01-Fundamentals Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S6800 & S6860 Switch Series Command References-Release 6715-6W10001-Fundamentals Command Reference
12-Device management commands
12-Device management commands 724.59 KB
Device management commands· 1
clock datetime· 1
clock delay-compensation· 2
clock protocol 2
clock summer-time· 3
clock timezone· 5
command· 5
copyright-info enable· 7
display alarm·· 7
display alarm active· 8
display alarm history· 11
display clock· 13
display copyright 13
display cpu-usage· 14
display cpu-usage configuration· 15
display cpu-usage history· 16
display device· 17
display device manuinfo· 18
display device manuinfo fan· 19
display device manuinfo power 20
display diagnostic-information· 20
display environment 22
display fan· 23
display hardware-resource switch-mode· 24
display key-component 25
display memory· 28
display memory dma· 29
display memory-threshold· 30
display memory-threshold dma· 32
display power 32
display power history· 34
display resource-monitor 36
display scheduler job· 37
display scheduler logfile· 37
display scheduler reboot 38
display scheduler schedule· 39
display system health· 40
display system health history· 41
display system stable state· 42
display system-working-mode· 43
display transceiver alarm·· 44
display transceiver diagnosis· 46
display transceiver eyediagram-diagnosis· 48
display transceiver interface· 50
display transceiver manuinfo· 50
display transceiver power 51
display version· 52
display version-update-record· 53
fan prefer-direction· 54
hardware-alarm disable· 54
hardware-resource switch-mode· 55
header 57
job· 57
memory-threshold· 58
memory-threshold dma· 60
memory-threshold usage· 61
monitor cpu-usage enable· 61
monitor cpu-usage interval 62
monitor cpu-usage logging interval 63
monitor cpu-usage threshold· 63
monitor memory-usage logging interval 64
monitor resend cpu-usage· 65
monitor resend memory-threshold· 66
parity-error consistency-check log enable· 67
parity-error consistency-check threshold· 68
parity-error monitor log enable· 69
parity-error monitor period· 69
parity-error monitor threshold· 70
parity-error unrecoverable log enable· 71
parity-error unrecoverable period· 71
parity-error unrecoverable reboot 72
parity-error unrecoverable threshold· 73
password-recovery enable· 74
reboot 74
reset alarm active· 76
reset scheduler logfile· 76
reset version-update-record· 77
resource-monitor minor resend enable· 77
resource-monitor output 78
resource-monitor resource· 79
restore factory-default 81
scheduler job· 81
scheduler logfile size· 82
scheduler reboot at 83
scheduler reboot delay· 84
scheduler schedule· 84
shutdown-interval 85
sysid· 86
sysname· 87
system-working-mode· 87
temperature-limit 88
time at 89
time once· 90
time repeating· 91
transceiver lane cdr 92
transceiver monitor enable· 93
transceiver monitor interval 94
transceiver power-mode· 95
usb disable· 95
user-role· 96
clock datetime
Use clock datetime to set the system time.
clock datetime time date
The system time is UTC time 00:00:00 01/01/2011.
time: Specifies a time in the hh:mm:ss format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. The value range for ss is 0 to 59. The leading zero in a segment can be omitted. If the seconds segment is 0 (hh:mm:00), you can omit it. If both the minutes and seconds segments are 0 (hh:00:00), you can omit both of the segments. For example, to specify 08:00:00, you can enter 8.
date: Specifies a date in the MM/DD/YYYY or YYYY/MM/DD format. The value range for YYYY is 2000 to 2035. The value range for MM is 1 to 12. The value range for DD varies by month.
CAUTION
CAUTION:
Change of the system time affects execution of system time-related features (such as scheduled tasks) and cooperative operation with other devices (such as log reporting and statistics collection). Before executing this command, make sure you understand its impact on the live network.
Correct system time is essential to network management and communication. You must configure the system time correctly before you run the device on the network.
For the device to use the local system time, execute the clock protocol none command and this command in turn. The specified system time takes effect immediately. Then, the device uses the clock signals generated by its built-in crystal oscillator to maintain the system time.
# Set the system time to 08:08:08 01/01/2015.
<Sysname> clock datetime 8:8:8 1/1/2015
# Set the system time to 08:10:00 01/01/2015.
<Sysname> clock datetime 8:10 2015/1/1
clock protocol
clock summer-time
clock timezone
display clock
Use clock delay-compensation to configure the delay compensation duration for obtaining time.
Use undo clock delay-compensation to restore the default.
clock delay-compensation { 1pps | gps } timer
undo delay-clock compensation { 1pps | gps }
The delay compensation duration for obtaining time is 0.
1pps: Specifies the 1PPS method for obtaining time. This keyword is required if the device obtains time through a coaxial cable.
gps: Specifies the GPS method for obtaining time. This keyword is required if the device obtains time through an external antenna.
timer: Specifies the delay compensation duration, in the range of 1 to 65535, in ns. The delay compensation duration is determined by the length of the used coaxial cable or external antenna.
When you execute this command, you need to determine the delay compensation duration based on the actual length of the external antenna or coaxial cable.
# Specify the delay compensation duration as 5 ns for obtaining time through GPS.
[Sysname] clock delay-compensation gps 5
clock protocol
Use clock protocol to specify the system time source.
Use undo clock protocol to restore the default.
clock protocol { none | ntp | ptp }
undo clock protocol
The device obtains the UTC time from an NTP time source.
none: Uses the system time set by using the clock datetime command.
ptp: Uses PTP to obtain the UTC time. You must configure PTP correctly. For more information about PTP and PTP configuration, see Network Management and Monitoring Configuration Guide.
The ptp keyword is not supported on the S6860 switch series.
ntp: Uses NTP to obtain the UTC time. You must configure NTP correctly. For more information about NTP and NTP configuration, see Network Management and Monitoring Configuration Guide.
The device can use the locally set system time, or obtain the UTC time from a time source on the network and calculate the system time.
If you execute the clock protocol none command, the device uses the locally set system time. The device then uses the clock signals generated by its built-in crystal oscillator to maintain the system time.
If you execute the clock protocol { ntp | ptp } command, the device obtains the UTC time through NTP or PTP and calculates the system time. The device then periodically synchronizes the UTC time and recalculates the system time.
# Configure the device to use the local UTC time.
[Sysname] clock protocol none
clock summer-time
Use clock summer-time to set the daylight saving time.
Use undo clock summer-time to restore the default.
The daylight saving time is not set.
name: Specifies a name for the daylight saving time schedule, a case-sensitive string of 1 to 32 characters.
start-time: Specifies the start time in the hh:mm:ss format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. The value range for ss is 0 to 59. The leading zero in a segment can be omitted. If the seconds segment is 0 (hh:mm:00), you can omit it. If both the minutes and seconds segments are 0 (hh:00:00), you can omit both of the segments. For example, to specify 08:00:00, you can enter 8.
start-date: Specifies the start date in one of the following formats:
·     MM/DD. The value range for MM is 1 to 12. The value range for DD varies by month.
·     month week day, where:
¡     month—Takes January, February, March, April, May, June, July, August, September, October, November or December.
¡     week—Represents week of the month. It takes first, second, third, fourth, fifth, or last.
¡     day—Takes Sunday, Monday, Tuesday, Wednesday, Thursday, Friday, or Saturday.
end-time: Specifies the end time in the hh:mm:ss format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. The value range for ss is 0 to 59. The leading zero in a segment can be omitted. If the seconds segment is 0 (hh:mm:00), you can omit it. If both the minutes and seconds segments are 0 (hh:00:00), you can omit both of the segments. For example, to specify 08:00:00, you can enter 8.
end-date: Specifies the end date in one of the following formats:
add-time: Specifies the time to be added to the standard time, in the hh:mm:ss format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. The value range for ss is 0 to 59. The leading zero in a segment can be omitted. If the seconds segment is 0 (hh:mm:00), you can omit it. If both the minutes and seconds segments are 0 (hh:00:00), you can omit both of the segments. For example, to specify 08:00:00, you can enter 8.
After you set the daylight saving time, the device recalculates the system time. To view the system time, use the display clock command.
Make sure all devices on the network are using the same daylight saving time as the local time.
# Set the system time ahead 1 hour for the period between 06:00:00 on 08/01 and 06:00:00 on 09/01.
[Sysname] clock summer-time PDT 6 08/01 6 09/01 1
clock datetime
clock timezone
display clock
clock timezone
Use clock timezone to set the time zone.
Use undo clock timezone to restore the default.
undo clock timezone
The UTC time zone is used.
zone-name: Specifies a time zone by its name, a case-sensitive string of 1 to 32 characters.
add: Adds an offset to the UTC time.
minus: Decreases the UTC time by an offset.
zone-offset: Specifies an offset to the UTC time, in the hh:mm:ss format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. The value range for ss is 0 to 59. The leading zero in a segment can be omitted. If the seconds segment is 0 (hh:mm:00), you can omit it. If both the minutes and seconds segments are 0 (hh:00:00), you can omit both of the segments. For example, to specify 08:00:00, you can enter 8.
After you set the time zone, the device recalculates the system time. To view the system time, use the display clock command.
Make sure all devices on the network are using the same time zone as the local time.
# Set the name of the time zone to Z5, and add 5 hours to the UTC time.
[Sysname] clock timezone Z5 add 5
clock datetime
clock summer-time
display clock
command
Use command to assign a command to a job.
Use undo command to revoke a command.
command id command
undo command id
No command is assigned to a job.
Job view
id: Specifies an ID for the command, in the range of 0 to 4294967295. A command ID uniquely identifies a command in a job. Commands in a job are executed in ascending order of their command IDs.
command: Specifies the command to be assigned to the job.
To assign a command (command A) to a job, you must first assign the job the command or commands for entering the view of command A.
If you specify the ID of an existing command for another command, the existing command is replaced.
Make sure all commands in a schedule are compliant to the command syntax. The system does not examine the syntax when you assign a command to a job.
If a command requires a yes or no answer, the system always assumes that a Y or Yes is entered. If a command requires a character string input, the system assumes that either the default character string (if any) or a null string is entered.
A job cannot contain the telnet, ftp, ssh2, or monitor process command.
# Assign commands to the backupconfig job to back up the startup.cfg file to the TFTP server at 192.168.100.11.
[Sysname] scheduler job backupconfig
[Sysname-job-backupconfig] command 2 tftp 192.168.100.11 put flash:/startup.cfg backup.cfg
# Assign commands to the shutdownGE job to shut down Ten-GigabitEthernet 1/0/1.
[Sysname] scheduler job shutdownGE
[Sysname-job-shutdownGE] command 1 system-view
[Sysname-job-shutdownGE] command 2 interface ten-gigabitethernet 1/0/1
[Sysname-job-shutdownGE] command 3 shutdown
scheduler job
Use copyright-info enable to enable copyright statement display.
Use undo copyright-info enable to disable copyright statement display.
Copyright statement display is enabled.
# Enable copyright statement display.
[Sysname] copyright-info enable
The device will display the following statement when a user logs in:
* Copyright (c) 2004-2019 New H3C Technologies Co., Ltd. All rights reserved.*
* Without the owner's prior written consent,                                 *
* no decompiling or reverse-engineering shall be allowed.                    *
display alarm
Use display alarm to display alarm information.
display alarm [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays alarm information for all IRF member devices.
# Display alarm information.
<Sysname> display alarm
Slot CPU Level   Info
1    0   ERROR   faulty
Slot
Slot that generated the alarm. If the alarm was generated by the frame, this field displays a hyphen (-).
Level
Alarm severity. Possible values include ERROR, WARNING, NOTICE, and INFO, in descending order.
Info
Detailed alarm information:
·     faulty—The slot is starting up or faulty.
·     Fan n is absent—The specified fan is absent.
·     Power n is absent—The specified power module is absent.
·     Power n is faulty—The specified power module is faulty.
·     The temperature of sensor n exceeds the lower limit—The temperature of the specified sensor is lower than the low-temperature threshold.
·     The temperature of sensor n exceeds the upper limit—The temperature of the specified sensor is higher than the high-temperature warning threshold.
Use display alarm active to display information about active alarms.
display alarm active [ verbose ]
verbose: Displays detailed information. If you do not specify this keyword, this command displays brief information.
If a power module, CPU, or fan is operating abnormally on the device, you can use the display alarm command to view the alarm information. To view historical alarms that have been cleared, use the display alarm history command. To view active alarms that were generated in the past and have not been cleared on the device, use the display alarm active command.
# Display information about active alarms.
<Sysname> display alarm active
Seq    Level    Time                  Info
24     Warning  2020-01-11  12:40:00  CPU usage is in minor alarm state on slot 1.
23     Warning  2020-01-11  12:30:00  Memory minor threshold has been exceeded on slot 1.
22     Minor    2020-01-11  12:18:00  Board state changed to Fault on slot 1.
Seq
Alarm sequence number, assigned when an alarm occurs.
Level
Alarm severity. The values include Critical, Major, Minor, and Warning, in descending order of severity.
Time
Time when the alarm occurs.
Info
Detailed alarm information. The values include:
·     Board state changed to Fault on slot n—The state of the specified slot changed to Fault. The slot might be starting up or might be faulty.
·     Slot n fan n is absent—The specified fan is absent.
·     Slot n fan n is failed—The specified fan is abnormal.
·     Slot n power n is absent—The specified power module is absent.
·     Slot n power n failed—The specified power module is abnormal.
·     Temperature is higher than the high-temperature alarming threshold on slot n sensor inflow—The temperature of the specified sensor has exceeded the high-temperature warning threshold.
·     Memory minor threshold has been exceeded on slot n—The amount of free memory space on the specified slot has exceeded the minor alarm threshold.
·     CPU usage is in minor alarm state on slot n—The CPU usage on the specified slot has exceeded the minor alarm threshold.
·     Interface-name: RX power is high!—The optical power on the specified interface is too high.
·     Interface-name:The bit error ratio exceeds the upper threshold—The bit error rate of the specified interface has exceeded the upper limit.
·     SSH user username (IP: IP-Address) connected to the server successfully—The specified SSH user at the specified IP address has logged in to the server successfully.
·     Member port xx of aggregation group xx changed to the inactive state, because xx.—The specified member port of the specified aggregation group changed to inactive for a reason.
·     The mpls ldp session status changes. (SessionState=$1, DiscontinuityTime=$2, StatsUnknownMesTypeErrors=$3, StatsUnknownTlvErrors=$4)—The status of an LDP session changes:
¡     $1: LDP session status, including nonexistent, initialized, openrec, opensent, and operational.
¡     $2: Duration when the LDP session is in the operational state.
¡     $3: Times that the LDP session received unknown messages.
¡     $4: Times that the LDP session received unknown TLVs.
·     The number of routes received from the BGP peer exceeded the max number of routes that can be received from the peer. (Instance=$1, AFI=$2, SAFI=$3, PeerAddrType=$4, PeerAddr=$5, MaxRouteNum=$6)
¡     $1: BGP instance name.
¡     $2: Address Family Identifier (AFI).
