- 10-Segment Routing Configuration Guide
- 01-SR-MPLS configuration
- 02-SR-MPLS TE policy configuration
- 03-SRv6 configuration
- 04-SRv6 TE policy configuration
- 05-SRv6 VPN overview
- 06-IP L3VPN over SRv6 configuration
- 07-EVPN L3VPN over SRv6 configuration
- 08-EVPN VPWS over SRv6 configuration
- 09-EVPN VPLS over SRv6 configuration
- 10-Public network IP over SRv6 configuration
- 11-SRv6 OAM configuration
- 12-SRv6 network slicing configuration
| 06-IP L3VPN over SRv6 configuration | 839.94 KB |
Configuring IP L3VPN over SRv6
Intercommunication between SRv6 and MPLS networks
Intercommunication between SRv6 and EVPN L3VPN networks
IP L3VPN over SRv6 tasks at a glance
Applying a locator to a BGP VPN instance
Configuring PEs to exchange BGP VPNv4 or VPNv6 routes
Configuring IPv6 peers to exchange SRv6 SIDs
Configuring next hop-based dynamic End.DX4 or End.DX6 SID allocation for BGP private network routes
Configuring BGP VPNv4 or VPNv6 routes
Restrictions and guidelines for BGP VPNv4 or VPNv6 route configuration
Controlling BGP VPNv4 or VPNv6 route advertisement and reception
Setting a preferred value for received BGP VPNv4 or VPNv6 routes
Configuring BGP VPNv4 or VPNv6 route reflection
Configuring BGP VPNv4 or VPNv6 route attributes
Configuring BGP VPNv4 or VPNv6 route distribution filtering policies
Configuring the BGP Additional Paths feature
Configuring BGP to preferentially use the routes learned from a peer or peer group
Configuring the route recursion mode
Specifying a source address for the outer IPv6 header of SRv6-encapsulated packets
Enabling SRv6 VPN compatibility for a peer or peer group
Configuring optimal route reorigination and advertisement
Modifying BGP VPNv4 or VPNv6 routes
Configuring inter-AS option B VPN
Enabling intercommunication between SRv6 and EVPN L3VPN networks
Configuring IP L3VPN over SRv6 FRR
Configuring a TTL processing mode for tunnels associated with a VPN instance
Display and maintenance commands for IP L3VPN over SRv6
Displaying and maintaining the running status of IP L3VPN over SRv6 VPN
IP L3VPN over SRv6 configuration examples
Example: Configuring IP L3VPN over SRv6 BE
Example: Configuring IPv4 L3VPN HoVPN over MPLS-to-SRv6
Example: Configuring inter-AS option B VPN
Example: Configuring IPv4 L3VPN over G-SRv6 (with COC32 locators)
Example: Configuring IPv4 L3VPN over G-SRv6 (with COC-both locators)
About IP L3VPN over SRv6
IP L3VPN over SRv6 uses SRv6 tunnels to carry IP L3VPN services. This technology establishes SRv6 tunnels among geographically dispersed customer sites over an IPv6 network and transparently forwards Layer 3 customer traffic to remote sites over the IPv6 network through the tunnels. For more information about MPLS L3VPN configuration, see MPLS Configuration Guide.
Basic principle
Figure 1 shows a typical IP L3VPN over SRv6 network.
· PE 1 and PE 2 use BGP to advertise IPv4 or IPv6 VPN routes to each other over the IPv6 backbone network. The VPN routes contain private network routing information and SID information.
· The PEs have a single-hop SRv6 tunnel between them and they use the SRv6 tunnel to forward VPN traffic across sites.
· The devices in the IPv6 backbone network forward the SRv6-encapsulated VPN traffic through the optimal path calculated by IGP.
IP L3VPN over SRv6 connects geographically dispersed sites that belong to the same VPN over the IPv6 backbone network.
If the customer sites belong to the public network, IP L3VPN over SRv6 takes the public network as a special VPN. The PEs establish a single-hop SRv6 tunnel between them and use the SRv6 tunnel to forward public network traffic across sites. This scenario is also called the public network over SRv6 scenario.
Route advertisement
The route advertisement process of IPv4 L3VPN over SRv6 is similar to that of IPv6 L3VPN over SRv6. This section uses IPv4 L3VPN over SRv6 to illustrate the process.
As shown in Figure 1, local routes of CE 1 are advertised to CE 2 by using the following process:
1. CE 1 uses static routing, RIP, OSPF, IS-IS, EBGP, or IBGP to advertise routes of the local site to PE 1.
2. After learning the route information of CE 1, PE 1 stores the private routes to the routing table of the VPN instance. In this example, VPN instance 1 is used. Then, PE 1 converts the routes to BGP VPNv4 routes and advertises the BGP VPNv4 routes to PE 2 by using MP-BGP. The BGP VPNv4 routes carry the RD, RT, and SID attributes (the SID attribute is used as the private network label).
¡ If next hop-based dynamic SID allocation is not used, all private network routes of the VPN instance are allocated the same End.DT4 or End.DT46 SID.
¡ If next hop-based dynamic SID allocation is used, private network routes with the same next hop are allocated the same End.DX4 SID in the VPN instance.
3. When PE 2 receives the routes advertised by PE 1, it adds the routes to the routing table of VPN 1, converts the routes to IPv4 routes, and advertises the IPv4 routes to CE 2.
4. By adding the received IPv4 routes to the routing table, CE 2 learns the private network routes of CE 1.
Packet forwarding
IP L3VPN over SRv6 supports the following route recursion modes:
· SRv6 BE mode.
· SRv6 TE mode.
· SRv6 TE and SRv6 BE hybrid mode.
· SRv6 TE and SRv6 BE FRR mode.
· SRv6 TE and SRv6 BE multilevel FRR modes.
The packet forwarding process differs by the route recursion mode in use.
SRv6 BE mode
This mode is also called SID-based forwarding mode. In this mode, a PE forwards an SRv6 packet by searching the IPv6 routing table based on the SRv6 SID encapsulated in the packet.
The packet forwarding process is similar for IPv4 L3VPN over SRv6 and IPv6 L3VPN over SRv6. This section uses IPv4 L3VPN over SRv6 and VPN sites to illustrate the process.
As shown in Figure 1, CE 2 forwards an IPv4 packet to CE 1 as follows:
1. CE 2 sends the IPv4 packet to PE 2.
2. PE 2 receives the packet on an interface associated with the VPN instance (in this example, the VPN instance is VPN 1). PE 2 searches for a route that matches the destination IPv4 address of the packet in the routing table of the VPN instance. The corresponding End.DT4, End.DT46, or End.DX4 SID is found. Then, PE 2 encapsulates an outer IPv6 header for the packet. The End.DT4, End.DT46, or End.DX4 SID is encapsulated in the outer IPv6 header as the destination address.
3. PE 2 searches the IPv6 routing table based on the End.DT4, End.DT46, or End.DX4 SID for the optimal IGP route and forwards the packet to P through the route.
4. P searches the IPv6 routing table based on the End.DT4, End.DT46, or End.DX4 SID for the optimal IGP route and forwards the packet to PE 1 through the route.
5. When PE 1 receives the packet, it processes the packet as follows:
¡ If the packet header contains an End.DT4 or End.DT46 SID, PE 1 searches the local SID forwarding table for the SID and removes the outer IPv6 header. Then, PE 1 matches the packet to VPN 1 based on the SID, searches the routing table of VPN 1 for the optimal route, and forwards the packet to CE 1.
¡ If the packet header contains an End.DX4 SID, PE 1 searches the local SID forwarding table for the SID and removes the outer IPv6 header. Then, PE 1 forwards the packet to CE 1 according to the next hop and output interface bound to the SID.
SRv6 TE mode
This mode is also called SRv6 TE policy-based forwarding mode. In this mode, when a PE forwards a customer packet, it first searches for a matching SRv6 TE policy based on the packet attributes. Then, the PE adds an SRH to the packet. The SRH includes the destination SRv6 SID and the SID list of the SRv6 TE policy. Finally, the PE forwards the encapsulated packet based on the SRv6 TE policy.
The following modes are available to steer traffic to an SRv6 TE policy:
· Color—The device searches for an SRv6 TE policy that has the same color and endpoint address as the color and nexthop address of a VPN route. If a matching SRv6 TE policy exists, the device recurses the VPN route to that SRv6 TE policy. When the device receives packets that match the VPN route, it forwards the packets through the SRv6 TE policy.
· Tunnel policy—The device searches the tunnel policies for a matching SRv6 TE policy based on the next hop of a matching route. Configure a preferred tunnel or load sharing tunnel policy that uses the SRv6 TE policy. In this way, the SRv6 TE policy will be used as the public tunnel to forward the packets of private network packets.
For more information about tunnel policies, see MPLS Configuration Guide. For more information about SRv6 TE policies, see "Configuring SRv6 TE policies."
In this mode, the PE preferentially uses the SRv6 TE mode to forward a packet. If no SRv6 TE policy is available for the packet, the PE performs IPv6 routing table lookup based on the encapsulated SRv6 SID, and forwards the packet in SRv6 BE mode.
This mode implements FRR by using the SRv6 TE path (primary path) and SRv6 BE path (backup path). If the SRv6 TE path fails or does not exist, traffic is immediately switched to the SRv6 BE path to ensure service continuity.
If the private network routes at one site must pass through both SRv6 and MPLS networks to reach another site, ensure that the SRv6 and MPLS networks can communicate with each other. For this purpose, use the following solutions:
· HoVPN.
· Inter-AS option B VPN.
HoVPN
Hierarchy of VPN (HoVPN), also called Hierarchy of PE (HoPE), prevents PEs from being bottlenecks and is applicable to large-scale VPN deployment.
HoVPN divides PEs into underlayer PEs (UPEs) or user-end PEs, middle-level PEs (MPEs), and superstratum PEs (SPEs) or service provider-end PEs. UPEs, MPEs, and SPEs have different functions and comprise a hierarchical PE. The HoPE and common PEs can coexist in a network.
UPEs, MPEs, and SPEs play the following different roles:
· A UPE is directly connected to CEs. It provides user access.
· An MPE is connected to UPEs and SPEs. It manages route information advertised by UPEs.
· An SPE resides inside the service provider network. It manages and advertises VPN routes.
As shown in Figure 2, in an HoVPN network, the UPE, MPE, and SPE are connected through MPLS and SRv6 networks. L3VPN data is transmitted over the backbone network in the following scenarios:
· L3VPN over MPLS-to-SRv6.
· L3VPN over SRv6-to-MPLS.
Figure 2 Basic architecture of HoVPN
As shown in Figure 2, the MPE connects the MPLS network and SRv6 network. Configure the MPE to reoriginate routes and advertise the optimal routes.
· When the MPE receives VPNv4 or VPNv6 routes from the MPLS L3VPN network, it compares the export targets of the routes with the local import targets of the VPN instance. If they match, the MPE modifies the RD and route target attributes in the routes, assigns them SRv6 SIDs, and associate the SRv6 SID and private label of each route. Then, the MPE advertises the reoriginated routes to the SRv6 network. The supported SRv6 SIDs include End.DT4, End.DT6, End.DT46, End.DX4, and End.DX6 SIDs.
· When the MPE receives VPNv4 or VPNv6 routes from the SRv6 network, it compares the export targets of the routes with the local import targets of the VPN instance. If they match, the MPE modifies the RD and route target attributes in the routes, assign them private labels, and associate the private label and SRv6 SID of each route. Then, the MPE advertises the reoriginated routes to the MPLS L3VPN network.
When the UPE and SPE learn the reoriginated optimal routes, they forward traffic according to the route information. For example, in the L3VPN over MPLS-to-SRv6 scenario, packets are forwarded as follows:
1. When the UPE receives a packet from CE 1, it encapsulates MPLS labels to the packet and forwards the packet to the MPE.
2. When the MPE receives the packet, it removes the private label from the packet and encapsulates an SRv6 SID to the packet according to the private label-SRv6 SID mapping. Then, the MPE forwards the packet to the SPE in SRv6 BE or SRv6 TE mode.
3. When the SPE receives the packet, it decapsulates the packet based on the SRv6 SID and forwards the packet to CE 2.
As shown in Figure 3, an MPLS network and an SRv6 network are in different ASs. For inter-AS communication, the devices must support SRv6 SID and MPLS label exchange.
Figure 3 Inter-AS option B VPN network diagram
End.T SID
The ASBR in the SRv6 network allocates End.T SIDs based on FECs and advertises the SIDs to other SRv6 nodes through an IGP. An FEC is a destination IP address/mask or destination IPv6 address/prefix length.
The function of an End.T SID is removing the outer IPv6 header and looking up the IPv6 FIB table based on the End.T SID to forward packets.
The ASBR in the SRv6 network encapsulates an End.T SID to the packets forwarded from the SRv6 network to the MPLS network.
Route advertisement
As shown in Figure 3, the route of CE 1 is advertised to CE 2 in the following process:
1. After PE 1 learns the private network route of CE 1, it assigns MPLS label L1 to the private network route. Then, PE 1 advertises the route to ASBR 1 through MP-IBGP.
2. ASBR 1 receives the VPNv4 route from PE 1 and reoriginates the route. ASBR 1 changes the next hop address of the route to its address, assign MPLS label L2 to the route, and maps MPLS label L2 and MPLS label L1. Then, the ASBR advertises the VPNv4 route to ASBR 2 through MP-EBGP.
3. ASBR 2 receives the VPNv4 route from ASBR 1 and reoriginates the route. ASBR 2 changes the next hop address of the route to its address, allocates an End.T SID to the route, and maps the End.T SID and MPLS label L2. Then, the ASBR advertises the route to PE 2 through MP-IBGP.
4. PE 2 advertises the route to CE 2.
As shown in Figure 3, the route of CE 2 is advertised to CE 1 in the following process:
1. After PE 2 learns the private network route of CE 2, it assigns an SRv6 SID to the private network route. Then, PE 2 advertises the route to ASBR 2 through MP-IBGP. The supported SRv6 SIDs include End.DT4, End.DT6, End.DT46, End.DX4, and End.DX6 SIDs.
2. ASBR 2 receives the VPNv4 route from PE 2 and reoriginates the route. ASBR 2 changes the next hop address of the route to its address, assign MPLS label L2 to the route, and maps MPLS label L2 and the SRv6 SID. Then, the ASBR advertises the VPNv4 route to ASBR 1 through MP-EBGP.
3. ASBR 1 receives the VPNv4 route from ASBR 2 and reoriginates the route. ASBR 1 changes the next hop address of the route to its address, allocates MPLS label L1 to the route, and maps MPLS label 1 and MPLS label L2. Then, the ASBR advertises the route to PE 1 through MP-IBGP.
4. PE 1 advertises the route to CE 1.
In the inter-AS option B VPN scenario, the ASBRs need to receive all inter-AS VPN routes. On the ASBRs, do not filter received VPNv4 routes based on route targets.
