15-ACL and QoS Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C MSR1000[2600][3600] Routers Configuration Guides(V9)-R9119-6W10015-ACL and QoS Configuration Guide
05-Flowspec configuration
05-Flowspec configuration 190.13 KB
Configuring Flowspec
About Flowspec
The flow specification (Flowspec) feature allows you to filter and manage illegal traffic in BGP networks, therefore mitigating the effects of DoS and DDoS attacks. Flowspec classifies attack traffic and takes action on classified traffic, such as drop, redirect, or rate limit.
Flowspec device roles
The following Flowspec device roles are involved in a Flowspec network:
·     Flowspec router—A BGP router in a BGP network, also called a Flowspec controller. A Flowspec router distributes Flowspec rules (match criteria and actions) to Flowspec edge routers through BGP updates.
·     Flowspec edge router—A BGP router in a BGP network, also called a Flowspec client. A Flowspec edge router receives Flowspec rules from a Flowspec router and applies the match criteria and actions to its forwarding plane.
When configuring Flowspec, select one BGP router as the Flowspec router and all other BGP routers as Flowspec edge routers.
How Flowspec works
To support Flowspec, MP-BGP defines the Flowspec IPv4 address family, Flowspec VPNv4 address family, Flowspec IPv6 address family, and Flowspec VPNv6 address family, and introduces Flowspec Network Layer Reachability Information (NLRI), called Flowspec routes. Flowspec can distribute Flowspec rules (match criteria and actions) to the public network and VPN instances through the defined address families.
As shown in Figure 1, the Flowspec router distributes Flowspec rules to Flowspec edge routers. After receiving Flowspec rules, a Flowspec edge router applies the criteria and actions to its forwarding plane. A Flowspec router can also distribute Flowspec rules to other ASs. This enables you to filter and control attack traffic on the device closest to the attack source.
Figure 1 How Flowspec works
Protocols and standards
·     RFC 5575, Dissemination of Flow Specification Rules
·     RFC 7674, Clarification of the Flowspec Redirect Extended Community
Prerequisites for Flowspec configuration
Before you configure Flowspec, you must configure basic BGP functions on the Flowspec router and Flowspec edge routers. For information about configuring basic BGP functions, see Layer 3—IP Routing Configuration Guide.
Configuring IPv4 Flowspec
IPv4 Flowspec tasks at a glance
To configure IPv4 Flowspec, perform the following tasks:
1.     Creating and activating an IPv4 Flowspec rule
Perform this task only on the Flowspec router.
2.     Applying an IPv4 Flowspec rule
¡     Applying an IPv4 Flowspec rule to the public network
¡     Applying an IPv4 Flowspec rule to a VPN instance
3.     Enabling BGP to distribute IPv4 Flowspec rules
¡     Enabling BGP to distribute public network IPv4 Flowspec rules
¡     Enabling BGP to distribute private network IPv4 Flowspec rules
¡     Enabling BGP to distribute VPNv4 Flowspec rules
Perform this task on both the Flowspec router and Flowspec edge routers.
4.     (Optional.) Configuring BGP Flowspec route reflection
2.     Create an IPv4 Flowspec rule and enter IPv4 Flowspec rule view.
flow-route flowroute-name
3.     Configure a match criterion.
if-match match-criteria
By default, no match criterion is configured.
4.     Apply an action. Choose one option as needed:
¡     Drop packets.
apply action
¡     Redirect packets to a next hop.
apply redirect next-hop { ipv4-address [ copy-mode ] | ipv6-address }
¡     Redirect packets to an SR-MPLS TE policy.
apply redirect next-hop ipv4-address color color
This command is not supported in the current software version.
¡     Redirect packets to an SRv6 TE policy.
apply redirect next-hop ipv6-address color color [ sid sid-value ]
¡     Redirect packets to a route target.
apply redirect vpn-target import-vpn-target
¡     Mark packets with a DSCP value.
apply remark-dscp dscp-value
¡     Rate limit packets.
apply traffic-rate rate
By default, no action is configured.