¡     $3: Subsequent Address Family Identifier (SAFI).
¡     $4: IP type of the BGP peer.
¡     $5: IP address of the BGP peer.
¡     $6: The maximum number of routes that the device can receive from a BGP peer.
·     BGP $1.$2: The number of routes from peer $3 ($4-$5) exceeds the limit $6.
¡     $2: VPN instance name. For a log message on the public network, this field is null.
¡     $3: IP address of the BGP peer.
¡     $4: Address Family Identifier (AFI).
¡     $5: Subsequent Address Family Identifier (SAFI).
¡     $6: The maximum number of route prefixes that can be received from the peer.
·     BGP $1.$2: The ratio of the number of routes received from peer $3 ($4-$5) to the number of allowed routes ($6) has reached the threshold ($7).
¡     $2: VPN instance name. For a log message on public network, this field is null.
¡     $7: The number of routes received by the device when the percentage of received routes to the maximum number of allowed routes reaches the alarm threshold.
·     The number of routes received from the BGP peer exceeded the alarm threshold. (Instance=$1, AFI=$2, SAFI=$3, PeerAddrType=$4, PeerAddr=$5, MaxRouteNumber=$6, alarm threshold=$7).
# Display detailed information about active alarms.
<Sysname> display alarm active verbose
Seq 4
Alarm name: BoardStatus
Alarm source: slot 2
Level: Minor
Start time: 2022-05-16 18:58:46
  Info: Board state changed to Fault on slot 2.
Seq
Alarm source
Location where the alarm occurs.
Level
Start time
Info
display alarm
Use display alarm history to display information about historical alarms that have been cleared.
display alarm history [ verbose ]
If a power module, CPU, or fan is operating abnormally on the device, use the display alarm command to view the alarm information. To view historical alarms that have been cleared, use the display alarm history command. To view active alarms that were generated in the past and have not been cleared on the device, use the display alarm active command.
The maximum number of historical alarms that can be displayed by this command varies by device model.
# Display brief information about historical alarms.
<Sysname> display alarm history
Seq        Time                  Info
23         2020-01-11 12:40:00 CPU usage recovered to normal state on slot 1.
For information about the fields in the command output, see Table 2.
# Display detailed information about historical alarms.
<Sysname> display alarm history verbose
Seq 23
Alarm name: CPUUsageMinor
Alarm position: slot 1
Start time: 2020-01-11 12:30:00
Level: Warning
Info: CPU usage is in minor alarm state on slot 1
Recovery time: 2020-01-11 12:40:30
Info: CPU usage minor alarm removed on slot 1.
Seq
Alarm sequence number, assigned automatically by the system when an alarm occurs.
AlarmPosition
Start time
Level
Recovery time
Time when an alarm is cleared.
Info
·     BGP $1.$2: The ratio of the number of routes received from peer $3 ($4-$5) to the number of allowed routes ($6) has fallen below the threshold ($7).
¡     $6: The maximum number of routes that can be received from the peer.
·     The number of routes received from the BGP peer decreased below the alarm threshold. (Instance=$1, AFI=$2, SAFI=$3, PeerAddrType=$4, PeerAddr=$5, MaxRouteNumber=$6, alarm threshold=$7).
·     The number of routes received from the BGP peer decreased below the max number of routes that can be received from the peer. (Instance=$1, AFI=$2, SAFI=$3, PeerAddrType=$4, PeerAddr=$5, MaxRouteNum=$6).
·     BGP $1.$2: The number of routes from peer $3 ($4-$5) fell below the limit $6.
display alarm
display clock
Use display clock to display the system time, date, time zone, and daylight saving time.
display clock
# Display the system time and date when the time zone is not specified.
<Sysname> display clock
10:09:00.258 UTC Fri 03/16/2015
The time is in the hour:minute:second.milliseconds format.
# Display the system time and date when the time zone Z5 is specified.
15:10:00.152 Z5 Fri 03/16/2015
Time Zone : Z5 add 05:00:00
# Display the system time and date when the time zone Z5 and daylight saving time PDT are specified.
15:11:00.211 Z5 Fri 03/16/2015
clock datetime
clock timezone
clock summer-time
display copyright
Use display copyright to display the copyright statement.
display copyright
# Display the copyright statement.
<Sysname> display copyright
display cpu-usage
Use display cpu-usage to display the current CPU usage statistics.
display cpu-usage [ summary ] [ slot slot-number [ cpu cpu-number [ core { core-number| all } ] ] ]
summary: Displays CPU usage statistics in table form. If you do not specify this keyword, the command displays CPU usage statistics in text form.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays CPU usage statistics for all member devices.
cpu cpu-number: Specifies a CPU by its number.
core core-number: Specifies a CPU core by its number.
core all: Specifies all CPU cores.
If two hyphens (--) are displayed for the CPU usage during the most recent 5-second, 1-minute, and 5-minute intervals, the command might fail to obtain data from the database on the device. Try the command later.
# Display the current CPU usage statistics in text form.
<Sysname> display cpu-usage
Slot 1 CPU 0 CPU usage:
       1% in last 5 seconds
       1% in last 1 minute
       1% in last 5 minutes
# Display the current CPU usage statistics in table form.
Slot CPU        Last 5 sec        Last 1 min        Last 5 min
1    0          17%               29%               28%
Table 5 Command output
x% in last 5 seconds
Last 5 sec
Average CPU or CPU core usage during the most recent 5-second interval.
y% in last 1 minute
Last 1 min
Average CPU or CPU core usage during the most recent 1-minute interval.
z% in last 5 minutes
Last 5 min
Average CPU or CPU core usage during the most recent 5-minute interval.
Use display cpu-usage configuration to display CPU usage monitoring settings.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays the CPU usage monitoring settings for the master device.
# Display the CPU usage monitoring settings.
<Sysname> display cpu-usage configuration
CPU usage monitor is enabled.
Current monitor interval is 60 seconds.
Current severe alarm threshold is 90%.
Current minor alarm threshold is 80%.
Current recovery-threshold is 40%.
Table 6 Command output
CPU usage monitor is xxx.
Whether CPU usage tracking is enabled.
Current monitor interval is xxx.
Sampling interval for CPU usage tracking.
Current severe alarm threshold is xxx.
Severe CPU usage alarm threshold.
Current minor alarm threshold is xxx.
Minor CPU usage alarm threshold.
Current recovery threshold is xxx.
CPU usage recovery threshold.
Use display cpu-usage history to display the historical CPU usage statistics in a coordinate system.
job job-id: Specifies a process by its ID. The value range for job-id is 1 to 2147483647. If you do not specify a process, this command displays the statistics for the entire system's CPU usage (the total CPU usage of all processes). To view the IDs and names of the running processes, use the display process command. For more information, see Network Management and Monitoring Configuration Guide.
slot slot-number: Specifies an IRF member device by its member ID. If you specify a process but do not specify a member device, this command displays the statistics for the process on the master device. If you do not specify any options, this command displays the statistics for all processes on all member devices.
cpu cpu-number: Specifies a CPU by its number. If you specify a process but do not specify a CPU, this command displays the statistics for the default CPU. If you do not specify a process or CPU, this command displays the historical statistics for all CPUs.
After CPU usage monitoring is enabled, the system regularly samples CPU usage and saves the samples to the history record buffer. This command displays the most recent 60 samples in a coordinate system as follows:
·     The vertical axis represents the CPU usage. If a statistic is not a multiple of the usage step, it is rounded up or down to the closest multiple of the usage step. For example, if the CPU usage step is 5%, the statistic 53% is rounded up to 55%, and the statistic 52% is rounded down to 50%.
·     The horizontal axis represents the time.
·     Pound signs (#) indicate the CPU usage. The value on the vertical axis for the topmost pound sign at a specific time represents the CPU usage at that time.
# Display the historical CPU usage statistics.
<Sysname> display cpu-usage history
100%|
 95%|
 90%|
 85%|
 80%|
 75%|
 70%|
 65%|
 60%|
 55%|
 50%|
 45%|
 40%|
 35%|
 30%|
 25%|
 20%|
 15%|             #
 10%|            ###  #
  5%|           ########
              10        20        30        40        50        60  (minutes)
                      cpu-usage (Slot 1 CPU 0) last 60 minutes (SYSTEM)
The output shows the following items:
·     Process name. The name SYSTEM represents the entire system.
·     CPU that is holding the process: CPU 0 in slot 1.
·     Historical CPU usage statistics for the entire system during the last 60 minutes.
¡     12 minutes ago—Approximately 5%.
¡     13 minutes ago—Approximately 10%.
¡     14 minutes ago—Approximately 15%.
¡     15 minutes ago—Approximately 10%.
¡     16 and 17 minutes ago—Approximately 5%.
¡     18 minutes ago—Approximately 10%.
¡     19 minutes ago—Approximately 5%.
¡     Other time—2% or lower.
display device
Use display device to display device information.
display device[ flash | usb ] [ slot slot-number [ subslot subslot-number ] | verbose ]
flash: Displays flash memory information.
usb: Displays USB interface information.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays information for all member devices.
subslot subslot-number: Specifies a subcard by its subslot number. If you do not specify a subcard, this command does not display information about any subcards.
Only S6800-2C and S6800-4C switches support the subslot subslot-number option.
If you do not specify the flash and usb keywords, this command displays information about member devices.
# Display device information.
<Sysname> display device
Slot 1
Slot Type             State    Subslot  Soft Ver             Patch Ver
1    S6800-32Q        Master   0        2901007              None
Table 7 Command output
Device type.
Role of the device in an IRF fabric:
·     Master—The device is the master.
·     Standby—The device is a subordinate member.
Soft Ver
Software version of the device.
Patch Ver
Most recently released patch image version that is running on the device. If no patch image is installed, this field displays None.
If both incremental and non-incremental patch images are running on the device, this field displays the most recently released incremental patch image version. For more information about patch image types, see "Upgrading software."
Use display device manuinfo to display electronic label information for the device.
display device manuinfo [ slot slot-number [ subslot subslot-number ] ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays electronic label information for all member devices.
This command supports displaying electronic label information for silver LSPM1FANSA and LSPM1FANSB fan trays and does not support displaying electronic label information for black LSPM1FANSA and LSPM1FANSB fan trays.
The S6800-4C (LS-6800-4C) and S6800-4C (LS-6800-4C-H1) switches in the S6800 switch series do not support displaying electronic label information for fan trays.
An electronic label contains the permanent configuration information, including the hardware serial number, manufacturing date, MAC address, and vendor name. The data is written to the storage component during hardware debugging or testing. This command displays only part of the electronic label information.
# Display electronic label information for the device.
<Sysname> display device manuinfo
Use display device manuinfo fan to display electronic label information for a fan tray.
In the S6800 switch series, S6800-4C (LS-6800-4C) and S6800-4C (LS-6800-4C-H1) do not support this command.
display device manuinfo slot slot-number fan fan-id
fan-id: Specifies a fan tray by its ID.
# Display electronic label information for a fan tray.
<Sysname> display device manuinfo slot 1 fan 1
Use display device manuinfo power to display electronic label information for a power module.
display device manuinfo slot slot-number power power-id
power-id: Specifies a power module by its ID.
# Display electronic label information for a power module.
<Sysname> display device manuinfo slot 1 power 1
Use display diagnostic-information to display or save operating information for features and hardware modules.
display diagnostic-information [ equipment | hardware | ifmgr | infrastructure | l2 | l3 | service ] [ key-info ] [ filename ]
equipment: Displays equipment-related operating information.
hardware: Specifies hardware-related operating information.
ifmgr: Specifies IFMGR-related operating information.
infrastructure: Specifies operating information for the fundamental features.
l2: Specifies operating information for the Layer 2 features.
l3: Specifies operating information for the Layer 3 features.
service: Specifies operating information for Layer 4 and upper-layer features.
key-info: Displays or saves only critical operating information. The device might have a large amount of operating information if an exception occurs or after the device runs for a long period of time. Specifying this keyword reduces the command execution time and helps you focus on critical operating information. If you do not specify this keyword, the command displays or saves both critical and non-critical operating information.
filename: Saves the information to a file. The filename argument must use the .tar.gz extension. If you do not specify this argument, the command prompts you to choose whether to save the information to a file or display the information.
You can use one of the following methods to collect operating statistics for diagnostics and troubleshooting:
·     Use separate display commands to collect operating information feature by feature or module by module.
·     Use the display diagnostic-information command to collect operating information for multiple or all features and hardware modules.
To save storage space, this command automatically compresses the information before saving the information to a file. To view the file content:
1.     Use the tar extract command to extract the file.
2.     Use the gunzip command to decompress the extracted file.
3.     Use the more command to view the content of the decompressed file.
If you abort the display diagnostic-information command, the gunzip command might not be able to decompress the extracted file. To decompress the extracted file, export the extracted file to a PC that is running Linux, and use the gunzip -c command.
If you do not specify a file name for the command, the system prompts you to choose whether to display or save the information. If you choose to save the information, the system automatically assigns a file name and displays the file name in brackets. For file name uniqueness, the file name includes the device name and the current system time. If the device name contains any of the following special characters, the system uses an underscore (_) to replace each special character: forward slashes (/), backward slashes (\), colons (:), asterisks (*), question marks (?), less than signs (<), greater than signs (>), pipeline signs (|), and quotation marks ("). For example, device name A/B will change to A_B in the file name, as in flash:/diag_A_B_20160101-000438.tar.gz.
If you do not specify any feature parameters, this command displays or saves the operating information for all features and modules.
This command does not support the |, >, and >> options.
While the device is executing this command, do not execute any other commands. Executing other commands might affect the collected operating information.
# Display the operating information for all features and modules.
14:03:55 UTC Thu 01/05/2015
# Save the operating information to the default file.
Save or display diagnostic information (Y=save, N=display)? [Y/N]:y
Please input the file name(*.tar.gz)[flash:/diag_Sysname_20160101-024601.tar.gz]:
Diagnostic information is outputting to flash:/diag_Sysname_20160101-024601.tar.gz.
Please wait...
Save successfully.
Press Enter when the system prompts you to enter the file name.
# Save the operating information for all features and modules to file test.tar.gz.
<Sysname> display diagnostic-information test.tar.gz
Diagnostic information is outputting to flash:/test.tar.gz.
Please wait...
Save successfully.
gunzip
more
tar extract
display environment
Use display environment to display temperature information.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays temperature information for all member devices.
# Display information about all temperature sensors on the device.
<Sysname> display environment
System temperature information (degree centigrade):
 Slot  Sensor    Temperature  Lower  Warning  Alarm  Shutdown
 1     hotspot 1 33           0      62       75     NA
 1     hotspot 2 29           0      62       75     NA
 1     hotspot 3 28           0      52       57     NA
 1     hotspot 4 42           0      77       87     NA
Table 8 Command output
System Temperature information (degree centigrade)
Temperature information (°C).
sensor
Temperature sensor:
·     hotspot 1—Board temperature sensor on the power fan side of the system board.
·     hotspot 2—Board temperature sensor near the MAC chip.