Traffic forwarding
As shown in Figure 3, packets are forwarded from CE 2 to CE 1 in the following process:
1. When PE 2 receives a packet from CE 2, it encapsulates an End.T SID to the packet and forwards the packet to ASBR 2.
2. When ASBR 2 receives the packet, it removes the outer IPv6 header and looks up the IPv6 FIB table based on the End.T SID. ASBR 2 finds that the out label is L2. Then, the ASBR reencapsulates MPLS label 2 to the packet and forwards the packet to ASBR 1. The packet includes only one layer of MPLS label.
3. ASBR 1 replaces MPLS label L2 with MPLS label L1 and adds the public label that identifies the public tunnel from ASBR 1 to PE 1 to the packet. Then, ASBR 1 forwards the packet to PE 1.
4. PE 1 removes the public and private labels from the packet and forwards the packet to CE 1.
Packets are forwarded from CE 1 to CE 2 in the following process:
1. When PE 1 receives a packet from CE 1, it encapsulates two layers of MPLS labels to the packet and forwards the packet to ASBR 1. The private label is L1 and the public label identifies the public tunnel from PE 1 to ASBR 1.
2. When ASBR 1 receives the packet, it removes the public label from the packet and replaces private label L1 with private label L2. Then, ASBR 1 forwards the packet to ASBR 2. The packet includes only one layer of MPLS label.
3. ASBR 2 replaces private label L2 with an SRv6 SID and forwards the packet to PE 2 according to the SRv6 SID.
4. PE 2 executes the function of the SRv6 SID and forwards the packet to CE 2.
As shown in Figure 4, EVPN L3VPN is deployed at the sites connected by an IP L3VPN over SRv6 network. To ensure connectivity between the sites over the IP L3VPN over SRv6 network, enable intercommunication between SRv6 and EVPN L3VPN networks on the ASBRs.
Figure 4 Network diagram for intercommunication between SRv6 and EVPN L3VPN networks
When intercommunication between SRv6 and EVPN L3VPN networks is enabled on an ASBR, the ASBR processes routes as follows:
· When the ASBR receives EVPN IP prefix advertisement routes from the EVPN L3VPN network, it matches the route targets with the local import route targets. If a matching VPN instance is found, the ASBR adds the routes to the routing table of the matching VPN instance. Then, the ASBR allocates an SRv6 SID to the routes and converts the routes to VPNv4 routes based on the VPN instance configuration. Finally, the ASBR advertises the VPNv4 routes that include an SRv6 SID to the IP L3VPN over SRv6 network.
· When the ASBR receives VPNv4 routes from the IP L3VPN over SRv6 network, it matches the route targets with the local import route targets. If a matching VPN instance is found, the ASBR adds the routes to the routing table of the matching VPN instance. Then, the ASBR allocates an MPLS label to the routes and converts the routes to EVPN IP prefix advertisement routes based on the VPN instance configuration. Finally, the ASBR advertises the EVPN IP prefix advertisement routes to the EVPN L3VPN network.
After route reorigination, you need to enable intercommunication between SRv6 and MPLS networks on the ASBR to associate SRv6 SIDs with MPLS labels.
Figure 5 Packet forwarding between SRv6 and EVPN L3VPN networks
After the PEs and ASBRs finish route learning, packets from Site 2 to Site 1 are forwarded as follows:
1. When PE 2 receives packets from Site 2, it adds a private network label to the packets and forwards the packets to ASBR 2.
2. ASBR 2 performs the following operations:
a. Identifies the VPN instance of the packets based on the private network label.
b. Looks up the routing table of the VPN instance for a matching route.
c. Adds an SRv6 SID to the packets.
d. Forwards the packets to ASBR 1 in SRv6 BE or SRv6 TE mode.
3. ASBR 1 performs the following operations:
a. Identifies the VPN instance of the packets based on the SRv6 SID.
b. Removes the SRv6 encapsulation.
c. Looks up the routing table of the VPN instance.
d. Adds a private network label to the packets.
e. Forwards the packets to PE 1.
4. When PE 1 receives the packets, it performs the following operations:
b. Identifies the output interface of the packets through a lookup in the routing table of the VPN instance.
c. Removes the private network label from the packets.
d. Forwards the packets to Site 1.
IMPORTANT: IP L3VPN over SRv6 FRR is supported only when the customer sites belong to VPNs. |
IP L3VPN over SRv6 Fast Reroute (FRR) is applicable to a dualhomed scenario, as shown in Figure 6. By using static BFD to detect the primary link, FRR enables a PE to use the backup link when the primary link fails. The PE then selects a new optimal route, and uses the new optimal route to forward traffic.
IP L3VPN over SRv6 supports VPNv4 route backup for a VPNv4 route and VPNv6 route backup for a VPNv6 route.
Figure 6 Network diagram of VPNv4 route backup for a VPNv4 route
IPv4 L3VPN over SRv6 and IPv6 L3VPN over SRv6 use the same FRR mechanism. This section uses VPNv4 route backup for a VPNv4 route as an example to illustrate the mechanism.
As shown in Figure 6, configure FRR on the ingress node PE 1, and specify the backup next hop for VPN 1 as PE 3. When PE 1 receives a VPNv4 route to CE 2 from both PE 2 and PE 3, it uses the route from PE 2 as the primary link, and the route from PE 3 as the backup link.
Configure static BFD for public tunnels on PE 1 to detect the connectivity of the public tunnel from PE 1 to PE 2. When the tunnel PE 1—PE 2 operates correctly, traffic from CE 1 to CE 2 goes through the path CE 1—PE 1—PE 2—CE 2. When the tunnel fails, the traffic goes through the path CE 1—PE 1—PE 3—CE 2.
In this scenario, PE 1 is responsible for primary link detection and traffic switchover.
For more information about static BFD, see BFD configuration in High Availability Configuration Guide.
To configure IP L3VPN over SRv6, perform the following tasks:
1. Configuring a VPN instance and associating interfaces connected to CEs with the VPN instance
Perform this task on PEs. For more information, see MPLS L3VPN in MPLS Configuration Guide.
2. Configuring route exchange between a PE and a CE
Configure an IPv4 routing protocol (static routing, RIP, OSPF, IS-IS, EBGP, or IBGP) or an IPv6 routing protocol (IPv6 static routing, RIPng, OSPFv3, IPv6 IS-IS, EBGP, or IBGP) to exchange routes between a PE and a CE
On the CE, configure an IPv4 or IPv6 routing protocol to advertise routes of the local site to the PE. On the PE, associate the routing protocol with the VPN instance. For more information about routing protocol configurations, see Layer 3—IP Routing Configuration Guide.
3. Configuring route exchange between PEs
Perform this task to manually configure an End.DT4, End.DT6, End.DT46, End.DX4, or End.DX6 SID.
b. Applying a locator to a BGP VPN instance
BGP can advertise SRv6 SIDs through BGP routes only after you apply a locator to BGP.
c. Configuring PEs to exchange BGP VPNv4 or VPNv6 routes
d. Configuring IPv6 peers to exchange SRv6 SIDs
This feature enables PEs to exchange End.DT4, End.DT6, End.DT46, End.DX4, or End.DX6 SIDs through BGP VPNv4 or VPNv6 routes.
e. (Optional.) Configuring next hop-based dynamic End.DX4 or End.DX6 SID allocation for BGP private network routes
This feature enables a PE to dynamically allocate End.DX4 or End.DX6 SIDs to BGP routes based on the route next hops.
f. (Optional.) Configuring BGP VPNv4 or VPNv6 routes
4. Configuring the route recursion mode
5. Specifying a source address for the outer IPv6 header of SRv6-encapsulated packets
This feature specifies the source address of the outer IPv6 header for SRv6 packets that are delivered between two sites over the backbone network.
6. (Optional.) Enabling SRv6 VPN compatibility for a peer or peer group
7. (Optional.) Configuring intercommunication for SRv6 and MPLS networks
¡ Configuring optimal route reorigination and advertisement
¡ Modifying BGP VPNv4 or VPNv6 routes
¡ Configuring inter-AS option B VPN
8. (Optional.) Enabling intercommunication between SRv6 and EVPN L3VPN networks
9. (Optional.) Configuring IP L3VPN over SRv6 FRR
10. (Optional.) Configuring a TTL processing mode for tunnels associated with a VPN instance
Configuring an SRv6 SID
If PEs advertise BGP VPNv4 or VPNv6 routes to each other, you must specify a VPN instance when configuring an opcode.
1. Enter system view.
2. Enable SRv6 and enter SRv6 view.
segment-routing ipv6
3. Configure a locator and enter SRv6 locator view.
locator locator-name [ ipv6-prefix ipv6-address prefix-length [ args args-length | static static-length ] * ]
4. Configure an opcode. Perform one of the following tasks:
¡ Configure an End.DT4 SID.
opcode { opcode | hex hex-opcode } end-dt4 [ vpn-instance vpn-instance-name ]
The specified VPN instance must exist. An End.DT4 SID cannot be configured in different VPN instances.
¡ Configure an End.DT6 SID.
opcode { opcode | hex hex-opcode } end-dt6 [ vpn-instance vpn-instance-name ]
The specified VPN instance must exist. An End.DT6 SID cannot be configured in different VPN instances.
¡ Configure an End.DT46 SID.
opcode { opcode | hex hex-opcode } end-dt46 [ vpn-instance vpn-instance-name ]
The specified VPN instance must exist. An End.DT46 SID cannot be configured in different VPN instances.
¡ Configure an End.DX4 SID.
opcode { opcode | hex hex-opcode } end-dx4 interface interface-type interface-number nexthop nexthop-ipv4-address [ vpn-instance vpn-instance-name ]
The specified VPN instance must exist. An End.DX4 SID cannot be configured with different output interfaces or next hops.
¡ Configure an End.DX6 SID.
opcode { opcode | hex hex-opcode } end-dx6 interface interface-type interface-number nexthop nexthop-ipv6-address [ vpn-instance vpn-instance-name ]
The specified VPN instance must exist. An End.DX6 SID cannot be configured with different output interfaces or next hops.
This feature is applicable to an IP L3VPN over SRv6 network with VPN sites. Use this feature in BGP-VPN IPv4 or IPv6 unicast address family view of a VPN instance to apply for SRv6 SIDs for the private network routes of the VPN instance.
Use this feature if the device will use End.DT4, End.DT6, End.DT46, End.DX4, or End.DX6 SIDs to deliver VPN traffic across sites.
The VPN instance of the specified locator must be the same as the VPN instance of the private network. To specify a VPN instance for a locator, use the opcode end-dt4, opcode end-dt6, opcode end-dt46, opcode end-dx4, or opcode end-dx6 command in SRv6 locator view.
Before you perform this task, you must create the specified locator.
2. Enter BGP instance view.
3. Enter BGP-VPN instance view.
4. Enter BGP-VPN IPv4 unicast address family view or BGP-VPN IPv6 unicast address family view.
¡ Enter BGP-VPN IPv4 unicast address family view.
¡ Enter BGP-VPN IPv6 unicast address family view.
5. Apply a locator to the BGP VPN instance.
segment-routing ipv6 locator locator-name [ auto-sid-disable ]
By default, no locator is applied to a BGP VPN instance.
For more information about the commands in this section, see BGP in Layer 3—IP Routing Command Reference.
To ensure optimal route selection and SRv6 tunnel traffic forwarding, make sure a pair of PEs are not both IPv4 and IPv6 peers to each other.
3. Specify a remote PE as an IPv6 peer.
peer { group-name | ipv6-address [ prefix-length ] } as-number as-number
4. Specify a source interface (IPv6 address) for establishing TCP connections to an IPv6 peer or peer group.
By default, BGP uses the output interface in the optimal route destined for a BGP peer or peer group as the source interface for establishing TCP connections.
5. Create the BGP VPNv4 or VPNv6 address family and enter its view.
¡ Create the BGP VPNv4 address family and enter its view.
address-family vpnv4
¡ Create the BGP VPNv6 address family and enter its view.
address-family vpnv6
6. Enable BGP to exchange VPNv4 or VPNv6 routing information with an IPv6 peer or peer group.
peer { group-name | ipv6-address [ prefix-length ] } enable
By default, BGP cannot exchange VPNv4 or VPNv6 routing information with an IPv6 peer or peer group.
Perform this task to configure IPv6 peers to exchange SRv6 SID information through BGP VPNv4, VPNv6, IPv4 unicast, or IPv6 unicast routes.
3. Enter BGP VPNv4 address family view or BGP VPNv6 address family view.
¡ Enter BGP VPNv4 address family view.
¡ Enter BGP VPNv6 address family view.
4. Enable BGP to exchange SRv6 SID information with an IPv6 peer or peer group.
peer { group-name | ipv6-address [ prefix-length ] } prefix-sid
By default, BGP cannot exchange SRv6 SID information with an IPv6 peer or peer group.
This task is applicable to an IP L3VPN over SRv6 network. Perform this task to forward an SRv6 decapsulated VPN packet to the next hop without looking up the routing table of the matching VPN instance.
By default, a PE allocates the same SID to all BGP private network routes in a VPN instance. When the PE removes the SRv6 encapsulation from a received packet, it looks up the routing table of the VPN instance based on the SID for an optimal route. Then, the PE forwards the packet to a CE. To forward the packet to the next hop without looking up the routing table, perform this task.
This task dynamically allocates End.DX4 or End.DX6 SIDs to specific next hops or all next hops of the BGP private network routes in a VPN instance based on the next hop addresses. When forwarding a packet, the PE searches for the output interface and next hop based on the End.DX4 or End.DX6 SID of the packet. Then, the PE directly forwards the packet out of the output interface to the next hop.
This feature does not allocate End.DX4 or End.DX6 SIDs to direct routes.
In BGP-VPN IPv4 or IPv6 unicast address family view, execute the segment-routing ipv6 locator command to apply a locator to the view. This ensures successful dynamic End.DX4 or End.DX6 SID allocation.
5. Configure next hop-based dynamic End.DX4 or End.DX6 SID allocation for BGP private network routes. Choose one of the following tasks:
¡ Automatically allocate an End.DX4 or End.DX6 SID to each next hop of BGP private network routes.
segment-routing ipv6 apply-sid all-nexthop
¡ Execute the following commands in sequence to automatically allocate an End.DX4 or End.DX6 SID to the specified next hop of BGP private network routes:
segment-routing ipv6 apply-sid specify-nexthop
nexthop nexthop-address interface interface-type interface-number
By default, VPN instance-based SID allocation is used for private network routes.
4. Set the maximum number of routes that BGP can receive from a peer or peer group.
peer { group-name | ipv6-address [ prefix-length ] } route-limit prefix-number [ { alert-only | discard | reconnect reconnect-time } | percentage-value ] *
By default, the number of routes that BGP can receive from a peer or peer group is not limited.
5. Save all route updates from a peer or peer group.
peer { group-name | ipv6-address [ prefix-length ] } keep-all-routes
By default, route updates from peers and peer groups are not saved.
4. Set a preferred value for routes received from a peer or peer group.
peer { group-name | ipv6-address [ prefix-length ] } preferred-value value
By default, the preferred value is 0 for routes received from a peer or peer group.
