15-BRAS Services Command Reference
HomeSupportRoutersCR16000-M SeriesReference GuidesCommand ReferencesH3C CR16000-M Routers Command Reference-R838x-6W10115-BRAS Services Command Reference
12-UCM commands
12-UCM commands 576.67 KB
UCM commands
access-limit
Use access-limit to configure the maximum number of access users allowed on an interface.
Use undo access-limit to restore the default.
access-limit user-number [ start-vlan start-vlan [ end-vlan end-vlan ] [ qinq qinq-vlan ] ]
undo access-limit [ start-vlan start-vlan [ end-vlan end-vlan ] [ qinq qinq-vlan ] ]
The maximum number of access users on an interface is not limited.
Layer 3 Ethernet interface/subinterface view
Layer 3 aggregate interface/subinterface view
L3VE interface/subinterface view
user-number: Specifies the maximum number of access users allowed. The value range is 1 to 64000.
start-vlan start-vlan: Specifies the start VLAN in the range of 1 to 4094. In QinQ applications, this option specifies the start inner VLAN. Only subinterfaces support this option.
end-vlan end-vlan: Specifies the end VLAN in the range of 1 to 4094. In QinQ applications, this option specifies the end inner VLAN. The end VLAN cannot be smaller than the start VLAN. Only subinterfaces support this option.
qinq qinq-vlan: Specifies the outer VLAN of QinQ in the range of 1 to 4094. If you specify start-vlan and do not specify qinq, all outer VLANs 1 through 4094 are each allocated to the specified inner VLAN. Only subinterfaces support this option.
When you execute this command, follow these restrictions and guidelines:
·     If no VLAN is specified, the following rules apply:
¡     For a main interface, the user-number argument specifies the maximum number of access users allowed on the main interface.
¡     For a subinterface, the user-number argument specifies the maximum number of access users allowed on each single VLAN or each inner-outer VLAN pair of the subinterface.
·     If VLANs are specified in this command, this command specifies the maximum number of users in each of the specified VLANs. For example, if you specify the start-vlan start-vlan and end-vlan end-vlan keywords in this command, this command specifies the maximum number of users allowed in each of the VLANs from the start VLAN to the end VLAN.
·     If one access-limit command is configured with VLANs and another access-limit command is not configured with VLANs, the number of users in the specified VLANs is limited by the first command and the number of users in the other VLANs is limited by the second command.
·     For a single VLAN or a single inner-outer VLAN pair, the most recent configuration takes effect. For example, if you first execute the access-limit 50 start-vlan 1 end-vlan 3 command and then the access-limit 100 start-vlan 2 end-vlan 3 command, the maximum number of users allowed is 100 in VLAN 2 or VLAN 3 and 50 in VLAN 1.
If the configured limit is smaller than the number of existing users on an interface (or VLANs on an interface), the configuration succeeds and the existing users are not affected. However, new users cannot access on the interface (or VLANs on the interface).
When this command is executed together with the pppoe-server session-limit per-vlan command and the access-limit command in an ISP domain, the three commands all take effect. The three commands control the number of users on the interface (or VLANs on the interface) in different perspectives, and the number of users is controlled by all the three commands. A new PPPoE user can access only when none of these limits is reached.
When this command is executed together with the access-limit command in an ISP domain, the two commands both take effect. The two commands control the number of BRAS users on the interface (or VLANs on the interface) in different perspectives, and the number of BRAS users is controlled by both commands. A new BRAS user can access only when neither limit is reached.
#Set the maximum number of access users allowed on Ten-GigabitEthernet 3/0/1.1. For packets with a single layer of VLAN tags, set the maximum number of access users to 100 for packets with VLAN tag 2. For packets with two layers of VLAN tags, set the maximum number of access users to 100 for each combination of inner VLAN 2 and any of outer VLANs 1 through 4094.
[Sysname] interface ten-gigabitethernet 3/0/1.1
[Sysname-Ten-GigabitEthernet3/0/1.1] access-limit 100 start-vlan 2
access-limit (BRAS Services Command Reference)
pppoe-server session-limit per-vlan (BRAS Services Command Reference)
access-user log enable
Use access-user log enable to enable logging for access users.
Use undo access-user log enable to disable logging for access users.
access-user log enable [ abnormal-logout | failed-login | normal-logout | successful-login ] *
undo access-user log enable [ abnormal-logout | failed-login | normal-logout | successful-login ] *
Logging is disabled for access users.
abnormal-logout: Specifies abnormal logout logs.
failed-login: Specifies login failure logs.
normal-logout: Specifies normal logout logs.
successful-login: Specifies login success logs.
CAUTION
CAUTION:
As a best practice, disable this feature to prevent excessive log output.
The logging feature enables the device to generate logs and send them to the information center. Logs are generated after a user comes online successfully, fails to come online, normally goes offline, or abnormally goes offline. A log entry contains information such as the username, IP address, interface name, inner VLAN, outer VLAN, MAC address, and failure causes. For information about the log destination and output rule configuration in the information center, see Network Management and Monitoring Configuration Guide.
When you configure this command without specifying any keyword, this command enables or disables logging for login successes, login failures, normal logouts, and abnormal logouts.
# Enable logging for access users.
[Sysname] access-user log enable
access-user online-fail-warning
Use access-user online-fail-warning to enable the user online failure threshold alarm function.
Use undo access-user online-fail-warning to disable the user online failure threshold alarm function.
access-user online-fail-warning threshold threshold-value period period-value
The user online failure threshold alarm function is disabled.
threshold threshold-value: Specifies a percentage of the number of user online failures to the total number of user online events, in the range of 1 to 100.
period period-value: Specifies the alarm detection interval in the range of 1 to 1440 minutes.
With the user online failure threshold alarm function enabled, when the number of user online failures within an alarm detection interval exceeds the specified threshold, an alarm is automatically triggered. Then, the administrator can promptly learn the user online failure conditions on the live network. An administrator can execute the display aaa online-fail-record command to view user online failure records.
The alarm information output contains logs and traps.
·     The generated log messages by the device will be sent to the information center. The information center configuration specifies the log message sending rule and destination. For more information about the information center, see Network Management and Monitoring Configuration Guide.
·     To send the traps to an NMS correctly, you must also configure SNMP correctly as described in Network Management and Monitoring Configuration Guide. For more information about SNMP alarms, see SNMP configuration in Network Management and Monitoring Guide.
The total number of access user online failures refers to the sum of IPoE user, PPPoE user, and L2TP user online failures on the whole device.
The total number of access user online events refers to the sum of IPoE user, PPPoE user, and L2TP user online failures and online successes on the whole device.
If a single user comes online successfully or fails to come online for multiple times, each online success or failure is counted in the total number of online successes or failure.
When the device calculates the number of online events of a user, the device uniquely identifies a user by the MAC address, inner VLAN, and outer VLAN.
·     For a dual-stack user, only if the user successfully comes online in one protocol stack, the user is considered as coming online successfully. A dual-stack user is considered failing to come online only when the user fails to come online in both protocol stacks.
·     For an IPoE leased user, the online events of the main user and the online events of the subusers are separately counted.
# Configure the device to generate an alarm when the percentage of user online failures to user online events exceeds 50% within 10 minutes.
[Sysname] access-user online-fail-warning threshold 50 period 10
access-user session-threshold
Use access-user session-threshold to configure the online access user session count alarm thresholds on the device.
Use undo access-user session-threshold to restore the default.
access-user session-threshold { lower-limit lower-limit-value | upper-limit upper-limit-value }
undo access-user session-threshold { lower-limit | upper-limit }
On the device, the upper online access user session count alarm threshold is 100, and the lower online access user session count alarm threshold is 0.
lower-limit lower-limit-value: Specifies the lower online access user session count alarm threshold in the range of 0 to 99. The configured value is a percentage of the maximum number of online access user sessions allowed.
upper-limit upper-limit-value: Specifies the upper online access user session count alarm threshold in the range of 1 to 100. The configured value is a percentage of the maximum number of online access user sessions allowed.
The online access user session count on the device is the total number of online IPoE sessions, PPPoE sessions, and L2TP sessions on the device.
You can use this command to set the upper alarm threshold and lower alarm threshold for the online access user session count. When the online access user session count exceeds the upper alarm threshold or drops below the lower threshold, an alarm is triggered automatically. Then, the administrator can promptly know the online user conditions of the network. To view the total number of access users, use the display access-user command.
The user session count alarm function counts only user sessions that occupy session resources. In the current software version, only the following sessions occupy session resources:
·     The following IPoE sessions:
¡     Sessions of individual access users
¡     Sessions of interface-leased users
¡     Sessions of interface-leased subusers
¡     Sessions of subnet-leased users
¡     Sessions of subnet-leased subusers
¡     Sessions of L2VPN-leased users
·     PPPoE sessions
·     L2TP sessions
Either a single-stack user or dual-stack user occupies one session resource.
Suppose the maximum number of online access user sessions allowed on the device is a, the upper alarm threshold is b, and the lower alarm threshold is c. The following rules apply:
·     When the online access user session count exceeds a×b or drops below a×c, the corresponding alarm information is output.
·     When the online access user session count returns between the upper alarm threshold and lower alarm threshold, the alarm clearing information is output.
In some special cases, the online access user session count frequently changes in the critical range, which causes frequent output of alarm information and alarm clearing information. To avoid this problem, the system introduces a buffer area when the online access user session count recovers from the upper or lower threshold. The buffer area size is 10% of the difference between the upper threshold and the lower threshold. Suppose the buffer area size is d. Then, d=a×(b-c)÷10. When the online access user session count drops below a×b-d or exceeds a×c+d, the alarm information is output.
For example, suppose a is 1000, b is 80%, and c is 20%. Then, d= a×(b-c)÷10=1000×(80%-20%)÷10=1000×60%÷10=600÷10=60.
·     When the online access user session count exceeds the upper threshold a×b=1000×80%=800, the upper threshold alarm is output. When the online access user session count restores to be smaller than a×b-d=800-60=740, the alarm clearing information is output.
·     When the online access user session count drops below the lower threshold a×c=1000×20%=200, the lower threshold alarm is output. When the online access user session count restores to be greater than a×c+d=200+60=260, the alarm clearing information is output.
The upper threshold alarm information output and the alarm clearing information output both contain logs and traps.
·     For traps to be correctly sent to the NMS host, you must execute the snmp-agent trap enable user-warning-threshold command in addition to configuring the SNMP alarm feature correctly. For more information about SNMP alarms, see SNMP configuration in Network Management and Monitoring Guide.
# Set the upper online access user session count threshold to 80% on the device.
[Sysname] access-user session-threshold upper-limit 80
access-user user-detect packet-loss-ratio-threshold
Use access-user user-detect packet-loss-ratio-threshold to enable the packet loss ratio alarm for access user detection packets.
Use undo access-user user-detect packet-loss-ratio-threshold to disable the packet loss ratio alarm for access user detection packets.
access-user user-detect packet-loss-ratio-threshold threshold-value
The packet loss ratio alarm is disabled for access user detection packets.
threshold-value: Specifies the alarm threshold for the packet loss ratio of access user detection packets (the ratio of dropped detection packets to all detection packets). The value range is 20 to 100.
After the online user detection feature is enabled, the device will automatically create a 30-second timer. The timer will be reset after expiration. After the packet loss ratio alarm is enabled for access user detection packets, an alarm will be automatically triggered in either of the following conditions:
·     The packet loss ratio calculated exceeds the specified alarm threshold when the 30-second timer expires continuously for three times, and the number of packets sent within each 30-second timer exceeds 50.
·     The packet loss ratio calculated within the last 30 seconds when the 30-second timer expires restores to the normal range (equal to or less than the specified alarm threshold) after an alarm is output.
In this way, the administrator can timely learn the packet loss conditions of user detection packets on the live network.
In this function, the packet loss ratio of detection packets refers to the ratio of dropped packets (sent packets - received packets) to all detection packets within the 30-second timer on a detected interface. The formula is as follows: the packet loss ratio = (sent packets - received packet)/sent packets. If you execute the display access-user user-detect packet-loss-ratio or display ppp keepalive packet-loss-ratio command at a time point within a 30-second timer, this command displays the packet loss ratio statistics collected at the specified time point within the 30-second timer. For example, if you execute this display command at the 10th second within a 30-second timer, this command displays the packet loss ratio statistics collected within the 10 seconds.
The alarm information output contains only logs. The generated log messages by the device will be sent to the information center. The information center configuration specifies the log message sending rule and destination. For more information about the information center, see Network Management and Monitoring Configuration Guide.
This feature applies to only IPoE users, PPPoE users, and L2TP users.
# Enable the packet loss ratio alarm for access user detection packets, and set the alarm threshold to 25%.
[Sysname] access-user user-detect packet-loss-ratio-threshold 25
display ppp keepalive packet-loss-ratio (BRAS Services Command Reference)
reset access-user user-detect packet-loss-ratio
reset ppp keepalive packet-loss-ratio (BRAS Services Command Reference)
bras auto-cut-user before-reboot
Use bras auto-cut-user before-reboot to enable auto user logout before BRAS reboot.
Auto user logout before BRAS reboot is disabled.
By default, if devices are rebooted as planned or slots are separately rebooted when devices are upgraded, the devices or slots will not actively send accounting stop packets to the AAA server during the reboot process. During the reboot process, the devices will log out users, but the AAA server cannot sense the logout events and still considers the users online.  Within a short period of time after the devices or slots are rebooted, the online users before reboot cannot log in again because the AAA server still considers them as online.
To resolve this issue, enable the feature of auto user logout before BRAS reboot. With this feature enabled, when the reboot command is executed to reboot a device or slot, the device first forbids new users from coming online, and logs out all online users or online users on the slot to be rebooted. When users are logged out, the device will actively send accounting stop packets to the AAA server. After these users are logged out, the device or slot will be rebooted.
The bras auto-cut-user before-reboot command is not saved in the configuration file. After the device is rebooted, to use the feature of auto user logout before BRAS reboot again, you must execute this command again. If only slots are rebooted but the device is not rebooted, you do not need to execute this command. In this case, this command takes effect on each slot reboot.
When a slot is restarted, this feature takes effect only on users coming online through physical interfaces in the slot.
If you execute the reboot command with the force keyword specified, the feature of auto user logout before BRAS reboot does not take effect.
# Enable auto user logout before BRAS reboot.
[Sysname] bras auto-cut-user before-reboot
reboot (Fundamentals Command Reference)
bras data-backup-mode
Use bras data-backup-mode to configure the data backup mode for the BRAS service module.
Use undo bras data-backup-mode to restore the default.
bras data-backup-mode non-realtime [ auto-reboot-board ]
The data backup mode is non-auto-reboot-board mode for the BRAS service module.
non-realtime: Specifies the BRAS service module not to back up the running data (for example, user session information) to the running database in real time.
auto-reboot-board: Specifies the device to automatically forcibly reboot the active MPU and complete active/standby MPU switchover when the BRAS service module process on the active MPU is abnormal. If you do not specify this keyword, the device does not automatically forcibly reboot the active MPU when the BRAS service module process is abnormal.
