- 03-Security Command Reference
- 01-Security zone commands
- 02-Security policy commands
- 03-ASPF commands
- 04-Session management commands
- 05-Object group commands
- 06-IP source guard commands
- 07-AAA commands
- 08-User identification commands
- 09-Password control commands
- 10-Portal commands
- 11-MAC authentication commands
- 12-802.1X commands
- 13-IPoE commands
- 14-Public key management commands
- 15-PKI commands
- 16-SSH commands
- 17-SSL commands
- 18-Connection limit commands
- 19-Attack detection and prevention commands
- 20-Server connection detection commands
- 21-ARP attack protection commands
- 22-ND attack defense commands
- 23-uRPF commands
- 24-IP-MAC binding commands
- 25-APR commands
- 26-Keychain commands
- 27-Crypto engine commands
- 28-MAC learning through a Layer 3 device commands
- 29-SMS commands
| 04-Session management commands | 559.98 KB |
display session aging-time application
display session aging-time state
display session dual-active transparent statistics
display session fast-drop statistics
display session fast-drop table ipv4
display session fast-drop table ipv6
display session fast-drop top-statistics
display session relation-table
display session statistics ipv4
display session statistics ipv6
display session statistics multicast
display session table multicast ipv4
display session table multicast ipv6
display session top-statistics
reset session statistics multicast
reset session table multicast ipv4
reset session table multicast ipv6
session alarm rate-abrupt enable
session alarm rate-abrupt threshold
session alarm try-rate-abrupt enable
session alarm try-rate-abrupt threshold
session alarm usage-abrupt enable
session alarm usage-abrupt threshold
session dual-active create-mode
session dual-active transparent udp enable
session fast-drop resource-ratio
session fast-drop top-statistics enable
session log { bytes-active | packets-active }
session synchronization { dns | http } *
session synchronization enable
Use display session aging-time application to display the aging time for sessions of different application layer protocols or applications.
context-admin
context-operator
# Display the aging time for sessions of different application layer protocols and applications.
<Sysname> display session aging-time application
Application Aging time(s)
bootpc 120
bootps 120
dns 30
ftp 3600
ftp-data 240
gprs-data 60
gprs-sig 60
gtp-control 60
gtp-user 60
h225 3600
h245 3600
https 600
ils 3600
l2tp 120
mgcp-callagent 60
mgcp-gateway 60
netbios-dgm 3600
netbios-ns 3600
netbios-ssn 3600
ntp 120
pptp 3600
qq 120
ras 300
rip 120
rsh 60
rtsp 3600
sccp 3600
sip 300
snmp 120
snmptrap 120
sqlnet 600
stun 600
syslog 120
tacacs-ds 120
tftp 60
who 120
xdmcp 3600
others: 1200
Application |
Name of an application layer protocol or an application. |
Aging time(s) |
Aging time in seconds. |
others:1200 |
All application layer protocols and applications whose aging time is 1200 seconds is displayed as others. |
Use display session aging-time stat to display the aging time for sessions in different protocol states.
context-admin
context-operator
# Display the aging time for sessions in different protocol states.
<Sysname> display session aging-time state
State Aging Time(s)
SYN 10
TCP-EST 3600
FIN 10
UDP-OPEN 10
UDP-READY 30
ICMP-REQUEST 30
ICMP-REPLY 10
RAWIP-OPEN 30
RAWIP-READY 60
UDPLITE-OPEN 30
UDPLITE-READY 60
DCCP-REQUEST 30
DCCP-EST 3600
DCCP-CLOSEREQ 30
SCTP-INIT 30
SCTP-EST 3600
SCTP-SHUTDOWN 30
ICMPV6-REQUEST 60
ICMPV6-REPLY 30
TCP-TIME-WAIT 2
TCP-CLOSE 2
State |
Protocol state. |
Aging Time(s) |
Use display session dual-active transparent statistics to display statistics about transparently transmitted packets in session dual-active mode.
display session dual-active transparent statistics [ slot slot-number ]
context-admin
context-operator
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays packet statistics for all member devices.
# Display statistics about transparently transmitted packets in session dual-active mode.
<Sysname> display session dual-active transparent statistics
Slot 1:
UDP relay packets : 0
Hash relay packets : 0
Sent relay packets : 0
Received relay packets : 0
UDP relay packets |
Number of transparently transmitted UDP packets. |
Hash relay packets |
Number of packets for which sessions are created according to the result of source IP-based hashing. |
Sent relay packets |
Number of sent packets that are transparently transmitted. |
Received relay packets |
Number of received packets that are transparently transmitted. |
session statistics enable
Use display session fast-drop statistics to display unicast deny session statistics.
display session fast-drop statistics [ summary ] [ slot slot-number ]
context-admin
context-operator
summary: Displays summary information about unicast deny session statistics. If you do not specify this keyword, the command displays detailed information about unicast deny session statistics.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays information on all member devices.
# Display detailed information about unicast deny session statistics.
<Sysname> display session fast-drop statistics
Slot 1:
Current : 1
Session type Est count
TCP : 0
UDP : 0
ICMP : 1
ICMPv6 : 0
UDP-Lite : 0
SCTP : 0
DCCP : 0
RAWIP : 0
DNS : 0
FTP : 0
GTP : 0
H323 : 0
HTTP : 0
ILS : 0
MGCP : 0
NBT : 0
PPTP : 0
RSH : 0
RTSP : 0
SCCP : 0
SIP : 0
SMTP : 0
SQLNET : 0
SSH : 0
TELNET : 0
TFTP : 0
XDMCP : 0
Deny session establishment rate: 0/s
TCP : 0/s
UDP : 0/s
ICMP : 0/s
ICMPv6 : 0/s
UDP-Lite : 0/s
SCTP : 0/s
DCCP : 0/s
RAWIP : 0/s
Current |
Total number of unicast deny sessions. |
Session type |
Deny session type: · TCP. · UDP. · ICMP. · ICMPv6. · UDP-Lite. · SCTP. · DCCP. · RAWIP. · DNS. · FTP. · GTP. · H323. · HTTP. · ILS. · MGCP. · NBT. · PPTP. · RSH. · RTSP. · SCCP. · SIP. · SMTP. · SQLNET. · SSH. · TELNET. · TFTP. · XDMCP. |
Est count |
Number of deny sessions created for each protocol. |
Deny session establishment rate |
Rate of deny session establishment. |
Session type |
Deny session type: · TCP. · UDP. · ICMP. · ICMPv6. · UDP-Lite. · SCTP. · DCCP. · RAWIP. |
Est count |
Number of deny sessions created per second for each protocol. |
# Display summary information about unicast deny session statistics.
<Sysname> display session fast-drop statistics summary
Slot 1:
type Sessions TCP sessions UDP sessions Rate TCP rate UDP rate
Est 1 0 0 1/s 0/s 0/s
Try 47 0 0 1/s 0/s 0/s
Table 5 Command output
type |
Deny session type: · Est—Successfully created deny session. · Try—Deny session that the system attempted to create. |
Sessions |
TCP sessions |
Number of TCP unicast deny sessions. |
UDP sessions |
Number of UDP unicast deny sessions. |
Rate |
Rate of unicast deny session creation. |
TCP rate |
Rate of TCP unicast deny session creation. |
UDP rate |
Rate of UDP unicast deny session creation. |
Use display session fast-drop table ipv4 to display IPv4 unicast deny session entries.
display session fast-drop table ipv4 [ slot slot-number ] [ verbose ]
context-admin
context-operator
verbose: Displays detailed information about IPv4 unicast deny session entries. If you do not specify this keyword, the command displays brief information about IPv4 unicast deny session entries.
# Display brief information about all IPv4 unicast deny session entries.
<Sysname> display session fast-drop table ipv4
Slot 1:
Initiator:
Source IP/port: 192.168.1.18/1877
Destination IP/port: 192.168.1.55/22
DS-Lite tunnel peer: -
Protocol: TCP(6)
Inbound interface: GigabitEthernet1/0/1
Source security zone: Trust
Total deny session found: 1
# Display detailed information about all IPv4 unicast deny session entries.
<Sysname> display session fast-drop table ipv4 verbose
Slot 1:
Initiator:
Protocol: TCP(6)
Responder:
Source IP/port: 192.168.1.55/22
Destination IP/port: 192.168.1.18/1877
Protocol: TCP(6)
Inbound interface: GigabitEthernet1/0/2
Source security zone: Local
State: TCP_SYN_SENT
Application: SSH
Rule ID: 1
Rule name: test
Start time: 2011-07-29 19:12:36 TTL: 28s
Initiator->Responder: 1 packets 48 bytes
Responder->Initiator: 0 packets 0 bytes
Table 6 Command output
Initiator |
Information about the unicast deny session from the initiator to the responder. |
Responder |
Information about the unicast deny session from the responder to the initiator. |
DS-Lite tunnel peer |
Address of the DS-Lite tunnel peer. When the unicast deny session is not tunneled by DS-Lite, this field displays a hyphen (-). |
VPN instance/VLAN ID/Inline ID |
MPLS L3VPN instance to which the unicast deny session belongs. VLAN and inline to which the deny session belongs during Layer 2 forwarding. If a parameter is not specified, a hyphens (-) is displayed for the proper field. |
Protocol |
Transport layer protocol: · DCCP. · ICMP. · ICMPv6. · Raw IP. · SCTP. · TCP. · UDP. · UDP-Lite. The number in the brackets indicates the protocol number. |
Inbound interface |
Interface on which packets are received. |
Source security zone |
Security zone to which the inbound interface belongs. If the inbound interface does not belong to any security zone, this field displays a hyphen (-). |
State |
Unicast deny session state. |
Application |
Application layer protocol, FTP or DNS. If it is an unknown protocol identified by an unknown port, this field displays OTHER. |
Rule ID |
ID of the security policy rule. |
Rule name |
Name of the security policy rule. |
Start time |
Unicast deny session establishment time. |
TTL |
Remaining lifetime of the unicast deny session, in seconds. |
Initiator->Responder |
Number of packets and bytes from the initiator to the responder. |
Responder->Initiator |
Number of packets and bytes from the responder to the initiator. |
Total deny session found |
Total number of found unicast deny session entries. |
Use display session fast-drop table ipv6 to display IPv6 unicast deny session entries.
display session fast-drop table ipv6 [ slot slot-number ] [ verbose ]
context-admin
context-operator
verbose: Displays detailed information about IPv6 unicast deny session entries. If you do not specify this keyword, the command displays brief information about IPv6 unicast deny session entries.