5.     (Optional.) Display the match criteria and actions that are not committed.
check flow-route-configuration
6.     Commit match criteria and actions.
commit
By default, match criteria and actions are not committed.
2.     Enter Flowspec view.
flowspec
3.     Create a Flowspec IPv4 address family for the public network and enter its view.
address-family ipv4
4.     Apply an IPv4 Flowspec rule to the public network.
By default, no IPv4 Flowspec rule is applied to the public network.
2.     Configure a VPN instance.
a.     Create a VPN instance and enter VPN instance view.
b.     Configure an RD for the VPN instance.
By default, no RD is configured for a VPN instance.
c.     Configure route targets for the VPN instance.
vpn-target { vpn-target&<1-8> [ both | export-extcommunity | import-extcommunity ] }
By default, no route targets are configured.
For more information about the ip vpn-instance, route-distinguisher, and vpn-target commands, see MPLS L3VPN commands in MPLS Command Reference.
3.     Enter the IPv4 Flowspec address family view of the VPN instance.
address-family ipv4 flowspec
4.     Configure an RD for the IPv4 Flowspec address family.
By default, no RD is configured for the IPv4 Flowspec address family.
5.     Configure route targets for the IPv4 Flowspec address family.
By default, no route targets are configured for the IPv4 Flowspec address family.
The route targets configured must be the same as the route targets configured previously for the VPN instance.
6.     Execute the quit command twice to return to system view.
7.     Enter Flowspec view.
flowspec
8.     Create a Flowspec IPv4 address family and associate the address family with the VPN instance.
address-family ipv4 vpn-instance vpn-instance-name
9.     Apply an IPv4 Flowspec rule to the Flowspec IPv4 VPN instance address family.
By default, no IPv4 Flowspec rule is applied to a Flowspec IPv4 VPN instance address family.
About BGP Flowspec rule distribution
By default, the device validates received IPv4 Flowspec rules and their redirection next hops (if present).
An IPv4 Flowspec rule is valid if the following conditions exist:
·     The Flowspec rule contains a destination address match criterion.
·     The device that receives the rule has routes with the destination address for matching as their destination address.
For the device to take the action on matching traffic without validation, disable validation of IPv4 Flowspec rules.
A redirection next hop is valid if the following conditions exist:
·     A route exists on the device with the redirection next hop as the route's next hop.
·     The next hop IP address and the device are in the same AS.
For the device to take the action of redirecting traffic to a next hop without validation, disable validation of the redirection next hops.
The BGP Flowspec rule distribution feature not only distributes IPv4 Flowspec rules in BGP routes to Flowspec edge routers but also makes those IPv4 Flowspec rules take effect on the Flowspec router itself.
Restrictions and guidelines for enabling BGP to distribute Flowspec rules
For more information about the bgp and peer enable commands, see basic BGP commands in Layer 3—IP Routing Command Reference.
2.     Execute the following commands in sequence to enter BGP IPv4 Flowspec address family view:
3.     Enable BGP Flowspec peers to exchange routing information.
By default, BGP Flowspec peers cannot exchange routing information.
4.     (Optional.) Disable validation of IPv4 Flowspec rules from BGP Flowspec peers.
peer { group-name | ip-address [ mask-length ] | ipv6-address [ prefix-length ] } validation-disable
By default, IPv4 Flowspec rules from BGP Flowspec peers will be validated.
5.     (Optional.) Disable validation of the redirection next hops in IPv4 Flowspec rules from BGP Flowspec peers.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } validation-redirect-disable
By default, the redirection next hops in IPv4 Flowspec rules from BGP Flowspec peers will be validated.
6.     (Optional.) Configure the device to not change the next hop of routes advertised to EBGP peers.
peer { group-name | ip-address [ mask-length ] | ipv6-address [ prefix-length ] } next-hop-invariable
By default, the device uses its own IP address as the next hop of IPv4 routes advertised to EBGP peers.