Working mechanism
In non-realtime mode, the BRAS service module does not back up the running data to the running database in real time and the following rules apply:
·     To avoid data loss when the BRAS service module process is normally restarted (for example, by using the process restart command), the BRAS service module will back up the running data of the module to the running database before the process is restarted.
·     When the BRAS service module process on the active MPU is abnormal, the data of the BRAS service module on the current active MPU will be lost. The device determines whether to forcibly reboot the active MPU according to whether the auto-reboot-board keyword is specified.
Active/standby MPU switchover is automatically performed only when the auto-reboot-board keyword is specified in the dual-MPU environment and the BRAS service module process is abnormal.
In the current software version, this feature takes effect only on the UCM module.
# Configure the data backup mode as auto-reboot-board for the BRAS service module.
[Sysname] bras data-backup-mode non-realtime auto-reboot-board
cut access-user
Use cut access-user to forcibly log out users.
cut access-user [ { auth-type { admin | bind | ppp | pre-auth | web-auth [ inherit-pppoe | non-inherit-pppoe ] } | domain domain-name | interface interface-type interface-number [ s-vlan svlan-id [ c-vlan cvlan-id ] ] | ip-pool pool-name | ip-type { dual-stack | ipv4 | ipv6 } | ipv6-pool pool-name | mac-address mac-address | user-address-type { ipv6 | nat64 | private-ds | private-ipv4 | public-ds | public-ipv4 } | user-profile profile-name [ both | inbound | outbound ] | username user-name | vpn-instance vpn-instance-name | vxlan vxlan-id [ vxlan-id-max ] | slot slot-number } * | { { ip-address ipv4-address | ipv6-address ipv6-address | ipv6-prefix prefix-address/prefix-length } [ vpn-instance vpn-instance-name ] | user-id user-id } ]
auth-type: Specifies an authentication type for access users.
·     admin: Specifies device management users.
·     bind: Specifies IPoE users using bind authentication.
·     ppp: Specifies PPP users.
·     pre-auth: Specifies IPoE users in the preauthentication phase.
·     web-auth: Specifies IPoE users using Web authentication in the Web authentication phase.
¡     inherit-pppoe: Specifies IPoE Web users that inherit the PPPoE user information.
¡     non-inherit-pppoe: Specifies IPoE Web users except those that inherit PPPoE user information.
domain domain-name: Logs out users in the forced domain specified by its name, a case-insensitive string of 1 to 255 characters.
interface interface-type interface-number: Logs out users on an interface specified by its type and number. Only network access users support this keyword.
·     s-vlan svlan-id: Logs out users in an SVLAN specified by its ID. The value range is 1 to 4094.
·     c-vlan cvlan-id: Logs out users in a CVLAN specified by its ID. The value range is 1 to 4094.
ip-pool pool-name: Logs out users in an IPv4 address pool specified by its name, a case-insensitive string of 1 to 63 characters.
ip-type: Logs out users of the specified IP type.
·     dual-stack: Specifies dual-stack users.
·     ipv4: Specifies IPv4 users.
·     ipv6: Specifies IPv6 users.
ipv6-pool pool-name: Logs out users in an IPv6 address pool specified by its name, a case-insensitive string of 1 to 63 characters. On an NDRA network, if the IPv6 prefix of a user is from the ND prefix pool, the pool-name argument represents the name of the AAA-authorized ND prefix pool.
mac-address mac-address: Logs out a user with the specified MAC address in the form of H-H-H, case-insensitive. Only network access users support this keyword.
user-address-type: Logs out users with the specified IP address type.
·     ipv6: Specifies IPv6 addresses.
·     nat64: Specifies NAT64 addresses.
·     private-ds: Specifies private dual-stack addresses.
·     private-ipv4: Specifies private IPv4 addresses.
·     public-ds: Specifies public dual-stack addresses.
·     public-ipv4: Specifies public IPv4 addresses.
user-profile profile-name: Logs out users of a user profile specified by its name, a case-sensitive string of 1 to 31 characters. Valid characters include letters, digits, underlines (_), minus sings (-), and periods (.). A user profile name must start with a letter or digit, and cannot be all digits. If you do not specify a user profile direction, a user is logged out only if the user’s user profile matches the specified user profile in any direction.
·     both: Logs a user whose profile matches the specified profile in both directions.
·     inbound: Logs a user whose profile matches the specified profile in the inbound direction.
·     outbound: Logs a user whose profile matches the specified profile in the outbound direction.
username user-name: Logs out a user specified by its username, a case-sensitive string of 1 to 253 characters.
vpn-instance vpn-instance-name: Logs out users in a VPN instance specified by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, this command logs out users in the public network.
vxlan vxlan-id [ vxlan-id-max ]: Logs out users in a VXLAN specified by the vxlan-id argument or VXLAN range specified by the vxlan-id vxlan-id-max arguments The vxlan-id and vxlan-id-max arguments are both in the range of 0 to 16777215.
ip-address ipv4-address: Logs out a user with the specified IPv4 address.
ipv6-address ipv6-address: Logs out a user with the specified IPv6 address.
ipv6-prefix prefix-address/prefix-length: Logs out users with the specified IPv6 prefix. The prefix-address argument specifies the IPv6 prefix, and the prefix-length argument specifies the IPv6 prefix length.
user-id user-id: Logs out a user specified by its online index. The value range is 1 to FFFF4240 (hexadecimal).
slot slot-number: Specifies a card by its slot number.
This command takes effect only on online IPoE, PPPoE, and L2TP users.
# Forcibly log out the user with IP address 10.10.10.10.
<Sysname> cut access-user ip-address 10.10.10.10
# Forcibly log out the users in ISP domain dm1.
<Sysname> cut access-user domain dm1
# Forcibly log out the user named user1.
<Sysname> cut access-user username user1
display access-user
display access-user
Use display access-user to display access user information.
Syntax I:
display access-user [ [ { { [ all-vpn-instance | public-instance | vpn-instance vpn-instance-name ] | auth-type { admin | bind | ppp | pre-auth | web-auth [ inherit-pppoe | non-inherit-pppoe ] } | domain domain-name [ authorization | authentication ] | interface interface-type interface-number [ all | s-vlan svlan-id [ c-vlan cvlan-id ] ] | ip-pool pool-name | ip-pool-group ip-pool-groupname | ip-type { dual-stack | ipv4 | ipv6 } | ipv6-address-protocol { dhcpv6 | dhcpv6-pd | nd } | ipv6-cpe-mode { ipv6 | ipv6-pd } | ipv6-pool pool-name | ipv6-pool-group ipv6-pool-groupname | lac-ip lac-ip-address | lns-ip lns-ip-address | mac-address mac-address | remote-name tunnel-name | start-time start-time start-date end-time end-time end-date | user-address-type { ipv6 | nat64 | private-ds | private-ipv4 | public-ds | public-ipv4 } | user-group user-group-name | user-type { lac | leased | lns | pppoe } | username user-name | vxlan vxlan-id [ vxlan-id-max ] | slot slot-number } * | time time [ slot slot-number ] } [ count | verbose ] | { { ip-address ipv4-address | ipv6-address ipv6-address | ipv6-prefix ipv6-prefix/prefix-length | public-ip-address public-ip-address } [ all-vpn-instance | public-instance | vpn-instance vpn-instance-name ] | user-id user-id } [ slot slot-number ] [ verbose ] ] | { count | verbose } ]
all-vpn-instance: Specifies all VPN instances, excluding the public network instance.
public-instance: Specifies the public network instance.
vpn-instance vpn-instance-name: Specifies users in an MPLS L3VPN instance specified by its name, a case-sensitive string of 1 to 31 characters.
·     pre-auth: Specifies IPoE in the preauthentication phase.
¡     inherit-pppoe: Specifies IPoE Web users that inherit PPPoE user information.
domain domain-name: Specifies users accessing through an authorization or authentication domain specified by its name, a case-insensitive string of 1 to 255 characters. If you specify the domain keyword but do not specify the authorization or authentication keyword, this command displays information about all matching users accessing through the specified authentication domain and authorization domain.
·     authorization: Specifies users that access through the specified authorization domain.
·     authentication: Specifies users that access through the specified authentication domain.
interface interface-type interface-number: Specifies users accessing through an interface specified by its type and number. Only network access users support this option.
·     all: Displays user information on the current main interface and all its subinterfaces. To specify this keyword, make sure the interface specified by using the interface keyword is a main interface and you must also specify the count keyword.
·     s-vlan svlan-id: Specifies an SVLAN by its ID. The value range is 1 to 4094.
·     c-vlan cvlan-id: Specifies a CVLAN by its ID. The value range is 1 to 4094.
ip-pool pool-name: Specifies users in an IPv4 address pool specified by its name, a case-insensitive string of 1 to 63 characters.
ip-pool-group ip-pool-groupname: Specifies users in an IPv4 address pool group specified by its name, a case-insensitive string of 1 to 63 characters.
ip-type: Specifies users of an IP type.
ipv6-address-protocol: Specifies users whose IPv6 addresses or prefixes are assigned by the specified IPv6 protocol.
·     dhcpv6: Specifies users whose address are assigned by DHCPv6.
·     dhcpv6-pd: Specifies IPv6 PD prefixes allocated to users by using DHCPv6.
·     nd: Specifies users whose address are assigned by IPv6 NDRA.
ipv6-cpe-mode: Specifies CPE users. In an NDRA+IA_PD or IA_NA+IA_PD hybrid network, you cannot specify the ipv6-cpe-mode keyword to search for access users.
·     ipv6: Specifies access users that obtain IPv6 addresses through NDRA or IA_NA.
·     ipv6-pd: Specifies access users that obtain IPv6 PD prefixes through IA_PD.
ipv6-pool pool-name: Specifies users in an IPv6 address pool specified by its name, a case-insensitive string of 1 to 63 characters. On an NDRA network, if the IPv6 prefix of a user is from the ND prefix pool, the pool-name argument represents the name of the AAA-authorized ND prefix pool.
ipv6-pool-group ipv6-pool-groupname: Specifies users in an IPv6 address pool group by its name, a case-insensitive string of 1 to 63 characters.
lac-ip lac-ip-address: Specifies the LNS to display users on the LAC specified by its IP address. Only the LNS supports this option.
lns-ip lns-ip-address: Specifies the LAC to display users on the LNS specified by its IP address. Only the LAC supports this option.
mac-address mac-address: Specifies a user by its MAC address in H-H-H format, case-insensitive. Only network access users support this option.
remote-name tunnel-name: Specifies an L2TP user of the LAC or LNS specified by its tunnel name, a string of 1 to 31 characters.
start-time start-time start-date end-time end-time end-date: Specifies users within the specified time range. The start-time start-time start-date option specifies the start time and date. The end-time start-time start-date option specifies the end time and date.
·     The start-time and end-time arguments are in the HH:MM:SS format. HH specifies an hour in the range of 0 to 23. MM specifies a minute in the range of 0 to 59. SS specifies a second in the range of 0 to 59. To specify an integer hour, you do not need to specify the minute or second. To specify an integer minute, you do not need to specify the second. For example, if you enter 0 or 0:0, the time is hour 0 minute 0 second 0.
·     The start-date and end-date arguments are in the MM/DD/YYYY or YYYY/MM/DD format. MM specifies a month in the range of 1 to 12. DD specifies a day and its value range varies by month. YYYY specifies a year in the range of 2000 to 2035.
user-address-type: Specifies users with addresses of the specified type.
user-group user-group-name: Specifies users in a user group specified by its name, a case-insensitive string of 1 to 32 characters.
user-type: Specifies users of the specified type.
·     lac: Specifies users on the device acting as a LAC.
·     leased: Specifies IPoE leased users.
·     lns: Specifies users on the device acting as an LNS.
·     pppoe: Specifies PPPoE users.
username user-name: Specifies a user by its name, a case-sensitive string of 1 to 253 characters.
vxlan vxlan-id [ vxlan-id-max ]: Specifies users in the specified VXLANs. The vxlan-id argument and the vxlan-id-max argument specify the start VXLAN ID and end VXLAN ID, respectively, each in the range of 1 to 16777215.
time time: Specifies users accessing with the specified time range. The time argument specifies a duration in the range of 1 to 7200 seconds. For example, if you set the time argument to 2000, this command displays users coming online with the latest 2000 seconds.
ip-address ipv4-address: Specifies the user with the specified IPv4 address.
ipv6-address ipv6-address: Specifies the user with the specified IPv6 address.
ipv6-prefix ipv6-prefix: Specifies users with the specified IPv6 prefix (IPv6 ND prefix or IPv6 PD prefix). The ipv6-prefix argument specifies an IPv6 prefix. The prefix-length argument specifies an IPv6 prefix length.
public-ip-address public-ip-address: Specifies a NAT user by the public IP address assigned to the user in the NAT network.
user-id user-id: Specifies an online user by its index, a hexadecimal number in the range of 1 to FFFF4240.
count: Displays the number of users.
verbose: Displays detailed user information. This keyword is supported only by IPoE, PPPoE, and L2TP users.
If you do not specify the count or verbose keyword, this command displays brief user information.
If you do not specify any of the all-vpn-instance, public-instance, and vpn-instance keywords, this command displays user information of the public network instance and all VPN instances.
In an L2TP network, this command is supported on an LAC only if a remote system dials in to the LAC through a PPPoE network. For more information about L2TP, see L2TP configuration in BRAS Services Configuration Guide .
# Display the number of all access users.
<Sysname> display access-user count
Total users                      : 5
PPPoE users                      : 0
PPPoEA users                     : 0
PPPoA users                      : 0
PPPoFR users                     : 0
PPPoPhy users                    : 0
LNS users                        : 0
LAC users                        : 0
VPPP users                       : 0
L2 IPoE dynamic users            : 1
L2 IPoE static users             : 0
L2 IPoE interface leased users   : 0
L2 IPoE subnet leased users      : 0
L2 IPoE leased subusers          : 0
IPoE L2VPN leased users          : 0
L3 IPoE dynamic users            : 0
L3 IPoE static users             : 0
L3 IPoE interface leased users   : 0
L3 IPoE subnet leased users      : 0
Web auth users                   : 0
Portal users                     : 0
Telnet users                     : 1
SSH users                        : 0
HTTP users                       : 1
HTTPS users                      : 1
FTP users                        : 1
Command users                    : 0
PAD users                        : 0
Terminal users                   : 0
MAC auth users                   : 0
Dot1X users                      : 0
IKE users                        : 0
SSLVPN users                     : 0
DVPN users                       : 0
Total users
Total number of users (excluding LAC users).
PPPoE users
Number of PPPoE users.
