- 04-Layer 2—LAN Switching Command Reference
- 01-MAC address table commands
- 02-Ethernet link aggregation commands
- 03-Port isolation commands
- 04-VLAN commands
- 05-MVRP commands
- 05-QinQ commands
- 07-VLAN mapping commands
- 08-VLAN termination commands
- 09-Loop detection commands
- 10-Spanning tree commands
- 11-LLDP commands
| 05-QinQ commands | 58.44 KB |
QinQ commands
· Customer network VLANs (CVLANs), also called inner VLANs, refer to VLANs that a customer uses on the private network.
· Service provider network VLANs (SVLANs), also called outer VLANs, refer to VLANs that a service provider uses to transmit VLAN tagged traffic for customers.
display qinq
Use display qinq to display QinQ-enabled interfaces.
display qinq [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays all QinQ-enabled interfaces.
If QinQ is not enabled on any interfaces, this command does not provide any output.
# Enable QinQ on Ten-GigabitEthernet 3/1/1. Then, verify that QinQ is enabled on the interface.
[Sysname] interface ten-gigabitethernet 3/1/1
[Sysname-Ten-GigabitEthernet3/1/1] qinq enable
[Sysname-Ten-GigabitEthernet3/1/1] display qinq interface ten-gigabitethernet 3/1/1
# Enable QinQ on Ten-GigabitEthernet 3/1/1 and Ten-GigabitEthernet 3/1/3. Then, verify that QinQ is enabled on the interfaces.
[Sysname-Ten-GigabitEthernet3/1/1] quit
[Sysname] interface ten-gigabitethernet 3/1/3
[Sysname-Ten-GigabitEthernet3/1/3] qinq enable
[Sysname-Ten-GigabitEthernet3/1/3] display qinq
qinq enable
qinq enable
Use qinq enable to enable QinQ on an interface.
Use undo qinq enable to disable QinQ on an interface.
qinq enable
undo qinq enable
QinQ is disabled on interfaces.
You can enable QinQ on a port only when its link type is access. If the link type of the port is hybrid or trunk, you cannot enable QinQ on the port.
[Sysname-Ten-GigabitEthernet3/1/1] port link-type access
display qinq
qinq ethernet-type (interface view)
Use qinq ethernet-type to set the TPID value in SVLAN tags on an interface.
Use undo qinq ethernet-type to restore the default TPID value in SVLAN tags on an interface.
qinq ethernet-type service-tag hex-value
undo qinq ethernet-type service-tag
The TPID value in SVLAN tags is 8100 in hexadecimal notation.
service-tag: Sets the TPID value in the SVLAN tag.
hex-value: Sets a hexadecimal TPID value in the range of 1 to ffff, excluding the reserved EtherType values listed in Table 1.
Table 1 Reserved EtherType values
Protocol type |
Value |
ARP |
0x0806 |
PUP |
0x0200 |
RARP |
0x8035 |
IP |
0x0800 |
IPv6 |
0x86dd |
PPPoE |
0x8863/0x8864 |
MPLS |
0x8847/0x8848 |
IPX/SPX |
0x8137 |
IS-IS |
0x8000 |
LACP |
0x8809 |
LLDP |
0x88cc |
802.1X |
0x888e |
802.1ag |
0x8902 |
Cluster |
0x88a7 |
Reserved |
0xfffd/0xfffe/0xffff |
# Set the TPID value in the SVLAN tags to 9100 (hexadecimal) on Ten-GigabitEthernet 3/1/1.
[Sysname-Ten-GigabitEthernet3/1/1] qinq ethernet-type service-tag 9100