·     hotspot 3—Board temperature sensor on the front panel side of the system board.
·     hotspot 4—MAC temperature sensor, reading the internal register inside the MAC chip.
Slot
Sensor position.
Temperature
Current temperature.
Lower
Lower temperature limit. If the device does not support this field, this field displays NA.
Warning
Warning temperature threshold. If the device does not support this field, this field displays NA.
Alarm
Alarming temperature threshold. If the device does not support this field, this field displays NA.
Shutdown
Shutdown temperature threshold. When the sensor temperature reaches the limit, the system shuts down automatically. If the device does not support this field, this field displays NA.
display fan
Use display fan to display fan tray operating status information.
display fan [ slot slot-number [ fan-id ] ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays fan tray operating status information for all member devices.
fan-id: Specifies a fan tray by its ID. If you do not specify a fan tray, this command displays operating status information for all fan trays at the specified position.
# Display the operating states of all fan trays.
<Sysname> display fan
 Slot 1:
 Fan 1:
 State    : Normal
 Airflow Direction: Port-to-power
 Prefer Airflow Direction: Port-to-power
Table 9 Command output
Slot 1
Member device number.
Fan 1
Fan tray number.
Fan status:
·     Absent—The slot is not installed with a fan tray.
·     Fault—The fan is faulty.
·     Normal—The fan is operating correctly.
·     FanDirectionFault—The actual airflow direction is not the preferred direction.
Airflow Direction
Actual airflow direction:
·     Port-to-power—From the port side to the power module side.
·     Power-to-port—From the power module side to the port side.
Preferred airflow direction:
Use display hardware-resource switch-mode to display hardware resource operating mode information for the MAC address table, ARP and ND tables, and routing tables.
display hardware-resource [ switch-mode ]
If you do not specify the switch-mode keyword, the command displays hardware resource operating mode information for all hardware resources.
# (S6800 switch series.) Display the hardware resource operating mode information for the MAC address table, ARP and ND tables, and routing tables.
<H3C>display hardware-resource switch-mode
Switch-mode resource(switch-mode), all supported modes:
  0                 MAC table is 288K, L3 host table is 16K, LPM Table is 16K
  1                 MAC table is 224K, L3 host table is 80K, LPM Table is 16K
  2                 MAC table is 160K, L3 host table is 144K, LPM Table is 16K
  3                 MAC table is 96K, L3 host table is 208K, LPM Table is 16K
  4                 MAC table is 32K, L3 host table is 16K, LPM Table is 250K
  Default         Current         Next
  0               2               2
# (S6860 switch series.) Display the hardware resource operating mode information for the MAC address table, ARP and ND tables, and routing tables.
  0                 MAC table is 272K, L3 host table is 4K, LPM Table is 16K
  1                 MAC table is 208K, L3 host table is 68K, LPM Table is 16K
  2                 MAC table is 80K, L3 host table is 196K, LPM Table is 16K
  3                 MAC table is 16K, L3 host table is 260K, LPM Table is 16K
  4                 MAC table is 80K, L3 host table is 68K, LPM Table is 128K
  5                 MAC table is 16K, L3 host table is 4K, LPM Table is 256K
  0               4               4
Use the display key-component command to display the operating status of the key components of the device, including the power supplies, fans (or fan trays), and temperature sensors.
# Display the operating status of the key components of the device, including the power supplies, fans, and temperature sensors.
<Sysname> display key-component
Power:
Chassis 1:
InPower: 5000W
OutPower: 4000W
Power supply policy: Enable
Power modules redundant: 1
PowerID  State     InPower Current Voltage OutPower  Type            Mode
                    (W)     (A)     (V)     (W)
1        Normal    2400    6.00    53.39   320.34    PSR2400-54A     AC
2        Normal    2400    6.25    53.36   333.50    PSR2400-54A     AC
3        Absent    --      --      --      --        --              -
4        Absent    --      --      --      --        --              -
Fan:
Chassis 1:
Frame Status            Type          Mode            Direction      Speed
1/1   Normal            LSWFAN        Auto            Power-to-port  5000
1/2   Normal            LSWFAN        Auto            Power-to-port  5000
Slot  Sensor    Temperature LowerLimit WarningLimit AlarmLimit
 0/0  Inflow  1   30           -5          66          76
 0/0  Outflow 1   33           -5          66          76
 0/0  Outflow 2   37           -5          66          76
 0/0  Hotspot 1   39           -5          66          76
 0/0  Hotspot 2   42           -5          66          76
 0/0  Hotspot 3   44           -5          66          76
Table 10 Command output
Chassis
Chassis number.
InPower
Rated power of the device.
OutPower
Allocated power, in watts.
Power supply policy
Whether power management is enabled.
Number of redundant power supplies.
PowerID
Power supply ID.
State of the power supply:
·     Absent: No power supply is present.
·     Normal: The power supply is operating correctly.
·     Faulty: The power supply is faulty.
InPower(W)
Actual input power of the power supply, in watts. "--" is displayed if the device does not support collection of this information.
Current(A)
Actual output current of the power supply, in amperes. "--" is displayed if the device does not support collection of this information.
Voltage(V)
Actual output voltage of the power supply, in volts. "--" is displayed if the device does not support collection of this information.
OutPower(W)
Actual output power of the power supply, in watts. "--" is displayed if the device does not support collection of this information.
Power supply model. "--" is displayed if the device does not this information.
Mode
Type of the power supply.
·     AC: AC power supply.
·     DC: DC power supply.
Fan
Fan number. If the device uses fan trays, the column name might be Tray or Frame.
Status
Fan status.
·     Absent: No fan is present.
·     Normal: The fan is operating correctly.
·     Fault: The fan is faulty.
·     FanDirectionFault: The actual airflow direction of the fan is inconsistent with preferred airflow direction configured by the user.
·     --: The fan is not the first fan in the fan tray or the device does not support this information.
Fan type.
Mode
Speed adjustment mode.
Direction
Actual airflow direction of the fan:
·     Port-to-power: The fan draws air from the port side to the power supply side. The airflow direction is from front to rear.
·     Power-to-port: The fan blows air from the power supply side to the port side. The airflow direction is from rear to front.
Speed
Fan speed or fan speed level.
System temperature information, in °C.
Slot
Chassis number/slot number. If the value is a number, for example, 1, it represents the slot number. If the value is Vent, it represents the chassis or fan tray.
Sensor
Temperature sensor.
·     Hotspot: Represents the hotspot temperature sensor
·     Inflow: Represents the temperature sensor at the air inlet.
·     Outflow: Represents the temperature sensor at the air outlet.
Temperature
LowerLimit
Lower temperature alarm threshold. This threshold is not supported if NA is displayed.
WarningLimit
High temperature warning threshold. This threshold is not supported if NA is displayed.
AlarmLimit
High temperature alarm threshold. This threshold is not supported if NA is displayed.
display memory
Use display memory to display memory usage information.
summary: Displays brief information about memory usage. If you do not specify this keyword, the command displays detailed information about memory usage.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays memory usage for all member devices.
If two hyphens (--) are displayed for all the fields in a line of the command output, the command might fail to obtain data from the database on the device. Try the command later.
# Display detailed memory usage information.
<Sysname> display memory
Memory statistics are measured in KB:
Slot 1:
             Total      Used      Free    Shared   Buffers    Cached   FreeRatio
Mem:       4106048   2430384   1675664         0      3584    836512       41.4%
-/+ Buffers/Cache:   1590288   2515760
Swap:            0         0         0
# Display brief memory usage information.
<Sysname> display memory summary
Slot CPU        Total      Used      Free  Buffers    Caches FreeRatio
   1   0      4106048   2430384   1675664     3584    836512     41.4%
Table 11 Command output
Mem
Memory usage information.
Total
Total size of the physical memory space that can be allocated.
The memory space is virtually divided into two parts. Part 1 is solely used for kernel code, kernel management, and ISSU functions. Part 2 can be allocated and used for such tasks as running service modules and storing files. The size of part 2 equals the total size minus the size of part 1.
Used
Used physical memory.
Free
Free physical memory.
Shared
Physical memory shared by processes.
If this field is not supported, two hyphens (--) are displayed.
Buffers
Physical memory used for buffers.
Cached
Caches
Physical memory used for caches. If a memory threshold is reached, part of memory used for caches can be automatically released for other services.
FreeRatio
Free memory ratio. The free memory includes the free physical memory and the part of memory used for caches that can be automatically released for other services when a memory threshold is reached.
-/+ Buffers/Cache
-/+ Buffers/Cache:used = Mem:Used – Mem:Buffers – Mem:Cached, which indicates the physical memory used by applications.
-/+ Buffers/Cache:free = Mem:Free + Mem:Buffers + Mem:Cached, which indicates the physical memory available for applications.
Swap
Memory space for swapping.
LowMem
Low-memory usage information.
HighMem
High-memory usage information.
display memory dma
Use display memory dma to display DMA memory usage information.
display memory dma [ slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays DMA memory usage information for the master device.
# Display DMA memory usage information for slot 1.
<System> display memory dma slot 1
DMA memory statistics measured in KB on slot 1:
Total        Used         Free         FreeRatio
16384        6140         10244        63%
Table 12 Command output
Total
Total size of the DMA memory space, including the free and used DMA memory.
Used
Used DMA memory.
Free
Free DMA memory.
FreeRatio
Free DMA memory ratio.
Use display memory-threshold to display memory alarm thresholds and statistics.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays the memory usage thresholds and statistics for the master device.
For more information about memory usage notifications, see log information containing MEM_EXCEED_THRESHOLD or MEM_BELOW_THRESHOLD.
# Display memory alarm thresholds and statistics.
<Sysname> display memory-threshold
Memory usage threshold: 100%
Free-memory thresholds:
    Minor: 96M
    Severe: 64M
    Critical: 48M
    Normal: 128M
    Early-warning: 256M
    Secure: 304M
Current free-memory state: Normal (secure)
Free-memory event statistics:
 [Back to secure state]
    First notification: 0.0
    Latest notification: 0.0
    Total number of notifications sent: 0
 [Entered early-warning state]
    First notification at: 0.0
    Latest notification at: 0.0
 [Back to normal state]
 [Entered minor alarm state]
 [Back to minor alarm state]
 [Entered severe alarm state]
 [Back to severe alarm state]
 [Entered critical alarm state]
Table 13 Command output
    Minor
    Severe
    Critical
    Normal
    Early-warning
    Secure
·     Minor—Minor alarm threshold in MB.
·     Severe—Severe alarm threshold in MB.
·     Critical—Critical alarm threshold in MB.
·     Normal—Normal state threshold in MB.
·     Early-warning—Early-warning threshold in MB.
·     Secure—Sufficient-memory threshold in MB.
Current state of the free memory in the system:
·     Normal—Normal state.
·     Minor—Minor alarm threshold.
·     Severe—Severe alarm threshold.
·     Critical—Critical alarm threshold.
·     Normal (early-warning)—Early-warning threshold.‌
·     Normal (secure)—Sufficient-memory state.‌
Time when the alarm notification was sent for the first time, in the format of yyyy-mm-dd hh:mm:ss.msec.
Time when the alarm notification was sent most recently in the format of yyyy-mm-dd hh:mm:ss.msec.
Total number of notification send
Total number of the alarm notifications that were sent.
Use display memory-threshold dma to display DMA memory alarm information.
display memory-threshold dma [ slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays DMA memory alarm information for the master device.
# Display DMA memory alarm information.
<Sysname> display memory-threshold dma
Free DMA memory thresholds:
    Critical: 2048KB
    Normal: 4096KB
Current DMA memory state: Normal
Free memory event statistics:
 [Entered to critical state]
display power
Use display power to display power module information.
display power [ slot slot-number [ power-id | verbose ] ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays power module information for all member devices.
power-id: Specifies a power module by its ID. If you do not specify a power module, this command displays information about all power modules at the specified position.
verbose: Displays detailed information. If you do not specify this keyword, the command displays brief information.
# Display brief power supply information.
<Sysname> display power
Slot 1:
 Input Power: 99(W)
 PowerID State         Mode   Current(A)  Voltage(V)  Power(W)  FanDirection
 1       Normal        AC        5.40       12.35        66     PowerToPort
 2       Normal        AC        --         --           --     --
Table 14 Command output
Input Power
Rated power.
PowerID
Power supply ID.
Power supply status.
·     Absent—The slot is not installed with a power supply.
·     Fault—The power supply is faulty.
·     Normal—The power supply is operating correctly.
Mode
Mode of the power supply:
·     ACAC power supply.
·     DCDC power supply.
Current(A)
Output current of the power supply, in amperes.
Voltage(V)
Output voltage of the power supply, in volts.
Power(W)
Output power of the power supply, in watts.
FanDirection
Airflow direction of the power supply:
·     PowerToPortFrom the power supply side to the port side.
·     PortToPowerFrom the port supply side to the power side.
# Display detailed power module information.
<Sysname> display power slot 1 verbose
Slot 1:
Input Power: 54(W)
1       Normal        AC       4.60       11.95       54       PowerToPort
2       Absent       --        --         --          --       --
Table 15 Command output
Input Power
PowerID
Power supply ID.
Status of the power supply:
Mode
Type of the power supply:
·     AC—AC power supply.
·     DC—DC power supply.
Current(A)
Voltage(V)
Power(W)
FanDirection
Fan airflow direction of the power supply:
·     PowerToPort—From the power supply side to the port side.
·     PortToPower—From the port side to the power supply side.
Use display power-supply to display the historical power consumption information in a coordinate system.
display power history { 30days | day | hour } [ slot slot-number ]
30days: Displays the historical power consumption information during the past 30 days.
day: Displays the historical power consumption information during the past 24 hours.
hour: Displays the historical power consumption information during the past 60 minutes.
slot slot-number: slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays the historical power consumption information of all member devices.
The device periodically samples the power consumption and buffers the samples. When you execute this command, the device calculates and displays the most recent average power consumption values as follows:
·     For the power consumption information during the past 60 minutes, the device calculates the average power consumption value during every 1-minute interval.
·     For the power consumption information during the past 24 hours, the device calculates the average power consumption value during every 1-hour interval.
·     For the power consumption information during the past 30 days, the device calculates the average temperature value during every 1-day interval.
This command displays power consumption values in a coordinate system.
·     The vertical axis represents the power consumption in watts (W).
If a value is not a multiple of the 5-watt step, it is rounded up or down to the closest multiple of the step.
·     The horizontal axis represents the time. The unit varies by the specified time keyword.
·     Pound signs (#) indicate the power consumption values. The value on the vertical axis for the topmost pound sign at a specific time represents the power consumption value at that time.
# Display the historical power consumption information on a slot during the past 60 minutes.
<Sysname> display power history hour slot 1
Power consumption during the past 60 minutes on slot 1:
Highest power consumption is 163W.
Lowest power consumption is 82W.
