09-Network Management and Monitoring Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S6826 & S9826 Switch Series Command References-Release 6715-6W10009-Network Management and Monitoring Command Reference
10-Process monitoring and maintenance commands
10-Process monitoring and maintenance commands 389.12 KB
The display memory, display process, display process cpu, monitor process and monitor thread commands display information about both user processes and kernel threads. In these commands, "process" refers to both user processes and kernel threads.
display exception context
Use display exception context to display context information for process exceptions.
display exception context [ count value ] [ slot slot-number [ cpu cpu-number ] ]
count value: Specifies the number of context information entries, in the range of 1 to 20. The default value is 1.
slot slot-number: Specifies a device by its ID, which is fixed at 1.
cpu cpu-number: Specifies a CPU by its number.
The system generates a context information entry for each process exception. A context information entry includes the process ID, the crash time, the core dump file directory, stack information, and register information.
# Display context information for process exceptions.
<Sysname> display exception context
Index 1 of 1
Crashed slot: 1
Crashed PID: 120 (routed)
Crash signal: SIGBUS
Crash time: Tue Apr  9 17:14:30 2019
Core file path:
flash:/core/node0_routed_120_7_20190409-171430_1365527670.core
info proc mapping
Mapped address spaces:
         Start Addr   End Addr       Size     Offset objfile
             0x8000    0x27000    0x1f000        0x0 /sbin/diagd
         0x6ece9000 0x6ecfe000    0x15000        0x0 [stack]
---- Thread 1 start ----
thread 1
[Switching to thread 1 (Thread 0x4102a530 (LWP 783))]
#0  0x401a0084 in raise () from /lib/libc.so.0
backtrace
#1  0x40199ebc in abort () from /lib/libc.so.0
#2  0x00014514 in Diag_DispMemAltInfoCallBack ()
#3  0x0000f914 in ?? ()
#4  0x40021da8 in start_thread () from /lib/libpthread.so.0
#5  0x401a0c8c in clone () from /lib/libc.so.0
#6  0x401a0c8c in clone () from /lib/libc.so.0
Backtrace stopped: previous frame identical to this frame (corrupt stack?)
info register
eax            0xfffffffc       -4
ecx            0xbfd29ec0       -1076715840
edx            0x1      1
ebx            0x3      3
esp            0xbfd29e98       0xbfd29e98
ebp            0xbfd29ea8       0xbfd29ea8
esi            0xffffffff       -1
edi            0xbfd29fb4       -1076715596
eip            0xb76905c6       0xb76905c6 <epoll_wait+40>
eflags         0x292    [ AF SF IF ]
cs             0x73     115
ss             0x7b     123
ds             0x7b     123
es             0x7b     123
fs             0x0      0
gs             0x33     51
x/320x $sp-64
0x41028ebc:      0x0005d090      0x41028efc      0x41028ed0      0x400038c8
0x410293ac:      0x74616369      0x736e6f69      0x6e657320      0x30203a74
x/320a $sp-64
0x41028ebc:      0x5d090 0x41028efc      0x41028ed0      0x400038c8 <_dl_linux_r
esolver+92>
x/32x $eax-64
0x41028ef0:      0x41028f54      0x41028f00      0x40005b34      0x401bc000
0x41028f00:      0x401bc410      0x000004ee      0x41028f54      0x41028f18
0x41028f10:      0x40199ebc      0x401a002c      0x0002f6fc      0x00000000
0x41028f20:      0x41028f58      0x000004ee      0x00000010      0x4102a100
0x41028f30:      0x00000020      0x00000000      0x40005b34      0x0002f6fc
0x41028f40:      0x00000000      0x41028f58      0x41029f7c      0x41028f58
0x41028f50:      0x00014514      0x40199e34      0x65657246      0x6d656d2d
0x41028f60:      0x2079726f      0x65726874      0x6c6f6873      0x0a3a7364
x/32x $ecx-64
0xcc:    Cannot access memory at address 0xcc
x/32x $edx-64
x/32x $ebx-64
x/32x $esp-64
x/32x $ebp-64
x/32x $esi-64
x/32x $edi-64
x/32x $eip-64
x/32x $eflags-64
x/32x $cs-64
x/32x $ss-64
x/32x $ds-64
x/32x $es-64
x/32x $fs-64
x/32x $gs-64
x/32a $eax-64
0x41028ef0:      0x41028f54      0x41028f00      0x40005b34 <_dl_linux_resolve+2
0>       0x401bc000
0x41028f00:      0x401bc410 <mylock>     0x4ee   0x41028f54      0x41028f18
0x41028f10:      0x40199ebc <abort+148>  0x401a002c <raise+12>   0x2f6fc 0x0
0x41028f20:      0x41028f58      0x4ee   0x10    0x4102a100
0x41028f30:      0x20    0x0     0x40005b34 <_dl_linux_resolve+20>       0x2f6fc
0x41028f40:      0x0     0x41028f58      0x41029f7c      0x41028f58
0x41028f50:      0x14514 <Diag_DispMemAltInfoCallBack+188>       0x40199e34 <abo
rt+12>   0x65657246      0x6d656d2d
0x41028f60:      0x2079726f      0x65726874      0x6c6f6873      0xa3a7364
x/32a $ecx-64
x/32a $edx-64
x/32a $ebx-64
x/32a $esp-64
x/32a $ebp-64
x/32a $esi-64
x/32a $edi-64
x/32a $eip-64
x/32a $eflags-64
x/32a $cs-64
x/32a $ss-64
x/32a $ds-64
x/32a $es-64
x/32a $fs-64
x/32a $gs-64
---- Thread 1 end ----
The command output might vary by operating system type of the device.
Filed
Crashed PID
ID of the crashed process.
Crash signal
Signals that led to the crash:
·     SIGABRT—Abort.
·     SIGBUS—Bus error.
·     SIGFPE—Erroneous arithmetic operation.
·     SIGILL—Illegal hardware instructions.
·     SIGQUIT—Quit signal sent by the controlling terminal.
·     SIGSEGV—Invalid memory access.
·     SIGSYS—Invalid system call.
·     SIGTRAP—Trap message.
·     SIGXCPU—CPU usage limit exceeded.
·     SIGXFSZ—File size limit exceeded.
·     SIGUNKNOW—Unknown reason.
Crash time
Time when the crash occurred.
Core file path
Directory where the core dump file is saved.
Start Addr
Start address of the file running abnormally.
End Addr
End address of the file running abnormally.
Size
Size of the file running abnormally.
Offset
Offset of the file running abnormally.
objfile
Software module associated with the file running abnormally.
Start delimiter of thread 1 information.
End delimiter of thread 1 information.
reset exception context
display exception filepath
Use display exception filepath to display the core dump file directory.
display exception filepath [ slot slot-number [ cpu cpu-number ] ]
# Display the core dump file directory on the specified slot.
<Sysname> display exception filepath slot 1
The exception filepath on slot 1 is flash:.
display kernel deadloop
Use display kernel deadloop to display kernel thread deadloop information.
display kernel deadloop show-number [ offset ] [ verbose ] [ slot slot-number [ cpu cpu-number ] ]
show-number: Specifies the number of deadloops to display, in the range of 1 to 20.
offset: Specifies the offset between the starting deadloop and the most recent deadloop, in the range of 0 to 19. The default value is 0.
verbose: Displays detailed information. If you do not specify this keyword, the command displays brief information.
