| 03-MPLS QoS commands | 69.72 KB |
MPLS QoS commands
diffserv-mode
Use diffserv-mode to configure the MPLS DiffServ mode.
Use undo diffserv-mode to restore the default.
diffserv-mode { ingress { pipe service-class | short-pipe service-class | uniform } egress { pipe | short-pipe [ trust { dscp | inner-dot1p } ] | uniform } | { pipe service-class | short-pipe service-class | uniform } }
undo diffserv-mode
The MPLS DiffServ mode is pipe and the priority value is 0.
VPN instance view
VSI view
Cross-connect view
ingress: Configures the MPLS DiffServ mode for the inbound direction.
egress: Configures the MPLS DiffServ mode for the outbound direction.
pipe: Specifies the pipe mode.
short-pipe: Specifies the short-pipe mode.
trust: Specifies the priority trust mode. If you do not specify this keyword, the inner 802.1p priority in MPLS L2VPN packets is trusted. This keyword is available only in VSI view and cross-connect view.
· inner-dot1p: Trusts the inner 802.1p priority in MPLS L2VPN packets.
· dscp: Trusts the DSCP in MPLS L2VPN packets.
uniform: Specifies the uniform mode.
service-class: Specifies the MPLS EXP value for packets that enter from a private network to a public network, in the range of 0 to 7.
If you do not specify a direction when executing this command, the configured MPLS DiffServ mode applies to both directions.
If you execute this command for the same direction multiple times, the most recent configuration takes effect.
In a DiffServ architecture, an intermediate node can modify the IP precedence, DSCP, and EXP fields, which are collectively referred to as class of service (CoS). Therefore, the CoS value of a packet might change during transmission in an IP network or MPLS network. The device supports the following MPLS DiffServ modes to process CoS:
· pipe—When an IP packet enters an MPLS network, the ingress node ignores the IP precedence or DSCP value of the IP packet and uses the configured value as the EXP value of the MPLS packet. When the MPLS packet leaves the MPLS network, the egress node does not modify the original IP precedence or DSCP value. In the MPLS network, the packet is scheduled based on the configured EXP value.
· short-pipe—When an IP packet enters and leaves an MPLS network, the packet is processed in the same way as in pipe mode.
¡ On nodes from the ingress node to the penultimate node, the packet is scheduled based on the configured EXP value.
¡ On the egress node, the top label is popped, and then the packet is scheduled based on the configured priority trust mode. If no priority trust mode is configured, the packet is scheduled based on its IP precedence or DSCP value.
· uniform—When an IP packet enters an MPLS network, the ingress node maps the IP precedence or DSCP value of the IP packet to the EXP value of the MPLS packet. When the MPLS packet leaves the MPLS network, the ingress node maps the EXP value to the IP precedence or DSCP value.
¡ For a L2VPN:
- If the ingress node is configured with the qos trust command on an AC interface, it maps the trusted priority of the incoming IP packet to the EXP value of the MPLS packet.
- If the ingress node is not configured with the qos trust command on the AC interface, the ingress node maps the 802.1p priority of the IP packet to the EXP value of the MPLS packet. If the IP packet does not have VLAN tags, the EXP value will be 0. When the MPLS packet leaves the MPLS network, the ingress node maps the EXP value to the 802.1p priority. If the MPLS packet does not have VLAN tags, the ingress node performs no mapping.
¡ For a L3VPN, when an IP packet enters an MPLS network, the ingress node maps the IP precedence or DSCP value of the IP packet to the EXP value of the MPLS packet. When the MPLS packet leaves the MPLS network, the ingress node maps the EXP value to the IP precedence or DSCP value.
When a VPN instance uses an MPLS DiffServ mode other than the default, the following rules apply:
· If the public network interface or the interface bound to the VPN instance is applied with a QoS policy containing a priority marking action, the priority in the action takes precedence.
· If the public network interface or the interface bound to the VPN instance is configured a port priority, the priority configured for the VPN instance takes precedence.
This command does not take effect in a multi-segment PW. For more information about multi-segment PWs, see MPLS L2VPN in MPLS Configuration Guide.
Mappings between IP precedence or DSCP and EXP are performed according to the IP precedence-exp map, dscp-exp map, and exp-dscp map. For more information about these priorities and maps, see ACL and QoS Configuration Guide.
# Configure the MPLS DiffServ mode as uniform for VPN instance abc.
[Sysname] ip vpn-instance abc
[Sysname-vpn-instance-abc] diffserv-mode uniform
# In VPN instance xyz, configure the MPLS DiffServ mode as pipe with EXP AF1 for the inbound direction and as short-pipe for the outbound direction.
[Sysname] ip vpn-instance xyz
[Sysname-vpn-instance-xyz] diffserv-mode ingress pipe af1 egress short-pipe
# Configure the MPLS DiffServ mode as uniform for VSI abc.
[Sysname] vsi abc
[Sysname-vsi-abc] diffserv-mode uniform
# For cross-connect 1 in cross-connect group xyz, configure the MPLS DiffServ mode as pipe with EXP 4 in the inbound direction, and configure the MPLS DiffServ mode as pipe in the outbound direction.
[Sysname] xconnect-group xyz
[Sysname-xcg-xyz] connection 1
[Sysname-xcg-xyz-1] diffserv-mode ingress pipe 4
if-match mpls-exp
Use if-match mpls-exp to define a criterion to match the EXP field in the first MPLS label.
Use undo if-match mpls-exp to delete the match criterion.
if-match mpls-exp exp-value&<1-8>
undo if-match mpls-exp exp-value&<1-8>
No criterion is defined to match the EXP field in the first MPLS label.
Traffic class view
exp-value&<1-8>: Specifies a space-separated list of up to eight EXP values. The value range for the exp-value argument is 0 to 7. If the same EXP value is specified multiple times, the system considers them as one. If a packet matches one of the defined MPLS EXP values, it matches the if-match clause.
# Define a criterion to match packets with EXP value 3 or 4 in the first MPLS label.
[Sysname] traffic classifier database
[Sysname-classifier-database] if-match mpls-exp 3 4
remark imposition-mpls-exp
Use remark imposition-mpls-exp to configure an EXP value marking action for added labels in a traffic behavior.
Use undo remark imposition-mpls-exp to delete the action.
remark imposition-mpls-exp exp-value
No EXP value marking action for added labels is configured in a traffic behavior.
Traffic behavior view
exp-value: Specifies an EXP value in the range of 0 to 7.
This command takes effect only when the QoS policy is applied to the inbound direction. On a P device, this command modifies only the EXP value in the first label. On a PE device, this command modifies the EXP values in all labels.
# Set the EXP value to 0 for added labels of MPLS packets.
[Sysname-behavior-database] remark imposition-mpls-exp 0
remark mpls-exp
remark mpls-exp
Use remark mpls-exp to configure an action of marking the EXP value in the first label in a traffic behavior.
Use undo remark mpls-exp to delete the action.
remark mpls-exp exp-value
No action of marking the EXP value in the first label is configured in a traffic behavior.
This command modifies the EXP values in all labels when the QoS policy is applied to the inbound direction.
This command modifies only the EXP value in the first label when the QoS policy is applied to the outbound direction.
# Set the EXP value in the first label to 0 for MPLS packets.
[Sysname-behavior-database] remark mpls-exp 0
