| 03-AAA commands | 1.73 MB |
aaa abnormal-offline-record enable
aaa normal-offline-record enable
authorization-attribute (ISP domain view)
display aaa abnormal-offline-record
display aaa normal-offline-record
display aaa online-fail-record
local-server log change-password-prompt
reset aaa abnormal-offline-record
reset aaa normal-offline-record
session-time include-idle-time
access-user email authentication
authorization-attribute (local user view/user group view)
display local-guest waiting-approval
local-user-export class network
local-user-export class network guest
local-user-import class network
local-user-import class network guest
password (device management user view)
password (network access user view)
reset local-guest waiting-approval
service-type (local user view)
attribute convert (RADIUS DAS view)
attribute convert (RADIUS scheme view)
attribute reject (RADIUS DAS view)
attribute reject (RADIUS scheme view)
attribute vendor-id 2011 version
data-flow-format (RADIUS scheme view)
display radius server-load statistics
display stop-accounting-buffer (for RADIUS)
include-attribute 218 vendor-id 25506
primary accounting (RADIUS scheme view)
primary authentication (RADIUS scheme view)
radius authentication-request first
reauthentication server-select
reset radius server-load statistics
reset stop-accounting-buffer (for RADIUS)
retry stop-accounting (RADIUS scheme view)
secondary accounting (RADIUS scheme view)
secondary authentication (RADIUS scheme view)
server-block-action (RADIUS scheme view)
stop-accounting-buffer enable (RADIUS scheme view)
stop-accounting-packet send-force
timer quiet (RADIUS scheme view)
timer realtime-accounting (RADIUS scheme view)
timer response-timeout (RADIUS scheme view)
user-name-format (RADIUS scheme view)
data-flow-format (HWTACACS scheme view)
display stop-accounting-buffer (for HWTACACS)
primary accounting (HWTACACS scheme view)
primary authentication (HWTACACS scheme view)
reset stop-accounting-buffer (for HWTACACS)
retry stop-accounting (HWTACACS scheme view)
secondary accounting (HWTACACS scheme view)
secondary authentication (HWTACACS scheme view)
stop-accounting-buffer enable (HWTACACS scheme view)
timer quiet (HWTACACS scheme view)
timer realtime-accounting (HWTACACS scheme view)
timer response-timeout (HWTACACS scheme view)
user-name-format (HWTACACS scheme view)
display radius-server active-client
display radius-server active-eap-profile
display radius-server active-ldap-scheme
display radius-server active-user
Connection recording policy commands
AAA commands
General AAA commands
Use aaa abnormal-offline-record enable to enable user abnormal offline recording.
Use undo aaa abnormal-offline-record enable to disable user abnormal offline recording.
User abnormal offline recording is disabled.
This feature enables the system to record information about users that go offline abnormally. These records help the administrator analyze the causes and resolve the issues for abnormal user offline events. To display user abnormal offline records, use the display aaa abnormal-offline-record command.
This feature takes effect only when user offline recording is enabled.
The device can record a maximum of 32768 user abnormal offline records. When the maximum number is reached, a new record overwrites the oldest record.
To reduce the memory usage, you can disable this feature.
# Enable user abnormal offline recording.
[Sysname] aaa abnormal-offline-record enable
aaa offline-record enable
aaa nas-id profile
Use aaa nas-id profile to create a NAS-ID profile and enter its view, or enter the view of an existing NAS-ID profile.
Use undo aaa nas-id profile to delete a NAS-ID profile.
undo aaa nas-id profile profile-name
No NAS-ID profiles exist.
profile-name: Specifies the NAS-ID profile name, a case-insensitive string of 1 to 31 characters.
Configure a NAS-ID profile to maintain NAS-ID and VLAN bindings on the device.
During RADIUS authentication, the device uses a NAS-ID to set the NAS-Identifier attribute of RADIUS packets so that the RADIUS server can identify the access location of users.
The device selects the NAS-ID for the NAS-Identifier attribute in the following order:
1. NAS-ID bound with VLANs in a NAS-ID profile.
2. NAS-ID in an ISP domain.
# Create a NAS-ID profile named aaa and enter its view.
[Sysname] aaa nas-id profile aaa
[Sysname-nas-id-prof-aaa]
aaa nas-id
aaa nas-id-profile
nas-id bind
portal nas-id-profile
Use aaa normal-offline-record enable to enable user normal offline recording.
Use undo aaa normal-offline-record enable to disable user normal offline recording.
User normal offline recording is disabled.
This feature enables the system to record information about users that go offline normally. These records help the administrator analyze causes of user offline events. To display user normal offline records, use the display aaa normal-offline-record command.
The device can record a maximum of 32768 user normal offline records. When the maximum number is reached, a new record overwrites the oldest record.
# Enable user normal offline recording.
[Sysname] aaa normal-offline-record enable
Use aaa offline-record enable to enable user offline recording.
Use undo aaa offline-record enable to disable user offline recording.
User offline recording is disabled.
You must enable this feature so that user abnormal offline recording and user normal offline recording can take effect. Then, the system can record information about users that go offline normally and abnormally. To display user offline records, use the display aaa offline-record command.
The device can record a maximum of 65536 user offline records. When the maximum number is reached, a new record overwrites the oldest record.
# Enable user offline recording.
[Sysname] aaa offline-record enable
aaa online-fail-record enable
Use aaa online-fail-record enable to enable user online failure recording.
Use undo aaa online-fail-record enable to disable user online failure recording.
User online failure recording is disabled.
This feature enables the system to record information about users that fail to come online. These records help the administrator identify causes of user online failures and check for malicious users. To display user online failure records, use the display aaa online-fail-record command.
The device can record a maximum of 32768 user online failure records. When the maximum number is reached, a new record overwrites the oldest record.
# Enable user online failure recording.
[Sysname] aaa online-fail-record enable
aaa session-id mode
Use aaa session-id mode to specify the format for attribute Acct-Session-Id.
Use undo aaa session-id mode to restore the default.
aaa session-id mode { common | simplified }
undo session-id mode
The device uses the common mode for attribute Acct-Session-Id.
common: Specifies the common format for attribute Acct-Session-Id. In this format, the Acct-Session-Id attribute is a string of 37 characters. This string contains the prefix (indicating the access type), date and time, sequence number, LIP address of the access node, device ID, and job ID of the access process.
simplified: Specifies the simple format for attribute Acct-Session-Id. In this format, the Acct-Session-Id attribute is a string of 16 characters. This string contains the prefix (indicating the access type), month, sequence number, device ID, and LIP address of the access node.
Configure the format for attribute Acct-Session-Id to meet the requirements of the RADIUS servers.
# Specify the simple format for attribute Acct-Session-Id.
[Sysname] aaa session-id mode simplified
aaa session-limit
Use aaa session-limit to set the maximum number of concurrent users that can log on to the device through the specified method.
Use undo aaa session-limit to restore the default maximum number of concurrent users for the specified login method.
aaa session-limit { ftp | http | https | ssh | telnet } max-sessions
undo aaa session-limit { ftp | http | https | ssh | telnet }
The maximum number of concurrent users is 32 for each user type.
ftp: FTP users.
http: HTTP users.
https: HTTPS users.
ssh: SSH users.
telnet: Telnet users.
max-sessions: Specifies the maximum number of concurrent login users. The value range is 1 to 32 for SSH and Telnet services, and is 1 to 64 for FTP, HTTP, and HTTPS services.
After the maximum number of concurrent login users for a user type exceeds the upper limit, the system denies the subsequent users of this type.
For HTTP and HTTPS services, the number of concurrent users of an application is separately limited. For example, if the maximum number of concurrent HTTP users is 20, a maximum of 20 concurrent users are allowed for each HTTP-based application, such as RESTful, Web, and NETCONF.
# Set the maximum number of concurrent FTP users to 4.
[Sysname] aaa session-limit ftp 4
accounting command
Use accounting command to specify the command line accounting method.
Use undo accounting command to restore the default.
accounting command hwtacacs-scheme hwtacacs-scheme-name
The default accounting methods of the ISP domain are used for command line accounting.
ISP domain view
hwtacacs-scheme hwtacacs-scheme-name: Specifies an HWTACACS scheme by its name, a case-insensitive string of 1 to 32 characters.
The command line accounting feature works with the accounting server to record valid commands that have been successfully executed on the device.
· When the command line authorization feature is disabled, the accounting server records all valid commands that have been successfully executed.
· When the command line authorization feature is enabled, the accounting server records only authorized commands that have been successfully executed.
Command line accounting can use only a remote HWTACACS server.
# In ISP domain test, perform command line accounting based on HWTACACS scheme hwtac.
[Sysname] domain name test
[Sysname-isp-test] accounting command hwtacacs-scheme hwtac
accounting default
command accounting (Fundamentals Command Reference)
hwtacacs scheme
accounting default
Use accounting default to specify default accounting methods for an ISP domain.
Use undo accounting default to restore the default.
accounting default { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] [ none ] | local [ hwtacacs-scheme hwtacacs-scheme-name | radius-scheme radius-scheme-name ] * [ none ] | none | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] [ none ] }
The default accounting method of an ISP domain is local.
ISP domain view
local: Performs local accounting.
none: Does not perform accounting.
radius-scheme radius-scheme-name: Specifies a RADIUS scheme by its name, a case-insensitive string of 1 to 32 characters.
The default accounting method is used for all users that support this method and do not have an accounting method configured.
Local accounting is only used for monitoring and controlling the number of local user connections. It does not provide the statistics function that the accounting feature generally provides.
You can specify one primary default accounting method and multiple backup default accounting methods.
When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the accounting default radius-scheme radius-scheme-name local none command specifies the primary default RADIUS accounting method and two backup methods (local accounting and no accounting). The device performs RADIUS accounting by default and performs local accounting when RADIUS accounting is invalid. The device does not perform accounting when both of the previous methods are invalid.
The remote accounting method is invalid in the following situations:
· The specified accounting scheme does not exist.
· Accounting packet sending fails.
· The device does not receive any accounting response packets from an accounting server.
The local accounting method is invalid if the device fails to find the matching local user configuration.
When the primary accounting method is local, the following rules apply to the accounting of a user:
· The device uses the backup accounting methods in sequence only if local accounting is invalid for one of the following reasons:
¡ An exception occurs in the local accounting process.
¡ The user account is not configured on the device or the user is not allowed to use the access service.
· The device does not turn to the backup accounting methods if local accounting is invalid because of any other reason. Accounting fails for the user.
# In ISP domain test, use RADIUS scheme rd as the primary default accounting method and use local accounting as the backup.
[Sysname-isp-test] accounting default radius-scheme rd local
hwtacacs scheme
local-user
radius scheme
accounting dual-stack
Use accounting dual-stack to specify the accounting method for dual-stack users.
Use undo accounting dual-stack to restore the default.
accounting dual-stack { merge | separate }
The merge method applies.
ISP domain view
merge: Merges IPv4 data with IPv6 data for accounting.
separate: Separates IPv4 data from IPv6 data for accounting.
If the charging rates are different for IPv4 and IPv6 data, use the separate method for the accounting of dual-stack users.
If the separate method is used for the accounting of dual-stack users, the authorization CAR action is also separately applied to IPoE users' basic IPv4 traffic and basic IPv6 traffic.
# In ISP domain test, configure the device to separate IPv4 data from IPv6 data for the accounting of dual-stack users.
[Sysname-isp-test] accounting dual-stack separate
accounting ipoe
Use accounting ipoe to specify accounting methods for IPoE users.
Use undo accounting ipoe to restore the default.
accounting ipoe { broadcast radius-scheme radius-scheme-name1 radius-scheme radius-scheme-name2 [ local ] [ none ] | local [ radius-scheme radius-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ local ] [ none ] }
The default accounting methods of the ISP domain are used for IPoE users.
ISP domain view
broadcast: Broadcasts accounting requests to servers in RADIUS schemes.
radius-scheme radius-scheme-name1: Specifies the primary broadcast RADIUS scheme by its name, a case-insensitive string of 1 to 32 characters.
radius-scheme radius-scheme-name2: Specifies the backup broadcast RADIUS scheme by its name, a case-insensitive string of 1 to 32 characters.
You can specify one primary accounting method and multiple backup accounting methods.
When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the accounting ipoe radius-scheme radius-scheme-name local none command specifies a primary RADIUS accounting method and two backup methods (local accounting and no accounting). The device performs RADIUS accounting by default and performs local accounting when RADIUS accounting is invalid. The device does not perform accounting when both of the previous methods are invalid.
The following guidelines apply to broadcast accounting:
· The device sends accounting requests to the primary accounting servers in the specified broadcast RADIUS schemes at the real-time accounting interval set in the primary broadcast RADIUS scheme. If the primary server is unavailable in a scheme, the device sends accounting requests to the secondary servers of the scheme in the order the servers are configured.
· The accounting result is determined by the primary broadcast RADIUS scheme. The accounting result from the backup scheme is used as reference only. If the primary scheme does not return any result, the device considers the accounting as a failure.
¡ The user account is not configured on the device or the user is not allowed to use the IPoE service.
# In ISP domain test, perform local accounting for IPoE users.
[Sysname-isp-test] accounting ipoe local
# In ISP domain test, perform RADIUS accounting for IPoE users based on scheme rd and use local accounting as the backup.
[Sysname-isp-test] accounting ipoe radius-scheme rd local
# In ISP domain test, broadcast accounting requests of IPoE users to RADIUS servers in schemes rd1 and rd2, and use local accounting as the backup.
[Sysname-isp-test] accounting ipoe broadcast radius-scheme rd1 radius-scheme rd2 local
accounting default
local-user
radius scheme
accounting login
Use accounting login to specify accounting methods for login users.
Use undo accounting login to restore the default.
accounting login { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] [ none ] | local [ hwtacacs-scheme hwtacacs-scheme-name | radius-scheme radius-scheme-name ] * [ none ] | none | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] [ none ] }
The default accounting methods of the ISP domain are used for login users.
ISP domain view
Accounting is not supported for FTP, SFTP, and SCP users.
When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the accounting login radius-scheme radius-scheme-name local none command specifies a primary default RADIUS accounting method and two backup methods (local accounting and no accounting). The device performs RADIUS accounting by default and performs local accounting when RADIUS accounting is invalid. The device does not perform accounting when both of the previous methods are invalid.
¡ The user account is not configured on the device.
# In ISP domain test, perform local accounting for login users.
[Sysname-isp-test] accounting login local
# In ISP domain test, perform RADIUS accounting for login users based on scheme rd and use local accounting as the backup.
[Sysname-isp-test] accounting login radius-scheme rd local
accounting default
hwtacacs scheme
local-user
radius scheme
accounting portal
Use accounting portal to specify accounting methods for portal users.
Use undo accounting portal to restore the default.
accounting portal { broadcast radius-scheme radius-scheme-name1 radius-scheme radius-scheme-name2 [ local ] [ none ] | local [ radius-scheme radius-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ local ] [ none ] }
The default accounting methods of the ISP domain are used for portal users.
ISP domain view
When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the accounting portal radius-scheme radius-scheme-name local none command specifies a primary default RADIUS accounting method and two backup methods (local accounting and no accounting). The device performs RADIUS accounting by default and performs local accounting when RADIUS accounting is invalid. The device does not perform accounting when both of the previous methods are invalid.
¡ The user account is not configured on the device or the user is not allowed to use the portal service.
# In ISP domain test, perform local accounting for portal users.
[Sysname-isp-test] accounting portal local
# In ISP domain test, perform RADIUS accounting for portal users based on scheme rd and use local accounting as the backup.
[Sysname-isp-test] accounting portal radius-scheme rd local
# In ISP domain test, broadcast accounting requests of portal users to RADIUS servers in schemes rd1 and rd2, and use local accounting as the backup.
[Sysname-isp-test] accounting portal broadcast radius-scheme rd1 radius-scheme rd2 local
accounting default
local-user
radius scheme
accounting quota-out
Use accounting quota-out to configure access control for users that have used up their data or time accounting quotas.
Use undo accounting quota-out to restore the default.
accounting quota-out { offline | online } [ no-accounting-update ]
The device sends accounting-update packets to the server to request new quotas for the users that have used up their accounting quotas. A user is logged off if the device does not receive any new quota for the user.
ISP domain view
offline: Logs off users that have used up their accounting quotas.
online: Allows users that have used up their accounting quotas to stay online.
no-accounting-update: Disables the device from sending accounting-update requests to refresh the users' quotas.
If the server notifies the device of portal users' remaining accounting quotas, the time that the device logs out portal users that have used up their accounting quotas might be inaccurate.
The server might divide the accounting quota of a user into multiple portions and assign a portion to the user each time. If the server does not support dividing user accounting quota, specify the no-accounting-update keyword to decrease the burden of the server as a best practice.
# In ISP domain test, configure the device to allow users that have used up their accounting quotas to stay online.
[Sysname-isp-test] accounting quota-out online
accounting sslvpn
Use accounting sslvpn to specify accounting methods for SSL VPN users.
Use undo accounting sslvpn to restore the default.
In non-FIPS mode:
accounting sslvpn { local [ radius-scheme radius-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ local ] [ none ] }
In FIPS mode:
accounting sslvpn { local | radius-scheme radius-scheme-name } *
The default accounting methods of the ISP domain are used for SSL VPN users.
ISP domain view
When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the accounting sslvpn radius-scheme radius-scheme-name local none command specifies a primary RADIUS accounting method and two backup methods (local accounting and no accounting). The device performs RADIUS accounting by default and performs local accounting when RADIUS accounting is invalid. The device does not perform accounting when both of the previous methods are invalid.
¡ The user account is not configured on the device or the user is not allowed to use the SSL VPN service.
# In ISP domain test, perform local accounting for SSL VPN users.
[Sysname] domain test
[Sysname-isp-test] accounting sslvpn local
# In ISP domain test, perform RADIUS accounting for SSL VPN users based on scheme rd and use local accounting as the backup.
[Sysname-isp-test] accounting sslvpn radius-scheme rd local
accounting default
local-user
radius scheme
accounting start-fail
Use accounting start-fail to configure access control for users that encounter accounting-start failures.
Use undo accounting start-fail to restore the default.
accounting start-fail { offline | online }
The device allows users that encounter accounting-start failures to stay online.
ISP domain view
offline: Logs off users that encounter accounting-start failures.
online: Allows users that encounter accounting-start failures to stay online.
# In ISP domain test, configure the device to allow users that encounter accounting-start failures to stay online.
[Sysname-isp-test] accounting start-fail online
accounting update-fail
Use accounting update-fail to configure access control for users that have failed all their accounting-update attempts.
Use undo accounting update-fail to restore the default.
accounting update-fail { [ max-times max-times ] offline | online }
The device allows users that have failed all their accounting-update attempts to stay online.
ISP domain view
max-times max-times: Specifies the maximum number of consecutive accounting-update failures allowed by the device for each user. The value range for the times argument is 1 to 255, and the default value is 1. The setting for this parameter takes effect only on IPoE and portal users. Its value is fixed at 1 for other users, regardless of the setting for this parameter.
offline: Logs off users that have failed all their accounting-update attempts.
online: Allows users that have failed all their accounting-update attempts to stay online.
For an IPoE, PPP, or portal user, the device takes the action specified by using this command when the maximum number of consecutive accounting-update failures is reached.
For any other types of users, the device takes the action specified by using this command immediately after an accounting-update fails.
The device determines the failure of an accounting-update attempt based on the following factors:
· Maximum number of transmission attempts for a RADIUS packet (set by using the retry command).
· Real-time accounting interval (set by using the timer realtime-accounting command).
· Maximum number of real-time accounting request attempts (set by using the retry realtime-accounting command).
The following information describes the process that the device uses to determine the failure of an accounting-update failure:
1. The device sends accounting request packets at real-time accounting intervals set by using the timer realtime-accounting command.
2. If the device has not received a response to a request packet when the response timeout timer expires, the device resends the request packet.
3. When the number of consecutive transmission attempts for the request reaches the limit set by using the retry command, the device determines that the real-time accounting request fails.
4. When the number of consecutive real-time accounting request failures reaches the limit set by using the retry realtime-accounting command, the device determines that an accounting-update fails.
5. The system determines the action to take upon an accounting-update failure depending on the user type:
¡ If the user is not an IPoE, PPP, or portal user, the system immediately takes the action specified by using the accounting update-fail command.
¡ If the user is an IPoE, PPP, or portal user, the system will count the failure. If the number of consecutive accounting-update failures reaches the limit set by using the accounting update-fail command, it takes the action specified by using the same command.
# In ISP domain test, configure the device to allow users that have failed all their accounting-update attempts to stay online.
[Sysname-isp-test] accounting update-fail online
retry
authentication default
Use authentication default to specify default authentication methods for an ISP domain.
Use undo authentication default to restore the default.
authentication default { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] [ none ] | ldap-scheme ldap-scheme-name [ local ] [ none ] | local [ hwtacacs-scheme hwtacacs-scheme-name | radius-scheme radius-scheme-name ] * [ none ] | local [ ldap-scheme ldap-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] [ none ] }
The default authentication method of an ISP domain is local.
ISP domain view
ldap-scheme ldap-scheme-name: Specifies an LDAP scheme by its name, a case-insensitive string of 1 to 32 characters.
local: Performs local authentication.
none: Does not perform authentication.
The default authentication method is used for all users that support this method and do not have an authentication method configured.
You can specify one primary default authentication method and multiple backup default authentication methods.
When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the authentication default radius-scheme radius-scheme-name local none command specifies a primary default RADIUS authentication method and two backup methods (local authentication and no authentication). The device performs RADIUS authentication by default and performs local authentication when RADIUS authentication is invalid. The device does not perform authentication when both of the previous methods are invalid.
The remote authentication method is invalid in the following situations:
· The specified authentication scheme does not exist.
· Authentication packet sending fails.
· The device does not receive any authentication response packets from an authentication server.
The local authentication method is invalid if the device fails to find the matching local user configuration.
When the primary authentication method is local, the following rules apply to the authentication of a user:
· The device uses the backup authentication methods in sequence only if local authentication is invalid for one of the following reasons:
¡ An exception occurs in the local authentication process.
· The device does not turn to the backup authentication methods if local authentication is invalid because of any other reason. Authentication fails for the user.
# In ISP domain test, use RADIUS scheme rd as the primary default authentication method and use local authentication as the backup.
[Sysname-isp-test] authentication default radius-scheme rd local
hwtacacs scheme
ldap scheme
local-user
radius scheme
authentication ike
Use authentication ike to specify extended authentication methods for IKE users.
Use undo authentication ike to restore the default.
authentication ike { local [ radius-scheme radius-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ local ] [ none ] }
The default authentication methods of the ISP domain are used for IKE extended authentication.
ISP domain view
You can specify one primary authentication method and multiple backup authentication methods.
When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the authentication ike radius-scheme radius-scheme-name local none command specifies a primary RADIUS authentication method and two backup methods (local authentication and no authentication). The device performs RADIUS authentication by default and performs local authentication when RADIUS authentication is invalid. The device does not perform authentication when both of the previous methods are invalid.
¡ The user account is not configured on the device or the user is not allowed to use the IKE service.
# In ISP domain test, configure the device to perform local authentication through IKE extended authentication.
[Sysname-isp-test] authentication ike local
# In ISP domain test, perform IKE extended authentication based on RADIUS scheme rd and use local authentication as the backup.
[Sysname-isp-test] authentication ike radius-scheme rd local
local-user
radius scheme
authentication ipoe
Use authentication ipoe to specify authentication methods for IPoE users.
Use undo authentication ipoe to restore the default.
authentication ipoe { local [ radius-scheme radius-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ local ] [ none ] }
The default authentication methods of the ISP domain are used for IPoE users.
ISP domain view
When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the authentication ipoe radius-scheme radius-scheme-name local none command specifies a primary RADIUS authentication method and two backup methods (local authentication and no authentication). The device performs RADIUS authentication by default and performs local authentication when RADIUS authentication is invalid. The device does not perform authentication when both of the previous methods are invalid.
# In ISP domain test, perform local authentication for IPoE users.
[Sysname-isp-test] authentication ipoe local
# In ISP domain test, perform RADIUS authentication for IPoE users based on scheme rd and use local authentication as the backup.
[Sysname-isp-test] authentication ipoe radius-scheme rd local
local-user
radius scheme
authentication login
Use authentication login to specify authentication methods for login users.
Use undo authentication login to restore the default.
authentication login { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] [ none ] | ldap-scheme ldap-scheme-name [ local ] [ none ] | local [ hwtacacs-scheme hwtacacs-scheme-name | radius-scheme radius-scheme-name ] * [ none ] | local [ ldap-scheme ldap-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] [ none ] }
The default authentication methods of the ISP domain are used for login users.
ISP domain view
When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the authentication login radius-scheme radius-scheme-name local none command specifies the default primary RADIUS authentication method and two backup methods (local authentication and no authentication). The device performs RADIUS authentication by default and performs local authentication when RADIUS authentication is invalid. The device does not perform authentication when both of the previous methods are invalid.
¡ The user account is not configured on the device or the user is not allowed to use the service for accessing the device.
# In ISP domain test, perform local authentication for login users.
[Sysname-isp-test] authentication login local
# In ISP domain test, perform RADIUS authentication for login users based on scheme rd and use local authentication as the backup.
[Sysname-isp-test] authentication login radius-scheme rd local
hwtacacs scheme
ldap scheme
local-user
radius scheme
authentication portal
Use authentication portal to specify authentication methods for portal users.
Use undo authentication portal to restore the default.
authentication portal { ldap-scheme ldap-scheme-name [ local ] [ none ] | local [ ldap-scheme ldap-scheme-name | radius-scheme radius-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ local ] [ none ] }
The default authentication methods of the ISP domain are used for portal users.
ISP domain view
When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the authentication portal radius-scheme radius-scheme-name local none command specifies the default primary RADIUS authentication method and two backup methods (local authentication and no authentication). The device performs RADIUS authentication by default and performs local authentication when RADIUS authentication is invalid. The device does not perform authentication when both of the previous methods are invalid.
# In ISP domain test, perform local authentication for portal users.
[Sysname-isp-test] authentication portal local
# In ISP domain test, perform RADIUS authentication for portal users based on scheme rd and use local authentication as the backup.
[Sysname-isp-test] authentication portal radius-scheme rd local
ldap scheme
local-user
radius scheme
authentication sslvpn
Use authentication sslvpn to specify authentication methods for SSL VPN users.
Use undo authentication sslvpn to restore the default.
In non-FIPS mode:
authentication sslvpn { ldap-scheme ldap-scheme-name [ local ] [ none ] | local [ ldap-scheme ldap-scheme-name | radius-scheme radius-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ local ] [ none ] }
In FIPS mode:
authentication sslvpn { ldap-schemle ldap-scheme-name [ local ] | local [ ldap-scheme ldap-scheme-name | radius-scheme radius-scheme-name ] | radius-scheme radius-scheme-name [ local ] }
The default authentication methods of the ISP domain are used for SSL VPN users.
ISP domain view
When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the authentication sslvpn radius-scheme radius-scheme-name local none command specifies a primary RADIUS authentication method and two backup methods (local authentication and no authentication). The device performs RADIUS authentication by default and performs local authentication when RADIUS authentication is invalid. The device does not perform authentication when both of the previous methods are invalid.
If you specify multiple authentication methods for SSL VPN users in an ISP domain, the device does not support the online user password change feature for the SSL VPN users.
# In ISP domain test, perform local authentication for SSL VPN users.
[Sysname-isp-test] authentication sslvpn local
# In ISP domain test, perform LDAP authentication for SSL VPN users based on scheme ldp and use local authentication as the backup.
[Sysname-isp-test] authentication sslvpn ldap-scheme ldp local
ldap scheme
local-user
radius scheme
authentication super
Use authentication super to specify a method for user role authentication.
Use undo authentication super to restore the default.
authentication super { hwtacacs-scheme hwtacacs-scheme-name | radius-scheme radius-scheme-name } *
The default authentication methods of the ISP domain are used for user role authentication.
ISP domain view
To enable a user to obtain another user role without reconnecting to the device, you must configure user role authentication. The device supports local and remote methods for user role authentication. For more information about user role authentication, see RBAC configuration in Fundamentals Configuration Guide.
You can specify one authentication method and one backup authentication method to use in case that the previous authentication method is invalid.
# In ISP domain test, perform user role authentication based on HWTACACS scheme tac.
[Sysname] super authentication-mode scheme
[Sysname-isp-test] authentication super hwtacacs-scheme tac
hwtacacs scheme
radius scheme
authorization command
Use authorization command to specify command authorization methods.
Use undo authorization command to restore the default.
authorization command { hwtacacs-scheme hwtacacs-scheme-name [ local ] [ none ] | local [ none ] | none }
The default authorization methods of the ISP domain are used for command authorization.
ISP domain view
local: Performs local authorization.
none: Does not perform authorization. The authorization server does not verify whether the entered commands are permitted by the user role. The commands are executed successfully if the user role has permission to the commands.
Command authorization restricts login users to execute only authorized commands by employing an authorization server to verify whether each entered command is permitted.
When local command authorization is configured, the device compares each entered command with the user's configuration on the device. The command is executed only when it is permitted by the user's authorized user roles.
The commands that can be executed are controlled by both the access permission of user roles and command authorization of the authorization server. Access permission only controls whether the authorized user roles have access to the entered commands, but it does not control whether the user roles have obtained authorization to these commands. If a command is permitted by the access permission but denied by command authorization, this command cannot be executed.
You can specify one primary command authorization method and multiple backup command authorization methods.
When the default authorization method is invalid, the device attempts to use the backup authorization methods in sequence. For example, the authorization command hwtacacs-scheme hwtacacs-scheme-name local none command specifies the default HWTACACS authorization method and two backup methods (local authorization and no authorization). The device performs HWTACACS authorization by default and performs local authorization when the HWTACACS server is invalid. The device does not perform command authorization when both of the previous methods are invalid.
The remote authorization method is invalid in the following situations:
· The specified authorization scheme does not exist.
· Authorization packet sending fails.
· The device does not receive any authorization response packets from an authorization server.
The local authorization method is invalid if the device fails to find the matching local user configuration.
# In ISP domain test, configure the device to perform local command authorization.
[Sysname-isp-test] authorization command local
# In ISP domain test, perform command authorization based on HWTACACS scheme hwtac and use local authorization as the backup.
[Sysname-isp-test] authorization command hwtacacs-scheme hwtac local
command authorization (Fundamentals Command Reference)
hwtacacs scheme
local-user
authorization default
Use authorization default to specify default authorization methods for an ISP domain.
Use undo authorization default to restore the default.
authorization default { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] [ none ] | local [ hwtacacs-scheme hwtacacs-scheme-name | radius-scheme radius-scheme-name ] * [ none ] | none | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] [ none ] }
The default authorization method of an ISP domain is local.
ISP domain view
none: Does not perform authorization. The following default authorization information applies after users pass authentication:
· Login users obtain the level-0 user role. Login users include the Telnet, FTP, SFTP, SCP, and terminal users. Terminal users can access the device through the console port. For more information about the level-0 user role, see RBAC configuration in Fundamentals Configuration Guide.
· The working directory for FTP, SFTP, and SCP login users is the root directory of the NAS. However, the users do not have permission to access the root directory.
· Non-login users can access the network.
The default authorization method is used for all users that support this method and do not have an authorization method configured.
The RADIUS authorization configuration takes effect only when the authentication method and authorization method of the ISP domain use the same RADIUS scheme.
You can specify one primary authorization method and multiple backup authorization methods.
When the default authorization method is invalid, the device attempts to use the backup authorization methods in sequence. For example, the authorization default radius-scheme radius-scheme-name local none command specifies the default RADIUS authorization method and two backup methods (local authorization and no authorization). The device performs RADIUS authorization by default and performs local authorization when RADIUS authorization is invalid. The device does not perform authorization when both of the previous methods are invalid.
When the primary authorization method is local, the following rules apply to the authorization of a user:
· The device uses the backup authorization methods in sequence only if local authorization is invalid for one of the following reasons:
¡ An exception occurs in the local authorization process.
· The device does not turn to the backup authorization methods if local authorization is invalid because of any other reason. Authorization fails for the user.
# In ISP domain test, use RADIUS scheme rd as the primary default authorization method and use local authorization as the backup.
[Sysname-isp-test] authorization default radius-scheme rd local
hwtacacs scheme
local-user
radius scheme
authorization ike
Use authorization ike to specify authorization methods for IKE extended authentication.
Use undo authorization ike to restore the default.
authorization ike { local [ none ] | none }
The default authorization methods of the ISP domain are used for IKE extended authentication.
ISP domain view
You can specify one primary authorization method and one backup authorization method.
When the primary method is invalid, the device attempts to use the backup method.
# In ISP domain test, perform local authorization for IKE extended authentication.
[Sysname-isp-test] authorization ike local
local-user
authorization ipoe
Use authorization ipoe to specify authorization methods for IPoE users.
Use undo authorization ipoe to restore the default.
authorization ipoe { local [ radius-scheme radius-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ local ] [ none ] }
The default authorization methods of the ISP domain are used for IPoE users.
ISP domain view
The RADIUS authorization configuration takes effect only when authentication and authorization methods of the ISP domain use the same RADIUS scheme.
When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the authorization ipoe radius-scheme radius-scheme-name local none command specifies a primary RADIUS authorization method and two backup methods (local authorization and no authorization). The device performs RADIUS authorization by default and performs local authorization when RADIUS authorization is invalid. The device does not perform authorization when both of the previous methods are invalid.
# In ISP domain test, perform local authorization for IPoE users.
[Sysname-isp-test] authorization ipoe local
# In ISP domain test, perform RADIUS authorization for IPoE users based on scheme rd and use local authorization as the backup.
[Sysname-isp-test] authorization ipoe radius-scheme rd local
local-user
radius scheme
authorization login
Use authorization login to specify authorization methods for login users.
Use undo authorization login to restore the default.
authorization login { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] [ none ] | local [ hwtacacs-scheme hwtacacs-scheme-name | radius-scheme radius-scheme-name ] * [ none ] | none | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] [ none ] }
The default authorization methods of the ISP domain are used for login users.
ISP domain view
When the default authorization method is invalid, the device attempts to use the backup authorization methods in sequence. For example, the authorization login radius-scheme radius-scheme-name local none command specifies the default RADIUS authorization method and two backup methods (local authorization and no authorization). The device performs RADIUS authorization by default and performs local authorization when RADIUS authorization is invalid. The device does not perform authorization when both of the previous methods are invalid.
# In ISP domain test, perform local authorization for login users.
[Sysname-isp-test] authorization login local
# In ISP domain test, perform RADIUS authorization for login users based on scheme rd and use local authorization as the backup.
[Sysname-isp-test] authorization login radius-scheme rd local
hwtacacs scheme
local-user
radius scheme
authorization portal
Use authorization portal to specify authorization methods for portal users.
Use undo authorization portal to restore the default.
authorization portal { local [ radius-scheme radius-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ local ] [ none ] }
The default authorization methods of the ISP domain are used for portal users.
ISP domain view
none: Does not perform authorization. An authenticated portal user directly accesses the network.
When the default authorization method is invalid, the device attempts to use the backup authorization methods in sequence. For example, the authorization portal radius-scheme radius-scheme-name local none command specifies the default RADIUS authorization method and two backup methods (local authorization and no authorization). The device performs RADIUS authorization by default and performs local authorization when RADIUS authorization is invalid. The device does not perform authorization when both of the previous methods are invalid.
# In ISP domain test, perform local authorization for portal users.
[Sysname-isp-test] authorization portal local
# In ISP domain test, perform RADIUS authorization for portal users based on scheme rd and use local authorization as the backup.
[Sysname-isp-test] authorization portal radius-scheme rd local
local-user
radius scheme
authorization sslvpn
Use authorization sslvpn to specify authorization methods for SSL VPN users.
Use undo authorization sslvpn to restore the default.
In non-FIPS mode:
authorization sslvpn { ldap-scheme ldap-scheme-name [ local ] [ none ] | local [ ldap-scheme ldap-scheme-name | radius-scheme radius-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ local ] [ none ] }
In FIPS mode:
authorization sslvpn { ldap-scheme ldap-scheme-name [ local ] | local [ ldap-scheme ldap-scheme-name | radius-scheme radius-scheme-name ] | radius-scheme radius-scheme-name [ local ] }
The default authorization methods of the ISP domain are used for SSL VPN users.
ISP domain view
none: Does not perform authorization. Authenticated SSL VPN users can access the network directly.
When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the authorization sslvpn radius-scheme radius-scheme-name local none command specifies a primary RADIUS authorization method and two backup methods (local authorization and no authorization). The device performs RADIUS authorization by default and performs local authorization when RADIUS authorization is invalid. The device does not perform authorization when both of the previous methods are invalid.
# In ISP domain test, perform local authorization for SSL VPN users.
[Sysname-isp-test] authorization sslvpn local
# In ISP domain test, perform LDAP authorization for SSL VPN users based on scheme ldp and use local authorization as the backup.
[Sysname-isp-test] authorization sslvpn ldap-scheme ldp local
ldap scheme
local-user
radius scheme
Use authorization-attribute to configure authorization attributes for users in an ISP domain.
Use undo authorization-attribute to restore the default of an authorization attribute.
authorization-attribute { acl acl-number | car inbound cir committed-information-rate [ pir peak-information-rate ] outbound cir committed-information-rate [ pir peak-information-rate ] | idle-cut minutes [ flow ] [ traffic { both | inbound | outbound } ] | igmp max-access-number max-access-number | ip-pool ipv4-pool-name | ipv6-pool ipv6-pool-name | ipv6-prefix ipv6-prefix prefix-length | mld max-access-number max-access-number | { primary-dns | secondary-dns } { ip ipv4-address | ipv6 ipv6-address } | session-group-profile session-group-profile-name | session-timeout timeout | url url-string | user-group user-group-name | user-priority { inbound | outbound } priority | user-profile profile-name }
undo authorization-attribute { acl | car | idle-cut | igmp | ip-pool | ipv6-pool | ipv6-prefix | mld | { primary-dns | secondary-dns } { ip | ipv6 }| session-group-profile | session-timeout | url | user-group | user-priority { inbound | outbound } | user-profile }
The idle cut feature is disabled.
An IPv4 user can concurrently join a maximum of four IGMP multicast groups.
An IPv6 user can concurrently join a maximum of four MLD multicast groups.
No other authorization attributes exist.
