candidate-RP in VPN instance vpna.
[SwitchA] pim vpn-instance vpna
[SwitchA-pim-vpna] c-bsr 1.1.1.1
[SwitchA-pim-vpna] c-rp 1.1.1.1
[SwitchA-pim-vpna] quit
# Create an MDT-based MVXLAN for VPN instance vpna and enter MVXLAN IPv4 address family view. Configure the default group, MVXLAN source interface, and data group range settings, and enable advertising active multicast sources through S-PMSI routes.
[SwitchA] multicast-vpn vxlan vpn-instance vpna mode mdt
[SwitchA-mvxlan-vpna] address-family ipv4
[SwitchA-mvxlan-vpna-ipv4] default-group 236.0.0.0
[SwitchA-mvxlan-vpna-ipv4] source loopback 0
[SwitchA-mvxlan-vpna-ipv4] data-group 239.0.0.0 24
[SwitchA-mvxlan-vpna-ipv4] s-pmsi advertise source-active
[SwitchA-mvxlan-vpna-ipv4] quit
[SwitchA-mvxlan-vpna] quit
[SwitchA-LoopBack1] ip binding vpn-instance vpna
# Specify VSI-interface 1 as the gateway interface for VSI vsi1.
[SwitchA] vsi vsi1
[SwitchA-vsi-vsi1] gateway vsi-interface 1
4.     Configure Switch B:
# Enable IP multicast routing and enable OSPF process 1.
[SwitchB] multicast routing
[SwitchB-mrib] quit
[SwitchB] ospf 1
[SwitchB-ospf-1] area 0.0.0.0
[SwitchB-LoopBack0] pim sm
# Configure BGP to advertise BGP EVPN routes, enable the BGP additional path receiving capability, and set the maximum number of Add-Path optimal routes that can be advertised to the peer group. The maximum number of Add-Path optimal routes must be greater than or equal to the number of peer EDs.
