- 03-Layer 2—LAN Switching Configuration Guide
- 01-MAC address table configuration
- 02-Ethernet link aggregation configuration
- 03-Port isolation configuration
- 04-VLAN configuration
- 05-MVRP configuration
- 06-QinQ configuration
- 07-VLAN mapping configuration
- 08-VLAN termination configuration
- 09-Loop detection configuration
- 10-Spanning tree configuration
- 11-LLDP configuration
| 08-VLAN termination configuration | 431.70 KB |
Common VLAN termination and user VLAN termination
VLAN termination application scenarios
Restrictions and guidelines: VLAN termination configuration
VLAN termination tasks at a glance
Configuring ambiguous Dot1q termination
Configuring common ambiguous Dot1q termination
Configuring ambiguous user VLAN Dot1q termination
Configuring unambiguous Dot1q termination
Configuring common unambiguous Dot1q termination
Configuring unambiguous user VLAN Dot1q termination
Configuring ambiguous QinQ termination
About ambiguous QinQ termination
Configuring ambiguous QinQ termination by specifying the outermost two layers of VLAN ID ranges
Configuring ambiguous QinQ termination by specifying the Layer 2 VLAN IDs
Configuring unambiguous QinQ termination
About unambiguous QinQ termination
Configuring unambiguous QinQ termination by specifying the outermost two layers of VLAN IDs
Configuring unambiguous QinQ termination by specifying the Layer 2 VLAN ID
Configuring untagged termination
Configuring default termination
Enabling a VLAN termination-enabled interface to transmit broadcasts and multicasts
Enabling user mode of VLAN termination
Configuring the TPID for VLAN-tagged packets
Display and maintenance commands for VLAN termination
VLAN termination configuration examples
Example: Configuring ambiguous Dot1q termination
Example: Configuring unambiguous Dot1q termination
Example: Configuring Dot1q termination for PPPoE server
Example: Configuring ambiguous QinQ termination
Example: Configuring unambiguous QinQ termination
Example: Configuring QinQ termination for PPPoE server (common VLAN termination)
Example: Configuring QinQ termination for PPPoE server (user VLAN termination)
Configuring VLAN termination
About VLAN termination
VLAN termination typically processes packets that include VLAN tags. A VLAN termination-enabled interface performs the following tasks when receiving a VLAN-tagged packet:
1. Assigns the packet to an interface according to its VLAN tags.
2. Removes the VLAN tags of the packet.
3. Delivers the packet to Layer 3 forwarding or other processing pipelines.
Before sending the packet, the VLAN termination-enabled interface determines whether to add new VLAN tags to the packet, based on the VLAN termination type.
VLAN termination can also process packets that do not include any VLAN tags.
This document uses the following VLAN tag concepts for a packet that has two or more layers of VLAN tags:
· Layer 1 VLAN tag—Specifies the outermost layer of VLAN tags.
· Layer 2 VLAN tag—Specifies the second outermost layer of VLAN tags.
The VLAN IDs of the packets are numbered in the same manner as the VLAN tags.
VLAN termination types
Types of packets to be terminated on the interface |
Tags of outgoing packets on the interface |
Dot1q termination |
The packets must meet both of the following requirements: · The packets include one or more layers of VLAN tags. · The outermost VLAN ID matches the configured value. |
Single-tagged |
QinQ termination |
The packets must meet both of the following requirements: · The packets include two or more layers of VLAN tags. · The outermost two layers of tags match the configured values. |
Double-tagged |
Untagged termination |
Untagged packets. |
Untagged |
Depending on creation methods of VLAN termination entries, Dot1q termination and QinQ termination on a subinterface can be implemented as follows:
· Common VLAN termination—Includes common Dot1q termination and common QinQ termination, which are configured by using the vlan-type dot1q vid and vlan-type dot1q vid second-dot1q commands, respectively. The device immediately creates entries to record VLAN termination information when these commands are executed.
· User VLAN termination—Includes user VLAN Dot1q termination, user VLAN QinQ termination, and user VLAN default termination, which are configured by using the user-vlan dot1q vid, user-vlan dot1q vid second-dot1q, and user-vlan dot1q default commands, respectively. The device dynamically creates entries for online users in the specified VLANs to save system resources.
User VLAN termination applies to user access scenarios with BRAS devices, for example, IPoE or PPPoE networks.
Common VLAN termination and user VLAN termination cannot be configured on the same subinterface.
The mechanism of user VLAN termination is similar to common VLAN termination. Unless otherwise specified, Dot1q termination and QinQ termination in this document are implemented in the common way.
VLAN termination mechanism
Subinterfaces (including Layer 3 Ethernet subinterfaces and Layer 3 aggregate subinterfaces) and VLAN interfaces can terminate packets whose outermost one or two layers of VLAN IDs match specific values. A VLAN interface terminates only the packets whose outermost VLAN ID is the same as the VLAN interface number. For example, VLAN-interface 10 terminates only the packets with the outermost VLAN tag 10.
A main interface does not terminate VLAN-tagged packets (for example, Layer 3 Ethernet interface or Layer 3 aggregate interface). To terminate VLAN-tagged packets, create subinterfaces for the main interface.