# Display brief information about all IPv6 unicast deny session entries.
<Sysname> display session fast-drop table ipv6
Slot 1:
Initiator:
Source IP/port: 2011::2/58473
Destination IP/port: 2011::8/32768
Protocol: TCP(6)
# Display detailed information about all IPv6 unicast deny session entries.
<Sysname> display session fast-drop table ipv6 verbose
Slot 1:
Initiator:
Protocol: TCP(6)
Responder:
Protocol: TCP(6)
State: TCP_SYN_SENT
Application: SSH
Rule ID: 1
Rule name: test
Table 7 Command output
Initiator |
Responder |
MPLS L3VPN instance to which the unicast deny session belongs. VLAN and inline to which the unicast deny session belongs during Layer 2 forwarding. If a parameter is not specified, a hyphens (-) is displayed for the proper field. |
Protocol |
Inbound interface |
State |
Application |
Rule ID |
Rule name |
Start time |
TTL |
Use display session fast-drop top-statistics to display top deny session statistics.
display session fast-drop top-statistics { last-1-hour | last-24-hours | last-30-days }
The following compatibility matrix shows the support of hardware platforms for this command:
Series |
Models |
Command compatibility |
F50X0 series |
F5010, F5020, F5020-GM, F5030, F5030-6GW, F5040, F5060, F5080, F5000-A, F5000-C, F5000-S, F5000-M |
Yes |
F5000-CN series |
F5000-CN30, F5000-CN60 |
Yes |
F5000-AI series |
F5000-AI-15, F5000-AI-20, F5000-AI-40 |
Yes |
F5000-V series |
F5000-V30 |
Yes |
F1000-AI series |
F1000-AI-05, F1000-AI-10, F1000-AI-15, F1000-AI-20, F1000-AI-25, F1000-AI-30, F1000-AI-35, F1000-AI-50, F1000-AI-55, F1000-AI-60, F1000-AI-65, F1000-AI-70, F1000-AI-75, F1000-AI-80, F1000-AI-90 |
Yes |
F1000-L series |
F1003-L, F1005-L, F1010-L |
Yes |
F10X0 series |
F1005, F1010, F1020, F1020-GM, F1030, F1030-GM, F1050, F1060, F1070, F1070-GM, F1070-GM-L, F1080, F1090 |
Yes |
F1000-V series |
F1000-V50, F1000-V60, F1000-V70, F1000-V90 |
Yes |
F1000-SASE series |
F1000-SASE100, F1000-SASE200 |
Yes |
F1000-AK series |
F1000-AK108, F1000-AK109, F1000-AK110, F1000-AK115, F1000-AK120, F1000-AK125, F1000-AK130, F1000-AK135, F1000-AK140, F1000-AK145, F1000-AK150, F1000-AK155, F1000-AK160, F1000-AK165, F1000-AK170, F1000-AK175, F1000-AK180, F1000-AK185, F1000-GM-AK370, F1000-GM-AK380, F1000-AK710, F1000-AK711, F1000-AK1010, F1000-AK1020, F1000-AK1030, F1000-AK1110, F1000-AK1120, F1000-AK1130, F1000-AK1140, F1000-AK1150, F1000-AK1160, F1000-AK1170, F1000-AK1180, F1000-AK1212, F1000-AK1222, F1000-AK1232, F1000-AK1242, F1000-AK1252, F1000-AK1262, F1000-AK1272, F1000-AK1312, F1000-AK1322, F1000-AK1332, F1000-AK1342, F1000-AK1352, F1000-AK1362, F1000-AK1414, F1000-AK1424, F1000-AK1434, F1000-AK1514, F1000-AK1524, F1000-AK1534, F1000-AK1614, F1000-AK9110, F1000-AK9210 |
Yes |
Firewall modules |
IM-NGFWX-IV, LSPM6FWD, LSPM6FWDB, LSQM1FWDSC0, LSQM2FWDSC0, LSU3FWCEA0, LSUM1FWCEAB0, LSUM1FWDEC0, LSWM1FWD0, LSX1FWCEA1, LSXM1FWDF1 |
No |
vFW series |
vFW1000, vFW2000 |
No |
context-admin
context-operator
last-1-hour: Displays top deny session statistics in last hour.
last-24-hours: Displays top deny session statistics in last 24 hours.
last-30-days: Displays top deny session statistics in last 30 days.
This command displays nothing if the top deny session statistics feature is disabled. A maximum of 10 session items can be displayed.
# Display top deny session statistics in last hour.
<Sysname> display session fast-drop top-statistics last-1-hour
Counting by source addresses:
No. Source address Sessions
1 8.1.1.1 6085
2 111.15.111.16 10
3 6::2 2
Counting by destination addresses:
No. Destination address Sessions
1 8.1.1.2 6085
2 6::3 2
3 30.1.1.8 1
4 30.1.1.4 1
5 30.1.1.11 1
6 30.1.1.9 1
7 30.1.1.6 1
8 30.1.1.5 1
9 30.1.1.7 1
10 30.1.1.3 1
Table 8 Command output
Counting by source addresses |
Top deny session statistics based on source addresses. |
Counting by destination addresses |
Top deny session statistics based on destination addresses. |
No. |
Ranking number. |
Source address |
Source IP address of the deny sessions. |
Destination address |
Destination IP address of the deny sessions. |
Sessions |
Total number of deny sessions. |
session fast-drop enable
Use display session relation-table to display relation entries.
display session relation-table { ipv4 | ipv6 } [ slot slot-number ]
context-admin
context-operator
ipv4: Specifies IPv4 relation entries.
ipv6: Specifies IPv6 relation entries.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays relation entries for all member devices.
# Display all IPv4 relation entries.
<Sysname> display session relation-table ipv4
Slot 1:
Source IP/port: 192.168.1.100/-
Destination IP/port: 192.168.2.100/99
VPN instance/VLAN ID/Inline ID: 1/-/-
Protocol: TCP(6) TTL: 1234s App: FTP-DATA
Source IP/port: -/-
Destination IP/port: 192.168.2.200/1212
Protocol: TCP(6) TTL: 3100s App: H225
Total entries found: 2
# Display all IPv6 relation entries.
<Sysname> display session relation-table ipv6
Slot 1:
Source IP: 2011::0002
Destination IP/port: 2011::0008/1212
Protocol: TCP(6) TTL: 567s App: FTP-DATA
Total entries found: 1
Table 9 Command output
Source IP/port |
Source IP address and port number of the session. If the IP or port number is not specified, this field displays a hyphen (-). For an IPv6 relation entry, the source port number is not displayed. |
Destination IP/port |
Destination IP address and port number of the session. |
Peer tunnel interface address of the DS-Lite tunnel to which the session belongs. If no peer tunnel interface address is specified, a hyphen (-) is displayed. |
VPN instance/VLAN ID/ Inline ID |
MPLS L3VPN instance to which the relation entry belongs. VLAN and inline to which the relation entry belongs during Layer 2 forwarding. If a parameter is not specified, a hyphen (-) is displayed for the proper field. |
Protocol |
Transport layer protocol. |
TTL |
Remaining lifetime of the relation entry, in seconds. |
App |
Application layer protocol. |
Total entries found |
Total number of found relation entries. |
Use display session statistics to display unicast session statistics.
display session statistics [ history-max | summary ] [ slot slot-number ]
context-admin
context-operator
history-max: Displays history statistics of the maximum unicast sessions and the maximum unicast session establishment rates. If you do not specify this keyword, the command displays all unicast session statistics.
summary: Displays summary information about unicast session statistics. If you do not specify this keyword, the command displays detailed information about unicast session statistics.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays unicast session statistics for all member devices.
If you do not specify any parameters, this command displays detailed information about the current unicast session statistics.
# Display detailed information about unicast session statistics.
<Sysname> display session statistics
Slot 1:
Current sessions: 3
TCP sessions: 0
UDP sessions: 0
ICMP sessions: 3
ICMPv6 sessions: 0
UDP-Lite sessions: 0
SCTP sessions: 0
DCCP sessions: 0
RAWIP sessions: 0
DNS sessions: 0
FTP sessions: 0
GTP sessions: 0
H323 sessions: 0
HTTP sessions: 0
ILS sessions: 0
MGCP sessions: 0
NBT sessions: 0
PPTP sessions: 0
RSH sessions: 0
RTSP sessions: 0
SCCP sessions: 0
SIP sessions: 0
SMTP sessions: 0
SQLNET sessions: 0
SSH sessions: 0
TELNET sessions: 0
TFTP sessions: 0
XDMCP sessions: 0
History average sessions per second:
Past hour: 1
Past 24 hours: 0
Past 30 days: 0
History average session establishment rate:
Past hour: 0/s
Past 24 hours: 0/s
Past 30 days: 0/s
Current relation-table entries: 0
Relation table establishment rate: 0/s
Session establishment rate: 0/s
TCP: 0/s
UDP: 0/s
ICMP: 0/s
ICMPv6: 0/s
UDP-Lite: 0/s
SCTP: 0/s
DCCP: 0/s
RAWIP: 0/s
Received TCP : 0 packets 0 bytes
Received UDP : 118 packets 13568 bytes
Received ICMP : 105 packets 8652 bytes
Received ICMPv6 : 0 packets 0 bytes
Received UDP-Lite : 0 packets 0 bytes
Received SCTP : 0 packets 0 bytes
Received DCCP : 0 packets 0 bytes
Received RAWIP : 0 packets 0 bytes
Table 10 Command output
Current sessions |
Total number of unicast sessions. |
TCP sessions |
Number of TCP sessions. |
UDP sessions |
Number of UDP sessions. |
ICMP sessions |
Number of ICMP sessions. |
ICMPv6 sessions |
Number of ICMPv6 sessions. |
UDP-Lite sessions |
Number of UDP-Lite sessions. |
SCTP sessions |
Number of SCTP sessions. |
DCCP sessions |
Number of DCCP sessions. |
RAWIP sessions |
Number of Raw IP sessions. |
DNS sessions |
Number of DNS unicast sessions. |
FTP sessions |
Number of FTP unicast sessions. |
GTP sessions |
Number of GTP unicast sessions. |
H323 sessions |
Number of H.323 unicast sessions. |
HTTP sessions |
Number of HTTP unicast sessions. |
ILS sessions |
Number of ILS unicast sessions. |
MGCP sessions |
Number of MGCP unicast sessions. |
NBT sessions |
Number of NBT unicast sessions. |
PPTP sessions |
Number of PPTP unicast sessions. |
RSH sessions |
Number of RSH unicast sessions. |
RTSP sessions |
Number of RTSP unicast sessions. |
SCCP sessions |
Number of SCCP unicast sessions. |
SIP sessions |
Number of SIP unicast sessions. |
SMTP sessions |
Number of SMTP unicast sessions. |
SQLNET sessions |
Number of SQLNET unicast sessions. |
SSH sessions |
Number of SSH unicast sessions. |
TELNET sessions |
Number of Telnet unicast sessions. |
TFTP sessions |
Number of TFTP unicast sessions. |
XDMCP sessions |
Number of XDMCP unicast sessions. |
History statistics of average sessions per second. |
The average number of sessions per second in the most recent hour. |
The average number of sessions per second in the most recent 24 hours. |
The average number of sessions per second in the most recent 30 days. |
History statistics of average session establishment rates. |
The average session establishment rate in the most recent hour. |
The average session establishment rate in the most recent 24 hours. |
The average session establishment rate in the most recent 30 days. |
Current relation-table entries |
Total number of relation entries. |
Relation table establishment rate |
Rate of relation table establishment. |
Session establishment rate |
Unicast session establishment rate, and rates for establishing unicast sessions of different protocols. |
Received TCP |
Number of received TCP packets and bytes. |
Received UDP |
Number of received UDP packets and bytes. |
Received ICMP |
Number of received ICMP packets and bytes. |
Received ICMPv6 |
Number of received ICMPv6 packets and bytes. |
Received UDP-Lite |
Number of received UDP-Lite packets and bytes. |
Received SCTP |
Number of received SCTP packets and bytes. |
Received DCCP |
Number of received DCCP packets and bytes. |
Received RAWIP |
Number of received Raw IP packets and bytes. |
# Display summary information about unicast session statistics.
<Sysname> display session statistics summary
Slot Sessions TCP UDP Rate TCP rate UDP rate
1 3 0 0 0/s 0/s 0/s
Table 11 Command output
Sessions |
TCP |
Number of TCP unicast sessions. |
UDP |
Number of UDP unicast sessions. |
Rate |
Rate of unicast session creation. |
TCP rate |
Rate of TCP unicast session creation. |
UDP rate |
Rate of UDP unicast session creation. |
# Display history statistics of the maximum unicast sessions and maximum unicast session establishment rates.
<Sysname> display session statistics history-max
Slot 1
Max sessions: 20084 Time: 2017-03-04 12:03:53
Max session establishment rate: 9080/s Time: 2017-03-04 12:03:53
Max TCP sessions: 20084 Time: 2017-03-04 12:03:53
Max TCP session establishment rate: 9080/s Time: 2017-03-04 12:03:53
Max UDP sessions: 0 Time: 2017-03-04 12:03:53
Max UDP session establishment rate: 0 Time: 2017-03-04 12:03:53
Table 12 Command output
Max sessions |
History statistics of the maximum unicast sessions. |
Max session establishment rate |
History statistics of the maximum rate at which unicast sessions were created. |
Max TCP sessions |
History statistics of the maximum TCP unicast sessions. |
Max TCP session establishment rate |
History statistics of the maximum rate at which TCP unicast sessions were created. |
Max UDP sessions |
History statistics of the maximum UDP unicast sessions. |
Max UDP session establishment rate |
History statistics of the maximum rate at which UDP unicast sessions were created. |
Use display session statistics ipv4 to display IPv4 unicast session statistics.