[SwitchB] bgp 100
[SwitchB-bgp-default] group evpn internal
[SwitchB-bgp-default] peer evpn connect-interface loopback 0
[SwitchB-bgp-default] group vtep internal
[SwitchB-bgp-default] peer vtep connect-interface loopback 0
[SwitchB-bgp-default] peer 1.1.1.1 group vtep
[SwitchB-bgp-default] peer 3.3.3.3 group evpn
[SwitchB-bgp-default] peer 4.4.4.4 group evpn
[SwitchB-bgp-default-evpn] undo policy vpn-target
[SwitchB-bgp-default-evpn] additional-paths select-best 2
[SwitchB-bgp-default-evpn] peer evpn enable
[SwitchB-bgp-default-evpn] peer evpn reflect-client
[SwitchB-bgp-default-evpn] peer vtep enable
[SwitchB-bgp-default-evpn] peer vtep reflect-client
[SwitchB-bgp-default-evpn] peer vtep additional-paths send
[SwitchB-bgp-default-evpn] peer vtep advertise additional-paths best 2
5.     Configure Switch C:
[SwitchC] l2vpn enable
[SwitchC-mrib] quit
[SwitchC] pim
[SwitchC-pim] quit
[SwitchC] ospf 1
[SwitchC-ospf-1] area 0.0.0.0
[SwitchC-ospf-1] quit
[SwitchC] rip 1
[SwitchC-rip-1] quit
[SwitchC] igmp-snooping
[SwitchC-igmp-snooping] quit
# On VLAN-interface 3, enable RIP and DCI multicast.
[SwitchC-Vlan-interface3] rip 1 enable
[SwitchC-Vlan-interface3] dci enable
# Specify the virtual ED address as 1.2.3.4.
[SwitchC] evpn m-lag group 1.2.3.4
[SwitchC] ip vpn-instance vpna
[SwitchC-vpn-instance-vpna] route-distinguisher 3:3
[SwitchC-vpn-instance-vpna] vpn-target 1:1 import-extcommunity
[SwitchC-vpn-instance-vpna] vpn-target 1:1 export-extcommunity
[SwitchC-vpn-instance-vpna] quit
[SwitchC-LoopBack0] ip address 3.3.3.3 32
[SwitchC-LoopBack0] rip 1 enable
[SwitchC-LoopBack0] pim sm
[SwitchC] interface loopback 1
[SwitchC-LoopBack1] ip binding vpn-instance vpna
[SwitchC-LoopBack1] ip address 3.3.3.3 32
[SwitchC-LoopBack1] pim sm
[SwitchC-LoopBack1] quit
[SwitchC] interface loopback 2
[SwitchC-LoopBack2] ip address 1.2.3.4 32
[SwitchC-LoopBack2] ospf 1 area 0.0.0.0
[SwitchC-LoopBack2] rip 1 enable
[SwitchC-LoopBack2] quit
# Create VSI-interface 2, associate the VSI interface with VPN instance vpna, and configure the L3 VXLAN ID as 1000 for the VPN instance.
[SwitchC] interface vsi-interface 2
[SwitchC-Vsi-interface2] ip binding vpn-instance vpna
[SwitchC-Vsi-interface2] l3-vni 1000
[SwitchC-Vsi-interface2] pim sm
[SwitchC-Vsi-interface2] quit
# Enable IP multicast routing in VPN instance vpna.
[SwitchC] multicast routing vpn-instance vpna
[SwitchC-mrib-vpna] quit
[SwitchC] pim vpn-instance vpna
[SwitchC-pim-vpna] c-bsr 3.3.3.3
[SwitchC-pim-vpna] c-rp 3.3.3.3
[SwitchC-pim-vpna] quit
# Create an MDT-based MVXLAN for VPN instance vpna and enter MVXLAN IPv4 address family view. Configure the default group, MVXLAN source interface, and data group range settings, and enable DCI multicast.
