03-Layer 2—LAN Switching Command Reference
HomeSupportRoutersCR16000-M SeriesReference GuidesCommand ReferencesH3C CR16000-M Routers Command Reference-R838x-6W10103-Layer 2—LAN Switching Command Reference
07-VLAN mapping commands
07-VLAN mapping commands 46.60 KB
display vlan mapping
Use display vlan mapping to display VLAN mapping information.
display vlan mapping [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, the command displays VLAN mapping information on all interfaces.
# Display VLAN mapping information on all interfaces.
<Sysname> display vlan mapping
Interface Ten-GigabitEthernet3/0/1:
  Outer VLAN    Inner VLAN    Translated Outer VLAN    Translated Inner VLAN
  10            N/A           120                      N/A
Outer VLAN
Original outer VLAN.
This field indicates the original VLAN for one-to-one VLAN mapping.
Inner VLAN
Original inner VLAN.
This field displays N/A for one-to-one VLAN mapping.
Translated outer VLAN.
This field indicates the translated VLAN for one-to-one VLAN mapping.
Translated inner VLAN.
vlan mapping
vlan mapping
Use vlan mapping to configure VLAN mapping on an interface.
Use undo vlan mapping to cancel the VLAN mapping configuration.
vlan mapping vlan-id translated-vlan vlan-id
undo vlan mapping { vlan-id translated-vlan vlan-id | all }
No VLAN mapping is configured on an interface.
vlan-id translated-vlan vlan-id: Specifies the original VLAN and translated VLAN for a one-to-one VLAN mapping. The value range for the vlan-id argument is 1 to 4094. The original VLAN and the translated VLAN cannot be the same.
all: Deletes all VLAN mapping configurations from the interface.
VLAN mapping takes effect only on VLAN-tagged packets received on an interface.
Different one-to-one VLAN mapping entries cannot include the same translated VLANs. If you configure multiple one-to-one VLAN mapping entries for the same original VLANs, only the first configuration takes effect.
Before you enable or disable QinQ on a port, you must remove all VLAN mappings on the port.
# Configure a one-to-one VLAN mapping on Ten-GigabitEthernet 3/0/1 to map VLAN 1 to VLAN 101.
[Sysname] interface ten-gigabitethernet 3/0/1
[Sysname-Ten-GigabitEthernet3/0/1] vlan mapping 1 translated-vlan 101