display session statistics ipv4 [ [ responder ] { application application-name | destination-ip destination-ip | destination-port destination-port | destination-zone destination-zone-name | interface interface-type interface-number | protocol { dccp | dns | ftp | gtp | h323 | http | icmp | ils | mgcp | nbt | pptp | raw-ip | rsh | rtsp | sccp | sctp | sip | smtp | sqlnet | ssh | tcp | telnet | tftp | udp | udp-lite | xdmcp } | security-policy-rule rule-name | source-ip source-ip | source-port source-port | source-zone source-zone-name | state { dccp-closereq | dccp-closing | dccp-open | dccp-partopen | dccp-request | dccp-respond | dccp-timewait | icmp-reply | icmp-request | rawip-open | rawip-ready | sctp-closed | sctp-cookie-echoed | sctp-cookie-wait | sctp-established | sctp-shutdown-ack-sent | sctp-shutdown-recd | sctp-shutdown-sent | tcp-close | tcp-close-wait | tcp-est | tcp-fin-wait | tcp-last-ack | tcp-syn-recv | tcp-syn-sent | tcp-syn-sent2 | tcp-time-wait | udp-open | udp-ready | udplite-open | udplite-ready } | vpn-instance vpn-instance-name } * ] [ slot slot-number ]
context-admin
context-operator
responder: Displays statistics about IPv4 unicast sessions from the responder to the initiator. If you do not specify this keyword, the command displays statistics about IPv4 unicast sessions from the initiator to the responder.
application application-name: Specifies an application protocol by its name. The application-name argument is a case-insensitive string of 1 to 63 characters. The names invalid and other are not allowed.
destination-ip destination-ip: Specifies a destination IPv4 address for a unicast session.
destination-port destination-port: Specifies a destination port by its number. The destination-port argument specifies the destination port of an IPv6 unicast session. The value range for the destination-port argument is 0 to 65535.
destination-zone destination-zone-name: Specifies a destination security zone by its name, a case-insensitive string of 1 to 31 characters.
interface interface-type interface-num: Specifies an interface by its type and number.
protocol { dccp | dns | ftp | gtp | h323 | http | icmp | ils | mgcp | nbt | pptp | raw-ip | rsh | rtsp | sccp | sctp | sip | smtp | sqlnet | ssh | tcp | telnet | tftp | udp | udp-lite | xdmcp }: Specifies an IPv4 protocol.
security-policy-rule rule-name: Specifies a security policy rule by its name for session filtering. The rule-name argument represents the name of the security policy rule, a case-sensitive string of 1 to 127 characters.
source-ip source-ip: Specifies a source IPv4 address for a unicast session.
source-port source-port: Specifies a source port by its number. The source-port argument specifies the source port of an IPv4 unicast session. The value range for the source-port argument is 0 to 65535.
source-zone source-zone-name: Specifies a source security zone by its name, a case-insensitive string of 1 to 31 characters.
state { dccp-closereq | dccp-closing | dccp-open | dccp-partopen | dccp-request | dccp-respond | dccp-timewait | icmp-reply | icmp-request | rawip-open | rawip-ready | sctp-closed | sctp-cookie-echoed | sctp-cookie-wait | sctp-established | sctp-shutdown-ack-sent | sctp-shutdown-recd | sctp-shutdown-sent | tcp-close | tcp-close-wait | tcp-est | tcp-fin-wait | tcp-last-ack | tcp-syn-recv | tcp-syn-sent | tcp-syn-sent2 | tcp-time-wait | udp-open | udp-ready | udplite-open | udplite-ready }: Specifies a protocol state.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays IPv4 unicast session statistics in the public network.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays IPv4 unicast session statistics for all member devices.
If you do not specify any parameters, this command displays all IPv4 unicast session statistics.
# Display statistics for unicast sessions from IP address 111.15.111.66.
<Sysname> display session statistics ipv4 source-ip 111.15.111.66
Slot 1:
Current sessions: 3
TCP sessions: 0
UDP sessions: 0
ICMP sessions: 3
SCTP sessions: 0
DCCP sessions: 0
RAWIP sessions: 0
DNS sessions: 0
FTP sessions: 0
GTP sessions: 0
H323 sessions: 0
HTTP sessions: 0
ILS sessions: 0
MGCP sessions: 0
NBT sessions: 0
PPTP sessions: 0
RSH sessions: 0
RTSP sessions: 0
SCCP sessions: 0
SIP sessions: 0
SMTP sessions: 0
SQLNET sessions: 0
SSH sessions: 0
TELNET sessions: 0
TFTP sessions: 0
XDMCP sessions: 0
# Display statistics for IPv4 unicast TCP sessions.
<Sysname> display session statistics ipv4 protocol tcp
Slot 1:
Current sessions: 3
TCP sessions: 3
Table 13 Command output
Current sessions |
TCP sessions |
UDP sessions |
ICMP sessions |
Number of ICMP unicast sessions. |
UDP-Lite sessions |
Number of UDP-Lite unicast sessions. |
SCTP sessions |
Number of SCTP unicast sessions. |
DCCP sessions |
Number of DCCP unicast sessions. |
RAWIP sessions |
Number of Raw IP unicast sessions. |
DNS sessions |
FTP sessions |
GTP sessions |
H323 sessions |
HTTP sessions |
ILS sessions |
MGCP sessions |
NBT sessions |
PPTP sessions |
RSH sessions |
RTSP sessions |
SCCP sessions |
SIP sessions |
SMTP sessions |
SQLNET sessions |
SSH sessions |
TELNET sessions |
TFTP sessions |
XDMCP sessions |
Use display session statistics ipv6 to display IPv6 unicast session statistics.
display session statistics ipv6 [ [ responder ] { application application-name | destination-ip destination-ip | destination-port destination-port | destination-zone destination-zone-name | interface interface-type interface-number | protocol { dccp | dns | ftp | gtp | h323 | http | icmpv6 | ils | mgcp | nbt | pptp | raw-ip | rsh | rtsp | sccp | sctp | sip | smtp | sqlnet | ssh | tcp | telnet | tftp | udp | udp-lite | xdmcp } | security-policy-rule rule-name | source-ip source-ip | source-port source-port | source-zone source-zone-name | state { dccp-closereq | dccp-closing | dccp-open | dccp-partopen | dccp-request | dccp-respond | dccp-timewait | icmpv6-reply | icmpv6-request | rawip-open | rawip-ready | sctp-closed | sctp-cookie-echoed | sctp-cookie-wait | sctp-established | sctp-shutdown-ack-sent | sctp-shutdown-recd | sctp-shutdown-sent | tcp-close | tcp-close-wait | tcp-est | tcp-fin-wait | tcp-last-ack | tcp-syn-recv | tcp-syn-sent | tcp-syn-sent2 | tcp-time-wait | udp-open | udp-ready | udplite-open | udplite-ready } | vpn-instance vpn-instance-name } * ] [ slot slot-number ]
context-admin
context-operator
responder: Displays statistics about IPv6 unicast sessions from the responder to the initiator. If you do not specify this keyword, the command displays statistics about IPv6 unicast sessions from the initiator to the responder.
destination-ip destination-ip: Specifies a destination IPv6 address for a unicast session.
protocol { dccp | dns | ftp | gtp | h323 | http | icmpv6 | ils | mgcp | nbt | pptp | raw-ip | rsh | rtsp | sccp | sctp | sip | smtp | sqlnet | ssh | tcp | telnet | tftp | udp | udp-lite | xdmcp }: Specifies an IPv6 protocol.
source-ip source-ip: Specifies a source IPv6 address for a unicast session.
source-port source-port: Specifies a source port by its number. The source-port argument specifies the source port of an IPv6 unicast session. The value range for the source-port argument is 0 to 65535.
state { dccp-closereq | dccp-closing | dccp-open | dccp-partopen | dccp-request | dccp-respond | dccp-timewait | icmpv6-reply | icmpv6-request | rawip-open | rawip-ready | sctp-closed | sctp-cookie-echoed | sctp-cookie-wait | sctp-established | sctp-shutdown-ack-sent | sctp-shutdown-recd | sctp-shutdown-sent | tcp-close | tcp-close-wait | tcp-est | tcp-fin-wait | tcp-last-ack | tcp-syn-recv | tcp-syn-sent | tcp-syn-sent2 | tcp-time-wait | udp-open | udp-ready | udplite-open | udplite-ready }: Specifies a protocol state.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays IPv6 unicast session statistics in the public network.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays IPv6 unicast session statistics for all member devices.
# Display statistics for unicast sessions from IPv6 address 100::2.
<Sysname> display session statistics ipv6 source-ip 100::2
Slot 1:
Current sessions: 3
TCP sessions: 0
UDP sessions: 0
ICMPv6 sessions: 3
SCTP sessions: 0
DCCP sessions: 0
RAWIP sessions: 0
DNS sessions: 0
FTP sessions: 0
GTP sessions: 0
H323 sessions: 0
HTTP sessions: 0
ILS sessions: 0
MGCP sessions: 0
NBT sessions: 0
PPTP sessions: 0
RSH sessions: 0
RTSP sessions: 0
SCCP sessions: 0
SIP sessions: 0
SMTP sessions: 0
SQLNET sessions: 0
SSH sessions: 0
TELNET sessions: 0
TFTP sessions: 0
XDMCP sessions: 0
# Display statistics for IPv6 unicast TCP sessions.
<Sysname> display session statistics ipv6 protocol tcp
Slot 1:
Current sessions: 3
TCP sessions: 3
Table 14 Command output
Current sessions |
TCP sessions |
UDP sessions |
ICMPv6 sessions |
Number of ICMPv6 unicast sessions. |
UDP-Lite sessions |
SCTP sessions |
DCCP sessions |
RAWIP sessions |
DNS sessions |
FTP sessions |
GTP sessions |
H323 sessions |
HTTP sessions |
ILS sessions |
MGCP sessions |
NBT sessions |
PPTP sessions |
RSH sessions |
RTSP sessions |
SCCP sessions |
SIP sessions |
SMTP sessions |
SQLNET sessions |
SSH sessions |
TELNET sessions |
TFTP sessions |
XDMCP sessions |
Use display session statistic multicast to display multicast session statistics.
display session statistics multicast [ slot slot-number ]
context-admin
context-operator
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays multicast session statistics for all member devices.