4. Configure the router as a route reflector (RR) and specify a peer or peer group as its client.
peer { group-name | ipv6-address [ prefix-length ] } reflect-client
By default, no RR or client is configured.
5. (Optional.) Enable route reflection between clients.
reflect between-clients
By default, route reflection between clients is enabled.
6. (Optional.) Configure the cluster ID of the RR.
By default, an RR uses its own router ID as the cluster ID.
7. (Optional.) Create an RR reflection policy.
rr-filter { ext-comm-list-number | ext-comm-list-name }
By default, an RR does not filter reflected routes.
8. (Optional.) Enable the RR to change the attributes of routes to be reflected.
reflect change-path-attribute
By default, the RR cannot change the attributes of routes to be reflected.
4. Configure the NEXT_HOP attribute. Choose one of the following options:
¡ Specify the router as the next hop for routes sent to a peer or peer group.
peer { group-name | ipv6-address [ prefix-length ] } next-hop-local
¡ Configure the router to not change the next hop of routes advertised to a peer or peer group.
peer { group-name | ipv6-address [ prefix-length ] } next-hop-invariable
By default, the router sets itself as the next hop for routes sent to a peer or peer group.
5. Configure the AS_PATH attribute.
¡ Permit the local AS number to appear in routes from a peer or peer group and set the appearance times.
peer { group-name | ipv6-address [ prefix-length ] } allow-as-loop [ number ]
By default, the local AS number is not allowed in routes from a peer or peer group.
¡ Remove private AS numbers from the AS_PATH attribute of updates sent to an EBGP peer or peer group.
peer { group-name | ipv6-address [ prefix-length ] } public-as-only [ { force | limited } [ replace ] [ include-peer-as ] ]
By default, BGP updates sent to an EBGP peer or peer group can carry both public and private AS numbers.
For more information about the parameters in this command, see BGP in Layer 3—IP Routing Command Reference.
6. Advertise the COMMUNITY attribute to a peer or peer group.
peer { group-name | ipv6-address [ prefix-length ] } advertise-community
By default, the COMMUNITY attribute is not advertised.
7. Advertise the Large community attribute to a peer or peer group.
peer { group-name | ipv6-address [ prefix-length ] } advertise-large-community
By default, the Large community attribute is not advertised to a peer or peer group.
8. Configure the SoO attribute for a peer or peer group.
peer { group-name | ipv6-address [ prefix-length ] } soo site-of-origin
By default, no SoO attribute is configured for a peer or peer group.
4. Specify an ACL or IP prefix list to filter advertised BGP routes.
filter-policy { ipv4-acl-number | name ipv4-acl-name | prefix-list prefix-list-name } export [ protocol process-id ]
By default, no ACL or IP prefix list is specified to filter advertised BGP routes.
5. Specify an ACL or IP prefix list to filter received BGP routes.
filter-policy { ipv4-acl-number | name ipv4-acl-name | prefix-list prefix-list-name } import
By default, no ACL or IP prefix list is specified to filter received BGP routes.
6. Specify an IP prefix list to filter BGP routes for a peer or peer group.
peer { group-name | ipv6-address [ prefix-length ] } prefix-list prefix-list-name { export | import }
By default, no IP prefix list is specified to filter BGP routes for a peer or peer group.
7. Apply a routing policy to routes received from or advertised to a peer or peer group.
peer { group-name | ipv6-address [ prefix-length ] } route-policy route-policy-name { export | import }
By default, no routing policy is applied to routes received from or advertised to a peer or peer group.
8. Enable route target filtering of received VPNv4 or VPNv6 routes.
policy vpn-target
By default, the route target filtering feature is enabled for received VPNv4 or VPNv6 routes. BGP adds an VPNv4 or VPNv6 route to the routing table only when the export route targets of the route match the local import route targets.
4. Configure the BGP Additional Paths capabilities.
peer { group-name | ipv6-address [ prefix-length ] } additional-paths { receive | send } *
By default, no BGP Additional Paths capabilities are configured.
5. Set the maximum number of Add-Path optimal routes that can be advertised to a peer or peer group.
peer { group-name | ipv6-address [ prefix-length ] } advertise additional-paths best number
By default, only one Add-Path optimal route can be advertised to a peer or peer group.
6. (Optional.) Set the optimal route selection delay timer.
By default, the optimal route selection delay timer is 0 seconds, which indicates that optimal route selection is not delayed.
Perform this task to enable BGP to prefer the routes learned from a specific peer or peer group to the routes learned from other peers or peer groups. This route selection rule has lower priority than the rule that selects the route learned from EBGP, confederation EBGP, confederation IBGP, or IBGP in turn. In addition, this route selection rule has higher priority than the rule that selects the route with the smallest IGP metric.
For more information about BGP route selection rules, see BGP in Layer 3—IP Routing Configuration Guide.
This feature takes effect only on BGP routes learned in the address family view where this feature is configured. It cannot take effect on BGP routes imported from other instances or address families.
4. Configure BGP to preferentially use the routes learned from a peer or peer group.
peer { group-name | ipv6-address [ prefix-length ] } high-priority
By default, BGP does not preferentially use the routes learned from a peer or peer group.
After a PE receives a customer packet destined for an SRv6 SID, it forwards the packet according to the route recursion mode.
· SRv6 BE mode—This mode is also called SID-based forwarding mode. In this mode, the PE first encapsulates the End.DT4, End.DT6, or End.DT46 SID into the packet. Then, the PE searches the IPv6 routing table based on the SID encapsulated in the packet to forward the packet.
· SRv6 TE mode—This mode is also called SRv6 TE policy-based forwarding mode. In this mode, the PE first searches for a matching SRv6 TE policy based on the packet attributes. Then, the PE adds an SRH to the packet. The SRH includes the End.DT4, End.DT6, or End.DT46 SID and the SID list of the SRv6 TE policy. Finally, the PE forwards the encapsulated packet through the SRv6 TE policy. For more information, see "Configuring SRv6 TE policies."
· SRv6 TE and SRv6 BE hybrid mode—In this mode, the PE preferentially uses the SRv6 TE mode to forward the packet. If no SRv6 TE policy is available for the packet, the PE forwards the packet in SRv6 BE mode.
· SRv6 TE and SRv6 BE FRR mode—This mode implements FRR by using the SRv6 TE path (primary path) and SRv6 BE path (backup path). If the SRv6 TE path fails or does not exist, traffic is immediately switched to the SRv6 BE path to ensure service continuity.
5. Configure the route recursion mode.
segment-routing ipv6 { best-effort | traffic-engineering | traffic-engineering best-effort | traffic-engineering best-effort-backup }
By default, a PE searches the IPv6 routing table based on the next hop of a matching route to forward traffic.
To ensure correct traffic forwarding in an IP L3VPN over SRv6 network with VPN or public network sites, you must specify a source address for the outer IPv6 header of SRv6-encapsulated packets.
You cannot specify a loopback address, link-local address, multicast address, or unspecified address as the source IPv6 address. You must specify an IPv6 address of the local device as the source IPv6 address, and make sure the IPv6 address has been advertised by a routing protocol. As a best practice, specify a loopback interface address of the local device as the source IPv6 address.
2. Enter SRv6 view.
3. Specify a source address for the outer IPv6 header of SRv6-encapsulated packets.
encapsulation source-address ipv6-address [ ip-ttl ttl-value ]
By default, no source address is specified for the outer IPv6 header of SRv6-encapsulated packets.
In an IP L3VPN over SRv6 network, PE devices from different vendors might use different formats to encrypt SRv6 SIDs in the VPNv4 or VPNv6 routes. As a result, the PE devices might fail to identify the received VPNv4 or VPNv6 routes, causing route advertisement failure. To resolve this issue, you can perform this task to change the SRv6 SID encryption format for BGP routes sent by H3C devices for interoperability with devices from other vendors.
4. Enable SRv6 VPN compatibility for a peer or peer group.
peer { group-name | ipv6-address [ prefix-length ] } srv6-vpn compatible [ srv6-sid-transposition ]
By default, SRv6 VPN compatibility is disabled for a peer or peer group. The device encapsulates SRv6 SIDs for sent BGP routes in the non-Transposition-Scheme format as defined in draft-ietf-bess-srv6-services-07.
Configure this feature on an MPE that connects the MPLS L3VPN and MPLS L3VPN over SRv6 networks.This feature enables the MPE to reoriginate the optimal BGP VPNv4 or VPNv6 routes for intercommunication between the MPLS and SRv6 networks.
With this feature, the MPE performs the following operations after receiving BGP VPNv4 or VPNv6 routes:
1. Matches the route targets of the routes with the import route targets of local VPN instances.
2. Reoriginates the optimal routes in the matching VPN instance. The optimal routes include the private network label or an SRv6 SID.
3. Advertises the reoriginated routes to VPNv4 or VPNv6 peers.
The reoriginated routes include the RD of the VPN instance. In addition, the route targets of the VPN instance are added to the routes based on the original routes.
Configure all settings in this section on an MPE.
5. Configure the device to reoriginate the optimal routes in the VPN instance and advertise the reoriginated routes to VPNv4 or VPNv6 peers.
advertise route-reoriginate [ route-policy route-policy-name ] [ replace-rt ]
By default, the device does not reoriginate the optimal routes in a VPN instance. The original VPNv4 or VPNv6 routes are advertised to VPNv4 or VPNv6 peers.
For more information about this command, see MPLS L3VPN commands in MPLS Command Reference.
Configure this feature on an MPE that connects the MPLS L3VPN and IP L3VPN over SRv6 networks.This feature enables the MPE to modify BGP VPNv4 or VPNv6 route information for intercommunication between the MPLS and SRv6 networks.
After you configure this feature on an MPE, the MPE performs the following operations after receiving BGP VPNv4 or VPNv6 routes from the MPLS L3VPN network:
2. Replaces the RD and route targets of the routes with those of the matching local VPN instance. In addition, the MPE adds an SRv6 SID to the routes and maps the SRv6 SID of the routes to the private label of the routes.
3. Advertises the reoriginated routes to the SRv6 network.
After you configure this feature on an MPE, the MPE performs the following operations after receiving BGP VPNv4 or VPNv6 routes from the SRv6 network:
2. Replaces the RD and route targets of the routes with those of the matching local VPN instance. In addition, the MPE adds an MPLS label to the routes and maps the private label of the routes to the SRv6 SID of the routes.
3. Advertises the reoriginated routes to the MPLS L3VPN network.
All settings in this section are configured on an MPE.
In addition to the settings in this section, you also need to configure other settings on the UPEs, MPE, and SPE depending on the network type. If the network type is MPLS, configure basic MPLS L3VPN settings. If the network type is SRv6, configure basic MPLS L3VPN over SRv6 settings.
4. Enable the device to reoriginate BGP VPNv4 or VPNv6 routes based on the BGP VPNv4 or VPNv6 routes received from a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } re-originated [ replace-rt ]
By default, the device does not reoriginate BGP VPNv4 or VPNv6 routes based on received BGP VPNv4 or VPNv6 routes.
5. (Optional.) Enable the device to advertise original BGP VPNv4 or VPNv6 routes to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise original-route
By default, the device advertises only reoriginated BGP VPNv4 or VPNv6 routes to peers and peer groups after the peer re-originated command is executed.
6. (Optional.) Suppress advertisement of reoriginated BGP VPNv4 or VPNv6 routes to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } suppress re-originated
By default, the device advertises reoriginated BGP VPNv4 or VPNv6 routes to peers and peer groups after the peer re-originated command is executed.
For intercommunication between an MPLS network in one AS and an SRv6 network in another AS, enable SRv6 and MPLS interworking on the ASBR in the SRv6 network. This feature enables End.T SID allocation and establishes mappings between End.T SIDs and MPLS labels.
After you enable SRv6 and MPLS interworking, the per-next-hop label allocation mode applies to routes forwarded from SRv6 networks to MPLS networks. The label allocation mode is not affected by the label-allocation-mode or apply-label command. For more information about the label-allocation-mode command, see BGP commands in Layer 3—IP Routing Command Reference. For more information about the apply-label command, see MPLS L3VPN commands in MPLS Command Reference.
4. Enable SRv6 and MPLS interworking.
srv6-mpls-interworking enable
By default, SRv6 and MPLS interworking is disabled.
6. Configure the route recursion mode.
segment-routing ipv6 { best-effort | traffic-engineering | traffic-engineering best-effort }
When EVPN L3VPN is deployed within data centers and the data centers are interconnected through an IP L3VPN over SRv6 network, configure this feature on the ASBR for each data center. This feature enables intercommunication between the data centers.
Enable intercommunication between the SRv6 and MPLS networks on the ASBR.
Reoriginating VPNv4/VPNv6 routes as EVPN IP prefix advertisement routes
4. Modify BGP routes received from the specified peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } re-originated stitch-evpn
By default, the VPNv4 or VPNv6 routes received from a peer or peer group are not modified.
Reoriginating EVPN IP prefix advertisement routes as VPNv4/VPNv6 routes
3. Enter BGP EVPN address family view.
address-family l2vpn evpn
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } re-originated [ ip-prefix ] stitch-l3vpn
By default, the EVPN routes received from a peer or peer group are not modified.
MPLS L3VPN over SRv6 FRR enables the device to calculate backup routes for all routes of a VPN instance to reduce the traffic interruption caused by link or device failures on the backbone. If the device learns two unequal-cost routes destined for the same network from different peers, the optimal route is backed up by the other route. When the optimal route becomes unavailable, the device uses the backup route to forward traffic. At the same time, the device calculates a new optimal route and then uses it to direct traffic forwarding.
By default, a VPN instance IP routing table does not have SRv6 SID route information. As a result, FRR can only use the static BFD session for the locator network address to detect the primary path between PEs. If the address families of multiple VPN instances have used the same locator, FRR in these address families might use the same static BFD session to detect the primary path. Once the BFD session detects that the path is not available, the BGP routes in all these address families will perform path switching simultaneously.
For refined FRR management, the segment-routing ipv6 primary-path-detect sid-bfd command is provided in BGP-VPN IPv4 unicast address family view and BGP-VPN IPv6 unicast address family view. After this command is executed, when the device adds a BGP VPNv4/VPNv6 route that contains an SRv6 SID to a VPN instance IP routing table, it adds the SRv6 SID as the next hop of the route. This allows FRR to automatically and preferentially associate the static BFD session for the SRv6 SID to detect the primary path. Once BFD detects that an SRv6 SID is not reachable, it triggers the BGP routes in only one address family to perform path switching. This mechanism provides a smaller control granularity for FRR.
This feature might cause routing loops in certain conditions. Make sure you are fully aware of this feature when you use it on a live network.
The segment-routing ipv6 primary-path-detect sid-bfd command applies only to routes that use the SRv6 BE route recursion mode. If the route recursion mode is SRv6 TE and SRv6 BE hybrid, SRv6 TE and SRv6 BE FRR, or SRv6 TE and SRv6 BE multilevel FRR, this command takes effect only when the SRv6 TE path is not available.
