01-Typical configuration example
HomeSupportRoutersH3C SR8800-X Router SeriesConfigure & DeployConfiguration ExamplesH3C SR8800-X Routers Configuration Examples All-In-One-R8530Pxx-6W10001-Typical configuration example
Table of Contents
Related Documents
18-H3C_DLDP_Configuration_Examples
18-H3C_DLDP_Configuration_Examples 183.48 KB
Introduction
This document provides DLDP configuration examples.
The Device Link Detection Protocol (DLDP) was developed by H3C to detect the status of fiber links or twisted-pair links. When DLDP detects unidirectional links, it can automatically shut down the faulty port to avoid network problems. Alternatively, a user can manually shut down the faulty port.
This document assumes that you have basic knowledge of DLDP.
Example: Configuring the auto port shutdown mode
As shown in Figure 1, Device A and Device B are connected through two fiber pairs.
Configure DLDP on the devices so each device performs the following tasks:
·     Detects unidirectional links caused by cross-connected fibers or a disconnected fiber.
·     Automatically shuts down the faulty interface when detecting a unidirectional link.
·     Automatically brings up the interface after the administrator clears the fault.
Figure 1 Network diagram
When you configure DLDP, follow these restrictions and guidelines:
·     For DLDP to operate correctly, configure the full duplex mode for the interfaces at the two ends of the link, and configure the same speed for the two interfaces.
·     For DLDP to operate correctly, enable DLDP on both sides and make sure the following settings are consistent:
¡     Interval to send Advertisement packets.
¡     DLDP authentication mode.
¡     Password.
Procedures
1.     Configure Device A:
# Enable DLDP globally.
[DeviceA] dldp global enable
# Configure Ten-GigabitEthernet 3/1/1 and Ten-GigabitEthernet 3/1/2 to operate in full duplex mode at 10000 Mbps, and enable DLDP on the interfaces.
[DeviceA] interface ten-gigabitethernet 3/1/1
[DeviceA-Ten-GigabitEthernet3/1/1] duplex full
[DeviceA-Ten-GigabitEthernet3/1/1] speed 10000
[DeviceA-Ten-GigabitEthernet3/1/1] dldp enable
[DeviceA-Ten-GigabitEthernet3/1/1] quit
[DeviceA] interface ten-gigabitethernet 3/1/2
[DeviceA-Ten-GigabitEthernet3/1/2] undo shutdown
[DeviceA-Ten-GigabitEthernet3/1/2] duplex full
[DeviceA-Ten-GigabitEthernet3/1/2] speed 10000
[DeviceA-Ten-GigabitEthernet3/1/2] dldp enable
[DeviceA-Ten-GigabitEthernet3/1/2] quit
# Set the interval for sending Advertisement packets to 5 seconds (default interval).
[DeviceA] dldp interval 5
# Configure the plain text authentication mode and set the password to abc.
[DeviceA] dldp authentication-mode simple
[DeviceA] dldp authentication-password simple abc
# Set the interface shutdown mode to auto (default mode).
[DeviceA] dldp unidirectional-shutdown auto
2.     Configure Device B in the same way Device A is configured. (Details not shown.)
# Display global and interface-specific DLDP configuration for Device A.
[DeviceA] display dldp
 DLDP global status: Enabled
 DLDP advertisement interval: 5s
 DLDP authentication-mode: Simple
 DLDP authentication-password: ******
 DLDP unidirectional-shutdown mode: Auto
 DLDP delaydown-timer value: 1s
 Number of enabled ports: 2
Interface Ten-GigabitEthernet3/1/1
 DLDP port state: Bidirectional
 Number of the port’s neighbors: 1
  Neighbor MAC address: 0023-8956-3600
  Neighbor port index: 366
  Neighbor state: Confirmed
  Neighbor aged time: 15s
Interface Ten-GigabitEthernet3/1/2
  Neighbor port index: 361
  Neighbor aged time: 12s
The output shows that the DLDP port status of both Ten-GigabitEthernet 3/1/1 and Ten-GigabitEthernet 3/1/2 is Bidirectional.