PPPoEA users
This field is not supported in the current software version. Number of PPPoEA users.
PPPoA users
This field is not supported in the current software version. Number of PPPoA users.
PPPoFR users
This field is not supported in the current software version. Number of PPPoFR users.
PPPoPhy users
Number of PPP access users directly carried on physical links.
LNS users
Number of L2TP users on the LNS.
LAC users
Number of L2TP users on the LAC. For example, PPPoE users that trigger the LAC to set up L2TP tunnels in NAS-initiated mode and LNS users on the LTS.
VPPP users
Number of L2TP users automatically dialing on the LAC.
Number of Layer 2 IPoE dynamic users.
Number of Layer 2 IPoE static users.
Number of Layer 2 IPoE interface-leased users.
Number of Layer 2 IPoE subnet-leased users.
Number of Layer 2 IPoE leased subusers.
Number of IPoE L2VPN-leased users.
Number of Layer 3 IPoE dynamic users.
Number of Layer 3 IPoE static users, including static individual users and static leased users.
Number of Layer 3 IPoE interface-leased users.
Number of Layer 3 IPoE subnet-leased users.
Web auth users
Number of Web authentication users.
Portal users
This field is not supported in the current software version. Number of portal users.
Telnet users
Number of Telnet users.
SSH users
Number of SSH users.
HTTP users
Number of HTTP users.
HTTPS users
Number of HTTPS users.
FTP users
Number of FTP users.
Command users
Number of command authorization and accounting users.
PAD users
This field is not supported in the current software version. Number of PAD users.
Terminal users
Number of uses logging in through the Console port, AUX port, and Asyn port.
MAC auth users
This field is not supported in the current software version. Number of MAC authentication users.
Dot1X users
This field is not supported in the current software version. Number of Layer 2 802.1X users.
IKE users
This field is not supported in the current software version. Number of IKE users.
SSLVPN users
This field is not supported in the current software version. Number of SSL VPN users.
DVPN users
This field is not supported in the current software version. Number of DVPN users.
# Display brief information about all access users.
UserID      Interface            IP address              MAC address     S-/C-VLAN
            Username             Access type
            IPv6 address
0x33d       BAS0                 192.168.0.2             -               -/-
            user1                LNS
0x33e       XGE3/0/1             3.3.3.3                 001b-21a8-0949  -/-
            user2                L2 IPoE dynamic
0x33e       XGE3/0/1             5.3.3.3                 001b-21a8-0950  -/-
            User3                L3 IPoE static
0x33f       XGE3/0/1             192.168.0.3             001b-21a8-0951  -/-
            user3                PPPoE
0x400005    -                    3.3.3.3                 -               -/-
            user4                Telnet
0x400006    -                    3.3.3.3                 -               -/-
            user5                FTP
0x400007    -                    3.3.3.3                 -               -/-
            user6                HTTP
0x400008    -                    3.3.3.3                 -               -/-
            user7                HTTPS
UserID
Online index of a user.
Access interface of a user. If the user does not have an access interface, this field displays a hyphen (-).
Username
Username for authentication. If the username contains more than 20 characters, the username is displayed in the format of “the first 20 characters in the username+...” in the brief information.
IP address
IPv4 address of a user. If the user does not have an IPv4 address, this field displays a hyphen (-).
IPv6 address
IPv6 address of a user. If the user does not have an IPv4 address, this field displays a hyphen (-).
MAC address
MAC address of a user. If the user does not have a MAC address, this field displays a hyphen (-).
S-/C-VLAN
SVLAN and CVLAN of a user. If the user does not have a SVLAN or CVLAN, this field displays -/-.
Access type
Access type of a user. For more information, see Table 1.
#(Individual users.) Display detailed information about IPoE users using bind authentication.
<Sysname> display access-user auth-type bind verbose
Basic:
  Description: N/A
  User ID: 0x33e
  Username: user1
  Backup role: N/A
  Authorization domain: dm1
  Authentication domain: dm1
  Interface: XGE3/0/1
  Service-VLAN/Customer-VLAN: -/-
  VXLAN ID: -
  MAC address: 001b-21a8-0949
  IP address: 3.3.3.3
  IP pool: pool1
  Primary DNS server: -
  Secondary DNS server: -
  IPv6 address: -
  IPv6 pool: N/A
  Primary IPv6 DNS server: -
  Secondary IPv6 DNS server: -
  IPv6 PD prefix: -
  IPv6 ND prefix: -
  IPv6 ND prefix pool: N/A
  DHCP lease: -
  DHCP remaining lease: -
  DHCPv6 lease: -
  DHCPv6 remaining lease: -
  User address type: N/A
  VPN instance: N/A
  Access type: L2 IPoE dynamic
  Authentication type: Bind
  Static leased user: No
  Agent-Circuit-Id: -
  Agent-Remote-Id: -
  NAS-Port-Id: slot=1;subslot=0;port=1;vlanid=0;
  User IPv6CP interface ID: -
AAA:
  Authentication state: Authenticated
  Authorization state: Authorized
  Realtime accounting switch: Closed
  Realtime accounting interval: -
  Login time: 2019-09-21  13:55:57
  Accounting start time: 2019-09-21  13:55:57
  Online time (hh:mm:ss): 0:02:19
  Accounting state: Accounting
  Acct start-fail action: Online
  Acct update-fail action: Online
  Acct quota-out action: Offline
  Dual-stack accounting mode: Merge
  Idle cut: 0 seconds  0 bytes, direction: Both
  Session timeout: Unlimited
  Time remained: Unlimited
  Traffic quota: Unlimited
  Traffic remained: Unlimited
  IPv6CP interface ID assignment: Disabled
  Redirect WebURL: -
  Redirect IPv6 WebURL: -
  ITA policy name: N/A
  MRU: N/A
  IPv4 MTU: N/A
  IPv6 MTU: N/A
  Subscriber ID: -
  Inbound netstream sampler: Not set
  Outbound netstream sampler: Not set
  IPv4 multicast user profile: N/A
  IPv6 multicast user profile: N/A
  User session: limit 2, online 1
  Account ID: 0x2
ACL&QoS:
  Inbound user profile: N/A
  Outbound user profile: N/A
  Session group profile: N/A
  User group acl: N/A
  Inbound CAR: -
  Outbound CAR: -
  Inbound user priority: -
  Outbound user priority: -
Flow Statistic:
  Uplink   packets/bytes: 389/50005
  Downlink packets/bytes: 23/1362
  IPv6 uplink   packets/bytes: 0/0
  IPv6 downlink packets/bytes: 0/0
ITA:
  Level-1 Uplink packets/bytes        : 4/392
          Downlink packets/bytes      : 4/392
          IPv6 uplink packets/bytes   : 0/0
          IPv6 downlink packets/bytes : 0/0
  Level-2 Uplink packets/bytes        : 0/0
          Downlink packets/bytes      : 0/0
#(Static leased users.) Display detailed information about IPoE users using bind authentication.
Basic:
  Description: N/A
  User ID: 0x33e
  Username: user1
  Backup role: N/A
  Interface: XGE3/0/1
  VXLAN ID: -
  IP address: 3.3.3.3
  IP pool: pool1
  IPv6 address: -
  IPv6 pool: N/A
  IPv6 PD prefix: -
  IPv6 ND prefix: -
  DHCP lease: -
  DHCPv6 lease: -
  VPN instance: N/A
  Access type: L3 IPoE static
  Static leased user: Yes
  Agent-Circuit-Id: -
  Agent-Remote-Id: -
AAA:
  Redirect WebURL: -
  MRU: N/A
  IPv4 MTU: N/A
  IPv6 MTU: N/A
  Subscriber ID: -
  Account ID: 0x2
ACL&QoS:
  User group acl: N/A
  Inbound CAR: -
  Outbound CAR: -
Flow Statistic:
#(Leased users.) Display detailed information about IPoE users using bind authentication.
Basic:
  Description: N/A
  User ID: 0x1
  Username: user1
  Backup role: N/A
  Authorization domain : dm1
  Interface: XGE3/0/1
  VXLAN ID: -
  MAC address: -
  IP address: -
  IP pool: N/A
  IPv6 address: -
  IPv6 pool: N/A
  IPv6 PD prefix: -
  IPv6 ND prefix: -
  DHCP lease: -
  DHCPv6 lease: -
  VPN instance: N/A
  Access type: L2 IPoE interface leased
  Agent-Circuit-Id: -
  Agent-Remote-Id: -
AAA:
  Login time: 2019-11-19  10:15:40
  Accounting start time: 2019-11-19  10:15:40
  Online time(hh:mm:ss): 0:33:54
  Redirect WebURL: -
  MRU: N/A
  IPv4 MTU: N/A
  IPv6 MTU: N/A
  Subscriber ID: -
ACL&QoS:
  User group ACL: N/A
  Inbound CAR: -
  Outbound CAR: -
Flow Statistic:
  Uplink   packets/bytes: 4/392
  Downlink packets/bytes: 4/392
Total subusers: 1
  UserID   IP address          MAC address     S-/C-VLAN
           IPv6 address
  0xc      1.1.1.2             6c45-4eea-0206  -/-
Basic:
  Description: N/A
  User ID: 0xc
  Username: user1
  Backup role: N/A
  Authentication domain: N/A
  Interface: XGE3/0/1
  VXLAN ID: -
  MAC address: 6c45-4eea-0206
  IP address: 1.1.1.2
  IP pool: N/A
  IPv6 address: -
  IPv6 pool: N/A
  IPv6 PD prefix: -
  IPv6 ND prefix: -
  DHCP lease: -
  DHCPv6 lease: -
  VPN instance: N/A
  Access type: L2 IPoE leased subusers
  Agent-Circuit-Id: -
  Agent-Remote-Id: -
AAA:
  Authentication state: -
  Authorization state: -
  Login time: 2019-11-19  10:32:09
  Accounting start time: -
  Online time(hh:mm:ss): 0:00:00
  Accounting state: Stop
  Dual-stack accounting mode: N/A
  Redirect WebURL: -
  MRU: N/A
  IPv4 MTU: N/A
  IPv6 MTU: N/A
  Subscriber ID: -
ACL&QoS:
  User group ACL: N/A
  Inbound CAR: -
  Outbound CAR: -
Flow Statistic:
  Uplink   packets/bytes: 0/0
  Downlink packets/bytes: 0/0
#Display detailed information about PPP access users.
<Sysname> display access-user auth-type ppp verbose
Basic:
  Description: N/A
  PPP index: 0x22d0a92580000105
  User ID: 0x33d
  Username: user1
  Backup role: N/A
  Interface: BAS0
  VXLAN ID: -
  MAC address: -
  IP address: 192.168.0.2
  IP pool: pool1
  Primary DNS server: 8.8.8.8
  IPv6 address: 8::8
  IPv6 pool: pool1
  IPv6 PD prefix: -
  IPv6 ND prefix: -
  DHCP lease: -
  DHCPv6 lease: -
  VPN instance: N/A
  Access type: LNS
  Authentication type: PPP
  Agent-Circuit-Id: -
  Agent-Remote-Id: -
  User IPv6CP interface ID: 1e2f:c3e4:3333:1234
L2TP LNS:
  Group ID: 1
  Local tunnel ID: 8912
  Remote tunnel ID: 2
  Local session ID: 43301
  Remote session ID: 1
  Local IP: 3.3.3.1
  Remote IP: 3.3.3.3
  Local port: 1701
  Remote port: 1701
  Vrf index: 0
  Calling station: 9a4d-e968-0116 XGE3/0/1:ffff.ffff
AAA:
  Login time: 2019-09-21  13:54:52
  Accounting start time: 2019-09-21  13:54:52
  Online time (hh:mm:ss): 0:03:24
  IPv6CP interface ID assignment: Enabled
  Redirect WebURL: -
  MRU: 1400 bytes
  IPv4 MTU: 1400 bytes
  IPv6 MTU: 1400 bytes
  Subscriber ID: -
ACL&QoS:
  User group acl: N/A
  Inbound CAR: -
  Outbound CAR: -
Flow Statistic:
  Uplink   packets/bytes: 691/57955
Basic:
  Description: N/A
  PPP index: 0x140000002
  User ID: 0x33f
  Username: user2
  Backup role: N/A
  Authorization domain: dm2
  Authentication domain: dm2
  Interface: XGE3/0/1
  VXLAN ID: -
  IP address: 192.168.0.3
  IP pool: pool1
  IPv6 address: 192::1
  IPv6 pool: pool1
  Primary IPv6 DNS server: 8::8
  IPv6 PD prefix: -
  IPv6 ND prefix: -
  DHCP lease: -
  DHCPv6 lease: -
  VPN instance: N/A
  Access type: PPPoE
  Agent-Circuit-Id: -
  Agent-Remote-Id: -
PPPoE:
  Session ID: 1
AAA:
  Login time: 2019-09-21  13:57:07
  Accounting start time: 2019-09-21  13:57:07
  Online time (hh:mm:ss): 0:01:09
  Redirect WebURL: -
  MRU: 1480 bytes
  IPv4 MTU: 1480 bytes
  IPv6 MTU: 1480 bytes
  Subscriber ID: -
ACL&QoS:
  User group acl: N/A
  Inbound CAR: -
  Outbound CAR: -
NAT:
  Global IP address: 111.8.0.200
  Port block: 28744-28748
  Extended port block: 2024-2033/3024-3033/4024-4033/5024-5033/6024-6033
Flow Statistic:
  Uplink   packets/bytes: 28/4736
EDSG:
  Service ID                    : 1
  Service ID                    : 2
Basic
Basic information of a user.
Description of a user. If the user does not have a description, this field displays N/A.
PPP index
PPP session index. This field is displayed only for PPPoE users and L2TP users.
Username
Backup role
This field is not supported in the current software version. Role of the user in the VSRP network:
·     Master—The user belongs to the master device.
·     Backup—The user belongs to the backup device, and the user information is synchronized from the master device.
·     N/A—The user is not in a VSRP network.
Authorization domain, which specifies the ISP domain that the AAA server authorizes to the user through the H3C-ISP-ID attribute. The authorization domain is the actual ISP domain that the user uses after coming online.
Authentication domain, which specifies the domain used by the user for authentication on the AAA server. For Layer 2 IPoE leased subusers, who do not need authentication, this field displays N/A.
Backup interface
UP backup access interface of a user. If the user does not have a UP backup access interface, this field is not displayed.
VXLAN ID
VXLAN ID. If the user does not have a VXLAN ID, this field displays a hyphen (-).
MAC address
MAC address. If the user does not have a MAC address, this field displays a hyphen (-).
IP address
IPv4 address of the user. If the user does not have an IPv4 address, this field displays a hyphen (-).
IP pool
Name of the IP address pool actually used by the user (this field displays N/A if the user does not use an IP address pool). The value displayed for this field depends on the origins of the IP address pool as follows:
·     If AAA authorizes an IP address pool but does not authorize an IP address pool group, the field displays the name of the AAA-authorized IP address pool.