ISP domain view
acl acl-number: Specifies an ACL to filter traffic for users. The value range for the acl-number argument is 2000 to 4999. This option is applicable only to portal users. The device processes the traffic that matches the rules in the authorization ACL based on the permit or deny statement in the rules.
car: Specifies a CAR action for users. Typically, the attribute applies to authenticated users. If you configure the attribute in a portal preauthentication domain, the CAR action applies before portal authentication. This keyword is applicable only to IPoE and portal users.
inbound: Specifies the upload rate of users.
outbound: Specifies the download rate of users.
cir committed-information-rate: Specifies the committed information rate in kbps. The value range for this argument is 8 to 10000000.
pir peak-information-rate: Specifies the peak information rate in kbps. The peak information rate cannot be smaller than the committed information rate. If you do not specify this option, the CAR action does not restrict users by peak information rate. The value range for this argument varies is 8 to 10000000.
idle-cut minutes: Specifies an idle timeout period in minutes. The value range for the minutes argument is 1 to 129600. This option is applicable only to IPoE users.
flow: Specifies the minimum traffic that must be generated in the idle timeout period in bytes. The value range is 1 to 10240000, and the default value is 10240.
traffic: Specifies the traffic direction for the idle cut feature. If you do not specify this keyword, the idle cut feature applies to both traffic directions.
both: Specifies both traffic directions.
inbound: Specifies the inbound direction.
outbound: Specifies the outbound direction.
igmp max-access-number max-access-number: Specifies the maximum number of IGMP groups that an IPv4 user can join concurrently. The value range for the max-access-number argument is 1 to 64. This option is applicable only to IPoE and portal users.
ip-pool ipv4-pool-name: Specifies an IPv4 pool for users. The ipv4-pool-name argument is a case-insensitive string of 1 to 63 characters. This option is applicable only to IKE, IPoE, and portal users.
ipv6-pool ipv6-pool-name: Specifies an IPv6 pool for users. The ipv6-pool-name argument is a case-insensitive string of 1 to 63 characters. This option is applicable only to IPoE and portal users.
ipv6-prefix ipv6-prefix prefix-length: Specifies an IPv6 address prefix for users. The value range for the prefix-length argument is 1 to 128. This option is applicable only to IPoE users.
mld max-access-number max-access-number: Specifies the maximum number of MLD groups that an IPv6 user can join concurrently. The value range for the max-access-number argument is 1 to 64. This option is applicable only to IPoE and portal users.
primary-dns ip ipv4-address: Specifies the IPv4 address of the primary DNS server for users. This option is applicable only to IPoE users.
primary-dns ipv6 ipv6-address: Specifies the IPv6 address of the primary DNS server for users. This option is applicable only to IPoE users.
secondary-dns ip ipv4-address: Specifies the IPv4 address of the secondary DNS server for users. This option is applicable only to IPoE users.
secondary-dns ipv6 ipv6-address: Specifies the IPv6 address of the secondary DNS server for users. This option is applicable only to IPoE users.
session-group-profile session-group-profile-name: Specifies an authorization session group profile for users. The session-group-profile-name argument is a case-sensitive string of 1 to 31 characters and can contain only letters, digits, underscores (_), minus signs (-), and dots (.). The string can begin with a letter or a digit, but it cannot be all digits. Typically, the attribute applies to authenticated users. If you configure the attribute in a portal preauthentication domain, the session group profile applies before portal authentication. This option is applicable only to IPoE and portal users.
session-timeout timeout: Sets the session timeout timer for users, in seconds. The value range for the timeout argument is 1 to 4294967294. The device logs out a user when the session timeout timer expires for that user. If the RADIUS server assigns that user the Session-Timeout attribute, the value in the assigned attribute takes precedence over the session timeout timer set on the device. The session timeout timer attribute is applicable only to IPoE and portal users.
url url-string: Specifies a redirect URL for users. The url-string argument is a case-sensitive string of 1 to 255 characters. The URL must start with http:// or https://. You can configure the redirect URL attribute to push advertisements or notifications to users after the users pass authentication or push bill overdue notifications to users. This option is applicable only to IPoE and LAN users. For IPoE users, you must specify a URL with port number 80 or 443.
user-group user-group-name: Specifies a user group for users. The user-group-name argument is a case-insensitive string of 1 to 32 characters. Authenticated users obtain all attributes of the user group.
user-priority: Specifies a user priority for users. The device uses the specified user priority to perform QoS priority mapping on user packets, and then assigns the user packets to a queue based on the target priority. Packets in a high-priority queue are preferentially scheduled when congestion occurs. In addition to priority mapping, the device replaces the value of the IP Precedence field in upstream packets of users with the specified user priority. You can set the upstream user priority in conjunction with the downstream user priority. By default, no user priority is assigned to users. The user priority attribute is applicable to portal and IPoE users.
inbound: Applies the user priority to upstream packets of users.
outbound: Applies the user priority to downstream packets of users.
priority: Specifies a user priority in the range of 0 to 7. The greater the value, the higher the priority.
user-profile profile-name: Specifies an authorization user profile by its name. The profile-name argument is a case-sensitive string of 1 to 31 characters. Valid characters include letters, digits, underscores (_), minus signs (-), and dots (.). The string can begin with a letter or digit, but it cannot be all digits. Typically, the attribute applies to authenticated users. If you configure the attribute in a portal preauthentication domain, the user profile applies before portal authentication. This option is applicable only to portal and IPoE users.
When the idle cut feature is configured, the device periodically detects the traffic of each online user. The device logs out users that do not meet the minimum traffic requirement in the idle timeout period. When the idle cut feature is disabled on the device, the idle cut feature of the server takes effect. The server considers a user idle if the user's traffic is less than 10240 bytes in a configurable idle timeout period.
If authorization attributes are configured in an IPoE preauthentication domain, the device assigns the attributes to the users after the users pass preauthentication and obtain IP addresses. The attributes restrict access behaviors of the users before the users pass Web authentication.
If the server or NAS does not authorize any attributes to an authenticated user, the device authorizes the attributes in the ISP domain to the user. However, if the server authorizes the CAR action attribute only for one direction, the device does not authorize the CAR action attribute of the ISP domain for the other direction.
You can configure multiple authorization attributes for users in an ISP domain. If you execute the command multiple times with the same attribute specified, the most recent configuration takes effect.
When you specify an authorization ACL, the following restrictions apply:
· The authorization ACL is invalid if it does not exist or does not contain rules. If strict checking on authorization ACLs is enabled for portal users in this situation, portal users will be forced offline.
· For portal users to come online after passing authentication, make sure ACLs assigned to portal users do not have rules specified with a source IP or MAC address.
# Specify user group abc as the authorization user group for users in ISP domain test.
[Sysname-isp-test] authorization-attribute user-group abc
display domain
Use display aaa abnormal-offline-record to display user abnormal offline records.
display aaa abnormal-offline-record { access-type { ipoe | login | portal } | domain domain-name | interface interface-type interface-number | { ip ipv4-address | ipv6 ipv6-address } | mac-address mac-address | username user-name [ fuzzy-match ] } * [ brief | count count ]
display aaa abnormal-offline-record offline-reason { idle-cut | quota-out | realtime-acct-fail | session-timeout | user-detect-fail } [ brief ]
display aaa abnormal-offline-record time begin-time end-time [ date begin-date end-date ] [ brief ]
access-type: Specifies users by the access type.
ipoe: Specifies IPoE users.
login: Specifies login users, such as SSH users, Telnet users, and FTP users.
portal: Specifies portal users.
domain domain-name: Specifies an ISP domain by its name, a case-insensitive string of 1 to 255 characters.
interface interface-type interface-number: Specifies an interface by its interface type and interface number.
ip ipv4-address: Specifies a user by its IPv4 address.
ipv6 ipv6-address: Specifies a user by its IPv6 address.
mac-address mac-address: Specifies a user by its MAC address in the format of H-H-H.
username user-name: Specifies users using the specified username, a case-sensitive string of 1 to 253 characters.
fuzzy-match: Matches the username in fuzzy mode. In fuzzy mode, a user matches if the user's username includes the specified username. If you do not specify this keyword, the device matches the username in exact mode. In exact mode, a user matches if the user's username is the same as the specified username.
offline-reason: Specifies a user offline reason.
idle-cut: Specifies the reason as session idle timeout.
quota-out: Specifies the reason as data quota out.
realtime-acct-fail: Specifies the reason as realtime accounting failure.
session-timeout: Specifies the reason as session timeout.
user-detect-fail: Specifies the reason as user online detection failure.
time: Specifies user abnormal offline records generated in a time range.
begin-time: Specifies the start time in the format of hh:mm:ss. The value range for the hh argument is 0 to 23. The value range for the mm and ss arguments is 0 to 59.
end-time: Specifies the end time in the format of hh:mm:ss. The value range for the hh argument is 0 to 23. The value range for the mm and ss arguments is 0 to 59.
date: Specifies a date range. If you do not specify a date range, this command displays user abnormal offline records on the current day.
begin-date: Specifies the start date in the format of MM/DD/YYYY or YYYY/MM/DD. The value range for the MM argument is 1 to 12. The value range for the DD argument varies with the specified month. The value range for the YYYY argument is 2000 to 2035.
end-date: Specifies the end date in the format of MM/DD/YYYY or YYYY/MM/DD. The value range for the MM argument is 1 to 12. The value range for the DD argument varies with the specified month. The value range for the YYYY argument is 2000 to 2035.
brief: Displays brief information about user abnormal offline records. If you do not specify this keyword, the command displays detailed information about user abnormal offline records.
count count: Specifies the number of user abnormal offline records to be displayed. The value range for the count argument is 1 to 32768.
You can specify multiple query criteria to filter user abnormal offline records. This command displays the most recent user abnormal offline records that match the specified criteria in reverse chronological order.
If user abnormal offline records exist in the system, you can use this command to display the records regardless of whether user abnormal offline recording is enabled or not.
If you do not specify any parameters, this command displays detailed information about user abnormal offline records for all users.
The usernames that the server sends to the device might include invisible characters. For the device to display the records for users with such usernames, you must specify the fuzzy-match keyword in this command.
# Display detailed information about abnormal offline records for all users.
<Sysname> display aaa abnormal-offline-record
Total count: 1
Username: jay
Domain: dm1
MAC address: -
Access type: SSH
SVLAN/CVLAN: -/-
IP address: 19.19.0.2
IPv6 address: -
Online request time: 2020/01/02 15:20:33
Offline time: 2020/02/28 15:20:56
Offline reason: User disconnected from the server.
# Display brief information about abnormal offline records for login users.
<Sysname> display aaa abnormal-offline-record access-type login brief
Username: jay
MAC address: -
IP address: 11.2.2.41
IPv6 address: -
Total count |
Total number of matching user abnormal offline records. |
Username |
Name of the user. This field does not display anything if the system failed to obtain the username. |
Domain |
Name of the ISP domain to which the user belongs. This field does not display anything if the system failed to obtain the ISP domain. |
MAC address |
MAC address of the user. This filed displays a hyphen (-) if the system failed to obtain the MAC address. |
Access type |
Access type of the user: · Telnet. · FTP. · SSH. · Portal. · IPoE. · Web—Web login. · Terminal—Terminal login such as console login. |
Access interface |
Interface through which the user accesses the network. This field displays a hyphen (-) if the system failed to obtain the access interface. |
SVLAN/CVLAN |
This field is not supported in the current software version. SVLAN and CVLAN to which the user belongs. This field displays a hyphen (-) for the SVLAN or CVLAN in the following situations: · The user does not belong to an SVLAN. · The system failed to obtain the SVLAN or CVLAN of the user. |
IP address |
IPv4 address of the user. This field displays a hyphen (-) if the system failed to obtain the IPv4 address. |
IPv6 address |
IPv6 address of the user. This field displays a hyphen (-) if the system failed to obtain the IPv6 address. |
Online request time |
Time when the user requested to come online. |
Offline time |
Time when the user went offline. |
Offline reason |
Reason that the user went offline. For more information about the reasons, see Table 2. |
Table 2 shows the reasons that users fail to come online and that users go offline. Support for the reasons depends on device type.
Table 2 User online failure reasons and user offline reasons
Reason |
Lost carrier. |
The physical link went down. |
Lost service. |
The service that the user requested is not supported. |
NAS error. |
An error occurred on the device. |
NAS reboot. |
The device rebooted. |
Admin reboot. |
The administrator rebooted the device. |
Process exit. |
The access process exited. |
NAS request. |
The device requested to log out the user. |
Cut command. |
The administrator manually logged out the user at the CLI. |
Logged off by the RADIUS server. |
The RADIUS server logged out the user. |
User request. |
The user requested to go offline. |
Authentication failed |
Authentication failed. |
Authorization failed. |
Start accounting failed. |
The device failed to start accounting for the user. |
No AAA response during authentication. |
The device did not receive a response from the remote authentication server within the authentication timeout time. |
RADIUS authentication rejected. |
The user failed RADIUS authentication because the username or password was inconsistent with that on the RADIUS server. |
AAA authorization information invalid. |
The authorization information was invalid or the device did not have configuration of the authorized items. |
No AAA response for accounting start. |
The device did not receive a response for the start-accounting request sent to the remote server within the start-accounting timeout time. |
Authentication request to AAA failed. |
The device failed to send the authentication request to the RADIUS server because the route between the device and the RADIUS server is unreachable. |
Accounting request to AAA failed. |
The device failed to send the accounting request to the RADIUS server because the route between the device and the RADIUS server is unreachable. |
TACACS authentication rejected. |
The user failed HWTACACS authentication because the username or password was inconsistent with that on the HWTACACS server. |
Authentication method error. |
The authentication method of the user was inconsistent with the authentication method configured on the access interface. |
No AAA response for accounting stop. |
The device did not receive a response for the stop-accounting request sent to the server. |
The local user doesn't exist. |
The local user does not exist on the device. |
Local authentication request was rejected. |
The user failed local authentication because of incorrect password. |
IP assignment failed. |
IP address assignment for the user failed. |
Concurrent user login limit reached. |
Maximum number of concurrent local users that use the username already reached. |
NAS interface access limit reached. |
Maximum number of online users on the interface already reached. |
Maximum number of concurrent users that use this account already reached. |
Maximum number of concurrent users that use the username already reached. |
PPP negotiation terminated. |
PPP negotiation for the user failed. |
Insufficient hardware resources. |
Hardware resources were insufficient. |
Failed to obtain IPv6 prefix. |
No IPv6 prefix was available to be assigned to the user. |
No response from DHCP server. |
The device did not receive a response for the request sent to the DHCP server to apply an IP address for the user. |
DHCP IP address allocation failure. |
DHCPv6 address assignment for the user failed. Possible reasons include: · No authorization IPv6 pool is configured in the ISP domain. · The IPv6 pool is being locked. |
DHCP session conflict. |
The DHCP session to be created conflicted with an existing DHCP session. |
DHCP user request. |
The DHCP user requested to go offline. |
DHCP lease timeout. |
The allocated IP address lease of the DHCP user expired. |
DHCP declined. |
The device received a DHCP-decline packet from the DHCP user because the allocated IP address was being used by another DHCP user. |
DHCP configuration changed. |
The DHCP configuration changed. |
NAK from the DHCP server or tenant duration is 0. |
The IP address that the DHCP user requested was not on the network segment specified for IP assignment on the device or the lease duration of the address was not extended. |
IP conflict on DHCP server. |
The device detected an IP address conflict. |
DHCP server notified. |
The DHCP server instructed the device to log out the user. |
DHCP server notified, and the device deleted the user. |
The DHCP server instructed the device to log out the user and the device deleted the user. |
The static session already exists. |
The dynamic IPoE session to be created conflicted with an existing static IPoE session. |
NAT444 failed. |
IPoE failed to collaborate with NAT444. |
The ND RS session is updated. |
The device received a new ND RS session request for the user when the user was online. |
L2TP tunnel terminated by the peer. |
The peer device terminated the L2TP tunnel. It might because the peer device determined that the user had gone offline. |
The peer did not respond to control packets. |
The peer device did not respond to the PPP control packet from the device. |
Failed to set up an L2TP session. |
An L2TP session was failed to be created. |
Repeated LCP negotiation packets. |
The device received a duplicated LCP negotiation packet. It might because the user terminated the connection and then initiated a connection again. |
Failed to assign a user rule. |
The device failed to issue a portal user rule to the user. |
COA failure. |
The device failed to process a CoA message for the user. |
Failed to update authorization information. |
The device failed to update the authorization information for the user. |
Realtime accounting request to AAA failed. |
The real-time accounting request for the user failed. |
Session timeout. |
The session of the user timed out. |
Data quota limit reached. |
The data quotas of the user were used up. |
Session idle cut. |
The device logged out of the user because the user's traffic in the idle timeout period at the specified direction is less than the specified minimum traffic. |
User online detection failure. |
The user failed online detection. |
Port was removed from VLAN. |
The access interface of the user was removed from the VLAN. |
Port error. |
A port error occurred. |
Interface down or deactive. |
The protocol of the interface went down, the link on the interface went down, or the interface was deactivated. |
VSRP status changed. |
Backup device deleted user data that is inconsistent with data on the master device. |
The backup device in the VSRP group deleted user data inconsistent with data on the master device. |
MAC address change. |
The MAC address of the user changed. |
Failed to recover AAA resources. |
The device failed to recover AAA resources for the user. |
Deleted users because of inter-card session conflict. |
The device deleted the user because sessions on different cards conflict. |
User aged out before coming online. |
The online wait timer for the user expired. |
MPU-LPU data synchronization failure. |
Inter-card data smoothing failed. |
Failed to synchronize data with DHCP server. |
The device failed to synchronize data with the DHCP server. |
Failed to synchronize data with portal server. |
The device failed to synchronize data with the portal server. |
Failed to synchronize user information with the server. |
The device failed to synchronize user data with the DHCP server. |
User recovery failure. |
User data recovery failed. |
Failed to obtain physical information. |
The device failed to obtain physical information of the user. |
Authorization ACL for the online user changed. |
The authorization ACL for the user changed. |
Authorization user profile for the online user changed. |
The authorization user profile for the user changed. |
Magic number check failed. |
Reauthentication failed. |
Reauthentication for the user failed. |
No AAA response during realtime accounting. |
The device did not receive a response for the real-time accounting request sent to the server. |
Portal notified. |
Portal instructed the device to log out the user. |
Invalid username or password. |
No VTY line available. |
No available VTY line because the maximum number of users that use VTY lines already reached. |
SSH server received a packet with an incorrect message authentication code. |
The message authentication code in the packet from the SSH client was incorrect. |
User disconnected from the server. |
The SSH or FTP user disconnected from the server. |
No working directory available. |
No working directory is available. |
PTY allocation failed. |
FTP server error. |
The user failed to log in to the FTP server because an error existed on the FTP server. |
Server is disabled. |
The service was disabled. |
Service type not supported. |
The type of the service that the user requested was not supported. |
RBAC denied file management operations in the login command. |
Failed to issue RBAC access permissions to the login user. |
The device failed to issue RBAC access permissions to the login user. |
NETCONF inner error. |
An internal NETCONF error occurred. |
NETCONF session was terminated by another NETCONF session. |
The NETCONF session of the user was terminated by another NETCONF session. |
Failed to allocate public network ports in a CGN network. |
Public network port allocation failed on the CGN network. |
Failed to obtain an IP address of the type specified for basic services of users. |
The user failed to obtain an IP address of the type specified for the basic services of the user. |
UserGroup configuration changed. |
The configuration of the user group changed. |
Service-type mismatch. |
Failed to find the service type configuration of the local user. |
The local user is blocked. |
The local user is in blocked state. |
The local user is in the password control blacklist. |
Binding attributes mismatch. |
The attributes of the local user do not match the binding attributes. |
The ISP domain does not exist. |
The authentication ISP domain does not exist. |
The ISP domain is blocked. |
The ISP domain is in blocked state. |
HWTACACS authorization server is unreachable or the server configuration does not exist. |
reset aaa abnormal-offline-record
display aaa normal-offline-record
Use display aaa normal-offline-record to display user normal offline records.
display aaa normal-offline-record { access-type { ipoe | login | portal } | domain domain-name | interface interface-type interface-number | { ip ipv4-address | ipv6 ipv6-address } | mac-address mac-address | username user-name [ fuzzy-match ] } * [ brief | count count ]
display aaa normal-offline-record time begin-time end-time [ date begin-date end-date ] [ brief ]
time: Specifies user normal offline records generated in a time range.
brief: Displays brief information about user normal offline records. If you do not specify this keyword, the command displays detailed information about user normal offline records.
count count: Specifies the number of user normal offline records to be displayed. The value range for the count argument is 1 to 32768.
You can specify multiple query criteria to filter user normal offline records. This command displays the most recent user normal offline records that match the specified criteria in reverse chronological order.
If user normal offline records exist in the system, you can use this command to display the records regardless of whether user normal offline recording is enabled or not.
If you do not specify any parameters, this command displays detailed information about user normal offline records for all users.
# Display detailed information about normal offline records for all users.
<Sysname> display aaa normal-offline-record
Total count: 1
Username: jay
Domain: dm1
MAC address: -
Access type: Telnet
SVLAN/CVLAN: -/-
IPv6 address: -
Offline reason: User request.
# Display brief information about normal offline records for login users.
<Sysname> display aaa normal-offline-record access-type login brief
Username: jay
MAC address: -
IPv6 address: -
Total count |
Total number of matching user normal offline records. |
Username |
Domain |
MAC address |
Access type |
Access interface |
SVLAN/CVLAN |
IP address |
IPv6 address |
Offline time |
Offline reason |
reset aaa normal-offline-record
display aaa offline-record
Use display aaa offline-record to display user offline records.
display aaa offline-record { access-type { ipoe | login | portal } | domain domain-name | interface interface-type interface-number | { ip ipv4-address | ipv6 ipv6-address } | mac-address mac-address | username user-name [ fuzzy-match ] } * [ brief | count count ]
display aaa offline-record time begin-time end-time [ date begin-date end-date ] [ brief ]
time: Specifies user offline records generated in a time range.
brief: Displays brief information about user offline records. If you do not specify this keyword, the command displays detailed information about user offline records.
count count: Specifies the number of user offline records to be displayed. The value range for the count argument is 1 to 32768.
You can specify multiple query criteria to filter user offline records. This command displays the most recent user offline records that match the specified criteria in reverse chronological order.
If user offline records exist in the system, you can use this command to display the records regardless of whether user offline recording is enabled or not.
If you do not specify any parameters, this command displays detailed information about user offline records for all users.
# Display detailed information about offline records for all users.
<Sysname> display aaa offline-record
Total count: 1
Username: jay
Domain: dm1
MAC address: -
Access type: Telnet
SVLAN/CVLAN: -/-
IPv6 address: -
# Display brief information about offline records for login users
<Sysname> display aaa offline-record access-type login brief
Username: jay
MAC address: -
IP address: 20.20.20.1
IPv6 address: -
Username: test
MAC address: -
IP address: 20.20.20.3
IPv6 address: -
Total count |
Total number of matching user offline records. |
Username |
Domain |
MAC address |
Access type |
Access type of the user: · Telnet. · FTP. · SSH. · Portal. · IPoE. · Web. · Terminal—Terminal login such as console login. |
Access interface |
SVLAN/CVLAN |
IP address |
IPv6 address |
Offline time |
Offline reason |
reset aaa offline-record
display aaa online-fail-record
Use display aaa online-fail-record to display user online failure records.
display aaa online-fail-record { access-type { ipoe | login | portal } | domain domain-name | interface interface-type interface-number | { ip ipv4-address | ipv6 ipv6-address } | mac-address mac-address | username user-name [ fuzzy-match ] } * [ brief | count count ]
display aaa online-fail-record time begin-time end-time [ date begin-date end-date ] [ brief ]
time: Specifies user online failure records generated in a time range.
brief: Displays brief information about user online failure records. If you do not specify this keyword, the command displays detailed information about user online failure records.
count count: Specifies the number of user online failure records to be displayed. The value range for the count argument is 1 to 32768.
You can specify multiple query criteria to filter user online failure records. This command displays the most recent user online failure records that match the specified criteria in reverse chronological order.
If user online failure records exist in the system, you can use this command to display the records regardless of whether user online failure recording is enabled or not.
If you do not specify any parameters, this command displays detailed information about user online failure records for all users.
# Display detailed information about the most recent two online failure records for login users that use the username aaa.
<Sysname> display aaa online-fail-record username aaa access-type login count 2
Username: aaa
Domain: test
MAC address: -
Access type: Telnet
SVLAN/CVLAN: 100/-
IP address: 19.19.0.1
IPv6 address: -
Online request time: 2020/01/02 15:20:37
Online failure reason: Authentication failed.
Server reply message: no user exists.
Username: aaa
Domain: test
MAC address: -
Access type: Telnet
SVLAN/CVLAN: -/-
IPv6 address: -
# Display brief information about user online failure records generated from 2020-02-01 13:20:50 to 2020-02-02 17:20:30.
<Sysname> display aaa online-fail-record time 13:20:50 10:20:30 date 2020/2/1 2020/2/2 brief
Username: aaa
MAC address: -
IPv6 address: -
# Display detailed information about user online failure records generated from 2020-02-01 13:20:50 to 2020-02-02 17:20:30.
<Sysname> display aaa online-fail-record time 13:20:50 17:20:30 date 2020/2/1 2020/2/2
Username: aaa
Domain: test
MAC address: -
Access type: Telnet
SVLAN/CVLAN: -/-
IPv6 address: -
Online request time: 2020/02/02 16:20:33
Username: aaa
Domain: test
MAC address: -
Access type: Telnet
SVLAN/CVLAN: -/-
IPv6 address: -
Online request time: 2020/02/01 15:20:51
Table 5 Command output
Total count |
Total number of matching user online failure records. |
Username |
Domain |
MAC address |
MAC address of the user. This filed displays a hyphen (-) if the system failed to obtain the user's MAC address. |
Access type |
Access interface |
SVLAN/CVLAN |
IP address |
IPv6 address |
Online failure reason |
Reason that the user failed to come online. For more information about the reasons, see Table 2. |
Server reply message |
Message sent from the server. This field is not displayed if the server does not send a message. |
reset aaa online-fail-record
display domain
Use display domain to display ISP domain configuration.
display domain [ isp-name ]
isp-name: Specifies an ISP domain by its name, a case-insensitive string of 1 to 255 characters. If you do not specify an ISP domain, this command displays the configuration of all ISP domains.
# Display the configuration of all ISP domains.
<Sysname> display domain
Total 2 domains
Domain: system
Current state: Active
State configuration: Active
Default authentication scheme: Local
Default authorization scheme: Local
Default accounting scheme: Local
Accounting start failure action: Online
Accounting update failure action: Online
Accounting quota out policy: Offline
Send accounting update:Yes
ITA service policy: ita1
Service type: HSI
Session time: Exclude idle time
DHCPv6-follow-IPv6CP timeout: Not configured
Dual-stack accounting method: Merge
NAS-ID: N/A
Web server URL : Not configured
Web server URL parameters : Not configured
Web server IPv4 address : Not configured
Web server IPv6 address : Not configured
Authorization attributes:
Idle cut: Disabled
IGMP access limit: 4
MLD access limit: 4
Domain: dm
State configuration: Blocked during specific time ranges
Time ranges:
t1
t2
Online-user logoff: Disabled
Login authentication scheme: RADIUS=rad
Login authorization scheme: HWTACACS=hw
Super authentication scheme: RADIUS=rad
Command authorization scheme: HWTACACS=hw
LAN access authentication scheme: RADIUS=r4
Portal authentication scheme: LDAP=ldp
IPoE authentication scheme: RADIUS=rad, Local, None
Default authentication scheme: RADIUS=rad, Local, None
Default accounting scheme: None
Service type: HSI
Session time: Include idle time
NAS-ID: test
Idle cut : Enabled
Idle timeout: 2 minutes
Flow: 10240 bytes
Traffic direction: Both
IP pool: appy
User profile: test
Session group profile: abc
Inbound CAR: CIR 64000 bps PIR 640000 bps
Outbound CAR: CIR 64000 bps PIR 640000 bps
ACL number: 3000
User group: ugg
IPv6 prefix: 1::1/34
IPv6 pool: ipv6pool
Primary DNS server: 6.6.6.6
Secondary DNS server: 3.6.2.3
URL: http://test
MLD access limit: 4
Default domain name: system
Table 6 Command output
Domain |
ISP domain name. |
Current state |
Current state of the ISP domain: · Blocked. · Active. |
State configuration |
State settings of the ISP domain: · Active—The ISP domain is set to the active state. · Blocked during specific time ranges—The ISP domain is set to the blocked state during the listed time ranges. · Blocked—The ISP domain is set to the blocked state. |
Time ranges |
Time ranges during which the ISP domain is in blocked state. |
Online-user logoff |
Status for the feature of logging off online users when the state of the ISP domain changes to blocked: · Enabled. · Disabled. |
Default authentication scheme |
Default authentication methods. |
Default authorization scheme |
Default authorization methods. |
Default accounting scheme |
Default accounting methods. |
Login authentication scheme |
Authentication methods for login users. |
Login authorization scheme |
Authorization methods for login users. |
Login accounting scheme |
Accounting methods for login users. |
Super authentication scheme |
Authentication methods for obtaining another user role without reconnecting to the device. |
Command authorization scheme |
Command line authorization methods. |
Command accounting scheme |
Command line accounting method. |
Portal authentication scheme |
Authentication methods for portal users. |
Portal authorization scheme |
Authorization methods for portal users. |
Portal accounting scheme |
Accounting methods for portal users. |
SSL VPN authentication scheme |
Authentication methods for SSL VPN users. |
SSL VPN authorization scheme |
Authorization methods for SSL VPN users. |
SSL VPN accounting scheme |
Accounting methods for SSL VPN users. |
IKE authentication scheme |
IKE extended authentication methods. |
IKE authorization scheme |
Authorization methods for IKE extended authentication. |
IPoE authentication scheme |
Authentication methods for IPoE users. |
IPoE authorization scheme |
Authorization methods for IPoE users. |
IPoE accounting scheme |
Accounting methods for IPoE users. |
RADIUS |
RADIUS scheme. |
HWTACACS |
HWTACACS scheme. |
LDAP |
LDAP scheme. |
Local |
Local scheme. |
None |
No authentication, no authorization, or no accounting. |
Accounting start failure action |
Access control for users that encounter accounting-start failures: · Online—Allows the users to stay online. · Offline—Logs off the users. |
Accounting update failure max-times |
Maximum number of consecutive accounting-update failures allowed by the device for each user in the domain. |
Accounting update failure action |
Access control for users that have failed all their accounting-update attempts: · Online—Allows the users to stay online. · Offline—Logs off the users. |
Accounting quota out policy |
Access control for users that have used up their accounting quotas: · Online—Allows the users to stay online. · Offline—Logs off the users. · Redirect—Redirects the users to the specified URL. |
Redirect URL |
URL to which users are redirected when the users have used up their data quotas. |
Stop accounting |
Whether to send stop-accounting packets for users that have used up their data quotas. |
User profile |
Name of the user profile assigned to users that have used up their data quotas. |
Send accounting update |
Whether to send accounting-update packets to refresh users' data quotas: · Yes. · No. |
ITA service policy |
ITA policy applied to the ISP domain. |
Service type |
Service type of the ISP domain, including HSI, STB, and VoIP. |
Session time |
Online duration sent to the server for users that went offline due to connection failure or malfunction: · Include idle time—The online duration includes the idle timeout period. · Exclude idle time—The online duration does not include the idle timeout period. |
User address type |
Type of IP addresses for users in the ISP domain. This field is not available if no user address type is specified in the ISP domain. |
User basic service IP type |
Types of IP addresses that PPPoE and L2TP users rely on to use the basic services: · IPv4. · IPv6. · IPv6-PD. |
DHCPv6-follow-IPv6CP timeout |
This field is not supported in the current software version. IPv6 address wait timer (in seconds) that starts after IPv6CP negotiation for PPPoE and L2TP users. This field displays Not Configured if no IPv6 address wait timer is set for PPPoE or L2TP users. |
Dual-stack accounting method |
Accounting method for dual-stack users: · Merge—Merges IPv4 data with IPv6 data for accounting. · Separate—Separates IPv4 data from IPv6 data for accounting. |
NAS-ID |
NAS-ID of the device. This field displays N/A if no NAS-ID is set in the ISP domain. |
Web server URL |
URL of the Web server. |
Web server URL parameters |
Parameters added to the URL of the Web server. |
Web server IPv4 address |
IPv4 address of the Web server. |
Web server IPv6 address |
IPv6 address of the Web server. |
Authorization attributes |
Authorization attributes for users in the ISP domain. |
Idle cut |
Idle cut feature status: · Enabled—The feature is enabled. The device logs off users that do not meet the minimum traffic requirements in an idle timeout period. · Disabled—The feature is disabled. It is the default idle cut state. |
Idle timeout |
Idle timeout period, in minutes. |
Flow |
Minimum traffic that a login user must generate in an idle timeout period, in bytes. |
Traffic direction |
Traffic direction for the idle cut feature: · Both. · Inbound. · Outbound. |
IP pool |
Name of the authorization IPv4 pool. |
User profile |
Name of the authorization user profile. |
Session group profile |
Name of the authorization session group profile. |
Inbound CAR |
Authorization inbound CAR: · CIR—Committed information rate in bps. · PIR—Peak information rate in bps. If no inbound CAR is authorized, this field displays N/A. |
Outbound CAR |
Authorization outbound CAR: · CIR—Committed information rate in bps. · PIR—Peak information rate in bps. If no outbound CAR is authorized, this field displays N/A. |
ACL number |
Authorization ACL for users. |
User group |
Authorization user group for users. |
IPv6 prefix |
Authorization IPv6 address prefix for users. |
IPv6 pool |
Name of the authorization IPv6 pool for users. |
Primary DNS server |
IPv4 address of the authorization primary DNS server for users. |
Secondary DNS server |
IPv4 address of the authorization secondary DNS server for users. |
Primary DNSV6 server |
IPv6 address of the authorization primary DNS server for users. |
Secondary DNSV6 server |
IPv6 address of the authorization secondary DNS server for users. |
URL |
Authorization redirect URL for users. |
IGMP access limit |
Maximum number of IGMP groups that an IPv4 user is authorized to join concurrently. |
MLD access limit |
Maximum number of MLD groups that an IPv6 user is authorized to join concurrently. |
Inbound user priority |
Authorization user priority for users' upstream packets. |
Outbound user priority |
Authorization user priority for users' downstream packets. |
User session timeout |
Authorization session timeout time for users, in seconds. |
display max-user history
Use display max-user history to display history peak statistics of users.
The history peak statistics of users include the following information:
· Peak values of concurrent authenticated users, concurrent online users, concurrent user sessions that have been issued to the driver, and concurrent users in accounting.
· The time when each peak value is reached.
This command might fail to display history peak statistics for an access module if the access module is busy. You can re-execute this command later.
This command displays history peak statistics only for IPoE users. The system does not count IPoE Web users at the preauthentication stage into history peak statistics.
# Display history peak statistics of users.
<Sysname> display max-user history
Slot 0:
Max concurrent online IPoE users: 100 Time: 2020-03-04 12:03:53
Max concurrent IPoE driver sessions: 100 Time: 2020-03-04 12:03:53
Max concurrent IPoE users in accounting: 100 Time: 2020-03-04 12:03:53
Table 7 Command output
Max concurrent authenticated xxx users |
Peak value of concurrent xxx users that have initiated authentication since the system started up, where xxx represents the type of users. This field is not displayed if the maximum number is 0. |
Max concurrent online xxx users |
Peak value of concurrent online xxx users since the system started up, where xxx represents the type of users. This field is not displayed if the maximum number is 0. |
Max concurrent xxx driver sessions |
Peak value of concurrent xxx sessions that have been issued to the driver since the system started up, where xxx represents the type of users. This field is not displayed if the maximum number is 0. |
Max concurrent xxx users in accounting |
Peak value of concurrent xxx users that are in accounting since the system started up, where xxx represents the type of users. This field is not displayed if the maximum number is 0. |
Time |
Time when the peak value is reached. |
display mubm record
Use display mubm record to display user MAC and UUID binding entries.
display mubm record [ mac mac-address ] [ interface interface-type interface-number ] [ access-type { dot1x | mac-auth | wlan } ]
mac mac-address: Specifies a user MAC address in the format of H-H-H. If you do not specify a user MAC address, this command displays MAC and UUID binding entries for all user MAC addresses.
interface interface-type interface-number: Specifies the user's access interface by its type and number. If you do not specify an interface, this command displays MAC and UUID binding entries on all interfaces.
access-type: Specifies the user access type. If you do not specify a user access type, this command displays MAC and UUID binding entries for all user access types.
dot1x: Specifies 802.1X authentication access.
mac-auth: Specifies MAC authentication access.
wlan: Specifies wireless 802.1X and MAC authentication access.
If you do not specify any parameters, this command displays all user MAC and UUID binding entries.
To help administrators identify whether a universally unique identifier (UUID) has been assigned to a user and maintain the MAC and UUID binding entries for users, use this command.
In some scenarios, administrators configure and manage MAC address and UUID binding entries for users on the authentication server, depending on the user access control policies. The binding entries will be assigned to the users after they pass authentication. The device automatically generates the MAC and UUID binding entry of a user when the user comes online and automatically deletes the binding entry when the user goes offline.
When a user's client requests the DHCP server to assign or release an IP address, the DHCP snooping module first searches for the UUID bound to the client MAC address. Then, the device replaces the value of Option 61 (client ID) in the client's DHCP packets with the UUID and forwards the DHCP packets to the DHCP server. The DHCP server will assign or reclaim an IP address based on the UUID in the received DHCP packets. UUID-based IP address assignment flexibly meets the IP address requirements of different scenarios.
# Display UUID information bound to user MAC address 0C-DA-41-1D-1E-EF.
<Sysname> display mubm record mac 0C-DA-41-1D-1E-EF
Mac Address Access Type Interface UUID
0CDA-411D-1EEF Dot1x GE1/0/1 ff ff ff ff
0CDA-411D-1EEF MAC-auth GE1/0/2 41 41 41 41 42 42 42
0CDA-411D-1EEF WLAN N/A 41 41 41 41 42 42 43
Table 8 Command output
Mac Address |
User MAC address. |
Access Type |
User access type: · Dot1x—802.1X authentication. · MAC-auth—MAC authentication. · WLAN—Wireless authentication. |
Interface through which the user accesses the device. If the user accesses the device through a wireless network, this field displays N/A. |
UUID |
UUID bound to the user MAC address. The UUID value and format subject to the actual situation. |
domain
Use domain to create an ISP domain and enter its view, or enter the view of an existing ISP domain.
Use undo domain to delete an ISP domain.
Format 1:
domain name isp-name
undo domain name isp-name
Format 2:
domain isp-name
undo domain isp-name
A system-defined ISP domain exists. The domain name is system.
Format 1:
name isp-name: Specifies the ISP domain name, a case-insensitive string of 1 to 255 characters. The name cannot contain a forward slash (/), backslash (\), vertical bar (|), quotation marks ("), colon (:), asterisk (*), question mark (?), left angle bracket (<), right angle bracket (>), or at sign (@).
Format 2:
isp-name: Specifies the ISP domain name, a case-insensitive string of 1 to 255 characters. The name cannot contain a forward slash (/), backslash (\), vertical bar (|), quotation marks ("), colon (:), asterisk (*), question mark (?), left angle bracket (<), right angle bracket (>), or at sign (@). The name cannot be d, de, def, defa, defau, defaul, default, i, if, if-, if-u, if-un, if-unk, if-unkn, if-unkno, if-unknow, or if-unknown.
All ISP domains are in active state when they are created.
You can modify settings for the system-defined ISP domain system, but you cannot delete this domain.
An ISP domain cannot be deleted when it is the default ISP domain. Before you use the undo domain command, change the domain to a non-default ISP domain by using the undo domain default enable command.
Use short domain names to ensure that user names containing a domain name do not exceed the maximum name length required by different types of users.
# Create an ISP domain named test and enter ISP domain view.
[Sysname] domain name test
display domain
domain if-unknown
state (ISP domain view)
Use domain default enable to specify the default ISP domain. Users without any domain name included in the usernames are considered in the default domain.
Use undo domain default enable to restore the default.
domain default enable isp-name
The default ISP domain is the system-defined ISP domain system.
isp-name: Specifies the ISP domain name, a case-insensitive string of 1 to 255 characters. The ISP domain must already exist.
The system has only one default ISP domain.
# Create an ISP domain named test, and configure the domain as the default ISP domain.
[Sysname-isp-test] quit
[Sysname] domain default enable test
display domain
domain
domain if-unknown
Use domain if-unknown to specify an ISP domain to accommodate users that are assigned to nonexistent domains.
Use undo domain if-unknown to restore the default.
domain if-unknown isp-name
No ISP domain is specified to accommodate users that are assigned to nonexistent domains.
The device chooses an authentication domain for each user in the following order:
1. The authentication domain specified for the access module.
2. The ISP domain in the username.
3. The default ISP domain of the device.
If the chosen domain does not exist on the device, the device searches for the ISP domain that accommodates users assigned to nonexistent domains. If no such ISP domain is configured, user authentication fails.
NOTE: Support for the authentication domain configuration depends on the access module. |
# Specify ISP domain test to accommodate users that are assigned to nonexistent domains.
[Sysname] domain if-unknown test
display domain
ita-policy
Use ita-policy to apply an ITA policy to users in an ISP domain.
Use undo ita-policy to restore the default.
ita-policy policy-name
undo ita-policy
No ITA policy is applied in an ISP domain.
ISP domain view
policy-name: Specifies an ITA policy by its name, a case-insensitive string of 1 to 31 characters.
The ITA policy assigned from a RADIUS server takes precedence over the ITA policy in an ISP domain. If an ISP domain user has been assigned an ITA policy from the RADIUS server, the ITA policy of the ISP domain does not take effect even if the server-assigned ITA policy does not exist on the device.
# Apply ITA policy ita1 to users in ISP domain test.
[Sysname-isp-test] ita-policy ita1
ita policy
local-server log change-password-prompt
Use local-server log change-password-prompt to enable password change prompt logging.
Use undo local-server log change-password-prompt to disable password change prompt logging.
Password change prompt logging is enabled.
Use this feature to enhance the protection of passwords for Telnet, SSH, HTTP, HTTPS, NETCONF over SSH, and NETCONF over SOAP users and improve the system security.
