| 09-Track configuration | 616.73 KB |
Collaboration application example
Restrictions and guidelines: Track configuration
Associating Track with a detection module object
Associating Track with interface management
Associating Track with route management
Associating Track with a tracked list
Associating Track with a Boolean list
Associating Track with a percentage threshold list
Associating Track with a weight threshold list
Associating the Track module with an application module
Prerequisites for associating the Track module with an application module
Associating Track with the direct route on a device interface
Associating Track with static routing
Associating Track with traffic redirection
Associating Track with MPLS L2VPN
Display and maintenance commands for Track
Example: Configuring VRRP-Track-NQA collaboration
Example: Configuring BFD for a VRRP backup to monitor the master
Example: Configuring BFD for the VRRP master to monitor the uplink
Example: Configuring static routing-Track-NQA collaboration
Example: Configuring static routing-Track-BFD collaboration
Example: Configuring VRRP-Track-interface management collaboration
Example: Configuring VRRP-Track-route management collaboration
Example: Configuring direct route-Track-IPv4 VRRP collaboration
Example: Configuring direct route-Track-IPv6 VRRP collaboration
Configuring Track
About Track
Collaboration mechanism
The Track module collaborates with detection modules and application modules.
As shown in Figure 1, collaboration is enabled when you associate the Track module with a detection module and an application module, and it operates as follows:
1. The detection module probes specific objects such as interface status, link status, network reachability, and network performance, and informs the Track module of detection results.
2. The Track module sends the detection results to the application module.
3. When notified of changes for the tracked object, the application modules can react to avoid communication interruption and network performance degradation.
Figure 1 Collaboration through the Track module
Collaboration between the Track module and a detection module
The detection module sends the detection result of the tracked object to the Track module. The Track module changes the status of the track entry as follows:
· If the tracked object operates correctly, the state of the track entry is Positive. For example, the track entry state is Positive in one of the following conditions:
¡ The target interface is up.
¡ The target network is reachable.
· If the tracked object does not operate correctly, the state of the track entry is Negative. For example, the track entry state is Negative in one of the following conditions:
¡ The target interface is down.
¡ The target network is unreachable.
· If the detection result is invalid, the state of the track entry is NotReady. For example, the track entry state is NotReady if its associated NQA operation does not exist.
You can associate a track entry with an object of a detection module, such as the state of an interface or reachability of an IP route. The state of the track entry is determined by the state of the tracked object.
You can also associate a track entry with a list of objects called a tracked list. The state of a tracked list is determined by the states of all objects in the list. The following types of tracked lists are supported:
· Boolean AND list—The state of a Boolean AND list is determined by the states of the tracked objects using the Boolean AND operation.
· Boolean OR list—The state of a Boolean OR list is determined by the states of the tracked objects using the Boolean OR operation.
· Percentage threshold list—The state of a percentage threshold list is determined by comparing the percentage of positive and negative objects in the list with the percentage thresholds configured for the list.
· Weight threshold list—The state of a weight threshold list is determined by comparing the weight of positive and negative objects in the list with the weight thresholds configured for the list.
Collaboration between the Track module and an application module
Supported detection modules
The following detection modules can be associated with the Track module:
· NQA.
· BFD.
· CFD.
· Interface management.
· Route management.
· VRRP.
· Failover group.
Supported application modules
The following application modules can be associated with the Track module:
· VRRP.
· VSRP.
· Direct route.
· Static routing.
· PBR.
· Interface backup.
· Traffic redirection.
· VPLS.
· VXLAN.
· MPLS L2VPN.
· EAA.
The following is an example of collaboration between NQA, Track, and static routing.
Configure a static route with next hop 192.168.0.88 on the device. If the next hop is reachable, the static route is valid. If the next hop becomes unreachable, the static route is invalid. For this purpose, configure NQA-Track-static routing collaboration as follows:
1. Create an NQA operation to monitor the accessibility of IP address 192.168.0.88.
2. Create a track entry and associate it with the NQA operation.
¡ When next hop 192.168.0.88 is reachable, NQA sends the result to the Track module. The Track module sets the track entry to Positive state.
¡ When the next hop becomes unreachable, NQA sends the result to the Track module. The Track module sets the track entry to Negative state.
3. Associate the track entry with the static route.
¡ When the track entry is in Positive state, the static routing module considers the static route to be valid.
¡ When the track entry is in Negative state, the static routing module considers the static route to be invalid.
When configuring a track entry for an application module, you can set a notification delay to avoid immediate notification of status changes.
When the delay is not configured and the route convergence is slower than the link state change notification, communication failures occur. For example, when the master in a VRRP group detects an uplink interface failure through Track, Track immediately notifies the master to decrease its priority. A backup with a higher priority then preempts as the new master. When the failed uplink interface recovers, the Track module immediately notifies the original master to restore its priority. If the uplink route has not recovered, forwarding failure will occur.
Track tasks at a glance
To implement the collaboration function, establish associations between the Track module and detection modules, and between the Track module and application modules.
To configure the Track module, perform the following tasks:
1. Associating Track with a detection module object
¡ Associating Track with interface management
¡ Associating Track with route management
2. Associating Track with a tracked list
¡ Associating Track with a Boolean list
¡ Associating Track with a percentage threshold list
¡ Associating Track with a weight threshold list
3. Associating the Track module with an application module
¡ Associating Track with the direct route
¡ Associating Track with static routing
¡ Associating Track with traffic redirection
¡ Associating Track with VXLAN
¡ Associating Track with MPLS L2VPN
NOTE: Support for detection modules depends on the device model. |
Associating Track with NQA
NQA supports multiple operation types to analyze network performance and service quality. For example, an NQA operation can periodically detect whether a destination is reachable, or whether a TCP connection can be established.
An NQA operation operates as follows when it is associated with a track entry:
· If the consecutive probe failures reach the specified threshold, the NQA module notifies the Track module that the tracked object has malfunctioned. The Track module then sets the track entry to Negative state.
· If the specified threshold is not reached, the NQA module notifies the Track module that the tracked object is operating correctly. The Track module then sets the track entry to Positive state.
For more information about NQA, see Network Management and Monitoring Configuration Guide.
If you associate a track entry with a nonexistent NQA operation or reaction entry, the state of the track entry is NotReady.
1. Enter system view.
2. Create a track entry associated with an NQA reaction entry and enter its view.
track track-entry-number nqa entry admin-name operation-tag reaction item-number
3. (Optional.) Set the delay for notifying the application module of track entry state changes.
delay { negative negative-time | positive positive-time } *
By default, the Track module notifies the application module immediately when the track entry state changes.
Associating Track with BFD
BFD supports the control packet mode and echo packet mode. A track entry can be associated with a echo-mode BFD session or control-mode static BFD session. For more information about BFD, see "Configuring BFD."
The associated Track and BFD operate as follows:
· If the BFD detects that the link fails, it informs the Track module of the link failure. The Track module sets the track entry to Negative state.
· If the BFD detects that the link is operating correctly, the Track module sets the track entry to Positive state.
When you associate a track entry with BFD, do not configure the virtual IP address of a VRRP group as the local or remote address of the BFD session.
Before you associate Track with BFD, configure the source IP address of BFD echo packets. For more information, see "Configuring BFD."
2. Create a track entry associated with a BFD session and enter its view.
track track-entry-number bfd { echo interface interface-type interface-number remote { ip remote-ip-address | ipv6 remote-ipv6-address } local { ip local-ip-address | ipv6 local-ipv6-address } | static bfd-session-name }
Associating Track with CFD
The associated Track and CFD operate as follows:
· If the CFD detects that the link fails, it informs the Track module of the link failure. The Track module then sets the track entry to Negative state.