·     If AAA does not authorize an IP address pool but authorizes an IP address pool group, the field displays the name of the IP address pool allocated from the AAA-authorized IP address pool group to the user.
·     If AAA authorizes both an IP address pool and an IP address pool group, the field displays the name of the AAA-authorized IP address pool.
·     If AAA does not authorize an IP address pool or IP address pool group, the field displays the name of the IP address pool selected through DHCP. For more information about how DHCP selects an IP address pool, see DHCP configuration in BRAS Services Configuration Guide.
IP pool group
AAA-authorized IP address pool group name. This field is displayed when AAA authorizes an IP address pool group.
Primary DNS server
Primary IPv4 DNS server address. This field displays a hyphen (-) when the address does not exist.
Secondary IPv4 DNS server address. This field displays a hyphen (-) when the address does not exist.
IPv6 address
IPv6 address of the user. If the user does not have an IPv6 address, this field displays a hyphen (-).
IPv6 pool
Name of the IPv6 address pool actually used by the user (this field displays N/A if the user does not use an IPv6 address pool). The value displayed for this field depends on the origins of the IPv6 address pool as follows:
·     If AAA authorizes an IPv6 address pool but does not authorize an IPv6 address pool group, the field displays the name of the AAA-authorized IPv6 address pool.
·     If AAA does not authorize an IPv6 address pool but authorizes an IPv6 address pool group, the field displays the name of the IPv6 address pool allocated from the AAA-authorized IPv6 address pool group to the user.
·     If AAA authorizes both an IPv6 address pool and an IPv6 address pool group, the field displays the name of the AAA-authorized IPv6 address pool.
·     If AAA does not authorize an IPv6 address pool or IPv6 address pool group, the field displays the name of the IPv6 address pool selected through DHCP. For more information about how DHCP selects an IPv6 address pool, see DHCPv6 configuration in BRAS Services Configuration Guide.
IPv6 pool group
AAA-authorized IPv6 address pool group name. This field is displayed when AAA authorizes an IPv6 address pool group.
Primary IPv6 DNS server address. This field displays a hyphen (-) when the address does not exist.
Secondary IPv6 DNS server address. This field displays a hyphen (-) when the address does not exist.
IPv6 PD prefix
IPv6 PD prefix of the user. If the user does not have an IPv6 PD prefix, this field displays a hyphen (-).
IPv6 ND prefix
IPv6 ND prefix of the user. If the user does not have an IPv6 ND prefix, this field displays a hyphen (-).
IPv6 ND prefix pool
Name of the AAA-authorized IPv6 ND prefix pool.  (This field displays N/A if the no IPv6 ND prefix pool is authorized). The value displayed for this field depends on the origins of the IPv6 ND prefix pool:
·     If AAA authorizes an IPv6 ND prefix pool but does not authorize an IPv6 ND prefix pool group, the field displays the name of the AAA-authorized IPv6 ND prefix pool.
·     If AAA does not authorize an IPv6 ND prefix pool but authorizes an IPv6 ND prefix pool group, the field displays the name of the IPv6 ND prefix pool allocated from the AAA-authorized IPv6 ND prefix pool group to the user.
·     If AAA authorizes both an IPv6 ND prefix pool and an IPv6 ND prefix pool group, the field displays the name of the AAA-authorized IPv6 ND prefix pool.
Name of the AAA-authorized IPv6 ND prefix pool group. This field is displayed only when AAA authorizes an IPv6 ND prefix pool group.
DHCP lease
DHCP-authorized IP lease in seconds:
·     Hyphen (-)—No IP lease is authorized.
·     Unlimited—The IP lease is unlimited.
Remaining DHCP-authorized IP lease in seconds.
This field is displayed only on the service node. On the other nodes, this field displays a hyphen (-).
DHCPv6 lease
DHCPv6-authorized IPv6 lease in seconds:
·     Hyphen (-)—No IPv6 lease is authorized.
·     Unlimited—The IPv6 lease is unlimited.
Remaining DHCPv6-authorized IPv6 lease in seconds.
User address type
AAA-authorized user address type:
·     private-ds—Private dual-stack address.
·     private-ipv4—Private IPv4 address.
·     public-ds—Public dual-stack address.
·     public-ipv4—Public IPv4 address.
·     ipv6—IPv6 address.
·     nat64—NAT64 address.
·     N/A—If no IPv4 user address type is authorized, this field displays N/A.
VPN instance
VPN instance of the user. If the user belongs to a public network, this field displays N/A.
Access type
Access type of the user. For more information, see Table 1.
Authentication type
Authentication type of the user:
·     Admin—Device management users.
·     Bind—IPoE users using bind authentication.
·     PPP—PPP users.
·     Pre-auth—IPoE users in preauthentication phase.
·     SSLVPN—SSL VPN users.
·     Web-auth—IPoE users in Web authentication phase and users performing authentication through a Web interface on a Layer 2 Ethernet interface.
Inherit-PPPoE user: Yes
The current IPoE Web user directly inherits the PPPoE user information in the preauthentication domain and comes online in the postauthentication domain. This field is displayed only when the IPoE Web user inherits the PPPoE user information and comes online in the postauthentication domain.
Static leased user
Whether the user is an IPoE static leased user. This field displays Yes for static leased users and No for the other users.
Agent-Circuit-Id
Circuit ID. If no circuit ID exists, this field displays a hyphen (-).
Agent-Remote-Id
Remote ID. If no remote ID exists, this field displays a hyphen (-).
NAS-Port-Id
Information encapsulated in the NAS-Port-ID attribute. If no circuit ID NAS-Port-ID attribute information exists, this field displays a hyphen (-). For a leased user or subuser, this field always displays the NAS-Port-ID of the leased user.
This field displays the NAS-Port-ID encapsulation format defined by each service module and is not affected by the attribute 87 format command configuration. For more information about this command, see AAA commands.
Interface ID used by a PPP user after the IPv6CP negotiation succeeds. If the user does not have an interface ID, this field displays a hyphen (-). The interface IDs used by PPP users include the following types, in descending order of priority:
1.     Interface ID authorized by the RADIUS server through the Framed-Interface-Id attribute.
2.     The lowest 64 bits of the authorized IPv6 address if an IPv6 address is authorized to the user but no IPv6 prefix is authorized to the user when NDRA is used to allocate IPv6 addresses to PPP users.
3.     Interface ID automatically assigned by the device when the ipv6cp assign-interface-id command is executed in the ISP domain of the user.
If the ipv6cp assign-interface-id command is not executed in the ISP domain of the user, the following rules apply:
·     If the user carries a non-zero interface ID that does not conflict with any other interface ID, the interface carried by the user is used.
·     Otherwise, the interface ID assigned by the device is used.
AAA
AAA information.
Authentication state of the user:
·     Idle—The user is not authenticated.
·     Authenticating—The user is being authenticated.
·     Authenticated—The user has been authenticated.
Authorization state
Authorization state of the user:
·     Idle—The user is not authorized.
·     Authorizing—The user is being authorized.
·     Authorized—The user has been authorized.
·     Open.
·     Closed.
Realtime accounting interval in seconds. If the device does not send accounting information of online users to the AAA server, this field displays a hyphen (-).
Login time
Time when the user logged in.
Time when accounting started for the user. For a leased subuser, this field always displays a hyphen (-).
Online duration of the user in the current login. For a leased subuser, this field always displays 0:00:00.
Accounting state
Accounting state of the user:
·     Accounting—Accounting is being performed for the user.
·     Stop—Accounting is stopped for the user.
Actions to take after accounting fails to start:
·     Online—Keeps the user online.
·     Offline—Forces the user offline.
Actions to take after accounting fails to update:
Actions to take after the traffic quota is exhausted:
·     Redirect—Pushes a redirect Web page to the user.
Accounting mode of dual-stack users:
·     Merge—Reports the IPv4 and IPv6 traffic of dual-stack users as a whole to the accounting server.
·     Separate—Reports the IPv4 and IPv6 traffic of dual-stack users to the accounting server separately.
Idle cut
Parameters for idle cut. If traffic does not reach the specified threshold in bytes within the specified period, the user is considered as offline and is logged out.
direction
The device determines whether to idle cut (forcibly log out) a user based on whether the inbound, outbound, or total traffic of the user reaches the specified threshold in bytes within the specified period.
Direction of traffic to be used by idle cut:
·     Both—Sum of inbound and outbound traffic.
·     Inbound—Inbound traffic.
·     Outbound—Outbound traffic.
Session timeout
AAA-authorized session timeout in seconds.
·     Unlimited—The online duration of the user is not limited in either of the following conditions:
¡     The action to take on a user after the accounting quota (traffic or duration) is exhausted is to keep the user online.
¡     No session timeout is authorized to the user.
·     Hyphen (-)—After the authorized online duration times out, a redirect Web page is pushed to the user.
This field is displayed only when the remaining AAA-authorized session timeout is not 0.
Time remained
Remaining AAA-authorized session timeout in seconds.
Traffic quota
AAA-authorized traffic quota in bytes.
·     Unlimited—The traffic quota of the user is not limited in either of the following conditions:
¡     No traffic quota is authorized to the user.
·     Hyphen (-)—After the authorized traffic quota is exhausted, a redirect Web page is pushed to the user.
This field is displayed only when the remaining AAA-authorized traffic quota is not 0.
Traffic remained
Whether the ipv6cp assign-interface-id command is executed to enable the device to forcibly assign interface IDs to PPP users during IPv6CP negotiation and not to accept non-zero interface IDs that are carried in user packets and do not conflict with other interface IDs.
·     Enabled.
·     Disabled.
Redirect WebURL
Redirect IPv4 Web URL pushed to the user when the user comes online, including:
·     Authorized redirect URL. (In an IPoE Web preauthentication domain, this field indicates the Web authentication page URL pushed to the user.)
·     Redirect Web page URL pushed to the user when the traffic quota of the user is exhausted.
If the user does not have the redirect Web URL, this field displays a hyphen (-).
Redirect IPv6 Web URL pushed to the user when the user comes online, including:
·     Authorized redirect IPv6 URL. (In an IPoE Web preauthentication domain, this field indicates the Web authentication page IPv6 URL pushed to the user.)
·     Redirect Web page IPv6 URL pushed to the user when the traffic quota of the user is exhausted.
If the user does not have the redirect IPv6 Web URL, this field displays a hyphen (-).
ITA policy name
AAA-authorized ITA policy name. If no ITA policy name is authorized, this field displays N/A.
MRU
MRU in bytes negotiated by both ends of a link in the PPP LCP phase. This field is applicable to only PPPoE and L2TP users, and displays N/A for other users.
IPv4 MTU
MTU used for guiding IPv4 packet forwarding, in bytes. This field is applicable to only PPPoE and L2TP users, and displays N/A for other users.
IPv6 MTU
MTU used for guiding IPv6 packet forwarding, in bytes. This field is applicable to only PPPoE and L2TP users, and displays N/A for other users.
Subscriber ID
Subscriber ID authorized to the user. If no subscriber ID is authorized, this field displays a hyphen (-).
Name of the inbound NetStream sampler authorized to the user. If no inbound NetStream sampler is authorized to the user, this field displays Not set.
Name of the outbound NetStream sampler authorized to the user. If no outbound NetStream sampler is authorized to the user, this field displays Not set.
Name of the IPv4 multicast user profile authorized to the user. If no IPv4 multicast user profile is authorized to the user, this field displays N/A.
Name of the IPv6 multicast user profile authorized to the user. If no IPv6 multicast user profile is authorized to the user, this field displays N/A.
User session: limit n, online m
Statistics about users using a shared account. This field is displayed only when the users-per-account command has been executed in the ISP domain to which users belongs or the RADIUS server has authorized attribute 62 (port-limit) to users.
·     limit—Maximum number of concurrent users allowed for a shared account.
·     online—Actual number of access users.
Account ID
Account ID automatically allocated by the system to the user. This field is not displayed if no account ID is allocated.
ACL&QoS
ACL and QoS information.
Name of the AAA-authorized inbound user profile. N/A means that no inbound user profile is authorized.
The user profile has the following states:
·     active—The inbound user profile is authorized successfully.
·     inactive—Inbound user profile authorization failed or the user inbound profile does not exist on the BRAS.
·     N/A—The authorization state is insignificant. The device does not need the authorized attribute.
Name of the AAA-authorized outbound user profile. N/A means that no outbound user profile is authorized.
·     active—The outbound user profile is authorized successfully.
·     inactive—Outbound user profile authorization failed or the user outbound profile does not exist on the BRAS.
Name of the AAA-authorized session group profile. N/A means that no session group profile is authorized.
The session group profile has the following states:
·     inactive—Session group profile authorization failed or the session group profile does not exist on the BRAS.
·     active—The session group profile is authorized successfully.
If the authorization result has not been updated, nothing is displayed.
User group acl
Name of the AAA-authorized user group ACL. N/A means that no user group ACL is authorized.
The user group ACL has the following states:
·     active—The user group ACL is authorized successfully.
·     inactive—User group ACL authorization failed or the user group ACL does not exist on the BRAS.
Inbound CAR
AAA-authorized inbound CIR and PIR in kbps, and CBS in bytes. A hyphen (-) means that no inbound CAR is authorized.
The inbound CAR has the following states:
·     inactive—Inbound CAR is not authorized successfully.
·     active—Inbound CAR is authorized successfully.
Outbound CAR
AAA-authorized outbound CIR and PIR in kbps, and CBS in bytes. A hyphen (-) means that no outbound CAR is authorized.
The outbound CAR has the following states:
·     inactive—Outbound CAR is not authorized successfully.
·     active—Outbound CAR is authorized successfully.
AAA-authorized inbound user priority, which can be a number in the range of 0 to 7, 15, and a hyphen (-). A hyphen (-) or 15 means that no inbound user priority is authorized.
The inbound user priority has the following states:
·     inactive—Inbound user priority is not authorized successfully.
·     active—Inbound user priority is authorized successfully.
AAA-authorized outbound user priority, which can be a number in the range of 0 to 7, 15, and a hyphen (-). A hyphen (-) or 15 means that no outbound user priority is authorized.
The outbound user priority has the following states:
·     inactive—Outbound user priority is not authorized successfully.
·     active—Outbound user priority is authorized successfully.
NAT
NAT information.
Global IP address
Public network IP address. This field is displayed after NAT444 translation.
Port block
Port block, from the start port to the end port. This field is displayed after NAT444 translation.
Extended port block
Extended port block, from the start port to the end port. Extended port blocks are separated by using slashes (/). This field is displayed only when extended port blocks are configured in dynamic port block mapping mode.
Flow Statistic
Flow statistics.
Total number and size of uplink packets. This field displays the total number and size of uplink IPv4 and IPv6 packets in Merge accounting mode. Otherwise, this field displays the total number and size of uplink IPv4 packets.
