16-Telemetry Command Reference
HomeSupportRoutersCR16000-M SeriesReference GuidesCommand ReferencesH3C CR16000-M Routers Command Reference-R838x-6W10116-Telemetry Command Reference
Table of Contents
Related Documents
01-gRPC commands
01-gRPC commands 220.32 KB
gRPC commands
Generic gRPC commands
display grpc
Use display grpc to display gRPC dial-in mode information.
display grpc [ verbose ]
verbose: Display detailed gRPC information. If you do not specify this keyword, the command displays brief gRPC information.
# Display brief gRPC information.
<Sysname> display grpc
gRPC status : Enabled
PKI domain : --
Current-time: 2021-08-20T17:53:12.880
------------Dial-in mode information------------
gRPC server port: 50051
Session idle-timeout: 5 minutes
Session count: 0
  ID         IP Address:Port                  UserName
   1         192.1.11.254:53030               test
------------Dial-out mode information-----------
Sensor mode: Simple
Sensor group count: 1
Sensor path count: 1
Destination group count: 1
Destination count: 1
Subscription count: 1
Connection ID: 1
  IP address:Port: 1.1.1.1:50051
   Encoding: JSON
   Status: Idle
gRPC status
Status of the gRPC service:
·     Enabled—The gRPC service is enabled.
·     Disabled—The gRPC service is disabled.
PKI domain
PKI domain for secure gRPC connections to collectors.
This field displays a hyphen (-) if no PKI domain has been specified by using the grpc pki domain command.
Current-time
Current system time.
Information about gRPC in dail-in mode.
gRPC server port
Port number for the gRPC service.
gRPC session idle timeout timer, in minutes.
Session count
Number of gRPC sessions.
ID
ID of a gRPC session.
IP Address:Port
IP address and port number of the gRPC client.
UserName
Username of the gRPC user.
Information about gRPC in dial-out mode.
Sensor mode
Sensor mode:
·     flex—Flexible sensor mode.
·     simple—Simple sensor mode.
Sensor group count
Number of sensor groups.
Sensor path count
Number of sensor paths.
Number of destination groups.
Destination count
Number of collectors.
Subscription count
Number of subscriptions.
Connection ID
ID of the connection between the device and a collector.
IP address:Port
IP address and port number of the collector.
Encoding
Encoding format for data packets sent to the controller. Available options are JSON and GPB.
Status
State of the channel between the device and the collector:
·     Init—The channel is being initialized.
·     Idle—The channel is idle.
·     Connecting—The channel is being established.
·     Connected—The channel has been established.
·     Transient failure—The channel has failed transiently and is attempting to recover.
·     Shutdown—The channel has been closed because of an issue.
# Display detailed gRPC information.
<Sysname> display grpc verbose
PKI domain : --
Current-time: 2021-08-20T17:51:28.846
Session count: 1
  Session ID: 1
    User name: test
    Login time:2020-05-19 16:40:16     Idle time : 3 mins 41 s
    Client IP address : 192.1.11.254:53030
    Received RPCs        : 39        Received erroneous RPCs : 6
    Received subscription: 0         Sent notifications: 0
Sensor mode: Simple
Subscription s
Subscription mode: non-gNMI
DSCP value: 0
Source address or interface: Not configured
Telemetry data model:  2-layer
Encoding: JSON
Protocol: GRPC
Sensor group: s
  Sampling interval: 10 seconds
  Sampling type         Effective sampling interval   Sensor path
  Periodic              10 seconds                    ifmgr/statistics
Destination group: d
  Start time: 2021-08-20T17:51:24.377
  IP:Port: 1.1.1.1:50051
    VPN: N/A
    Connection state: Idle
    Periodic sampling statistics:
      Effective count: 0
      Sent successfully: 0                  Failed: 0
    Event-triggered statistics:
      Effective count: 0
    Queued packets/Queue size: 0/1000
    Total sent bytes: 0
    Total delayed packets: 0
    Total dropped packets: 0
    Last sent time: N/A
    Heartbeat interval: 0s
    Last error: --
gRPC status
PKI domain
PKI domain for securing gRPC connections to collectors.
Current-time
Information about gRPC in dial-in mode.
gRPC server port
Session count
Session ID
User name
Login time
Date and time when the gRPC user logged in to the device.