· If the CFD detects that the link is operating correctly, the Track module sets the track entry to Positive state.
For more information about CFD, see "Configuring CFD."
Before you associate Track with CFD, enable CFD and create a MEP. For more information, see "Configuring CFD."
2. Create a track entry associated with CFD and enter its view.
track track-entry-number cfd cc service-instance instance-id mep mep-id
The interface management module monitors the link status or network-layer protocol status of interfaces. The associated Track and interface management operate as follows:
· When the link or network-layer protocol status of the interface changes to up, the interface management module informs the Track module of the change. The Track module sets the track entry to Positive state.
· When the link or network-layer protocol status of the interface changes to down, the interface management module informs the Track module of the change. The Track module sets the track entry to Negative state.
2. Create a track entry associated with an interface and enter its view. Choose the options to configure as needed:
¡ Create a track entry associated with the link status of an interface.
track track-entry-number interface interface-type interface-number
¡ Create a track entry associated with the physical status of an interface.
track track-entry-number interface interface-type interface-number physical
¡ Create a track entry associated with the network layer protocol status of an interface.
track track-entry-number interface interface-type interface-number protocol { ipv4 | ipv6 }
The route management module monitors route entry changes in the routing table. The associated Track and route management operate as follows:
· When a monitored route entry is found in the routing table, the route management module informs the Track module. The Track module sets the track entry to Positive state.
· When a monitored route entry is removed from the routing table, the route management module informs the Track module of the change. The Track module sets the track entry to Negative state.
2. Create a track entry associated with an IP route and enter its view.
track track-entry-number ip route [ vpn-instance vpn-instance-name ] ip-address { mask-length | mask } reachability
Associating Track with VRRP
You can associate a track entry with a VRRP group on a device interface. The Track-VRRP association operates as follows:
· When the device becomes the master device in the VRRP group, the Track module sets the track entry to Positive state.
· When the device transitions to Backup or Initialize state, the Track module sets the track entry to Negative state.
· When the monitored device transitions to Inactive state or if the VRRP group does not exist, the Track module sets the track entry to NotReady state.
2. Create a track entry associated with a VRRP group on an interface and enter track entry view.
IPv4:
track track-entry-number vrrp interface interface-type interface-number vrid virtual-router-id
IPv6:
track track-entry-number vrrp ipv6 interface interface-type interface-number vrid virtual-router-id
A Boolean list is a list of tracked objects based on a Boolean logic. It can be further divided into the following types:
· Boolean AND list—A Boolean AND list is set to the Positive state only when all objects are in Positive state. If one or more objects are in Negative state, the tracked list is set to the Negative state.
· Boolean OR list—A Boolean OR list is set to the Positive state if any object is in Positive state. If all objects are in Negative state, the tracked list is set to the Negative state.
2. Create a track entry.
See "Associating Track with a detection module object."
Create a track entry before you add it as a tracked object to a tracked list.
A minimum of one track entry must be created.
3. Create a Boolean tracked list and enter its view.
track track-entry-number list boolean { and | or }
4. Add the track entry as an object to the tracked list.
object track-entry-id [ not ]
By default, a tracked list does not contain any objects.
Repeat this step to add all interested objects to the tracked list.
5. (Optional.) Set the delay for notifying the application module of tracked list state changes.
By default, the Track module notifies the application module immediately when the tracked list state changes.
A percentage threshold list uses a percentage threshold to measure the state of the list.
· If the percentage of positive objects is equal to or above the positive state threshold, the list is set to the Positive state.
· If the percentage of positive objects is equal to or below the negative state threshold, the list is set to the Negative state.
· The state of a percentage threshold list remains unchanged if the percentage of positive objects is below the positive state threshold and above the negative state threshold.
3. Create a percentage threshold list and enter its view.
track track-entry-number list threshold percentage
5. Configure the threshold values used to determine the state of the percentage threshold list.
threshold percentage { negative negative-threshold | positive positive-threshold } *
By default, the negative state threshold is 0% and the positive state threshold is 1%.
6. (Optional.) Set the delay for notifying the application module of tracked list state changes.
A weight threshold list uses a weight threshold to measure the state of the list.
· If the total weight of positive objects is equal to or above the positive state threshold, the list is set to the Positive state.
· If the total weight of positive objects is equal to or below the negative state threshold, the list is set to the Negative state.
· The state of a weight threshold list remains unchanged if the total weight of positive objects is below the positive state threshold and above the negative state threshold.
3. Create a weight threshold list and enter its view.
track track-entry-number list threshold weight
By default, no tracked lists exist.
object track-entry-number [ weight ]
5. Configure the threshold values used to determine the state of the weight threshold list.
threshold weight { negative negative-threshold | positive positive-threshold } *
By default, the negative state threshold is 0 and the positive state threshold is 1.
Create a track entry first before you associate it with an application module.
An application module might obtain incorrect track entry status information if the associated track entry does not exist.
When VRRP is operating in standard mode or load balancing mode, associate the Track module with the VRRP group to implement the following actions:
· Change the priority of a router according to the status of the uplink. If a fault occurs on the uplink of the router, the VRRP group is not aware of the uplink failure. If the router is the master, hosts in the LAN cannot access the external network. To resolve this problem, configure a detection module-Track-VRRP collaboration. The detection module monitors the status of the uplink of the router and notifies the Track module of the detection result.
When the uplink fails, the detection module notifies the Track module to change the status of the monitored track entry to Negative. The priority of the master decreases by a user-specified value. A router with a higher priority in the VRRP group becomes the master.
· Monitor the master on a backup. If a fault occurs on the master, the backup operating in switchover mode will switch to the master immediately to maintain normal communication.
When VRRP is operating in load balancing mode, associate the Track module with the VRRP VF to implement the following functions:
· Change the priority of the AVF according to its uplink state. When the uplink of the AVF fails, the track entry changes to Negative state. The weight of the AVF decreases by a user-specified value. The VF with a higher priority becomes the new AVF to forward packets.
· Monitor the AVF status from the LVF. When the AVF fails, the LVF that is operating in switchover mode becomes the new AVF to ensure continuous forwarding.
For more information about configuring VRRP, see "Configuring VRRP."
Restrictions and guidelines for Track association with VRRP
· VRRP tracking does not take effect on an IP address owner. The configuration takes effect when the router does not act as the IP address owner.
An IP address owner is the router with its interface IP address used as the virtual IP address of the VRRP group.
· When the status of the track entry changes from Negative to Positive or NotReady, the associated router or VF restores its priority automatically.
Associating Track with a VRRP group
2. Enter interface view.
3. Associate a track entry with a VRRP group.
vrrp [ ipv6 ] vrid virtual-router-id track track-entry-number { forwarder-switchover member-ip ip-address | priority reduced [ priority-reduced ] switchover | weight reduced [ weight-reduced ] }
By default, no track entry is associated with a VRRP group.
This command is supported when VRRP is operating in both standard mode and load balancing mode.
Associating Track with a VRRP VF
3. Associate Track with a VRRP VF.
By default, no track entry is associated with a VRRP VF.
This command is configurable when VRRP is operating in standard mode or load balancing mode. However, the configuration takes effect only when VRRP is operating in load balancing mode.
Associating Track with VSRP
VSRP determines the availability of the TCP control channel based on the TCP connection state. You can associate the Track module with VSRP to detect the availability of the control channel.
