08-BIER Command Reference
HomeSupportRoutersCR16000-M SeriesReference GuidesCommand ReferencesH3C CR16000-M Routers Command Reference-R838x-6W10108-BIER Command Reference
02-BIER OAM commands
02-BIER OAM commands 90.89 KB
BIER OAM commands
g-bier oam enable
Use g-bier oam enable to enable G-BIER OAM.
Use undo g-bier oam enable to disable G-BIER OAM.
g-bier oam enable [ udp-port udp-port ]
G-BIER OAM is enabled.
BIER view
udp-port udp-port: Specifies the destination UDP port number for G-BIER OAM packets (G-BIER echo requests and G-BIER echo replies). The value is in the range of 1024 to 65535, and the default is 49100.
Devices transmit G-BIER OAM packets over UDP. To avoid UDP port conflict between G-BIER OAM and other protocols, use the default UDP port number for G-BIER OAM packets.
For all BFRs in a BIER sub-domain to receive G-BIER echo requests, specify the same UDP port number for the BFRs.
# Disable G-BIER OAM.
[Sysname] bier
[Sysname-bier] undo g-bier oam enable
ping bier g-bier
Use ping bier g-bier to test the reachability of one or a range of G-BIER BFRs and display ping statistics.
ping bier g-bier sub-domain sub-domain-id bsl bsl-value bfr-id bfr-id-value [ to bfr-id-end-value ] [ -c count | -h ttl-value | -m interval | -t timeout | udp-port udp-port ] *
sub-domain sub-domain-id: Specifies a BIER sub-domain by its ID in the range of 0 to 255.
bsl bsl-value: Specifies a BSL value. The valid values are 64, 128, and 256.
bfr-id bfr-id-value [ to bfr-id-end-value ]: Specifies a destination BFR by its ID or specifies a range of destination BFRs in the form of bfr-id-value to bfr-id-end-value. The value range for the bfr-id-value argument is 1 to 65535. The value range for the bfr-id-end-value argument is 2 to 65535. The end ID must be equal to or greater than the start ID.
-c count: Specifies the number of G-BIER echo requests to be sent to each destination BFR. The value range is 1 to 65535, and the default is 5.
-h ttl-value: Specifies the TTL value of G-BIER echo requests. The value range is 1 to 255, and the default is 255.
-m interval: Specifies the interval (in milliseconds) between G-BIER echo request transmissions. The value range is 100 to 10000, and the default is 2000.
-t timeout: Specifies the number of milliseconds to wait for a response from the destination. The value range is 100 to 65535, and the default is 2000.
udp-port udp-port: Specifies the destination UDP port number for G-BIER echo requests. The value range is 1024 to 65535, and the default is 49100.
Before using this command, make sure G-BIER OAM is enabled.
If you specify multiple destination BFRs in this command, make sure all the BFRs are in the same SI.
After sending a G-BIER echo request, the device waits for the response timeout to expire before a subsequent transmission if the specified echo request transmission interval is less than the response timeout.
To stop the ping operation after the command is issued, press Ctrl+C.