# Display brief information about the most recent kernel thread deadloop.
<Sysname> display kernel deadloop 1
----------------- Deadloop record 1 -----------------
Description          : BUG: soft lockup - CPU#0 stuck for 61! [comsh: 16306]
Recorded at          : 2019-05-01  11:16:00.823018
Occurred at          : 2019-05-01  11:16:00.823018
Instruction address  : 0x4004158c
Thread               : comsh (TID: 16306)
Context              : thread context
Slot                 : 1
Cpu                  : 0
VCPU ID              : 0
Kernel module info   : module name (mrpnc) module address (0xe332a000)
# Display detailed information about the most recent kernel thread deadloop.
<Sysname> display kernel deadloop 1 verbose
Slot                 : 1
Cpu                  : 0
VCPU ID              : 0
Last 5 thread switches : migration/0 (11:16:00.823018)-->
                         swapper (11:16:00.833018)-->
                         kthreadd (11:16:00.833518)-->
                         swapper (11:16:00.833550)-->
                         disk (11:16:00.833560)
Register content:
Reg:       r0, Val = 0x00000000 ; Reg:       r1, Val = 0xe2be5ea0 ;
Reg:       r2, Val = 0x00000000 ; Reg:       r3, Val = 0x77777777 ;
Reg:       r4, Val = 0x00000000 ; Reg:       r5, Val = 0x00001492 ;
Reg:       r6, Val = 0x00000000 ; Reg:       r7, Val = 0x0000ffff ;
Reg:       r8, Val = 0x77777777 ; Reg:       r9, Val = 0x00000000 ;
Reg:      r10, Val = 0x00000001 ; Reg:      r11, Val = 0x0000002c ;
Reg:      r12, Val = 0x057d9484 ; Reg:      r13, Val = 0x00000000 ;
Reg:      r14, Val = 0x00000000 ; Reg:      r15, Val = 0x02000000 ;
Reg:      r16, Val = 0xe2be5f00 ; Reg:      r17, Val = 0x00000000 ;
Reg:      r18, Val = 0x00000000 ; Reg:      r19, Val = 0x00000000 ;
Reg:      r20, Val = 0x024c10f8 ; Reg:      r21, Val = 0x057d9244 ;
Reg:      r22, Val = 0x00002000 ; Reg:      r23, Val = 0x0000002c ;
Reg:      r24, Val = 0x00000002 ; Reg:      r25, Val = 0x24000024 ;
Reg:      r26, Val = 0x00000000 ; Reg:      r27, Val = 0x057d9484 ;
Reg:      r28, Val = 0x0000002c ; Reg:      r29, Val = 0x00000000 ;
Reg:      r30, Val = 0x0000002c ; Reg:      r31, Val = 0x00000000 ;
Reg:       cr, Val = 0x84000028 ; Reg:      nip, Val = 0x057d9550 ;
Reg:      xer, Val = 0x00000000 ; Reg:       lr, Val = 0x0186eff0 ;
Reg:      ctr, Val = 0x682f7344 ; Reg:      msr, Val = 0x00784b5c ;
Reg:     trap, Val = 0x0000b030 ; Reg:      dar, Val = 0x77777777 ;
Reg:    dsisr, Val = 0x40000000 ; Reg:   result, Val = 0x00020300 ;
Dump stack (total 1024 bytes, 16 bytes/line):
0xe2be5ea0: 02 be 5e c0 24 00 00 24 00 00 00 00 05 7d 94 84
0xe2be5eb0: 00 00 00 04 00 00 00 00 00 00 00 28 05 8d 34 c4
0xe2be5ec0: 02 be 60 a0 01 86 ef f0 00 00 00 00 00 00 00 00
0xe2be5ed0: 02 04 05 b4 00 00 00 00 00 00 00 00 00 00 00 00
0xe2be5ee0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0xe2be5ef0: 95 47 73 35 00 00 00 00 00 00 00 00 00 00 00 00
0xe2be5f00: a0 e1 64 21 00 00 00 00 00 00 00 00 00 00 00 00
0xe2be5f10: 00 00 00 00 00 00 00 00 00 00 00 00 01 e9 00 00
0xe2be5f20: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0xe2be5f30: 00 00 00 00 00 00 00 00 02 be 66 c0 02 be 66 d0
0xe2be5f40: 02 be 61 e0 00 00 00 02 00 00 00 00 02 44 b3 a4
0xe2be5f50: 02 be 5f 90 00 00 00 08 02 be 5f e0 00 00 00 08
0xe2be5f60: 02 be 5f 80 00 ac 1b 14 00 00 00 00 00 00 00 00
0xe2be5f70: 05 b4 5f 90 02 be 5f e0 00 00 00 30 02 be 5f e0
0xe2be5f80: 02 be 5f c0 00 ac 1b f4 00 00 00 00 02 45 00 00
0xe2be5f90: 00 03 00 00 00 00 00 00 02 be 5f e0 00 00 00 30
0xe2be5fa0: 02 be 5f c0 00 ac 1b 14 61 f1 2e ae 02 45 00 00
0xe2be5fb0: 02 44 b3 74 02 be 5f d0 00 00 00 30 02 be 5f e0
0xe2be5fc0: 02 be 60 60 01 74 ff f8 00 00 00 00 00 00 08 00
0xe2be5fd0: 02 be 5f f0 00 e8 93 7e 02 be 5f f8 02 be 5f fc
0xe2be5fe0: 00 00 00 00 00 00 00 00 00 00 00 00 02 be 60 18
0xe2be5ff0: 02 be 60 10 00 e9 65 98 00 00 00 58 00 00 2a 4f
0xe2be6000: 02 be 60 10 00 00 00 00 00 00 00 00 02 be 60 68
0xe2be6010: 02 be 60 40 00 e8 c6 a0 00 00 11 17 00 00 00 00
0xe2be6020: 02 be 60 40 00 00 00 00 00 00 00 00 02 be 60 98
0xe2be6030: 02 27 00 00 00 00 00 00 00 00 00 00 02 be 60 68
0xe2be6040: 02 be 60 60 00 00 00 01 00 00 b0 30 02 be 60 98
0xe2be6050: 00 00 00 04 02 21 00 00 00 00 00 00 01 e9 00 00
0xe2be6060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0xe2be6070: 00 00 00 00 00 00 00 00 02 be 66 c0 02 be 66 d0
0xe2be6080: 02 be 61 e0 00 00 00 02 00 00 00 00 02 be 61 70
0xe2be6090: 00 00 00 00 02 21 00 00 05 8d 34 c4 05 7d 92 44
Call trace:
Function Address = 0x8012a4b4
Function Address = 0x8017989c
Function Address = 0x80179b30
Function Address = 0x80127438
Function Address = 0x8012d734
Function Address = 0x80100a00
Function Address = 0xe0071004
Function Address = 0x8016ce0c
Function Address = 0x801223a0
Instruction dump:
41a2fe9c 812300ec 800200ec 7f890000 409efe8c 80010014 540b07b9 40a2fe80
4bfffe6c 80780290 7f64db78 4804ea35 <807f002c> 38800000 38a00080 3863000c
Description for the kernel thread deadloop, including the CPU number, thread running time, thread name, and thread number.
Recorded at
Time when the kernel thread deadloop was recorded, with microsecond precision.
Occurred at
Time when the kernel thread deadloop occurred, with microsecond precision.
Instruction address
Instruction address for the kernel thread deadloop.
Thread
Name and number of the kernel thread deadloop.
Context
Context for the kernel thread deadloop.
Cpu
Number of the CPU where the kernel thread ran.
VCPU ID
Number of the CPU core where the kernel thread ran.
Kernel module info
Information about kernel modules that had been loaded when the kernel thread deadloop was detected, including:
·     Module name—Kernel module name.
·     Module address—Memory address of the module.
Last five kernel thread switches on the CPU before the kernel thread deadloop was detected, including kernel thread name and kernel thread switching time with microsecond precision.
Register content
Register information:
·     Reg—Name of a register.
·     Val—Value saved in a register.
Dump stack
Stack information.
Call trace
Function call stack information, which shows the instruction address of a called function at each level.
Instruction dump
Instruction code when the kernel thread deadloop was detected. ffffffff indicates an illegitimate instruction code.
