- 16-Security Command Reference
- 01-ACL commands
- 02-Packet filter commands
- 03-Time range commands
- 04-User profile commands
- 05-Password control commands
- 06-Keychain commands
- 07-Public key management commands
- 08-PKI commands
- 09-IPsec commands
- 10-IKE commands
- 11-IKEv2 commands
- 12-SSH commands
- 13-SSL commands
- 14-SSL VPN commands
- 15-Session management commands
- 16-Connection limit commands
- 17-Attack detection and prevention commands
- 18-IP-based attack prevention commands
- 19-IP source guard commands
- 20-ARP attack protection commands
- 21-ND attack defense commands
- 22-Protocol packet rate limit commands
- 23-Object group commands
- 24-Security policy commands
02-Packet filter commands | 140.54 KB |
display packet-filter statistics
display packet-filter statistics sum
packet-filter (interface view)
packet-filter (user profile view)
packet-filter default hardware-count
reset packet-filter statistics
acl logging interval
Use acl logging interval to enable logging for packet filtering and set the interval.
Use undo acl logging interval to restore the default.
acl logging interval interval
The interval is 0. The device does not generate log entries for packet filtering.
interval: Specifies the interval at which log entries are generated and output. It must be a multiple of 5, in the range of 0 to 1440 minutes. To disable the logging, set the value to 0.
The logging feature is available for IPv4 or IPv6 ACL rules that have the logging keyword.
You can configure the ACL module to generate log entries for packet filtering and output them to the information center at the output interval. The log entry records the number of matching packets and the matched ACL rules. When the first packet of a flow matches an ACL rule, the output interval starts, and the device immediately outputs a log entry for this packet. When the output interval ends, the device outputs a log entry for subsequent matching packets of the flow.
For more information about the information center, see System Management Configuration Guide.
# Configure the device to generate and output packet filtering log entries every 10 minutes.
[Sysname] acl logging interval 10
rule (IPv4 advanced ACL view)
rule (IPv4 basic ACL view)
rule (IPv6 advanced ACL view)
rule (IPv6 basic ACL view)
acl trap interval
Use acl trap interval to enable SNMP notifications for packet filtering and set the interval.
Use undo acl interval to restore the default.
acl trap interval interval
undo acl trap interval
The interval is 0. The device does not generate SNMP notifications for packet filtering.
interval: Specifies the interval at which SNMP notifications are generated and output. It must be a multiple of 5, in the range of 0 to 1440 minutes. To disable SNMP notifications, set the value to 0.
The SNMP notifications feature is available for IPv4 or IPv6 ACL rules that have the logging keyword.
You can configure the ACL module to generate SNMP notifications for packet filtering and output them to the SNMP module at the output interval. The notification records the number of matching packets and the matched ACL rules. When the first packet of a flow matches an ACL rule, the output interval starts, and the device immediately outputs a notification for this packet. When the output interval ends, the device outputs a notification for subsequent matching packets of the flow.
For more information about SNMP, see Network Management and Monitoring Configuration Guide.
# Configure the device to generate and output packet filtering SNMP notifications every 10 minutes.
[Sysname] acl trap interval 10
Use display packet-filter to display ACL application information for packet filtering.
display packet-filter interface [ interface-type interface-number ] [ inbound | outbound ]
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If you do not specify an interface, this command displays ACL application information for packet filtering on all interfaces except VA interfaces. For information about VA interfaces, see PPPoE in User Access and Authentication Configuration Guide.
inbound: Specifies the inbound direction.
outbound: Specifies the outbound direction.
If neither the inbound keyword nor the outbound keyword is specified, this command displays ACL application information for packet filtering in both directions.
# Display ACL application information for inbound packet filtering on interface GigabitEthernet 1/0/1.
<Sysname> display packet-filter interface gigabitethernet 1/0/1 inbound
Inbound policy:
IPv4 ACL 2001
IPv6 ACL 2002 (Failed)
MAC ACL 4003
Interface to which the ACL applies. |
Inbound policy |
ACL used for filtering incoming traffic. |
Outbound policy |
ACL used for filtering outgoing traffic. |
IPv4 ACL 2001 |
IPv4 basic ACL 2001 has been successfully applied. |
IPv6 ACL 2002 (Failed) |
The device has failed to apply IPv6 basic ACL 2002. |
IPv4 default action |
Packet filter default action for packets that do not match any IPv4 ACLs: · Deny—The default action deny has been successfully applied for packet filtering. · Deny (Failed)—The device has failed to apply the default action deny for packet filtering. The action permit still functions. · Permit—The default action permit has been successfully applied for packet filtering. · Hardware-count—The hardware-count feature has been successfully applied for the default action for packet filtering. · Hardware-count (Failed)—The device has failed to apply the hardware-count feature for the packet filtering default action. |
IPv6 default action |
Packet filter default action for packets that do not match any IPv6 ACLs: · Deny—The default action deny has been successfully applied for packet filtering. · Deny (Failed)—The device has failed to apply the default action deny for packet filtering. The action permit still functions. · Permit—The default action permit has been successfully applied for packet filtering. · Hardware-count—The hardware-count feature has been successfully applied for the default action for packet filtering. · Hardware-count (Failed)—The device has failed to apply the hardware-count feature for the packet filtering default action. |
MAC default action |
Packet filter default action for packets that do not match any Layer 2 ACLs: · Deny—The default action deny has been successfully applied for packet filtering. · Deny (Failed)—The device has failed to apply the default action deny for packet filtering. The action permit still functions. · Permit—The default action permit has been successfully applied for packet filtering. · Hardware-count—The hardware-count feature has been successfully applied for the default action for packet filtering. · Hardware-count (Failed)—The device has failed to apply the hardware-count feature for the packet filtering default action. |
Use display packet-filter statistics to display packet filtering statistics.