2. Configure static BFD.
bfd static session-name [ peer-ipv6 ipv6-address [ vpn-instance vpn-instance-name ] source-ipv6 ipv6-address [ discriminator local local-value remote remote-value ] [ track-interface interface-type interface-number ] ]
If the segment-routing ipv6 primary-path-detect sid-bfd command is not executed, the addresses specified by the peer-ipv6 ipv6-address option and source-ipv6 ipv6-address option must be the locator subnet addresses advertised by the two peers of the link.
If the segment-routing ipv6 primary-path-detect sid-bfd command is executed, the addresses specified by the peer-ipv6 ipv6-address option and source-ipv6 ipv6-address option can be the SRv6 SIDs assigned by the two peers of the link in the VPN instance.
For more information about the bfd static command, see BFD commands in High Availability Command Reference.
3. Return to system view.
4. Enter BGP instance view.
5. Configure BGP FRR to use BFD to detect next hop connectivity for the primary route in control packet mode or echo packet mode.
primary-path-detect bfd { ctrl | echo }
By default, BGP FRR uses ARP to detect the connectivity to the next hop of the primary route.
For more information about this command, see BGP commands in Layer 3—IP Routing Command Reference.
6. Enter BGP-VPN IPv4 unicast address family view, BGP VPNv4 address family view, BGP-VPN IPv6 unicast address family view, or BGP VPNv6 address family view.
¡ Execute the following commands in sequence to enter BGP-VPN IPv4 unicast address family view:
¡ Execute the following commands in sequence to enter BGP-VPN IPv6 unicast address family view:
7. (Optional.) Enable using the static BFD session for the SRv6 SID to detect the reachability of the primary path for SRv6 VPN FRR.
By default, the device detects the reachability of the primary path for SRv6 VPN FRR by using the static BFD session for the locator.
This command can be executed only in BGP-VPN IPv4 unicast address family view or BGP-VPN IPv6 unicast address family view.
8. Enable FRR for the address family.
pic
By default, FRR is disabled for a BGP address family.
A tunnel associated with a VPN instance supports the following TTL processing modes:
· Pipe—When an IP or IPv6 packet enters the tunnel of the VPN instance, the ingress node adds a new header to the packet. The ingress node sets the TTL value or hop limit in the new header to 255 or the value specified by using the encapsulation source-address ip-ttl command in SRv6 view. When the packet leaves the tunnel of the VPN instance, the egress node removes the new header from the packet.The TTL value or hop limit in the original packet does not change when the packet is forwarded in the tunnel. Therefore, the public network nodes are invisible to user networks, and the tracert facility cannot show the real path in the public network.
· Uniform—When an IP or IPv6 packet enters the tunnel of the VPN instance, the ingress node adds a new header to the packet. The ingress node copies the TTL value or the hop limit of the original packet to the TTL or hop limit field of the new header. When the packet leaves the tunnel of the VPN instance, the egress node copies the remaining TTL value or hop limit in the new header back to the original packet. The TTL value or hop limit can reflect how many hops the packet has traversed in the public network. The tracert facility can show the real path along which the packet has traveled.
In the current software version, you can configure a TTL processing mode only for SRv6 tunnels associated with VPN instances.
2. Enter VPN instance view.
ip vpn-instance vpn-instance-name [ index vpn-index ]
3. Configure a TTL processing mode for the tunnels associated with the VPN instance.
ttl-mode { pipe | uniform }
By default, the TTL processing mode for the tunnels associated with a VPN instance is pipe.
For more information about this command, see MPLS L3VPN configuration in MPLS Configuration Guide.
Resetting BGP sessions
For BGP setting changes to take effect, you must reset or soft-reset BGP sessions. Soft-resetting BGP sessions updates BGP routing information without tearing down the BGP sessions. Resetting BGP sessions updates BGP routing information by tearing down and re-establishing the BGP sessions. Soft-reset requires that both the local router and the peer support ROUTE-REFRESH messages.
Execute the commands in this section in user view. For more information about the commands, see BGP in Layer 3—IP Routing Command Reference.
Task |
Command |
Soft-reset BGP sessions of the BGP VPNv4 address family. |
refresh bgp [ instance instance-name ] ipv6-address [ prefix-length ] { export | import } vpnv4 |
Reset BGP sessions of the BGP VPNv4 address family. |
reset bgp [ instance instance-name ] ipv6-address [ prefix-length ] vpnv4 |
Task |
Command |
Display BGP VPNv4 peer or peer group information. |
display bgp [ instance instance-name ] peer vpnv4 { ipv6-address prefix-length | ipv6-address { log-info | verbose } } |
Display BGP VPNv6 peer or peer group information. |
display bgp [ instance instance-name ] peer vpnv6 [ vpn-instance vpn-instance-name ] [ ipv6-address prefix-length | { ipv6-address | group-name group-name } log-info | [ ipv6-address ] verbose ] |
Display BGP update group information for VPNv4 address family. |
display bgp [ instance instance-name ] update-group vpnv4 ipv6-address |
Display BGP update group information for VPNv6 address family. |
display bgp [ instance instance-name ] update-group vpnv6 [ vpn-instance vpn-instance-name ] [ ipv6-address ] |
Clear flap statistics for BGP VPNv4 routes. |
reset bgp [ instance instance-name ] flap-info vpnv4 [ ipv4-address [ mask | mask-length ] | as-path-acl as-path-acl-number | peer ipv6-address [ prefix-length ] ] |
As shown in Figure 7, the backbone network is an IPv6 network, and VPN 1 is an IPv4 network. Deploy IP L3VPN over SRv6 between PE 1 and PE 2 and use an SRv6 tunnel to transmit VPNv4 traffic between the PEs.
· Configure EBGP to exchange VPN routing information between the CEs and PEs.
· Configure IPv6 IS-IS on the PEs in the same AS to realize IPv6 network connectivity.
· Configure MP-IBGP to exchange VPNv4 routing information between the PEs.
Device |
IP address |
Device |
IP address |
CE 1 |
XGE3/0/1 |
10.1.1.2/24 |
PE 2 |
Loop0 |
3::3/128 |
PE 1 |
Loop0 |
1::1/128 |
XGE3/0/1 |
10.2.1.1/24 |
XGE3/0/1 |
10.1.1.1/24 |
XGE3/0/2 |
2002::1/96 |
XGE3/0/2 |
2001::1/96 |
CE 2 |
XGE3/0/1 |
10.2.1.2/24 |
P |
Loop0 |
2::2/128 |
XGE3/0/1 |
2001::2/96 |
XGE3/0/2 |
2002::2/96 |
1. Configure IPv6 IS-IS on the PEs and device P for network connectivity between the devices:
# Configure PE 1.
<PE1> system-view
[PE1] isis 1
[PE1-isis-1] is-level level-1
[PE1-isis-1] cost-style wide
[PE1-isis-1] network-entity 10.1111.1111.1111.00
[PE1-isis-1] address-family ipv6 unicast
[PE1-isis-1-ipv6] quit
[PE1-isis-1] quit
[PE1] interface loopback 0
[PE1-LoopBack0] ipv6 address 1::1 128
[PE1-LoopBack0] isis ipv6 enable 1
[PE1-LoopBack0] quit
[PE1] interface ten-gigabitethernet 3/0/2
[PE1-Ten-GigabitEthernet3/0/2] ipv6 address 2001::1 96
[PE1-Ten-GigabitEthernet3/0/2] isis ipv6 enable
[PE1-Ten-GigabitEthernet3/0/2] quit
# Configure P.
<P> system-view
[P] isis
[P-isis-1] is-level level-1
[P-isis-1] cost-style wide
[P-isis-1] network-entity 10.2222.2222.2222.00
[P-isis-1] address-family ipv6 unicast
[P-isis-1-ipv6] quit
[P-isis-1] quit
[P] interface loopback 0
[P-LoopBack0] ipv6 address 2::2 128
[P-LoopBack0] isis ipv6 enable
[P-LoopBack0] quit
[P] interface ten-gigabitethernet 3/0/1
[P-Ten-GigabitEthernet3/0/1] ipv6 address 2001::2 96
[P-Ten-GigabitEthernet3/0/1] isis ipv6 enable
[P-Ten-GigabitEthernet3/0/1] quit
[P] interface ten-gigabitethernet 3/0/2
[P-Ten-GigabitEthernet3/0/2] ipv6 address 2002::2 96
[P-Ten-GigabitEthernet3/0/2] isis ipv6 enable
[P-Ten-GigabitEthernet3/0/2] quit
# Configure PE 2.
<PE2> system-view
[PE2] isis
[PE2-isis-1] is-level level-1
[PE2-isis-1] cost-style wide
[PE2-isis-1] network-entity 10.3333.3333.3333.00
[PE2-isis-1] address-family ipv6 unicast
[PE2-isis-1-ipv6] quit
[PE2-isis-1] quit
[PE2] interface loopback 0
[PE2-LoopBack0] ipv6 address 3::3 128
[PE2-LoopBack0] isis ipv6 enable
[PE2-LoopBack0] quit
[PE2] interface ten-gigabitethernet 3/0/2
[PE2-Ten-GigabitEthernet3/0/2] ipv6 address 2002::1 96
[PE2-Ten-GigabitEthernet3/0/2] isis ipv6 enable
[PE2-Ten-GigabitEthernet3/0/2] quit
# Verify that PE 1, P, and PE 2 have established IPv6 IS-IS neighbor relationships and the neighbor state is up.
[PE1] display isis peer
[P] display isis peer
[PE2] display isis peer
# Verify that PE 1 and PE 2 each learn a route destined for the loopback interface of each other.
[PE1] display isis route ipv6
[PE2] display isis route ipv6
2. Configure VPN instance settings on PE 1 and PE 2 and verify that each CE can access its local PE:
# Configure PE 1.
[PE1] ip vpn-instance vpn1
[PE1-vpn-instance-vpn1] route-distinguisher 100:1
[PE1-vpn-instance-vpn1] vpn-target 111:1
[PE1-vpn-instance-vpn1] quit
[PE1] interface ten-gigabitethernet 3/0/1
[PE1-Ten-GigabitEthernet3/0/1] ip binding vpn-instance vpn1
[PE1-Ten-GigabitEthernet3/0/1] ip address 10.1.1.1 24
[PE1-Ten-GigabitEthernet3/0/1] quit
# Configure PE 2.
[PE2] ip vpn-instance vpn1
[PE2-vpn-instance-vpn1] route-distinguisher 100:1
[PE2-vpn-instance-vpn1] vpn-target 111:1
[PE2-vpn-instance-vpn1] quit
[PE2] interface ten-gigabitethernet 3/0/1
[PE2-Ten-GigabitEthernet3/0/1] ip binding vpn-instance vpn1
[PE2-Ten-GigabitEthernet3/0/1] ip address 10.2.1.1 24
[PE2-Ten-GigabitEthernet3/0/1] quit
# Configure IP addresses for the interfaces on the CEs, as shown in Figure 7. (Details not shown.)
# Display VPN instance settings on each PE. This step uses PE 1 as an example.
[PE1] display ip vpn-instance
Total IPv4 VPN-Instances configured : 1
Total IPv6 VPN-Instances configured : 1
VPN-Instance Name RD Address family Create time
vpn1 100:1 N/A 2019/08/12 13:59:39
# Verify that each PE can ping its local CE. This step uses PE 1 and CE 1 as an example.
[PE1] ping -vpn-instance vpn1 10.1.1.2
Ping 10.1.1.2 (10.1.1.2): 56 data bytes, press CTRL+C to break
56 bytes from 10.1.1.2: icmp_seq=0 ttl=255 time=2.000 ms
56 bytes from 10.1.1.2: icmp_seq=1 ttl=255 time=0.000 ms
56 bytes from 10.1.1.2: icmp_seq=2 ttl=255 time=1.000 ms
56 bytes from 10.1.1.2: icmp_seq=3 ttl=255 time=0.000 ms
56 bytes from 10.1.1.2: icmp_seq=4 ttl=255 time=0.000 ms
--- Ping statistics for 10.1.1.2 in VPN instance vpn1 ---
round-trip min/avg/max/std-dev = 0.000/0.600/2.000/0.800 ms
3. Set up an EBGP peer relationship between each PE and its local CE and distribute VPN routes to EBGP:
# Configure CE 1.
<CE1> system-view
[CE1] bgp 65410
[CE1-bgp-default] peer 10.1.1.1 as-number 100
[CE1-bgp-default-ipv4] peer 10.1.1.1 enable
[CE1-bgp-default-ipv4] quit
[CE1-bgp-default] quit
# Configure CE 2 in the same way as CE 1 is configured. (Details not shown.)
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp-default] router-id 1.1.1.1
[PE1-bgp-default-vpn1] peer 10.1.1.2 as-number 65410
[PE1-bgp-default-ipv4-vpn1] peer 10.1.1.2 enable
[PE1-bgp-default-vpn1] quit
# Configure PE 2 in the same way PE 1 is configured. (Details not shown.)
# Verify that the PEs have established BGP peer relationships with their local CEs and the peers are in established state.
[PE1] display bgp peer ipv4 vpn-instance
[PE2] display bgp peer ipv4 vpn-instance
4. Set up an MP-IBGP peer relationship between PE 1 and PE 2:
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp-default] peer 3::3 as-number 100
[PE1-bgp-default] peer 3::3 connect-interface loopback 0
[PE1-bgp-default-vpnv4] peer 3::3 enable
[PE1-bgp-default-vpnv4] quit
[PE1-bgp-default] quit
# Configure PE 2.
[PE2] bgp 100
[PE2-bgp-default] peer 1::1 as-number 100
[PE2-bgp-default] peer 1::1 connect-interface loopback 0
[PE2-bgp-default-vpnv4] peer 1::1 enable
[PE2-bgp-default-vpnv4] quit
[PE2-bgp-default] quit
# Verify that the PEs have established a BGP peer relationship and the peers are in established state.
[PE1] display bgp peer vpnv4
[PE2] display bgp peer vpnv4
5. Specify a source address for the outer IPv6 header of SRv6-encapsulated IP L3VPN packets on PE 1 and PE 2:
# Configure PE 1.
[PE1] segment-routing ipv6
[PE1-segment-routing-ipv6] encapsulation source-address 1::1
# Configure PE 2.
[PE2] segment-routing ipv6
[PE2-segment-routing-ipv6] encapsulation source-address 3::3
6. Configure SRv6 locators advertised through IGP:
# Configure PE 1.
[PE1-segment-routing-ipv6] locator aaa ipv6-prefix 1:2::1:0 96 static 8
[PE1-segment-routing-ipv6-locator-aaa] quit
[PE1-segment-routing-ipv6] quit
[PE1] isis 1
[PE1-isis-1-ipv6] segment-routing ipv6 locator aaa
[PE1-isis-1] quit
# Configure PE 2.
[PE2-segment-routing-ipv6] locator bbb ipv6-prefix 6:5::1:0 96 static 8
[PE2-segment-routing-ipv6-locator-bbb] quit
[PE2-segment-routing-ipv6] quit
[PE2] isis 1
[PE2-isis-1-ipv6] segment-routing ipv6 locator bbb
[PE2-isis-1] quit
7. Add End.DT4 SIDs to private network routes on PE 1 and PE 2:
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp-default-ipv4-vpn1] segment-routing ipv6 locator aaa
# Configure PE 2.
[PE2] bgp 100
[PE2-bgp-default-ipv4-vpn1] segment-routing ipv6 locator bbb
[PE2-bgp-default-vpn1] quit
# Verify that the PEs have distributed the End.DT4 SIDs to the routing table and generated SRv6 routes. This step uses PE 1 as an example.