7.     (Optional.) Enable recursion to tunnels for IPv4 Flowspec rules with an action of redirecting to a next hop.
redirect ip recursive-lookup tunnel [ tunnel-selector tunnel-selector-name ]
By default, recursion to tunnels is disabled for IPv4 Flowspec rules with an action of redirecting to a next hop.
2.     Execute the following commands in sequence to enter BGP-VPN IPv4 Flowspec address family view:
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } validation-disable
By default, IPv4 Flowspec rules from BGP Flowspec peers are validated.
2.     Execute the following commands in sequence to enter BGP VPNv4 Flowspec address family view:
address-family vpnv4 flowspec
4.     (Optional.) Configure the device to not change the next hop of VPNv4 routes advertised to EBGP peers.
By default, the device uses its own IP address as the next hop of VPNv4 routes advertised to EBGP peers.
Route reflection reduces the number of IBGP connections in an AS. In an AS, you can configure a BGP route reflector and its clients. The route reflector and its clients automatically form a cluster identified by the router ID of the route reflector. The route reflector forwards route updates among its clients, which do not need to establish connections with one another.
2.     Enter one of the following views:
¡     Execute the following commands in sequence to enter BGP IPv4 Flowspec address family view:
¡     Execute the following commands in sequence to enter BGP-VPN IPv4 Flowspec address family view:
¡     Execute the following commands in sequence to enter BGP VPNv4 Flowspec address family view:
3.     Configure the router as a route reflector and specify a peer or peer group as its client.
By default, no route reflector or client is configured.
4.     (Optional.) Disable route target filtering for received BGP VPNv4 Flowspec routes.
undo policy vpn-target
By default, route target filtering is enabled for received VPNv4 routes. The VPNv4 routes whose export route target attribute matches the local import route target attribute are added to the routing table.
This command is available only in BGP VPNv4 Flowspec address family view.
5.     (Optional.) Enable route reflection between clients.
reflect between-clients
By default, route reflection between clients is enabled.
6.     (Optional.) Configure the cluster ID of the route reflector.
By default, a route reflector uses its own router ID as the cluster ID.
Configuring IPv6 Flowspec
IPv6 Flowspec tasks at a glance
To configure IPv6 Flowspec, perform the following tasks:
1.     Creating and activating an IPv6 Flowspec rule
2.     Applying an IPv6 Flowspec rule
¡     Applying an IPv6 Flowspec rule to the public network
¡     Applying an IPv6 Flowspec rule to a VPN instance
3.     Enabling BGP to distribute IPv6 Flowspec rules
¡     Enabling BGP to distribute public network IPv6 Flowspec rules
¡     Enabling BGP to distribute private network IPv6 Flowspec rules
¡     Enabling BGP to distribute VPNv6 Flowspec rules
2.     Create an IPv6 Flowspec rule and enter IPv6 Flowspec rule view.
flow-route flowroute-name ipv6
¡     Drop packets.
apply action
apply redirect next-hop { ipv4-address | ipv6-address [ copy-mode ] }
commit
flowspec
3.     Create a Flowspec IPv6 address family for the public network and enter its view.
address-family ipv6
4.     Apply an IPv6 Flowspec rule to the public network.
By default, no IPv6 Flowspec rule is applied to the public network.
3.     Enter the IPv6 Flowspec address family view of the VPN instance.
address-family ipv6 flowspec
4.     Execute the quit command twice to return to system view.
5.     Enter Flowspec view.
flowspec
6.     Create a Flowspec IPv6 address family and associate the address family with the VPN instance.
address-family ipv6 vpn-instance vpn-instance-name
7.     Apply an IPv6 Flowspec rule to the Flowspec IPv6 VPN instance address family.
By default, no IPv6 Flowspec rule is applied to a Flowspec IPv6 VPN instance address family.
2.     Execute the following commands in sequence to enter BGP IPv6 Flowspec address family view:
4.     (Optional.) Disable validation of IPv6 Flowspec rules from BGP Flowspec peers.
By default, IPv6 Flowspec rules from BGP Flowspec peers are validated.