No information to display
No kernel thread deadloop information.
reset kernel deadloop
display kernel deadloop configuration
Use display kernel deadloop configuration to display kernel thread deadloop detection configuration.
display kernel deadloop configuration [ slot slot-number [ cpu cpu-number ] ]
# Display kernel thread deadloop detection configuration.
<Sysname> display kernel deadloop configuration
Thread dead loop detection: Enabled
Dead loop timer (in seconds): 20
Dead loop core list: 0-1
Dead loop action: Record-only
Threads excluded from monitoring: 1
  TID:     15   Name: co0
Dead loop timer (in seconds): n
Time interval (in seconds) to identify a kernel thread deadloop. A kernel thread deadloop occurs if a kernel thread runs more than n seconds.
Dead loop core list
CPU cores for which kernel thread deadloop detection is performed.
Dead loop action
Action to be taken in response to a kernel thread deadloop:
·     RebootLogs the event and reboots the hardware.
·     Record-onlyLogs the event.
Kernel threads excluded from kernel thread deadloop detection. This field appears only if the monitor kernel deadloop exclude-thread command is configured.
Name
Kernel thread name.
TID
Kernel thread number.
No thread is excluded from monitoring
All kernel threads are monitored by kernel thread deadloop detection.
display kernel exception
Use display kernel exception to display kernel thread exception information.
display kernel exception show-number [ offset ] [ verbose ] [ slot slot-number [ cpu cpu-number ] ]
show-number: Specifies the number of kernel exceptions to display, in the range of 1 to 20.
offset: Specifies the offset between the starting exception and the most recent exception, in the range of 0 to 19. The default value is 0.
If an exception occurs to a running kernel thread, the system automatically records the exception information.
# Display brief information about the most recent kernel thread exception.
<Sysname> display kernel exception 1
----------------- Exception record 1 -----------------
Description          : Oops[#0]
Slot                 : 1
Cpu                  : 0
VCPU ID              : 0
                       module name (disk) module address (0xe00bd000)
# Display detailed information about the most recent kernel thread exception.
<Sysname> display kernel exception 1 verbose
Slot                 : 1
Cpu                  : 0
VCPU ID              : 0
                       module name (12500) module address (0xe00bd000)
Register content:
Call trace:
Instruction dump:
For more information about the command output, see Table 2.
reset kernel exception
display kernel reboot
Use display kernel reboot to display reboot information for the device.
display kernel reboot show-number [ offset ] [ verbose ] [ slot slot-number [ cpu cpu-number ] ]
show-number: Specifies the number of reboots to display, in the range of 1 to 20.
offset: Specifies the offset between the starting reboot and the most recent reboot, in the range of 0 to 19. The default value is 0.
# Display brief information about the most recent reboot.
<Sysname> display kernel reboot 1
----------------- Reboot record 1 -----------------
Reason               : 0x31
Slot                 : 1
Target Slot          : 0
Cpu                  : 0
VCPU ID              : 0
# Display detailed information about the most recent reboot.
<Sysname> display kernel reboot 1 verbose
Reason               : 0x31
Slot                 : 1
Target Slot          : 0
Cpu                  : 0
VCPU ID              : 0
Call trace:
Recorded at
Time when the reboot was recorded, with microsecond precision.
Occurred at
Time when the reboot occurred, with microsecond precision.
Reason
Reboot reason.
Thread
Name and number of the kernel thread that was running when the reboot occurred.
Context
Context where the reboot occurred.
Slot
Number of the slot that triggered the reboot.
Target Slot
Number of the rebooted slot.
Cpu
Number of the CPU that triggered the reboot.
VCPU ID
Number of the CPU core that triggered the reboot.
Kernel module info
Information about kernel modules that had been loaded when the reboot occurred, including the kernel module names and memory addresses.
Last five kernel thread switches that occurred on the CPU before the reboot, including the kernel thread names and kernel thread switching time points, with microsecond precision.
Dump stack
Stack information for the threads that were running when the reboot occurred.
Call trace
Function call stack information.
No reboot information exists.
reset kernel reboot
display kernel starvation
Use display kernel starvation to display kernel thread starvation information.
display kernel starvation show-number [ offset ] [ verbose ] [ slot slot-number [ cpu cpu-number ] ]
show-number: Specifies the number of thread starvations to display, in the range of 1 to 20.
offset: Specifies the offset between the starting starvation and the most recent starvation, in the range of 0 to 19. The default value is 0.
# Display brief information about the most recent kernel thread starvation.
<Sysname> display kernel starvation 1
----------------- Starvation record 1 -----------------
Description          : INFO: task comsh: 16306 blocked for more than 10 seconds.
Slot                 : 1
Cpu                  : 0
VCPU ID              : 0
# Display detailed information about the most recent kernel thread starvation.
<Sysname> display kernel starvation 1 verbose
Slot                 : 1
Cpu                  : 0
VCPU ID              : 0
Register content:
Call trace:
Instruction dump:
For detailed information about the command output, see Table 2.
reset kernel starvation
display kernel starvation configuration
Use display kernel starvation configuration to display kernel thread starvation detection configuration.
display kernel starvation configuration [ slot slot-number [ cpu cpu-number ] ]
# Display kernel thread starvation detection configuration.
<Sysname> display kernel starvation configuration
Thread starvation detection: Disabled
Starvation timer (in seconds): 10
  TID:    123   Name: co0
Table 5 Command output
Starvation timer (in seconds): n
Time interval (in seconds) to identify a kernel thread starvation. A kernel thread starvation occurs if a kernel thread does not run within n seconds.
Kernel threads excluded from kernel thread starvation detection.
Name
Kernel thread name.
TID
monitor kernel starvation enable
monitor kernel starvation exclude-thread
monitor kernel starvation time
display process
Use display process to display process state information.
display process [ all | job job-id | name process-name ] [ slot slot-number [ cpu cpu-number ] ]
all: Specifies all processes. With the all keyword or without any parameters, the command displays state information for all processes.
job job-id: Specifies a process by its job ID, in the range of 1 to 2147483647. Each process has a fixed job ID.
name process-name: Specifies a process by its name, a case-insensitive string of 1 to 15 characters that must not contain question marks or spaces.
# Display state information for the process scmd.
<Sysname> display process name scmd
                             Job ID: 1
                                PID: 1
                         Parent JID: 0
                         Parent PID: 0
                    Executable path: /sbin/scmd
                           Instance: 0
                            Respawn: OFF
                      Respawn count: 1
             Max. spawns per minute: 0
                       Last started: Wed Jun  1 14:45:46 2019
                      Process state: sleeping
                          Max. core: 0
                               ARGS: -
    TID  LAST_CPU    Stack      PRI    State   HH:MM:SS:MSEC  Name
      1      0          0K      120      S     0:0:5:220      scmd
Table 6 Command output
Job ID
Job ID of the process. The job ID never changes.
PID
Number of the process. The number identifies the process, and it might change as the process restarts.
Parent JID
Job ID of the parent process.
Parent PID
Number of the parent process.
Executable path
Executable path of the process. For a kernel thread, this field displays a hyphen (-).
Instance
Instance number of the process. Whether a process can run multiple instances depends on the software implementation.
Respawn
Indicates whether the process restarts when an error occurs:
·     ON—The process automatically restarts.
·     OFF—The process does not automatically restarts.
Respawn count
Times that the process has restarted. The starting value is 1.
Maximum number of times that the process can restart within one minute. If the threshold is reached, the system automatically shuts down the process.
Last started
Time when the most recent restart occurred.
Process state
State of the process:
·     running—Running or waiting in the queue.
·     sleeping—Interruptible sleep.
·     traced or stopped—Stopped.
·     uninterruptible sleep—Uninterruptible sleep.
·     zombie—The process has quit, but some resources are not released.
