End of Sale of the H3C S7500E & S7500X
    18-03-2024
H3C announces the upcoming end of sale for the S7500E & S7500X. The product part numbers covered by this announcement are listed below in Table 1. The last day to order the affected products is December 31st 2023 . Customers with active support contracts will continue to receive support from H3C TS (Technical Support) as per the dates listed in Table 2, the End-of-Life Milestones.
Migration Options
Customers are encouraged to plan a migration to newer models that are equivalent or better. The newer models are more power efficient, support existing features and offer enhanced functionality.
Affected Product
Replacement Products
0231A5M7
H3C S7503E-M Main Processing Unit with Switching and Routing,Providing 24*1000BASE Ethernet Optical Interfaces(SFP,LC)+ 4*10G Ethernet Optical Interfaces(SFP+,LC)(SC)
0231AFRR
H3C S7503X-M-G Main Processing Unit with Switching and Routing,with 24*1000BASE Ethernet Optical Interfaces(SFP,LC)+ 4*10G Ethernet Optical Interfaces(SFP+,LC)(SC)
0231A5M5
H3C S7503E-M Main Processing Unit with Switching and Routing,Providing 24*10/100/1000BASE-T Ethernet Copper Interfaces(RJ45)+ 4*10G Ethernet Optical Interfaces(SFP+,LC)(SC)
0231AFRK
H3C S7503X-M-G Main Processing Unit with Switching and Routing,with 24*10/100/1000BASE-T Ethernet Copper Interfaces(RJ45)+ 4*10G Ethernet Optical Interfaces(SFP+,LC)(SC)
0231A5UD
H3C S7503E-M Main Processing Unit with Switching and Routing,Providing 24*10G Ethernet Optical Interfaces(SFP+,LC)+ 2*40G/1*100G Ethernet Optical Interface(QSFP28)(FD)
0231A5RW
H3C S7503X Supervisor Engine Unit,Type A
0231AGG1
H3C S7503X-G Supervisor Engine Unit,Type B
0235A3MF
H3C S7503E-M Ethernet Switch Chassis
0235A3XA
H3C S7503X-M-G Ethernet Switch Chassis
0235A3MH
H3C S7503X Ethernet Switch Chassis
0235A2DE
H3C S7503X-G Ethernet Switch Chassis
0235A2HX
H3C S7506X Ethernet Switch Chassis,S Version
0235A2WA
H3C S7506X-G Ethernet Switch Chassis,PoE
0235A3MK
H3C S7506X Ethernet Switch Chassis,PoE
0235A2WA
0235A3MJ
H3C S7510X Ethernet Switch Chassis,PoE
0235A2W9
H3C S7510X-G Ethernet Switch Chassis,PoE
0231AFU9
0231AGB3
H3C S7503X-G Supervisor Engine Unit,Type A
0231ADWL
H3C S7506X Main Processing Unit with Switching,Type S
0231AFRS
H3C S7506X-G Main Processing Unit with Switching,Type AS
0231A5S1
H3C S7506X Main Processing Unit with Switching,Type A
0231AGB5
0231A5S0
H3C S7510X Main Processing Unit with Switching,Type C
0231AGG5
H3C S7510X-G Main Processing Unit with Switching,Type B
0231A7BA
H3C S7506X Main Processing Unit with Switching,Type C
0231AGB5
0231A7B8
H3C S7510X Main Processing Unit with Switching,Type B
0231AGG5
0231A4EV
48-Port GE Optical Interface Module(SFP,LC)(SA)
0231AJ0N
H3C S7500X-G 48-Port 1000BASE Ethernet Optical Interface Module (SFP,LC)(SD)
0231A4ET
24-Port GE Optical Interface(SFP,LC)+4-Port 10GE Optical Interface Module(SFP+,LC)(SA)
0231AJ0S