5.     (Optional.) Disable validation of the redirection next hops in IPv6 Flowspec rules from BGP Flowspec peers.
By default, the redirection next hops in IPv6 Flowspec rules from BGP Flowspec peers are validated.
By default, the device uses its own IP address as the next hop of IPv6 routes advertised to EBGP peers.
7.     (Optional.) Enable recursion to tunnels for IPv6 Flowspec rules with an action of redirecting to a next hop.
By default, recursion to tunnels is disabled for IPv6 Flowspec rules with an action of redirecting to a next hop.
2.     Execute the following commands in sequence to enter BGP-VPN IPv6 Flowspec address family view:
2.     Execute the following commands in sequence to enter BGP VPNv6 Flowspec address family view:
address-family vpnv6 flowspec
4.     (Optional.) Configure the device to not change the next hop of VPNv6 routes advertised to EBGP peers.
By default, the device uses its own IP address as the next hop of VPNv6 routes advertised to EBGP peers.
¡     Execute the following commands in sequence to enter BGP IPv6 Flowspec address family view:
¡     Execute the following commands in sequence to enter BGP-VPN IPv6 Flowspec address family view:
¡     Execute the following commands in sequence to enter BGP VPNv6 Flowspec address family view:
4.     (Optional.) Disable route target filtering for received BGP VPNv6 Flowspec routes.
By default, route target filtering is enabled for received VPNv6 routes. The VPNv6 routes whose export route target attribute matches the local import route target attribute are added to the routing table.
This command is available only in BGP VPNv6 Flowspec address family view.
Verifying and maintaining Flowspec
For more information about the commands not covered in this feature, see Layer 3—IP Routing Command Reference.
Verifying Flowspec rule running status
To display Flowspec rule running status, execute the following command in any view:
display flow-route { { ipv4 | ipv6 } all | flow-route-id } [ slot slot-number ]
display flow-route { { ipv4 | ipv6 } [ vpn-instance vpn-instance-name ] | flow-route-id } [ slot slot-number ]
Displaying Flowspec peer information
·     Display IPv4 BGP Flowspec peer information.
display bgp [ instance instance-name ] peer ipv4 flowspec [ vpn-instance vpn-instance-name ] [ ipv4-address mask-length | ipv6-address prefix-length | { ipv4-address | ipv6-address | group-name group-name } log-info | [ ipv4-address | ipv6-address ] verbose ]
·     Display IPv6 BGP Flowspec peer information.
display bgp [ instance instance-name ] peer ipv6 flowspec [ vpn-instance vpn-instance-name ] ] [ ipv4-address mask-length | ipv6-address prefix-length | { ipv4-address | ipv6-address | group-name group-name } log-info | [ ipv4-address | ipv6-address ] verbose ]
·     Display BGP VPNv4 Flowspec peer information.
display bgp [ instance instance-name ] peer vpnv4 flowspec [ ipv4-address mask-length | ipv6-address prefix-length | { ipv4-address | ipv6-address | group-name group-name } log-info | [ ipv4-address | ipv6-address ] verbose ]
·     Display BGP VPNv6 Flowspec peer information.
display bgp [ instance instance-name ] peer vpnv6 flowspec [ ipv4-address mask-length | ipv6-address prefix-length| { ipv4-address | ipv6-address | group-name group-name } log-info | [ ipv4-address | ipv6-address ] verbose ]
·     Display IPv4 BGP Flowspec peer group information.
display bgp [ instance instance-name ] group ipv4  flowspec [ vpn-instance vpn-instance-name ] [ group-name group-name ]
·     Display IPv6 BGP Flowspec peer group information.
display bgp [ instance instance-name ] group ipv6  flowspec [ vpn-instance vpn-instance-name ] [ group-name group-name ]
Displaying Flowspec routing information
·     Display BGP IPv4 Flowspec routing information.
