17-Network Management and Monitoring Command Reference
HomeSupportReference GuidesCommand ReferencesH3C SecPath F1000[F5000][VFW] Firewalls Series Command Reference(V7)-6W60017-Network Management and Monitoring Command Reference
05-Mirroring commands
05-Mirroring commands 139.24 KB
Port mirroring commands
The fixed interfaces of a device and the interfaces on interface cards cannot be assigned to the same mirroring group on devices of the following series:
·     F5010, F5020, F5020-GM, F5040, F5000-AI-15, F5000-C, and F5000-S.
·     F1000-AI-20, F1000-AI-25, F1000-AI-30, F1000-AI-35, F1000-AI-50, F1000-AI-55, F1000-AI-65, and F1000-AI-75.
·     F1020, F1020-GM, F1030, F1030-GM, F1050, F1060, F1070, F1070-GM, F1070-GM-L, F1080, F1000-V50, F1000-V60, and F1000-V70.
·     F1000-AK1212, F1000-AK1222, F1000-AK1232, F1000-AK1242, F1000-AK1252, F1000-AK1262, F1000-AK1272, F1000-AK1312, F1000-AK1322, F1000-AK1332, F1000-AK1342, F1000-AK1352, F1000-AK1362, F1000-AK130, F1000-AK135, F1000-AK140, F1000-AK145, F1000-AK150, F1000-AK155, F1000-AK160, F1000-AK165, F1000-AK170, F1000-AK711, F1000-AK175, F1000-AK180, F1000-AK185, F1000-GM-AK370, F1000-GM-AK380.
Port mirroring across IRF member devices are not supported. The mirroring sources and destination must reside on the same IRF member device.
Virtual interfaces do not support port mirroring.
If you configure an interface shared by multiple contexts as a source port, traffic passing through the shared interface will be mirrored to the monitor port without distinction of contexts.
The following compatibility matrix shows the support of hardware platforms for port mirroring:
Series
Models
Port mirroring compatibility
F50X0 series
F5010, F5020, F5020-GM, F5040, F5000-C, F5000-S
Yes
F5030, F5030-6GW, F5060, F5080, F5000-A, F5000-M
Yes only in slot 3 through slot 8.
F5000-CN series
F5000-CN30, F5000-CN60
No
F5000-AI series
F5000-AI-15
Yes only on GE 1/0/0 through GE1/0/13 and XGE 1/0/18 through XGE 1/0/19.
F5000-AI-20, F5000-AI-40
F5000-V series
F5000-V30
F1000-AI series
F1000-AI-05, F1000-AI-10, F1000-AI-15
No
F1000-AI-20, F1000-AI-30, F1000-AI-50
Yes
F1000-AI-25, F1000-AI-35, F1000-AI-55
Yes only on interfaces GE 1/0/0 through GE 1/0/23, GE1/0/25, XGE 1/0/26, and XGE 1/0/27.
F1000-AI-60, F1000-AI-70, F1000-AI-80, F1000-AI-90
Yes only on GE 1/0/0 through GE 1/0/13, XGE 1/0/18 and XGE 1/0/19, GE 1/0/22 through GE 1/0/29, and interfaces on cards in four interface card slots.
F1000-AI-65, F1000-AI-75
Yes only on interfaces GE 1/0/0 through GE1/0/23, XGE 1/0/24, and XGE 1/0/25.
F1000-L series
F1003-L, F1005-L, F1010-L
No
F10X0 series
F1005, F1010
No
Yes
F1090
F1000-V series
F1000-V50
F1000-V60
F1000-V70
Yes
F1000-V90
F1000-SASE series
F1000-SASE100, F1000-SASE200
No
F1000-AK series
F1000-AK108, F1000-AK109, F1000-AK110, F1000-AK115, F1000-AK120, F1000-AK125, F1000-AK710, F1000-AK1010, F1000-AK1020, F1000-AK1030, F1000-AK1110, F1000-AK1120, F1000-AK1130, F1000-AK1140, F1000-AK1150, F1000-AK1160, F1000-AK1170, F1000-AK1180, F1000-AK9110, F1000-AK9210
No
F1000-AK130, F1000-AK135, F1000-AK140, F1000-AK145, F1000-AK150, F1000-AK155, F1000-AK160, F1000-AK165, F1000-AK170, F1000-AK175, F1000-AK180, F1000-AK185, F1000-GM-AK370, F1000-GM-AK380, F1000-AK711, F1000-AK1212, F1000-AK1222, F1000-AK1232, F1000-AK1312, F1000-AK1322, F1000-AK1332
Yes
F1000-AK1414, F1000-AK1424, F1000-AK1434, F1000-AK1514, F1000-AK1524, F1000-AK1534, F1000-AK1614
Modules
IM-NGFWX-IV, LSPM6FWD, LSPM6FWDB, LSQM1FWDSC0, LSQM2FWDSC0, LSU3FWCEA0, LSUM1FWCEAB0, LSUM1FWDEC0, LSWM1FWD0, LSX1FWCEA1, LSXM1FWDF1
No
vFW series
vFW1000, vFW2000
No
display mirroring-group
Use display mirroring-group to display mirroring group information.
display mirroring-group { group-id | all | local }
context-admin
context-operator
group-id: Specifies a mirroring group by its ID.