This feature enables the device to generate logs to prompt users to change their weak passwords at an interval of 24 hours and at the users' login.
A password is a weak password if it does not meet the following requirements:
· Password composition restriction configured by using the password-control composition command.
· Minimum password length restriction set by using the password-control length command.
· Password complexity checking policy configured by using the password-control complexit command.
For a NETCONF over SSH or NETCONF over SOAP user, the device also generates a password change prompt log if any of the following conditions exists:
· The current password of the user is the default password or has expired.
· The user logs in to the device for the first time or uses a new password to log in after global password control is enabled.
The device will no longer generate password change prompt logs for a user when one of the following conditions exists:
· The password change prompt logging feature is disabled.
· The user has changed the password and the new password meets the password control requirements.
· The enabling status of a related password control feature has changed so the current password of the user meets the password control requirements.
· The password composition policy or the minimum password length has changed.
You can use the display password-control command to display password control configuration. For more information about password control commands, see "Password control commands."
# Enable password change prompt logging.
[Sysname] local-server log change-password-prompt
nas-id
Use nas-id to set the NAS-ID in an ISP domain.
Use undo nas-id to delete the NAS-ID from an ISP domain.
nas-id nas-identifier
undo nas-id
No NAS-ID is set in an ISP domain.
ISP domain view
nas-identifier: Specifies a NAS-ID, a case-sensitive string of 1 to 253 characters.
During RADIUS authentication, the device uses a NAS-ID to set the NAS-Identifier attribute of RADIUS packets so that the RADIUS server can identify the access location of users.
You can configure a NAS-ID in NAS-ID profile view or in ISP domain view. The device selects the NAS-ID for the NAS-Identifier attribute in the following order:
4. NAS-ID bound with VLANs in a NAS-ID profile.
5. NAS-ID in an ISP domain.
If no NAS-ID is selected, the device uses the device name as the NAS-ID.
# Set the NAS-ID to test for ISP domain test.
[Sysname-isp-test] nas-id test
aaa nas-id
aaa nas-id profile
nas-id bind
Use nas-id bind to configure a NAS-ID and VLAN binding.
Use undo nas-id bind to remove a NAS-ID and VLAN binding.
nas-id nas-identifier bind vlan vlan-id
undo nas-id nas-identifier bind vlan vlan-id
No NAS-ID and VLAN bindings exist.
NAS-ID profile view
vlan vlan-id: Specifies a VLAN ID in the range of 1 to 4094.
You can configure multiple NAS-ID and VLAN bindings in a NAS-ID profile.
A NAS-ID can be bound with more than one VLAN or one combination of inner VLAN and outer VLAN. A VLAN or a combination of inner VLAN and outer VLAN can be bound with only one NAS-ID. If you configure multiple bindings for the same VLAN, the most recent configuration takes effect.
# Bind NAS-ID 222 with VLAN 2 in NAS-ID profile aaa.
[Sysname] aaa nas-id profile aaa
[Sysname-nas-id-prof-aaa] nas-id 222 bind vlan 2
aaa nas-id profile
Use reset aaa abnormal-offline-record to clear all user abnormal offline records.
The device saves user abnormal offline records in memory and does not automatically clear the records unless the device reboots. To prevent the records from overusing the memory, use this command to clear all user abnormal offline records.
Use this command with caution. Cleared records cannot be recovered.
# Clear all user abnormal offline records.
<Sysname> reset aaa abnormal-offline-record
Use reset aaa normal-offline-record to clear all user normal offline records.
The device saves user normal offline records in memory and does not automatically clear the records unless the device reboots. To prevent the records from overusing the memory, use this command to clear all user normal offline records.
# Clear all user normal offline records.
<Sysname> reset aaa normal-offline-record
Use reset aaa offline-record to clear all user offline records.
The device saves user offline records in memory and does not automatically clear the records unless the device reboots. To prevent the records from overusing the memory, use this command to clear all user offline records.
# Clear all user offline records.
<Sysname> reset aaa offline-record
Use reset aaa online-fail-record to clear all user online failure records.
The device saves user online failure records in memory and does not automatically clear the records unless the device reboots. To prevent the records from overusing the memory, use this command to clear all user online failure records.
# Clear all user online failure records.
<Sysname> reset aaa online-fail-record
session-time include-idle-time
Use session-time include-idle-time to configure the device to include the idle timeout period in the user online duration sent to the server.
Use undo session-time include-idle-time to restore the default.
The device does not include the idle timeout period in the user online duration sent to the server.
ISP domain view
Whether to configure the device to include the idle timeout period in the user online duration sent to the server, depending on the accounting policy in your network. The idle timeout period is assigned to users by the authorization server after the users pass authentication. For portal users, the device includes the idle timeout period set for the online portal user detection feature in the user online duration. For more information about online detection for portal users, see portal authentication configuration in User Access and Authentication Configuration Guide.
If the user goes offline due to connection failure or malfunction, the user online duration sent to the server is not the same as the actual online duration.
· If the session-time include-idle-time command is used, the user's online duration sent to the server includes the idle timeout period. The online duration that is generated on the server is longer than the actual online duration of the user.
· If the undo session-time include-idle-time command is used, the user's online duration sent to the server excludes the idle timeout period. The online duration that is generated on the server is shorter than the actual online duration of the user.
# Configure the device to include the idle timeout period in the online duration sent to the server for users in ISP domain test.
[Sysname-isp-test] session-time include-idle-time
display domain
Use state to set the status of an ISP domain.
Use undo state to restore the default.
state { active | block [ time-range ] [ offline ] }
undo state
An ISP domain is in active state.
ISP domain view
active: Places the ISP domain in active state to allow the users in the ISP domain to request network services.
block: Places the ISP domain in blocked state to prevent users in the ISP domain from requesting network services. This keyword takes effect on all types of users except the SSH users that perform publickey authentication.
time-range: Places the ISP domain in blocked state based on time ranges. If you specify the block keyword but do not specify the time-range keyword, the ISP domain is always placed in blocked state.
offline: Logs off online users (including portal and IPoE users) in the ISP domain when the state of the ISP domain changes to blocked. If you specify the block keyword but do not specify the offline keyword, the users in the ISP domain stay online when the state of the ISP domain changes to blocked.
To block an ISP domain based on time ranges, specify the time-range keyword in this command, and specify time ranges by using the state block time-range name command.
# Place ISP domain test in blocked state.
[Sysname-isp-test] state block
display domain
Use state block time-range name to specify time ranges during which an ISP domain is placed in blocked state.
Use undo state block time-range name to delete time ranges for placing an ISP domain in blocked state.
state block time-range name time-range-name
undo state block time-range { all | name time-range-name }
No time ranges are specified for placing an ISP domain in blocked state.
ISP domain view
time-range-name: Specifies a time range by its name, a case-insensitive string of 1 to 32 characters. The string must begin with a letter and cannot be all.
all: Specifies all time ranges.
The specified time ranges take effect only when the device is configured to block an ISP domain based on time ranges. To configure the device to block the ISP domain based on time ranges, use the state block time-range command.
You can repeat this command to specify multiple time ranges.
# Specify time ranges t1 and t2 for placing ISP domain test in blocked state.
[Sysname-isp-test] state block time-range name t1
[Sysname-isp-test] state block time-range name t2
state
time-range (ACL and QoS Command Reference)
user-address-type
Use user-address-type to specify the user address type in the ISP domain.
Use undo user-address-type to restore the default.
user-address-type { ds-lite | ipv6 | nat64 | private-ds | private-ipv4 | public-ds | public-ipv4 }
No user address type is specified for the ISP domain.
ISP domain view
ds-lite: Specifies the DS-Lite address type.
ipv6: Specifies the IPv6 address type.
nat64: Specifies the NAT64 address type.
private-ds: Specifies the private-DS address type.
private-ipv4: Specifies the private IPv4 address type.
public-ds: Specifies the public-DS address type.
public-ipv4: Specifies the public IPv4 address type.
Specify the address type for users in an ISP domain according to the actual customer network environment and address assignment policies for the users.
Any change to the user address type does not affect online users.
# Specify the private IPv4 address type for users in ISP domain test.
[Sysname-isp-test] user-address-type private-ipv4
display domain
Local user commands
access-limit
Use access-limit to set the maximum number of concurrent logins using the local user name.
Use undo access-limit to restore the default.
access-limit max-user-number
undo access-limit
The number of concurrent logins using the local user name is not limited.
Local user view
max-user-number: Specifies the maximum number of concurrent logins, in the range of 1 to 1024.
The command does not apply to FTP, SFTP, or SCP users. These users do not support accounting.
For this command to take effect on network access users, execute the accounting start-fail offline command in the ISP domain view as a best practice.
# Set the maximum number of concurrent logins to 5 for users using the local user name abc.
[Sysname] local-user abc
[Sysname-luser-manage-abc] access-limit 5
display local-user
access-user email authentication
Use access-user email authentication to specify the username and password used to log in to the SMTP server that sends email notifications to network access users.
Use undo access-user email authentication to restore the default.
access-user email authentication username user-name password { cipher | simple } string
No SMTP server username or password is specified.
username user-name: Specifies the username, a case-sensitive string of 1 to 63 characters.
password: Specifies the password.
cipher: Specifies the password in encrypted form.
simple: Specifies the password in plaintext form. For security purposes, the password specified in plaintext form will be stored in encrypted form.
string: Specifies the password string. Its plaintext form is a case-sensitive string of 1 to 63 characters. Its encrypted form is a case-sensitive string of 1 to 117 characters.
If the SMTP server requires a username and password for login, you must use this command to specify the username and password on the device.
# Set the username to abc and the password to 123 for logging in to the SMTP server that sends email notifications to network access users.
[Sysname] access-user email authentication username abc password simple 123
access-user email format
access-user email sender
access-user email smtp-server
Use access-user email format to configure the subject and body for the email notifications to send to network access users.
Use undo access-user email format to restore the default.
access-user email format { body body-string | subject sub-string }
undo access-user email format { body | subject }
The email subject is Password reset notification.
The email body is as follows:
A random password has been generated for your account.
Username: xxx
Password: yyy
Validity: YYYY/MM/DD hh:mm:ss to YYYY/MM/DD hh:mm:ss
The xxx string represents the username, the yyy string represents the password, and the YYYY/MM/DD hh:mm:ss to YYYY/MM/DD hh:mm:ss string represents the validity period.
body body-string: Configures the body content. The body-string argument is a case-sensitive string of 1 to 255 characters.
subject sub-string: Configures the email subject. The sub-string argument is a case-sensitive string of 1 to 127 characters.
You can configure the device to generate a random password for a network access user on the Web interface. The random password is sent to the user by email. Use this command to configure the email subject and body content.
The email body includes the string configured by using the body-string argument and the following information:
Username: xxx
Password: yyy
# Configure the subject and body for the email notifications to send to network access users.
[Sysname] access-user email format subject new password setting
[Sysname] access-user email format body The username, password, and validity period of the account are given below.
Use access-user email sender to configure the email sender address in email notifications sent by the device to network access users.
Use undo access-user email sender to restore the default.
access-user email sender email-address
No email sender address is configured for the email notifications sent by the device to network access users.
email-address: Specifies the email sender address, a case-sensitive string of 1 to 255 characters. The string must contain an at sign (@), and it can contain only one at sign (@). In addition, the string cannot contain only the at sign (@).
If you do not specify the email sender address, the device cannot send email notifications to any network access users.
The device supports only one email sender address for network access users. If you execute this command multiple times, the most recent configuration takes effect.
# Specify the email sender address as [email protected] for email notifications of network access users.
[Sysname] access-user email sender [email protected]
Use access-user email smtp-server to specify an SMTP server to send email notifications of network access users.
Use undo access-user email smtp-server to restore the default.
access-user email smtp-server url-string
No SMTP server is specified to send email notifications of network access users.
url-string: Specifies the path of the SMTP server, a case-sensitive string of 1 to 255 characters. The path must comply with the standard SMTP protocol and start with smtp://.
You can specify only one SMTP server to send email notifications of network access users.
# Specify the SMTP server at smtp://www.test.com/smtp to send email notifications of network access users.
[Sysname] access-user email smtp-server smtp://www.test.com/smtp
authorization-attribute (local user view/user group view)
Use authorization-attribute to configure authorization attributes for a local user or user group. After the local user or a local user in the user group passes authentication, the device assigns these attributes to the user.
Use undo authorization-attribute to restore the default of an authorization attribute.
authorization-attribute { acl acl-number | idle-cut minutes | ip ipv4-address | ip-pool ipv4-pool-name | ipv6 ipv6-address | ipv6-pool ipv6-pool-name | ipv6-prefix ipv6-prefix prefix-length | { primary-dns | secondary-dns } { ip ipv4-address | ipv6 ipv6-address } | session-group-profile session-group-profile-name | session-timeout minutes | subscriber-id subscriber-id | user-group user-group-name | user-profile profile-name | user-role role-name | vlan vlan-id | work-directory directory-name } *
undo authorization-attribute { acl | idle-cut | ip | ip-pool | ipv6 | ipv6-pool | ipv6-prefix | primary-dns | secondary-dns | session-group-profile | session-timeout | subscriber-id | user-group | user-profile | user-role role-name | vlan | work-directory } *
The working directory for FTP, SFTP, and SCP users is the root directory of the NAS. However, the users do not have permission to access the root directory.
The local users created by a network-admin or level-15 user are assigned the network-operator user role.
Local user view
User group view
acl acl-number: Specifies an authorization ACL. The value range for the acl-number argument is 2000 to 4999. The device processes the traffic that matches the rules in the authorization ACL based on the permit or deny statement in the rules.
idle-cut minutes: Specifies an idle timeout period in minutes. The value range for the minutes argument is 1 to 120. An online user is logged out if its idle period exceeds the specified idle timeout period.
ip ipv4-address: Assigns a static IPv4 address to the user after it passes authentication. You can specify this option only in local user view. This option is not supported in user group view.
ip-pool ipv4-pool-name: Specifies an IPv4 pool for the user. The ipv4-pool-name argument is a case-insensitive string of 1 to 63 characters.
ipv6 ipv6-address: Assigns a static IPv6 address to the user after it passes authentication. You can specify this option only in local user view. This option is not supported in user group view.
ipv6-pool ipv6-pool-name: Specifies an IPv6 pool for the user. The ipv6-pool-name argument is a case-insensitive string of 1 to 63 characters.
ipv6-prefix ipv6-prefix prefix-length: Specifies an IPv6 address prefix for the user. The value range for the prefix-length argument is 1 to 128.
primary-dns ip ipv4-address: Specifies the IPv4 address of the primary DNS server for the user.
primary-dns ipv6 ipv6-address: Specifies the IPv6 address of the primary DNS server for the user.
secondary-dns ip ipv4-address: Specifies the IPv4 address of the secondary DNS server for the user.
secondary-dns ipv6 ipv6-address: Specifies the IPv6 address of the secondary DNS server for the user.
session-group-profile session-group-profile-name: Specifies a session group profile for the user. The session-group-profile-name argument is a case-sensitive string of 1 to 31 characters and can contain only letters, digits, underscores (_), minus signs (-), and dots (.). The string can begin with a letter or a digit, but it cannot be all digits. For more information about session group profiles, see user profile configuration in Security Configuration Guide.
session-timeout minutes: Specifies the session timeout timer for the user, in minutes. The value range for the minutes argument is 1 to 1440. The device logs off the user after the timer expires.
subscriber-id subscriber-id: Specifies a subscriber ID for the user, in the range of 1 to 4095. Subscriber IDs are used with session group profiles to implement QoS traffic control on a per-group basis. For more information about QoS, see QoS Configuration Guide.
user-group user-group-name: Specifies local user group by its name, a case-insensitive string of 1 to 32 characters. This attribute can be configured only in local user view.
user-profile profile-name: Specifies an authorization user profile by its name. The profile-name argument is a case-sensitive string of 1 to 31 characters. Valid characters include letters, digits, underscores (_), minus signs (-), and dots (.). The string can begin with a letter or digit, but it cannot be all digits. The user profile restricts the behavior of authenticated users. For more information, see Security Configuration Guide.
user-role role-name: Specifies an authorized user role. The role-name argument is a case-sensitive string of 1 to 63 characters. A maximum of 64 user roles can be specified for a user. For user role-related commands, see Fundamentals Command Reference for RBAC commands. This option is available only in local user view, and is not available in user group view.
vlan vlan-id: Specifies an authorized VLAN. The value range for the vlan-id argument is 1 to 4094. After passing authentication and being authorized a VLAN, a local user can access only the resources in this VLAN.
wlan-vlan wlan-vlan-id: Specifies a VLAN by its ID in the range of 1 to 4094. This option takes effect only on wireless users.
wlan-vlan-group wlan-vlan-group-name: Specifies a VLAN group by its name, a case-sensitive string of 1 to 32 characters. The name must start with a letter. This option takes effect only on wireless users.
work-directory directory-name: Specifies the working directory for FTP, SFTP, or SCP users. The directory-name argument is a case-insensitive string of 1 to 255 characters. The directory must already exist.
Configure authorization attributes according to the application environments and purposes. Support for authorization attributes depends on the service types of users.
For IPoE users, only the following authorization attributes take effect: idle-cut, ip-pool, ipv6-pool, ipv6-prefix, session-group-profile, subscriber-id, user-profile, primary-dns, secondary-dns, and session-timeout.
For portal users, only the following authorization attributes take effect: acl, ip-pool, ipv6-pool, user-group, user-profile, and session-timeout. The user-group attribute is available only for wireless users.
For SSH, Telnet, and terminal users, only the authorization attributes idle-cut and user-role take effect.
For HTTP and HTTPS users, only the authorization attribute user-role takes effect.
For FTP users, only the authorization attributes user-role and work-directory take effect.
For IKE users, only the authorization attribute ip-pool, ip, and ipv6 takes effect.
For other types of local users, no authorization attribute takes effect.
Authorization attributes configured for a user group are intended for all local users in the group. You can group local users to improve configuration and management efficiency. An authorization attribute configured in local user view takes precedence over the same attribute configured in user group view.
When you specify an authorization ACL, note that the authorization ACL is invalid if it does not exist or does not contain rules. If strict checking on authorization ACLs is enabled for portal users in this situation, portal users will be forced offline.
To make sure the user have only the user roles authorized by using this command, use the undo authorization-attribute user-role command to remove the default user role.
The security-audit user role has access to the commands for managing security log files and security log file system. To display all the accessible commands of the security-audit user role, use the display role name security-audit command. For more information about security log management, see configuring the information center in System Management Configuration Guide. For more information about file system management, see Fundamentals Configuration Guide.
You cannot delete a local user if the local user is the only user that has the security-audit user role.
The security-audit user role is mutually exclusive with other user roles.
· When you assign the security-audit user role to a local user, the system requests confirmation for deleting all the other user roles of the user.
· When you assign other user roles to a local user that has the security-audit user role, the system requests confirmation for deleting the security-audit user role for the local user.
# Configure the authorized VLAN of network access user abc as VLAN 2.
[Sysname] local-user abc class network
[Sysname-luser-network-abc] authorization-attribute vlan 2
# Configure the authorized VLAN of user group abc as VLAN 3.
[Sysname] user-group abc
[Sysname-ugroup-abc] authorization-attribute vlan 3
# Assign the security-audit user role to device management user xyz as the authorized user role.
[Sysname] local-user xyz class manage
[Sysname-luser-manage-xyz] authorization-attribute user-role security-audit
This operation will delete all other roles of the user. Are you sure? [Y/N]:y
display local-user
display user-group
bind-attribute
Use bind-attribute to configure binding attributes for a local user.
Use undo bind-attribute to remove binding attributes of a local user.
bind-attribute { location interface interface-type interface-number | mac mac-address | vlan vlan-id } *
undo bind-attribute { call-number | ip | location | mac | vlan } *
No binding attributes are configured for a local user.
Local user view
location interface interface-type interface-number: Specifies the interface to which the user is bound. The interface-type argument represents the interface type, and the interface-number argument represents the interface number. To pass authentication, the user must access the network through the bound interface. This option applies only to IPoE and portal users.
mac mac-address: Specifies the MAC address of the user in the format H-H-H. This option applies only to SSL VPN users that log in through iNode clients, IPoE and portal users.
vlan vlan-id: Specifies the VLAN to which the user belongs. The vlan-id argument is in the range of 1 to 4094. This option applies only to IPoE and portal users.
To perform local authentication of a user, the device matches the actual user attributes with the configured binding attributes. If the user has a non-matching attribute or lacks a required attribute, the user will fail authentication.
Binding attribute check takes effect on all access services. Configure the binding attributes for a user based on the access services and make sure the device can obtain all attributes to be checked from the user's packet.
The binding interface type must meet the requirements of the local user. If the user is a portal user, specify the portal-enabled interface. Specify the Layer 2 Ethernet interface if portal is enabled on a VLAN interface and the portal roaming enable command is not configured.
# Bind MAC address 11-11-11 with network access user abc.
[Sysname-luser-network-abc] bind-attribute mac 11-11-11
display local-user
company
Use company to specify the company of a local guest.
Use undo company to restore the default.
company company-name
undo company
No company is specified for a local guest.
Local guest view
company-name: Specifies the company name, a case-sensitive string of 1 to 255 characters.
# Specify company yyy for local guest abc.
[Sysname] local-user abc class network guest
[Sysname-luser-network(guest)-abc] company yyy
display local-user
description
Use description to configure a description for a network access user.
No description is configured for a network access user.
Network access user view
text: Configures a description, case-sensitive string of 1 to 255 characters.
To mark a network access user for special displaying or management purposes, configure description #user_from_server# for the user. The purposes depend on the implementation of the management side.
# Configure a description for network access user 123.
[Sysname] local-user 123 class network
[Sysname-luser-network-123] description Manager of MSC company
display local-user
display local-guest waiting-approval
Use display local-guest waiting-approval to display pending registration requests for local guests.
display local-guest waiting-approval [ user-name user-name ]
user-name user-name: Specifies a local guest by the username, a string of 1 to 80 characters. If you do not specify a guest, this command displays pending registration requests for all local guests. The username of the specified guest can be a pure username or contain a domain name (in the format of pure-username@domain-name).
· The pure username is a case-sensitive string and must meet the following requirements:
¡ Cannot contain any of the following characters: forward slash (/), backslash (\), vertical bar (|), colon (:), asterisk (*), question mark (?), left angle bracket (<), right angle bracket (>), or at sign (@).
¡ Cannot be a, al, or all.
· The domain name is a case-insensitive string and cannot contain an at sign (@).
On the Web registration page, users submit local guest registration requests for approval. The guest manager can add supplementary information to the guest accounts and approves the requests. The device then creates local guest accounts based on the approved requests.
# Display all pending registration requests for local guests.
<Sysname> display local-guest waiting-approval
Total 1 guest entries matched.
Guest user Smith:
Full name : Smith Li
Company : YYY
Email : [email protected]
Phone : 139189301033
Description: The employee of YYY company
Table 9 Command output
Total 1 guest entries matched. |
Number of local guests that have pending registration requests. |
Full name |
Full name of the local guest. |
Company |
Company name of the local guest. |
Email address of the local guest. |
Phone |
Phone number of the local guest. |
Description of the local guest. |
reset local-guest waiting-approval
display local-user
Use display local-user to display the local user configuration and online user statistics.
display local-user [ class { manage | network [ guest ] } | idle-cut { disable | enable } | service-type { ftp | http | https | ike | ipoe | portal | ssh | sslvpn | telnet | terminal } | state { active | block } | user-name user-name class { manage | network [ guest ] } | vlan vlan-id ]
class: Specifies the local user type.
manage: Device management user.
network: Network access user.
guest: Guest user account.
idle-cut { disable | enable }: Specifies local users by the status of the idle cut feature.
service-type: Specifies the local users that use a specific type of service.
ftp: FTP users.
http: HTTP users.
https: HTTPS users.
ike: IKE users that access the network through IKE extended authentication.
ipoe: IPoE users that access the network through Layer 2 or Layer 3 leased lines or STBs.
portal: Portal users.
ssh: SSH users.
sslvpn: SSL VPN users.
telnet: Telnet users.
terminal: Terminal users that log in through console ports.
state { active | block }: Specifies local users in active or blocked state. A local user in active state can access network services, but a local user in blocked state cannot.
user-name user-name: Specifies all local users using the specified username, a string of 1 to 80 characters. The specified username can be a pure username or contain a domain name (in the format of pure-username@domain-name).
vlan vlan-id: Specifies all local users in a VLAN. The vlan-id argument is in the range of 1 to 4094.
If you do not specify any parameters, this command displays information about all local users.
# Display information about all local users.
<Sysname> display local-user
Total 1 local users matched.
Device management user root:
State: Active
Service type: SSH/Telnet/Terminal
Access limit: Enabled
Max access number: 3
Current access number: 1
User group: system
Bind attributes:
Work directory: flash:
User role list: network-admin
Password aging: 3 days
Password history was last reset: 0 days ago
Password remaining lifetime: 2 days 12 hours 30 minutes 30 seconds
Table 10 Command output
State |
Status of the local user: active or blocked. |
Service type |
Service types that the local user can use. |
Access limit |
Whether the concurrent login limit is enabled. |
Max access number |
Maximum number of concurrent logins using the local user name. |
Current access number |
Current number of concurrent logins using the local user name. |
User group |
Group to which the local user belongs. |
Bind attributes |
Binding attributes of the local user. |
IP address |
IP address of the local user. |
Location bound |
Binding port of the local user. |
MAC address |
MAC address of the local user. |
VLAN ID |
Binding VLAN of the local user. |
WLAN VLAN ID |
Authorization VLAN of the local wireless user. |
WLAN VLAN group name |
Authorization VLAN group of the local wireless user. |
Authorization attributes of the local user. |
Idle timeout |
Idle timeout period of the user, in minutes. |
Session-timeout |
Session timeout timer for the user, in minutes. |
Work directory |
Directory that the FTP, SFTP, or SCP user can access. |
ACL number |
Authorization ACL of the local user. |
VLAN ID |
Authorized VLAN of the local user. |
User profile |
Authorization user profile of the local user. |
User role list |
Authorized roles of the local user. |
IP pool |
IPv4 pool authorized to the local user. |
IP address |
IPv4 address authorized to the local user. |
IPv6 address |
IPv6 address authorized to the local user. |
IPv6 prefix |
IPv6 address prefix authorized to the local user. |
IPv6 pool |
IPv6 pool authorized to the local user. |
IPv4 address of the primary DNS server for the local user. |
IPv4 address of the secondary DNS server for the local user. |
IPv6 address of the primary DNS server for the local user. |
IPv6 address of the secondary DNS server for the local user. |
Subscriber ID |
Subscriber ID of the local user. |
Session group profile of the local user. |
User group |
User group of the local user. |
Password control configurations |
Password control attributes that are configured for the local user. |
Password aging |
Password expiration time. |
Password length |
Minimum number of characters that a password must contain. |
Password composition |
Password composition policy: · Minimum number of character types that a password must contain. · Minimum number of characters from each type in a password. |
Password complexity |
Password complexity checking policy: · Reject a password that contains the username or the reverse of the username. · Reject a password that contains any character repeated consecutively three or more times. |
Maximum login attempts |
Maximum number of consecutive failed login attempts. |
Action for exceeding login attempts |
Action to take on the user that failed to log in after using up all login attempts. |
Password history was last reset |
The most recent time that the history password records were cleared. |
Password remaining lifetime |
Remaining aging time for the password. |
Full name |
Name of the local guest. |
Company |
Phone |
Sponsor full name |
Name of the guest sponsor. |
Sponsor department |
Department of the guest sponsor. |
Sponsor email |
Email address of the guest sponsor. |
Description of the network access user. |
Validity period |
Validity period of the network access user. |
Start date and time |
Date and time from which the network access user begins to take effect. |
Expiration date and time |
Date and time at which the network access user expires. |
display user-group
Use display user-group to display user group configuration.
display user-group { all | name group-name [ byod-authorization ] } [ identity-member { all | group | user } ]
all: Specifies all user groups.
name group-name: Specifies a user group by its name, a case-insensitive string of 1 to 32 characters.
byod-authorization: Specifies BYOD authorization information. If you do not specify this keyword, the command does not display BYOD authorization information and only displays whether BYOD authorization attributes are configured.
identity-member { all | group | user }: Specifies identity members in the specified user group or all user groups. If you do not specify these keywords, the command does not display identity member information.
# Display the configuration of all user groups.
<Sysname> display user-group all
Total 2 user groups matched.
User group: system
Group ID: 1
User-Isolation: Not configured
User group: jj
Group ID: 2
Work directory: flash:/
ACL number: 2000
VLAN ID: 2
User profile: pp
User-Isolation: Intra-group
Password aging: 2 days
# Display information about all identity members for all user groups.
<Sysname> display user-group all identity-member all
User group: system
Identity groups: 0
User group: jj
Identity groups: 2
Group ID Group name
0xffffffff group1
0x567 group2
Identity users: 2
User ID Username
0x234 user1
0xffffffff user2
Table 11 Command output
User group |
User group name. |
Authorization attributes of the user group. |
Idle timeout |
Session-timeout |
Session timeout timer, in minutes. |
Work directory |
Directory that FTP, SFTP, or SCP users in the group can access. |
ACL number |
Authorization ACL. |
VLAN ID |
Authorized VLAN. |
User profile |
Authorization user profile. |
IP pool |
IPv4 pool authorized to the user group. |
IPv6 prefix |
IPv6 address prefix authorized to the user group. |
IPv6 pool |
IPv6 pool authorized to the user group. |
IPv4 address of the primary DNS server authorized to the user group. |
IPv4 address of the secondary DNS server authorized to the user group. |
User isolation |
User isolation: · Intra-group—Intra-group isolation. · Inter-group—Inter-group isolation. |
IPv6 address of the primary DNS server authorized to the user group. |
IPv6 address of the secondary DNS server authorized to the user group. |
Password control attributes that are configured for the user group. |
Password aging |
Password length |
Identity users |
Number of identity users. |
Identity groups |
Number of identity groups. |
User ID |
Identity user ID. |
Group ID |
Identity group ID. |
Username |
Identity user name. |
Group name |
Identity group name. |
Use email to configure an email address for a local guest.
Use undo email to restore the default.
email email-string
undo email
No email address is configured for a local guest.
Local guest view
email-string: Specifies the email address for the local guest, a case-sensitive string of 1 to 255 characters. For example, [email protected]. The address must comply with RFC 822.
The local guest uses the email address to receive notifications from the device.
# Configure the email address as [email protected] for local guest abc.
[Sysname-luser-network(guest)-abc] email [email protected]
display local-user
full-name
Use full-name to configure the name of a local guest.
Use undo full-name to restore the default.
full-name name-string
undo full-name
No name is configured for a local guest.
Local guest view
name-string: Specifies the local guest name, a case-sensitive string of 1 to 255 characters.
# Configure the name as abc Snow for local guest abc.
[Sysname-luser-network(guest)-abc] full-name abc Snow
display local-user
group
Use group to assign a local user to a user group.
Use undo group to restore the default.
group group-name
undo group
A local user belongs to user group system.
Local user view
group-name: Specifies the user group name, a case-insensitive string of 1 to 32 characters.
# Assign device management user 111 to user group abc.
[Sysname] local-user 111 class manage
[Sysname-luser-manage-111] group abc
display local-user
identity-member
Use identity-member to add an identity member to a user group.
Use undo identity-member to remove identity members from a user group.
identity-member { group group-name | user user-name }
undo identity-member { group [ group-name ] | user [ user-name ] }
No identity members exist in a user group.
User group view
group group-name: Specifies an identity group by its name, a case-insensitive string of 1 to 32 characters.
user user-name: Specifies an identity user by its name, a string of 1 to 80 characters. The username can be a pure username or a username containing a domain name.
· A pure username is case sensitive. It cannot contain a forward slash (/), backslash (\), vertical bar (|), colon (:), asterisk (*), question mark (?), left angle bracket (<), or right angle bracket (>). It also cannot be a, al, or all.
· A username containing a domain name is in the pure-username@domain-name format.
¡ The pure username part is case sensitive. It cannot contain a forward slash (/), backslash (\), vertical bar (|), colon (:), asterisk (*), question mark (?), left angle bracket (<), right angle bracket (>), or at sign (@). It also cannot be a, al, or all.
¡ The domain name part is case insensitive and cannot contain an at sign (@).
Assign users or users groups that have the same user identification requirements to the same group.
When you add identity members, follow these restrictions and guidelines:
· You can add only network access users as identity users.
· After you add an identity user to an identity group in user group view, the system automatically synchronizes the configuration to the local user view of the identity user if the user exists. Then, the identity user group is available in the local user view of the identity user.
· You cannot assign the parent group of a user group to the user group as an identity member.
If you do not specify a user name or group name, the undo identity-member command removes all identity users or groups from the user group.
If an identity user group is used in a security policy, avoid removing member identity user groups from that identity user group. Doing so will change the tree of identity user groups, resulting in incorrect user traffic matching or user traffic matching failure.
# Add identity user user1 and identity group group2 to user group group1.
[Sysname] user-group group1
[Sysname-ugroup-group1] identity-member user user1
[Sysname-ugroup-group1] identity-member group group2
display user-group
identity-group
local-guest email format
Use local-guest email format to configure the subject and body for the email notifications of local guest information.
Use undo local-guest email format to delete the configured subject or body for the email notifications of local guest information.
local-guest email format to { guest | manager | sponsor } { body body-string | subject sub-string }
undo local-guest email format to { guest | manager | sponsor } { body | subject }
No subject or body is configured for the email notifications of local guest information.
to: Specifies the email recipient.
guest: Specifies the local guest.
manager: Specifies the guest manager.
sponsor: Specifies the guest sponsor.
Email notifications need to be sent to notify the local guests, guest sponsors, or guest managers of the guest account information or guest registration requests. Use this command to configure the subject and body for the email notifications to be sent by the device.
You can configure one subject and one body for each email recipient. If you configure the subject or body content multiple times for the same recipient, the most recent configuration takes effect.
You must configure both the subject and body for each recipient.
# Configure the subject and body for the email notifications to send to the local guest.
[Sysname] local-guest email format to guest subject Guest account information
[Sysname] local-guest email format to guest body A guest account has been created for you. The username, password, and validity period of the account are given below.
local-guest email sender
local-guest email smtp-server
local-guest manager-email
local-guest send-email
Use local-guest email sender to configure the email sender address in email notifications of local guests sent by the device.
Use undo local-guest email sender to restore the default.
local-guest email sender email-address
No email sender address is configured for the email notifications of local guests sent by the device.
If you do not specify the email sender address, the device cannot send email notifications.
The device supports only one email sender address. If you execute this command multiple times, the most recent configuration takes effect.
# Specify the email sender address as [email protected] for email notifications of local guests.
[Sysname] local-guest email sender [email protected]
Use local-guest email smtp-server to specify an SMTP server to send email notifications of local guests.
Use undo local-guest email smtp-server to restore the default.
local-guest email smtp-server url-string
No SMTP server is specified to send email notifications of local guests.
# Specify the SMTP server at smtp://www.test.com/smtp to send local guest email notifications.
[Sysname] local-guest email smtp-server smtp://www.test.com/smtp
local-guest generate
Use local-guest generate to create local guests in batch.
local-guest generate username-prefix name-prefix [ password-prefix password-prefix ] suffix suffix-number [ group group-name ] count user-count validity-datetime start-date start-time to expiration-date expiration-time
username-prefix name-prefix: Specifies the name prefix. The name-prefix argument is a case-sensitive string of 1 to 70 characters. The prefix cannot contain any of the following characters: forward slash (/), backslash (\), vertical bar (|), colon (:), asterisk (*), question mark (?), left angle bracket (<), right angle bracket (>), or at sign (@).
password-prefix password-prefix: Specifies a prefix for the plaintext password. The password-prefix argument is a case-sensitive string of 1 to 53 characters. If you do not specify a password prefix, the device randomly generates passwords for the local guests.
suffix suffix-number: Specifies the start suffix number of the username and password. The suffix-number argument is a numeric string of 1 to 10 digits.
group group-name: Specifies a user group by the name. The group-name argument is a case-sensitive string of 1 to 32 characters. If you do not specify a user group, the guests are assigned to the system-defined user group system.
count user-count: Specifies the number of local guests to be created. The value range for the user-count argument is 1 to 256.
validity-datetime: Specifies the validity period of the local guests.
start-date: Specifies the start date of the validity period, in the format of MM/DD/YYYY or YYYY/MM/DD. The value range for the MM argument is 1 to 12. The value range for the DD argument varies with the specified month. The value range for the YYYY argument is 2000 to 2035.
start-time: Specifies the start time of the validity period, in the format of hh:mm:ss. The value range for the hh argument is 0 to 23. The value range for the mm and ss arguments is 0 to 59. The mm and ss arguments are optional. For example, enter 1 to indicate 1:00:00. A value of 0 indicates 00:00:00.
to: Specifies the end date and time of the validity period.
expiration-date: Specifies the expiration date in the format of MM/DD/YYYY or YYYY/MM/DD. The value range for the MM argument is 1 to 12. The value range for the DD argument varies with the specified month. The value range for the YYYY argument is 2000 to 2035.
expiration-time: Specifies the expiration time in the format of hh:mm:ss. The value range for the hh argument is 0 to 23. The value range for the mm and ss arguments is 0 to 59. The mm and ss arguments are optional. For example, enter 1 to indicate 1:00:00. A value of 0 indicates 00:00:00.
Account names of batch created local guests start with the same string specified by the name prefix, and end with a different number as the suffix. The system increases the start suffix number by 1 for each new local guest created in the batch.
The device generates plaintext passwords by using the password prefix and suffix number in the same way it batch creates the local guest names.
Consider the system resources when you specify the number of local guests to create. The device might fail to create all accounts for a large batch of local guests because of insufficient resources.
If a local guest to be created has the same name as an existing local guest on the device, the new guest overrides the existing guest.
# Create 20 local guests in batch with user names abc01 through abc20 for user group visit. The user accounts are effective from 2020/01/01 00:00:00 to 2020/02/02 12:00:00.
[Sysname] local-guest generate username-prefix abc suffix 01 group visit count 20 validity-datetime 2020/01/01 00:00:00 to 2020/02/02 12:00:00
local-user
display local-user
Use local-guest manager-email to configure the email address of the guest manager.
Use undo local-guest manager-email to restore the default.
local-guest manager-email email-address
No email address is configured for the guest manager.
email-address: Specifies the email address, a case-sensitive string of 1 to 255 characters. For example, [email protected]. The address must comply with RFC 822.
Use this command to specify the email address to which the device sends the local guest registration requests for approval.
# Configure the email address of the guest manager as mailto:[email protected].
[Sysname] local-guest manager-email [email protected]
Use local-guest send-email to send emails to a local guest or guest sponsor.
local-guest send-email user-name user-name to { guest | sponsor }
user-name user-name: Specifies a local guest by the username, a string of 1 to 80 characters. The username of the specified guest can be a pure username or contain a domain name (in the format of pure-username@domain-name).
Device managers can use this command to inform local guests or guest sponsors of the guest password and validity period information.
# Send an email to notify local guest abc of the guest password and validity period information.
<Sysname> local-guest send-email user-name abc to guest
sponsor-email
local-guest timer
Use local-guest timer to set the waiting-approval timeout timer for local guests.
local-guest timer waiting-approval time-value
undo local-guest timer waiting-approval
The setting is 24 hours.
time-value: Specifies the waiting-approval timeout timer in the range of 1 to 720, in hours.
The waiting-approval timeout timer starts when the registration request of a local guest is sent for approval. If the request is not approved within the timer, the device deletes the registration request.
# Set the waiting-approval timeout timer to 12 hours.
[Sysname] local-guest timer waiting-approval 12
local-user
Use local-user to add a local user and enter its view, or enter the view of an existing local user.
Use undo local-user to delete local users.
local-user user-name [ class { manage | network [ guest ] } ]
undo local-user { user-name class { manage | network [ guest ] } | all [ class { manage | network [ guest ] } |service-type { ftp | http | https | ike | ipoe | portal | ssh | sslvpn | telnet | terminal } ] }
No local users exist.
user-name: Specifies the username of the local user, a string of 1 to 80 characters. The specified username can be a pure username or contain a domain name (in the format of pure-username@domain-name).