Subinterfaces of the same main interface can use different types of VLAN termination. To process received packets, the system selects a subinterface based on the following VLAN termination types in descending order of priority:
· QinQ termination.
· Dot1q termination or support for Dot1q termination by default.
· Untagged termination.
· Main interface.
If untagged termination is enabled on a subinterface of an interface, untagged packets are processed by the subinterface instead of the main interface. As a best practice, do not configure routing protocols such as OSPF on the main interface.
When a main interface is bound to a VLAN interface, the main interface processes VLAN-tagged packets according to the VLAN termination configuration of the VLAN interface.
Inter-VLAN communication
Hosts in different VLANs cannot directly communicate with each other. You can use Layer 3 routing to allow all VLANs to communicate.
As shown in Figure 1, Host A and Host B are in different VLANs. For the two hosts to communicate with each other, perform the following tasks:
1. Specify 1.1.1.1/24 and 1.1.2.1/24 as the gateway IP address for Host A and Host B, respectively.
2. On the device, configure Dot1q termination on Layer 3 Ethernet subinterfaces Subinterface A.2 and Subinterface A.3.
Figure 1 Inter-VLAN communication through Layer 3 subinterfaces
As shown in Figure 2, Host A is in VLAN 2, Host B is in VLAN 3, and Host C is in VLAN 4. For Host A and Host B to communicate with each other, perform the following tasks:
2. On the device, create VLAN-interface 2 and configure the IP address as 1.1.1.1/24, which is the same as the gateway address of Host A. Create VLAN-interface 3 and configure the IP address as 1.1.2.1/24, which is the same as the gateway address of Host B.
VLAN termination by the outermost VLAN ID of packets is automatically performed on VLAN interfaces. For example, when Host A sends a packet to Host B, VLAN-interface 2 removes the VLAN tag from the packet and forwards it to VLAN-interface 3. Then, VLAN-interface 3 tags the packet with VLAN 3 and Host B can receive the packet.
Because the device does not have a VLAN interface to terminate packets from VLAN 4, Host C cannot communicate with Host A or Host B.
Figure 2 Inter-VLAN communication through VLAN interfaces
LAN-WAN communication
Typically, WAN protocols such as PPP do not recognize VLAN-tagged packets from LANs. Before packets are sent to a WAN, the sending port must locally record the VLAN information and remove VLAN tags from the packets.
As shown in Figure 3, a host is located on a customer network and wants to access the WAN network through a PPPoE connection. CVLAN and SVLAN represent the VLAN on the customer network and service provider network, respectively.
To access the WAN network, a packet originating from the host is processed as follows:
1. Layer 2 Switch A adds a CVLAN tag to the packet and sends the packet.
2. Layer 2 Switch B adds an SVLAN tag to the packet on the QinQ-enabled port.
3. The packet is forwarded on the service provider network based on the SVLAN tag.
4. The gateway removes the two layers of VLAN tags from the packet and adds new VLAN tags on the QinQ termination-enabled port.
5. The gateway sends the packet to the WAN.
Figure 3 VLAN termination enables LAN-WAN communication
When you configure VLAN termination, follow these restrictions and guidelines:
· After you configure user VLAN QinQ termination on a subinterface of a Layer 3 aggregate interface with port mirroring configured, port mirroring does not take effect if no user accesses the network through the Layer 3 aggregate interface. For more information about port mirroring, see Network Management and Monioring Configuration Guide.
· By default, after you modify the common VLAN termination configuration for a subinterface, the subinterface flaps once. All dynamic ARP table entries for the subinterface are deleted. At the same time, another subinterface on the same main interface also flaps if it meets the following conditions:
¡ It terminates the same Layer 1 VLAN ID as the modified subinterface.
¡ It terminates any Layer 2 VLAN IDs.
For example, the vlan-type dot1q vid 200 second-dot1q 10 setting exists on subinterface A.2, and the vlan-type dot1q vid 200 second-dot1q any setting exists on subinterface A.3. If you modify the VLAN termination configuration on subinterface A.2, both subinterface A.2 and subinterface A.3 flap.
To avoid this issue, configure the vlan-termination user-mode command on the subinterface. For more information, see "Enabling user mode of VLAN termination".
· The user mode of VLAN termination is always enabled on a subinterface that is configured with user VLAN termination. You cannot disable this feature.
· If you configure QinQ termination on a VLAN interface, make sure packets received and forwarded on all ports in the VLAN associated with the VLAN interface carry a minimum of two VLAN layers. If this requirement is not met, packets cannot be correctly forwarded.
· As a best practice to avoid configuration conflicts, do not configure the user VLAN termination commands with any of the following commands on the same subinterface:
¡ The ip subscriber l2vpn-leased command to configure L2VPN-leased users.
¡ The ip subscriber routed enable command to enable IPoE and configure the Layer 3 access mode for IPv4 users.
· To ensure routing stability, do not configure two interconnected subinterfaces to terminate multiple Layer 1 VLAN IDs if they are running a routing protocol.