[SwitchC] multicast-vpn vxlan vpn-instance vpna mode mdt
[SwitchC-mvxlan-vpna] address-family ipv4
[SwitchC-mvxlan-vpna-ipv4] default-group 236.0.0.0
[SwitchC-mvxlan-vpna-ipv4] source loopback 2 evpn-drni-group
[SwitchC-mvxlan-vpna-ipv4] data-group 239.0.0.0 24
[SwitchC-mvxlan-vpna-ipv4] dci enable
# Specify the IP addresses of the member devices in the M-LAG system.
[SwitchC-mvxlan-vpna-ipv4] m-lag local 3.3.3.3 remote 4.4.4.4
[SwitchC-mvxlan-vpna-ipv4] quit
[SwitchC-mvxlan-vpna] quit
# Configure a routing policy, so Switch C modifies the next hop as 3.3.3.3 when sending an S-PMSI route to Switch B.
[SwitchC] route-policy rt_spmsi permit node 0
[SwitchC-route-policy-rt_spmsi-0] if-match route-type bgp-evpn-s-pmsi
[SwitchC-route-policy-rt_spmsi-0] apply ip-address next-hop 3.3.3.3
[SwitchC-route-policy-rt_spmsi-0] quit
[SwitchC] route-policy rt_spmsi permit node 1
[SwitchC-route-policy-rt_spmsi-1] quit
# Configure BGP to advertise BGP EVPN routes, and set the virtual ED address as the next hop for the advertised routes.
[SwitchC] bgp 100
[SwitchC-bgp-default] peer 2.2.2.2 as-number 100
[SwitchC-bgp-default] peer 6.6.6.6 as-number 200
[SwitchC-bgp-default] peer 6.6.6.6 connect-interface loopback 0
[SwitchC-bgp-default] peer 6.6.6.6 ebgp-max-hop 64
[SwitchC-bgp-default-evpn] nexthop evpn-m-lag group-address
[SwitchC-bgp-default-evpn] peer 2.2.2.2 enable
[SwitchC-bgp-default-evpn] peer 2.2.2.2 route-policy rt_spmsi export
[SwitchC-bgp-default-evpn] peer 2.2.2.2 next-hop-local
[SwitchC-bgp-default-evpn] peer 6.6.6.6 enable
[SwitchC-bgp-default-evpn] peer 6.6.6.6 router-mac-local
# Configure Layer 2 dynamic aggregate interface Bridge-Aggregation 9, and specify it as the peer-link interface.
[SwitchC] interface bridge-aggregation 9
[SwitchC-Bridge-Aggregation9] port link-type trunk
[SwitchC-Bridge-Aggregation9] port trunk permit vlan all
[SwitchC-Bridge-Aggregation9] link-aggregation mode dynamic
[SwitchC-Bridge-Aggregation9] port m-lag peer-link 1
[SwitchC-Bridge-Aggregation9] quit
# Assign Ten-GigabitEthernet 1/0/2 to link aggregation group 9.
[SwitchC] interface ten-gigabitethernet 1/0/2
[SwitchC-Ten-GigabitEthernet1/0/2] port link-aggregation group 9
[SwitchC-Ten-GigabitEthernet1/0/2] quit
# Add Ten-GigabitEthernet 1/0/2 to the user-configured list of excluded ports.
[SwitchC] m-lag mad exclude interface ten-gigabitethernet 1/0/1
# Configure M-LAG system settings.
[SwitchC] m-lag restore-delay 180
[SwitchC] m-lag system-mac 0001-0001-0001