¡ Cannot be a substring of all or auto-delete that starts with character a (for example, a, al, all, au, aut, auto, or auto-).
class: Specifies the local user type. If you do not specify this keyword, the command adds a device management user.
manage: Device management user that can configure and monitor the device after login. Device management users can use FTP, HTTP, HTTPS, Telnet, SSH, and terminal services.
network: Network access user that accesses network resources through the device. Network access users can use IKE, IPoE, and portal services.
guest: Guest that can access network resources through the device during a specific validity period. Guests can use portal services.
all: Specifies all users.
ftp: FTP users.
http: HTTP users.
https: HTTPS users.
ssh: SSH users.
In local authentication, a username and user type uniquely identifies a local user. The username is used to match the pure username parsed from the username entered by the user. The user type restricts the service types that can be used by the user.
The device supports multiple local users. You can add a maximum of 1024 device management users and a maximum of 4294967295 network access users.
If the local user name contains Chinese characters, make sure the client software used for local user login use the same character encoding format as the device. If the software uses a different encoding format than the device, the device might fail to decode the username and local authentication might fail. To view the current character encoding format, use the display character-encoding command.
# Add a device management user named user1 and enter local user view.
[Sysname-luser-manage-user1]
# Add a network access user named user2 and enter local user view.
[Sysname] local-user user2 class network
[Sysname-luser-network-user2]
# Add a local guest named user3 and enter local guest view.
[Sysname] local-user user3 class network guest
[Sysname-luser-network(guest)-user3]
display local-user
display character-encoding (Fundamentals Command Reference)
service-type (local user view)
local-user auto-delete enable
Use local-user auto-delete enable to enable the local user auto-delete feature.
Use undo local-user auto-delete enable to restore the default.
The local user auto-delete feature is disabled.
This feature enables the device to examine the validity of local users at fixed time periods of 10 minutes and automatically delete expired local users.
# Enable the local user auto-delete feature.
[Sysname] local-user auto-delete enable
validity-datetime
local-user-export class network
Use local-user-export class network to export network access user account information to a .csv file.
local-user-export class network url url-string [ from { group group-name | user user-name } ]
url url-string: Specifies the URL of the destination file, a case-insensitive string of 1 to 255 characters.
from: Specifies the range of users to be exported. If you do not specify this keyword, the command exports all network access users on the device.
group group-name: Specifies a user group by the name, a case-insensitive string of 1 to 32 characters.
user user-name: Specifies a user by the name, a string of 1 to 80 characters. The specified username can be a pure username or contain a domain name (in the format of pure-username@domain-name).
You can import the user account information back to the device or to other devices that support the local-user-import class network command. Before the import, you can edit the .csv file as needed. However, you must follow the restrictions in "local-user-import class network."
The device supports TFTP and FTP file transfer modes. Table 12 describes the valid URL formats of the .csv file.
Protocol |
URL format |
TFTP |
tftp://server/path/filename |
Specify a TFTP server by IP address or hostname. The path parameter represents the relative path of the TFTP working directory. For example, specify the file path as tftp://1.1.1.1/user/user.csv. |
FTP |
· With FTP user name and password: · Without FTP user name and password: |
Specify an FTP server by IP address or hostname. The path parameter represents the relative path of the FTP working directory. The device ignores the domain name in the FTP user name. For example, specify the file path as ftp://1:[email protected]/user/user.csv or ftp://1.1.1.1/user/user.csv. |
# Export network access user account information to the identityuser.csv file in the ftp://1.1.1.1/user/ path.
[Sysname] local-user-export class network url ftp://1.1.1.1/user/identityuser.csv
display local-user
local-user-export class network guest
Use local-user-export class network guest to export local guest account information to a .csv file.
local-user-export class network guest url url-string
You can import the user account information back to the device or to other devices that support the local-user-import class network guest command. Before the import, you can edit the .csv file as needed. However, you must follow the restrictions in "local-user-import class network guest."
The device supports TFTP and FTP file transfer modes. Table 13 describes the valid URL formats of the .csv file.
Protocol |
URL format |
TFTP |
FTP |
# Export local guest account information to the guest.csv file in the ftp://1.1.1.1/user/ path.
[Sysname] local-user-export class network guest url ftp://1.1.1.1/user/guest.csv
display local-user
Use local-user-import class network to import user information from a .csv file and create network access users based on the imported information.
local-user-import class network url url-string [ auto-create-group | override | start-line line-number ] *
url url-string: Specifies the URL of the source file, a case-insensitive string of 1 to 255 characters.
auto-create-group: Enables the device to automatically create user groups for the imported network access users if the groups do not exist on the device. If you do not specify this keyword, the device ignores the nonexistent user groups of the network access users and assigns the users to the predefined user group system.
override: Specifies the device to override the existing account with the same name as a user account to be imported. If you do not specify this keyword, the device retains the existing account information.
start-line line-number: Specifies the number of the line at which the account import begins. The value range for the line-number argument is 1 to 1048576. If you do not specify this option, the command imports information about all user accounts in the file.
The .csv file contains multiple parameters for each account and the parameters must be strictly arranged in the following order:
· Username—The username cannot be empty and is a string of 1 to 80 characters. The username can be a pure username or contain a domain name (in the format of pure-username@domain-name).
¡ The pure username is a case-sensitive string and must meet the following requirements:
- Cannot contain any of the following characters: forward slash (/), backslash (\), vertical bar (|), colon (:), asterisk (*), question mark (?), left angle bracket (<), right angle bracket (>), or at sign (@).
- Cannot be a, al, or all.
¡ The domain name is a case-insensitive string and cannot contain an at sign (@).
IMPORTANT: Any invalid character results in account import failure and interruption. |
· Password form—Plaintext or encrypted form. If the parameter is empty, the password is in encrypted form.
· Password—The encrypted form is a case-sensitive string of 1 to 117 characters. The plaintext form is a case-sensitive string of 1 to 63 characters. If the device fails to parse the password or the password is empty, the device imports the account without a password.
· Authorization user group—User group to which the user belongs after the user passes local authentication. The group name is a case-insensitive string of 1 to 32 characters. If the parameter is empty, the device assigns the user to the default user group system.
· Identity groups—Groups for identity-based access control. A user can belong to multiple identity groups. An identity group name is a case-insensitive string of 1 to 32 characters. Separate identity group names by the string 0x0A. If the parameter is empty, the user does not belong to any identity group.
· Service types—Services to assign to the user. Available services include portal, IPoE, SSL VPN, and IKE. A service name is case insensitive. Separate service types by the string 0x0A. If the parameter is empty, the user cannot use any service.
· Max concurrent logins—The maximum number of online users with the same user name. The value range is 1 to 1024. If the parameter is empty, the device does not restrict the number of online users with the same user name.
Separate different accounts by a carriage return and separate each parameter value of the same account by a comma (,). For example,
Jack,$c$3$uM6DH5empTfbsx341Qk/ORGozkbxNE0=,author-group1,parent-group1(0x0A)parent-group2,portal(0x0A)ipoe,1024
When you edit the .csv file, follow these restrictions and guidelines:
· Start lines with pound signs (#) to contain explanation information for usage guidelines. The device does not import the lines as user account information.
· Separate parameter values by a comma (,). If the value of a parameter contains a comma (,), you must enclose the value into single quotation marks (') to avoid ambiguity. For example, if the authorization user group of a user is named as author,group, you must specify the authorization user group name as 'author,group' in the .csv file.
The device supports TFTP and FTP file transfer modes. Table 15 describes the valid URL formats of the .csv file.
Table 14 URL formats
Protocol |
URL format |
TFTP |
FTP |
# Import user account information from the localuser.csv file in the ftp://1.1.1.1/user/ path, and create network access users based on the imported information. Specify the device to ignore the accounts that have the same name as the existing accounts on the device. Enable the device to automatically create the user group of an imported network access user if the user group does not exist on the device.
[Sysname] local-user-import class network url ftp://1.1.1.1/user/localuser.csv auto-create-group
Use local-user-import class network guest to import local guest account information from a .csv file to create local guests based on the imported information.
local-user-import class network guest url url-string validity-datetime start-date start-time to expiration-date expiration-time [ auto-create-group | override | start-line line-number ] *
url url-string: Specifies the source file path. The url-string argument is a case-insensitive string of 1 to 255 characters.
validity-datetime: Specifies the guest validity period of the local guests.
auto-create-group: Enables the device to automatically create user groups for the imported local guests if the groups in the imported information do not exist on the device. If you do not specify this keyword, the device adds all imported local guests to the system-defined user group named system.
override: Enables the device to override the existing account with the same name as an imported guest account. If you do not specify this keyword, the device retains the existing account and does not import the local guest with the same name.
start-line line-number: Specifies the number of the line at which the account import begins. If you do not specify a line number, this command imports all accounts in the .csv file.
· Username—User name of the guest account. The user name cannot be empty.
· Password—Password of the guest account in plaintext form. If the password is empty, the device generates a random password in encrypted form for the guest.
· User group—User group to which the guest belongs. If the user group is empty, the device assigns the guest to the system-defined user group named system.
· Guest full name—Name of the guest.
· Guest company—Company of the guest.
· Guest email—Email address of the guest.
· Guest phone—Phone number of the guest.
· Guest description—Description of the guest.
· Sponsor full name—Name of the guest sponsor.
· Sponsor department—Department of the guest sponsor.
· Sponsor email—Email address of the guest sponsor.
The value of each parameter in the file must meet the requirements of the local user attributes on the device. Any violation results in account import failure and interruption. The system displays the number of the line where the account import is interrupted.
Separate different account entries by a carriage return and separate each parameter value in an account entry by a comma (,). If the value of a parameter contains a comma (,), you must enclose the value within a pair of quotation marks ("") to avoid ambiguity. For example,
Jack,abc,visit,Jack Chen,ETP,[email protected],1399899,"The manager of ETP, come from TP.",Sam Wang,Ministry of personnel,[email protected]
Protocol |
URL format |
TFTP |
FTP |
# Import guest account information from the ftp://1.1.1.1/user/guest.csv file and specify a validity period for the imported guests.
[Sysname] local-user-import class network guest url ftp://1.1.1.1/user/guest.csv validity-datetime 2020/02/01 00:00:00 to 2020/02/02 12:00:00
display local-user
password (device management user view)
Use password to configure a password for a device management user.
Use undo password to restore the default.
password [ { hash | simple } string ]
undo password
A device management user does not have a password and can pass authentication after entering the correct username and passing attribute checks.
Device management user view
hash: Specifies a password encrypted by the hash algorithm.
simple: Specifies a password in plaintext form. For security purposes, the password specified in plaintext form will be stored in hashed form.
string: Specifies the password string. This argument is case sensitive. The hashed form of the password is a string of 1 to 110 characters. The plaintext form of the password is a string of 1 to 63 characters. Supported characters are all visible characters, including the question mark (?). Visible characters correspond to the ASCII codes in the range of 32 to 126. To contain a quotation mark (") or back slash (\) in the password, you must add an escape character (\) before the quotation mark or back slash. That is, enter \" to represent a quotation mark and enter \\ to represent a back slash. To contain spaces in the password, you must enclose the entire password string into a pair of quotation marks ("").
If you do not specify any parameters, you enter the interactive mode to set a plaintext password.
A device management user for which no password is specified can pass authentication after entering the correct username and passing attribute checks. To enhance security, configure a password for each device management user.
When global password control is enabled, the device handles passwords of device management users as follows:
· All passwords in the history records are saved in hashed form.
· If a user changes its own password in plaintext form, the system requests the user to enter the current plaintext password. The new password must be different from all passwords in the history records and the current password. In addition, the new password must have a minimum of four characters different from the current password.
· If a user changes the password for another user in plaintext form, the new password must be different from the latter user's all passwords in the history records and current password.
· If a user deletes its own password, the system requests the user to enter the current plaintext password.
· Except the above listed situations, the system does not request a user to enter the current plaintext password or compare the new password with passwords in the history records and the current password.
# Set the password to 123456TESTplat&! in plaintext form for device management user user1.
# Configure the password in interactive mode for device management user test.
[Sysname-luser-manage-test] password
Password:
Confirm:
display local-user
password (network access user view)
Use password to configure a password for a network access user.
undo password
A network access user does not have a password and can pass authentication after entering the correct username and passing attribute checks.
As a best practice to enhance security, configure a password for each network access user.
If password control is globally enabled for network access users by using the password-control enable network-class command, the device neither displays local user passwords nor retains them in the running configuration.
# Set the password to 123456TESTuser&! in plaintext form for network access user user1.
[Sysname] local-user user1 class network
[Sysname-luser-network-user1] password simple 123456TESTuser&!
display local-user
password (user view)
Use password to configure a password for a device management user in interactive mode.
password
Use this command to configure a password in interactive mode for an existing device management user without entering the user's local user view.
The password is a plaintext string of 1 to 63 characters.
# Configure a password for user test.
<Sysname> password
Change password for user: test
Old password:
Enter new password:
Confirm:
phone
Use phone to specify the phone number of a local guest.
Use undo phone to restore the default.
phone phone-number
undo phone
No phone number is specified for a local guest.
Local guest view
phone-number: Specifies the phone number, a string of 1 to 32 characters.
# Specify the phone number as 13813723920 for local guest abc.
[Sysname-luser-network(guest)-abc] phone 13813723920
display local-user
Use reset local-guest waiting-approval to clear pending registration requests for local guests.
reset local-guest waiting-approval [ user-name user-name ]
user-name user-name: Specifies a local guest by the username, a string of 1 to 80 characters. If you do not specify a local guest, this command clears information about all registration requests for all local guests. The username of the specified local guest can be a pure username or contain a domain name (in the format of pure-username@domain-name).
# Clear information about all registration requests for local guests.
<Sysname> reset local-guest waiting-approval
Use service-type to specify the service types that a local user can use.
Use undo service-type to remove service types configured for a local user.
service-type { ftp | ike | ipoe | { http | https | ssh | telnet | terminal } * | portal | sslvpn }
undo service-type { ftp | ike | ipoe | { http | https | ssh | telnet | terminal } * | portal | sslvpn }
A local user is not authorized to use any service.
Local user view
ftp: Authorizes the user to use the FTP service. The authorized directory can be modified by using the authorization-attribute work-directory command.
http: Authorizes the user to use the HTTP service.
https: Authorizes the user to use the HTTPS service.
ike: Authorizes the user to use the IKE extended authentication service.
ipoe: Authorizes the user to use the IPoE service.
ssh: Authorizes the user to use the SSH service.
telnet: Authorizes the user to use the Telnet service.
terminal: Authorizes the user to use the terminal service and log in from a console port.
portal: Authorizes the user to use the portal service.
sslvpn: Authorizes the user to use the SSL VPN service.
You can assign multiple service types to a user.
# Authorize device management user user1 to use the Telnet and FTP services.
[Sysname-luser-manage-user1] service-type telnet
[Sysname-luser-manage-user1] service-type ftp
display local-user
sponsor-department
Use sponsor-department to specify the department of the guest sponsor for a local guest.
Use undo sponsor-department to restore the default.
sponsor-department department-string
No department is specified for the guest sponsor of a local guest.
Local guest view
department-string: Specifies the department name, a case-sensitive string of 1 to 127 characters.
# Specify the department as test for the guest sponsor of local guest abc.
[Sysname-luser-network(guest)-abc] sponsor-department test
display local-user
sponsor-email
Use sponsor-email to specify the email address of the guest sponsor for a local guest.
Use undo sponsor-email to restore the default.
sponsor-email email-string
undo sponsor-email
No email address is specified for the guest sponsor.
Local guest view
email-string: Specifies the email address, a case-sensitive string of 1 to 255 characters. The address must comply with RFC 822.
# Specify the email address as [email protected] for the guest sponsor of local guest abc.
[Sysname-luser-network(guest)-abc] sponsor-email [email protected]
display local-user
sponsor-full-name
Use sponsor-full-name to specify the guest sponsor name for a local guest.
Use undo sponsor-full-name to restore the default.
sponsor-full-name name-string
No guest sponsor name is specified for a local guest.
Local guest view
name-string: Specifies the guest sponsor name, a case-sensitive string of 1 to 255 characters.
# Specify the guest sponsor name as Sam Li for local guest abc.
[Sysname-luser-network(guest)-abc] sponsor-full-name Sam Li
display local-user
state (local user view)
Use state to set the status of a local user.
Use undo state to restore the default.
undo state
A local user is in active state.
Local user view
active: Places the local user in active state to allow the local user to request network services.
block: Places the local user in blocked state to prevent the local user from requesting network services.
# Place device management user user1 in blocked state.
[Sysname-luser-manage-user1] state block
display local-user
user-group
Use user-group to create a user group and enter its view, or enter the view of an existing user group.
Use undo user-group to delete a user group.
user-group group-name
undo user-group group-name
A system-defined user group exists. The group name is system.
A user group consists of a group of local users and has a set of local user attributes. You can configure local user attributes for a user group to implement centralized management of user attributes for the local users in the group.
A user group that has local users cannot be deleted.
You can modify settings for the system-defined user group named system, but you cannot delete the user group.
# Create a user group named abc and enter user group view.
display user-group
user-isolation
Use user-isolation to configure user group-based user isolation.
Use undo user-isolation to remove the user group-based user isolation configuration.
user-isolation { intra-group | inter-group } *
undo user-isolation { intra-group | inter-group } *
User group-based user isolation is not configured.
User group view
intra-group: Specifies intra-group isolation. In this mode, users in the group cannot reach each other at Layer 2 or Layer 3.
inter-group: Specifies inter-group isolation. In this mode, users in the group cannot communicate with users in any other groups.
To isolate wireless users by user group, you can assign a user group to each user, and configure user group isolation.
When you configure user group-based user isolation, follow these restrictions and guidelines:
· This feature takes effect only on unicast packets in wireless centralized forwarding scenarios.
· If wireless users exist in different service VLANs, you must deploy the gateway on the AC for user isolation to take effect.
If a user in a user group has obtained user isolation configuration, do not delete or modify the group as a best practice. If you do so, user isolation errors might occur.
# Configure inter-group isolation for user group test.
[Sysname] user-group test
[Sysname-ugroup-test] user-isolation inter-group
display user-group
validity-datetime
Use validity-datetime to specify the validity period for a network access user.
Use undo validity-datetime to restore the default.
In network access user view:
validity-datetime { from start-date start-time to expiration-date expiration-time | from start-date start-time | to expiration-date expiration-time }
In local guest view:
validity-datetime from start-date start-time to expiration-date expiration-time
The validity period for a local user does not expire.
Local guest view
from: Specifies the validity start date and time for the user. If you do not specify this option, the command defines only the expiration date and time of the user.
start-date: Specifies the date on which the user becomes effective. The date is in the format of MM/DD/YYYY or YYYY/MM/DD. The value range for the MM argument is 1 to 12. The value range for the DD argument varies with the specified month. The value range for the YYYY argument is 2000 to 2035.
start-time: Specifies the time on the day when the user becomes effective. The time is in the format of hh:mm:ss. The value range for the hh argument is 0 to 23. The value range for the mm and ss arguments is 0 to 59. The mm and ss arguments are optional. For example, enter 1 to indicate 1:00:00. A value of 0 indicates 00:00:00.
to: Specifies the expiration date and time for the user. If you do not specify this option, the command defines only the validity start date and time of the user.
Expired network access user accounts cannot be used for authentication.
When both from and to options are specified, the expiration date and time must be later than the validity start date and time.
When only the from option is specified, the user is valid since the specified date and time. When only the to option is specified, the user is valid until the specified date and time.
# Specify the validity period for network access user 123.
[Sysname-luser-network-123] validity-datetime from 2020/01/01 00:00:00 to 2020/02/02 12:00:00
display local-user
Local BYOD authorization
byod authorization
Use byod authorization to configure authorization attributes for a type of BYOD endpoints in a user group.
Use undo byod authorization to delete the authorization attributes for a type of BYOD endpoints in a user group.
byod authorization device-type type-name { acl acl-number | idle-cut minutes | ip-pool ipv4-pool-name | ipv6-pool ipv6-pool-name | session-timeout minutes | url url-string | user-profile profile-name | vlan vlan-id } *
undo byod authorization device-type type-name { acl | idle-cut | ip-pool | ipv6-pool | session-timeout | url | user-profile | vlan } *
No authorization attributes are configured for any type of BYOD endpoints in a user group.
User group view
device-type type-name: Specifies an endpoint type. The type-name argument is a case-insensitive string of 1 to 127 characters.
acl acl-number: Specifies an authorization ACL. The value range for the acl-number argument varies by device model. After passing authentication, a local user can access the network resources specified by this ACL.
idle-cut minutes: Specifies an idle timeout period in minutes. The value range for the minutes argument is 1 to 120. An online user is logged out if its idle period exceeds the specified idle timeout period.
ip-pool ipv4-pool-name: Specifies an IPv4 pool. The ipv4-pool-name argument is a case-insensitive string of 1 to 31 characters. After passing authentication, a local user can obtain an IP address from the pool.
ipv6-pool ipv6-pool-name: Specifies an IPv6 pool. The ipv6-pool-name argument is a case-insensitive string of 1 to 63 characters. After passing authentication, a local user can obtain an IP address from the pool.
session-timeout minutes: Specifies the session timeout timer for the user, in minutes. The value range for the minutes argument is 1 to 1440. The device logs off the user after the timer expires.
url url-string: Specifies the URL to which a user is redirected after it passes authentication. The url-string argument is a case-sensitive string of 1 to 255 characters.
user-profile profile-name: Specifies an authorization user profile by the name. The profile-name argument is a case-sensitive string of 1 to 31 characters. Valid characters include letters, digits, underscores (_), minus signs (-), and dots (.). The string can begin with a letter or digit, but it cannot be all digits. The user profile restricts the behavior of authenticated users. For more information, see User Access and Authentication Configuration Guide.
vlan vlan-id: Specifies an authorized VLAN. The value range for the vlan-id argument is 1 to 4094. After passing authentication and being authorized a VLAN, a local user can access only the resources in this VLAN.
Configure authorization attributes according to the application environments and purposes. Support for authorization attributes depends on the service types of users.
For portal users, only the following authorization attributes are effective: acl, idle-cut, ip-pool, ipv6-pool, session-timeout, and user-profile.
For MAC authentication or 802.1X users, only the following authorization attributes are effective: acl, idle-cut, session-timeout, url, user-profile, and vlan.
For other types of local users, no authorization attribute takes effect.
For a user, an endpoint type-specific authorization attribute takes precedence over the same common authorization attribute specified for the user. A common authorization attribute specified for the user takes precedence over the same common authorization attribute specified for the user group to which the user belongs. To specify common authorization attributes, use the authorization-attribute command.
When you specify an authorization ACL, the following restrictions apply: The authorization ACL is invalid if it does not exist or does not contain rules. If strict checking on authorization ACLs is enabled for portal users in this situation, portal users will be forced offline.
# Specify VLAN 3 as the authorization VLAN for endpoints of the iPhone 6 type in user group abc.
[Sysname] user-group abc
[Sysname-ugroup-abc] byod authorization device-type iphone6 vlan 3
display byod rule
display local-user
display user-group
byod rule
Use byod rule to configure a BYOD endpoint identification rule.
Use undo byod rule to delete a BYOD endpoint identification rule.
byod rule { dhcp-option option-string | http-user-agent agent-string | mac-address mac-address mask mac-mask } device-type type-name
undo byod rule { dhcp-option option-string | http-user-agent agent-string | mac-address mac-address mask mac-mask }
Predefined BYOD endpoint identification rules exist. To view predefined BYOD endpoint identification rules, use the display byod rule command.
dhcp-option option-string: Specifies the DHCP Option 55 fingerprint. The option-string argument is a case-insensitive string of 1 to 255 characters. If the fingerprint contains spaces, you must enclose the fingerprint into a pair of quotation marks. For example, "Microsoft Windows 8".
http-user-agent agent-string: Specifies the HTTP user agent fingerprint. The agent-string argument is a case-insensitive string of 1 to 255 characters. If the fingerprint contains spaces, you must enclose the fingerprint into a pair of quotation marks. For example, "Apple iPod".
mac-address mac-address: Specifies the MAC address of an endpoint, in the H-H-H format. The address cannot be a multicast MAC address or an all-zero MAC address. You can omit the leading zeros in each section. For example, enter f-e2-1 to indicate 000f-00e2-0001.
mask mac-mask: Specifies the MAC address mask in the H-H-H format. The binary number converted from the MAC address mask must be all 1s or contain consecutive 1s and 0s. For example, fe00-0000-0000.
device-type type-name: Specifies an endpoint type, a case-insensitive string of 1 to 127 characters.
A BYOD endpoint identification rule defines the mapping between an endpoint type and a fingerprint string. The device obtains fingerprint information from the authentication request of an endpoint, and matches the fingerprint with the rules for the associated endpoint type.
A fingerprint string can match only one endpoint type. However, an endpoint type can be associated with multiple fingerprint strings.
The device matches fingerprint information for an endpoint in the following order:
1. DHCP Option 55 fingerprint.
2. HTTP user agent fingerprint.
3. MAC address fingerprint.
# Specify a rule to identify BYOD endpoints containing DHCP Option 55 fingerprint di2ns0ns as the iPhone 6 type.
[Sysname] byod rule dhcp-option di2ns0ns device-type iphone6
byod authorization
display byod rule
byod rule-order
Use byod rule-order to specify the types of BYOD endpoint identification rules supported by the device and their priority order.
Use undo byod rule-order to restore the default.
byod rule-order { dhcp-option | http-user-agent | mac-address } *
The device uses the following types of BYOD endpoint identification rules to identify an endpoint type and their match priority order is as follows:
1. DHCP Option 55-based rules.
2. HTTP user agent-based rules.
3. MAC address-based rules.
dhcp-option: Specifies the DHCP Option 55-based rules.
http-user-agent: Specifies the HTTP user agent-based rules.
mac-address: Specifies the MAC address-based rules.
The type of BYOD endpoint identification rules not specified by this command will not be used for endpoint identification.
The order of the keywords determines the priority order of the BYOD endpoint identification rule types. For example, if you configure the byod rule-order mac-address http-user-agent command, the device only uses the MAC address-based and HTTP user agent-based rules to identify an endpoint type. The MAC address-based rules take precedence over the HTTP user agent-based rules.
# Specify the priority order of BYOD endpoint identification rules as MAC address-based rules, HTTP user agent-based rules, and DHCP Option 55-based rules.
[Sysname] byod rule-order mac-address http-user-agent dhcp-option
byod rule
display byod rule
Use display byod rule to display BYOD endpoint identification rules.
display byod rule { dhcp-option [ option-string ] | http-user-agent [ agent-string ] | mac-address [ mac-address ] }
dhcp-option: Specifies identification rules based on DHCP Option 55 fingerprints.
option-string: Specifies a DHCP Option 55 fingerprint, a case-insensitive string of 1 to 255 characters. If you do not specify this argument, this command displays all identification rules based on DHCP Option 55 fingerprints.
http-user-agent: Specifies identification rules based on HTTP user agent fingerprints.
agent-string: Specifies an HTTP user agent fingerprint, a case-insensitive string of 1 to 255 characters. If you do not specify this argument, this command displays all identification rules based on HTTP user agent fingerprints.
mac-address: Specifies identification rules based on MAC addresses.
mac-address: Specifies the MAC address of an endpoint, in the H-H-H format. The address cannot be a multicast MAC address or an all-zero MAC address. You can omit the leading zeros in each section. For example, enter f-e2-1 to indicate 000f-00e2-0001. If you do not specify this argument, this command displays all identification rules based on MAC addresses.
# Display all identification rules based on DHCP Option 55 fingerprints.
<Sysname> display byod rule dhcp-option
Total 110 DHCP option rules matched.
DHCP option: 1
Device type: Defy
DHCP option: 1,
Device type: Galaxy Ace2 X
DHCP option: 1,121,33,3,6,12,15,26,28,51,54,58,59,119,252
Device type: Chrome OS
# Display all identification rules based on HTTP user agent fingerprints.
<Sysname> display byod rule http-user-agent
Total 9534 HTTP user agent rules matched.
HTTP user agent: ##_MAX 4G 5.0 _T-Mobile_4.2.2_android_en_5.0.4428_DID999
Device type: Generic Android
HTTP user agent: ##_SM-G900V_Network Extender_4.4.4_android_en_5.0.4402_VZW007
# Display all identification rules based on MAC addresses.
<Sysname> display byod rule mac-address
Total 1104 MAC rules matched.
MAC address: 0000-4600-0000 MAC mask: ffff-ff00-0000
Device type: OnePlus One
MAC address: 0001-3600-0000 MAC mask: ffff-ff00-0000
Table 16 Command output
Total n DHCP option rules matched. |
Number of DHCP Option 55-based BYOD endpoint identification rules. |
Total n HTTP user agent rules matched. |
Number of HTTP user agent-based BYOD endpoint identification rules. |
Total n MAC rules matched. |
Number of MAC address-based BYOD endpoint identification rules. |
DHCP option |
DHCP Option 55 fingerprint. |
HTTP user agent |
HTTP user agent fingerprint. |
MAC mask |
MAC address mask. |
Device type |
BYOD endpoint type. |
display byod rule-order
Use display byod rule-order to display BYOD endpoint identification rule types supported by the device and their priority order.
# Display BYOD endpoint identification rule types supported by the device and their priority order.
<Sysname> display byod rule-order
BYOD rule matching order: mac-address http-user-agent dhcp-option
byod rule-order
RADIUS commands
aaa device-id
Use aaa device-id to configure the device ID.
Use undo aaa device-id to restore the default.
aaa device-id device-id
undo aaa device-id
The device ID is 0.
device-id: Specifies a device ID in the range of 1 to 255.
RADIUS uses the value of the Acct-Session-ID attribute as the accounting ID for a user. The device generates an Acct-Session-ID value that includes the device ID for each online user.
If you modify the device ID, the new device ID does not take effect on users that have been online during the change.
# Configure the device ID as 1.
[Sysname] aaa device-id 1
accounting-on enable
Use accounting-on enable to configure the accounting-on feature.
Use undo accounting-on enable to disable the accounting-on feature.
accounting-on enable [ interval interval | send send-times ] *
The accounting-on feature is disabled.
RADIUS scheme view
interval interval: Specifies the time interval for retransmitting an accounting-on packet in seconds. The value range for the interval argument is 1 to 15, and the default setting is 3.
send send-times: Specifies the maximum number of accounting-on packet transmission attempts. The value range for the send-times argument is 1 to 255, and the default setting is 50.
The accounting-on feature enables the device to automatically send an accounting-on packet to the RADIUS server after a device reboot. Upon receiving the accounting-on packet, the RADIUS server logs out all online users so they can log in again through the device.
Execute the save command to ensure that the accounting-on enable command takes effect at the next device reboot. For information about the save command, see Fundamentals Command Reference.
Parameters set by using the accounting-on enable command take effect immediately.
# Enable the accounting-on feature for RADIUS scheme radius1, and set the retransmission interval to 5 seconds and the transmission attempts to 15.
[Sysname] radius scheme radius1
[Sysname-radius-radius1] accounting-on enable interval 5 send 15
display radius scheme
attribute 15 check-mode
Use attribute 15 check-mode to configure the Login-Service attribute check method for SSH, FTP, and terminal users.
Use undo attribute 15 check-mode to restore the default.
attribute 15 check-mode { loose | strict }
The strict check method applies for SSH, FTP, and terminal users.
RADIUS scheme view
loose: Matches the standard Login-Service attribute value 0 for SSH, FTP, and terminal services.
strict: Matches Login-Service attribute values 50, 51, and 52 for SSH, FTP, and terminal services, respectively.
Use the loose check method only when the server does not issue Login-Service attribute values 50, 51, and 52 for SSH, FTP, and terminal users.
# Configure the Login-Service attribute check method as loose for SSH, FTP, and terminal users in RADIUS scheme radius1.
[Sysname-radius-radius1] attribute 15 check-mode loose
attribute 25 car
Use attribute 25 car to configure the device to interpret the RADIUS class attribute (attribute 25) as CAR parameters.
Use undo attribute 25 car to restore the default.
attribute 25 car
The RADIUS class attribute is not interpreted as CAR parameters.
RADIUS scheme view
Configure the device to interpret the RADIUS class attribute if the RADIUS server uses the attribute to deliver CAR parameters for user-based traffic monitoring and control.
The device can interpret the RADIUS class attribute only in the format of string1string2string3string4 as CAR parameters. Each string contains eight characters and each character must be a digit from 0 to 9.
After the device interprets the RADIUS class attribute sent by a RADIUS server as CAR parameters, it carries the interpreted CAR parameters in the subsequent accounting packets sent to that server instead of carrying the original class attribute.
# In RADIUS scheme radius1, configure the device to interpret the RADIUS class attribute as CAR parameters.
[Sysname-radius-radius1] attribute 25 car
attribute 30 mac-format
Use attribute 30 mac-format to configure the format of the MAC address in the RADIUS Called-Station-Id attribute.
Use undo attribute 30 mac-format to restore the default.
attribute 30 mac-format section { one | { six | three } separator separator-character } { lowercase | uppercase }
The MAC address in the RADIUS Called-Station-Id attribute is in the format of HH-HH-HH-HH-HH-HH. The MAC address is separated by hyphens (-) into six sections with letters in upper case.
RADIUS scheme view
section: Specifies the number of sections that a MAC address contains.
one: Specifies the one-section format HHHHHHHHHHHH.
six: Specifies the six-section format HH-HH-HH-HH-HH-HH.
three: Specifies the three-section format HHHH-HHHH-HHHH.
separator separator-character: Specifies a case-sensitive character that separates the sections.
lowercase: Specifies the letters in a MAC address to be in lower case.
uppercase: Specifies the letters in a MAC address to be in upper case.
Configure the format of the MAC address in the RADIUS Called-Station-Id attribute to meet the requirements of the RADIUS servers.
# In RADIUS scheme radius1, specify hhhhhhhhhhhh as the format of the MAC address in the RADIUS Called-Station-Id attribute.
[Sysname-radius-radius1] attribute 30 mac-format section one lowercase
attribute 31 mac-format
Use attribute 31 mac-format to configure the format of the MAC address in the RADIUS Calling-Station-Id attribute.
Use undo attribute 31 mac-format to restore the default.
attribute 31 mac-format section { one | six | three } separator separator-character { lowercase | uppercase }
The MAC address in the RADIUS Calling-Station-Id attribute (attribute 31) is in the format of HH-HH-HH-HH-HH-HH. The MAC address is separated by hyphens (-) into six sections with letters in upper case.
RADIUS scheme view
Configure the format of the MAC address in the RADIUS Calling-Station-Id attribute to meet the requirements of the RADIUS servers.
# In RADIUS scheme radius1, specify hh:hh:hh:hh:hh:hh as the format of the MAC address in the RADIUS Calling-Station-Id attribute.
[Sysname-radius-radius1] attribute 31 mac-format section six separator : lowercase
attribute convert (RADIUS DAS view)
Use attribute convert to configure a RADIUS attribute conversion rule.
Use undo attribute convert to delete RADIUS attribute conversion rules.
attribute convert src-attr-name to dest-attr-name { { coa-ack | coa-request } * | { received | sent } * }
undo attribute convert [ src-attr-name ]
No RADIUS attribute conversion rules exist. The system processes RADIUS attributes according to the principles of the standard RADIUS protocol.
RADIUS DAS view
src-attr-name: Specifies the source RADIUS attribute by its name, a case-insensitive string of 1 to 63 characters. The attribute must be supported by the system.
dest-attr-name: Specifies the destination RADIUS attribute by its name, a case-insensitive string of 1 to 63 characters. The attribute must be supported by the system.
coa-ack: Specifies the CoA acknowledgment packets.
coa-request: Specifies the CoA request packets.
received: Specifies the received DAE packets.
sent: Specifies the sent DAE packets.
The device replaces the attribute in packets that match a RADIUS attribute conversion rule with the destination RADIUS attribute in the rule.
The conversion rules take effect only when the RADIUS attribute translation feature is enabled.
When you configure RADIUS attribute conversion rules, follow these restrictions and guidelines:
· The source and destination RADIUS attributes in a rule must use the same data type.
· The source and destination RADIUS attributes in a rule cannot use the same name.
· A source RADIUS attribute can be converted only by one criterion, packet type or direction.
· One source RADIUS attribute cannot be converted to multiple destination attributes.
If you do not specify a source RADIUS attribute, the undo attribute convert command deletes all RADIUS attribute conversion rules.
# In RADIUS DAS view, configure a RADIUS attribute conversion rule to replace the Hw-Server-String attribute in the received DAE packets with the Connect-Info attribute.
[Sysname] radius dynamic-author server
[Sysname-radius-da-server] attribute convert Hw-Server-String to Connect-Info received
attribute translate
attribute convert (RADIUS scheme view)
attribute convert src-attr-name to dest-attr-name { { access-accept | access-request | accounting } * | { received | sent } * }
RADIUS scheme view
access-accept: Specifies the RADIUS Access-Accept packets.
access-request: Specifies the RADIUS Access-Request packets.
accounting: Specifies the RADIUS accounting packets.
received: Specifies the received RADIUS packets.
sent: Specifies the sent RADIUS packets.
# In RADIUS scheme radius1, configure a RADIUS attribute conversion rule to replace the Hw-Server-String attribute of received RADIUS packets with the Connect-Info attribute.
[Sysname-radius-radius1] attribute convert Hw-Server-String to Connect-Info received
attribute translate
attribute reject (RADIUS DAS view)
Use attribute reject to configure a RADIUS attribute rejection rule.
Use undo attribute reject to delete RADIUS attribute rejection rules.
attribute reject attr-name { { coa-ack | coa-request } * | { received | sent } * }
undo attribute reject [ attr-name ]
No RADIUS attribute rejection rules exist.
RADIUS DAS view
attr-name: Specifies a RADIUS attribute by its name, a case-insensitive string of 1 to 63 characters. The attribute must be supported by the system.
Configure RADIUS attribute rejection rules for the following purposes:
· Delete attributes from the RADIUS packets to be sent if the destination RADIUS server does not identify the attributes.
· Ignore unwanted attributes in the RADIUS packets received from a RADIUS server.
The RADIUS attribute rejection rules take effect only when the RADIUS attribute translation feature is enabled.
A RADIUS attribute can be rejected only by one criterion, packet type or direction.
If you do not specify a RADIUS attribute, the undo attribute reject command deletes all RADIUS attribute rejection rules.
# In RADIUS DAS view, configure a RADIUS attribute rejection rule to delete the Connect-Info attribute from the DAE packets to be sent.
[Sysname-radius-da-server] attribute reject Connect-Info sent
attribute translate
attribute reject (RADIUS scheme view)
attribute reject attr-name { { access-accept | access-request | accounting } * | { received | sent } * }
RADIUS scheme view
# In RADIUS scheme radius1, configure a RADIUS attribute rejection rule to delete the Connect-Info attribute from the RADIUS packets to be sent.
[Sysname-radius-radius1] attribute reject Connect-Info sent
attribute translate
attribute remanent-volume
Use attribute remanent-volume to set the data measurement unit for the Remanent_Volume attribute.
Use undo attribute remanent-volume to restore the default.
attribute remanent-volume unit { byte | giga-byte | kilo-byte | mega-byte }
undo attribute remanent-volume unit
The data measurement unit is kilobyte for the Remanent_Volume attribute.
RADIUS scheme view
byte: Specifies the unit as byte.
giga-byte: Specifies the unit as gigabyte.
kilo-byte: Specifies the unit as kilobyte.
mega-byte: Specifies the unit as megabyte.
Make sure the measurement unit is the same as the user data measurement unit on the RADIUS server.
# In RADIUS scheme radius1, set the data measurement unit to kilobyte for the Remanent_Volume attribute.
[Sysname-radius-radius1] attribute remanent-volume unit kilo-byte
attribute translate
Use attribute translate to enable the RADIUS attribute translation feature.
Use undo attribute translate to disable the RADIUS attribute translation feature.
attribute translate
The RADIUS attribute translation feature is disabled.
RADIUS DAS view
RADIUS scheme view
To cooperate with RADIUS servers of different vendors, enable the RADIUS attribute translation feature. Configure RADIUS attribute conversion rules and rejection rules to ensure that RADIUS attributes in the packets exchanged between the device and the server are supported by both sides.
# Enable the RADIUS attribute translation feature for RADIUS scheme radius1.
[Sysname-radius-radius1] attribute translate
attribute vendor-id 2011 version
Use attribute vendor-id 2011 version to specify the version of the RADIUS servers with a vendor ID of 2011.