# Enable the monitoring of logs on the current terminal for Device A, and set the lowest level of the logs that can be output to the monitor terminal to 6.
[DeviceA] quit
<DeviceA> terminal monitor
<DeviceA> terminal logging level 6
As shown in Figure 2, the two pairs of fibers between Device A and Device B are cross-connected.
Figure 2 Cross-connected fibers
The following log information is displayed on Device A:
<DeviceA>%May  3 09:32:35:324 2017 DeviceA IFNET/3/PHY_UPDOWN: -MDC=1; Physical state on the interface Ten-GigabitEthernet3/1/1 changed to down.
%May  3 09:32:35:344 2017 DeviceA IFNET/5/LINK_UPDOWN: -MDC=1; Line protocol state on the interface Ten-GigabitEthernet3/1/1 changed to down.
%May  3 09:32:43:836 2017 DeviceA IFNET/3/PHY_UPDOWN: -MDC=1; Physical state on the interface Ten-GigabitEthernet3/1/2 changed to down.
%May  3 09:32:43:853 2017 DeviceA IFNET/5/LINK_UPDOWN: -MDC=1; Line protocol state on the interface Ten-GigabitEthernet3/1/2 changed to down.
%May  3 09:32:48:289 2017 DeviceA IFNET/3/PHY_UPDOWN: -MDC=1; Physical state on the interface Ten-GigabitEthernet3/1/2 changed to up.
%May  3 09:32:54:263 2017 DeviceA IFNET/3/PHY_UPDOWN: -MDC=1; Physical state on the interface Ten-GigabitEthernet3/1/1 changed to up.
The output shows that the physical status of both Ten-GigabitEthernet 3/1/1 and Ten-GigabitEthernet 3/1/2 is down and then up. The link status of both interfaces is down.
# Display information about interface Ten-GigabitEthernet 3/1/1 on Device A.
[DeviceA]display interface ten-gigabitethernet 3/1/1
Current state: UP
Line protocol state: DOWN(DLDP)
IP Packet Frame Type: PKTFMT_ETHNT_2, Hardware Address: 00e0-fc00-5929
Description: Ten-GigabitEthernet3/1/1 Interface
Bandwidth: 10000000kbps
Loopback is not set
Media type is optical fiber, Port hardware type is 10G_BASE_SR_SFP
10Gbps-speed mode, full-duplex mode
Link speed type is autonegotiation, link duplex type is force link
Flow-control is not enabled
The Maximum Frame Length is 10000
Allow jumbo frame to pass
Broadcast MAX-ratio: 100%
Multicast MAX-ratio: 100%
Unicast MAX-ratio: 100%
PVID: 1
Mdi type: Automdix
Port link-type: Access
 Tagged Vlan:   None
 UnTagged Vlan: 1
Port priority: 0
Last link flapping: Never
Current system time:2017-03-03 09:49:03
Last time when physical state changed to up: 2017-03-03 09:32:48
Last time when physical state changed to down: 2017-03-03 09:49:03
 Peak value of input: 141 bytes/sec, at 2011-01-01 01:37:08
 Peak value of output: 84 bytes/sec, at 2011-01-01 05:39:56
 Last 300 seconds input:  0 packets/sec 99 bytes/sec 0%
 Last 300 seconds output:  0 packets/sec 63 bytes/sec 0%
 Input (total):  26470 packets, 2469445 bytes
          0 unicasts, 1 broadcasts, 26469 multicasts, 0 pauses
 Input (normal):  26470 packets, - bytes
          0 CRC, 0 frame, - overruns, 0 aborts
          - ignored, - parity errors
 Output (total): 16962 packets, 1165236 bytes
          0 unicasts, 0 broadcasts, 16962 multicasts, 0 pauses
 Output (normal): 16962 packets, - bytes
          0 lost carrier, - no carrier
The output shows that the physical status of Ten-GigabitEthernet 3/1/1 is up, but DLDP automatically shuts down the interface. The output for interface Ten-GigabitEthernet 3/1/2 is similar to Ten-GigabitEthernet 3/1/1. (Details not shown.)