[SwitchC] m-lag system-number 1
[SwitchC] m-lag system-priority 10
[SwitchC] m-lag keepalive ip destination 60.1.1.2 source 60.1.1.1
6.     Configure Switch D:
[SwitchD-mrib] quit
[SwitchD] pim
[SwitchD-pim] quit
[SwitchD] ospf 1
[SwitchD-ospf-1] area 0.0.0.0
[SwitchD-ospf-1] quit
[SwitchD] rip 1
[SwitchD-rip-1] quit
# On VLAN-interface 5, enable RIP and DCI multicast.
[SwitchD] interface vlan-interface 5
[SwitchD-Vlan-interface5] rip 1 enable
[SwitchD-Vlan-interface5] dci enable
[SwitchD-Vlan-interface5] quit
[SwitchD] evpn m-lag group 1.2.3.4
[SwitchD] ip vpn-instance vpna
[SwitchD-vpn-instance-vpna] route-distinguisher 3:3
[SwitchD-vpn-instance-vpna] vpn-target 1:1 import-extcommunity
[SwitchD-vpn-instance-vpna] vpn-target 1:1 export-extcommunity
[SwitchD-vpn-instance-vpna] quit
[SwitchD-LoopBack0] ip address 4.4.4.4 32
[SwitchD-LoopBack0] rip 1 enable
[SwitchD-LoopBack0] pim sm
[SwitchD-LoopBack1] ip binding vpn-instance vpna
[SwitchD-LoopBack1] ip address 4.4.4.4 32
[SwitchD-LoopBack2] ip address 1.2.3.4 32
[SwitchD-LoopBack2] ospf 1 area 0.0.0.0
[SwitchD-LoopBack2] rip 1 enable
[SwitchD-Vsi-interface2] ip binding vpn-instance vpna
[SwitchD-Vsi-interface2] l3-vni 1000
[SwitchD] multicast routing vpn-instance vpna
[SwitchD-mrib-vpna] quit
[SwitchD] pim vpn-instance vpna
[SwitchD-pim-vpna] c-bsr 4.4.4.4
[SwitchD-pim-vpna] c-rp 4.4.4.4
[SwitchD-pim-vpna] quit
[SwitchD] multicast-vpn vxlan vpn-instance a mode mdt
[SwitchD-mvxlan-a] address-family ipv4
[SwitchD-mvxlan-a-ipv4] default-group 236.0.0.0
[SwitchD-mvxlan-a-ipv4] source loopback 2 evpn-drni-group
[SwitchD-mvxlan-a-ipv4] dci enable
[SwitchD-mvxlan-a-ipv4] m-lag local 4.4.4.4 remote 3.3.3.3
[SwitchD-mvxlan-a-ipv4] quit
[SwitchD-mvxlan-a] quit
# Configure a routing policy, so Switch D modifies the next hop as 4.4.4.4 when sending an S-PMSI route to Switch B.
[SwitchD] route-policy rt_spmsi permit node 0
[SwitchD-route-policy-rt_spmsi-0] if-match route-type bgp-evpn-s-pmsi
[SwitchD-route-policy-rt_spmsi-0] apply ip-address next-hop 4.4.4.4
[SwitchD-route-policy-rt_spmsi-0] quit
[SwitchD] route-policy rt_spmsi permit node 1
[SwitchD-route-policy-rt_spmsi-1] quit
[SwitchC] bgp 100
[SwitchD-bgp-default] peer 2.2.2.2 as-number 100
[SwitchD-bgp-default] peer 2.2.2.2 connect-interface loopback 0
[SwitchD-bgp-default] peer 6.6.6.6 as-number 200
[SwitchD-bgp-default] peer 6.6.6.6 connect-interface loopback 0
[SwitchD-bgp-default] peer 6.6.6.6 ebgp-max-hop 64