To configure VLAN termination, perform the following tasks:
1. (Required.) Configuring VLAN termination
¡ Configuring ambiguous Dot1q termination
¡ Configuring unambiguous Dot1q termination
¡ Configuring ambiguous QinQ termination
¡ Configuring unambiguous QinQ termination
¡ Configuring untagged termination
2. (Optional.) Enabling a VLAN termination-enabled interface to transmit broadcasts and multicasts
Perform this task to enable VLAN termination-enabled interfaces to transmit broadcasts and multicasts.
3. (Optional.) Enabling user mode of VLAN termination
Perform this task to prevent subinterface restart caused by VLAN termination setting modification.
4. (Optional.) Configuring the TPID for VLAN-tagged packets
Use this feature to terminate VLAN-tagged packets whose outermost VLAN IDs are in the specified range. Other VLAN-tagged packets are not allowed to pass.
When an interface receives a packet, it removes the outermost VLAN ID from the packet. When the interface sends a packet, it tags the packet with a VLAN ID as follows:
· For a PPPoE packet, the VLAN ID is from the matching PPPoE session entry.
· For a DHCP relay packet, the VLAN ID is from the matching DHCP session entry.
· For an IPv4 or MPLS packet, the VLAN ID is from the matching ARP entry.
1. Enter system view.
2. Enter interface view.
¡ Enter Layer 3 Ethernet subinterface view.
interface interface-type interface-number.subnumber
¡ Enter Layer 3 aggregate subinterface view.
interface route-aggregation interface-number.subnumber
¡ Enter L3VE subinterface view.
interface ve-l3vpn interface-number.subnumber
¡ Enter FlexE logical subinterface view.
interface flexe interface-number.subnumber
3. Configure ambiguous Dot1q termination.
vlan-type dot1q vid vlan-id-list
By default, Dot1q termination is disabled on a subinterface.
3. Configure ambiguous user VLAN Dot1q termination.
user-vlan dot1q vid vlan-id-list
By default, user VLAN Dot1q termination is disabled on a subinterface.
Use this feature to terminate only VLAN-tagged packets whose outermost VLAN ID matches the specified VLAN ID. Other VLAN-tagged packets are not allowed to pass.
When an interface receives a packet, it removes the outermost VLAN ID from the packet. When the interface sends a packet, it tags the packet with the specified VLAN ID.
¡ Enter L2VE subinterface view.
interface ve-l2vpn interface-number.subnumber
3. Configure unambiguous Dot1q termination.
3. Configure unambiguous user VLAN Dot1q termination.
Use this feature to terminate QinQ packets whose outermost two layers of VLAN IDs are in the specified range.
When an interface receives a packet, it removes the outermost two layers of VLAN tags from the packet. When the interface sends a packet, it tags the packet with the outermost two layers of VLAN IDs, which are determined as follows:
· For a PPPoE packet, VLAN IDs are from the matching PPPoE session entry.
· For a DHCP relay packet, VLAN IDs are from the matching DHCP relay entry.
· For an IPv4 or MPLS packet, VLAN IDs are from the matching ARP entry.
· If you specify the same Layer 1 VLAN ID for multiple subinterfaces of the same main interface, specify different Layer 2 VLAN IDs for them. However, if you specify different Layer 1 VLAN IDs for the subinterfaces, the Layer 2 VLAN IDs specified for the subinterfaces are not required to be different.
· Subinterfaces of different main interfaces can terminate VLAN-tagged packets with the same Layer 1 and Layer 2 VLAN IDs.
· If you execute the vlan-type dot1q vid second-dot1q or user-vlan dot1q vid second-dot1q command multiple times, all specified pairs of Layer 1 IDs and Layer 2 IDs in each execution take effect.
Configuring common ambiguous QinQ termination
3. Configure ambiguous QinQ termination by specifying the outermost two layers of VLAN ID ranges.
vlan-type dot1q vid vlan-id-list second-dot1q { vlan-id-list | any }
By default, QinQ termination is disabled on a subinterface.
Configuring ambiguous user VLAN QinQ termination
3. Configure ambiguous user VLAN QinQ termination by specifying the outermost two layers of VLAN ID ranges.
user-vlan dot1q vid vlan-id-list second-dot1q { vlan-id-list | any } [ loose ]
By default, user VLAN QinQ termination is disabled on a subinterface.
After you enable ambiguous QinQ termination on a VLAN interface, Layer 2 Ethernet interfaces bound to the VLAN interface operate as follows:
· Process only packets that match the ambiguous QinQ termination configuration of the VLAN interface.
· Drop any other packets sent to the VLAN interface.
2. Enter VLAN interface view.
3. Configure ambiguous QinQ termination by specifying the Layer 2 VLAN IDs.
By default, QinQ termination is disabled on an interface.
The Layer 1 VLAN ID of the VLAN-tagged packets that can be terminated by the subinterface or VLAN interface is the number of the subinterface or VLAN interface. This Layer 1 VLAN ID is not configurable.
Use this feature to terminate QinQ packets whose outermost two layers of VLAN IDs match the specified values.
When an interface receives a packet, it removes the two layers of VLAN tags from the packet. When the interface sends the packet, it tags the packet with two layers of VLAN tags as specified.
