| 01-HH3C-IF-EXT-MIB | 1.14 MB |
hh3cIfMonInputErrorAlarmRising
hh3cIfMonInputErrorAlarmResume
hh3cIfMonOutputErrorAlarmRising
hh3cIfMonOutputErrorAlarmResume
hh3cIfChangeMultiChassisResume
hh3cIfMonInputJamDiscardResume
hh3cIfMonOutputJamDiscardAlarm
hh3cIfMonOutputJamDiscardResume
hh3cIfMonPortCrcRateExceedResume
hh3cIfFlowControlDLAlarmResume
hh3cIfCableSnrDetectNotSupport
hh3cIfSfpNotSupportSingleFiber
hh3cIfQueueEgressCongestionAlarm
HH3C-IF-EXT-MIB
About this MIB
Use this MIB to manage and describe interfaces.
MIB file name
hh3c-if-ext.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cIfExt(40)
Scalar objects
hh3cIfStatGlobalFlowInterval
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfStatGlobalFlowInterval (1.3.6.1.4.1.25506.2.40.1.1) |
read-write |
Integer32 |
Integer32(0..2147483647) |
Global statistics polling interval. 0 indicates the traffic statistics collection feature is disabled. |
Not supported |
hh3cIfShutDownInterval
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfShutDownInterval (1.3.6.1.4.1.25506.2.40.1.2) |
read-write |
Integer32 |
Integer32(1..2147483647) |
Port status detection timer. |
0..300 |
hh3cIfChassisIndex
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfChassisIndex (1.3.6.1.4.1.25506.2.40.1.6) |
accessible-for-notify |
Integer32 |
0-65535 |
Actual interface bandwidth. |
As per the MIB. |
hh3cIfSlotIndex
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfSlotIndex (1.3.6.1.4.1.25506.2.40.1.7) |
Integer32 |
0-65535 |
As per the MIB. |
hh3cIfSubSlotIndex
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfSubSlotIndex (1.3.6.1.4.1.25506.2.40.1.8) |
Integer32 |
0-65535 |
As per the MIB. |
hh3cIfErrDownDesc
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfErrDownDesc (1.3.6.1.4.1.25506.2.40.1.9) |
DisplayString |
OCTET STRING(0..255) |
Error-down description. |
As per the MIB. |
hh3cIfCpuId
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfCpuId (1.3.6.1.4.1.25506.2.40.1.21) |
Unsigned32 |
0-65535 |
CPU ID of a card. |
As per the MIB. |
hh3cIfOldComboType
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfOldComboType (1.3.6.1.4.1.25506.2.40.1.22) |
INTEGER |
fiber(1), copper(2) |
Combo interface type before change |
As per the MIB. |
hh3cIfNewComboType
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfNewComboType (1.3.6.1.4.1.25506.2.40.1.23) |
INTEGER |
Combo interface type after change |
As per the MIB. |
hh3cIfDropRateThreshold
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfDropRateThreshold (1.3.6.1.4.1.25506.2.40.1.24) |
Integer32 |
Integer32(0..1000) |
Threshold for the packet loss rate |
As per the MIB. |
hh3cIfCurrentDropRate
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfCurrentDropRate (1.3.6.1.4.1.25506.2.40.1.25) |
Integer32 |
Current packet loss rate |
As per the MIB. |
hh3cIfDropRateInterval
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfDropRateInterval (1.3.6.1.4.1.25506.2.40.1.26) |
Integer32 |
Packet loss rate period |
As per the MIB. |
hh3cIfMessageProtocol
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfMessageProtocol (1.3.6.1.4.1.25506.2.40.1.27) |
Integer32 |
1:ISIS 2:ESIS 3:CLNP 4:VRRP 5:UNKNOWN_IPV4MC 6:UNKNOWN_IPV6MC 7:IPV4_MCAST_RIP 8:IPV4_BCAST_RIP 9:MCAST_NTP 10:BCAST_NTP 11:IPV4_MCAST_OSPF_5 12:IPV4_MCAST_OSPF_6 13:IPV4_UCAST_OSPF 14:IPV4_MCAST_PIM 15:IPV4_UCAST_PIM 16:IPV4_IGMP 17:UCAST_LDP 18:IPV6_MCAST_PIM 19:IPV6_UCAST_PIM 20:IPV6_MLD 21:IPV6_RIPNG 22:IPV6_UCAST_OSPFV3 23:IPV6_MCAST_OSPFV3_5 24:IPV6_MCAST_OSPFV3_6 25:IPV6_LDP 26:IPV6_VRRP 27:IPV6_VRRP_DHCPV6 28:RRPP 29:IPV4_AUTORP 30:ARP 31:ARP_REPLY 32:DHCP_CLIENT 33:DHCP_SERVER 34:DHCP_RELAY_CLIENT 35:DHCP_RELAY_SERVER 36:DOT1X 37:STP 38:LACP 39:GVRP 40:HGMP 41:UCAST_BGP 42:UCAST_ICMP 43:UCAST_TTL 44:UCAST_IPOPTION 45:IPV6_BGP 46:IPV6_ND_PASS 47:IPV6_ND_DEST 48:IPV6_PING 49:IPV6_TTL 50:IPV6_IPOPTION 51:IPV6_DHCP 52:LOOPBACKDETECTION 53:LOOP_TEST 54:LLDP 55:DLDP 56:LSP_PING 57:BPDU_TUNNEL_DEF 58:BPDU_TUNNEL_MAC0 59:BPDU_TUNNEL_MAC1 60:BPDU_TUNNEL_MAC2 61:MSDP 62:TELNET_SSH 63:HTTP_HTTPS 64:SNMP 65:SMLK 66:DOT1AG 67:CDP 68:ARP_DAI 69:ARP_DAI_VLAN 70:ACSEI 71:UCAST_NTP 72:MD 73:IPV4_UC_DHCP 74:IPV4_UC_OSPF_TTL 75:IPV4_UC_PIM_TTL 76:IPV4_UC_BGP_TTL 77:UKNOWN_SMAC 78:IPV6_ICMP 79:IPV6_TELNET_SSH 80:MPLS_RSVP 81:HGMP_BC 82:GMRP 83:PVST 84:SNAP_CIS 85:OAM 86:EAPOL_BRIDGEMAC 87:WPI_BRIDGEMAC 88:CFD_BRIDGEMAC 89:HGMP_BRIDGEMAC 90:ACSEI_BRIDGEMAC 91:IPV6_DHCPUC_CLIENT 92:IPV6_DHCPUC_RELAY 93:IPV6_DHCP_RELAY_SERVER 94:RRPP_FD 95:BFD_ARPREPLY 96:MAC_BASEVLAN 97:TUNNEL 98:BFD_ECHO 99:BFD_CTRL 100:BFD_DEFAULTMADBFD 101:BFD_MULTIHOP 102:L2_STATIONMOVE 103:IPV6_ND_DAI 104:IPV6_ND_RA 105:IPV6_ND_DAI_VLAN 106:IPV6_ND_RA_VLAN 107:IPV6_DHCP_CLIENT 108:IPV6_DHCP_SERVER 109:ICMP_RDM 110:IPV6_CPUDST_CAR 111:PTP 112:FCOE_FIP_UC 113:FCOE_TO_CPU 114:IPV6_UCAST_RTRENUM 115:IPV6_MCAST_RTRENUM 116:IPV6_UCAST_NTP 117:IPV6_MCAST_NTP 118:TRILL_ALLISIS 119:TRILL_STP 120:VDP 121:IPV4_MCAST_CBT 122:FCOE_ROUTE 123:ISSU_RELAY 124:PTP_UDP 125:VXLAN_UDP 126:CAPWAP 127:OFP_MISS 128:OFP_MATCH 129:OFP_DEVCONF_TTL 130:OFP_MACIP_MISS 131:SPBM 132:FTP_CTRL 133:BFD_INTF_CTRL 134:ROUTE_TO_CPU_MASK 135:VSRP_CONTROL 136:IPV6_VSRP_CONTROL 137:IPSEC_ESP_AH_OSPFV3 138:IPSEC_ESP_AH_OSPFV3_UC 139:IPSEC_ESP_AH_RIPNG 140:SMARTMC_UC 141:SMARTMC_BC 142:IPV6_ND_NA_OVERLAY 143:IPV6_ND_NS_OVERLAY 144:IPV6_ND_RA_OVERLAY 145:IPV6_ND_RS_OVERLAY 146:IPV6_ND_RR_OVERLAY 147:MDNS 148: DRV_RXTX_PPPOE 149:VSRP_DHCP4 150:DRCP 151:RLINK_NORMAL 152:RLINK_MIDDLE 153:RLINK_HIGH 154:RLINKEXT_NORMAL 155:RLINKEXT_MIDDLE 156:RLINKEXT_HIGH 157:LOOPBACKDETECTION_DRNI 158:SADP_HIK_PRIVATE 159:LOOPBACKDETECTION_VSI 160:IPV4_SIP 161:IPV4_EMDI 162:IPV6_ND_DAI_PORT 163:IPV6_ND_RA_MLAG 164:TWAMP 165:IPV6_IPSG 166:ARP_DAI_PORT 167:L2PT_PASS 168:IPV4_SIPH225 169:IPV4_SIPH245 170:TYPE_ERPS 171:ONVIFv4 172:ONVIFv6 173:DOT11CAPWAP 174:ESMC 175:ARP_DETECTION 176:ND_DETECTION 177:MDNS_GATE_WAY |
Packet protocol |
As per the MIB. |
hh3cIfCurrentFlowThreshold
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfCurrentFlowThreshold (1.3.6.1.4.1.25506.2.40.1.28) |
Counter64 |
Counter64 (0..18446744073709551615) |
Current traffic threshold |
As per the MIB. |
hh3cIfCurrentFlowValue
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfCurrentFlowValue (1.3.6.1.4.1.25506.2.40.1.29) |
Counter64 |
Current traffic value |
As per the MIB. |
hh3cIfCurrentUsedRatio
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfCurrentUsedRatio (1.3.6.1.4.1.25506.2.40.1.30) |
Unsigned32 |
Unsigned32 (0..4294967295) |
Current queue usage |
As per the MIB. |
hh3cIfUsedRatioThreshold
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfUsedRatioThershold (1.3.6.1.4.1.25506.2.40.1.31) |
Unsigned32 |
Queue usage threshold |
As per the MIB. |
hh3cIfDiscardType
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfDiscardType (1.3.6.1.4.1.25506.2.40.1.32) |
INTEGER |
discardstat(1) discardByte(2) discardrate(3) |
Packet loss type |
As per the MIB. |
hh3cIfDiscardThreshold
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfDiscardThreshold (1.3.6.1.4.1.25506.2.40.1.33) |
Counter64 |
Packet loss threshold |
As per the MIB. |
Tabular objects
hh3cIfFlowStatTable
About this table
Use this table to obtain the interface traffic information.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is ifIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfStatFlowInterval (1.3.6.1.4.1.25506.2.40.2.1.2.1.1.1) |
read-write |
Integer32 |
Integer32(1..300) |
Traffic statistics polling interval. |
Implementation varies by product. |
hh3cIfStatFlowInBits (1.3.6.1.4.1.25506.2.40.2.1.2.1.1.2) |
read-only |
Unsigned32 |
Incoming traffic in bits. |
As per the MIB. |
hh3cIfStatFlowOutBits (1.3.6.1.4.1.25506.2.40.2.1.2.1.1.3) |
read-only |
Unsigned32 |
Outgoing traffic in bits. |
As per the MIB. |
hh3cIfStatFlowInPkts (1.3.6.1.4.1.25506.2.40.2.1.2.1.1.4) |
read-only |
Unsigned32 |
Incoming traffic in packets. |
As per the MIB. |
hh3cIfStatFlowOutPkts (1.3.6.1.4.1.25506.2.40.2.1.2.1.1.5) |
read-only |
Unsigned32 |
Outgoing traffic in packets. |
As per the MIB. |
hh3cIfStatFlowInBytes (1.3.6.1.4.1.25506.2.40.2.1.2.1.1.6) |
read-only |
Unsigned32 |
Incoming traffic in bytes. |
As per the MIB. |
hh3cIfStatFlowOutBytes (1.3.6.1.4.1.25506.2.40.2.1.2.1.1.7) |
read-only |
Unsigned32 |
Outgoing traffic in bytes. |
As per the MIB. |
hh3cIfSpeedStatTable
About this table
Use this table to obtain the interface traffic speed statistics.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfSpeedStatInterval (1.3.6.1.4.1.25506.2.40.2.1.2.2.1.1) |
read-write |
Integer32 |
Integer32(1..300) |
Interface traffic speed statistics polling interval. 0 indicates the interface traffic speed statistics collection feature is disabled. |
hh3cIfSpeedStatInPkts (1.3.6.1.4.1.25506.2.40.2.1.2.2.1.2) |
read-only |
Unsigned32 |
Average incoming traffic speed (in pps) of the interface within the specified interval before the latest sampling point. The interval is specified by h3cIfSpeedStatInterval. |
As per the MIB. |
hh3cIfSpeedStatOutPkts (1.3.6.1.4.1.25506.2.40.2.1.2.2.1.3) |
read-only |
Unsigned32 |
Average outgoing traffic speed (in pps) of the interface within the specified interval before the latest sampling point. The interval is specified by h3cIfSpeedStatInterval. |
As per the MIB. |
hh3cIfSpeedStatInBytes (1.3.6.1.4.1.25506.2.40.2.1.2.2.1.4) |
read-only |
Unsigned32 |
Average incoming traffic speed (in Bps) of the interface within the specified interval before the latest sampling point. The interval is specified by h3cIfSpeedStatInterval. |