Idle time
Amount of time in which the session idle timeout timer will expire. If the value in this field is 0, gRPC sessions will never time out.
Client IP address
Received RPCs
Number of received gRPC requests.
Number of received erroneous gRPC requests.
Number of received gRPC subscription requests.
Sent notifications
Number of gRPC notifications reported to the collector.
Sensor mode
Sensor mode:
Sensor group count
Sensor path count
Destination count
Subscription count
Subscription
Name of the subscription.
Subscription mode
Supported subscription mode. The current software version supports only non-gNMI subscription.
DSCP value
DSCP value of packets sent to the collector.
Source-address or interface
Source IP address or source interface for packets sent to the collector.
This field displays not-config if no source IP address or source interface has been specified.
Telemetry data model architecture for gRPC.
Options:
·     2-layer—Two-layer telemetry data model architecture.
·     3-layer—Three-layer telemetry data model architecture.
Encoding
Encoding format for packets sent to the controller. Available options are JSON and GPB.
Protocol
Transport protocol.
Available options:
·     gRPC (TCP).
·     UDP.
Sensor-group
Name of the sensor group.
Sampling interval
User-configured data sampling and push interval, in seconds.
This field displays 0 for event-triggered sampling.
Sampling type
Data sampling type:
·     Event-triggered—Event-triggered sampling.
·     Periodic—Periodical sampling.
The data sampling and push interval that actually takes effect.
Sensor path
Sensor path.
Destination group
Name of the destination group.
Start time
Date and time when the gRPC connection was established.
IP:Port
IP address and port number of the collector (gRPC server).
VPN
VPN instance to which the collector belongs.
This field displays N/A if the collector belongs to the public network.
Connection state
State of the gRPC connection between the device and the collector:
·     Idle—The connection has not been established.
·     Established—The connection has been established.
Statistics for periodic sampling.
Statistics for event-triggered sampling.
Effective count
Number of effective samplings. This counter does not count a sampling if it does not collect any data.
Sent successfully
Number of successfully sent data packets.
Failed
Number of data packets failed to be sent.
Number of data packets waiting for transmission in queue and the size of the queue.
Total sent bytes
Total number of sent bytes.
Total number of packets delayed for transmission.
Number of data packets dropped because the queue was full.
Last sent time
Date and time when the most recent packet transmission occurred.
Heartbeat interval
Keepalive interval (in seconds) on the gRPC channel. This parameter is not configurable in the current software version. A value of 0 indicates that keepalive detection is disabled.
Last error
Most recent error:
·     VPN doesn’t exist—The VPN instance does not exist.
·     PKI failed—An error exists in the PKI domain. For example, the certificate became invalid.
·     Channel (reason)—An error occurred on the gRPC channel. Possible reasons:
¡     Init—The channel is being initialized.
¡     Idle—The channel is idle,
¡     Connecting—The channel is being established.
¡     Transient failure—The channel has transiently failed and is attempting to recover.
¡     Shutdown—The channel has been closed because of an issue.
This field displays two hyphens (--) if no errors exist.
grpc data-model
Use grpc data-model to specify the architecture of telemetry data models.
Use undo grpc data-model to restore the default.
grpc data-model { 2-layer | 3-layer }
The device uses the two-layer telemetry data model architecture to push data.
2-layer: Specifies the two-layer telemetry data model architecture.
3-layer: Specifies the three-layer telemetry data model architecture.
This command is available only in gRPC dial-out mode.
If you specify the two-layer telemetry data model, the encoding format for pushed data can only be JSON.
For more information about telemetry data model architectures, see gRPC configuration in Telemetry Configuration Guide.
# Configure the device to use three-layer telemetry data models to push data.
[Sysname] grpc data-model 3-layer
encoding
grpc enable
Use grpc enable to enable the gRPC service.
Use undo grpc enable to disable the gRPC service.
grpc enable
undo grpc enable
You must enable the gRPC service before you can configure gRPC service attributes.
Disabling the gRPC service deletes all gRPC settings.
# Enable the gRPC service.
<Sysname> system
[Sysname] grpc enable
grpc pki domain
Use grpc pki domain to specify a PKI domain for establishing secure gRPC connections to collectors.