Max. core
Maximum number of core dump files that the process can create. 0 indicates that the process never creates a core dump file. A process creates a core dump file after it abnormally restarts. If the number of core dump files reaches the maximum value, no more core dump files are created. Core dump files are helpful for troubleshooting.
ARGS
Parameters carried by the process during startup. If the process carries no parameters, this field displays a hyphen (-).
TID
Thread ID.
LAST_CPU
Number of the CPU on which the process is last scheduled.
Stack
Stack size.
PRI
Thread priority.
Thread state:
·     R—Running.
·     S—Sleeping.
·     T—Traced or stopped.
·     D—Uninterruptible sleep.
·     Z—Zombie.
HH:MM:SS:MSEC
Running time since the most recent start.
Name
Process name.
# Display state information for all processes.
<Sysname> display process all
    JID    PID %CPU %MEM STAT PRI THIRD TTY HH:MM:SS COMMAND
      1      1  0.0  0.0   S  120   N   -  00:00:04 scmd
      2      2  0.0  0.0   S  115   N   -  00:00:00 [kthreadd]
      3      3  0.0  0.0   S   99   N   -  00:00:00 [migration/0]
      4      4  0.0  0.0   S  115   N   -  00:00:05 [ksoftirqd/0]
      5      5  0.0  0.0   S   99   N   -  00:00:00 [watchdog/0]
      6      6  0.0  0.0   S  115   N   -  00:00:00 [events/0]
      7      7  0.0  0.0   S  115   N   -  00:00:00 [khelper]
      8      8  0.0  0.0   S  115   N   -  00:00:00 [kblockd/0]
      9      9  0.0  0.0   S  115   N   -  00:00:00 [ata/0]
     10     10  0.0  0.0   S  115   N   -  00:00:00 [ata_aux]
     11     11  0.0  0.0   S  115   N   -  00:00:00 [kseriod]
     12     12  0.0  0.0   S  120   N   -  00:00:00 [vzmond]
     13     13  0.0  0.0   S  120   N   -  00:00:00 [pdflush]
     14     14  0.0  0.0   S  120   N   -  00:00:00 [pdflush]
     15     15  0.0  0.0   S  115   N   -  00:00:00 [kswapd0]
     16     16  0.0  0.0   S  115   N   -  00:00:00 [aio/0]
     17     17  0.0  0.0   S  115   N   -  00:00:00 [scsi_eh_0]
     18     18  0.0  0.0   S  115   N   -  00:00:00 [scsi_eh_1]
     19     19  0.0  0.0   S  115   N   -  00:00:00 [scsi_eh_2]
     35     35  0.0  0.0   D  100   N   -  00:00:00 [lipc_topology]
---- More ----
Table 7 Command output
JID
Job ID of a process. It never changes.
PID
Number of a process.
%CPU
CPU usage in percentage (%).
%MEM
Memory usage in percentage (%).
STAT
State of a process:
·     R—Running.
·     S—Sleeping.
·     Z—Zombie.
PRI
Priority of a process for scheduling.
THIRD
Whether the process is a third party process:
·     Y—The process is a third party process.
·     N—The process is not a third party process.
TTY
TTY used by a process.
HH:MM:SS
Running time since the most recent start. If the running time reaches or exceeds 100 hours, this field displays only the number of hours.
COMMAND
Name and parameters of a process. If square brackets ([ ]) exist in a process name, the process is a kernel thread.
display process cpu
Use display process cpu to display CPU usage for all processes.
display process cpu [ slot slot-number [ cpu cpu-number ] ]
# Display CPU usage for all processes.
<Sysname> display process cpu
CPU utilization in 5 secs: 16.8%; 1 min: 4.7%; 5 mins: 4.7%
    JID      5Sec      1Min      5Min    Name
      1      0.0%      0.0%      0.0%    scmd
      2      0.0%      0.0%      0.0%    [kthreadd]
      3      0.1%      0.0%      0.0%    [ksoftirqd/0]
Table 8 Command output
System CPU usage within the last 5 seconds, 1 minute, and 5 minutes.
JID
5Sec
CPU usage of the process within the last 5 seconds.
1Min
CPU usage of the process within the last minute.
5Min
CPU usage of the process within the last 5 minutes.
Name
Name of the process. If square brackets ([ ]) exist in a process name, the process is a kernel thread.
display process log
Use display process log to display log information for all user processes.
display process log [ slot slot-number [ cpu cpu-number ] ]
# Display log information for all user processes.
<Sysname> display process log
Process       JobID  PID    Abort Core Exit Kill StartTime      EndTime
knotify       92     92     N     N    0    36   12-17 07:10:27 12-17 07:10:27
knotify       93     93     N     N    0    --   12-17 07:10:27 12-17 07:10:27
automount     94     94     N     N    0    --   12-17 07:10:27 12-17 07:10:28
knotify       111    111    N     N    0    --   12-17 07:10:28 12-17 07:10:28
comsh         121    121    N     N    0    --   12-17 07:10:30 12-17 07:10:30
knotify       152    152    N     N    0    --   12-17 07:10:31 12-17 07:10:31
autocfgd      155    155    N     N    0    --   12-17 07:10:31 12-17 07:10:31
pkg_update    122    122    N     N    0    --   12-17 07:10:30 12-17 07:10:31
Table 9 Command output
Process
Name of a user process.
JobID
Job ID of a user process.
PID
Abort
Indicates whether the process exited abnormally:
·     Y—Yes.
·     N—No.
Core
Indicates whether the process can generate core dump files:
·     Y—Yes.
·     N—No.
Exit
Process exit code. This field displays two hyphens (--) if the process was killed by a signal.
Kill
Code of the signal that killed the process. This field displays two hyphens (--) if the process exited instead of being killed.
StartTime
Time when the user process started.
EndTime
Time when the user process ended.
display process memory
Use display process memory to display memory usage for all user processes.
display process memory [ slot slot-number [ cpu cpu-number ] ]
When a user process starts, it requests the following types of memory from the system:
·     Text memory—Stores code for the user process.
·     Data memory—Stores data for the user process.
·     Stack memory—Stores temporary data.
·     Dynamic memory—Heap memory dynamically assigned and released by the system according to the needs of the user process. To view dynamic memory information, execute the display process memory heap command.
# Display memory usage for all user processes.
<Sysname> display process memory
   JID       Text      Data      Stack    Dynamic    Name
     1        384      1800         16         36    scmd
     2          0         0          0          0    [kthreadd]
     3          0         0          0          0    [ksoftirqd/0]
     4          0         0          0          0    [watchdog/0]
     5          0         0          0          0    [events/0]
     6          0         0          0          0    [khelper]
    29          0         0          0          0    [kblockd/0]
    49          0         0          0          0    [vzmond]
    52          0         0          0          0    [pdflush]
---- More ----
Table 10 Command output
JID
Text
Text memory used by the user process, in KB. The value for a kernel thread is 0.
Data
Data memory used by the user process, in KB. The value for a kernel thread is 0.
Stack
Stack memory used by the user process, in KB. The value for a kernel thread is 0.
Dynamic
Dynamic memory used by the user process, in KB. The value for a kernel thread is 0.
Name
Name of the user process. If square brackets ([ ]) exist in a process name, the process is a kernel thread.
display process memory heap address
display process memory heap size
display process memory fragment free
Use display process memory fragment free to display information about free memory blocks for a user process.
display process memory fragment free job job-id [ slot slot-number [ cpu cpu-number ] ]
job job-id: Specifies a user process by its job ID, in the range of 1 to 2147483647.
Memory fragmentation issue occurs when most of the memory is allocated as blocks, or chunks and a percentage of the total memory is unallocated, but unusable.
Use this command to display the address and size of memory blocks greater than 32 bytes for locating insufficient memory issues.