Consumption (W)
180|
175|
170|
165|####
160|####
155|####
150|####
145|####
140|####
135|####
130|####
125|####
120|####
115|####
110|####
105|####
100|####
 95|####
 90|####
 85|####
 80|####
display power
Use display resource-monitor to display resource monitoring information.
display resource-monitor [ resource resource-name ] [ slot slot-number [ cpu cpu-number ] ]
resource resource-name: Specifies a resource type by its name.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays resource monitoring information for all member devices.
# Display ARP resource monitoring information.
<Sysname> display resource-monitor resource arp
Minor alarms resending: Enabled
Slot 1:
Resource                         Minor Severe Free/Total
                                 (%)   (%)    (absolute)
arp                              50    20     90095/90098
Table 16 Command output
Status of the minor resource depletion alarm resending feature, Enabled or Disabled.
Resource
Monitored resource type.
Minor
Minor resource depletion threshold, in percentage.
Severe
Severe resource depletion threshold, in percentage.
Free/Total
(absolute)
Numbers of available resources and total resources, in absolute values. Some resources share the same hardware entry, and the total number of resources will change dynamically.
Use display scheduler job to display job configuration information.
job-name: Specifies a job by its name, a case-sensitive string of 1 to 47 characters. If you do not specify a job, this command displays configuration information for all jobs.
# Display configuration information for all jobs.
<Sysname> display scheduler job
Job name: saveconfig
 copy startup.cfg backup.cfg
Job name: backupconfig
Job name: creat-VLAN100
 vlan 100
// The output shows that the device has three jobs: the first has one command, the second does not have any commands, and the third has two commands. Jobs are separated by blank lines.
Use display scheduler logfile to display job execution log information.
# Display job execution log information.
<Sysname> display scheduler logfile
Logfile Size: 1902 Bytes.
Job name        : shutdown
Schedule name   : shutdown
Execution time  : Tue Dec 27 10:44:42 2015
Completion time : Tue Dec 27 10:44:47 2015
<Sysname>system-view
[Sysname]interface rang ten-gigabitethernet 1/0/1 to ten-gigabitethernet 1/0/3
[Sysname-if-range]shutdown
Table 17 Command output
Logfile Size
Size of the log file, in bytes.
Schedule name
Schedule to which the job belongs.
Execution time
Time when the job was started.
Completion time
Time when the job was completed. If the job has never been executed or the job does not have any commands, this field is blank.
Job output
Commands in the job and their output.
Use display scheduler reboot to display the automatic reboot schedule.
# Display the automatic reboot schedule.
<Sysname> display scheduler reboot
System will reboot at 16:32:00 05/23/2015 (in 1 hours and 39 minutes).
scheduler reboot at
Use display scheduler schedule to display schedule information.
schedule-name: Specifies a schedule by its name, a case-sensitive string of 1 to 47 characters. If you do not specify a schedule, this command displays information about all schedules.
# Display information about all schedules.
<Sysname> display scheduler schedule
Schedule type        : Run once after 0 hours 2 minutes
Start time           : Tue Dec 27 10:44:42 2015
Last execution time  : Tue Dec 27 10:44:42 2015
Last completion time : Tue Dec 27 10:44:47 2015
Execution counts     : 1
Job name                                          Last execution status
shutdown                                          Successful
Table 18 Command output
Schedule type
Execution time setting of the schedule. If no execution time is specified, this field is not displayed.
Start time
Time to execute the schedule for the first time. If no execution time is specified, this field is not displayed.
Last execution time
Last time when the schedule was executed. If no execution time is specified, this field is not displayed. If the schedule has never been executed, "Yet to be executed" is displayed for this field.
Last time when the schedule was completed. If no execution time is specified, this field is not displayed.
Execution counts
Number of times the schedule has been executed. If the schedule has never been executed, this field is not displayed.
Job name
Name of a job under the schedule.
Result of the most recent execution:
·     Successful.
·     Failed.
·     Waiting—The device is executing the schedule and the job is waiting to be executed.
·     In process—The job is being executed.
·     -NA-—The execution time has not arrived yet.
To view information about whether the commands in the job has been executed and the execution results, execute the display scheduler logfile command.
Use display system health to display system health status information.
display system health [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays health status information about the master device.
The device periodically performs a series of checks to identify the health status of the device. The check items are already defined in the factory-default configuration. The check results can be used by the internal service modules such as IRF and M-LAG in the device. You can execute this command to view these check results.
# Display system health status information.
<Sysname> display system health
Slot 1 health: Normal(0)
    Memory: Normal(0)
    CPU port: Normal(0)
    MMU: Normal(0)
    CPU deadloop: Normal(0)
    Fan status: Normal(0)
    Temperature: Normal(0)
    SubCardCheck: Normal(0)
    PortDownFault: Normal(0)
    LacpFault: Normal(0)
    CPLDFault: Normal(0)
    PHYFault: Normal(0)
Table 19 Command output
Health: Normal(0)
System health status:
·     Normal(0)—The system is healthy.
·     Faulty(n)—The system is faulty. A greater value of n indicates a worse condition.
Memory
Memory health status.
CPU port
CPU port health status.
MMU
MMU health status.
CPU deadloop
CPU deadloop status.
Fan status
Fan health status.
Temperature
Temperature sensor health status.
SubCardCheck
Subcard operating status.
PortDownFault
Port up/down status. If not all ports on the device are down, the health value is 0. If all ports are down, the health value is 3.
LacpFault
Selection status of aggregation member ports. When not less than half of the aggregation member ports on the device are selected, the health value is 0. When less than half of the aggregation member ports are selected, the health value is 1. When no aggregation member ports are selected, the health value is 3.
CPLDFault
CPLD fault detection.
PHYFault
PHY fault detection.
display system health history
Use display system health history to display historical system health status change information.
display system health history [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays historical health status change information about the master device.
# Display historical system health status change information.
<Sysname> display system health history
Table 20 Command output
display system stable state
Use display system stable state to display system stability and status information.
display system stable state [ summary ]
summary: Displays brief information about system status, redundancy status, and NSR status. If you do not specify this keyword, the command displays detailed information about system status, redundancy status, and CPU role and status.
Before performing an ISSU or a switchover, execute this command multiple times to identify whether the system is operating stably. If the value of the System State field is not Stable, you cannot perform an ISSU. If the value of the Redundancy Stable field is not Stable, you cannot perform a switchover.
The device startup process takes some time. If the values of the status fields do not change to Stable, execute this command multiple times to identify the devices that are not in Stable state. You can also use other commands to identify the faulty components. For example:
·     Use the display device command to identify the device operating status.
·     Use the display ha service-group command to display the status of HA service groups and identify the groups in batch backup state.
·     Use the display system internal process state command in probe view to display service operating status.
# Display brief system stability and status information.
<Sysname> display system stable state summary
System state      : Stable
Redundancy state  : No redundancy
NSR     state     : No standby
# Display system stability and status information.
Redundancy state: No redundancy
  Slot   CPU   Role      State
  1      0     Active    Stable
Table 21 Command output
System state
Operating status of all member devices:
·     Stable—All member devices are operating stably.
·     Not ready—The system is not operating stably. You cannot perform an ISSU when the system is in this state.
Redundancy state
System redundancy status:
·     Stable—Member devices are operating stably. You can perform a switchover.
·     No redundancy—The system has only one member device. You cannot perform a switchover.
·     Not ready—The system is not operating stably. You cannot perform a switchover.
Role
Role of the member device in the system:
·     Active—The member device is the master.
·     Standby—The member device is a subordinate member.
Member device status:
·     Stable—The member device is operating stably.
·     Board inserted—The member device has just been installed.
·     Kernel initiating—Member device kernel is being initialized.
·     Service starting—Services are starting on the member device.
·     Service stopping—Services are stopping on the member device.
·     HA Batch backup—An HA batch backup is going on.
·     Interface data batch backup—An interface data batch backup is in progress.
The object is not operating stably.
display device
display ha service-group (High Availability Command Reference)
display system-working-mode
Use display system-working-mode to display system working mode information.
# Display system working mode information.
<Sysname> display system-working-mode
The current system working mode is standard.
The system working mode for next startup is standard.
display transceiver alarm
Use display transceiver alarm to display transceiver alarms.
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If no interface is specified, this command displays the alarms present on every transceiver module.
You can use the display transceiver alarm command to display alarm information on transceiver modules.
If no error occurs, None is displayed. The following tables describe the alarm information that might be present on transceiver module.
Table 22 Command output for SFP/SFP+ transceiver modules
RX signal loss
Receive signal loss.
RX power high alarm
Alarm on a high receive optical power.
RX power high warning
Early warning on a high receive optical power.
RX power low alarm
Alarm on a low receive optical power.
RX power low warning
Early warning on a low receive optical power.
TX fault
Transmit fault.
TX bias high alarm
Alarm on a high transmit bias current.
TX bias high warning
Early warning on a high transmit bias current.
TX bias low alarm
Alarm on a low transmit bias current.
TX bias low warning
Early warning on a low transmit bias current.
TX power high alarm
Alarm on a high transmit optical power.
TX power high warning
Early warning on a high transmit optical power.
TX power low alarm
Alarm on a low transmit optical power.
TX power low warning
Early warning on a low transmit optical power.
Temp high alarm
Alarm on a high temperature.
Temp high warning
Early warning on a high temperature.
Temp low alarm
Alarm on a low temperature.
Temp low warning
Early warning on a low temperature.
Voltage high alarm
Alarm on a high voltage.
Voltage high warning
Early warning on a high voltage.
Voltage low alarm
Alarm on a low voltage.
Voltage low warning
Early warning on a low voltage.
Transceiver info I/O error
N/A
Transceiver info checksum error
N/A
Transceiver type and port configuration mismatch
The transceiver type does not match port configuration.
Transceiver type not supported by port hardware
The transceiver type is not supported on the port.
RX CDR loss of lock
Receive CDR loss of lock, indicating poor signal.
TX CDR loss of lock
Transmit CDR loss of lock, indicating poor signal.
Table 23 Command output for QSFP+/QSFP28 transceiver modules
Temp high alarm
Temp high warning
Temp low alarm
Temp low warning
Voltage high alarm
Voltage low alarm
Voltage low warning
RX loss of signal(channel x)
Loss of receive signal in channel x.
TX fault(channel x)
Packet transmission fault in channel x.
TX loss of signal(channel x)
Loss of transmit signal in channel x.
RX power high(channel x)
Alarm on a high receive optical power in channel x.
RX power low(channel x)
Alarm on a low receive optical power in channel x.
TX power high alarm(channel x)
Alarm on a high transmit optical power in channel x.
TX power high warning(channel x)
Early warning on a high transmit optical power in channel x.
TX power low alarm(channel x)
Alarm on a low transmit optical power in channel x.
TX power low warning(channel x)
Early warning on a low transmit optical power in channel x.
TX bias high(channel x)
Alarm on a high bias current in channel x.
TX bias low(channel x)
Alarm on a low bias current in channel x.
N/A
N/A
Transceiver type and port configuration mismatched
# Display the alarms present on the transceiver module in interface Ten-GigabitEthernet 1/0/1.
<Sysname> display transceiver alarm interface ten-gigabitethernet 1/0/1
Ten-GigabitEthernet1/0/1 transceiver current alarm information:
  RX signal loss
  RX power low
Table 24 Command output
Alarms present on the transceiver module.
RX signal loss
RX power low
Received power is low.
display transceiver diagnosis
Use display transceiver diagnosis to display the current values of the digital diagnosis parameters on transceiver modules.
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If no interface is specified, this command displays the current values of the digital diagnosis parameters on every transceiver module.
# Display the current values of the digital diagnosis parameters on the transceiver module in interface Ten-GigabitEthernet 1/0/1.
<Sysname> display transceiver diagnosis interface ten-gigabitethernet 1/0/1
Ten-GigabitEthernet1/0/1 transceiver diagnostic information:
    Temp.(C)   Voltage(V)  Bias(mA)  RX power(dBm)  TX power(dBm)
    36         3.31        6.13      -35.64          -5.19
  Alarm thresholds:
    High  50         3.55        1.44      -10.00         5.00
    Low   30         3.01        1.01      -30.00         0.00
  Warning thresholds:
           Temp(C)    Voltage(V)  Bias(mA)  RX power(dBM)  TX power(dBM)
    High   45         3.25        1.25      -15.00         4.00
    Low    25         2.85        0.85      -25.00         1.00
# Display the current values of the digital diagnosis parameters on the QSFP28 transceiver module in interface HundredGigE 1/0/49.
<Sysname> display transceiver diagnosis interface hundredgige 1/0/49
HundredGigE1/0/49 transceiver diagnostic information:
[module]  Temp.(C)   Voltage(V)
          29         3.33
[channel] Bias(mA)  RX power(dBm)  TX power(dBm)
    1     0.00      -36.96         -36.96
    2     0.00      -36.96         -36.96
    3     0.00      -36.96         -36.96
    4     0.00      -36.96         -36.96
  Alarm thresholds:
    High  75         3.47        13.00     3.40           5.00
    Low   -5         3.13        3.00      -14.00         -10.00
  Warning thresholds:
    High  70         3.45        11.00     2.40           3.00
    Low   0          3.15        5.00      -11.00         -8.00
  Total average launch power(dBm): 5.90
Table 25 Command output
Digital diagnosis information for the transceiver module in the interface.
Temp.(C)
Temperature in °C, accurate to 1°C.
Voltage(V)
Voltage in V, accurate to 0.01 V.
Bias(mA)
Bias current in mA, accurate to 0.01 mA.
Total RX power(dBm)
Total receive power in dBm, accurate to 0.01 dBm.
Total TX power(dBm)
Total transmit power in dBm, accurate to 0.01 dBm.
RX power(dBm)
Receive power in dBm, accurate to 0.01 dBm.
TX power(dBm)
Transmit power in dBm, accurate to 0.01 dBm.
High
High alarm threshold or high early warning threshold.
Low
Low alarm threshold or low early warning threshold.
Warning threshold
Early warning threshold.
Total average launch power on the multi-lane transceiver module in dBM, accurate to 0.01 dBm.
display transceiver eyediagram-diagnosis
Use display transceiver eyediagram-diagnosis to diagnose transceiver modules and display diagnosis information in an eye diagram.
display transceiver eyediagram-diagnosis interface [ interface-type interface-number ]
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If no interface is specified, this command displays the diagnostic results on every transceiver module.
This command is used to simulate the quality of data transmission from professional testing instruments. It obtains the sampling values of received data on chips and outputs the diagnostic results of transceiver modules in an eye diagram. This facilitates users in analyzing and evaluating the data transmission quality of transceiver modules.
You can analyze the data transmission quality of transceiver modules through eye diagrams as follows:
·     A larger eye opening area with a clearer shape indicates more stable signal transmission and better quality. The eye opening area is the blank area above and below the central line (0mV line).
·     No digits in the eye opening area indicate good data transmission quality. If the eye opening area has digits, the data transmission quality is poor.
# Diagnose the transceiver module in interface Ten-GigabitEthernet 1/0/1, and display the diagnostic results in an eye diagram.