Configuring common unambiguous QinQ termination by specifying the outermost two layers of VLAN IDs
3. Configure unambiguous QinQ termination by specifying the outermost two layers of VLAN IDs.
vlan-type dot1q vid vlan-id second-dot1q vlan-id
Configuring unambiguous user VLAN QinQ termination by specifying the outermost two layers of VLAN IDs
3. Configure unambiguous user QinQ termination by specifying the outermost two layers of VLAN IDs.
user-vlan dot1q vid vlan-id second-dot1q vlan-id
After you enable unambiguous QinQ termination on a VLAN interface, Layer 2 Ethernet interfaces bound to the VLAN interface operate as follows:
· Process only packets that match the unambiguous QinQ termination configuration of the VLAN interface.
¡ Enter VLAN interface view.
3. Configure unambiguous QinQ termination by specifying the Layer 2 VLAN ID.
3. Configure untagged termination.
vlan-type dot1q untagged
By default, untagged termination is disabled on a subinterface.
To avoid configuration conflicts, do not configure default termination in combination with the following features on a subinterface:
· MPLS L2VPN. For more information about MPLS L2VPN, see MPLS L2VPN configuration in MPLS Configuration Guide.
· VPLS. For more information about VPLS, see VPLS configuration in MPLS Configuration Guide.
· Layer 2 forwarding on the main interface of the subinterface.
You cannot configure default termination and other VLAN termination methods simultaneously on the same subinterface.
You cannot configure default termination and common ambiguous QinQ termination simultaneously for different subinterfaces.
3. Configure user VLAN default termination.
By default, user VLAN default termination is disabled on a subinterface.
After you configure Dot1q/ QinQ termination on an interface to terminate packets of multiple VLANs, the interface drops broadcast and multicast packets by default. Use this feature to enable the interface to transmit broadcasts and multicasts.
To transmit a broadcast or multicast packet, the interface starts a traversal over all the VLAN IDs specified for Dot1q/QinQ termination. It copies the packet and tags each copy with VLAN IDs, until all combinations of VLAN IDs are traversed. For example, when ambiguous QinQ termination is configured, both layers of VLAN ID ranges are traversed.
You must use the vlan-termination broadcast ra command to enable an ambiguous Dot1q or QinQ termination-enabled interface to transmit RA multicast packets on an IPv6 network. This command prohibits transmission of broadcast packets and other types of multicast packets, and consumes less CPU resources than the vlan-termination broadcast enable command.
When you execute the vlan-termination broadcast ra command on an interface, configure the undo ipv6 nd ra halt command to allow the interface to advertise RA messages. For more information about the undo ipv6 nd ra halt command, see Layer 3—IP Services Command Reference.
3. Enable the interface to transmit broadcasts and multicasts.
¡ Enable the interface to transmit broadcasts and multicasts.
¡ Enable the interface to transmit only RA multicasts on an IPv6 network.
By default, broadcast and multicast packets are dropped on an interface configured with Dot1q/QinQ termination to terminate packets of multiple VLANs.
If user mode of VLAN termination is disabled on a subinterface, the subinterface automatically restarts after you modify its VLAN termination settings. In some networks (for example, networks using IPoE or PPPoE connections), the subinterface restart logs off online users. To prevent the subinterface restart and protect the online user state, enable user mode of VLAN termination before you modify VLAN termination on the subinterface.
After you enable user mode of VLAN termination and modify VLAN termination on a subinterface, clear entries of VLANs that are no longer terminated by the subinterface. If you do not clear these entries, running services might be affected.
For example, after you modify VLAN termination on a subinterface, perform the following tasks for the subinterface:
· Use the reset arp interface command in user view to clear all ARP entries.
· Use the reset ipv6 neighbors interface command in user view to clear all dynamic neighbors.
For more information about the reset arp and reset ipv6 neighbors commands, see ARP and IPv6 basics commands in Layer 3—IP Services Command Reference.
3. Enable user mode of VLAN termination.
By default, user mode of VLAN termination is disabled.
TPID identifies whether or not a frame contains VLAN tags. By default, the value of 0x8100 identifies an IEEE 802.1Q-tagged frame. You can set another TPID value to identify VLAN-tagged packets.
To work with VLAN termination on a subinterface, set the TPID value in the outermost VLAN tag of packets on the main interface of the subinterface. If VLAN termination is enabled on a VLAN interface, set the TPID value in the outermost VLAN tag of packets on the same VLAN interface.
The interface processes packets as untagged packets if their outermost VLAN tag is not 0x8100 or the configured value.
When sending a packet, the interface sets the TPID value in the outermost VLAN tag to the configured value. If the packet includes two or more layers of VLAN tags, the interface sets the TPID values to 0x8100 in all VLAN tags except the outermost VLAN tag.
The main interface of a subinterface cannot modify the TPID value in the outermost VLAN tag of the ARP packets sent by the subinterface when the following conditions exist on the subinterface:
· The vlan-termination broadcast enable command is executed.
· The vlan-type dot1q vid second-dot1q or user-vlan dot1q vid second-dot1q command is executed with the any keyword.
¡ Enter Layer 3 Ethernet interface view.
¡ Enter Layer 3 aggregate interface view.
This feature is not configurable in subinterface view. Configurations made on a main interface (Layer 3 interface for example) take effect on all subinterfaces of the interface.