As per the MIB. |
hh3cIfSpeedStatOutBytes (1.3.6.1.4.1.25506.2.40.2.1.2.2.1.5) |
read-only |
Unsigned32 |
Average outgoing traffic speed (in Bps) of the interface within the specified interval before the latest sampling point. The interval is specified by h3cIfSpeedStatInterval. |
As per the MIB. |
hh3cIfHCFlowStatTable
About this table
Use this table to obtain the 64-bit traffic information of interfaces.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfStatFlowHCInBits (1.3.6.1.4.1.25506.2.40.2.1.2.3.1.1) |
read-only |
CounterBasedGauge64 |
Incoming traffic in bits (64-bit version). |
As per the MIB. |
hh3cIfStatFlowHCOutBits (1.3.6.1.4.1.25506.2.40.2.1.2.3.1.2) |
read-only |
Outgoing traffic in bits (64-bit version). |
As per the MIB. |
hh3cIfStatFlowHCInPkts (1.3.6.1.4.1.25506.2.40.2.1.2.3.1.3) |
read-only |
Incoming traffic in packets (64-bit version). |
As per the MIB. |
hh3cIfStatFlowHCOutPkts (1.3.6.1.4.1.25506.2.40.2.1.2.3.1.4) |
read-only |
Outgoing traffic in packets (64-bit version). |
As per the MIB. |
hh3cIfStatFlowHCInBytes (1.3.6.1.4.1.25506.2.40.2.1.2.3.1.5) |
read-only |
Incoming traffic in bytes (64-bit version). |
As per the MIB. |
hh3cIfStatFlowHCOutBytes (1.3.6.1.4.1.25506.2.40.2.1.2.3.1.6) |
read-only |
Outgoing traffic in bytes (64-bit version). |
As per the MIB. |
hh3cRTParentIfTable
About this table
Use this table to obtain main interface information of subinterfaces.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cRTParentIfIndex (1.3.6.1.4.1.25506.2.40.2.2.1.1.1) |
not-accessible |
Integer32 |
Main interface index. Index of the interface for which you can create subinterfaces. |
As per the MIB. |
hh3cRTMinSubIfOrdinal (1.3.6.1.4.1.25506.2.40.2.2.1.1.2) |
read-only |
Integer32 |
Minimum number of the subinterface that can be created. |
As per the MIB. |
hh3cRTMaxSubIfOrdinal (1.3.6.1.4.1.25506.2.40.2.2.1.1.3) |
read-only |
Integer32 |
Maximum number of the subinterface that can be created. |
As per the MIB. |
hh3cRTSubIfTable
About this table
Use this table to obtain information about subinterface information of main interfaces.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cRTSubIfParentIfIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cRTSubIfParentIfIndex (1.3.6.1.4.1.25506.2.40.2.2.2.1.1) |
not-accessible |
Integer32 |
Main interface index. |
As per the MIB. |
hh3cRTSubIfOrdinal (1.3.6.1.4.1.25506.2.40.2.2.2.1.2) |
not-accessible |
Integer32 |
Subinterface number. |
As per the MIB. |
hh3cRTSubIfSubIfIndex (1.3.6.1.4.1.25506.2.40.2.2.2.1.3) |
read-only |
Integer32 |
Subinterface index. |
As per the MIB. |
hh3cRTSubIfSubIfDesc (1.3.6.1.4.1.25506.2.40.2.2.2.1.4) |
read-only |
DisplayString |
Subinterface description. |
As per the MIB. |
hh3cRTSubIfRowStatus (1.3.6.1.4.1.25506.2.40.2.2.2.1.5) |
read-create |
RowStatus |
active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), destroy(6) |
Subinterface state. |
Available values are active(1), createAndGo(4), and destroy(6). |
hh3cIfLinkModeTable
About this table
Use this table to obtain the interface link mode.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cIfLinkModeIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfLinkModeIndex (1.3.6.1.4.1.25506.2.40.2.2.3.1.1) |
not-accessible |
Integer32 |
1..2147483647 |
Link mode index. |
As per the MIB. |
hh3cIfLinkMode (1.3.6.1.4.1.25506.2.40.2.2.3.1.2) |
read-write |
INTEGER |
bridgeMode(1), routeMode(2) |
Current link mode of the interface. |
As per the MIB. |
hh3cIfLinkModeSwitchSupport (1.3.6.1.4.1.25506.2.40.2.2.3.1.3) |
read-only |
TruthValue |
true(1), false(2) |
Whether the link mode of the interface can be switched. |
As per the MIB. |
hh3cIfPortTypeTable
About this table
Use this table to obtain the port type of an interface.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cIfPortTypeIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfPortTypeIndex (1.3.6.1.4.1.25506.2.40.2.2.4.1.1) |
not-accessible |
Integer32 |
Interface index, which is the same as ifIndex in ifTable. |
As per the MIB. |
hh3cIfPortType (1.3.6.1.4.1.25506.2.40.2.2.4.1.2) |
read-write |
INTEGER |
other(1),ethernet(2),fc(3)
Ethernet/ FC mode of an interface. |
As per the MIB. |
hh3cIfTable
About this table
Use this table to obtain interface-related information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cIfUpDownTimes.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfUpDownTimes (1.3.6.1.4.1.25506.2.40.2.3.2.1.1) |
read-only |
Integer32 |
Number of interface up/down events. |
As per the MIB. |
hh3cIfMtu (1.3.6.1.4.1.25506.2.40.2.3.2.1.2) |
read-write |
Integer32 |
Interface MTU. |
As per the MIB. |
hh3cIfBandwidthRate (1.3.6.1.4.1.25506.2.40.2.3.2.1.3) |
read-only |
Integer32 |
Integer32(0..100) |
Interface bandwidth. |
Not supported |
hh3cIfDiscardPktRate (1.3.6.1.4.1.25506.2.40.2.3.2.1.4) |
read-only |
Integer32 |
Integer32(0..100) |
Packet loss rate of an interface. |
Not supported |
hh3cIfStatusKeepTime (1.3.6.1.4.1.25506.2.40.2.3.2.1.5) |
read-only |
TimeTicks |
TimeTicks (0..4294967295) |
Duration of the current interface state. |
As per the MIB. |
hh3cIfInNUcastPkts (1.3.6.1.4.1.25506.2.40.2.3.2.1.6) |
read-only |
Counter64 |
Number of incoming non-unicast packets. |
Not supported |
hh3cIfOutNUcastPkts (1.3.6.1.4.1.25506.2.40.2.3.2.1.7) |
read-only |
Counter64 |
Number of outgoing non-unicast packets. |
Not supported |
hh3cIfIsPoe (1.3.6.1.4.1.25506.2.40.2.3.2.1.8) |
read-only |
TruthValue |
true(1), false(2) |
Support for PoE on an interface. |
Not supported |
hh3cIfOperStatus (1.3.6.1.4.1.25506.2.40.2.3.2.1.9) |
read-only |
INTEGER |
up(1), down(2), testing(3), admindown(4) |
Operational state of an interface. |
Not supported |
hh3cIfDownTimes (1.3.6.1.4.1.25506.2.40.2.3.2.1.10) |
read-only |
Integer32 |
Number of link-down events. |
Not supported |
hh3cIfPfcStatus (1.3.6.1.4.1.25506.2.40.2.3.2.1.11) |
read-write |
INTEGER |
enable(1), disable(2), auto(3)
PFC mode of an interface. |
hh3cIfPfcDot1pNoDrop (1.3.6.1.4.1.25506.2.40.2.3.2.1.12) |
read-write |
BITS |
pri0(0), pri1(1), pri2(2), pri3(3), pri4(4), pri5(5), pri6(6), pri7(7) |
802.1p priority list for PFC on an interface. |
hh3cIfDescription (1.3.6.1.4.1.25506.2.40.2.3.2.1.13) |
read-write |
DisplayString |
Description of an interface. |
As per the MIB. |
hh3cIfFwdErrDiscards (1.3.6.1.4.1.25506.2.40.2.3.2.1.14) |
read-only |
Unsigned32 |
Number of packets dropped because of forwarding entry errors on an interface. |
As per the MIB. |
hh3cIfUsingTable
About this table
Use this table to obtain information about breakout interfaces.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cIfUsingIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfUsingIndex (1.3.6.1.4.1.25506.2.40.2.3.3.1.1) |
not-accessible |
Integer32 |
Index of an interface that can be split or combined. |
As per the MIB. |
hh3cIfUsingSupportType (1.3.6.1.4.1.25506.2.40.2.3.3.1.2) |
read-only |
Integer32 |
Interface type that an interface can be split or combined into. |
As per the MIB. |
hh3cIfUsingType (1.3.6.1.4.1.25506.2.40.2.3.3.1.3) |
read-write |
INTEGER |
noUsing(0), using10GE(1), using20GE(2), using40GE(3), using100GE(4), using25GE(5), using50GE(6) using200GE(7) using400GE(8) |
Interface type that an interface will be split or combined into. |
As per the MIB. |
hh3cIfUsingStatus (1.3.6.1.4.1.25506.2.40.2.3.3.1.4) |
read-only |
INTEGER |
noUsing(0), needReboot(1) |
State of the splitting or combining operation. |
As per the MIB. |
hh3cIfQueBufferTable
About this table
Use this table to obtain the interface buffer information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cIfQueId.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfQueId (1.3.6.1.4.1.25506.2.40.2.2.6.1.1) |
read-only |
INTEGER |
que0(1), que1(2), que2(3), que3(4), que4(5), que5(6), que6(7), que7(8) |
ID of an interface buffer queue. |
As per the MIB. |
hh3cIfQueOutUcastTotal (1.3.6.1.4.1.25506.2.40.2.2.6.1.2) |
read-only |
Unsigned32 |
Total buffer of an outbound unicast queue. |
As per the MIB. |
hh3cIfQueOutUcastFree (1.3.6.1.4.1.25506.2.40.2.2.6.1.3) |
read-only |
Unsigned32 |
Available buffer of an outbound unicast queue. |
As per the MIB. |
hh3cIfQueOutUcastUsedRatio (1.3.6.1.4.1.25506.2.40.2.2.6.1.4) |
read-only |
Unsigned32 |
Buffer usage of an outbound unicast queue. |
As per the MIB. |
hh3cIfQueOutUcastUsedPeak (1.3.6.1.4.1.25506.2.40.2.2.6.1.5) |
read-only |
Unsigned32 |
Peak buffer usage of an outbound unicast queue. |
As per the MIB. |
hh3cIfQueOutUcastThreshold (1.3.6.1.4.1.25506.2.40.2.2.6.1.6) |
read-write |
Unsigned32 |
Buffer alarm threshold of an outbound unicast queue. |
As per the MIB. |
hh3cIfQueOutUcastOverThres (1.3.6.1.4.1.25506.2.40.2.2.6.1.7) |
read-only |
Unsigned32 |
Number of buffer usage alarms of an outbound unicast queue. |
As per the MIB. |
hh3cIfQueInTotal (1.3.6.1.4.1.25506.2.40.2.2.6.1.8) |
read-only |
Unsigned32 |
Total buffer of an inbound unicast queue. |
As per the MIB. |
hh3cIfQueInFree (1.3.6.1.4.1.25506.2.40.2.2.6.1.9) |
read-only |
Unsigned32 |
Available buffer of an inbound unicast queue. |
As per the MIB. |
hh3cIfQueInUsedRatio (1.3.6.1.4.1.25506.2.40.2.2.6.1.10) |
read-only |
Unsigned32 |
Buffer usage of an inbound unicast queue. |
As per the MIB. |
hh3cIfQueInUsedPeak (1.3.6.1.4.1.25506.2.40.2.2.6.1.11) |
read-only |
Unsigned32 |
Peak buffer usage of an inbound unicast queue. |
As per the MIB. |
hh3cIfQueInThreshold (1.3.6.1.4.1.25506.2.40.2.2.6.1.12) |