[PE1] display ipv6 routing-table protocol srv6
Summary count : 1
SRv6 Routing table status : <Active>
Summary count : 1
Destination: 1:2::101/128 Protocol : SRv6
NextHop : ::1 Preference: 4
Interface : InLoop0 Cost : 0
SRv6 Routing table status : <Inactive>
Summary count : 0
8. Enable IPv6 peers on the PEs to exchange End.DT4 SIDs and enable the SID-route-recursion feature:
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp-default-vpnv4] peer 3::3 prefix-sid
[PE1-bgp-default-ipv4-vpn1] segment-routing ipv6 best-effort
# Configure PE 2.
[PE2] bgp 100
[PE2-bgp-default-vpnv4] peer 1::1 prefix-sid
[PE2-bgp-default-ipv4-vpn1] segment-routing ipv6 best-effort
# Display BGP VPNv4 routing information on each PE and verify that the routes advertised by the PEs have the SID attribute. This step uses PE 1 as an example.
[PE1] display bgp routing-table vpnv4 10.2.1.0
BGP local router ID: 1.1.1.1
Local AS number: 100
Route distinguisher: 100:1(vpn1)
Total number of routes: 1
Paths: 1 available, 1 best
BGP routing table information of 10.2.1.0/24:
Rely nexthop : FE80::2A96:34FF:FE9D:216
Original nexthop: 3::3
Out interface : Ten-GigabitEthernet3/0/2
Route age : 00h14m23s
OutLabel : 3
Ext-Community : <RT: 111:1>
RxPathID : 0x0
TxPathID : 0x0
PrefixSID : End.DT4 SID <6:5::101>
# Display IPv4 routing table information on the PEs and verify that each PE has a route destined for the remote CE and the next hop of the route is the locator of the End.DT4 SID. This step uses PE 1 as an example.
[PE1] display ip routing-table vpn-instance vpn1
Destinations : 11 Routes : 11
0.0.0.0/32 Direct 0 0 127.0.0.1 InLoop0
10.1.1.0/24 Direct 0 0 10.1.1.1 XGE3/0/1
10.1.1.0/32 Direct 0 0 10.1.1.1 XGE3/0/1
10.1.1.1/32 Direct 0 0 127.0.0.1 InLoop0
10.1.1.255/32 Direct 0 0 10.1.1.1 XGE3/0/1
10.2.1.0/24 BGP 255 0 6:5:: XGE3/0/2
127.0.0.0/32 Direct 0 0 127.0.0.1 InLoop0
127.255.255.255/32 Direct 0 0 127.0.0.1 InLoop0
255.255.255.255/32 Direct 0 0 127.0.0.1 InLoop0
# Verify that CE 1 and CE 2 can ping each other. (Details not shown.)
Example: Configuring IPv4 L3VPN HoVPN over MPLS-to-SRv6
As shown in Figure 8, the network between the UPE and MPE is an MPLS network and the network between the MPE and SPE is an SRv6 network. Configure HoVPN to permit users in the same VPN instance to communicate with each other across the MPLS and SRv6 networks.
Device |
IP address |
Device |
IP address |
CE 1 |
XGE3/0/1 |
10.1.1.2/24 |
MPE |
Loop0 |
2.2.2.2/32 2::2/128 |
CE 2 |
XGE3/0/1 |
10.2.1.2/24 |
XGE3/0/1 |
11.1.1.2/24 |
UPE |
Loop0 |
1.1.1.1/32 |
XGE3/0/2 |
100::1/96 |
XGE3/0/1 |
10.1.1.1/24 |
SPE |
Loop0 |
3::3/128 |
XGE3/0/2 |
11.1.1.1/24 |
XGE3/0/1 |
10.2.1.1/24 |
XGE3/0/2 |
100::2/96 |
1. Configure CE 1:
# Establish EBGP peer relationship with the UPE and import VPN routes.
<CE1> system-view
[CE1] bgp 101
2. Configure the UPE:
# Configure MPLS basic capability and MPLS LDP capability.
<UPE> system-view
[UPE] mpls lsr-id 1.1.1.1
[UPE] mpls ldp
[UPE-ldp] quit
# Configure IS-IS for backbone network communication.
[UPE] isis 1
[UPE-isis-1] is-level level-1
[UPE-isis-1] cost-style wide
[UPE-isis-1] network-entity 10.1111.1111.1111.00
[UPE-isis-1] quit
[UPE] interface loopback 0
[UPE-LoopBack0] ip address 1.1.1.1 32
[UPE-LoopBack0] isis enable 1
[UPE-LoopBack0] quit
[UPE] interface ten-gigabitethernet 3/0/2
[UPE-Ten-GigabitEthernet3/0/2] ip address 11.1.1.1 24
[UPE-Ten-GigabitEthernet3/0/2] isis enable 1
[UPE-Ten-GigabitEthernet3/0/2] mpls enable
[UPE-Ten-GigabitEthernet3/0/2] mpls ldp enable
[UPE-Ten-GigabitEthernet3/0/2] quit
# Configure a VPN instance for CE 1 to access the UPE.
[UPE] ip vpn-instance vpn1
[UPE-vpn-instance-vpn1] route-distinguisher 100:1
[UPE-vpn-instance-vpn1] vpn-target 111:1
[UPE-vpn-instance-vpn1] quit
[UPE] interface ten-gigabitethernet 3/0/1
[UPE-Ten-GigabitEthernet3/0/1] ip binding vpn-instance vpn1
[UPE-Ten-GigabitEthernet3/0/1] ip address 10.1.1.1 24
[UPE-Ten-GigabitEthernet3/0/1] quit
# Establish EBGP peer relationship with CE 1 and import VPN routes.
[UPE] bgp 100
[UPE-bgp-default] router-id 1.1.1.1
[UPE-bgp-default] ip vpn-instance vpn1
[UPE-bgp-default-vpn1] peer 10.1.1.2 as-number 101
[UPE-bgp-default-vpn1] address-family ipv4 unicast
[UPE-bgp-default-ipv4-vpn1] peer 10.1.1.2 enable
[UPE-bgp-default-ipv4-vpn1] import-route direct
[UPE-bgp-default-ipv4-vpn1] quit
[UPE-bgp-default-vpn1] quit
# Establish MP-IBGP peer relationship with the MPE.
[UPE-bgp-default] peer 2.2.2.2 as-number 100
[UPE-bgp-default] peer 2.2.2.2 connect-interface loopback 0
[UPE-bgp-default] address-family vpnv4
[UPE-bgp-default-vpnv4] peer 2.2.2.2 enable
[UPE-bgp-default-vpnv4] quit
[UPE-bgp-default] quit
3. Configure the MPE:
<MPE> system-view
[MPE] mpls lsr-id 2.2.2.2
[MPE] mpls ldp
[MPE-ldp] quit
[MPE] isis 1
[MPE-isis-1] is-level level-1
[MPE-isis-1] cost-style wide
[MPE-isis-1] network-entity 10.2222.2222.2222.00
[MPE-isis-1] address-family ipv6 unicast
[MPE-isis-1-ipv6] quit
[MPE-isis-1] quit
[MPE] interface loopback 0
[MPE-LoopBack0] ip address 2.2.2.2 32
[MPE-LoopBack0] ipv6 address 2::2 128
[MPE-LoopBack0] isis enable 1
[MPE-LoopBack0] isis ipv6 enable 1
[MPE-LoopBack0] quit
[MPE] interface ten-gigabitethernet 3/0/1
[MPE-Ten-GigabitEthernet3/0/1] ip address 11.1.1.2 24
[MPE-Ten-GigabitEthernet3/0/1] isis enable 1
[MPE-Ten-GigabitEthernet3/0/1] mpls enable
[MPE-Ten-GigabitEthernet3/0/1] mpls ldp enable
[MPE-Ten-GigabitEthernet3/0/1] quit
[MPE] interface ten-gigabitethernet 3/0/2
[MPE-Ten-GigabitEthernet3/0/2] ipv6 address 100::1 96
[MPE-Ten-GigabitEthernet3/0/2] isis ipv6 enable 1
[MPE-Ten-GigabitEthernet3/0/2] quit
# Configure a VPN instance.
[MPE] ip vpn-instance vpn2
[MPE-vpn-instance-vpn1] route-distinguisher 200:1
[MPE-vpn-instance-vpn1] vpn-target 111:1
[MPE-vpn-instance-vpn1] quit
# Establish MP-IBGP peer relationship with the UPE and SPE.
[MPE] bgp 100
[MPE-bgp-default] router-id 2.2.2.2
[MPE-bgp-default] peer 1.1.1.1 as-number 100
[MPE-bgp-default] peer 1.1.1.1 connect-interface LoopBack0
[MPE-bgp-default] peer 3::3 as-number 100
[MPE-bgp-default] peer 3::3 connect-interface LoopBack0
[MPE-bgp-default] address-family vpnv4
[MPE-bgp-default-vpnv4] peer 1.1.1.1 enable
[MPE-bgp-default-vpnv4] peer 3::3 enable
[MPE-bgp-default-vpnv4] quit
# Specify a UPE.
[MPE-bgp-default-vpnv4] peer 1.1.1.1 upe
[MPE-bgp-default-vpnv4] peer 1.1.1.1 next-hop-local
# Configure optimal route reorigination and advertisement for intercommunication between the MPLS L3VPN network and IP L3VPN over SRv6 network.
[MPE-bgp-default] ip vpn-instance vpn2
[MPE-bgp-default-vpn2] address-family ipv4 unicast
[MPE-bgp-default-ipv4-vpn2] advertise route-reoriginate
[MPE-bgp-default-ipv4-vpn2] quit
[MPE-bgp-default-vpn2] quit
[MPE-bgp-default] quit
# Enable the MPE to send routing information matching a routing policy to the UPE. The route of CE 2 can be sent to the UPE.
[MPE] ip prefix-list hovpn index 10 permit 10.2.1.0 24
[MPE] route-policy hovpn permit node 0
[MPE-route-policy-hovpn-0] if-match ip address prefix-list hovpn
[MPE-route-policy-hovpn-0] quit
[MPE] bgp 100
[MPE-bgp-default-vpnv4] peer 1.1.1.1 upe route-policy hovpn export
# Configure L3VPN over SRv6 BE.
[MPE] segment-routing ipv6
[MPE-segment-routing-ipv6] encapsulation source-address 2::2
[MPE-segment-routing-ipv6] locator hovpn ipv6-prefix 42:1:: 64 static 32
[MPE-segment-routing-ipv6-locator-hovpn] quit
[MPE-segment-routing-ipv6] quit
[MPE] bgp 100
[MPE-bgp-default-vpnv4] peer 3::3 prefix-sid
[MPE-bgp-default-ipv4-vpn2] segment-routing ipv6 best-effort
[MPE-bgp-default-ipv4-vpn2] segment-routing ipv6 locator hovpn
[MPE] isis 1
[MPE-isis-1-ipv6] segment-routing ipv6 locator hovpn
[MPE-isis-1] quit
4. Configure the SPE:
# Configure IPv6 IS-IS for backbone network communication.
<SPE> system-view
[SPE] isis 1
[SPE-isis-1] is-level level-1
[SPE-isis-1] cost-style wide
[SPE-isis-1] network-entity 10.3333.3333.3333.00
[SPE-isis-1] address-family ipv6 unicast
[SPE-isis-1-ipv6] quit
[SPE-isis-1] quit
[SPE] interface loopback 0
[SPE-LoopBack0] ipv6 address 3::3 128
[SPE-LoopBack0] isis ipv6 enable 1
[SPE-LoopBack0] quit
[SPE] interface ten-gigabitethernet 3/0/2
[SPE-Ten-GigabitEthernet3/0/2] ipv6 address 100::2 96
[SPE-Ten-GigabitEthernet3/0/2] isis ipv6 enable 1
[SPE-Ten-GigabitEthernet3/0/2] quit
# Configure a VPN instance for CE 2 to access the SPE.
[SPE] ip vpn-instance vpn1
[SPE-vpn-instance-vpn1] route-distinguisher 100:1
[SPE-vpn-instance-vpn1] vpn-target 111:1
[SPE-vpn-instance-vpn1] quit
[SPE] interface ten-gigabitethernet 3/0/1
[SPE-Ten-GigabitEthernet3/0/1] ip binding vpn-instance vpn1
[SPE-Ten-GigabitEthernet3/0/1] ip address 10.2.1.1 24
[SPE-Ten-GigabitEthernet3/0/1] quit
# Establish EGFP peer relationship with CE 2 and import VPN routes.
[SPE] bgp 100
[SPE-bgp-default] router-id 3.3.3.3
[SPE-bgp-default] ip vpn-instance vpn1
[SPE-bgp-default-vpn1] peer 10.2.1.2 as-number 102
[SPE-bgp-default-vpn1] address-family ipv4 unicast
[SPE-bgp-default-ipv4-vpn1] peer 10.2.1.2 enable
[SPE-bgp-default-ipv4-vpn1] import-route direct
[SPE-bgp-default-ipv4-vpn1] quit
[SPE-bgp-default-vpn1] quit
[SPE] bgp 100
[SPE-bgp-default] peer 2::2 as-number 100
[SPE-bgp-default] peer 2::2 connect-interface loopback 0
[SPE-bgp-default] address-family vpnv4
[SPE-bgp-default-vpnv4] peer 2::2 enable
[SPE-bgp-default-vpnv4] quit
[SPE-bgp-default] quit
[SPE] segment-routing ipv6
[SPE-segment-routing-ipv6] encapsulation source-address 3::3
[SPE-segment-routing-ipv6] locator hovpn ipv6-prefix 43:1:: 64 static 32
[SPE-segment-routing-ipv6-locator-hovpn] quit
[SPE-segment-routing-ipv6] quit
[SPE] bgp 100
[SPE-bgp-default-vpnv4] peer 2::2 prefix-sid
[SPE-bgp-default-ipv4-vpn1] segment-routing ipv6 best-effort
[SPE-bgp-default-ipv4-vpn1] segment-routing ipv6 locator hovpn
[SPE] isis 1
[SPE-isis-1-ipv6] segment-routing ipv6 locator hovpn
[SPE-isis-1] quit
5. Configure CE 2:
# Establish EBGP peer relationship with the SPE and import VPN routes.
<CE2> system-view
[CE2] bgp 102
[CE2-bgp-default] peer 10.2.1.1 as-number 100
[CE2-bgp-default-ipv4] peer 10.2.1.1 enable
[CE2-bgp-default-ipv4] import-route direct
[CE2-bgp-default-ipv4] quit
[CE2-bgp-default] quit
# On MPE, verify that the routes destined for CE 2 and CE 1 have established SRv6 SID and MPLS label mappings.
[MPE] display bgp routing-table vpnv4 10.2.1.0 24
BGP local router ID: 2.2.2.2
Rely nexthop : FE80::9885:31FF:FE87:317
Route age : 03h16m43s
OutLabel : 3
RxPathID : 0x0
TxPathID : 0x0
PrefixSID : End.DT4 SID <43:1::1:0:2>
Route distinguisher: 200:1(vpn2)
OutLabel : 3
RxPathID : 0x0
TxPathID : 0x0
[MPE] display bgp routing-table vpnv4 10.1.1.0 24
BGP routing table information of 10.1.1.0/24:
Rely nexthop : 11.1.1.1
Original nexthop: 1.1.1.1
Out interface : Ten-GigabitEthernet3/0/1
Route age : 00h44m22s
OutLabel : 600126
RxPathID : 0x0
TxPathID : 0x0
OutLabel : 600126
RxPathID : 0x0
TxPathID : 0x0
PrefixSID : End.DT4 SID <42:1::1:0:2>
Example: Configuring inter-AS option B VPN
As shown in Figure 9, an MPLS network is deployed in AS 100 and an SRv6 network is deployed in AS 200. Configure inter-AS option B VPN to permit users in the same VPN instance to communicate with each other across the MPLS and SRv6 networks.