Use undo grpc pki domain to restore the default.
grpc pki domain domain-name
No PKI domain is specified for establishing secure gRPC connections to collectors.
domain-name: Specifies a PKI domain by its name, a case-insensitive string of 1 to 31 characters.
By default, the gRPC connection between the device and a collector does not provide data encryption service or require authentication. After you specify a PKI domain, the device and the collector will use TLS for data encryption and bidirectional certificate-based authentication to improve communication security.
For the device to establish secure gRPC connections to collectors, make sure the PKI domain already exists and has correct certificate and key settings. If these requirements are not met, the connections to collectors are not secure. For more information about PKI configuration, see Security Configuration Guide.
# Specify a PKI domain for establishing secure gRPC connections to collectors.
[Sysname] grpc pki domain grpc_test
grpc enable
gRPC dial-in mode commands
grpc idle-timeout
Use grpc idle-timeout to set the gRPC session idle timeout timer.
Use undo grpc idle-timeout to restore the default.
grpc idle-timeout minutes
The gRPC session idle timeout timer is 5 minutes.
minutes: Specifies the gRPC session idle timeout timer in minutes, in the range of 0 to 30. To disable gRPC sessions from being timed out, set it to 0.
If no gRPC packet exchanges occur on the session between a gRPC and the server before the idle timeout timer expires, the device closes the session.
# Set the gRPC session idle timeout timer to 6 minutes.
<Sysname> system
[Sysname] grpc idle-timeout 6
grpc log dial-in gnmi
Use grpc log dial-in gnmi to enable gRPC logging for gNMI operations in dial-in mode.
Use undo grpc log dial-in gnmi to disable gRPC logging for gNMI operations in dial-in mode.
grpc log dial-in gnmi { all | { capabilities | get | set | subscribe }* }
undo grpc log dial-in gnmi { all | { capabilities | get | set | subscribe }* }
In dial-in mode, gRPC logging is enabled for gNMI Set operations and disabled for other gNMI operations.
all: Specifies all gNMI operations.
capabilities: Specifies the gNMI Capabilities operations.
get: Specifies the gNMI Get operations.
set: Specifies the gNMI Set operations.
subscribe: Specifies the gNMI Subscribe operations.
To identify gRPC issues, enable gNMI operations logging in dial-in mode.
This command generates gNMI operation logs in dial-in mode and sends them to the information center. With the information center, you can configure log destinations and output rules. For more information about the information center, see Network Management and Monitoring Configuration Guide.
# Enable gRPC logging for gNMI Get operations in dial-in mode.
<Sysname> system
[Sysname] grpc log dial-in gnmi get
grpc log dial-in rpc
Use grpc log dial-in rpc to enable gRPC logging for RPC operations in dial-in mode.
Use undo grpc log dial-in rpc to disable gRPC logging for RPC operations in dial-in mode.
grpc log dial-in rpc { all | { cli | get }* }
undo grpc log dial-in rpc { all | { cli | get }* }
In dial-in mode, gRPC logging is disabled for RPC operations.
all: Specifies both RPC CLI and Get operations.
cli: Specifies the RPC CLI operations.
get: Specifies the RPC Get operations.
To identify gRPC issues, enable RPC operations logging in dial-in mode.
This command generates RPC operation logs in dial-in mode and sends them to the information center. With the information center, you can configure log destinations and output rules. For more information about the information center, see Network Management and Monitoring Configuration Guide.
# Enable gRPC logging for RPC Get operations in dial-in mode.
<Sysname> system
grpc port
Use grpc port to specify the gRPC service port number.
Use undo grpc port to restore the default.
grpc port port-number
undo grpc port
The gRPC service port number is 50051.
port-number: Specifies the gRPC service port number, in the range of 1 to 65535.
Changing the gRPC service port number reboots the gRPC service and terminates all gRPC sessions to the gRPC server. If the new port is not available, the system reboots the gRPC service again to use the old port.
# Set the gRPC service port number to 50052.
<Sysname> system
[Sysname] grpc port 50052
grpc enable
gRPC dial-out mode commands
condition
Use condition to configure a filtering condition for a filter.
Use undo condition to delete a filtering condition from a filter.
condition node node operator operator value value
undo condition node node operator operator value value
A filter does not contain filtering conditions.