# Display information about multicast session statistics.
<Sysname> display session statistics multicast
Slot 1:
Current sessions: 0
History max sessions: 0 Time: 2017-04-25 11:28:00
History max session establishment rate: 0/s Time: 2017-04-25 11:28:00
Received: 0 packets 0 bytes
Sent : 0 packets 0 bytes
Table 15 Command output
Current sessions |
Total number of multicast sessions. |
Rate of multicast session creation. |
History max sessions |
History statistics of the maximum multicast sessions. |
History max session establishment rate |
History statistics of the maximum rate at which multicast sessions were created. |
Received |
Number of received multicast packets and bytes. |
Sent |
Number of sent multicast packets and bytes. |
display session table ipv4
Use display session table ipv4 to display information about IPv4 unicast session entries that match specific criteria.
display session table ipv4 [ slot slot-number ] [ [ responder ] { application application-name | destination-ip start-destination-ip [ end-destination-ip ] | destination-port destination-port | destination-zone destination-zone-name | interface interface-type interface-number | protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } | security-policy-rule rule-name | source-ip start-source-ip [ end-source-ip ] | source-port source-port | source-zone source-zone-name | state { dccp-closereq | dccp-closing | dccp-open | dccp-partopen | dccp-request | dccp-respond | dccp-timewait | icmp-reply | icmp-request | rawip-open | rawip-ready | sctp-closed | sctp-cookie-echoed | sctp-cookie-wait | sctp-established | sctp-shutdown-ack-sent | sctp-shutdown-recd | sctp-shutdown-sent | tcp-close | tcp-close-wait | tcp-est | tcp-fin-wait | tcp-last-ack | tcp-syn-recv | tcp-syn-sent | tcp-syn-sent2 | tcp-time-wait | udp-open | udp-ready | udplite-open | udplite-ready } | vpn-instance vpn-instance-name } * ] [ verbose ]
context-admin
context-operator
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays information for all member devices.
responder: Displays entries of IPv4 unicast sessions from the responder to the initiator. If you do not specify this keyword, the command displays entries of IPv4 unicast sessions from the initiator to the responder.
destination-ip start-destination-ip [ end-destination-ip ]: Specifies a destination IPv4 address or IPv4 address range for a unicast session. The start destination-ip argument specifies the start destination IPv4 address. The end destination-ip argument specifies the end destination IPv4 address.
destination-port destination-port: Specifies a destination port by its number. The destination-port argument specifies the destination port of a unicast session. The value range for the destination-port argument is 0 to 65535.
protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite }: Specifies an IPv4 transport layer protocol, including DCCP, ICMP, Raw IP, SCTP, TCP, UDP, and UDP-Lite.
source-ip start-source-ip [ end-source-ip ]: Specifies a source IPv4 address or IPv4 address range for a unicast session. The start source-ip argument specifies the start source IPv4 address. The end source-ip argument specifies the end source IPv4 address.
source-port source-port: Specifies a source port by its number. The source-port argument specifies the source port of a unicast session. The value range for the source-port argument is 0 to 65535.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays IPv4 unicast session entries in the public network.
verbose: Displays detailed information about IPv4 unicast session entries. If you do not specify this keyword, the command displays brief information about IPv4 unicast session entries.
If you do not specify any parameters, this command displays all IPv4 unicast session entries.
# Display brief information about all IPv4 unicast session entries.
<Sysname> display session table ipv4
Slot 1:
Initiator:
Protocol: TCP(6)
Total sessions found: 1
# Display detailed information about all IPv4 unicast session entries.
<Sysname> display session table ipv4 verbose
Slot 1:
Initiator:
DS-Lite tunnel peer:-
Protocol: TCP(6)
Responder:
Protocol: TCP(6)
State: TCP_SYN_SENT
Application: SSH
Rule ID: 1
Rule name: test
Table 16 Command output
Initiator |
Information about the unicast session from the initiator to the responder. |
Responder |
Information about the unicast session from the responder to the initiator. |
Address of the DS-Lite tunnel peer. When the unicast session does not belong to any DS-Lite tunnel, this field displays a hyphen (-). |
MPLS L3VPN instance to which the unicast session belongs. VLAN and inline to which the session belongs during Layer 2 forwarding. If a parameter is not specified, a hyphens (-) is displayed for the proper field. |
Protocol |
Inbound interface |
State |
Unicast session state. |
Application |
Rule ID |
Rule name |
Start time |
Unicast session establishment time. |
TTL |
Remaining lifetime of the unicast session, in seconds. |
Total sessions found |
Total number of found unicast session entries. |
display session table ipv6
Use display session table ipv6 to display information about IPv6 unicast session entries that match specific criteria.
display session table ipv6 [ slot slot-number ] [ [ responder ] { application application-name | destination-ip start-destination-ip [ end-destination-ip ] | destination-port destination-port | destination-zone destination-zone-name | interface interface-type interface-number | protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite } | security-policy-rule rule-name | source-ip start-source-ip [ end-source-ip ] | source-port source-port | source-zone source-zone-name | state { dccp-closereq | dccp-closing | dccp-open | dccp-partopen | dccp-request | dccp-respond | dccp-timewait | icmpv6-reply | icmpv6-request | rawip-open | rawip-ready | sctp-closed | sctp-cookie-echoed | sctp-cookie-wait | sctp-established | sctp-shutdown-ack-sent | sctp-shutdown-recd | sctp-shutdown-sent | tcp-close | tcp-close-wait | tcp-est | tcp-fin-wait | tcp-last-ack | tcp-syn-recv | tcp-syn-sent | tcp-syn-sent2 | tcp-time-wait | udp-open | udp-ready | udplite-open | udplite-ready } | vpn-instance vpn-instance-name } * ] [ verbose ]
context-admin
context-operator
responder: Displays entries of IPv6 unicast sessions from the responder to the initiator. If you do not specify this keyword, the command displays entries of IPv6 unicast sessions from the initiator to the responder.
destination-ip start-destination-ip [ end-destination-ip ]: Specifies a destination IPv6 address or IPv6 address range for a unicast session. The start destination-ip argument specifies the start destination IPv6 address. The end destination-ip argument specifies the end destination IPv6 address.
protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite }: Specifies an IPv6 transport layer protocol, including DCCP, ICMPv6, Raw IP, SCTP, TCP, UDP, and UDP-Lite.
source-ip start-source-ip [ end-source-ip ]: Specifies a source IPv6 address or IPv6 address range for a unicast session. The start source-ip argument specifies the start source IPv6 address. The end source-ip argument specifies the end source IPv6 address.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays IPv6 unicast session entries in the public network.
verbose: Displays detailed information about IPv6 unicast session entries. If you do not specify this keyword, the command displays brief information about IPv6 unicast session entries.
If you do not specify any parameters, this command displays all IPv6 unicast session entries.
# Display brief information about all IPv6 unicast session entries.
<Sysname> display session table ipv6
Slot 1:
Initiator:
Protocol: IPV6-ICMP(58)
# Display detailed information about all IPv6 unicast session entries.
<Sysname> display session table ipv6 verbose
Slot 1:
Initiator:
Responder:
Source IP/port: 2011::8/58473
Destination IP/port: 2011::2/33024
State: ICMPV6_REQUEST
Application: OTHER
Rule ID: 1
Rule name: test
Start time: 2011-07-29 19:23:41 TTL: 55s
Initiator->Responder: 1 packets 104 bytes
Table 17 Command output
Initiator |
Responder |
Address of the DS-Lite tunnel peer. When the unicast session is not tunneled by DS-Lite, this field displays a hyphen (-). |
MPLS L3VPN instance to which the unicast session belongs. VLAN and inline to which the unicast session belongs during Layer 2 forwarding. If a parameter is not specified, a hyphens (-) is displayed for the proper field. |
Protocol |
Inbound interface |
State |
Application |
Rule ID |
Rule name |
Start time |
TTL |
Use display session table multicast ipv4 to display information about IPv4 multicast session entries that match specific criteria.
display session table multicast ipv4 [ slot slot-number ] [ [ responder ] { destination-ip start-destination-ip [ end-destination-ip ] | destination-port destination-port | protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } | source-ip start-source-ip [ end-source-ip ] | source-port source-port } * ] [ verbose ]
context-admin
context-operator
responder: Displays entries of IPv4 multicast sessions from the responder to the initiator. If you do not specify this keyword, the command displays entries of IPv4 multicast sessions from the initiator to the responder.
destination-ip start-destination-ip [ end-destination-ip ]: Specifies a destination IPv4 address or IPv4 address range for a multicast session. The start destination-ip argument specifies the start destination IPv4 address. The end destination-ip argument specifies the end destination IPv4 address.
destination-port destination-port: Specifies a destination port by its number. The destination-port argument specifies the destination port of a multicast session. The value range for the destination-port argument is 0 to 65535.
protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite }: Specifies an IPv4 transport layer protocol.
source-ip start-source-ip [ end-source-ip ]: Specifies a source IPv4 address or IPv4 address range for a multicast session. The start source-ip argument specifies the start source IPv4 address. The end source-ip argument specifies the end source IPv4 address.
source-port source-port: Specifies a source port by its number. The source-port argument specifies the source port of a multicast session. The value range for the source-port argument is 0 to 65535.
verbose: Displays detailed information about IPv4 multicast session entries. If you do not specify this keyword, the command displays brief information about IPv4 multicast session entries.
If you do not specify any parameters, this command displays all IPv4 multicast session entries.