Total number and size of downlink packets. This field displays the total number and size of downlink IPv4 and IPv6 packets in Merge accounting mode. Otherwise, this field displays the total number and size of downlink IPv4 packets.
Total number and size of uplink IPv6 packets.
Total number and size of downlink IPv6 packets.
PPPoE
PPPoE information.
Session ID
PPPoE session ID.
L2TP LAC
L2TP LAC information.
L2TP LNS
L2TP LNS information.
Group ID
L2TP group number.
Local tunnel ID
Tunnel ID of the local L2TP end.
Remote tunnel ID
Tunnel ID of the L2TP peer.
Local session ID
Session ID of the local L2TP end.
Remote session ID
Session ID of the L2TP peer.
Local IP
IP address of the local L2TP end.
Remote IP
IP address of the L2TP peer.
Local port
UDP port number used by the local L2TP end.
Remote port
UDP port number used by the L2TP peer.
Vrf index
VPN index of an L2TP session.
Calling station
L2TP calling number. If the calling number does not exist, this field displays a hyphen (-).
ITA
ITA information.
Level-n
ITA accounting level n, in the range of 1 to 8.
EDSG
EDSG information.
Service ID
EDSG service ID.
·     Uplink IPv4 and IPv6 ITA or EDSG traffic in packets and bytes when the dual-stack accounting mode is merge.
·     Uplink IPv4 ITA or EDSG traffic in packets and bytes in any other case.
·     Downlink IPv4 and IPv6 ITA or EDSG traffic in packets and bytes when the dual-stack accounting mode is merge.
·     Downlink IPv4 ITA or EDSG traffic in packets and bytes in any other case.
Uplink IPv6 ITA or EDSG traffic in packets and bytes.
Downlink IPv6 ITA or EDSG traffic in packets and bytes.
Total subusers
Number of Layer 2 IPoE leased subusers and brief information about these subusers (the brief information is displayed only when subusers exist).
cut access-user
display access-user backup-state
Use display access-user backup-state to display the access user backup state on each slot.
The active MPU will synchronize the online user information to the standby MPUs and interface cards. You can use this command to view the progress of synchronizing online user information to the standby MPUs and interface cards.
For example, when locating faults, you might need to manually trigger active/standby switchover. To ensure data consistency after the switchover, use this command to verify that the data has been synchronized completely before triggering the switchover.
# Display the access user backup state on each slot.
<Sysname> display access-user backup-state
Slot 10: Ready for smoothing
Slot 11: Smoothing
Ready for smoothing
Data synchronization has not started.
Smoothing
Data synchronization is in progress.
Smoothing finished
Data synchronization has finished.
display access-user offline-reason statistics
Use display access-user offline-reason statistics to display offline reason statistics of access users.
display access-user offline-reason statistics [ verbose ]
verbose: Displays the sub-reason codes and related statistics for each main reason code. If you do not specify this keyword, this command displays each main reason code and related statistics.
The offline reasons in the command output include normal logout reasons, abnormal logout reasons, and login failure reasons.
When the access module is busy processing services, the system might fail to display the related statistics temporarily. In this case, wait a moment and display the statistics later.
This command can display the offline reason statistics for PPPoE, L2TP, and IPoE users.
If the count for a reason code is 0, the reason code field is not displayed.
The offline reasons vary by network environment. Table 5 only list some common offline reasons. For more offline reasons, see the actual output the device.
# Display statistics for the main offline reasons.
<Sysname> display access-user offline-reason statistics
Administrator is resetting service on the NAS: 1
NAS detected an error on the port which required ending the session: 1
NAS error: 5
NAS ended session for a non-error unknown reason: 2
# Display statistics for the offline sub-reasons.
<Sysname> display access-user offline-reason statistics verbose
cut command: 1
Interface down: 1
Service-type mismatch with local-user's: 5
TERM with Ifnet down: 2
Table 5 Command output
User request
Number of users who proactively request to go offline.
Physical down
Number of users that go offline because of data interruption. For example, keepalive detection fails for PPP users.
Service can no longer be provided
Number of users that go offline because of service server interruption. For example, the LNS requests users to go offline.
Idle cut
Number of users that go offline because the idle timer expires.
Session timeout
Number of users that go offline because sessions time out. For example, the AAA-authorized session duration times out.
Number of users that go offline because the administrator resets the service. For example, the administrator executes the cut access-user command.
Administrator is ending service on the NAS
Number of users that go offline because the administrator stops the service. For example, the process exits abnormally.
Number of users that go offline because of interface failures. For example, an access interface goes down.
Number of users that went offline because the sessions were ended by the NAS due to non-error unknown reasons.
NAS error
Number of users that go offline because of NAS failures. For example, UCM failed to apply for memory resources.
NAS request
Number of users that the NAS requests to go offline. For example, the maximum number of online users is reached.
NAS ended session for reboot
Number of users that go offline because the NAS is rebooted.
Port not needed
Number of users that go offline because interfaces are disabled.
Port preempted
Number of users that go offline because interfaces are preempted.
Port suspended
Number of users that go offline because interfaces are suspended.
Service unavailable
Number of users that go offline because services are not supported. For example, the PPPoE server failed to send PADS packets.
Callback user
Number of users that go offline because of callback services. For example, PPP authentication failed.
cut command
Number of users that went offline because the administrator executed the cut access-user command.
Interface down
Number of users that went offline because the access interfaces went down or flapped.
Number of users that went offline because the access types of users did not match the service type in the local user configuration on the device.
Number of users that went offline because the access interfaces went down on the network layer.
User info error
Number of users that go offline because of incorrect user information. For example, the authentication username is empty.
Host logoff
Number of users that the client requests to go offline.
Use display access-user user-detect packet-loss-ratio to display the packet loss ratio statistics for the access user detection packets.
display access-user user-detect packet-loss-ratio [ interface interface-type interface-number [ s-vlan svlan-id ] ] [ slot slot-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays entries of all interfaces.
s-vlan svlan-id: Specifies a SVLAN by its ID. The value range for the svlan-id argument is 1 to 4094.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays entries on all cards.
After online user detection is enabled on an interface, the device will automatically record the number of sent detection packets and received packets. You can use this command to view the packet loss ratio statistics for detection packets.
If you execute the display access-user user-detect packet-loss-ratio command at a time point within a 30-second timer, this command displays the packet loss ratio statistics collected at the specified time point within the 30-second timer. For example, if you execute this display command at the 10th second within a 30-second timer, this command displays the packet loss ratio statistics collected within the 10 seconds.
On a unified network, this command displays only the packet loss ratio statistics for IPoE user detection packets. To view the packet loss ratio statistics for PPPoE and L2TP user detection packets on a unified network, use the display ppp keepalive packet-loss-ratio command.
# Display the packet loss ratio statistics for access user detection packets on all interfaces.
<Sysname> display access-user user-detect packet-loss-ratio
Slot 10:
L2TP keepalive   : 50%
Interface Ten-GigabitEthernet3/0/1:
ARP              : 10%
ND               : 15%
PPPoE keepalive  : 18%
Interface Ten-GigabitEthernet3/0/2:
ICMPv4           : 20%
ICMPv6           : 15%
Slot 11:
Interface Ten-GigabitEthernet4/0/1:
ARP              : 10%
ICMPv6           : 15%
# Display the packet loss ratio statistics for access user detection packets on the specified interface.
<Sysname> display access-user user-detect packet-loss-ratio interface ten-gigabitethernet 3/0/1.1
Slot 10:
Interface Ten-GigabitEthernet3/0/1.1:
ND               : 15%
ICMPv4           : 15%
S-VLAN: 100
ND               : 15%
ICMPv4           : 13%
S-VLAN: 200
ND               : 15%
ICMPv4           : 17%
Table 6 Command output
L2TP keepalive
Packet loss ratio of L2TP user keepalive detection packets.
Detected interface.
S-VLAN
Service provider VLAN.
ARP
Packet loss ratio of IPoE user ARP detection packets.
ND
Packet loss ratio of IPoE user ND detection packets.
ICMPv4
Packet loss ratio of IPoE user ICMPv4 detection packets.
ICMPv6
Packet loss ratio of IPoE user ICMPv6 detection packets.
PPPoE keepalive
Packet loss ratio of PPPoE user keepalive detection packets.
ip subscriber user-detect ip
ip subscriber user-detect ipv6
display bras-interface access-user-count
Use display bras-interface access-user-count to display BRAS configuration and the number users of an interface.
display bras-interface [ interface-type interface-number ] access-user-count
interface-type interface-number: Specifies an interface by its type and number. If you do not specify this option, the command displays BRAS configuration and the number users of all interfaces.
You can use this command to view configuration and user counts only on interfaces configured with IPoE or PPPoE.
#Display BRAS configuration and the number of users on Ten-GigabitEthernet 3/0/1.
<Sysname> display bras-interface ten-gigabitethernet 3/0/1 access-user-count
Interface              IPoE            PPPoE            Users
XGE3/0/1               L2-connected    Bind             100
Table 7 Command output
IPoE
Whether IPoE is enabled on the interface:
·     L2-connected—IPoE in Layer 2 access mode is enabled on the interface.
·     Routed—IPoE in Layer 3 access mode is enabled on the interface.
·     N/A—IPoE is not enabled on the interface.
PPPoE
Whether the interface has the PPPoE server protocol enabled and is bound to a VT interface:
·     Bind—The interface has the PPPoE server protocol enabled and is bound to a VT interface.
·     N/A—The PPPoE server protocol is not enabled on the interface.
Users
Number of current users on the interface.
display bras-interface configuration
Use display bras-interface configuration to display BRAS configuration and running information of an interface.
display bras-interface [ interface-type interface-number ] configuration [ slot slot-number ]
interface-type interface-number: Specifies an interface by its type and number. If you do not specify this option, the command displays BRAS configuration and running information of all interfaces.
slot slot-number: Specifies a card by its slot number. If you do not specify a slot, this command displays entries on all cards.
You can use this command to view BRAS configuration and running information only on interfaces configured with IPoE or PPPoE.
The command output and the sequence of information in the command output vary by device type, device configuration, networking mode, and device role on the network.
#Display configuration and running information of interface Route-Aggregation 1.
<Sysname> display bras-interface route-aggregation 1 configuration
Interface configuration:
  Interface name            : RAGG1
  MAC address               : 6eb9-84e6-0102
  Authentication type       : Web
  BRAS mode                 : Normal
  UP status                 : None
  Blocking                  : No
  Global interface          : Yes
  Interface deleting        : No
  Link layer status         : Down
  IPv4 network layer status : Down
  IPv6 network layer status : Down
IPoE configuration:
  IPoE access mode                            : L2-connected
  IPoE protocol type                          : Dual-stack
  IPv4 unclassified-IP trigger                : Enable
  IPv4 unclassified-IP matching-user          : Disable
  IPv6 unclassified-IP trigger                : Enable
  IPv6 unclassified-IP matching-user          : Disable
  IPoE MAC-auth                               : Enable
  IPoE inherit-PPPoE                          : Disable
  Access-out                                  : Disable
  Service identify type                       : N/A
  Lease-end-time original                     : Disable
  Web basic-service-IPv4                      : Disable
  Web support-authorized-vpn                  : Disable
  IPoE basic-service-ip-type                  : Disable
  IPoE user name type                         : MAC-address
  IPoE user name MAC separator                : N/A
  IPoE user name MAC case                     : Uppercase
  IPoE password type                          : String
  IPoE pre-auth domain name                   : N/A
  IPoE web-auth domain name                   : N/A
  IPoE MAC-auth domain name                   : N/A
  DHCP user name type                         : Sysname
  DHCP user name separator                    : N/A
  DHCP domain name                            : N/A
  DHCP domain name force                      : No
  NDRS domain name                            : N/A
  Unclassified-IP domain name                 : dm1
  IPv4 user detect mode                       : ARP
  IPv4 user detect retry times                : 5
  IPv4 user detect interval                   : 120 seconds
  IPv4 user detect NoDataCheck                : Disable
  IPv6 user detect mode                       : ND
  IPv6 user detect retry times                : 5
  IPv6 user detect interval                   : 120 seconds
  IPv6 user detect NoDataCheck                : Disable
  IPoE pre-auth user track number             : N/A
  IPoE pre-auth user fail-permit user-group   : N/A
  IPoE pre-auth user track status             : N/A
  IPoE captive-bypass type                    : N/A
  IPoE web redhcp                             : Enable
  IPoE http-fast-relay                        : Disable
  IPoE roam                                   : Enable
  IPoE roam group name                        : roam
  QoS session-group identify                  : N/A
Max session configuration:
  Interface max session number            : 1000
  NDRS max session number                 : N/A
  DHCPv4 max session number               : 500
  DHCPv6 max session number               : N/A
  IPv4 unclassified-IP max session number : N/A
  IPv6 unclassified-IP max session number : N/A
Access limit configuration:
  Access delay type                     : Even-mac and odd-mac
  Even-MAC user delay time              : 100 milliseconds
  Odd-MAC user delay time               : 100 milliseconds
  User-policy interface-down online     : No
  User-policy interface-down keepalive  : No
Nas-Port-ID configuration:
  NAS port type                          : 802.11
  IPoE circuit-id format                 : ASCII
  IPoE remote-id format                  : ASCII
  IPoE nas-port-id cn-telecom format     : Version3.0
  IPoE nas-port-id nasinfo-insert        : Yes
  PPPoE remote-id format                 : ASCII
  PPPoE circuit-id format                : ASCII
  PPPoE circuit-id mode                  : TR-101
  PPPoE nas-port-id insert BasInfo       : Disable
  PPPoE nas-port-id insert BasInfo type  : N/A
  PPPoE trust access-line-id             : No
  PPPoE access-line-id insert VxlanInfo  : Disable
  PPPoE access-line-id content           : Circuit-id
  PPPoE access-line-id separator         :
PPPoE configuration:
  PPPoE bind                             : Enable
  PPPoE agency bind                      : Disable
Table 8 Command output
MAC address
MAC address of a local interface.
Authentication type
Authentication mode:
·     Bind—Bind authentication.
·     Web—Web authentication.
·     PPP— PPP authentication.
·     Admin— Device admin user authentication.
BRAS mode
BRAS mode:
·     Normal—Normal mode (the device is not a UP).
·     UP—Forwarding mode (the device is a UP).
UP status
UP state:
·     None—The device is not a UP.
·     Main UP—The device is the master UP.
·     Hot-standby backup UP—The device is a backup UP in hot UP standby.
·     Warm-standby backup UP—The device is a backup UP in warm UP standby.
Blocking
Blocking state of the interface:
·     Yes—The interface is blocked, and does not allow new users to access.
·     No—The interface is in normal state, and allows new users to access.
Global interface
Whether the interface is a global interface.
·     Yes—The interface a global interface (for example, a Layer 3 aggregate interface).