3. Set the TPID value in the outermost VLAN tag of packets received and sent by the interface.
dot1q ethernet-type hex-value
The default setting is 0x8100.
Task |
Command |
Display user VLAN termination information. |
display user-vlan interface interface-type interface-number.subnumber [ slot slot-number ] |
Display information about VLAN terminated-enabled interfaces. |
display subinterface interface-type interface-number dot1q vid vlan-id [ second-dot1q vlan-id ] |
Unless otherwise specified, the configuration examples are applicable to common VLAN termination. To configure user VLAN termination, change the vlan-type keyword in VLAN termination commands to user-vlan.
As shown in Figure 4, configure ambiguous Dot1q termination so that hosts in different VLANs can communicate with the server group.
In this example, L2 Switch B uses the factory configuration.
1. Configure Host A, Host B, and Host C:
# Assign 1.1.1.1/24, 1.1.1.2/24, and 1.1.1.3/24 to Host A, Host B, and Host C, respectively. (Details not shown.)
# Specify 1.1.1.11/24 as the gateway IP address for the hosts. (Details not shown.)
2. Configure Layer 2 Switch A:
# Create VLAN 11.
<L2_SwitchA> system-view
[L2_SwitchA] vlan 11
# Assign GigabitEthernet 1/0/1 to VLAN 11.
[L2_SwitchA-vlan11] port gigabitethernet 1/0/1
[L2_SwitchA-vlan11] quit
# Create VLAN 12.
[L2_SwitchA] vlan 12
# Assign GigabitEthernet 1/0/2 to VLAN 12.
[L2_SwitchA-vlan12] port gigabitethernet 1/0/2
[L2_SwitchA-vlan12] quit
# Create VLAN 13.
[L2_SwitchA] vlan 13
# Assign GigabitEthernet 1/0/3 to VLAN 13.
[L2_SwitchA-vlan13] port gigabitethernet 1/0/3
[L2_SwitchA-vlan13] quit
# Configure Ten-GigabitEthernet 1/0/4 as a trunk port and assign the port to VLANs 11 through 13.
[L2_SwitchA] interface ten-gigabitethernet 1/0/4
[L2_SwitchA-Ten-GigabitEthernet1/0/4] port link-type trunk
[L2_SwitchA-Ten-GigabitEthernet1/0/4] port trunk permit vlan 11 to 13
3. Configure the device:
# Create Ethernet subinterface Ten-GigabitEthernet 3/0/1.10 and assign an IP address to the subinterface.
[Device] interface ten-gigabitethernet 3/0/1.10
[Device-Ten-GigabitEthernet3/0/1.10] ip address 1.1.1.11 255.255.255.0
# Enable Dot1q termination on Ten-GigabitEthernet 3/0/1.10 to terminate VLAN-tagged packets whose Layer 1 VLAN IDs are 11, 12, or 13.
[Device-Ten-GigabitEthernet3/0/1.10] vlan-type dot1q vid 11 to 13
# Enable Ten-GigabitEthernet 3/0/1.10 to transmit broadcasts and multicasts.
[Device-Ten-GigabitEthernet3/0/1.10] vlan-termination broadcast enable
[Device-Ten-GigabitEthernet3/0/1.10] quit
# Configure an IP address for Ten-GigabitEthernet 3/0/2.
[Device] interface ten-gigabitethernet 3/0/2
[Device-Ten-GigabitEthernet3/0/2] ip address 1.1.2.11 255.255.255.0
4. Configure the server group:
# Assign each device in the server group an IP address on network segment 1.1.2.0/24. (Details not shown.)
# Specify 1.1.2.11/24 as the gateway IP address for the server group. (Details not shown.)
# Verify that Host A, Host B, and Host C can ping the device in the server group. (Details not shown.)
As shown in Figure 5, configure unambiguous Dot1q termination on subinterfaces of the device to implement intra-VLAN and inter-VLAN communications between hosts.
1. Configure Host A, Host B, Host C, and Host D:
# On Host A, specify 1.1.1.1/8 and 1.0.0.1/8 as its IP address and gateway IP address, respectively. (Details not shown.)
# On Host B, specify 2.2.2.2/8 and 2.0.0.1/8 as its IP address and gateway IP address, respectively. (Details not shown.)
# On Host C, specify 3.3.3.3/8 and 3.0.0.1/8 as its IP address and gateway IP address, respectively. (Details not shown.)
# On Host D, specify 4.4.4.4/8 and 4.0.0.1/8 as its IP address and gateway IP address, respectively. (Details not shown.)