The following compatibility matrix shows the value ranges for the mirroring group ID:
Series
Models
Value range
F50X0 series
F5010, F5020, F5020-GM, F5030, F5030-6GW, F5040, F5060, F5080, F5000-A, F5000-C, F5000-S, F5000-M
1 and 2
F5000-CN series
Not supported
F5000-AI series
F5000-AI-15, F5000-AI-20, F5000-AI-40
1 and 2
F5000-V series
F5000-V30
1 and 2
F1000-AI series
Not supported
1
F1000-AI-20, F1000-AI-30, F1000-AI-50, F1000-AI-60, F1000-AI-65, F1000-AI-70, F1000-AI-75, F1000-AI-80, F1000-AI-90
1 and 2
F1000-L series
Not supported
F10X0 series
F1005, F1010
Not supported
F1020, F1020-GM, F1030, F1030-GM, F1050, F1060, F1070, F1070-GM, F1070-GM-L, F1080, F1090
1 and 2
F1000-V series
F1000-V50
1
F1000-V70, F1000-V60, F1000-V90
1 and 2
F1000-SASE series
Not supported
F1000-AK series
Not supported
F1000-AK130, F1000-AK135, F1000-AK140, F1000-AK145, F1000-AK150, F1000-AK155, F1000-AK160, F1000-AK165, F1000-AK170, F1000-AK175, F1000-AK180, F1000-AK185, F1000-GM-AK370, F1000-GM-AK380, F1000-AK711, F1000-AK1212, F1000-AK1222, F1000-AK1232, F1000-AK1312, F1000-AK1322, F1000-AK1332, F1000-AK1342, F1000-AK1352, F1000-AK1362, F1000-AK1414, F1000-AK1424, F1000-AK1434, F1000-AK1514, F1000-AK1524, F1000-AK1534, F1000-AK1614
1 and 2
1
Modules
Not supported
vFW series
vFW1000, vFW2000
Not supported
all: Specifies all mirroring groups.
local: Specifies local mirroring groups.
Mirroring group information includes the type, status, and content of a mirroring group. It is sorted by mirroring group number.
# Display information about all mirroring groups.
<Sysname> display mirroring-group all
Mirroring group 1:
    Type: Local
    Status: Active
    Mirroring port:
        GigabitEthernet1/0/1  Inbound
    Monitor port: GigabitEthernet1/0/2
Mirroring group
ID of the mirroring group.
Type of the mirroring group:
Local.
Status
Status of the mirroring group:
·     Active—The mirroring group has taken effect.
·     Incomplete—The mirroring group configuration is not complete and does not take effect.
Mirroring port
Source port.
Monitor port
Destination port.
mirroring-group
Use mirroring-group to create a mirroring group.
Use undo mirroring-group to delete mirroring groups.
mirroring-group group-id local
undo mirroring-group { group-id | all | local }
No mirroring groups exist.
context-admin
group-id: Specifies a mirroring group ID.
Series
Models
Value range
F50X0 series
1 and 2
F5000-CN series
Not supported
F5000-AI series
1 and 2
F5000-V series
F5000-V30
1 and 2
F1000-AI series
Not supported
1
1 and 2
F1000-L series
Not supported
F10X0 series
F1005, F1010
Not supported
1 and 2
F1000-V series
F1000-V50
1
1 and 2
F1000-SASE series
Not supported
F1000-AK series
Not supported
1 and 2
1
Modules
Not supported
vFW series
vFW1000, vFW2000
Not supported
# Create local mirroring group 1.
[Sysname] mirroring-group 1 local
mirroring-group mirroring-port (interface view)
Use mirroring-group mirroring-port to configure a port as a source port for a mirroring group.
Use undo mirroring-group mirroring-port to restore the default.
mirroring-group group-id mirroring-port { both | inbound | outbound }
undo mirroring-group group-id mirroring-port
A port does not act as a source port for any mirroring groups.