H3C S7500X-G 24-Port 10/100/1000BASE-T Ethernet Copper Interface(RJ45)+20-Port 1000BASE Ethernet Optical Interface(SFP,LC)+4-Port 10G Ethernet Optical Interface Module (SFP+,LC)(SD)
0231A4EU
48-Port 10/100/1000BASE-T Interface Module(RJ45)(SA)
0231AJ0P
H3C S7500X-G 48-Port 10/100/1000BASE-T Ethernet Copper Interface Module (RJ45)(SD)
0231A4WE
48-Port 10/100/1000BASE-T Interface Module(RJ45)(SA),PoE Plus
0231AJ0U
H3C S7500X-G 48-Port 10/100/1000BASE-T Ethernet Copper Interface Module (RJ45)(SD),PoE Plus
0231A2XW
44-Port GE Optical Interface(SFP,LC)+4-Port 10GE Optical Interface Module(SFP+,LC)
0231A2XX
0231AJ0S
0231A5PM
H3C S7500E 2-Port 100G Ethernet Optical Interface Module(QSFP28)(FE)
0231A2XY
24-Port 10/100/1000BASE-T Interface(RJ45)+20-Port GE Optical Interface(SFP,LC)+4-Port 10GE Optical Interface Module(SFP+,LC)
0231AJ0S
0231A2Y0
24-Port 10/100/1000BASE-T Interface(RJ45)+4-Port 10GE Optical Interface Module(SFP+,LC)
0231AJ0S
0231A2YA
0231AJ0P
0231A5PF
H3C S7500E 16-Port 10G Ethernet Optical Interface Module(SFP+,LC)(FD)
0231AJ0P
0231A5P8
H3C S7500E 24-Port 10G Ethernet Optical Interface Module(SFP+,LC)(FD)
0231A5SC
H3C S7500E 48-Port 1000BASE Ethernet Optical Interface Module(SFP,LC)(FD)
0231AJ0N
0231A5SS
H3C S7500E 40-Port 1000BASE Ethernet Optical Interface (SFP,LC)+8-Port 10G Ethernet Optical Interface Module(SFP+,LC)(FD)
0231AHSK
H3C S7500X-G 32-Port 1000BASE Ethernet Optical Interface(SFP,LC)+16-Port 10G Ethernet Optical Interface Module (SFP+,LC)(SD)
0231A5SK
H3C S7500E 48-Port 1000BASE-T Ethernet Copper Interface Module(RJ45)(FD)
0231AJ0P
0231A5UE
H3C S7500E,24-Port 10G Ethernet Optical Interfaces(SFP+,LC)+ 2-Port 40G/1-Port 100G Ethernet Optical Interface Module(QSFP28)(FD)
0231A8UM
H3C S7500E 24-Port Multigigabit Ethernet (10G/5G/2.5G/1G/100Mbps) Copper Interface Module (RJ45)(FD)
0231A5K5
H3C S7500E 12-Port 40G/4-Port 100G Ethernet Optical Interface Module(QSFP28)(SG)
0231AGB4
H3C S7500X-G 8-Port 40G Ethernet Optical Interface(QSFP+)+4-Port 100G Ethernet Optical Interface Module(QSFP28)(SE)
0231A5PT
H3C S7500E 48-Port 10G Ethernet Optical Interface Module(SFP+,LC)(SG)
0231AKCV
H3C S7500X-G 48-Port 10G Ethernet Optical Interface Module (SFP+)(SF)
0231A5S5
H3C S7500E 24-Port 40G Ethernet Optical Interface Module(QSFP+)(SG)
0231A5SR
H3C S7500E 48-Port 10G Ethernet Optical Interface Module(SFP+,LC)(FE)
0231AGB6
H3C S7500X-G 48-Port 10G Ethernet Optical Interface Module(SFP+,LC)(SE)
0231A4PU
H3C S7500E SecBlade IV Next Generation Firewall
0231AK4W
H3C S7500X-G SecBlade IV Next Generation Firewall Module
Table 1: Affected Product and Part numbers
Milestone
Date
Last day to order the products (End-of-Sale)
2023-12-31
Last day to receive software bug fixes and support
2025-12-31
Last day to add new service contracts
2024-12-31
Last day to renew existing service contracts
2027-12-31
Last day to receive 24x7 TAC support
2028-12-31
Table 2: End-of-Life Milestones
For more information about the H3C End-of-Life policy, please visit:https://www.h3c.com/en/Support/Policy_Dynamics/Management_Strategy/