Use undo attribute vendor-id 2011 version to restore the default.
attribute vendor-id 2011 version { 1.0 | 1.1 }
The version is 1.0.
RADIUS scheme view
1.0: Specifies version 1.0.
1.1: Specifies version 1.1.
For the device to correctly interpret RADIUS attributes from the servers with a vendor ID of 2011, specify a server version the same as the actual version of the RADIUS servers.
The following table shows the differences in the way that the device interprets the vendor-specific RADIUS attributes assigned by different versions of RADIUS servers with vendor ID 2011.
RADIUS attribute |
RADIUS server with version 1.0 |
RADIUS server with version 1.1 |
HW_ARRT_26_1 |
Upstream peak rate |
Upstream burst size |
HW_ARRT_26_2 |
Upstream average rate |
HW_ARRT_26_3 |
N/A |
HW_ARRT_26_4 |
Downstream peak rate |
Downstream burst size |
HW_ARRT_26_5 |
Downstream average rate |
HW_ARRT_26_6 |
N/A |
# In RADIUS scheme radius1, specify the version of the RADIUS servers with a vendor ID of 2011 as version 1.1.
[Sysname-radius-radius1] attribute vendor-id 2011 version 1.1
client
client
Use client to specify a RADIUS DAC.
Use undo client to remove a RADIUS DAC.
client { ip ipv4-address | ipv6 ipv6-address } { key { cipher | simple } string | vendor-id 2011 version { 1.0 | 1.1 } }
undo client { ip ipv4-address | ipv6 ipv6-address }
No RADIUS DACs are specified.
RADIUS DAS view
ip ipv4-address: Specifies a DAC by its IPv4 address.
ipv6 ipv6-address: Specifies a DAC by its IPv6 address.
key: Specifies the shared key for secure communication between the RADIUS DAC and server. Make sure the shared key is the same as the key configured on the RADIUS DAC. If the RADIUS DAC does not have any shared key, do not specify this option.
cipher: Specifies the key in encrypted form.
simple: Specifies the key in plaintext form. For security purposes, the key specified in plaintext form will be stored in encrypted form.
string: Specifies the key. This argument is case sensitive. The encrypted form of the key is a string of 1 to 117 characters. The plaintext form of the key is a string of 1 to 64 characters.
vendor-id 2011: Specifies the vendor-ID of the DAC as 2011.
version: Specifies the version of the DAC.
1.0: Specifies the DAC version as version 1.0.
1.1: Specifies the DAC version as version 1.1.
With the RADIUS DAS feature, the device listens to the default or specified UDP port to receive DAE requests from the specified DACs. The device processes the requests and sends DAE responses to the DACs.
The device discards any DAE packets sent from DACs that are not specified for the DAS.
You can execute the client command multiple times to specify multiple DACs for the DAS.
To work with a DAC with vendor-ID 2011 and version 1.0, you do not need to specify the vendor-ID or version attribute. To work with a DAC with vendor-ID 2011 and version 1.1, you must specify the vendor-id 2011 version 1.1 keywords.
# Specify the DAC as 10.110.1.2. Set the shared key to 123456 in plaintext form for secure communication between the DAS and DAC.
[Sysname-radius-da-server] client ip 10.110.1.2 key simple 123456
port
dae-loose-check enable
Use dae-loose-check enable to enable DAE loose check.
Use undo dae-loose-check enable to disable DAE loose check.
DAE loose check is disabled. The device checks both the user identification information and device identification information in DAE requests.
RADIUS DAS view
The DAE loose check feature requires the DAS to check only part of the user identification information in a DAE request and not to check the device identification information.
As a best practice to avoid unnecessary drop of DAE requests, enable this feature when the user and device identification information on DACs are inconsistent with those on the DAS.
# Enable DAE loose check.
[Sysname-radius-da-server] dae-loose-check enable
data-flow-format (RADIUS scheme view)
Use data-flow-format to set the data flow and packet measurement units for traffic statistics.
Use undo data-flow-format to restore the default.
data-flow-format { data { byte | giga-byte | kilo-byte | mega-byte } | packet { giga-packet | kilo-packet | mega-packet | one-packet } } *
undo data-flow-format { data | packet }
Traffic is counted in bytes and packets.
RADIUS scheme view
data: Specifies the unit for data flows.
packet: Specifies the unit for data packets.
giga-packet: Specifies the unit as giga-packet.
kilo-packet: Specifies the unit as kilo-packet.
mega-packet: Specifies the unit as mega-packet.
one-packet: Specifies the unit as one-packet.
The data flow and packet measurement units for traffic statistics must be the same as configured on the RADIUS accounting servers. Otherwise, accounting results might be incorrect.
# In RADIUS scheme radius1, set the data flow and packet measurement units for traffic statistics to kilobyte and kilo-packet, respectively.
[Sysname-radius-radius1] data-flow-format data kilo-byte packet kilo-packet
Use display radius scheme to display RADIUS scheme configuration.
display radius scheme [ radius-scheme-name ]
radius-scheme-name: Specifies a RADIUS scheme by its name, a case-insensitive string of 1 to 32 characters. If you do not specify a RADIUS scheme, this command displays the configuration of all RADIUS schemes.
# Display the configuration of all RADIUS schemes.
<Sysname> display radius scheme
Total 1 RADIUS schemes
RADIUS scheme name: radius1
Index : 0
Primary authentication server:
Host name: Not configured
IP : 2.2.2.2 Port: 1812
VPN : Not configured
State: Active (duration: 0 weeks, 0 days, 0 hours, 0 minutes, 42 seconds)
Most recent blocked period: 2021/12/23 01:48:55 - 2021/12/23 01:49:03
Test profile: 132
Probe username: test
Probe interval: 60 minutes
Probe count : 5
Probe eap-profile: eap1
Weight: 40
Primary accounting server:
IP : 1.1.1.1 Port: 1813
Weight: 40
Second authentication server:
IP : 3.3.3.3 Port: 1812
State: Blocked
Most recent blocked period: 2021/12/23 20:33:45 - now
Test profile: Not configured
Weight: 40
Second accounting server:
IP : 3.3.3.3 Port: 1813
State: Blocked (mandatory)
Weight: 0
Private authentication server:
Most recent blocked period: 2022/03/10 01:48:55 - 2022/03/10 01:49:03
Private accounting server:
Most recent blocked period: 2022/03/10 20:33:45 - now
Accounting-On function : Enabled
extended function : Disabled
retransmission times : 5
retransmission interval(seconds) : 2
Timeout Interval(seconds) : 3
Retransmission Times : 3
Retransmission Times for Accounting Update : 5
Server Quiet Period(minutes) : 5
Realtime Accounting Interval(seconds) : 22
Stop-accounting packets buffering : Enabled
Retransmission times : 500
NAS IP Address : 1.1.1.1
Local NAS IP Address : Not configured
Peer NAS IP Address : Not configured
Source IP Address : 1.1.1.1
Username format : with-domain
Data flow unit : Megabyte
Packet unit : One
Attribute 15 check-mode : Strict
Attribute 17 carry old password : Disabled
Attribute 25 : CAR
Attribute 30 format : hh:hh:hh:hh:hh:hh:SSID
Attribute 30 MAC format : hh:hh:hh:hh:hh:hh
Attribute 31 MAC format : hh:hh:hh:hh:hh:hh
Remanent-Volume threshold : 0
Attribute Remanent-Volume unit : Mega
RADIUS server version (vendor ID 2011) : 1.0
server-load-sharing : Enabled
Stop-accounting-packet send-force : Disabled
Authentication response pending limit : Not configured
Accounting response pending limit : Not configured
Username authorization : Applied
All-server-block action : Attempt the top-priority server
Attribute 218 of vendor ID 25506 : DHCP-Option 61
Format 1 (1-byte Type field)
Reauthentication server selection : Reselect
Table 17 Command output
Index |
Index number of the RADIUS scheme. |
Primary authentication server |
Information about the primary authentication server. |
Primary accounting server |
Information about the primary accounting server. |
Second authentication server |
Information about the secondary authentication server. |
Second accounting server |
Information about the secondary accounting server. |
Private authentication server |
Information about the private authentication server. |
Private accounting server |
Information about the private accounting server. |
Host name |
Host name of the server. This field displays Not configured in the following situations: · The server is not configured. · The server is specified by IP address. |
IP |
IP address of the server. This field displays Not configured in the following situations: · The server is not configured. · The server is specified by hostname, and the hostname is not resolved. |
Port |
Service port number of the server. If no port number is specified, this field displays the default port number. |
VPN |
This field is not supported in the current software version. MPLS L3VPN instance to which the server or the RADIUS scheme belongs. If no VPN instance is specified for the server, this field displays Not configured. |
State |
Status of the server: · Active—The server is in active state. · Blocked—The server is changed to blocked state automatically. · Blocked (mandatory)—The server is set to blocked state manually. |
duration |
The duration of the current active state for the server. This field is displayed only when the server is in active state. |
Most recent blocked period |
Most recent blocking start time and end time when the server stayed in blocked state. If the server still remains in blocked state, now is displayed for the end time. |
Most recent state changes |
Most recent five state changes of the server. |
Test profile |
Test profile used for RADIUS server status detection. |
Probe username |
Username used for RADIUS server status detection. |
Probe interval |
Server status probe interval, in minutes. |
Probe count |
Number of consecutive probe intervals that the device takes to determine the reachability of a RADIUS server. |
Probe eap-profile |
EAP profile specified for RADIUS server status detection. This field is not available if no EAP profile is specified in the test profile for RADIUS server status detection. |
Weight |
Weight value of the RADIUS server. |
Accounting-On function |
Whether the accounting-on feature is enabled. |
extended function |
Whether the extended accounting-on feature is enabled. |
retransmission times |
Number of accounting-on packet transmission attempts. |
retransmission interval(seconds) |
Interval at which the device retransmits accounting-on packets, in seconds. |
Timeout Interval(seconds) |
RADIUS server response timeout period, in seconds. |
Retransmission times |
Maximum number of attempts for transmitting a RADIUS packet to a single RADIUS server. |
Retransmission Times for Accounting Update |
Maximum number of accounting attempts. |
Server Quiet Period(minutes) |
Quiet period for the servers, in minutes. |
Realtime Accounting Interval(seconds) |
Interval for sending real-time accounting updates, in seconds. |
Stop-accounting packets buffering |
Whether buffering of nonresponded RADIUS stop-accounting requests is enabled. |
Maximum number of transmission attempts for individual RADIUS stop-accounting requests. |
NAS IP Address |
NAS IP address of RADIUS packets. This field displays Not configured if no NAS IP addresses are specified for RADIUS packets. |
Local NAS IP Address |
This field is not supported in the current software version. NAS IP address of RADIUS packets sent for users that access the network through DR interfaces on the local DR member device. If a source interface is specified to provide the NAS IP address, this field displays Provided by local interface xxx. This field displays Not configured if no local NAS IP address is configured. |
Peer NAS IP Address |
NAS IP address of RADIUS packets sent for users that access the network through DR interfaces on the peer DR member device. If a source interface is specified to provide the NAS IP address, this field displays Provided by peer interface xxx. This field displays Not configured if no peer NAS IP address is configured. |
Source IP address |
Source IP address for outgoing RADIUS packets. This field displays Not configured if no source IP addresses are specified. |
Username format |
Format for the usernames sent to the RADIUS server: · with-domain—Includes the domain name. · without-domain—Excludes the domain name. · keep-original—Forwards the username as the username is entered. |
Data flow unit |
Measurement unit for data flow. |
Packet unit |
Measurement unit for packets. |
Attribute 15 check-mode |
RADIUS Login-Service attribute check method for SSH, FTP, and terminal users: · Strict—Matches Login-Service attribute values 50, 51, and 52 for SSH, FTP, and terminal services, respectively. · Loose—Matches the standard Login-Service attribute value 0 for SSH, FTP, and terminal services. |
Attribute 17 carry old password |
This field is not supported in the current software version. Status of online user password change by using RADIUS attribute 17: · Enabled—Online user password change by using RADIUS attribute 17 is enabled. The device uses RADIUS attribute 17 to carry a user's old password. · Disabled—Online user password change by using RADIUS attribute 17 is disabled. |
Attribute 25 |
RADIUS attribute 25 interpretation status: · Standard—The attribute is not interpreted as CAR parameters. · CAR—The attribute is interpreted as CAR parameters. |
Attribute 30 format |
Format of the RADIUS Called-Station-Id attribute. |
Attribute 30 MAC format |
Format of the MAC address in the RADIUS Called-Station-Id attribute. |
Attribute 31 MAC format |
Format of the MAC address in the RADIUS Calling-Station-Id attribute. |
Remanent-Volume threshold |
Available data threshold. The unit for the threshold is the same as the data measurement unit for the RADIUS Remanent_Volume attribute. |
Attribute Remanent-Volume unit |
Data measurement unit for the RADIUS Remanent_Volume attribute. |
RADIUS server version (vendor ID 2011) |
Version of the RADIUS servers with a vendor ID of 2011: · 1.0. · 1.1. |
server-load-sharing |
Status of the RADIUS server load sharing feature: · Disabled—The feature is disabled. The device forwards traffic to the server selected based on primary and secondary server roles. · Enabled—The feature is enabled. The device distributes traffic among multiple servers for load sharing. |
Stop-accounting-packet send-force |
Whether the device is enabled to forcibly send stop-accounting packets when users for which no start-accounting packets are sent go offline. |
Authentication response pending limit |
Maximum number of pending authentication requests (requests for which no responses are received from the authentication server). If the maximum number of pending authentication requests is not set, this field displays Not configured. |
Accounting response pending limit |
Maximum number of pending accounting requests (requests for which no responses are received from the accounting server). If the maximum number of pending accounting requests is not set, this field displays Not configured. |
Username authorization |
Whether to allow the device to use the server-assigned usernames for AAA processes subsequent to authentication: · Applied—The device uses the server-assigned usernames for AAA processes subsequent to authentication. · Not applied—The device uses the usernames used in authentication for AAA processes subsequent to authentication. |
All-server-block action |
Action to take for AAA requests when all servers in the scheme are blocked: · Attempt the top-priority server. · Skip all servers in the scheme. |
Attribute 218 vendor ID 25506 |
DHCP options encapsulated in subattribute 218 of vendor 25506 in RADIUS packets and the encapsulation format. · Format 1 (1-byte Type field)—The Type field of the encapsulated TLV is 1 byte long. Use this format when the device cooperates with most RADIUS servers. · Format 2 (2-byte Type field)—The Type field of the encapsulated TLV is 2 bytes long. Use this format when the device cooperates with HUAWEI RADIUS servers. This field is not displayed if the device is not configured to add subattribute 218 of vendor 25506 in RADIUS packets. |
Reauthentication server selection |
RADIUS server selection mode in reauthentication: · Inherit—The device uses the RADIUS server that performed authentication for a user to reauthenticate that user. · Reselect—The device searches for a reachable RADIUS server to reauthenticate a user. |
display radius server-load statistics
Use display radius server-load statistics to display authentication and accounting load statistics for all RADIUS servers.
This command displays the following statistics:
· Last-5-second statistics—Total number of authentication or accounting requests sent to each RADIUS server in the last 5 seconds.
· History statistics—Total number of authentication or accounting requests sent to each RADIUS server since the device starts up.
The device collects the statistics as follows:
· Last-5-second statistics—From the device sends the first authentication or accounting request to a RADIUS server, the device counts the number of authentication or accounting requests sent to the server every 5 seconds. Then, the device updates the last-5-second authentication and accounting statistics for the server.
· History statistics—The device increases the history statistics for a RADIUS server by 1 each time it sends an authentication or accounting request to the server. The device does not decrease the history statistics even though users go offline or the server fails to response to a request within the timeout time.
Based on the statistics, you can adjust the load on RADIUS servers by changing the sequence in which the servers are configured or the weight values of the servers.
This command displays statistics only for RADIUS servers whose IP addresses are available or can be resolved from their hostnames.
The device deletes all statistics for a RADIUS server if the server is removed from a RADIUS scheme or the server's IP address or service port number changes.
If an active/standby switchover occurs, the last-5-second statistics are deleted. However, the history statistics are not deleted. The history statistics might be inaccurate.
If the device reboots, both the last-5-seconds statistics and the history statistics are deleted.
# Display authentication and accounting load statistics for all RADIUS servers.
<Sysname> display radius server-load statistics
Authentication servers: 2
IP VPN Port Last 5 sec History
1.1.1.1 N/A 1812 20 100
2.2.2.2 N/A 1812 0 20
Accounting servers: 2
1.1.1.1 N/A 1813 20 100
2.2.2.2 N/A 1813 0 20
Table 18 Command output
Authentication servers |
Total number of RADIUS authentication servers. |
Accounting servers |
Total number of RADIUS accounting servers. |
IP |
IP address of a RADIUS server. |
VPN |
This field is not supported in the current software version. MPLS L3VPN instance to which the RADIUS server belongs. This field displays N/A if no VPN instance is specified for the server. |
Port |
Service port number of the RADIUS server. |
Last 5 sec |
Total number of RADIUS authentication or accounting requests sent to the RADIUS server within the last 5 seconds. |
History |
Total number of RADIUS authentication or accounting requests sent to the RADIUS server since the device starts up. |
reset radius server-load statistics
display radius statistics
Use display radius statistics to display RADIUS packet statistics.
# Display RADIUS packet statistics.
<Sysname> display radius statistics
Auth. Acct. SessCtrl.
Request Packet: 0 0 0
Retry Packet: 0 0 -
Timeout Packet: 0 0 -
Access Challenge: 0 - -
Account Start: - 0 -
Account Update: - 0 -
Account Stop: - 0 -
Terminate Request: - - 0
Set Policy: - - 0
Packet With Response: 0 0 0
Packet Without Response: 0 0 -
Access Rejects: 0 - -
Dropped Packet: 0 0 0
Check Failures: 0 0 0
Table 19 Command output
Auth. |
Authentication packets. |
Acct. |
Accounting packets. |
SessCtrl. |
Session-control packets. |
Request Packet |
Number of request packets. |
Retry Packet |
Number of retransmitted request packets. |
Timeout Packet |
Number of request packets timed out. |
Access Challenge |
Number of access challenge packets. |
Account Start |
Number of start-accounting packets. |
Account Update |
Number of accounting update packets. |
Account Stop |
Number of stop-accounting packets. |
Terminate Request |
Number of packets for logging off users forcibly. |
Set Policy |
Number of packets for updating user authorization information. |
Packet With Response |
Number of packets for which responses were received. |
Packet Without Response |
Number of packets for which no responses were received. |
Access Rejects |
Number of Access-Reject packets. |
Dropped Packet |
Number of discarded packets. |
Check Failures |
Number of packets with checksum errors. |
reset radius statistics
display stop-accounting-buffer (for RADIUS)
Use display stop-accounting-buffer to display information about buffered RADIUS stop-accounting requests to which no responses have been received.
display stop-accounting-buffer { radius-scheme radius-scheme-name | session-id session-id | time-range start-time end-time | user-name user-name }
radius-scheme radius-scheme-name: Specifies a RADIUS scheme by its name, a case-insensitive string of 1 to 32 characters.
session-id session-id: Specifies a session by its ID. The session-id argument is a string of 1 to 64 characters and cannot contain a letter. A session ID uniquely identifies an online user for a RADIUS scheme.
time-range start-time end-time: Specifies a time range. The start time and end time must be in the format of hh:mm:ss-mm/dd/yyyy or hh:mm:ss-yyyy/mm/dd.
user-name user-name: Specifies a user by its name, a case-sensitive string of 1 to 255 characters. Whether the user-name argument should include the domain name depends on the setting configured by using the user-name-format command for the RADIUS scheme.
# Display information about nonresponded RADIUS stop-accounting requests buffered for user abc.
<Sysname> display stop-accounting-buffer user-name abc
Total entries: 2
Scheme Session ID Username First sending time Attempts
rad1 1000326232325010 abc 23:27:16-08/02/2020 19
aaa 1000326232326010 abc 23:33:01-08/02/2020 20
Table 20 Command output
Session ID |
Session ID, which is the value of attribute Acct-Session-Id. |
First sending time |
Time when the stop-accounting request was first sent. |
Attempts |
Number of attempts that were made to send the stop-accounting request. |
reset stop-accounting-buffer (for RADIUS)
retry
retry stop-accounting (RADIUS scheme view)
stop-accounting-buffer enable (RADIUS scheme view)
user-name-format (RADIUS scheme view)
exclude
Use exclude to exclude an attribute from RADIUS requests.
Use undo exclude to cancel the configuration of excluding an attribute from RADIUS requests.
exclude { accounting | authentication } name attribute-name
undo exclude { accounting | authentication } name attribute-name
No attributes are configured to be excluded from RADIUS requests.
RADIUS attribute test group view
accounting: Specifies RADIUS accounting requests.
authentication: Specifies RADIUS authentication requests.
name attribute-name: Specifies a RADIUS attribute by its name, a case-insensitive string of 1 to 63 characters. The specified attribute must be an attribute that RADIUS requests carry by default. Attributes that you can exclude from RADIUS authentication requests include Service-Type, Framed-Protocol, NAS-Identifier, Acct-Session-Id, and NAS-Port-Type. Attributes that you can exclude from RADIUS accounting requests include NAS-Identifier, Acct-Delay-Time, Acct-Session-Id, and Acct-Terminate-Cause.
Use this command to exclude an attribute from RADIUS requests sent during an AAA test to help troubleshoot authentication or accounting failures.
Before you exclude an attribute that is already configured to be included in RADIUS requests, you must cancel the inclusion configuration by using the undo include command.
# In RADIUS attribute test group t1, exclude Service-Type attribute from RADIUS authentication requests.
[Sysname] radius attribute-test-group t1
[Sysname-radius-attr-test-grp-t1] exclude authentication name Service-Type
include
test-aaa
include
Use include to include an attribute in RADIUS requests.
Use undo include to cancel the configuration of including an attribute in RADIUS requests.
include { accounting | authentication } { name attribute-name | [ vendor vendor-id ] code attribute-code } type { binary | date | integer | interface-id | ip | ipv6 | ipv6-prefix | octets | string } value attribute-value
undo include { accounting | authentication} { name attribute-name | [ vendor vendor-id ] code attribute-code }
No attributes are configured to be included in RADIUS authentication or accounting requests.
name attribute-name: Specifies a standard RADIUS attribute by its name, a case-insensitive string of 1 to 63 characters.
vendor vendor-id: Specifies a vendor by its ID in the range of 1 to 65535. If the attribute is a standard RADIUS attribute, do not specify this option.
code attribute-code: Specifies a RADIUS attribute by its code in the range of 1 to 255.
type: Specifies a data type for the attribute content.
binary: Binary type.
date: Date type.
integer: Integer type.
interface-id: Interface ID type.
ip: IPv4 address type.
ipv6: IPv6 address type.
ipv6-prefix: IPv6 address prefix type.
octets: Octet type.
string: String type.
value attribute-value: Specifies the value for the attribute of the data type. The value range of the attribute-value argument varies by data type.
· For the binary type, the value is a string of 1 to 256 hexadecimal characters, which represents a binary number with a maximum of 128 bytes.
· For the date type, the value range is 0 to 4294967295.
· For the integer type, the value range is 0 to 4294967295.
· For the interface ID type, the value range is 1 to ffffffffffffffff.
· For the IPv6 address prefix type, the value is in the format of prefix/prefix-length.
· For the octet type, the value is a string of 1 to 256 hexadecimal characters, which represents an octet number with a maximum of 128 bytes.
· For the string type, the value of this argument is a string of 1 to 253 characters.
Use this command to add an attribute that RADIUS requests do not carry by default to the RADIUS requests. The undo form of this command removes the attribute from the RADIUS requests.
For an attribute that RADIUS requests carry by default, you can use this command to change its value. The undo form of this command restores the attribute value to the default.
Table 20 shows the attributes that RADIUS requests carry by default.
Table 21 Attributes that RADIUS requests carry by default
Packet type |
Attributes that the type of packets carry by default |
RADIUS authentication request |
User-Name, CHAP-Password (or User-Password), CHAP-Challenge, NAS-IP-Address (or NAS-IPv6-Address), Service-Type, Framed-Protocol, NAS-Identifier, NAS-Port-Type, and Acct-Session-Id. |
RADIUS accounting request |
User-Name, Acct-Status-Type, NAS-IP-Address (or NAS-IPv6-Address), NAS-Identifier, Acct-Session-Id, Acct-Delay-Time, and Acct-Terminate-Cause. |
For the accuracy of AAA tests, the value of an attribute must be of the data type specified for that attribute.
The attribute names of standard attributes saved in the configuration file will be converted to attribute codes.
Before you include an attribute that is already configured to be excluded from RADIUS requests, you must cancel the exclusion configuration by using the undo exclude command.
Plan the RADIUS attributes to be included in RADIUS requests. Besides the attributes carried by default, the device adds the specified attributes to RADIUS packets in the order that they are specified by using the include command. Additional attributes cannot be added to a RADIUS request if the length of the RADIUS request reaches 4096 bytes.
# In RADIUS attribute test group t1, include Calling-Station-Id attribute with value 08-00-27-00-34-D8 in RADIUS authentication requests.
[Sysname-radius-attr-test-grp-t1] include authentication name Calling-Station-Id type string value 08-00-27-00-34-d8
exclude
test-aaa
include-attribute 218 vendor-id 25506
Use include-attribute 218 vendor-id 25506 to include subattribute 218 of vendor 25506 in RADIUS packets.
Use undo include-attribute 218 vendor-id 25506 to not include subattribute 218 of vendor 25506 in RADIUS packets.
Use undo include-attribute 218 vendor-id 25506 dhcp-option to restore the default.
include-attribute 218 vendor-id 25506 dhcp-option { 55 | 61 } * { format1 | format2 }
undo include-attribute 218 vendor-id 25506 [ dhcp-option ]
The device uses format 1 to encapsulate DHCP Option 61 in subattribute 218 of vendor 25506 in RADIUS packets.
RADIUS scheme view
dhcp-option: Specifies a DHCP option to be encapsulated in subattribute 218.
· 55: Specifies DHCP Option 55.
· 61: Specifies DHCP Option 61.
format1: Specifies encapsulation format 1 for the subattribute, in which the Type field is 1 byte long. Use this format when the device cooperates with most RADIUS servers.
format2: Specifies encapsulation format 2 for the subattribute, in which the Type field is 2 bytes long. Use this format when the device cooperates with HUAWEI RADIUS servers.
The RADIUS Vendor-Specific attribute (attribute 26) allows vendors to define extended attributes to implement functions that the standard RADIUS protocol does not provide. Vendor 25506 defines subattribute 218 to carry user DHCP option information.
To send user DHCP option information to RADIUS servers, perform this task to include subattribute 218 of vendor 25506 in outgoing RADIUS start-accounting and update-accounting requests.
In the current software version, only DHCP Option 55 and DHCP Option 61 can be carried in the subattribute.
You can repeat this command to encapsulate both DHCP Option 55 and DHCP Option 61 in the subattribute. The length of each option is limited to 246 bytes.
If you repeat this command multiple times with the same DHCP option specified, the most recent configuration takes effect.
# In RADIUS scheme rad, configure the device to use format 2 to encapsulate DHCP Option 55 in subattribute 218 of vendor 25506 in RADIUS packets.
[Sysname-radius-rad] include-attribute 218 vendor-id 25506 dhcp-option 55 format2
key (RADIUS scheme view)
Use key to set the shared key for secure RADIUS authentication or accounting communication.
Use undo key to delete the shared key for secure RADIUS authentication or accounting communication.
key { accounting | authentication } { cipher | simple } string
undo key { accounting | authentication }
No shared key is configured for secure RADIUS authentication or accounting communication.
RADIUS scheme view
accounting: Specifies the shared key for secure RADIUS accounting communication.
authentication: Specifies the shared key for secure RADIUS authentication communication.
The shared keys configured by using this command apply to all servers in the scheme. Make sure the settings match the shared keys configured on the RADIUS servers.
The shared keys specified for specific RADIUS servers take precedence over the shared key specified with this command.
# In RADIUS scheme radius1, set the shared key to ok in plaintext form for secure accounting communication.
[Sysname-radius-radius1] key accounting simple ok
nas-ip (RADIUS scheme view)
Use nas-ip to specify a NAS IP address for RADIUS packets.
Use undo nas-ip to remove the NAS IP address of the specified type for RADIUS packets.
nas-ip { ipv4-address | interface interface-type interface-number | ipv6 ipv6-address }
undo nas-ip [ interface | ipv6 ]
The NAS IP address of a RADIUS packet is that specified by using the radius nas-ip command in system view.
RADIUS scheme view
ipv4-address: Specifies an IPv4 address. The IP address cannot be 0.0.0.0, 255.255.255.255, a class D address, a class E address, or a loopback address.
interface interface-type interface-number: Specifies an interface by its type and number. The device uses the primary IPv4 address or the IPv6 address of the interface as the NAS IP address of an outgoing RADIUS packet.
ipv6 ipv6-address: Specifies an IPv6 address, which must be a unicast address and cannot be a loopback address or a link-local address.
Use this command to specify a NAS IP address for the NAS to carry in the NAS-IP-Address or NAS-IPv6-Address attribute in outgoing RADIUS packets. The NAS IP address must be unique for a RADIUS server to identify the NAS.
The NAS can also use the NAS IP address to match incoming RADIUS packets. For example, if the NAS receives a DAE request that contains a NAS IP address, it compares the NAS IP address in the request with the local NAS IP address. The NAS can process this request only when its NAS IP address is the same as the NAS IP address in the request.
As a best practice, specify a loopback interface address as the NAS IP address for outgoing RADIUS packets to avoid RADIUS packet loss caused by physical port errors.
You can specify the NAS IP address in both RADIUS scheme view and system view.
· The NAS IP address specified by using the nas-ip command in RADIUS scheme view applies only to the RADIUS scheme.
· The NAS IP address specified by using the radius nas-ip command in system view applies to all RADIUS schemes.
· The NAS IP address specified in RADIUS scheme view takes precedence over the NAS IP address specified in system view.
For a RADIUS scheme, the following restrictions apply:
· You can specify only one NAS IPv4 address and one NAS IPv6 address for RADIUS packets.
· You can specify only one interface to provide the NAS IP address for RADIUS packets. Make sure the route between the interface and the RADIUS server is reachable.
· The interface configuration and the IP address configuration overwrite each other.
If you do not specify the ipv6 keyword for the undo nas-ip command, the command removes the configured NAS IPv4 address for RADIUS packets.
# In RADIUS scheme radius1, specify IP address 10.1.1.1 as the NAS IPv4 address of RADIUS packets.
[Sysname-radius-radius1] nas-ip 10.1.1.1
radius nas-ip
port
Use port to specify the RADIUS DAS port.
Use undo port to restore the default.
port port-number
undo port
The RADIUS DAS port number is 3799.
RADIUS DAS view
port-number: Specifies a UDP port number in the range of 1 to 65535.
The destination port in DAE packets on the DAC must be the same as the RADIUS DAS port on the DAS.
# Enable the RADIUS DAS to listen to UDP port 3790 for DAE requests.
[Sysname-radius-da-server] port 3790
client
primary accounting (RADIUS scheme view)
Use primary accounting to specify the primary RADIUS accounting server.
Use undo primary accounting to restore the default.
primary accounting { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | weight weight-value ] *
The primary RADIUS accounting server is not specified.
RADIUS scheme view
host-name: Specifies the host name of the primary RADIUS accounting server, a case-insensitive string of 1 to 253 characters.
ipv4-address: Specifies the IPv4 address of the primary RADIUS accounting server.
ipv6 ipv6-address: Specifies the IPv6 address of the primary RADIUS accounting server.
port-number: Specifies the service port number of the primary RADIUS accounting server. The value range for the UDP port number is 1 to 65535. The default setting is 1813.
key: Specifies the shared key for secure communication with the primary RADIUS accounting server.
weight weight-value: Specifies a weight value for the RADIUS server. The value range for the weight-value argument is 0 to 100, and the default value is 0. The value 0 indicates that the RADIUS server will not be used for load sharing. This option takes effect only when the RADIUS server load sharing feature is enabled for the RADIUS scheme. A larger weight value represents a higher capacity to process accounting requests.
Make sure the port number and shared key settings of the primary RADIUS accounting server are the same as those configured on the server.
Two accounting servers specified for a scheme, primary or secondary, cannot have identical host name, IP address, and port number settings.
The shared key configured by using this command takes precedence over the shared key configured with the key accounting command.
If you modify or remove the accounting server to which the device is sending a start-accounting request, the accounting server might become unreachable. When communication with the unreachable server times out, the device performs the following operations:
· When the RADIUS server load sharing feature is disabled, the device tries to communicate with an active server that has the highest priority for accounting.
· When the RADIUS server load sharing feature is enabled, the device selects an active server for accounting based on the weight values and current user counts on the active servers.
If you remove the accounting server to which the device has sent start-accounting requests successfully for an online user, the following events occur:
· If the RADIUS server load sharing feature is disabled, the device tries to communicate with an active server that has the highest priority for subsequent accounting requests.
· If the RADIUS server load sharing feature is enabled, real-time accounting fails for that online user and the accounting result is not accurate for that online user. The reason is that the device can communicate only with the accounting server to which it has sent start-accounting requests successfully. As a result, the device cannot send real-time accounting requests or send and buffer stop-accounting requests for that online user.
# In RADIUS scheme radius1, specify the primary accounting server with IP address 10.110.1.2, UDP port number 1813, and plaintext shared key 123456TESTacct&!.
[Sysname-radius-radius1] primary accounting 10.110.1.2 1813 key simple 123456TESTacct&!
secondary accounting (RADIUS scheme view)
server-load-sharing enable
primary authentication (RADIUS scheme view)
Use primary authentication to specify the primary RADIUS authentication server.
Use undo primary authentication to restore the default.
primary authentication { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | test-profile profile-name | weight weight-value ] *
The primary RADIUS authentication server is not specified.
RADIUS scheme view
host-name: Specifies the host name of the primary RADIUS authentication server, a case-insensitive string of 1 to 253 characters.
ipv4-address: Specifies the IPv4 address of the primary RADIUS authentication server.
ipv6 ipv6-address: Specifies the IPv6 address of the primary RADIUS authentication server.
port-number: Specifies the service port number of the primary RADIUS authentication server. The value range for the UDP port number is 1 to 65535. The default setting is 1812.
key: Specifies the shared key for secure communication with the primary RADIUS authentication server.
test-profile profile-name: Specifies a test profile for detecting the RADIUS server status. The profile-name argument is a case-sensitive string of 1 to 31 characters.
weight weight-value: Specifies a weight value for the RADIUS server. The value range for the weight-value argument is 0 to 100, and the default value is 0. The value 0 indicates that the RADIUS server will not be used for load sharing. This option takes effect only when the RADIUS server load sharing feature is enabled for the RADIUS scheme. A larger weight value represents a higher capacity to process authentication requests.
Make sure the service port and shared key settings of the primary RADIUS authentication server are the same as those configured on the server.
Two authentication servers specified for a scheme, primary or secondary, cannot have identical host name, IP address, and port number settings.
The shared key configured by this command takes precedence over the shared key configured with the key authentication command.
The server status detection is triggered for the server if the specified test profile exists on the device.
If the server in use becomes unreachable after you modify or remove it during an authentication process, the device performs the following operations when communication with the server times out:
· When the RADIUS server load sharing feature is disabled, the device tries to communicate with an active server that has the highest priority for authentication.
· When the RADIUS server load sharing feature is enabled, the device selects an active server based on the weight values and current user counts on the active servers.
# In RADIUS scheme radius1, specify the primary authentication server with IP address 10.110.1.1, UDP port number 1812, and plaintext shared key 123456TESTauth&!.
[Sysname-radius-radius1] primary authentication 10.110.1.1 1812 key simple 123456TESTauth&!
radius-server test-profile
secondary authentication (RADIUS scheme view)
private accounting
Use private accounting to specify a private RADIUS accounting server.
Use undo private accounting to restore the default.
private accounting { ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string ] *
No private RADIUS accounting server is specified.
RADIUS scheme view
ipv4-address: Specifies the IPv4 address of the private RADIUS accounting server.
ipv6 ipv6-address: Specifies the IPv6 address of the private RADIUS accounting server.
port-number: Specifies the UDP service port number of the private RADIUS accounting server. The value range for the UDP port number is 1 to 65535. The default setting is 1813.
key: Specifies the shared key for secure communication with the private RADIUS accounting server.
string: Specifies the key. This string is case sensitive. The encrypted form of the key is a string of 1 to 117 characters, and the plaintext form of the key is a string of 1 to 64 characters.
This command is applicable to the scenario in which the accounting requests for users contain an accounting server address.
Operating mechanism
When the device receives an accounting request that contains an accounting server address, the device searches the applicable RADIUS scheme for that private server.
· If a match is found, the device communicates with the server for accounting. If the server does not exist or is unreachable, the accounting operation fails. The device will not try other servers in the scheme.
· If no match is found, the accounting operation fails.
An accounting request might contain an IPv4 server address, an IPv6 server address, or both.
· If the request contains an IPv4 server address and an IPv6 server address, the device preferentially exchanges information with the IPv6 server.
¡ If the IPv6 server has failed to respond before the timeout timer expires, the device tries the IPv4 server.
¡ If the IPv6 server is in blocked state, the device examines if the IPv4 server is active.
- If yes, the device communicates with the IPv4 server.
- If no, the device continues to communicate with the IPv6 server.
· If the request contains only an IPv4 or IPv6 server address, the device exchanges client information with the server at that IP address without checking its active state.
When you specify a private RADIUS server, follow these restrictions and guidelines:
· Make sure the specified UDP port number and shared key are consistent with the configuration on the server.
· In a RADIUS scheme, you can specify a maximum of 16 private accounting servers.
· You can specify a shared key when specifying a private server. If no shared key is specified, the device uses the key configured for the RADIUS scheme by using the key accounting command to communicate with the server.
# In RADIUS scheme radius1, specify the private accounting server with IP address 10.110.1.2, UDP port number 1813, and plaintext shared key 123456TESTauth&!.
[Sysname-radius-radius1] private accounting 10.110.1.2 1812 key simple 123456TESTauth&!
radius scheme
Use private authentication to specify a private RADIUS authentication server.
Use undo private authentication to restore the default.
private authentication { ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string ] *
No private RADIUS authentication server is specified.
RADIUS scheme view
ipv4-address: Specifies the IPv4 address of the private RADIUS authentication server.
ipv6 ipv6-address: Specifies the IPv6 address of the private RADIUS authentication server.
port-number: Specifies the UDP service port number of the private RADIUS authentication server. The value range for the UDP port number is 1 to 65535. The default setting is 1812.
key: Specifies the shared key for secure communication with the private RADIUS authentication server.
This command is applicable to the scenario in which the authentication requests for users contain a private authentication server address.
Operating mechanism
When the device receives an authentication request that contains an authentication server address, the device searches the applicable RADIUS scheme for that private server.
· If a match is found, the device communicates with the server for client authentication. If the server does not exist or is unreachable, the authentication operation fails. The device will not try other servers in the scheme.
· If no match is found, the client authentication operation fails.
A client authentication request might contain an IPv4 server address, an IPv6 server address, or both.
· In a RADIUS scheme, you can specify a maximum of 16 private authentication servers.
· You can specify a shared key when specifying a private server. If no shared key is specified, the device uses the key configured for the RADIUS scheme by using the key authentication command to communicate with the server.
# In RADIUS scheme radius1, specify the private authentication server with IP address 10.110.1.1, UDP port number 1812, and plaintext shared key 123456TESTauth&!.
[Sysname-radius-radius1] private authentication 10.110.1.1 1812 key simple 123456TESTauth&!
radius scheme
radius attribute extended
Use radius attribute extended to define an extended RADIUS attribute.
Use undo radius attribute extended to delete user-defined extended RADIUS attributes.
radius attribute extended attribute-name [ vendor vendor-id ] code attribute-code type { binary | date | integer | interface-id | ip | ipv6 | ipv6-prefix | octets | string }
undo radius attribute extended [ attribute-name ]
No user-defined extended RADIUS attributes exist.
attribute-name: Specifies the RADIUS attribute name, a case-insensitive string of 1 to 63 characters. The name must be unique among all RADIUS attributes, including the standard and extended RADIUS attributes.
vendor vendor-id: Specifies a vendor ID in the range of 1 to 65535. If you do not specify a vendor ID, the device processes the RADIUS attribute as a standard RADIUS attribute. Table 21 shows the vendor IDs of supported vendors.