# Display information about free memory blocks for user process job 1.
<Sysname> display process memory fragment free job 1
Free block greater than or equal to 32KB in the main arena:
Address 0x7f2f0f2bd950 size 32kbytes
Free block greater than or equal to 32KB in A1 arena:
Address 0x7f2f0f4bd960 size 34kbytes
display process memory fragment used
Use display process memory fragment used to display information about used memory blocks for a user process.
display process memory fragment used job job-id [ slot slot-number [ cpu cpu-number ] ]
used-block: Specifies the number of used memory blocks, in the range of 1 to 128.
# Display information about used memory blocks for user process job 100.
<Sysname> display process memory fragment used 1 job 100
Main arena:
  Top Chunk:
    Address 0x88e9468 size  7064
  Neighboring 84 chunks used:
    Address 0x88e941c size    80
    Address 0x88e93cc size    80
    Address 0x88e93ac size    32
    Address 0x88e935c size    80
    Address 0x88e930c size    80
    Address 0x88e92ec size    32
    Address 0x88e929c size    80
    Address 0x88e924c size    80
    Address 0x88e91fc size    80
    Address 0x88e91dc size    32
    Address 0x88e918c size    80
    Address 0x88e913c size    80
    Address 0x88e90ec size    80
    Address 0x88e909c size    80
    Address 0x88e904c size    80
    Address 0x88e8ffc size    80
    Address 0x88e8fac size    80
    Address 0x88e8f8c size    32
    Address 0x88e8f3c size    80
---- More ----
Table 11 Command output
XX arena
Memory arena for allocating memory, where XX can be Main or other values such as A1 or A2. Main represents the main arena, and other values represent non-main arenas.
Top chunk
Address and size of the top chunk.
Neighboring  1  chunks used:
    Address0x7f2f8f2bd550 size 48 *
Number of used neighbor chunks of the top chunk. On a 32-bit device, * represents chunks smaller than 80 bytes. On a 64-bit device, * represents chunks smaller than 160 bytes.
Use display process memory heap to display heap memory usage for a user process.
display process memory heap job job-id [ verbose ] [ slot slot-number [ cpu cpu-number ] ]
Heap memory comprises fixed-sized blocks such as 16-byte or 64-byte blocks. It stores data and variables used by the user process. When a user process starts, the system dynamically allocates heap memory to the process.
Each memory block has an address represented in hexadecimal format, which can be used to access the memory block. You can view memory block addresses by using the display process memory heap size command, and view memory block contents by using the display process memory heap address command.
# Display brief information about heap memory usage for the process identified by job ID 1.
<Sysname> display process memory heap job 1
Total virtual memory heap space(in bytes)  :  188416
Total physical memory heap space(in bytes) :  188416
Total allocated memory(in bytes)           :  170376
Free physical memory ratio                 :  9.6%
# Display detailed information about heap memory usage for the process identified by job ID 1.
<Sysname> display process memory heap job 1 verbose
Heap usage:
Size      Free      Used      Total      Free Ratio
16        1         345       346        0.3%
24        2         193       195        1.0%
32        2         104       106        1.9%
40        0         18        18         0.0%
12592     1         0         1          100.0%
Summary:
Table 12 Command output
Size
Size of each memory block, in bytes.
Free
Number of free memory blocks.
Used
Number of used memory blocks.
Total
Total number of memory blocks.
Free Ratio
Ratio of free memory to total memory. It helps identify fragment information.
Use display process memory heap address to display heap memory content starting from a specified memory block for a process.
display process memory heap job job-id address starting-address length memory-length [ slot slot-number [ cpu cpu-number ] ]
address starting-address: Specifies the starting memory block by its address.
length memory-length: Specifies the memory block length in the range of 1 to 1024 bytes.
When a user process runs abnormally, the command helps locate the problem.
# Display 128-byte memory block content starting from the memory block 0xb7e30580 for the process job 1.
<Sysname> display process memory heap job 1 address b7e30580 length 128
B7E30580:  14 00 EF FF 00 00 00 00 E4 39 E2 B7 7C 05 E3 B7  .........9..|...
B7E30590:  14 00 EF FF 2F 73 62 69 6E 2F 73 6C 62 67 64 00  ..../sbin/slbgd.
B7E305A0:  14 00 EF FF 00 00 00 00 44 3B E2 B7 8C 05 E3 B7  ........D;......
B7E305B0:  14 00 EF FF 2F 73 62 69 6E 2F 6F 73 70 66 64 00  ..../sbin/ospfd.
B7E305C0:  14 00 EF FF 00 00 00 00 A4 3C E2 B7 AC 05 E3 B7  .........<......
B7E305D0:  14 00 EF FF 2F 73 62 69 6E 2F 6D 73 74 70 64 00  ..../sbin/mstpd.
B7E305E0:  14 00 EF FF 00 00 00 00 04 3E E2 B7 CC 05 E3 B7  .........>......
B7E305F0:  14 00 EF FF 2F 73 62 69 6E 2F 6E 74 70 64 00 00  ..../sbin/ntpd..
Use display process memory heap size to display the addresses of heap memory blocks with a specified size used by a process.
display process memory heap job job-id size memory-size [ offset offset-size ] [ slot slot-number [ cpu cpu-number ] ]
size memory-size: Specifies the memory block size in the range of 1 to 4294967295.
offset offset-size: Specifies an offset in the range of 0 to 4294967295. The default value is 128. For example, suppose the system allocates 100 16-byte memory blocks to process job 1, and the process has used 66 blocks. Then if you execute the display process memory heap job 1 size 16 offset 50 command, the output shows the addresses of the 51st through 66th 16-byte blocks used by the process.
The command displays memory block addresses in hexadecimal format. To view memory block content, execute the display process memory heap address command.
# Display the addresses of 16-byte memory blocks used by process job 1.
<Sysname> display process memory heap job 1 size 16
0xb7e300c0  0xb7e300d0  0xb7e300e0  0xb7e300f0
0xb7e30100  0xb7e30110  0xb7e30120  0xb7e30130
0xb7e30140  0xb7e30150  0xb7e30160  0xb7e30170
0xb7e30180  0xb7e30190  0xb7e301a0  0xb7e301b0
0xb7e301c0  0xb7e301d0  0xb7e301e0  0xb7e301f0
0xb7e30200  0xb7e30210  0xb7e30220  0xb7e30230
# Display the addresses of 16-byte memory blocks starting from the fifth block used by process job 1.
<Sysname> display process memory heap job 1 size 16 offset 4
exception filepath
Use exception filepath to specify the directory for saving core dump files.
Use undo exception filepath to remove the specified directory.
exception filepath directory
undo exception filepath directory
The directory for saving core dump files is the root directory of the default file system. For more information about the default file system, see file system management in Fundamentals Configuration Guide.
directory: Specifies the directory for saving core dump files. The directory must be the root directory of a file system.
The system will save core dump files to the core folder in the specified directory on the master. If the core folder does not exist in the specified directory, the system creates the core folder before saving core dump files.
You can use the command to change the directory if there are different types of storage media on the device.
If no directory is specified or the specified directory is not accessible, the system cannot save core dump files.
# Set the directory for saving core dump files to flash:/.
<Sysname> exception filepath flash:/
process core
monitor kernel deadloop action
Use monitor kernel deadloop action to specify the action to be taken in response to a kernel thread deadloop.
Use undo monitor kernel deadloop action to restore the default.
monitor kernel deadloop action { reboot | record-only } [ slot slot-number [ cpu cpu-number ] ]
undo monitor kernel deadloop action [ slot slot-number [ cpu cpu-number ] ]
The kernel thread deadloop protection action is record-only.
reboot: Logs the event and reboots the specified slot or CPU.
record-only: Logs the event.
CAUTION
CAUTION:
Use this command only under the guidance of H3C Support. Inappropriate configuration can cause system breakdown. As a best practice, leave the default unchanged.
# Set the kernel thread deadloop protection action to reboot for slot 1.
[Sysname] monitor kernel deadloop action reboot slot 1
monitor kernel deadloop enable
Use monitor kernel deadloop enable to enable kernel thread deadloop detection.