The device does the following based on the state of the track entry:
· When the track entry is in Positive or NotReady state, the device attempts to establish a TCP connection to the peer.
· When the track entry is in Negative state, the device terminates the TCP connection.
For more information about VSRP, see "Configuring VSRP."
2. Create a VSRP peer and enter VSRP peer view.
vsrp peer peer-name
3. Associate VSRP with a track entry.
By default, no track entry is associated with VSRP.
On a network where a VRRP group is used as the default gateway, upstream traffic is always forwarded through the master device in the VRRP group. The corresponding downstream traffic might take a different path because the route selection is determined by the configured dynamic routing protocol. The mismatching forwarding paths might cause the traffic to be blocked by firewalls (if configured), and increase the complexity and overhead for traffic monitoring and statistics collection operations.
You can resolve the issue by configuring direct route-Track-VRRP collaboration. The collaboration ensures that the upstream traffic and the corresponding downstream traffic are forwarded through matching paths (both through the master device in the VRRP group).
To configure direct route-Track-VRRP collaboration, perform the following tasks on each member device of the VRRP group:
1. Create a track entry associated with the VRRP group member device so the track entry state changes according to the status of the device in the VRRP group.
2. Associate the track entry with the direct route on the interface connected to the downstream device. The cost of the direct route changes to a user-defined value when the track entry is in Negative state.
3. Enable direct route redistribution for the dynamic routing protocol on the device.
For more information about direct routes, see basic IP routing configuration in Layer 3—IP Routing Configuration Guide.
2. Enter Layer 3 interface view.
3. Associate a track entry with the direct route on the interface and change the cost of the route to a user-defined value when the track entry is in Negative state.
route-direct track track-entry-number degrade-cost cost-value
By default, no track entry is associated with the direct route on a device interface.
A static route is a manually configured route to route packets. For more information about static route configuration, see Layer 3—IP Routing Configuration Guide.
Static routes cannot adapt to network topology changes. Link failures or network topological changes can make the routes unreachable and cause communication interruption.
To resolve this problem, configure another route to back up the static route. When the static route is reachable, packets are forwarded through the static route. When the static route is unreachable, packets are forwarded through the backup route.
To check the accessibility of a static route in real time, associate the Track module with the static route.
If you specify the next hop but not the output interface when configuring a static route, you can configure the static routing-Track-detection module collaboration. This collaboration enables you to verify the accessibility of the static route based on the track entry state.
· If the track entry is in Positive state, the following conditions exist:
¡ The next hop of the static route is reachable.
¡ The configured static route is valid.
· If the track entry is in Negative state, the following conditions exist:
¡ The next hop of the static route is not reachable.
¡ The configured static route is invalid.
· If the track entry is in NotReady state, the following conditions exist:
¡ The accessibility of the next hop of the static route is unknown.
¡ The static route is valid.
· In static routing-Track-NQA collaboration, you must configure the same VPN instance name for the NQA operation and the next hop of the static route. Otherwise, the accessibility detection cannot operate correctly.
· If a static route needs route recursion, the associated track entry must monitor the next hop of the recursive route. The next hop of the static route cannot be monitored. Otherwise, a valid route might be considered invalid.
2. Associate a static route with a track entry to check the accessibility of the next hop.
Public network:
ip route-static dest-address { mask-length | mask } { interface-type interface-number [ next-hop-address ] | next-hop-address | vpn-instance d-vpn-instance-name next-hop-address } [ permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ description text ]
VPN:
ip route-static vpn-instance s-vpn-instance-name dest-address { mask-length | mask } { interface-type interface-number [ next-hop-address ] | next-hop-address [ public ] | vpn-instance d-vpn-instance-name next-hop-address } [ permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ description text ]
By default, Track is not associated with static routing.
Associating Track with PBR
PBR uses user-defined policies to route packets. You can specify parameters in a PBR policy to guide the forwarding of the packets that match specific criteria. For more information about PBR, see Layer 3—IP Routing Configuration Guide.
PBR cannot detect the availability of any action taken on packets. When an action is not available, packets processed by the action might be discarded. For example, if the output interface specified for PBR fails, PBR cannot detect the failure, and continues to forward matching packets out of the interface.
To enable PBR to detect topology changes and improve the flexibility of the PBR application, configure Track-PBR-detection module collaboration.
After you associate a track entry with an apply clause, the detection module associated with the track entry sends Track the detection result of the availability of the tracked object.
· The Positive state of the track entry indicates that the object is available, and the apply clause is valid.
· The Negative state of the track entry indicates that the object is not available, and the apply clause is invalid.
· The NotReady state of the track entry indicates that the apply clause is valid.
The following objects can be associated with a track entry:
· Output interface.
· Next hop.
· Default next hop.
Prerequisites for Track association with PBR
Before you associate Track with PBR, create a policy or a policy node, and configure the match criteria.
2. Create a policy or policy node and enter PBR policy node view.
3. Define a match criterion.
¡ Define an ACL match criterion.
4. Associate Track with PBR.
¡ Set the output interface, and associate it with a track entry.
apply output-interface { interface-type interface-number [ track track-entry-number ] }&<1-n>
By default, no output interface is set.
¡ Set the next hop, and associate it with a track entry.
apply next-hop [ vpn-instance vpn-instance-name ] { ip-address [ direct ] [ track track-entry-number ] }&<1-n>
By default, no next hop is set.
¡ Set the default next hop, and associate it with a track entry.
apply default-next-hop [ vpn-instance vpn-instance-name ] { ip-address [ direct ] [ track track-entry-number ] }&<1-n>
By default, no default next hop is set.
Associating Track with IPv6 PBR
4. Associate Track with IPv6 PBR.
apply next-hop [ vpn-instance vpn-instance-name ] { ipv6-address [ direct ] [ track track-entry-number ] }&<1-n>
apply default-next-hop [ vpn-instance vpn-instance-name ] { ipv6-address [ direct ] [ track track-entry-number ] }&<1-n>
Traffic redirection redirects the packets matching specific criteria to a certain location, such as to an interface, a CPU, or a next hop. When the location (for example, next hop) is not reachable, packets redirected to it are lost. To check the accessibility of the next hop in real time, associate Track with traffic redirection. For more information about traffic redirection, see ACL and QoS Configuration Guide.
¡ The next hop is reachable.
¡ Traffic redirection redirects packets to the next hop.
¡ The next hop is not reachable.
¡ Traffic redirection does not redirect packets.
The packets are forwarded based on the routing table lookup result.
¡ The accessibility of the next hop is unknown.
¡ Traffic redirection redirects packets to the next hop of the unknown state.
2. Create a behavior and enter behavior view.
3. Associate Track with traffic redirection.
redirect next-hop { ipv4-add [ track track-entry-number ] [ ipv4-add [ track track-entry-number ] ] | ipv6-add [ interface-type interface-number ] [ track track-entry-number ] [ ipv6-add [ interface-type interface-number ] [ track track-entry-number ] ] }
By default, no track entry is associated with traffic redirection.
Associating Track with VPLS
When you associate Track with an AC on a VPLS network, the AC is up only when one or more of the associated track entries are positive.
Associating Track with an AC helps detect AC failures. For example, when an AC is a VE-L2VPN interface, the AC interface will not go down upon a link failure because the interface is a virtual interface. To resolve the problem, you can associate Track with the AC to detect failures on the link that connects the PE-agg to the L3VPN or IP backbone. When a failure occurs on the link, the VE-L2VPN interface is set to down. Consequently, the PW bound to the AC goes down. If the PW has a backup PW, traffic can be switched to the backup PW. For more information about VE-L2VPN interfaces and L2VPN access to L3VPN or IP backbone, see MPLS Configuration Guide.