read-write |
Unsigned32 |
Buffer alarm threshold of an inbound unicast queue. |
As per the MIB. |
hh3cIfQueInOverThres (1.3.6.1.4.1.25506.2.40.2.2.6.1.13) |
read-only |
Unsigned32 |
Number of buffer usage alarms of an inbound unicast queue. |
As per the MIB. |
hh3cIfQueInHeadRoomTotal (1.3.6.1.4.1.25506.2.40.2.2.6.1.14) |
read-only |
Unsigned32 |
Total headroom of an inbound queue. |
As per the MIB. |
hh3cIfQueInHeadRoomFree (1.3.6.1.4.1.25506.2.40.2.2.6.1.15) |
read-only |
Unsigned32 |
Available headroom of an inbound queue. |
As per the MIB. |
hh3cIfQueInHeadRoomUsedRatio (1.3.6.1.4.1.25506.2.40.2.2.6.1.16) |
read-only |
Unsigned32 |
Headroom usage of an inbound queue. |
As per the MIB. |
hh3cIfQueInHeadRoomUsedPeak (1.3.6.1.4.1.25506.2.40.2.2.6.1.17) |
read-only |
Unsigned32 |
Peak headroom usage of an inbound unicast queue. |
As per the MIB. |
hh3cIfHCSpeedStatTable
About this table
Use this table to obtain the 64-bit packet statistics of an interface.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cIfSpeedStatHCInPkts.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfSpeedStatHCInPkts (1.3.6.1.4.1.25506.2.40.2.1.2.4.1.1) |
read-only |
Average incoming traffic speed (in packets) of the interface within the specified interval before the latest sampling point. |
As per the MIB. |
hh3cIfSpeedStatHCOutPkts (1.3.6.1.4.1.25506.2.40.2.1.2.4.1.2) |
read-only |
Average outgoing traffic speed (in packets) of the interface within the specified interval before the latest sampling point. |
As per the MIB. |
hh3cIfSpeedStatHCInBytes (1.3.6.1.4.1.25506.2.40.2.1.2.4.1.3) |
read-only |
Average incoming traffic speed (in bytes) of the interface within the specified interval before the latest sampling point. |
As per the MIB. |
hh3cIfSpeedStatHCOutBytes (1.3.6.1.4.1.25506.2.40.2.1.2.4.1.4) |
read-only |
Average outgoing traffic speed (in bytes) of the interface within the specified interval before the latest sampling point. |
As per the MIB. |
hh3cIfExtTrapCfgTable
About this table
Use this table to obtain information about the interface bandwidth and packet loss rate.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cIfBandwidthUpperLimit.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfBandwidthUpperLimit (1.3.6.1.4.1.25506.2.40.3.1.1.1.1) |
read-write |
Integer32 |
Integer32(1..100) |
Upper limit of the interface bandwidth. |
Not supported |
hh3cIfDiscardPktRateUpperLimit (1.3.6.1.4.1.25506.2.40.3.1.1.1.2) |
read-write |
Integer32 |
Integer32(1..100) |
Upper limit of the interface packet loss rate. |
Not supported |
hh3cIfPfcDot1pTable
About this table
Use this table to set the inbound and outbound rate thresholds for an 802.1p priority.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIfPfcDot1pValue (1.3.6.1.4.1.25506.2.40.2.2.5.1.1) |
read-only |
INTEGER |
0-7 |
Interface queue priority. |
As per the MIB. |
hh3cIfPfcDot1pInPps (1.3.6.1.4.1.25506.2.40.2.2.5.1.2) |
read-only |
Unsigned32 |
1-4294967295 |
Inbound rate for a priority. |
As per the MIB. |
hh3cIfPfcDot1pOutPps (1.3.6.1.4.1.25506.2.40.2.2.5.1.3) |
read-only |
Unsigned32 |
1-4294967295 |
Outbound rate for a priority. |
As per the MIB. |
hh3cIfPfcDot1pInPpsThreshold (1.3.6.1.4.1.25506.2.40.2.2.5.1.4) |
read-write |
Unsigned32 |
1-4294967295 |
Inbound rate threshold for a priority. |
As per the MIB. |
hh3cIfPfcDot1pOutPpsThreshold (1.3.6.1.4.1.25506.2.40.2.2.5.1.5) |
read-write |
Unsigned32 |
1-4294967295 |
Outbound rate threshold for a priority. |
As per the MIB. |
Notifications
The following information describes the notifications included in the HH3C-IF-EXT-MIB module.
hh3cIfPortUp
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.40.3.0.5 |
Link-up alarm |
Recovery |
Major |
ON |
Notification triggers
The notification is generated when physical state of the interface changes to up.
Possible reasons are:
· The undo shutdown command is executed on the interface.
· The interface or link failure is resolved.
· The physical state of the interface comes up.
System impact
The interface can normally forward packets.
Status control
ON
CLI: snmp-agent trap enable standard linkup
OFF
CLI: undo snmp-agent trap enable standard linkup
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.2.1.2.2.1.1 (ifIndex) |
Interface index. |
ifIndex |
Integer32 |
Standard MIB values. |
1.3.6.1.2.1.2.2.1.2 (ifDescr) |
Interface description. |
ifIndex |
OCTET STRING |
Recommended action
No action is required.
hh3cIfPortDown
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.3.0.6 |
Link-down alarm. |
Error |
Major |
1.3.6.1.4.1.25506.2.40.3.0.5 (hh3cIfPortUp) |
ON |
The notification is generated when physical state of the interface changes to down.
· The physical link of the interface is down, and the link is disconnected.
· The interface is shut down.
System impact
The interface cannot normally forward packets.
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface index. |
ifIndex |
Integer32 |
ifIndex |
OCTET STRING |
Recommended action
To resolve this issue:
1. Execute the display this command in interface view to identify whether the interfaces on both end are shut down. If the interfaces are shut down, execute the undo shutdown command in interface view to bring them up.
2. Identify whether the physical connection is normal (for example, whether the network cables or transceiver modules are firmly connected). If the physical connection is abnormal, correctly connect the interfaces.
3. If the issue persists, contact H3C Support.
hh3cIfMonInputUsageRising
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.6.0.1 |
Inbound bandwidth usage rising alarm. |
Error |
Warning |
1.3.6.1.4.1.25506.2.40.6.0.2 (hh3cIfMonInputUsageResume) |
ON |
The notification is generated when the inbound bandwidth usage exceeds the upper threshold.
System impact
When the inbound bandwidth usage reaches about 100%, the service traffic might be delayed or dropped.
Status control
ON
CLI: snmp-agent trap enable ifmonitor input-usage
OFF
CLI: undo snmp-agent trap enable ifmonitor input-usage
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface index. |
ifIndex |
Integer32 |
ifIndex |
OCTET STRING |
1.3.6.1.4.1.25506.2.40.5.2.1.1.1(hh3cIfMonInputUsageLowThres) |
Lower threshold for the inbound bandwidth usage. |
hh3cIfMonInputUsageLowThres |
Unsigned32 |
0-100 |
1.3.6.1.4.1.25506.2.40.5.2.1.1.2(hh3cIfMonInputUsageHighThres) |
Upper threshold for the inbound bandwidth usage. |
Unsigned32 |
0-100 |
1.3.6.1.4.1.25506.2.40.5.1.1.1.1(hh3cIfMonInputUsageStatistics) |
Inbound bandwidth usage statistics. |
hh3cIfMonInputRateStatistics |
Counter64 |
Recommended action
1. Identify whether the upper threshold set on the interface is too low.
¡ If the threshold is too low, execute the port ifmonitor input-usage command to modify the threshold.
¡ If the threshold is set reasonably, collect alarm information and configuration data, and then contact H3C Support.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.6.0.2 |
Inbound bandwidth usage recovery alarm |
Recovery |
Warning |
ON |
The notification is generated when the inbound bandwidth usage drops from above the upper threshold to below the lower threshold.
System impact
The service restores.
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface index. |
ifIndex |
Integer32 |
ifIndex |
OCTET STRING |
Unsigned32 |
0-100 |
Unsigned32 |
0-100 |
Counter64 |
Recommended action
hh3cIfMonOutputUsageRising
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.6.0.3 |
Outbound bandwidth usage rising alarm |
Error |
Warning |
1.3.6.1.4.1.25506.2.40.6.0.4 (hh3cIfMonOutputUsageResume) |
ON |
The notification is generated when the outbound bandwidth usage exceeds the upper threshold.
System impact
When the outbound bandwidth usage reaches about 100%, the service traffic might be delayed or dropped.
Status control
ON
CLI: snmp-agent trap enable ifmonitor output-usage
OFF
CLI: undo snmp-agent trap enable ifmonitor output-usage
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface index. |
ifIndex |
Integer32 |
ifIndex |
OCTET STRING |
1.3.6.1.4.1.25506.2.40.5.2.1.1.3(hh3cIfMonOutputUsageLowThres) |
Lower threshold for the outbound bandwidth usage. |
Unsigned32 |
0-100 |
1.3.6.1.4.1.25506.2.40.5.2.1.1.4(hh3cIfMonOutputUsageHighThres) |
Upper threshold for the outbound bandwidth usage. |
Unsigned32 |
0-100 |
1.3.6.1.4.1.25506.2.40.5.1.1.1.2(hh3cIfMonOutputUsageStatistics) |
Outbound bandwidth usage statistics. |
Counter64 |
Recommended action
¡ If the threshold is too low, execute the port ifmonitor output-usage command to modify the threshold.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.6.0.4 |
Outbound bandwidth usage recovery alarm |
Recovery |
Warning |
ON |
The notification is generated when the outbound bandwidth usage drops from above the upper threshold to below the lower threshold.
System impact
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface index. |
ifIndex |
Integer32 |
ifIndex |
OCTET STRING |
Unsigned32 |
1-4294967295 |
Unsigned32 |
1-4294967295 |
Counter64 |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.6.0.5 |
Inbound error packet rising alarm |
Error |
Warning |
1.3.6.1.4.1.25506.2.40.6.0.6 (hh3cIfMonInputErrorAlarmResume) |
ON |
The notification is generated when the number of inbound error packets exceeds the upper threshold within the specified interval.
· The optical transceiver module fails.
· The optical fiber or link fails.
System impact
Service traffic might be dropped.