Filter view
node node: Specifies a node by its full name, a case-insensitive string. To obtain information about the available nodes, execute the condition node ? command.
operator operator: Specifies a comparison operator. Available operations vary by node. The following are values available for the operator argument:
·     eq: Equal to.
·     ge: Greater than or equal to.
·     gt: Greater than.
·     le: Less than or equal to.
·     lt: Less than.
·     ne: Not equal to.
value value: Specify the value on which the operation is performed.
Use this command to add filtering conditions to a filter for flexible filtering. A filtering condition matches a subnet of data of interest to collectors.
To add multiple filtering conditions to a filter, repeat this command. A filter can contain a maximum of five filtering conditions.
By default, a filter is matched if all its filtering conditions are matched. To have a filter match data that matches any one of its filtering conditions, use the operator command to change the operator between filtering conditions.
# Enable flexible sensor mode and add sensor path device/base for flexible filtering in sensor group test. Configure a filter for the device to push data entries with a value of 377 or 378 for the uptime node under the sensor path.
[Sysname] telemetry
[Sysname-telemetry] grpc sensor-mode flex
[Sysname-telemetry] sensor-group test
[Sysname-telemetry-sensor-group-test] sensor-path-flex device/base
[Sysname-telemetry-sensor-group-test-path] filter filter1
[Sysname-telemetry-sensor-group-test-path-filter] operator or
[Sysname-telemetry-sensor-group-test-path-filter] condition node uptime operator eq value 377
[Sysname-telemetry-sensor-group-test-path-filter] condition node uptime operator eq value 378
filter
operator
depth
Use depth to specify the retrieval depth for a flex-mode sensor path.
Use undo depth to restore the default.
depth depth
undo depth
Data retrieval depth is 1.
Flex-mode sensor path view
depth: Retrieval depth. The value range is 1 to 3.
·     If the depth is set to 1, the device retrieves data from all columns under the specified path.
·     If the depth is set to 2, the device retrieves data from both columns and subtables under the specified path.
·     If the depth is set to 3, the device retrieves data from columns and subtables under the specified path as well as the subtables (if any) attached to the subtables under the specified path.
This command is supported only for sensor paths that represent multilevel tables.
# Enable flexible sensor mode and set the retrieval depth to 2 for a multilevel table sensor path in sensor group test.
[Sysname] telemetry
[Sysname-telemetry-sensor-group-test] sensor-path-flex grpc/subscriptions/subscription/destinationprofiles/destinationprofile
[Sysname-telemetry-sensor-group-test-path] depth 2
destination-group (subscription view)
Use destination-group to specify a destination group for a subscription.
Use undo destination-group to remove a destination group from a subscription.
destination-group group-name
undo destination-group group-name
A subscription does not have a destination group.
Subscription view
group-name: Specifies a destination group by its name, a case-sensitive string of 1 to 31 characters.
A subscription binds sensor groups to destination groups. Then, the device pushes data from the specified sensors to the collectors.
The specified destination group must have been created by using the destination-group command in telemetry view.
A subscription can have a maximum of five destination groups.
# Specify destination group collector1 for subscription A.
[Sysname] telemetry
[Sysname-telemetry] subscription A
[Sysname-telemetry-subscription-A] destination-group collector1
destination-group (telemetry view)
Use destination-group to create a destination group and enter its view, or enter the view of an existing destination group.
Use undo destination-group to delete a destination group.
No destination groups exist.
Telemetry view
group-name: Specifies the destination group name, a case-sensitive string of 1 to 31 characters.
As a best practice, configure a maximum of five destination groups. If you configure too many destination groups, system performance might degrade.
To delete a destination group that is already used by a subscription, you must remove the destination group from the subscription first.
# Create a destination group named collector1.
[Sysname] telemetry
[Sysname-telemetry] destination-group collector1
[Sysname-telemetry-destination-group-collector1]
subscription
dscp
Use dscp to set the DSCP value of packets sent to collectors.
Use undo dscp to restore the default.
dscp dscp-value
undo dscp
The DSCP value of packets sent to collectors is 0.
Subscription view
dscp-value: Specifies a DSCP value for packets sent to collectors, in the range of 0 to 63.