An AC can be one of the following types:
· Layer 3 interface.
· Ethernet service instance on a Layer 2 Ethernet interface or Layer 2 aggregate interface.
Associating a Layer 3 interface with a track entry
3. Bind the interface to a VSI and associate it with a track entry.
xconnect vsi vsi-name track track-entry-number&<1-3>
By default, a Layer 3 interface is not bound to any VSI or associated with any track entries.
Associating an Ethernet service instance with a track entry
2. Enter Layer 2 Ethernet interface view or Layer 2 aggregate interface view.
3. Create an Ethernet service instance and enter Ethernet service instance view.
4. Bind the Ethernet service instance to a VSI and associate it with a track entry.
xconnect vsi vsi-name [ access-mode { ethernet | vlan } ] track track-entry-number&<1-3>
By default, an Ethernet service instance is not bound to any VSI or associated with any track entries.
When you associate Track with an AC on a VXLAN network, the AC is up only when one or more of the associated track entries are positive.
The AC can be one of the following types.
3. Create an Ethernet service instance and enter its view.
When you bind an AC to a cross-connect on an MPLS L2VPN network, you can associate Track with the AC. Then, the AC is up only when one or more of the associated track entries are positive.
Associating a track entry with a Layer 3 interface bound to a non-BGP cross-connect
2. Enter cross-connect group view.
xconnect-group group-name
3. Enter cross-connect view.
connection connection-name
4. Bind the Layer 3 interface to the non-BGP cross-connect and associate the interface with a track entry.
ac interface interface-type interface-number track track-entry-number&<1-3>
By default, a Layer 3 interface is not bound to any cross-connect or associated with any track entries.
Associating a track entry with a Layer 3 interface bound to a BGP cross-connect
3. Enter auto-discovery cross-connect group view.
auto-discovery bgp
4. Enter site view.
site site-id [ range range-value ] [ default-offset default-offset-value ]
5. Enter auto-discovery cross-connect view.
connection remote-site-id remote-site-id
6. Bind the Layer 3 interface to the BGP cross-connect and associate the interface with a track entry.
Associating a track entry with an Ethernet service instance bound to a non-BGP cross-connect
4. Bind the Ethernet service instance on the interface to the non-BGP cross-connect and associate the service instance with a track entry.
ac interface interface-type interface-number service-instance instance-id [ access-mode { ethernet | vlan } ] track track-entry-number&<1-3>
By default, an Ethernet service instance is not bound to any cross-connect or associated with any track entries.
Associating a track entry with an Ethernet service instance bound to a BGP cross-connect
auto-discovery bgp
4. Enter site view.
6. Bind the Ethernet service instance on the interface to the BGP cross-connect and associate the service instance with a track entry.
Associating Track with EAA
You can configure EAA track event monitor policies to monitor the positive-to-negative or negative-to-positive state changes of track entries.
· If you specify only one track entry for a policy, EAA triggers the policy when it detects the specified state change on the track entry.
· If you specify multiple track entries for a policy, EAA triggers the policy when it detects the specified state change on the last monitored track entry. For example, if you configure a policy to monitor the positive-to-negative state change of multiple track entries, EAA triggers the policy when the last positive track entry monitored by the policy is changed to the Negative state.
You can set a suppression time for a track event monitor policy. The timer starts when the policy is triggered. The system does not process messages that report the monitored track event until the timer times out.
For more information about EAA, see Network Management and Monitoring Configuration Guide.
2. Create a CLI-defined monitor policy and enter its view, or enter the view of an existing CLI-defined monitor policy.
rtm cli-policy policy-name
3. Configure a track event.
event track track-entry-number-list state { negative | positive } [ suppress-time suppress-time ]
By default, a monitor policy does not monitor any track event.
Task |
Command |
Display information about track entries. |
display track { track-entry-number | all [ negative | positive ] } [ brief ] |
Track configuration examples
As shown in Figure 2:
· Host A requires access to Host B. The default gateway of Host A is 10.1.1.10/24.
· Router A and Router B belong to VRRP group 1. The virtual IP address of VRRP group 1 is 10.1.1.10.
Configure VRRP-Track-NQA collaboration to monitor the uplink on the master and meet the following requirements:
· When Router A operates correctly, it forwards packets from Host A to Host B.
· When NQA detects a fault on the uplink of Router A, Router B forwards packets from Host A to Host B.
1. Configure the IP address of each interface, as shown in Figure 2. (Details not shown.)
2. Configure an NQA operation on Router A:
# Create an NQA operation with administrator name admin and operation tag test.
[RouterA] nqa entry admin test
# Specify the ICMP echo operation type.
[RouterA-nqa-admin-test] type icmp-echo
# Specify 10.1.2.2 as the destination address of ICMP echo requests.
[RouterA-nqa-admin-test-icmp-echo] destination ip 10.1.2.2
# Configure the ICMP echo operation to repeat every 100 milliseconds.
[RouterA-nqa-admin-test-icmp-echo] frequency 100
# Create reaction entry 1, specifying that five consecutive probe failures trigger the Track module.
[RouterA-nqa-admin-test-icmp-echo] reaction 1 checked-element probe-fail threshold-type consecutive 5 action-type trigger-only
[RouterA-nqa-admin-test-icmp-echo] quit
# Start the NQA operation.
[RouterA] nqa schedule admin test start-time now lifetime forever
3. On Router A, configure track entry 1, and associate it with reaction entry 1 of the NQA operation.
[RouterA] track 1 nqa entry admin test reaction 1
4. Configure VRRP on Router A:
# Specify VRRPv2 to run on Ten-GigabitEthernet 3/0/1.
[RouterA] interface ten-gigabitethernet 3/0/1
[RouterA-Ten-GigabitEthernet3/0/1] vrrp version 2
# Create VRRP group 1, and configure virtual IP address 10.1.1.10 for the group.
[RouterA-Ten-GigabitEthernet3/0/1] vrrp vrid 1 virtual-ip 10.1.1.10
# Set the priority of Router A to 110 in VRRP group 1.
[RouterA-Ten-GigabitEthernet3/0/1] vrrp vrid 1 priority 110
# Set the authentication mode of VRRP group 1 to simple, and the authentication key to hello.
[RouterA-Ten-GigabitEthernet3/0/1] vrrp vrid 1 authentication-mode simple plain hello
# Configure the master to send VRRP packets every 500 centiseconds.
[RouterA-Ten-GigabitEthernet3/0/1] vrrp vrid 1 timer advertise 500
# Configure Router A to operate in preemptive mode and set the preemption delay to 5000 centiseconds.
[RouterA-Ten-GigabitEthernet3/0/1] vrrp vrid 1 preempt-mode delay 5000
# Associate VRRP group 1 with track entry 1 and decrease the router priority by 30 when the state of track entry 1 changes to negative.