# Ping BFR 22 in BIER sub-domain 0 to test its reachability.
<Sysname> ping bier g-bier sub-domain 0 bsl 128 bfr-id 22
Ping G-BIER: Sub-domain ID: 0, BSL: 128, BFR-IDs: 22, press CTRL_C to break
BFR-ID: 22 Request timed out
--- Ping statistics for BFR-ID (22)---
5 packets transmitted, 0 packets received, 100.00% packet loss
Round-trip min/avg/max=0.000/0.000/0.000 ms
# Ping BFR 2 in BIER sub-domain 0 to test its reachability.
Ping G-BIER: Sub-domain ID: 0, BSL: 256, BFR-IDs: 2, press CTRL_C to break
64 bytes from BFR-ID: 2 (2001:db8:1::1), Sequence=1 time=10.000 ms ReturnCode=3
64 bytes from BFR-ID: 2 (2001:db8:1::1), Sequence=2 time=4.000 ms ReturnCode=3
64 bytes from BFR-ID: 2 (2001:db8:1::1), Sequence=3 time=4.000 ms ReturnCode=3
64 bytes from BFR-ID: 2 (2001:db8:1::1), Sequence=4 time=4.000 ms ReturnCode=3
64 bytes from BFR-ID: 2 (2001:db8:1::1), Sequence=5 time=4.000 ms ReturnCode=3
--- Ping statistics for BFR-ID (22) ---
Round-trip min/avg/max=4.000/5.000/10.000 ms
# Ping BFRs 1 through 4 in BIER sub-domain 0 and specify three echo requests to be sent to each of those BFRs.
<Sysname> ping bier g-bier sub-domain 0 bsl 128 bfr-id 1 to 4 –c 3
Ping G-BIER: Sub-domain ID: 1, BSL: 256, BFR-IDs: [1,4], press CTRL_C to break
64 bytes from BFR-ID: 1 (2001:db8:1::1), Sequence=1 time=10.000 ms ReturnCode=4
64 bytes from BFR-ID: 2 (2002:db8:1::1), Sequence=1 time=4.000 ms ReturnCode=4
BFR-ID: 3 Request timed out
BFR-ID: 4 Request timed out
64 bytes from BFR-ID: 1 (2001:db8:1::1), Sequence=2 time=11.000 ms ReturnCode=4
64 bytes from BFR-ID: 2 (2002:db8:1::1), Sequence=2 time=5.000 ms ReturnCode=4
BFR-ID: 3 Request time out
BFR-ID: 4 Request time out
64 bytes from BFR-ID: 1 (2001:db8:1::1), Sequence=3 time=10.000 ms ReturnCode=4
64 bytes from BFR-ID: 2 (2002:db8:1::1), Sequence=3 time=5.000 ms ReturnCode=4
--- Ping statistics for BFR-ID (1) ---
--- Ping statistics for BFR-ID (2) ---
--- Ping statistics for BFR-ID (3) ---
--- Ping statistics for BFR-ID (4) ---
Ping G-BIER: Sub-Domain ID: 0, BSL: 128, BFR-ID: 22, press CTRL_C to break
Test whether BFR 22 in BIER sub-domain 0 with BSL of 128 is reachable. To stop the ping operation, press escape key Ctrl+C.
Received an echo reply of 64 bytes from BFR 2 whose prefix is 2001:db8:1::1.
Sequence
Sequence number of the reply packet, used to determine whether a segment is lost, disordered, or repeated.
time
Response time.
ReturnCode
Return code:
·     1—The received G-BIER OAM echo request packet is malformed.
·     2—The reply packet contains one or more unsupported TLVs.
·     3—The replying BFR is the only BFER matching the BitString field in the echo request header.
·     4—The replying BFR is one of the BFERs matching the BitString field in the echo request header.
·     5—The echo request packet is forwarded successfully.
·     6—The received echo request contains multipath information for more than one BFER. (This field is not supported in the current software version.)
·     8—No matching entry in the local BIER forwarding table.
·     9—The SI in the received echo request does not match that assigned for the local BFR.
·     10—The BitString field in the received echo request does not match that in the Downstream Detailed Mapping TLV. (This field is not supported in the current software version.)
--- Ping statistics for BFR-ID(1) ---
Statistics on data received and sent in the ping operation.
Number of transmitted G-BIER OAM echo request packets.
5 packets received
Number of received G-BIER OAM echo reply packets.
0.0% packet loss
Percentage of unacknowledged packets to the total packets sent.
Minimum/average/maximum response time, in milliseconds.
g-bier oam enable
tracert bier g-bier
Use tracert bier g-bier to trace the path that a G-BIER packet traverses from source to destination.
tracert bier g-bier sub-domain sub-domain-id bsl bsl-value bfr-id bfr-id-value [ to bfr-id-end-value ] [ entropy entropy-value [ to entropy-end-value ] | -ds | -h ttl-value | -ibs | -t timeout | -tbs | udp-port udp-port ] *
bsl bsl-value: Specifies a BSL value. The valid values are 64, 128, 256.
entropy entropy-value [ to entropy-end-value ]: Specifies an entropy value, or a range of entropy values in the form of entropy-value to entropy-end-value for selecting a path from multiple equal-cost multipath (ECMP) paths. You must select the same path for G-BIER OAM packets with the same entropy value. The value range for the entropy-value argument is 0 to 1048575 and the default is 0. The value range for the entropy-end-value argument is 1 to 1048575. The end entropy value must be equal to or greater than the start entropy value.
-ds: Includes the Downstream Mapping TLV in G-BIER echo requests.
-ibs: Sets the I flag in the Downstream Mapping TLV in G-BIER echo requests. With the I flag set, G-BIER echo replies will carry the Incoming SI-BitString TLV.
-tbs: Includes the Target SI-BitString TLV in G-BIER echo requests.
Before configuring this command, make sure G-BIER OAM is enabled.