[SwitchD-bgp-default-evpn] nexthop evpn-m-lag group-address
[SwitchD-bgp-default-evpn] peer 2.2.2.2 enable
[SwitchD-bgp-default-evpn] peer 2.2.2.2 route-policy rt_spmsi export
[SwitchD-bgp-default-evpn] peer 2.2.2.2 next-hop-local
[SwitchD-bgp-default-evpn] peer 6.6.6.6 enable
[SwitchD-bgp-default-evpn] peer 6.6.6.6 router-mac-local
[SwitchD] interface bridge-aggregation 9
[SwitchD-Bridge-Aggregation9] port link-type trunk
[SwitchD-Bridge-Aggregation9] port trunk permit vlan all
[SwitchD-Bridge-Aggregation9] link-aggregation mode dynamic
[SwitchD-Bridge-Aggregation9] port m-lag peer-link 1
[SwitchD-Bridge-Aggregation9] quit
[SwitchD] interface ten-gigabitethernet 1/0/2
[SwitchD-Ten-GigabitEthernet1/0/2] port link-aggregation group 9
[SwitchD-Ten-GigabitEthernet1/0/2] quit
[SwitchD] m-lag restore-delay 180
[SwitchD] m-lag system-mac 0001-0001-0001
[SwitchD] m-lag system-number 2
[SwitchD] m-lag system-priority 10
[SwitchD] m-lag keepalive ip destination 60.1.1.1 source 60.1.1.2
7.     Configure Switch E:
# Enable RIP process 1.
[SwitchE] rip 1
[SwitchE-rip-1] quit
# Enable RIP on interfaces.
[SwitchE] interface vlan-interface 3
[SwitchE-Vlan-interface3] rip 1 enable
[SwitchE-Vlan-interface3] quit
[SwitchE] interface vlan-interface 5
[SwitchE-Vlan-interface5] rip 1 enable
[SwitchE-Vlan-interface5] quit
[SwitchE] interface vlan-interface 6
[SwitchE-Vlan-interface6] rip 1 enable
[SwitchE-Vlan-interface6] quit
8.     Configure Switch F:
[SwitchF-mrib] quit
[SwitchF] pim
[SwitchF-pim] quit
[SwitchF] ospf 1
[SwitchF-ospf-1] area 0.0.0.0
[SwitchF-ospf-1-area-0.0.0.0] quit
[SwitchF-ospf-1] quit
[SwitchF] rip 1
[SwitchF-rip-1] quit
[SwitchF-LoopBack0] ip address 6.6.6.6 32
[SwitchF-LoopBack0] pim sm
[SwitchF-LoopBack0] ospf 1 area 0.0.0.0
# On VLAN-interface 6, configure OSPF and DCI multicast.
[SwitchF] interface vlan-interface 6
[SwitchF-Vlan-interface6] rip 1 enable
[SwitchF-Vlan-interface6] dci enable
[SwitchF-Vlan-interface6] quit
[SwitchF] ip vpn-instance vpna
[SwitchF-vpn-instance-vpna] route-distinguisher 6:6
[SwitchF-vpn-instance-vpna] vpn-target 1:1 import-extcommunity
[SwitchF-vpn-instance-vpna] vpn-target 1:1 export-extcommunity
[SwitchF-vpn-instance-vpna] quit
# Create VSI-interface 2, and associate the VSI interface with VPN instance vpna, and configure the L3 VXLAN ID as 1000 for the VPN instance.
[SwitchF] interface vsi-interface 2
[SwitchF-Vsi-interface2] ip binding vpn-instance vpna
[SwitchF-Vsi-interface2] l3-vni 1000