[RouterA-Ten-GigabitEthernet3/0/1] vrrp vrid 1 track 1 priority reduced 30
5. Configure VRRP on Router B:
<RouterB> system-view
[RouterB] interface ten-gigabitethernet 3/0/1
[RouterB-Ten-GigabitEthernet3/0/1] vrrp version 2
[RouterB-Ten-GigabitEthernet3/0/1] vrrp vrid 1 virtual-ip 10.1.1.10
[RouterB-Ten-GigabitEthernet3/0/1] vrrp vrid 1 authentication-mode simple plain hello
[RouterB-Ten-GigabitEthernet3/0/1] vrrp vrid 1 timer advertise 500
# Configure Router B to operate in preemptive mode and set the preemption delay to 5000 centiseconds.
[RouterB-Ten-GigabitEthernet3/0/1] vrrp vrid 1 preempt-mode delay 5000
# Ping Host B from Host A to verify that Host B is reachable. (Details not shown.)
# Display detailed information about VRRP group 1 on Router A.
[RouterA-Ten-GigabitEthernet3/0/1] display vrrp verbose
IPv4 virtual router information:
Running mode : Standard
Interface Ten-GigabitEthernet3/0/1
VRID : 1 Adver timer : 500 centiseconds
Admin status : Up State : Master
Config pri : 110 Running pri : 110
Preempt mode : Yes Delay time : 5000 centiseconds
Auth type : Simple Key : ******
Virtual IP : 10.1.1.10
Virtual MAC : 0000-5e00-0101
Master IP : 10.1.1.1
Backup ARP : Disabled
VRRP track information:
Track object : 1 State : Positive Pri reduced : 30
# Display detailed information about VRRP group 1 on Router B.
[RouterB-Ten-GigabitEthernet3/0/1] display vrrp verbose
Admin status : Up State : Backup
Config pri : 100 Running pri : 100
Become master : 2200 milliseconds left
The output shows that in VRRP group 1, Router A is the master and Router B is a backup. Router A forwards packets from Host A to Host B.
# Disconnect the link between Router A and Router C, and verify that Host A can still ping Host B. (Details not shown.)
Config pri : 110 Running pri : 80
Become Master : 2200 milliseconds left
Master IP : 10.1.1.2
Track object : 1 State : Negative Pri reduced : 30
# Display detailed information about VRRP group 1 on Router B when a fault is on the link between Router A and Router C.
The output shows that Router A becomes the backup, and Router B becomes the master. Router B forwards packets from Host A to Host B.
As shown in Figure 3:
· Router A and Router B belong to VRRP group 1. The virtual IP address of VRRP group 1 is 192.168.0.10.
· The default gateway of the hosts in the LAN is 192.168.0.10.
Configure VRRP-Track-BFD collaboration to monitor the master on the backup and meet the following requirements:
· When Router A operates correctly, the hosts in the LAN access the Internet through Router A.
· When Router A fails, the backup (Router B) can detect the state change of the master through BFD and become the new master. The hosts in the LAN access the Internet through Router B.
1. Configure Router A:
# Create VRRP group 1, and configure virtual IP address 192.168.0.10 for the group.
[RouterA-Ten-GigabitEthernet3/0/1] vrrp vrid 1 virtual-ip 192.168.0.10
[RouterA-Ten-GigabitEthernet3/0/1] return
2. Configure Router B:
# Specify 10.10.10.10 as the source address of BFD echo packets.
[RouterB] bfd echo-source-ip 10.10.10.10
# Create track entry 1, and associate it with the BFD session to verify the reachability of Router A.
[RouterB] track 1 bfd echo interface ten-gigabitethernet 3/0/1 remote ip 192.168.0.101 local ip 192.168.0.102
[RouterB-Ten-GigabitEthernet3/0/1] vrrp vrid 1 virtual-ip 192.168.0.10
# Configure VRRP group 1 to monitor the status of track entry 1.
[RouterB-Ten-GigabitEthernet3/0/1] vrrp vrid 1 track 1 switchover
[RouterB-Ten-GigabitEthernet3/0/1] return
<RouterA> display vrrp verbose
VRID : 1 Adver timer : 100 centiseconds
Preempt mode : Yes Delay time : 0 centiseconds
Auth type : None
Virtual IP : 192.168.0.10
Master IP : 192.168.0.101
<RouterB> display vrrp verbose
Auth type : None
Track object : 1 State : Positive Switchover
# Display information about track entry 1 on Router B.
<RouterB> display track 1
Track ID: 1
State: Positive
Tracked object type: BFD
Notification delay: Positive 0, Negative 0 (in seconds)
Tracked object:
BFD session mode: Echo
Outgoing Interface: Ten-GigabitEthernet3/0/1
VPN instance name: --
Remote IP: 192.168.0.101
Local IP: 192.168.0.102
The output shows that when the status of the track entry becomes Positive, Router A is the master, and Router B the backup.
# Enable VRRP state debugging and BFD event notification debugging on Router B.
<RouterB> terminal debugging
<RouterB> terminal monitor
<RouterB> debugging vrrp fsm
<RouterB> debugging bfd ntfy
# When Router A fails, the following output is displayed on Router B.
*Dec 17 14:44:34:142 2019 RouterB BFD/7/DEBUG: Notify application:TRACK State:DOWN
*Dec 17 14:44:34:144 2019 RouterB VRRP4/7/FSM
IPv4 Ten-GigabitEthernet3/0/1 | Virtual Router 1 : Backup --> Master reason: The status of the tracked object changed
# Display detailed information about the VRRP group on Router B.
Auth type : None
Master IP : 192.168.0.102
Track object : 1 State : Negative Switchover
The output shows that when BFD detects that Router A fails, the Track module notifies VRRP to change the status of Router B to master. The backup can quickly preempt as the master without waiting for a period three times the advertisement interval plus the Skew_Time.
As shown in Figure 4:
Configure VRRP-Track-BFD collaboration to monitor the uplink on the master and meet the following requirements:
· When Router A operates correctly, hosts in the LAN access the Internet through Router A.
· When Router A detects that the uplink is down through BFD, Router B can preempt as the master. The hosts in the LAN can access the Internet through Router B.
[RouterA] bfd echo-source-ip 10.10.10.10
# Create track entry 1 for the BFD session on Router A to verify the reachability of the uplink device (1.1.1.2).
[RouterA] track 1 bfd echo interface ten-gigabitethernet 3/0/1 remote ip 1.1.1.2 local ip 1.1.1.1
# Create VRRP group 1, and specify 192.168.0.10 as the virtual IP address of the group.
[RouterA] interface ten-gigabitethernet 3/0/2
[RouterA-Ten-GigabitEthernet3/0/2] vrrp vrid 1 virtual-ip 192.168.0.10
[RouterA-Ten-GigabitEthernet3/0/2] vrrp vrid 1 priority 110
# Associate VRRP group 1 with track entry 1 and decrease the router priority by 20 when the state of track entry 1 changes to negative.
[RouterA-Ten-GigabitEthernet3/0/2] vrrp vrid 1 track 1 priority reduced 20
[RouterA-Ten-GigabitEthernet3/0/2] return
2. On Router B, create VRRP group 1, and specify 192.168.0.10 as the virtual IP address of the group.
[RouterB] interface ten-gigabitethernet 3/0/2
[RouterB-Ten-GigabitEthernet3/0/2] vrrp vrid 1 virtual-ip 192.168.0.10
[RouterB-Ten-GigabitEthernet3/0/2] return
# Display detailed information about the VRRP group on Router A.
Interface Ten-GigabitEthernet3/0/2
Auth type : None
Track object : 1 State : Positive Pri reduced : 20
# Display information about track entry 1 on Router A.
<RouterA> display track 1
Track ID: 1
State: Positive
Tracked object:
Outgoing interface: Ten-GigabitEthernet3/0/1
Remote IP: 1.1.1.2
Local IP: 1.1.1.1
Auth type : None
The output shows that when the status of track entry 1 becomes Positive, Router A is the master and Router B the backup.
