14-High Availability Command Reference
HomeSupportRoutersCR16000-F SeriesReference GuidesCommand ReferencesH3C CR16000-F Routers Command Reference-R838x-6W10114-High Availability Command Reference
10-Service instance group commands
10-Service instance group commands 58.71 KB
display service-instance-group
Use display service-instance-group to display service instance group information.
display service-instance-group [ service-instance-group-name ]
service-instance-group-name: Specifies a service instance group by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a service instance group, this command displays information about all service instance groups.
# Display information about all service instance groups.
<Sysname> display service-instance-group
Service instance group information:
  Service instance group: sgrp
          Failover group: test
  Total service instance groups: 1
# Display information about the service instance group sgrp.
<Sysname> display service-instance-group sgrp
Name of the service instance group.
Failover group
Name of the failover group associated with the service instance group.
Total number of service instance groups.
failover-group
Use failover-group to associate a failover group with the service instance group.
Use undo failover-group to remove the association between the failover group and the service instance group.
failover-group failover-group-name
undo failover-group failover-group-name
A service instance group is not associated with any failover groups.
Service instance group view
failover-group-name: Specifies a failover group by its name, a case-sensitive string of 1 to 63 characters.
For inter-system service backup, you can associate a service instance group with only one failover group. The nodes in the failover group must belong to different systems.
For intra-system service backup, you can associate a service instance group with one or multiple failover groups. The nodes in the failover groups must belong to the same system.
·     If you associate a service instance group with one failover group, the nodes in the failover group perform NAT service backup globally.
·     If you associate a service instance group with multiple failover groups, NAT service backup loads are distributed among the failover groups. Each failover group also backs up services between its nodes. You can associate a service instance group with a maximum of four failover groups.
For more information about failover groups, see High Availability Configuration Guide.
You cannot use a service instance group for both inter-system and intra-system service backup.
You cannot associate a service instance group with multiple failover groups if the service instance group has been associated with a NAT instance that has one of the following settings:
·     Static port block mappings.
·     Address ranges configured by using the address command for a NAT address group that provides the outbound dynamic NAT service.
·     NO-PAT.
·     Static NAT.
·     Global NAT address group that has multiple NAT instance associations.
·     NAT server mapping that maps one public IP address to multiple private IP addresses.
If the NAT instance with a service instance group specified has NAT entries, you are not allowed to remove the association between the service instance group and failover group.
# Associate failover group test with service instance group abc.
[Sysname] service-instance-group abc
[Sysname-service-instance-group-abc] failover-group test
# Associate failover groups test1 and test2 with service instance group abc.
[Sysname-service-instance-group-abc] failover-group test1
[Sysname-service-instance-group-abc] failover-group test2
failover group
Use service-instance-group to create a service instance group and enter its view, or enter the view of an existing service instance group.
Use undo service-instance-group to delete a service instance group.
service-instance-group service-instance-group-name
undo service-instance-group service-instance-group-name
No service instance groups exist.
A service instance group can be associated with failover groups.
A service instance group can be specified for only one NAT instance.
If the NAT instance with a service instance group specified has NAT entries, you are not allowed to delete the service instance group.
# Create service instance group sgrp and enter its view.
[Sysname] service-instance-group sgrp
[Sysname-service-instance-group-sgrp]
nat instance (Layer 3—IP Services Command Reference)