display bgp [ instance instance-name ] routing-table ipv4 flowspec [ vpn-instance vpn-instance-name ] [ flowspec-prefix [ advertise-info ] | statistics ]
display bgp [ instance instance-name ] routing-table ipv4 flowspec [ vpn-instance vpn-instance-name ] peer { ipv4-address | ipv6-address } { advertised-routes | received-routes } [ flowspec-prefix | statistics ]
·     Display BGP IPv6 Flowspec routing information.
display bgp [ instance instance-name ] routing-table ipv6 flowspec [ vpn-instance vpn-instance-name ] [ flowspec-prefix [ advertise-info ] | statistics ]
display bgp [ instance instance-name ] routing-table ipv6 flowspec [ vpn-instance vpn-instance-name ] peer { ipv4-address | ipv6-address } { advertised-routes | received-routes } [ flowspec-prefix | statistics ] ]
·     Display BGP VPNv4 Flowspec routing information.
display bgp [ instance instance-name ] routing-table vpnv4 flowspec [ peer ipv4-address { advertised-routes | received-routes } [ flowspec-prefix | statistics ] | [ route-distinguisher route-distinguisher ] [ flowspec-prefix [ advertise-info ] ] | statistics ]
·     Display BGP VPNv6 Flowspec routing information.
display bgp [ instance instance-name ] routing-table vpnv6 flowspec [ peer ipv6-address { advertised-routes | received-routes } [ flowspec-prefix | statistics ] | [ route-distinguisher route-distinguisher ] [ flowspec-prefix [ advertise-info ] ] | statistics ]
Displaying BGP IPv4 Flowspec update group information
·     Display BGP IPv4 Flowspec update group information.
display bgp [ instance instance-name ] update-group ipv4 flowspec [ ipv4-address | ipv6-address ]
·     Display BGP IPv6 Flowspec update group information.
display bgp [ instance instance-name ] update-group ipv6 flowspec [ ipv4-address | ipv6-address ]
·     Display BGP VPNv4 Flowspec update group information.
display bgp [ instance instance-name ] update-group vpnv4 flowspec [ ipv4-address | ipv6-address ]
·     Display BGP VPNv6 Flowspec update group information.
display bgp [ instance instance-name ] update-group vpnv6 flowspec [ ipv4-address | ipv6-address ]
Manually soft-resetting BGP sessions
Perform soft-reset tasks in user view.
·     Manually soft-reset BGP sessions for an IPv4 Flowspec address family.
refresh bgp [ instance instance-name ] { ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | all | external | group group-name | internal } { export | import } ipv4 flowspec
·     Manually soft-reset BGP sessions for an IPv6 Flowspec address family.
refresh bgp [ instance instance-name ] { ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | all | external | group group-name | internal } { export | import } ipv6 flowspec
·     Manually soft-reset BGP sessions for a VPNv4 Flowspec address family.
refresh bgp [ instance instance-name ] { ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | all | external | group group-name | internal } { export | import } vpnv4 flowspec
·     Manually soft-reset BGP sessions for a VPNv6 Flowspec address family.
refresh bgp [ instance instance-name ] { ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | all | external | group group-name | internal } { export | import } vpnv6 flowspec
Resetting BGP sessions
Perform reset tasks in user view.
·     Reset BGP sessions for a BGP IPv4 Flowspec address family.
reset bgp [ instance instance-name ] { as-number | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | all | external | group group-name | internal } ipv4 flowspec [ vpn-instance vpn-instance-name ]
·     Reset BGP sessions for a BGP IPv6 Flowspec address family.
reset bgp [ instance instance-name ] { as-number | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | all | external | group group-name | internal } ipv6  flowspec [ vpn-instance vpn-instance-name ]
·     Reset BGP sessions for a BGP VPNv4 Flowspec address family.
reset bgp [ instance instance-name ] { as-number | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | all | external | internal | group group-name } vpnv4 flowspec
·     Reset BGP sessions for a BGP VPNv6 Flowspec address family.
reset bgp [ instance instance-name ] { as-number | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | all | external | internal | group group-name } vpnv6 flowspec
Clearing Flowspec rule statistics
Perform clear tasks in user view.