# Display information about track entry 1 when the uplink of Router A goes down.
Track ID: 1
State: Negative
Tracked object:
Remote IP: 1.1.1.2
Local IP: 1.1.1.1
Config pri : 110 Running pri : 90
Auth type : None
Track object : 1 State : Negative Pri reduced : 20
Auth type : None
The output shows that when Router A detects that the uplink fails through BFD, it decreases its priority by 20. Router B then preempts as the master.
As shown in Figure 5:
· Router A is the default gateway of the hosts in network 20.1.1.0/24.
· Router D is the default gateway of the hosts in network 30.1.1.0/24.
· Hosts in the two networks communicate with each other through static routes.
To ensure network availability, configure route backup and static routing-Track-NQA collaboration on Router A and Router D as follows:
· On Router A, assign a higher priority to the static route to 30.1.1.0/24 with next hop Router B. This route is the master route. The static route to 30.1.1.0/24 with the next hop Router C acts as the backup route. When the master route is unavailable, the backup route takes effect.
· On Router D, assign a higher priority to the static route to 20.1.1.0/24 with next hop Router B. This route is the master route. The static route to 20.1.1.0/24 with next hop Router C acts as the backup route. When the master route is unavailable, the backup route takes effect.
1. Configure the IP address of each interface, as shown in Figure 5. (Details not shown.)
2. Configure Router A:
# Configure a static route to 30.1.1.0/24 with next hop 10.1.1.2 and the default priority (60). Associate this static route with track entry 1.
[RouterA] ip route-static 30.1.1.0 24 10.1.1.2 track 1
# Configure a static route to 30.1.1.0/24 with next hop 10.3.1.3 and priority 80.
[RouterA] ip route-static 30.1.1.0 24 10.3.1.3 preference 80
# Configure a static route to 10.2.1.4 with next hop 10.1.1.2.
[RouterA] ip route-static 10.2.1.4 24 10.1.1.2
# Specify 10.2.1.4 as the destination address of the operation.
[RouterA-nqa-admin-test-icmp-echo] destination ip 10.2.1.4
# Specify 10.1.1.2 as the next hop of the operation.
[RouterA-nqa-admin-test-icmp-echo] next-hop ip 10.1.1.2
# Configure reaction entry 1, specifying that five consecutive probe failures trigger the Track module.
# Configure track entry 1, and associate it with reaction entry 1 of the NQA operation.
3. Configure Router B:
# Configure a static route to 30.1.1.0/24 with next hop 10.2.1.4.
[RouterB] ip route-static 30.1.1.0 24 10.2.1.4
# Configure a static route to 20.1.1.0/24 with next hop 10.1.1.1.
[RouterB] ip route-static 20.1.1.0 24 10.1.1.1
4. Configure Router C:
# Configure a static route to 30.1.1.0/24 with next hop 10.4.1.4.
<RouterC> system-view
[RouterC] ip route-static 30.1.1.0 24 10.4.1.4
# Configure a static route to 20.1.1.0/24 with next hop 10.3.1.1.
[RouterC] ip route-static 20.1.1.0 24 10.3.1.1
5. Configure Router D:
# Configure a static route to 20.1.1.0/24 with next hop 10.2.1.2 and the default priority (60). Associate this static route with track entry 1.
<RouterD> system-view
[RouterD] ip route-static 20.1.1.0 24 10.2.1.2 track 1
# Configure a static route to 20.1.1.0/24 with next hop 10.4.1.3 and default priority 80.
[RouterD] ip route-static 20.1.1.0 24 10.4.1.3 preference 80
# Configure a static route to 10.1.1.1 with next hop 10.2.1.2.
[RouterD] ip route-static 10.1.1.1 24 10.2.1.2
[RouterD] nqa entry admin test
[RouterD-nqa-admin-test] type icmp-echo
# Specify 10.1.1.1 as the destination address of the operation.
[RouterD-nqa-admin-test-icmp-echo] destination ip 10.1.1.1
# Specify 10.2.1.2 as the next hop of the operation.
[RouterD-nqa-admin-test-icmp-echo] next-hop ip 10.2.1.2
[RouterD-nqa-admin-test-icmp-echo] frequency 100
[RouterD-nqa-admin-test-icmp-echo] reaction 1 checked-element probe-fail threshold-type consecutive 5 action-type trigger-only
[RouterD-nqa-admin-test-icmp-echo] quit
[RouterD] nqa schedule admin test start-time now lifetime forever
[RouterD] track 1 nqa entry admin test reaction 1
# Display information about the track entry on Router A.
[RouterA] display track all
Track ID: 1
State: Positive
Tracked object:
NQA entry: admin test
Reaction: 1
Remote IP/URL: 10.2.1.4
Local IP:--
Interface:--
The output shows that the status of the track entry is Positive, indicating that the NQA operation has succeeded and the master route is available.
# Display the routing table of Router A.
Destinations : 10 Routes : 10
10.1.1.0/24 Direct 0 0 10.1.1.1 XGE3/0/1
10.1.1.1/32 Direct 0 0 127.0.0.1 InLoop0
10.2.1.0/24 Static 60 0 10.1.1.2 XGE3/0/1
10.3.1.0/24 Direct 0 0 10.3.1.1 XGE3/0/2
10.3.1.1/32 Direct 0 0 127.0.0.1 InLoop0
20.1.1.0/24 Direct 0 0 20.1.1.1 XGE3/0/3
20.1.1.1/32 Direct 0 0 127.0.0.1 InLoop0
30.1.1.0/24 Static 60 0 10.1.1.2 XGE3/0/1
The output shows that Router A forwards packets to 30.1.1.0/24 through Router B.
# Remove the IP address of Ten-GigabitEthernet 3/0/1 on Router B.
[RouterB-Ten-GigabitEthernet3/0/1] undo ip address
Track ID: 1
State: Negative
Tracked object:
Reaction: 1
Local IP:--
Interface:--
The output shows that the status of the track entry is Negative, indicating that the NQA operation has failed and the master route is unavailable.
30.1.1.0/24 Static 80 0 10.3.1.3 XGE3/0/2
The output shows that Router A forwards packets to 30.1.1.0/24 through Router C. The backup static route has taken effect.
# Verify that hosts in 20.1.1.0/24 can communicate with the hosts in 30.1.1.0/24 when the master route fails.
[RouterA] ping -a 20.1.1.1 30.1.1.1
Ping 30.1.1.1: 56 data bytes, press CTRL_C to break
Reply from 30.1.1.1: bytes=56 Sequence=1 ttl=254 time=2 ms
Reply from 30.1.1.1: bytes=56 Sequence=2 ttl=254 time=1 ms
Reply from 30.1.1.1: bytes=56 Sequence=3 ttl=254 time=1 ms
Reply from 30.1.1.1: bytes=56 Sequence=4 ttl=254 time=2 ms
Reply from 30.1.1.1: bytes=56 Sequence=5 ttl=254 time=1 ms
--- Ping statistics for 30.1.1.1 ---
5 packet(s) transmitted, 5 packet(s) received, 0.00% packet loss
round-trip min/avg/max/std-dev = 1/1/2/1 ms
# Verify that the hosts in 30.1.1.0/24 can communicate with the hosts in 20.1.1.0/24 when the master route fails.
[RouterD] ping -a 30.1.1.1 20.1.1.1
Ping 20.1.1.1: 56 data bytes, press CTRL_C to break
Reply from 20.1.1.1: bytes=56 Sequence=1 ttl=254 time=2 ms
Reply from 20.1.1.1: bytes=56 Sequence=2 ttl=254 time=1 ms
Reply from 20.1.1.1: bytes=56 Sequence=3 ttl=254 time=1 ms
Reply from 20.1.1.1: bytes=56 Sequence=4 ttl=254 time=1 ms
Reply from 20.1.1.1: bytes=56 Sequence=5 ttl=254 time=1 ms
--- Ping statistics for 20.1.1.1 ---
As shown in Figure 6:
· Router B is the default gateway of the hosts in network 30.1.1.0/24.