# Display brief information about all IPv4 multicast session entries.
<Sysname> display session table multicast ipv4
Slot 1:
Inbound initiator:
Source IP/port: 3.3.3.4/1609
Destination IP/port: 232.0.0.1/1025
Protocol: UDP(17)
Outbound interface list:
GigabitEthernet1/0/3
Total sessions found: 3
# Display detailed information about all IPv4 multicast session entries.
<Sysname> display session table multicast ipv4 verbose
Slot 1:
Total sessions found: 0
CPU 1 on slot 2:
Inbound initiator:
Protocol: UDP(17)
Inbound responder:
Source IP/port: 232.0.0.1/1025
Destination IP/port: 3.3.3.4/1609
Protocol: UDP(17)
State: UDP_OPEN
Application: OTHER
Start time: 2014-03-03 15:59:22 TTL: 18s
Initiator->Responder: 1 packets 84 bytes
Outbound initiator:
Protocol: UDP(17)
Outbound responder:
Protocol: UDP(17)
Outbound interface: GigabitEthernet1/0/2
Destination security zone: aaa
State: UDP_OPEN
Application: OTHER
Outbound initiator:
Protocol: UDP(17)
Outbound responder:
Protocol: UDP(17)
Outbound interface: GigabitEthernet1/0/3
Destination security zone: bbb
State: UDP_OPEN
Application: OTHER
Table 18 Command output
Inbound initiator |
Information about the multicast session from the initiator to the responder on the inbound interface. |
Inbound responder |
Information about the multicast session from the responder to the initiator on the inbound interface. |
Outbound initiator |
Information about the multicast session from the initiator to the responder on the outbound interface. |
Outbound responder |
Information about the multicast session from the responder to the initiator on the outbound interface. |
Address of the DS-Lite tunnel peer. If the multicast session is not tunneled by DS-Lite, this field displays a hyphen (-). |
MPLS L3VPN instance to which the multicast session belongs. VLAN and inline to which the multicast session belongs during Layer 2 forwarding. If a parameter is not specified, a hyphens (-) is displayed for the proper field. |
Protocol |
Transport layer protocol: · DCCP. · ICMP. · Raw IP. · SCTP. · TCP. · UDP. · UDP-Lite. The number in the brackets indicates the protocol number. |
State |
Multicast session state. |
Application |
Start time |
Time when the multicast session was created. |
TTL |
Remaining lifetime of the multicast session, in seconds. |
Inbound interface |
Inbound interface of the first packet from the initiator to responder. |
Outbound interface |
Outbound interface of the first packet from the initiator to responder. |
Outbound interface list |
Outbound interfaces of the first packet from the initiator to responder. |
Destination security zone |
Security zone to which the outbound interface belongs. If the outbound interface does not belong to any security zone, this field displays a hyphen (-). |
Total number of found multicast session entries. |
Use display session table multicast ipv6 to display information about IPv6 multicast session entries that match specific criteria.
display session table multicast ipv6 [ slot slot-number ] [ [ responder ] { destination-ip start-destination-ip [ end-destination-ip ] | destination-port destination-port | protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite } | source-ip start-source-ip [ end-source-ip ] | source-port source-port } * ] [ verbose ]
context-admin
context-operator
responder: Displays entries of IPv6 multicast sessions from the responder to the initiator. If you do not specify this keyword, the command displays entries of IPv4 multicast sessions from the initiator to the responder.
destination-ip start-destination-ip [ end-destination-ip ]: Specifies a destination IPv6 address or IPv6 address range for a multicast session. The start destination-ip argument specifies the start destination IPv6 address. The end destination-ip argument specifies the end destination IPv6 address.
protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite }: Specifies an IPv6 transport layer protocol.
source-ip start-source-ip [ end-source-ip ]: Specifies a source IPv6 address or IPv6 address range for a multicast session. The start source-ip argument specifies the start source IPv6 address. The end source-ip argument specifies the end source IPv6 address.
verbose: Displays detailed information about IPv6 multicast session entries. If you do not specify this keyword, the command displays brief information about IPv6 multicast session entries.
If you do not specify any parameters, this command displays all IPv6 multicast session entries.
# Display brief information about all IPv6 multicast session entries.
<Sysname> display session table multicast ipv6
Slot 1:
Inbound initiator:
Source IP/port: 3::4/1617
Destination IP/port: FF0E::1/1025
Protocol: UDP(17)
# Display detailed information about all IPv6 multicast session entries.
<Sysname> display session table multicast ipv6 verbose
Slot 1:
Inbound initiator:
Protocol: UDP(17)
Inbound responder:
Source IP/port: FF0E::1/1025
Destination IP/port: 3::4/1617
Protocol: UDP(17)
State: UDP_OPEN
Application: OTHER
Start time: 2014-03-03 16:10:58 TTL: 23s
Initiator->Responder: 5 packets 520 bytes
Outbound initiator:
Protocol: UDP(17)
Outbound responder:
Protocol: UDP(17)
State: UDP_OPEN
Application: OTHER
Outbound initiator:
Protocol: UDP(17)
Outbound responder:
Protocol: UDP(17)
Destination security zone: ccc
State: UDP_OPEN
Application: OTHER
Table 19 Command output
Inbound initiator |
Inbound responder |
Protocol |
Transport layer protocol: · DCCP. · ICMPv6. · Raw IP. · SCTP. · TCP. · UDP. · UDP-Lite. The number in the brackets indicates the protocol number. |
State |
Application |
Start time |
TTL |
Inbound interface |
Use display session top-statistics to display top session statistics.
display session top-statistics { last-1-hour | last-24-hours | last-30-days }
context-admin
context-operator
last-1-hour: Displays top session statistics in last hour.
last-24-hours: Displays top session statistics in last 24 hours.
last-30-days: Displays top session statistics in last 30 days.
This command displays nothing if the top session statistics feature is not enabled. A maximum of ten session items can be displayed.
# Display top session statistics in last hour.
<Sysname> display session top-statistics last-1-hour
1 10.1.2.3 50004302
2 10.1.2.2 40123255
3 10.2.2.10 26664302
4 10.1.2.11 7123255
5 10.1.2.12 424302
6 10.1.2.13 253255
7 10.1.2.14 55302
8 10.1.2.15 50025
9 10.1.2.16 3555
10 10.1.2.1 995
1 20.1.2.3 50004302
2 20.1.2.2 40123255
3 20.2.2.10 26664302
4 20.1.2.11 7123255
5 20.1.2.12 424302
6 20.1.2.13 325325
7 20.1.2.14 55530
8 20.1.2.15 50025
9 20.1.2.16 3555
10 20.1.2.1 995
Table 20 Command output
Top session statistics based on source addresses. |
Top session statistics based on destination addresses. |
No. |
Ranking number. |
Source address |
Source IP address of the sessions. |
Destination IP address of the sessions. |
Sessions |
Total number of sessions. |
session top-statistics enable
reset session relation-table
Use reset session relation-table to clear relation entries.
reset session relation-table [ ipv4 | ipv6 ] [ slot slot-number ]
context-admin
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command clears relation entries for all member devices.
If you do not specify any parameters, this command clears all relation entries.
# Clear all IPv4 relation entries.
<Sysname> reset session relation-table ipv4
Use reset session statistics to clear unicast session statistics.
reset session statistics [ slot slot-number ]
context-admin
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command clears unicast session statistics for all member devices.
# Clear all unicast session statistics.
<Sysname> reset session statistics
Use reset session statistics multicast to clear multicast session statistics.
reset session statistics multicast [ slot slot-number ]
context-admin
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command clears multicast session statistics for all member devices.
# Clear all multicast session statistics.
<Sysname> reset session statistics multicast
reset session table
Use reset session table to clear IP unicast session entries.
reset session table [ slot slot-number ]
context-admin
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command clears unicast session entries for all member devices.
# Clear all unicast session entries.
<Sysname> reset session table
reset session table ipv4
Use reset session table ipv4 to clear information about IPv4 unicast session entries that match specific criteria.
reset session table ipv4 [ slot slot-number ] [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ] [ vpn-instance vpn-instance-name ]
context-admin
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command clears information for all member devices.
source-ip source-ip: Specifies a source IPv4 address. The source-ip argument specifies the source IPv4 address of a unicast session from the initiator to the responder.
destination-ip destination-ip: Specifies a destination IPv4 address. The destination-ip argument specifies the destination IPv4 address of a unicast session from the initiator to the responder.
source-port source-port: Specifies a source port by its number. The source-port argument specifies the source port of a unicast session from the initiator to the responder. The value range for the source-port argument is 0 to 65535.
destination-port destination-port: Specifies a destination port by its number. The destination-port argument specifies the destination port of a unicast session from the initiator to the responder. The value range for the destination-port argument is 0 to 65535.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you want to clear IPv4 unicast session entries on the public network, do not specify this option.
If you do not specify any parameters, this command clears all IPv4 unicast session entries on the public network.
# Clear all IPv4 unicast session entries.
<Sysname> reset session table ipv4
# Clear the IPv4 unicast session entries with the source IP address of 10.10.10.10.
<Sysname> reset session table ipv4 source-ip 10.10.10.10
reset session table ipv6
Use reset session table ipv6 to clear information about IPv6 unicast session entries that match the specified criteria.
reset session table ipv6 [ slot slot-number ] [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ] [ vpn-instance vpn-instance-name ]
context-admin
source-ip source-ip: Specifies a source IPv6 address. The source-ip argument specifies the source IPv6 address of a unicast session from the initiator to the responder.
destination-ip destination-ip: Specifies a destination IPv6 address. The destination-ip argument specifies the destination IPv6 address of a unicast session from the initiator to the responder.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you want to clear IPv6 unicast session entries on the public network, do not specify this option.
If you do not specify any parameters, this command clears all IPv6 unicast session entries on the public network.
# Clear all IPv6 unicast session entries.
<Sysname> reset session table ipv6
# Clear the IPv6 unicast session entries with the source IP address of 2011::0002.
<Sysname> reset session table ipv6 source-ip 2011::0002
Use reset session table multicast to clear IP multicast session entries.
reset session table multicast [ slot slot-number ]
context-admin
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command clears multicast session entries for all member devices.
# Clear all multicast session entries.
<Sysname> reset session table multicast
Use reset session table multicast ipv4 to clear information about IPv4 multicast session entries that match specific criteria.
reset session table multicast ipv4 [ slot slot-number ] [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ] [ vpn-instance vpn-instance-name ]
context-admin
source-ip source-ip: Specifies a source IPv4 address. The source-ip argument specifies the source IPv4 address of a multicast session from the initiator to the responder.
destination-ip destination-ip: Specifies a destination IPv4 address. The destination-ip argument specifies the destination IPv4 address of a multicast session from the initiator to the responder.
source-port source-port: Specifies a source port by its number. The source-port argument specifies the source port of a multicast session from the initiator to the responder. The value range for the source-port argument is 0 to 65535.
destination-port destination-port: Specifies a destination port by its number. The destination-port argument specifies the destination port of a multicast session from the initiator to the responder. The value range for the destination-port argument is 0 to 65535.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you want to clear IPv4 multicast session entries on the public network, do not specify this option.
If you do not specify any parameters, this command clears all IPv4 multicast session entries on the public network.
# Clear all IPv4 multicast session entries.
<Sysname> reset session table multicast ipv4
# Clear the IPv4 multicast session entries with the source IP address of 10.10.10.10.
<Sysname> reset session table multicast ipv4 source-ip 10.10.10.10
Use reset session table multicast ipv6 to clear information about IPv6 multicast session entries that match specific criteria.
reset session table multicast ipv6 [ slot slot-number ] [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ] [ vpn-instance vpn-instance-name ]
context-admin
source-ip source-ip: Specifies a source IPv6 address. The source-ip argument specifies the source IPv6 address of a multicast session from the initiator to the responder.
destination-ip destination-ip: Specifies a destination IPv6 address. The destination-ip argument specifies the destination IPv6 address of a multicast session from the initiator to the responder.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you want to clear IPv6 multicast session entries on the public network, do not specify this option.
If you do not specify any parameters, this command clears all IPv6 multicast session entries on the public network.
# Clear all IPv6 multicast session entries.
<Sysname> reset session table multicast ipv6
# Clear the IPv6 multicast session entries with the source IP address of 2011::0002.
<Sysname> reset session table multicast ipv6 source-ip 2011::0002
Use session aging-time application to set the aging time for sessions of an application layer protocol or an application.
Use undo session aging-time application to restore the default. If you do not specify an application layer protocol or an application, this command restores the default aging time for all sessions of the supported application layer protocols and applications.
session aging-time application application-name time-value
undo session aging-time application [ application-name ]
The aging time is 1200 seconds for sessions of application layer protocols or applications except for the following sessions:
· BOOTPC sessions: 120 seconds.
· BOOTPS sessions: 120 seconds.