<Sysname> display transceiver eyediagram-diagnosis interface ten-gigabitethernet 1/0/1
This operation might consume a large amount of system resources. It might cause unknown risks and might take several minutes. Continue?[Y/N]:y
    | EYESCAN Phy: 0x0e1 lane_mask: 0x01                                 |
Each character N represents approximate error rate 1e-N at that location
  UI/64  : -30  -25  -20  -15  -10  -5    0    5    10   15   20   25   30
   128mV : 111111111111111111111111112222322222222211111111111111111111111
   124mV : 111111111111111111111111122233332222222221111111111111111111111
   120mV : 111111111111111111111111222333333332222222211111111111111111111
   115mV : 111111111111111111111112223334443333222222221111111111111111111
   111mV : 111111111111111111111122233344444333322222222111111111111111111
   107mV : 111111111111111111111122233445544433332222222211111111111111111
   103mV : 111111111111111111111222334456655544333332222222111111111111111
    99mV : 111111111111111111112223344566665544433333222222211111111111111
    95mV : 11111111111111111111222344556776655443333322222221111111111111
    91mV : 11111111111111111112223345567  :766554443333222222111111111111
    86mV : 11111111111111111122233455677  :  76655444333322222211111111111
    82mV : 111111111111111111223344567----+---7665544433322222221111111111
    78mV : 111111111111111112223345667    :    :76655444333222222111111111
    74mV : 11111111111111112223345677:    :    :77665544333322222111111111
    70mV : 1111111111111111223344567 7    :    :   76655443332222211111111
    66mV : 1111111111111112223345677 :    :    :    7665444333222221111111
    62mV : 111111111111112223345667--+----+----+----+776554433322222111111
    57mV : 111111111111112223445677  :    :    :    :76655443332222111111
    53mV : 1111111111111222334566    :    :    :    :  7765544333222211111
    49mV : 1111111111112223345567    :    :    :    :    76554333222221111
    45mV : 111111111111222334567:    :    :    :    :    :7655443322222111
    41mV : 111111111112223345677+----+----+----+----+----+7765544332222211
    37mV : 11111111112223344567 :    :    :    :    :    :776544333222211
    33mV : 11111111112223345667 :    :    :    :    :    :   7654433322221
    28mV : 1111111112223344567  :    :    :    :    :    :   7765443322222
    24mV : 111111111222334567   :    :    :    :    :    :    765543332222
    20mV : 111111112223345567---+----+----+----+----+----+----+76544333222
    16mV : 11111112222344567    :    :    :    :    :    :    :7654433222
    12mV : 1111111222334567:    :    :    :    :    :    :    :77655433322
     8mV : 1111112223344567:    :    :    :    :    :    :    :  765543322
     4mV : 111111222334566 :    :    :    :    :    :    :    :  776544332
     0mV : 111111222344567-+----+----+----+----+----+----+----+----6554332
    -4mV : 111111222344567 :    :    :    :    :    :    :    :   76544332
    -8mV : 111111222334567 :    :    :    :    :    :    :    :  765443332
   -12mV : 1111112223344567:    :    :    :    :    :    :    :7655433322
   -16mV : 1111111222334567:    :    :    :    :    :    :    :7654433222
   -20mV : 11111112222344567----+----+----+----+----+----+----776544333222
   -24mV : 111111112223345677   :    :    :    :    :    :    765543332222
   -28mV : 111111111222334567   :    :    :    :    :    :   7665443332222
   -33mV : 1111111111222344567  :    :    :    :    :    :  77654433322221
   -37mV : 1111111111222334567  :    :    :    :    :    :766544333222211
   -41mV : 11111111111223344567-+----+----+----+----+----+7765544332222211
   -45mV : 11111111111222334566 :    :    :    :    :    77655443332222111
   -49mV : 1111111111112223345677    :    :    :    :    76554433322221111
   -53mV : 1111111111111222344567    :    :    :    :  7765544333222221111
   -57mV :1111111111111222334567    :    :    :    :77655443332222211111
   -62mV : 111111111111112223445677--+----+----+----+776654433332222211111
   -66mV : 111111111111111223345567  :    :    :    7765544333222222111111
   -70mV : 1111111111111112223345667 :    :    :    7655443333222221111111
   -74mV :11111111111111112223345667 :    :    :  766554433322222211111111
   -78mV :111111111111111112233445677    :    :  776554433322222211111111
   -82mV : 111111111111111112223345567----+----766554443332222221111111111
   -86mV : 1111111111111111112223345567   :    765544433322222221111111111
   -91mV : 11111111111111111112233445667  :   7665444333322222211111111111
   -95mV : 111111111111111111122233445667 :7766554433332222222111111111111
   -99mV : 111111111111111111112223344566777665544333322222221111111111111
  -103mV : 111111111111111111111223334556676655443333222222211111111111111
  -107mV : 111111111111111111111222333445565544333322222222111111111111111
  -111mV : 111111111111111111111122233444554443333222222221111111111111111
  -115mV : 111111111111111111111112223334444433332222222211111111111111111
  -120mV : 111111111111111111111111222333444333322222222111111111111111111
  -124mV : 111111111111111111111111222233333332222222211111111111111111111
  -128mV : 111111111111111111111111122223333322222222111111111111111111111
  UI/64  :-30  -25  -20  -15  -10  -5    0    5    10   15   20   25   30
display transceiver interface
Use display transceiver interface to display the key parameters of transceiver modules.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the key parameters of every transceiver module.
# Display the key parameters of the transceiver module in interface Ten-GigabitEthernet 1/0/1.
<Sysname> display transceiver interface ten-gigabitethernet 1/0/1
display transceiver manuinfo
Use display transceiver manuinfo to display electronic label information for transceiver modules.
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If no interface is specified, this command displays electronic label information for all transceiver modules.
# Display electronic label information for the transceiver module in interface Ten-GigabitEthernet 1/0/1.
<Sysname> display transceiver manuinfo interface ten-gigabitethernet 1/0/1
display transceiver power
Use display transceiver power to display power information for transceiver modules.
display transceiver power [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If no interface is specified, this command displays power information for all transceiver modules.
# Display power information for all transceiver modules.
<Sysname> display transceiver power
Interface       Transceiver type         Current power(w)    Max power(w)
XGE1/0/1         100G_BASE_SR4_QSFP28     2.30                3.50
XGE1/0/2         100G_BASE_LR4_QSFP28     2.50                4.00
XGE1/0/3         100G_BASE_ER4_QSFP28     3.51                5.00
XGE1/0/4         Absent                   --                  --
XGE1/0/5         100G_BASE_SR4_QSFP28     --                  --
XGE1/0/6         10G_BASE_LR_SFP          --                  1.50
         10G_BASE_LR_SFP          1.00                --
Current total power  : 9.31w
Maximum total Power  : 15.5w
# Display power information for the transceiver module in interface Ten-GigabitEthernet 1/0/1.
<Sysname> display transceiver power interface ten-gigabitethernet 1/0/1
XGE1/0/1           10G_BASE_LR_SFP              1.00                1.50
Table 26 Command output
Current power(w)
Current power of a transceiver module, in watts, accurate to 0.01 w.
Max power(w)
Maximum power of a transceiver module, in watts, accurate to 0.01 w.
Current total power
Current total power of all transceiver modules, in watts, accurate to 0.01 w.
Max total power
Maximum total power of all transceiver modules, in watts, accurate to 0.01 w
display version
Use display version to display system version information.
display version
# Display system version information.
<Sysname> display version
H3C Comware Software, Version 7.1.070, ESS 6713P01
Copyright (c) 2004-2023 New H3C Technologies Co., Ltd. All rights reserved.
H3C S6800-32Q uptime is 0 weeks, 0 days, 9 hours, 46 minutes
Last reboot reason : Cold reboot
Boot image: flash:/s6800-cmw710-boot-e6713p01.bin
Boot image version: 7.1.070, ESS 6713P01
  Compiled Nov 13 2023 11:00:00
System image: flash:/s6800-cmw710-system-e6713p01.bin
System image version: 7.1.070, ESS 6713P01
Table 27 Command output
Last reboot reason
Reason for the last reboot:
·     User reboot—The reboot was manually initiated from a user interface, such as the CLI or SNMP.
·     Cold reboot—The reboot was caused by a power cycle. This cause is also displayed when the version of the basic BootWare segment changes due to an update.
·     Kernel abnormality reboot—The reboot was caused by kernel exceptions.
·     DeadLoop reboot—The reboot was caused by a kernel thread dead loop.
·     DEV HandShake reboot—The reboot was caused by a device management handshake failure.
·     SlaveSwitch reboot—The reboot was caused by a master/subordinate switchover.
·     IRF Merge reboot—The reboot was caused by an IRF merge.
·     Auto Update reboot—The reboot was caused by an automatic software upgrade.
·     Memory exhaust reboot—The reboot was caused by a card-memory-exhausted event.
·     DoubleMasterReboot—The reboot was caused by a double master event.
display version-update-record
Use display version-update-record to display startup software image upgrade records.
The device records its current startup software version information whenever it starts up, and records all software version update information. Such information can survive reboots.
# Display the startup software image upgrade records.
<Sysname> display version-update-record
Record 1  (updated on Apr 18 2015 at 06:23:54):
 *Name        : boot-test.bin
  Version     : 7.1.070 Test 0001
  Compile time: Mar 25 2015 15:52:43
 *Name        : system-test.bin
Table 28 Command output
Record n
Number of the startup software image upgrade record. Record 1 is the most recent record.
Name
Software image file name.
The software image version changed during the upgrade.
reset version-update-record
fan prefer-direction
Use fan prefer-direction to specify the preferred airflow direction for the device.
Use undo fan prefer-direction to restore the default.
fan prefer-direction slot slot-number { port-to-power | power-to-port }
undo fan prefer-direction slot slot-number
The preferred airflow direction is from the power supply side to the port side.
port-to-power: Specifies the airflow direction from the port side to the power module side.
power-to-port: Specifies the airflow direction from the power module side to the port side.
This command specifies the desired airflow direction of the fans, but does not adjust the airflow direction. If the airflow direction detected by the system does not match the preferred direction, the system will send a trap and log message to notify you. Then, you can take the appropriate actions accordingly.
# Set the preferred airflow direction to port-to-power for member device 1.
[Sysname] fan prefer-direction slot 1 port-to-power
display fan
hardware-alarm disable
Use hardware-alarm disable to disable the notification of hardware resource alarms.
hardware-alarm { syslog | trap } resource-type { all | board | bus | chip-channel | chip-port | device | disk | fan | interface | power | subcard | transceiver | voltage } disable
undo hardware-alarm { syslog | trap } resource-type { all | board | bus | chip-channel | chip-portdevice | disk | fan | interface | power | subcard | transceiver | voltage } disable
The notification of all hardware resource alarms is enabled.
all: Specifies all types of resource alarms.
board: Specifies card-related resource alarms.
bus: Specifies bus-related resource alarms.
chip-channel: Specifies chip channel-related resource alarms.
chip-port: Specifies chip port-related resource alarms.
device: Specifies device-related resource alarms.
disk: Specifies disk-related resource alarms.
fan: Specifies fan-related resource alarms.
interface: Specifies interface-related resource alarms.
syslog: Sends hardware resources alarms in syslog messages.
subcard: Specifies subcard-related resource alarms.
transceiver: Specifies transceiver -related resource alarms.
trap: Sends hardware resources alarms in traps.
power: Specifies power supply-related resource alarms.
voltage: Specifies voltage-related resource alarms.
# Disable trap notification for all hardware resource alarms.
<Sysname> system
[Sysname] hardware-alarm trap resource-type all disable
# Disable syslog notification for device-related resource alarms.
<Sysname> system
[Sysname] hardware-alarm syslog resource-type device disable
Use hardware-resource switch-mode to set the hardware resource operating mode for the MAC address table, ARP/ND table, and routing tables.
Use undo hardware-resource switch-mode to restore the default.
hardware-resource switch-mode { 0 | 1 | 2 | 3 | 4 | 5}
The hardware resource operating mode is 0 for the MAC address table, ARP/ND table, and routing tables.
0: Sets the hardware resource operating mode to standard mode.
1: Sets the hardware resource operating mode to Layer 2 mode to use a larger MAC address table.
2: Sets the hardware resource operating mode to SDN mode.
3: Sets the hardware resource operating mode to Layer 3 mode to use a larger ARP/ND table.
4: Sets the hardware resource operating mode to routing mode to use larger routing tables.
5: Sets the hardware resource operating mode to routing mode. This mode provides the largest routing tables but the smallest ARP and ND tables.
The S6800 switch series does not support mode 5.
The switch supports multiple hardware resource operating modes for the MAC address table, ARP/ND table, and routing tables. The capacities of the tables vary by hardware resource operating mode. For more information, see device management in Fundamentals Configuration Guide.
This setting takes effect after you save the running configuration and reboot the switch. Before rebooting the switch, make sure you know the possible impact on the network.
If you set the hardware resource operating mode to 3, create only VPN instances that you must use so you can reserve more resources for routing tables.
# Set the hardware resource operating mode to 1 to use a larger MAC address table.
[Sysname] hardware-resource switch-mode 1
Do you want to change the specified hardware resource working mode? [Y/N]:y
The hardware resource working mode is changed, please save the configuration and
 reboot the system to make it effective.
hardware-resource routing-mode (Layer 3–IP Routing Command Reference)
header
Use header to configure a banner.
Use undo header to delete a banner.
header { legal | login | motd | shell } text
undo header { legal | login | motd | shell }
The device does not have banners.
legal: Configures the banner to be displayed before a user inputs the username and password to access the CLI.
login: Configures the banner to be displayed before password or scheme authentication is performed for a login user.
motd: Configures the greeting banner to be displayed before the legal banner appears.
shell: Configures the banner to be displayed before a user accesses user view.
text: Specifies the banner message. You can enter the banner message on the same line as the keywords or on different lines. For more information, see Fundamentals Configuration Guide.
# Configure the legal banner.
[Sysname] header legal
Welcome to use the legal banner%
job
Use job to assign a job to a schedule.
Use undo job to revoke a job.
job job-name
undo job job-name
No job is assigned to a schedule.
Schedule view
job-name: Specifies the job name, a case-sensitive string of 1 to 47 characters.
You can assign multiple jobs to a schedule. The jobs in a schedule are executed concurrently.
The jobs to be assigned to a schedule must already exist. To create a job, use the scheduler job command.
# Assign job save-job to schedule saveconfig.
[Sysname] scheduler schedule saveconfig
[Sysname-schedule-saveconfig] job save-job
scheduler job
scheduler schedule
memory-threshold
Use memory-threshold to set free-memory thresholds.
Use undo memory-threshold to restore the defaults.
undo memory-threshold [ slot slot-number [ cpu cpu-number ] ]
Minor alarm threshold: 128 MB.
Severe alarm threshold: 128 MB.
Critical alarm threshold: 128 MB.
Normal state threshold: 304 MB.
Early-warning threshold: 320 MB.