<DeviceA> display dldp
 DLDP port state: Unidirectional
 Number of the port’s neighbors: 0 (Maximum number ever detected: 1)
The output shows that the DLDP port status of both Ten-GigabitEthernet 3/1/1 and Ten-GigabitEthernet 3/1/2 is Unidirectional. DLDP has detected a unidirectional link on both interfaces.
# Correct the fiber connections. As a result, the ports shut down by DLDP automatically recover, and Device A displays the following log information:
<DeviceA>%May  3 09:16:05:742 2017 DeviceA OPTMOD/5/RX_POW_LOW: -MDC=1-Slot=3; Ten-GigabitEthernet3/1/1: RX power is low!
%May  3 09:16:05:881 2017 DeviceA IFNET/3/PHY_UPDOWN: -MDC=1; Physical state on the interface Ten-GigabitEthernet3/1/1 changed to down.
%May  3 09:16:07:958 2017 DeviceA OPTMOD/5/RX_POW_LOW: -MDC=1-Slot=3; Ten-GigabitEthernet3/1/2: RX power is low!
%May  3 09:16:07:986 2017 DeviceA IFNET/3/PHY_UPDOWN: -MDC=1; Physical state on the interface Ten-GigabitEthernet3/1/2 changed to down.
%May  3 09:16:11:793 2017 DeviceA IFNET/3/PHY_UPDOWN: -MDC=1; Physical state on the interface Ten-GigabitEthernet3/1/1 changed to up.
%May  3 09:16:11:869 2017 DeviceA DLDP/6/DLDP_NEIGHBOR_CONFIRMED: -MDC=1-Slot=3; A neighbor was confirmed on interface Ten-GigabitEthernet3/1/1. The neighbor's system MAC is 0023-8956-3600, and the port index is 366.
%May  3 09:16:11:870 2017 DeviceA DLDP/6/DLDP_LINK_BIDIRECTIONAL: -MDC=1-Slot=3; DLDP detected a bidirectional link on interface Ten-GigabitEthernet3/1/1.
%May  3 09:16:11:817 2017 DeviceA IFNET/5/LINK_UPDOWN: -MDC=1; Line protocol state on the interface Ten-GigabitEthernet3/1/1 changed to up.
%May  3 09:16:12:573 2017 DeviceA OPTMOD/5/RX_POW_NORMAL: -MDC=1-Slot=3; Ten-GigabitEthernet3/1/1: RX power is normal!
%May  3 09:16:13:905 2017 DeviceA IFNET/3/PHY_UPDOWN: -MDC=1; Physical state on the interface Ten-GigabitEthernet3/1/2 changed to up.
%May  3 09:16:13:981 2017 DeviceA DLDP/6/DLDP_NEIGHBOR_CONFIRMED: -MDC=1-Slot=3; A neighbor was confirmed on interface Ten-GigabitEthernet3/1/2. The neighbor's system MAC is 0023-8956-3600, and the port index is 361.
%May  3 09:16:13:982 2017 DeviceA DLDP/6/DLDP_LINK_BIDIRECTIONAL: -MDC=1-Slot=3; DLDP detected a bidirectional link on interface Ten-GigabitEthernet3/1/2.
%May  3 09:16:13:927 2017 DeviceA IFNET/5/LINK_UPDOWN: -MDC=1; Line protocol state on the interface Ten-GigabitEthernet3/1/2 changed to up.
%May  3 09:16:14:788 2017 DeviceA OPTMOD/5/RX1_POW_NORMAL: -MDC=1-Slot=3; Ten-GigabitEthernet3/1/2: RX power is normal!
The output shows that the physical status and link status of both Ten-GigabitEthernet 3/1/1 and Ten-GigabitEthernet 3/1/2 are up and their DLDP neighbors are determined. The links become bidirectional.
Configuration files
·     Device A:
 dldp global enable
 dldp authentication-password cipher $c$3$wHDzwD/AZNW+q+otXapfZ/tUB/Wgbg==
 port link-mode route
 speed 10000
 duplex full
 dldp enable
 speed 10000
 duplex full
 dldp enable
·     The configuration file for Device B is the same as Device A. (Details not shown.)