· DNS.
The following compatibility matrix shows the defaults for this command:
Series |
Models |
Default |
F50X0 series |
30 |
F5000-CN series |
30 |
F5000-AI series |
30 |
F5000-V series |
F5000-V30 |
30 |
F1000-AI series |
30 |
F1000-L series |
30 |
F10X0 series |
30 |
F1000-V series |
30 |
F1000-SASE series |
30 |
F1000-AK series |
F1000-AK108, F1000-AK109, F1000-AK110, F1000-AK115, F1000-AK120, F1000-AK125, F1000-AK130, F1000-AK135, F1000-AK140, F1000-AK145, F1000-AK150, F1000-AK155, F1000-AK160, F1000-AK165, F1000-AK170, F1000-AK175, F1000-AK180, F1000-AK185, F1000-GM-AK370, F1000-GM-AK380, F1000-AK710, F1000-AK711, F1000-AK1010, F1000-AK1020, F1000-AK1030, F1000-AK1110, F1000-AK1120, F1000-AK1130, F1000-AK1140, F1000-AK1150, F1000-AK1160, F1000-AK1170, F1000-AK1180, F1000-AK1212, F1000-AK1222, F1000-AK1232, F1000-AK1242, F1000-AK1252, F1000-AK1262, F1000-AK1272, F1000-AK1312, F1000-AK1322, F1000-AK1332, F1000-AK1342, F1000-AK1352, F1000-AK1362, F1000-AK1414, F1000-AK1424, F1000-AK1434, F1000-AK1514, F1000-AK1524, F1000-AK1534, F1000-AK1614 |
30 |
1 |
Firewall modules |
30 |
vFW series |
vFW1000, vFW2000 |
30 |
· FTP sessions: 3600 seconds.
· FTP-DATA sessions: 240 seconds.
· GPRS-DATA sessions: 60 seconds.
· GPRS-SIG sessions: 60 seconds.
· GTP-CONTROL sessions: 60 seconds.
· GTP-USER sessions: 60 seconds.
· H.225 sessions: 3600 seconds.
· H.245 sessions: 3600 seconds.
· HTTPS sessions: 600 seconds.
· ILS sessions: 3600 seconds.
· L2TP sessions: 120 seconds.
· MGCP-CALLAGENT sessions: 60 seconds.
· MGCP-GATEWAY sessions: 60 seconds.
· NETBIOS-DGM sessions: 3600 seconds.
· NETBIOS-NS sessions: 3600 seconds.
· NETBIOS-SSN sessions: 3600 seconds.
· NTP sessions: 120 seconds.
· PPTP sessions: 3600 seconds.
· QQ sessions: 120 seconds.
· RAS sessions: 300 seconds.
· RIP sessions: 120 seconds.
· RSH sessions: 60 seconds.
· RTSP session: 3600 seconds.
· SCCP sessions: 3600 seconds.
· SIP sessions: 300 seconds.
· SNMP sessions: 120 seconds.
· SNMPTRAP sessions: 120 seconds.
· SQLNET sessions: 600 seconds.
· STUN sessions: 600 seconds.
· SYSLOG sessions: 120 seconds.
· TACACS-DS sessions: 120 seconds.
· TFTP sessions: 60 seconds.
· WHO sessions: 120 seconds.
· XDMCP sessions: 3600 seconds.
context-admin
application-name: Specifies an application layer protocol or an application by its name, a case-insensitive string of 1 to 63 characters. Valid characters can be digits, letters, hyphens (-), and underscores (_). The names invalid and other are not allowed. The application layer protocol or application must exist on the device.
time-value: Specifies the aging time in seconds. The value range 1 to 100000.
This command sets the aging time for stable sessions of the specified application layer protocols or applications. For TCP sessions, the stable state is ESTABLISHED. For UDP sessions, the stable state is READY.
For sessions of application layer protocols or applications that are not supported by this command, the aging time is set by the session aging-time state command. For persistent sessions, the aging time is set by the session persistent acl command.
Supported application layer protocols or applications specified in this command depend on the APR module. For information about APR, see Security Configuration Guide.
# Set the aging time for FTP sessions to 1800 seconds.
[Sysname] session aging-time application ftp 1800
# Set the aging time for 126WebEmail sessions to 1800 seconds.
[Sysname] session aging-time application 126WebEmail 1800
display session aging-time application
nbar application
port-mapping
Use session aging-time state to set the aging time for the sessions in a protocol state.
Use undo session aging-time state to restore the default for the sessions in a protocol state. If you do not specify a protocol state, this command restores all aging time for sessions in different protocol states to the default.
session aging-time state { fin | icmp-reply | icmp-request | icmpv6-reply | icmpv6-request | rawip-open | rawip-ready | syn | tcp-close | tcp-est | tcp-time-wait | udp-open | udp-ready } time-value
undo session aging-time state [ fin | icmp-reply | icmp-request | icmpv6-reply | icmpv6-request | rawip-open | rawip-ready | syn | tcp-close | tcp-est | tcp-time-wait | udp-open | udp-ready ]
The aging time for sessions in different protocol states is as follows:
· FIN_WAIT: 30 seconds.
· ICMP-REPLY: 30 seconds.
· ICMP-REQUEST: 60 seconds.
· ICMPv6-REPLY: 30 seconds.
· ICMPv6-REQUEST: 60 seconds.
· RAWIP-OPEN: 30 seconds.
· RAWIP-READY: 60 seconds.
· TCP SYN-SENT and SYN-RCV: 30 seconds.
· TCP-CLOSE: 2 seconds.
· TCP ESTABLISHED: 3600 seconds.
· TCP TIME-WAIT: 2 seconds.
· UDP-OPEN: 30 seconds.
· UDP-READY: 60 seconds.
context-admin
fin: Specifies the TCP FIN_WAIT state.
icmp-reply: Specifies the ICMP REPLY state.
icmp-request: Specifies the IGMP REQUEST state.
icmpv6-reply: Specifies the ICMPv6 REPLY state.
icmpv6-request: Specifies the IGMPv6 REQUEST state.
rawip-open: Specifies the RAWIP-OPEN state.
rawip-ready: Specifies the RAWIP-READY state.
syn: Specifies the TCP SYN-SENT and SYN-RCV states.
tcp-close: Specifies the TCP CLOSE state.
tcp-est: Specifies the TCP ESTABLISHED state.
tcp-time-wait: Specifies the TCP TIME-WAIT state.
udp-open: Specifies the UDP OPEN state.
udp-ready: Specifies the UDP READY state.
time-value: Specifies the aging time in seconds. For the TCP CLOSE and TCP TIME-WAIT states, the value range is 0 to 100000. For other states, the value range is 1 to 100000.
This command sets the aging time for stable sessions of the application layer protocols that are not supported by the session aging-time application command. For persistent sessions, the aging time is set by the session persistent acl command.
# Set the aging time for TCP sessions in SYN-SENT and SYN-RCV states to 60 seconds.
[Sysname] session aging-time state syn 60
display session aging-time state
session alarm rate-abrupt enable
Use session alarm rate-abrupt enable to enable alarms for abrupt session creation rate changes.
Use undo session alarm rate-abrupt enable to disable alarms for abrupt session creation rate changes.
Alarms are disabled for abrupt session creation rate changes.
context-admin
This command enables the device to generate alarms for abrupt increase or drop in the session creation rate when the alarm thresholds for abrupt session creation rate changes are crossed.
# Enable alarms for abrupt session creation rate changes.
[Sysname] session alarm rate-abrupt enable
session alarm rate-abrupt threshold
Use session alarm rate-abrupt threshold to set the alarm thresholds for abrupt session creation rate changes.
Use undo session alarm rate-abrupt threshold to restore the default.
session alarm rate-abrupt threshold threshold-value [ base-threshold base-value ]
The session creation rate change threshold is 20%, and the base session creation rate threshold is 10%.
context-admin
threshold-value: Sets the session creation rate change threshold in percentage. The value range for this argument is 1 to 100.
base-threshold base-value: Sets the base session creation rate threshold in percentage. The value range for this argument is 1 to 100. If you do not specify this option, the default setting applies.
With alarms enabled for abrupt session creation rate changes, the system collects the session creation rate at an interval of 10 seconds and checks whether the following indicators reach the corresponding alarm thresholds:
· Session creation rate change in percentage—Obtained by dividing the difference between the session creation rates at the beginning and end of a collection interval by the session creation rate at the beginning of the collection interval.
· Base session creation rate in percentage—Obtained by dividing the session creation rate at the beginning of a collection interval by 100000.
If both of the following conditions are met in a detection interval, the system generates an alarm for the abrupt change of the session creation rate:
· The session creation rate change threshold is reached.
· The base session creation rate threshold is crossed.
# Set the session creation rate change threshold to 30%.
[Sysname] session alarm rate-abrupt threshold 30
session alarm try-rate-abrupt enable
Use session alarm try-rate-abrupt enable to enable alarms for abrupt session attempt rate changes.
Use undo session alarm try-rate-abrupt enable to disable alarms for abrupt session attempt rate changes.
Alarms are disabled for abrupt session attempt rate changes.
context-admin
This command enables the device to generate alarms for abrupt increase or drop in the session creation attempt rate when the alarm thresholds for abrupt session attempt rate changes are reached.
# Enable alarms for abrupt session attempt rate changes.
[Sysname] session alarm try-rate-abrupt enable
session alarm try-rate-abrupt threshold
Use session alarm try-rate-abrupt threshold to set the alarm thresholds for abrupt session attempt rate changes.
Use undo session alarm try-rate-abrupt threshold to restore the default.
session alarm try-rate-abrupt threshold threshold-value [ base-threshold base-value ]
The session attempt rate change threshold is 20%, and the base session attempt rate threshold is 10%.
context-admin
threshold-value: Sets the session attempt rate change threshold in percentage. The value range for this argument is 1 to 100.
base-threshold base-value: Sets the base session attempt rate threshold in percentage. The value range for this argument is 1 to 100. If you do not specify this option, the default setting applies.
With alarms enabled for abrupt session attempt rate changes, the system collects the session creation attempt rate at an interval of 10 seconds and checks whether the following indicators reach the corresponding alarm thresholds:
· Session attempt rate change in percentage—Obtained by dividing the difference between the session creation attempt rates at the beginning and end of a collection interval by the session creation attempt rate at the beginning of the collection interval.
· Base session attempt rate in percentage—Obtained by dividing the session creation attempt rate at the beginning of a collection interval by 100000.
If both of the following conditions are met in a detection interval, the system generates an alarm for the abrupt change of the session creation attempt rate:
· The session attempt rate change threshold is reached.
· The base session attempt rate threshold is crossed.
# Set the session attempt rate change threshold to 30%.
[Sysname] session alarm try-rate-abrupt threshold 30
session alarm usage-abrupt enable
Use session alarm usage-abrupt enable to enable alarms for abrupt session table usage changes.
Use undo session alarm usage-abrupt enable to disable alarms for abrupt session table usage changes.
Alarms are disabled for abrupt session table usage changes.
context-admin
This command enables the device to generate alarms for abrupt increase or drop in the session table usage when the alarm thresholds for abrupt session table usage changes are reached.
# Enable alarms for abrupt session table usage changes.
[Sysname] session alarm usage-abrupt enable
session alarm usage-abrupt threshold
Use session alarm usage-abrupt threshold to set the alarm thresholds for abrupt session table usage changes.