# Create VLAN 10.
[L2_SwitchA] vlan 10
# Assign GigabitEthernet 1/0/2 to VLAN 10.
[L2_SwitchA-vlan10] port gigabitethernet 1/0/2
[L2_SwitchA-vlan10] quit
# Create VLAN 20.
[L2_SwitchA] vlan 20
# Assign GigabitEthernet 1/0/3 to VLAN 20.
[L2_SwitchA-vlan20] port gigabitethernet 1/0/3
[L2_SwitchA-vlan20] quit
# Configure Ten-GigabitEthernet 1/0/1 as a trunk port, and assign the port to VLANs 10 and 20.
[L2_SwitchA] interface ten-gigabitethernet 1/0/1
[L2_SwitchA-Ten-GigabitEthernet1/0/1] port link-type trunk
[L2_SwitchA-Ten-igabitEthernet1/0/1] port trunk permit vlan 10 20
3. Configure Layer 2 Switch B in the same way you configure Layer 2 Switch A. (Details not shown.)
4. Configure the device:
# Create Ten-GigabitEthernet 3/0/1.10 and assign an IP address to this interface.
[Device-Ten-GigabitEthernet3/0/1.10] ip address 1.0.0.1 255.0.0.0
# Configure Ten-GigabitEthernet 3/0/1.10 to terminate packets tagged with VLAN 10.
[Device-Ten-GigabitEthernet3/0/1.10] vlan-type dot1q vid 10
# Create Ten-GigabitEthernet 3/0/1.20 and assign an IP address to this interface.
[Device] interface ten-gigabitethernet 3/0/1.20
[Device-Ten-GigabitEthernet3/0/1.20] ip address 2.0.0.1 255.0.0.0
# Configure Ten-GigabitEthernet 3/0/1.20 to terminate packets tagged with VLAN 20.
[Device-Ten-GigabitEthernet3/0/1.20] vlan-type dot1q vid 20
[Device-Ten-GigabitEthernet3/0/1.20] quit
# Configure Ten-GigabitEthernet 3/0/2.10 and assign an IP address to this interface.
[Device] interface ten-gigabitethernet 3/0/2.10
[Device-Ten-GigabitEthernet3/0/2.10] ip address 3.0.0.1 255.0.0.0
# Configure Ten-GigabitEthernet 3/0/2.10 to terminate packets tagged with VLAN 10.
[Device-Ten-GigabitEthernet3/0/2.10] vlan-type dot1q vid 10
[Device-Ten-GigabitEthernet3/0/2.10] quit
# Configure Ten-GigabitEthernet 3/0/2.20 and assign an IP address to this interface.
[Device] interface ten-gigabitethernet 3/0/2.20
[Device-Ten-GigabitEthernet3/0/2.20] ip address 4.0.0.1 255.0.0.0
# Configure Ten-GigabitEthernet 3/0/2.20 to terminate packets tagged with VLAN 20.
[Device-Ten-GigabitEthernet3/0/2.20] vlan-type dot1q vid 20
# Verify that Host A, Host B, Host C, and Host D can ping each other. (Details not shown.)
As shown in Figure 6, the router acts as a PPPoE server. Hosts in different VLANs access the Internet through the PPPoE server.
Configure Dot1q termination so that hosts in different VLANs can access the Internet.
# Configure VLANs and Dot1q termination. For the configuration procedure, see "Example: Configuring ambiguous Dot1q termination." (Details not shown.)
# Configure the router as the PPPoE server. Configure PPPoE settings on Ten-GigabitEthernet 3/0/1.10 on the router. For more information about the PPPoE configuration, see BRAS Services Configuration Guide. (Details not shown.)
As shown in Figure 7, QinQ is enabled on GigabitEthernet 1/0/2 of Layer 2 Switch B.
Configure ambiguous QinQ termination, so that hosts can communicate with the server group.
In this example, Layer 2 Switch C uses the factory configuration.
# Assign the IP addresses 1.1.1.1/24, 1.1.1.2/24, and 1.1.1.3/24 to Host A, Host B, and Host C, respectively. (Details not shown.)
# Specify 1.1.1.11/24 as the gateway address for the hosts. (Details not shown.)
# Create VLAN 11.
# Create VLAN 12.
# Create VLAN 13.
# Configure GigabitEthernet 1/0/4 as a trunk port, and assign the port to VLANs 11 through 13.
[L2_SwitchA] interface gigabitethernet 1/0/4
[L2_SwitchA-GigabitEthernet1/0/4] port link-type trunk
[L2_SwitchA-GigabitEthernet1/0/4] port trunk permit vlan 11 to 13
3. Configure Layer 2 Switch B:
# Configure GigabitEthernet 1/0/2 as a trunk port, and assign the port to VLANs 11 through 13 and VLAN 100.
<L2_SwitchB> system-view
[L2_SwitchB] interface gigabitethernet 1/0/2
[L2_SwitchB-GigabitEthernet1/0/2] port link-type trunk
[L2_SwitchB-GigabitEthernet1/0/2] port trunk permit vlan 11 to 13 100
# Set the PVID of GigabitEthernet 1/0/2 to VLAN 100.
[L2_SwitchB-GigabitEthernet1/0/2] port trunk pvid vlan 100
# Enable QinQ on GigabitEthernet 1/0/2.
[L2_SwitchB-GigabitEthernet1/0/2] qinq enable
[L2_SwitchB-GigabitEthernet1/0/2] quit
# Configure GigabitEthernet 1/0/1 as a trunk port and assign the port to VLAN 100.
[L2_SwitchB] interface gigabitethernet 1/0/1
[L2_SwitchB-GigabitEthernet1/0/1] port link-type trunk
[L2_SwitchB-GigabitEthernet1/0/1] port trunk permit vlan 100
4. Configure the router:
<Router> system-view
[Router] interface ten-gigabitethernet 3/0/1.10
[Router-Ten-GigabitEthernet3/0/1.10] ip address 1.1.1.11 255.255.255.0
# Configure Ten-GigabitEthernet 3/0/1.10 to terminate VLAN-tagged packets whose Layer 1 VLAN ID is 100 and Layer 2 VLAN ID is 11, 12, or 13.