Status control
ON
CLI: snmp-agent trap enable ifmonitor input-error
OFF
CLI: undo snmp-agent trap enable ifmonitor input-error
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface index. |
ifIndex |
Integer32 |
ifIndex |
OCTET STRING |
1.3.6.1.4.1.25506.2.40.5.2.1.1.6(hh3cIfMonInputErrorAlarmHighThres) |
Upper threshold for the number of inbound error packets. |
Unsigned32 |
1-4294967295 |
1.3.6.1.4.1.25506.2.40.5.2.1.1.5(hh3cIfMonInputErrorAlarmLowThres) |
Lower threshold for the number of inbound error packets. |
Unsigned32 |
1-4294967295 |
1.3.6.1.4.1.25506.2.40.5.1.1.1.3(hh3cIfMonInputErrorAlarmStatistics) |
Inbound error alarm statistics. |
Counter64 |
1-4294967295 |
1.3.6.1.4.1.25506.2.40.5.2.1.1.7(hh3cIfMonInputErrorAlarmInterval) |
Inbound error alarm statistics collection interval. |
Unsigned32 |
0-65535 |
Recommended action
1. Replace the transceiver module. Identify whether the alarm is cleared.
2. Replace the optical fiber or link. Identify whether the alarm is cleared.
3. Identify whether the upper threshold set on the interface is too low.
¡ If the threshold is too low, execute the port ifmonitor input-error command to modify the threshold.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.6.0.6 |
Inbound error packet recovery alarm |
Recovery |
Warning |
ON |
The notification is generated when the number of inbound error packets drops from above the upper threshold to below the lower threshold within the specified interval.
System impact
Status control
ON
OFF
CLI: undo snmp-agent trap enable ifmonitor input -error
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface index. |
ifIndex |
Integer32 |
ifIndex |
OCTET STRING |
Unsigned32 |
1-4294967295 |
Unsigned32 |
1-4294967295 |
Counter64 |
1-4294967295 |
Unsigned32 |
0-65535 |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.6.0.7 |
Outbound error packet rising alarm |
Error |
Warning |
1.3.6.1.4.1.25506.2.40.6.0.8 (hh3cIfMonOutputErrorAlarmResume) |
ON |
The notification is generated when the number of outbound error packets exceeds the upper threshold within the specified interval.
System impact
Status control
ON
CLI: snmp-agent trap enable ifmonitor output-error
OFF
CLI: undo snmp-agent trap enable ifmonitor output-error
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface index. |
ifIndex |
Integer32 |
ifIndex |
OCTET STRING |
1.3.6.1.4.1.25506.2.40.5.2.1.1.9(hh3cIfMonOutputErrorAlarmHighThres) |
Upper threshold for the number of outbound error packets. |
Unsigned32 |
1-4294967295 |
1.3.6.1.4.1.25506.2.40.5.2.1.1.8(hh3cIfMonOutputErrorAlarmLowThres) |
Lower threshold for the number of outbound error packets. |
Unsigned32 |
1-4294967295 |
1.3.6.1.4.1.25506.2.40.5.1.1.1.4(hh3cIfMonOutputErrorAlarmStatistics) |
Outbound error alarm statistics. |
Counter64 |
1-4294967295 |
1.3.6.1.4.1.25506.2.40.5.2.1.1.10(hh3cIfMonOutputErrorAlarmInterval) |
Outbound error alarm statistics collection interval. |
Unsigned32 |
0-65535 |
Recommended action
1. Verify that the optical fiber is firmly installed. Identify whether the alarm is cleared.
2. Verify that the physical link is normal.
3. Execute the display interface command to identify whether the Tx power of the transceiver module of the interface that fails is within the normal range. Identify whether the negotiation mode, clock mode, and scrambling mode (link protocol, clock, and scramble) are the same on both ends. If they are different, modify the negotiation mode configuration on both ends to make them consistent. Identify whether the alarm is cleared.
4. Identify whether the upper threshold set on the interface is too low. If the threshold is too low, execute the port ifmonitor output-error command to modify the threshold.
5. If the threshold is set reasonably, collect alarm information and configuration data, and then contact H3C Support.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.6.0.8 |
Outbound error packet recovery alarm |
Recovery |
Warning |
ON |
The notification is generated when the number of outbound error packets drops from above the upper threshold to below the lower threshold within the specified interval.
System impact
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface index. |
ifIndex |
Integer32 |
ifIndex |
OCTET STRING |
Unsigned32 |
1-4294967295 |
Unsigned32 |
1-4294967295 |
Counter64 |
1-4294967295 |
Unsigned32 |
0-65535 |
Recommended action
hh3cIfMonSdhErrorRising
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.6.0.9 |
SDH error packet rising alarm |
Error |
Warning |
1.3.6.1.4.1.25506.2.40.6.0.10 (hh3cIfMonSdhErrorResume) |
ON |
The notification is generated when the number of SDH error packets exceeds the upper threshold within the specified interval.
· The optical fiber fails.
System impact
Status control
ON
Syntax: snmp-agent trap enable ifmonitor sdh-error
OFF
CLI: undo snmp-agent trap enable ifmonitor sdh-error
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface index. |
ifIndex |
Integer32 |
ifIndex |
OCTET STRING |
1.3.6.1.4.1.25506.2.40.5.2.1.1.11(hh3cIfMonSdhErrorLowThres) |
Lower threshold for the number of SDH error packets. |
Unsigned32 |
1-4294967295 |
1.3.6.1.4.1.25506.2.40.5.2.1.1.12(hh3cIfMonSdhErrorHighThres) |
Upper threshold for the number of SDH error packets. |
Unsigned32 |
1-4294967295 |
1.3.6.1.4.1.25506.2.40.5.1.1.1.5(hh3cIfMonSdhErrorStatistics) |
SDH error statistics. |
Counter64 |
1-4294967295 |
1.3.6.1.4.1.25506.2.40.5.2.1.1.13(hh3cIfMonSdhErrorInterval) |
SDH error statistics collection interval. |
Unsigned32 |
0-65535 |
Recommended action
2. Replace the optical fiber. Identify whether the alarm is cleared.
3. Identify whether the upper threshold set on the interface is too low. If the threshold is too low, execute the port ifmonitor sdh-error command to modify the threshold.
4. Collect alarm information and configuration data, and then contact H3C Support.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.6.0.10 |
SDH error packet recovery alarm |
Recovery |
Warning |
ON |
The notification is generated when the number of SDH error packets drops from above the upper threshold to below the lower threshold within the specified interval.
System impact
Status control
ON
CLI: snmp-agent trap enable ifmonitor sdh-error
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface index. |
ifIndex |
Integer32 |
ifIndex |
OCTET STRING |
Unsigned32 |
1-4294967295 |
Unsigned32 |
1-4294967295 |
Counter64 |
1-4294967295 |
Unsigned32 |
0-65535 |
Recommended action
hh3cIfMonSdhB1ErrorRising
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.6.0.11 |
SDH B1 error packet rising alarm |
Error |
Warning |
1.3.6.1.4.1.25506.2.40.6.0.12 (hh3cIfMonSdhB1ErrorResume) |
ON |
The notification is generated when the number of SDH B1 error packets exceeds the upper threshold within the specified interval.
System impact
Status control
ON
CLI: snmp-agent trap enable ifmonitor sdh-b1-error
OFF
CLI: undo snmp-agent trap enable ifmonitor sdh-b1-error
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface index. |
ifIndex |
Integer32 |
ifIndex |
OCTET STRING |
1.3.6.1.4.1.25506.2.40.5.2.1.1.14(hh3cIfMonSdhB1ErrorLowThres) |
Lower threshold for the number of SDH B1 error packets. |
Unsigned32 |
1-4294967295 |
1.3.6.1.4.1.25506.2.40.5.2.1.1.15(hh3cIfMonSdhB1ErrorHighThres) |
Upper threshold for the number of SDH B1 error packets. |
Unsigned32 |
1-4294967295 |
1.3.6.1.4.1.25506.2.40.5.1.1.1.6(hh3cIfMonSdhB1ErrorStatistics) |
SDH B1 error packet statistics. |
Counter64 |
1-4294967295 |
1.3.6.1.4.1.25506.2.40.5.2.1.1.16(hh3cIfMonSdhB1ErrorInterval) |
SDH B1 error statistics collection interval. |
Unsigned32 |
0-65535 |
Recommended action
1. Identify whether the link (including optical fiber, transceiver module, transmission device, jumper, and so on) fails. Replace the faulty components (if any), and verify that the link is connected correctly. Identify whether the alarm is cleared.
2. Identify whether the upper threshold set on the interface is too low. If the threshold is too low, execute the port ifmonitor sdh-b1-error command to modify the threshold.
3. Collect alarm information and configuration data, and then contact H3C Support.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.6.0.12 |
SDH B1 error packet recovery alarm |
Recovery |
Warning |
ON |
The notification is generated when the number of SDH B1 error packets drops from above the upper threshold to below the lower threshold within the specified interval.
System impact
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface index. |
ifIndex |
Integer32 |
ifIndex |
OCTET STRING |
Unsigned32 |
1-4294967295 |
Unsigned32 |
1-4294967295 |
Counter64 |
1-4294967295 |
Unsigned32 |
0-65535 |
Recommended action
hh3cIfMonSdhB2ErrorRising
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.6.0.13 |
SDH B2 error packet rising alarm |
Error |
Warning |
1.3.6.1.4.1.25506.2.40.6.0.14 (hh3cIfMonSdhB2ErrorResume) |
ON |
The notification is generated when the number of SDH B2 error packets exceeds the upper threshold within the specified interval.
System impact
Status control
ON
CLI: snmp-agent trap enable ifmonitor sdh-b2-error
OFF
CLI: undo snmp-agent trap enable ifmonitor sdh-b2-error
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface index. |
ifIndex |
Integer32 |
ifIndex |
OCTET STRING |
1.3.6.1.4.1.25506.2.40.5.2.1.1.17(hh3cIfMonSdhB2ErrorLowThres) |
Lower threshold for the number of SDH B2 error packets. |
Unsigned32 |
1-4294967295 |
1.3.6.1.4.1.25506.2.40.5.2.1.1.18(hh3cIfMonSdhB2ErrorHighThres) |
Upper threshold for the number of SDH B2 error packets. |
Unsigned32 |
1-4294967295 |
1.3.6.1.4.1.25506.2.40.5.1.1.1.7(hh3cIfMonSdhB2ErrorStatistics) |
SDH B2 error packet statistics. |
Counter64 |
1-4294967295 |
1.3.6.1.4.1.25506.2.40.5.2.1.1.19(hh3cIfMonSdhB2ErrorInterval) |
SDH B2 error statistics collection interval. |
Unsigned32 |
0-65535 |
Recommended action
2. Replace the faulty components (if any), and verify that the link is connected correctly. Identify whether the alarm is cleared.
3. Identify whether the upper threshold set on the interface is too low. If the threshold is too low, execute the port ifmonitor sdh-b2-error command to modify the threshold. If the threshold is set reasonably, collect alarm information and configuration data, and then contact H3C Support.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.6.0.14 |
Recovery |
Warning |
ON |
The notification is generated when the number of SDH B2 error packets drops from above the upper threshold to below the lower threshold within the specified interval.
System impact
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface index. |
ifIndex |
Integer32 |
ifIndex |
OCTET STRING |
Unsigned32 |
1-4294967295 |
Unsigned32 |
1-4294967295 |
SDH B2 error statistics. |
Counter64 |
1-4294967295 |
Unsigned32 |
0-65535 |
Recommended action
hh3cIfMonCRCErrorRising
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.6.0.15 |
CRC error packet rising alarm |
Error |
Warning |
1.3.6.1.4.1.25506.2.40.6.0.16 (hh3cIfMonCRCErrorResume) |
ON |
The notification is generated when the number of CRC error packets exceeds the upper threshold within the specified interval.