Use undo session alarm usage-abrupt threshold to restore the default.
session alarm usage-abrupt threshold threshold-value [ base-threshold base-value ]
The session table usage change threshold is 20%, and the base session table usage threshold is 10%.
context-admin
threshold-value: Sets the session table usage change threshold in percentage. The value range for this argument is 1 to 100.
base-threshold base-value: Sets the base session table usage threshold in percentage. The value range for this argument is 1 to 100. If you do not specify this option, the default setting applies.
With alarms enabled for abrupt session table usage changes, the system collects the session table usage at an interval of 10 seconds and checks whether the following indicators reach the corresponding alarm thresholds:
· Session table usage change in percentage—Obtained by dividing the difference between the session entry counts at the beginning and end of a collection interval by the session entry count at the beginning of the collection interval.
· Base session table usage in percentage—Obtained by dividing the session entry count at the beginning of a collection interval by the supported maximum number of session entries.
If both of the following conditions are met in a detection interval, the system generates an alarm for the abrupt change of the session table usage:
· The session table usage change threshold is reached.
· The base session table usage threshold is crossed.
# Set the session table usage change threshold to 30%.
[Sysname] session alarm usage-abrupt threshold 30
session alg fragment
Use session alg fragment to enable ALG to process fragments.
Use undo session alg fragment to disable ALG from processing fragments.
session alg fragment sip
undo session alg fragment sip
ALG does not process fragments.
context-admin
sip: Specifies SIP fragments.
This command enables ALG to process fragments of specified protocols. In the current software version, ALG can process only SIP fragments.
# Enable ALG to process SIP fragments.
<Sysname> system
[Sysname] session alg fragment sip
session dual-active create-mode
Use session dual-active create-mode to set the session creation mode when the device is operating in session dual-active mode.
Use undo session dual-active create-mode to restore the default.
session dual-active create-mode { hash | local }
Local-based session creation is used in session dual-active mode.
context-admin
hash: Specifies hash-based session creation.
local: Specifies local-based session creation.
This feature takes effect only in session dual-active mode.
In a hot backup system operating in session dual-active mode, both devices process services. To balance the service load on the devices, you can use one of the following session creation modes:
· Hash-based session creation—A session is created on the device to which its first packet is relayed according to the hash result. The device where a session is created might not be the device that receives the traffic. This mode applies if traffic is unevenly distributed among the devices.
· Local-based session creation—A session is created on the device where the first packet of the session arrives. This mode applies if traffic is evenly distributed among the devices.
# Enable hash-based session creation when the device is operating in session dual-active mode.
[Sysname] session dual-active create-mode hash
session dual-active enable
Use session dual-active enable to enable session dual-active mode.
Use undo session dual-active enable to disable session dual-active mode.
Session dual-active mode is disabled. The device is operating in session active/standby mode.
context-admin
In a hot backup system operating in session active/standby mode, only one device processes security services. Session dual-active mode increases load capacity of the system by enabling both devices to process security services.
# Enable session dual-active mode.
[Sysname] session dual-active enable
session synchronization enable
session dual-active transparent udp enable
Use session dual-active transparent udp enable to enable transparent transmission for UDP packets in session dual-active mode.
Use undo session dual-active transparent udp enable to disable transparent transmission for UDP packets in session dual-active mode.
Transparent transmission for UDP packets is disabled in session dual-active mode.
context-admin
In a hot backup system operating in session dual-active mode, a device cannot identify the direction of packets in a UDP traffic flow due to UDP mechanisms. By default, if the return packets of a session do not match any sessions, the device creates a new session. This results in the following issues:
· If the security control policy permits a UDP traffic flow in one direction, the return packets of the flow are dropped.
· If the security control policy permits a UDP traffic flow in both directions, two sessions are created for the flow. This affects traffic processing of security services.
To resolve these issues, you can enable transparent transmission for UDP packets. This feature allows a device to relay UDP packets that do not match any sessions to the other device in the hot back system. If the UDP packets also do not match any sessions on the other device, a new session is created locally.
As a best practice, enable this feature only when asymmetric UDP traffic exists in the hot backup system and sessions cannot be synchronized timely. This feature degrades forwarding performance. Make sure you are fully aware of the impact of this feature when you use it on a live network.
Transparent transmission for UDP packets takes effect only when local-based session creation is used. If hash-based session creation is used, the devices do not relay UDP packets.
# Enable transparent transmission for UDP packets in session dual-active mode.
[Sysname] session dual-active transparent udp enable
session fast-drop aging-time
Use session fast-drop aging-time to set the aging time for deny sessions.
Use undo session fast-drop aging-time to restore the default.
session fast-drop aging-time time-value
The following compatibility matrix shows the support of hardware platforms for this command:
Series |
Models |
Command compatibility |
F50X0 series |
F5010, F5020, F5020-GM, F5030, F5030-6GW, F5040, F5060, F5080, F5000-A, F5000-C, F5000-S, F5000-M |
Yes |
F5000-CN series |
F5000-CN30, F5000-CN60 |
Yes |
F5000-AI series |
F5000-AI-15, F5000-AI-20, F5000-AI-40 |
Yes |
F5000-V series |
F5000-V30 |
Yes |
F1000-AI series |
F1000-AI-05, F1000-AI-10, F1000-AI-15, F1000-AI-20, F1000-AI-25, F1000-AI-30, F1000-AI-35, F1000-AI-50, F1000-AI-55, F1000-AI-60, F1000-AI-65, F1000-AI-70, F1000-AI-75, F1000-AI-80, F1000-AI-90 |
Yes |
F1000-L series |
F1003-L, F1005-L, F1010-L |
Yes |
F10X0 series |
F1005, F1010, F1020, F1020-GM, F1030, F1030-GM, F1050, F1060, F1070, F1070-GM, F1070-GM-L, F1080, F1090 |
Yes |
F1000-V series |
F1000-V50, F1000-V60, F1000-V70, F1000-V90 |
Yes |
F1000-SASE series |
F1000-SASE100, F1000-SASE200 |
Yes |
F1000-AK series |
F1000-AK108, F1000-AK109, F1000-AK110, F1000-AK115, F1000-AK120, F1000-AK125, F1000-AK130, F1000-AK135, F1000-AK140, F1000-AK145, F1000-AK150, F1000-AK155, F1000-AK160, F1000-AK165, F1000-AK170, F1000-AK175, F1000-AK180, F1000-AK185, F1000-GM-AK370, F1000-GM-AK380, F1000-AK710, F1000-AK711, F1000-AK1010, F1000-AK1020, F1000-AK1030, F1000-AK1110, F1000-AK1120, F1000-AK1130, F1000-AK1140, F1000-AK1150, F1000-AK1160, F1000-AK1170, F1000-AK1180, F1000-AK1212, F1000-AK1222, F1000-AK1232, F1000-AK1242, F1000-AK1252, F1000-AK1262, F1000-AK1272, F1000-AK1312, F1000-AK1322, F1000-AK1332, F1000-AK1342, F1000-AK1352, F1000-AK1362, F1000-AK1414, F1000-AK1424, F1000-AK1434, F1000-AK1514, F1000-AK1524, F1000-AK1534, F1000-AK1614, F1000-AK9110, F1000-AK9210 |
Yes |
Firewall modules |
IM-NGFWX-IV, LSPM6FWD, LSPM6FWDB, LSQM1FWDSC0, LSQM2FWDSC0, LSU3FWCEA0, LSUM1FWCEAB0, LSUM1FWDEC0, LSWM1FWD0, LSX1FWCEA1, LSXM1FWDF1 |
No |
vFW series |
vFW1000, vFW2000 |
No |
The aging time for deny sessions is 3 seconds.
context-admin
time-value: Specifies the aging time in seconds. The value range 1 to 3.
The system deletes deny sessions based on the deny session aging time. The deny session aging time is not refreshed when packets match deny sessions.
# Set the aging time for deny sessions to 1 second.
[Sysname] session fast-drop aging-time 1
session fast-drop aspf enable
session fast-drop enable
Use session fast-drop enable to enable the deny session feature for modules.
Use undo session fast-drop enable to disable the deny session feature for modules.
session fast-drop { aspf | connection-limit } * enable
undo session fast-drop { aspf | connection-limit } * enable
Series |
Models |
F50X0 series |
Yes |
F5000-CN series |
Yes |
F5000-AI series |
Yes |
F5000-V series |
F5000-V30 |
Yes |
F1000-AI series |
Yes |
F1000-L series |
Yes |
F10X0 series |
Yes |
F1000-V series |
Yes |
F1000-SASE series |
Yes |
F1000-AK series |
Yes |
Firewall modules |
No |
vFW series |
vFW1000, vFW2000 |
No |
The deny session feature is disabled.
aspf: Specifies the ASPF module.
connection-limit: Specifies the connection limit module.
context-admin
The deny session feature allows the device to create sessions for dropped packets. These sessions are called deny sessions. To improve forwarding performance, the device drops all packets that match deny sessions.
The device generates deny sessions only for the packets dropped by the ASPF or connection limit module.
# Enable the deny session feature for ASPF.
[Sysname] session fast-drop aspf enable
display session fast-drop table ipv4
display session fast-drop table ipv6
session fast-drop resource-ratio
Use session fast-drop resource-ratio to set the maximum ratio of deny sessions to all sessions.
Use undo session fast-drop resource-ratio to restore the default.
session fast-drop resource-ratio ratio
Series |
Models |
F50X0 series |
Yes |
F5000-CN series |
Yes |
F5000-AI series |
Yes |
F5000-V series |
F5000-V30 |
Yes |
F1000-AI series |
Yes |
F1000-L series |
Yes |
F10X0 series |
Yes |
F1000-V series |
Yes |
F1000-SASE series |
Yes |
F1000-AK series |
Yes |
Firewall modules |
No |
vFW series |
vFW1000, vFW2000 |
No |
The maximum ratio of deny sessions to all sessions is 20‰.
context-admin
ratio: Specifies the maximum ratio of deny sessions to all sessions, in permillage. The value range for this argument is 1 to 20.
When the ratio of deny session entries reaches the maximum ratio set by using this command, the device stops generating deny sessions.
# Set the maximum ratio of deny sessions to all sessions to 1‰.
[Sysname] session fast-drop resource-ratio 1
session fast-drop top-statistics enable
Use session fast-drop top-statistics enable to enable the top deny session statistics feature.
Use undo session fast-drop top-statistics enable to disable the top deny session statistics feature.
Series |
Models |
F50X0 series |
Yes |
F5000-CN series |
Yes |
F5000-AI series |
Yes |
F5000-V series |
F5000-V30 |
Yes |
F1000-AI series |
Yes |
F1000-L series |
Yes |
F10X0 series |
Yes |
F1000-V series |
Yes |
F1000-SASE series |
Yes |
F1000-AK series |
Yes |
Firewall modules |
No |
vFW series |
vFW1000, vFW2000 |
No |
The top deny session statistics feature is disabled.
context-admin
This command collects the number of deny sessions for session-based services and ranks the deny sessions by source address and by destination address.
To display the top deny session statistics, use the display session fast-drop top-statistics command.
# Enable the top deny session statistics feature.
[Sysname] session fast-drop top-statistics enable
session log { bytes-active | packets-active }
Use session log { bytes-active | packets-active } to set a threshold for traffic-based logging.