A greater DSCP value represents a higher priority.
If you execute this command multiple times in the same view, the most recent configuration takes effect.
# Set the DSCP value of packets sent to collectors to 12 for subscription A.
[Sysname] telemetry
[Sysname-telemetry-subscription-A] dscp 12
encoding
Use encoding to specify the encoding format for pushed data.
Use undo encoding to restore the default.
encoding { gpb | json }
undo encoding
The encoding format for pushed data is JSON.
Subscription view
gpb: Specifies the GPB encoding format. This keyword is available only when the device uses the three-layer telemetry data model architecture to push data.
json: Specifies the JSON encoding format.
The device supports JSON encoding for all data available for subscription. However, it does not support GPB encoding for all data. With GPB encoding, the device will not push data that cannot be GPB encoded. When you choose GPB encoding for a subscription, make sure all data in the subscription can be encoded in GPB.
# Specify the three-layer architecture for telemetry data models and use GPB to encode data for subscription A.
[Sysname] telemetry
[Sysname-telemetry] subscrption A
[Sysname-telemetry-subscription-A] encoding gpb
grpc data-model
filter
Use filter to configure a filter for a flex-mode sensor path.
Use undo filter to delete a filter from a flex-mode sensor path.
filter filter-name
undo filter filter-name
No filters are configured for sensor paths.
filter-name: Specify a filter name, a case-sensitive string of 1 to 31 characters.
You can use this command to specify a filter only for periodic sensor paths. A period sensor path can have only one filter.
To add filtering conditions to a filter, use the condition command.
# Enable flexible sensor mode, add the ifmgr/devicecapabilities sensor path to sensor group test, and then configure a filter for the sensor path.
[Sysname] telemetry
[Sysname-telemetry-sensor-group-test] sensor-path-flex ifmgr/devicecapabilities
condition
grpc log dial-out
Use grpc log dial-out to enable gRPC logging in dial-out mode.
Use undo grpc log dial-out to disable gRPC logging in dial-out mode.
grpc log dial-out { all | { event | sample }* }
undo grpc log dial-out { all | { event | sample }* }
In dial-out mode, gRPC logging is disabled.
all: Specifies all data collection types.
event: Specifies event-triggered data collection.
sample: Specifies periodical data collection.
To identify gRPC issues, enable gRPC data collection logging in dial-out mode.
This command generates gRPC data collection logs in dial-out mode and sends them to the information center. With the information center, you can configure log destinations and output rules. For more information about the information center, see Network Management and Monitoring Configuration Guide.
gRPC logging in dial-out mode is unavailable for gNMI subscriptions.
# Enable gRPC logging for periodical data collection in dial-out mode.
<Sysname> system
grpc sensor-mode
Use grpc sensor-mode to set the gRPC sensor mode.
Use undo grpc sensor-mode to restore the default gRPC sensor mode.
grpc sensor-mode { flex | simple }
Simple sensor mode applies.
Telemetry view
flex: Enable flexible sensor mode.
simple: Enable simple sensor mode.
The device supports flexible sensor mode and simple sensor mode for flexible filtering and simple filtering, respectively.
Depending on the sensor mode, you can configure the sensor paths in a sensor group with simple filtering conditions or flexible filtering conditions.
·     In flexible sensor mode, you can set the operator between filtering conditions on a sensor path to AND or OR.
·     In simple sensor mode, the operator between filtering conditions on a sensor path is fixed at AND. The device pushes only data that matches all filtering conditions from the sensor path.
The sensor path configuration procedure differs depending on the sensor mode.
·     In flexible sensor mode, use the following procedure to configure a sensor path and its filtering conditions:
a.     Execute the sensor-path-flex command to add the sensor path to the sensor group and enter flex-mode sensor path view. In some situations, the sensor paths specified by using this method are called flex-mode sensor paths for clarity.
b.     Execute the filter command to create a filter for the sensor path.
c.     Execute the condition command to add filtering conditions to the filter.
d.     Execute the operator command to set the operator between the filtering conditions.
-     To push data that matches all conditions, set the operator to and.
-     To push data that matches any filtering conditions, set the operator to or.