·     Clear IPv4 Flowspec rule statistics.
reset flow-route statistics ipv4 [ all | vpn-instance vpn-instance-name ]
·     Clear IPv6 Flowspec rule statistics.
reset flow-route statistics ipv6 [ all | vpn-instance vpn-instance-name ]
·     Clear all Flowspec rule statistics.
reset flow-route statistics all
·     Clear statistics for a Flowspec rule.
reset flow-route statistics flow-route-id
Flowspec configuration examples
Example: Configuring IPv4 Flowspec
As shown in Figure 2, all routers run BGP. Device A is a Flowspec router, and Device B is a Flowspec edge router.
Configure Flowspec to limit the rate of incoming packets with destination IP address 1.1.1.0/24 and port 10 on Device B.
Figure 2 Network diagram
1.     Assign IP addresses to interfaces. (Details not shown.)
2.     Configure Device A:
# Configure a BGP connection.
[DeviceA] bgp 100
[DeviceA-bgp-default] peer 10.1.1.2 as-number 200
[DeviceA-bgp-default] address-family ipv4 flowspec
[DeviceA-bgp-default-flowspec-ipv4] peer 10.1.1.2 enable
[DeviceA-bgp-default-flowspec-ipv4] peer 10.1.1.2 validation-disable
[DeviceA-bgp-flowspec-ipv4] quit
[DeviceA-bgp-default] quit
# Configure a Flowspec rule.
[DeviceA] flow-route route1
[DeviceA-flow-route-route1] if-match destination-ip 1.1.1.0 24
[DeviceA-flow-route-route1] if-match destination-port 10
[DeviceA-flow-route-route1] apply traffic-rate 20
[DeviceA-flow-route-route1] check flow-route-configuration
Traffic filtering rules:
 Destination ip   :  1.1.1.0 255.255.255.0
 Destination port :  10
Traffic filtering actions:
 Traffic rate : 20(kbps)
[DeviceA-flow-route-route1] commit
[DeviceA-flow-route-route1] quit
# Apply the Flowspec rule to the public network.
[DeviceA] flowspec
[DeviceA-flowspec] address-family ipv4
[DeviceA-flowspec-ipv4] flow-route route1
[DeviceA-flowspec-ipv4] quit
3.     Configure Device B:
[DeviceB] bgp 200
[DeviceB-bgp-default] peer 10.1.1.1 as-number 100
[DeviceB-bgp-default] address-family ipv4 flowspec
[DeviceB-bgp-default-flowspec-ipv4] peer 10.1.1.1 enable
[DeviceB-bgp-default-flowspec-ipv4] peer 10.1.1.1 validation-disable
[DeviceB-bgp-default-flowspec-ipv4] quit
[DeviceB-bgp-default] quit
# On Device A, display BGP IPv4 Flowspec peer information.
[DeviceA] display bgp peer ipv4 flowspec
 BGP local router ID: 192.168.150.1
 Local AS number: 100
 Total number of peers: 1                 Peers in established state: 1
  * - Dynamically created peer
  10.1.1.2               200       10       12    0       0 00:06:40 Established
# On Device B, display BGP IPv4 Flowspec peer information.
[DeviceB] display bgp peer ipv4 flowspec
BGP local router ID: 192.168.150.2
 Local AS number: 200
  10.1.1.1               100       10       12    0       0 00:06:40 Established
# On Device B, display BGP IPv4 Flowspec routing information.
[DeviceB] display bgp routing-table ipv4 flowspec
Total number of routes: 1
 BGP local router ID is 192.168.150.2
 Status codes: * - valid, > - best, d - dampened, h - history
               a - additional-path
* >e DEST:1.1.1.0/24/40
                        0.0.0.0                    100        0       ?
# On Device B, display information about all Flowspec rules.
<DeviceB> display flow-route ipv4 all
Total number of flow-routes: 1
Flow-Route (ID 0x0)
  BGP instance : default
   Destination IP   : 1.1.1.0 255.255.255.0