Table 22 Supported vendors and vendor IDs
Vendor |
Vendor ID |
Vendor |
Vendor ID |
Vendor |
Vendor ID |
HUAWEI |
2011 |
H3C |
25506 |
Microsoft |
311 |
3COM |
43 |
DSL Forum |
3561 |
China Telecom |
20942 |
Wi-Fi Alliance |
40808 |
Juniper |
2636 |
CMCC |
28357 |
Cisco |
9 |
code attribute-code: Specifies the ID of the RADIUS attribute in the attribute set. The value range for the attribute-code argument is 1 to 255.
date: Date type.
octets: Octet type.
To support the proprietary RADIUS attributes of other vendors, perform the following tasks:
4. Use this command to define the attributes as extended RADIUS attributes.
5. Use the attribute convert command to map the extended RADIUS attributes to attributes supported by the system.
6. Use the attribute translate command to enable the RADIUS attribute translation feature for the mappings to take effect.
To cooperate with RADIUS servers of a third-party vendor, map attributes that cannot be identified by the server to server-supported attributes.
Two RADIUS attributes cannot have the same combination of attribute name, vendor ID, and attribute ID.
If you do not specify a RADIUS attribute name, the undo radius attribute extended command deletes all user-defined extended RADIUS attributes.
# Define a string-type extended RADIUS attribute with attribute name Owner-Password, vendor ID 122, and attribute ID 80.
[Sysname] radius attribute extended Owner-Password vendor 122 code 80 type string
attribute translate
Use radius attribute-test-group to create a RADIUS attribute test group and enter its view, or enter the view of an existing RADIUS attribute test group.
Use undo radius attribute-test-group to remove a RADIUS attribute test group.
radius attribute-test-group attr-test-group-name
undo radius attribute-test-group attr-test-group-name
No RADIUS attribute test groups exist.
attr-test-group-name: Specifies the name of a RADIUS attribute test group, a case-insensitive string of 1 to 31 characters.
A RADIUS attribute test group is a collection of RADIUS attributes that will be included in or excluded from RADIUS requests.
The system can have multiple RADIUS attribute test groups.
# Create a RADIUS attribute test group named t1 and enter its view.
exclude
include
test-aaa
radius authentication-request first
Use radius authentication-request first to preferentially process RADIUS authentication requests
Use undo radius authentication-request first to restore the default.
The device processes RADIUS requests in the sequence that the requests are initiated.
RADIUS requests include RADIUS authentication requests, RADIUS accounting-start requests, RADIUS accounting-update requests, and RADIUS accounting-stop requests.
When a large number of users go offline and then try to come online immediately, authentication might fail for these users because of authentication request timeout. To resolve this issue, configure the device to preferentially process authentication requests.
Do not perform this task if the RADIUS server identifies users by the username and does not allow repeated authentication for the same username. A violation might cause authentication failure for users that try to come online immediately after going offline.
As a best practice, do not perform this task when the device has online users.
# Configure the device to preferentially process RADIUS authentication requests.
[Sysname] radius authentication-request first
radius dscp
Use radius dscp to change the DSCP priority of RADIUS packets.
Use undo radius dscp to restore the default.
radius [ ipv6 ] dscp dscp-value
undo radius [ ipv6 ] dscp
The DSCP priority of RADIUS packets is 0.
ipv6: Specifies the IPv6 RADIUS packets. If you do not specify this keyword, the command sets the DSCP priority for the IPv4 RADIUS packets.
dscp-value: Specifies the DSCP priority of RADIUS packets, in the range of 0 to 63. A larger value represents a higher priority.
Use this command to set the DSCP priority in the ToS field of IPv4 packets or the Traffic Class field of IPv6 packets for changing their transmission priority.
# Set the DSCP priority of IPv4 RADIUS packets to 10.
[Sysname] radius dscp 10
Use radius dynamic-author server to enable the RADIUS DAS feature and enter RADIUS DAS view.
Use undo radius dynamic-author server to disable the RADIUS DAS feature.
The RADIUS DAS feature is disabled.
After you enable the RADIUS DAS feature, the device listens to the RADIUS DAS port to receive DAE packets from specified DACs. Based on the DAE packet type and contents, the device performs one of the following operations:
· Log off online users.
· Change online user authorization information.
· Shut down or reboot online users' access ports.
· Reauthenticate online users.
# Enable the RADIUS DAS feature and enter RADIUS DAS view.
client
port
radius enable
Use radius enable to enable the RADIUS service.
Use undo radius enable to disable the RADIUS service.
radius enable
undo radius enable
The RADIUS service is enabled.
By default, the RADIUS service is enabled. The device can send and receive RADIUS packets. Attackers might use RADIUS session-control and DAE ports to attack the device. To protect the device when such an attack occurs, disable the RADIUS service temporarily on the device. After the network is secure, re-enable the RADIUS service.
If settings on the RADIUS servers require modification or the RADIUS servers cannot provide services temporarily, you can temporarily disable the RADIUS service on the device.
When the RADIUS service is disabled, the device stops sending and receiving RADIUS packets. If a new user comes online, the device uses the backup authentication, authorization, or accounting method to process that user. If the device has not finished requesting authentication or accounting for a user before the RADIUS service is disabled, it uses the following rules to process that user:
· If the device has sent RADIUS authentication requests for that user to a RADIUS server, the device processes that user depending on whether it receives a response from the RADIUS server.
¡ If the device receives a response from the RADIUS server, it uses the response to determine whether that user has passed authentication. If that user has passed authentication, the device assigns authorization information to that user according to the response.
¡ If the device does not receive any response from the RADIUS server, it attempts to use the backup authentication method to authenticate that user.
· If the device has sent RADIUS start-accounting requests for that user to a RADIUS server, the device processes that user depending on whether it receives a response from the RADIUS server.
¡ If the device receives a response from the RADIUS server, it allows that user to come online. However, the device cannot send out accounting-update or stop-accounting requests to the RADIUS server. It cannot buffer the accounting requests, either. When that user goes offline, the RADIUS server cannot log off that user in time. The accounting result might be inaccurate.
¡ If the device does not receive any response from the RADIUS server, it attempts to use the backup accounting method.
Disabling the RADIUS service does not affect the RADIUS server feature of the device.
The authentication, authorization, and accounting processes undertaken by other methods are not switched to RADIUS when you re-enable the RADIUS service.
# Enable the RADIUS service.
[Sysname] radius enable
radius nas-ip
Use radius nas-ip to specify a NAS IP address for RADIUS packets.
Use undo radius nas-ip to remove the NAS IP address of the specified type for RADIUS packets.
radius nas-ip { interface interface-type interface-number | { ipv4-address | ipv6 ipv6-address } }
undo radius nas-ip { interface | { ipv4-address | ipv6 ipv6-address } }
The NAS IP address of RADIUS packets is the primary IPv4 address or the IPv6 address of the outbound interface.
ipv4-address: Specifies an IPv4 address, which must be an address of the device. The IP address cannot be 0.0.0.0, 255.255.255.255, a class D address, a class E address, or a loopback address.
ipv6 ipv6-address: Specifies an IPv6 address, which must be a unicast address of the device and cannot be a loopback address or a link-local address.
You can specify only one NAS IPv4 address and one NAS IPv6 address in system view.
You can specify only one interface to provide the NAS IP address for outgoing RADIUS packets. Make sure the route between the interface and the RADIUS server is reachable.
# Specify IP address 129.10.10.1 as the NAS IP address of RADIUS packets.
[Sysname] radius nas-ip 129.10.10.1
radius scheme
Use radius scheme to create a RADIUS scheme and enter its view, or enter the view of an existing RADIUS scheme.
Use undo radius scheme to delete a RADIUS scheme.
radius scheme radius-scheme-name
undo radius scheme radius-scheme-name
No RADIUS schemes exist.
radius-scheme-name: Specifies the RADIUS scheme name, a case-insensitive string of 1 to 32 characters.
A RADIUS scheme can be used by more than one ISP domain at the same time.
The device supports a maximum of 16 RADIUS schemes.
# Create a RADIUS scheme named radius1 and enter RADIUS scheme view.
[Sysname] radius scheme radius1
radius session-control client
Use radius session-control client to specify a RADIUS session-control client.
Use undo radius session-control client to remove the specified RADIUS session-control clients.
radius session-control client { ip ipv4-address | ipv6 ipv6-address } [ key { cipher | simple } string ]
undo radius session-control client { all | ip ipv4-address | ipv6 ipv6-address }
No RADIUS session-control clients are specified.
ip ipv4-address: Specifies a session-control client by its IPv4 address.
ipv6 ipv6-address: Specifies a session-control client by its IPv6 address.
key: Specifies the shared key for secure communication with the session-control client.
all: Specifies all session-control clients.
To verify the session-control packets sent from a RADIUS server running on IMC, specify the RADIUS server as a session-control client to the device. The device matches a session-control packet to a session-control client based on the IP address, and then uses the shared key of the matched client to validate the packet.
The device searches the session-control client settings prior to searching all RADIUS scheme settings for a server with matching settings. This process narrows the search scope for finding the matched RADIUS server.
The session-control client settings take effect only when the RADIUS session-control feature is enabled.
The session-control client settings must be the same as the corresponding settings of the RADIUS server.
You can specify multiple session-control clients on the device.
# Specify a session-control client with IP address 10.110.1.2 and shared key 12345 in plaintext form.
[Sysname] radius session-control client ip 10.110.1.2 key simple 12345
radius session-control enable
Use radius session-control enable to enable the RADIUS session-control feature.
Use undo radius session-control enable to disable the RADIUS session-control feature.
The RADIUS session-control feature is disabled.
An H3C IMC RADIUS server uses session-control packets to deliver dynamic authorization change requests or disconnection requests to the device. The session-control feature enables the device to receive the RADIUS session-control packets on UDP port 1812.
This feature must work with H3C IMC servers.
# Enable the RADIUS session-control feature.
[Sysname] radius session-control enable
radius source-ip
Use radius source-ip to specify a source IP address for outgoing RADIUS packets.
Use undo radius source-ip to remove the source IP address of the specified type for outgoing RADIUS packets.
radius source-ip { ipv4-address | ipv6 ipv6-address }
undo radius source-ip { ipv4-address | ipv6 ipv6-address }
No IP address is specified as the source IP address of outgoing RADIUS packets.
The source IP address of RADIUS packets that a NAS sends must match the IP address of the NAS that is configured on the RADIUS server. A RADIUS server identifies a NAS by its IP address. Upon receiving a RADIUS packet, a RADIUS server checks the source IP address of the packet.
· If the source IP address belongs to a managed NAS, the server processes the packet.
· If the source IP address does not belong to a managed NAS, the server drops the packet.
As a best practice to avoid RADIUS packet loss caused by physical port errors, specify a loopback interface address as the source IP address of outgoing RADIUS packets.
The device selects a source IP address for outgoing RADIUS packets in the following order:
7. The source IP address specified by using the source-ip command in RADIUS scheme view.
8. The source IP address specified by using the radius source-ip command in system view.
9. The NAS IP address specified by using the nas-ip command in RADIUS scheme view.
10. The NAS IP address specified by using the radius nas-ip command in system view.
11. The IP address of the outbound interface for the outgoing RADIUS packets.
The source IP address specified in system view applies to all RADIUS schemes.
You can specify only one source IPv4 address and one source IPv6 address in system view.
# Specify IP address 129.10.10.1 as the source IPv4 address of outgoing RADIUS packets.
[Sysname] radius source-ip 129.10.10.1
radius nas-ip
source-ip (RADIUS scheme view)
Use radius-server test-profile to configure a test profile for detecting the RADIUS server status.
Use undo radius-server test-profile to delete a RADIUS test profile.
radius-server test-profile profile-name username name [ password { cipher | simple } string ] [ interval interval ] [ probe-count count ] [ eap-profile eap-profile-name ]
undo radius-server test-profile profile-name
No RADIUS test profiles exist.
profile-name: Specifies the name of the test profile, which is a case-sensitive string of 1 to 31 characters.
username name: Specifies the username in the probe packets. The name argument is a case-sensitive string of 1 to 253 characters.
password: Specifies the user password in the probe packets. If you do not specify a user password, the device randomly generates a user password for each probe packet. As a best practice, specify a user password. RADIUS server might mistake probe packets that contain randomly generated passwords as attack packets.
string: Specifies the password. Its plaintext form is a case-sensitive string of 1 to 63 characters. Its encrypted form is a case-sensitive string of 1 to 117 characters.
interval interval: Specifies the interval for sending a probe packet, in minutes. The value range for the interval argument is 1 to 3600, and the default value is 60.
probe-count count: Specifies the number of consecutive probe intervals that the device takes to determine the reachability of a RADIUS server. The value range for the count argument is 1 to 10, and the default value is 1.
eap-profile eap-profile-name: Specifies an EAP profile by its name, a case-sensitive string of 1 to 32 characters.
The device starts detecting the status of a RADIUS server only if the test profile specified for the server exists. If you specify a nonexistent test profile for a RADIUS server, the device does not detect the status of the server until you create the test profile on the device.
To perform EAP-based status detection for a RADIUS server, you must specify a test profile that contains an EAP profile for the RADIUS server.
EAP-based detection provides more reliable detection results than simple detection. As a best practice, configure EAP-based detection on a network environment where EAP authentication is configured.
If you specify a nonexistent EAP profile in a test profile, the device performs simple detection for the RADIUS servers that use the test profile. After the EAP profile is configured, the device will start EAP-based detection at the next detection interval.
When the network is unstable, increase the value for the probe-count count option to improve accuracy of RADIUS server state information.
When the network is stable, reduce the value for the probe-count count option. This operation ensures that the device can obtain the real status of a RADIUS server in time.
When you delete a test profile, the device stops detecting the status of RADIUS servers that use the test profile.
You can execute this command multiple times to configure multiple test profiles.
# Configure a test profile named abc for RADIUS server status detection. A probe packet that uses username admin and plaintext password abc123 is sent every 10 minutes. The device takes two consecutive probe intervals to determine the reachability of a RADIUS server.
[Sysname] radius-server test-profile abc username admin password simple abc123 interval 10 probe-count 2
eap-profile
reauthentication server-select
Use reauthentication server-select to specify a RADIUS server selection mode for reauthentication.
Use undo reauthentication server-select to restore the default.
reauthentication server-select { inherit | reselect }
The inherit mode is used.
RADIUS scheme view
inherit: Uses the RADIUS server that performed authentication for reauthentication.
reselect: Reselects a RADIUS server for reauthentication.
Use this command to configure the RADIUS server selection mechanism in reauthentication. Use one of the following modes depending on the network condition:
· Inherit—The device uses the RADIUS server that performed authentication for a user to reauthenticate that user. This mode reduces the amount of time used in reauthentication. However, if the RADIUS server is unreachable, the reauthentication will fail.
· Reselect—The device searches for a reachable RADIUS server to reauthenticate a user. This mode requires more time than the inherit mode. However, this mode ensures that the device uses the optimal reachable RADIUS server for reauthentication. The following factors affect the RADIUS server selection:
¡ Server configuration in the RADIUS scheme, including the configuration order.
¡ Enabling status of the RADIUS server load sharing feature.
¡ Status of the RADIUS servers in the RADIUS scheme.
# In RADIUS scheme radius1, set the RADIUS server selection mode to reselect for reauthentication.
[Sysname-radius-radius1] reauthentication server-select reselect
display radius scheme
Use reset radius server-load statistics to clear history authentication and accounting load statistics for all RADIUS servers.
This command does not clear authentication and accounting load statistics in the last 5 seconds.
# Clear history authentication and accounting load statistics for all RADIUS servers.
<Sysname> reset radius server-load statistics
Use reset radius statistics to clear RADIUS statistics.
# Clear RADIUS statistics.
<Sysname> reset radius statistics
Use reset stop-accounting-buffer to clear buffered RADIUS stop-accounting requests to which no responses have been received.
reset stop-accounting-buffer { radius-scheme radius-scheme-name | session-id session-id | time-range start-time end-time | user-name user-name }
# Clear nonresponded RADIUS stop-accounting requests buffered for user user0001@test.
<Sysname> reset stop-accounting-buffer user-name user0001@test
# Clear nonresponded RADIUS stop-accounting requests buffered from 0:0:0 to 23:59:59 on January 31, 2020.
<Sysname> reset stop-accounting-buffer time-range 0:0:0-01/31/2020 23:59:59-01/31/2020
response-pending-limit
Use response-pending-limit to set the maximum number of pending RADIUS requests (requests for which no responses are received from the RADIUS server).
Use undo response-pending-limit to cancel the maximum number configuration for the specified type of pending RADIUS requests.
response-pending-limit { accounting | authentication } max-number
undo response-pending-limit { accounting | authentication }
The number of pending RADIUS requests is not restricted.
RADIUS scheme view
accounting: Specifies pending RADIUS accounting requests.
authentication: Specifies pending RADIUS authentication requests.
max-number: Specifies the maximum number of pending RADIUS requests, in the range of 1 to 255.
This command controls the rate of RADIUS requests that are sent to the RADIUS server. Use this command if the RADIUS server has a limited performance and cannot concurrently process too many RADIUS requests.
The device has two types of pending packet counters, one for the RADIUS authentication server and the other for the RADIUS accounting server. A pending packet counter is used to record the number of sent RADIUS requests for which no responses are received from the RADIUS server. The maximum value of a pending packet counter is determined by this command.
If you set the maximum number of pending authentication or accounting requests, a pending packet counter will be started for the RADIUS authentication or accounting server.
1. The device starts a pending packet counter for a RADIUS authentication or accounting server after sending the first authentication or accounting request to the server.
2. The device keeps sending the corresponding type of requests to the server before the counter reaches the maximum value. The number of requests that can be sent to the server is the difference between the counter value and the maximum number.
The counter increases by 1 each time the device sends a corresponding request.
The counter decreases by 1 each time the device receives a respond from the server or the respond timeout timer for a request expires.
3. The device buffers the subsequent requests when the counter reaches the maximum value.
If the value of the counter falls below the maximum value, the device sends the buffered requests in the sequence the requests are buffered.
If you cancel this configuration, the number of pending RADIUS authentication or accounting requests is not restricted.
The device can control the access rate only for portal and IPoE users.
# In RADIUS scheme radius1, set the maximum number of pending RADIUS authentication requests to 100.
[Sysname-radius-radius1] response-pending-limit authentication 100
retry
Use retry to set the maximum number of attempts for transmitting a RADIUS packet to a single RADIUS server.
Use undo retry to restore the default.
retry retries
undo retry
The maximum number of RADIUS packet transmission attempts is 3.
RADIUS scheme view
retries: Specifies the maximum number of RADIUS packet transmission attempts, in the range of 1 to 20.
Because RADIUS uses UDP packets to transmit data, the communication is not reliable.
If the device does not receive a response to its request from the RADIUS server within the response timeout period, the device retransmits the RADIUS request. To set the response timeout period, use the timer response-timeout command.
If the device does not receive a response from the RADIUS server after the maximum number of transmission attempts is reached, the device considers the request a failure.
If the client times out during the authentication process, the user is immediately logged off. To avoid user logoffs, the value multiplied by the following items cannot be larger than the client timeout period defined by the access module:
· The maximum number of RADIUS packet transmission attempts.
· The RADIUS server response timeout period.
· The number of RADIUS authentication servers in the RADIUS scheme.
When the device sends a RADIUS request to a new RADIUS server, it checks the total amount of time it has taken to transmit the RADIUS packet. If the amount of time has reached 300 seconds, the device stops sending the RADIUS request to the next RADIUS server. As a best practice, consider the number of RADIUS servers when you configure the maximum number of packet transmission attempts and the RADIUS server response timeout period.
# In RADIUS scheme radius1, set the maximum number of RADIUS packet transmission attempts to 5.
[Sysname-radius-radius1] retry 5
radius scheme
timer response-timeout (RADIUS scheme view)
retry realtime-accounting
Use retry realtime-accounting to set the maximum number of accounting attempts.
Use undo retry realtime-accounting to restore the default.
retry realtime-accounting retries
The maximum number of accounting attempts is 5.
RADIUS scheme view
retries: Specifies the maximum number of accounting attempts, in the range of 1 to 255.
Typically, a RADIUS accounting server checks whether a user is online by using a timeout timer. If the server does not receive a real-time accounting request for a user in the timeout period, it considers that a line or device failure has occurred. The server stops accounting for the user.
To work with the RADIUS server, the NAS needs to send real-time accounting requests to the server before the timer on the server expires and to keep pace with the server in disconnecting the user when a failure occurs. The NAS considers the user accounting a failure according to the maximum number of accounting attempts and specific parameters, and then take the action (stay online or log off) specified by using the accounting update-fail command.
For example, for a LAN user, the following conditions exist:
· The RADIUS server response timeout period is 3 seconds (set by using the timer response-timeout command).
· The maximum number of RADIUS packet transmission attempts is 3 (set by using the retry command).
· The real-time accounting interval is 12 minutes (set by using the timer realtime-accounting command).
· The maximum number of accounting attempts is 5 (set by using the retry realtime-accounting command).
In the above case, the device generates an accounting request every 12 minutes, and retransmits the request if it sends the request but receives no response within 3 seconds. If the device receives no response after transmitting the request three times, it considers the accounting attempt a failure, and makes another accounting attempt. If five consecutive accounting attempts fail, the device considers that user accounting fails.
# In RADIUS scheme radius1, set the maximum number of accounting attempts to 10.
[Sysname-radius-radius1] retry realtime-accounting 10
retry
timer realtime-accounting (RADIUS scheme view)
Use retry stop-accounting to set the maximum number of transmission attempts for individual RADIUS stop-accounting requests.
Use undo retry stop-accounting to restore the default.
retry stop-accounting retries
The maximum number of transmission attempts is 500 for individual RADIUS stop-accounting requests.
RADIUS scheme view
retries: Specifies the maximum number of transmission attempts. The value range is 10 to 65535.
The maximum number of stop-accounting request transmission attempts controls the transmission of stop-accounting requests together with the following parameters:
· RADIUS server response timeout timer (set by using the timer response-timeout command).
· Maximum number of times to transmit a RADIUS packet per round (set by using the retry command).
For example, the following settings exist:
· The RADIUS server response timeout timer is 3 seconds.
· The maximum number of times to transmit a RADIUS packet per round is five.
· The maximum number of stop-accounting request transmission attempts is 20.
A stop-accounting request is retransmitted if the device does not receive a response within 3 seconds. When all five transmission attempts in this round are used, the device buffers the request and starts another round of retransmission. If 20 consecutive rounds of attempts fail, the device discards the request.
# Set the maximum number of stop-accounting request transmission attempts to 1000 for RADIUS scheme radius1.
[Sysname-radius-radius1] retry stop-accounting 1000
retry
Use secondary accounting to specify a secondary RADIUS accounting server.
Use undo secondary accounting to remove a secondary RADIUS accounting server.
secondary accounting { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | weight weight-value ] *
undo secondary accounting [ { host-name | ipv4-address | ipv6 ipv6-address } [ port-number ] ]
No secondary RADIUS accounting servers are specified.
RADIUS scheme view
host-name: Specifies the host name of a secondary RADIUS accounting server, a case-insensitive string of 1 to 253 characters.
ipv4-address: Specifies the IPv4 address of a secondary RADIUS accounting server.
ipv6 ipv6-address: Specifies the IPv6 address of a secondary RADIUS accounting server.
port-number: Specifies the service port number of the secondary RADIUS accounting server. The value range for the UDP port number is 1 to 65535. The default setting is 1813.
key: Specifies the shared key for secure communication with the secondary RADIUS accounting server.
cipher: Specifies the key in encrypted form.
simple: Specifies the key in plaintext form. For security purposes, the key specified in plaintext form will be stored in encrypted form.
string: Specifies the key. This argument is case sensitive. The encrypted form of the key is a string of 1 to 117 characters. The plaintext form of the key is a string of 1 to 64 characters.
Make sure the port number and shared key settings of each secondary RADIUS accounting server are the same as those configured on the corresponding server.
A RADIUS scheme supports a maximum of 16 secondary RADIUS accounting servers. If the primary server fails, the device tries to communicate with a secondary server in active state. The device connects to the secondary servers in the order they are configured.
The shared key configured by this command takes precedence over the shared key configured with the key accounting command.
# In RADIUS scheme radius1, specify a secondary accounting server with IP address 10.110.1.1 and UDP port 1813.
[Sysname-radius-radius1] secondary accounting 10.110.1.1 1813
# In RADIUS scheme radius2, specify two secondary accounting servers with IP addresses 10.110.1.1 and 10.110.1.2 and UDP port 1813.
[Sysname] radius scheme radius2
[Sysname-radius-radius2] secondary accounting 10.110.1.1 1813
[Sysname-radius-radius2] secondary accounting 10.110.1.2 1813
Use secondary authentication to specify a secondary RADIUS authentication server.
Use undo secondary authentication to remove a secondary RADIUS authentication server.
secondary authentication { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | test-profile profile-name | weight weight-value ] *
undo secondary authentication [ { host-name | ipv4-address | ipv6 ipv6-address } [ port-number ] ]
No secondary RADIUS authentication servers are specified.
RADIUS scheme view
host-name: Specifies the host name of a secondary RADIUS authentication server, a case-insensitive string of 1 to 253 characters.
ipv4-address: Specifies the IPv4 address of a secondary RADIUS authentication server.
ipv6 ipv6-address: Specifies the IPv6 address of a secondary RADIUS authentication server.
port-number: Specifies the service port number of the secondary RADIUS authentication server. The value range for the UDP port number is 1 to 65535. The default setting is 1812.
key: Specifies the shared key for secure communication with the secondary RADIUS authentication server.
Make sure the port number and shared key settings of each secondary RADIUS authentication server are the same as those configured on the corresponding server.
A RADIUS scheme supports a maximum of 16 secondary RADIUS authentication servers. If the primary server fails, the device tries to communicate with a secondary server in active state. The device connects to the secondary servers in the order they are configured.
The server status detection is triggered for a server if the specified test profile exists on the device.
# In RADIUS scheme radius1, specify a secondary authentication server with IP address 10.110.1.2 and UDP port 1812.
[Sysname-radius-radius1] secondary authentication 10.110.1.2 1812
# In RADIUS scheme radius2, specify two secondary authentication servers with IP addresses 10.110.1.1 and 10.110.1.2 and UDP port 1812.
[Sysname-radius-radius2] secondary authentication 10.110.1.1 1812
[Sysname-radius-radius2] secondary authentication 10.110.1.2 1812
server-block-action (RADIUS scheme view)
Use server-block-action to specify the action to take for AAA requests if all servers in a RADIUS scheme are blocked.
Use undo server-block-action to restore the default.
server-block-action { attempt | skip }
The device attempts to connect to the server with the highest priority in a RADIUS scheme upon receiving AAA requests if all servers in the scheme are blocked.
RADIUS scheme view
attempt: Attempts to connect to the first server (except servers manually set in block state) in the scheme when all servers in the scheme are in block state.
skip: Skips all servers in the scheme and turns to the backup method.
The attempt action gives the device a chance to use the scheme in case the server with the highest priority in the scheme might be available. However, the attempt to communicate with an unavailable server increases the response time for AAA requests. As a best practice, specify the skip action in scenarios that require quick responses to AAA requests.
When processing an AAA request, the device does not turn back to a skipped scheme even though the state of the servers in the scheme changes from blocked to active.
# In RADIUS scheme radius1, configure the device to skip all servers in the scheme upon receiving AAA requests if all servers in the scheme are blocked.
[Sysname] radius scheme hwt1
[Sysname-radius-radius1] server-block-action skip
retry
Use server-load-sharing enable to enable the RADIUS server load sharing feature.
Use undo server-load-sharing enable to disable the RADIUS server load sharing feature.
The RADIUS server load sharing feature is disabled.
RADIUS scheme view
Use the RADIUS server load sharing feature to dynamically distribute the AAA requests over multiple servers regardless of their server roles. The device forwards an AAA request to the most appropriate server of all active servers in the scheme after it compares the weight values and numbers of currently served users. Specify a weight value for each RADIUS server based on the AAA capacity of the server. A larger weight value indicates a higher AAA capacity.
In RADIUS server load sharing, once the device sends a start-accounting request to a server for a user, it forwards all subsequent accounting requests of the user to the same server. If the accounting server is unreachable, the device returns an accounting failure message rather than searching for another active accounting server.
# Enable the RADIUS server load sharing feature for RADIUS scheme radius1.
[Sysname-radius-radius1] server-load-sharing enable
snmp-agent trap enable radius
Use snmp-agent trap enable radius to enable SNMP notifications for RADIUS.
Use undo snmp-agent trap enable radius to disable SNMP notifications for RADIUS.
snmp-agent trap enable radius [ accounting-server-down | accounting-server-up | authentication-error-threshold | authentication-server-down | authentication-server-up ] *
undo snmp-agent trap enable radius [ accounting-server-down | accounting-server-up | authentication-error-threshold | authentication-server-down | authentication-server-up ] *
All RADIUS SNMP notifications are disabled.
accounting-server-down: Specifies notifications to be sent when the RADIUS accounting server becomes unreachable.
accounting-server-up: Specifies notifications to be sent when the RADIUS accounting server becomes reachable.
authentication-error-threshold: Specifies notifications to be sent when the number of authentication failures exceeds the specified threshold. The threshold is represented by the ratio of the authentication failures to the total number of authentication attempts. The value range is 1 to 100, and the default value is 30. This threshold can only be configured through the MIB.
authentication-server-down: Specifies notifications to be sent when the RADIUS authentication server becomes unreachable.
authentication-server-up: Specifies notifications to be sent when the RADIUS authentication server becomes reachable.
If you do not specify any keywords, this command enables or disables all types of notifications for RADIUS.
When SNMP notifications for RADIUS are enabled, the device supports the following notifications generated by RADIUS:
· RADIUS server unreachable notification—The RADIUS server cannot be reached. RADIUS generates this notification if it cannot receive any response to an accounting or authentication request within the specified RADIUS request transmission attempts.
· RADIUS server reachable notification—The RADIUS server can be reached. RADIUS generates this notification for a previously blocked RADIUS server after the quiet timer expires.
· Excessive authentication failures notification—RADIUS generates this notification when the number of authentication failures to the total number of authentication attempts exceeds the specified threshold.
# Enable the device to send RADIUS accounting server unreachable notifications.
[Sysname] snmp-agent trap enable radius accounting-server-down
source-ip
Use source-ip to specify a source IP address for outgoing RADIUS packets.
Use undo source-ip to remove the source IP address of the specified type for outgoing RADIUS packets.
undo source-ip [ ipv6 ]
The source IP address of an outgoing RADIUS packet is that specified by using the radius source-ip command in system view.
RADIUS scheme view
4. The source IP address specified by using the source-ip command in RADIUS scheme view.
5. The source IP address specified by using the radius source-ip command in system view.
6. The NAS IP address specified by using the nas-ip command in RADIUS scheme view.
7. The NAS IP address specified by using the radius nas-ip command in system view.
8. The IP address of the outbound interface for the outgoing RADIUS packets.
A RADIUS scheme can have only one source IPv4 address and one source IPv6 address for outgoing RADIUS packets.
If you do not specify the ipv6 keyword for the undo source-ip command, the command removes the configured source IPv4 address for outgoing RADIUS packets.
# In RADIUS scheme radius1, specify IP address 10.1.1.1 as the source IPv4 address of outgoing RADIUS packets.
[Sysname-radius-radius1] source-ip 10.1.1.1
radius nas-ip
radius source-ip
state primary
Use state primary to set the status of a primary RADIUS server.
state primary { accounting | authentication } { active | block }
A primary RADIUS server is in active state.
RADIUS scheme view
accounting: Specifies the primary RADIUS accounting server.
authentication: Specifies the primary RADIUS authentication server.
active: Specifies the active state, the normal operation state.
block: Specifies the blocked state, the out-of-service state.
When the RADIUS server load sharing feature is disabled, the device first tries to communicate with the primary server if the primary server is in active state. If the primary server is unavailable, the device performs the following operations:
· Changes the status of the primary server to blocked.
· Starts a quiet timer for the server.
· Tries to communicate with a secondary server in active state.
When the quiet timer of the primary server times out, the status of the server automatically changes to active. If you set the server status to blocked before the quiet timer times out, the server status cannot change back to active unless you manually set the status to active.
When the RADIUS server load sharing feature is enabled, the device checks the weight value and number of currently served users only for servers in active state. The most appropriate active server is selected for communication.
When the primary server and all secondary servers are in blocked state, the device tries to communicate with the primary server.
This command can affect the RADIUS server status detection feature when a valid test profile is specified for a primary RADIUS authentication server.
· If you set the status of the server to blocked, the device stops detecting the status of the server.
· If you set the status of the server to active, the device starts to detect the status of the server.
# In RADIUS scheme radius1, set the status of the primary authentication server to blocked.
[Sysname-radius-radius1] state primary authentication block
state secondary
state private
Use state private to set the state of a private RADIUS server.
state private { accounting | authentication } [ { ipv4-address | ipv6 ipv6-address } ] { active | block }
A private RADIUS server is in active state.
RADIUS scheme view
accounting: Specifies a private RADIUS accounting server.
authentication: Specifies a private RADIUS authentication server.
ipv4-address: Specifies the IPv4 address of a private RADIUS server.
ipv6 ipv6-address: Specifies the IPv6 address of a private RADIUS server.
port-number: Specifies the UDP service port number of a private RADIUS server. The value range for the UDP port number is 1 to 65535. The default port numbers for authentication and accounting are 1812 and 1813, respectively.
active: Specifies the active state. The device sends requests to a private server when it is in active state.
block: Specifies the blocked state. The device does not send requests to a private server when it is in blocked state.
The device automatically detects reachability of a private server and changes its state from active to blocked if the server is unreachable. The blocked state persists only for the period set by using the timer quiet command. When the quiet timer expires, the state of the server automatically changes to active.
To prevent the server state automatically changes from blocked to active, use this command to manually place the server in blocked state before the quiet timer expires. To restore the active state of a manually blocked server, you must also use this command.
If you do not specify a server IP address, this command changes the state of all private RADIUS accounting or authentication servers specified in the scheme.
# Block all private authentication servers in RADIUS scheme radius1.
[Sysname-radius-radius1] state private authentication block
state secondary
Use state secondary to set the status of a secondary RADIUS server.
state secondary { accounting | authentication } [ { host-name | ipv4-address | ipv6 ipv6-address } [ port-number ] ] { active | block }
A secondary RADIUS server is in active state.
RADIUS scheme view
accounting: Specifies a secondary RADIUS accounting server.
authentication: Specifies a secondary RADIUS authentication server.
host-name: Specifies the host name of the secondary RADIUS server, a case-insensitive string of 1 to 253 characters.
ipv4-address: Specifies the IPv4 address of a secondary RADIUS server.
ipv6 ipv6-address: Specifies the IPv6 address of a secondary RADIUS server.
port-number: Specifies the service port number of a secondary RADIUS server. The value range for the UDP port number is 1 to 65535. The default port numbers for authentication and accounting are 1812 and 1813, respectively.
If you do not specify an IP address, this command changes the status of all configured secondary RADIUS servers.
If the device finds that a secondary server in active state is unreachable, the device performs the following operations:
· Changes the status of the secondary server to blocked.
· Tries to communicate with another secondary server in active state.
When the quiet timer of a server times out, the status of the server automatically changes to active. If you set the server status to blocked before the quiet timer times out, the server status cannot change back to active unless you manually set the status to active. If all configured secondary servers are unreachable, the device considers the authentication or accounting attempt a failure.
This command can affect the RADIUS server status detection feature when a valid test profile is specified for a secondary RADIUS authentication server.
# In RADIUS scheme radius1, set the status of all the secondary authentication servers to blocked.
[Sysname-radius-radius1] state secondary authentication block
state primary
stop-accounting-buffer enable (RADIUS scheme view)
Use stop-accounting-buffer enable to enable buffering of RADIUS stop-accounting requests to which no responses have been received.
Use undo stop-accounting-buffer enable to disable the buffering feature.
The device buffers the RADIUS stop-accounting requests to which no responses have been received.
RADIUS scheme view
This command enables the device to buffer a RADIUS stop-accounting request that has no response after the maximum transmission attempts (set by using the retry command) have been made. The device resends the buffered request until it receives a server response or when the number of stop-accounting request transmission attempts reaches the upper limit. If no more attempts are available, the device discards the request. However, if you have removed an accounting server, stop-accounting requests destined for the server are not buffered.
# Enable buffering of RADIUS stop-accounting requests to which no responses have been received.
[Sysname-radius-radius1] stop-accounting-buffer enable
display stop-accounting-buffer (for RADIUS)
reset stop-accounting-buffer (for RADIUS)
stop-accounting-packet send-force
Use stop-accounting-packet send-force to enable forcibly sending stop-accounting packets. The device will send stop-accounting packets when users for which no start-accounting packets are sent go offline.
Use undo stop-accounting-packet send-force to disable forcibly sending stop-accounting packets.
Forcibly sending stop-accounting packets is disabled. The device does not send stop-accounting packets when users for which no start-accounting packets are sent go offline.
RADIUS scheme view
Typically, if the device does not send a start-accounting packet to the RADIUS server for an authenticated user, it does not send a stop-accounting packet when the user goes offline. If the server has generated a user entry for the user without start-accounting packets, it does not release the user entry when the user goes offline. This feature forces the device to send stop-accounting packets to the RADIUS server when the user goes offline for timely releasing the user entry on the server.
# In RADIUS scheme radius1, enable forcibly sending stop-accounting packets.
[Sysname-radius-radius1] stop-accounting-packet send-force
test-aaa
Use test-aaa to perform an AAA test.
test-aaa user user-name password password radius-scheme radius-scheme-name [ radius-server { ipv4-address | ipv6 ipv6-address } port-number ] [ chap | pap ] [ attribute-test-group attr-test-group-name ] [ trace ]
user user-name: Specifies the test username, a string of 1 to 80 characters. The username can be a pure username or contain a domain name. The format for a username containing a domain name is pure-username@domain-name. The pure username is case sensitive and the domain name is case insensitive.
password password: Specifies the password of the test user, a case-sensitive string of 1 to 63 characters.
radius-scheme radius-scheme-name: Specifies a RADIUS scheme by its name, a case-insensitive string of 1 to 32 characters.
radius-server: Specifies a RADIUS server.
ipv4-address: Specifies the IPv4 address of the RADIUS server.
ipv6 ipv6-address: Specifies the IPv6 address of the RADIUS server.
port-number: Specifies the UDP port number of the RADIUS server, in the range of 1 to 65535.
chap: Specifies the CHAP authentication method (the default).
pap: Specifies the PAP authentication method.
attribute-test-group attr-test-group-name: Specifies a RADIUS attribute test group by its name, a case-insensitive string of 1 to 31 characters. If you do not specify a RADIUS attribute test group or the specified RADIUS attribute test group does not exist, the device does not change the attributes carried in authentication or accounting requests.
trace: Displays detailed information about RADIUS packets exchanged during the AAA test. If you do not specify this keyword, the command displays brief information about the AAA test, including the sent and received packets and the test result.
Use this command to identify the reasons for the failure of interaction between the device and the AAA servers.
The device might communicate with the AAA servers incorrectly during an AAA test. Make sure no users come online or go offline during an AAA text.
If the configuration of the specified RADIUS scheme changes, the new configuration does not affect the current AAA test. The modification will take effect in the next test.
The system can have only one AAA test at a time. Another AAA test can be performed only after the current test finishes.
# Perform an AAA test and display detailed information about the test. The test uses username user1, password 123456, the CHAP authentication method, and RADIUS scheme test.
<Sysname> test-aaa user user1 password 123456 radius-scheme test chap trace
Sent a RADIUS authentication request.
Server IP : 192.168.1.110
Source IP : 192.168.1.166
VPN instance : N/A
Server port : 1812
Packet type : Authentication request
Packet length: 118 bytes
Packet ID : 0
Attribute list:
[User-Name(1)] [6] [user1]
[CHAP-Password(3)] [19] [******]
[NAS-IP-Address(4)] [6] [192.168.1.166]
[Service-Type(6)] [6] [2] [Framed]
[Framed-Protocol(7)] [6] [1] [PPP]
[NAS-Identifier(32)] [5] [Sysname]
[Acct-Session-Id(44)] [40] [00000008201707241008280000000c16100171]
[CHAP-Challenge(60)] [18] [******]
[NAS-Port-Type(61)] [6] [15] [Ethernet]
Received a RADIUS authentication response.