·     In simple sensor mode, use the following procedure to configure a sensor path and its filtering conditions:
a.     Execute the sensor path command to add the sensor path to the sensor group. When you execute the command, you can specify a filtering condition. In some situations, the sensor paths specified by using this method are called simple-mode sensor paths for clarity.
b.     To specify multiple filtering conditions on the sensor path, repeat the command with different filtering conditions.
The operator between filtering conditions on the sensor path is fixed at AND. The device pushes only data that matches all filtering conditions from the sensor path.
Flexible filtering and simple filtering are mutually exclusive. Before you change the sensor mode from simple to flexible, you must delete all sensor groups or delete all simple-mode sensor paths from all sensor groups. Likewise, before you change the sensor mode from flexible to simple, you must delete all sensor groups or delete all flex-mode sensor paths.
# Enable simple sensor mode.
[Sysname] telemetry
operator
sensor path
sensor-path-flex
ipv4-address
Use ipv4-address to add an IPv4 collector to a destination group.
Use undo ipv4-address to remove an IPv4 collector from a destination group.
ipv4-address ipv4-address [ port port-number ] [ vpn-instance vpn-instance-name ]
undo ipv4-address ipv4-address [ port port-number ] [ vpn-instance vpn-instance-name ]
A destination group does not have IPv4 collectors.
Destination group view
ipv4-address: Specifies the IPv4 address of the collector.
port port-number: Specifies the listening port of the collector, in the range of 1 to 65535. The default is 50051.
vpn-instance vpn-instance-name: Specifies the VPN instance to which the collector belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the collector belongs to the public network, do not specify this option.
One collector must have a different address, port, or VPN instance than the other collectors.
To add multiple collectors to a destination group, execute this command multiple times.
A destination group can have a maximum of five collectors.
To modify the collector configuration for a destination group that is already used by a subscription, you must remove the destination group from the subscription first.
# Add a collector that uses IPv4 address 192.168.21.21 and the default port number to destination group collector1.
[Sysname] telemetry
[Sysname-telemetry-destination-group-collector1] ipv4-address 192.168.21.21
subscription
ipv6-address
Use ipv6-address to add an IPv6 collector to a destination group.
Use undo ipv6-address to remove an IPv6 collector from a destination group.
ipv6-address ipv6-address [ port port-number ] [ vpn-instance vpn-instance-name ]
undo ipv6-address ipv6-address [ port port-number ] [ vpn-instance vpn-instance-name ]
A destination group does not have IPv6 collectors.
ipv6-address: Specifies the IPv6 address of the collector. It cannot be an IPv6 link-local address. For more information about IPv6 link-local addresses, see IPv6 basics configuration in Layer 3—IP Services Configuration Guide.
# Add a collector that uses IPv6 address 1::1 and the default port number to destination group collector1.
[Sysname] telemetry
[Sysname-telemetry-destination-group-collector1] ipv6-address 1::1
subscription
operator
Use operator to set the logical operator on the filtering conditions in a filter.
Use undo operator to restore the default.
operator { and | or }
undo operator
By default, the AND operator applies to the filtering conditions in a filter.
Filter view
and: Specifies the logical AND operator. The device pushes only data that matches all the filtering conditions in the filter.
or: Specifies the OR operator. The device pushes data that matches any filtering conditions in the filter.
# In flexible sensor mode, add the ifmgr/devicecapabilities sensor path to sensor group test, configure a filter for the sensor path, and set the operator between the filtering conditions in the filter to OR.
[Sysname] telemetry
filter
protocol
Use protocol to specify a transport protocol for the device to send packets to collectors.
Use undo protocol to restore the default.
protocol { grpc | udp }
undo protocol
The device uses gRPC as the transport protocol to send packets to collectors.
Subscription view
grpc: Specifies gRPC as the transport protocol. gRPC uses TCP at the transport layer
udp: Specifies UDP as the transport protocol.
For a subscription that has sensor group and destination group bindings, you must first remove all the sensor groups and destination groups from it before you execute this command.
# Specify UDP as the transport protocol for subscription A.
[Sysname] telemetry
[Sysname-telemetry-subscription-A] protocol udp
sensor-path-flex
Use sensor-path-flex to add a flex-mode sensor path and enter its view.
Use undo sensor-path-flex to delete a flex-mode sensor path.
sensor-path-flex path
undo sensor-path-flex path
No sensor paths are configured.