To ensure network availability, configure route backup and static routing-Track-BFD collaboration on Router A and Router B as follows:
· On Router A, assign a higher priority to the static route to 30.1.1.0/24 with next hop Router B. This route is the master route. The static route to 30.1.1.0/24 with next hop Router C acts as the backup route. When the master route is unavailable, BFD can quickly detect the route failure to make the backup route take effect.
· On Router B, assign a higher priority to the static route to 20.1.1.0/24 with next hop Router A. This route is the master route. The static route to 20.1.1.0/24 with next hop Router C acts as the backup route. When the master route is unavailable, BFD can quickly detect the route failure to make the backup route take effect.
1. Configure the IP address of each interface, as shown in Figure 6. (Details not shown.)
# Configure a static route to 30.1.1.0/24 with next hop 10.2.1.2 and the default priority (60). Associate this static route with track entry 1.
[RouterA] ip route-static 30.1.1.0 24 10.2.1.2 track 1
# Configure track entry 1, and associate it with the BFD session to verify the connectivity between Router A and Router B.
[RouterA] track 1 bfd echo interface ten-gigabitethernet 3/0/1 remote ip 10.2.1.2 local ip 10.2.1.1
# Configure a static route to 20.1.1.0/24 with next hop 10.2.1.1 and default priority (60). Associate this static route with track entry 1.
[RouterB] ip route-static 20.1.1.0 24 10.2.1.1 track 1
# Configure a static route to 20.1.1.0/24 with next hop 10.4.1.3 and the priority 80.
[RouterB] ip route-static 20.1.1.0 24 10.4.1.3 preference 80
# Specify 1.1.1.1 as the source address of BFD echo packets.
[RouterB] bfd echo-source-ip 1.1.1.1
# Configure track entry 1, and associate it with the BFD session to verify the connectivity between Router B and Router A.
[RouterB] track 1 bfd echo interface ten-gigabitethernet 3/0/1 remote ip 10.2.1.1 local ip 10.2.1.2
# Configure a static route to 30.1.1.0/24 with next hop 10.4.1.2.
[RouterC] ip route-static 30.1.1.0 24 10.4.1.2
[RouterB] ip route-static 20.1.1.0 24 10.3.1.1
Track ID: 1
State: Positive
Tracked object:
Remote IP: 10.2.1.2
Local IP: 10.2.1.1
The output shows that the status of the track entry is Positive, indicating that next hop 10.2.1.2 is reachable.
Destinations : 9 Routes : 9
10.2.1.0/24 Direct 0 0 10.2.1.1 XGE3/0/1
10.2.1.1/32 Direct 0 0 127.0.0.1 InLoop0
30.1.1.0/24 Static 60 0 10.2.1.2 XGE3/0/1
The output shows that Router A forwards packets to 30.1.1.0/24 through Router B. The master static route has taken effect.
Track ID: 1
State: Negative
Tracked object:
Remote IP: 10.2.1.2
Local IP: 10.2.1.1
The output shows that the status of the track entry is Negative, indicating that next hop 10.2.1.2 is unreachable.
# Verify that the hosts in 20.1.1.0/24 can communicate with the hosts in 30.1.1.0/24 when the master route fails.
[RouterB] ping -a 30.1.1.1 20.1.1.1
As shown in Figure 7:
Configure VRRP-Track-interface management collaboration to monitor the uplink interface on the master and meet the following requirements:
· When Router A operates correctly, Router A forwards packets from Host A to Host B.
· When VRRP detects a fault on the uplink interface of Router A through the interface management module, Router B forwards packets from Host A to Host B.
1. Configure the IP address of each interface, as shown in Figure 7. (Details not shown.)
# Configure track entry 1, and associate it with the link status of the uplink interface Ten-GigabitEthernet 3/0/2.
[RouterA] track 1 interface ten-gigabitethernet 3/0/2
3. On Router B, create VRRP group 1, and configure virtual IP address 10.1.1.10 for the group.
Auth type : None
Auth type : None
# Shut down the uplink interface Ten-GigabitEthernet 3/0/2 on Router A.
[RouterA-Ten-GigabitEthernet3/0/1] interface ten-gigabitethernet 3/0/2
[RouterA-Ten-GigabitEthernet3/0/2] shutdown
[RouterA-Ten-GigabitEthernet3/0/2] display vrrp verbose
Auth type : None
Auth type : None
As shown in Figure 8:
· BGP peer relationships are established between Router A and Router C and between Router B and Router D. Router C and Router D advertise the default route 0.0.0.0/0 to Router A and Router B.
Configure VRRP-Track-route management collaboration to meet the following requirements:
· When VRRP detects the removal of the default route from the routing table of Router A through route management, Router B forwards packets from Host A to Host B.
1. Configure the IP address of each interface, as shown in Figure 8. (Details not shown.)
2. Establish an IBGP peer relationship between Router A and Router C, and configure Router C to advertise the default route 0.0.0.0/0 to Router A.
[RouterA] bgp 100
[RouterA-bgp-default] peer 10.1.2.2 as-number 100
[RouterA-bgp-default] address-family ipv4
[RouterA-bgp-default-ipv4] peer 10.1.2.2 enable
[RouterC] bgp 100
[RouterC-bgp-default] peer 10.1.2.1 as-number 100
[RouterC-bgp-default] address-family ipv4
[RouterC-bgp-default-ipv4] peer 10.1.2.1 enable
[RouterC-bgp-default-ipv4] peer 10.1.2.1 default-route-advertise
[RouterC-bgp-default-ipv4] quit
3. Configure Router B and Router D in the same way Router A and Router C are configured. (Details not shown.)
4. Configure Track and VRRP on Router A:
# Configure track entry 1, and associate it with the default route 0.0.0.0/0.
[RouterA] track 1 ip route 0.0.0.0 0.0.0.0 reachability
[RouterA-Ten-GigabitEthernet3/0/1] quit
5. On Router B, create VRRP group 1, and configure virtual IP address 10.1.1.10 for the group.
[RouterB-Ten-GigabitEthernet3/0/1] quit
[RouterA] display vrrp verbose
Auth type : None
[RouterB] display vrrp verbose
Auth type : None
# Disable Router C from exchanging routing information with Router A so that the default route 0.0.0.0/0 is removed from Router A.
[RouterC-bgp-default-ipv4] undo peer 10.1.2.1 enable
Auth type : None
Auth type : None
As shown in Figure 9:
· BGP peer relationships are established between Router A and Router C and between Router B and Router C. Router C can learn the direct routes to Router A and Router B.
Configure direct route-Track-IPv4 VRRP collaboration so that traffic from Host A to Host B and from Host B to Host A are forwarded through the same router (the master router in the VRRP group).