System impact
Status control
ON
CLI: snmp-agent trap enable ifmonitor crc-error
OFF
CLI: undo snmp-agent trap enable ifmonitor crc-error
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface index. |
ifIndex |
Integer32 |
ifIndex |
OCTET STRING |
1.3.6.1.4.1.25506.2.40.5.2.1.1.21(hh3cIfMonCRCErrorHighThres) |
Upper threshold for the number of CRC error packets. |
Unsigned32 |
1-4294967295 |
1.3.6.1.4.1.25506.2.40.5.2.1.1.20(hh3cIfMonCRCErrorLowThres) |
Lower threshold for the number of CRC error packets. |
Unsigned32 |
1-4294967295 |
1.3.6.1.4.1.25506.2.40.5.1.1.1.8(hh3cIfMonCRCErrorStatistics) |
CRC error statistics. |
Counter64 |
1-4294967295 |
1.3.6.1.4.1.25506.2.40.5.2.1.1.22(hh3cIfMonCRCErrorInterval) |
CRC error statistics collection interval. |
Unsigned32 |
0-65535 |
1.3.6.1.4.1.25506.2.40.5.2.1.1.23(hh3cIfMonCRCErrType) |
INTEGER |
1-2 |
Recommended action
3. Identify whether the upper threshold set on the interface is too low. If the threshold is too low, execute the port ifmonitor crc-error command to modify the threshold. If the threshold is set reasonably, collect alarm information and configuration data, and then contact H3C Support.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.6.0.16 |
CRC error packet recovery alarm |
Recovery |
Warning |
ON |
The notification is generated when the number of CRC error packets drops from above the upper threshold to below the lower threshold within the specified interval.
System impact
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface index. |
ifIndex |
Integer32 |
ifIndex |
OCTET STRING |
Unsigned32 |
1-4294967295 |
Unsigned32 |
1-4294967295 |
Counter64 |
1-4294967295 |
Unsigned32 |
0-65535 |
INTEGER |
1-2 |
Recommended action
hh3cIfMonRxPauseFrameRising
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.6.0.17 |
Received pause frame rising alarm |
Error |
Warning |
1.3.6.1.4.1.25506.2.40.6.0.18 (hh3cIfMonRxPauseFrameResume) |
ON |
The notification is generated when the number of received pause frames exceeds the upper threshold within the specified interval.
· The rate of received pause frames exceeds the threshold.
· Pause frames are received continuously for a long period of time.
System impact
Status control
ON
CLI: snmp-agent trap enable ifmonitor rx-pause
OFF
CLI: undo snmp-agent trap enable ifmonitor rx-pause
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface index. |
ifIndex |
Integer32 |
ifIndex |
OCTET STRING |
1.3.6.1.4.1.25506.2.40.5.2.1.1.25(hh3cIfMonRxPauseFrameHighThres) |
Upper threshold for received pause frames. |
Unsigned32 |
1-4294967295 |
1.3.6.1.4.1.25506.2.40.5.2.1.1.24(hh3cIfMonRxPauseFrameLowThres) |
Lower threshold for received pause frames. |
Unsigned32 |
1-4294967295 |
1.3.6.1.4.1.25506.2.40.5.1.1.1.9(hh3cIfMonRxPauseFrameStatistics) |
Received pause frame statistics. |
Counter64 |
1-4294967295 |
1.3.6.1.4.1.25506.2.40.5.2.1.1.26(hh3cIfMonRxPauseFrameInterval) |
Received pause frame statistics collection interval. |
Unsigned32 |
0-65535 |
Recommended action
1. Decrease the service traffic received on the peer interface. Identify whether the alarm is cleared.
2. Identify whether the upper threshold set on the interface is too low. If the threshold is too low, execute the port ifmonitor rx-pause command to modify the threshold. If the threshold is set reasonably, collect alarm information and configuration data, and then contact H3C Support.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.6.0.18 |
Received pause frame recovery alarm |
Recovery |
Warning |
ON |
The notification is generated when the number of received pause frames drops from above the upper threshold to below the lower-threshold within the specified interval.
System impact
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface index. |
ifIndex |
Integer32 |
ifIndex |
OCTET STRING |
Unsigned32 |
1-4294967295 |
Unsigned32 |
1-4294967295 |
Counter64 |
1-4294967295 |
Unsigned32 |
0-65535 |
Recommended action
hh3cIfMonTxPauseFrameRising
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.6.0.19 |
Transmitted pause frame rising alarm |
Error |
Warning |
1.3.6.1.4.1.25506.2.40.6.0.20 (hh3cIfMonTxPauseFrameResume) |
ON |
The notification is generated when the number of transmitted pause frames exceeds the upper threshold within the specified interval.
· The rate of sent pause frames exceeds the threshold.
· Pause frames are sent continuously for a long period of time.
System impact
Status control
ON
CLI: snmp-agent trap enable ifmonitor tx-pause
OFF
CLI: undo snmp-agent trap enable ifmonitor tx-pause
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface index. |
ifIndex |
Integer32 |
ifIndex |
OCTET STRING |
1.3.6.1.4.1.25506.2.40.5.2.1.1.28(hh3cIfMonTxPauseFrameHighThres) |
Upper threshold for transmitted pause frames. |
Unsigned32 |
1-4294967295 |
1.3.6.1.4.1.25506.2.40.5.2.1.1.27(hh3cIfMonTxPauseFrameLowThres) |
Lower threshold for transmitted pause frames. |
Unsigned32 |
1-4294967295 |
1.3.6.1.4.1.25506.2.40.5.1.1.1.10(hh3cIfMonTxPauseFrameStatistics) |
Transmitted pause frame statistics. |
Counter64 |
1-4294967295 |
1.3.6.1.4.1.25506.2.40.5.2.1.1.29(hh3cIfMonTxPauseFrameInterval) |
Transmitted pause frame statistics collection interval. |
Unsigned32 |
0-65535 |
Recommended action
1. Decrease the service traffic sent on the peer interface. Identify whether the alarm is cleared.
2. Identify whether the upper threshold set on the interface is too low. If the threshold is too low, execute the port ifmonitor tx-pause command to modify the threshold. If the threshold is set reasonably, collect alarm information and configuration data, and then contact H3C Support.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.6.0.20 |
Transmitted pause frame recovery alarm |
Recovery |
Warning |
ON |
The notification is generated when the number of transmitted pause frames drops from above the upper threshold to below the lower threshold within the specified interval.
System impact
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface index. |
ifIndex |
Integer32 |
ifIndex |
OCTET STRING |
Unsigned32 |
1-4294967295 |
Unsigned32 |
1-4294967295 |
Counter64 |
1-4294967295 |
Unsigned32 |
0-65535 |
Recommended action
hh3cIfMonGiantRising
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.6.0.21 |
Giant packet rising alarm |
Error |
Warning |
1.3.6.1.4.1.25506.2.40.6.0.22 (hh3cIfMonGiantResume) |
ON |
The notification is generated when the number of giant packets exceeds the upper threshold within the specified interval.
System impact
Status control
ON
CLI: snmp-agent trap enable ifmonitor giant
OFF
CLI: undo snmp-agent trap enable ifmonitor giant
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface index. |
ifIndex |
Integer32 |
ifIndex |
OCTET STRING |
1.3.6.1.4.1.25506.2.40.5.2.1.1.30(hh3cIfMonGiantLowThres) |
Lower threshold for giant packets. |
Unsigned32 |
1-4294967295 |
1.3.6.1.4.1.25506.2.40.5.2.1.1.31(hh3cIfMonGiantHighThres) |
Upper threshold for giant packets. |
Unsigned32 |
1-4294967295 |
1.3.6.1.4.1.25506.2.40.5.1.1.1.11(hh3cIfMonGiantStatistics) |
Giant packet statistics. |
Counter64 |
1-4294967295 |
1.3.6.1.4.1.25506.2.40.5.2.1.1.32(hh3cIfMonGiantInterval) |
Giant packet statistics collection interval. |
Unsigned32 |
0-65535 |
Recommended action
1. Verify that the source traffic is normal.
2. Execute the jumboframe enable command to adjust the maximum size of a packet that can be transmitted on the interface.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.6.0.22 |
Giant packet recovery alarm |
Recovery |
Warning |
ON |
The notification is generated when the number of giant packets drops from above the upper threshold to below the lower threshold within the specified interval.
System impact
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface index. |
ifIndex |
Integer32 |
ifIndex |
OCTET STRING |
Unsigned32 |
1-4294967295 |
Unsigned32 |
1-4294967295 |
Counter64 |
1-4294967295 |
Unsigned32 |
0-65535 |
Recommended action
hh3cIfMonRuntRising
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.6.0.23 |
Runt packet rising alarm |
Error |
Warning |
1.3.6.1.4.1.25506.2.40.6.0.24 (hh3cIfMonRuntResume) |
ON |
The notification is generated when the number of runt packets exceeds the upper threshold within the specified interval.
System impact
Status control
ON
CLI: snmp-agent trap enable ifmonitor runt
OFF
CLI: undo snmp-agent trap enable ifmonitor runt
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface index. |
ifIndex |
Integer32 |
ifIndex |
OCTET STRING |
1.3.6.1.4.1.25506.2.40.5.2.1.1.33(hh3cIfMonRuntLowThres) |
Lower threshold for runt packets. |
Unsigned32 |
1-4294967295 |
1.3.6.1.4.1.25506.2.40.5.2.1.1.34(hh3cIfMonRuntHighThres) |
Upper threshold for runt packets. |
Unsigned32 |
1-4294967295 |
1.3.6.1.4.1.25506.2.40.5.1.1.1.12(hh3cIfMonRuntStatistics) |
Runt packet statistics. |
Counter64 |
1-4294967295 |
1.3.6.1.4.1.25506.2.40.5.2.1.1.35(hh3cIfMonRuntInterval) |
Runt packet statistics collection interval. |
Unsigned32 |
0-65535 |
Recommended action
hh3cIfMonRuntResume
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.6.0.24 |
Runt packet recovery alarm |
Recovery |
Warning |
ON |
The notification is generated when the number of runt packets drops from above the upper threshold to below the lower threshold within the specified interval.
System impact
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface index. |
ifIndex |
Integer32 |
ifIndex |
OCTET STRING |
Unsigned32 |
1-4294967295 |
Unsigned32 |
1-4294967295 |
Counter64 |
1-4294967295 |
Unsigned32 |
0-65535 |
Recommended action
hh3cIfPfcOutRising
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.3.0.7 |
Outbound PFC frame rate rising alarm |
Informational |
Warning |
ON |
This notification is generated when the outbound PFC frame rate exceeds the early warning threshold.
System impact
Outbound PFC frames might be lost.
Status control
This notification cannot be turned off.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface index. |
ifIndex |
Integer32 |
ifIndex |
OCTET STRING |
1.3.6.1.4.1.25506.2.40.2.2.5.1.1(hh3cIfPfcDot1pValue) |
INTEGER |
0-7 |
1.3.6.1.4.1.25506.2.40.2.2.5.1.3(hh3cIfPfcDot1pOutPps) |
Unsigned32 |
1-4294967295 |
1.3.6.1.4.1.25506.2.40.2.2.5.1.5(hh3cIfPfcDot1pOutPpsThreshold) |
Unsigned32 |
1-4294967295 |
Recommended action
1. Identify whether the upper threshold set on the interface is too low. If the threshold is set reasonably, identify whether the interface fails.
¡ If the inbound PFC frame rate exceeds the threshold, identify whether the peer device fails.
¡ If the outbound PFC frame rate exceeds the threshold, identify whether the local device fails.
¡ If both the inbound PFC frame rate and outbound PFC frame rate exceed the thresholds, identify whether the local device and peer device fail.
2. Identify whether the upper threshold set on the interface is too low. If the threshold is too low, execute the priority-flow-control early-warning dot1p dot1p-list outpps pps-value command to modify the threshold. If the threshold is set reasonably, collect alarm information and configuration data, and then contact H3C Support.
hh3cIfInPfcRising
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.3.0.8 |
Inbound PFC frame rate rising alarm |
Informational |
Warning |
ON |
This notification is generated when the inbound PFC frame rate exceeds the early warning threshold.