Sufficient-memory threshold: 368 MB.
ratio: Specifies free-memory thresholds in percentage. If you do not specify this keyword, the command sets free-memory thresholds in MB.
minor minor-value: Specifies the minor alarm threshold. To view the value range for this threshold, enter a question mark (?) in the place of the minor-value argument. Setting this threshold to 0 disables the minor alarm feature.
severe severe-value: Specifies the severe alarm threshold. To view the value range for this threshold, enter a question mark (?) in the place of the severe-value argument. Setting this threshold to 0 disables the severe alarm feature.
critical critical-value: Specifies the critical alarm threshold. To view the value range for this threshold, enter a question mark (?) in the place of the critical-value argument. Setting this threshold to 0 disables the critical alarm feature.
normal normal-value: Specifies the normal state threshold. To view the value range for this threshold, enter a question mark (?) in the place of the normal-value argument.
early-warning early-warning-value: Specifies the early-warning threshold. To view the value range for this threshold, enter a question mark (?) in the place of the early-warning-value argument. Setting this threshold to 0 disables the early warning feature.
secure secure-value: Specifies the sufficient-memory threshold. To view the value range for this threshold, enter a question mark (?) in the place of the secure-value argument.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command sets free-memory thresholds for the master device.
cpu cpu-number: Specifies a CPU by its number.
To ensure correct operation and improve memory efficiency, the system monitors the amount of free memory space in real time. If the amount of free memory space decreases to or below the minor, severe, or critical alarm threshold, the system issues an alarm to affected service modules or processes.
The early warning feature warns you of an approaching insufficient-memory condition.
If a memory alarm occurs, delete unused configuration items or disable some features to increase the free memory space. Because the memory space is insufficient, some configuration items might not be able to be deleted.
For more information about the thresholds, see Fundamentals Configuration Guide.
After you execute this command, if the amount of the free memory space reaches an alarm threshold, the system does not support creating a segment or entering its view. However, an existing microsegment will not be affected by this command.
The system restarts the device if one of the following conditions is met:
·     After a critical alarm occurs, the remaining free-memory value has been smaller than the critical alarm threshold for 30 seconds.
·     The interval between two consecutive critical alarms is shorter than 30 seconds.
·     The critical alarm has occurred three times within three minutes.
·     After a critical alarm occurs, the system will periodically sample free memory space and predict if the free memory space will be exhausted within 30 seconds. If the prediction result indicates that the free memory space will be exhausted within 30 seconds, the system will restart the device.
If the minor, severe, and critical alarm thresholds are the same, the device will generate notifications and automatically restart after the free memory space reaching these thresholds.
Once the free memory space reaches the early warning, minor, severe, or critical alarm threshold, the device will display the current memory usage information when you log in to the device through console or Telnet login, or execute every command.
# Set the minor alarm, severe alarm, critical alarm, and normal state thresholds to 64 MB, 48 MB, 32 MB, and 96 MB, respectively.
[Sysname] memory-threshold minor 64 severe 48 critical 32 normal 96
# Set the minor alarm, severe alarm, critical alarm, and normal state thresholds to 3%, 2%, 1%, and 5% of the total memory size, respectively.
[Sysname] memory-threshold ratio minor 3 severe 2 critical 1 normal 5
Use memory-threshold dma to set DMA memory thresholds.
Use undo memory-threshold dma to restore the default.
memory-threshold dma [ slot slot-number [ cpu cpu-number ] ] [ ratio ] critical critical-value normal normal-value
undo memory-threshold dma [ slot slot-number [ cpu cpu-number ] ]
The DMA memory alarm threshold is 2048 KB, and the normal state threshold is 4096 KB
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command sets DMA memory thresholds for the master device.
ratio: Specifies DMA memory thresholds in percentage.
critical critical-value: Specifies the DMA memory alarm threshold. If the ratio keyword is specified, the value range for the critical-value argument is 0 to 100 in percentage. If the ratio keyword is not specified, the value range for the critical-value argument is 0 to 2097148.
normal normal-value: Specifies the normal state threshold. If the ratio keyword is specified, the value range for the normal-value argument is 0 to 100 in percentage. If the ratio keyword is not specified, the device adjusts the value for the normal-value argument depending on the value for the critical-value argument.
To ensure correct operation of services that use Direct Memory Access (DMA) memory, the system monitors the amount of free DMA memory space regularly. If the amount of free DMA memory space decreases to or below the alarm threshold, the device restarts.
# Set the DMA memory alarm threshold and the normal state threshold to 32KB and 96 KB, respectively, for slot 1.
<System> system-view
[System] memory-threshold dma slot 1 critical 32 normal 96
memory-threshold usage
Use memory-threshold usage to set the memory usage threshold.
Use undo memory-threshold usage to restore the default.
undo memory-threshold [ slot slot-number [ cpu cpu-number ] ] usage
The memory usage threshold is 100%.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command sets the memory usage threshold for the master device.
memory-threshold: Specifies the memory usage threshold in percentage. The value range is 0 to 100.
The device samples memory usage at 1-minute intervals. If the sample is greater than the memory usage threshold, the device sends a trap.
# Set the memory usage threshold to 80%.
[Sysname] memory-threshold usage 80
monitor cpu-usage enable
Use monitor cpu-usage enable to enable CPU usage monitoring.
Use undo monitor cpu-usage enable to disable CPU usage monitoring.
undo monitor cpu-usage enable [ slot slot-number [ cpu cpu-number ] ]
CPU usage monitoring is enabled.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command enables CPU usage monitoring for the master device.
After CPU usage monitoring is enabled, the system samples and saves CPU usage at the interval specified by the monitor cpu-usage interval command. You can use the display cpu-usage history command to view recent CPU usage.
# Enable CPU usage monitoring.
[Sysname] monitor cpu-usage enable
display cpu-usage configuration
Use monitor cpu-usage interval to set the sampling interval for CPU usage monitoring.
Use undo monitor cpu-usage interval to restore the default.
undo monitor cpu-usage interval [ slot slot-number [ cpu cpu-number ] ]
The system samples CPU usage every 1 minute.
interval: Specifies the sampling interval for CPU usage monitoring. Valid values include 5Sec (5 seconds), 1Min (1 minute), and 5Min (5 minutes), case insensitive.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command sets the interval for the master device.
After CPU usage monitoring is enabled, the system samples and saves CPU usage at the specified interval. You can use the display cpu-usage history command to view recent CPU usage.
# Set the sampling interval for CPU usage monitoring to 5 seconds.
[Sysname] monitor cpu-usage interval 5Sec
monitor cpu-usage logging interval
Use monitor cpu-usage logging interval to enable periodic CPU usage logging.
Use undo monitor cpu-usage logging interval to disable periodic CPU usage logging.
monitor cpu-usage logging interval interval-time
Periodic CPU usage logging is disabled.
interval interval-time: Specifies the logging interval in seconds, a multiple of five in the range of 5 to 300.
# Enable periodic CPU usage logging and set the logging interval to 60 seconds.
[Sysname] monitor cpu-usage logging interval 60
monitor cpu-usage threshold
Use monitor cpu-usage threshold to set CPU usage alarm thresholds.
Use undo monitor cpu-usage threshold to restore the default.
monitor cpu-usage threshold severe-threshold { minor-threshold minor-threshold recovery-threshold recovery-threshold [ slot slot-number [ cpu cpu-number ] ] }
undo monitor cpu-usage threshold { minor-threshold recovery-threshold [ slot slot-number [ cpu cpu-number ] ] }
Severe CPU usage alarm threshold: 99%.
Minor CPU usage alarm threshold: 80%.
CPU usage recovery threshold: 75%.
severe-threshold: Specifies the severe CPU usage alarm threshold in percentage. The value range for this argument is 2 to 100.
minor-threshold minor-threshold: Specifies the minor CPU usage alarm threshold in percentage. The value range for this argument is 1 to the severe CPU usage alarm threshold minus 1.
recovery-threshold recovery-threshold: Specifies the CPU usage recovery threshold in percentage. The value range for this argument is 0 to the minor CPU usage alarm threshold minus 1.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command sets the CPU usage threshold for the master device.
CAUTION
CAUTION:
If you set the severe CPU usage alarm threshold to a too low value, the device will reach the threshold easily. Normal services will be affected.
The device samples CPU usage at 1-minute intervals. If the sample is greater than the CPU usage threshold, the device sends a trap.
# Set the severe CPU usage alarm threshold to 90%, minor CPU usage alarm threshold to 80%, and CPU usage recovery threshold to 70%.
[Sysname] monitor cpu-usage threshold 90 minor-threshold 80 recovery-threshold 70
monitor memory-usage logging interval
Use monitor memory-usage logging interval to enable periodic memory usage logging.
Use undo monitor memory-usage logging interval to disable periodic memory usage logging.
monitor memory-usage logging interval interval-time
Periodic memory usage logging is disabled.
# Enable periodic memory usage logging and set the logging interval to 60 seconds.
[Sysname] monitor memory-usage logging interval 60
monitor resend cpu-usage
Use monitor resend cpu-usage to set CPU usage alarm resending intervals.
Use undo monitor resend cpu-usage to restore the default.
undo monitor resend cpu-usage [ minor-interval | severe-interval ] [ slot slot-number [ cpu cpu-number ] ]
The minor alarm resending interval is 300 seconds. The severe alarm resending interval is 60 seconds.
minor-interval minor-interval: Specifies the minor alarm resending interval in seconds, a multiple of five in the range of 10 to 3600.
severe-interval severe-interval: Specifies the severe alarm resending interval in seconds, a multiple of five in the range of 10 to 3600.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command sets alarm resending intervals for the master device.
The device samples CPU usage periodically and compares the sample with the CPU usage threshold. If the sample increases above an alarm threshold, the CPU usage enters an alarm state and the device sends an alarm.
While the CPU usage is in minor alarm state, the device sends minor alarms periodically until the CPU usage increases above the severe threshold or the minor alarm is removed.
While the CPU usage is in severe alarm state, the device sends severe alarms periodically until the severe alarm is removed.
You can use this command to change CPU usage alarm resending intervals.
If you do not specify the minor-interval or severe-interval keyword, the undo monitor resend cpu-usage command restores default settings for both the minor and severe alarm resending intervals.
# Set the CPU usage minor alarm resending interval to 60 seconds for CPU 0 in slot 1.
[Sysname] monitor resend cpu-usage minor-interval 60 slot 1 cpu 0
monitor resend memory-threshold
Use monitor resend memory-threshold to set memory depletion alarm resending intervals.
Use undo monitor resend memory-threshold to restore the default.
undo monitor resend memory-threshold [ critical-interval | early-warning-interval | minor-interval | severe-interval ] * [ slot slot-number [ cpu cpu-number ] ]
·     Early warning resending interval: 1 hour.
·     Minor alarm resending interval: 12 hours.
·     Severe alarm resending interval: 3 hours.
·     Critical alarm resending interval: 1 hour.
critical-interval critical-interval: Specifies the critical alarm resending interval in hours, in the range of 1 to 48.
early-warning-interval early-warning-interval: Specifies the early warning resending interval in hours, in the range of 1 to 48.
minor-interval minor-interval: Specifies the minor alarm resending interval in hours, in the range of 1 to 48.
severe-interval severe-interval: Specifies the severe alarm resending interval in hours, in the range of 1 to 48.
The device samples the amount of free memory space periodically and compares the sample with free-memory thresholds. If the sample decreases to or below a threshold, the device enters a memory depletion alarm state and sends an alarm.
In critical alarm state, the device sends critical alarm notifications periodically until the critical alarm is removed.
In a lower alarm state, the device sends notifications for the alarm state periodically until it enters a higher alarm state or the current alarm is removed.
You can use this command to change the alarm resending intervals.
If you do not specify any memory depletion alarm resending intervals, the undo monitor resend memory-threshold command restores default settings for all memory depletion alarm resending intervals.
# Set the minor memory depletion alarm resending interval to 12 hours for CPU 0 in slot 1.
[Sysname] monitor resend memory-threshold minor-interval 12 slot 1 cpu 0
parity-error consistency-check log enable
Use parity-error consistency-check log enable to enable consistency error logging for software and hardware forwarding entries.
Use undo parity-error consistency-check log enable to disable consistency error logging for software and hardware forwarding entries.
Consistency error logging is enabled for software and hardware forwarding entries.
To forward packets, the device generates hardware forwarding entries in forwarding chips and software forwarding entries in memory at the same time. The device automatically detects whether the hardware forwarding entries and the software forwarding entries are consistent.
After you execute this command, the device collects consistency errors periodically. If the number of consistency errors in a statistics period reaches or exceeds the logging threshold, the device generates a log message.
# Enable consistency error logging for software and hardware forwarding entries.
[Sysname] parity-error consistency-check log enable
parity-error consistency-check threshold
Use parity-error consistency-check threshold to set the logging threshold for consistency errors between software and hardware forwarding entries.
Use undo parity-error consistency-check threshold to restore the default.
parity-error consistency-check threshold value
The logging threshold is 10.
value: Specifies the logging threshold for consistency errors between software and hardware forwarding entries, in the range of 1 to 2147483647.
After you enable consistency error logging for software and hardware forwarding entries, the device collects statistics for consistency errors periodically. If the number of consistency errors reaches or exceeds the logging threshold, the device generates a log message.
# Set the logging threshold to 20 for consistency errors between software and hardware forwarding entries.
[Sysname] parity-error consistency-check threshold 20
parity-error monitor log enable
Use parity-error monitor log enable to enable parity error logging for entries on forwarding chips.
Use undo parity-error monitor log enable to disable parity error logging for entries on forwarding chips.
Parity error logging is disabled for entries on forwarding chips.
The device detects parity errors in entries on forwarding chips. The parity error logging feature collects parity error statistics periodically and generates log messages as defined.
# Enable parity error logging for entries on forwarding chips.
[Sysname] parity-error monitor log enable
parity-error monitor period
parity-error monitor threshold
Use parity-error monitor period to set the parity error statistics period for entries on forwarding chips.
Use undo parity-error monitor period to restore the default.
parity-error monitor period value
The parity error statistics period is 600 seconds for entries on forwarding chips.
value: Specifies the parity error statistics period in seconds, in the range of 1 to 86400.
The device detects parity errors in entries on forwarding chips. The parity error logging feature collects parity error statistics periodically. This command sets the statistics period.
# Set the parity error statistics period to 120 seconds.
[Sysname] parity-error monitor period 120
Use parity-error monitor threshold to set the parity error logging threshold for entries on forwarding chips.
Use undo parity-error monitor threshold to restore the default.
parity-error monitor threshold value
The parity error logging threshold is 5000 for entries on forwarding chips.
value: Specifies the parity error logging threshold for entries on forwarding chips, in the range of 1 to 1000000.
The device detects parity errors in entries on forwarding chips. The parity error logging feature collects parity error statistics periodically, and generates a log message if the number of parity errors exceeds the logging threshold. This command sets the logging threshold.