1. Configure the IP address of each interface, as shown in Figure 9. (Details not shown.)
# Create VRRP group 1 on Ten-GigabitEthernet 3/0/1 and set its virtual IP address to 10.1.1.10.
# Create track entry 1 and associate it with VRRP group 1.
[RouterA] track 1 vrrp interface ten-gigabitethernet 3/0/1 vrid 1
# On Ten-GigabitEthernet 3/0/1, associate the direct route with track entry 1 and apply the cost 200 to the direct route when the state of track entry 1 changes to Negative.
[RouterA-Ten-GigabitEthernet3/0/1] route-direct track 1 degrade-cost 200
# Specify Router C as the BGP peer and set the AS number to 100.
[RouterA] bgp 100
[RouterA-bgp-default] address-family ipv4 unicast
# Configure BGP to redistribute direct routes on Router A.
[RouterA-bgp-default-ipv4] import-route direct
[RouterA-bgp-default-ipv4] quit
[RouterA-bgp-default] quit
[RouterB] track 1 vrrp interface ten-gigabitethernet 3/0/1 vrid 1
[RouterB-Ten-GigabitEthernet3/0/1] route-direct track 1 degrade-cost 200
[RouterB] bgp 100
[RouterB-bgp-default] peer 10.1.3.2 as-number 100
[RouterB-bgp-default] address-family ipv4 unicast
[RouterB-bgp-default-ipv4] peer 10.1.3.2 enable
# Configure BGP to redistribute direct routes on Router B.
[RouterB-bgp-default-ipv4] import-route direct
[RouterB-bgp-default-ipv4] quit
[RouterB-bgp-default] quit
4. On Router C, specify Router A and Router B as BGP peers and set the AS number to 100.
[RouterC] bgp 100
[RouterC-bgp-default] peer 10.1.3.1 as-number 100
[RouterC-bgp-default] address-family ipv4 unicast
[RouterC-bgp-default-ipv4] peer 10.1.3.1 enable
[RouterC-bgp-default] quit
Auth type : None
Auth type : None
[RouterA] display track 1
Track ID: 1
State: Positive
Tracked object type: VRRP
Tracked object:
VRID: 1
[RouterB] display track 1
Track ID: 1
State: Negative
Tracked object:
VRID: 1
The output shows that:
· In VRRP group 1, Router A is the master and Router B is a backup.
· Track entry 1 on Router A is in Positive state and track entry 1 on Router B is in Negative state.
# Display the BGP routing table on Router C.
[RouterC] display bgp routing-table ipv4
Total number of routes: 6
BGP local router ID is 192.168.56.4
Status codes: * - valid, > - best, d - dampened, h - history
a - additional-path
* >i 10.1.1.0/24 10.1.2.1 0 100 0 ?
* i 10.1.3.1 200 100 0 ?
* >i 10.1.2.0/24 10.1.2.1 0 100 0 ?
* >i 10.1.3.0/24 10.1.3.1 0 100 0 ?
* >i 192.168.56.0 10.1.2.1 0 100 0 ?
* i 10.1.3.1 0 100 0 ?
· The cost is 0 for the route to network 10.1.1.0/24 with Router A (the master in the VRRP group) as the next hop.
· The cost is 200 for the route to network 10.1.1.0/24 with Router B (the backup in the VRRP group) as the next hop.
· Traffic from Host B to Host A is forwarded through Router A.
As shown in Figure 10:
· Host A requires access to Host B. The default gateway of Host A is 10::100/64.
· Router A and Router B belong to VRRP group 1. The virtual IP address of VRRP group 1 is 10::100.
Configure direct route-Track-IPv6 VRRP collaboration so that traffic from Host A to Host B and from Host B to Host A are forwarded through the same router (the master router in the VRRP group).
1. Configure the IPv6 address of each interface, as shown in Figure 10. (Details not shown.)
# Create VRRP group 1 on Ten-GigabitEthernet 3/0/1 and set its virtual IP address to 10::100.
[RouterA-Ten-GigabitEthernet3/0/1] vrrp ipv6 vrid 1 virtual-ip fe80::1 link-local
[RouterA-Ten-GigabitEthernet3/0/1] vrrp ipv6 vrid 1 virtual-ip 10::100
[RouterA-Ten-GigabitEthernet3/0/1] vrrp ipv6 vrid 1 priority 110
[RouterA] track 1 vrrp ipv6 interface ten-gigabitethernet 3/0/1 vrid 1
[RouterA-Ten-GigabitEthernet3/0/1] ipv6 route-direct track 1 degrade-cost 200
[RouterA] bgp 100
[RouterA-bgp-default] peer 20::2 as-number 100
[RouterA-bgp-default] address-family ipv6 unicast
[RouterA-bgp-default-ipv6] peer 20::2 enable
[RouterA-bgp-default-ipv6] import-route direct
[RouterA-bgp-default-ipv6] quit
[RouterB-Ten-GigabitEthernet3/0/1] vrrp ipv6 vrid 1 virtual-ip 10::100
[RouterB] track 1 ipv6 vrrp interface ten-gigabitethernet 3/0/1 vrid 1
[RouterB-Ten-GigabitEthernet3/0/1] ipv6 route-direct track 1 degrade-cost 200
[RouterB] bgp 100
[RouterB-bgp-default] peer 30::2 as-number 100
[RouterB-bgp-default] address-family ipv6 unicast
[RouterB-bgp-default-ipv6] peer 30::2 enable
[RouterB-bgp-default-ipv6] import-route direct
[RouterB-bgp-default-ipv6] quit
[RouterC] bgp 100
[RouterC-bgp-default] peer 20::1 as-number 100
[RouterC-bgp-default] peer 30::1 as-number 100
[RouterC-bgp-default] address-family ipv6 unicast
[RouterC-bgp-default-ipv6] peer 20::1 enable
[RouterC-bgp-default-ipv6] peer 30::1 enable
[RouterC-bgp-default-ipv6] quit
[RouterA] display vrrp ipv6 verbose
IPv6 virtual router information:
Auth type : None
Virtual IP : FE80::10
10::100
Master IP : FE80::1
[RouterB] display vrrp ipv6 verbose
Auth type : None
10::100
Master IP : FE80::1
Track ID: 1
State: Positive
Tracked object type: IPv6 VRRP
Tracked object:
VRID: 1
Track ID: 1
State: Negative
Tracked object:
VRID: 1
[RouterC] display bgp routing-table ipv6
Total number of routes: 9
a - additional-path
* >i Network : 10:: PrefixLen : 64
NextHop : 20::1 LocPrf : 100
PrefVal : 0 OutLabel : NULL
MED : 0
Path/Ogn: ?
* i Network : 10:: PrefixLen : 64
NextHop : 30::1 LocPrf : 100
MED : 200
Path/Ogn: ?
* > Network : 20:: PrefixLen : 64
NextHop : :: LocPrf :
MED : 0
Path/Ogn: ?
* i Network : 20:: PrefixLen : 64
MED : 0
Path/Ogn: ?
* > Network : 20::2 PrefixLen : 128
NextHop : ::1 LocPrf :
MED : 0
Path/Ogn: ?
* > Network : 30:: PrefixLen : 64
MED : 0
Path/Ogn: ?
* i Network : 30:: PrefixLen : 64
MED : 0
Path/Ogn: ?
* > Network : 30::2 PrefixLen : 128
MED : 0
Path/Ogn: ?
* >i Network : 40:: PrefixLen : 64
MED : 0
Path/Ogn: ?
· The cost is 0 for the route to network 10::/64 with Router A (the master in the VRRP group) as the next hop.
· The cost is 200 for the route to network 10::/64 with Router B (the backup in the VRRP group) as the next hop.