System impact
Incoming PFC frames might be lost.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface index. |
Integer32 |
OCTET STRING |
INTEGER |
0-7 |
1.3.6.1.4.1.25506.2.40.2.2.5.1.2(hh3cIfPfcDot1pInPps) |
Unsigned32 |
1-4294967295 |
1.3.6.1.4.1.25506.2.40.2.2.5.1.4(hh3cIfPfcDot1pInPpsThreshold) |
Unsigned32 |
1-4294967295 |
Recommended action
1. Identify whether the upper threshold set on the interface is too low. If the threshold is set reasonably, identify whether the device fails.
2. Identify whether the upper threshold set on the interface is too low. If the threshold is too low, execute the priority-flow-control early-warning dot1p dot1p-list inpps pps-value command to modify the threshold. If the threshold is set reasonably, collect alarm information and configuration data, and then contact H3C Support.
hh3cIfBufferInDiscardAlarm
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.3.0.14 |
Traffic in the ingress buffer of a card is dropped |
Error |
Warning |
1.3.6.1.4.1.25506.2.40.3.0.15 (hh3cIfBufferInDiscardResume) |
ON |
This notification is generated when the traffic in the ingress buffer of a card is dropped.
System impact
Traffic in the ingress buffer of a card is dropped. The inbound traffic of the card exceeds the link bandwidth of the switching fabric module.
Status control
This notification cannot be disabled.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.40.1.6 (hh3cIfChassisIndex) |
Chassis index. |
N/A |
Integer32 |
0-65535 |
1.3.6.1.4.1.25506.2.40.1.7 (hh3cIfSlotIndex) |
Card index. |
N/A |
Integer32 |
0-65535 |
Recommended action
Optimize the network, and adjust the traffic forwarding solution.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.3.0.15 |
The uplink traffic of a card recovers from the drop state. |
Recovery |
Warning |
ON |
This notification is generated when network congestion is relieved within the specified time.
System impact
The system is not impacted.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis index. |
N/A |
Integer32 |
0-65535 |
Card index. |
N/A |
Integer32 |
0-65535 |
Recommended action
hh3cIfHalfDuplexRising
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.3.0.16 |
An interface operates in half duplex mode |
Error |
Warning |
1.3.6.1.4.1.25506.2.40.3.0.52 (hh3cIfHalfDuplexClear) |
ON |
This notification is generated when an interface operates in half duplex mode.
System impact
Packets might be lost when an interface operates in half duplex mode.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface index. |
ifIndex |
Integer32 |
0-65535 |
ifIndex |
OCTET STRING |
Recommended action
Configure the interface to operate in full duplex mode. Related command: duplex full.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.3.0.17 |
Interface information changes when a single-chassis device is expanded to a multi-chassis device |
Informational |
Informational |
1.3.6.1.4.1.25506.2.40.3.0.18 (hh3cIfChangeMultiChassisResume) |
ON |
This notification is generated if interface information changes when a single-chassis device is expanded to a multi-chassis device.
System impact
An interface name changes from a three-tier name to a four-tier name.
Status control
Objects
None.
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.3.0.18 |
Interface information changes when a multi-chassis device is rolled back to a single-chassis device |
Informational |
Informational |
ON |
This notification is generated if interface information changes when a multi-chassis device is rolled back to a single-chassis device.
System impact
An interface name changes from a four-tier name to a three-tier name.
Status control
Objects
None.
Recommended action
hh3cIfCfgRecoverOverSlot
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.3.0.19 |
The interface card configuration recovers |
Informational |
Informational |
ON |
This notification is generated if the interface card configuration recovers.
System impact
The interface card configuration has recovered, and the interface card becomes available.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis index. |
N/A |
Integer32 |
0-65535 |
Card index. |
N/A |
Integer32 |
0-65535 |
Recommended action
hh3cIfCfgRecoverOverSubSlot
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.3.0.20 |
The interface subcard configuration recovers |
Informational |
Informational |
ON |
System impact
The interface subcard configuration has recovered, and the interface subcard becomes available.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis index. |
N/A |
Integer32 |
0-65535 |
Slot index. |
N/A |
Integer32 |
0-65535 |
1.3.6.1.4.1.25506.2.40.1.8 (hh3cIfSubSlotIndex) |
Subcard index. |
N/A |
Integer32 |
0-65535 |
Recommended action
hh3cIfInterfaceDelete
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.3.0.21 |
An interface is deleted |
Informational |
Informational |
ON |
This notification is generated if an interface is deleted.
System impact
Services that depend on the interface might be impacted.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
ifIndex |
OCTET STRING |
Recommended action
hh3cIfErrordown
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.3.0.22 |
An interface enters the error-down state |
Error |
Warning |
1.3.6.1.4.1.25506.2.40.3.0.23 (hh3cIfErrordownRecovery) |
ON |
An error-down event occurs when an interface is set to the ERROR DOWN state after the device detects failure. In this case, the interface cannot receive or send packets and the LED for the interface is solid off.
· Too many CRC error packets are generated on the interface.
· The interface flaps frequently and is unstable.
System impact
Interface traffic cannot be forwarded, and the services are interrupted.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface index. |
ifIndex |
Integer32 |
0-65535 |
ifIndex |
OCTET STRING |
1.3.6.1.4.1.25506.2.40.1.9 (hh3cIfErrDownDesc) |
Error-down reason description. |
N/A |
OCTET STRING |
1: CRC error packets actively report physical down events. 2: All serdes between interface cards and switching fabric modules fail. 3: IRF fabric configuration conflicts cause the IRF port to go down. 4: The optical powers of transceiver modules are low. 5: IRF physical interfaces receive a large number of protocol packets or IRF fabric error packets within a short period of time. 6: STP Down 7: The interface is shut down on the data link layer because the MACsec module has not successfully negotiated the communication encryption parameters for the interface. 8: The interface is shut down because the unknown unicast, multicast, or broadcast traffic on the interface exceeds the corresponding upper threshold. 9: Standby bit 10: Loop detection 11: Link-Aggregation interface down 12: Monitor-Link uplink down 13: IRF-link-down 14: MAD Down 15: Used by FC aggregation 16: Tunnel-Bundle administratively down 17: FC port security 18: Used by the NPV feature of an FC interface 19: Used by M-LAG MAD 20: Used by MAC flapping 21: ETH-rddc Down 22: Used by CFD collaboration 23: Used by LLDP 24: OFP DOWN 25: The interface is shut down on the data link layer because DLDP has detected unidirectional links on the interface 26: Used by POSA 27: Used by collaboration group 28: DRNI MAD Down 29: Link-Flap DOWN |
Recommended action
1. Troubleshoot the link failures.
2. Collect alarm information and configuration data, and then contact H3C Support.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.3.0.23 |
An interface recovers from the error-down state |
Recovery |
Warning |
ON |
This notification is generated when an IRF physical interface recovers from the error-down state.
System impact
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface index. |
ifIndex |
Integer32 |
0-65535 |
ifIndex |
OCTET STRING |
OCTET STRING(0..255) |
N/A |
OCTET STRING |
Same as that of the hh3cIfErrordown node |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.3.0.52 |
Autonegotiated full duplex mode for an interface |
Recovery |
Warning |
ON |
This notification is generated when the autonegotiated duplex mode changes from half duplex to full duplex for an interface.
System impact
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface index. |
ifIndex |
Integer32 |
ifIndex |
OCTET STRING |
Recommended action
hh3cIfEgressDropAlarm
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.3.0.53 |
Packet drop on a port |
Error |
Warning |
1.3.6.1.4.1.25506.2.40.3.0.54 (hh3cIfEgressDropRecover) |
ON |
This notification is generated when packets are dropped within the specified time.
System impact
Outgoing traffic of a port is dropped.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface index. |
ifIndex |
Integer32 |
ifIndex |
OCTET STRING |
1.3.6.1.4.1.25506.2.40.2.2.6.1.1 (hh3cIfQueId) |
ID of an interface's buffer queue. |
hh3cIfQueId |
INTEGER |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.3.0.54 |
Packet drop on a port recovers |
Recovery |
Warning |
ON |
This notification is generated when packet drop recovers on a port within the specified time.
System impact
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface index. |
ifIndex |
Integer32 |
ifIndex |
OCTET STRING |
hh3cIfQueId |
INTEGER |
Recommended action
hh3cIfBoardEgressDropAlarm
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.3.0.55 |
Outgoing unicast traffic of a card is dropped |
Error |
Warning |
1.3.6.1.4.1.25506.2.40.3.0.56 (hh3cIfBoardEgressDropRecover) |
ON |
This notification is generated if outgoing unicast traffic of a card is dropped within the specified time.
System impact
The outgoing unicast traffic of a card is dropped.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis index. |
N/A |
Integer32 |
0-65535 |
Card index. |
N/A |
Integer32 |
0-65535 |
1.3.6.1.4.1.25506.2.40.1.21 (hh3cIfCpuId) |
CPU ID of a card. |
N/A |
Unsigned32 |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.3.0.56 |
Outgoing unicast traffic drop of a card recovers. |
Recovery |
Warning |
ON |
This notification is generated if outgoing unicast traffic drop of a card recovers within the specified time.
System impact
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis index. |
N/A |
Integer32 |
0-65535 |
Card index. |
N/A |
Integer32 |
0-65535 |
CPU ID of a card. |
N/A |
Unsigned32 |
Recommended action
hh3cIfComboTypeChange
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.3.0.57 |
The combo type is changed by the CLI |
Informational |
Informational |
ON |
This notification is generated if the combo enable { copper | fiber } command configuration changes.
System impact
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface index. |
ifIndex |
Integer32 |
ifIndex |
OCTET STRING |
1.3.6.1.4.1.25506.2.40.1.22 (hh3cIfOldComboType) |
Combo interface type before change. |
N/A |
INTEGER |
fiber(1), copper(2) |
1.3.6.1.4.1.25506.2.40.1.23 (hh3cIfNewComboType) |
Combo interface type after change. |
N/A |
INTEGER |
Recommended action
hh3cIfIngressAgingDropAlarm
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.3.0.58 |
The traffic in the ingress buffer of a slot is dropped because of no schedule. |
Error |
Warning |
1.3.6.1.4.1.25506.2.40.3.0.59 (hh3cIfIngressAgingDropResume) |
ON |
This notification is generated if the traffic of high-priority queues exceeds the port bandwidth and thus the packets in low-priority queues cannot be scheduled.
System impact
The service traffic of a card is lost.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis index. |
N/A |
Integer32 |
0-65535 |
Card index. |
N/A |
Integer32 |
0-65535 |
CPU ID of a card. |
N/A |
Unsigned32 |
Unsigned32 (0..4294967295) |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.3.0.59 |
Traffic drop in the ingress buffer of a slot recovers |
Recovery |
Warning |
ON |
This notification is generated if traffic drop in the ingress buffer of a slot recovers within the specified time.
System impact
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis index. |
N/A |
Integer32 |
0-65535 |
Card index. |
N/A |
Integer32 |
0-65535 |
CPU ID of a card. |
N/A |
Unsigned32 |
Recommended action
hh3cIfMonInputJamDiscardAlarm
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.6.0.35 |
The number of incoming packets dropped due to congestion exceeds the threshold |
Error |
Warning |
1.3.6.1.4.1.25506.2.40.6.0.36 (hh3cIfMonInputJamDiscardResume) |
ON |
This notification is generated if the number of incoming packets dropped due to congestion exceeds the threshold.