[Router-Ten-GigabitEthernet3/0/1.10] vlan-type dot1q vid 100 second-dot1q 11 to 13
[Router-Ten-GigabitEthernet3/0/1.10] vlan-termination broadcast enable
[Router-Ten-GigabitEthernet3/0/1.10] quit
# Assign an IP address to Ten-GigabitEthernet 3/0/2.
[Router] interface ten-gigabitethernet 3/0/2
[Router-Ten-GigabitEthernet3/0/2] ip address 1.1.2.11 255.255.255.0
5. Configure the server group:
# Verify that Host A, Host B, and Host C can ping the server group. (Details not shown.)
As shown in Figure 8:
· Layer 2 Switch C supports only single VLAN-tagged packets.
· On Layer 2 Switch B, GigabitEthernet 1/0/2 is enabled with QinQ to add an SVLAN tag 100 to the packets with CVLAN ID 11.
Configure unambiguous QinQ termination so that Host A can communicate with Host B.
1. Configure Host A and Host B:
# On Host A, specify 1.1.1.1/24 and 1.1.1.11/24 as its IP address and gateway IP address, respectively. (Details not shown.)
# On Host B, specify 1.1.2.1/24 and 1.1.2.11/24 as its IP address and gateway IP address, respectively. (Details not shown.)
# Create VLAN 11.
# Assign GigabitEthernet 1/0/2 to VLAN 11.
[L2_SwitchA-vlan11] port gigabitethernet 1/0/2
# Configure GigabitEthernet 1/0/1 as a trunk port and assign the port to VLAN 11.
[L2_SwitchA] interface gigabitethernet 1/0/1
[L2_SwitchA-GigabitEthernet1/0/1] port link-type trunk
[L2_SwitchA-GigabitEthernet1/0/1] port trunk permit vlan 11
# Configure GigabitEthernet 1/0/2 as a trunk port and assign the port to VLAN 11 and VLAN 100.
[L2_SwitchB-GigabitEthernet1/0/2] port trunk permit vlan 11 100
# Enable QinQ termination on Ten-GigabitEthernet 3/0/1.10 to terminate the VLAN-tagged packets with the Layer 1 VLAN ID 100 and the Layer 2 VLAN ID 11.
# Verify that Host A and Host B can ping each other. (Details not shown.)
As shown in Figure 9:
· QinQ is enabled on GigabitEthernet 1/0/2 of Layer 2 Switch B.
· The router acts as a PPPoE server. Hosts in different VLANs access the Internet through the PPPoE server.
Configure QinQ termination, so that the hosts can access the Internet.
# Configure VLANs and QinQ termination. For the configuration procedure, see "Example: Configuring ambiguous QinQ termination." (Details not shown.)
# Configure the router as the PPPoE server. Configure PPPoE settings on Ten-GigabitEthernet 3/0/1.10 on the router. For more information about PPPoE configuration, see BRAS Services Configuration Guide.(Details not shown.)
As shown in Figure 10:
Configure user VLAN QinQ termination to dynamically create QinQ termination entries to save system resources.
# Create VLAN 11.
# Create VLAN 12.
# Create VLAN 13.
# Create Layer 3 Ethernet subinterface Ten-GigabitEthernet 3/0/1.10.
# Configure PPPoE parameters on Layer 3 Ethernet subinterface Ten-GigabitEthernet 3/0/1.10.For more information, see PPPoE configuration in BRAS Services Configuration Guide. (Details not shown.)
# Enable PPPoE server on Layer 3 Ethernet subinterface Ten-GigabitEthernet 3/0/1.10, and bind to an existing VT interface. (This example use Virtual-Template 1).
[Router-Ten-GigabitEthernet3/0/1.10] pppoe-server bind virtual-template 1
# Configure user VLAN QinQ termination on Ten-GigabitEthernet 3/0/1.10 to terminate VLAN-tagged packets whose Layer 1 VLAN ID is 100 and Layer 2 VLAN ID is 11, 12, or 13.
[Router-Ten-GigabitEthernet3/0/1.10] user-vlan dot1q vid 100 second-dot1q 11 to 13
# Assign an IP address to Layer 3 interface Ten-GigabitEthernet 3/0/2.
Example: Configuring QinQ termination for DHCP relay
As shown in Figure 11:
· Provider A and Provider B are edge devices on the service provider network.
· DHCP client A and DHCP client B are devices on the customer networks.
· Provider A is the DHCP relay agent. Provider B is the DHCP server.
· Provider A and Provider B communicate with each other through Layer 3 interfaces.
Configure QinQ termination on Provider A so that DHCP client A and DHCP client B can obtain IP settings from Provider B.