Device |
IP address |
Device |
IP address |
CE 1 |
XGE3/0/1 |
10.1.1.2/24 |
CE 2 |
XGE3/0/1 |
20.1.1.2/24 |
PE 1 |
Loop0 |
1.1.1.1/32 |
PE 2 |
Loop0 |
1::1/128 |
XGE3/0/1 |
10.1.1.1/24 |
XGE3/0/1 |
20.1.1.1/24 |
XGE3/0/2 |
11.1.1.1/24 |
XGE3/0/2 |
100::1/96 |
ASBR 1 |
Loop0 |
2.2.2.2/32 |
ASBR 2 |
Loop0 |
2::2/128 |
XGE3/0/1 |
11.1.1.2/24 |
XGE3/0/1 |
100::2/96 |
XGE3/0/2 |
12.1.1.1/24 |
XGE3/0/2 |
12.1.1.2/24 |
1. Configure CE 1:
# Establish EBGP peer relationship with PE 1 and import VPN routes.
<CE1> system-view
[CE1] bgp 101
2. Configure PE 1:
# Run IS-IS on PE 1.
<PE1> system-view
[PE1] isis 1
[PE1-isis-1] quit
# Specify an LSR ID and enable MPLS and LDP.
[PE1] mpls lsr-id 1.1.1.1
[PE1] mpls ldp
[PE1-ldp] quit
# On interface Ten-GigabitEthernet 3/0/2, specify an IP address, run IS-IS, and enable MPLS and LDP.
[PE1-Ten-GigabitEthernet3/0/2] ip address 11.1.1.1 255.0.0.0
[PE1-Ten-GigabitEthernet3/0/2] isis enable 1
[PE1-Ten-GigabitEthernet3/0/2] mpls enable
[PE1-Ten-GigabitEthernet3/0/2] mpls ldp enable
# Create interface Loopback 0, specify an IP address for the interface, and run IS-IS on the interface.
[PE1-LoopBack0] isis enable 1
# Create a VPN instance named vpn1 and configure a RD and route target for the VPN instance.
[PE1-vpn-instance-vpn1] vpn-target 100:1
# Associate the interface connected to CE 1 with VPN instance vpn1.
# Run BGP on PE 1.
[PE1] bgp 100
# Configure IBGP peer 2.2.2.2 as a VPNv4 peer.
[PE1-bgp-default] peer 2.2.2.2 as-number 100
[PE1-bgp-default] peer 2.2.2.2 connect-interface loopback 0
[PE1-bgp-default-vpnv4] peer 2.2.2.2 enable
[PE1-bgp-default-vpn1] peer 10.1.1.2 as-number 101
3. Configure ASBR 1:
# Run IS-IS on ASBR 1.
<ASBR1> system-view
[ASBR1] isis 1
[ASBR1-isis-1] cost-style wide
[ASBR1-isis-1] network-entity 10.2222.2222.2222.00
[ASBR1-isis-1] quit
[ASBR1] mpls lsr-id 2.2.2.2
[ASBR1] mpls ldp
[ASBR1-ldp] quit
# On interface Ten-GigabitEthernet 3/0/1, specify an IP address, run IS-IS, and enable MPLS and LDP.
[ASBR1] interface ten-gigabitethernet 3/0/1
[ASBR1-Ten-GigabitEthernet3/0/1] ip address 11.1.1.2 255.0.0.0
[ASBR1-Ten-GigabitEthernet3/0/1] isis enable 1
[ASBR1-Ten-GigabitEthernet3/0/1] mpls enable
[ASBR1-Ten-GigabitEthernet3/0/1] mpls ldp enable
[ASBR1-Ten-GigabitEthernet3/0/1] quit
# On interface Ten-GigabitEthernet 3/0/2, specify an IP address and enable MPLS.
[ASBR1] interface ten-gigabitethernet 3/0/2
[ASBR1-Ten-GigabitEthernet3/0/2] ip address 12.1.1.1 255.0.0.0
[ASBR1-Ten-GigabitEthernet3/0/2] mpls enable
[ASBR1-Ten-GigabitEthernet3/0/2] quit
# Create interface Loopback 0, specify an IP address and run IS-IS on the interface.
[ASBR1] interface loopback 0
[ASBR1-LoopBack0] ip address 2.2.2.2 32
[ASBR1-LoopBack0] isis enable 1
[ASBR1-LoopBack0] quit
# Run BGP on ASBR 1.
[ASBR1] bgp 100
[ASBR1-bgp-default] router-id 2.2.2.2
[ASBR1-bgp-default] peer 1.1.1.1 as-number 100
[ASBR1-bgp-default] peer 1.1.1.1 connect-interface loopback 0
[ASBR1-bgp-default] peer 12.1.1.2 as-number 200
[ASBR1-bgp-default] peer 12.1.1.2 connect-interface ten-gigabitethernet 3/0/2
# Configure BGP to not filter received VPNv4 routes based on route targets.
[ASBR1-bgp-default] address-family vpnv4
[ASBR1-bgp-default-vpnv4] undo policy vpn-target
# Configure IBGP peer 1.1.1.1 and EBGP peer 12.1.1.2 as VPNv4 peers.
[ASBR1-bgp-default-vpnv4] peer 12.1.1.2 enable
[ASBR1-bgp-default-vpnv4] peer 1.1.1.1 enable
[ASBR1-bgp-default-vpnv4] quit
[ASBR1-bgp-default] quit
4. Configure ASBR 2:
# Run IPv6 IS-IS on ASBR 2.
<ASBR2> system-view
[ASBR2] isis 1
[ASBR2-isis-1] cost-style wide
[ASBR2-isis-1] network-entity 10.3333.3333.3333.00
[ASBR2-isis-1] address-family ipv6 unicast
[ASBR2-isis-1-ipv6] quit
[ASBR2-isis-1] quit
# On interface Ten-GigabitEthernet 3/0/1, specify an IPv6 address and run IPv6 IS-IS.
[ASBR2] interface ten-gigabitethernet 3/0/1
[ASBR2-Ten-GigabitEthernet3/0/1] ipv6 address 100::2 96
[ASBR2-Ten-GigabitEthernet3/0/1] isis ipv6 enable 1
[ASBR2-Ten-GigabitEthernet3/0/1] quit
[ASBR2] interface ten-gigabitethernet 3/0/2
[ASBR2-Ten-GigabitEthernet3/0/2] ip address 12.1.1.2 255.0.0.0
[ASBR2-Ten-GigabitEthernet3/0/2] mpls enable
[ASBR2-Ten-GigabitEthernet3/0/2] quit
# Create interface Loopback 0, specify an IPv6 address for the interface, and run IPv6 IS-IS on the interface.
[ASBR2] interface loopback 0
[ASBR2-LoopBack0] ipv6 address 2::2 128
[ASBR2-LoopBack0] isis ipv6 enable 1
[ASBR2-LoopBack0] quit
# Run BGP on ASBR 2.
[ASBR2] bgp 200
[ASBR2-bgp-default] router-id 3.3.3.3
[ASBR2-bgp-default] peer 12.1.1.1 as-number 100
[ASBR2-bgp-default] peer 12.1.1.1 connect-interface ten-gigabitethernet 3/0/2
[ASBR2-bgp-default] peer 1::1 as-number 200
[ASBR2-bgp-default] peer 1::1 connect-interface loopback 0
[ASBR2-bgp-default] address-family vpnv4
[ASBR2-bgp-default-vpnv4] undo policy vpn-target
# Configure IBGP peer 1::1 and EBGP peer 12.1.1.1 as VPNv4 peers.
[ASBR2-bgp-default-vpnv4] peer 12.1.1.1 enable
[ASBR2-bgp-default-vpnv4] peer 1::1 enable
[ASBR2-bgp-default-vpnv4] quit
[ASBR2-bgp-default] quit
[ASBR2] segment-routing ipv6
[ASBR2-segment-routing-ipv6] encapsulation source-address 2::2
[ASBR2-segment-routing-ipv6] locator abc ipv6-prefix 43:1:: 64 static 32
[ASBR2-segment-routing-ipv6-locator-abc] quit
[ASBR2-segment-routing-ipv6] quit
[ASBR2] bgp 200
[ASBR2-bgp-default-vpnv4] segment-routing ipv6 best-effort
[ASBR2-bgp-default-vpnv4] segment-routing ipv6 locator abc
[ASBR2-bgp-default-vpnv4] peer 1::1 prefix-sid
# Enable SRv6 and MPLS interworking.
[ASBR2-bgp-default-vpnv4] srv6-mpls-interworking enable
# Apply a locator to IPv6 IS-IS.
[ASBR2] isis 1
[ASBR2-isis-1-ipv6] segment-routing ipv6 locator abc
[ASBR2-isis-1] quit
5. Configure PE 2:
# Run IPv6 IS-IS on PE 2.
<PE2> system-view
[PE2] isis 1
[PE2-isis-1] network-entity 10.4444.4444.4444.00
[PE2-isis-1] quit
# On interface Ten-GigabitEthernet 3/0/2, specify an IPv6 address and run IPv6 IS-IS.
[PE2-Ten-GigabitEthernet3/0/2] ipv6 address 100::1 96
[PE2-Ten-GigabitEthernet3/0/2] isis ipv6 enable 1
# Create interface Loopback 0, specify an IPv6 address and run IPv6 IS-IS on the interface.
[PE2-LoopBack0] ipv6 address 1::1 128
[PE2-LoopBack0] isis ipv6 enable 1
[PE2-vpn-instance-vpn1] vpn-target 100:1
# Associate the interface connected to CE 2 with VPN instance vpn1.
[PE2-Ten-GigabitEthernet3/0/1] ip address 20.1.1.1 24
# Run BGP on PE 2.
[PE2] bgp 200
[PE2-bgp-default] router-id 4.4.4.4
# Configure IBGP peer 2::2 as a VPNv4 peer.
[PE2-bgp-default] peer 2::2 as-number 200
[PE2-bgp-default] peer 2::2 connect-interface loopback 0
[PE2-bgp-default-vpnv4] peer 2::2 enable
# Establish EBGP peer relationship with CE 2 and import VPN routes.
[PE2-bgp-default-vpn1] peer 20.1.1.2 as-number 201
[PE2-bgp-default-ipv4-vpn1] peer 20.1.1.2 enable
[PE2-segment-routing-ipv6] encapsulation source-address 1::1
[PE2-segment-routing-ipv6] locator abc ipv6-prefix 42:1:: 64 static 32
[PE2-segment-routing-ipv6-locator-abc] quit
[PE2] bgp 200
[PE2-bgp-default-ipv4-vpn1] segment-routing ipv6 locator abc
[PE2-bgp-default-vpnv4] peer 2::2 prefix-sid
[PE2] isis 1
[PE2-isis-1-ipv6] segment-routing ipv6 locator abc
[PE2-isis-1] quit
6. Configure CE 2:
# Establish EBGP peer relationship with PE 2 and import VPN routes.
<CE2> system-view
[CE2] bgp 201
[CE2-bgp-default] peer 20.1.1.1 as-number 200
[CE2-bgp-default-ipv4] peer 20.1.1.1 enable
# On ASBR 2, verify that the MPLS label and SRv6 SID have established mapping relationship. The LSP out label is the SRv6 SID.
[ASBR2] display mpls lsp srv6-mpls-interworking
FEC : 3::3/43:1::1:0:2
Protocol : BGP
In Label : 600127
Out SRv6 SID : 43:1::1:0:2
Path ID : 0x16000000.1
# On ASBR 2, verify that an End.T SID has been allocated to FEC 10.1.1.0/24.
[ASBR2] display bgp routing-table vpnv4 10.1.1.0
BGP local router ID: 3.3.3.3
Local AS number: 200
Rely nexthop : 12.1.1.1
Original nexthop: 12.1.1.1
Route age : 00h03m18s
OutLabel : 600126
Ext-Community : <RT: 100:1>
RxPathID : 0x0
TxPathID : 0x0
PrefixSID : End.T SID <42:1::1:0:4>
AS-path : 100 101
Origin : incomplete
Attribute value : pref-val 0
State : valid, external, best
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
Tunnel policy : NULL
Rely tunnel IDs : 1
Example: Configuring IPv4 L3VPN over G-SRv6 (with COC32 locators)
As shown in Figure 11, the backbone network is an IPv6 network, and VPN aaa is an IPv4 network. Deploy an SRv6 TE policy tunnel between PE 1 and PE 2 in the IPv6 network and use the SRv6 TE policy tunnel to transmit end-to-end VPN traffic.
· Because a large number of devices exist in the backbone network, the SID list for the optimal candidate path of the SRv6 TE policy contains many SRv6 SIDs. To reduce the SRH length for packets, use the G-SRv6 compression solution.
· The SRv6 nodes in the backbone network use COC32 locators, and assign SIDs with the COC flag from the COC32 locators.
· As shown in Figure 10, to prevent packet forwarding issues, appropriately plan the common prefix for the locators in the AS. Specify the common prefix as A:1:1:A:: with 64-bit length for COC32 locators on all devices. In addition, specify the IPv6 address prefix length for the locators as 80 bits, the static portion length for COC32 locators as 8 bits, and the Args portion length as 16 bits. Through calculation, the dynamic portion length in COC32 locators is 8 bits, and the MBZ length is 16 bits.