System impact
If this alarm appears, serious congestion has occurred in the network. If you do not resolve this issue timely, network congestion will cause more packets to be dropped. As a result, services will be impacted.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface index. |
ifIndex |
Integer32 |
ifIndex |
OCTET STRING |
1.3.6.1.4.1.25506.2.40.5.1.1.1.15 (hh3cIfMonJamDiscardStatistics) |
Number of packets dropped due to congestion. |
Counter64 |
Counter64 (0..18446744073709551615) |
1.3.6.1.4.1.25506.2.40.5.2.1.1.42 (hh3cIfMonJamDiscardThres) |
Threshold for the number of packets dropped due to congestion. |
Unsigned32 |
1.3.6.1.4.1.25506.2.40.5.2.1.1.43 (hh3cIfMonJamDiscardInterval) |
Statistics interval for the number of packets dropped due to congestion. |
Unsigned32 |
Unsigned32 (0..65535) |
Recommended action
1. Execute the display this command to identify whether rate limiting is configured in the inbound direction of the interface.
2. Execute the qos lr inbound cir cir-value [ cbs cbs-value ] command in interface view to modify the rate limit values or execute the undo qos lr inbound command to delete rate limit configuration. Identify whether the alarm is cleared.
3. According to the service conditions, execute the port ifmonitor input-usage high-threshold high-value command in interface view to modify the alarm threshold for the number of packets lost due to congestion on the interface.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.6.0.36 |
The number of incoming packets dropped due to congestion is restored to the normal state |
Recovery |
Warning |
ON |
This notification is generated if the number of incoming packets dropped due to congestion drops below the threshold.
System impact
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface index. |
ifIndex |
Integer32 |
ifIndex |
OCTET STRING |
Counter64 |
Unsigned32 |
Unsigned32 |
Recommended action
hh3cIfMonOutputJamDiscardAlarm
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.6.0.37 |
The number of outgoing packets dropped due to congestion exceeds the threshold |
Error |
Warning |
1.3.6.1.4.1.25506.2.40.6.0.38 (hh3cIfMonOutputJamDiscardResume) |
ON |
This notification is generated if the number of outgoing packets dropped due to congestion exceeds the threshold.
System impact
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface index. |
ifIndex |
Integer32 |
ifIndex |
OCTET STRING |
Counter64 |
Unsigned32 |
Unsigned32 |
Recommended action
1. Execute the display this command to identify whether rate limiting is configured in the outbound direction of the interface.
2. Execute the qos lr outbound cir cir-value [ cbs cbs-value ] command in interface view to modify the rate limit values or execute the undo qos lr outbound command to delete rate limit configuration. Identify whether the alarm is cleared.
3. According to the service conditions, execute the port ifmonitor output-usage high-threshold high-value command in interface view to modify the alarm threshold for the number of packets lost due to congestion on the interface.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.6.0.38 |
The number of outgoing packets dropped due to congestion is restored to the normal state |
Recovery |
Warning |
ON |
System impact
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface index. |
ifIndex |
Integer32 |
ifIndex |
OCTET STRING |
Counter64 |
Unsigned32 |
Unsigned32 |
Recommended action
hh3cIfMonPktDropRateRising
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.6.0.39 |
The number of packets dropped on an interface card exceeds the configured alarm threshold |
Error |
Warning |
1.3.6.1.4.1.25506.2.40.6.0.40 (hh3cIfMonPktDropRateRecover) |
ON |
This notification is generated when the number of packets dropped on an interface card exceeds the configured alarm threshold.
System impact
The sending bandwidth of normal protocol packets is preempted. As a result, the protocols are interrupted, and data is lost.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis index. |
N/A |
Integer32 |
0-65535 |
Card index. |
N/A |
Integer32 |
0-65535 |
CPU ID of a card. |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.40.1.24 (hh3cIfDropRateThreshold) |
Threshold for the packet loss rate. |
N/A |
Integer32 |
Integer32(1..2147483647) |
1.3.6.1.4.1.25506.2.40.1.25 (hh3cIfCurrentDropRate) |
Current packet loss rate. |
N/A |
Integer32 |
1.3.6.1.4.1.25506.2.40.1.26 (hh3cIfDropRateInterval) |
Packet loss rate detection interval. |
N/A |
Integer32 |
1.3.6.1.4.1.25506.2.40.1.27 (hh3cIfMessageProtocol) |
Packet protocol. |
N/A |
Integer32 |
Recommended action
1. If the shutdown keyword is specified when you configure the alarm for the number of packets lost on a card, the system shuts down all interfaces on the card when the number of lost packets on the card exceeds the upper threshold. Then, the card stops forwarding all packets. To recover the interfaces on the card, execute the undo shutdown command on the interfaces.
2. If the reboot keyword is specified when you configure the alarm for the number of packets lost on a card, the system reboots the interface card when the number of lost packets on the card exceeds the upper threshold.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.6.0.40 |
The number of packets dropped on an interface card is restored to the normal state |
Recovery |
Warning |
ON |
This notification is generated when the number of packets dropped on an interface card drops below the threshold within the specified time.
System impact
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis index. |
N/A |
Integer32 |
0-65535 |
Card index. |
N/A |
Integer32 |
0-65535 |
CPU ID of a card. |
N/A |
Unsigned32 |
N/A |
Integer32 |
N/A |
Integer32 |
N/A |
Integer32 |
Packet protocol. |
N/A |
Integer32 |
Recommended action
hh3cIfMonBadBytesErrorRising
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.6.0.41 |
The number of bytes in bad packets exceeds the set alarm threshold |
Error |
Warning |
1.3.6.1.4.1.25506.2.40.6.0.42 (hh3cIfMonBadBytesErrorResume) |
ON |
This notification is generated when the number of bytes in bad packets exceeds the set alarm threshold within the specified time.
System impact
Service switchover or interruption might occur.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface index. |
ifIndex |
Integer32 |
ifIndex |
OCTET STRING |
1.3.6.1.4.1.25506.2.40.5.1.1.1.16 (hh3cIfMonBadBytesStatistics) |
Number of bytes in bad packets. |
Counter64 |
1.3.6.1.4.1.25506.2.40.5.2.1.1.44 (hh3cIfMonBadBytesThreshold) |
Threshold for the number of bytes in bad packets. |
Unsigned32 |
1.3.6.1.4.1.25506.2.40.5.2.1.1.45 (hh3cIfMonBadBytesDiscardInterval) |
Statistics interval for the number of bytes in bad packets. |
Unsigned32 |
Recommended action
1. When the attenuation of the line is too great, replace the optical fiber. Identify whether the alarm is cleared.
2. View the Tx optical power of the remote end on NMS. If the Tx optical power is abnormal, replace the corresponding line card of the remote end. Identify whether the recovery notification is generated.
3. Replace the line card of the local end that reports the alarm. Identify whether the recovery notification is generated.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.6.0.42 |
The number of bytes in bad packets is restored to the normal state |
Recovery |
Warning |
ON |
This notification is generated when the number of bytes in bad packets drops below the set alarm threshold within the specified time.
System impact
The services recover.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface index. |
ifIndex |
Integer32 |
ifIndex |
OCTET STRING |
Counter64 |
Unsigned32 |
Unsigned32 |
Recommended action
hh3cIfMonPortCrcRateExceed
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.6.0.43 |
The CRC packet error rate is equal to or greater than 1000 pps |
Informational |
Warning |
ON |
This notification is generated when the CRC packet error rate is equal to or greater than 1000 pps within the specified time.
System impact
Some service data on the interface is dropped.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface index. |
ifIndex |
Integer32 |
ifIndex |
OCTET STRING |
1.3.6.1.4.1.25506.2.40.5.1.1.1.17 (hh3cIfMonErrorRateStatistics) |
Packet error rate statistics. |
Counter64 |
1.3.6.1.4.1.25506.2.40.5.2.1.1.46 (hh3cIfMonErrorRateThres) |
Threshold for the packet error rate. |
Unsigned32 |
1.3.6.1.4.1.25506.2.40.5.2.1.1.47 (hh3cIfMonErrorRateDiscardInterval) |
Statistics interval for the packet error rate. |
Unsigned32 |
Recommended action
1. Replace the transceiver module, and then execute the display interface command to identify whether the number of CRC error packets keeps increasing on the interface.
2. Replace the fiber, and then execute the display interface command to identify whether the number of CRC error packets keeps increasing on the interface.
hh3cIfMonPortErrorRateExceed
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.6.0.44 |
The average packet error rate of CRC error packets, giants, and runts exceeds 1000 pps. |
Informational |
Warning |
ON |
This notification is generated when the average packet error rate of CRC error packets, giants, and runts exceeds 1000 pps within the specified time.
System impact
Some service data on the interface might be dropped.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface index. |
ifIndex |
Integer32 |
ifIndex |
OCTET STRING |
Counter64 |
Unsigned32 |
Unsigned32 |
Recommended action
1. Replace the transceiver module, and then execute the display interface command to identify whether the number of error packets keeps increasing on the interface.
2. Replace the fiber, and then execute the display interface command to identify whether the number of error packets keeps increasing on the interface.
3. Execute the jumboframe enable command to modify the jumbo frame length limit or change the packet length. Then, execute the display interface command to identify whether the number of error packets keeps increasing.
hh3cIfMonInBCRapidChange
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.6.0.45 |
The inbound broadcast traffic of an interface rapidly changes to exceed the threshold |
Error |
Warning |
1.3.6.1.4.1.25506.2.40.6.0.46 (hh3cIfMonInBCRapidRecover) |
ON |
This notification is generated if the inbound broadcast traffic of an interface rapidly changes to exceed the threshold (CurrentInputBroadcastRate ≥BaseInputBroadcastRate+InputBroadcastChangeThreshold) within the specified time.
System impact
Packet loss might occur.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface index. |
ifIndex |
Integer32 |
ifIndex |
OCTET STRING |
1.3.6.1.4.1.25506.2.40.1.28 (hh3cIfCurrentFlowThreshold) |
Current traffic threshold. |
N/A |
Counter64 |
1.3.6.1.4.1.25506.2.40.1.29 (hh3cIfCurrentFlowValue) |
N/A |
Counter64 |
Recommended action
1. When CurrentInputBroadcastRate ≥BaseInputBroadcastRate+InputBroadcastChangeThreshold, identify whether the broadcast traffic increases normally. If not, identify whether loops exist in the link.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.6.0.46 |
The rapid change of inbound broadcast traffic on an interface restores |
Recovery |
Warning |
ON |
This notification is generated if the inbound broadcast traffic of an interface rapidly changes to drop below the threshold (CurrentInputBroadcastRate≤BaseInputBroadcastRate- InputBroadcastChangeThresholdd) within the specified time.
System impact
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface index. |
ifIndex |
Integer32 |
ifIndex |
OCTET STRING |
N/A |
Counter64 |
N/A |
Counter64 |
Recommended action
hh3cIfMonPortCrcRateExceedResume
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.6.0.47 |
The CRC packet error rate is less than or equal to 1000 pps. |
Informational |
Warning |
N/A |
ON |
This recovery notification is generated when the CRC packet error rate is less than or equal to 1000 pps within the specified time.
System impact
No negative impact on the system.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface index. |
ifIndex |
Integer32 |
ifIndex |
OCTET STRING |
Counter64 |
Unsigned32 |
Unsigned32 |
Recommended action
hh3cIfFlowControlDLAlarm
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.3.0.63 |
The port does not forward packets but receives pause frames, or the port sends pause frames but does not receive packets |
Error |
Warning |
1.3.6.1.4.1.25506.2.40.3.0.64 (hh3cIfFlowControlDLAlarmResume) |
ON |
This notification is generated in either of the following conditions:
· The port does not forward packets, but receives a large number of pause frames.
· The port continuously sends a large number of pause frames, but does not receive packets.
System impact
An interface cannot forward packets.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface index. |
ifIndex |
Integer32 |
ifIndex |
OCTET STRING |
Recommended action
To resolve this issue, collect alarm information and configuration data, and then contact H3C Support.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.3.0.64 |
The port does not forward packets or receive pause frames, or the port sends pause frames and receives packets |
Recovery |
Warning |
N/A |
ON |
This notification is generated when the port sends pause frames and receives packets or the port does not forward packets or receive pause frames.