·     No—The interface a physical interface.
Interface deleting
Interface deletion state:
·     Yes—The interface is being deleted.
·     No—The interface is in normal state.
Link layer status
Link layer state of the interface:
·     Up—The link layer state of the interface is up.
·     Down—The link layer state of the interface is down.
IPv4 network layer state of the interface:
·     Up—The network layer state of the interface is up.
·     Down—The network layer state of the interface is down.
IPv6 network layer state of the interface:
IPoE configuration
IPoE-related configuration.
IPoE access mode
IPoE access mode:
·     L2-connected—Layer 2 access mode.
·     Routed—Layer 3 access mode.
·     N/A—IPoE is not enabled.
IPoE protocol type
Protocol stack for which IPoE is enabled:
·     IPv4—IPoE is enabled for the IPv4 protocol stack.
·     IPv6—IPoE is enabled for the IPv6 protocol stack.
·     Dual-stack—IPoE is enabled for both the IPv4 protocol stack and the IPv6 protocol stack.
Unclassified-IPv4 packet initiation state:
·     Enable.
·     Disable.
Unclassified-IPv4 packets allow only the specified types of users to come online:
·     Enable—Unclassified-IPv4 packets allow only the matching static users, abnormally logged out DHCP users, roaming users, and users in loose mode to come online.
·     Disable—Unclassified-IPv4 packets allow dynamic users in addition to the matching static users, abnormally logged out DHCP users, roaming users, and users in loose mode to come online.
Unclassified-IPv6 packet initiation state:
·     Enable.
·     Disable.
Unclassified-IPv6 packets allow only the specified types of users to come online:
·     Enable—Unclassified-IPv6 packets allow only the matching static users, abnormally logged out DHCP users, and roaming users to come online.
·     Disable—Unclassified-IPv6 packets allow dynamic users in addition to the matching static users, abnormally logged out DHCP users, and roaming users to come online.
IPoE MAC-auth
IPoE Web MAC authentication state:
·     Enable.
·     Disable.
IPoE inherit-PPPoE
State of inherit-PPPoE for IPoE.
·     Enable.
·     Disable.
Access-out
IPoE access-out authentication state:
·     Enable.
·     Disable.
Service identification type of an access user.
·     8021p second-vlan—Identifies a service by the 802.1p priority value in the inner VLAN tag of a packet in QinQ mode.
·     8021p vlan—Identifies a service by the 802.1p priority value in the VLAN tag of a packet (the 802.1p priority value in the outer VLAN tag of a packet in QinQ mode).
·     DSCP—Identifies a service by the DSCP value in a packet.
·     Second-vlan—Identifies a service by the inner VLAN ID of a packet in QinQ mode.
·     Vlan—Identifies a service by the VLAN ID of a packet (the outer VLAN ID of a packet in QinQ mode).
State of using the lease expiration time when an IPoE user went offline as the lease expiration time when the IPoE comes online again.
·     Enable.
·     Disable.
State of IPv6 protocol stack dependency of IPoE Web users on IPv4 protocol stack:
·     Enable.
·     Disable.
State of the VPN authorization feature in the Web postauthentication domain
·     Enable.
·     Disable.
Protocol stack on which the main serivce of IPoE users depends:
·     IPv4—The main serivce of IPoE users depends on the IPv4 protocol stack.
·     IPv6—The main serivce of IPoE users depends on the IPv6 protocol stack.
·     Disable—The protocol stack on which the main serivce of IPoE users depends is not set.
IPoE user name type
Authentication username type of an individual IPoE user:
·     MAC-address—Uses the MAC address as the username.
·     String—Uses the specified string as the username.
·     N/A—No authentication username is configured for an individual IPoE user.
IPoE user name string
String specified as the authentication username of an IPoE user.
MAC address separator when IPoE uses MAC addresses as authentication usernames.
Case of MAC addresses when IPoE uses MAC addresses as authentication usernames.
·     Lowercase—Letters in MAC addresses are lower case.
·     Uppercase—Letters in MAC addresses are upper case.
IPoE password type
Authentication password type of an individual IPoE user:
·     String—Uses the specified string as the password.
·     MAC-address—Uses the MAC address as the password.
·     N/A—No authentication password is configured for IPoE.
IPoE password address-separator
MAC address separator when IPoE uses MAC addresses as passwords.
IPoE password MAC case
Case of MAC addresses when IPoE uses MAC addresses as passwords:
Preauthentication domain name for IPoE Web authentication.
Authentication domain name for IPoE Web authentication.
Authentication domain name for MAC authentication users.
DHCP user name type
Authentication username type of DHCP users:
·     Sysname—Uses the access device name as the username.
·     Source-IP—Uses the source IP address in packets as the username.
·     Source-MAC—Uses the source MAC address in packets as the username.
·     Client-id—Uses the DHCPv4 Option61 or DHCPv6 Option1 in DHCP packets as the username.
·     Vendor-class—Uses the DHCPv4 Option60 or DHCPv6 Option16 in DHCP packets as the username.
·     Circuit-id—Uses the DHCPv4 Option82 sub-option1 or DHCPv6 Option18 in DHCP packets as the username.
·     Remote-id—Uses the DHCPv4 Option82 sub-option2 or DHCPv6 Option37 in DHCP packets as the username.
·     Vendor-specific—Uses the DHCPv4 Option82 sub-option9 or DHCPv6 Option17 in DHCP packets as the username.
·     Nas-port-id—Uses the NAS-PORT-ID attribute in the authentication packets as the username.
·     Vlan—Uses the outer VLAN in the authentication packets as the username.
·     Second-vlan—Uses the inner VLAN in the authentication packets as the username.
·     Slot—Uses the slot number of a user as the username.
·     Subslot—Uses the subslot of a user as the username.
·     Port—Uses the access port number of a user as the username.
·     Circuit-id MAC—Uses the MAC address in the Circuit-ID (Option82 sub-option1) as the username.
·     Hostname—Uses the DHCPv4 Option12 in DHCP packets as the username.
·     N/A—No authentication username is configured for a DHCP user.
Separator used for the field used as the authentication username of a DHCP user.
DHCP user name address-separator
MAC address separator when MAC addresses are used as authentication usernames of DHCP users.
DHCP user name keep original
Directly use the information in the DHCPv4 Option12, DHCPv4 Option60, or DHCPv6 Option16 field in DHCP packets as the username and transmit it to the authentication server for authentication:
·     Yes—The device directly transmits information above to the authentication server for authentication.
·     No—The device converts non-printable characters into printable characters and then transmits the information to the authentication server for authentication.
DHCP user name absent replace
Processing when the DHCPv4 Option60 or DHCPv6 Option16 field does not exist in DHCP packets:
·     Yes—Replaces an inexistent option with the domain name of the user authentication domain as the username when condition above exists.
·     No—Leaves the option part in the username empty when the condition above exists.
DHCP user name string
String specified as the authentication username of a DHCP user.
DHCPv4 password type
An individual DHCPv4 user uses the specified information in the DHCPv4 packets as the authentication password:
·     Circuit-id—Uses the DHCPv4 Option82 sub-option1 field in DHCP packets as the authentication password.
·     Option60—Uses the Option60 field in DHCPv4 packets as the authentication password.
·     User-class—Uses the Option77 field in DHCPv4 packets as the authentication password.
·     N/A—No field in the DHCPv4 packets is specified as the authentication password.
DHCPv4 password length
Password length when a DHCPv4 user uses the specified information in the DHCPv4 packets as the authentication password:
N/A—The password length is not configured.
DHCPv4 password offset length
Offset length when a DHCPv4 user uses the specified information in the DHCPv4 packets as the authentication password:
N/A—The offset length is not configured.
Original mode of DHCPv4 password option 60
Whether to directly use the information selected from Option60 according to the specified rule as the authentication password without performing validity check:
·     Yes.
·     No.
DHCPv6 password type
An individual DHCPv6 user uses the specified information in the DHCPv6 packets as the authentication password:
·     Option16—Uses the Option16 or Option17 field in DHCPv6 packets as the authentication password.
·     N/A—No field in the DHCPv6 packets is specified as the authentication password.
DHCPv6 password length
Password length when a DHCPv6 user uses the specified information in the DHCPv6 packets as the authentication password:
DHCPv6 password offset length
Offset length when a DHCPv6 user uses the specified information in the DHCPv6 packets as the authentication password:
Original mode of DHCPv6 password option 16 or option 17
Whether to directly use the information selected from Option16 or Option17 according to the specified rule as the authentication password without perform validity check:
·     Yes.
·     No.
DHCP domain name
Authentication domain name for DHCP users.
Whether the authentication domain name configured for DHCP users is forced:
·     Yes—The authentication domain name configured for DHCP users is forced.
·     No—The authentication domain name configured for DHCP users is not forced.
DHCP domain type
Sub-option type when a DHCP user uses the vendor class as the authentication domain name:
·     Vlan—Uses the outer VLAN in authentication packets as the  authentication domain name.
DHCP domain separator
Separator when a DHCP user uses the vendor class as the authentication domain name.
DHCP domain string
String specified as the authentication domain name of a DHCP user.
NDRS user name type
Authentication username type of NDRS users:
·     Nas-port-id—Uses the NAS-Port-ID attribute in the authentication packets as the username.
·     Subslot—Uses the subslot number of a user as the username.
·     N/A—No authentication username is configured for NDRS users.
NDRS user name separator
Separator for the field used as the authentication username of an NDRS user.
NDRS user name address-separator
MAC address separator when MAC addresses are used as authentication usernames of NDRS users.
NDRS user name string
String specified as the authentication username of an NDRS user.
NDRS domain name
Authentication domain name for NDRS users.
Unclassified-IP user name type
Authentication username type of unclassified-IP access users:
·     N/A—No authentication username is configured for unclassified-IP users.
Unclassified-IP user name separator
Separator for the field used as the authentication username of an unclassified-IP user.
Unclassified-IP user name address-separator
MAC address separator when MAC addresses are used as authentication usernames of unclassified-IP users.
Unclassified-IP user name string
String specified as the authentication username of an unclassified-IP access user.
Authentication domain name for an unclassified-IP user.
Online detection type for IPv4 access users:
·     ARP—Uses ARP packets as the detection packets.
·     ICMP—Uses ICMP packets as the detection packets.
·     N/A—Online detection is not enabled for the IPv4 protocol stack.
Maximum number of online detection retries for the IPv4 access users.
Online detection interval for IPv4 access users in seconds.
Ignore data traffic update in online detection for IPv4 access users:
·     Enable—Detection packets are sent after the detection timer expires no matter whether user uplink traffic is updated within a detection timer.
·     Disable—No detection packets are sent within one detection timer period after the detection timer expires if user uplink traffic is updated within a detection timer period.
Online detection type for IPv6 access users:
·     ND—Uses ND packets as the detection packets.
·     ICMP—Uses ICMPv6 packets as the detection packets.
·     N/A—Online detection is not enabled for the IPv6 protocol stack.
Maximum number of online detection retries for the IPv6 access users.
Online detection interval for IPv6 access users in seconds.
Ignore data traffic update in online detection for IPv6 access users:
ID of the track entry associated with a fail-permit user group.
Fail-permit user group.
Current state of the track entry associated with the fail-permit user group:
·     NotReady—The monitored object is not ready.
·     Positive—The monitored object is operating normally.
·     Negative—The monitored object is operating abnormally.
·     N/A—No track entry is associated with the fail-permit user group.
IPoE captive-bypass feature type:
·     Android—Specifies Android users.
·     IOS—Specifies IOS users.
·     Android and IOS—Specifies Android and IOS users.
·     N/A—The IPoE captive-bypass feature is not configured.
IPoE web redhcp
Re-DHCP for IPoE Web authentication:
·     Enable—Re-DHCP for IPoE Web authentication is enabled.
·     Disable—Re-DHCP for IPoE Web authentication is disabled.
IPoE http-fast-reply
HTTP packet fast reply state:
·     Enable—HTTP packet fast reply is enabled.
·     Disable—HTTP packet fast reply is disabled.
IPoE roam
IPoE individual user roaming state:
·     Enable—IPoE individual user roaming is enabled.
·     Disable—IPoE individual user roaming is disabled.
Roaming group to which the interface belongs.
Session group recognition method:
·     Customer-vlan—Recognizes a session group by inner VLAN (private network VLAN of the user).
·     Service-vlan—Recognizes a session group by outer VLAN (public network VLAN that the service provider allocates to the user).
·     Customer-service-vlan—Recognizes a session group by inner VLAN and outer VLAN.
·     Subscriber-id—Recognizes a session group by subscriber ID. For more information about subscriber IDs, see BRAS Services Command Reference.
·     N/A—No session group recognition method is configured.
Configuration related to the maximum numbers of sessions.
Maximum number of individual IPoE sessions and leased subuser sessions that can be created on an interface.
Maximum number of IPoE sessions that can be triggered by RS packets on an interface.
Maximum number of IPoE sessions that can be triggered by DHCPv4 packets on an interface.
Maximum number of IPoE sessions that can be triggered by DHCPv6 packets on an interface.
Maximum number of IPoE dynamic sessions that can be triggered by unclassified-IPv4 packets on an interface.
Maximum number of IPoE dynamic sessions that can be triggered by unclassified-IPv6 packets on an interface.
Access limit configuration.
Access delay type
Response delay time for IPoE users on an interface:
·     Even-MAC—Specifies the response delay time for IPoE users with even MAC addresses.
·     Odd-MAC—Specifies the response delay time for IPoE users with odd MAC addresses.
·     Even-MAC and odd-MAC—Specifies the response delay time for all users on the interface.
·     N/A—The response delay time for IPoE users is not configuration on the interface.
Response delay time for IPoE users with even MAC addresses in milliseconds.
Response delay time for IPoE users with odd MAC addresses in milliseconds.
Keep BRAS users online when an interface goes down:
·     Yes—Keep BRAS users online when an interface goes down.
·     No—Log out BRAS users when an interface goes down.
Online detection state if users are kept online when the interface goes down. (This function takes effect only when the function of keeping users online when the interface goes down is configured.)
·     Yes—Online detection does not take effect  if users are kept online when the interface goes down.
·     No—Online detection still takes effect if users are kept online when the interface goes down.
IPoE chasten configuration
IPoE blocking configuration.
IPoE chasten quiet time
IPoE user blocking period in seconds. The value of 0 indicates that blocking is not enabled.
IPoE chasten period time
Detection period of consecutive IPoE user authentication failures, in seconds.
IPoE chasten check times
Maximum number of consecutive IPoE user authentication failures allowed within a detection period.
NAS-Port-ID configuration.
NAS port type
NAS-Port-Type attribute type of an interface, which is Ethernet by default:
·     802.11—Interface type compliant with the Wireless-IEEE 802.11 standard. The corresponding code is 19.