Interface view
context-admin
Series
Models
Value range
F50X0 series
1 and 2
F5000-CN series
Not supported
F5000-AI series
1 and 2
F5000-V series
F5000-V30
1 and 2
F1000-AI series
Not supported
1
1 and 2
F1000-L series
Not supported
F10X0 series
F1005, F1010
Not supported
1 and 2
F1000-V series
F1000-V50
1
1 and 2
F1000-SASE series
Not supported
F1000-AK series
Not supported
1 and 2
1
Modules
Not supported
vFW series
vFW1000, vFW2000
Not supported
both: Mirrors both received and sent packets.
inbound: Mirrors only received packets.
outbound: Mirrors only sent packets.
A Layer 2 or Layer 3 aggregate interface cannot be configured as a source port for a mirroring group.
A source port cannot be used as a monitor port.
# Create local mirroring group 1 to monitor the bidirectional traffic of port GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] mirroring-group 1 mirroring-port both
mirroring-group
mirroring-group mirroring-port (system view)
Use mirroring-group mirroring-port to configure source ports for a mirroring group.
Use undo mirroring-group mirroring-port to remove source ports from a mirroring group.
mirroring-group group-id mirroring-port interface-list { both | inbound | outbound }
undo mirroring-group group-id mirroring-port interface-list
No source port is configured for a mirroring group.
context-admin
Series
Models
Value range
F50X0 series
1 and 2
F5000-CN series
Not supported
F5000-AI series
1 and 2
F5000-V series
F5000-V30
1 and 2
F1000-AI series
Not supported
1
1 and 2
F1000-L series
Not supported
F10X0 series
F1005, F1010
Not supported
1 and 2
F1000-V series
F1000-V50
1
1 and 2
F1000-SASE series
Not supported
F1000-AK series
Not supported
1 and 2
1
Modules
Not supported
vFW series
vFW1000, vFW2000
Not supported
interface-list: Specifies a space-separated list of up to eight interface items. Each item specifies an interface by its type and number or specifies a range of interfaces in the form of interface-type interface-number1 to interface-type interface-number2. When you specify a range of interfaces, the interfaces must be of the same type and on the same slot. The start interface number must be identical to or lower than the end interface number.
# Create local mirroring group 1 to monitor the bidirectional traffic of GigabitEthernet 1/0/1.
[Sysname] mirroring-group 1 mirroring-port gigabitethernet 1/0/1 both
mirroring-group
mirroring-group monitor-port (interface view)
Use mirroring-group monitor-port to configure a port as the monitor port for a mirroring group.
Use undo mirroring-group monitor-port to restore the default.
mirroring-group group-id monitor-port
undo mirroring-group group-id monitor-port
A port does not act as the monitor port for any mirroring groups.
Interface view
context-admin
Series
Models
Value range
F50X0 series
1 and 2
F5000-CN series
Not supported
F5000-AI series
1 and 2
F5000-V series
F5000-V30
1 and 2
F1000-AI series
Not supported
1
1 and 2
F1000-L series
Not supported
F10X0 series
F1005, F1010
Not supported
1 and 2
F1000-V series
F1000-V50
1
1 and 2
F1000-SASE series
Not supported
F1000-AK series
Not supported
1 and 2
1
Modules
Not supported
vFW series
vFW1000, vFW2000
Not supported
Do not enable the spanning tree feature on the monitor port of a mirroring group.
A Layer 2 or Layer 3 aggregate interface cannot be configured as the monitor port for a mirroring group.
Use a monitor port only for port mirroring, so the data monitoring device receives and analyzes only the mirrored traffic.
The member port of an existing mirroring group cannot be configured as a monitor port.
# Create local mirroring group 1 and configure GigabitEthernet 1/0/1 as its monitor port.
[Sysname-GigabitEthernet1/0/1] mirroring-group 1 monitor-port
mirroring-group
mirroring-group monitor-port (system view)
Use mirroring-group monitor-port to configure the monitor ports for a mirroring group.
Use undo mirroring-group monitor-port to remove the monitor ports from a mirroring group.
mirroring-group group-id monitor-port interface-type interface-number
undo mirroring-group group-id monitor-port interface-type interface-number
No monitor port is configured for a mirroring group.
context-admin
Series
Models
Value range
F50X0 series
1 and 2
F5000-CN series
Not supported
F5000-AI series
1 and 2
F5000-V series
F5000-V30
1 and 2
F1000-AI series
Not supported
1
1 and 2
F1000-L series
Not supported
F10X0 series
F1005, F1010
Not supported
1 and 2
F1000-V series
F1000-V50
1
1 and 2
F1000-SASE series
Not supported
F1000-AK series
Not supported
1 and 2
1
Modules
Not supported
vFW series
vFW1000, vFW2000
Not supported
Use a monitor port only for port mirroring, so the data monitoring device receives only the mirrored traffic.
[Sysname] mirroring-group 1 monitor-port gigabitethernet 1/0/1
mirroring-group