Sensor group view
path: Specifies a data path by its full name. The data path name is case insensitive. For information about the available paths, execute the sensor-path-flex ? command.
To execute this command, first execute the grpc sensor-mode flex command in telemetry view to enable flexible sensor mode.
The device supports a total maximum of 128 sensor paths in total.
You can execute the sensor-group command in subscription view to specify a sensor group for a subscription. To modify the sensor path configuration for a sensor group that is used in a subscription, you must first remove the sensor group from the subscription.
For the ifmgr/statistics sensor path, you can alternatively specify ifindex attribute values in the path to filter data.
·     You can specify condition nodes to do node-based filtering or include ifindex attribute values in sensor paths to do index-based filtering, but not both.
·     Use the [ifindex=”index”] format to specify index-based filters in the path. The index argument is a case-insensitive string that represents the type and number of an interface or its index.
·     You can specify a maximum of 64 ifindex attribute values in a sensor path. The device pushes data from the sensor path if one of the ifindex attribute values is met.
·     The end character for theindex argument can be a wildcard character (*), for example, sensor-path-flex ifmgr/statistics[ifindex="ten-gigabitethernet3/0/*"].
# In flexible sensor mode, add the ifmgr/devicecapabilities sensor path to sensor group test.
[Sysname] telemetry
grpc sensor-mode
sensor-group (subscription view)
sensor path
Use sensor path to configure a sensor path.
Use undo sensor path to delete a sensor path.
sensor path path [ condition node node operator operator value value | depth depth ]
undo sensor path path [ condition node node operator operator ]
No sensor paths exist.
Sensor group view
path: Specifies a data path by its full name. The data path name is case insensitive. For information about the available paths, execute the sensor path ? command.
condition: Adds a data filtering condition. The device pushes only data that matches the comparison-based filtering condition. If you do not specify a condition, the device does not filter data. This keyword is available only for periodic sensor paths.
node node: Specifies a node by its full name, a case-insensitive string. For information about the available nodes, enter sensor path condition path node ?.
operator operator: Specifies an operator for the condition. Supported operators vary by node. The following are available operators:
·     eq—Equal to.
·     ge—Greater than or equal to.
·     gt—Greater than.
·     le—Less than or equal to.
·     lt—Less than.
·     ne—Not equal to.
value value: Specifies the reference value.
depth depth: Sets the retrieval level for the sensor path. This option takes effect if the sensor path is a periodic path. The value range for the depth is 1 to 3. The default depth is 1.
·     If the depth is set to 1, the device collects data from all columns under the specified path.
·     If the depth is set to 2, the device collects data from all columns and subtables under the specified path.
·     If the depth is set to 3, the device collects data from all columns, subtables, and subtables under the subtables, under the specified path.
The device supports a maximum of 128 sensor paths in total.
You can repeat this command to configure a sensor path with different filtering conditions. A sensor path can have a maximum of five data filtering conditions. The device pushes data from the sensor path to collectors only when all the specified conditions are met.
For the ifmgr/statistics sensor path, you can alternatively specify ifindex attribute values in the path to filter data. When you use this method, the following restrictions and guidelines apply:
·     Use the [ifindex=”index”] format to specify index-based filters in the path. The index argument is a case-insensitive string that represents the type and number or index of an interface.
·     The end character for the index argument can be a wildcard character (*), for example, sensor path ifmgr/statistics[ifindex="Ten-GigabitEthernet3/0/*"].
To modify the sensor path configuration for a sensor group that is already used by a subscription, you must remove the sensor group from the subscription first.
# Configure sensor path ifmgr/devicecapabilities for sensor group test.
[Sysname] telemetry
[Sysname-telemetry-sensor-group-test] sensor path ifmgr/devicecapabilities
# Configure sensor path device/base for sensor group test so the device pushes data of the sensor path only when the uptime is greater than or equal to 377.
[Sysname] telemetry
[Sysname-telemetry-sensor-group-test] sensor path device/base condition node uptime operator ge value 377
Use sensor-group to specify a sensor group for a subscription.
Use undo sensor-group to remove a sensor group from a subscription.
sensor-group group-name [ sample-interval [ msec ] interval ]
undo sensor-group group-name
A subscription does not have a sensor group.