Figure 10 COC32 locator plan in the AS
Device |
Interfaces |
IP address |
Device |
Interfaces |
IP address |
CE 1 |
XGE3/0/1 |
10.1.1.1/30 |
CE 2 |
XGE3/0/2 |
20.1.1.1/30 |
Loop0 |
11.11.11.11/32 |
Loop0 |
22.22.22.22/32 |
PE 1 |
Loop0 |
1::1/128 |
PE 2 |
Loop0 |
5::5/128 |
XGE3/0/1 |
10.1.1.2/30 |
XGE3/0/2 |
20.1.1.2/30 |
XGE3/0/2 |
12:1:1::1/126 |
XGE3/0/1 |
45:1:1::2/126 |
P 1 |
Loop0 |
2::2/128 |
P 2 |
Loop0 |
3::3/128 |
XGE3/0/1 |
23:1:1::1/126 |
XGE3/0/1 |
23:1:1::2/126 |
XGE3/0/2 |
12:1:1::2/126 |
XGE3/0/2 |
34:1:1::1/126 |
P 3 |
Loop0 |
4::4/128 |
XGE3/0/1 |
45:1:1::1/126 |
XGE3/0/2 |
34:1:1::2/126 |
1. Configure CE 1:
# Configure IP addresses for the interfaces.
<CE1> system-view
[CE1] sysname CE1
[CE1] interface ten-gigabitethernet 3/0/1
[CE1-Ten-GigabitEthernet3/0/1] ip address 10.1.1.1 30
[CE1-Ten-GigabitEthernet3/0/1] quit
[CE1] interface loopback 0
[CE1-LoopBack0] ip address 11.11.11.11 32
[CE1-LoopBack0] quit
# Create EBGP peers between the PE and CE, and import direct routes.
[CE1] bgp 10
[CE1-bgp-default] router-id 11.11.11.11
[CE1-bgp-default] peer 10.1.1.2 as-number 100
[CE1-bgp-default-ipv4] peer 10.1.1.2 enable
2. Configure CE 2:
<CE2> system-view
[CE2] sysname CE2
[CE2] interface ten-gigabitethernet 3/0/2
[CE2-Ten-GigabitEthernet3/0/2] ip address 20.1.1.1 30
[CE2-Ten-GigabitEthernet3/0/2] quit
[CE2] interface loopback 0
[CE2-LoopBack0] ip address 22.22.22.22 32
[CE2-LoopBack0] quit
[CE2] bgp 20
[CE2-bgp-default] router-id 22.22.22.22
[CE2-bgp-default] peer 20.1.1.2 as-number 100
[CE2-bgp-default-ipv4] peer 20.1.1.2 enable
3. Configure PE 1:
# Configure the VPN instance on PE 1 to connect the CE to PE.
<PE1> system-view
[PE1] sysname PE1
[PE1] ip vpn-instance aaa
[PE1-vpn-instance-aaa] route-distinguisher 100:1
[PE1-vpn-instance-aaa] vpn-target 200:1 both
[PE1-vpn-instance-aaa] quit
[PE1-Ten-GigabitEthernet3/0/1] ip binding vpn-instance aaa
[PE1-Ten-GigabitEthernet3/0/1] ip address 10.1.1.2 30
[PE1-Ten-GigabitEthernet3/0/2] ipv6 address 12:1:1::1 126
# Configure IPv6 IS-IS to implement backbone network intercommunication.
[PE1] isis 1
[PE1-isis-1] is-level level-2
[PE1-isis-1] network-entity 00.0000.0000.0001.00
[PE1-isis-1] quit
[PE1-Ten-GigabitEthernet3/0/2] isis ipv6 enable 1
# Configure an SRv6 locator on the PE to be advertised by IGP, and enable SRv6 compression.
[PE1] segment-routing-ipv6
[PE1-segment-routing-ipv6] srv6 compress enable
[PE1-segment-routing-ipv6] locator a ipv6-prefix A:1:1:A:1:: 80 common-prefix 64 coc32 static 8 args 16
[PE1-segment-routing-ipv6-locator-a] quit
[PE1] isis 1
[PE1-isis-1-ipv6] segment-routing ipv6 locator a auto-sid-coc32
[PE1-isis-1-ipv6] srv6 compress enable
[PE1-isis-1] quit
# Specify a source address for the outer IPv6 header of SRv6-encapsulated IP L3VPN packets on the PE.
# Configure the source address of SBFD packets on PE 1.
[PE1] sbfd source-ipv6 1::1
# Configure a static SID list on the PE that contains SRv6 SIDs with the COC flag, specify the static SID list for an SRv6 TE policy, and enable SBFD for the SRv6 TE policy, ensuring that the SRv6 TE policy tunnel can forward services correctly.
In the static SID list:
¡ The first hop is the End.X(COC32) SID of the link from P 1 to P 2. The SRv6 SID in the encapsulated SRH is still 128 bits long without being compressed. The next SID will be compressed.
¡ The second hop is the End(COC32) SID of P 2. The SRv6 SID in the encapsulated SRH is compressed to 32 bits long.
¡ The third hop is the End.X(COC32) SID of the link from P 3 to PE 2. The SRv6 SID in the encapsulated SRH is compressed to 32 bits long.
¡ The fourth hop is the End SID of PE 2. The SRv6 SID in the encapsulated SRH is compressed to 32 bits long. The next SID will not be compressed.
[PE1-segment-routing-ipv6] traffic-engineering
[PE1-srv6-te] srv6-policy locator a
[PE1-srv6-te] segment-list a
[PE1-srv6-te-sl-a] index 10 coc32 ipv6 A:1:1:A:2:20:: 64
[PE1-srv6-te-sl-a] index 20 coc32 ipv6 A:1:1:A:3:10:: 64
[PE1-srv6-te-sl-a] index 30 coc32 ipv6 A:1:1:A:4:20:: 64
[PE1-srv6-te-sl-a] index 40 ipv6 A:1:1:A:5:10::
[PE1-srv6-te-sl-a] quit
[PE1-srv6-te] policy a
[PE1-srv6-te-policy-a] color 10 end-point ipv6 5::5
[PE1-srv6-te-policy-a] sbfd enable remote 1000001
[PE1-srv6-te-policy-a] candidate-paths
[PE1-srv6-te-policy-a-path] preference 200
[PE1-srv6-te-policy-a-path-pref-200] explicit segment-list a
[PE1-srv6-te-policy-a-path-pref-200] quit
[PE1-srv6-te-policy-a-path] quit
[PE1-srv6-te-policy-a] quit
[PE1-srv6-te] quit
# Create EBGP peers between the PE and CE, and import VPN routes.
[PE1] bgp 100
[PE1-bgp-default] ip vpn-instance aaa
[PE1-bgp-default-aaa] peer 10.1.1.1 as-number 10
[PE1-bgp-default-aaa] address-family ipv4 unicast
[PE1-bgp-default-ipv4-aaa] peer 10.1.1.1 enable
[PE1-bgp-default-ipv4-aaa] quit
[PE1-bgp-default-aaa] quit
# Create MP-IBGP peers between PE 1 and PE 2.
[PE1-bgp-default] peer 5::5 as-number 100
[PE1-bgp-default] peer 5::5 connect-interface loopback 0
[PE1-bgp-default-vpnv4] peer 5::5 enable
# Enable exchange of End.DT4 SIDs between IPv6 peers on PE 1, and enable recursion of VPN routes to the SRv6 TE policy tunnel.
[PE1] bgp 100
[PE1-bgp-default-vpnv4] peer 5::5 prefix-sid
[PE1-bgp-default-ipv4-aaa] segment-routing ipv6 locator a
[PE1-bgp-default-ipv4-aaa] segment-routing ipv6 traffic-engineering
# Configure a routing policy and a tunnel policy on PE 1 to steer VPN service traffic to the specified SRv6 TE policy through the routing policy and ensure that the SRv6 TE policy is the optimal tunnel.
[PE1] route-policy a permit node 10
[PE1-route-policy-a-10] apply extcommunity color 00:10
[PE1-route-policy-a-10] quit
[PE1] bgp 100
[PE1-bgp-default-vpnv4] peer 5::5 route-policy a import
[PE1] tunnel-policy a
[PE1-tunnel-policy-a] select-seq srv6-policy load-balance-number 1
[PE1-tunnel-policy-a] quit
[PE1-vpn-instance-vpn1] tnl-policy a
4. Configure P 1:
[P1] interface loopback 0
[P1-LoopBack0] ipv6 address 2::2 128
[P1-LoopBack0] quit
[P1] interface ten-gigabitethernet 3/0/1
[P1-Ten-GigabitEthernet3/0/1] ipv6 address 23:1:1::1 126
[P1-Ten-GigabitEthernet3/0/1] quit
[P1] interface ten-gigabitethernet 3/0/2
[P1-Ten-GigabitEthernet3/0/2] ipv6 address 12:1:1::2 126
[P1-Ten-GigabitEthernet3/0/2] quit
[P1] isis 1
[P1-isis-1] is-level level-2
[P1-isis-1] cost-style wide
[P1-isis-1] network-entity 00.0000.0000.0002.00
[P1-isis-1] address-family ipv6 unicast
[P1-isis-1-ipv6] quit
[P1-isis-1] quit
[P1-Ten-GigabitEthernet3/0/1] isis ipv6 enable 1
[P1-Ten-GigabitEthernet3/0/2] isis ipv6 enable 1
[P1-LoopBack0] isis ipv6 enable 1
[P1-LoopBack0] quit
# Configure an SRv6 locator on P 1 to be advertised by IGP, and enable SRv6 compression.
[P1] segment-routing-ipv6
[P1-segment-routing-ipv6] srv6 compress enable
[P1-segment-routing-ipv6] locator b ipv6-prefix A:1:1:A:2:: 80 common-prefix 64 coc32 static 8 args 16
[P1-segment-routing-ipv6-locator-b] opcode 32 end-x-coc32 interface Ten-GigabitEthernet3/0/1 nexthop 23:1:1::2 no-flavor
[P1-segment-routing-ipv6-locator-b] quit
[P1-segment-routing-ipv6] quit
[P1] isis 1
[P1-isis-1-ipv6] segment-routing ipv6 locator b auto-sid-coc32
[P1-isis-1-ipv6] srv6 compress enable
[P1-isis-1] quit
5. Configure P 2:
[P2] interface loopback 0
[P2-LoopBack0] ipv6 address 3::3 128
[P2-LoopBack0] quit
[P2] interface ten-gigabitethernet 3/0/1
[P2-Ten-GigabitEthernet3/0/1] ipv6 address 23:1:1::2 126
[P2-Ten-GigabitEthernet3/0/1] quit
[P2] interface ten-gigabitethernet 3/0/2
[P2-Ten-GigabitEthernet3/0/2] ipv6 address 34:1:1::1 126
[P2-Ten-GigabitEthernet3/0/2] quit
[P2] isis 1
[P2-isis-1] is-level level-2
[P2-isis-1] cost-style wide
[P2-isis-1] network-entity 00.0000.0000.0003.00
[P2-isis-1] address-family ipv6 unicast
[P2-isis-1-ipv6] quit
[P2-isis-1] quit
[P2-Ten-GigabitEthernet3/0/1] isis ipv6 enable 1
[P2-Ten-GigabitEthernet3/0/2] isis ipv6 enable 1
[P2-LoopBack0] isis ipv6 enable 1
[P2-LoopBack0] quit
# Configure an SRv6 locator on P 2 to be advertised by IGP, and enable SRv6 compression.
[P2] segment-routing-ipv6
[P2-segment-routing-ipv6] srv6 compress enable
[P2-segment-routing-ipv6] locator c ipv6-prefix A:1:1:A:3:: 80 common-prefix 64 coc32 static 8 args 16
[P2-segment-routing-ipv6-locator-c] opcode 16 end-coc32 no-flavor
[P2-segment-routing-ipv6-locator-c] quit
[P2-segment-routing-ipv6] quit
[P2] isis 1
[P2-isis-1-ipv6] segment-routing ipv6 locator c auto-sid-coc32
[P2-isis-1-ipv6] srv6 compress enable
[P2-isis-1] quit
6. Configure P 3:
[P3] interface loopback 0
[P3-LoopBack0] ipv6 address 4::4 128
[P3-LoopBack0] quit
[P3] interface ten-gigabitethernet 3/0/1
[P3-Ten-GigabitEthernet3/0/1] ipv6 address 45:1:1::1 126
[P3-Ten-GigabitEthernet3/0/1] quit
[P3] interface ten-gigabitethernet 3/0/2
[P3-Ten-GigabitEthernet3/0/2] ipv6 address 34:1:1::2 126
[P3-Ten-GigabitEthernet3/0/2] quit
[P3] isis 1
[P3-isis-1] is-level level-2
[P3-isis-1] cost-style wide
[P3-isis-1] network-entity 00.0000.0000.0004.00
[P3-isis-1] address-family ipv6 unicast
[P3-isis-1-ipv6] quit
[P3-isis-1] quit
[P3-Ten-GigabitEthernet3/0/1] isis ipv6 enable 1
[P3-Ten-GigabitEthernet3/0/2] isis ipv6 enable 1
[P3-LoopBack0] isis ipv6 enable 1
[P3-LoopBack0] quit
# Configure an SRv6 locator on P 3 to be advertised by IGP, and enable SRv6 compression.
[P3] segment-routing-ipv6
[P3-segment-routing-ipv6] srv6 compress enable
[P3-segment-routing-ipv6] locator d ipv6-prefix A:1:1:A:4:: 80 common-prefix 64 coc32 static 8 args 16
[P3-segment-routing-ipv6-locator-d] opcode 32 end-x-coc32 interface Ten-GigabitEthernet3/0/1 nexthop 45:1:1::2 no-flavor
[P3-segment-routing-ipv6-locator-d] quit
[P3-segment-routing-ipv6] quit
[P3] isis 1
[P3-isis-1-ipv6] segment-routing ipv6 locator d auto-sid-coc32
[P3-isis-1-ipv6] srv6 compress enable
[P3-isis-1] quit
7. Configure PE 2:
# Configure the VPN instance on PE 2 to connect the CE to PE.
<PE2> system-view
[PE2] sysname PE2
[PE2] ip vpn-instance aaa
[PE2-vpn-instance-aaa] route-distinguisher 100:1
[PE2-vpn-instance-aaa] vpn-target 200:1 both
[PE2-vpn-instance-aaa] quit
[PE2-LoopBack0] ipv6 address 5::5 128
[PE2-Ten-GigabitEthernet3/0/2] ip binding vpn-instance aaa
[PE2-Ten-GigabitEthernet3/0/2] ip address 20.1.1.2 30
[PE2-Ten-GigabitEthernet3/0/1] ipv6 address 45:1:1::2 126
[PE2] isis 1
[PE2-isis-1] is-level level-2
[PE2-isis-1] network-entity 00.0000.0000.0005.00
[PE2-isis-1] quit
[PE2-Ten-GigabitEthernet3/0/1] isis ipv6 enable 1
[PE2] segment-routing-ipv6
[PE2-segment-routing-ipv6] srv6 compress enable
[PE2-segment-routing-ipv6] locator e ipv6-prefix A:1:1:A:5:: 80 common-prefix 64 coc32 static 8 args 16
[PE2-segment-routing-ipv6-locator-e] opcode 16 end no-flavor
[PE2-segment-routing-ipv6-locator-e] quit
[PE2] isis 1
[PE2-isis-1-ipv6] segment-routing ipv6 locator e auto-sid-coc32
[PE2-isis-1-ipv6] srv6 compress enable
[PE2-isis-1] quit
[PE2-segment-routing-ipv6] encapsulation source-address 5::5
[PE2] bgp 100
[PE2-bgp-default] router-id 5.5.5.5
[PE2-bgp-default] ip vpn-instance aaa
[PE2-bgp-default-aaa] peer 20.1.1.1 as-number 20
[PE2-bgp-default-aaa] address-family ipv4 unicast
[PE2-bgp-default-ipv4-aaa] peer 20.1.1.1 enable
[PE2-bgp-default-ipv4-aaa] quit
[PE2-bgp-default-aaa] quit
# Enable exchange of End.DT4 SIDs between IPv6 peers on PE 2, and enable recursion of VPN routes to the SRv6 BE tunnel.
[PE2] bgp 100
[PE2-bgp-default-ipv4-aaa] segment-routing ipv6 locator e
[PE2-bgp-default-ipv4-aaa] segment-routing ipv6 best-effort
# Specify the local discriminator for the SBFD session on PE 2, and make sure it is the same as the remote discriminator on PE 1.