# Set the parity error logging threshold to 8000 for entries on forwarding chips.
[Sysname] parity-error monitor threshold 8000
parity-error unrecoverable log enable
Use parity-error unrecoverable log enable to enable uncorrectable parity error and ECC error logging for entries on forwarding chips.
Use undo parity-error unrecoverable log enable to disable uncorrectable parity error and ECC error logging for entries on forwarding chips.
Uncorrectable parity error and ECC error logging is enabled for entries on forwarding chips
The device automatically detects parity errors and ECC errors in entries on forwarding chips and tries to correct the error when an error is detected. The uncorrectable parity error and ECC error logging feature enables the device to collect uncorrectable parity error and ECC error statistics periodically. If the number of uncorrectable parity errors and ECC errors reaches or exceeds the logging threshold, the device generates and sends an uncorrectable parity error and ECC error log message to the information center module. The information center module determines how and where to send the log message. For more information about the information center module, see information center configuration in Network Management and Monitoring Configuration Guide.
# Enable uncorrectable parity error and ECC error logging for entries on forwarding chips
[Sysname] parity-error unrecoverable log enable
parity-error unrecoverable period
parity-error unrecoverable reboot
parity-error unrecoverable threshold
Use parity-error unrecoverable period to set the statistics period for uncorrectable parity errors and ECC errors for entries on forwarding chips.
Use undo parity-error unrecoverable period to restore the default.
parity-error unrecoverable period period
The statistics period for uncorrectable parity errors and ECC errors for entries on forwarding chips is 600 seconds.
period: Specifies the statistics period for uncorrectable parity errors and ECC errors for entries on forwarding chips. The value is in the range of 1 to 86400, in seconds.
The device automatically detects parity errors and ECC errors in entries on forwarding chips and tries to correct the error when an error is detected. The uncorrectable parity error and ECC error logging feature enables the device to collect uncorrectable parity error and ECC error statistics periodically. If the number of uncorrectable parity errors and ECC errors reaches or exceeds the logging threshold, the device generates an uncorrectable parity error and ECC error log message.
This command sets the period for the device to collect uncorrectable parity error and ECC error statistics.
# Set the statistics period for uncorrectable parity errors and ECC errors in entries on forwarding chips to 120 seconds.
[Sysname] parity-error unrecoverable period 120
Use parity-error unrecoverable reboot to enable automatic system reboot upon generation of an uncorrectable parity error and ECC error log.
Use undo parity-error unrecoverable reboot to disable automatic system reboot upon generation of an uncorrectable parity error and ECC error log
The system reboots automatically upon generation of an uncorrectable parity error and ECC error log.
Uncorrectable parity errors and ECC errors in entries on forwarding chips might affect system services. To remove the errors from the entries on forwarding chips, you can execute this command to enable automatic system reboot upon generation of an uncorrectable parity error and ECC error log.
# Enable automatic system reboot upon generation of an uncorrectable parity error and ECC error log.
[Sysname] parity-error unrecoverable reboot
Use parity-error unrecoverable threshold to set the logging threshold for uncorrectable parity errors and ECC errors on entries on forwarding chips.
Use undo parity-error unrecoverable threshold to restore the default.
parity-error unrecoverable threshold value
The logging threshold for uncorrectable parity errors and ECC errors in entries on forwarding chips is 1.
value: Specifies the logging threshold for uncorrectable parity errors and ECC errors in entries on forwarding chips. The value is in the range of 1 to 1000000.
# Set the logging threshold for uncorrectable parity errors and ECC errors in entries on forwarding chips to 10.
[Sysname] parity-error unrecoverable log threshold 10
password-recovery enable
Use password-recovery enable to enable password recovery capability.
Use undo password-recovery enable to disable password recovery capability.
Password recovery capability is enabled.
Password recovery capability controls console user access to the device configuration and SDRAM from BootWare menus.
If password recovery capability is enabled, a console user can access the device configuration without authentication to configure new passwords.
If password recovery capability is disabled, console users must restore the factory-default configuration before they can configure new passwords. Restoring the factory-default configuration deletes the next-startup configuration files.
To enhance system security, disable password recovery capability.
Availability of BootWare menu options depends on the password recovery capability setting. For more information, see the release notes.
# Disable password recovery capability.
[Sysname] undo password-recovery enable
reboot
Use reboot to reboot the device.
reboot [ slot slot-number [ subslot subslot-number ] ] [ force ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify an IRF member device, the command reboots all IRF member devices.
subslot subslot-number: Specifies a subcard by its subslot number. If you do not specify a subslot number, the command reboots the slot. In the S6800 switch series, only S6800-2C, S6800-2C-FC, and S6800-4C switches support this option.
force: Reboots the device immediately without performing software or hard disk check. If this keyword is not specified, the system first identifies whether the reboot might result in data loss or a system failure. For example, the system identifies whether the main system software image file exists and whether a write operation is in progress on a storage medium. If the reboot might cause problems, the system does not reboot the device.
CAUTION
CAUTION:
·     A reboot might interrupt network services.
·     Use the force keyword only when the device fails or a reboot command without the force keyword cannot perform a reboot correctly. A reboot command with the force keyword might result in file system corruption because it does not perform data protection.
If the main startup software images are corrupt or missing, you must re-specify a set of main startup software images before executing the reboot command.
For data security, the device does not reboot if you reboot the device while the device is performing file operations.
If the IRF fabric has only one member device, rebooting the member device reboots the entire IRF fabric. If the IRF fabric has a subordinate member and the member is operating correctly, rebooting the master triggers a master/subordinate switchover.
To ensure correct operation of the IRF fabric and member devices, do not trigger a switchover by rebooting the master if no subordinate member devices are in Stable state. To view the status of subordinate member devices, execute the display system stable state command.
# Reboot the device. Save the running configuration at prompt.
<Sysname> reboot
Current configuration will be lost after the reboot, save current configuration? [Y/N]:y
Configuration is saved to mainboard device successfully.
Now rebooting, please wait...
# Reboot the device immediately without performing software check.
<Sysname> reboot force
A forced reboot might cause the storage medium to be corrupted. Continue? [Y/N]:y
reset alarm active
Use reset alarm active to clear active alarm information on the device.
reset alarm active { all | sequence-number sequence-number }
The active alarm information on the device is not cleared.
Parameter
all: Specifies all active alarms.
sequence-number sequence-number: Specifies an active alarm by its sequence number, in the range of 1 to 4294967295.
When the system has information about active alarms, you can execute this command to manually clear these alarms. After an alarm is cleared, the system will not display that alarm when you view alarm information.
# Clear the active alarm with sequence number 1.
[Sysname] reset alarm active sequence-number 1
display alarm active
display alarm history
reset scheduler logfile
Use reset scheduler logfile to clear job execution log information.
# Clear job execution log information.
<Sysname> reset scheduler logfile
display scheduler logfile
Use reset version-update-record to clear startup software image upgrade records.
# Clear the startup software image upgrade records.
[Sysname] reset version-update-record
This command will delete all records of version update. Continue? [Y/N]:y
resource-monitor minor resend enable
Use resource-monitor minor resend enable to enable resending of minor resource depletion alarms.
Use undo resource-monitor minor resend enable to disable resending of minor resource depletion alarms.
Resending of minor resource depletion alarms is enabled.
When a resource type enters minor alarm state, the device issues a minor alarm. If the resource type stays in minor alarm state or changes from severe alarm state to minor alarm state, the device identifies whether resending of minor resource depletion alarms is enabled. If the feature is disabled, the device does not issue additional minor alarms. If the feature is enabled, the device resends minor alarms periodically.
The resending period is fixed at 24 hours for a severe alarm and is fixed at 7 * 24 hours for a minor alarm.
# Enable resending of minor resource depletion alarms.
[Sysname] resource-monitor minor resend enable
display resource-monitor
resource-monitor output
resource-monitor resource
Use resource-monitor output to specify destinations for resource depletion alarms.
Use undo resource-monitor output to remove destinations for resource depletion alarms.
undo resource-monitor output [ netconf-event | snmp-notification | syslog ] *
Resource depletion alarms are sent to NETCONF, SNMP, and the information center.
netconf-event: Sends resource depletion alarms to the NETCONF feature to encapsulate the alarms in NETCONF events. For more information, see NETCONF in Network Management and Monitoring Configuration Guide.
snmp-notification: Sends resource depletion alarms to the SNMP feature to encapsulate the alarms in SNMP traps and informs. For more information, see SNMP in Network Management and Monitoring Configuration Guide.
syslog: Sends resource depletion alarms to the information center to encapsulate the alarms in log messages. For more information, see information center in Network Management and Monitoring Configuration Guide.
If you do not specify any keywords for the undo resource-monitor output command, the command disables resource depletion alarm output.
# Specify the information center module as the output destination for resource depletion alarms.
[Sysname] resource-monitor output syslog
Use resource-monitor resource to set resource depletion thresholds.
Use undo resource-monitor resource to disable resource depletion thresholds.
resource-monitor resource resource-name slot slot-number cpu cpu-number  by-percent  minor-threshold minor-threshold severe-threshold severe-threshold
undo resource-monitor resource resource-name slot slot-number cpu cpu-number
The default settings vary by resource type. Use the display resource-monitor command to display the resource depletion thresholds.
resource-name: Specifies a resource type by its name. The values for this argument are case insensitive and cannot be abbreviated. Table 29 shows the resource types that can be monitored.
Table 29 Resource types that can be monitored
Resource type
ac
Ethernet service instances.
arp
ARP resources.
ecmpgroup
ECMP group resources.
ipv4l2mc
IPv4 Layer 2 multicast resources.
ipv4l3mc
IPv4 Layer 3 multicast resources.
ipv6_127
Resources for IPv6 routes with a prefix length of 65 to 127 bits.
This resource type is not supported on the S6800-32Q (LS-6800-32Q-H1) switch.
ipv6_128
Resources for IPv6 routes with a prefix length of 128 bits.
ipv6_64
Resources for IPv6 routes with a prefix length of 0 to 64 bits.
ipv6l2mc
IPv6 Layer 2 multicast resources.
ipv6l3mc
IPv6 Layer 3 multicast resources.
mac
MAC address table resources.
mqcin
Inbound MQC resources.
mqcin_c0_p0
Inbound MQC resources of Pipe 0 on Chip 0.
mqcout
Outbound MQC resources.
mqcout_c0
Outbound MQC resources of Chip 0.
nd
ND resources.
nexthoppool1
Next-hop pool resources for the underlay network.
nexthoppool2
Next-hop pool resources for the overlay network.
This resource type is not supported on the S6800-2C (LS-6800-2C) and S6800-4C (LS-6800-4C) switches.
openflow
OpenFlow resources.
openflowin_c0_p0
OpenFlow resources of Pipe 0 on Chip 0.
pbr
PBR resources.
pbrin_c0_p0
PBR resources of Pipe 0 on Chip 0.
pfilterin
Inbound packet filter resources.
pfilterin_c0_p0
Inbound packet filter resources of Pipe 0 on Chip 0.
pfilterout
Outbound packet filter resources.
pfilterout_c0
Outbound packet filter resources of Chip 0.
route
Routing resources.
rport
Layer 3 Ethernet interface resources.
subrport
Layer 3 Ethernet subinterface resources.
vlan
VLANs.
vlaninterface
VLAN interface resources.
vrf
VPN instance resources.
vsi
VSIs.
vsiintf
VSI interface resources.
by-percent: Specifies resource depletion thresholds in percentage.
minor-threshold minor-threshold: Specifies the minor resource depletion threshold. To view the value range, enter a question mark (?) in the place of the minor-threshold argument.
severe-threshold severe-threshold: Specifies the severe resource depletion threshold. To view the value range, enter a question mark (?) in the place of the severe-threshold argument.
After you execute this command for a resource type, the device monitors the available amount of the type of resources. The device samples the available amount at intervals, compares the sample with the resource depletion thresholds to identify the resource depletion status, and sends alarms as configured.
# Set the minor resource depletion threshold to 30% and the severe resource depletion threshold to 10% for ARP entry resources on slot 1.
[Sysname] resource-monitor resource arp slot 1 cpu 0 by-percent minor-threshold 30 severe-threshold 10
restore factory-default
Use restore factory-default to restore the factory-default configuration for the device.
CAUTION
CAUTION:
This command restores the device to the factory default settings. Before executing this command, make sure you understand its impact on the live network.
This command is disruptive. Use this command only when you cannot troubleshoot the device by using other methods, or you want to use the device in a different scenario.
# Restore the factory-default configuration for the device.
<Sysname> restore factory-default
This command will restore the system to the factory default configuration and clear the operation data. Continue [Y/N]:y
Restoring the factory default configuration. This process might take a few minutes. Please wait..........................................................................................................Done.
Please reboot the system to place the factory default configuration into effect.
reboot
scheduler job
Use scheduler job to create a job and enter its view, or enter the view of an existing job.
Use undo scheduler job to delete a job.
scheduler job job-name
undo scheduler job job-name
No job exists.
A job can be referenced by multiple schedules. In job view, you can assign commands to the job.
# Create a job named backupconfig and enter job view.
[Sysname] scheduler job backupconfig
[Sysname-job-backupconfig]
command
scheduler schedule
scheduler logfile size
Use scheduler logfile size to set the size of the job execution log file.
scheduler logfile size value
The size of the job execution log file is 16 KB.
value: Specifies the size of the job execution log file, in KB. The value range is 16 to 1024.
The job execution log file saves the execution information of jobs. If the file is full, old records are deleted to make room for new records. If the size of the log information to be written to the file is greater than the file size, the excessive information is not written to the file.
# Set the size of the job execution log file to 32 KB.
[Sysname] scheduler logfile size 32
scheduler reboot at
Use scheduler reboot at to specify the reboot date and time.
Use undo scheduler reboot to delete the reboot schedule configuration.
No reboot date or time is specified.
time: Specifies the reboot time in the hh:mm format. The value range for hh is 0 to 23. The value range for mm is 0 to 59.
date: Specifies the reboot date in the MM/DD/YYYY or YYYY/MM/DD format. The value range for YYYY is 2000 to 2035. The value range for MM is 1 to 12. The value range for DD varies by month.
CAUTION
CAUTION:
This command enables the device to reboot at a scheduled time, which causes service interruption. Before using this command, make sure you fully understand its impact on your live network.
When the date argument is not specified, the system uses the following rules to determine the reboot time:
·     If the reboot time is later than the current time, a reboot occurs at the reboot time of the current day.
·     If the reboot time is earlier than the current time, a reboot occurs at the reboot time the next day.
The device supports only one device reboot schedule. If you execute both the scheduler reboot delay and scheduler reboot at commands or execute one of the commands multiple times, the most recent configuration takes effect.
For data security, the system does not reboot at the reboot time if a file operation is being performed.
# Configure the device to reboot at 12:00 p.m. This example assumes that the current time is 11:43 a.m. on June 6, 2015.
<Sysname> scheduler reboot at 12:00
Reboot system at 12:00:00 06/06/2015 (in 0 hours and 16 minutes). Confirm? [Y/N]:
Use scheduler reboot delay to specify the reboot delay time.
scheduler reboot delay time
No reboot delay time is specified.
time: Specifies the reboot delay time in the hh:mm or mm format. This argument can contain up to six characters. When in the hh:mm format, mm must be in the range of 0 to 59.