Use undo monitor kernel deadloop enable to disable kernel thread deadloop detection.
monitor kernel deadloop enable [ slot slot-number [ cpu cpu-number [ core core-number&<1-64> ] ] ]
undo monitor kernel deadloop enable [ slot slot-number [ cpu cpu-number ] ]
Kernel thread deadloop detection is enabled.
core core-number&<1-64> ]: Specifies a maximum of 64 CPU cores. If you do not specify this option, the command applies to all cores of the specified CPU.
CAUTION
CAUTION:
Kernel threads share resources in kernel space. If a kernel thread monopolizes the CPU for a long time, other threads cannot run, resulting in a deadloop.
This command enables the device to detect deadloops. If a thread occupies the CPU regularly, the device considers that a deadloop has occurred.
# Enable kernel thread deadloop detection.
[Sysname] monitor kernel deadloop enable
monitor kernel deadloop time
Use monitor kernel deadloop exclude-thread to exclude a kernel thread from kernel thread deadloop detection.
Use undo monitor kernel deadloop exclude-thread to include a kernel thread in kernel thread deadloop detection
monitor kernel deadloop exclude-thread tid [ slot slot-number [ cpu cpu-number ] ]
undo monitor kernel deadloop exclude-thread [ tid ] [ slot slot-number [ cpu cpu-number ] ]
Kernel thread deadloop detection monitors all kernel threads.
tid: Specifies a kernel thread by its ID, in the range of 1 to 2147483647. If you do not specify a kernel thread, the undo command restores the default.
You can exclude up to 128 kernel threads from kernel thread deadloop detection.
# Exclude kernel thread 15 from kernel thread deadloop detection.
[Sysname]monitor kernel deadloop exclude-thread 15
Use monitor kernel deadloop time to set the threshold for identifying a kernel thread deadloop.
Use undo monitor kernel deadloop time to restore the default.
monitor kernel deadloop time time [ slot slot-number [ cpu cpu-number ] ]
undo monitor kernel deadloop time [ slot slot-number [ cpu cpu-number ] ]
The threshold for identifying a kernel thread deadloop is 20 seconds.
time time: Specifies the threshold for identifying a kernel thread deadloop, in the range of 1 to 65535 seconds.
If a kernel thread runs for the specified period of time, kernel thread deadloop detection considers that a deadloop has occurred.
# Set the threshold for identifying a kernel thread deadloop to 8 seconds.
[Sysname] monitor kernel deadloop time 8
Use monitor kernel starvation enable to enable kernel thread starvation detection.
Use undo monitor kernel starvation enable to disable kernel thread starvation detection.
monitor kernel starvation enable [ slot slot-number [ cpu cpu-number ] ]
undo monitor kernel starvation enable [ slot slot-number [ cpu cpu-number ] ]
Kernel thread starvation detection is disabled.
CAUTION
CAUTION:
Starvation occurs when a thread is unable to access shared resources.
The command enables the system to detect and report thread starvation. If a thread is not executed within an interval, the system considers that a starvation has occurred, and outputs a starvation message.
Thread starvation does not impact system operation. A starved thread can automatically run when certain conditions are met.
# Enable kernel thread starvation detection.
[Sysname] monitor kernel starvation enable
Use monitor kernel starvation exclude-thread to exclude a kernel thread from kernel thread starvation detection.
Use undo monitor kernel starvation exclude-thread to include a kernel thread in kernel thread starvation detection.
monitor kernel starvation exclude-thread tid [ slot slot-number [ cpu cpu-number ] ]
undo monitor kernel starvation exclude-thread [ tid ] [ slot slot-number [ cpu cpu-number ] ]
Kernel thread starvation detection, if enabled, monitors all kernel threads.
You can exclude up to 128 kernel threads from kernel thread starvation detection.
# Exclude kernel thread 15 from kernel thread starvation detection.
[Sysname] monitor kernel starvation exclude-thread 15
Use monitor kernel starvation time to set the threshold for identifying a kernel thread starvation.
Use undo monitor kernel starvation time to restore the default.
monitor kernel starvation time time [ slot slot-number [ cpu cpu-number ] ]
undo monitor kernel starvation time [ slot slot-number [ cpu cpu-number ] ]
The threshold for identifying a kernel thread starvation is 120 seconds.
time time: Specifies the threshold for identifying a kernel thread starvation, in the range of 1 to 65535 seconds.
If a thread is not executed within the specified period of time, the system considers that a starvation has occurred, and outputs a starvation message.
# Set the threshold for identifying a kernel thread starvation to 120 seconds.
[Sysname] monitor kernel starvation time 120
monitor process
Use monitor process to display process statistics.
monitor process [ dumbtty ] [ iteration number ] [ slot slot-number [ cpu cpu-number ] ]
dumbtty: Specifies dumbtty mode. In this mode, the command displays process statistics in descending order of CPU usage without refreshing statistics. If you do not specify this keyword, the command displays statistics for the top 10 processes in descending order of CPU usage in an interactive mode, and refreshes statistics every 5 seconds by default.
iteration number: Specifies the number of display times, in the range of 1 to 4294967295. If you specify the dumbtty keyword, the number argument is 1 by default. If neither the dumbtty keyword nor the number argument is specified, there is no limit to the display times and process statistics are refreshed every 5 seconds.
If you do not specify the dumbtty keyword, the command displays process statistics in an interactive mode. In this mode, the system automatically determines the number of displayed processes according to the screen size, and does not display exceeding processes. You can also input interactive commands as shown in Table 13 to perform relevant operations.
Table 13 Interactive commands
Commands
? or h
Displays help information that includes available interactive commands.
1
Displays state information for physical CPUs. For example, if you enter 1 for the first time, the state of each physical CPU is displayed in a separate row. If you enter 1 again, the average value of all CPU states is displayed. If you enter 1 for the third time, separate states are displayed.
By default, the average value of all CPU states is displayed.
c
Sorts processes by CPU usage in descending order, which is the default setting.
d
Sets the interval for refreshing process statistics, in the range of 1 to 2147483647 seconds. The default value is 5 seconds.
f
Sorts processes by the number of open files in descending order. Files are identified by file descriptors (FDs).
k
Kills a process. Because the command can impact system operation, be cautious to use it.
l
Refreshes the screen.
m
Sorts processes by memory usage in descending order.
n
Changes the maximum number of processes displayed within a screen, in the range of 0 to 2147483647. The default value is 10. A value of 0 means no limit. Only processes not exceeding the screen size can be displayed.
q
Quits the interactive mode.
t
Sorts processes by running time in descending order.
Moves sort field to the next left column.
Moves sort field to the next right column.
# Display process statistics in dumbtty mode. In this mode, the system displays process statistics once, and then returns to command view.