[PE2] sbfd local-discriminator 1000001
# On PE 1, execute the display segment-routing ipv6 te policy command to display detailed SRv6 TE policy information. Verify that the Status field for the SRv6 TE policy is Up, and the SID list state is Up.
[PE1] display segment-routing ipv6 te policy
Name/ID: a/0
Color: 10
End-point: 5::5
Name from BGP:
Name from PCE:
BSID:
Mode: Dynamic Type: Type_2 Request state: Succeeded
Current BSID: A:1:1:A:1:104:: Explicit BSID: - Dynamic BSID: A:1:1:A:1:104::
Reference counts: 5
Flags: A/BS/NC
Status: Up
AdminStatus: Up
Up time: 2023-08-04 16:21:25
Down time: 2023-08-04 16:13:02
Hot backup: Disabled
Statistics: Disabled
Statistics by service class: Disabled
Path verification: Not configured
Drop-upon-invalid: Disabled
BFD trigger path-down: Disabled
SBFD: Enabled
Encapsulation mode: -
Remote: 1000001
SBFD template name: -
SBFD backup template name: -
OAM SID: -
Reverse path type: None
BFD Echo: Disabled
BFD no-bypass: Disabled
Forward no-bypass: Disabled
Forwarding index: 2150629377
Association ID: 0
Service-class: -
Rate-limit: -
PCE delegation: Disabled
PCE delegate report-only: Disabled
Reoptimization: Disabled
Flapping suppression Remaining interval: -
Candidate paths state: Configured
Candidate paths statistics:
CLI paths: 1 BGP paths: 0 PCEP paths: 0 ODN paths: 0
Candidate paths:
Preference : 200
Network slice ID: -
CPathName:
CPathPolicyName:
ProtoOrigin: CLI Discriminator: 200
Instance ID: 0 Node address: 0.0.0.0
Originator: 0, ::
Optimal: Y Flags: V/A
Dynamic: Not configured
PCEP: Not configured
Explicit SID list:
ID: 1 Name: a
Weight: 1 Forwarding index: 2149580802
State: Up State(SBFD): Up
Verification State: -
Path MTU: 1500 Path MTU Reserved: 0
SID list flags: None
Local BSID: -
Reverse BSID: -
# On PE 1, execute the display bgp routing-table vpnv4 command to display detailed information about the route sent by PE 2. Verify that the route sent by PE 2 carries the PrefixSID attribute data, and the route is recursed to SRv6 TE policy tunnel a.
[PE1] display bgp routing-table vpnv4 22.22.22.22
Route distinguisher: 100:1(aaa)
BGP routing table information of 22.22.22.22/32:
Rely nexthop : FE80::1AF8:23FF:FE50:207
Original nexthop: 5::5
Route age : 03h52m50s
OutLabel : 3
Ext-Community : <RT: 200:1>, <CO-Flag:Color(00:10)>
RxPathID : 0x0
TxPathID : 0x0
PrefixSID : End.DT4 SID <A:1:1:A:5:104::>
SRv6 Service TLV (37 bytes):
Type: SRV6 L3 Service TLV (5)
Length: 34 bytes, Reserved: 0x0
SRv6 Service Information Sub-TLV (33 bytes):
Type: 1 Length: 30, Rsvdl: 0x0
SID Flags: 0x0 Endpoint behavior: 0x13 Rsvd2: 0x0
SRv6 SID Sub-Sub-TLV:
Type: 1 Len: 6
BL: 64 NL: 16 FL: 16 AL: 16 TL: 0 TO: 0
AS-path : 20
Origin : incomplete
State : valid, internal, best
Source type : local
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
Tunnel policy : a
Rely tunnel IDs : 2150629377
# On PE 1, execute the display ip routing-table vpn-instance command. Verify that VPN route 22.22.22.22 is available to CE 2, and the output interface for the route is SRv6 TE policy tunnel a.
Take PE 1 as an example:
[PE1] display ip routing-table vpn-instance aaa
Destinations : 8 Routes : 8
10.1.1.0/30 Direct 0 0 10.1.1.2 XGE3/0/1
10.1.1.2/32 Direct 0 0 127.0.0.1 XGE3/0/1
10.1.1.3/32 Direct 0 0 10.1.1.2 XGE3/0/1
11.11.11.11/32 BGP 255 0 10.1.1.1 XGE3/0/1
20.1.1.0/30 BGP 255 0 5::5 a
22.22.22.22/32 BGP 255 0 5::5 a
# From source IP address 11.11.11.11 on CE 1, ping destination IP address 22.22.22.22 on CE 2. Verify that the ping operation is successful. Capture packets on the forwarding interfaces of the devices such as PE 1 to verify that the second-, third-, and fourth-hop SIDs are all compressed to 32 bits in the static SID list of the SRH. Compression is implemented through G-SRv6.
Example: Configuring IPv4 L3VPN over G-SRv6 (with COC-both locators)
As shown in Figure 13, the backbone network is an IPv6 network, and VPN aaa is an IPv4 network. Deploy an SRv6 TE policy tunnel between PE 1 and PE 2 in the IPv6 network and use the SRv6 TE policy tunnel to transmit end-to-end VPN traffic.
· The SRv6 nodes in the backbone network use COC-both locators, and dynamically assign various types of SRv6 SIDs from the COC-both locators. Execute the display segment-routing ipv6 local-sid command on each SRv6 node to display local Srv6 SIDs. Add the SRv6 SIDs in the appropriate order to the SID list of the SRv6 TE policy.
· As shown in Figure 12, to prevent packet forwarding issues, appropriately plan the common prefix for the locators in the AS. Specify the common prefix as A:2:2:A:: with 64-bit length for COC-both locators on all devices. In addition, specify the IPv6 address prefix length for the locators as 80 bits, the compressible static portion length (C-SID Static) for COC-both locators as 8 bits, the non-compressible static portion length (NC-SID Static) as 8 bits, and the Args portion length as 16 bits. Through calculation, the compressible dynamic portion length (C-SID Dynamic) is 8 bits, and the non-compressible static portion length (NC-SID Static) is 8 bits.
· In the compressible SID (C-SID) range, you can dynamically assign or statically specify SIDs with the COC flag, for example, End(COC32) SIDs and End.X(COC32) SIDs. You can also dynamically assign or statically specify SIDs without the COC flag, for example, End(COCNONE) SIDs and End.X(COCNONE) SIDs. In the non-compressible SID (NC-SID) range, you can assign common SIDs, for example, End SIDs and End.X SIDs.
Figure 12 COC-both locator plan in the AS
Device |
Interfaces |
IP address |
Device |
Interfaces |
IP address |
CE 1 |
XGE3/0/1 |
10.1.1.1/30 |
CE 2 |
XGE3/0/2 |
20.1.1.1/30 |
Loop0 |
11.11.11.11/32 |
Loop0 |
22.22.22.22/32 |
PE 1 |
Loop0 |
1::1/128 |
PE 2 |
Loop0 |
5::5/128 |
XGE3/0/1 |
10.1.1.2/30 |
XGE3/0/2 |
20.1.1.2/30 |
XGE3/0/2 |
12:1:1::1/126 |
XGE3/0/1 |
45:1:1::2/126 |
P 1 |
Loop0 |
2::2/128 |
P 2 |
Loop0 |
3::3/128 |
XGE3/0/1 |
23:1:1::1/126 |
XGE3/0/1 |
23:1:1::2/126 |
XGE3/0/2 |
12:1:1::2/126 |
XGE3/0/2 |
34:1:1::1/126 |
P 3 |
Loop0 |
4::4/128 |
XGE3/0/1 |
45:1:1::1/126 |
XGE3/0/2 |
34:1:1::2/126 |
1. Configure CE 1:
<CE1> system-view
[CE1] sysname CE1
[CE1] bgp 10
2. Configure CE 2:
<CE2> system-view
[CE2] sysname CE2
[CE2] bgp 20
3. Configure PE 1:
<PE1> system-view
[PE1] sysname PE1
[PE1] isis 1
[PE1-isis-1] quit
[PE1-segment-routing-ipv6] locator ax ipv6-prefix A:2:2:A:1:: 80 common-prefix 64 coc-both non-compress-static 8 static 8 args 16
[PE1-segment-routing-ipv6-locator-ax] quit
[PE1] isis 1
[PE1-isis-1-ipv6] segment-routing ipv6 locator ax auto-sid-coc-both coc32
[PE1-isis-1] quit
¡ The first hop is the End.X(COC32) SID of the link from P 1 to P 2. The SRv6 SID in the encapsulated SRH is still 128 bits long without being compressed. The next SID will be compressed. After configuring P1, you can execute the display segment-routing ipv6 local-sid command to obtain information about dynamically allocated End.X(COC32) SIDs.
¡ The second hop is the End(COC32) SID of P 2. The SRv6 SID in the encapsulated SRH is compressed to 32 bits long. After configuring P 2, you can execute the display segment-routing ipv6 local-sid command to obtain information about dynamically allocated End(COC32) SIDs.
¡ The third hop is the End.X(COC32) SID of the link from P 3 to PE 2. The SRv6 SID in the encapsulated SRH is compressed to 32 bits long. After configuring P 3, you can execute the display segment-routing ipv6 local-sid command to obtain information about dynamically allocated End.X(COC32) SIDs.
¡ The fourth hop is the End SID of PE 2. The SRv6 SID in the encapsulated SRH is compressed to 32 bits long. The next SID will not be compressed. After configuring PE 2, you can execute the display segment-routing ipv6 local-sid command to obtain information about dynamically allocated End(COCNONE) SIDs.
[PE1-srv6-te] srv6-policy locator ax
[PE1-srv6-te] segment-list b
[PE1-srv6-te-sl-b] index 10 coc32 ipv6 A:2:2:A:2:10A:: 64
[PE1-srv6-te-sl-b] index 20 coc32 ipv6 A:2:2:A:3:101:: 64
[PE1-srv6-te-sl-b] index 30 coc32 ipv6 A:2:2:A:4:104:: 64
[PE1-srv6-te-sl-b] index 40 ipv6 A:2:2:A:5:103::
[PE1-srv6-te-sl-b] quit
[PE1-srv6-te-policy-a-path-pref-200] explicit segment-list b
[PE1-srv6-te] quit
[PE1] bgp 100
[PE1] bgp 100
[PE1-bgp-default-ipv4-aaa] segment-routing ipv6 locator ax
[PE1] bgp 100
4. Configure P 1:
[P1-LoopBack0] quit
[P1] isis 1
[P1-isis-1] quit
[P1-LoopBack0] quit
[P1-segment-routing-ipv6] locator bx ipv6-prefix A:2:2:A:2:: 80 common-prefix 64 coc-both non-compress-static 8 static 8 args 16
[P1-segment-routing-ipv6-locator-bx] quit
[P1] isis 1
[P1-isis-1-ipv6] segment-routing ipv6 locator bx auto-sid-coc-both coc32-all
[P1-isis-1] quit
5. Configure P 2:
[P2-LoopBack0] quit
[P2] isis 1
[P2-isis-1] quit
[P2-LoopBack0] quit
[P2-segment-routing-ipv6] locator cx ipv6-prefix A:2:2:A:3:: 80 common-prefix 64 coc-both non-compress-static 8 static 8 args 16
[P2-segment-routing-ipv6-locator-cx] quit
[P2] isis 1
[P2-isis-1-ipv6] segment-routing ipv6 locator cx auto-sid-coc-both all
[P2-isis-1] quit
6. Configure P 3:
[P3-LoopBack0] quit
[P3] isis 1
[P3-isis-1] quit
[P3-LoopBack0] quit
[P3-segment-routing-ipv6] locator dx ipv6-prefix A:2:2:A:4:: 80 common-prefix 64 coc-both non-compress-static 8 static 8 args 16
[P3-segment-routing-ipv6-locator-dx] quit
[P3] isis 1
[P3-isis-1-ipv6] segment-routing ipv6 locator dx auto-sid-coc-both coc32
[P3-isis-1] quit
7. Configure PE 2:
<PE2> system-view
[PE2] sysname PE2
[PE2] isis 1
[PE2-isis-1] quit
[PE2-segment-routing-ipv6] locator ex ipv6-prefix A:2:2:A:5:: 80 common-prefix 64 coc-both non-compress-static 8 static 8 args 16
[PE2] isis 1
[PE2-isis-1-ipv6] segment-routing ipv6 locator ex auto-sid-coc-both all
[PE2-isis-1] quit
[PE2] bgp 100
[PE2] bgp 100
[PE2-bgp-default-ipv4-aaa] segment-routing ipv6 locator ex
Name/ID: a/0
Color: 10
End-point: 5::5
Name from BGP:
Name from PCE:
BSID:
Current BSID: A:2:2:A:1:0:101:0 Explicit BSID: - Dynamic BSID: A:2:2:A:1:0:101:0
Reference counts: 5
Flags: A/BS/NC
Status: Up
AdminStatus: Up
Up time: 2023-08-06 16:31:34
Down time: 2023-08-06 16:29:20
SBFD: Enabled
Remote: 1000001
OAM SID: -
BFD Echo: Disabled
Forwarding index: 2150629378
Association ID: 0
Service-class: -
Rate-limit: -
Candidate paths:
Preference : 100
Network slice ID: -
CPathName:
CPathPolicyName:
ProtoOrigin: CLI Discriminator: 100
Originator: 0, ::
Explicit SID list:
ID: 2 Name: b
Weight: 1 Forwarding index: 2149580805
Local BSID: -
Reverse BSID: -
Route age : 00h28m35s
OutLabel : 3
RxPathID : 0x0
TxPathID : 0x0
PrefixSID : End.DT4 SID <A:2:2:A:5:0:106:0>
Type: 1 Len: 6
AS-path : 20
Origin : incomplete
Source type : local
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
Tunnel policy : a
Rely tunnel IDs : 2150629378