·     Adsl-cap—Asymmetric DSL, Carrierless Amplitude Phase Modulation (ADSL-CAP) interface type. The corresponding code is 12.
·     Adsl-dmt—Asymmetric DSL, Discrete Multi-Tone (ADSL-DMT) interface type. The corresponding code is 13.
·     Async—Async interface type. The corresponding code is 0.
·     Cable—Cable interface type. The corresponding code is 17.
·     Ethernet—Ethernet interface type. The corresponding code is 15.
·     G.3-fax—G.3 fax interface type. The corresponding code is 10.
·     HDLC—HDLC interface type. The corresponding code is 7.
·     IDSL—ISDN Digital Subscriber Line (IDSL) interface type. The corresponding code is 14.
·     ISDN-async-v110—ISDN-async-v110 interface type. The corresponding code is 4.
·     ISDN-async-v120—ISDN-async-v120 interface type. The corresponding code is 3.
·     ISDN-sync—ISDN sync interface type. The corresponding code is 2.
·     Piafs—Interface type compliant with the Personal Handyphone System (PHS) Internet Access Forum Standard (PIAFS) standard. The corresponding code is 6.
·     SDSL—Symmetric DSL (SDSL) interface type. The corresponding code is 11.
·     Sync—Sync interface type. The corresponding code is 1.
·     Virtual—Virtual interface type. The corresponding code is 5.
·     Wireless-other— Wireless-other interface type. The corresponding code is 18.
·     X.25—X.25 interface type. The corresponding code is 8.
·     X.75—X.75 interface type. The corresponding code is 9.
·     XDSL—Digital Subscriber Line of unknown type (XDSL) interface type. The corresponding code is 16.
Parsing format for the circuit-id in DHCP Option by IPoE. The default is ascii.
·     ASCII—Parses in string format.
·     Hex—Parses in hexadecimal format.
Parsing format for the remote-id in DHCP Option by IPoE. The default is ascii.
IPoE nas-port-id bind interface type
Interface type when IPoE uses the specified interface information to fill in the NAS-Port-ID attribute of RADIUS.
IPoE nas-port-id bind interface number
Interface number when IPoE uses the specified interface information to fill in the NAS-Port-ID attribute of RADIUS.
Encapsulation format of the NAS-Port-ID attribute that the access device sends to the RADIUS server when IPoE users perform authentication. The default is version 1.0.
·     Version1.0—Specifies the version 1.0 format. The NAS-Port-ID attribute sent to the RADIUS server is filled in the China-Telecom 163 format.
·     Version2.0—Specifies the version 2.0 format. The NAS-Port-ID attribute sent to the RADIUS server is filled according to the YDT 2275-2011 subscriber access loop (port) identification requirements.
·     Version3.0—Specifies the version 3.0 format.
·     Version4.0—Specifies the version 4.0 format.
·     Version5.0—Specifies the version 5.0 format.
The device extracts the content in Option 82 Circuit-ID from DHCPv4 packets or Option18 from DHCPv6 packets, and uses it together with the NAS information as the NAS-Port-ID attribute string.
·     Yes—This feature is enabled on the interface
·     No—This feature is disabled on the interface.
Transmission format of the remote-id in the PPPoE access line ID. The default is string.
·     ASCII—String format, which transmits the remote-id information in the form of characters.
·     Hex—Hexadecimal format, which transmits the remote-id information in the form of hexadecimal digits.
Transmission format of the circuit-id in the PPPoE access line ID. The default is string.
·     ASCII—String format, which transmits the circuit-id information in the form of characters.
·     Hex—Hexadecimal format, which transmits the circuit-id information in the form of hexadecimal digits.
Parsing format of the circuit-id in the PPPoE access line ID. The default is TR-101.
·     CN-telecom—China Telecom format.
·     TR-101—TR-101 format.
PPPoE nas-port-id interface type
Interface type when PPPoE uses the specified interface information to fill in the NAS-Port-ID attribute of RADIUS.
PPPoE nas-port-id interface number
Interface number when PPPoE uses the specified interface information to fill in the NAS-Port-ID attribute of RADIUS.
Function of automatically inserting BAS information into the NAS-Port-ID attribute by PPPoE:
·     Enable—The function of automatically inserting BAS information into the NAS-Port-ID attribute by PPPoE is enabled.
·     Disable—The function of automatically inserting BAS information into the NAS-Port-ID attribute by PPPoE is disabled.
Format for the BAS information automatically inserted into the NAS-Port-ID attribute by PPPoE:
·     CN-163—Inserts BAS information in the China Telecom 163 format.
·     CN-163.redback—Inserts BAS information in the China Telecom 163 redback format.
·     N/A—Does not automatically insert BAS information.
Whether PPPoE trusts the contents in the access line ID in the received packets.
·     Yes—Sets the trust mode.
·     No—Does not set the trust mode.
Function of inserting VXLAN information into the NAS-Port-ID attribute by PPPoE:
·     Enable—The function of inserting VXLAN information into the NAS-Port-ID attribute by PPPoE is enabled.
·     Disable—The function of inserting VXLAN information into the NAS-Port-ID attribute by PPPoE is disabled.
Type of the content in the NAS-Port-ID attribute sent to the RADIUS server by PPPoE. By default is, only the circuit-ID is included.
·     All—Uploads both the circuit-id and remote-id.
·     Circuit-id—Uploads only the Circuit-id.
·     Remote-id—Uploads only the Remote-id.
Separator for the content in the NAS-Port-ID attribute sent to the RADIUS server by PPPoE. The length is one character. The default is a space.
UP backup configuration
UP backup profile ID
UP backup profile ID.
Interface configure role
Configured interface role:
·     Master—The interface is the master interface in the UP backup profile.
·     Backup—The interface is the backup interface in the UP backup profile.
·     N/A—The interface is not an interface in the UP backup profile.
Interface backup status
Interface backup state:
·     Master—The interface is the master interface.
·     Backup—The interface is the backup interface.
·     Unbind—The master/backup relationship of the interface is removed.
·     Failed—The interface is in failed state.
·     N/A—The interface is not a UP backup interface.
Backup mode
Backup mode:
·     Hot—Hot backup.
·     Warm—Warm backup.
·     Load Balance—Load balancing backup.
·     Warm Load Balance—Warm load balancing backup.
·     N/A—UP backup is not set.
Interface backup mode
Interface backup mode of the UP backup profile to which the interface belongs:
·     Inherit-main—Inherits the main interface state.
·     No-inherit—Does not inherit the main interface state.
Virtual MAC address
Virtual MAC address of the interface.
Backup relation ID
Backup relationship ID.
Configured main interface
Configured master interface. N/A indicate that no master interface is configured.
Configured backup interface
Configured backup interface. N/A indicate that no backup interface is configured.
Master UP ID
ID of the UP to which the configured master interface belongs.
UP running configuration
UP running configuration.
ARP trigger
ARP packet initiation state:
·     Enable.
·     Disable.
NSNA trigger
IPv6 NS/NA packet initiation state:
·     Enable.
·     Disable.
NDRS trigger
IPv6 NDRS packet initiation state:
·     Enable.
·     Disable.
MAC trigger
MAC trigger authentication state:
·     Enable.
·     Disable.
PPPoE bind
PPPoE server protocol state on the interface:
·     Enable—The interface has the PPPoE server protocol enabled and is bound to a VT interface.
·     Disable—The PPPoE server protocol is not enabled on the interface.
ARP proxy
ARP proxy state on the interface:
·     Enable.
·     Disable.
ND proxy
ND proxy state on the interface:
·     Enable.
·     Disable.
UP ID
UP ID.
Interface online
Online state of the interface:
·     Yes—The interface is in online state.
·     No—The interface is in offline state.
IPoE protocol type
IPoE access protocol stack. This feature takes effect only when IPoE is enabled.
PPPoE detect retry times
Maximum number of PPPoE user keepalive detection retries.
PPPoE detect interval
PPPoE user keepalive detection interval, in seconds.
PPPoE detect NoDataCheck
Ignore data traffic update in keepalive detection for PPPoE users:
PPPoE agency bind
State of PPPoE agency an interface.
·     Enable—The interface has the PPPoE agency protocol enabled and is bound to a VT interface.
·     Disable—The PPPoE agency protocol is not enabled on the interface.
display bras-interface users-by-vlan
Use display bras-interface users-by-vlan to display the number of BRAS users by VLAN on an interface.
display bras-interface interface-type interface-number users-by-vlan [ s-vlan s-vlan-id [ c-vlan c-vlan-id ] ]
s-vlan svlan-id: Specifies a SVLAN by its ID. The value range for the svlan-id argument is 1 to 4094. If you do not specify this option, the command displays the number of BRAS users for each SVLAN and CVLAN combination on an interface.
c-vlan cvlan-id: Specifies a CVLAN by its ID. The value range for the cvlan-id argument is 1 to 4094. If you specify the s-vlan keyword but do not specify the c-vlan keyword, this command displays the number of BRAS users for the combination of the fixed SVLAN and each CVLAN on an interface.
#Display the number of BRAS users by VLAN on Ten-GigabitEthernet 3/0/1.1.
<Sysname> display bras-interface ten-gigabitethernet 3/0/1.1 users-by-vlan
Interface                  S-VLAN/C-VLAN            Users
XGE3/0/1.1                 100/200                  200
XGE3/0/1.1                 100/201                  160
XGE3/0/1.1                 111/105                  100
Table 9 Command output
User access interface name.
S-VLAN
SVLAN. This field displays a hyphen (-) if no SVLAN exists.
C-VLAN
CVLAN. This field displays a hyphen (-) if no CVLAN exists.
Users
Total number of users.
display max-user history
Use display max-user history to display history information about the peak user counts.
display max-user history [ slot slot-number ]
This command displays the following peak user counts and the time when each peak user count was reached:
·     Maximum number of users initiating authentication concurrently.
·     Maximum number of users passing authentication concurrently.
·     Maximum number of sessions set to the driver concurrently.
·     Maximum number of users being accounted concurrently.
When the access module is busy processing services, the history information might not be displayed. In this case, wait for several minutes and then try again.
In the current software version, the history information about the peak user counts can be displayed for PPPoE, L2TP, and IPoE users.
Users authenticated on logical interfaces such as aggregate interfaces are processed in the same way as users authenticated on physical interfaces. The history information of the peak online user counts issued to the driver is displayed only on the slot of the physical interface where users actually come online.
# Display history information about the peak user counts.
<Sysname> display max-user history slot 10
Slot 10:
PPPoE:
Max concurrent users initiating authentication: 2      Time: 2019-01-08 19:48:23
Max concurrent users passing authentication: 2         Time: 2019-01-08 19:48:23
Max concurrent sessions set to driver: 2               Time: 2019-01-08 19:48:23
Max concurrent users in accounting: 2                  Time: 2019-01-08 19:48:23
L2TP:
Max concurrent users initiating authentication: 5      Time: 2019-01-08 19:48:23
Max concurrent users passing authentication: 5         Time: 2019-01-08 19:48:23
Max concurrent sessions set to driver: 5               Time: 2019-01-08 19:48:23
Max concurrent users in accounting: 5                  Time: 2019-01-08 19:48:23
IPoE:
Max concurrent users initiating authentication: 6      Time: 2019-01-08 19:48:23
Max concurrent users passing authentication: 6         Time: 2019-01-08 19:48:23
Max concurrent sessions set to driver: 6               Time: 2019-01-08 19:48:23
Max concurrent users in accounting: 6                  Time: 2019-01-08 19:48:23
Table 10 Command output
Maximum number of users initiating authentication concurrently after the system starts up.
This field is not displayed if the user count is 0.
Maximum number of users passing authentication concurrently after the system starts up.
Maximum number of sessions set to the driver concurrently after the system starts up.
Maximum number of users being accounted concurrently after the system starts up.
Time
Time when the peak user count was reached.
reset max-user history
display trace access-user
Use display trace access-user to display service tracing object configuration information.
display trace access-user [ object object-id ]
object object-id: Specifies a service tracing object by its ID, in the range of 1 to 5. If you do not specify a tracing object, this command displays configuration information for all service tracing objects.
This command displays configuration information for only service tracing objects whose tracing time has not expired.
#Display configuration information for all service tracing objects.
<Sysname> display trace access-user
Object ID: 1
Access mode: IPoE
User name: aaa
Access interface: Ten-GigabitEthernet3/0/1.1
IP address: 1.1.1.2
MAC address: 0001-0002-0003
Service VLAN: 3
Customer VLAN: 2
Output direction: VTY
Aging time: 0 min
Object ID: 2
Access mode: LNS
User name: aaa
Access interface: Ten-GigabitEthernet3/0/1.2
IP address: 1.1.1.3
Service VLAN: 3
Customer VLAN: 2
Tunnel ID: 12345
Calling station ID: 7425-8a23-23d5 XGE3/0/1.2:0003.0002
Aging time: 0 min
Table 11 Command output
Object ID
ID of the service tracing object.
Access mode
Access mode of the service tracing object:
·     IPoE.
·     PPPoE.
·     LNS.
User name
Username of the access user.
Access interface
Access interface of the access user.
IP address
IP address of the access user.
MAC address
MAC address of the access user.
Service VLAN
Outer VLAN ID of the access user.
Customer VLAN
Inner VLAN ID of the access user.
Tunnel ID
L2TP tunnel ID of the access user. This field is displayed only for L2TP users.
Calling station ID
L2TP calling number. If a user comes online without carrying a calling station, this field displays a hyphen (-).
Output direction
Location to which the service tracing object information is output.
Aging time
Tracing time of the service tracing object.
trace access-user
flow-statistics frequency
Use flow-statistics frequency to set the traffic accounting frequency mode for online users.
Use undo flow-statistics frequency to restore the default.
flow-statistics frequency { fast | normal | slow }
The traffic accounting frequency mode for online users is normal.
fast: Specifies the fast mode. For high accuracy of the BRAS user traffic statistics, specify this keyword.
normal: Specifies the normal mode. For medium accuracy of the BRAS user traffic statistics, specify this keyword.
slow: Specifies the slow mode. For low accuracy of the BRAS user traffic statistics, specify this keyword.
# Set the traffic accounting frequency mode for online users to fast.
[Sysname] flow-statistics frequency fast
nas-port-type
Use nas-port-type to configure the NAS-Port-Type for an interface.
Use undo nas-port-type to restore the default.
nas-port-type { 802.11 | adsl-cap | adsl-dmt | async | cable | ethernet | g.3-fax | hdlc | idsl | isdn-async-v110 | isdn-async-v120 | isdn-sync | piafs | sdsl | sync | virtual | wireless-other | x.25 | x.75 | xdsl }
undo nas-port-type
The NAS-Port-Type for an interface is Ethernet.
