13-Layer 3—IP Services Command Reference
HomeSupportReference GuidesCommand ReferencesH3C SecPath F1000[F5000][VFW] Firewalls Series Command Reference(V7)-6W60013-Layer 3—IP Services Command Reference
11-Multi-CPU packet distribution commands
11-Multi-CPU packet distribution commands 58.92 KB
forwarding policy
Use forwarding policy to specify a multi-CPU packet distribution policy.
Use undo forwarding policy to restore the default.
forwarding policy { per-flow [ three-tuple | mode { source-ip | destination-ip | source-port | destination-port } ] | per-packet }
The device uses the flow-based policy that identifies a flow by source IP address, destination IP address, source port number, destination port number, and protocol number.
context-admin
per-flow: Specifies the flow-based forwarding. The device identifies a data flow by the five-tuple, and forwards packets of the same flow to one CPU. The CPU processes flow packets by following the first-in first-out rule.
three-tuple: Identifies a data flow by the three-tuple (source IP address, destination IP address, and protocol number). If you do not specify this keyword, the device identifies a data flow by the five-tuple.
The following compatibility matrix shows the support of hardware platforms for the three-tuple keyword:
Series
Models
Parameter compatibility
F50X0 series
F5010, F5020, F5020-GM, F5040, F5000-C, F5000-S
No
F5030, F5030-6GW, F5060, F5080, F5000-A, F5000-M
Yes
F5000-CN series
F5000-CN30, F5000-CN60
Yes
F5000-AI series
F5000-AI-15, F5000-AI-20, F5000-AI-40
Yes
F5000-V series
F5000-V30
Yes
F1000-AI series
F1000-AI-05, F1000-AI-10, F1000-AI-15, F1000-AI-60, F1000-AI-65, F1000-AI-70, F1000-AI-75, F1000-AI-80, F1000-AI-90
Yes
F1000-AI-20, F1000-AI-25, F1000-AI-30, F1000-AI-35, F1000-AI-50, F1000-AI-55
No
F1000-L series
F1003-L, F1005-L, F1010-L
Yes
F10X0 series
F1005, F1010, F1090
Yes
F1020, F1020-GM, F1030, F1030-GM, F1050, F1060, F1070, F1070-GM, F1070-GM-L, F1080
No
F1000-V series
F1000-V50, F1000-V70
No
F1000-V60, F1000-V90
Yes
F1000-SASE series
F1000-SASE100, F1000-SASE200
Yes
F1000-AK series
F1000-AK108, F1000-AK109, F1000-AK110, F1000-AK115, F1000-AK120, F1000-AK125, F1000-AK710, F1000-AK1010, F1000-AK1020, F1000-AK1030, F1000-AK1110, F1000-AK1120, F1000-AK1130, F1000-AK1140, F1000-AK1150, F1000-AK1160, F1000-AK1170, F1000-AK1180, F1000-AK1312, F1000-AK1322, F1000-AK1332, F1000-AK1342, F1000-AK1352, F1000-AK1362, F1000-AK1414, F1000-AK1424, F1000-AK1434, F1000-AK1514, F1000-AK1524, F1000-AK1534, F1000-AK1614, F1000-AK9110, F1000-AK9120
Yes
F1000-AK130, F1000-AK135, F1000-AK140, F1000-AK145, F1000-AK150, F1000-AK155, F1000-AK160, F1000-AK165, F1000-AK170, F1000-AK175, F1000-AK180, F1000-AK185, F1000-GM-AK370, F1000-GM-AK380, F1000-AK711, F1000-AK1212, F1000-AK1222, F1000-AK1232, F1000-AK1242, F1000-AK1252, F1000-AK1262, F1000-AK1272
No
Firewall modules
IM-NGFWX-IV, LSPM6FWD, LSPM6FWDB, LSQM1FWDSC0, LSQM2FWDSC0, LSU3FWCEA0, LSUM1FWCEAB0, LSUM1FWDEC0, LSWM1FWD0, LSX1FWCEA1, LSXM1FWDF1
Yes
vFW series
vFW1000, vFW2000
No
mode: Specifies a flow-based forwarding mode.
source-ip: Identifies a flow by source IP address.
destination-ip: Identifies a flow by destination IP address.
source-port: Identifies a flow by source port.
destination-port: Identifies a flow by destination port.
The following compatibility matrix shows the support of hardware platforms for the mode keyword:
Series
Models
F50X0 series
No
Yes
F5000-CN series
Yes
F5000-AI series
Yes
F5000-V series
F5000-V30
Yes
F1000-AI series
Yes
No
F1000-L series
Yes
F10X0 series
F1005, F1010, F1090
Yes
No
F1000-V series
No
Yes
F1000-SASE series
Yes
F1000-AK series
F1000-AK108, F1000-AK109, F1000-AK110, F1000-AK115, F1000-AK120, F1000-AK125, F1000-AK710, F1000-AK1010, F1000-AK1020, F1000-AK1030, F1000-AK1110, F1000-AK1120, F1000-AK1130, F1000-AK1140, F1000-AK1150, F1000-AK1160, F1000-AK1170, F1000-AK1180, F1000-AK1312, F1000-AK1322, F1000-AK1332, F1000-AK1342, F1000-AK1352, F1000-AK1362, F1000-AK1414, F1000-AK1424, F1000-AK1434, F1000-AK1514, F1000-AK1524, F1000-AK1534, F1000-AK1614, F1000-AK9110, F1000-AK9210
Yes
No
Firewall modules
Yes
vFW series
vFW1000, vFW2000
No
per-packet: Specifies the packet-based forwarding. The device forwards packets in sequence to different CPUs, even though they are the same flow. This policy does not ensure packet order.
If you do not specify any keyword for flow identification, the device identifies a flow by source IP address, destination IP address, source port number, destination port number, and protocol number.
# Specify the flow-based policy.
[Sysname] forwarding policy per-flow