display packet-filter statistics interface interface-type interface-number { inbound | outbound } [ default | [ ipv6 | mac ] { acl-number | name acl-name } ] [ brief ]
default: Displays the default action statistics for packet filtering.
ipv6: Specifies the IPv6 ACL type.
mac: Specifies the Layer 2 ACL type.
acl-number: Specifies an ACL by its number. The following are available value ranges:
· 2000 to 2999 for basic ACLs.
· 3000 to 3999 for advanced ACLs.
· 4000 to 4999 for Layer 2 ACLs.
name acl-name: Specifies an ACL by its name. The acl-name argument is a case-insensitive string of 1 to 63 characters.
brief: Displays brief statistics.
If you do not specify any parameters, this command displays packet filtering statistics for all ACLs.
To specify the IPv4 ACL type, do not specify the ipv6 keyword.
# Display packet filtering statistics for all ACLs on incoming packets of GigabitEthernet 1/0/1.
<Sysname> display packet-filter statistics interface gigabitethernet 1/0/1 inbound
Inbound policy:
IPv4 ACL 2001, Hardware-count
From 2019-06-04 10:25:21 to 2019-06-04 10:35:57
rule 0 permit source 2.2.2.2 0 (2 packets)
rule 5 permit source 1.1.1.1 0 (Failed)
Totally 2 packets permitted, 0 packets denied
Totally 100% permitted, 0% denied
IPv6 ACL 2000
MAC ACL 4000
rule 0 permit
IPv4 default action: Deny, Hardware-count
Totally 7 packets
IPv6 default action: Deny, Hardware-count
From 2019-06-04 10:25:41 to 2019-06-04 10:35:57
Totally 0 packets
MAC default action: Deny, Hardware-count
From 2019-06-04 10:25:34 to 2019-06-04 10:35:57
Totally 0 packets
Inbound policy |
Outbound policy |
IPv4 ACL 2001 |
IPv4 ACL 2002 (Failed) |
The device has failed to apply IPv4 basic ACL 2002. |
Hardware-count |
ACL rule match counting in hardware has been successfully enabled. |
Hardware-count (Failed) |
The device has failed to enable counting ACL rule matches in hardware. |
From 2019-06-04 10:25:21 to 2019-06-04 10:35:57 |
Start time and end time of the statistics. |
2 packets |
Two packets matched the rule. This field is not displayed when no packets matched the rule. |
No resource |
Resources are not enough for counting matches for the rule. In packet filtering statistics, this field is displayed for a rule when resources are not sufficient for rule match counting. |
rule 5 permit source 1.1.1.1 0 (Failed) |
The device has failed to apply rule 5. |
Totally 2 packets permitted, 0 packets denied |
Number of packets permitted and denied by the ACL. |
Totally 100% permitted, 0% denied |
Ratios of permitted and denied packets to all packets. |
Totally 7 packets |
The default action has been executed on seven packets. |
Use display packet-filter statistics sum to display accumulated packet filtering statistics for an ACL.
display packet-filter statistics sum { inbound | outbound } [ ipv6 | mac ] { acl-number | name acl-name } [ brief ]
# Display accumulated packet filtering statistics for IPv4 basic ACL 2001 on incoming packets.
<Sysname> display packet-filter statistics sum inbound 2001
Sum:
Inbound policy:
IPv4 ACL 2001
# Display brief accumulated packet filtering statistics for IPv4 basic ACL 2000 on incoming packets.
<Sysname> display packet-filter statistics sum inbound 2000 brief
Sum:
Inbound policy:
IPv4 ACL 2000
Sum |
Accumulated packet filtering statistics. |
Inbound policy |
Accumulated packet filtering statistics in the inbound direction. |
Outbound policy |
Accumulated packet filtering statistics in the outbound direction. |
IPv4 ACL 2001 |
Accumulated packet filtering statistics of IPv4 basic ACL 2001. |
2 packets |
display packet-filter verbose
Use display packet-filter verbose to display ACL application details for packet filtering.
display packet-filter verbose interface interface-type interface-number { inbound | outbound } [ [ ipv6 | mac ] { acl-number | name acl-name } ]
If acl-number, name acl-name, ipv6, or mac is not specified, this command displays application details of all ACLs for packet filtering.