<Sysname> monitor process dumbtty
 76 processes; 103 threads; 687 fds
Thread states: 1 running, 102 sleeping, 0 stopped, 0 zombie
CPU states: 77.16% idle, 0.00% user, 14.96% kernel, 7.87% interrupt
Memory: 496M total, 341M available, page size 4K
    JID    PID  PRI  State  FDs    MEM  HH:MM:SS    CPU   Name
   1047   1047  120    R     9   1420K  00:02:23  13.53%  diagd
      1      1  120    S    17   1092K  00:00:20   7.61%  scmd
   1000   1000  115    S     0      0K  00:00:09   0.84%  [sock/1]
   1026   1026  120    S    20  26044K  00:00:05   0.84%  syslogd
      2      2  115    S     0      0K  00:00:00   0.00%  [kthreadd]
      3      3   99    S     0      0K  00:00:00   0.00%  [migration/0]
      4      4  115    S     0      0K  00:00:06   0.00%  [ksoftirqd/0]
      5      5   99    S     0      0K  00:00:00   0.00%  [watchdog/0]
      6      6  115    S     0      0K  00:00:01   0.00%  [events/0]
      7      7  115    S     0      0K  00:00:00   0.00%  [khelper]
   4797   4797  120    S     8  28832K  00:00:02   0.00%  comsh
   5117   5117  120    S     8   1496K  00:00:00   0.00%  top
<Sysname>
# Display process statistics twice in dumbtty mode.
<Sysname> monitor process dumbtty iteration 2
CPU states: 44.84% idle, 0.51% user, 39.17% kernel, 15.46% interrupt
   1047   1047  120    R     9   1420K  00:02:30  37.11%  diagd
      1      1  120    S    17   1092K  00:00:21  11.34%  scmd
   1000   1000  115    S     0      0K  00:00:09   2.06%  [sock/1]
   1026   1026  120    S    20  26044K  00:00:05   1.54%  syslogd
   1027   1027  120    S    12   9280K  00:01:12   1.03%  devd
      4      4  115    S     0      0K  00:00:06   0.51%  [ksoftirqd/0]
   1009   1009  115    S     0      0K  00:00:08   0.51%  [karp/1]
   1010   1010  115    S     0      0K  00:00:13   0.51%  [kND/1]
   5373   5373  120    S     8   1496K  00:00:00   0.51%  top
   4796   4796  120    S    11   2744K  00:00:00   0.00%  login
   4797   4797  120    S     8  28832K  00:00:03   0.00%  comsh
Five seconds later, the system refreshes process statistics as follows (which is the same as executing the monitor process dumbtty command twice at a 5-second interval):
CPU states: 78.71% idle, 0.16% user, 14.86% kernel, 6.25% interrupt
   1047   1047  120    R     9   1420K  00:02:31  14.25%  diagd
      1      1  120    S    17   1092K  00:00:21   4.25%  scmd
   1027   1027  120    S    12   9280K  00:01:12   1.29%  devd
   1000   1000  115    S     0      0K  00:00:09   0.37%  [sock/1]
   5373   5373  120    S     8   1500K  00:00:00   0.37%  top
      6      6  115    S     0      0K  00:00:01   0.18%  [events/0]
   1009   1009  115    S     0      0K  00:00:08   0.18%  [karp/1]
   1010   1010  115    S     0      0K  00:00:13   0.18%  [kND/1]
   4795   4795  120    S    11   2372K  00:00:01   0.18%  telnetd
<Sysname>
# Display process statistics in interactive mode.
CPU states: 78.98% idle, 0.16% user, 14.57% kernel, 6.27% interrupt
   1047   1047  120    R     9   1420K  00:02:39  14.13%  diagd
      1      1  120    S    17   1092K  00:00:23   3.98%  scmd
   1027   1027  120    S    12   9280K  00:01:13   1.44%  devd
   1000   1000  115    S     0      0K  00:00:09   0.36%  [sock/1]
   1009   1009  115    S     0      0K  00:00:09   0.36%  [karp/1]
      4      4  115    S     0      0K  00:00:06   0.18%  [ksoftirqd/0]
   5491   5491  120    S     8   1500K  00:00:00   0.18%  top
The system refreshes process statistics every 5 seconds. You can enter interactive commands to perform operation as follows:
·     Enter h or a question mark (?) to display help information as follows:
Help for interactive commands:
      ?,h    Show the available interactive commands
        1    Toggle SMP view: '1' single/separate states
        c    Sort by the CPU field(default)
        d    Set the delay interval between screen updates
        f    Sort by number of open files
        k    Kill a job
        l    Refresh the screen
        m    Sort by memory used
        n    Set the maximum number of processes to display
        q    Quit the interactive display
        t    Sort by run time of processes since last restart
        <    Move sort field to the next left column
        >    Move sort field to the next right column
Press any key to continue
·     Enter d, and then enter a number to modify the refresh interval. If you enter 3, statistics are refreshed every 3 seconds.
Enter the delay interval between updates(1~2147483647): 3
·     Enter n, and then enter a number to modify the maximum number of displayed processes. If you enter 5, statistics for five processes are displayed.
Enter the max number of processes to display(0 means unlimited): 5
87 processes; 113 threads; 735 fds
Thread states: 2 running, 111 sleeping, 0 stopped, 0 zombie
CPU states: 86.57% idle, 0.83% user, 11.74% kernel, 0.83% interrupt
Memory: 755M total, 414M available, page size 4K
    864    864  120    S    24  27020K  00:00:43   8.95%  syslogd
   1173   1173  120    R    24   2664K  00:00:01   2.37%  top
    866    866  120    S    18  10276K  00:00:09   0.69%  devd
      1      1  120    S    16   1968K  00:00:04   0.41%  scmd
    881    881  120    S     8   2420K  00:00:07   0.41%  diagd
·     Enter f to sort processes by FDs in descending order. (You can also enter command c, m, or t to sort processes.)
Thread states: 1 running, 112 sleeping, 0 stopped, 0 zombie
CPU states: 90.66% idle, 0.88% user, 5.77% kernel, 2.66% interrupt
    862    862  120    S    61   5384K  00:00:01   0.00%  dbmd
    905    905  120    S    35   2464K  00:00:02   0.00%  ipbased
    863    863  120    S    31   1956K  00:00:00   0.00%  had
    884    884  120    S    31  30600K  00:00:00   0.00%  lsmd
    889    889  120    S    29  61592K  00:00:00   0.00%  routed
·     Enter k and then enter a JID to kill a process. If you enter 884, the process with the JID of 884 is killed.
Enter the JID to kill: 884
84 processes; 107 threads; 683 fds
Thread states: 1 running, 106 sleeping, 0 stopped, 0 zombie
CPU states: 59.03% idle, 1.92% user, 37.88% kernel, 1.15% interrupt
Memory: 755M total, 419M available, page size 4K
    862    862  120    S    56   5384K  00:00:01   0.00%  dbmd
    863    863  120    S    30   1956K  00:00:00   0.00%  had
   1160   1160  120    S    28  23096K  00:00:01   0.19%  sshd
·     Enter q to quit interactive mode.
Table 14 Command output
Numbers of processes, threads, and open files.
JID
Job ID of a process, which never changes.
PID
ID of a process.
PRI
Priority level of a process.
State of a process:
·     R—Running.
·     S—Sleeping.
·     Z—Zombie.
FDs
Number of open files for a process.
MEM
Memory usage. It displays 0 for a kernel thread.
HH:MM:SS
Running time of a process since last restart.
CPU
CPU usage of a process.
Name
Name of a process. If square brackets ([ ]) exist in a process name, the process is a kernel thread.
monitor thread
Use monitor thread to display thread statistics.
monitor thread [ dumbtty ] [ iteration number ] [ slot slot-number [ cpu cpu-number ] ]
dumbtty: Specifies dumbtty mode. In this mode, the command displays all thread statistics in descending order of CPU usage without refreshing statistics. If you do not specify the keyword, the command displays statistics for top 10 processes in descending order of CPU usage in an interactive mode, and refreshes statistics every 5 seconds by default.
iteration number: Specifies the number of display times, in the range of 1 to 4294967295. If you specify the dumbtty keyword, the number argument is 1 by default. If neither the dumbtty keyword nor the number argument is specified, there is no limit to the display times.
If you do not specify the dumbtty keyword, the command displays thread statistics in an interactive mode. In this mode, the system automatically determines the number of displayed thread processes according to the screen size and does not display exceeding processes. You can also input interactive keywords as shown in Table 15 to perform relevant operations.
Table 15 Interactive keywords
Keyword
? or h
Displays help information that includes available interactive keywords.
1
Displays one of the following items in turn when you press 1 again and again:
·     Values of parameters of physical CPUs.
·     Average values of parameters of all CPUs.