VPN instance : N/A
Server port : 1812
Packet type : Access-Reject
Packet length: 20 bytes
Packet ID : 0
Reply-Message: "E63032: Incorrect password. You can retry 9 times."
Sent a RADIUS start-accounting request.
VPN instance : N/A
Server port : 1813
Packet type : Start-accounting request
Packet length: 63 bytes
Packet ID : 1
Attribute list:
[Acct-Status-Type(40)] [6] [1] [Start]
Received a RADIUS start-accounting response.
VPN instance : N/A
Server port : 1813
Packet type : Start-accounting response
Packet ID : 1
Sent a RADIUS stop-accounting request.
VPN instance : N/A
Server port : 1813
Packet type : Stop-accounting request
Packet length: 91 bytes
Packet ID : 1
Attribute list:
[Acct-Status-Type(40)] [6] [2] [Stop]
[Acct-Delay-Time(41)] [6] [0]
[Acct-Terminate-Cause(49)] [6] [1] [User Request]
Received a RADIUS stop-accounting response.
VPN instance : N/A
Server port : 1813
Packet type : Stop-accounting response
Packet ID : 1
Test result: Failed
# Perform an AAA test and display brief information about the test. The test uses username user1, password 123456 and the CHAP authentication method to test RADIUS server at 192.168.1.110 in RADIUS scheme test.
<Sysname> test-aaa user user1 password 123456 radius-scheme test radius-server 192.168.1.110 1812
Test result: Successful
Table 23 Command output
Server IP |
IP address of the server. |
Source IP |
Source IP address of the RADIUS packet. |
VPN instance |
This field is not supported in the current software version. MPLS L3VPN instance to which the server belongs. This field displays N/A if the server belongs to the public network. |
Server port |
UDP port number of the server. |
Packet type |
Type of the RADIUS packet: · Authentication request. · Access-Accept. · Access-Reject. · Start-accounting request. · Start-accounting response. · Stop-accounting request. · Stop-accounting response. |
Packet length |
Total length of the RADIUS packet, in bytes. |
Packet ID |
ID of the RADIUS packet. This field is used to identity a pair of request and response packets. |
[attribute-name (code)] [length] [value] [description] |
Information about a RADIUS attribute: · attribute-name—Name of the attribute. · code—Code of the attribute. · length—Length of the attribute, in bytes. · value—Value of the attribute. · description—Description of the attribute. |
Reply-Message: |
The RADIUS server rejected the authentication request and replied a message. |
Test result |
Result of the AAA test: · Successful—The test has succeeded. · Failed—The test has failed. If any request is rejected, the test fails. |
radius scheme
threshold remanent-volume
Use threshold remanent-volume to set the available data threshold.
Use undo threshold remanent-volume to restore the default.
threshold remanent-volume threshold-value
The available data threshold is 0.
RADIUS scheme view
threshold-value: Specifies the available data threshold, in the range of 0 to 4294967295. The unit is set by using the attribute remanent-volume unit command.
Use this command if the RADIUS server divides the total data quota of an authenticated user into multiple equal portions and assigns one portion to the user each time. When the user's available data on the device reaches the threshold, the device sends a realtime accounting request to the RADIUS server to apply for a new portion. This process continues till the user uses up the total data quota.
# In RADIUS scheme radius1, set the available data threshold to 2048 MB.
[Sysname-radius-radius1] threshold remanent-volume 2048
[Sysname-radius-radius1] attribute remanent-volume unit mega-byte
timer quiet (RADIUS scheme view)
Use timer quiet to set the quiet timer for the servers specified in a RADIUS scheme.
Use undo timer quiet to restore the default.
timer quiet minutes
undo timer quiet
The server quiet timer period is 5 minutes in a RADIUS scheme.
RADIUS scheme view
minutes: Specifies the server quiet period in minutes, in the range of 1 to 255.
Make sure the server quiet timer is set correctly.
A timer that is too short might result in frequent authentication or accounting failures. This is because the device will continue to attempt to communicate with an unreachable server that is in active state.
A timer that is too long might temporarily block a reachable server that has recovered from a failure. This is because the server will remain in blocked state until the timer expires.
# In RADIUS scheme radius1, set the quiet timer to 10 minutes for the servers.
[Sysname-radius-radius1] timer quiet 10
Use timer realtime-accounting to set the real-time accounting interval.
Use undo timer realtime-accounting to restore the default.
timer realtime-accounting interval [ second ]
The real-time accounting interval is 12 minutes.
RADIUS scheme view
interval: Specifies the real-time accounting interval in the range of 0 to 71582.
second: Specifies the measurement unit as second. If you do not specify this keyword, the real-time accounting interval is measured in minutes.
When the real-time accounting interval on the device is not zero, the device sends online user accounting information to the RADIUS accounting server at the configured interval.
When the real-time accounting interval on the device is zero, the device sends online user accounting information to the RADIUS accounting server at the real-time accounting interval configured on the server. If the real-time accounting interval is not configured on the server, the device does not send online user accounting information.
If a user uses RADIUS accounting but not RADIUS authentication and authorization, the device performs real-time accounting for that user only based on the real-time accounting interval set in the user's RADIUS accounting scheme. The real-time accounting interval assigned by the RADIUS accounting server does not take effect.
A short interval helps improve accounting precision but requires many system resources.
Table 24 Recommended real-time accounting intervals
Number of users |
Real-time accounting interval |
1 to 99 |
3 minutes |
100 to 499 |
6 minutes |
500 to 999 |
12 minutes |
1000 or more |
15 minutes or longer |
The device sends a start-accounting packet for a dual-stack user after the user obtains an IP address of one stack. No matter how long the real-time accounting interval is, the device sends an update-accounting packet for the user immediately after the user obtains an IP address of another stack.
# In RADIUS scheme radius1, set the real-time accounting interval to 51 minutes.
[Sysname-radius-radius1] timer realtime-accounting 51
Use timer response-timeout to set the RADIUS server response timeout timer.
Use undo timer response-timeout to restore the default.
timer response-timeout seconds
The RADIUS server response timeout period is 3 seconds.
RADIUS scheme view
seconds: Specifies the RADIUS server response timeout period, in the range of 1 to 10 seconds.
If a NAS receives no response from the RADIUS server in a period of time after sending a RADIUS request, it resends the request so that the user has more opportunity to obtain the RADIUS service. The NAS uses the RADIUS server response timeout timer to control the transmission interval.
· The number of RADIUS servers in the RADIUS scheme.
# In RADIUS scheme radius1, set the RADIUS server response timeout timer to 5 seconds.
[Sysname-radius-radius1] timer response-timeout 5
retry
trust ip
Use trust ip to configure a trusted IPv4 DAC.
Use undo trust ip to remove a trusted IPv4 DAC.
trust ip ipv4-address
undo trust ip ipv4-address
No trusted IPv4 DACs are configured.
RADIUS DAS view
ipv4-address: Specifies the IPv4 address of a DAC, which cannot be 0.0.0.0, 255.255.255.255, a class D address, a class E address, or a loopback address.
On a DAE proxy network, the DAE proxy checks the legitimacy of DAE requests received from DACs and it sends only legitimate DAE requests to the DAS. To exempt DAE requests from a DAC from being checked, you can configure the DAC as a trusted DAC. In this way, the DAE proxy directly sends DAE requests from the DAC to the DAS. This reduces the burden of the DAE proxy.
You can repeat this command to configure multiple trusted IPv4 DACs.
# Configure the DAC at 10.110.1.2 as a trusted IPv4 DAC.
[Sysname] radius dynamic-author server
[Sysname-radius-da-server] trust ip 10.110.1.2
trust ipv6
trust ipv6
Use trust ipv6 to configure a trusted IPv6 DAC.
Use undo trust ipv6 to remove a trusted IPv6 DAC.
trust ipv6 ipv6-address
undo trust ipv6 ipv6-address
No trusted IPv6 DACs are configured.
RADIUS DAS view
ipv6 ipv6-address: Specifies the IPv6 address of a DAC, which must be a unicast address and cannot be a loopback address or a link-local address.
You can repeat this command to configure multiple trusted IPv6 DACs.
# Configure the DAC at 10:110::1:2 as a trusted IPv6 DAC.
[Sysname-radius-da-server] trust ipv6 10:110::1:2
trust ip
username-authorization apply
Use username-authorization apply to configure the device to use server-assigned usernames for AAA processes subsequent to authentication.
Use undo username-authorization apply to restore the default.
The device uses the usernames used in authentication for AAA processes subsequent to authentication.
RADIUS scheme view
A RADIUS server might add the User-Name attribute in an Access-Accept response. This feature enables the device to notify the access module of the User-Name attribute and use the server-assigned username for AAA processes subsequent to authentication. For example, the device includes the username in start-accounting requests sent to the RADIUS server and displays the username in command output instead of the username used in authentication.
The username assigned by the RADIUS server is different from the username used in authentication. How a server-assigned username is encapsulated in the RADIUS User-Name attribute by the device depends on the username format configuration in the RADIUS scheme.
· If the username format is keep-original, the username is encapsulated without any change.
· If the username format is without-domain, the username is encapsulated without any domain name.
· If the username format is with-domain, the username is encapsulated with the authentication domain name. If the server-assigned username contains a domain name other than the authentication domain name, the device replaces the domain name with the authentication domain name.
This command takes effect only on IPoE users.
If this command is used, the usernames in IPoE user information displayed by using the display ip subscriber command are the usernames assigned by the RADIUS server.
# In RADIUS scheme radius1, configure the device to use server-assigned usernames for AAA processes subsequent to authentication.
[Sysname-radius-radius1] username-authorization apply
user-name-format (RADIUS scheme view)
Use user-name-format to specify the format of the username to be sent to a RADIUS server.
Use undo user-name-format to restore the default.
user-name-format { keep-original | with-domain | without-domain }
The ISP domain name is included in the usernames sent to a RADIUS server.
RADIUS scheme view
keep-original: Sends the username to the RADIUS server as the username is entered.
with-domain: Includes the ISP domain name in the username sent to the RADIUS server.
without-domain: Excludes the ISP domain name from the username sent to the RADIUS server.
A username is generally in the userid@isp-name format, of which the isp-name argument is used by the device to determine the ISP domain to which a user belongs. Some earlier RADIUS servers, however, cannot recognize a username containing an ISP domain name. Before sending a username including a domain name to such a RADIUS server, the device must remove the domain name. This command allows you to specify whether to include a domain name in a username sent to a RADIUS server.
If a RADIUS scheme defines that the username is sent without the ISP domain name, do not apply the scheme to more than one ISP domain. Otherwise, the RADIUS server will consider two users in different ISP domains but with the same userid as one user.
For 802.1X users using EAP authentication, the user-name-format command configured for a RADIUS scheme does not take effect. The device does not change the usernames from clients before forwarding them to the RADIUS server.
If the RADIUS scheme is used for roaming wireless users, specify the keep-original keyword. Otherwise, authentication of the wireless users might fail.
# In RADIUS scheme radius1, configure the device to remove the domain name from the usernames sent to the RADIUS servers.
[Sysname-radius-radius1] user-name-format without-domain
EAP profile commands
ca-file
Use ca-file to specify a CA certificate file for EAP authentication.
Use undo ca-file to restore the default.
ca-file file-name
undo ca-file
No CA certificate is specified for EAP authentication.
EAP profile view
file-name: Specifies a CA certificate file by its name, a case-sensitive string of 1 to 91 characters. Only CA certificate files in PEM format are supported.
You must specify a CA certificate file for the RADIUS server to authenticate certificates of RADIUS clients if the PEAP-GTC, PEAP-MSCHAPv2, TTLS-GTC, or TTLS-MSCHAPv2 EAP authentication method is used.
Before you specify a CA certificate file, you must use FTP or TFTP to transfer the file to the root directory of the default storage medium on the device.
You can specify only one CA certificate file in an EAP profile. If you execute this command multiple times, the most recent configuration takes effect.
# In EAP profile eap1, specify CA certificate file ca.pem for EAP authentication.
[Sysname] eap-profile eap1
[Sysname-eap-profile-eap1] ca-file ca.pem
certificate-file
certificate-file
Use certificate-file to specify a local certificate file for EAP authentication.
Use undo certificate-file to restore the default.
certificate-file file-name
No local certificate file is specified for EAP authentication.
EAP profile view
file-name: Specifies a certificate file by its name, a case-sensitive string of 1 to 91 characters. Only certificate files in PEM format are supported.
You must specify a local certificate file if the PEAP-GTC, PEAP-MSCHAPv2, TTLS-GTC, TTLS-MSCHAPv2, or TLS EAP authentication method is used and RADIUS clients request to authenticate the certificate of the RADIUS server.
Before you specify a local certificate file, you must use FTP or TFTP to transfer the file to the root directory of the default storage medium on the device.
You can specify only one local certificate file in an EAP profile. If you execute this command multiple times, the most recent configuration takes effect.
For the RADIUS server to start up, you must specify a local certificate file.
# In EAP profile eap1, specify certificate file server.pem as the local certificate file for EAP authentication.
[Sysname-eap-profile-eap1] certificate-file server.pem
private-key-file
eap-profile
Use eap-profile to create an EAP profile and enter its view, or enter the view of an existing EAP profile.
Use undo eap-profile to delete an EAP profile.
undo eap-profile eap-profile-name
No EAP profiles exist.
eap-profile-name: Specifies the EAP profile name, a case-sensitive string of 1 to 32 characters.
An EAP profile is a collection of EAP authentication settings, including the EAP authentication method and authentication parameters used by the RADIUS server to perform authentication.
You can configure a maximum of 16 EAP profiles.
If an EAP profile is applied to the local RADIUS server, all settings in the EAP profile take effect only after the RADIUS server configuration is activated by using the radius-server activate command.
# Create an EAP profile named eap1 and enter its view.
display radius-server active-eap-profile
method
Use method to specify the default EAP authentication method.
Use undo method to restore the default.
method { md5 | peap-gtc | peap-mschapv2 | tls | ttls-gtc | ttls-mschapv2 }
undo method
The default EAP authentication method is the MD5-challenge method.
EAP profile view
md5: Specifies the MD5-challenge method.
peap-gtc: Specifies the PEAP-GTC method.
peap-mschapv2: Specifies the PEAP-MSCHAPv2 method.
tls: Specifies the TLS method.
ttls-gtc: Specifies the TTLS-GTC method.
ttls-mschapv2: Specifies the TTLS-MSCHAPv2 method.
You can specify only one default EAP authentication method in an EAP profile. If you execute this command multiple times, the most recent configuration takes effect.
The device supports multiple EAP authentication methods. When the device initiates an authentication request to the peer, it preferentially uses the default EAP authentication method in the EAP profile. If the peer uses a different EAP authentication method, it will notify the device of its supported EAP authentication methods. The device will select a method that is supported both locally and by the peer to re-initiate the authentication request. However, if the access device uses the EAP termination mode in authentication for wireless clients, you can specify only the PEAP-GTC as the default EAP authentication method.
# In EAP profile eap1, specify PEAP-GTC as the default EAP authentication method.
[Sysname-eap-profile-eap1] method peap-gtc
private-key-file
Use private-key-file to specify a private key file for the local certificate.
Use undo private-key-file to restore the default.
private-key-file file-name
No private key file is specified for the local certificate.
EAP profile view
file-name: Specifies a private key file by its name, a case-sensitive string of 1 to 91 characters. Only private key files in PEM format are supported.
You must specify a private key file for the RADIUS server to decrypt information encrypted by RADIUS clients if the PEAP-GTC, PEAP-MSCHAPv2, TTLS-GTC, TTLS-MSCHAPv2, or TLS EAP authentication method is used.
If the local certificate file for EAP authentication includes a private key, specify the local certificate file as the private key file.
Before you specify a private key file, you must use FTP or TFTP to transfer the file to the root directory of the default storage medium on the device.
You can specify only one private key file in an EAP profile. If you execute this command multiple times, the most recent configuration takes effect.
For the RADIUS server to start up, you must specify a private key file.
# In EAP profile eap1, specify private key file server.pem for the local certificate.
[Sysname-eap-profile-eap1] private-key-file server.pem
certificate-file
private-key-password
Use private-key-password to specify a private key password for the local certificate.
Use undo private-key-password to restore the default.
private-key-password { cipher | simple } string
No private key password is specified for the local certificate.
EAP profile view
string: Specifies the password. Its encrypted form is a case-sensitive string of 1 to 117 characters. Its plaintext form is a case-sensitive string of 1 to 63 characters.
The private key password must be provided when the device imports or uses the private key of the local certificate. Make sure the private key password specified by using this command is the same as the private key password provided when the private key is imported to the device.
You can specify only one private key password in an EAP profile. If you execute this command multiple times, the most recent configuration takes effect.
For the RADIUS server to start up, you must specify a private key password.
# In EAP profile eap1, specify plaintext password 123 as the private key password for the local certificate.
[Sysname-eap-profile-eap1] private-key-password simple 123
private-key-file
ssl-server-policy
Use ssl-server-policy to specify an SSL server policy for EAP authentication.
Use undo ssl-server-policy to restore the default.
ssl-server-policy policy-name
No SSL server policy is specified for EAP authentication.
EAP profile view
policy-name: Specifies an SSL server policy name, a case-insensitive string of 1 to 31 characters.
Before you execute this command, you must complete the configuration of the specified SSL server policy and the PKI domain to be specified for this policy. For more information about SSL server policies and PKI domains, see SSL configuration and PKI configuration in Security Configuration Guide.
# In EAP profile eap1, specify SSL server policy tls-server for EAP authentication.
[Sysname] eap-profile aprf1
[System-eap-prof-aprf1] ssl-server-policy tls-server
pki-domain (Security Command Reference)
ssl server-policy (Security Command Reference)
HWTACACS commands
data-flow-format (HWTACACS scheme view)
Use data-flow-format to set the data flow and packet measurement units for traffic statistics.
Use undo data-flow-format to restore the default.
data-flow-format { data { byte | giga-byte | kilo-byte | mega-byte } | packet { giga-packet | kilo-packet | mega-packet | one-packet } } *
undo data-flow-format { data | packet }
Traffic is counted in bytes and packets.
data: Specifies the unit for data flows.
byte: Specifies the unit as byte.
giga-byte: Specifies the unit as gigabyte.
kilo-byte: Specifies the unit as kilobyte.
mega-byte: Specifies the unit as megabyte.
packet: Specifies the unit for data packets.
giga-packet: Specifies the unit as giga-packet.
kilo-packet: Specifies the unit as kilo-packet.
mega-packet: Specifies the unit as mega-packet.
one-packet: Specifies the unit as one-packet.
The data flow and packet measurement units for traffic statistics must be the same as configured on the HWTACACS accounting servers. Otherwise, accounting results might be incorrect.
# In HWTACACS scheme hwt1, set the data flow and packet measurement units for traffic statistics to kilobyte and kilo-packet, respectively.
[Sysname] hwtacacs scheme hwt1
[Sysname-hwtacacs-hwt1] data-flow-format data kilo-byte packet kilo-packet
display hwtacacs scheme
Use display hwtacacs scheme to display the configuration or statistics of HWTACACS schemes.
display hwtacacs scheme [ hwtacacs-scheme-name [ statistics ] ]
hwtacacs-scheme-name: Specifies an HWTACACS scheme by its name, a case-insensitive string of 1 to 32 characters. If you do not specify an HWTACACS scheme, this command displays the configuration of all HWTACACS schemes.
statistics: Displays the HWTACACS service statistics. If you do not specify this keyword, the command displays the configuration of the specified HWTACACS scheme.
# Displays the configuration of all HWTACACS schemes.
<Sysname> display hwtacacs scheme
Total 1 HWTACACS schemes
HWTACACS Scheme Name : hwtac
Index : 0
Primary Auth Server:
Host name: Not configured
IP : 2.2.2.2 Port: 49 State: Active
VPN Instance: Not configured
Single-connection: Enabled
Primary Author Server:
Single-connection: Disabled
Primary Acct Server:
IP : Not Configured Port: 49 State: Block
VPN Instance : Not configured
NAS IP Address : 2.2.2.3
Server Quiet Period(minutes) : 5
Realtime Accounting Interval(minutes) : 12
Stop-accounting packets buffering : Enabled
Retransmission times : 100
Response Timeout Interval(seconds) : 5
Username Format : with-domain
Data flow unit : Byte
Packet unit : one
Table 25 Command output
Index |
Index number of the HWTACACS scheme. |
Primary Auth Server |
Primary HWTACACS authentication server. |
Primary Author Server |
Primary HWTACACS authorization server. |
Primary Acct Server |
Primary HWTACACS accounting server. |
Secondary Auth Server |
Secondary HWTACACS authentication server. |
Secondary Author Server |
Secondary HWTACACS authorization server. |
Secondary Acct Server |
Secondary HWTACACS accounting server. |
Host name |
Host name of the server. This field displays Not configured in the following situations: · The server is not configured. · The server is specified by IP address. |
IP |
IP address of the server. This field displays Not configured in the following situations: · The server is not configured. · The server is specified by hostname, and the hostname is not resolved. |
Port |
Service port of the HWTACACS server. If no port configuration is performed, this field displays the default port number. |
State |
Status of the HWTACACS server: active or blocked. |
VPN Instance |
This field is not supported in the current software version. MPLS L3VPN instance to which the HWTACACS server or scheme belongs. If no VPN instance is specified for the server or scheme, this field displays Not configured. |
Single-connection |
Single connection status: · Enabled—Establish only one TCP connection for all users to communicate with the server. · Disabled—Establish a TCP connection for each user to communicate with the server. |
NAS IP Address |
Source IP addresses or source interface for outgoing HWTACACS packets. This field displays Not configured if no source interface or source IP addresses are specified for outgoing HWTACACS packets. |
Server Quiet Period(minutes) |
Quiet period for the primary servers, in minutes. |
Realtime Accounting Interval(minutes) |
Real-time accounting interval, in minutes. |
Stop-accounting packets buffering |
Whether buffering of nonresponded HWTACACS stop-accounting requests is enabled. |
Retransmission times |
Maximum number of transmission attempts for individual HWTACACS stop-accounting requests. |
Response Timeout Interval(seconds) |
HWTACACS server response timeout period, in seconds. |
Username Format |
Format for the usernames sent to the HWTACACS server: · with-domain—Includes the domain name. · without-domain—Excludes the domain name. · keep-original—Forwards the username as the username is entered. |
Data flow unit |
Measurement unit for data flows. |
Packet unit |
Measurement unit for packets. |
# Display statistics for HWTACACS scheme tac.
<Sysname> display hwtacacs scheme tac statistics
HWTACACS scheme name: tac
Primary authentication server: 111.8.0.244 (Port: 49, VPN instance: -)
Round trip time: 20 seconds
Request packets: 1
Login request packets: 1
Change-password request packets: 0
Request packets including plaintext passwords: 0
Request packets including ciphertext passwords: 0
Response packets: 2
Pass response packets: 1
Failure response packets: 0
Get-data response packets: 0
Get-username response packets: 0
Get-password response packets: 1
Restart response packets: 0
Error response packets: 0
Follow response packets: 0
Malformed response packets: 0
Continue packets: 1
Continue-abort packets: 0
Pending request packets: 0
Timeout packets: 0
Unknown type response packets: 0
Dropped response packets: 0
Primary authorization server :111.8.0.244 (Port: 49, VPN instance: -)
Round trip time: 1 seconds
Request packets: 1
Response packets: 1
PassAdd response packets: 1
PassReply response packets: 0
Timeout packets: 0
Primary accounting server :111.8.0.244 (Port: 49, VPN instance: -)
Round trip time: 0 seconds
Request packets: 2
Accounting start request packets: 1
Accounting stop request packets: 1
Accounting update request packets: 0
Response packets: 2
Success response packets: 2
Timeout response packets: 0
Table 26 Command output
Primary authentication server |
Primary authorization server |
Primary accounting server |
Secondary authentication server |
Secondary authorization server |
Secondary accounting server |
Port |
Port number of the HWTACACS server. |
VPN instance |
This field is not supported in the current software version. VPN instance to which the HWTACACS server or scheme belongs. If the HWTACACS server or scheme belongs to the public network, this field displays a hyphen (-). |
Round trip time |
The time interval during which the device processed a pair of request and response. The unit is second. |
Request packets |
Total number of sent request packets. |
Login request packets |
Number of sent login request packets. |
Change-password request packets |
Number of sent request packets for changing passwords. |
Request packets including plaintext passwords |
Number of request packets that include plaintext passwords. |
Request packets including ciphertext passwords |
Number of request packets that include ciphertext passwords. |
Response packets |
Total number of received response packets. |
Pass response packets |
Number of response packets indicating successful authentication. |
Failure response packets |
Number of response packets indicating authentication or authorization failure. |
Get-data response packets |
Number of response packets for obtaining user data. |
Get-username response packets |
Number of response packets for obtaining usernames. |
Get-password response packets |
Number of response packets for obtaining passwords. |
Restart response packets |
Number of response packets for reauthentication. |
Error response packets |
Number of error-type response packets. |
Follow response packets |
Number of follow-type response packets. |
Malformed response packets |
Number of malformed response packets. |
Continue packets |
Number of sent Continue packets. |
Continue-abort packets |
Number of sent Continue-abort packets. |
Pending request packets |
Number of request packets waiting for a response. |
Timeout packets/Timeout response packets |
Number of timeout response packets. |
Unknown type response packets |
Number of unknown-type response packets. |
Dropped response packets |
Number of dropped response packets. |
PassAdd response packets |
Number of received PassAdd response packets. The packets indicate that all requested authorization attributes are assigned and additional authorization attributes are added. |
PassReply response packets |
Number of received PassReply response packets. The device uses the specified authorization attributes in the packets to replace the requested authorization attributes. |
Accounting start request packets |
Number of accounting start request packets. |
Accounting stop request packets |
Number of accounting stop request packets. |
Accounting update request packets |
Number of accounting update request packets. |
Success response packets |
Number of accounting success response packets. |
reset hwtacacs statistics
display stop-accounting-buffer (for HWTACACS)
Use display stop-accounting-buffer to display information about buffered HWTACACS stop-accounting requests to which no responses have been received.
display stop-accounting-buffer hwtacacs-scheme hwtacacs-scheme-name
hwtacacs-scheme hwtacacs-scheme-name: Specifies an HWTACACS scheme by its name, a case-insensitive string of 1 to 32 characters.
# Display information about nonresponded stop-accounting requests buffered for HWTACACS scheme hwt1.
<Sysname> display stop-accounting-buffer hwtacacs-scheme hwt1
Total entries: 2
Scheme IP address Username First sending time Attempts
hwt1 192.168.100.1 abc 23:27:16-01/15/2020 19
hwt1 192.168.90.6 bob 23:33:01-01/15/2020 20
Table 27 Command output
First sending time |
Time when the stop-accounting request was first sent. |
Attempts |
Number of attempts that were made to send the stop-accounting request. |
reset stop-accounting-buffer (for HWTACACS)
retry stop-accounting (HWTACACS scheme view)
stop-accounting-buffer enable (HWTACACS scheme view)
user-name-format (HWTACACS scheme view)
hwtacacs dscp
Use hwtacacs dscp to change the DSCP priority of HWTACACS packets.
Use undo hwtacacs dscp to restore the default.
hwtacacs [ ipv6 ] dscp dscp-value
undo hwtacacs [ ipv6 ] dscp
The DSCP priority of HWTACACS packets is 0.
ipv6: Specifies IPv6 HWTACACS packets. If you do not specify this keyword, the command sets the DSCP priority for IPv4 HWTACACS packets.
dscp-value: Specifies the DSCP priority of HWTACACS packets, in the range of 0 to 63. A larger value represents a higher priority.
To change the transmission priority of HWTACACS packets, change the DSCP priority for them.
DSCP priority is contained in the ToS field of the IPv4 header and in the Traffic Class field of the IPv6 header.
# Set the DSCP priority of IPv4 HWTACACS packets to 10.
[Sysname] hwtacacs dscp 10
hwtacacs nas-ip
Use hwtacacs nas-ip to specify a source IP address for outgoing HWTACACS packets.
Use undo hwtacacs nas-ip to delete the specified source IP address for outgoing HWTACACS packets.
hwtacacs nas-ip { interface interface-type interface-number | { ipv4-address | ipv6 ipv6-address } }
undo hwtacacs nas-ip { interface | { ipv4-address | ipv6 ipv6-address } }
The source IP address of an HWTACACS packet sent to the server is the primary IPv4 address or the IPv6 address of the outbound interface.
interface interface-type interface-number: Specifies a source interface by its type and number. The device uses the primary IPv4 address or the IPv6 address of the interface as the source IP address of an outgoing HWTACACS packet.
ipv4-address: Specifies an IPv4 address, which must be an address of the device. The IP address cannot be 0.0.0.0, 255.255.255.255, a class D address, a class E address, or a loopback address.
ipv6 ipv6-address: Specifies an IPv6 address, which must be a unicast address of the device and cannot be a loopback address or a link-local address.
The source IP address of HWTACACS packets that a NAS sends must match the IP address of the NAS that is configured on the HWTACACS server. An HWTACACS server identifies a NAS by IP address. Upon receiving an HWTACACS packet, the HWTACACS server checks the source IP address of the packet.
· If the source IP address of the packet is the IP address of a managed NAS, the server processes the packet.
· If the source IP address of the packet is not the IP address of a managed NAS, the server drops the packet.
As a best practice to avoid HWTACACS packet loss caused by physical port errors, specify a loopback interface address as the source IP address for outgoing HWTACACS packets.
If you use both the nas-ip command and hwtacacs nas-ip command, the following guidelines apply:
· The setting configured by using the nas-ip command in HWTACACS scheme view applies only to the HWTACACS scheme.
· The setting configured by using the hwtacacs nas-ip command in system view applies to all HWTACACS schemes.
· The setting in HWTACACS scheme view takes precedence over the setting in system view.
You can specify only one source IPv4 address and one source IPv6 address in system view.
You can specify only one source interface to provide the source IP address for outgoing HWTACACS packets. Make sure the route between the source interface and the HWTACACS server is reachable.
The source interface configuration and the source IP address configuration overwrite each other.
# Specify IP address 129.10.10.1 as the source IP address for HWTACACS packets.
[Sysname] hwtacacs nas-ip 129.10.10.1
nas-ip (HWTACACS scheme view)
hwtacacs scheme
Use hwtacacs scheme to create an HWTACACS scheme and enter its view, or enter the view of an existing HWTACACS scheme.
Use undo hwtacacs scheme to delete an HWTACACS scheme.
hwtacacs scheme hwtacacs-scheme-name
undo hwtacacs scheme hwtacacs-scheme-name
No HWTACACS schemes exist.
hwtacacs-scheme-name: Specifies the HWTACACS scheme name, a case-insensitive string of 1 to 32 characters.
An HWTACACS scheme can be used by more than one ISP domain at the same time.
You can configure a maximum of 16 HWTACACS schemes.
# Create an HWTACACS scheme named hwt1 and enter HWTACACS scheme view.
key (HWTACACS scheme view)
Use key to set the shared key for secure HWTACACS authentication, authorization, or accounting communication.
Use undo key to delete the shared key for secure HWTACACS authentication, authorization, or accounting communication.
key { accounting | authentication | authorization } { cipher | simple } string
undo key { accounting | authentication | authorization }
No shared key is configured for secure HWTACACS authentication, authorization, or accounting communication.
accounting: Specifies the shared key for secure HWTACACS accounting communication.
authentication: Specifies the shared key for secure HWTACACS authentication communication.
authorization: Specifies the shared key for secure HWTACACS authorization communication.
cipher: Specifies the key in encrypted form.
simple: Specifies the key in plaintext form. For security purposes, the key specified in plaintext form will be stored in encrypted form.
string: Specifies the key. This argument is case sensitive. The encrypted form of the key is a string of 1 to 373 characters. The plaintext form of the key is a string of 1 to 255 characters.
The shared keys configured on the device must match those configured on the HWTACACS servers.
# In HWTACACS scheme hwt1, set the shared key to 123456TESTauth&! in plaintext form for secure HWTACACS authentication communication.
[Sysname-hwtacacs-hwt1] key authentication simple 123456TESTauth&!
# Set the shared key to 123456TESTautr&! in plaintext form for secure HWTACACS authorization communication.
[Sysname-hwtacacs-hwt1] key authorization simple 123456TESTautr&!
# Set the shared key to 123456TESTacct&! in plaintext form for secure HWTACACS accounting communication.
[Sysname-hwtacacs-hwt1] key accounting simple 123456TESTacct&!
Use nas-ip to specify a source IP address for outgoing HWTACACS packets.
Use undo nas-ip to delete the specified source IP address for outgoing HWTACACS packets.
nas-ip { ipv4-address | interface interface-type interface-number | ipv6 ipv6-address }
undo nas-ip [ interface | ipv6 ]
The source IP address of an outgoing HWTACACS packet is that configured by using the hwtacacs nas-ip command in system view.
If the hwtacacs nas-ip command is not used, the source IP address is the primary IP address of the outbound interface.
For an HWTACACS scheme, the following restrictions apply:
· You can specify only one source IPv4 address and one source IPv6 address for outgoing HWTACACS packets.
· You can specify only one source interface to provide the source IP address for outgoing HWTACACS packets. Make sure the route between the source interface and the HWTACACS server is reachable.
· The source interface configuration and the source IP address configuration overwrite each other.
If you do not specify any parameter for the undo nas-ip command, the command deletes the configured source IPv4 address for outgoing HWTACACS packets.
# In HWTACACS scheme hwt1, specify IP address 10.1.1.1 as the source address for outgoing HWTACACS packets.
[Sysname-hwtacacs-hwt1] nas-ip 10.1.1.1
hwtacacs nas-ip
primary accounting (HWTACACS scheme view)
Use primary accounting to specify the primary HWTACACS accounting server.
Use undo primary accounting to restore the default.
primary accounting { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | single-connection ] *
The primary HWTACACS accounting server is not specified.
host-name: Specifies the host name of the primary HWTACACS accounting server, a case-insensitive string of 1 to 253 characters.
ipv4-address: Specifies an IPv4 address of the primary HWTACACS accounting server.
ipv6 ipv6-address: Specifies an IPv6 address of the primary HWTACACS accounting server.
port-number: Specifies the service port number of the primary HWTACACS accounting server. The value range for the TCP port number is 1 to 65535. The default setting is 49.
key: Specifies the shared key for secure communication with the primary HWTACACS accounting server.
single-connection: The device and the primary HWTACACS accounting server use the same TCP connection to exchange accounting packets for all users. If you do not specify this keyword, the device establishes a new TCP connection each time it exchanges accounting packets with the primary accounting server for a user.
Make sure the port number and shared key settings of the primary HWTACACS accounting server are the same as those configured on the server.
Two accounting servers specified for a scheme, primary or secondary, cannot have identical host name, IP address, and port number settings.
As a best practice, specify the single-connection keyword to reduce TCP connections for improving system performance if the HWTACACS server supports the single-connection method.
You can remove an accounting server only when it is not used for user accounting. Removing an accounting server affects only accounting processes that occur after the remove operation.
# In HWTACACS scheme hwt1, specify the primary accounting server with IP address 10.163.155.12, TCP port number 49, and plaintext shared key 123456TESTacct&!.
[Sysname-hwtacacs-hwt1] primary accounting 10.163.155.12 49 key simple 123456TESTacct&!
secondary accounting (HWTACACS scheme view)
primary authentication (HWTACACS scheme view)
Use primary authentication to specify the primary HWTACACS authentication server.
Use undo primary authentication to restore the default.
primary authentication { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | single-connection ] *
The primary HWTACACS authentication server is not specified.
host-name: Specifies the host name of the primary HWTACACS authentication server, a case-insensitive string of 1 to 253 characters.
ipv4-address: Specifies the IPv4 address of the primary HWTACACS authentication server.
ipv6 ipv6-address: Specifies the IPv6 address of the primary HWTACACS authentication server.
port-number: Specifies the service port number of the primary HWTACACS authentication server. The value range for the TCP port number is 1 to 65535. The default setting is 49.
key: Specifies the shared key for secure communication with the primary HWTACACS authentication server.
single-connection: The device and the primary HWTACACS authentication server use the same TCP connection to exchange all authentication packets for all users. If you do not specify this keyword, the device establishes a new TCP connection at each authentication.
Make sure the port number and shared key settings of the primary HWTACACS authentication server are the same as those configured on the server.
Two authentication servers specified for a scheme, primary or secondary, cannot have identical host name, IP address, and port number settings.
You can remove an authentication server only when it is not used for user authentication. Removing an authentication server affects only authentication processes that occur after the remove operation.
# In HWTACACS scheme hwt1, specify the primary authentication server with IP address 10.163.155.13, TCP port number 49, and plaintext shared key 123456TESTauth&!.
[Sysname-hwtacacs-hwt1] primary authentication 10.163.155.13 49 key simple 123456TESTauth&!
secondary authentication (HWTACACS scheme view)
primary authorization
Use primary authorization to specify the primary HWTACACS authorization server.
Use undo primary authorization to restore the default.
primary authorization { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | single-connection ] *
The primary HWTACACS authorization server is not specified.
host-name: Specifies the host name of the primary HWTACACS authorization server, a case-insensitive string of 1 to 253 characters.
ipv4-address: Specifies the IPv4 address of the primary HWTACACS authorization server.
ipv6 ipv6-address: Specifies the IPv6 address of the primary HWTACACS authorization server.
port-number: Specifies the service port number of the primary HWTACACS authorization server. The value range for the TCP port number is 1 to 65535. The default setting is 49.
key: Specifies the shared key for secure communication with the primary HWTACACS authorization server.
single-connection: The device and the primary HWTACACS authorization server use the same TCP connection to exchange all authorization packets for all users. If you do not specify this keyword, the device establishes a new TCP connection each time it exchanges authorization packets with the primary authorization server for a user.
Make sure the port number and shared key settings of the primary HWTACACS authorization server are the same as those configured on the server.
Two authorization servers specified for a scheme, primary or secondary, cannot have identical host name, IP address, and port number settings.
You can remove an authorization server only when it is not used for user authorization. Removing an authorization server affects only authorization processes that occur after the remove operation.
# In HWTACACS scheme hwt1, specify the primary authorization server with IP address 10.163.155.13, TCP port number 49, and plaintext shared key 123456TESTautr&!.
[Sysname-hwtacacs-hwt1] primary authorization 10.163.155.13 49 key simple 123456TESTautr&!
secondary authorization (HWTACACS scheme view)
Use reset hwtacacs statistics to clear HWTACACS statistics.
reset hwtacacs statistics { accounting | all | authentication | authorization }
accounting: Clears the HWTACACS accounting statistics.
all: Clears all HWTACACS statistics.
authentication: Clears the HWTACACS authentication statistics.
authorization: Clears the HWTACACS authorization statistics.
# Clear all HWTACACS statistics.
<Sysname> reset hwtacacs statistics all
Use reset stop-accounting-buffer to clear buffered HWTACACS stop-accounting requests to which no responses have been received.
reset stop-accounting-buffer hwtacacs-scheme hwtacacs-scheme-name
# Clear nonresponded stop-accounting requests buffered for HWTACACS scheme hwt1.
<Sysname> reset stop-accounting-buffer hwtacacs-scheme hwt1
Use retry stop-accounting to set the maximum number of transmission attempts for individual HWTACACS stop-accounting requests.
Use undo retry stop-accounting to restore the default.
retry stop-accounting retries
The maximum number of transmission attempts for individual HWTACACS stop-accounting requests is 100.
retries: Specifies the maximum number of transmission attempts for HWTACACS stop-accounting requests. The value range is 1 to 300.
# In HWTACACS scheme hwt1, set the maximum number of HWTACACS stop-accounting attempts to 300.
[Sysname-hwtacacs-hwt1] retry stop-accounting 300
timer response-timeout (HWTACACS scheme view)
Use secondary accounting to specify a secondary HWTACACS accounting server.