Use undo session log { bytes-active | packets-active } to restore the default.
session log { bytes-active bytes-value | packets-active packets-value }
No threshold is set for traffic-based logging.
context-admin
bytes-value: Specifies the byte-based threshold in the range of 1 to 100000 MB.
packets-value: Specifies the packet-based threshold in the range of 1 to 100000 mega-packets.
For this command to take effect, make sure the session statistics collection for software fast forwarding feature is enabled.
If you set both the traffic-based and time-based logging, the device outputs a session log when whichever is reached. After outputting a session log, the device resets the traffic counter and restarts the interval for the session.
# Configure the device to output session logs on a per-10-mega-packet basis.
[Sysname] session statistics enable
[Sysname] session log packets-active 10
session log enable
session log enable
Use session log enable to enable session logging.
Use undo session log enable to disable session logging.
session log enable { ipv4 | ipv6 } [ acl acl-number ] { inbound | outbound }
undo session log enable { ipv4 | ipv6 } [ acl acl-number ] { inbound | outbound }
Session logging is disabled.
Interface view
context-admin
ipv4: Logs IPv4 sessions.
ipv6: Logs IPv6 sessions.
acl acl-number: Specifies an ACL by its number in the range of 2000 to 3999. If you do not specify an ACL, this command enables session logging for all IPv4 or IPv6 sessions on the interface.
inbound: Specifies the inbound direction.
outbound: Specifies the outbound direction.
If you do not specify the inbound or the outbound keyword, this command enables session logging on both directions.
A maximum of one IPv4 ACL and one IPv6 ACL can be applied to each direction.
After session logging is enabled, the device outputs session logs as follows:
· Outputs a session log when the specified traffic threshold or interval is reached.
· Outputs a session log when a session entry is created or removed only if the logging for session creation or deletion is enabled.
The session logging feature must work with the flow log or fast log output feature to generate session logs. Session logs can be output in flow log or fast log output format. By default, they are output in flow log format. For information about flow log and fast log output, see Network Management and Monitoring.
# Enable IPv4 session logging in the inbound direction of GigabitEthernet 1/0/1.
[Sysname] session log flow-begin
[Sysname] session log flow-end
[Sysname-GigabitEthernet1/0/1] session log enable ipv4 inbound
# Enable session logging on GigabitEthernet 1/0/2 for IPv4 sessions that match ACL 2050 in the outbound direction.
[Sysname-GigabitEthernet1/0/2] session log enable ipv4 acl 2050 outbound
# Enable session logging on GigabitEthernet 1/0/3 for IPv6 sessions that match ACL 2050 in the outbound direction.
[Sysname] interface gigabitethernet 1/0/3
[Sysname-GigabitEthernet1/0/3] session log enable ipv6 acl 2050 outbound
session log bytes-active
session log time-active
Use session log flow-begin to enable logging for session creation.
Use undo session log flow-begin to disable logging for session creation.
Logging for session creation is disabled.
context-admin
For the device to output a session log when a session entry is created, make sure both session logging and logging for session creation are enabled.
# Enable logging for session creation.
session log enable
Use session log flow-end to enable logging for session deletion.
Use undo session log flow-end to disable logging for session deletion.
Logging for session deletion is disabled.
context-admin
For the device to output a session log when a session entry is deleted, make sure both session logging and logging for session deletion are enabled.
# Enable logging for session deletion.
session log enable
Use session log time-active to set the time-based session logging.
Use undo session log time-active to restore the default.
session log time-active time-value
The device does not output session logs.
context-admin
time-value: Specifies the interval in minutes. The value range for the time-value argument is 10 to 120 and the value must be integer times of 10.
If you set both time-based and traffic-based logging, the device outputs a session log when whichever is reached. After outputting a session log, the device resets the traffic counter and restarts the interval for the session.
# Configure the device to output session logs every 50 minutes.
<Sysname> system
[Sysname] session log time-active 50
session log enable
Use session persistent acl to specify persistent sessions.
Use undo session persistent acl to restore the default.
session persistent acl [ ipv6 ] acl-number [ aging-time time-value ]
undo session persistent acl [ ipv6 ] acl-number
No persistent sessions exist.
context-admin
ipv6: Specifies an IPv6 ACL. To specify an IPv4 ACL, do not specify this keyword.
aging-time time-value: Specifies the aging time for persistent sessions in hours. The value range for the time-value argument is 0 to 360, and the default value is 24. To disable the aging for persistent sessions, set the value to 0.
This command is effective only on TCP sessions in ESTABLISHED state.
For a TCP session in ESTABLISHED state, the priority of the aging time is as follows:
· Aging time for persistent sessions.
· Aging time for sessions of application layer protocols.
· Aging time for sessions in different protocol states.
A persistent session is not removed until one of the following events occurs:
· The session entry ages out.
· The device receives a connection close request from the initiator or responder.
· You manually clear the session entries.
The configuration of persistent sessions applies only to new sessions. It has no effect on existing sessions.
Repeat this command to use multiple ACLs to specify persistent sessions.
# Specify IPv4 ACL 2000 for identifying persistent sessions and set the aging time to 72 hours.
[Sysname] session persistent acl 2000 aging-time 72
# Specify IPv6 ACL 3000 for identifying persistent sessions and set the aging time to 100 hours.
[Sysname] session persistent acl ipv6 3000 aging-time 100
session state-machine mode
Use session state-machine mode to set the mode of session state machine.
Use undo session state-machine mode to restore the default.
session state-machine mode { compact | loose }
The session state machine is in strict mode.
context-admin
compact: Specifies compact mode.
loose: Specifies loose mode.
When asymmetric-path traffic exists in a hot backup system operating in session active/standby mode, set the mode of session state machine to loose to avoid abnormal traffic loss.
When asymmetric-path traffic exists in a hot backup system operating in session dual-active mode, set the mode of session state machine to compact for disconnected sessions to age out timely.
As a best practice, change the mode of session state machine only when asymmetric-path traffic exists. This feature degrades performance of session-based security check. Make sure you are fully aware of the impact of this command when you use it on a live network.
# Set the mode of session state machine to loose.
[Sysname] session state-machine mode loose
Use session statistics enable to enable session statistics collection for software fast forwarding.
Use undo session statistics enable to disable session statistics collection for software fast forwarding.
Series |
Models |
Default |
F50X0 series |
F5010, F5020, F5020-GM, F5040, F5000-C, F5000-S |
Session statistics collection is enabled for software fast forwarding. |
F5030, F5030-6GW, F5060, F5080, F5000-A, F5000-M |
Session statistics collection is disabled for software fast forwarding. |
F5000-CN series |
F5000-AI series |
F5000-V series |
F5000-V30 |
F1000-AI series |
F1000-AI-05, F1000-AI-10, F1000-AI-15, F1000-AI-60, F1000-AI-65, F1000-AI-70, F1000-AI-75, F1000-AI-80, F1000-AI-90 |
F1000-AI-20, F1000-AI-25, F1000-AI-30, F1000-AI-35, F1000-AI-50, F1000-AI-55 |
F1000-L series |
F10X0 series |
F1005, F1010, F1090 |
F1020, F1020-GM, F1030, F1030-GM, F1050, F1060, F1070, F1070-GM, F1070-GM-L, F1080 |
F1000-V series |
F1000-V50, F1000-V60, F1000-V70 |
F1000-V90 |
F1000-SASE series |
F1000-AK series |
F1000-AK130, F1000-AK135, F1000-AK140, F1000-AK145, F1000-AK150, F1000-AK155, F1000-AK160, F1000-AK165, F1000-AK170, F1000-AK175, F1000-AK180, F1000-AK185, F1000-GM-AK370, F1000-GM-AK380, F1000-AK711, F1000-AK1212, F1000-AK1222, F1000-AK1232, F1000-AK1242, F1000-AK1252, F1000-AK1262, F1000-AK1272, F1000-AK1312, F1000-AK1322, F1000-AK1332, F1000-AK1342, F1000-AK1352, F1000-AK1362 |
F1000-AK108, F1000-AK109, F1000-AK110, F1000-AK115, F1000-AK120, F1000-AK125, F1000-AK710, F1000-AK1010, F1000-AK1020, F1000-AK1030F1000-AK1110, F1000-AK1120, F1000-AK1130, F1000-AK1140, F1000-AK1150, F1000-AK1160, F1000-AK1170, F1000-AK1180, F1000-AK1414, F1000-AK1424, F1000-AK1434, F1000-AK1514, F1000-AK1524, F1000-AK1534, F1000-AK1614, F1000-AK9110, F1000-AK9210 |
Firewall modules |
vFW series |
vFW1000, vFW2000 |
context-admin
This command enables the device to collect the session-based outbound and inbound packets and bytes for software fast forwarding.
To display statistics per session, use the display session table command. To display statistics per packet type, use the display session statistics command.
This command is CPU and memory intensive. Before using this command, make sure you fully understand its impact on system performance.
# Enable session statistics collection for software fast forwarding.
session synchronization { dns | http } *
Use session synchronization { dns | http } * to enable session synchronization for DNS, HTTP, or both.
Use undo session synchronization { dns | http } * to disable session synchronization for DNS, HTTP, or both.
Session synchronization is disabled for DNS and HTTP.
context-admin
dns: Specifies the DNS protocol.
http: Specifies the HTTP protocol.
DNS or HTTP connections usually do not last long. When a DNS or HTTP connection is terminated because of an active/standby switchover, the client will immediately reinitiate a connection request. The connection exception is barely noticed.
DNS and HTTP sessions do not require session synchronization except for the following conditions:
· Users are aware that the current HTTP or DNS sessions will last for a long time.
· HTTP or DNS session backup is required.
For this command to take effect, you must also configure the session synchronization enable command.
This command takes effect only on sessions of the application protocols HTTP and DNS. Sessions of other application protocols will be backed up if the session synchronization enable command is configured.
# Enable session synchronization for stateful failover, and enable session synchronization for HTTP.
[Sysname] session synchronization enable
[Sysname] session synchronization http
Use session synchronization enable to enable session synchronization for stateful failover.
Use undo session synchronization enable to disable session synchronization for stateful failover.
session synchronization enable [ asymmetric ]
Session synchronization for stateful failover is disabled.
context-admin
asymmetric: Specifies asymmetric traffic. If you do not specify this keyword, this command supports only symmetric traffic.
This features enables the master and backup devices to synchronize sessions and dynamic entries of session-based services.
In a network that has asymmetric traffic, heavy service traffic might cause service delay or service unavailable because sessions cannot be backed up timely. For example, one device forwards the TCP SYN packets, and another device forwards its ACK packets. If the session tables of the two devices are not synchronized, the TCP packets will be dropped because of state error. To resolve this issue, use the session synchronization enable asymmetric command.
This command cannot be used together with the hot-backup enable command.For information about the hot-backup enable command, see HA group commands in High Availability Command Reference.
# Enable session synchronization for stateful failover.
<Sysname> session synchronization enable
# Enable session synchronization for both symmetric and asymmetric traffic.
<Sysname> session synchronization enable asymmetric
hot-backup enable (High Availability Command Reference)
Use session top-statistics enable to enable the top session statistics feature.
Use undo session top-statistics enable to disable the top session statistics feature.
The top session statistics feature is disabled.
context-admin
This command collects the number of sessions for session-based services and ranks the sessions by source address and by destination address.
To display the top session statistics, use the display session top-statistics command.
# Enable the top session statistics feature.
[Sysname] session top-statistics enable