By default, the command displays the average values of parameters of all CPUs.
c
Sorts statistics by CPU usage in descending order. By default, the command sorts statistics by CPU usage in descending order.
d
Sets the interval for refreshing statistics. The default interval is 5 seconds.
k
Kills a process. Because the command can impact system operation, be cautious when you use it.
l
n
Changes the maximum number of threads displayed within a screen, in the range of 0 to 2147483647. The default value is 10. A value of 0 means no limit. Only threads not exceeding the screen size can be displayed.
q
Quits interactive mode.
t
Sorts statistics by the running time since the latest startup.
# Display thread statistics in dumbtty mode.
<Sysname> monitor thread dumbtty
CPU states: 83.19% idle, 1.68% user, 10.08% kernel, 5.04% interrupt
Memory: 755M total, 417M available, page size 4K
    JID    TID  LAST_CPU  PRI  State  HH:MM:SS   MAX    CPU    Name
   1175   1175      0     120    R    00:00:00     1  10.75%   top
      1      1      0     120    S    00:00:06     1   2.68%   scmd
    881    881      0     120    S    00:00:09     1   2.01%   diagd
    776    776      0     120    S    00:00:01     0   0.67%   [DEVD]
    866    866      0     120    S    00:00:11     1   0.67%   devd
      2      2      0     115    S    00:00:00     0   0.00%   [kthreadd]
      3      3      0     115    S    00:00:01     0   0.00%   [ksoftirqd/0]
      4      4      0      99    S    00:00:00     1   0.00%   [watchdog/0]
      5      5      0     115    S    00:00:00     0   0.00%   [events/0]
      6      6      0     115    S    00:00:00     0   0.00%   [khelper]
    796    796      0     115    S    00:00:00     0   0.00%   [kip6fs/1]
<Sysname>
# Display thread statistics in interactive mode.
CPU states: 94.43% idle, 0.76% user, 3.64% kernel, 1.15% interrupt
   1176   1176      0     120    R    00:00:01     1   3.42%   top
    866    866      0     120    S    00:00:12     1   0.85%   devd
    881    881      0     120    S    00:00:09     1   0.64%   diagd
      1      1      0     120    S    00:00:06     1   0.42%   scmd
   1160   1160      0     120    S    00:00:01     1   0.21%   sshd
          k      Kill a job
          n      Set the maximum number of threads to display
          t      Sort by run time of threads since last restart
Enter the delay interval between screen updates (1~2147483647): 3
·     Enter n, and then enter a number to modify the maximum number of displayed threads. If you enter 5, statistics for five threads are displayed.
Enter the max number of threads to display(0 means unlimited): 5
CPU states: 93.26% idle, 0.99% user, 4.23% kernel, 1.49% interrupt
   1176   1176      0     120    R    00:00:02     1   3.71%   top
      1      1      0     120    S    00:00:06     1   0.92%   scmd
    866    866      0     120    S    00:00:13     1   0.69%   devd
    881    881      0     120    S    00:00:10     1   0.69%   diagd
    720    720      0     115    D    00:00:01     0   0.23%   [TMTH]
·     Enter k and then enter a JID to kill a thread. If you enter 881, the thread with the JID of 881 is killed.
Enter the JID to kill: 881
83 processes; 106 threads
Thread states: 1 running, 105 sleeping, 0 stopped, 0 zombie
CPU states: 96.26% idle, 0.54% user, 2.63% kernel, 0.54% interrupt
Memory: 755M total, 418M available, page size 4K
   1176   1176      0     120    R    00:00:04     1   1.86%   top
    866    866      0     120    S    00:00:14     1   0.87%   devd
      1      1      0     120    S    00:00:07     1   0.49%   scmd
    730    730      0       0    S    00:00:04     1   0.12%   [DIBC]
    762    762      0     120    S    00:00:22     1   0.12%   [MNET]
Table 16 Command output
Numbers of processes and threads.
JID
Job ID of a thread, which never changes.
TID
ID of a thread.
LAST_CPU
Number of the CPU on which the most recent thread scheduling occurs.
PRI
Priority level of a thread.
State of a thread:
·     R—Running.
·     S—Sleeping.
·     Z—Zombie.
HH:MM:SS
Running time of a thread since last restart.
MAX
Longest time that a single thread scheduling occupies the CPU, in milliseconds.
CPU
CPU usage of a thread.
Name
Name of a thread. If square brackets ([ ]) exist in a thread name, the thread is a kernel thread.
process core
Use process core to enable or disable a process to generate core dump files for exceptions and set the maximum number of core dump files.
process core { maxcore value | off } { job job-id | name process-name } [ slot slot-number [ cpu cpu-number ] ]
A process generates a core dump file for the first exception and does not generate any core dump files for subsequent exceptions.
off: Disables core dump file generation.
maxcore value: Enables core dump file generation and sets the maximum number of core dump files, in the range of 1 to 10.
name process-name: Specifies a process by its name, a case-insensitive string of 1 to 15 characters.
job job-id: Specifies a process by its job ID, in the range of 1 to 2147483647. The job ID does not change after the process restarts.
The command applies to all instances of a process.
The command enables the system to generate a core dump file each time the specified process crashes until the maximum number of core dump files is reached. A core dump file records the exception information.
Because the core dump files consume system storage resources, you can disable core dump file generation for processes for which you do not need to review exception information.
# Disable core dump file generation for process routed.
<Sysname> process core off name routed
# Enable core dump file generation for process routed and set the maximum number of core dump files to 5.
<Sysname> process core maxcore 5 name routed
exception filepath
Use reset exception context to clear context information for process exceptions.
reset exception context [ slot slot-number [ cpu cpu-number ] ]
# Clear context information for exceptions.
<Sysname> reset exception context
Use reset kernel deadloop to clear kernel thread deadloop information.
reset kernel deadloop [ slot slot-number [ cpu cpu-number ] ]
# Clear kernel thread deadloop information.
<Sysname> reset kernel deadloop
Use reset kernel exception to clear kernel thread exception information.
reset kernel exception [ slot slot-number [ cpu cpu-number ] ]
# Clear kernel thread exception information.
<Sysname> reset kernel exception
reset kernel reboot
Use reset kernel reboot to clear kernel thread reboot information.
reset kernel reboot [ slot slot-number [ cpu cpu-number ] ]
# Clear kernel thread reboot information.
<Sysname> reset kernel reboot
Use reset kernel starvation to clear kernel thread starvation information.
reset kernel starvation [ slot slot-number [ cpu cpu-number ] ]
# Clear kernel thread starvation information.
<Sysname> reset kernel starvation
third-part-process start
Use third-part-process start to start a third-party process.
third-part-process start name process-name [ arg args ]
name process-name: Specifies the name of a third-party process. The value can be wifidog, puppet, or chef.
arg args: Specifies the arguments used when the third-party process is started. The value and format of the arguments must conform to the rules of the third party process. If you do not specify this option, the command starts a third-party process without any arguments.
Use this command to start a third-party process, such as Wifidog, Puppet, or Chef when the Comware system is operating.
If you execute this command multiple times but specify the same process name, whether this command can be executed successfully depends on the process. You can use the display current-configuration | include third-part-process command to view the result.
# Start third-party process puppet.
[Sysname] third-part-process start name puppet arg agent --certname=1.1.1.1 --server=1.1.1.2
third-part-process stop
Use third-part-process stop to stop a third-party process.
third-part-process stop pid pid&<1-10>
pid&<1-10>: Specifies a space-separated list of up to 10 third-party processes that have been started.
This command can only be used to stop processes started by the third-part-process start command. To display the ID of a third-party process, use the display process all command. "Y" in the THIRD field from the output indicates the third-party process and the PID field indicates the ID of the process.
# Stop third party process puppet.
     20     35  0.0  0.0   D  100   Y    -  00:00:00 puppet
---- More ----
[Sysname] third-part-process stop pid 35
display process all