System impact
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface index. |
ifIndex |
Integer32 |
ifIndex |
OCTET STRING |
Recommended action
hh3cIfOutputErrorAlarm
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.3.0.65 |
Some service data on the port is dropped |
Error |
Warning |
1.3.6.1.4.1.25506.2.40.3.0.66 (hh3cIfOutputErrorAlarmResume) |
ON |
This notification is generated if the optical transceiver module or optical fiber fails.
System impact
Some service data on the port is dropped.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface index. |
ifIndex |
Integer32 |
ifIndex |
OCTET STRING |
Card index. |
N/A |
Integer32 |
0-65535 |
Subcard index. |
N/A |
Integer32 |
0-65535 |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.3.0.66 |
No service data is dropped on the port. |
Recovery |
Warning |
N/A |
ON |
This notification is generated when the optical transceiver module or optical fiber recovers and the service data on the port restores.
System impact
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface index. |
ifIndex |
Integer32 |
ifIndex |
OCTET STRING |
Card index. |
N/A |
Integer32 |
0-65535 |
Subcard index. |
N/A |
Integer32 |
0-65535 |
Recommended action
hh3cIfCableSnrAbnormal
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.40.3.0.67 |
The network cable quality is poor or signal interference occurs |
Error |
Warning |
1.3.6.1.4.1.25506.2.40.3.0.68 (hh3cIfCableSnrNormal) |
ON |
Notification triggers
This notification is generated when a multiGE copper port operates at 2.5 Gbps or higher and the network cable quality is poor or signal interference occurs.
System impact
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.2.1.2.2.1.1 (ifIndex) |
Interface index. |
ifIndex |
Integer32 |
Standard MIB values. |
1.3.6.1.2.1.2.2.1.2 (ifDescr) |
Interface description. |
ifIndex |
OCTET STRING |
Recommended action
1. Replace the current cable with a higher-quality cable, for example, category 6A cable or shielded cable.
2. Execute the speed { 100 | 1000 } or auto speed { 100 | 1000 } command to set a lower speed for the multiGE interface.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.3.0.68 |
The network cable quality is good and no signal interference occurs |
Recovery |
Warning |
N/A |
ON |
This notification is generated when a multiGE copper port operates at 2.5 Gbps or higher, the network cable quality is good, and no signal interference occurs.
System impact
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface index. |
ifIndex |
Integer32 |
ifIndex |
OCTET STRING |
Recommended action
No action is required.
hh3cIfCableSnrDetectNotSupport
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.3.0.69 |
A multiGE interface in up state goes down |
Informational |
Warning |
N/A |
ON |
This notification is generated when the network cable quality cannot be detected and a multiGE interface in up state goes down.
System impact
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface index. |
ifIndex |
Integer32 |
ifIndex |
OCTET STRING |
Recommended action
To resolve this issue:
1. The network cable quality cannot be detected. Replace the network cable.
hh3cIfSfpNotSupportSingleFiber
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.3.0.70 |
A transceiver module inserted into an interface does not support single fiber communication |
Informational |
Warning |
N/A |
ON |
This notification is generated when a transceiver module inserted into an interface does not support single fiber communication.
System impact
The single fiber communication function cannot be used on the interface because of the transceiver module inserted into the interface.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface index. |
ifIndex |
Integer32 |
ifIndex |
OCTET STRING |
Recommended action
To resolve this issue, replace the transceiver module with a transceiver module that supports single fiber communication.
hh3cIfLRMStateAbnormal
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.3.0.71 |
The interface does not support LRM transceiver modules |
Informational |
Warning |
N/A |
ON |
This notification is generated when the transceiver module inserted into an interface does not support LRM transceiver modules.
System impact
The transceiver module is not available, and the service of the interface is interrupted.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface index. |
ifIndex |
Integer32 |
ifIndex |
OCTET STRING |
Recommended action
1. Execute the display transceiver command to view the type of the transceiver module installed in the interface.
2. Replace the transceiver module with a non-LRM transceiver module.
hh3cIfSfpWorkOnlyNonNego
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.3.0.72 |
A GE transceiver module installed in an XGE interface can operate only at non-autonegotiated 1000 Mbps |
Informational |
Warning |
N/A |
ON |
This notification is generated when a GE transceiver module installed in an XGE interface can operate only at non-autonegotiated 1000 Mbps and the interconnect interface is manually configured to operate at 1000 Mbps.
System impact
After an XGE interface has a GE transceiver module installed, the autonegotiation function of the interface is unavailable.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface index. |
ifIndex |
Integer32 |
ifIndex |
OCTET STRING |
Recommended action
To resolve this issue, manually configure the interconnect interface to operate at 1000 Mbps.
hh3cIfPfcDeadLockAlarm
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.3.0.73 |
PFC deadlock might cause traffic interruption on the network |
Error |
Warning |
1.3.6.1.4.1.25506.2.40.3.0.74 (hh3cIfPfcDeadLockResume) |
ON |
This notification is generated when PFC deadlock occurs.
System impact
Traffic interruption might occur on the network.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface index. |
ifIndex |
Integer32 |
ifIndex |
OCTET STRING |
hh3cIfQueId |
INTEGER |
que0(1), que1(2), que2(3), que3(4), que4(5), que5(6), que6(7), que7(8) |
Recommended action
1. Execute the display priority-flow-control command to identify the PFC deadlock reasons on the network and optimize the network. If this issue persists on the network, proceed with step 2.
2. Execute the priority-flow-control deadlock cos cos-value interval interval command to adjust the PFC deadlock detection interval to meet the actual network requirements.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.3.0.74 |
PFC deadlock recovers, and traffic is forwarded |
Recovery |
Warning |
N/A |
ON |
This notification is generated when PFC deadlock recovers and traffic can be normally forwarded.
System impact
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface index. |
ifIndex |
Integer32 |
ifIndex |
OCTET STRING |
hh3cIfQueId |
INTEGER |
Recommended action
hh3cIfPfcTurnOffAlarm
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.3.0.75 |
The number of PFC deadlock times exceeds the threshold for automatically disabling PFC |
Error |
Warning |
1.3.6.1.4.1.25506.2.40.3.0.76 (hh3cIfPfcTurnOffResume) |
ON |
This notification is generated when the number of PFC deadlock times within a detection period exceeds the threshold for automatically disabling PFC.
System impact
PFC is automatically disabled.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface index. |
ifIndex |
Integer32 |
ifIndex |
OCTET STRING |
hh3cIfQueId |
INTEGER |
Recommended action
2. Execute the priority-flow-control deadlock cos cos-value interval interval command to adjust the PFC deadlock detection interval and execute the priority-flow-control deadlock threshold cos cos-value period period count count command to adjust the number of PFC deadlock times for automatically disabling PFC to meet the actual network requirements.
3. If the PFC deadlock has been removed from the network, first execute the undo priority-flow-control enable command to disable PFC and then execute the priority-flow-control enable command to enable PFC on the interface, so that PFC is applied again.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.3.0.76 |
The number of PFC deadlock times is lower than the threshold for automatically disabling PFC |
Recovery |
Warning |
N/A |
ON |
This notification is generated when the number of PFC deadlock times within a detection period is lower than the threshold for automatically disabling PFC.
System impact
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface index. |
ifIndex |
Integer32 |
ifIndex |
OCTET STRING |
hh3cIfQueId |
INTEGER |
Recommended action
hh3cIfQueueAlarm
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.3.0.77 |
The usage of a queue on an interface exceeds the threshold configured on the interface |
Error |
Warning |
1.3.6.1.4.1.25506.2.40.3.0.78 (hh3cIfQueueResume) |
ON |
This notification is generated when the usage of a queue on an interface exceeds the threshold configured on the interface.
System impact
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface index. |
ifIndex |
Integer32 |
ifIndex |
OCTET STRING |
hh3cIfQueId |
INTEGER |
1.3.6.1.4.1.25506.2.40.1.30 (hh3cIfCurrentUsedRatio) |
Current queue usage |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.40.31.0 (hh3cIfUsedRatioThershold) |
Queue usage threshold |
N/A |
Unsigned32 |
Recommended action
hh3cIfQueueResume
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.3.0.78 |
The usage of a queue on an interface drops below the threshold configured on the interface |
Recovery |
Warning |
N/A |
ON |
This notification is generated when the usage of a queue on an interface drops below the threshold configured on the interface.
System impact
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface index. |
ifIndex |
Integer32 |
ifIndex |
OCTET STRING |
hh3cIfQueId |
INTEGER |
N/A |
Unsigned32 |
N/A |
Unsigned32 |
Recommended action
hh3cIfQueueStatDiscardAlarm
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.3.0.79 |
The number of dropped packets, the number of dropped bytes, or the packet loss ratio of a port queue exceeds the alarm threshold |
Error |
Warning |
1.3.6.1.4.1.25506.2.40.3.0.80 (hh3cIfQueueStatDiscardResume) |
ON |
This notification is generated when the number of dropped packets, the number of dropped bytes, or the packet loss ratio of a port queue exceeds the alarm threshold.
System impact
Packet loss occurs, and services on the interface might be impacted.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface index. |
ifIndex |
Integer32 |
ifIndex |
OCTET STRING |
hh3cIfQueId |
INTEGER |
1.3.6.1.4.1.25506.2.40.1.32 (hh3cIfDiscardType) |
Packet loss type |
N/A |
INTEGER |
discardstat(1) discardByte(2) discardrate(3) |
1.3.6.1.4.1.25506.2.40.1.33 (hh3cIfDiscardThreshold) |
Packet loss threshold |
N/A |
Counter64 |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.3.0.80 |
The number of dropped packets, the number of dropped bytes, or the packet loss ratio of a port queue drops below the alarm threshold |
Recovery |
Warning |
N/A |
ON |
This notification is generated when the number of dropped packets, the number of dropped bytes, or the packet loss ratio of a port queue drops below the alarm threshold.
System impact
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface index. |
ifIndex |
Integer32 |
ifIndex |
OCTET STRING |
hh3cIfQueId |
INTEGER |
Packet loss type |
N/A |
INTEGER |
N/A |
Counter64 |
Recommended action
hh3cIfQueueEgressCongestionAlarm
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.3.0.81 |
Congestion occurs in the outbound direction of an interface queue |
Error |
Warning |
1.3.6.1.4.1.25506.2.40.3.0.82(hh3cIfQueueEgressCongestionClear) |
ON |
This notification is generated when congestion occurs in the outbound direction of an interface queue.
System impact
Outgoing traffic of an interface might be lost.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface index. |
ifIndex |
Integer32 |
ifIndex |
OCTET STRING |
hh3cIfQueId |
INTEGER |
Recommended action
Adjust the network to relieve the network congestion.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.3.0.82 |
Congestion in the outbound direction of an interface queue is removed |
Recovery |
Warning |
ON |
This recovery notification is generated when congestion in the outbound direction of an interface queue is removed.
System impact
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface index. |
ifIndex |
Integer32 |
ifIndex |
OCTET STRING |
hh3cIfQueId |
INTEGER |
Recommended action
hh3cIfAggPortBwChange
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.3.0.83 |
The bandwidth of the Trunk interface changes |
Informational |
Informational |
ON |
This notification is generated when the bandwidth of the aggregate interface changes.
System impact
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface index. |
ifIndex |
Integer32 |
ifIndex |
OCTET STRING |
Recommended action
hh3cIfRateOfTrafficRising
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.40.3.0.84 |
The traffic on the interface modules exceeds the threshold |
Informational |
Warning |
ON |
This notification is generated when the traffic on the interface modules exceeds the threshold, and the downlink bandwidth of the NP data channel exceeds 80 percent.
System impact
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis index. |
N/A |
Integer32 |
0-65535 |
Card index. |
N/A |
Integer32 |
0-65535 |
Recommended action
1. Adjust the network topology and identify whether the alarm is cleared.
2. If the issue persists, collect alarm information, log messages, and configuration data, and then contact Technical Support for help.