Layer 3 Ethernet interface/subinterface view
Layer 3 aggregate interface/subinterface view
L3VE interface/subinterface view
802.11: Specifies the port type complying with Wireless-IEEE 802.11. The type ID is 19.
adsl-cap: Specifies the ADSL-CAP port type, including Asymmetric DSL and Carrierless Amplitude Phase Modulation. The type ID is 12.
adsl-dmt: Specifies the ADSL-DMT port type, including Asymmetric DSL and Discrete Multi-Tone. The type ID is 13.
async: Specifies the Async port type with a type ID of 0.
cable: Specifies the Cable port type with a type ID of 17.
ethernet: Specifies the Ethernet port type with a type ID of 15.
g.3-fax: Specifies the G.3 Fax port type with a type ID of 10.
hdlc: Specifies the HDLC port type with a type ID of 7.
idsl: Specifies the IDSL port type with a type ID of 14.
isdn-async-v110: Specifies the ISDN Async V.110 port type with a type ID of 4.
isdn-async-v120: Specifies the ISDN Async V.120 port type with a type ID of 3.
isdn-sync: Specifies the ISDN Sync port type with a type ID of 2.
piafs: Specifies the port type complying with PIAFS. The type ID is 6.
sdsl: Specifies the SDSL port type with a type ID of 11.
sync: Specifies the Sync port type with a type ID of 1.
virtual: Specifies the Virtual port type with a type ID of 5.
wireless-other: Specifies the Wireless-other port type with a type ID of 18.
x.25: Specifies the X.25 port type with a type ID of 8.
x.75: Specifies the X.75 port type with a type ID of 9.
xdsl: Specifies the XDSL port type with a type ID of 16.
The nas-port-type attribute is used for RADIUS authentication and accounting. For more information about the nas-port-type attribute, see RFC 2865.
This command does not affect existing users.
#Configure the NAS-Port-Type as sdsl for Ten-GigabitEthernet 3/0/1.
[Sysname] interface ten-gigabitethernet 3/0/1
[Sysname-Ten-GigabitEthernet3/0/1] nas-port-type sdsl
reset access-user offline-reason statistics
Use reset access-user offline-reason statistics to clear offline reason statistics of access users.
# Clear statistics for the offline reasons.
<Sysname> reset access-user offline-reason statistics
reset access-user user-detect packet-loss-ratio
Use reset access-user user-detect packet-loss-ratio to clear the packet loss ratio statistics for the access user detection packets.
reset  access-user user-detect packet-loss-ratio [ interface interface-type interface-number ] [ slot slot-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command clears entries of all interfaces.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command clears entries on all cards.
On a unified network, this command clears only the packet loss ratio statistics for IPoE user detection packets. To clear the packet loss ratio statistics for PPPoE and L2TP user detection packets on a unified network, use the reset ppp keepalive packet-loss-ratio command.
After you execute the reset access-user user-detect packet-loss-ratio command to clear the packet loss ratio statistics for detection packets, the device will re-calculate the packet loss ratio and the continuous intervals. When the packet loss ratio meets the alarm conditions continuously for three intervals, an alarm will be output. For more information, see the access-user user-detect packet-loss-ratio-threshold command.
After you execute the reset system internal ucm statistics command to clear the detection packet statistics, the device will also clear the packet loss ratio statistics and re-calculate the packet loss ratio and continuous intervals. When the alarm conditions are met, an alarm will be output.
# Clear the packet loss ratio statistics for access user detection packets on all interfaces.
<Sysname> reset access-user user-detect packet-loss-ratio
reset ppp keepalive packet-loss-ratio (BRAS Services Command Reference)
Use reset max-user history to clear history information about the peak user counts.
reset max-user history [ slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a slot, this command clears entries on all cards.
This command clears the following peak user counts and the time when each peak user count was reached:
# Clear history information about the peak user counts for slot 1.
<Sysname> reset max-user history slot 1
slot-user-warning-threshold
Use slot-user-warning-threshold to configure the per-slot user count alarm threshold.
Use undo slot-user-warning-threshold to restore the default.
slot-user-warning-threshold threshold-value
The per-slot user count alarm threshold is 100.
threshold-value: Specifies the per-slot user count alarm threshold in percentage (the percentage of the user count on a slot to the per-slot maximum user count allowed), in the range of 1 to 100. When you set the upper-limit-value argument to 100 (the default) in this command, the result is the same as when this command is not executed.
You can use this command to set the per-slot user count alarm threshold. When the user count on a slot exceeds the threshold, an alarm is triggered automatically. Then, the administrator can promptly know the online user conditions of the network.
This feature counts only the number of IPoE users, PPPoE users, and L2TP users.
·     A dual-stack PPPoE user is counted as one user.
·     A dual-stack IPoE user is counted as one user.
·     For IPoE leased users, one interface-leased user is counted as one user and one subnet-leased user is counted as one user.
·     For IPoE leased subusers, one subuser is counted as one user.
·     L2TP users on LACs are counted in the same way as PPPoE users are counted. L2TP users on LNSs are not counted.
Suppose the per-slot maximum user count allowed is a and the per-slot user count alarm threshold is b. The following rules apply:
·     When the user count on a slot exceeds a×b, the alarm information is output.
·     When the user count on a slot drops within the normal range, the alarm clearing information is output.
In some special cases, the user count on a slot frequently changes in the critical range, which causes frequent output of alarm information and alarm clearing information. To avoid this problem, the system introduces a buffer area when the user count on a slot drops below the threshold. The buffer area size is 10% of the threshold set. Suppose the buffer area size is c. Then, c=a×b÷10. When the user count on a slot drops below a×b-c, the alarm clearing information is output.
For example, suppose a is 1000 and b is 80%. Then, c= a×b÷10=1000×80%÷10=80.
·     When the user count on a slot exceeds a×b=1000×80%=800, the alarm information is output.
·     When the user count on a slot drops below a×b-c=800-80=720, the alarm clearing information is output.
The alarm information and alarm clearing information output both contain the logs and traps.
·     The generated log messages by the device will be sent to the information center. The information center configuration specifies the log message sending rule and destination. For more information about the information center, see Network Management and Monitoring Configuration Guide.
·     For traps to be correctly sent to the NMS host, you must execute the snmp-agent trap enable slot-user-warning-threshold command in addition to configuring the SNMP alarm feature correctly. For more information about SNMP alarms, see SNMP configuration in Network Management and Monitoring Guide.
# Set the per-slot user count threshold to 80.
[Sysname] slot-user-warning-threshold 80
Use snmp-agent trap enable slot-user-warning-threshold to enable the per-slot user count trap feature.
Use undo snmp-agent trap enable slot-user-warning-threshold to disable the per-slot user count trap feature.
The per-slot user count trap feature is disabled.
With the per-slot user count trap feature enabled, when the user count on a slot exceeds the set threshold or drops within the normal range, a trap is generated. The generated trap will be sent to the SNMP module of the device. You can set the trap sending parameters in SNMP to determine how the traps are output. For more information about traps, see Network Management and Monitoring Configuration Guide.
This feature takes effect only when the per-slot user count alarm threshold is set.
# Enable the per-slot user count trap feature.
[Sysname] snmp-agent trap enable slot-user-warning-threshold
snmp-agent trap enable user-warning-threshold
Use snmp-agent trap enable user-warning-threshold to enable SNMP notifications for the device-level access user count.
Use undo snmp-agent trap enable user-warning-threshold to disable SNMP notifications for the device-level access user count.
SNMP notifications are disabled for the device-level access user count trap feature.
The number of access user sessions on the whole device refers to the total number of IPoE sessions, PPPoE sessions, and L2TP sessions on the device.
With SNMP notifications enabled for the device-level access user count, when the access user session count ratio on the device exceeds the threshold or restores to the normal range, the corresponding alarm is generated. The generated alarms are sent to the SNMP module of the device. You can specify how the alarms are output through setting the alarm output parameters in SNMP. For more information about alarms, see SNMP configuration in Network Management and Monitoring Guide.
For this feature to take effect, you must first configure the device-level access user count alarm threshold. Use one of the following commands to configure the device-level user count alarm threshold:
·     access-user session-threshold (Applicable to IPoE, PPPoE, and L2TP users.)
·     l2tp session-threshold (Applicable to only L2TP users.)
·     ppp session-threshold (Applicable to only PPPoE users.)
If all of the preceding commands are executed, all of them take effect. An alarm is output when any threshold is reached.
# Enable SNMP notifications for the device-level access user count.
[Sysname] snmp-agent trap enable user-warning-threshold
l2tp session-threshold (BRAS Services Command Reference)
ppp session-threshold (BRAS Services Command Reference)
trace access-user
Use trace access-user to create a service tracing object.
Use undo trace access-user to delete a service tracing object.
trace access-user object object-id { access-mode { ipoe | lns | pppoe } | c-vlan vlan-id | interface interface-type interface-number | ip-address ip-address | mac-address mac-address | s-vlan vlan-id | tunnel-id tunnel-id | username user-name } * [ aging time | output { file file-name | syslog-server server-ip-address | vty } ] *
trace access-user object object-id [ access-mode { ipoe | lns | pppoe } | c-vlan vlan-id | interface interface-type interface-number | ip-address ip-address | mac-address mac-address | s-vlan vlan-id | tunnel-id tunnel-id | username user-name ] * calling-station-id calling-station-id
undo trace access-user { all | object object-id }
No service tracing object exists.
object object-id: Specifies a service tracing object ID, in the range of 1 to 5.
access-mode: Creates a service tracing object based on an access mode.
·     ipoe: Creates a service tracing object based on the IPoE access mode.
·     lns: Creates a service tracing object based on the LNS device in L2TP access mode.
·     pppoe: Creates a service tracing object based on the PPPoE access mode.
calling-station-id calling-station-id: Creates a service tracing object based on an L2TP calling number. The calling-station-id argument specifies an L2TP calling number, a case-insensitive string of 1 to 64 characters. The L2TP calling number format is H-H-H IFNAME:SVLAN.CVLAN, where H-H-H represents the user MAC address, IFNAME represents the abbreviated name of the user access interface on the LAC, and SVLAN.CVLAN represents the outer VLAN ID and inner VLAN ID of the user. When the user does not have VLAN information, the SVLAN.CVLAN field is padded with ffff.ffff. For example, if the MAC address of a user is 000f-e235-dc71, the user access interface on the LAC is RAGG1.1, and the outer VLAN ID and inner VLAN ID of the user are 1 and 2, respectively, the L2TP calling number is 000f-e235-dc71 RAGG1.1:0001.0002.
c-vlan vlan-id: Creates a service tracing object based on an inner VLAN ID in the range of 1 to 4094.
interface interface-type interface-number: Creates a service tracing object based on the specified interface. With this option specified, the service tracing object becomes ineffective when the slot or subslot that hosts the specified interface is rebooted. Only network access users support this option.
ip-address ip-address: Creates a service tracing object based an IP address.
mac-address mac-address: Creates a service tracing object based on a MAC address in H-H-H format, case-insensitive. Only network access users support this option.
s-vlan vlan-id: Creates a service tracing object based on an outer VLAN ID in the range of 1 to 4094.
tunnel-id tunnel-id: Creates a service tracing object based on an L2TP tunnel ID in the range of 1 to 65535. This option does not take effect on IPoE users.
username user-name: Creates a service tracing object based on a username, a case-sensitive string of 1 to 253 characters.
aging time: Specifies the maximum length of the tracing time in the range of 0 to 60 minutes. The default is 15. The tracing time is calculated from the time when this command is configured. The service object is no longer traced after the tracing time expires. The value of 0 indicates that the tracing time never expires and the device will always trace the service object. To stop tracing a service object, delete the service tracing object by using the undo form or shut down the VTY where the command is executed.
output: Specifies the location to which the service tracing object information is output. By default, the service tracing object information is output to the VTY monitor terminal.
·     file file-name: Outputs the service tracing information to the storage medium on the device. For the specific storage location, execute the display trace access-user command. The file-name argument represents the name of the file storing the service tracing information in the storage medium, a case-sensitive string of 1 to 63 characters. For the configuration to take effect, make sure the file-name argument does not contain the working directory.
·     syslog-server server-ip-address: Outputs the service tracing information to the log server specified by its IP address.
·     vty: Outputs the service tracing information to the current VTY monitor terminal.
all: Specifies all service tracing objects.
You can create service tracing objects to trace access user information, such as login and logout information. By specifying match parameters, you can trace the specific access users.
This command is resource intensive. As a best practice, use this command only when troubleshooting devices.
When the syslog-server server-ip-address option is specified, make sure the device and the specified log server can reach each other and the log server configuration is correct.
Active/standby MPU switchover causes the command to be ineffective.
An LNS cannot obtain the MAC address or inner/outer VLAN information of access users, the mac-address, c-vlan, or s-vlan keyword in this command does not take effect. For example, when the access-mode lns and the mac-address, c-vlan, or s-vlan keyword are configured in this command, only the access-mode lns configuration takes effect.
#Create service tracing object 1.
[Sysname] trace access-user object 1 access-mode ipoe interface ten-gigabitethernet 3/0/1.1 ip-address 1.1.1.2 mac-address 1-2-3 c-vlan 2 s-vlan 3
user-policy interface-down online
Use user-policy interface-down online to keep the users online after the interface goes down.
Use undo user-policy interface-down to restore the default.
user-policy interface-down online [ no-user-detect ]
Users on an interface are forced to go offline after the interface goes down.
online: Keeps users online after the interface goes down.
no-user-detect: Does not perform online detection on users after the interface goes down. If you do not specify this keyword, online detection is still performed for users on the interface after the interface goes down, and forcibly logs out users that fail online detection.
To prevent users from frequently coming online and going offline because the interface frequently comes up and goes down, you can use this command to keep users online after the interface goes down.
When you configure an interface to keep the users online after the interface goes down, to prevent users from being logged out because the users fail online detection during the period the interface recovers from down to up, specify the no-user-detect keyword.
This command takes effect only on PPPoE and IPoE access users.
When executing this command, follow these restrictions and guidelines:
·     When the interface goes down after this command is executed, if you execute this command again to modify the parameter settings, the new settings do not take effect immediately, and the old settings before the interface goes down still take effect. The new settings take effect only when the down interface comes up and then goes down. For example, if you first execute the user-policy interface-down online command, and then execute the user-policy interface-down online no-user-detect command after the interface goes down, the user-policy interface-down online command executed before the interface goes down still takes effect. The user-policy interface-down online no-user-detect command configuration takes effect only when the down interface comes up and then goes down.
·     After you execute this command, if you execute the undo form after the interface goes down, users on the interface will be forcibly logged out.
#Allow users on Ten-GigabitEthernet 3/0/1 to keep online after the interface goes down.
[Sysname-Ten-GigabitEthernet3/0/1] user-policy interface-down online
ip subscriber user-detect ip (BRAS Services Command Reference)
ip subscriber user-detect ipv6 (BRAS Services Command Reference)
timer-hold (BRAS Services Command Reference)
timer-hold retry (BRAS Services Command Reference)