Example: Configuring the manual port shutdown mode
As shown in Figure 3, Device A and Device B are connected through two fiber pairs.
Configure DLDP on the devices to meet the following requirements:
·     Each device can detect unidirectional links caused by cross-connected fibers or a disconnected fiber.
·     When a unidirectional link is detected, the administrator can manually shut down the faulty port based on the connection status of the link.
·     The interface recovers from failure after the administrator clears the fault and manually brings up the port.
Figure 3 Network diagram
¡     Password.
Procedures
# Set the interface shutdown mode to manual.
[DeviceA] dldp unidirectional-shutdown manual
 DLDP unidirectional-shutdown mode: Manual
[DeviceA] quit
As shown in Figure 4, the two pairs of fibers between Device A and Device B are cross-connected.
Figure 4 Cross-connected fibers
<DeviceA>%May  3 09:56:57:124 2017 DeviceA IFNET/3/PHY_UPDOWN: -MDC=1; Physical state on the interface Ten-GigabitEthernet3/1/1 changed to down.
%May  3 09:56:57:143 2017 DeviceA IFNET/5/LINK_UPDOWN: -MDC=1; Line protocol state on the interface Ten-GigabitEthernet3/1/1 changed to down.
%May  3 09:56:57:336 2017 DeviceA IFNET/3/PHY_UPDOWN: -MDC=1; Physical state on the interface Ten-GigabitEthernet3/1/2 changed to down.
%May  3 09:56:57:376 2017 DeviceA IFNET/5/LINK_UPDOWN: -MDC=1; Line protocol state on the interface Ten-GigabitEthernet3/1/2 changed to down.
%May  3 09:57:17:365 2017 DeviceA IFNET/3/PHY_UPDOWN: -MDC=1; Physical state on the interface Ten-GigabitEthernet3/1/1 changed to up.
%May  3 09:57:17:365 2017 DeviceA IFNET/5/LINK_UPDOWN: -MDC=1; Line protocol state on the interface Ten-GigabitEthernet3/1/1 changed to up.
%May  3 09:57:18:245 2017 DeviceA IFNET/3/PHY_UPDOWN: -MDC=1; Physical state on the interface Ten-GigabitEthernet3/1/1 changed to up.
%May  3 09:57:18:245 2017 DeviceA IFNET/5/LINK_UPDOWN: -MDC=1; Line protocol state on the interface Ten-GigabitEthernet3/1/1 changed to up.
The output shows that the physical status and link status of both Ten-GigabitEthernet 3/1/1 and Ten-GigabitEthernet 3/1/2 are down and then up.
[DeviceA] display interface ten-gigabitethernet 3/1/1
Current state: UP
Line protocol state: UP
Loopback is not set
PVID: 1
Mdi type: Automdix
 Tagged Vlan:   None
 UnTagged Vlan: 1
Port priority: 0
 Peak value of output: 104 bytes/sec, at 2011-01-01 06:40:58
 Last 300 seconds input:  0 packets/sec 27 bytes/sec 0%
 Last 300 seconds output:  1 packets/sec 101 bytes/sec 0%
 Input (total):  27226 packets, 2547709 bytes
          0 unicasts, 1 broadcasts, 27225 multicasts, 0 pauses
 Input (normal):  27226 packets, - bytes
 Output (total): 17991 packets, 1260564 bytes
          0 unicasts, 0 broadcasts, 17991 multicasts, 0 pauses
 Output (normal): 17991 packets, - bytes
The output shows that the physical status and link status of Ten-GigabitEthernet 3/1/1 are up. DLDP does not shut down the interface. The output for interface Ten-GigabitEthernet 3/1/2 is similar to Ten-GigabitEthernet 3/1/1. (Details not shown.)
The output shows that the DLDP port status of both Ten-GigabitEthernet 3/1/1 and Ten-GigabitEthernet 3/1/2 is Unidirectional. DLDP has detected a unidirectional link on both interfaces but does not shut them down.