# Display application details of all ACLs for inbound packet filtering on GigabitEthernet 1/0/1.
<Sysname> display packet-filter verbose interface gigabitethernet 1/0/1 inbound
Inbound policy:
IPv4 ACL 2001
rule 0 permit
IPv6 ACL 2000
rule 0 permit
MAC ACL 4000
IPv6 default action: Deny, Hardware-count (Failed)
Inbound policy |
Outbound policy |
IPv4 ACL 2001 |
Hardware-count |
Use packet-filter to apply an ACL to an interface to filter packets.
Use undo packet-filter to remove an ACL from an interface.
packet-filter [ ipv6 | mac ] { acl-number | name acl-name } { inbound | outbound } [ hardware-count ]
undo packet-filter [ ipv6 | mac ] { acl-number | name acl-name } { inbound | outbound }
No ACL is applied to an interface to filter packets.
Interface view
inbound: Filters incoming packets.
outbound: Filters outgoing packets.
hardware-count: Enables counting ACL rule matches performed in hardware. If you do not specify this keyword, rule matches for the ACL are not counted in hardware.
The hardware-count keyword in this command enables match counting in hardware for all rules in an ACL, and the counting keyword in the rule command enables match counting specific to rules.
To disable ACL rule match counting in hardware when resources are insufficient, you must execute the undo packet-filter command and then re-execute the packet-filter command without specifying the hardware-count keyword.
To disable ACL rule match counting in hardware when resources are sufficient, you can directly re-execute the packet-filter command without specifying the hardware-count keyword.
To the same direction of an interface, you can apply a maximum of 32 ACLs.
# Apply IPv4 basic ACL 2001 to filter incoming traffic on GigabitEthernet 1/0/1, and enable counting ACL rule matches performed in hardware.
[Sysname-GigabitEthernet1/0/1] packet-filter 2001 inbound hardware-count
Use packet-filter to apply an ACL to a user profile to filter packets.
Use undo packet-filter to remove an ACL from a user profile.
packet-filter [ ipv6 ] { acl-number | name acl-name } { inbound | outbound }
undo packet-filter [ ipv6 ] { acl-number | name acl-name } { inbound | outbound }
No ACL is applied to a user profile to filter packets.
User profile view
To the same direction of a user profile, you can apply only one ACL.
If the specified ACL does not exist or does not have any rules, the ACL will not be referenced.
# Apply IPv4 basic ACL 2001 to filter the incoming traffic of user profile user-profile1.
[Sysname] user-profile user-profile1
[Sysname-user-profile-user-profile1] packet-filter 2001 inbound
display user-profile (User Access and Authentication Command Reference)
packet-filter default deny
Use packet-filter default deny to set the packet filtering default action to deny. The packet filter denies packets that do not match any ACL rule.
Use undo packet-filter default deny to restore the default.
The packet filtering default action is permit. The packet filter permits packets that do not match any ACL rule.
The packet filter applies the default action to all ACL applications for packet filtering. The default action appears in the display command output for packet filtering.
# Set the packet filter default action to deny.
[Sysname] packet-filter default deny
Use packet-filter default hardware-count to enable hardware-count for the packet filtering default action.
Use undo packet-filter default hardware-count to disable hardware-count for the packet filtering default action.
packet-filter default { inbound | outbound } hardware-count
undo packet-filter default { inbound | outbound } hardware-count
Hardware-count is disabled for the packet filtering default action.
Interface view
inbound: Specifies the incoming packets.
outbound: Specifies the outgoing packets.
To enable hardware-count for the packet filtering default action on an interface, make sure you have applied ACLs to the interface for packet filtering.
# Set the packet filtering default action to deny. Apply IPv4 basic ACL 2001 to GigabitEthernet 1/0/1 for filtering incoming packets, and enable hardware-count for the packet filtering default action on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] packet-filter default inbound hardware-count
packet-filter
Use reset packet-filter statistics to clear the packet filtering statistics.
reset packet-filter statistics interface [ interface-type interface-number { inbound | outbound } [ default | [ ipv6 | mac ] { acl-number | name acl-name } ]
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If you do not specify an interface, this command clears packet filtering statistics for all interfaces.
default: Clears the default action statistics for packet filtering.
If default, acl-number, name acl-name, ipv6, or mac is not specified, this command clears the packet filtering statistics for all ACLs.
# Clear IPv4 basic ACL 2001 statistics for inbound packet filtering on GigabitEthernet 1/0/1.
<Sysname> reset packet-filter statistics interface gigabitethernet 1/0/1 inbound 2001