[SwitchF-Vsi-interface2] pim sm
[SwitchF-Vsi-interface2] quit
# Configure Loopback 1.
[SwitchF-LoopBack1] ip binding vpn-instance vpna
[SwitchF-LoopBack1] ip address 6.6.6.6 32
[SwitchF-LoopBack1] pim sm
[SwitchF] pim vpn-instance vpna
[SwitchF-pim-vpna] c-bsr 6.6.6.6
[SwitchF-pim-vpna] c-rp 6.6.6.6
[SwitchF-pim-vpna] quit
[SwitchF] multicast routing vpn-instance vpna
[SwitchF-mrib-vpna] quit
# Create an MDT-based MVXLAN for VPN instance vpna and enter MVXLAN IPv4 address family view. Configure the default group, MVXLAN source interface, and data group range settings. Enable DCI multicast.
[SwitchF] multicast-vpn vxlan vpn-instance vpna mode mdt
[SwitchF-mvxlan-vpna] address-family ipv4
[SwitchF-mvxlan-vpna-ipv4] default-group 236.0.0.0
[SwitchF-mvxlan-vpna-ipv4] source loopback 0
[SwitchF-mvxlan-vpna-ipv4] data-group 239.0.0.0 24
[SwitchF-mvxlan-vpna-ipv4] dci enable
[SwitchF-mvxlan-vpna-ipv4] quit
[SwitchF-mvxlan-vpna] quit
[SwitchF] bgp 200
[SwitchF-bgp-default] peer 3.3.3.3 as-number 100
[SwitchF-bgp-default] peer 3.3.3.3 connect-interface loopback 0
[SwitchF-bgp-default] peer 3.3.3.3 ebgp-max-hop 64
[SwitchF-bgp-default] peer 4.4.4.4 as-number 100
[SwitchF-bgp-default] peer 4.4.4.4 connect-interface loopback 0
[SwitchF-bgp-default] peer 4.4.4.4 ebgp-max-hop 64
[SwitchF-bgp-default] peer 7.7.7.7 as-number 200
[SwitchF-bgp-default] peer 7.7.7.7 connect-interface loopback 0
[SwitchF-bgp-default-evpn] peer 3.3.3.3 enable
[SwitchF-bgp-default-evpn] peer 3.3.3.3 router-mac-local
[SwitchF-bgp-default-evpn] peer 4.4.4.4 enable
[SwitchF-bgp-default-evpn] peer 4.4.4.4 router-mac-local
[SwitchF-bgp-default-evpn] peer 7.7.7.7 enable
[SwitchF-bgp-default-evpn] peer 7.7.7.7 next-hop-local
9.     Configure Switch G:
<SwitchG> system-view
[SwitchG] l2vpn enable
[SwitchG] multicast routing
[SwitchG-mrib] quit
[SwitchG] pim
[SwitchG-pim] quit
[SwitchG] ospf 1
[SwitchG-ospf-1] area 0.0.0.0
[SwitchG-ospf-1-area-0.0.0.0] quit
[SwitchG] igmp-snooping
[SwitchG-igmp-snooping] quit
[SwitchG] interface loopback 0
[SwitchG-LoopBack0] ip address 7.7.7.7 32
[SwitchG-LoopBack0] pim sm
[SwitchG-LoopBack0] ospf 1 area 0.0.0.0
[SwitchG-LoopBack0] quit
[SwitchG] vsi vsi1
[SwitchG-vsi-vsi1] evpn encapsulation vxlan
[SwitchG-vsi-vsi1-evpn-vxlan] route-distinguisher auto
[SwitchG-vsi-vsi1-evpn-vxlan] vpn-target auto export-extcommunity
[SwitchG-vsi-vsi1-evpn-vxlan] vpn-target auto import-extcommunity [SwitchG-vsi-vsi1-evpn-vxlan] quit