CAUTION
CAUTION:
The device supports only one device reboot schedule. If you execute both the scheduler reboot delay and schedule reboot at commands or execute one of the commands multiple times, the most recent configuration takes effect.
# Configure the device to reboot after 88 minutes. This example assumes that the current time is 11:48 a.m. on June 6, 2015.
<Sysname> scheduler reboot delay 88
Reboot system at 13:16 06/06/2015(in 1 hours and 28 minutes). Confirm? [Y/N]:
scheduler schedule
Use scheduler schedule to create a schedule and enter its view, or enter the view of an existing schedule.
Use undo scheduler schedule to delete a schedule.
undo scheduler schedule schedule-name
No schedule exists.
schedule-name: Specifies the schedule name, a case-sensitive string of 1 to 47 characters.
You can configure a schedule to have the device automatically run a command or a set of commands without administrative interference.
To configure a schedule:
1.     Use the scheduler job command to create a job and enter job view.
2.     Use the command command to assign commands to the job.
3.     Use the scheduler schedule command to create a schedule and enter schedule view.
4.     Use the job command to assign the job to the schedule. You can assign multiple jobs to a schedule. The jobs must already exist.
5.     Use the user-role command to assign user roles to the schedule. You can assign up to 64 user roles to a schedule.
6.     Use the time at, time once, or time repeating command to specify an execution time for the schedule. You can specify only one execution time for a schedule.
# Create a schedule named saveconfig.
job
time at
time once
shutdown-interval
Use shutdown-interval to set the port status detection timer.
Use undo shutdown-interval to restore the default.
shutdown-interval interval
The port status detection timer setting is 30 seconds.
interval: Specifies the port status detection timer value in seconds. The value range is 0 to 300. The value of 0 indicates that port status detection is not automatically performed, and you need to execute the undo shutdown command to restore the port status manually.
The device starts a port status detection timer when a port is shut down by a protocol. If the port has been in down state before the timer expires, the device will set the port status to the port's physical status.
If you change the timer setting during port detection, the device compares the new setting (T1) with the time that elapsed since the port was shut down (T).
If T < T1, the port will be brought up after T1 – T seconds.
If T ≥ T1, the port is brought up immediately.
For example, the timer setting is 30 seconds. If you change it to 10 seconds 2 seconds after the port is shut down, the port will come up 8 seconds later. If you change the timer setting to 2 seconds 10 seconds after the port is shut down, the port comes up immediately.
# Set the port status detection timer to 100 seconds.
[Sysname] shutdown-interval 100
sysid
Use sysid to set the system ID.
Use undo sysid to restore the default.
sysid system-id
undo sysid
The device does not have a system ID.
system-id: Specifies the system ID for the device. You can use this argument to indicate the position or functionality of the device or any other information.
# Set the system ID of the device to position-hall.
[Sysname] sysid positon-hall
sysname
Use sysname to set the device name.
Use undo sysname to restore the default.
sysname sysname
undo sysname
The device name is H3C.
sysname: Specifies a name for the device, a string of 1 to 64 characters.
A device name identifies a device in a network and is used in CLI view prompts. For example, if the device name is Sysname, the user view prompt is <Sysname>.
# Set the name of the device to R2000.
[Sysname] sysname R2000
[R2000]
system-working-mode
Use system-working-mode to set the system operating mode.
Use undo system-working-mode to restore the default.
system-working-mode { advance | expert | standard }
The device operates in standard mode.
advance: Sets the system operating mode to advanced.
expert: Sets the system operating mode to expert.
standard: Sets the system operating mode to standard.
The system operating mode determines the supported features and the feature specifications. For more information, see device management in Fundamentals Configuration Guide.
Change to the operating mode takes effect after a reboot.
# Set the system operating mode to advanced.
[Sysname] system-working-mode advance
Do you want to change the system working mode? [Y/N]:y
The system working mode is changed, please save the configuration and reboot the system to make it effective.
temperature-limit
Use temperature-limit to set the temperature alarm thresholds.
Use undo temperature-limit to restore the default.
temperature-limit slot slot-number  hotspot  sensor-number lowlimit warninglimit [ alarmlimit ]
undo temperature-limit slot slot-number  hotspot  sensor-number
The defaults vary by temperature sensor model. To view the defaults, execute the undo temperature-limit and display environment commands in turn.
hotspot: Configures temperature alarm thresholds for hotspot sensors. A hotspot sensor is typically located near a high-heat chip to monitor the chip temperature.
sensor-number: Specifies a sensor by its number. To view the value range, enter a question mark (?) in the place of this argument.
lowlimit: Specifies the low-temperature threshold in Celsius degrees. The value range varies by temperature sensor. To view the value range, enter a question mark (?) in the place of this argument.
warninglimit: Specifies the high-temperature warning threshold in Celsius degrees. This threshold must be greater than the low-temperature threshold. To view the value range, enter a question mark (?) in the place of this argument.
alarmlimit: Specifies the high-temperature alarming threshold in Celsius degrees. This threshold must be greater than the warning threshold. To view the value range, enter a question mark (?) in the place of this argument.
When the device temperature drops below the low-temperature threshold or reaches the high-temperature warning or alarming threshold, the device performs the following operations:
·     Sends log messages and traps.
·     Sets LEDs on the device panel.
# Set temperature alarm thresholds for hotspot sensor 1 in a slot.
[Sysname] temperature-limit slot 1 hotspot 1 -10 50 60
display environment
time at
Use time at to specify an execution date and time for a non-periodic schedule.
Use undo time to delete the execution date and time configuration for a non-periodic schedule.
time at time date
undo time
No execution time or date is specified for a non-periodic schedule.
Schedule view
time: Specifies the schedule execution time in the hh:mm format. The value range for hh is 0 to 23. The value range for mm is 0 to 59.
date: Specifies the schedule execution date in the MM/DD/YYYY or YYYY/MM/DD format. The value range for YYYY is 2000 to 2035. The value range for MM is 1 to 12. The value range for DD varies by month.
The specified time (date plus time) must be later than the current system time.
The time at command, the time once command, and the time repeating command overwrite one another. The most recently executed command takes effect.
# Configure the device to execute schedule saveconfig at 01:01 a.m. on May 11, 2015.
[Sysname-schedule-saveconfig] time at 1:1 2015/05/11
scheduler schedule
time once
Use time once to specify one or more execution days and the execution time for a non-periodic schedule.
Use undo time to delete the execution day and time configuration for a non-periodic schedule.
time once delay time
undo time
No execution time or day is specified for a non-periodic schedule.
Schedule view
at time: Specifies the execution time in the hh:mm format. The value range for hh is 0 to 23. The value range for mm is 0 to 59.
month-date month-day: Specifies a day in the current month, in the range of 1 to 31. If you specify a day that does not exist in the current month, the configuration takes effect on that day in the next month.
week-day week-day&<1-7>: Specifies a space-separated list of up to seven week days for the schedule. Valid week day values include Mon, Tue, Wed, Thu, Fri, Sat, and Sun.
delay time: Specifies the delay time for executing the schedule, in the hh:mm or mm format. This argument can have up to six characters. When in the hh:mm format, mm must be in the range of 0 to 59.
If the specified time has already occurred, the schedule will be executed at the specified time the following day.
If the day in the month has already occurred, the schedule will be executed at the specified day in the following month.
If the specified day in a week has already occurred, the schedule will be executed at the specified day in the following week.
# Configure the device to execute schedule saveconfig once at 15:00.
[Sysname-schedule-saveconfig] time once at 15:00
Schedule starts at 15:00 5/11/2011.
# Configure the device to execute schedule saveconfig once at 15:00 on the coming 15th day in a month.
[Sysname-schedule-saveconfig] time once at 15:00 month-date 15
# Configure the device to execute schedule saveconfig at 12:00 p.m. on the coming Monday and Friday.
[Sysname-schedule-saveconfig] time once at 12:00 week-day mon fri
# Configure the device to execute schedule saveconfig after 10 minutes.
[Sysname-schedule-saveconfig] time once delay 10
scheduler schedule
time repeating
Use time repeating to specify an execution time table for a periodic schedule.
Use undo time to delete the execution time table configuration for a periodic schedule.
time repeating [ at time [ date ] ] interval interval
undo time
No execution time table is specified for a periodic schedule.
Schedule view
at time: Specifies the execution time in the hh:mm format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. If you do not specify this option, the current system time is used as the execution time.
date: Specifies the start date for the periodic schedule, in the MM/DD/YYYY or YYYY/MM/DD format. The value range for YYYY is 2000 to 2035. The value range for MM is 1 to 12. The value range for DD varies by month. If you do not specify this argument, the execution start date is the first day when the specified time arrives.
interval interval: Specifies the execution time interval in the hh:mm or mm format. This argument can have up to six characters. When in the hh:mm format, mm must be in the range of 0 to 59. When in the mm format, this argument must be equal to or greater than 1 minute.
month-date [ month-day | last ]: Specifies a day in a month, in the range 1 to 31. The last keyword indicates the last day of a month. If you specify a day that does not exist in a month, the configuration takes effect on that day in the next month.
The time repeating [ at time [ date ] ] interval interval command configures the device to execute a schedule at intervals from the specified time on.
The time repeating at time [ month-date [ month-day | last ] | week-day week-day&<1-7> ] command configures the device to execute a schedule at the specified time on every specified day in a month or week.
The time at command, the time once command, and the time repeating command overwrite one another, whichever is executed most recently takes effect.
# Configure the device to execute schedule saveconfig once an hour from 8:00 a.m. on.
[Sysname-schedule-saveconfig] time repeating at 8:00 interval 60
# Configure the device to execute schedule saveconfig at 12:00 p.m. every day.
[Sysname-schedule-saveconfig] time repeating at 12:00
# Configure the device to execute schedule saveconfig at 8:00 a.m. on the 5th of every month.
[Sysname-schedule-saveconfig] time repeating at 8:00 month-date 5
# Configure the device to execute schedule saveconfig at 8:00 a.m. on the last day of every month.
[Sysname-schedule-saveconfig] time repeating at 8:00 month-date last
# Configure the device to execute schedule saveconfig at 8:00 a.m. every Friday and Saturday.
[Sysname-schedule-saveconfig] time repeating at 8:00 week-day fri sat
scheduler schedule
transceiver lane cdr
Use transceiver lane cdr to configure CDR on a transmit or receive lane for a QSFP transceiver module.
Use undo transceiver lane cdr to restore the default.
transceiver lane [ lane-number ] cdr { tx | rx } { on | off }
undo transceiver lane [ lane-number ] cdr { tx | rx }
CDR is enabled on a transmit or receive lane on a QSFP transceiver module.
Ethernet interface view
lane-number: Specifies a transceiver lane number, in the range of 1 to 4. If you do not specify a transceiver lane, the command applies to all transceiver lanes.
tx: Specifies the transmit link on the transceiver module.
rx: : Specifies the receive link on the transceiver module.
on: Enables CDR.
off: Disables CDR.
Enabling CDR can reduce the jitter to improve transmission performance, and disabling CDR degrades transmission performance. Both the enable and disable operations might cause oscillation on device ports.
The configuration by this command is saved in a register on the transceiver module. It is not saved to the configuration file.
This command is supported only on the QSFP transceiver modules.
# Enable CDR on the transmit side on the QSFP transceiver module in interface HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] transceiver lane cdr tx on
This command will engage the internal retiming function of transceiver Tx route. Continue? [Y/N]:Y
# Disable CDR on the receive side on the QSFP transceiver module in interface HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] transceiver lane cdr rx off
This command will enable an internal bypassing mode of transceiver Rx route, which directs traffic around the internal CDR. Continue? [Y/N]:Y
display transceiver status
transceiver monitor enable
Use transceiver monitor enable to enable transceiver monitoring.
Use undo transceiver monitor enable to restore the default.
Transceiver monitoring is disabled.
After transceiver monitoring is enabled, the device samples the parameters of transceiver modules periodically, including the input power and output power of transceiver modules. If a sampled value reaches the alarm threshold, the device generates a log to notify users.
# Enable transceiver monitoring.
[Sysname] transceiver monitor enable
transceiver monitor interval
Use transceiver monitor interval to set a transceiver monitoring interval.
Use undo transceiver monitor interval to restore the default.
transceiver monitor interval interval
The transceiver monitoring interval is 600 seconds.
interval: Specifies the transceiver monitoring interval in seconds. The value range is 300 to 3600.
After transceiver monitoring is enabled, the device samples the parameters of transceiver modules periodically, including the input power and output power of transceiver modules. If a sampled value reaches the alarm threshold, the device generates a log entry to notify users.
This command takes effect only when the transceiver monitor enable command is used.
# Set the transceiver monitoring interval to 500 seconds.
[Sysname] transceiver monitor interval 500
transceiver power-mode
Use transceiver power-mode to set a power mode for a transceiver module.
Use undo transceiver power-mode to restore the default.
transceiver power-mode { high | low }
The high power mode is specified for a transceiver module.
A transceiver module generally operates in high power mode. If the transceiver module does not work for a long time, you can switch the transceiver module to low power mode to reduce power consumption. In low power mode, the transceiver module does not transmit signals. To transmit signals, set high power mode for the transceiver module.
The power mode setting is saved in a register on the transceiver module. It is not saved to the configuration file.
# Set high power mode for the QSFP28 transceiver module in interface HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] transceiver power-mode high
# Set low power mode for the QSFP28 transceiver module in interface HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] transceiver power-mode low
This command will place the transceiver module in low-power-consumption mode, disabling the transceiver module from transmitting data. Continue? [Y/N]:Y
usb disable
Use usb disable to disable USB interfaces.
Use undo usb disable to enable USB interfaces.
usb disable
undo usb disable
All USB interfaces are enabled.
You can use USB interfaces to upload or download files. By default, all USB interfaces are enabled.
Before executing this command, use the umount command to unmount all USB file systems.
# Enable USB interfaces.
[Sysname] undo usb disable
user-role
Use user-role to assign user roles to a schedule.
Use undo user-role to remove user roles from a schedule.
user-role role-name
undo user-role role-name
A schedule has the user roles of the schedule creator.
Schedule view
role-name: Specifies a user role name, a case-sensitive string of 1 to 63 characters. The user role can be user-defined or predefined. Predefined user roles include network-admin, network-operator, and level-0 to level-15.
A schedule must have one or more user roles. A command in a schedule can be executed if it is permitted by one or more user roles of the schedule. For more information about user roles, see the RBAC configuration in Fundamentals Configuration Guide.
A schedule can have a maximum of 64 user roles. After the limit is reached, you cannot assign additional user roles to the schedule.
# Assign user role rolename to schedule test.
[Sysname] scheduler schedule test
[Sysname-schedule-test] user-role rolename
command
scheduler schedule
