- 11-Network Management and Monitoring Configuration Guide
- 03-NTP configuration
- 05-SNMP configuration
- 07-Event MIB configuration
- 09-Ansible configuration
- 11-Chef configuration
- 13-EAA configuration
- 15-Mirroring configuration
- 17-Information center configuration
- 19-VCF fabric configuration
- 21-TCP connection trace configuration
| 00-Preface | 110.50 KB |
Preface
This configuration guide describes the network management and monitoring fundamentals and configuration procedures. It describes how to view system information, collect network traffic statistics, assess the network performance, synchronize time for all devices with clocks in your network, and use the ping, tracert, and debug commands to check and debug the current network connectivity.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the S6800 & S6860 switch series.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