[SwitchG-vsi-vsi1] igmp-snooping enable
# Create VXLAN 10.
[SwitchG-vsi-vsi1] vxlan 10
[SwitchG-vsi-vsi1-vxlan-10] quit
[SwitchG-vsi-vsi1] quit
# Configure BGP to advertise BGP EVPN routes.
[SwitchG] bgp 200
[SwitchG-bgp-default] peer 6.6.6.6 as-number 200
[SwitchG-bgp-default] peer 6.6.6.6 connect-interface loopback 0
[SwitchG-bgp-default] address-family l2vpn evpn
[SwitchG-bgp-default-evpn] peer 6.6.6.6 enable
[SwitchG-bgp-default-evpn] quit
[SwitchG-bgp-default] quit
# On Ten-GigabitEthernet 1/0/1, create Ethernet service instance 33 to match VLAN 33.
[SwitchG] interface ten-gigabitethernet 1/0/1
[SwitchG-Ten-GigabitEthernet1/0/1] port link-mode bridge
[SwitchG-Ten-GigabitEthernet1/0/1] port link-type trunk
[SwitchG-Ten-GigabitEthernet1/0/1] port trunk permit vlan 1 33
[SwitchG-Ten-GigabitEthernet1/0/1] service-instance 33
[SwitchG-Ten-GigabitEthernet1/0/1-srv33] encapsulation s-vid 33
# Map Ethernet service instance 33 to VSI vsi1.
[SwitchG-Ten-GigabitEthernet1/0/1-srv33] xconnect vsi vsi1
[SwitchG-Ten-GigabitEthernet1/0/1-srv33] quit
[SwitchG] ip vpn-instance vpna
[SwitchG-vpn-instance-vpna] route-distinguisher 8:8
[SwitchG-vpn-instance-vpna] vpn-target 1:1 import-extcommunity
[SwitchG-vpn-instance-vpna] vpn-target 1:1 export-extcommunity
[SwitchG-vpn-instance-vpna] quit
# Configure VSI-interface 1.
[SwitchG] interface vsi-interface 1
[SwitchG-Vsi-interface1] ip binding vpn-instance vpna
[SwitchG-Vsi-interface1] ip address 100.1.2.1 255.255.255.0
[SwitchG-Vsi-interface1] pim sm
[SwitchG-Vsi-interface1] igmp enable
[SwitchG-Vsi-interface1] mac-address 0001-0001-0001
[SwitchG-Vsi-interface1] distributed-gateway local
[SwitchG-Vsi-interface1] quit
[SwitchG] interface vsi-interface 2
[SwitchG-Vsi-interface2] ip binding vpn-instance vpna
[SwitchG-Vsi-interface2] l3-vni 1000
[SwitchG-Vsi-interface2] pim sm
[SwitchG-Vsi-interface2] quit
[SwitchG] multicast routing vpn-instance vpna
[SwitchG-mrib-vpna] quit
[SwitchG] multicast-vpn vxlan vpn-instance vpna mode mdt
[SwitchG-mvxlan-vpna] address-family ipv4
[SwitchG-mvxlan-vpna-ipv4] default-group 236.0.0.0
[SwitchG-mvxlan-vpna-ipv4] source loopback 0
[SwitchG-mvxlan-vpna-ipv4] data-group 239.0.0.0 24
[SwitchG-mvxlan-vpna-ipv4] s-pmsi advertise source-active
[SwitchG-mvxlan-vpna-ipv4] quit
[SwitchG-mvxlan-vpna] quit
[SwitchG] interface loopback 1
[SwitchG-LoopBack1] ip binding vpn-instance vpna
[SwitchG-LoopBack1] ip address 7.7.7.7 32
[SwitchG-LoopBack1] pim sm
[SwitchG-LoopBack1] quit
[SwitchG] pim vpn-instance vpna
[SwitchG-pim-vpna] c-bsr 7.7.7.7
[SwitchG-pim-vpna] c-rp 7.7.7.7
[SwitchG-pim-vpna] quit
[SwitchG] vsi vsi1
[SwitchG-vsi-vsi1] gateway vsi-interface vsi1
1.     Verify the multicast routing information on the VTEPs.
# Verify that Switch A has multicast routing entries for VPN instance vpna and the public network.
<SwitchA> display pim vpn-instance vpna routing-table
 (*, 225.0.0.1)
     RP: 1.1.1.1 (local)
     UpTime: 00:00:31
         1: MTunnel0
 (100.1.1.100, 225.0.0.1)
     RP: 1.1.1.1 (local)
     UpTime: 00:00:32
         1: MTunnel1
     RP: NULL
     UpTime: 00:03:31
     Upstream interface: MTunnel0 (VPN: vpna)
         1: Vlan-interface10
     RP: NULL
     UpTime: 00:01:53
         1: MVXLAN-UPE0
     RP: NULL
     UpTime: 00:01:47
         1: MVXLAN-UPE0
     RP: NULL
     UpTime: 00:00:51
     Upstream interface: MTunnel1 (VPN: vpna)
         1: Vlan-interface10
# Verify that Switch G has multicast routing entries for VPN instance vpna and the public network.
<SwitchG> display pim vpn-instance vpna routing-table
 (*, 225.0.0.1)
     RP: 7.7.7.7 (local)
     UpTime: 00:12:32
         1: Vsi-interface1
         2: MTunnel0
     RP: 7.7.7.7 (local)
     UpTime: 00:12:30
         1: Vsi-interface1
<SwitchG> display pim routing-table
     RP: NULL
     UpTime: 00:19:27
         1: MVXLAN-UPE0
     RP: NULL
     UpTime: 00:19:29
         1: MVXLAN-UPE0
     RP: NULL
     UpTime: 00:18:04
         1: MVXLAN-UPE0
2.     Verify the multicast routing information on the EDs.
# Verify that Switch C has multicast routing entries for VPN instance vpna and the public network.
<SwitchC> display pim vpn-instance vpna routing-table
 (*, 225.0.0.1)
     RP: 3.3.3.3 (local)
     UpTime: 00:20:48
         1: Vsi-interface2
         2: MTunnel0
     RP: 3.3.3.3 (local)
     UpTime: 00:20:47
         1: Vsi-interface2
<SwitchC> display pim routing-table
     RP: NULL
     UpTime: 00:23:32
         1: MVXLAN-UPE0
     RP: NULL
     UpTime: 00:25:33
         1: Vlan-interface30
     RP: NULL
     UpTime: 00:22:31
         1: MVXLAN-UPE0