1. Configure the DHCP relay agent Provider A:
# Enable DHCP service.
<ProviderA> system-view
[ProviderA] dhcp enable
# Create a Layer 3 Ethernet subinterface Ten-GigabitEthernet 3/0/1.100.
[ProviderA] interface ten-gigabitethernet 3/0/1.100
# Configure Ten-GigabitEthernet 3/0/1.100 to terminate packets whose Layer 1 ID is 100 and Layer 2 VLAN ID is 10 or 20.
[ProviderA-Ten-GigabitEthernet3/0/1.100] vlan-type dot1q vid 100 second-dot1q 10 20
# Enable Ten-GigabitEthernet 3/0/1.100 to transmit broadcast and multicast packets.
[ProviderA-Ten-GigabitEthernet3/0/1.100] vlan-termination broadcast enable
# Enable DHCP relay on Ten-GigabitEthernet 3/0/1.100 and specify 10.2.1.1 as the DHCP server address.
[ProviderA-Ten-GigabitEthernet3/0/1.100] dhcp select relay
[ProviderA-Ten-GigabitEthernet3/0/1.100] dhcp relay server-address 10.2.1.1
# Assign an IP address to Ten-GigabitEthernet 3/0/1.100.
[ProviderA-Ten-GigabitEthernet3/0/1.100] ip address 192.168.1.1 24
[ProviderA-Ten-GigabitEthernet3/0/1.100] quit
# Enable recording of relay entries on the relay agent.
[ProviderA] dhcp relay client-information record
[ProviderA] interface ten-gigabitethernet 3/0/2
[ProviderA-Ten-GigabitEthernet3/0/2] ip address 10.1.1.1 24
[ProviderA-Ten-GigabitEthernet3/0/2] quit
# Configure a static route to the DHCP server.
[ProviderA] ip route-static 10.2.1.1 24 10.1.1.1
2. Configure the DHCP server Provider B:
# Assign an IP address to the DHCP server.
<ProviderB> system-view
[ProviderB] interface ten-gigabitethernet 3/0/2
[ProviderB-Ten-GigabitEthernet3/0/2] ip address 10.2.1.1 24
[ProviderB-Ten-GigabitEthernet3/0/2] quit
# Enable DHCP.
[ProviderB] dhcp enable
# Configure an IP address pool on the DHCP server.
[ProviderB] ip pool 1
[ProviderB-ip-pool-1] network 192.168.1.0 24
[ProviderB-ip-pool-1] gateway-list 192.168.1.1
[ProviderB-ip-pool-1] quit
# Configure a static route to Ten-GigabitEthernet 3/0/1.100.
[ProviderB] ip route-static 192.168.1.1 24 10.1.1.1
3. Configure Switch A:
# Configure the uplink port (Ten-GigabitEthernet 1/0/1) as a trunk port and assign the port to VLAN 100.
[SwitchA] interface ten-gigabitethernet 1/0/1
[SwitchA-Ten-GigabitEthernet1/0/1] port link-type trunk
[SwitchA-Ten-GigabitEthernet1/0/1] port trunk permit vlan 100
[SwitchA-Ten-GigabitEthernet1/0/1] quit
# Configure downlink port GigabitEthernet 1/0/2 as a trunk port, and assign the port to VLANs 10 and 100.
[SwitchA] interface gigabitethernet 1/0/2
[SwitchA-GigabitEthernet1/0/2] port link-type trunk
[SwitchA-GigabitEthernet1/0/2] port trunk permit vlan 10 100
[SwitchA-GigabitEthernet1/0/2] port trunk pvid vlan 100
[SwitchA-GigabitEthernet1/0/2] qinq enable
[SwitchA-GigabitEthernet1/0/2] quit
# Configure downlink port GigabitEthernet 1/0/3 as a trunk port, and assign the port to VLANs 20 and 100.
[SwitchA] interface gigabitethernet 1/0/3
[SwitchA-GigabitEthernet1/0/3] port link-type trunk
[SwitchA-GigabitEthernet1/0/3] port trunk permit vlan 20 100
# Set the PVID of GigabitEthernet 1/0/3 to VLAN 100.
[SwitchA-GigabitEthernet1/0/3] port trunk pvid vlan 100
# Enable QinQ on GigabitEthernet 1/0/3.
[SwitchA-GigabitEthernet1/0/3] qinq enable
4. Configure Switch B:
# Create VLAN 10.
[SwitchB] vlan 10
[SwitchB-vlan10] port gigabitethernet 1/0/2
[SwitchB-vlan10] quit
# Configure GigabitEthernet 1/0/1 as a trunk port and assign the port to VLAN 10.
[SwitchB-GigabitEthernet1/0/1] port link-type trunk
[SwitchB-GigabitEthernet1/0/1] port trunk permit vlan 10
5. Configure Switch C:
# Create VLAN 20.
[SwitchC] vlan 20
# Assign GigabitEthernet 1/0/2 to VLAN 20.
[SwitchC-vlan20] port gigabitethernet 1/0/2
[SwitchC-vlan20] quit
# Configure GigabitEthernet 1/0/1 as a trunk port and assign the port to VLAN 20.
[SwitchC] interface gigabitethernet 1/0/1
[SwitchC-GigabitEthernet1/0/1] port link-type trunk
[SwitchC-GigabitEthernet1/0/1] port trunk permit vlan 20
# Verify that DHCP client A and DHCP client B can obtain IP settings from Provider B. (Details not shown.)