Subscription view
group-name: Specifies a sensor group by its name, a case-sensitive string of 1 to 31 characters.
sample-interval: Specifies that the sensor group collect and push data at intervals. If you do not specify this keyword, the sensor group collects and pushes data only when triggered by events.
[ msec ] interval: Specifies the data sampling interval.
·     If you do not specify the msec keyword, the data sampling interval is set in seconds. The value range is 1 to 86400.
·     If you specify the msec keyword, the data sampling interval is set in milliseconds. The interval value must be 10 or a multiple of 100 in the range of 100 to 900.
Specify the sample-interval interval option for periodic sensor paths and only for periodic sensor paths.
·     If you specify the option for event-triggered sensor paths, the sensor paths do not take effect.
·     If you do not specify the option for periodic sensor paths, the device does not collect or push data.
The specified sensor group must have been created by using the sensor-group command in telemetry view.
As a best practice, set the data sampling interval to 1 second or a higher value. If you set the data sampling interval to 10 or 100 milliseconds, the collected statistics might not be incomplete because of hardware limitations.
When you set the data sampling interval to 10 milliseconds, follow these restrictions and guidelines:
·     The 10 milliseconds data sampling interval applies only to the ifmgr/statistics sensor paths specified with the [ifindex="index"] filter, for example, sensor path ifmgr/statistics[ifindex="Ten-GigabitEthernet3/0/1"]. The device will collect data from all other sensor paths in the sensor group at the minimum data sampling interval for each of them.
·     To collect data from the ifmgr/statistics sensor path at 10 milliseconds, the transport protocol for the subscription must be UDP. To set the transport protocol for a subscription, use the protocol command.
·     You can add ifmgr/statistics paths with interface-based filtering conditions in the sensor group to sample data from up to four interfaces per slot in total.
# Specify sensor group test for subscription A. Set the data sampling interval to 10 seconds.
[Sysname] telemetry
[Device-telemetry] subscription A
[Device-telemetry-subscription-A] sensor-group test sample-interval 10
protocol
sensor-group (telemetry view)
Use sensor-group to create a sensor group and enter its view, or enter the view of an existing sensor group.
Use undo sensor-group to delete a sensor group.
No sensor groups exist.
Telemetry view
group-name: Specifies the sensor group name, a case-sensitive string of 1 to 31 characters.
The device supports a maximum of 32 sensor groups.
To delete a sensor group that is already used by a subscription, you must remove the sensor group from the subscription first.
# Create a sensor group named test.
[Sysname] telemetry
subscription
source-address
Use source-address to specify the source IP address for packets sent to collectors.
Use undo source-address to restore the default.
source-address { ipv4-address | interface interface-type interface-number | ipv6 ipv6-address }
undo source-address
The device uses the primary IP address of the output interface in the route to the collectors as the source address.
Subscription view
ipv4-address: Specifies an IPv4 address.
interface interface-type interface-number: Specifies an interface by its type and number. In the current software version, you must specify a loopback interface. The device will use the interface's primary IPv4 address as the source address. If the interface does not have a primary IPv4 address, the device selects the first secondary IPv4 address of the interface. If the interface does not have any IPv4 addresses, the device uses the primary IP address of the output interface in the route to the collectors.
ipv6 ipv6-address: Specifies an IPv6 address.
Changing the source address causes the device to reconnect to the gRPC server.
# Specify the source IPv4 address of 169.254.1.1 for packets sent to collectors.
[Sysname] telemetry
[Sysname-telemetry-subscription-A] source-address 169.254.1.1
subscription
Use subscription to create a subscription and enter its view, or enter the view of an existing subscription.
Use undo sensor-group to delete a subscription.
subscription subscription-name
undo subscription subscription-name
No subscription exists.
Telemetry view
subscription-name: Specifies the subscription name, a case-sensitive string of 1 to 31 characters.
The device supports a maximum of 10 subscriptions.
# Configure a subscription named A.
[Sysname] telemetry
telemetry
Use telemetry to enter telemetry view.
telemetry
In telemetry view, you can configure telemetry parameters.
# Enter telemetry view.
[Sysname] telemetry
[Sysname-telemetry]