# Shut down Ten-GigabitEthernet 3/1/1.
[DeviceA-Ten-GigabitEthernet3/1/1] shutdown
[DeviceA-Ten-GigabitEthernet3/1/1]%May  3 10:13:26:072 2017 DeviceA IFNET/3/PHY_UPDOWN: -MDC=1; Physical state on the interface Ten-GigabitEthernet3/1/1 changed to down.
%May  3 10:13:26:072 2017 DeviceA IFNET/5/LINK_UPDOWN: -MDC=1; Line protocol state on the interface Ten-GigabitEthernet3/1/1 changed to down.
%May  3 10:13:27:172 2017 DeviceA IFNET/3/PHY_UPDOWN: -MDC=1; Physical state on the interface Ten-GigabitEthernet3/1/2 changed to down.
%May  3 10:13:27:172 2017 DeviceA IFNET/5/LINK_UPDOWN: -MDC=1; Line protocol state on the interface Ten-GigabitEthernet3/1/2 changed to down.
The output shows that the physical status and link status of Ten-GigabitEthernet 3/1/1 and Ten-GigabitEthernet 3/1/2 are down.
# Shut down Ten-GigabitEthernet 3/1/2.
[DeviceA-Ten-GigabitEthernet3/1/2] shutdown
# Correct the fiber connections, and bring up Ten-GigabitEthernet 3/1/2.
[DeviceA-Ten-GigabitEthernet3/1/2]%May  3 10:20:37:016 2017 DeviceA IFNET/3/PHY_UPDOWN: -MDC=1; Physical state on the interface Ten-GigabitEthernet3/1/2 changed to up.
%May  3 10:20:37:018 2017 DeviceA IFNET/5/LINK_UPDOWN: -MDC=1; Line protocol state on the interface Ten-GigabitEthernet3/1/2 changed to up.
%May  3 10:20:37:019 2017 DeviceA DLDP/6/DLDP_NEIGHBOR_CONFIRMED: A neighbor was confirmed on interface Ten-GigabitEthernet3/1/2. The neighbor's system MAC is 0023-8956-3600, and the port index is 361.
%May  3 10:20:37:019 2017 DeviceA DLDP/6/DLDP_LINK_BIDIRECTIONAL: DLDP detected a bidirectional link on interface Ten-GigabitEthernet3/1/2.
The output shows that the physical status and link status of Ten-GigabitEthernet 3/1/2 are up and its DLDP neighbor is determined. The links become bidirectional.
# Bring up Ten-GigabitEthernet 3/1/1.
[DeviceA-Ten-GigabitEthernet3/1/1] undo shutdown
[DeviceA-Ten-GigabitEthernet3/1/1]%May  3 10:31:27:188 2017 DeviceA IFNET/3/PHY_UPDOWN: -MDC=1; Physical state on the interface Ten-GigabitEthernet3/1/1 changed to up.
%May  3 10:31:27:189 2017 DeviceA IFNET/5/LINK_UPDOWN: -MDC=1; Line protocol state on the interface Ten-GigabitEthernet3/1/1 changed to up.
%May  3 10:31:27:190 2017 DeviceA DLDP/6/DLDP_NEIGHBOR_CONFIRMED: -MDC=1-Slot=3; A neighbor was confirmed on interface Ten-GigabitEthernet3/1/1. The neighbor's system MAC is 0023-8956-3600, and the port index is 366.
%May  2 10:31:27:191 2017 DeviceA DLDP/6/DLDP_LINK_BIDIRECTIONAL: -MDC=1-Slot=3; DLDP detected a bidirectional link on interface Ten-GigabitEthernet3/1/1.
The output shows that the physical status and link status of Ten-GigabitEthernet 3/1/1 are up and its DLDP neighbor is determined. The links become bidirectional.
Configuration files
·     Device A:
 dldp global enable
 speed 10000
 duplex full
 dldp enable
 speed 10000
 duplex full
 dldp enable
Related documentation
·     H3C SR8800-X Routers High Availability Command Reference
·     H3C SR8800-X Routers High Availability Configuration Guide