After a fault is detected by using the ping bier g-bier command, you can use the tracert bier g-bier command to locate the fault point on the network.
If multiple G-BIER ECMP paths exist between the source node and destination node, specify an entropy value for selection of a path.
To stop the tracert operation after the command is issued, press Ctrl+C.
# Display the path that a G-BIER packet traverse from BFR 120 to BFR 127. Configure the G-BIER OAM echo requests to carry the Target SI-BitString TLV and G-BIER OAM echo replies to carry the Incoming SI-BitString TLV.
<Sysname> tracert bier g-bier sub-domain 0 bsl 128 bfr-id 120 to 127 –tbs –ibs
Traceroute G-BIER source BFR-Prefix=11::11, Destination BFR-IDs=[120,127], 255 hops at most, press CTRL_C to break
Entropy 0:
  Original Bit String(HEX): 7F800000-00000000-00000000-00000000
  TTL: 0
    Target Bit String(HEX): 7F800000-00000000-00000000-00000000
    Replier: --    Type: Ingress
      Time: --    Return Code: 0
      Downstream nodes:
        33::33
    Timeout Target Bit String(HEX): 00000000-00000000-00000000-00000000
  TTL: 1
    Replier: 33::33    Type: Transit
      Time: 2.000 ms    Return Code: 5
      Incoming Bit String(HEX): 10800000-00000000-00000000-00000000
      Downstream nodes:
        44::44
        55::55
    Timeout Target Bit String(HEX): 6F000000-00000000-00000000-00000000
  TTL: 2
    Target Bit String(HEX): 10800000-00000000-00000000-00000000
    Replier: 44::44    Type: Transit
      Time: 50.000 ms    Return Code: 5
      Incoming Bit String(HEX): 00800000-00000000-0000000-00000000
      Downstream nodes:
        66::66
        88::88
    Replier: 55::55    Type: Transit
      Incoming Bit String(HEX): 10000000-00000000-00000000-00000000
      Downstream nodes:
        88::88
  TTL: 3
    Replier: 66::66    Type: Egress
      Time: 80.000 ms    Return Code: 3
      Downstream nodes:
    Replier: 88::88    Type: Egress
      Time: 90.000 ms    Return Code: 3
      Downstream nodes:
Summary:
  Path to BFR-ID 120 (66::66)
    TTL    Replier            Time          Downstream
    0      --                 --            33::33
    1      33::33             2.000 ms      44::44
    2      44::44             50.000 ms     66::66
    3      66::66             80.000 ms     --
  Path to BFR-ID 125 (88::88)
    0      --                 --            33::33
    1      33::33             2.000 ms      55::55
    2      55::55             50.000 ms     88::88
    3      88::88             90.000 ms     --
Traceroute G-BIER source BFR-Prefix=11::11, Destination BFR-ID=[120,127]
Display the path that a G-BIER packet traverses from the current BFR (11::11) to destination BFRs 120 through 127.
hops at most
Maximum number of hops.
byte packets
Number of bytes of an echo request packet.
To stop the tracert operation after the command is used, press Ctrl+C.
Entropy
Entropy value used for select a path from multiple ECMP paths.
TTL
TTL value.
Replier
Prefix of the replying BFR. This field displays -- if the TTL is 0.
BFR type:
·     Ingress—Ingress BFR.
·     Transit—Transit BFR.
·     Egress—Egress BFR.
Time
Response time.
Return Code
Return code:
·     3—The replying BRF is the only BFER matching the BitString field in the echo request header.
·     4—The replying BRF is one of the BFERs matching the BitString field in the echo request header.
Downstream nodes
Prefixes of the downstream BFRs.
This field is available only after you specify the -ds keyword.
Bit string in the Original SI-BitString TLV carried in the G-BIER OAM echo request (in hexadecimal format, with the least significant bit at the rightmost)
Bit string in the Target SI-BitString TLV carried in the G-BIER OAM echo request (in hexadecimal format, with the least significant bit at the rightmost). When the TTL is 0, the value is consistent with the original bit string.
This field is available only after you specify the -ds or tbs keyword.
Bit string in the Incoming SI-BitString TLV carried in the G-BIER OAM Echo reply (in hexadecimal format, with the least significant bit at the rightmost).
This field is available only after you specify the -ds or -ibs keyword.
Bit string carried in the G-BIER OAM echo reply (in hexadecimal format, with the least significant bit at the rightmost) that represents unreachable destination nodes and destination nodes for which the request times out.
Summary
Brief information about the path from the current device to the destination node.
g-bier oam enable
