13-Layer 3—IP Services Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C SecPath F1000[F5000][VFW] Firewalls Series Configuration Guides(V7)-6W60013-Layer 3—IP Services Configuration Guide
11-Multi-CPU packet distribution configuration
11-Multi-CPU packet distribution configuration 43.11 KB
Configuring multi-CPU packet distribution
About multi-CPU packet distribution
On a multi-CPU device, packets can be distributed among CPUs based on one of the following policies:
·     Flow-based policy—Forwards packets of a flow to one CPU or multiple CPUs. The CPU processes flow packets by following the first-in first-out rule. The device supports using the source IP address, destination IP address, source port number, destination port number, and protocol number to identify a flow.
·     Packet-based policy—Forwards packets in sequence to different CPUs, even though they are the same flow. This policy does not ensure packet order.
Restrictions and guidelines: Multi-CPU packet distribution configuration
If a service requires packets of a flow to be received by the same CPU, you must use the flow-based policy.
Specifying a packet distribution policy
2.     Specify a packet distribution policy.
forwarding policy { per-flow [ three-tuple | mode { source-ip | destination-ip | source-port | destination-port } ] | per-packet }
By default, the device uses the flow-based policy that identifies a flow by source IP address, destination IP address, source port number, destination port number, and protocol number.
Support for the three-tuple and mode keywords depends on the device model. For more information, see the command reference.