Use undo secondary accounting to remove a secondary HWTACACS accounting server.
secondary accounting { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | single-connection ] *
undo secondary accounting [ { host-name | ipv4-address | ipv6 ipv6-address } [ port-number ] ]
No secondary HWTACACS accounting servers are specified.
host-name: Specifies the host name of a secondary HWTACACS accounting server, a case-insensitive string of 1 to 253 characters.
ipv4-address: Specifies the IPv4 address of a secondary HWTACACS accounting server.
ipv6 ipv6-address: Specifies the IPv6 address of a secondary HWTACACS accounting server.
port-number: Specifies the service port number of the secondary HWTACACS accounting server. The value range for the TCP port number is 1 to 65535. The default setting is 49.
key: Specifies the shared key for secure communication with the secondary HWTACACS accounting server.
single-connection: The device and the secondary HWTACACS accounting server use the same TCP connection to exchange all accounting packets for all users. If you do not specify this keyword, the device establishes a new TCP connection each time it exchanges accounting packets with the secondary accounting server for a user.
Make sure the port number and shared key settings of the secondary HWTACACS accounting server are the same as those configured on the server.
An HWTACACS scheme supports a maximum of 16 secondary HWTACACS accounting servers. If the primary server fails, the device tries to communicate with a secondary server in active state. The device connects to the secondary servers in the order they are configured.
If you do not specify any parameters for the undo secondary accounting command, the command removes all secondary accounting servers.
# In HWTACACS scheme hwt1, specify a secondary accounting server with IP address 10.163.155.12, TCP port number 49, and plaintext shared key 123456TESTacct&!.
[Sysname-hwtacacs-hwt1] secondary accounting 10.163.155.12 49 key simple 123456TESTacct&!
Use secondary authentication to specify a secondary HWTACACS authentication server.
Use undo secondary authentication to remove a secondary HWTACACS authentication server.
secondary authentication { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | single-connection ] *
undo secondary authentication [ { host-name | ipv4-address | ipv6 ipv6-address } [ port-number ] ]
No secondary HWTACACS authentication servers are specified.
host-name: Specifies the host name of a secondary HWTACACS authentication server, a case-insensitive string of 1 to 253 characters.
ipv4-address: Specifies the IPv4 address of a secondary HWTACACS authentication server.
ipv6 ipv6-address: Specifies the IPv6 address of a secondary HWTACACS authentication server.
port-number: Specifies the service port number of the secondary HWTACACS authentication server. The value range for the TCP port number is 1 to 65535. The default setting is 49.
key: Specifies the shared key for secure communication with the secondary HWTACACS authentication server.
single-connection: The device and the secondary HWTACACS authentication server use the same TCP connection to exchange all authentication packets for all users. If you do not specify this keyword, the device establishes a new TCP connection each time it exchanges authentication packets with the secondary authentication server for a user.
Make sure the port number and shared key settings of each secondary HWTACACS authentication server are the same as those configured on the corresponding server.
An HWTACACS scheme supports a maximum of 16 secondary HWTACACS authentication servers. If the primary server fails, the device tries to communicate with a secondary server in active state. The device connects to the secondary servers in the order they are configured.
If you do not specify any parameters for the undo secondary authentication command, the command removes all secondary authentication servers.
# In HWTACACS scheme hwt1, specify a secondary authentication server with IP address 10.163.155.13, TCP port number 49, and plaintext shared key 123456TESTauth&!.
[Sysname-hwtacacs-hwt1] secondary authentication 10.163.155.13 49 key simple 123456TESTauth&!
Use secondary authorization to specify a secondary HWTACACS authorization server.
Use undo secondary authorization to remove a secondary HWTACACS authorization server.
secondary authorization { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | single-connection ] *
undo secondary authorization [ { host-name | ipv4-address | ipv6 ipv6-address } [ port-number ] ]
No secondary HWTACACS authorization servers are specified.
host-name: Specifies the host name of a secondary HWTACACS authorization server, a case-insensitive string of 1 to 253 characters.
ipv4-address: Specifies the IPv4 address of a secondary HWTACACS authorization server.
ipv6 ipv6-address: Specifies the IPv6 address of a secondary HWTACACS authorization server.
port-number: Specifies the service port number of the secondary HWTACACS authorization server. The value range for the TCP port number is 1 to 65535. The default setting is 49.
key: Specifies the shared key for secure communication with the secondary HWTACACS authorization server.
single-connection: The device and the secondary HWTACACS authorization server use the same TCP connection to exchange all authorization packets for all users. If you do not specify this keyword, the device establishes a new TCP connection each time it exchanges authorization packets with the secondary authorization server for a user.
Make sure the port number and shared key settings of the secondary HWTACACS authorization server are the same as those configured on the server.
An HWTACACS scheme supports a maximum of 16 secondary HWTACACS authorization servers. If the primary server fails, the device tries to communicate with a secondary server in active state. The device connects to the secondary servers in the order they are configured.
If you do not specify any parameters for the undo secondary authorization command, the command removes all secondary authorization servers.
# In HWTACACS scheme hwt1, specify a secondary authorization server with IP address 10.163.155.13, TCP port number 49, and plaintext shared key 123456TESTautr&!.
[Sysname-hwtacacs-hwt1] secondary authorization 10.163.155.13 49 key simple 123456TESTautr&!
primary authorization (HWTACACS scheme view)
Use stop-accounting-buffer enable to enable buffering of HWTACACS stop-accounting requests to which no responses have been received.
Use undo stop-accounting-buffer enable to disable buffering of HWTACACS stop-accounting requests to which no responses have been received.
The device buffers HWTACACS stop-accounting requests to which no responses have been received.
This command enables the device to buffer an HWTACACS stop-accounting request to which no response has been received. The device resends the buffered request until it receives a server response or when the number of transmission attempts reaches the maximum (set by using the retry stop-accounting command). If no more attempts are available, the device discards the request. However, if you have removed an accounting server, stop-accounting requests destined for the server are not buffered.
# Enable buffering of HWTACACS stop-accounting requests to which no responses have been received.
[Sysname-hwtacacs-hwt1] stop-accounting-buffer enable
timer quiet (HWTACACS scheme view)
Use timer quiet to set the quiet timer for the servers specified in an HWTACACS scheme.
timer quiet minutes
undo timer quiet
The server quiet period is 5 minutes.
# In HWTACACS scheme hwt1, set the server quiet timer to 10 minutes.
[Sysname-hwtacacs-hwt1] timer quiet 10
timer realtime-accounting (HWTACACS scheme view)
timer realtime-accounting minutes
minutes: Specifies the real-time accounting interval in minutes, in the range of 0 to 60. Setting this interval to 0 disables the device from sending online user accounting information to the HWTACACS accounting server.
For real-time accounting, a NAS must transmit the accounting information of online users to the HWTACACS accounting server periodically. This command is used to set the interval.
Table 28 Recommended real-time accounting intervals
Number of users |
1 to 99 |
3 minutes |
100 to 499 |
6 minutes |
500 to 999 |
12 minutes |
1000 or more |
# In HWTACACS scheme hwt1, set the real-time accounting interval to 51 minutes.
[Sysname-hwtacacs-hwt1] timer realtime-accounting 51
Use timer response-timeout to set the HWTACACS server response timeout timer.
The HWTACACS server response timeout time is 5 seconds.
seconds: Specifies the HWTACACS server response timeout time, in the range of 1 to 300 seconds.
HWTACACS is based on TCP. When the server response timeout timer or the TCP timeout timer times out, the device is disconnected from the HWTACACS server.
The client timeout period of the associated access module cannot be shorter than the total response timeout timer of all HWTACACS servers in the scheme. Any violation will result in user logoffs before the authentication, authorization, or accounting process is complete.
# In HWTACACS scheme hwt1, set the HWTACACS server response timeout timer to 30 seconds.
[Sysname-hwtacacs-hwt1] timer response-timeout 30
Use user-name-format to specify the format of the username to be sent to an HWTACACS server.
The ISP domain name is included in the usernames sent to an HWTACACS server.
keep-original: Sends the username to the HWTACACS server as the username is entered.
with-domain: Includes the ISP domain name in the username sent to the HWTACACS server.
without-domain: Excludes the ISP domain name from the username sent to the HWTACACS server.
A username is generally in the userid@isp-name format, of which the isp-name argument is used by the device to determine the ISP domain to which a user belongs. However, some HWTACACS servers cannot recognize a username containing an ISP domain name. Before sending a username including a domain name to such an HWTACACS server, the device must remove the domain name. This command allows you to specify whether to include a domain name in a username to be sent to an HWTACACS server.
If an HWTACACS scheme defines that the username is sent without the ISP domain name, do not apply the scheme to more than one ISP domain. Otherwise, the HWTACACS server will consider two users in different ISP domains but with the same userid as one user.
If the HWTACACS scheme is used for wireless users, specify the format of the username to be sent from the access device to the HWTACACS server as keep-original. Otherwise, authentication of the wireless users might fail.
# In HWTACACS scheme hwt1, configure the device to remove the ISP domain name from the usernames sent to the HWTACACS servers.
[Sysname-hwtacacs-hwt1] user-name-format without-domain
LDAP commands
attribute-map
Use attribute-map to specify the LDAP attribute map in an LDAP scheme.
Use undo attribute-map to restore the default.
attribute-map map-name
undo attribute-map
An LDAP scheme does not use an LDAP attribute map.
LDAP scheme view
map-name: Specifies an LDAP attribute map by its name, a case-insensitive string of 1 to 31 characters.
When the LDAP scheme used for authorization contains an LDAP attribute map, the device converts server-assigned LDAP attributes to device-recognizable AAA attributes based on the mapping entries.
You can specify only one LDAP attribute map in an LDAP scheme. If you execute this command multiple times, the most recent configuration takes effect.
If you specify another attribute map or change the mapping entries, the new settings take effect only on the LDAP authorization that occurs after your operation.
# Specify LDAP attribute map map1 in LDAP scheme ldap1.
[Sysname] ldap scheme ldap1
[Sysname-ldap-ldap1] attribute-map map1
display ldap scheme
ldap attribute-map
authentication-server
Use authentication-server to specify the LDAP authentication server for an LDAP scheme.
Use undo authentication-server to restore the default.
authentication-server server-name
No LDAP authentication server is specified for an LDAP scheme.
LDAP scheme view
server-name: Specifies the name of an LDAP server, a case-insensitive string of 1 to 64 characters.
You can specify only one LDAP authentication server in an LDAP scheme. If you execute this command multiple times, the most recent configuration takes effect.
# In LDAP scheme ldap1, specify the LDAP authentication server as ccc.
[Sysname-ldap-ldap1] authentication-server ccc
display ldap scheme
ldap server
authorization-server
Use authorization-server to specify the LDAP authorization server for an LDAP scheme.
Use undo authorization-server to restore the default.
authorization-server server-name
No LDAP authorization server is specified for an LDAP scheme.
LDAP scheme view
You can specify only one LDAP authorization server in an LDAP scheme. If you execute this command multiple times, the most recent configuration takes effect.
# In LDAP scheme ldap1, specify the LDAP authorization server as ccc.
[Sysname-ldap-ldap1] authorization-server ccc
display ldap scheme
ldap server
display ldap scheme
Use display ldap scheme to display LDAP scheme configuration.
display ldap scheme [ ldap-scheme-name ]
ldap-scheme-name: Specifies an LDAP scheme by its name, a case-insensitive string of 1 to 32 characters. If you do not specify an LDAP scheme, this command displays the configuration of all LDAP schemes.
# Display the configuration of all LDAP schemes.
<Sysname> display ldap scheme
Total 1 LDAP schemes
LDAP scheme name : aaa
Authentication server : aaa
IP : 1.1.1.1
Port : 111
VPN instance : Not configured
LDAP protocol version : LDAPv3
Server timeout interval : 10 seconds
Login account DN : Not configured
Base DN : Not configured
Search scope : all-level
User searching parameters:
User object class : Not configured
Username attribute : cn
Username format : with-domain
Group filter : (objectclass=group)
Authorization server : aaa
IP : 1.1.1.1
Port : 111
Attribute map : map1
Table 29 Command output
Authentication server |
Name of the LDAP authentication server. If no server is configured, this field displays Not configured. |
Authorization server |
Name of the LDAP authorization server. If no server is configured, this field displays Not configured. |
IP |
IP address of the LDAP server. If no server is specified, this field displays Not configured. |
Port |
Port number of the server. If no port number is specified, this field displays the default port number. |
VPN instance |
This field is not supported in the current software version. MPLS L3VPN instance to which the LDAP server belongs. If no VPN instance is specified, this field displays Not configured. |
LDAP protocol version |
LDAP version, LDAPv2 or LDAPv3. |
Server timeout interval |
LDAP server timeout period, in seconds. |
Login account DN |
DN of the administrator. |
Base DN |
Base DN for user search. |
Search scope |
User DN search scope, including: · all-level—All subdirectories. · single-level—Next lower level of subdirectories under the base DN. |
User searching parameters |
User search parameters. |
User object class |
User object class for user DN search. If no user object class is configured, this field displays Not configured. |
Username attribute |
User account attribute for login. |
Username format |
Format for the username sent to the server. |
Group filter |
User group filter. |
Attribute map |
LDAP attribute map used by the scheme. If no LDAP attribute map is used, this field displays Not configured. |
group-filter
Use group-filter to configure the user group filter.
Use undo group-filter to restore the default.
group-filter group-filter
undo group-filter
The user group filter is (objectclass=group).
LDAP server view
group-filter: Specifies the user group filter, a case-sensitive string of 1 to 127 characters. The syntax of the filter must meet the filter syntax requirements defined by LDAP servers.
When the device requests to import user group information from an LDAP server, the LDAP server sends only user groups that match the user group filter to the device.
# Configure the user group filter as (&(objectclass=group)(name=group1)) for LDAP server ccc.
[Sysname] ldap server ccc
[Sysname-ldap-server-ccc] group-filter (&(objectclass=group)(name=group1))
display ldap scheme
ip
Use ip to configure the IP address of the LDAP server.
Use undo ip to restore the default.
ip ip-address [ port port-number ]
undo ip
An LDAP server does not have an IP address.
LDAP server view
ip-address: Specifies the IP address of the LDAP server.
port port-number: Specifies the TCP port number of the LDAP server. The value range for the port-number argument is 1 to 65535, and the default value is 389.
The LDAP service port configured on the device must be consistent with the service port of the LDAP server.
If you change the IP address and port number of the LDAP server, the change takes effect only on the LDAP authentication that occurs after the change.
# Specify the IP address and port number as 192.168.0.10 and 4300 for LDAP server ccc.
[Sysname-ldap-server-ccc] ip 192.168.0.10 port 4300
ldap server
ipv6
Use ipv6 to configure the IPv6 address of the LDAP server.
Use undo ipv6 to restore the default.
ipv6 ipv6-address [ port port-number ]
undo ipv6
An LDAP server does not have an IPv6 address.
LDAP server view
ipv6-address: Specifies the IPv6 address of the LDAP server.
# Specify the IPv6 address and port number as 1:2::3:4 and 4300 for LDAP server ccc.
[Sysname-ldap-server-ccc] ipv6 1:2::3:4 port 4300
ldap server
ldap attribute-map
Use ldap attribute-map to create an LDAP attribute map and enter its view, or enter the view of an existing LDAP attribute map.
Use undo ldap attribute-map to delete an LDAP attribute map.
ldap attribute-map map-name
undo ldap attribute-map map-name
No LDAP attribute maps exist.
map-name: Specifies the name of the LDAP attribute map, a case-insensitive string of 1 to 31 characters.
Execute this command multiple times to create multiple LDAP attribute maps. You can add multiple mapping entries to an LDAP attribute map. Each entry defines the mapping between an LDAP attribute and an AAA attribute.
# Create an LDAP attribute map named map1 and enter LDAP attribute map view.
[Sysname] ldap attribute-map map1
[Sysname-ldap-map-map1]
attribute-map
ldap scheme
map
ldap scheme
Use ldap scheme to create an LDAP scheme and enter its view, or enter the view of an existing LDAP scheme.
Use undo ldap scheme to delete an LDAP scheme.
ldap scheme ldap-scheme-name
undo ldap scheme ldap-scheme-name
No LDAP schemes exist.
ldap-scheme-name: Specifies the LDAP scheme name, a case-insensitive string of 1 to 32 characters.
An LDAP scheme can be used by more than one ISP domain at the same time.
You can configure a maximum of 16 LDAP schemes.
# Create an LDAP scheme named ldap1 and enter LDAP scheme view.
display ldap scheme
ldap server
Use ldap server to create an LDAP server and enter its view, or enter the view of an existing LDAP server.
Use undo ldap server to delete an LDAP server.
ldap server server-name
undo ldap server server-name
No LDAP servers exist.
server-name: Specifies the LDAP server name, a case-insensitive string of 1 to 64 characters.
# Create an LDAP server named ccc and enter LDAP server view.
display ldap scheme
login-dn
Use login-dn to specify the administrator DN.
Use undo login-dn to restore the default.
login-dn dn-string
undo login-dn
No administrator DN is specified.
LDAP server view
dn-string: Specifies the administrator DN for binding with the server, a case-insensitive string of 1 to 255 characters.
The administrator DN specified on the device must be consistent with the administrator DN configured on the LDAP server.
If you change the administrator DN, the change takes effect only on the LDAP authentication that occurs after the change.
# Specify the administrator DN as uid=test, ou=people, o=example, c=city for LDAP server ccc.
[Sysname-ldap-server-ccc] login-dn uid=test,ou=people,o=example,c=city
display ldap scheme
login-password
Use login-password to configure the administrator password for binding with the LDAP server during LDAP authentication.
Use undo login-password to restore the default.
login-password { cipher | simple } string
undo login-password
No administrator password is configured.
LDAP server view
string: Specifies the password. Its plaintext form is a case-sensitive string of 1 to 128 characters. Its encrypted form is a case-sensitive string of 1 to 201 characters.
This command takes effect only after the login-dn command is used.
# Specify the administrator password as abcdefg in plaintext form for LDAP server ccc.
[Sysname-ldap-server-ccc] login-password simple abcdefg
display ldap scheme
login-dn
map
Use map to configure a mapping entry in an LDAP attribute map.
Use undo map to delete the specified mapping entries from the LDAP attribute map.
map ldap-attribute ldap-attribute-name [ prefix prefix-value delimiter delimiter-value ] aaa-attribute { user-group | user-profile }
undo map [ ldap-attribute ldap-attribute-name ]
An LDAP attribute map does not contain mapping entries.
ldap-attribute ldap-attribute-name: Specifies an LDAP attribute by its name. The ldap-attribute-name argument is a case-insensitive string of 1 to 63 characters.
prefix prefix-value delimiter delimiter-value: Specifies a partial value string of the LDAP attribute for attribute mapping. The prefix-value argument represents the position where the partial string starts. The prefix is a case-insensitive string of 1 to 7 characters, such as cn=. The delimiter-value argument represents the position where the partial string ends, such as a comma (,). If you do not specify the prefix prefix-value delimiter delimiter-value option, the mapping entry uses the entire value string of the LDAP attribute.
aaa-attribute: Specifies an AAA attribute.
user-group: Specifies the user group attribute.
user-profile: Specifies the user profile attribute.
Because the device ignores unrecognized LDAP attributes, configure the mapping entries to include important LDAP attributes that should not be ignored.
An LDAP attribute can be mapped only to one AAA attribute. Different LDAP attributes can be mapped to the same AAA attribute.
If you do not specify an LDAP attribute for the undo map command, the command deletes all mapping entries from the LDAP attribute map.
# In LDAP attribute map map1, map a partial value string of the LDAP attribute named memberof to AAA attribute named user-group.
[Sysname-ldap-map-map1] map ldap-attribute memberof prefix cn= delimiter , aaa-attribute user-group
ldap attribute-map
user-group
user-profile
protocol-version
Use protocol-version to specify the LDAP version.
Use undo protocol-version to restore the default.
protocol-version { v2 | v3 }
The LDAP version is LDAPv3.
LDAP server view
v2: Specifies the LDAP version LDAPv2.
v3: Specifies the LDAP version LDAPv3.
For successful LDAP authentication, the LDAP version used by the device must be consistent with the version used by the LDAP server.
If you change the LDAP version, the change takes effect only on the LDAP authentication that occurs after the change.
A Microsoft LDAP server supports only LDAPv3.
# Specify the LDAP version as LDAPv2 for LDAP server ccc.
[Sysname-ldap-server-ccc] protocol-version v2
display ldap scheme
search-base-dn
Use search-base-dn to specify the base DN for user search.
Use undo search-base-dn to restore the default.
search-base-dn base-dn
undo search-base-dn
No base DN is specified for user search.
LDAP server view
base-dn: Specifies the base DN for user search, a case-insensitive string of 1 to 255 characters.
# Specify the base DN for user search as dc=ldap,dc=com for LDAP server ccc.
[Sysname-ldap-server-ccc] search-base-dn dc=ldap,dc=com
display ldap scheme
ldap server
search-scope
Use search-scope to specify the user search scope.
Use undo search-scope to restore the default.
search-scope { all-level | single-level }
undo search-scope
The user search scope is all-level.
LDAP server view
all-level: Specifies that the search goes through all subdirectories of the base DN.
single-level: Specifies that the search goes through only the next lower level of subdirectories under the base DN.
# Specify the search scope for the LDAP authentication as all subdirectories of the base DN for LDAP server ccc.
[Sysname-ldap-server-ccc] search-scope all-level
display ldap scheme
ldap server
server-timeout
Use server-timeout to set the LDAP server timeout period, the maximum time that the device waits for an LDAP response.
Use undo server-timeout to restore the default.
server-timeout time-interval
undo server-timeout
The LDAP server timeout period is 10 seconds.
LDAP server view
time-interval: Specifies the LDAP server timeout period in the range of 5 to 20 seconds.
If you change the LDAP server timeout period, the change takes effect only on the LDAP authentication that occurs after the change.
# Set the LDAP server timeout period to 15 seconds for LDAP server ccc.
[Sysname-ldap-server-ccc] server-timeout 15
display ldap scheme
user-parameters
Use user-parameters to configure LDAP user attributes, including the username attribute, username format, and user-defined user object class.
Use undo user-parameters to restore the default of an LDAP user attribute.
user-parameters { user-name-attribute { name-attribute | cn | uid } | user-name-format { with-domain | without-domain } | user-object-class object-class-name }
undo user-parameters { user-name-attribute | user-name-format | user-object-class }
The LDAP username attribute is cn and the username format is without-domain. No user object class is specified and the default user object class of the LDAP server is used.
LDAP server view
user-name-attribute { name-attribute | cn | uid }: Specifies the username attribute. The name-attribute argument represents an attribute value, a case-insensitive string of 1 to 64 characters. The cn keyword represents the user account attribute of common name, and the uid keyword represents the user account attribute of user ID.
user-name-format { with-domain | without-domain }: Specifies the format of the username to be sent to the server. The with-domain keyword means that the username contains the domain name, and the without-domain keyword means that the username does not contain the domain name.
user-object-class object-class-name: Specifies the user object class for user search. The object-class-name argument represents a class value, a case-insensitive string of 1 to 64 characters.
If the username on the LDAP server does not contain the domain name, specify the without-domain keyword. If the username contains the domain name, specify the with-domain keyword.
# Set the user object class to person for LDAP server ccc.
[Sysname-ldap-server-ccc] user-parameters user-object-class person
display ldap scheme
login-dn
RADIUS server commands
display radius-server active-client
Use display radius-server active-client to display information about activated RADIUS clients.
# Display information about all activated RADIUS clients.
<Sysname> display radius-server active-client
Total 2 RADIUS clients.
Client IP: 2.2.2.2
Client IP: 3.3.3.3
Table 30 Command output
Total 2 RADIUS clients |
Total number of activated RADIUS clients. |
Client IP |
IP address of the RADIUS client. |
radius-server client
display radius-server active-eap-profile
Use display radius-server active-eap-profile to display information about the activated EAP profile.
# Display information about the activated EAP profile.
<Sysname> display radius-server active-eap-profile
Method : PEAP-MSCHAPv2
CA file : ca.pem
Certificate file : server.pem
Private key file : server.pem
Table 31 Command output
Method |
EAP authentication method. |
CA file |
Name of the CA certificate file. |
Certificate file |
Name of the local certificate file. |
Private key file |
Name of the private key file. |
radius-server eap-profile
display radius-server active-ldap-scheme
Use display radius-server active-ldap-scheme to display information about the activated LDAP scheme.
# Display information about the activated LDAP scheme.
<Sysname> display radius-server active-ldap-scheme
IP : 1.1.1.1
Administrator DN : cn=manager,dc=test,dc=com
Base DN : dc=test,dc=com
Table 32 Command output
IP |
IP address of the LDAP server. |
Base DN |
radius-server ldap-scheme
display radius-server active-user
Use display radius-server active-user to display information about activated RADIUS users.
display radius-server active-user [ user-name ]
user-name: Specifies a RADIUS user name, a case-sensitive string of 1 to 55 characters. The name must meet the following requirements:
· Cannot contain a domain name.
· Cannot contain any of the following characters: forward slash (/), backslash (\), vertical bar (|), colon (:), asterisk (*), question mark (?), left angle bracket (<), right angle bracket (>), or at sign (@).
· Cannot be a, al, or all.
If you do not specify a RADIUS user name, this command displays information about all activated RADIUS users.
# Display information about the activated RADIUS user named test.
<Sysname> display radius-server active-user test
Total 1 RADIUS users matched.
Username: test
Description: A network access user from company cc
Authorization attributes:
VLAN ID: 2
ACL number: 2000
Validity period:
Expiration time: 2020/02/03-18:00:00
# Display information about all activated RADIUS users.
Total 2 RADIUS users matched.
Username: 123
VLAN ID: 2
ACL number: 3000
Validity period:
Username: 456
VLAN ID: 2
ACL number: Not configured
Validity period:
Expiration time: Not configured
Table 33 Command output
Username |
Name of the RADIUS user. |
Description of the RADIUS user. |
Authorization attributes |
Authorization attributes of the RADIUS user. |
VLAN ID |
Authorization VLAN. |
ACL number |
Authorization ACL. |
Validity period |
Validity time period of the RADIUS user. |
Expiration time |
Expiration date and time of the RADIUS user. |
local-user
radius-server activate
Use radius-server activate to restart the RADIUS server process and activate the RADIUS server configuration.
At startup, the device automatically starts the RADIUS server process and activates the RADIUS server configuration (including RADIUS client, RADIUS user, EAP profile, and LDAP scheme configuration).
Use this command to restart the RADIUS server process and activate the most recent RADIUS server configuration after you perform any of the following operations:
· Add, modify, or delete RADIUS clients or RADIUS users.
· Change the EAP profile settings (configured in EAP profile view) or LDAP scheme settings (configured in LDAP scheme view) specified for the RADIUS server.
When the RADIUS server process is restarting, the device cannot provide authentication services for RADIUS users as a RADIUS server.
# Restart the RADIUS server process and activate the RADIUS server configuration.
[Sysname] radius-server activate
radius-server deactivate
Use radius-server client to specify a RADIUS client.
Use undo radius-server client to delete a RADIUS client.
radius-server client ip ipv4-address key { cipher | simple } string
undo radius-server client { all | ip ipv4-address }
No RADIUS clients are specified.
ip ipv4-address: Specifies the IPv4 address of the RADIUS client, which must be a Class A, B, or C address and the first octet cannot be 0 or 127.
key: Specifies the shared key used by the RADIUS server to communicate with the RADIUS client.
string: Specifies a case-sensitive key string. The encrypted form of the key is a string of 1 to 117 characters. The plaintext form of the key is a string of 1 to 64 characters.
all: Specifies all RADIUS clients.
The IP address of a RADIUS client must be the same as the source IP address for outgoing RADIUS packets specified on the RADIUS client.
The shared key of a RADIUS client must be the same as the setting on the RADIUS client.
You can execute this command multiple times to specify multiple RADIUS clients.
# Specify host at IP address 2.2.2.2 as a RADIUS client and set the shared key to test in plaintext form.
[Sysname] radius-server client ip 2.2.2.2 key simple test
Use radius-server deactivate to shut down the RADIUS server process and deactivate the RADIUS server configuration.
If the RADIUS server process is shut down, the device cannot provide authentication services for RADIUS users as a RADIUS server.
# Shut down the RADIUS server process and deactivate the RADIUS server configuration.
[Sysname] radius-server deactivate
Use radius-server eap-profile to specify the EAP profile for the RADIUS server.
Use undo radius-server eap-profile to restore the default.
radius-server eap-profile eap-profile-name
No EAP profile is specified for the RADIUS server.
eap-profile-name: Specifies an EAP profile by its name, a case-sensitive string of 1 to 32 characters. You must specify an existing EAP profile.
After startup, the RADIUS server uses the EAP authentication method and related parameters in the EAP profile to interact with managed RADIUS clients.
The EAP profile takes effect only after the RADIUS server configuration is activated by using the radius-server activate command.
If you execute the radius-server eap-profile command multiple times, the most recent configuration takes effect.
# Specify EAP profile eap1 for the RADIUS server.
[Sysname] radius-server eap-profile eap1
eap-profile
Use radius-server ldap-scheme to specify the LDAP scheme for the RADIUS server.
Use undo radius-server ldap-scheme to restore the default.
radius-server ldap-scheme ldap-scheme-name
No LDAP scheme is specified for the RADIUS server.
ldap-scheme-name: Specifies an LDAP scheme by its name, a case-insensitive string of 1 to 64 characters. You must specify an existing LDAP scheme.
After startup, the RADIUS server cooperates with the LDAP server specified in the LDAP scheme and uses the related parameters to authenticate users.
For the RADIUS server to start up successfully, make sure an available and reachable LDAP server is specified in the LDAP scheme.
The LDAP scheme takes effect only after the RADIUS server configuration is activated by using the radius-server activate command.
If you execute the radius-server ldap-scheme command multiple times, the most recent configuration takes effect.
# Specify LDAP scheme ldap1 for the RADIUS server.
[Sysname] radius-server ldap-scheme ldap1
ldap scheme
ITA policy commands
accounting-level
Use accounting-level to specify a traffic level for ITA accounting.
Use undo accounting-level to remove the ITA accounting configuration for a traffic level.
accounting-level level { { ipv4 | ipv6 } | car { inbound cir committed-information-rate [ pir peak-information-rate ] | outbound cir committed-information-rate [ pir peak-information-rate ] } * } *
undo accounting-level [ level ]
No traffic levels are specified for ITA accounting.
ITA policy view
level: Specifies a traffic level in the range of 1 to 8.
ipv4: Counts the traffic as IPv4 traffic.
ipv6: Counts the traffic as IPv6 traffic.
car: Specifies a CAR action for the level of traffic. If you do not specify this keyword, no CAR action is applied to the level of traffic.
inbound: Specifies the incoming traffic.
outbound: Specifies the outgoing traffic.
cir committed-information-rate: Specifies the committed information rate in kbps. The value range for the committed-information-rate argument is 8 to 10000000.
pir peak-information-rate: Specifies the peak information rate in kbps. The value range for the peak-information-rate argument is 8 to 10000000. The peak information rate cannot be smaller than the committed information rate. If you do not specify this option, the CAR action does not restrict traffic by peak information rate.
By defining different traffic levels based on the destination addresses of users' traffic, you can use ITA to separate the traffic accounting statistics of different levels for each user.
Execute this command multiple times to specify multiple traffic levels for ITA accounting or specify CAR actions for each traffic level. If you specify only CAR actions for a traffic level without specifying the ipv4 or ipv6 keyword, the device does not perform ITA accounting on the traffic of that level.
If you do not specify a level for the undo accounting-level command, this command removes the ITA accounting configuration for all traffic levels in the ITA policy.
If the IP protocol type specified for a traffic level is different from the actual IP protocol type, the device counts the traffic of this level as the traffic of the specified IP protocol.
# In ITA policy ita1, specify traffic levels 2 and 5, and count the level-2 traffic as IPv4 traffic and the level-5 traffic as IPv6 traffic.
[Sysname] ita policy ita1
[Sysname-ita-policy-ita1] accounting-level 2 ipv4
[Sysname-ita-policy-ita1] accounting-level 5 ipv6
display ita policy
accounting-merge enable
Use accounting-merge enable to enable the accounting merge feature.
Use undo accounting-merge enable to disable the accounting merge feature.
The accounting merge feature is disabled.
ITA policy view
When accounting merge is enabled, the device merges accounting statistics for the ITA traffic of all levels in the ITA policy. It reports the traffic as the lowest level of the policy to the accounting server.
# Enable the accounting merge feature for ITA policy ita1.
[Sysname-ita-policy-ita1] accounting-merge enable
display ita policy
accounting-method
Use accounting-method to configure the accounting method for an ITA policy.
Use undo accounting-method to restore the default.
accounting-method { none | radius-scheme radius-scheme-name [ none ] }
The default accounting method of an ITA policy is none.
ITA policy view
none: Does not perform accounting.
radius-scheme radius-scheme-name: Specifies a RADIUS scheme by its name, a case-insensitive string of 1 to 32 characters.
Use this command to configure accounting methods for an ITA policy. ITA accounting is separated from accounting of other services.
You can specify one primary accounting method and one backup accounting method for an ITA policy.
When the primary method is invalid, the device uses the backup method. For example, the accounting-method radius-scheme radius-scheme-name none command specifies RADIUS accounting as the primary method and no accounting as the backup method. The device performs RADIUS accounting by default and does not perform accounting when RADIUS accounting is invalid.
The remote accounting method is invalid in the following situations:
· The specified accounting scheme does not exist.
· Accounting packet sending fails.
· The device does not receive any accounting response packets from an accounting server.
The local accounting method is invalid if the device fails to find the matching local user configuration.
# Specify RADIUS accounting scheme radius1 for ITA policy ita1.
[Sysname-ita-policy-ita1] accounting-method radius-scheme radius1
display ita policy
radius scheme
display ita policy
Use display ita policy to display ITA policy information.
display ita policy [ policy-name ]
policy-name: Specifies an ITA policy by its name, a case-insensitive string of 1 to 31 characters. If you do not specify an ITA policy, this command displays information about all ITA policies.
# Display information about all ITA policies.
<Sysname> display ita policy
Total 2 ITA policies.
ITA policy: ita1
Accounting method : RADIUS=Rd1, None
Accounting merge : Enabled
Accounting levels :
Level 1 IPv4
Inbound CAR: CIR 100 kbps PIR 200 kbps
Outbound CAR: CIR 100 kbps PIR 200 kbps
Level 2 IPv6
Inbound CAR: CIR 300 kbps PIR 400 kbps
Level 3 IPv4
Level 8 IPv6
Traffic separation : Enabled
Separated levels: 1, 2, 3, 4
Traffic quota-out action: Online
Send accounting update: No
ITA policy: ita2
Accounting method : None
Accounting merge : Disabled
Accounting levels : None
Traffic separation : Disabled
Send accounting update: Yes
Table 34 Command output
ITA policy |
ITA policy name. |
Accounting merge |
Status of the accounting merge feature: · Enabled—The accounting merge feature is enabled. The device merges the ITA traffic of all accounting rates in the ITA policy, and applies the lowest rate to the merged traffic. · Disabled—The accounting merge feature is disabled. The device sends separate traffic statistics for each accounting rate to the server. |
Accounting levels |
ITA traffic accounting levels: · Level m IPv4—Applies accounting level m to IPv4 traffic. The value range for the m argument is 1 to 8. · Level n IPv6—Applies accounting level n to IPv6 traffic. The value range for the n argument is 1 to 8. · None—No ITA traffic accounting level is configured. |
Inbound CAR |
Inbound CAR: · CIR—Committed information rate in kbps. · PIR—Peak information rate in kbps. |
Outbound CAR |
Outbound CAR: · CIR—Committed information rate in kbps. · PIR—Peak information rate in kbps. |
Traffic separation |
Whether the amount of ITA traffic is excluded from the overall traffic statistics sent to the accounting server: · Enabled—The amount of specific-level ITA traffic is excluded from the overall traffic statistics. · Disabled—ITA traffic is included in the overall traffic statistics. |
Separated levels |
Levels of ITA traffic of which statistics are excluded from the overall traffic statistics sent to the accounting server. |
Traffic quota-out action |
Access control for users that have used up their ITA data quotas: · Online—Users can access the authorized IP subnets after their ITA data quotas are used up. · Offline—Users cannot access the authorized IP subnets after their ITA data quotas are used up. |
Send accounting update |
Whether to send accounting-update packets to refresh users' data quotas: · Yes. · No. |
ita policy
Use ita policy to create an ITA policy and enter its view, or enter the view of an existing ITA policy.
Use undo ita policy to delete an ITA policy.
ita policy policy-name
undo ita policy policy-name
No ITA policies exist.
policy-name: Specifies the ITA policy name, a case-insensitive string of 1 to 31 characters.
# Create an ITA policy named ita1 and enter ITA policy view.
display ita policy
traffic-quota-out
Use traffic-quota-out to configure access control for users that have used up their ITA data quotas.
Use undo traffic-quota-out to restore the default.
traffic-quota-out { offline | online } [ no-accounting-update ]
The device sends accounting-update packets to the server to request new data quotas for the users that have used up their data quotas. A user cannot access the authorized IP subnets if the device does not receive any new data quota from the server for the user.
ITA policy view
offline: Prohibits users from accessing the authorized IP subnets after their ITA data quotas are used up.
online: Permits users to access the authorized IP subnets after their ITA data quotas are used up.
no-accounting-update: Disables the device from sending accounting-update requests to refresh the users' quotas.
The server might divide the data quota of a user into multiple portions and assign a portion to the user each time. If the server does not support dividing user data quota, specify the no-accounting-update keyword to decrease the burden of the server as a best practice.
# In ITA policy ita1, prohibit users from accessing the authorized IP subnets after their ITA data quotas are used up.
[Sysname-ita-policy-ita1] traffic-quota-out offline
display ita policy
traffic-separate enable
Use traffic-separate enable to exclude the amount of specific-level ITA traffic from the overall traffic statistics that are sent to the accounting server.
Use undo traffic-separate enable to restore the default for an ITA traffic level.
traffic-separate enable [ level level&<1-8> ]
undo traffic-separate enable [ level level&<1-8> ]
The amount of ITA traffic is included in the overall traffic statistics that are sent to the accounting server.
ITA policy view
level level&<1-8>: Specifies a space-separated list of up to eight ITA traffic levels. If you do not specify an ITA traffic level, this command excludes the amount of ITA traffic at all levels from the overall traffic statistics that are sent to the accounting server. This option is not supported by portal users.
# In ITA policy ita1, exclude the amount of level-1 ITA traffic from the overall traffic statistics that are sent to the accounting server.
[Sysname-ita-policy-ita1] traffic-separate enable level 1
accounting-level
display ita policy
Connection recording policy commands
aaa connection-recording policy
Use aaa connection-recording policy to create a connection recording policy and enter its view, or enter the view of an existing connection recording policy.
Use aaa connection-recording policy to delete the connection recording policy.
undo aaa connection-recording policy
The connection recording policy does not exist.
Use this feature on scenarios where the device acts as an FTP, SSH, SFTP, or Telnet login client to establish a connection with a login server. This feature enables the device to provide an accounting server with the connection start and termination information. When the login client establishes a connection with the login server, the system sends a start-accounting request to the accounting server. When the connection is terminated, the system sends a stop-accounting request to the accounting server.
# Create a connection recording policy and enter its view.
[Sysname] aaa connection-recording policy
[sysname-connection-recording-policy]
accounting hwtacacs-scheme
display aaa connection-recording policy
Use accounting hwtacacs-scheme to specify the accounting method for the connection recording policy.
Use undo accounting to restore the default.
accounting hwtacacs-scheme hwtacacs-scheme-name
undo accounting
No accounting method is specified for the connection recording policy. No accounting is performed on the connections initiated by the device as a login client.
Connection recording policy view
hwtacacs-scheme-name: Specifies an HWTACACS scheme by its name, a case-insensitive string of 1 to 32 characters.
If the accounting method is changed, the new method takes effect only on subsequent connections initiated by the device as a login client.
For a connection, once the device sends the start-accounting request to an HWTACACS server, it sends the connection's stop-accounting packet to the same server.
The device includes the username entered by a user in the accounting packets to be sent to the AAA server for connection recording. The username format configured by using the user-name-format command in the accounting scheme does not take effect.
# Create a connection recording policy, and specify HWTACACS scheme tac as the accounting method.
[sysname-connection-recording-policy] accounting hwtacacs-scheme tac
Use display aaa connection-recording policy to display the connection recording policy configuration.
# Display the connection recording policy configuration.
<Sysname> display aaa connection-recording policy
Connection-recording policy:
Accounting scheme: HWTACACS=tac1
